No u-boot-rockchip pull request sent or merged for v2022.04
Hi Tom,
I have a few Rockchip-related series [1] that I was expecting to land for v2022.04 (including improvements for chromebook_bob, support for the chromebook_kevin board, rk3399 eMMC fixes) but there hasn't been a u-boot-rockchip pull request since the one for v2022.01 [2]. There's also more pending patches from other people [3].
Kever seems unresponsive, last message to the mailing list was that pull request in December 2021. I did send on-list mails as To: Kever whenever Simon happened to poke me about chromebook_kevin not being merged, but to no avail.
What should be done here, any advice?
Sorry for being quite late with this, Alper.
[1] Patches by me https://patchwork.ozlabs.org/project/uboot/list/?submitter=78732
[2] Pull request: u-boot-rockchip-20211226 https://lore.kernel.org/u-boot/c12f6f2b-8c5a-654a-ad6a-5aed4a93874a@rock-chi...
[3] Patches assigned to Kever Yang https://patchwork.ozlabs.org/project/uboot/list/?delegate=93623
On Fri, Mar 11, 2022 at 12:05:42AM +0300, Alper Nebi Yasak wrote:
Hi Tom,
I've been hoping for something to show up soon myself. To start with, are there any rockchip related regression fixes you're aware of?
I haven't been paying enough attention to others' patches. For those of mine, I think I can only call my RK3399 eMMC fix [1] a regression fix. IIRC it has been broken since v2021.10 on some boards (but not all).
[1] rockchip: sdhci: Fix RK3399 eMMC PHY power cycling https://patchwork.ozlabs.org/project/uboot/patch/20220128224240.4226-3-alper...
Hi.
On Fri, 11 Mar 2022 at 11:16, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
Apler, would you be interested in being a co-maintainer for Rockchip?
I very much want to get your other patches landed too, particularly the 'kevin' ones as I have that board in my lab.
I can try. Not sure how much I'll be able to help (both time and knowledge-wise), I only have a chromebook_kevin and just know few things about rk3399 stuff at best, learning as I go along. But I would like to help.
Me too. Would they go into -next and v2022.07 at this point?
Well, how self contained is it all?
It's this series [1], the first three patches only affect chromebook_bob (board/google/gru, dts, configs). The final patch for chromebook_kevin adds a single define to linux-event-codes.h, duplicates some bob code and Kconfig already in arch/arm/mach-rockchip, in addition to kevin-specific files.
[1] Improve support for Bob chromebook and add support for Kevin https://patchwork.ozlabs.org/project/uboot/list/?series=278350
I mean the first patches only affect chromebook_bob as kevin isn't there yet, those changes still apply to or are copied to kevin by the final patch. (Didn't sound right when I re-read it so wanted to clarify.)
Hi Tom, Simon, Philipp,
Thanks for your help, I think my spare time is getting back and I can handle the work of patch review and verify on different SoCs/boards for u-boot-rockchip now.
I will land patches and fixes which is ready to land to master for v2022.04 and others to for-next for v2022.07.
On Fri, 11 Mar 2022 at 19:15, Alper Nebi Yasak alpernebiyasak@gmail.com wrote:
For the regressions, I could try help moving them forward (i.e., build-test and reviewing) next week, but I don't have a test setup with any Rockchip boards available at the moment.
Philipp.
For regression stuff, I'm happy to just pick it up and run the build testing.
Hi Alper,
The eMMC driver is always not robust enough on mainline U-Boot, eg. there still have many
offlist patches on rockchip branch to make all the SoCs work(we do try to upstream them before), and the patch series you
mentioned which broken the chromebook_kevin board is one of patch want to clean up and support
rk3568, so I think we also need to test this fix on rk3568 board.
Thanks, - Kever
Well, Tom applied the patch to master. I also received a modified version of patch 4/4 of that series as fixed for RK3568 SDK, so I assume the merged one (2/4) does work on that board without modification.
Hi Alper,
We do the verify on rk3568 board and this patch set do broken rk3568, though if only pick 2/4 works.
We have debug and fix it, Yifeng should already share the updated working version of patch 4/4 to you off list,
please help to send the new version once ready, so that I can land all the patches.
Thanks, - Kever
Hi Alper,
Sorry for reply late, I apologize for not able to make a pull request for v2022.04 till now, I'm really busy for pass few weeks, the reason including some change from both my work and my family.
I will check the patches on the list for u-boot-rockchip and land them once I have check the patch and works on my boards.
Thanks, - Kever On 2022/3/11 05:05, Alper Nebi Yasak wrote:
Hi Tom,
participants (5)
Alper Nebi Yasak
Kever Yang
Philipp Tomsich
