[PATCH] efi_loader: fix BootOrder variable measurement handling
UEFI specification does not require that BootOrder is defined. In current implementation, boot variable measurement fails and returns EFI_NOT_FOUND if BootOrder is not defined.
This commit correcly handles this case, skip the boot variable measurement if BootOrder is not defined.
Signed-off-by: Masahisa Kojima masahisa.kojima@linaro.org --- lib/efi_loader/efi_tcg2.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_tcg2.c b/lib/efi_loader/efi_tcg2.c index 586f73af6d..189e4a5ba5 100644 --- a/lib/efi_loader/efi_tcg2.c +++ b/lib/efi_loader/efi_tcg2.c @@ -1452,8 +1452,8 @@ static efi_status_t tcg2_measure_boot_variable(struct udevice *dev) boot_order = efi_get_var(var_name, &efi_global_variable_guid, &var_data_size); if (!boot_order) { - ret = EFI_NOT_FOUND; - goto error; + /* If "BootOrder" is not defined, skip the boot variable measurement */ + return EFI_SUCCESS; }
ret = tcg2_measure_variable(dev, 1, EV_EFI_VARIABLE_BOOT2, var_name,
On Tue, 9 Nov 2021 at 11:42, Masahisa Kojima masahisa.kojima@linaro.org wrote:
goto error;
measurement */
return EFI_SUCCESS; } ret = tcg2_measure_variable(dev, 1, EV_EFI_VARIABLE_BOOT2,
var_name,
2.17.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
=> tpm2 init && tpm2 startup TPM2_SU_CLEAR => efidebug boot order 1000 Found 0 disks Missing RNG device for EFI_RNG_PROTOCOL No EFI system partition No EFI system partition Failed to persist EFI variables => efidebug boot order 1: Boot1000: (not defined) => bootefi hello Booting /MemoryMapped(0x0,0x7ff9b1f0,0x11e0) Boot1000 not found Hello, world! Running on UEFI 2.8 Have SMBIOS table Have device tree Load options: <none> Boot device: /MemoryMapped(0x0,0x7ff9b1f0,0x11e0) File path: <none> =>
The message "Boot1000 not found" is created in lib/efi_loader/efi_tcg2.c(1475) tcg2_measure_boot_variable(). That message should be log_debug(). But that can be done in a separate patch.
Reviewed-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com
Ilias Apalodimas
Masahisa Kojima
