[U-Boot] [PATCH 1/2] tegra: add SDMMC1 on SDIO1 funcmux entry
This will be used on TrimSlice.
Signed-off-by: Stephen Warren swarren@nvidia.com --- arch/arm/cpu/armv7/tegra2/funcmux.c | 7 +++++++ arch/arm/include/asm/arch-tegra2/funcmux.h | 1 + 2 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/tegra2/funcmux.c b/arch/arm/cpu/armv7/tegra2/funcmux.c index 1559869..820ba4e 100644 --- a/arch/arm/cpu/armv7/tegra2/funcmux.c +++ b/arch/arm/cpu/armv7/tegra2/funcmux.c @@ -127,6 +127,13 @@ int funcmux_select(enum periph_id id, int config) } break;
+ case PERIPH_ID_SDMMC1: + if (config == FUNCMUX_SDMMC1_SDIO1_4BIT) { + pinmux_set_func(PINGRP_SDIO1, PMUX_FUNC_SDIO1); + pinmux_tristate_disable(PINGRP_SDIO1); + } + break; + case PERIPH_ID_SDMMC2: if (config == FUNCMUX_SDMMC2_DTA_DTD_8BIT) { pinmux_set_func(PINGRP_DTA, PMUX_FUNC_SDIO2); diff --git a/arch/arm/include/asm/arch-tegra2/funcmux.h b/arch/arm/include/asm/arch-tegra2/funcmux.h index 19184d1..b16c496 100644 --- a/arch/arm/include/asm/arch-tegra2/funcmux.h +++ b/arch/arm/include/asm/arch-tegra2/funcmux.h @@ -44,6 +44,7 @@ enum { FUNCMUX_I2C3_DTF = 0,
/* SDMMC configs */ + FUNCMUX_SDMMC1_SDIO1_4BIT = 0, FUNCMUX_SDMMC2_DTA_DTD_8BIT = 0, FUNCMUX_SDMMC3_SDB_4BIT = 0, FUNCMUX_SDMMC3_SDB_SLXA_8BIT,
Signed-off-by: Stephen Warren swarren@nvidia.com --- MAINTAINERS | 1 + board/compulab/dts/tegra2-trimslice.dts | 57 ++++++++++++++++++++ board/compulab/trimslice/Makefile | 49 +++++++++++++++++ board/compulab/trimslice/trimslice.c | 76 ++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/trimslice.h | 89 +++++++++++++++++++++++++++++++ 6 files changed, 273 insertions(+), 0 deletions(-) create mode 100644 board/compulab/dts/tegra2-trimslice.dts create mode 100644 board/compulab/trimslice/Makefile create mode 100644 board/compulab/trimslice/trimslice.c create mode 100644 include/configs/trimslice.h
diff --git a/MAINTAINERS b/MAINTAINERS index 7c161db..9d35c0e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -912,6 +912,7 @@ Stephen Warren swarren@nvidia.com
ventana Tegra2 (ARM7 & A9 Dual Core) paz00 Tegra2 (ARM7 & A9 Dual Core) + trimslice Tegra2 (ARM7 & A9 Dual Core) whistler Tegra2 (ARM7 & A9 Dual Core)
Thomas Weber weber@corscience.de diff --git a/board/compulab/dts/tegra2-trimslice.dts b/board/compulab/dts/tegra2-trimslice.dts new file mode 100644 index 0000000..c707eb8 --- /dev/null +++ b/board/compulab/dts/tegra2-trimslice.dts @@ -0,0 +1,57 @@ +/dts-v1/; + +/include/ ARCH_CPU_DTS + +/ { + model = "Compulab TrimSlice board"; + compatible = "compulab,trimslice", "nvidia,tegra20"; + + aliases { + usb0 = "/usb@c5008000"; + }; + + memory { + reg = <0x00000000 0x40000000>; + }; + + clocks { + clk_32k: clk_32k { + clock-frequency = <32000>; + }; + osc { + clock-frequency = <12000000>; + }; + }; + + clock@60006000 { + clocks = <&clk_32k &osc>; + }; + + serial@70006000 { + clock-frequency = <216000000>; + }; + + i2c@7000c000 { + status = "disabled"; + }; + + i2c@7000c400 { + status = "disabled"; + }; + + i2c@7000c500 { + status = "disabled"; + }; + + i2c@7000d000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; + + usb@c5004000 { + status = "disabled"; + }; +}; diff --git a/board/compulab/trimslice/Makefile b/board/compulab/trimslice/Makefile new file mode 100644 index 0000000..bf624f4 --- /dev/null +++ b/board/compulab/trimslice/Makefile @@ -0,0 +1,49 @@ +# +# (C) Copyright 2010-2012 +# NVIDIA Corporation <www.nvidia.com> +# +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +ifneq ($(OBJTREE),$(SRCTREE)) +$(shell mkdir -p $(obj)../../nvidia/common) +endif + +LIB = $(obj)lib$(BOARD).o + +COBJS := $(BOARD).o +COBJS += ../../nvidia/common/board.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/compulab/trimslice/trimslice.c b/board/compulab/trimslice/trimslice.c new file mode 100644 index 0000000..3d50999 --- /dev/null +++ b/board/compulab/trimslice/trimslice.c @@ -0,0 +1,76 @@ +/* + * (C) Copyright 2010-2012 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <i2c.h> +#include <asm/io.h> +#include <asm/arch/tegra2.h> +#include <asm/arch/clock.h> +#include <asm/arch/funcmux.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/mmc.h> +#include <asm/gpio.h> +#ifdef CONFIG_TEGRA2_MMC +#include <mmc.h> +#endif + +/* + * Routine: gpio_config_uart + * Description: Does nothing on TrimSlice - no UART-related GPIOs. + */ +void gpio_config_uart(void) +{ +} + +/* + * Routine: pin_mux_mmc + * Description: setup the pin muxes/tristate values for the SDMMC(s) + */ +static void pin_mux_mmc(void) +{ + funcmux_select(PERIPH_ID_SDMMC1, FUNCMUX_SDMMC1_SDIO1_4BIT); + funcmux_select(PERIPH_ID_SDMMC4, FUNCMUX_SDMMC4_ATB_GMA_4_BIT); + + /* For CD GPIO PP1 */ + pinmux_tristate_disable(PINGRP_DAP3); +} + +/* this is a weak define that we are overriding */ +int board_mmc_init(bd_t *bd) +{ + uchar val; + int ret; + + debug("board_mmc_init called\n"); + + /* Enable muxes, etc. for SDMMC controllers */ + pin_mux_mmc(); + + /* init dev 0 (SDMMC4), (micro-SD slot) with 4-bit bus */ + tegra2_mmc_init(0, 4, -1, GPIO_PP1); + + /* init dev 3 (SDMMC1), (SD slot) with 4-bit bus */ + tegra2_mmc_init(3, 4, -1, -1); + + return 0; +} diff --git a/boards.cfg b/boards.cfg index a96b7d7..e983b05 100644 --- a/boards.cfg +++ b/boards.cfg @@ -260,6 +260,7 @@ jornada arm sa1100 plutux arm armv7 plutux avionic-design tegra2 medcom arm armv7 medcom avionic-design tegra2 paz00 arm armv7 paz00 compal tegra2 +trimslice arm armv7 trimslice compulab tegra2 atngw100 avr32 at32ap - atmel at32ap700x atstk1002 avr32 at32ap atstk1000 atmel at32ap700x atstk1003 avr32 at32ap atstk1000 atmel at32ap700x diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h new file mode 100644 index 0000000..dafca5e --- /dev/null +++ b/include/configs/trimslice.h @@ -0,0 +1,89 @@ +/* + * (C) Copyright 2010-2012 + * NVIDIA Corporation <www.nvidia.com> + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <asm/sizes.h> +#include "tegra2-common.h" + +/* Enable fdt support for TrimSlice. Flash the image in u-boot-dtb.bin */ +#define CONFIG_DEFAULT_DEVICE_TREE tegra2-trimslice +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +/* High-level configuration options */ +#define V_PROMPT "Tegra2 (TrimSlice) # " +#define CONFIG_TEGRA2_BOARD_STRING "NVIDIA Trimslice" + +/* Board-specific serial config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA2_ENABLE_UARTA +#define CONFIG_TEGRA2_UARTA_GPU +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#define CONFIG_MACH_TYPE MACH_TYPE_TRIMSLICE +#define CONFIG_SYS_BOARD_ODMDATA 0x300c0011 /* lp?, 1GB, UARTA */ + +#define CONFIG_BOARD_EARLY_INIT_F + +/* I2C */ +#define CONFIG_TEGRA_I2C +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS 4 +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_CMD_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA2_MMC +#define CONFIG_CMD_MMC + +#define CONFIG_DOS_PARTITION +#define CONFIG_EFI_PARTITION +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT + +/* Environment not stored */ +#define CONFIG_ENV_IS_NOWHERE + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_SMSC95XX +#define CONFIG_USB_ETHER_ASIX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + +#include "tegra2-common-post.h" + +#endif /* __CONFIG_H */
Hi Stephen,
else return -1 I think
break;
/* SDMMC configs */
The name does not seem consistent - is it not possible to route this peripheral to different pins?
-- 1.7.0.4
On 05/21/2012 06:41 PM, Simon Glass wrote:
Hi Stephen,
On Wed, May 16, 2012 at 4:54 PM, Stephen Warren <swarren@wwwdotorg.org mailto:swarren@wwwdotorg.org> wrote:
From: Stephen Warren <swarren@nvidia.com <mailto:swarren@nvidia.com>> This will be used on TrimSlice. Signed-off-by: Stephen Warren <swarren@nvidia.com <mailto:swarren@nvidia.com>> --- arch/arm/cpu/armv7/tegra2/funcmux.c | 7 +++++++ arch/arm/include/asm/arch-tegra2/funcmux.h | 1 + 2 files changed, 8 insertions(+), 0 deletions(-) diff --git a/arch/arm/cpu/armv7/tegra2/funcmux.c b/arch/arm/cpu/armv7/tegra2/funcmux.c index 1559869..820ba4e 100644 --- a/arch/arm/cpu/armv7/tegra2/funcmux.c +++ b/arch/arm/cpu/armv7/tegra2/funcmux.c @@ -127,6 +127,13 @@ int funcmux_select(enum periph_id id, int config) } break; + case PERIPH_ID_SDMMC1: + if (config == FUNCMUX_SDMMC1_SDIO1_4BIT) { + pinmux_set_func(PINGRP_SDIO1, PMUX_FUNC_SDIO1); + pinmux_tristate_disable(PINGRP_SDIO1); + }
This is handled at the end of the function; if bad_config is set, it will return -1. (and bad_config is cleared by default in config==FUNCMUX_DEFAULT, and FUNCMUX_SDMMC1_SDIO1_4BIT==FUNCMUX_DEFAULT)
diff --git a/arch/arm/include/asm/arch-tegra2/funcmux.h b/arch/arm/include/asm/arch-tegra2/funcmux.h index 19184d1..b16c496 100644 --- a/arch/arm/include/asm/arch-tegra2/funcmux.h +++ b/arch/arm/include/asm/arch-tegra2/funcmux.h @@ -44,6 +44,7 @@ enum { FUNCMUX_I2C3_DTF = 0, /* SDMMC configs */ + FUNCMUX_SDMMC1_SDIO1_4BIT = 0,
SDMMC1 is the module name, and SDIO1 is the pingroup name it's being routed to. I'm not sure what the inconsistency is. I don't recall if SDMMC1 can be routed to different pingroups or not.
Hi Stephen,
config)
PMUX_FUNC_SDIO1);
Stephen Warren
