[U-Boot] [PATCH] cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to Kconfig
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family.
I am the maintainer of UniPhier platform, so I know "select CMD_ZIP" is better for this platform.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
README | 6 ------ arch/arm/mach-uniphier/Kconfig | 1 + cmd/Kconfig | 10 ++++++++++ configs/brxre1_defconfig | 1 + configs/dragonboard410c_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/hikey_defconfig | 1 + configs/icnova-a20-swac_defconfig | 3 ++- configs/vexpress_aemv8a_dram_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 1 + configs/xilinx_zynqmp_zcu102_revB_defconfig | 1 + include/config_cmd_all.h | 1 - include/configs/brxre1.h | 1 - include/configs/dragonboard410c.h | 1 - include/configs/ethernut5.h | 1 - include/configs/hikey.h | 1 - include/configs/uniphier.h | 4 ---- include/configs/vexpress_aemv8a.h | 1 - include/configs/xilinx_zynqmp.h | 2 -- 26 files changed, 27 insertions(+), 19 deletions(-)
diff --git a/README b/README index 9c992c1..89c12b0 100644 --- a/README +++ b/README @@ -1765,12 +1765,6 @@ The following options need to be configured: can be displayed via the splashscreen support or the bmp command.
-- Do compressing for memory range: - CONFIG_CMD_ZIP - - If this option is set, it would use zlib deflate method - to compress the specified memory at its best effort. - - Compression support: CONFIG_GZIP
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index cd9ba6b..5739325 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -13,6 +13,7 @@ config ARCH_UNIPHIER_32BIT config ARCH_UNIPHIER_64BIT bool select ARM64 + select CMD_UNZIP select SPL_SEPARATE_BSS if SPL select ARMV8_MULTIENTRY if SPL select ARMV8_SPIN_TABLE if SPL diff --git a/cmd/Kconfig b/cmd/Kconfig index 4a0d489..a5b0315 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -346,6 +346,16 @@ config CMD_MEMINFO help Display memory information.
+config CMD_UNZIP + bool "unzip" + help + Uncompress a zip-compressed memory region. + +config CMD_ZIP + bool "zip" + help + Compresses a memory region with zlib deflate method. + endmenu
menu "Device access commands" diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 0b7b082..dfa8712 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -31,6 +31,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_CRC32 is not set +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 8f206e2..e94f7b3 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="dragonboard410c => " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMINFO=y +CONFIG_CMD_UNZIP=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index c831aab..4d1b4b0 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -8,6 +8,7 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set CONFIG_CMD_ASKENV=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_SF=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 8dd330a..b112be2 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -7,6 +7,7 @@ CONFIG_DISTRO_DEFAULTS=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_BOARD_EARLY_INIT_F=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_UNZIP=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 567eb9b..5ef0e47 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -13,9 +13,10 @@ CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set -CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_SPL_DOS_PARTITION is not set diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index c899be0..db492af 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 2267362..537301c 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 02740a4..2720a71 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 49c0786..6b568b4 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_UNZIP=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_GPT=y diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index a3585d0..4d7bcf3 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index 3693d9b..822b25d 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -21,6 +21,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_NAND=y diff --git a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig index a4c73f8..89813df 100644 --- a/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm018_dc4_defconfig @@ -16,6 +16,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig index f981b21..b8fe33e 100644 --- a/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm019_dc5_defconfig @@ -17,6 +17,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index 7b65fe0..b13bf5b 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index 4bed589..2489d89 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -19,6 +19,7 @@ CONFIG_SPL_OS_BOOT=y CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y +CONFIG_CMD_UNZIP=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index a0d4e94..a8befe3 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -49,7 +49,6 @@ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UBIFS /* UBIFS Support */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ -#define CONFIG_CMD_UNZIP /* unzip from memory to memory */ #define CONFIG_CMD_ZFS /* ZFS Support */
#endif /* _CONFIG_CMD_ALL_H */ diff --git a/include/configs/brxre1.h b/include/configs/brxre1.h index 02094b5..82ee7c6 100644 --- a/include/configs/brxre1.h +++ b/include/configs/brxre1.h @@ -22,7 +22,6 @@
#define CONFIG_VIDEO_BMP_GZIP #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (1366*767*4) -#define CONFIG_CMD_UNZIP #define CONFIG_CMD_BMP #define CONFIG_BMP_24BMP #define CONFIG_BMP_32BPP diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index da1c589..9b7f43f 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -57,7 +57,6 @@ /*#define CONFIG_SUPPORT_EMMC_BOOT */ #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_TFTP -#define CONFIG_CMD_UNZIP
/* Partition table support */ #define HAVE_BLOCK_DEVICE /* Needed for partition commands */ diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index a3c40d6..55d65ef 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -95,7 +95,6 @@ #define CONFIG_CMD_REISER #define CONFIG_CMD_SAVES #define CONFIG_CMD_UBIFS -#define CONFIG_CMD_UNZIP #endif
/* NAND flash */ diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 9ec8140..899d62d 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -74,7 +74,6 @@ #define CONFIG_FS_EXT4
/* Command line configuration */ -#define CONFIG_CMD_UNZIP #define CONFIG_CMD_ENV
#define CONFIG_MTD_PARTITIONS diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index 22962392e..b453d8f 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -15,10 +15,6 @@
#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10
-#ifdef CONFIG_ARM64 -#define CONFIG_CMD_UNZIP -#endif - /*----------------------------------------------------------------------- * MMU and Cache Setting *----------------------------------------------------------------------*/ diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 3a4bfe8..35ac60a 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -126,7 +126,6 @@ #endif
/*#define CONFIG_MENU_SHOW*/ -#define CONFIG_CMD_UNZIP #define CONFIG_CMD_ENV
/* BOOTP options */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 4759373..73830b2 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -207,8 +207,6 @@
#define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
-#define CONFIG_CMD_UNZIP - #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_CLOCKS
Acked-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Masahiro Yamada
Michal Simek
