[PATCH v3 0/2] Add support of an FXL6408 GPIO expander
Add support of a Fairchild's FXL6408 i2c gpio expander and enable this driver for Toradex Colibri iMX8QXP SoM.
Changes in v3: - fix a warning: "drivers/gpio/gpio-fxl6408.c:348:15: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘int’ [-Wformat=]" - add Tested-by record.
Changes in v2: - Kconfig: add better description for the config option. - gpio-fxl6408.c: -- improve registers' naming. -- fix code style (comments, etc.). -- reimplement fxl6408_read() reducing number of parameters. -- change return value of fxl6408_is_output() to bool. -- replace IS_ERR_VALUE() macros with simple x < 0 where it's possible. -- fxl6408_set_direction(): fix type of parameter "dir". -- fix return error codes to avoid using the predefined in the driver model ones. -- removed extra debug code. -- expand TODO list.
Oleksandr Suvorov (2): GPIO: fxl6408: Add support for FXL6408 GPIO expander colibri-imx8x: add on-module gpio expander fxl6408
arch/arm/dts/fsl-imx8qxp-colibri.dts | 27 ++ configs/colibri-imx8x_defconfig | 1 + drivers/gpio/Kconfig | 7 + drivers/gpio/Makefile | 1 + drivers/gpio/gpio-fxl6408.c | 366 +++++++++++++++++++++++++++ 5 files changed, 402 insertions(+) create mode 100644 drivers/gpio/gpio-fxl6408.c
From: Oleksandr Suvorov oleksandr.suvorov@toradex.com
Initial support for Fairchild's 8 bit I2C gpio expander FXL6408. The CONFIG_FXL6408_GPIO define enables support for such devices.
Based on: https://patchwork.kernel.org/patch/9148419/
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Reviewed-by: Simon Glass sjg@chromium.org Tested-by: Marcel Ziswiler marcel.ziswiler@toradex.com Signed-off-by: Oleksandr Suvorov cryosay@gmail.com Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
Changes in v3: - fix a warning: ...drivers/gpio/gpio-fxl6408.c:348:15: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘int’ [-Wformat=]... - add Tested-by record.
drivers/gpio/Kconfig | 7 + drivers/gpio/Makefile | 1 + drivers/gpio/gpio-fxl6408.c | 366 ++++++++++++++++++++++++++++++++++++ 3 files changed, 374 insertions(+) create mode 100644 drivers/gpio/gpio-fxl6408.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 4a89c1a62b..f56e4cc261 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -123,6 +123,13 @@ config DA8XX_GPIO help This driver supports the DA8xx GPIO controller
+config FXL6408_GPIO + bool "FXL6408 I2C GPIO expander driver" + depends on DM_GPIO && DM_I2C + help + This driver supports the Fairchild FXL6408 device. FXL6408 is a + fully configurable 8-bit I2C-controlled GPIO expander. + config INTEL_BROADWELL_GPIO bool "Intel Broadwell GPIO driver" depends on DM diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 58f4704f6b..83d8b5c9d8 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -16,6 +16,7 @@ obj-$(CONFIG_AT91_GPIO) += at91_gpio.o obj-$(CONFIG_ATMEL_PIO4) += atmel_pio4.o obj-$(CONFIG_BCM6345_GPIO) += bcm6345_gpio.o obj-$(CONFIG_CORTINA_GPIO) += cortina_gpio.o +obj-$(CONFIG_FXL6408_GPIO) += gpio-fxl6408.o obj-$(CONFIG_INTEL_GPIO) += intel_gpio.o obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o obj-$(CONFIG_INTEL_BROADWELL_GPIO) += intel_broadwell_gpio.o diff --git a/drivers/gpio/gpio-fxl6408.c b/drivers/gpio/gpio-fxl6408.c new file mode 100644 index 0000000000..dbc68618f9 --- /dev/null +++ b/drivers/gpio/gpio-fxl6408.c @@ -0,0 +1,366 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2021 Toradex + * Copyright (C) 2016 Broadcom + */ + +/** + * DOC: FXL6408 I2C to GPIO expander. + * + * This chip has 8 GPIO lines out of it, and is controlled by an I2C + * bus (a pair of lines), providing 4x expansion of GPIO lines. It + * also provides an interrupt line out for notifying of state changes. + * + * Any preconfigured state will be left in place until the GPIO lines + * get activated. At power on, everything is treated as an input, + * default input is HIGH and pulled-up, all interrupts are masked. + * + * Documentation can be found at: + * https://www.fairchildsemi.com/datasheets/FX/FXL6408.pdf + * + * This driver bases on: + * - the original driver by Eric Anholt eric@anholt.net: + * https://patchwork.kernel.org/patch/9148419/ + * - the Toradex version by Max Krummenacher max.krummenacher@toradex.com: + * http://git.toradex.com/cgit/linux-toradex.git/tree/drivers/gpio/gpio-fxl6408... + * - the U-boot PCA953x driver by Peng Fan van.freenix@gmail.com: + * drivers/gpio/pca953x_gpio.c + * + * TODO: + * - Add interrupts support + * - Replace deprecated callbacks direction_input/output() with set_flags() + */ + +#include <common.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <i2c.h> +#include <log.h> +#include <asm-generic/gpio.h> +#include <asm/global_data.h> +#include <linux/bitops.h> +#include <dt-bindings/gpio/gpio.h> + +#define REG_DEVID_CTRL 0x01 +# define SW_RST BIT(0) +# define RST_INT BIT(1) +/* 0b101 is the Manufacturer's ID assigned to Fairchild by Nokia */ +# define MF_ID_FAIRCHILD 5 + +/* Bits set here indicate that the GPIO is an output */ +#define REG_IO_DIR 0x03 + +/* + * Bits set here, when the corresponding bit of REG_IO_DIR is set, drive + * the output high instead of low. + */ +#define REG_OUT_STATE 0x05 + +/* Bits here make the output High-Z, instead of the OUTPUT value */ +#define REG_OUT_HIGH_Z 0x07 + +/* + * Bits here define the expected input state of the GPIO. + * INTERRUPT_STATUS bits will be set when the INPUT transitions away + * from this value. + */ +#define REG_IN_DEFAULT_STATE 0x09 + +/* + * Bits here enable either pull up or pull down according to + * REG_PULL_MODE. + */ +#define REG_PULL_ENABLE 0x0b + +/* + * Bits set here selects a pull-up/pull-down state of pin, which + * is configured as Input and the corresponding REG_PULL_ENABLE bit is + * set. + */ +#define REG_PULL_MODE 0x0d + +/* Returns the current status (1 = HIGH) of the input pins */ +#define REG_IN_STATUS 0x0f + +/* Mask of pins which can generate interrupts */ +#define REG_INT_MASK 0x11 + +/* Mask of pins which have generated an interrupt. Cleared on read */ +#define REG_INT_STATUS 0x13 + +/* Manufacturer's ID getting from Device ID & Ctrl register */ +enum { + MF_ID_MASK = GENMASK(7, 5), + MF_ID_SHIFT = 5, +}; + +/* Firmware revision getting from Device ID & Ctrl register */ +enum { + FW_REV_MASK = GENMASK(4, 2), + FW_REV_SHIFT = 2, +}; + +enum io_direction { + DIR_IN, + DIR_OUT, +}; + +/* + * struct fxl6408_info - Data for fxl6408 + * + * @dev: udevice structure for the device + * @addr: i2c slave address + * @reg_io_dir: hold the value of direction register + * @reg_output: hold the value of output register + */ +struct fxl6408_info { + struct udevice *dev; + int addr; + u8 device_id; + u8 reg_io_dir; + u8 reg_output; +}; + +static inline int fxl6408_write(struct udevice *dev, int reg, u8 val) +{ + return dm_i2c_write(dev, reg, &val, 1); +} + +static int fxl6408_read(struct udevice *dev, int reg) +{ + int ret; + u8 tmp; + + ret = dm_i2c_read(dev, reg, &tmp, 1); + if (!ret) + ret = tmp; + + return ret; +} + +/* + * fxl6408_is_output() - check whether the gpio configures as either + * output or input. + * Return: false - input, true - output. + */ +static bool fxl6408_is_output(struct udevice *dev, int offset) +{ + struct fxl6408_info *info = dev_get_plat(dev); + + return info->reg_io_dir & BIT(offset); +} + +static int fxl6408_get_value(struct udevice *dev, uint offset) +{ + int ret, reg = fxl6408_is_output(dev, offset) ? REG_OUT_STATE : REG_IN_STATUS; + + ret = fxl6408_read(dev, reg); + if (ret < 0) + return ret; + + return !!(ret & BIT(offset)); +} + +static int fxl6408_set_value(struct udevice *dev, uint offset, int value) +{ + struct fxl6408_info *info = dev_get_plat(dev); + u8 val; + int ret; + + if (value) + val = info->reg_output | BIT(offset); + else + val = info->reg_output & ~BIT(offset); + + ret = fxl6408_write(dev, REG_OUT_STATE, val); + if (ret < 0) + return ret; + + info->reg_output = val; + + return 0; +} + +static int fxl6408_set_direction(struct udevice *dev, uint offset, + enum io_direction dir) +{ + struct fxl6408_info *info = dev_get_plat(dev); + u8 val; + int ret; + + if (dir == DIR_IN) + val = info->reg_io_dir & ~BIT(offset); + else + val = info->reg_io_dir | BIT(offset); + + ret = fxl6408_write(dev, REG_IO_DIR, val); + if (ret < 0) + return ret; + + info->reg_io_dir = val; + + return 0; +} + +static int fxl6408_direction_input(struct udevice *dev, uint offset) +{ + return fxl6408_set_direction(dev, offset, DIR_IN); +} + +static int fxl6408_direction_output(struct udevice *dev, uint offset, int value) +{ + int ret; + + /* Configure output value */ + ret = fxl6408_set_value(dev, offset, value); + if (ret < 0) + return ret; + /* Configure direction as output */ + fxl6408_set_direction(dev, offset, DIR_OUT); + + return 0; +} + +static int fxl6408_get_function(struct udevice *dev, uint offset) +{ + if (fxl6408_is_output(dev, offset)) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int fxl6408_xlate(struct udevice *dev, struct gpio_desc *desc, + struct ofnode_phandle_args *args) +{ + desc->offset = args->args[0]; + desc->flags = args->args[1] & GPIO_ACTIVE_LOW ? GPIOD_ACTIVE_LOW : 0; + + return 0; +} + +static const struct dm_gpio_ops fxl6408_ops = { + .direction_input = fxl6408_direction_input, + .direction_output = fxl6408_direction_output, + .get_value = fxl6408_get_value, + .set_value = fxl6408_set_value, + .get_function = fxl6408_get_function, + .xlate = fxl6408_xlate, +}; + +static int fxl6408_probe(struct udevice *dev) +{ + struct fxl6408_info *info = dev_get_plat(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + char name[32], label[32], *str; + int addr; + int ret; + int size; + const u8 *tmp; + u32 val32; + + addr = dev_read_addr(dev); + if (addr == 0) + return -EINVAL; + info->addr = addr; + + /* + * Check the device ID register to see if it's responding. + * This also clears RST_INT as a side effect, so we won't get + * the "we've been power cycled" interrupt once interrupts + * being enabled. + */ + ret = fxl6408_read(dev, REG_DEVID_CTRL); + if (ret < 0) { + dev_err(dev, "FXL6408 probe returned %d\n", ret); + return ret; + } + + if ((ret & MF_ID_MASK) >> MF_ID_SHIFT != MF_ID_FAIRCHILD) { + dev_err(dev, "FXL6408 probe: wrong Manufacturer's ID: 0x%02x\n", ret); + return -ENXIO; + } + info->device_id = ret; + + /* + * Disable High-Z of outputs, so that the OUTPUT updates + * actually take effect. + */ + ret = fxl6408_write(dev, REG_OUT_HIGH_Z, (u8)0); + if (ret < 0) { + dev_err(dev, "Error writing High-Z register\n"); + return ret; + } + + /* + * If configured, set initial output state and direction, + * otherwise read them from the chip. + */ + if (dev_read_u32(dev, "initial_io_dir", &val32)) { + ret = fxl6408_read(dev, REG_IO_DIR); + if (ret < 0) { + dev_err(dev, "Error reading direction register\n"); + return ret; + } + info->reg_io_dir = ret; + } else { + info->reg_io_dir = val32 & 0xFF; + ret = fxl6408_write(dev, REG_IO_DIR, info->reg_io_dir); + if (ret < 0) { + dev_err(dev, "Error setting direction register\n"); + return ret; + } + } + + if (dev_read_u32(dev, "initial_output", &val32)) { + ret = fxl6408_read(dev, REG_OUT_STATE); + if (ret < 0) { + dev_err(dev, "Error reading output register\n"); + return ret; + } + info->reg_output = ret; + } else { + info->reg_output = val32 & 0xFF; + ret = fxl6408_write(dev, REG_OUT_STATE, info->reg_output); + if (ret < 0) { + dev_err(dev, "Error setting output register\n"); + return ret; + } + } + + tmp = dev_read_prop(dev, "label", &size); + if (tmp) { + size = min(size, (int)sizeof(label) - 1); + memcpy(label, tmp, size); + label[size] = '\0'; + snprintf(name, sizeof(name), "%s@%x_", label, info->addr); + } else { + snprintf(name, sizeof(name), "gpio@%x_", info->addr); + } + + str = strdup(name); + if (!str) + return -ENOMEM; + + uc_priv->bank_name = str; + uc_priv->gpio_count = dev_get_driver_data(dev); + uc_priv->gpio_base = -1; + + dev_dbg(dev, "%s (FW rev. %d) is ready\n", str, + (info->device_id & MF_ID_MASK) >> MF_ID_SHIFT); + + return 0; +} + +static const struct udevice_id fxl6408_ids[] = { + { .compatible = "fcs,fxl6408", .data = 8 }, + { } +}; + +U_BOOT_DRIVER(fxl6408_gpio) = { + .name = "fxl6408_gpio", + .id = UCLASS_GPIO, + .ops = &fxl6408_ops, + .probe = fxl6408_probe, + .of_match = fxl6408_ids, + .plat_auto = sizeof(struct fxl6408_info), +};
The FXL6408 GPIO expander manages critical devices, including on-module USB hub. Configure the expander to switch the USB hub into bypass mode, allowing to use on-carrier-board USB hub.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
arch/arm/dts/fsl-imx8qxp-colibri.dts | 27 +++++++++++++++++++++++++++ configs/colibri-imx8x_defconfig | 1 + 2 files changed, 28 insertions(+)
diff --git a/arch/arm/dts/fsl-imx8qxp-colibri.dts b/arch/arm/dts/fsl-imx8qxp-colibri.dts index 11ece34c02..df992ac639 100644 --- a/arch/arm/dts/fsl-imx8qxp-colibri.dts +++ b/arch/arm/dts/fsl-imx8qxp-colibri.dts @@ -129,6 +129,14 @@ >; };
+ /* On Module I2C */ + pinctrl_i2c0: i2c0grp { + fsl,pins = < + SC_P_MIPI_CSI0_GPIO0_00_ADMA_I2C0_SCL 0x06000021 + SC_P_MIPI_CSI0_GPIO0_01_ADMA_I2C0_SDA 0x06000021 + >; + }; + /* Off Module I2C */ pinctrl_i2c1: i2c1grp { fsl,pins = < @@ -298,6 +306,25 @@ }; };
+&i2c0 { + #address-cells = <1>; + #size-cells = <0>; + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c0>; + status = "okay"; + + /* GPIO expander */ + gpio_expander_43: gpio-expander@43 { + compatible = "fcs,fxl6408"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x43>; + initial_io_dir = <0xff>; + initial_output = <0x05>; + }; +}; + &i2c1 { #address-cells = <1>; #size-cells = <0>; diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig index a0816acc27..fbe6e575a3 100644 --- a/configs/colibri-imx8x_defconfig +++ b/configs/colibri-imx8x_defconfig @@ -38,6 +38,7 @@ CONFIG_TFTP_BLOCKSIZE=4096 CONFIG_TFTP_TSIZE=y CONFIG_CLK_IMX8=y CONFIG_CPU=y +CONFIG_FXL6408_GPIO=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_IMX_LPI2C=y
Hello Oleksandr,
Changes in v3:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
3 emails for you. Would be the best to choose only one.
Changes in v3:
- bool "FXL6408 I2C GPIO expander driver"
- depends on DM_GPIO && DM_I2C
- help
- Copyright (C) 2021 Toradex
- Copyright (C) 2016 Broadcom
Below is not kernel-doc format
- DOC: FXL6408 I2C to GPIO expander.
- This chip has 8 GPIO lines out of it, and is controlled by an I2C
- bus (a pair of lines), providing 4x expansion of GPIO lines. It
- also provides an interrupt line out for notifying of state changes.
- Any preconfigured state will be left in place until the GPIO lines
- get activated. At power on, everything is treated as an input,
- default input is HIGH and pulled-up, all interrupts are masked.
- Documentation can be found at:
- This driver bases on:
- drivers/gpio/pca953x_gpio.c
- TODO:
please sort it.
0x1
0x3
- Bits set here, when the corresponding bit of REG_IO_DIR is set, drive
- the output high instead of low.
ditto
ditto
- Bits here define the expected input state of the GPIO.
- INTERRUPT_STATUS bits will be set when the INPUT transitions away
- from this value.
ditto.
- Bits here enable either pull up or pull down according to
- REG_PULL_MODE.
ditto.
- Bits set here selects a pull-up/pull-down state of pin, which
- is configured as Input and the corresponding REG_PULL_ENABLE bit is
- set.
ditto
ditto
- MF_ID_MASK = GENMASK(7, 5),
- MF_ID_SHIFT = 5,
This smells. Take a look at include/linux/bitfield.h you should be able to use that macros to get fields you want.
- FW_REV_MASK = GENMASK(4, 2),
- FW_REV_SHIFT = 2,
ditto.
- DIR_IN,
- DIR_OUT,
good style is to initialized them.
/** this should be kernel doc.
Run this ./scripts/kernel-doc -man -v 1>/dev/null *.c
to check that all values are right.
- struct fxl6408_info - Data for fxl6408
- @dev: udevice structure for the device
- @addr: i2c slave address
- @reg_io_dir: hold the value of direction register
- @reg_output: hold the value of output register
- struct udevice *dev;
- int addr;
- u8 device_id;
- u8 reg_io_dir;
- u8 reg_output;
- return dm_i2c_write(dev, reg, &val, 1);
- int ret;
- u8 tmp;
- ret = dm_i2c_read(dev, reg, &tmp, 1);
- if (!ret)
ret = tmp;
This looks completely wrong. What value are you returning in case of error.
If ops->xfer is not defined dm_i2c_read returns -ENOSYS. tmp is not initialized and can have random value that's why here in case or error you will return ramdom value.
- return ret;
- fxl6408_is_output() - check whether the gpio configures as either
output or input.
- Return: false - input, true - output.
- struct fxl6408_info *info = dev_get_plat(dev);
- return info->reg_io_dir & BIT(offset);
- int ret, reg = fxl6408_is_output(dev, offset) ? REG_OUT_STATE : REG_IN_STATUS;
- ret = fxl6408_read(dev, reg);
- if (ret < 0)
return ret;
- return !!(ret & BIT(offset));
- u8 val;
- int ret;
- if (value)
- else
- ret = fxl6408_write(dev, REG_OUT_STATE, val);
- if (ret < 0)
return ret;
- info->reg_output = val;
- u8 val;
- int ret;
- if (dir == DIR_IN)
- else
- ret = fxl6408_write(dev, REG_IO_DIR, val);
- if (ret < 0)
return ret;
- info->reg_io_dir = val;
- return fxl6408_set_direction(dev, offset, DIR_IN);
- int ret;
- /* Configure output value */
- ret = fxl6408_set_value(dev, offset, value);
- if (ret < 0)
return ret;
newline
- /* Configure direction as output */
- fxl6408_set_direction(dev, offset, DIR_OUT);
- if (fxl6408_is_output(dev, offset))
- else
you can remove this else
return GPIOF_INPUT;
- desc->offset = args->args[0];
- desc->flags = args->args[1] & GPIO_ACTIVE_LOW ? GPIOD_ACTIVE_LOW : 0;
- .direction_input = fxl6408_direction_input,
- .direction_output = fxl6408_direction_output,
- .get_value = fxl6408_get_value,
- .set_value = fxl6408_set_value,
- .get_function = fxl6408_get_function,
- .xlate = fxl6408_xlate,
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- char name[32], label[32], *str;
- int addr;
- int ret;
- int size;
put them on the same line.
- const u8 *tmp;
- u32 val32;
- addr = dev_read_addr(dev);
- if (addr == 0)
return -EINVAL;
newline
- info->addr = addr;
* being enabled.
- ret = fxl6408_read(dev, REG_DEVID_CTRL);
- if (ret < 0) {
return ret;
- if ((ret & MF_ID_MASK) >> MF_ID_SHIFT != MF_ID_FAIRCHILD) {
return -ENXIO;
- info->device_id = ret;
- ret = fxl6408_write(dev, REG_OUT_HIGH_Z, (u8)0);
- if (ret < 0) {
return ret;
- if (dev_read_u32(dev, "initial_io_dir", &val32)) {
Where do you have dt binding document for this chip? I can't see anything in the linux kernel or in your series.
It is good that you read values from dt but you shouldn't do it in probe. You should create platdata and fill it by information from DT and then in probe just read them from platdata structure. This applied to all dt read in probe.
if (ret < 0) {
return ret;
- } else {
val32 is not initialized above. dev_read_u32 above fails that's why val32 wont't be initialized and here you do calculation with it.
That's quite weird behavior. The same pattern visible below.
if (ret < 0) {
return ret;
- if (dev_read_u32(dev, "initial_output", &val32)) {
if (ret < 0) {
return ret;
- } else {
if (ret < 0) {
return ret;
- tmp = dev_read_prop(dev, "label", &size);
- if (tmp) {
label[size] = '\0';
- } else {
I see some code around labels in gpio-uclass. I would be surprised if it is not there already because it should be core functionality not driver when labels are defined.
- str = strdup(name);
- if (!str)
return -ENOMEM;
- uc_priv->bank_name = str;
- uc_priv->gpio_count = dev_get_driver_data(dev);
- uc_priv->gpio_base = -1;
- dev_dbg(dev, "%s (FW rev. %d) is ready\n", str,
- { .compatible = "fcs,fxl6408", .data = 8 },
nit: Are you going to support more chip that you have data here?
- .name = "fxl6408_gpio",
- .id = UCLASS_GPIO,
- .ops = &fxl6408_ops,
- .probe = fxl6408_probe,
- .of_match = fxl6408_ids,
- .plat_auto = sizeof(struct fxl6408_info),
Thanks, Michal
Hi Oleksandr,
And to use a valid one, oleksandr.suvorov@toradex.com is gone as today, I understand and appreciate the very honest desire to give credit to the company that paid for this work (if I understand correctly), but on the other end using an email address that is going to bounce does not look like the correct solution.
Francesco
Hi Michal,
Thanks, fixed. That habit to always add '-s' when committing changes :)
Changes in v3:
help
I don't think so. And without formatting comments of this block as a kernel-doc, the kernel-doc tool shows the warning: drivers/gpio/gpio-fxl6408.c:1: warning: no structured comments found
Otherwise, it generates the correct description of the file: **FXL6408 I2C to GPIO expander.**
This chip has 8 GPIO lines out of it, and is controlled by an I2C bus (a pair of lines), providing 4x expansion of GPIO lines. It also provides an interrupt line out for notifying of state changes. ...
- TODO:
please sort it.
Done.
0x1
Here and for similar cases below: thanks, I'll fix it in the next revision.
0x3
ditto
ditto
- from this value.
ditto.
- REG_PULL_MODE.
ditto.
- set.
ditto
ditto
MF_ID_SHIFT = 5,
FW_REV_SHIFT = 2,
ditto.
DIR_IN,
DIR_OUT,
Thanks, I'll fix it in the next revision.
The kernel-doc doesn't found errors.
int addr;
u8 device_id;
u8 reg_io_dir;
u8 reg_output;
int ret;
u8 tmp;
if (!ret)
ret = tmp;
Nope. In case of error, I return an error value stored in "ret".
!(-ENOSYS) == false, thus "if" op fails and doesn't perform "ret = tmp". I don't see any errors here.
return ret;
output or input.
if (ret < 0)
return ret;
u8 val;
int ret;
if (value)
else
if (ret < 0)
return ret;
u8 val;
int ret;
if (dir == DIR_IN)
else
if (ret < 0)
return ret;
int ret;
if (ret < 0)
return ret;
newline
Done.
else
Sure, thank you.
return GPIOF_INPUT;
int addr;
int ret;
int size;
Done, thanks.
const u8 *tmp;
u32 val32;
if (addr == 0)
return -EINVAL;
newline
Done.
info->addr = addr;
* being enabled.
if (ret < 0) {
return ret;
return -ENXIO;
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
} else {
val32 is not initialized above. dev_read_u32 above fails that's why val32 wont't be initialized and here you do calculation with it. That's quite weird behavior. The same pattern visible below.
Nope. dev_read_u32() returns 0 on success. The logic is correct.
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
} else {
if (ret < 0) {
return ret;
if (tmp) {
label[size] = '\0';
} else {
This code is not about gpios labeling. It's about the bank name, it just sets the uc_priv->bank_name which is used in gpio-uclass.
str = strdup(name);
if (!str)
return -ENOMEM;
I can't be sure - I don't know plans of Fairchild or other manufacturers about gpio devices similar to that one :)
.id = UCLASS_GPIO,
Thanks, Michal
Thanks for such a detailed and helpful review!
-- Best regards Oleksandr
On 9/15/21 8:35 PM, Oleksandr Suvorov wrote:
Hi Michal,
Changes in v3:
help
Because script only checks format starting with /**.
<snip>
Because it doesn't find any structure to check. Add here /** and run that script again.
int addr;
u8 device_id;
u8 reg_io_dir;
u8 reg_output;
int ret;
u8 tmp;
if (!ret)
ret = tmp;
You are right. I read it incorrectly.
<snip>
if (ret < 0) {
return ret;
} else {
You are right again. I normally use reverse logic.
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
} else {
if (ret < 0) {
return ret;
if (tmp) {
label[size] = '\0';
} else {
Can you please use different variable name then label. If this is bank_name just call it bank name.
Thanks, Michal
i Michal,
Hi Michal,
Changes in v3:
help
Sure, missed that "little" thing :) Thanks!
<snip>
int addr;
u8 device_id;
u8 reg_io_dir;
u8 reg_output;
int ret;
u8 tmp;
if (!ret)
ret = tmp;
<snip>
if (ret < 0) {
return ret;
} else {
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
} else {
if (ret < 0) {
return ret;
if (tmp) {
label[size] = '\0';
} else {
It makes sense. I'll rename it in the next revision. Thanks!
Thanks, Michal
participants (5)
Francesco Dolcini
Heiko Schocher
Michal Simek
Oleksandr Suvorov
Oleksandr Suvorov
