[U-Boot] [PATCH] dataflash: fix parameters order in write_dataflash()
Fix parameters order in write_dataflash() function extern declaration in the header file. Parameters order, as in function definition, should be: addr_dest, addr_src, size.
Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- include/dataflash.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/include/dataflash.h b/include/dataflash.h index 96ac097..094babb 100644 --- a/include/dataflash.h +++ b/include/dataflash.h @@ -207,7 +207,8 @@ extern int addr2ram(ulong addr); extern int dataflash_real_protect (int flag, unsigned long start_addr, unsigned long end_addr); extern int addr_dataflash (unsigned long addr); extern int read_dataflash (unsigned long addr, unsigned long size, char *result); -extern int write_dataflash (unsigned long addr, unsigned long dest, unsigned long size); +extern int write_dataflash(unsigned long addr_dest, unsigned long addr_src, + unsigned long size); extern void dataflash_print_info (void); extern void dataflash_perror (int err); extern void AT91F_DataflashSetEnv (void);
Hi all,
This is a trivial patch and it has been 18 days since posting it. Can someone take care of it, please?
Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- v2: rebase on TOT
diff --git a/include/dataflash.h b/include/dataflash.h index 056e18b..94f86b3 100644 --- a/include/dataflash.h +++ b/include/dataflash.h @@ -207,7 +207,8 @@ extern int addr2ram(ulong addr); extern int dataflash_real_protect (int flag, unsigned long start_addr, unsigned long end_addr); extern int addr_dataflash (unsigned long addr); extern int read_dataflash (unsigned long addr, unsigned long size, char *result); -extern int write_dataflash (unsigned long addr, unsigned long dest, unsigned long size); +extern int write_dataflash(unsigned long addr_dest, unsigned long addr_src, + unsigned long size); extern int AT91F_DataflashInit(void);
On Sun, 27 Nov 2011 11:06:46 +0200 Igor Grinberg grinberg@compulab.co.il wrote:
v2: rebase on TOT
Applied to u-boot-staging/agust@denx.de. Thanks!
Anatolij
Anatolij Gustschin
Igor Grinberg
