[PATCH 0/3] clang-14 fixes
This series contains a few clang-14 fixes to partly resolve the problems shown by [1].
The event_dump problem is that the symbol name is not printed by addr2line even though it seems to be present:
Without LTO:
$ addr2line -e u-boot.clang14.no-lto 4a37f addr2line: DWARF error: invalid or unhandled FORM value: 0x23 vbe_simple.c:?
$ nm u-boot.clang14.no-lto |grep 4a37f 000000000004a37f t bootmeth_vbe_simple_ft_fixup
With LTO is even worse:
$ addr2line -e u-boot.clang14.lto 2d2ee0 addr2line: DWARF error: invalid or unhandled FORM value: 0x23 ??:0
$ nm u-boot.clang14.lto |grep 4dad1 000000000004dad1 t bootmeth_vbe_simple_ft_fixup
Perhaps this is a bug in addr2line or the clang DWARF output?
[1] https://source.denx.de/u-boot/u-boot/-/jobs/510282#L287
Simon Glass (3): dm: core: Fix lists_bind_fdt() using non-existent of_match event: Drop the path when checking event-list filenames test: Drop unwanted option in event_dump.py
drivers/core/lists.c | 4 +++- scripts/event_dump.py | 2 -- test/py/tests/test_event_dump.py | 4 ++-- 3 files changed, 5 insertions(+), 5 deletions(-)
The call to device_bind_with_driver_data() passes id->data but if the entry has no of_match then the id has not been set by the selected driver.
Normally this passes unnoticed since a previous driver likely had an of_match value, so the id is set to that. Of course it is not correct to pass the id->data from a different driver.
With clang-14 the driver ordering is such that the id is never actually set in the 'bind /usb@1 usb_ether' line in test_bind_unbind_with_node() thus causing a crash.
Fix this by passing 0 if the of_match for a driver does not exist.
drivers/core/lists.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/core/lists.c b/drivers/core/lists.c index c49695b24f0..3878957c9ef 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -222,6 +222,7 @@ int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp, log_debug(" - attempt to match compatible string '%s'\n", compat);
+ id = NULL; for (entry = driver; entry != driver + n_ents; entry++) { if (drv) { if (drv != entry) @@ -250,7 +251,8 @@ int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp, entry->name, entry->of_match->compatible, id->compatible); ret = device_bind_with_driver_data(parent, entry, name, - id->data, node, &dev); + id ? id->data : 0, node, + &dev); if (ret == -ENODEV) { log_debug("Driver '%s' refuses to bind\n", entry->name); continue;
Applied to u-boot-dm, thanks!
This path does not seem to be present in clang-14 for some reason. Relax the regular expression so that the test works, at least for non-LTO.
test/py/tests/test_event_dump.py | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/test/py/tests/test_event_dump.py b/test/py/tests/test_event_dump.py index bc54149e8f2..56b67da96df 100644 --- a/test/py/tests/test_event_dump.py +++ b/test/py/tests/test_event_dump.py @@ -16,6 +16,6 @@ def test_event_dump(u_boot_console): out = util.run_and_log(cons, ['scripts/event_dump.py', sandbox]) expect = '''.*Event type Id Source location -------------------- ------------------------------ ------------------------------ -EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup .*boot/vbe_simple.c:.* -EVT_MISC_INIT_F sandbox_misc_init_f .*arch/sandbox/cpu/start.c:''' +EVT_FT_FIXUP bootmeth_vbe_simple_ft_fixup .*vbe_simple.c:.* +EVT_MISC_INIT_F sandbox_misc_init_f .*start.c:''' assert re.match(expect, out, re.MULTILINE) is not None
This option is not used. Drop it.
scripts/event_dump.py | 2 -- 1 file changed, 2 deletions(-)
diff --git a/scripts/event_dump.py b/scripts/event_dump.py index 6aadddf28da..d87823f3749 100755 --- a/scripts/event_dump.py +++ b/scripts/event_dump.py @@ -108,8 +108,6 @@ def main(argv): parser.add_argument('elf', type=str, help='ELF file to decode') parser.add_argument('-e', '--endian', type=str, default='auto', help='Big-endian image') - parser.add_argument('-t', '--test', action='store_true', - help='Big-endian image') args = parser.parse_args(argv) show_event_spy_list(args.elf, args.endian)
Hi Tom,
Without LTO:
I should have mentioned that I can respin the series to deal with this, perhaps by not requiring the function name to be present when clang is used (or just at all?)
Plus I have one more patch to add for the LTO stuff.
Let me know what you think and I can respin this this.
-- 2.38.0.rc1.362.ged0d419d3c-goog
On Tue, Oct 11, 2022 at 08:14:53AM -0600, Simon Glass wrote:
Hi Tom,
Without LTO:
Maybe it's worth raising a question on one of the LLVM lists? This seems fairly odd.
I would like to move to LLVM-14 / gcc-12.2 for CI, for v2023.01, but there's still other warnings to be fixed too, so we have a little time yet.
Hi Tom,
Hi Tom,
Without LTO:
It looks like you fixed this with the dwarf change.
On Tue, Dec 06, 2022 at 05:11:46AM +1300, Simon Glass wrote:
Hi Tom,
Hi Tom,
Without LTO:
Yes, the dwarf change addresses this, and I'll be picking that up for next as well.
