[PULL] u-boot-sh/next
The following changes since commit d580a013cca67a8115fb88d260498bde181709a1:
Merge patch series "vbe: Series part E" (2024-12-27 15:16:39 -0600)
https://source.denx.de/u-boot/custodians/u-boot-sh.git next
for you to fetch changes up to 678f7c8f560775e0ac33300f54281dfcaa2e525a:
net: rswitch: Implement C22 to C45 access (2024-12-29 16:55:32 +0100)
---------------------------------------------------------------- Marek Vasut (19): pinctrl: renesas: Convert to IS_ENABLED() macro ram: renesas: Add Renesas R-Car Gen4 DBSC5 driver arm64: dts: renesas: Add R8A779G0 V4H DBSC5 and RT-VRAM DT nodes arm64: renesas: Make stub PSCI implementation available on 64bit R-Car SoCs arm64: renesas: Deduplicate R-Car Gen4 board files arm64: renesas: Split R-Car Gen3 and Gen4 common board code arm64: renesas: Make bottom 128 MiB of DRAM available in EL3 arm64: renesas: Add Renesas R-Car V4H SPL implementation arm64: renesas: Align configuration headers arm64: dts: renesas: Drop OF_UPSTREAM conversion remnant remoteproc: renesas: Add Renesas R-Car Gen4 remote processor driver arm64: dts: renesas: Add R8A779G0 V4H remoteproc DT node arm64: renesas: Enable CR52 remoteproc on R-Car R8A779G0 V4H net: rswitch: Replace enum rswitch_reg with plain macros net: rswitch: Fix up macro indent net: rswitch: Simplify code using clrsetbits_le32() net: rswitch: Fold MPSM C45 setting into rswitch_mii_access_c45() net: rswitch: Add PHY C22 access support net: rswitch: Implement C22 to C45 access
arch/arm/dts/Makefile | 4 - arch/arm/dts/r8a779g0-u-boot.dtsi | 175 +- arch/arm/dts/r8a779g0-white-hawk-u-boot.dtsi | 6 + arch/arm/mach-renesas/Kconfig.rcar4 | 10 + arch/arm/mach-renesas/Makefile | 4 +- arch/arm/mach-renesas/include/mach/boot0.h | 66 + .../arm/mach-renesas/include/mach/rcar-gen3-base.h | 5 + .../{psci-r8a779a0.c => psci-rcar64.c} | 3 +- board/beacon/beacon-rzg2m/Makefile | 2 +- board/hoperun/hihope-rzg2/Makefile | 2 +- board/renesas/condor/Makefile | 2 +- board/renesas/draak/Makefile | 2 +- board/renesas/eagle/Makefile | 2 +- board/renesas/ebisu/Makefile | 2 +- board/renesas/falcon/Makefile | 2 +- board/renesas/falcon/falcon.c | 102 - board/renesas/grayhawk/Makefile | 2 +- board/renesas/grayhawk/grayhawk.c | 66 - board/renesas/rcar-common/common.c | 200 +- board/renesas/rcar-common/gen3-common.c | 185 + .../whitehawk.c => rcar-common/gen4-common.c} | 36 +- board/renesas/rcar-common/gen4-spl.c | 119 + board/renesas/salvator-x/Makefile | 2 +- board/renesas/spider/Makefile | 2 +- board/renesas/spider/spider.c | 66 - board/renesas/ulcb/Makefile | 2 +- board/renesas/v3hsk/Makefile | 2 +- board/renesas/v3msk/Makefile | 2 +- board/renesas/whitehawk/Makefile | 6 +- board/silinux/ek874/Makefile | 2 +- configs/r8a779g0_whitehawk_defconfig | 40 + drivers/net/rswitch.c | 238 +- drivers/pinctrl/renesas/pfc.c | 128 +- drivers/ram/Kconfig | 1 + drivers/ram/renesas/Kconfig | 7 + drivers/ram/renesas/Makefile | 3 + drivers/ram/renesas/dbsc5/Makefile | 3 + drivers/ram/renesas/dbsc5/dbsc5.c | 79 + drivers/ram/renesas/dbsc5/dbsc5.h | 28 + drivers/ram/renesas/dbsc5/dram.c | 4532 ++++++++++++++++++++ drivers/ram/renesas/dbsc5/qos.c | 636 +++ drivers/ram/renesas/dbsc5/rtvram.c | 93 + drivers/remoteproc/Kconfig | 8 + drivers/remoteproc/Makefile | 1 + drivers/remoteproc/renesas_apmu.c | 266 ++ include/configs/rcar-gen2-common.h | 10 +- include/configs/rcar-gen3-common.h | 19 +- include/configs/rcar-gen4-common.h | 8 +- 48 files changed, 6539 insertions(+), 642 deletions(-) rename arch/arm/mach-renesas/{psci-r8a779a0.c => psci-rcar64.c} (92%) delete mode 100644 board/renesas/falcon/falcon.c delete mode 100644 board/renesas/grayhawk/grayhawk.c create mode 100644 board/renesas/rcar-common/gen3-common.c rename board/renesas/{whitehawk/whitehawk.c => rcar-common/gen4-common.c} (61%) create mode 100644 board/renesas/rcar-common/gen4-spl.c delete mode 100644 board/renesas/spider/spider.c create mode 100644 drivers/ram/renesas/Kconfig create mode 100644 drivers/ram/renesas/dbsc5/Makefile create mode 100644 drivers/ram/renesas/dbsc5/dbsc5.c create mode 100644 drivers/ram/renesas/dbsc5/dbsc5.h create mode 100644 drivers/ram/renesas/dbsc5/dram.c create mode 100644 drivers/ram/renesas/dbsc5/qos.c create mode 100644 drivers/ram/renesas/dbsc5/rtvram.c create mode 100644 drivers/remoteproc/renesas_apmu.c
