[PATCH v2 1/7] pci: pcie_dw_rockchip: Add rk3588 compatible
Add compatible for RK3588 SoC.
Signed-off-by: Jon Lin jon.lin@rock-chips.com --- Changes in v2: - none
drivers/pci/pcie_dw_rockchip.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index 6155710a9f5f..ff121046604a 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -468,6 +468,7 @@ static const struct dm_pci_ops rockchip_pcie_ops = {
static const struct udevice_id rockchip_pcie_ids[] = { { .compatible = "rockchip,rk3568-pcie" }, + { .compatible = "rockchip,rk3588-pcie" }, { } };
Add support for max_link_speed specified in the PCI DT binding.
Signed-off-by: Jon Lin jon.lin@rock-chips.com [eugen.hristev@collabora.com: port to latest API, set default correctly, align to 80 chars] Signed-off-by: Eugen Hristev eugen.hristev@collabora.com [jonas@kwiboo.se: switch to dev_read_u32_default] Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Changes in v2: - move to dev_read_u32_default
drivers/pci/pcie_dw_rockchip.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/pci/pcie_dw_rockchip.c b/drivers/pci/pcie_dw_rockchip.c index ff121046604a..60c74bea24b2 100644 --- a/drivers/pci/pcie_dw_rockchip.c +++ b/drivers/pci/pcie_dw_rockchip.c @@ -42,6 +42,7 @@ struct rk_pcie { struct clk_bulk clks; struct reset_ctl_bulk rsts; struct gpio_desc rst_gpio; + u32 gen; };
/* Parameters for the waiting for iATU enabled routine */ @@ -331,7 +332,7 @@ static int rockchip_pcie_init_port(struct udevice *dev) rk_pcie_writel_apb(priv, 0x0, 0xf00040); pcie_dw_setup_host(&priv->dw);
- ret = rk_pcie_link_up(priv, LINK_SPEED_GEN_3); + ret = rk_pcie_link_up(priv, priv->gen); if (ret < 0) goto err_link_up;
@@ -397,6 +398,9 @@ static int rockchip_pcie_parse_dt(struct udevice *dev) goto rockchip_pcie_parse_dt_err_phy_get_by_index; }
+ priv->gen = dev_read_u32_default(dev, "max-link-speed", + LINK_SPEED_GEN_3); + return 0;
rockchip_pcie_parse_dt_err_phy_get_by_index:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
u32 gen; };
- ret = rk_pcie_link_up(priv, priv->gen); if (ret < 0) goto err_link_up;
LINK_SPEED_GEN_3);
Some variants of the PHY have more than just one reset. To cover all cases, request the rests in bulk rather than just the reset at index 0.
Co-developed-by: Ren Jianing jianing.ren@rock-chips.com Signed-off-by: Ren Jianing jianing.ren@rock-chips.com Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- Changes in v2: - none
drivers/phy/rockchip/phy-rockchip-naneng-combphy.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c b/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c index 78da5fe79700..b673a8da9f8e 100644 --- a/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c +++ b/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c @@ -76,7 +76,7 @@ struct rockchip_combphy_priv { struct regmap *pipe_grf; struct regmap *phy_grf; struct phy *phy; - struct reset_ctl phy_rst; + struct reset_ctl_bulk phy_rsts; struct clk ref_clk; const struct rockchip_combphy_cfg *cfg; }; @@ -189,7 +189,7 @@ static int rockchip_combphy_init(struct phy *phy) if (ret) goto err_clk;
- reset_deassert(&priv->phy_rst); + reset_deassert_bulk(&priv->phy_rsts);
@@ -204,7 +204,7 @@ static int rockchip_combphy_exit(struct phy *phy) struct rockchip_combphy_priv *priv = dev_get_priv(phy->dev);
clk_disable(&priv->ref_clk); - reset_assert(&priv->phy_rst); + reset_assert_bulk(&priv->phy_rsts);
return 0; } @@ -255,7 +255,7 @@ static int rockchip_combphy_parse_dt(struct udevice *dev, return PTR_ERR(&priv->ref_clk); }
- ret = reset_get_by_index(dev, 0, &priv->phy_rst); + ret = reset_get_bulk(dev, &priv->phy_rsts); if (ret) { dev_err(dev, "no phy reset control specified\n"); return ret;
Thanks, - Kever
Changes in v2:
- none
- struct reset_ctl_bulk phy_rsts; struct clk ref_clk; const struct rockchip_combphy_cfg *cfg; };
return 0; }
- ret = reset_get_bulk(dev, &priv->phy_rsts); if (ret) { dev_err(dev, "no phy reset control specified\n"); return ret;
Add support for rk3588 phy variant. The PHY clock is fixed at 100MHz.
Signed-off-by: Jon Lin jon.lin@rock-chips.com [kever.yang@rock-chips.com: update pcie pll parameters] Co-developed-by: Kever Yang kever.yang@rock-chips.com Signed-off-by: Kever Yang kever.yang@rock-chips.com [eugen.hristev@collabora.com: squashed, tidy up] Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- Changes in v2: - none
.../rockchip/phy-rockchip-naneng-combphy.c | 95 +++++++++++++++++++ 1 file changed, 95 insertions(+)
diff --git a/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c b/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c index b673a8da9f8e..d5408ccac976 100644 --- a/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c +++ b/drivers/phy/rockchip/phy-rockchip-naneng-combphy.c @@ -58,6 +58,7 @@ struct rockchip_combphy_grfcfg { struct combphy_reg con2_for_sata; struct combphy_reg con3_for_sata; struct combphy_reg pipe_con0_for_sata; + struct combphy_reg pipe_con1_for_sata; struct combphy_reg pipe_sgmii_mac_sel; struct combphy_reg pipe_xpcs_phy_ready; struct combphy_reg u3otg0_port_en; @@ -423,11 +424,105 @@ static const struct rockchip_combphy_cfg rk3568_combphy_cfgs = { .combphy_cfg = rk3568_combphy_cfg, };
+static int rk3588_combphy_cfg(struct rockchip_combphy_priv *priv) +{ + const struct rockchip_combphy_grfcfg *cfg = priv->cfg->grfcfg; + u32 val; + + switch (priv->mode) { + case PHY_TYPE_PCIE: + param_write(priv->phy_grf, &cfg->con0_for_pcie, true); + param_write(priv->phy_grf, &cfg->con1_for_pcie, true); + param_write(priv->phy_grf, &cfg->con2_for_pcie, true); + param_write(priv->phy_grf, &cfg->con3_for_pcie, true); + break; + case PHY_TYPE_USB3: + param_write(priv->phy_grf, &cfg->pipe_txcomp_sel, false); + param_write(priv->phy_grf, &cfg->pipe_txelec_sel, false); + param_write(priv->phy_grf, &cfg->usb_mode_set, true); + break; + case PHY_TYPE_SATA: + param_write(priv->phy_grf, &cfg->con0_for_sata, true); + param_write(priv->phy_grf, &cfg->con1_for_sata, true); + param_write(priv->phy_grf, &cfg->con2_for_sata, true); + param_write(priv->phy_grf, &cfg->con3_for_sata, true); + param_write(priv->pipe_grf, &cfg->pipe_con0_for_sata, true); + param_write(priv->pipe_grf, &cfg->pipe_con1_for_sata, true); + break; + case PHY_TYPE_SGMII: + case PHY_TYPE_QSGMII: + default: + dev_err(priv->dev, "incompatible PHY type\n"); + return -EINVAL; + } + + /* 100MHz refclock signal is good */ + clk_set_rate(&priv->ref_clk, 100000000); + param_write(priv->phy_grf, &cfg->pipe_clk_100m, true); + if (priv->mode == PHY_TYPE_PCIE) { + /* PLL KVCO tuning fine */ + val = readl(priv->mmio + (0x20 << 2)); + val &= ~GENMASK(4, 2); + val |= 0x4 << 2; + writel(val, priv->mmio + (0x20 << 2)); + + /* Set up rx_trim: PLL LPF C1 85pf R1 1.25kohm */ + val = 0x4c; + writel(val, priv->mmio + (0x1b << 2)); + + /* Set up su_trim: T3 */ + val = 0xb0; + writel(val, priv->mmio + (0xa << 2)); + val = 0x47; + writel(val, priv->mmio + (0xb << 2)); + val = 0x57; + writel(val, priv->mmio + (0xd << 2)); + } + + return 0; +} + +static const struct rockchip_combphy_grfcfg rk3588_combphy_grfcfgs = { + /* pipe-phy-grf */ + .pcie_mode_set = { 0x0000, 5, 0, 0x00, 0x11 }, + .usb_mode_set = { 0x0000, 5, 0, 0x00, 0x04 }, + .pipe_rxterm_set = { 0x0000, 12, 12, 0x00, 0x01 }, + .pipe_txelec_set = { 0x0004, 1, 1, 0x00, 0x01 }, + .pipe_txcomp_set = { 0x0004, 4, 4, 0x00, 0x01 }, + .pipe_clk_25m = { 0x0004, 14, 13, 0x00, 0x01 }, + .pipe_clk_100m = { 0x0004, 14, 13, 0x00, 0x02 }, + .pipe_rxterm_sel = { 0x0008, 8, 8, 0x00, 0x01 }, + .pipe_txelec_sel = { 0x0008, 12, 12, 0x00, 0x01 }, + .pipe_txcomp_sel = { 0x0008, 15, 15, 0x00, 0x01 }, + .pipe_clk_ext = { 0x000c, 9, 8, 0x02, 0x01 }, + .pipe_phy_status = { 0x0034, 6, 6, 0x01, 0x00 }, + .con0_for_pcie = { 0x0000, 15, 0, 0x00, 0x1000 }, + .con1_for_pcie = { 0x0004, 15, 0, 0x00, 0x0000 }, + .con2_for_pcie = { 0x0008, 15, 0, 0x00, 0x0101 }, + .con3_for_pcie = { 0x000c, 15, 0, 0x00, 0x0200 }, + .con0_for_sata = { 0x0000, 15, 0, 0x00, 0x0129 }, + .con1_for_sata = { 0x0004, 15, 0, 0x00, 0x0040 }, + .con2_for_sata = { 0x0008, 15, 0, 0x00, 0x80c1 }, + .con3_for_sata = { 0x000c, 15, 0, 0x00, 0x0407 }, + /* pipe-grf */ + .pipe_con0_for_sata = { 0x0000, 11, 5, 0x00, 0x22 }, + .pipe_con1_for_sata = { 0x0000, 2, 0, 0x00, 0x2 }, +}; + +static const struct rockchip_combphy_cfg rk3588_combphy_cfgs = { + .grfcfg = &rk3588_combphy_grfcfgs, + .combphy_cfg = rk3588_combphy_cfg, +}; + static const struct udevice_id rockchip_combphy_ids[] = { { .compatible = "rockchip,rk3568-naneng-combphy", .data = (ulong)&rk3568_combphy_cfgs }, + { + .compatible = "rockchip,rk3588-naneng-combphy", + .data = (ulong)&rk3588_combphy_cfgs + }, { } };
Thanks, - Kever
Changes in v2:
- none
- struct combphy_reg pipe_con1_for_sata; struct combphy_reg pipe_sgmii_mac_sel; struct combphy_reg pipe_xpcs_phy_ready; struct combphy_reg u3otg0_port_en;
- const struct rockchip_combphy_grfcfg *cfg = priv->cfg->grfcfg;
- u32 val;
- switch (priv->mode) {
- case PHY_TYPE_PCIE:
break;
- case PHY_TYPE_USB3:
break;
- case PHY_TYPE_SATA:
break;
- case PHY_TYPE_SGMII:
- case PHY_TYPE_QSGMII:
- default:
return -EINVAL;
- /* 100MHz refclock signal is good */
- clk_set_rate(&priv->ref_clk, 100000000);
- param_write(priv->phy_grf, &cfg->pipe_clk_100m, true);
- if (priv->mode == PHY_TYPE_PCIE) {
val |= 0x4 << 2;
val = 0x4c;
val = 0xb0;
val = 0x47;
val = 0x57;
- /* pipe-phy-grf */
- .pcie_mode_set = { 0x0000, 5, 0, 0x00, 0x11 },
- .usb_mode_set = { 0x0000, 5, 0, 0x00, 0x04 },
- .pipe_rxterm_set = { 0x0000, 12, 12, 0x00, 0x01 },
- .pipe_txelec_set = { 0x0004, 1, 1, 0x00, 0x01 },
- .pipe_txcomp_set = { 0x0004, 4, 4, 0x00, 0x01 },
- .pipe_clk_25m = { 0x0004, 14, 13, 0x00, 0x01 },
- .pipe_clk_100m = { 0x0004, 14, 13, 0x00, 0x02 },
- .pipe_rxterm_sel = { 0x0008, 8, 8, 0x00, 0x01 },
- .pipe_txelec_sel = { 0x0008, 12, 12, 0x00, 0x01 },
- .pipe_txcomp_sel = { 0x0008, 15, 15, 0x00, 0x01 },
- .pipe_clk_ext = { 0x000c, 9, 8, 0x02, 0x01 },
- .pipe_phy_status = { 0x0034, 6, 6, 0x01, 0x00 },
- .con0_for_pcie = { 0x0000, 15, 0, 0x00, 0x1000 },
- .con1_for_pcie = { 0x0004, 15, 0, 0x00, 0x0000 },
- .con2_for_pcie = { 0x0008, 15, 0, 0x00, 0x0101 },
- .con3_for_pcie = { 0x000c, 15, 0, 0x00, 0x0200 },
- .con0_for_sata = { 0x0000, 15, 0, 0x00, 0x0129 },
- .con1_for_sata = { 0x0004, 15, 0, 0x00, 0x0040 },
- .con2_for_sata = { 0x0008, 15, 0, 0x00, 0x80c1 },
- .con3_for_sata = { 0x000c, 15, 0, 0x00, 0x0407 },
- /* pipe-grf */
- .pipe_con0_for_sata = { 0x0000, 11, 5, 0x00, 0x22 },
- .pipe_con1_for_sata = { 0x0000, 2, 0, 0x00, 0x2 },
- .grfcfg = &rk3588_combphy_grfcfgs,
- .combphy_cfg = rk3588_combphy_cfg,
- static const struct udevice_id rockchip_combphy_ids[] = { { .compatible = "rockchip,rk3568-naneng-combphy", .data = (ulong)&rk3568_combphy_cfgs },
Add the node for pciE 2x1l 2 device together with the corresponding combphy.
Signed-off-by: Joseph Chen chenjh@rock-chips.com [eugen.hristev@collabora.com: moved to -u-boot.dtsi, minor adaptations] Signed-off-by: Eugen Hristev eugen.hristev@collabora.com [jonas@kwiboo.se: adapt to kernel node] Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Changes in v2: - add compliance with linux by Jonas
arch/arm/dts/rk3588s-u-boot.dtsi | 77 ++++++++++++++++++++++++++++++++ 1 file changed, 77 insertions(+)
diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index ad652c02e58e..6385da1471a5 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -4,6 +4,7 @@ */
#include "rockchip-u-boot.dtsi" +#include <dt-bindings/phy/phy.h>
/ { dmc { @@ -58,6 +59,11 @@ reg = <0x0 0xfd58a000 0x0 0x2000>; };
+ pipe_phy0_grf: syscon@fd5bc000 { + compatible = "rockchip,pipe-phy-grf", "syscon"; + reg = <0x0 0xfd5bc000 0x0 0x100>; + }; + usb2phy2_grf: syscon@fd5d8000 { compatible = "rockchip,rk3588-usb2phy-grf", "syscon", "simple-mfd"; @@ -104,6 +110,61 @@ }; };
+ pcie2x1l2: pcie@fe190000 { + compatible = "rockchip,rk3588-pcie", "snps,dw-pcie"; + #address-cells = <3>; + #size-cells = <2>; + bus-range = <0x40 0x4f>; + clocks = <&cru ACLK_PCIE_1L2_MSTR>, <&cru ACLK_PCIE_1L2_SLV>, + <&cru ACLK_PCIE_1L2_DBI>, <&cru PCLK_PCIE_1L2>, + <&cru CLK_PCIE_AUX4>, <&cru CLK_PCIE1L2_PIPE>; + clock-names = "aclk_mst", "aclk_slv", + "aclk_dbi", "pclk", + "aux", "pipe"; + device_type = "pci"; + interrupts = <GIC_SPI 253 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 252 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 251 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 250 IRQ_TYPE_LEVEL_HIGH 0>, + <GIC_SPI 249 IRQ_TYPE_LEVEL_HIGH 0>; + interrupt-names = "sys", "pmc", "msg", "legacy", "err"; + #interrupt-cells = <1>; + interrupt-map-mask = <0 0 0 7>; + interrupt-map = <0 0 0 1 &pcie2x1l2_intc 0>, + <0 0 0 2 &pcie2x1l2_intc 1>, + <0 0 0 3 &pcie2x1l2_intc 2>, + <0 0 0 4 &pcie2x1l2_intc 3>; + linux,pci-domain = <4>; + num-ib-windows = <8>; + num-ob-windows = <8>; + num-viewport = <4>; + max-link-speed = <2>; + msi-map = <0x4000 &gic 0x4000 0x1000>; + num-lanes = <1>; + phys = <&combphy0_ps PHY_TYPE_PCIE>; + phy-names = "pcie-phy"; + power-domains = <&power RK3588_PD_PCIE>; + ranges = <0x01000000 0x0 0xf4100000 0x0 0xf4100000 0x0 0x00100000>, + <0x02000000 0x0 0xf4200000 0x0 0xf4200000 0x0 0x00e00000>, + <0x03000000 0x0 0x40000000 0xa 0x00000000 0x0 0x40000000>; + reg = <0xa 0x41000000 0x0 0x00400000>, + <0x0 0xfe190000 0x0 0x00010000>, + <0x0 0xf4000000 0x0 0x00100000>; + reg-names = "dbi", "apb", "config"; + resets = <&cru SRST_PCIE4_POWER_UP>, <&cru SRST_P_PCIE4>; + reset-names = "pcie", "periph"; + rockchip,pipe-grf = <&php_grf>; + status = "disabled"; + + pcie2x1l2_intc: legacy-interrupt-controller { + interrupt-controller; + #address-cells = <0>; + #interrupt-cells = <1>; + interrupt-parent = <&gic>; + interrupts = <GIC_SPI 250 IRQ_TYPE_EDGE_RISING 0>; + }; + }; + sfc: spi@fe2b0000 { compatible = "rockchip,sfc"; reg = <0x0 0xfe2b0000 0x0 0x4000>; @@ -134,6 +195,22 @@ reg = <0x0 0xfe378000 0x0 0x200>; status = "disabled"; }; + + combphy0_ps: phy@fee00000 { + compatible = "rockchip,rk3588-naneng-combphy"; + reg = <0x0 0xfee00000 0x0 0x100>; + #phy-cells = <1>; + clocks = <&cru CLK_REF_PIPE_PHY0>, <&cru PCLK_PCIE_COMBO_PIPE_PHY0>, + <&cru PCLK_PHP_ROOT>; + clock-names = "refclk", "apbclk", "phpclk"; + assigned-clocks = <&cru CLK_REF_PIPE_PHY0>; + assigned-clock-rates = <100000000>; + resets = <&cru SRST_P_PCIE2_PHY0>, <&cru SRST_REF_PIPE_PHY0>; + reset-names = "combphy-apb", "combphy"; + rockchip,pipe-grf = <&php_grf>; + rockchip,pipe-phy-grf = <&pipe_phy0_grf>; + status = "disabled"; + }; };
&xin24m {
Hi Eugen,
Typo "pciE" in the patch 5-7? We use 'PCIe' in term or 'pcie' in code.
Thanks,
- Kever
combphy.
Changes in v2:
- pipe_phy0_grf: syscon@fd5bc000 {
- usb2phy2_grf: syscon@fd5d8000 { compatible = "rockchip,rk3588-usb2phy-grf", "syscon", "simple-mfd";
- pcie2x1l2: pcie@fe190000 {
#size-cells = <2>;
"aclk_dbi", "pclk",
"aux", "pipe";
num-viewport = <4>;
num-lanes = <1>;
- sfc: spi@fe2b0000 { compatible = "rockchip,sfc"; reg = <0x0 0xfe2b0000 0x0 0x4000>;
#phy-cells = <1>;
&xin24m {
From: Christopher Obbard chris.obbard@collabora.com
Enable the pciE 2x1l 2 device and associated combphy. On this bus, the Rock5B has an Ethernet transceiver connected.
Signed-off-by: Christopher Obbard chris.obbard@collabora.com [eugen.hristev@collabora.com: minor tweaks] Signed-off-by: Eugen Hristev eugen.hristev@collabora.com [jonas@kwiboo.se: add pcie pins] Signed-off-by: Jonas Karlman jonas@kwiboo.se --- Changes in v2: - add pcie2x1l2_pins by Jonas
arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi index 78ffd60aaed4..d7650b7503a5 100644 --- a/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi +++ b/arch/arm/dts/rk3588-rock-5b-u-boot.dtsi @@ -30,13 +30,35 @@ }; };
+&combphy0_ps { + status = "okay"; +}; + &fspim2_pins { bootph-all; };
+&pcie2x1l2 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie2x1l2_pins &pcie_reset_h>; + reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + &pinctrl { bootph-all;
+ pcie { + pcie_reset_h: pcie-reset-h { + rockchip,pins = <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + pcie2x1l2_pins: pcie2x1l2-pins { + rockchip,pins = <3 RK_PC7 4 &pcfg_pull_none>, + <3 RK_PD0 4 &pcfg_pull_none>; + }; + }; + usb { vcc5v0_host_en: vcc5v0-host-en { rockchip,pins = <4 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
Add drivers for pciE , phy, and command.
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- Changes in v2: - binman_fdt is now removed
configs/rock5b-rk3588_defconfig | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/configs/rock5b-rk3588_defconfig b/configs/rock5b-rk3588_defconfig index 2685515d3956..3433e80f4b31 100644 --- a/configs/rock5b-rk3588_defconfig +++ b/configs/rock5b-rk3588_defconfig @@ -47,6 +47,7 @@ CONFIG_SPL_ATF=y CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set @@ -72,7 +73,10 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y CONFIG_SPL_PINCTRL=y CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y
Thanks, - Kever
Changes in v2:
- none
- { .compatible = "rockchip,rk3588-pcie" }, { } };
Eugen Hristev
Kever Yang
