[PATCH 00/11] Add STM32 FMC2 EBI controller driver
The FMC2 functional block makes the interface with: synchronous and asynchronous static devices (such as PSNOR, PSRAM or other memory-mapped peripherals) and NAND flash memories. Its main purposes are: - to translate AXI transactions into the appropriate external device protocol - to meet the access time requirements of the external devices All external devices share the addresses, data and control signals with the controller. Each external device is accessed by means of a unique Chip Select. The FMC2 performs only one access at a time to an external device.
Christophe Kerello (11): mtd: rawnand: stm32_fmc2: fix a buffer overflow mtd: rawnand: stm32_fmc2: remove useless inline comments mtd: rawnand: stm32_fmc2: use FMC2_TIMEOUT_5S for timeouts mtd: rawnand: stm32_fmc2: cosmetic change to use nfc instead of fmc2 where relevant mtd: rawnand: stm32_fmc2: use FIELD_PREP/FIELD_GET macros mtd: rawnand: stm32_fmc2: use clrsetbits_le32 memory: stm32-fmc2-ebi: add STM32 FMC2 EBI controller driver mtd: rawnand: stm32_fmc2: get resources from parent node board: stm32mp1: update fdt fixup partitions table configs: stm32mp: add CONFIG_STM32_FMC2_EBI ARM: dts: stm32: add FMC2 EBI support for stm32mp157c
arch/arm/dts/stm32mp151.dtsi | 43 +- arch/arm/dts/stm32mp157c-ev1.dts | 16 +- board/st/stm32mp1/stm32mp1.c | 1 + configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + drivers/memory/Kconfig | 9 + drivers/memory/Makefile | 1 + drivers/memory/stm32-fmc2-ebi.c | 1056 ++++++++++++++++++++++++++++++++ drivers/mtd/nand/raw/stm32_fmc2_nand.c | 499 ++++++++------- 9 files changed, 1349 insertions(+), 278 deletions(-) create mode 100644 drivers/memory/stm32-fmc2-ebi.c
The chip select defined in the device tree could only be 0 or 1.
Signed-off-by: Christophe Kerello christophe.kerello@st.com ---
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 3306bd8..2929acf 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -846,7 +846,7 @@ static int stm32_fmc2_parse_child(struct stm32_fmc2_nfc *fmc2, }
for (i = 0; i < nand->ncs; i++) { - if (cs[i] > FMC2_MAX_CE) { + if (cs[i] >= FMC2_MAX_CE) { pr_err("Invalid reg value: %d\n", nand->cs_used[i]); return -EINVAL;
Hi Christpohe
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
On 8/13/20 9:27 AM, Patrice CHOTARD wrote:
Hi Christpohe
Applied on u-boot-stm/master
Thanks
Thanks
Patrice
Remove inline comments that are useless since function label are self explanatory.
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 25 ------------------------- 1 file changed, 25 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 2929acf..f43e3ec 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -179,7 +179,6 @@ static inline struct stm32_fmc2_nfc *to_stm32_nfc(struct nand_hw_control *base) return container_of(base, struct stm32_fmc2_nfc, base); }
-/* Timings configuration */ static void stm32_fmc2_timings_init(struct nand_chip *chip) { struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); @@ -211,7 +210,6 @@ static void stm32_fmc2_timings_init(struct nand_chip *chip) writel(patt, fmc2->io_base + FMC2_PATT); }
-/* Controller configuration */ static void stm32_fmc2_setup(struct nand_chip *chip) { struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); @@ -239,7 +237,6 @@ static void stm32_fmc2_setup(struct nand_chip *chip) writel(pcr, fmc2->io_base + FMC2_PCR); }
-/* Select target */ static void stm32_fmc2_select_chip(struct mtd_info *mtd, int chipnr) { struct nand_chip *chip = mtd_to_nand(mtd); @@ -256,14 +253,10 @@ static void stm32_fmc2_select_chip(struct mtd_info *mtd, int chipnr) chip->IO_ADDR_R = fmc2->data_base[fmc2->cs_sel]; chip->IO_ADDR_W = fmc2->data_base[fmc2->cs_sel];
- /* FMC2 setup routine */ stm32_fmc2_setup(chip); - - /* Apply timings */ stm32_fmc2_timings_init(chip); }
-/* Set bus width to 16-bit or 8-bit */ static void stm32_fmc2_set_buswidth_16(struct stm32_fmc2_nfc *fmc2, bool set) { u32 pcr = readl(fmc2->io_base + FMC2_PCR); @@ -274,7 +267,6 @@ static void stm32_fmc2_set_buswidth_16(struct stm32_fmc2_nfc *fmc2, bool set) writel(pcr, fmc2->io_base + FMC2_PCR); }
-/* Enable/disable ECC */ static void stm32_fmc2_set_ecc(struct stm32_fmc2_nfc *fmc2, bool enable) { u32 pcr = readl(fmc2->io_base + FMC2_PCR); @@ -285,13 +277,11 @@ static void stm32_fmc2_set_ecc(struct stm32_fmc2_nfc *fmc2, bool enable) writel(pcr, fmc2->io_base + FMC2_PCR); }
-/* Clear irq sources in case of bch is used */ static inline void stm32_fmc2_clear_bch_irq(struct stm32_fmc2_nfc *fmc2) { writel(FMC2_BCHICR_CLEAR_IRQ, fmc2->io_base + FMC2_BCHICR); }
-/* Send command and address cycles */ static void stm32_fmc2_cmd_ctrl(struct mtd_info *mtd, int cmd, unsigned int ctrl) { @@ -361,7 +351,6 @@ static int stm32_fmc2_ham_calculate(struct mtd_info *mtd, const u8 *data, ecc[1] = heccr >> 8; ecc[2] = heccr >> 16;
- /* Disable ecc */ stm32_fmc2_set_ecc(fmc2, false);
return 0; @@ -466,13 +455,11 @@ static int stm32_fmc2_bch_calculate(struct mtd_info *mtd, const u8 *data, ecc[12] = bchpbr; }
return 0; }
-/* BCH algorithm correction */ static int stm32_fmc2_bch_correct(struct mtd_info *mtd, u8 *dat, u8 *read_ecc, u8 *calc_ecc) { @@ -497,7 +484,6 @@ static int stm32_fmc2_bch_correct(struct mtd_info *mtd, u8 *dat, bchdsr3 = readl(fmc2->io_base + FMC2_BCHDSR3); bchdsr4 = readl(fmc2->io_base + FMC2_BCHDSR4);
- /* Disable ECC */ stm32_fmc2_set_ecc(fmc2, false);
/* No errors found */ @@ -579,7 +565,6 @@ static int stm32_fmc2_read_page(struct mtd_info *mtd, return max_bitflips; }
-/* Controller initialization */ static void stm32_fmc2_init(struct stm32_fmc2_nfc *fmc2) { u32 pcr = readl(fmc2->io_base + FMC2_PCR); @@ -622,7 +607,6 @@ static void stm32_fmc2_init(struct stm32_fmc2_nfc *fmc2) writel(FMC2_PATT_DEFAULT, fmc2->io_base + FMC2_PATT); }
-/* Controller timings */ static void stm32_fmc2_calc_timings(struct nand_chip *chip, const struct nand_sdr_timings *sdrt) { @@ -768,13 +752,11 @@ static int stm32_fmc2_setup_interface(struct mtd_info *mtd, int chipnr,
stm32_fmc2_calc_timings(chip, sdrt);
return 0; }
-/* NAND callbacks setup */ static void stm32_fmc2_nand_callbacks_setup(struct nand_chip *chip) { chip->ecc.hwctl = stm32_fmc2_hwctl; @@ -803,7 +785,6 @@ static void stm32_fmc2_nand_callbacks_setup(struct nand_chip *chip) chip->ecc.bytes = chip->options & NAND_BUSWIDTH_16 ? 8 : 7; }
-/* FMC2 caps */ static int stm32_fmc2_calc_ecc_bytes(int step_size, int strength) { /* Hamming */ @@ -822,7 +803,6 @@ NAND_ECC_CAPS_SINGLE(stm32_fmc2_ecc_caps, stm32_fmc2_calc_ecc_bytes, FMC2_ECC_STEP_SIZE, FMC2_ECC_HAM, FMC2_ECC_BCH4, FMC2_ECC_BCH8);
-/* FMC2 probe */ static int stm32_fmc2_parse_child(struct stm32_fmc2_nfc *fmc2, ofnode node) { @@ -969,7 +949,6 @@ static int stm32_fmc2_probe(struct udevice *dev) reset_deassert(&reset); }
- /* FMC2 init routine */ stm32_fmc2_init(fmc2);
chip->controller = &fmc2->base; @@ -985,7 +964,6 @@ static int stm32_fmc2_probe(struct udevice *dev) chip->ecc.size = FMC2_ECC_STEP_SIZE; chip->ecc.strength = FMC2_ECC_BCH8;
- /* Scan to find existence of the device */ ret = nand_scan_ident(mtd, nand->ncs, NULL); if (ret) return ret; @@ -1012,7 +990,6 @@ static int stm32_fmc2_probe(struct udevice *dev) if (chip->bbt_options & NAND_BBT_USE_FLASH) chip->bbt_options |= NAND_BBT_NO_OOB;
- /* NAND callbacks setup */ stm32_fmc2_nand_callbacks_setup(chip);
/* Define ECC layout */ @@ -1026,11 +1003,9 @@ static int stm32_fmc2_probe(struct udevice *dev) ecclayout->oobfree->length = mtd->oobsize - ecclayout->oobfree->offset; chip->ecc.layout = ecclayout;
- /* Configure bus width to 16-bit */ if (chip->options & NAND_BUSWIDTH_16) stm32_fmc2_set_buswidth_16(fmc2, true);
- /* Scan the device to fill MTD data-structures */ ret = nand_scan_tail(mtd); if (ret) return ret;
Hi Christophe
Thanks
Patrice
On 8/13/20 9:28 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
Thanks
Patrice
FMC2_TIMEOUT_5S will be used each time that we need to wait. It was seen, during stress tests in an overloaded system, that we could be close to 1 second, even if we never met this value. To be safe, FMC2_TIMEOUT_MS is set to 5 seconds.
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index f43e3ec..2e947a3 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -131,6 +131,8 @@
#define FMC2_NSEC_PER_SEC 1000000000L
+#define FMC2_TIMEOUT_5S 5000000 + enum stm32_fmc2_ecc { FMC2_ECC_HAM = 1, FMC2_ECC_BCH4 = 4, @@ -339,7 +341,7 @@ static int stm32_fmc2_ham_calculate(struct mtd_info *mtd, const u8 *data, int ret;
ret = readl_poll_timeout(fmc2->io_base + FMC2_SR, sr, - sr & FMC2_SR_NWRF, 10000); + sr & FMC2_SR_NWRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Ham timeout\n"); return ret; @@ -424,7 +426,7 @@ static int stm32_fmc2_bch_calculate(struct mtd_info *mtd, const u8 *data,
/* Wait until the BCH code is ready */ ret = readl_poll_timeout(fmc2->io_base + FMC2_BCHISR, bchisr, - bchisr & FMC2_BCHISR_EPBRF, 10000); + bchisr & FMC2_BCHISR_EPBRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n"); return ret; @@ -472,7 +474,7 @@ static int stm32_fmc2_bch_correct(struct mtd_info *mtd, u8 *dat,
/* Wait until the decoding error is ready */ ret = readl_poll_timeout(fmc2->io_base + FMC2_BCHISR, bchisr, - bchisr & FMC2_BCHISR_DERF, 10000); + bchisr & FMC2_BCHISR_DERF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n"); return ret;
Hi Christophe
if (ret < 0) { pr_err("Ham timeout\n"); return ret;sr & FMC2_SR_NWRF, FMC2_TIMEOUT_5S);
if (ret < 0) { pr_err("Bch timeout\n"); return ret;bchisr & FMC2_BCHISR_EPBRF, FMC2_TIMEOUT_5S);
if (ret < 0) { pr_err("Bch timeout\n"); return ret;bchisr & FMC2_BCHISR_DERF, FMC2_TIMEOUT_5S);
Thanks
Patrice
On 8/13/20 9:29 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
Thanks
Patrice
This patch renames functions and local variables. This cleanup is done to get all functions starting by stm32_fmc2_nfc in the FMC2 raw NAND driver when all functions will start by stm32_fmc2_ebi in the FMC2 EBI driver.
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 263 ++++++++++++++++----------------- 1 file changed, 131 insertions(+), 132 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 2e947a3..9718bae 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -181,12 +181,12 @@ static inline struct stm32_fmc2_nfc *to_stm32_nfc(struct nand_hw_control *base) return container_of(base, struct stm32_fmc2_nfc, base); }
-static void stm32_fmc2_timings_init(struct nand_chip *chip) +static void stm32_fmc2_nfc_timings_init(struct nand_chip *chip) { - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip); struct stm32_fmc2_timings *timings = &nand->timings; - u32 pcr = readl(fmc2->io_base + FMC2_PCR); + u32 pcr = readl(nfc->io_base + FMC2_PCR); u32 pmem, patt;
/* Set tclr/tar timings */ @@ -207,15 +207,15 @@ static void stm32_fmc2_timings_init(struct nand_chip *chip) patt |= FMC2_PATT_ATTHOLD(timings->thold_att); patt |= FMC2_PATT_ATTHIZ(timings->thiz);
- writel(pcr, fmc2->io_base + FMC2_PCR); - writel(pmem, fmc2->io_base + FMC2_PMEM); - writel(patt, fmc2->io_base + FMC2_PATT); + writel(pcr, nfc->io_base + FMC2_PCR); + writel(pmem, nfc->io_base + FMC2_PMEM); + writel(patt, nfc->io_base + FMC2_PATT); }
-static void stm32_fmc2_setup(struct nand_chip *chip) +static void stm32_fmc2_nfc_setup(struct nand_chip *chip) { - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); - u32 pcr = readl(fmc2->io_base + FMC2_PCR); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); + u32 pcr = readl(nfc->io_base + FMC2_PCR);
/* Configure ECC algorithm (default configuration is Hamming) */ pcr &= ~FMC2_PCR_ECCALG; @@ -236,95 +236,96 @@ static void stm32_fmc2_setup(struct nand_chip *chip) pcr &= ~FMC2_PCR_ECCSS_MASK; pcr |= FMC2_PCR_ECCSS(FMC2_PCR_ECCSS_512);
- writel(pcr, fmc2->io_base + FMC2_PCR); + writel(pcr, nfc->io_base + FMC2_PCR); }
-static void stm32_fmc2_select_chip(struct mtd_info *mtd, int chipnr) +static void stm32_fmc2_nfc_select_chip(struct mtd_info *mtd, int chipnr) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip);
if (chipnr < 0 || chipnr >= nand->ncs) return;
- if (nand->cs_used[chipnr] == fmc2->cs_sel) + if (nand->cs_used[chipnr] == nfc->cs_sel) return;
- fmc2->cs_sel = nand->cs_used[chipnr]; - chip->IO_ADDR_R = fmc2->data_base[fmc2->cs_sel]; - chip->IO_ADDR_W = fmc2->data_base[fmc2->cs_sel]; + nfc->cs_sel = nand->cs_used[chipnr]; + chip->IO_ADDR_R = nfc->data_base[nfc->cs_sel]; + chip->IO_ADDR_W = nfc->data_base[nfc->cs_sel];
- stm32_fmc2_setup(chip); - stm32_fmc2_timings_init(chip); + stm32_fmc2_nfc_setup(chip); + stm32_fmc2_nfc_timings_init(chip); }
-static void stm32_fmc2_set_buswidth_16(struct stm32_fmc2_nfc *fmc2, bool set) +static void stm32_fmc2_nfc_set_buswidth_16(struct stm32_fmc2_nfc *nfc, + bool set) { - u32 pcr = readl(fmc2->io_base + FMC2_PCR); + u32 pcr = readl(nfc->io_base + FMC2_PCR);
pcr &= ~FMC2_PCR_PWID_MASK; if (set) pcr |= FMC2_PCR_PWID(FMC2_PCR_PWID_BUSWIDTH_16); - writel(pcr, fmc2->io_base + FMC2_PCR); + writel(pcr, nfc->io_base + FMC2_PCR); }
-static void stm32_fmc2_set_ecc(struct stm32_fmc2_nfc *fmc2, bool enable) +static void stm32_fmc2_nfc_set_ecc(struct stm32_fmc2_nfc *nfc, bool enable) { - u32 pcr = readl(fmc2->io_base + FMC2_PCR); + u32 pcr = readl(nfc->io_base + FMC2_PCR);
pcr &= ~FMC2_PCR_ECCEN; if (enable) pcr |= FMC2_PCR_ECCEN; - writel(pcr, fmc2->io_base + FMC2_PCR); + writel(pcr, nfc->io_base + FMC2_PCR); }
-static inline void stm32_fmc2_clear_bch_irq(struct stm32_fmc2_nfc *fmc2) +static void stm32_fmc2_nfc_clear_bch_irq(struct stm32_fmc2_nfc *nfc) { - writel(FMC2_BCHICR_CLEAR_IRQ, fmc2->io_base + FMC2_BCHICR); + writel(FMC2_BCHICR_CLEAR_IRQ, nfc->io_base + FMC2_BCHICR); }
-static void stm32_fmc2_cmd_ctrl(struct mtd_info *mtd, int cmd, - unsigned int ctrl) +static void stm32_fmc2_nfc_cmd_ctrl(struct mtd_info *mtd, int cmd, + unsigned int ctrl) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller);
if (cmd == NAND_CMD_NONE) return;
if (ctrl & NAND_CLE) { - writeb(cmd, fmc2->cmd_base[fmc2->cs_sel]); + writeb(cmd, nfc->cmd_base[nfc->cs_sel]); return; }
- writeb(cmd, fmc2->addr_base[fmc2->cs_sel]); + writeb(cmd, nfc->addr_base[nfc->cs_sel]); }
/* * Enable ECC logic and reset syndrome/parity bits previously calculated * Syndrome/parity bits is cleared by setting the ECCEN bit to 0 */ -static void stm32_fmc2_hwctl(struct mtd_info *mtd, int mode) +static void stm32_fmc2_nfc_hwctl(struct mtd_info *mtd, int mode) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller);
- stm32_fmc2_set_ecc(fmc2, false); + stm32_fmc2_nfc_set_ecc(nfc, false);
if (chip->ecc.strength != FMC2_ECC_HAM) { - u32 pcr = readl(fmc2->io_base + FMC2_PCR); + u32 pcr = readl(nfc->io_base + FMC2_PCR);
if (mode == NAND_ECC_WRITE) pcr |= FMC2_PCR_WEN; else pcr &= ~FMC2_PCR_WEN; - writel(pcr, fmc2->io_base + FMC2_PCR); + writel(pcr, nfc->io_base + FMC2_PCR);
- stm32_fmc2_clear_bch_irq(fmc2); + stm32_fmc2_nfc_clear_bch_irq(nfc); }
- stm32_fmc2_set_ecc(fmc2, true); + stm32_fmc2_nfc_set_ecc(nfc, true); }
/* @@ -332,34 +333,34 @@ static void stm32_fmc2_hwctl(struct mtd_info *mtd, int mode) * ECC is 3 bytes for 512 bytes of data (supports error correction up to * max of 1-bit) */ -static int stm32_fmc2_ham_calculate(struct mtd_info *mtd, const u8 *data, - u8 *ecc) +static int stm32_fmc2_nfc_ham_calculate(struct mtd_info *mtd, const u8 *data, + u8 *ecc) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); u32 heccr, sr; int ret;
- ret = readl_poll_timeout(fmc2->io_base + FMC2_SR, sr, + ret = readl_poll_timeout(nfc->io_base + FMC2_SR, sr, sr & FMC2_SR_NWRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Ham timeout\n"); return ret; }
- heccr = readl(fmc2->io_base + FMC2_HECCR); + heccr = readl(nfc->io_base + FMC2_HECCR);
ecc[0] = heccr; ecc[1] = heccr >> 8; ecc[2] = heccr >> 16;
return 0; }
-static int stm32_fmc2_ham_correct(struct mtd_info *mtd, u8 *dat, - u8 *read_ecc, u8 *calc_ecc) +static int stm32_fmc2_nfc_ham_correct(struct mtd_info *mtd, u8 *dat, + u8 *read_ecc, u8 *calc_ecc) { u8 bit_position = 0, b0, b1, b2; u32 byte_addr = 0, b; @@ -416,16 +417,16 @@ static int stm32_fmc2_ham_correct(struct mtd_info *mtd, u8 *dat, * max of 4-bit/8-bit) */
-static int stm32_fmc2_bch_calculate(struct mtd_info *mtd, const u8 *data, - u8 *ecc) +static int stm32_fmc2_nfc_bch_calculate(struct mtd_info *mtd, const u8 *data, + u8 *ecc) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); u32 bchpbr, bchisr; int ret;
/* Wait until the BCH code is ready */ - ret = readl_poll_timeout(fmc2->io_base + FMC2_BCHISR, bchisr, + ret = readl_poll_timeout(nfc->io_base + FMC2_BCHISR, bchisr, bchisr & FMC2_BCHISR_EPBRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n"); @@ -433,13 +434,13 @@ static int stm32_fmc2_bch_calculate(struct mtd_info *mtd, const u8 *data, }
/* Read parity bits */ - bchpbr = readl(fmc2->io_base + FMC2_BCHPBR1); + bchpbr = readl(nfc->io_base + FMC2_BCHPBR1); ecc[0] = bchpbr; ecc[1] = bchpbr >> 8; ecc[2] = bchpbr >> 16; ecc[3] = bchpbr >> 24;
- bchpbr = readl(fmc2->io_base + FMC2_BCHPBR2); + bchpbr = readl(nfc->io_base + FMC2_BCHPBR2); ecc[4] = bchpbr; ecc[5] = bchpbr >> 8; ecc[6] = bchpbr >> 16; @@ -447,46 +448,46 @@ static int stm32_fmc2_bch_calculate(struct mtd_info *mtd, const u8 *data, if (chip->ecc.strength == FMC2_ECC_BCH8) { ecc[7] = bchpbr >> 24;
- bchpbr = readl(fmc2->io_base + FMC2_BCHPBR3); + bchpbr = readl(nfc->io_base + FMC2_BCHPBR3); ecc[8] = bchpbr; ecc[9] = bchpbr >> 8; ecc[10] = bchpbr >> 16; ecc[11] = bchpbr >> 24;
- bchpbr = readl(fmc2->io_base + FMC2_BCHPBR4); + bchpbr = readl(nfc->io_base + FMC2_BCHPBR4); ecc[12] = bchpbr; }
return 0; }
-static int stm32_fmc2_bch_correct(struct mtd_info *mtd, u8 *dat, - u8 *read_ecc, u8 *calc_ecc) +static int stm32_fmc2_nfc_bch_correct(struct mtd_info *mtd, u8 *dat, + u8 *read_ecc, u8 *calc_ecc) { struct nand_chip *chip = mtd_to_nand(mtd); - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); u32 bchdsr0, bchdsr1, bchdsr2, bchdsr3, bchdsr4, bchisr; u16 pos[8]; int i, ret, den, eccsize = chip->ecc.size; unsigned int nb_errs = 0;
/* Wait until the decoding error is ready */ - ret = readl_poll_timeout(fmc2->io_base + FMC2_BCHISR, bchisr, + ret = readl_poll_timeout(nfc->io_base + FMC2_BCHISR, bchisr, bchisr & FMC2_BCHISR_DERF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n"); return ret; }
- bchdsr0 = readl(fmc2->io_base + FMC2_BCHDSR0); - bchdsr1 = readl(fmc2->io_base + FMC2_BCHDSR1); - bchdsr2 = readl(fmc2->io_base + FMC2_BCHDSR2); - bchdsr3 = readl(fmc2->io_base + FMC2_BCHDSR3); - bchdsr4 = readl(fmc2->io_base + FMC2_BCHDSR4); + bchdsr0 = readl(nfc->io_base + FMC2_BCHDSR0); + bchdsr1 = readl(nfc->io_base + FMC2_BCHDSR1); + bchdsr2 = readl(nfc->io_base + FMC2_BCHDSR2); + bchdsr3 = readl(nfc->io_base + FMC2_BCHDSR3); + bchdsr4 = readl(nfc->io_base + FMC2_BCHDSR4);
/* No errors found */ if (likely(!(bchdsr0 & FMC2_BCHDSR0_DEF))) @@ -516,9 +517,9 @@ static int stm32_fmc2_bch_correct(struct mtd_info *mtd, u8 *dat, return nb_errs; }
-static int stm32_fmc2_read_page(struct mtd_info *mtd, - struct nand_chip *chip, u8 *buf, - int oob_required, int page) +static int stm32_fmc2_nfc_read_page(struct mtd_info *mtd, + struct nand_chip *chip, u8 *buf, + int oob_required, int page) { int i, s, stat, eccsize = chip->ecc.size; int eccbytes = chip->ecc.bytes; @@ -567,13 +568,13 @@ static int stm32_fmc2_read_page(struct mtd_info *mtd, return max_bitflips; }
-static void stm32_fmc2_init(struct stm32_fmc2_nfc *fmc2) +static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) { - u32 pcr = readl(fmc2->io_base + FMC2_PCR); - u32 bcr1 = readl(fmc2->io_base + FMC2_BCR1); + u32 pcr = readl(nfc->io_base + FMC2_PCR); + u32 bcr1 = readl(nfc->io_base + FMC2_BCR1);
/* Set CS used to undefined */ - fmc2->cs_sel = -1; + nfc->cs_sel = -1;
/* Enable wait feature and nand flash memory bank */ pcr |= FMC2_PCR_PWAITEN; @@ -603,19 +604,19 @@ static void stm32_fmc2_init(struct stm32_fmc2_nfc *fmc2) /* Enable FMC2 controller */ bcr1 |= FMC2_BCR1_FMC2EN;
- writel(bcr1, fmc2->io_base + FMC2_BCR1); - writel(pcr, fmc2->io_base + FMC2_PCR); - writel(FMC2_PMEM_DEFAULT, fmc2->io_base + FMC2_PMEM); - writel(FMC2_PATT_DEFAULT, fmc2->io_base + FMC2_PATT); + writel(bcr1, nfc->io_base + FMC2_BCR1); + writel(pcr, nfc->io_base + FMC2_PCR); + writel(FMC2_PMEM_DEFAULT, nfc->io_base + FMC2_PMEM); + writel(FMC2_PATT_DEFAULT, nfc->io_base + FMC2_PATT); }
-static void stm32_fmc2_calc_timings(struct nand_chip *chip, - const struct nand_sdr_timings *sdrt) +static void stm32_fmc2_nfc_calc_timings(struct nand_chip *chip, + const struct nand_sdr_timings *sdrt) { - struct stm32_fmc2_nfc *fmc2 = to_stm32_nfc(chip->controller); + struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip); struct stm32_fmc2_timings *tims = &nand->timings; - unsigned long hclk = clk_get_rate(&fmc2->clk); + unsigned long hclk = clk_get_rate(&nfc->clk); unsigned long hclkp = FMC2_NSEC_PER_SEC / (hclk / 1000); unsigned long timing, tar, tclr, thiz, twait; unsigned long tset_mem, tset_att, thold_mem, thold_att; @@ -739,29 +740,28 @@ static void stm32_fmc2_calc_timings(struct nand_chip *chip, tims->thold_att = clamp_val(timing, 1, FMC2_PMEM_PATT_TIMING_MASK); }
-static int stm32_fmc2_setup_interface(struct mtd_info *mtd, int chipnr, - const struct nand_data_interface *conf) +static int stm32_fmc2_nfc_setup_interface(struct mtd_info *mtd, int chipnr, + const struct nand_data_interface *cf) { struct nand_chip *chip = mtd_to_nand(mtd); const struct nand_sdr_timings *sdrt;
- sdrt = nand_get_sdr_timings(conf); + sdrt = nand_get_sdr_timings(cf); if (IS_ERR(sdrt)) return PTR_ERR(sdrt);
if (chipnr == NAND_DATA_IFACE_CHECK_ONLY) return 0;
- stm32_fmc2_calc_timings(chip, sdrt); - - stm32_fmc2_timings_init(chip); + stm32_fmc2_nfc_calc_timings(chip, sdrt); + stm32_fmc2_nfc_timings_init(chip);
return 0; }
-static void stm32_fmc2_nand_callbacks_setup(struct nand_chip *chip) +static void stm32_fmc2_nfc_nand_callbacks_setup(struct nand_chip *chip) { - chip->ecc.hwctl = stm32_fmc2_hwctl; + chip->ecc.hwctl = stm32_fmc2_nfc_hwctl;
/* * Specific callbacks to read/write a page depending on @@ -769,17 +769,17 @@ static void stm32_fmc2_nand_callbacks_setup(struct nand_chip *chip) */ if (chip->ecc.strength == FMC2_ECC_HAM) { /* Hamming is used */ - chip->ecc.calculate = stm32_fmc2_ham_calculate; - chip->ecc.correct = stm32_fmc2_ham_correct; + chip->ecc.calculate = stm32_fmc2_nfc_ham_calculate; + chip->ecc.correct = stm32_fmc2_nfc_ham_correct; chip->ecc.bytes = chip->options & NAND_BUSWIDTH_16 ? 4 : 3; chip->ecc.options |= NAND_ECC_GENERIC_ERASED_CHECK; return; }
/* BCH is used */ - chip->ecc.read_page = stm32_fmc2_read_page; - chip->ecc.calculate = stm32_fmc2_bch_calculate; - chip->ecc.correct = stm32_fmc2_bch_correct; + chip->ecc.read_page = stm32_fmc2_nfc_read_page; + chip->ecc.calculate = stm32_fmc2_nfc_bch_calculate; + chip->ecc.correct = stm32_fmc2_nfc_bch_correct;
if (chip->ecc.strength == FMC2_ECC_BCH8) chip->ecc.bytes = chip->options & NAND_BUSWIDTH_16 ? 14 : 13; @@ -787,7 +787,7 @@ static void stm32_fmc2_nand_callbacks_setup(struct nand_chip *chip) chip->ecc.bytes = chip->options & NAND_BUSWIDTH_16 ? 8 : 7; }
-static int stm32_fmc2_calc_ecc_bytes(int step_size, int strength) +static int stm32_fmc2_nfc_calc_ecc_bytes(int step_size, int strength) { /* Hamming */ if (strength == FMC2_ECC_HAM) @@ -801,14 +801,13 @@ static int stm32_fmc2_calc_ecc_bytes(int step_size, int strength) return 8; }
-NAND_ECC_CAPS_SINGLE(stm32_fmc2_ecc_caps, stm32_fmc2_calc_ecc_bytes, +NAND_ECC_CAPS_SINGLE(stm32_fmc2_nfc_ecc_caps, stm32_fmc2_nfc_calc_ecc_bytes, FMC2_ECC_STEP_SIZE, FMC2_ECC_HAM, FMC2_ECC_BCH4, FMC2_ECC_BCH8);
-static int stm32_fmc2_parse_child(struct stm32_fmc2_nfc *fmc2, - ofnode node) +static int stm32_fmc2_nfc_parse_child(struct stm32_fmc2_nfc *nfc, ofnode node) { - struct stm32_fmc2_nand *nand = &fmc2->nand; + struct stm32_fmc2_nand *nand = &nfc->nand; u32 cs[FMC2_MAX_CE]; int ret, i;
@@ -834,13 +833,13 @@ static int stm32_fmc2_parse_child(struct stm32_fmc2_nfc *fmc2, return -EINVAL; }
- if (fmc2->cs_assigned & BIT(cs[i])) { + if (nfc->cs_assigned & BIT(cs[i])) { pr_err("Cs already assigned: %d\n", nand->cs_used[i]); return -EINVAL; }
- fmc2->cs_assigned |= BIT(cs[i]); + nfc->cs_assigned |= BIT(cs[i]); nand->cs_used[i] = cs[i]; }
@@ -849,8 +848,8 @@ static int stm32_fmc2_parse_child(struct stm32_fmc2_nfc *fmc2, return 0; }
-static int stm32_fmc2_parse_dt(struct udevice *dev, - struct stm32_fmc2_nfc *fmc2) +static int stm32_fmc2_nfc_parse_dt(struct udevice *dev, + struct stm32_fmc2_nfc *nfc) { ofnode child; int ret, nchips = 0; @@ -869,7 +868,7 @@ static int stm32_fmc2_parse_dt(struct udevice *dev, }
dev_for_each_subnode(child, dev) { - ret = stm32_fmc2_parse_child(fmc2, child); + ret = stm32_fmc2_nfc_parse_child(nfc, child); if (ret) return ret; } @@ -877,10 +876,10 @@ static int stm32_fmc2_parse_dt(struct udevice *dev, return 0; }
-static int stm32_fmc2_probe(struct udevice *dev) +static int stm32_fmc2_nfc_probe(struct udevice *dev) { - struct stm32_fmc2_nfc *fmc2 = dev_get_priv(dev); - struct stm32_fmc2_nand *nand = &fmc2->nand; + struct stm32_fmc2_nfc *nfc = dev_get_priv(dev); + struct stm32_fmc2_nand *nand = &nfc->nand; struct nand_chip *chip = &nand->chip; struct mtd_info *mtd = &chip->mtd; struct nand_ecclayout *ecclayout; @@ -889,10 +888,10 @@ static int stm32_fmc2_probe(struct udevice *dev) int oob_index, chip_cs, mem_region, ret; unsigned int i;
- spin_lock_init(&fmc2->controller.lock); - init_waitqueue_head(&fmc2->controller.wq); + spin_lock_init(&nfc->controller.lock); + init_waitqueue_head(&nfc->controller.wq);
- ret = stm32_fmc2_parse_dt(dev, fmc2); + ret = stm32_fmc2_nfc_parse_dt(dev, nfc); if (ret) return ret;
@@ -902,11 +901,11 @@ static int stm32_fmc2_probe(struct udevice *dev) pr_err("Resource io_base not found"); return ret; } - fmc2->io_base = (void __iomem *)resource.start; + nfc->io_base = (void __iomem *)resource.start;
for (chip_cs = 0, mem_region = 1; chip_cs < FMC2_MAX_CE; chip_cs++, mem_region += 3) { - if (!(fmc2->cs_assigned & BIT(chip_cs))) + if (!(nfc->cs_assigned & BIT(chip_cs))) continue;
ret = dev_read_resource(dev, mem_region, &resource); @@ -915,7 +914,7 @@ static int stm32_fmc2_probe(struct udevice *dev) chip_cs); return ret; } - fmc2->data_base[chip_cs] = (void __iomem *)resource.start; + nfc->data_base[chip_cs] = (void __iomem *)resource.start;
ret = dev_read_resource(dev, mem_region + 1, &resource); if (ret) { @@ -923,7 +922,7 @@ static int stm32_fmc2_probe(struct udevice *dev) chip_cs); return ret; } - fmc2->cmd_base[chip_cs] = (void __iomem *)resource.start; + nfc->cmd_base[chip_cs] = (void __iomem *)resource.start;
ret = dev_read_resource(dev, mem_region + 2, &resource); if (ret) { @@ -931,15 +930,15 @@ static int stm32_fmc2_probe(struct udevice *dev) chip_cs); return ret; } - fmc2->addr_base[chip_cs] = (void __iomem *)resource.start; + nfc->addr_base[chip_cs] = (void __iomem *)resource.start; }
/* Enable the clock */ - ret = clk_get_by_index(dev, 0, &fmc2->clk); + ret = clk_get_by_index(dev, 0, &nfc->clk); if (ret) return ret;
- ret = clk_enable(&fmc2->clk); + ret = clk_enable(&nfc->clk); if (ret) return ret;
@@ -951,12 +950,12 @@ static int stm32_fmc2_probe(struct udevice *dev) reset_deassert(&reset); }
- stm32_fmc2_init(fmc2); + stm32_fmc2_nfc_init(nfc);
- chip->controller = &fmc2->base; - chip->select_chip = stm32_fmc2_select_chip; - chip->setup_data_interface = stm32_fmc2_setup_interface; - chip->cmd_ctrl = stm32_fmc2_cmd_ctrl; + chip->controller = &nfc->base; + chip->select_chip = stm32_fmc2_nfc_select_chip; + chip->setup_data_interface = stm32_fmc2_nfc_setup_interface; + chip->cmd_ctrl = stm32_fmc2_nfc_cmd_ctrl; chip->chip_delay = FMC2_RB_DELAY_US; chip->options |= NAND_BUSWIDTH_AUTO | NAND_NO_SUBPAGE_WRITE | NAND_USE_BOUNCE_BUFFER; @@ -982,7 +981,7 @@ static int stm32_fmc2_probe(struct udevice *dev) return -EINVAL; }
- ret = nand_check_ecc_caps(chip, &stm32_fmc2_ecc_caps, + ret = nand_check_ecc_caps(chip, &stm32_fmc2_nfc_ecc_caps, mtd->oobsize - FMC2_BBM_LEN); if (ret) { pr_err("No valid ECC settings set\n"); @@ -992,10 +991,10 @@ static int stm32_fmc2_probe(struct udevice *dev) if (chip->bbt_options & NAND_BBT_USE_FLASH) chip->bbt_options |= NAND_BBT_NO_OOB;
- stm32_fmc2_nand_callbacks_setup(chip); + stm32_fmc2_nfc_nand_callbacks_setup(chip);
/* Define ECC layout */ - ecclayout = &fmc2->ecclayout; + ecclayout = &nfc->ecclayout; ecclayout->eccbytes = chip->ecc.bytes * (mtd->writesize / chip->ecc.size); oob_index = FMC2_BBM_LEN; @@ -1006,7 +1005,7 @@ static int stm32_fmc2_probe(struct udevice *dev) chip->ecc.layout = ecclayout;
if (chip->options & NAND_BUSWIDTH_16) - stm32_fmc2_set_buswidth_16(fmc2, true); + stm32_fmc2_nfc_set_buswidth_16(nfc, true);
ret = nand_scan_tail(mtd); if (ret) @@ -1015,16 +1014,16 @@ static int stm32_fmc2_probe(struct udevice *dev) return nand_register(0, mtd); }
-static const struct udevice_id stm32_fmc2_match[] = { +static const struct udevice_id stm32_fmc2_nfc_match[] = { { .compatible = "st,stm32mp15-fmc2" }, { /* Sentinel */ } };
-U_BOOT_DRIVER(stm32_fmc2_nand) = { - .name = "stm32_fmc2_nand", +U_BOOT_DRIVER(stm32_fmc2_nfc) = { + .name = "stm32_fmc2_nfc", .id = UCLASS_MTD, - .of_match = stm32_fmc2_match, - .probe = stm32_fmc2_probe, + .of_match = stm32_fmc2_nfc_match, + .probe = stm32_fmc2_nfc_probe, .priv_auto_alloc_size = sizeof(struct stm32_fmc2_nfc), };
@@ -1034,9 +1033,9 @@ void board_nand_init(void) int ret;
ret = uclass_get_device_by_driver(UCLASS_MTD, - DM_GET_DRIVER(stm32_fmc2_nand), + DM_GET_DRIVER(stm32_fmc2_nfc), &dev); if (ret && ret != -ENODEV) - pr_err("Failed to initialize STM32 FMC2 NAND controller. (error %d)\n", + pr_err("Failed to initialize STM32 FMC2 NFC controller. (error %d)\n", ret); }
Hi CHristophe
- struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip); struct stm32_fmc2_timings *timings = &nand->timings;
- writel(pcr, nfc->io_base + FMC2_PCR);
- writel(pmem, nfc->io_base + FMC2_PMEM);
- writel(patt, nfc->io_base + FMC2_PATT);
- if (nand->cs_used[chipnr] == nfc->cs_sel) return;
- nfc->cs_sel = nand->cs_used[chipnr];
- chip->IO_ADDR_R = nfc->data_base[nfc->cs_sel];
- chip->IO_ADDR_W = nfc->data_base[nfc->cs_sel];
- stm32_fmc2_nfc_setup(chip);
- stm32_fmc2_nfc_timings_init(chip);
bool set)
- writel(FMC2_BCHICR_CLEAR_IRQ, nfc->io_base + FMC2_BCHICR);
unsigned int ctrl)
unsigned int ctrl)
return; }writeb(cmd, nfc->cmd_base[nfc->cs_sel]);
- writeb(cmd, nfc->addr_base[nfc->cs_sel]);
- Enable ECC logic and reset syndrome/parity bits previously calculated
- Syndrome/parity bits is cleared by setting the ECCEN bit to 0
}stm32_fmc2_nfc_clear_bch_irq(nfc);
- stm32_fmc2_nfc_set_ecc(nfc, true);
- ECC is 3 bytes for 512 bytes of data (supports error correction up to
- max of 1-bit)
u8 *ecc)
u8 *ecc)
- struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); u32 heccr, sr; int ret;
- ret = readl_poll_timeout(nfc->io_base + FMC2_SR, sr, sr & FMC2_SR_NWRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Ham timeout\n"); return ret; }
- max of 4-bit/8-bit)
u8 *ecc)
u8 *ecc)
- ret = readl_poll_timeout(nfc->io_base + FMC2_BCHISR, bchisr, bchisr & FMC2_BCHISR_EPBRF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n");
- bchpbr = readl(nfc->io_base + FMC2_BCHPBR1); ecc[0] = bchpbr; ecc[1] = bchpbr >> 8; ecc[2] = bchpbr >> 16; ecc[3] = bchpbr >> 24;
- bchpbr = readl(nfc->io_base + FMC2_BCHPBR2); ecc[4] = bchpbr; ecc[5] = bchpbr >> 8; ecc[6] = bchpbr >> 16;
ecc[8] = bchpbr; ecc[9] = bchpbr >> 8; ecc[10] = bchpbr >> 16; ecc[11] = bchpbr >> 24;bchpbr = readl(nfc->io_base + FMC2_BCHPBR3);
ecc[12] = bchpbr; }bchpbr = readl(nfc->io_base + FMC2_BCHPBR4);
- ret = readl_poll_timeout(nfc->io_base + FMC2_BCHISR, bchisr, bchisr & FMC2_BCHISR_DERF, FMC2_TIMEOUT_5S); if (ret < 0) { pr_err("Bch timeout\n"); return ret; }
- bchdsr0 = readl(nfc->io_base + FMC2_BCHDSR0);
- bchdsr1 = readl(nfc->io_base + FMC2_BCHDSR1);
- bchdsr2 = readl(nfc->io_base + FMC2_BCHDSR2);
- bchdsr3 = readl(nfc->io_base + FMC2_BCHDSR3);
- bchdsr4 = readl(nfc->io_base + FMC2_BCHDSR4);
nfc->cs_sel = -1;
- writel(bcr1, nfc->io_base + FMC2_BCR1);
- writel(FMC2_PMEM_DEFAULT, nfc->io_base + FMC2_PMEM);
- writel(FMC2_PATT_DEFAULT, nfc->io_base + FMC2_PATT);
- struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip); struct stm32_fmc2_timings *tims = &nand->timings;
- unsigned long hclk = clk_get_rate(&nfc->clk); unsigned long hclkp = FMC2_NSEC_PER_SEC / (hclk / 1000); unsigned long timing, tar, tclr, thiz, twait; unsigned long tset_mem, tset_att, thold_mem, thold_att;
- Specific callbacks to read/write a page depending on
/* BCH is used */
ofnode node)
- struct stm32_fmc2_nand *nand = &nfc->nand; u32 cs[FMC2_MAX_CE]; int ret, i;
}if (nfc->cs_assigned & BIT(cs[i])) { pr_err("Cs already assigned: %d\n", nand->cs_used[i]); return -EINVAL;
nand->cs_used[i] = cs[i]; }nfc->cs_assigned |= BIT(cs[i]);
if (ret) return ret; }ret = stm32_fmc2_nfc_parse_child(nfc, child);
- struct stm32_fmc2_nfc *nfc = dev_get_priv(dev);
- struct stm32_fmc2_nand *nand = &nfc->nand; struct nand_chip *chip = &nand->chip; struct mtd_info *mtd = &chip->mtd; struct nand_ecclayout *ecclayout;
- spin_lock_init(&nfc->controller.lock);
- init_waitqueue_head(&nfc->controller.wq);
- ret = stm32_fmc2_nfc_parse_dt(dev, nfc); if (ret) return ret;
- ret = clk_get_by_index(dev, 0, &nfc->clk); if (ret) return ret;
- ret = clk_enable(&nfc->clk); if (ret) return ret;
- stm32_fmc2_nfc_init(nfc);
- chip->controller = &nfc->base;
- chip->select_chip = stm32_fmc2_nfc_select_chip;
- chip->setup_data_interface = stm32_fmc2_nfc_setup_interface;
- chip->cmd_ctrl = stm32_fmc2_nfc_cmd_ctrl; chip->chip_delay = FMC2_RB_DELAY_US; chip->options |= NAND_BUSWIDTH_AUTO | NAND_NO_SUBPAGE_WRITE | NAND_USE_BOUNCE_BUFFER;
- ret = nand_check_ecc_caps(chip, &stm32_fmc2_nfc_ecc_caps, mtd->oobsize - FMC2_BBM_LEN); if (ret) { pr_err("No valid ECC settings set\n");
- ecclayout = &nfc->ecclayout; ecclayout->eccbytes = chip->ecc.bytes * (mtd->writesize / chip->ecc.size); oob_index = FMC2_BBM_LEN;
- .name = "stm32_fmc2_nfc", .id = UCLASS_MTD,
- .of_match = stm32_fmc2_nfc_match,
- .probe = stm32_fmc2_nfc_probe, .priv_auto_alloc_size = sizeof(struct stm32_fmc2_nfc),
if (ret && ret != -ENODEV)DM_GET_DRIVER(stm32_fmc2_nfc), &dev);
Thanks
Patrice
Thanks
bool set)
unsigned int ctrl)
unsigned int ctrl)
- max of 1-bit)
u8 *ecc)
u8 *ecc)
u8 *ecc)
u8 *ecc)
nfc->cs_sel = -1;
/* BCH is used */
ofnode node)
This patch removes custom macros and uses FIELD_PREP and FIELD_GET macros.
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 120 +++++++++++++++------------------ 1 file changed, 56 insertions(+), 64 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 9718bae..eba1ded 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -10,6 +10,7 @@ #include <log.h> #include <nand.h> #include <reset.h> +#include <linux/bitfield.h> #include <linux/bitops.h> #include <linux/delay.h> #include <linux/err.h> @@ -60,20 +61,16 @@ /* Register: FMC2_PCR */ #define FMC2_PCR_PWAITEN BIT(1) #define FMC2_PCR_PBKEN BIT(2) -#define FMC2_PCR_PWID_MASK GENMASK(5, 4) -#define FMC2_PCR_PWID(x) (((x) & 0x3) << 4) +#define FMC2_PCR_PWID GENMASK(5, 4) #define FMC2_PCR_PWID_BUSWIDTH_8 0 #define FMC2_PCR_PWID_BUSWIDTH_16 1 #define FMC2_PCR_ECCEN BIT(6) #define FMC2_PCR_ECCALG BIT(8) -#define FMC2_PCR_TCLR_MASK GENMASK(12, 9) -#define FMC2_PCR_TCLR(x) (((x) & 0xf) << 9) +#define FMC2_PCR_TCLR GENMASK(12, 9) #define FMC2_PCR_TCLR_DEFAULT 0xf -#define FMC2_PCR_TAR_MASK GENMASK(16, 13) -#define FMC2_PCR_TAR(x) (((x) & 0xf) << 13) +#define FMC2_PCR_TAR GENMASK(16, 13) #define FMC2_PCR_TAR_DEFAULT 0xf -#define FMC2_PCR_ECCSS_MASK GENMASK(19, 17) -#define FMC2_PCR_ECCSS(x) (((x) & 0x7) << 17) +#define FMC2_PCR_ECCSS GENMASK(19, 17) #define FMC2_PCR_ECCSS_512 1 #define FMC2_PCR_ECCSS_2048 3 #define FMC2_PCR_BCHECC BIT(24) @@ -83,17 +80,17 @@ #define FMC2_SR_NWRF BIT(6)
/* Register: FMC2_PMEM */ -#define FMC2_PMEM_MEMSET(x) (((x) & 0xff) << 0) -#define FMC2_PMEM_MEMWAIT(x) (((x) & 0xff) << 8) -#define FMC2_PMEM_MEMHOLD(x) (((x) & 0xff) << 16) -#define FMC2_PMEM_MEMHIZ(x) (((x) & 0xff) << 24) +#define FMC2_PMEM_MEMSET GENMASK(7, 0) +#define FMC2_PMEM_MEMWAIT GENMASK(15, 8) +#define FMC2_PMEM_MEMHOLD GENMASK(23, 16) +#define FMC2_PMEM_MEMHIZ GENMASK(31, 24) #define FMC2_PMEM_DEFAULT 0x0a0a0a0a
/* Register: FMC2_PATT */ -#define FMC2_PATT_ATTSET(x) (((x) & 0xff) << 0) -#define FMC2_PATT_ATTWAIT(x) (((x) & 0xff) << 8) -#define FMC2_PATT_ATTHOLD(x) (((x) & 0xff) << 16) -#define FMC2_PATT_ATTHIZ(x) (((x) & 0xff) << 24) +#define FMC2_PATT_ATTSET GENMASK(7, 0) +#define FMC2_PATT_ATTWAIT GENMASK(15, 8) +#define FMC2_PATT_ATTHOLD GENMASK(23, 16) +#define FMC2_PATT_ATTHIZ GENMASK(31, 24) #define FMC2_PATT_DEFAULT 0x0a0a0a0a
/* Register: FMC2_BCHISR */ @@ -106,28 +103,23 @@ /* Register: FMC2_BCHDSR0 */ #define FMC2_BCHDSR0_DUE BIT(0) #define FMC2_BCHDSR0_DEF BIT(1) -#define FMC2_BCHDSR0_DEN_MASK GENMASK(7, 4) -#define FMC2_BCHDSR0_DEN_SHIFT 4 +#define FMC2_BCHDSR0_DEN GENMASK(7, 4)
/* Register: FMC2_BCHDSR1 */ -#define FMC2_BCHDSR1_EBP1_MASK GENMASK(12, 0) -#define FMC2_BCHDSR1_EBP2_MASK GENMASK(28, 16) -#define FMC2_BCHDSR1_EBP2_SHIFT 16 +#define FMC2_BCHDSR1_EBP1 GENMASK(12, 0) +#define FMC2_BCHDSR1_EBP2 GENMASK(28, 16)
/* Register: FMC2_BCHDSR2 */ -#define FMC2_BCHDSR2_EBP3_MASK GENMASK(12, 0) -#define FMC2_BCHDSR2_EBP4_MASK GENMASK(28, 16) -#define FMC2_BCHDSR2_EBP4_SHIFT 16 +#define FMC2_BCHDSR2_EBP3 GENMASK(12, 0) +#define FMC2_BCHDSR2_EBP4 GENMASK(28, 16)
/* Register: FMC2_BCHDSR3 */ -#define FMC2_BCHDSR3_EBP5_MASK GENMASK(12, 0) -#define FMC2_BCHDSR3_EBP6_MASK GENMASK(28, 16) -#define FMC2_BCHDSR3_EBP6_SHIFT 16 +#define FMC2_BCHDSR3_EBP5 GENMASK(12, 0) +#define FMC2_BCHDSR3_EBP6 GENMASK(28, 16)
/* Register: FMC2_BCHDSR4 */ -#define FMC2_BCHDSR4_EBP7_MASK GENMASK(12, 0) -#define FMC2_BCHDSR4_EBP8_MASK GENMASK(28, 16) -#define FMC2_BCHDSR4_EBP8_SHIFT 16 +#define FMC2_BCHDSR4_EBP7 GENMASK(12, 0) +#define FMC2_BCHDSR4_EBP8 GENMASK(28, 16)
@@ -190,22 +182,22 @@ static void stm32_fmc2_nfc_timings_init(struct nand_chip *chip) u32 pmem, patt;
/* Set tclr/tar timings */ - pcr &= ~FMC2_PCR_TCLR_MASK; - pcr |= FMC2_PCR_TCLR(timings->tclr); - pcr &= ~FMC2_PCR_TAR_MASK; - pcr |= FMC2_PCR_TAR(timings->tar); + pcr &= ~FMC2_PCR_TCLR; + pcr |= FIELD_PREP(FMC2_PCR_TCLR, timings->tclr); + pcr &= ~FMC2_PCR_TAR; + pcr |= FIELD_PREP(FMC2_PCR_TAR, timings->tar);
/* Set tset/twait/thold/thiz timings in common bank */ - pmem = FMC2_PMEM_MEMSET(timings->tset_mem); - pmem |= FMC2_PMEM_MEMWAIT(timings->twait); - pmem |= FMC2_PMEM_MEMHOLD(timings->thold_mem); - pmem |= FMC2_PMEM_MEMHIZ(timings->thiz); + pmem = FIELD_PREP(FMC2_PMEM_MEMSET, timings->tset_mem); + pmem |= FIELD_PREP(FMC2_PMEM_MEMWAIT, timings->twait); + pmem |= FIELD_PREP(FMC2_PMEM_MEMHOLD, timings->thold_mem); + pmem |= FIELD_PREP(FMC2_PMEM_MEMHIZ, timings->thiz);
/* Set tset/twait/thold/thiz timings in attribut bank */ - patt = FMC2_PATT_ATTSET(timings->tset_att); - patt |= FMC2_PATT_ATTWAIT(timings->twait); - patt |= FMC2_PATT_ATTHOLD(timings->thold_att); - patt |= FMC2_PATT_ATTHIZ(timings->thiz); + patt = FIELD_PREP(FMC2_PATT_ATTSET, timings->tset_att); + patt |= FIELD_PREP(FMC2_PATT_ATTWAIT, timings->twait); + patt |= FIELD_PREP(FMC2_PATT_ATTHOLD, timings->thold_att); + patt |= FIELD_PREP(FMC2_PATT_ATTHIZ, timings->thiz);
writel(pcr, nfc->io_base + FMC2_PCR); writel(pmem, nfc->io_base + FMC2_PMEM); @@ -228,13 +220,13 @@ static void stm32_fmc2_nfc_setup(struct nand_chip *chip) }
/* Set buswidth */ - pcr &= ~FMC2_PCR_PWID_MASK; + pcr &= ~FMC2_PCR_PWID; if (chip->options & NAND_BUSWIDTH_16) - pcr |= FMC2_PCR_PWID(FMC2_PCR_PWID_BUSWIDTH_16); + pcr |= FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16);
/* Set ECC sector size */ - pcr &= ~FMC2_PCR_ECCSS_MASK; - pcr |= FMC2_PCR_ECCSS(FMC2_PCR_ECCSS_512); + pcr &= ~FMC2_PCR_ECCSS; + pcr |= FIELD_PREP(FMC2_PCR_ECCSS, FMC2_PCR_ECCSS_512);
writel(pcr, nfc->io_base + FMC2_PCR); } @@ -264,9 +256,9 @@ static void stm32_fmc2_nfc_set_buswidth_16(struct stm32_fmc2_nfc *nfc, { u32 pcr = readl(nfc->io_base + FMC2_PCR);
- pcr &= ~FMC2_PCR_PWID_MASK; + pcr &= ~FMC2_PCR_PWID; if (set) - pcr |= FMC2_PCR_PWID(FMC2_PCR_PWID_BUSWIDTH_16); + pcr |= FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16); writel(pcr, nfc->io_base + FMC2_PCR); }
@@ -497,16 +489,16 @@ static int stm32_fmc2_nfc_bch_correct(struct mtd_info *mtd, u8 *dat, if (unlikely(bchdsr0 & FMC2_BCHDSR0_DUE)) return -EBADMSG;
- pos[0] = bchdsr1 & FMC2_BCHDSR1_EBP1_MASK; - pos[1] = (bchdsr1 & FMC2_BCHDSR1_EBP2_MASK) >> FMC2_BCHDSR1_EBP2_SHIFT; - pos[2] = bchdsr2 & FMC2_BCHDSR2_EBP3_MASK; - pos[3] = (bchdsr2 & FMC2_BCHDSR2_EBP4_MASK) >> FMC2_BCHDSR2_EBP4_SHIFT; - pos[4] = bchdsr3 & FMC2_BCHDSR3_EBP5_MASK; - pos[5] = (bchdsr3 & FMC2_BCHDSR3_EBP6_MASK) >> FMC2_BCHDSR3_EBP6_SHIFT; - pos[6] = bchdsr4 & FMC2_BCHDSR4_EBP7_MASK; - pos[7] = (bchdsr4 & FMC2_BCHDSR4_EBP8_MASK) >> FMC2_BCHDSR4_EBP8_SHIFT; + pos[0] = FIELD_GET(FMC2_BCHDSR1_EBP1, bchdsr1); + pos[1] = FIELD_GET(FMC2_BCHDSR1_EBP2, bchdsr1); + pos[2] = FIELD_GET(FMC2_BCHDSR2_EBP3, bchdsr2); + pos[3] = FIELD_GET(FMC2_BCHDSR2_EBP4, bchdsr2); + pos[4] = FIELD_GET(FMC2_BCHDSR3_EBP5, bchdsr3); + pos[5] = FIELD_GET(FMC2_BCHDSR3_EBP6, bchdsr3); + pos[6] = FIELD_GET(FMC2_BCHDSR4_EBP7, bchdsr4); + pos[7] = FIELD_GET(FMC2_BCHDSR4_EBP8, bchdsr4);
- den = (bchdsr0 & FMC2_BCHDSR0_DEN_MASK) >> FMC2_BCHDSR0_DEN_SHIFT; + den = FIELD_GET(FMC2_BCHDSR0_DEN, bchdsr0); for (i = 0; i < den; i++) { if (pos[i] < eccsize * 8) { __change_bit(pos[i], (unsigned long *)dat); @@ -581,7 +573,7 @@ static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) pcr |= FMC2_PCR_PBKEN;
/* Set buswidth to 8 bits mode for identification */ - pcr &= ~FMC2_PCR_PWID_MASK; + pcr &= ~FMC2_PCR_PWID;
/* ECC logic is disabled */ pcr &= ~FMC2_PCR_ECCEN; @@ -592,14 +584,14 @@ static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) pcr &= ~FMC2_PCR_WEN;
/* Set default ECC sector size */ - pcr &= ~FMC2_PCR_ECCSS_MASK; - pcr |= FMC2_PCR_ECCSS(FMC2_PCR_ECCSS_2048); + pcr &= ~FMC2_PCR_ECCSS; + pcr |= FIELD_PREP(FMC2_PCR_ECCSS, FMC2_PCR_ECCSS_2048);
/* Set default tclr/tar timings */ - pcr &= ~FMC2_PCR_TCLR_MASK; - pcr |= FMC2_PCR_TCLR(FMC2_PCR_TCLR_DEFAULT); - pcr &= ~FMC2_PCR_TAR_MASK; - pcr |= FMC2_PCR_TAR(FMC2_PCR_TAR_DEFAULT); + pcr &= ~FMC2_PCR_TCLR; + pcr |= FIELD_PREP(FMC2_PCR_TCLR, FMC2_PCR_TCLR_DEFAULT); + pcr &= ~FMC2_PCR_TAR; + pcr |= FIELD_PREP(FMC2_PCR_TAR, FMC2_PCR_TAR_DEFAULT);
Hi Christophe
/* Set buswidth */
- pcr &= ~FMC2_PCR_PWID; if (chip->options & NAND_BUSWIDTH_16)
- pcr &= ~FMC2_PCR_PWID; if (set)
writel(pcr, nfc->io_base + FMC2_PCR);pcr |= FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16);
- pos[0] = FIELD_GET(FMC2_BCHDSR1_EBP1, bchdsr1);
- pos[1] = FIELD_GET(FMC2_BCHDSR1_EBP2, bchdsr1);
- pos[2] = FIELD_GET(FMC2_BCHDSR2_EBP3, bchdsr2);
- pos[3] = FIELD_GET(FMC2_BCHDSR2_EBP4, bchdsr2);
- pos[4] = FIELD_GET(FMC2_BCHDSR3_EBP5, bchdsr3);
- pos[5] = FIELD_GET(FMC2_BCHDSR3_EBP6, bchdsr3);
- pos[6] = FIELD_GET(FMC2_BCHDSR4_EBP7, bchdsr4);
- pos[7] = FIELD_GET(FMC2_BCHDSR4_EBP8, bchdsr4);
- den = FIELD_GET(FMC2_BCHDSR0_DEN, bchdsr0); for (i = 0; i < den; i++) { if (pos[i] < eccsize * 8) { __change_bit(pos[i], (unsigned long *)dat);
Thanks
Patrice
Hi Christophe
Thanks
/* Set buswidth */
Thanks
Patrice
This patch uses clrsetbits_le32 function instead of multiple instructions.
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 56 +++++++++++++--------------------- 1 file changed, 21 insertions(+), 35 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index eba1ded..1e4d757 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -178,40 +178,37 @@ static void stm32_fmc2_nfc_timings_init(struct nand_chip *chip) struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); struct stm32_fmc2_nand *nand = to_fmc2_nand(chip); struct stm32_fmc2_timings *timings = &nand->timings; - u32 pcr = readl(nfc->io_base + FMC2_PCR); u32 pmem, patt;
/* Set tclr/tar timings */ - pcr &= ~FMC2_PCR_TCLR; - pcr |= FIELD_PREP(FMC2_PCR_TCLR, timings->tclr); - pcr &= ~FMC2_PCR_TAR; - pcr |= FIELD_PREP(FMC2_PCR_TAR, timings->tar); + clrsetbits_le32(nfc->io_base + FMC2_PCR, + FMC2_PCR_TCLR | FMC2_PCR_TAR, + FIELD_PREP(FMC2_PCR_TCLR, timings->tclr) | + FIELD_PREP(FMC2_PCR_TAR, timings->tar));
/* Set tset/twait/thold/thiz timings in common bank */ pmem = FIELD_PREP(FMC2_PMEM_MEMSET, timings->tset_mem); pmem |= FIELD_PREP(FMC2_PMEM_MEMWAIT, timings->twait); pmem |= FIELD_PREP(FMC2_PMEM_MEMHOLD, timings->thold_mem); pmem |= FIELD_PREP(FMC2_PMEM_MEMHIZ, timings->thiz); + writel(pmem, nfc->io_base + FMC2_PMEM);
/* Set tset/twait/thold/thiz timings in attribut bank */ patt = FIELD_PREP(FMC2_PATT_ATTSET, timings->tset_att); patt |= FIELD_PREP(FMC2_PATT_ATTWAIT, timings->twait); patt |= FIELD_PREP(FMC2_PATT_ATTHOLD, timings->thold_att); patt |= FIELD_PREP(FMC2_PATT_ATTHIZ, timings->thiz); - - writel(pcr, nfc->io_base + FMC2_PCR); - writel(pmem, nfc->io_base + FMC2_PMEM); writel(patt, nfc->io_base + FMC2_PATT); }
static void stm32_fmc2_nfc_setup(struct nand_chip *chip) { struct stm32_fmc2_nfc *nfc = to_stm32_nfc(chip->controller); - u32 pcr = readl(nfc->io_base + FMC2_PCR); + u32 pcr = 0, pcr_mask;
/* Configure ECC algorithm (default configuration is Hamming) */ - pcr &= ~FMC2_PCR_ECCALG; - pcr &= ~FMC2_PCR_BCHECC; + pcr_mask = FMC2_PCR_ECCALG; + pcr_mask |= FMC2_PCR_BCHECC; if (chip->ecc.strength == FMC2_ECC_BCH8) { pcr |= FMC2_PCR_ECCALG; pcr |= FMC2_PCR_BCHECC; @@ -220,15 +217,15 @@ static void stm32_fmc2_nfc_setup(struct nand_chip *chip) }
/* Set buswidth */ - pcr &= ~FMC2_PCR_PWID; + pcr_mask |= FMC2_PCR_PWID; if (chip->options & NAND_BUSWIDTH_16) pcr |= FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16);
/* Set ECC sector size */ - pcr &= ~FMC2_PCR_ECCSS; + pcr_mask |= FMC2_PCR_ECCSS; pcr |= FIELD_PREP(FMC2_PCR_ECCSS, FMC2_PCR_ECCSS_512);
- writel(pcr, nfc->io_base + FMC2_PCR); + clrsetbits_le32(nfc->io_base + FMC2_PCR, pcr_mask, pcr); }
static void stm32_fmc2_nfc_select_chip(struct mtd_info *mtd, int chipnr) @@ -254,22 +251,18 @@ static void stm32_fmc2_nfc_select_chip(struct mtd_info *mtd, int chipnr) static void stm32_fmc2_nfc_set_buswidth_16(struct stm32_fmc2_nfc *nfc, bool set) { - u32 pcr = readl(nfc->io_base + FMC2_PCR); + u32 pcr;
- pcr &= ~FMC2_PCR_PWID; - if (set) - pcr |= FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16); - writel(pcr, nfc->io_base + FMC2_PCR); + pcr = set ? FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16) : + FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_8); + + clrsetbits_le32(nfc->io_base + FMC2_PCR, FMC2_PCR_PWID, pcr); }
static void stm32_fmc2_nfc_set_ecc(struct stm32_fmc2_nfc *nfc, bool enable) { - u32 pcr = readl(nfc->io_base + FMC2_PCR); - - pcr &= ~FMC2_PCR_ECCEN; - if (enable) - pcr |= FMC2_PCR_ECCEN; - writel(pcr, nfc->io_base + FMC2_PCR); + clrsetbits_le32(nfc->io_base + FMC2_PCR, FMC2_PCR_ECCEN, + enable ? FMC2_PCR_ECCEN : 0); }
static void stm32_fmc2_nfc_clear_bch_irq(struct stm32_fmc2_nfc *nfc) @@ -306,13 +299,8 @@ static void stm32_fmc2_nfc_hwctl(struct mtd_info *mtd, int mode) stm32_fmc2_nfc_set_ecc(nfc, false);
if (chip->ecc.strength != FMC2_ECC_HAM) { - u32 pcr = readl(nfc->io_base + FMC2_PCR); - - if (mode == NAND_ECC_WRITE) - pcr |= FMC2_PCR_WEN; - else - pcr &= ~FMC2_PCR_WEN; - writel(pcr, nfc->io_base + FMC2_PCR); + clrsetbits_le32(nfc->io_base + FMC2_PCR, FMC2_PCR_WEN, + mode == NAND_ECC_WRITE ? FMC2_PCR_WEN : 0);
stm32_fmc2_nfc_clear_bch_irq(nfc); } @@ -563,7 +551,6 @@ static int stm32_fmc2_nfc_read_page(struct mtd_info *mtd, static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) { u32 pcr = readl(nfc->io_base + FMC2_PCR); - u32 bcr1 = readl(nfc->io_base + FMC2_BCR1);
/* Set CS used to undefined */ nfc->cs_sel = -1; @@ -594,9 +581,8 @@ static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) pcr |= FIELD_PREP(FMC2_PCR_TAR, FMC2_PCR_TAR_DEFAULT);
/* Enable FMC2 controller */ - bcr1 |= FMC2_BCR1_FMC2EN; + setbits_le32(nfc->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN);
- writel(bcr1, nfc->io_base + FMC2_BCR1); writel(pcr, nfc->io_base + FMC2_PCR); writel(FMC2_PMEM_DEFAULT, nfc->io_base + FMC2_PMEM); writel(FMC2_PATT_DEFAULT, nfc->io_base + FMC2_PATT);
Hi Christophe
- pcr_mask = FMC2_PCR_ECCALG;
- pcr_mask |= FMC2_PCR_BCHECC; if (chip->ecc.strength == FMC2_ECC_BCH8) { pcr |= FMC2_PCR_ECCALG; pcr |= FMC2_PCR_BCHECC;
/* Set buswidth */
- pcr_mask |= FMC2_PCR_ECCSS; pcr |= FIELD_PREP(FMC2_PCR_ECCSS, FMC2_PCR_ECCSS_512);
- clrsetbits_le32(nfc->io_base + FMC2_PCR, pcr_mask, pcr);
- u32 pcr;
- if (set)
- pcr = set ? FIELD_PREP(FMC2_PCR_PWID, FMC2_PCR_PWID_BUSWIDTH_16) :
- clrsetbits_le32(nfc->io_base + FMC2_PCR, FMC2_PCR_PWID, pcr);
- if (enable)
- clrsetbits_le32(nfc->io_base + FMC2_PCR, FMC2_PCR_ECCEN,
else
- setbits_le32(nfc->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN);
Thanks
Patrice
On 8/13/20 9:30 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
/* Set buswidth */
- u32 pcr;
- if (set)
- if (enable)
else
Thanks
Patrice
The driver adds the support for the STMicroelectronics FMC2 EBI controller found on STM32MP SOCs.
drivers/memory/Kconfig | 9 + drivers/memory/Makefile | 1 + drivers/memory/stm32-fmc2-ebi.c | 1056 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 1066 insertions(+) create mode 100644 drivers/memory/stm32-fmc2-ebi.c
diff --git a/drivers/memory/Kconfig b/drivers/memory/Kconfig index 4fbb5aa..7271892 100644 --- a/drivers/memory/Kconfig +++ b/drivers/memory/Kconfig @@ -4,6 +4,15 @@
menu "Memory Controller drivers"
+config STM32_FMC2_EBI + bool "Support for FMC2 External Bus Interface on STM32MP SoCs" + depends on ARCH_STM32MP + help + Select this option to enable the STM32 FMC2 External Bus Interface + controller. This driver configures the transactions with external + devices (like SRAM, ethernet adapters, FPGAs, LCD displays, ...) on + SOCs containing the FMC2 External Bus Interface. + config TI_AEMIF tristate "Texas Instruments AEMIF driver" depends on ARCH_KEYSTONE diff --git a/drivers/memory/Makefile b/drivers/memory/Makefile index 238add0..fec52ef 100644 --- a/drivers/memory/Makefile +++ b/drivers/memory/Makefile @@ -1,2 +1,3 @@
+obj-$(CONFIG_STM32_FMC2_EBI) += stm32-fmc2-ebi.o obj-$(CONFIG_TI_AEMIF) += ti-aemif.o diff --git a/drivers/memory/stm32-fmc2-ebi.c b/drivers/memory/stm32-fmc2-ebi.c new file mode 100644 index 0000000..d887a1e --- /dev/null +++ b/drivers/memory/stm32-fmc2-ebi.c @@ -0,0 +1,1056 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) STMicroelectronics 2020 + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <reset.h> +#include <linux/bitfield.h> +#include <linux/err.h> +#include <linux/iopoll.h> +#include <linux/ioport.h> + +/* FMC2 Controller Registers */ +#define FMC2_BCR1 0x0 +#define FMC2_BTR1 0x4 +#define FMC2_BCR(x) ((x) * 0x8 + FMC2_BCR1) +#define FMC2_BTR(x) ((x) * 0x8 + FMC2_BTR1) +#define FMC2_PCSCNTR 0x20 +#define FMC2_BWTR1 0x104 +#define FMC2_BWTR(x) ((x) * 0x8 + FMC2_BWTR1) + +/* Register: FMC2_BCR1 */ +#define FMC2_BCR1_CCLKEN BIT(20) +#define FMC2_BCR1_FMC2EN BIT(31) + +/* Register: FMC2_BCRx */ +#define FMC2_BCR_MBKEN BIT(0) +#define FMC2_BCR_MUXEN BIT(1) +#define FMC2_BCR_MTYP GENMASK(3, 2) +#define FMC2_BCR_MWID GENMASK(5, 4) +#define FMC2_BCR_FACCEN BIT(6) +#define FMC2_BCR_BURSTEN BIT(8) +#define FMC2_BCR_WAITPOL BIT(9) +#define FMC2_BCR_WAITCFG BIT(11) +#define FMC2_BCR_WREN BIT(12) +#define FMC2_BCR_WAITEN BIT(13) +#define FMC2_BCR_EXTMOD BIT(14) +#define FMC2_BCR_ASYNCWAIT BIT(15) +#define FMC2_BCR_CPSIZE GENMASK(18, 16) +#define FMC2_BCR_CBURSTRW BIT(19) +#define FMC2_BCR_NBLSET GENMASK(23, 22) + +/* Register: FMC2_BTRx/FMC2_BWTRx */ +#define FMC2_BXTR_ADDSET GENMASK(3, 0) +#define FMC2_BXTR_ADDHLD GENMASK(7, 4) +#define FMC2_BXTR_DATAST GENMASK(15, 8) +#define FMC2_BXTR_BUSTURN GENMASK(19, 16) +#define FMC2_BTR_CLKDIV GENMASK(23, 20) +#define FMC2_BTR_DATLAT GENMASK(27, 24) +#define FMC2_BXTR_ACCMOD GENMASK(29, 28) +#define FMC2_BXTR_DATAHLD GENMASK(31, 30) + +/* Register: FMC2_PCSCNTR */ +#define FMC2_PCSCNTR_CSCOUNT GENMASK(15, 0) +#define FMC2_PCSCNTR_CNTBEN(x) BIT((x) + 16) + +#define FMC2_MAX_EBI_CE 4 +#define FMC2_MAX_BANKS 5 + +#define FMC2_BCR_CPSIZE_0 0x0 +#define FMC2_BCR_CPSIZE_128 0x1 +#define FMC2_BCR_CPSIZE_256 0x2 +#define FMC2_BCR_CPSIZE_512 0x3 +#define FMC2_BCR_CPSIZE_1024 0x4 + +#define FMC2_BCR_MWID_8 0x0 +#define FMC2_BCR_MWID_16 0x1 + +#define FMC2_BCR_MTYP_SRAM 0x0 +#define FMC2_BCR_MTYP_PSRAM 0x1 +#define FMC2_BCR_MTYP_NOR 0x2 + +#define FMC2_BXTR_EXTMOD_A 0x0 +#define FMC2_BXTR_EXTMOD_B 0x1 +#define FMC2_BXTR_EXTMOD_C 0x2 +#define FMC2_BXTR_EXTMOD_D 0x3 + +#define FMC2_BCR_NBLSET_MAX 0x3 +#define FMC2_BXTR_ADDSET_MAX 0xf +#define FMC2_BXTR_ADDHLD_MAX 0xf +#define FMC2_BXTR_DATAST_MAX 0xff +#define FMC2_BXTR_BUSTURN_MAX 0xf +#define FMC2_BXTR_DATAHLD_MAX 0x3 +#define FMC2_BTR_CLKDIV_MAX 0xf +#define FMC2_BTR_DATLAT_MAX 0xf +#define FMC2_PCSCNTR_CSCOUNT_MAX 0xff + +#define FMC2_NSEC_PER_SEC 1000000000L + +enum stm32_fmc2_ebi_bank { + FMC2_EBI1 = 0, + FMC2_EBI2, + FMC2_EBI3, + FMC2_EBI4, + FMC2_NAND +}; + +enum stm32_fmc2_ebi_register_type { + FMC2_REG_BCR = 1, + FMC2_REG_BTR, + FMC2_REG_BWTR, + FMC2_REG_PCSCNTR +}; + +enum stm32_fmc2_ebi_transaction_type { + FMC2_ASYNC_MODE_1_SRAM = 0, + FMC2_ASYNC_MODE_1_PSRAM, + FMC2_ASYNC_MODE_A_SRAM, + FMC2_ASYNC_MODE_A_PSRAM, + FMC2_ASYNC_MODE_2_NOR, + FMC2_ASYNC_MODE_B_NOR, + FMC2_ASYNC_MODE_C_NOR, + FMC2_ASYNC_MODE_D_NOR, + FMC2_SYNC_READ_SYNC_WRITE_PSRAM, + FMC2_SYNC_READ_ASYNC_WRITE_PSRAM, + FMC2_SYNC_READ_SYNC_WRITE_NOR, + FMC2_SYNC_READ_ASYNC_WRITE_NOR +}; + +enum stm32_fmc2_ebi_buswidth { + FMC2_BUSWIDTH_8 = 8, + FMC2_BUSWIDTH_16 = 16 +}; + +enum stm32_fmc2_ebi_cpsize { + FMC2_CPSIZE_0 = 0, + FMC2_CPSIZE_128 = 128, + FMC2_CPSIZE_256 = 256, + FMC2_CPSIZE_512 = 512, + FMC2_CPSIZE_1024 = 1024 +}; + +struct stm32_fmc2_ebi { + struct clk clk; + fdt_addr_t io_base; + u8 bank_assigned; +}; + +/* + * struct stm32_fmc2_prop - STM32 FMC2 EBI property + * @name: the device tree binding name of the property + * @bprop: indicate that it is a boolean property + * @mprop: indicate that it is a mandatory property + * @reg_type: the register that have to be modified + * @reg_mask: the bit that have to be modified in the selected register + * in case of it is a boolean property + * @reset_val: the default value that have to be set in case the property + * has not been defined in the device tree + * @check: this callback ckecks that the property is compliant with the + * transaction type selected + * @calculate: this callback is called to calculate for exemple a timing + * set in nanoseconds in the device tree in clock cycles or in + * clock period + * @set: this callback applies the values in the registers + */ +struct stm32_fmc2_prop { + const char *name; + bool bprop; + bool mprop; + int reg_type; + u32 reg_mask; + u32 reset_val; + int (*check)(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, int cs); + u32 (*calculate)(struct stm32_fmc2_ebi *ebi, int cs, u32 setup); + int (*set)(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup); +}; + +static int stm32_fmc2_ebi_check_mux(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + + if (bcr & FMC2_BCR_MTYP) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_waitcfg(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + u32 val = FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + + if ((bcr & FMC2_BCR_MTYP) == val && bcr & FMC2_BCR_BURSTEN) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_sync_trans(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + + if (bcr & FMC2_BCR_BURSTEN) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_async_trans(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + + if (!(bcr & FMC2_BCR_BURSTEN) || !(bcr & FMC2_BCR_CBURSTRW)) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_cpsize(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + u32 val = FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM); + + if ((bcr & FMC2_BCR_MTYP) == val && bcr & FMC2_BCR_BURSTEN) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_address_hold(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + u32 bxtr = prop->reg_type == FMC2_REG_BWTR ? + readl(ebi->io_base + FMC2_BWTR(cs)) : + readl(ebi->io_base + FMC2_BTR(cs)); + u32 val = FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D); + + if ((!(bcr & FMC2_BCR_BURSTEN) || !(bcr & FMC2_BCR_CBURSTRW)) && + ((bxtr & FMC2_BXTR_ACCMOD) == val || bcr & FMC2_BCR_MUXEN)) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_clk_period(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + u32 bcr1 = cs ? readl(ebi->io_base + FMC2_BCR1) : bcr; + + if (bcr & FMC2_BCR_BURSTEN && (!cs || !(bcr1 & FMC2_BCR1_CCLKEN))) + return 0; + + return -EINVAL; +} + +static int stm32_fmc2_ebi_check_cclk(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs) +{ + if (cs) + return -EINVAL; + + return stm32_fmc2_ebi_check_sync_trans(ebi, prop, cs); +} + +static u32 stm32_fmc2_ebi_ns_to_clock_cycles(struct stm32_fmc2_ebi *ebi, + int cs, u32 setup) +{ + unsigned long hclk = clk_get_rate(&ebi->clk); + unsigned long hclkp = FMC2_NSEC_PER_SEC / (hclk / 1000); + + return DIV_ROUND_UP(setup * 1000, hclkp); +} + +static u32 stm32_fmc2_ebi_ns_to_clk_period(struct stm32_fmc2_ebi *ebi, + int cs, u32 setup) +{ + u32 nb_clk_cycles = stm32_fmc2_ebi_ns_to_clock_cycles(ebi, cs, setup); + u32 bcr = readl(ebi->io_base + FMC2_BCR1); + u32 btr = bcr & FMC2_BCR1_CCLKEN || !cs ? + readl(ebi->io_base + FMC2_BTR1) : + readl(ebi->io_base + FMC2_BTR(cs)); + u32 clk_period = FIELD_GET(FMC2_BTR_CLKDIV, btr) + 1; + + return DIV_ROUND_UP(nb_clk_cycles, clk_period); +} + +static int stm32_fmc2_ebi_get_reg(int reg_type, int cs, u32 *reg) +{ + switch (reg_type) { + case FMC2_REG_BCR: + *reg = FMC2_BCR(cs); + break; + case FMC2_REG_BTR: + *reg = FMC2_BTR(cs); + break; + case FMC2_REG_BWTR: + *reg = FMC2_BWTR(cs); + break; + case FMC2_REG_PCSCNTR: + *reg = FMC2_PCSCNTR; + break; + default: + return -EINVAL; + } + + return 0; +} + +static int stm32_fmc2_ebi_set_bit_field(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 reg; + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + clrsetbits_le32(ebi->io_base + reg, prop->reg_mask, + setup ? prop->reg_mask : 0); + + return 0; +} + +static int stm32_fmc2_ebi_set_trans_type(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 bcr_mask, bcr = FMC2_BCR_WREN; + u32 btr_mask, btr = 0; + u32 bwtr_mask, bwtr = 0; + + bwtr_mask = FMC2_BXTR_ACCMOD; + btr_mask = FMC2_BXTR_ACCMOD; + bcr_mask = FMC2_BCR_MUXEN | FMC2_BCR_MTYP | FMC2_BCR_FACCEN | + FMC2_BCR_WREN | FMC2_BCR_WAITEN | FMC2_BCR_BURSTEN | + FMC2_BCR_EXTMOD | FMC2_BCR_CBURSTRW; + + switch (setup) { + case FMC2_ASYNC_MODE_1_SRAM: + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_SRAM); + /* + * MUXEN = 0, MTYP = 0, FACCEN = 0, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 0, ACCMOD = 0 + */ + break; + case FMC2_ASYNC_MODE_1_PSRAM: + /* + * MUXEN = 0, MTYP = 1, FACCEN = 0, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM); + break; + case FMC2_ASYNC_MODE_A_SRAM: + /* + * MUXEN = 0, MTYP = 0, FACCEN = 0, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 1, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_SRAM); + bcr |= FMC2_BCR_EXTMOD; + btr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_A); + bwtr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_A); + break; + case FMC2_ASYNC_MODE_A_PSRAM: + /* + * MUXEN = 0, MTYP = 1, FACCEN = 0, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 1, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM); + bcr |= FMC2_BCR_EXTMOD; + btr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_A); + bwtr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_A); + break; + case FMC2_ASYNC_MODE_2_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN; + break; + case FMC2_ASYNC_MODE_B_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 1, CBURSTRW = 0, ACCMOD = 1 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN | FMC2_BCR_EXTMOD; + btr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_B); + bwtr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_B); + break; + case FMC2_ASYNC_MODE_C_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 1, CBURSTRW = 0, ACCMOD = 2 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN | FMC2_BCR_EXTMOD; + btr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_C); + bwtr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_C); + break; + case FMC2_ASYNC_MODE_D_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 0, WAITEN = 0, + * WREN = 1, EXTMOD = 1, CBURSTRW = 0, ACCMOD = 3 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN | FMC2_BCR_EXTMOD; + btr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D); + bwtr |= FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D); + break; + case FMC2_SYNC_READ_SYNC_WRITE_PSRAM: + /* + * MUXEN = 0, MTYP = 1, FACCEN = 0, BURSTEN = 1, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 1, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM); + bcr |= FMC2_BCR_BURSTEN | FMC2_BCR_CBURSTRW; + break; + case FMC2_SYNC_READ_ASYNC_WRITE_PSRAM: + /* + * MUXEN = 0, MTYP = 1, FACCEN = 0, BURSTEN = 1, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM); + bcr |= FMC2_BCR_BURSTEN; + break; + case FMC2_SYNC_READ_SYNC_WRITE_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 1, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 1, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN | FMC2_BCR_BURSTEN | FMC2_BCR_CBURSTRW; + break; + case FMC2_SYNC_READ_ASYNC_WRITE_NOR: + /* + * MUXEN = 0, MTYP = 2, FACCEN = 1, BURSTEN = 1, WAITEN = 0, + * WREN = 1, EXTMOD = 0, CBURSTRW = 0, ACCMOD = 0 + */ + bcr |= FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR); + bcr |= FMC2_BCR_FACCEN | FMC2_BCR_BURSTEN; + break; + default: + /* Type of transaction not supported */ + return -EINVAL; + } + + if (bcr & FMC2_BCR_EXTMOD) + clrsetbits_le32(ebi->io_base + FMC2_BWTR(cs), + bwtr_mask, bwtr); + clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), btr_mask, btr); + clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), bcr_mask, bcr); + + return 0; +} + +static int stm32_fmc2_ebi_set_buswidth(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val; + + switch (setup) { + case FMC2_BUSWIDTH_8: + val = FIELD_PREP(FMC2_BCR_MWID, FMC2_BCR_MWID_8); + break; + case FMC2_BUSWIDTH_16: + val = FIELD_PREP(FMC2_BCR_MWID, FMC2_BCR_MWID_16); + break; + default: + /* Buswidth not supported */ + return -EINVAL; + } + + clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MWID, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_cpsize(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val; + + switch (setup) { + case FMC2_CPSIZE_0: + val = FIELD_PREP(FMC2_BCR_CPSIZE, FMC2_BCR_CPSIZE_0); + break; + case FMC2_CPSIZE_128: + val = FIELD_PREP(FMC2_BCR_CPSIZE, FMC2_BCR_CPSIZE_128); + break; + case FMC2_CPSIZE_256: + val = FIELD_PREP(FMC2_BCR_CPSIZE, FMC2_BCR_CPSIZE_256); + break; + case FMC2_CPSIZE_512: + val = FIELD_PREP(FMC2_BCR_CPSIZE, FMC2_BCR_CPSIZE_512); + break; + case FMC2_CPSIZE_1024: + val = FIELD_PREP(FMC2_BCR_CPSIZE, FMC2_BCR_CPSIZE_1024); + break; + default: + /* Cpsize not supported */ + return -EINVAL; + } + + clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_CPSIZE, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_bl_setup(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val; + + val = min_t(u32, setup, FMC2_BCR_NBLSET_MAX); + val = FIELD_PREP(FMC2_BCR_NBLSET, val); + clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_NBLSET, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_address_setup(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 bcr = readl(ebi->io_base + FMC2_BCR(cs)); + u32 bxtr = prop->reg_type == FMC2_REG_BWTR ? + readl(ebi->io_base + FMC2_BWTR(cs)) : + readl(ebi->io_base + FMC2_BTR(cs)); + u32 reg, val = FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D); + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + if ((bxtr & FMC2_BXTR_ACCMOD) == val || bcr & FMC2_BCR_MUXEN) + val = clamp_val(setup, 1, FMC2_BXTR_ADDSET_MAX); + else + val = min_t(u32, setup, FMC2_BXTR_ADDSET_MAX); + val = FIELD_PREP(FMC2_BXTR_ADDSET, val); + clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_ADDSET, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_address_hold(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val, reg; + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + val = clamp_val(setup, 1, FMC2_BXTR_ADDHLD_MAX); + val = FIELD_PREP(FMC2_BXTR_ADDHLD, val); + clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_ADDHLD, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_data_setup(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val, reg; + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + val = clamp_val(setup, 1, FMC2_BXTR_DATAST_MAX); + val = FIELD_PREP(FMC2_BXTR_DATAST, val); + clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_DATAST, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_bus_turnaround(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val, reg; + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + val = setup ? min_t(u32, setup - 1, FMC2_BXTR_BUSTURN_MAX) : 0; + val = FIELD_PREP(FMC2_BXTR_BUSTURN, val); + clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_BUSTURN, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_data_hold(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val, reg; + int ret; + + ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®); + if (ret) + return ret; + + if (prop->reg_type == FMC2_REG_BWTR) + val = setup ? min_t(u32, setup - 1, FMC2_BXTR_DATAHLD_MAX) : 0; + else + val = min_t(u32, setup, FMC2_BXTR_DATAHLD_MAX); + val = FIELD_PREP(FMC2_BXTR_DATAHLD, val); + clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_DATAHLD, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_clk_period(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val; + + val = setup ? clamp_val(setup - 1, 1, FMC2_BTR_CLKDIV_MAX) : 1; + val = FIELD_PREP(FMC2_BTR_CLKDIV, val); + clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), FMC2_BTR_CLKDIV, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_data_latency(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 val; + + val = setup > 1 ? min_t(u32, setup - 2, FMC2_BTR_DATLAT_MAX) : 0; + val = FIELD_PREP(FMC2_BTR_DATLAT, val); + clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), FMC2_BTR_DATLAT, val); + + return 0; +} + +static int stm32_fmc2_ebi_set_max_low_pulse(struct stm32_fmc2_ebi *ebi, + const struct stm32_fmc2_prop *prop, + int cs, u32 setup) +{ + u32 old_val, new_val, pcscntr; + + if (setup < 1) + return 0; + + pcscntr = readl(ebi->io_base + FMC2_PCSCNTR); + + /* Enable counter for the bank */ + setbits_le32(ebi->io_base + FMC2_PCSCNTR, FMC2_PCSCNTR_CNTBEN(cs)); + + new_val = min_t(u32, setup - 1, FMC2_PCSCNTR_CSCOUNT_MAX); + old_val = FIELD_GET(FMC2_PCSCNTR_CSCOUNT, pcscntr); + if (old_val && new_val > old_val) + /* Keep current counter value */ + return 0; + + new_val = FIELD_PREP(FMC2_PCSCNTR_CSCOUNT, new_val); + clrsetbits_le32(ebi->io_base + FMC2_PCSCNTR, + FMC2_PCSCNTR_CSCOUNT, new_val); + + return 0; +} + +static const struct stm32_fmc2_prop stm32_fmc2_child_props[] = { + /* st,fmc2-ebi-cs-trans-type must be the first property */ + { + .name = "st,fmc2-ebi-cs-transaction-type", + .mprop = true, + .set = stm32_fmc2_ebi_set_trans_type, + }, + { + .name = "st,fmc2-ebi-cs-cclk-enable", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR1_CCLKEN, + .check = stm32_fmc2_ebi_check_cclk, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-mux-enable", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR_MUXEN, + .check = stm32_fmc2_ebi_check_mux, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-buswidth", + .reset_val = FMC2_BUSWIDTH_16, + .set = stm32_fmc2_ebi_set_buswidth, + }, + { + .name = "st,fmc2-ebi-cs-waitpol-high", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR_WAITPOL, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-waitcfg-enable", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR_WAITCFG, + .check = stm32_fmc2_ebi_check_waitcfg, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-wait-enable", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR_WAITEN, + .check = stm32_fmc2_ebi_check_sync_trans, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-asyncwait-enable", + .bprop = true, + .reg_type = FMC2_REG_BCR, + .reg_mask = FMC2_BCR_ASYNCWAIT, + .check = stm32_fmc2_ebi_check_async_trans, + .set = stm32_fmc2_ebi_set_bit_field, + }, + { + .name = "st,fmc2-ebi-cs-cpsize", + .check = stm32_fmc2_ebi_check_cpsize, + .set = stm32_fmc2_ebi_set_cpsize, + }, + { + .name = "st,fmc2-ebi-cs-byte-lane-setup-ns", + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_bl_setup, + }, + { + .name = "st,fmc2-ebi-cs-address-setup-ns", + .reg_type = FMC2_REG_BTR, + .reset_val = FMC2_BXTR_ADDSET_MAX, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_address_setup, + }, + { + .name = "st,fmc2-ebi-cs-address-hold-ns", + .reg_type = FMC2_REG_BTR, + .reset_val = FMC2_BXTR_ADDHLD_MAX, + .check = stm32_fmc2_ebi_check_address_hold, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_address_hold, + }, + { + .name = "st,fmc2-ebi-cs-data-setup-ns", + .reg_type = FMC2_REG_BTR, + .reset_val = FMC2_BXTR_DATAST_MAX, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_data_setup, + }, + { + .name = "st,fmc2-ebi-cs-bus-turnaround-ns", + .reg_type = FMC2_REG_BTR, + .reset_val = FMC2_BXTR_BUSTURN_MAX + 1, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_bus_turnaround, + }, + { + .name = "st,fmc2-ebi-cs-data-hold-ns", + .reg_type = FMC2_REG_BTR, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_data_hold, + }, + { + .name = "st,fmc2-ebi-cs-clk-period-ns", + .reset_val = FMC2_BTR_CLKDIV_MAX + 1, + .check = stm32_fmc2_ebi_check_clk_period, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_clk_period, + }, + { + .name = "st,fmc2-ebi-cs-data-latency-ns", + .check = stm32_fmc2_ebi_check_sync_trans, + .calculate = stm32_fmc2_ebi_ns_to_clk_period, + .set = stm32_fmc2_ebi_set_data_latency, + }, + { + .name = "st,fmc2-ebi-cs-write-address-setup-ns", + .reg_type = FMC2_REG_BWTR, + .reset_val = FMC2_BXTR_ADDSET_MAX, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_address_setup, + }, + { + .name = "st,fmc2-ebi-cs-write-address-hold-ns", + .reg_type = FMC2_REG_BWTR, + .reset_val = FMC2_BXTR_ADDHLD_MAX, + .check = stm32_fmc2_ebi_check_address_hold, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_address_hold, + }, + { + .name = "st,fmc2-ebi-cs-write-data-setup-ns", + .reg_type = FMC2_REG_BWTR, + .reset_val = FMC2_BXTR_DATAST_MAX, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_data_setup, + }, + { + .name = "st,fmc2-ebi-cs-write-bus-turnaround-ns", + .reg_type = FMC2_REG_BWTR, + .reset_val = FMC2_BXTR_BUSTURN_MAX + 1, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_bus_turnaround, + }, + { + .name = "st,fmc2-ebi-cs-write-data-hold-ns", + .reg_type = FMC2_REG_BWTR, + .check = stm32_fmc2_ebi_check_async_trans, + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_data_hold, + }, + { + .name = "st,fmc2-ebi-cs-max-low-pulse-ns", + .calculate = stm32_fmc2_ebi_ns_to_clock_cycles, + .set = stm32_fmc2_ebi_set_max_low_pulse, + }, +}; + +static int stm32_fmc2_ebi_parse_prop(struct stm32_fmc2_ebi *ebi, + ofnode node, + const struct stm32_fmc2_prop *prop, + int cs) +{ + u32 setup = 0; + + if (!prop->set) { + pr_err("property %s is not well defined\n", prop->name); + return -EINVAL; + } + + if (prop->check && prop->check(ebi, prop, cs)) + /* Skip this property */ + return 0; + + if (prop->bprop) { + bool bprop; + + bprop = ofnode_read_bool(node, prop->name); + if (prop->mprop && !bprop) { + pr_err("mandatory property %s not defined in the device tree\n", + prop->name); + return -EINVAL; + } + + if (bprop) + setup = 1; + } else { + u32 val; + int ret; + + ret = ofnode_read_u32(node, prop->name, &val); + if (prop->mprop && ret) { + pr_err("mandatory property %s not defined in the device tree\n", + prop->name); + return ret; + } + + if (ret) + setup = prop->reset_val; + else if (prop->calculate) + setup = prop->calculate(ebi, cs, val); + else + setup = val; + } + + return prop->set(ebi, prop, cs, setup); +} + +static void stm32_fmc2_ebi_enable_bank(struct stm32_fmc2_ebi *ebi, int cs) +{ + setbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MBKEN); +} + +static void stm32_fmc2_ebi_disable_bank(struct stm32_fmc2_ebi *ebi, int cs) +{ + clrbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MBKEN); +} + +/* NWAIT signal can not be connected to EBI controller and NAND controller */ +static bool stm32_fmc2_ebi_nwait_used_by_ctrls(struct stm32_fmc2_ebi *ebi) +{ + unsigned int cs; + u32 bcr; + + for (cs = 0; cs < FMC2_MAX_EBI_CE; cs++) { + if (!(ebi->bank_assigned & BIT(cs))) + continue; + + bcr = readl(ebi->io_base + FMC2_BCR(cs)); + if ((bcr & FMC2_BCR_WAITEN || bcr & FMC2_BCR_ASYNCWAIT) && + ebi->bank_assigned & BIT(FMC2_NAND)) + return true; + } + + return false; +} + +static void stm32_fmc2_ebi_enable(struct stm32_fmc2_ebi *ebi) +{ + setbits_le32(ebi->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN); +} + +static int stm32_fmc2_ebi_setup_cs(struct stm32_fmc2_ebi *ebi, + ofnode node, u32 cs) +{ + unsigned int i; + int ret; + + stm32_fmc2_ebi_disable_bank(ebi, cs); + + for (i = 0; i < ARRAY_SIZE(stm32_fmc2_child_props); i++) { + const struct stm32_fmc2_prop *p = &stm32_fmc2_child_props[i]; + + ret = stm32_fmc2_ebi_parse_prop(ebi, node, p, cs); + if (ret) { + pr_err("property %s could not be set: %d\n", + p->name, ret); + return ret; + } + } + + stm32_fmc2_ebi_enable_bank(ebi, cs); + + return 0; +} + +static int stm32_fmc2_ebi_parse_dt(struct udevice *dev, + struct stm32_fmc2_ebi *ebi) +{ + ofnode child; + bool child_found = false; + u32 bank; + int ret; + + dev_for_each_subnode(child, dev) { + ret = ofnode_read_u32(child, "reg", &bank); + if (ret) { + pr_err("could not retrieve reg property: %d\n", ret); + return ret; + } + + if (bank >= FMC2_MAX_BANKS) { + pr_err("invalid reg value: %d\n", bank); + return -EINVAL; + } + + if (ebi->bank_assigned & BIT(bank)) { + pr_err("bank already assigned: %d\n", bank); + return -EINVAL; + } + + if (bank < FMC2_MAX_EBI_CE) { + ret = stm32_fmc2_ebi_setup_cs(ebi, child, bank); + if (ret) { + pr_err("setup chip select %d failed: %d\n", + bank, ret); + return ret; + } + } + + ebi->bank_assigned |= BIT(bank); + child_found = true; + } + + if (!child_found) { + pr_warn("no subnodes found, disable the driver.\n"); + return -ENODEV; + } + + if (stm32_fmc2_ebi_nwait_used_by_ctrls(ebi)) { + pr_err("NWAIT signal connected to EBI and NAND controllers\n"); + return -EINVAL; + } + + stm32_fmc2_ebi_enable(ebi); + + return 0; +} + +static int stm32_fmc2_ebi_probe(struct udevice *dev) +{ + struct stm32_fmc2_ebi *ebi = dev_get_priv(dev); + struct reset_ctl reset; + int ret; + + ebi->io_base = dev_read_addr(dev); + if (ebi->io_base == FDT_ADDR_T_NONE) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &ebi->clk); + if (ret) + return ret; + + ret = clk_enable(&ebi->clk); + if (ret) + return ret; + + ret = reset_get_by_index(dev, 0, &reset); + if (!ret) { + reset_assert(&reset); + udelay(2); + reset_deassert(&reset); + } + + return stm32_fmc2_ebi_parse_dt(dev, ebi); +} + +static const struct udevice_id stm32_fmc2_ebi_match[] = { + {.compatible = "st,stm32mp1-fmc2-ebi"}, + { /* Sentinel */ } +}; + +U_BOOT_DRIVER(stm32_fmc2_ebi) = { + .name = "stm32_fmc2_ebi", + .id = UCLASS_NOP, + .of_match = stm32_fmc2_ebi_match, + .probe = stm32_fmc2_ebi_probe, + .priv_auto_alloc_size = sizeof(struct stm32_fmc2_ebi), + .bind = dm_scan_fdt_dev, +};
Hi Christophe
Signed-off-by: Christophe Kerello christophe.kerello@st.com
- bool "Support for FMC2 External Bus Interface on STM32MP SoCs"
- depends on ARCH_STM32MP
- help
- Copyright (C) STMicroelectronics 2020
- FMC2_EBI1 = 0,
- FMC2_EBI2,
- FMC2_EBI3,
- FMC2_EBI4,
- FMC2_NAND
- FMC2_REG_BCR = 1,
- FMC2_REG_BTR,
- FMC2_REG_BWTR,
- FMC2_REG_PCSCNTR
- FMC2_ASYNC_MODE_1_SRAM = 0,
- FMC2_ASYNC_MODE_1_PSRAM,
- FMC2_ASYNC_MODE_A_SRAM,
- FMC2_ASYNC_MODE_A_PSRAM,
- FMC2_ASYNC_MODE_2_NOR,
- FMC2_ASYNC_MODE_B_NOR,
- FMC2_ASYNC_MODE_C_NOR,
- FMC2_ASYNC_MODE_D_NOR,
- FMC2_SYNC_READ_SYNC_WRITE_PSRAM,
- FMC2_SYNC_READ_ASYNC_WRITE_PSRAM,
- FMC2_SYNC_READ_SYNC_WRITE_NOR,
- FMC2_SYNC_READ_ASYNC_WRITE_NOR
- FMC2_BUSWIDTH_8 = 8,
- FMC2_BUSWIDTH_16 = 16
- FMC2_CPSIZE_0 = 0,
- FMC2_CPSIZE_128 = 128,
- FMC2_CPSIZE_256 = 256,
- FMC2_CPSIZE_512 = 512,
- FMC2_CPSIZE_1024 = 1024
- struct clk clk;
- fdt_addr_t io_base;
- u8 bank_assigned;
- struct stm32_fmc2_prop - STM32 FMC2 EBI property
- @name: the device tree binding name of the property
- @bprop: indicate that it is a boolean property
- @mprop: indicate that it is a mandatory property
- @reg_type: the register that have to be modified
- @reg_mask: the bit that have to be modified in the selected register
- @reset_val: the default value that have to be set in case the property
- @check: this callback ckecks that the property is compliant with the
- @calculate: this callback is called to calculate for exemple a timing
clock period
- @set: this callback applies the values in the registers
- const char *name;
- bool bprop;
- bool mprop;
- int reg_type;
- u32 reg_mask;
- u32 reset_val;
- int (*check)(struct stm32_fmc2_ebi *ebi,
- u32 (*calculate)(struct stm32_fmc2_ebi *ebi, int cs, u32 setup);
- int (*set)(struct stm32_fmc2_ebi *ebi,
int cs, u32 setup);
int cs)
- u32 bcr = readl(ebi->io_base + FMC2_BCR(cs));
- if (bcr & FMC2_BCR_MTYP)
- return -EINVAL;
int cs)
- u32 val = FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_NOR);
- if ((bcr & FMC2_BCR_MTYP) == val && bcr & FMC2_BCR_BURSTEN)
- return -EINVAL;
int cs)
- if (bcr & FMC2_BCR_BURSTEN)
- return -EINVAL;
int cs)
- if (!(bcr & FMC2_BCR_BURSTEN) || !(bcr & FMC2_BCR_CBURSTRW))
- return -EINVAL;
int cs)
- u32 val = FIELD_PREP(FMC2_BCR_MTYP, FMC2_BCR_MTYP_PSRAM);
- return -EINVAL;
int cs)
- u32 bxtr = prop->reg_type == FMC2_REG_BWTR ?
- u32 val = FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D);
- if ((!(bcr & FMC2_BCR_BURSTEN) || !(bcr & FMC2_BCR_CBURSTRW)) &&
- return -EINVAL;
int cs)
- u32 bcr1 = cs ? readl(ebi->io_base + FMC2_BCR1) : bcr;
- if (bcr & FMC2_BCR_BURSTEN && (!cs || !(bcr1 & FMC2_BCR1_CCLKEN)))
- return -EINVAL;
int cs)
- if (cs)
return -EINVAL;
- return stm32_fmc2_ebi_check_sync_trans(ebi, prop, cs);
int cs, u32 setup)
- unsigned long hclk = clk_get_rate(&ebi->clk);
- unsigned long hclkp = FMC2_NSEC_PER_SEC / (hclk / 1000);
- return DIV_ROUND_UP(setup * 1000, hclkp);
int cs, u32 setup)
- u32 nb_clk_cycles = stm32_fmc2_ebi_ns_to_clock_cycles(ebi, cs, setup);
- u32 bcr = readl(ebi->io_base + FMC2_BCR1);
- u32 btr = bcr & FMC2_BCR1_CCLKEN || !cs ?
- u32 clk_period = FIELD_GET(FMC2_BTR_CLKDIV, btr) + 1;
- return DIV_ROUND_UP(nb_clk_cycles, clk_period);
- switch (reg_type) {
- case FMC2_REG_BCR:
break;
- case FMC2_REG_BTR:
break;
- case FMC2_REG_BWTR:
break;
- case FMC2_REG_PCSCNTR:
break;
- default:
return -EINVAL;
int cs, u32 setup)
- u32 reg;
- int ret;
- ret = stm32_fmc2_ebi_get_reg(prop->reg_type, cs, ®);
- if (ret)
return ret;
- clrsetbits_le32(ebi->io_base + reg, prop->reg_mask,
int cs, u32 setup)
- u32 bcr_mask, bcr = FMC2_BCR_WREN;
- u32 btr_mask, btr = 0;
- u32 bwtr_mask, bwtr = 0;
- bwtr_mask = FMC2_BXTR_ACCMOD;
- btr_mask = FMC2_BXTR_ACCMOD;
- bcr_mask = FMC2_BCR_MUXEN | FMC2_BCR_MTYP | FMC2_BCR_FACCEN |
- switch (setup) {
- case FMC2_ASYNC_MODE_1_SRAM:
break;
- case FMC2_ASYNC_MODE_1_PSRAM:
break;
- case FMC2_ASYNC_MODE_A_SRAM:
break;
- case FMC2_ASYNC_MODE_A_PSRAM:
break;
- case FMC2_ASYNC_MODE_2_NOR:
break;
- case FMC2_ASYNC_MODE_B_NOR:
break;
- case FMC2_ASYNC_MODE_C_NOR:
break;
- case FMC2_ASYNC_MODE_D_NOR:
break;
- case FMC2_SYNC_READ_SYNC_WRITE_PSRAM:
break;
- case FMC2_SYNC_READ_ASYNC_WRITE_PSRAM:
break;
- case FMC2_SYNC_READ_SYNC_WRITE_NOR:
break;
- case FMC2_SYNC_READ_ASYNC_WRITE_NOR:
break;
- default:
return -EINVAL;
- if (bcr & FMC2_BCR_EXTMOD)
bwtr_mask, bwtr);
- clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), btr_mask, btr);
- clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), bcr_mask, bcr);
int cs, u32 setup)
- u32 val;
- switch (setup) {
- case FMC2_BUSWIDTH_8:
break;
- case FMC2_BUSWIDTH_16:
break;
- default:
return -EINVAL;
- clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MWID, val);
int cs, u32 setup)
- u32 val;
- switch (setup) {
- case FMC2_CPSIZE_0:
break;
- case FMC2_CPSIZE_128:
break;
- case FMC2_CPSIZE_256:
break;
- case FMC2_CPSIZE_512:
break;
- case FMC2_CPSIZE_1024:
break;
- default:
return -EINVAL;
- clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_CPSIZE, val);
int cs, u32 setup)
- u32 val;
- val = min_t(u32, setup, FMC2_BCR_NBLSET_MAX);
- val = FIELD_PREP(FMC2_BCR_NBLSET, val);
- clrsetbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_NBLSET, val);
int cs, u32 setup)
- u32 reg, val = FIELD_PREP(FMC2_BXTR_ACCMOD, FMC2_BXTR_EXTMOD_D);
- int ret;
- if (ret)
return ret;
- if ((bxtr & FMC2_BXTR_ACCMOD) == val || bcr & FMC2_BCR_MUXEN)
- else
- val = FIELD_PREP(FMC2_BXTR_ADDSET, val);
- clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_ADDSET, val);
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
- val = clamp_val(setup, 1, FMC2_BXTR_ADDHLD_MAX);
- val = FIELD_PREP(FMC2_BXTR_ADDHLD, val);
- clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_ADDHLD, val);
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
- val = clamp_val(setup, 1, FMC2_BXTR_DATAST_MAX);
- val = FIELD_PREP(FMC2_BXTR_DATAST, val);
- clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_DATAST, val);
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
- val = setup ? min_t(u32, setup - 1, FMC2_BXTR_BUSTURN_MAX) : 0;
- val = FIELD_PREP(FMC2_BXTR_BUSTURN, val);
- clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_BUSTURN, val);
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
- if (prop->reg_type == FMC2_REG_BWTR)
- else
- val = FIELD_PREP(FMC2_BXTR_DATAHLD, val);
- clrsetbits_le32(ebi->io_base + reg, FMC2_BXTR_DATAHLD, val);
int cs, u32 setup)
- u32 val;
- val = setup ? clamp_val(setup - 1, 1, FMC2_BTR_CLKDIV_MAX) : 1;
- val = FIELD_PREP(FMC2_BTR_CLKDIV, val);
- clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), FMC2_BTR_CLKDIV, val);
int cs, u32 setup)
- u32 val;
- val = setup > 1 ? min_t(u32, setup - 2, FMC2_BTR_DATLAT_MAX) : 0;
- val = FIELD_PREP(FMC2_BTR_DATLAT, val);
- clrsetbits_le32(ebi->io_base + FMC2_BTR(cs), FMC2_BTR_DATLAT, val);
int cs, u32 setup)
- u32 old_val, new_val, pcscntr;
- if (setup < 1)
- pcscntr = readl(ebi->io_base + FMC2_PCSCNTR);
- /* Enable counter for the bank */
- setbits_le32(ebi->io_base + FMC2_PCSCNTR, FMC2_PCSCNTR_CNTBEN(cs));
- new_val = min_t(u32, setup - 1, FMC2_PCSCNTR_CSCOUNT_MAX);
- old_val = FIELD_GET(FMC2_PCSCNTR_CSCOUNT, pcscntr);
- if (old_val && new_val > old_val)
- new_val = FIELD_PREP(FMC2_PCSCNTR_CSCOUNT, new_val);
- clrsetbits_le32(ebi->io_base + FMC2_PCSCNTR,
- /* st,fmc2-ebi-cs-trans-type must be the first property */
.mprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
ofnode node,
int cs)
- u32 setup = 0;
- if (!prop->set) {
return -EINVAL;
- if (prop->check && prop->check(ebi, prop, cs))
- if (prop->bprop) {
bool bprop;
prop->name);
return -EINVAL;
if (bprop)
setup = 1;
- } else {
u32 val;
int ret;
prop->name);
return ret;
if (ret)
else
setup = val;
- return prop->set(ebi, prop, cs, setup);
- setbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MBKEN);
- clrbits_le32(ebi->io_base + FMC2_BCR(cs), FMC2_BCR_MBKEN);
- unsigned int cs;
- u32 bcr;
- for (cs = 0; cs < FMC2_MAX_EBI_CE; cs++) {
continue;
return true;
- return false;
- setbits_le32(ebi->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN);
- unsigned int i;
- int ret;
- stm32_fmc2_ebi_disable_bank(ebi, cs);
- for (i = 0; i < ARRAY_SIZE(stm32_fmc2_child_props); i++) {
if (ret) {
p->name, ret);
return ret;
- stm32_fmc2_ebi_enable_bank(ebi, cs);
- ofnode child;
- bool child_found = false;
- u32 bank;
- int ret;
- dev_for_each_subnode(child, dev) {
if (ret) {
return ret;
return -EINVAL;
return -EINVAL;
if (ret) {
bank, ret);
return ret;
child_found = true;
- if (!child_found) {
return -ENODEV;
- if (stm32_fmc2_ebi_nwait_used_by_ctrls(ebi)) {
return -EINVAL;
- stm32_fmc2_ebi_enable(ebi);
- struct stm32_fmc2_ebi *ebi = dev_get_priv(dev);
- struct reset_ctl reset;
- int ret;
- ebi->io_base = dev_read_addr(dev);
- if (ebi->io_base == FDT_ADDR_T_NONE)
return -EINVAL;
- ret = clk_get_by_index(dev, 0, &ebi->clk);
- if (ret)
return ret;
- ret = clk_enable(&ebi->clk);
- if (ret)
return ret;
- ret = reset_get_by_index(dev, 0, &reset);
- if (!ret) {
udelay(2);
- return stm32_fmc2_ebi_parse_dt(dev, ebi);
- {.compatible = "st,stm32mp1-fmc2-ebi"},
- { /* Sentinel */ }
- .name = "stm32_fmc2_ebi",
- .id = UCLASS_NOP,
- .of_match = stm32_fmc2_ebi_match,
- .probe = stm32_fmc2_ebi_probe,
- .priv_auto_alloc_size = sizeof(struct stm32_fmc2_ebi),
- .bind = dm_scan_fdt_dev,
Reviewed-by: Patrice Chotard patrice.chotard@st.com
Thanks
Patrice
On 8/13/20 9:31 AM, Patrice CHOTARD wrote:
Hi Christophe
Applied on u-boot-stm/master
Thanks
- help
- FMC2_EBI1 = 0,
- FMC2_EBI2,
- FMC2_EBI3,
- FMC2_EBI4,
- FMC2_NAND
- FMC2_REG_BCR = 1,
- FMC2_REG_BTR,
- FMC2_REG_BWTR,
- FMC2_REG_PCSCNTR
- struct clk clk;
- u8 bank_assigned;
clock period
- const char *name;
- bool bprop;
- bool mprop;
- int reg_type;
- u32 reg_mask;
- u32 reset_val;
int cs, u32 setup);
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- return -EINVAL;
int cs)
- if (cs)
return -EINVAL;
int cs, u32 setup)
int cs, u32 setup)
break;
break;
break;
break;
- default:
return -EINVAL;
int cs, u32 setup)
- u32 reg;
- int ret;
- if (ret)
return ret;
int cs, u32 setup)
- switch (setup) {
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
- default:
return -EINVAL;
bwtr_mask, bwtr);
int cs, u32 setup)
- u32 val;
- switch (setup) {
break;
break;
- default:
return -EINVAL;
int cs, u32 setup)
- u32 val;
- switch (setup) {
break;
break;
break;
break;
break;
- default:
return -EINVAL;
int cs, u32 setup)
- u32 val;
int cs, u32 setup)
- int ret;
- if (ret)
return ret;
- else
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
int cs, u32 setup)
- u32 val, reg;
- int ret;
- if (ret)
return ret;
- else
int cs, u32 setup)
- u32 val;
int cs, u32 setup)
- u32 val;
int cs, u32 setup)
- if (setup < 1)
.mprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
.bprop = true,
ofnode node,
int cs)
- u32 setup = 0;
- if (!prop->set) {
return -EINVAL;
bool bprop;
prop->name);
return -EINVAL;
if (bprop)
setup = 1;
- } else {
u32 val;
int ret;
prop->name);
return ret;
if (ret)
else
setup = val;
- unsigned int cs;
- u32 bcr;
continue;
return true;
- return false;
- unsigned int i;
- int ret;
if (ret) {
p->name, ret);
return ret;
- ofnode child;
- u32 bank;
- int ret;
if (ret) {
return ret;
return -EINVAL;
return -EINVAL;
if (ret) {
bank, ret);
return ret;
child_found = true;
return -ENODEV;
return -EINVAL;
- int ret;
return -EINVAL;
- if (ret)
return ret;
- if (ret)
return ret;
- if (!ret) {
udelay(2);
- .id = UCLASS_NOP,
Thanks
Patrice
FMC2 EBI support has been added. Common resources (registers base address and clock) can now be shared between the 2 drivers using "st,stm32mp1-fmc2-nfc" compatible string. It means that the common resources should now be found in the parent device when EBI node is available.
Signed-off-by: Christophe Kerello christophe.kerello@st.com ---
drivers/mtd/nand/raw/stm32_fmc2_nand.c | 87 +++++++++++++++++++++++----------- 1 file changed, 59 insertions(+), 28 deletions(-)
diff --git a/drivers/mtd/nand/raw/stm32_fmc2_nand.c b/drivers/mtd/nand/raw/stm32_fmc2_nand.c index 1e4d757..47fe610 100644 --- a/drivers/mtd/nand/raw/stm32_fmc2_nand.c +++ b/drivers/mtd/nand/raw/stm32_fmc2_nand.c @@ -158,10 +158,10 @@ struct stm32_fmc2_nfc { struct nand_hw_control base; struct stm32_fmc2_nand nand; struct nand_ecclayout ecclayout; - void __iomem *io_base; - void __iomem *data_base[FMC2_MAX_CE]; - void __iomem *cmd_base[FMC2_MAX_CE]; - void __iomem *addr_base[FMC2_MAX_CE]; + fdt_addr_t io_base; + fdt_addr_t data_base[FMC2_MAX_CE]; + fdt_addr_t cmd_base[FMC2_MAX_CE]; + fdt_addr_t addr_base[FMC2_MAX_CE]; struct clk clk;
u8 cs_assigned; @@ -241,8 +241,8 @@ static void stm32_fmc2_nfc_select_chip(struct mtd_info *mtd, int chipnr) return;
nfc->cs_sel = nand->cs_used[chipnr]; - chip->IO_ADDR_R = nfc->data_base[nfc->cs_sel]; - chip->IO_ADDR_W = nfc->data_base[nfc->cs_sel]; + chip->IO_ADDR_R = (void __iomem *)nfc->data_base[nfc->cs_sel]; + chip->IO_ADDR_W = (void __iomem *)nfc->data_base[nfc->cs_sel];
stm32_fmc2_nfc_setup(chip); stm32_fmc2_nfc_timings_init(chip); @@ -548,7 +548,7 @@ static int stm32_fmc2_nfc_read_page(struct mtd_info *mtd, return max_bitflips; }
-static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) +static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc, bool has_parent) { u32 pcr = readl(nfc->io_base + FMC2_PCR);
@@ -581,7 +581,8 @@ static void stm32_fmc2_nfc_init(struct stm32_fmc2_nfc *nfc) pcr |= FIELD_PREP(FMC2_PCR_TAR, FMC2_PCR_TAR_DEFAULT);
/* Enable FMC2 controller */ - setbits_le32(nfc->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN); + if (!has_parent) + setbits_le32(nfc->io_base + FMC2_BCR1, FMC2_BCR1_FMC2EN);
writel(pcr, nfc->io_base + FMC2_PCR); writel(FMC2_PMEM_DEFAULT, nfc->io_base + FMC2_PMEM); @@ -854,6 +855,30 @@ static int stm32_fmc2_nfc_parse_dt(struct udevice *dev, return 0; }
+static struct udevice *stm32_fmc2_nfc_get_cdev(struct udevice *dev) +{ + struct udevice *pdev = dev_get_parent(dev); + struct udevice *cdev = NULL; + bool ebi_found = false; + + if (pdev && ofnode_device_is_compatible(dev_ofnode(pdev), + "st,stm32mp1-fmc2-ebi")) + ebi_found = true; + + if (ofnode_device_is_compatible(dev_ofnode(dev), + "st,stm32mp1-fmc2-nfc")) { + if (ebi_found) + cdev = pdev; + + return cdev; + } + + if (!ebi_found) + cdev = dev; + + return cdev; +} + static int stm32_fmc2_nfc_probe(struct udevice *dev) { struct stm32_fmc2_nfc *nfc = dev_get_priv(dev); @@ -861,58 +886,63 @@ static int stm32_fmc2_nfc_probe(struct udevice *dev) struct nand_chip *chip = &nand->chip; struct mtd_info *mtd = &chip->mtd; struct nand_ecclayout *ecclayout; - struct resource resource; + struct udevice *cdev; struct reset_ctl reset; int oob_index, chip_cs, mem_region, ret; unsigned int i; + int start_region = 0; + fdt_addr_t addr;
spin_lock_init(&nfc->controller.lock); init_waitqueue_head(&nfc->controller.wq);
+ cdev = stm32_fmc2_nfc_get_cdev(dev); + if (!cdev) + return -EINVAL; + ret = stm32_fmc2_nfc_parse_dt(dev, nfc); if (ret) return ret;
- /* Get resources */ - ret = dev_read_resource(dev, 0, &resource); - if (ret) { - pr_err("Resource io_base not found"); - return ret; - } - nfc->io_base = (void __iomem *)resource.start; + nfc->io_base = dev_read_addr(cdev); + if (nfc->io_base == FDT_ADDR_T_NONE) + return -EINVAL; + + if (dev == cdev) + start_region = 1;
- for (chip_cs = 0, mem_region = 1; chip_cs < FMC2_MAX_CE; + for (chip_cs = 0, mem_region = start_region; chip_cs < FMC2_MAX_CE; chip_cs++, mem_region += 3) { if (!(nfc->cs_assigned & BIT(chip_cs))) continue;
- ret = dev_read_resource(dev, mem_region, &resource); - if (ret) { + addr = dev_read_addr_index(dev, mem_region); + if (addr == FDT_ADDR_T_NONE) { pr_err("Resource data_base not found for cs%d", chip_cs); return ret; } - nfc->data_base[chip_cs] = (void __iomem *)resource.start; + nfc->data_base[chip_cs] = addr;
- ret = dev_read_resource(dev, mem_region + 1, &resource); - if (ret) { + addr = dev_read_addr_index(dev, mem_region + 1); + if (addr == FDT_ADDR_T_NONE) { pr_err("Resource cmd_base not found for cs%d", chip_cs); return ret; } - nfc->cmd_base[chip_cs] = (void __iomem *)resource.start; + nfc->cmd_base[chip_cs] = addr;
- ret = dev_read_resource(dev, mem_region + 2, &resource); - if (ret) { + addr = dev_read_addr_index(dev, mem_region + 2); + if (addr == FDT_ADDR_T_NONE) { pr_err("Resource addr_base not found for cs%d", chip_cs); return ret; } - nfc->addr_base[chip_cs] = (void __iomem *)resource.start; + nfc->addr_base[chip_cs] = addr; }
/* Enable the clock */ - ret = clk_get_by_index(dev, 0, &nfc->clk); + ret = clk_get_by_index(cdev, 0, &nfc->clk); if (ret) return ret;
@@ -928,7 +958,7 @@ static int stm32_fmc2_nfc_probe(struct udevice *dev) reset_deassert(&reset); }
- stm32_fmc2_nfc_init(nfc); + stm32_fmc2_nfc_init(nfc, dev != cdev);
chip->controller = &nfc->base; chip->select_chip = stm32_fmc2_nfc_select_chip; @@ -994,6 +1024,7 @@ static int stm32_fmc2_nfc_probe(struct udevice *dev)
static const struct udevice_id stm32_fmc2_nfc_match[] = { { .compatible = "st,stm32mp15-fmc2" }, + { .compatible = "st,stm32mp1-fmc2-nfc" }, { /* Sentinel */ } };
Hi Christophe
fdt_addr_t io_base;
u8 cs_assigned;
if (!has_parent)
- struct udevice *pdev = dev_get_parent(dev);
- struct udevice *cdev = NULL;
- bool ebi_found = false;
- if (pdev && ofnode_device_is_compatible(dev_ofnode(pdev),
ebi_found = true;
- if (ofnode_device_is_compatible(dev_ofnode(dev),
if (ebi_found)
cdev = pdev;
return cdev;
- if (!ebi_found)
cdev = dev;
- return cdev;
fdt_addr_t addr;
if (!cdev)
return -EINVAL;
- if (ret) {
return ret;
- nfc->io_base = dev_read_addr(cdev);
- if (nfc->io_base == FDT_ADDR_T_NONE)
return -EINVAL;
- if (dev == cdev)
start_region = 1;
- for (chip_cs = 0, mem_region = start_region; chip_cs < FMC2_MAX_CE; chip_cs++, mem_region += 3) { if (!(nfc->cs_assigned & BIT(chip_cs))) continue;
if (ret) {
}if (addr == FDT_ADDR_T_NONE) { pr_err("Resource data_base not found for cs%d", chip_cs); return ret;
if (ret) {
}if (addr == FDT_ADDR_T_NONE) { pr_err("Resource cmd_base not found for cs%d", chip_cs); return ret;
if (ret) {
}if (addr == FDT_ADDR_T_NONE) { pr_err("Resource addr_base not found for cs%d", chip_cs); return ret;
- ret = clk_get_by_index(cdev, 0, &nfc->clk); if (ret) return ret;
- { .compatible = "st,stm32mp1-fmc2-nfc" }, { /* Sentinel */ }
Thanks
Patrice
On 8/13/20 9:33 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
fdt_addr_t io_base;
u8 cs_assigned;
if (!has_parent)
ebi_found = true;
if (ebi_found)
cdev = pdev;
return cdev;
- if (!ebi_found)
cdev = dev;
- return cdev;
fdt_addr_t addr;
if (!cdev)
return -EINVAL;
- if (ret) {
return ret;
return -EINVAL;
- if (dev == cdev)
start_region = 1;
if (ret) {
if (ret) {
if (ret) {
Thanks
Patrice
This patch adds "st,stm32mp1-fmc2-nfc" compatible string in the fdt fixup partitions table.
board/st/stm32mp1/stm32mp1.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 1d274c3..f2f6c99 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -851,6 +851,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) { "st,stm32f469-qspi", MTD_DEV_TYPE_NOR, }, { "st,stm32f469-qspi", MTD_DEV_TYPE_SPINAND}, { "st,stm32mp15-fmc2", MTD_DEV_TYPE_NAND, }, + { "st,stm32mp1-fmc2-nfc", MTD_DEV_TYPE_NAND, }, }; fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); #endif
Hi Christophe
}; fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes));{ "st,stm32mp1-fmc2-nfc", MTD_DEV_TYPE_NAND, },
#endif
Thanks
Patrice
This patch enables the support of FMC2 EBI.
configs/stm32mp15_basic_defconfig | 1 + configs/stm32mp15_trusted_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 5c500a1..2094183 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -88,6 +88,7 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_STM32_IPCC=y +CONFIG_STM32_FMC2_EBI=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 98680cb..8d59d84 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -68,6 +68,7 @@ CONFIG_LED=y CONFIG_LED_GPIO=y CONFIG_DM_MAILBOX=y CONFIG_STM32_IPCC=y +CONFIG_STM32_FMC2_EBI=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_STM32_SDMMC2=y
Hi Christophe
Thanks
Patrice
On 8/13/20 9:35 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
Thanks
Patrice
This patch adds FMC2 External Bus Interface support on stm32mp157c.
arch/arm/dts/stm32mp151.dtsi | 43 +++++++++++++++++++++++++++------------- arch/arm/dts/stm32mp157c-ev1.dts | 16 ++++++++------- 2 files changed, 38 insertions(+), 21 deletions(-)
diff --git a/arch/arm/dts/stm32mp151.dtsi b/arch/arm/dts/stm32mp151.dtsi index 0d97f56..39d9e54 100644 --- a/arch/arm/dts/stm32mp151.dtsi +++ b/arch/arm/dts/stm32mp151.dtsi @@ -1328,23 +1328,38 @@ dma-requests = <48>; };
- fmc: nand-controller@58002000 { - compatible = "st,stm32mp15-fmc2"; - reg = <0x58002000 0x1000>, - <0x80000000 0x1000>, - <0x88010000 0x1000>, - <0x88020000 0x1000>, - <0x81000000 0x1000>, - <0x89010000 0x1000>, - <0x89020000 0x1000>; - interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&mdma1 20 0x10 0x12000a02 0x0 0x0>, - <&mdma1 20 0x10 0x12000a08 0x0 0x0>, - <&mdma1 21 0x10 0x12000a0a 0x0 0x0>; - dma-names = "tx", "rx", "ecc"; + fmc: memory-controller@58002000 { + #address-cells = <2>; + #size-cells = <1>; + compatible = "st,stm32mp1-fmc2-ebi"; + reg = <0x58002000 0x1000>; clocks = <&rcc FMC_K>; resets = <&rcc FMC_R>; status = "disabled"; + + ranges = <0 0 0x60000000 0x04000000>, /* EBI CS 1 */ + <1 0 0x64000000 0x04000000>, /* EBI CS 2 */ + <2 0 0x68000000 0x04000000>, /* EBI CS 3 */ + <3 0 0x6c000000 0x04000000>, /* EBI CS 4 */ + <4 0 0x80000000 0x10000000>; /* NAND */ + + nand-controller@4,0 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "st,stm32mp1-fmc2-nfc"; + reg = <4 0x00000000 0x1000>, + <4 0x08010000 0x1000>, + <4 0x08020000 0x1000>, + <4 0x01000000 0x1000>, + <4 0x09010000 0x1000>, + <4 0x09020000 0x1000>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&mdma1 20 0x2 0x12000a02 0x0 0x0>, + <&mdma1 20 0x2 0x12000a08 0x0 0x0>, + <&mdma1 21 0x2 0x12000a0a 0x0 0x0>; + dma-names = "tx", "rx", "ecc"; + status = "disabled"; + }; };
qspi: spi@58003000 { diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index b190565..46f81ce 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -157,14 +157,16 @@ pinctrl-0 = <&fmc_pins_a>; pinctrl-1 = <&fmc_sleep_pins_a>; status = "okay"; - #address-cells = <1>; - #size-cells = <0>;
- nand@0 { - reg = <0>; - nand-on-flash-bbt; - #address-cells = <1>; - #size-cells = <1>; + nand-controller@4,0 { + status = "okay"; + + nand@0 { + reg = <0>; + nand-on-flash-bbt; + #address-cells = <1>; + #size-cells = <1>; + }; }; };
Hi Christophe
#size-cells = <1>;
#size-cells = <0>;
#size-cells = <0>;
nand@0 {
reg = <0>;
nand-on-flash-bbt;
#size-cells = <1>;
- nand-controller@4,0 {
status = "okay";
nand@0 {
reg = <0>;
nand-on-flash-bbt;
#size-cells = <1>;
Thanks
Patrice
On 8/13/20 9:36 AM, Patrice CHOTARD wrote:
Hi Christophe
Thanks
#size-cells = <1>;
#size-cells = <0>;
#size-cells = <0>;
nand@0 {
reg = <0>;
nand-on-flash-bbt;
#size-cells = <1>;
status = "okay";
nand@0 {
reg = <0>;
nand-on-flash-bbt;
#size-cells = <1>;
Thanks
Patrice
Christophe Kerello
Patrice CHOTARD
