[PATCH v6 1/2] arm: dts: imx8mq: Add Kontron pitx-imx8m
This adds the device tree for the Kontron pitx-imx8m Board. It is a copy of the device tree from the linux kernel sources.
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com --- v6: - no change
v5: - no change
v4: - no change
v3: - no change
v2: - no change
arch/arm/dts/Makefile | 3 +- arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts | 613 +++++++++++++++++++++ 2 files changed, 615 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 9438bf735a..9228b1d6c1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -887,7 +887,8 @@ dtb-$(CONFIG_ARCH_IMX8M) += \ imx8mq-phanbell.dtb \ imx8mp-evk.dtb \ imx8mp-phyboard-pollux-rdk.dtb \ - imx8mq-pico-pi.dtb + imx8mq-pico-pi.dtb \ + imx8mq-kontron-pitx-imx8m.dtb
dtb-$(CONFIG_ARCH_IMXRT) += imxrt1050-evk.dtb \ imxrt1020-evk.dtb diff --git a/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts b/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts new file mode 100644 index 0000000000..f593e4ff62 --- /dev/null +++ b/arch/arm/dts/imx8mq-kontron-pitx-imx8m.dts @@ -0,0 +1,613 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree File for the Kontron pitx-imx8m board. + * + * Copyright (C) 2021 Heiko Thiery heiko.thiery@gmail.com + */ + +/dts-v1/; + +#include "imx8mq.dtsi" +#include <dt-bindings/net/ti-dp83867.h> + +/ { + model = "Kontron pITX-imx8m"; + compatible = "kontron,pitx-imx8m", "fsl,imx8mq"; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + mmc0 = &usdhc1; + mmc1 = &usdhc2; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + spi0 = &qspi0; + spi1 = &ecspi2; + }; + + chosen { + stdout-path = "serial2:115200n8"; + }; + + pcie0_refclk: pcie0-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + pcie1_refclk: pcie1-clock { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <100000000>; + }; + + reg_usdhc2_vmmc: regulator-usdhc2-vmmc { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_reg_usdhc2>; + regulator-name = "V_3V3_SD"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 19 GPIO_ACTIVE_HIGH>; + off-on-delay-us = <20000>; + enable-active-high; + }; +}; + +&ecspi2 { + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_ecspi2 &pinctrl_ecspi2_cs>; + cs-gpios = <&gpio5 13 GPIO_ACTIVE_LOW>; + status = "okay"; + + tpm@0 { + compatible = "infineon,slb9670"; + reg = <0>; + spi-max-frequency = <43000000>; + }; +}; + +&fec1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_fec1>; + phy-mode = "rgmii-id"; + phy-handle = <ðphy0>; + fsl,magic-packet; + status = "okay"; + + mdio { + #address-cells = <1>; + #size-cells = <0>; + + ethphy0: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>; + ti,tx-internal-delay = <DP83867_RGMIIDCTL_2_75_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + reset-gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + reset-assert-us = <10>; + reset-deassert-us = <280>; + }; + }; +}; + +&i2c1 { + clock-frequency = <400000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; + + pmic@8 { + compatible = "fsl,pfuze100"; + fsl,pfuze-support-disable-sw; + reg = <0x8>; + + regulators { + sw1a_reg: sw1ab { + regulator-name = "V_0V9_GPU"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + }; + + sw1c_reg: sw1c { + regulator-name = "V_0V9_VPU"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + }; + + sw2_reg: sw2 { + regulator-name = "V_1V1_NVCC_DRAM"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + sw3a_reg: sw3ab { + regulator-name = "V_1V0_DRAM"; + regulator-min-microvolt = <825000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + sw4_reg: sw4 { + regulator-name = "V_1V8_S0"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-name = "NC"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + }; + + snvs_reg: vsnvs { + regulator-name = "V_0V9_SNVS"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-name = "V_0V55_VREF_DDR"; + regulator-always-on; + }; + + vgen1_reg: vgen1 { + regulator-name = "V_1V5_CSI"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + }; + + vgen2_reg: vgen2 { + regulator-name = "V_0V9_PHY"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <975000>; + regulator-always-on; + }; + + vgen3_reg: vgen3 { + regulator-name = "V_1V8_PHY"; + regulator-min-microvolt = <1675000>; + regulator-max-microvolt = <1975000>; + regulator-always-on; + }; + + vgen4_reg: vgen4 { + regulator-name = "V_1V8_VDDA"; + regulator-min-microvolt = <1625000>; + regulator-max-microvolt = <1875000>; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-name = "V_3V3_PHY"; + regulator-min-microvolt = <3075000>; + regulator-max-microvolt = <3625000>; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-name = "V_2V8_CAM"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + fan-controller@1b { + compatible = "maxim,max6650"; + reg = <0x1b>; + maxim,fan-microvolt = <5000000>; + }; + + rtc@32 { + compatible = "microcrystal,rv8803"; + reg = <0x32>; + }; + + sensor@4b { + compatible = "national,lm75b"; + reg = <0x4b>; + }; + + eeprom@51 { + compatible = "atmel,24c32"; + reg = <0x51>; + pagesize = <32>; + }; +}; + +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; +}; + +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c3>; + status = "okay"; +}; + +/* M.2 B-key slot */ +&pcie0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie0>; + reset-gpio = <&gpio1 9 GPIO_ACTIVE_LOW>; + clocks = <&clk IMX8MQ_CLK_PCIE1_ROOT>, + <&clk IMX8MQ_CLK_PCIE1_AUX>, + <&clk IMX8MQ_CLK_PCIE1_PHY>, + <&pcie0_refclk>; + clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; + status = "okay"; +}; + +/* Intel Ethernet Controller I210/I211 */ +&pcie1 { + clocks = <&clk IMX8MQ_CLK_PCIE2_ROOT>, + <&clk IMX8MQ_CLK_PCIE2_AUX>, + <&clk IMX8MQ_CLK_PCIE2_PHY>, + <&pcie1_refclk>; + clock-names = "pcie", "pcie_aux", "pcie_phy", "pcie_bus"; + fsl,max-link-speed = <1>; + status = "okay"; +}; + +&pgc_gpu { + power-supply = <&sw1a_reg>; +}; + +&pgc_vpu { + power-supply = <&sw1c_reg>; +}; + +&qspi0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_qspi>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + m25p,fast-read; + spi-max-frequency = <50000000>; + }; +}; + +&snvs_pwrkey { + status = "okay"; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + assigned-clocks = <&clk IMX8MQ_CLK_UART1>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2>; + assigned-clocks = <&clk IMX8MQ_CLK_UART2>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + fsl,uart-has-rtscts; + assigned-clocks = <&clk IMX8MQ_CLK_UART3>; + assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_80M>; + status = "okay"; +}; + +&usb3_phy0 { + status = "okay"; +}; + +&usb3_phy1 { + status = "okay"; +}; + +&usb_dwc3_0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usb0>; + dr_mode = "otg"; + hnp-disable; + srp-disable; + adp-disable; + maximum-speed = "high-speed"; + status = "okay"; +}; + +&usb_dwc3_1 { + dr_mode = "host"; + status = "okay"; +}; + +&usdhc1 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC1>; + assigned-clock-rates = <400000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc1>; + pinctrl-1 = <&pinctrl_usdhc1_100mhz>; + pinctrl-2 = <&pinctrl_usdhc1_200mhz>; + vqmmc-supply = <&sw4_reg>; + bus-width = <8>; + non-removable; + no-sd; + no-sdio; + status = "okay"; +}; + +&usdhc2 { + assigned-clocks = <&clk IMX8MQ_CLK_USDHC2>; + assigned-clock-rates = <200000000>; + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; + bus-width = <4>; + cd-gpios = <&gpio2 12 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 20 GPIO_ACTIVE_HIGH>; + vmmc-supply = <®_usdhc2_vmmc>; + status = "okay"; +}; + +&wdog1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_wdog>; + fsl,ext-reset-output; + status = "okay"; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog>; + + pinctrl_hog: hoggrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_CE1_B_GPIO3_IO2 0x19 /* TPM Reset */ + MX8MQ_IOMUXC_NAND_CE3_B_GPIO3_IO4 0x19 /* USB2 Hub Reset */ + >; + }; + + pinctrl_gpio: gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_CLE_GPIO3_IO5 0x19 /* GPIO0 */ + MX8MQ_IOMUXC_NAND_RE_B_GPIO3_IO15 0x19 /* GPIO1 */ + MX8MQ_IOMUXC_NAND_WE_B_GPIO3_IO17 0x19 /* GPIO2 */ + MX8MQ_IOMUXC_NAND_WP_B_GPIO3_IO18 0x19 /* GPIO3 */ + MX8MQ_IOMUXC_NAND_READY_B_GPIO3_IO16 0x19 /* GPIO4 */ + MX8MQ_IOMUXC_NAND_DATA04_GPIO3_IO10 0x19 /* GPIO5 */ + MX8MQ_IOMUXC_NAND_DATA05_GPIO3_IO11 0x19 /* GPIO6 */ + MX8MQ_IOMUXC_NAND_DATA06_GPIO3_IO12 0x19 /* GPIO7 */ + >; + }; + + pinctrl_pcie0: pcie0grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO09_GPIO1_IO9 0x16 /* PCIE_PERST */ + MX8MQ_IOMUXC_UART4_TXD_GPIO5_IO29 0x16 /* W_DISABLE */ + >; + }; + + pinctrl_reg_usdhc2: regusdhc2gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_RESET_B_GPIO2_IO19 0x41 + >; + }; + + pinctrl_fec1: fec1grp { + fsl,pins = < + MX8MQ_IOMUXC_ENET_MDC_ENET1_MDC 0x3 + MX8MQ_IOMUXC_ENET_MDIO_ENET1_MDIO 0x23 + MX8MQ_IOMUXC_ENET_TD3_ENET1_RGMII_TD3 0x1f + MX8MQ_IOMUXC_ENET_TD2_ENET1_RGMII_TD2 0x1f + MX8MQ_IOMUXC_ENET_TD1_ENET1_RGMII_TD1 0x1f + MX8MQ_IOMUXC_ENET_TD0_ENET1_RGMII_TD0 0x1f + MX8MQ_IOMUXC_ENET_RD3_ENET1_RGMII_RD3 0x91 + MX8MQ_IOMUXC_ENET_RD2_ENET1_RGMII_RD2 0x91 + MX8MQ_IOMUXC_ENET_RD1_ENET1_RGMII_RD1 0x91 + MX8MQ_IOMUXC_ENET_RD0_ENET1_RGMII_RD0 0x91 + MX8MQ_IOMUXC_ENET_TXC_ENET1_RGMII_TXC 0x1f + MX8MQ_IOMUXC_ENET_RXC_ENET1_RGMII_RXC 0x91 + MX8MQ_IOMUXC_ENET_RX_CTL_ENET1_RGMII_RX_CTL 0x91 + MX8MQ_IOMUXC_ENET_TX_CTL_ENET1_RGMII_TX_CTL 0x1f + MX8MQ_IOMUXC_GPIO1_IO11_GPIO1_IO11 0x16 + MX8MQ_IOMUXC_GPIO1_IO15_GPIO1_IO15 0x16 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C1_SCL_I2C1_SCL 0x4000007f + MX8MQ_IOMUXC_I2C1_SDA_I2C1_SDA 0x4000007f + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C2_SCL_I2C2_SCL 0x4000007f + MX8MQ_IOMUXC_I2C2_SDA_I2C2_SDA 0x4000007f + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX8MQ_IOMUXC_I2C3_SCL_I2C3_SCL 0x4000007f + MX8MQ_IOMUXC_I2C3_SDA_I2C3_SDA 0x4000007f + >; + }; + + pinctrl_qspi: qspigrp { + fsl,pins = < + MX8MQ_IOMUXC_NAND_ALE_QSPI_A_SCLK 0x82 + MX8MQ_IOMUXC_NAND_CE0_B_QSPI_A_SS0_B 0x82 + MX8MQ_IOMUXC_NAND_DATA00_QSPI_A_DATA0 0x82 + MX8MQ_IOMUXC_NAND_DATA01_QSPI_A_DATA1 0x82 + MX8MQ_IOMUXC_NAND_DATA02_QSPI_A_DATA2 0x82 + MX8MQ_IOMUXC_NAND_DATA03_QSPI_A_DATA3 0x82 + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI2_MOSI_ECSPI2_MOSI 0x19 + MX8MQ_IOMUXC_ECSPI2_MISO_ECSPI2_MISO 0x19 + MX8MQ_IOMUXC_ECSPI2_SCLK_ECSPI2_SCLK 0x19 + >; + }; + + pinctrl_ecspi2_cs: ecspi2csgrp { + fsl,pins = < + MX8MQ_IOMUXC_ECSPI2_SS0_GPIO5_IO13 0x19 + >; + }; + + pinctrl_uart1: uart1grp { + fsl,pins = < + MX8MQ_IOMUXC_UART1_TXD_UART1_DCE_TX 0x49 + MX8MQ_IOMUXC_UART1_RXD_UART1_DCE_RX 0x49 + >; + }; + + pinctrl_uart2: uart2grp { + fsl,pins = < + MX8MQ_IOMUXC_UART2_TXD_UART2_DCE_TX 0x49 + MX8MQ_IOMUXC_UART2_RXD_UART2_DCE_RX 0x49 + >; + }; + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX8MQ_IOMUXC_UART3_TXD_UART3_DCE_TX 0x49 + MX8MQ_IOMUXC_UART3_RXD_UART3_DCE_RX 0x49 + MX8MQ_IOMUXC_ECSPI1_SS0_UART3_DCE_RTS_B 0x49 + MX8MQ_IOMUXC_ECSPI1_MISO_UART3_DCE_CTS_B 0x49 + >; + }; + + pinctrl_usdhc1: usdhc1grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x83 + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xc3 + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xc3 + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xc3 + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xc3 + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xc3 + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xc3 + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xc3 + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xc3 + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xc3 + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x83 + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_100mhz: usdhc1-100grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x8d + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xcd + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xcd + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xcd + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xcd + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xcd + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xcd + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xcd + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xcd + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xcd + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x8d + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc1_200mhz: usdhc1-200grp { + fsl,pins = < + MX8MQ_IOMUXC_SD1_CLK_USDHC1_CLK 0x9f + MX8MQ_IOMUXC_SD1_CMD_USDHC1_CMD 0xdf + MX8MQ_IOMUXC_SD1_DATA0_USDHC1_DATA0 0xdf + MX8MQ_IOMUXC_SD1_DATA1_USDHC1_DATA1 0xdf + MX8MQ_IOMUXC_SD1_DATA2_USDHC1_DATA2 0xdf + MX8MQ_IOMUXC_SD1_DATA3_USDHC1_DATA3 0xdf + MX8MQ_IOMUXC_SD1_DATA4_USDHC1_DATA4 0xdf + MX8MQ_IOMUXC_SD1_DATA5_USDHC1_DATA5 0xdf + MX8MQ_IOMUXC_SD1_DATA6_USDHC1_DATA6 0xdf + MX8MQ_IOMUXC_SD1_DATA7_USDHC1_DATA7 0xdf + MX8MQ_IOMUXC_SD1_STROBE_USDHC1_STROBE 0x9f + MX8MQ_IOMUXC_SD1_RESET_B_USDHC1_RESET_B 0xc1 + >; + }; + + pinctrl_usdhc2_gpio: usdhc2gpiogrp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CD_B_GPIO2_IO12 0x41 + MX8MQ_IOMUXC_SD2_WP_GPIO2_IO20 0x19 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x83 + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xc3 + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xc3 + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xc3 + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xc3 + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xc3 + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2-100grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x8d + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xcd + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xcd + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xcd + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xcd + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xcd + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2-200grp { + fsl,pins = < + MX8MQ_IOMUXC_SD2_CLK_USDHC2_CLK 0x9f + MX8MQ_IOMUXC_SD2_CMD_USDHC2_CMD 0xdf + MX8MQ_IOMUXC_SD2_DATA0_USDHC2_DATA0 0xdf + MX8MQ_IOMUXC_SD2_DATA1_USDHC2_DATA1 0xdf + MX8MQ_IOMUXC_SD2_DATA2_USDHC2_DATA2 0xdf + MX8MQ_IOMUXC_SD2_DATA3_USDHC2_DATA3 0xdf + MX8MQ_IOMUXC_GPIO1_IO04_USDHC2_VSELECT 0xc1 + >; + }; + + pinctrl_usb0: usb0grp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO12_USB1_OTG_PWR 0x19 + MX8MQ_IOMUXC_GPIO1_IO13_USB1_OTG_OC 0x19 + >; + }; + + pinctrl_wdog: wdoggrp { + fsl,pins = < + MX8MQ_IOMUXC_GPIO1_IO02_WDOG1_WDOG_B 0xc6 + >; + }; +};
The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX form factor.
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com --- v6: - increase PHY_ANEG_TIMEOUT - spl: print boot source on startup - spl: remove PMIC output - enable CONFIG_CMD_TIME
v5: - save env in eMMC boot partition 0
v4: update board integration
- migrate to IMX_CONFIG - convert config options to Kconfig - CONFIG_POWER_I2C - CONFIG_SPL_POWER_I2C - CONFIG_POWER_LEGACY - CONFIG_SYS_LOAD_ADDR - CONFIG_SYS_I2C_MXC - CONFIG_SYS_I2C_LEGACY - CONFIG_SYS_I2C_MXC_I2C1 - CONFIG_SYS_I2C_MXC_I2C2 - CONFIG_SYS_I2C_MXC_I2C3 - CONFIG_SYS_LOAD_ADDR - CONFIG_MXC_GPIO
v3: - enable EFI capsule support - add update FIT image creation to binman config - change env offset to fit into eMMC boot partition
v2: - add support for 2/4GB variant - enable config options - CONFIG_CMD_GPT - CONFIG_DM_ETH_PHY - CONFIG_EFI_SET_TIME - add pxefile_addr_r env variable
.../dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi | 163 ++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/kontron/pitx_imx8m/Kconfig | 15 + board/kontron/pitx_imx8m/MAINTAINERS | 7 + board/kontron/pitx_imx8m/Makefile | 8 + board/kontron/pitx_imx8m/imximage.cfg | 5 + board/kontron/pitx_imx8m/lpddr4_timing_2gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/lpddr4_timing_4gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/pitx_imx8m.c | 156 ++ board/kontron/pitx_imx8m/spl.c | 327 +++ configs/kontron_pitx_imx8m_defconfig | 87 + doc/board/kontron/index.rst | 1 + doc/board/kontron/pitx-imx8m.rst | 67 + include/configs/kontron_pitx_imx8m.h | 111 + 14 files changed, 4660 insertions(+) create mode 100644 arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi create mode 100644 board/kontron/pitx_imx8m/Kconfig create mode 100644 board/kontron/pitx_imx8m/MAINTAINERS create mode 100644 board/kontron/pitx_imx8m/Makefile create mode 100644 board/kontron/pitx_imx8m/imximage.cfg create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_2gb.c create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_4gb.c create mode 100644 board/kontron/pitx_imx8m/pitx_imx8m.c create mode 100644 board/kontron/pitx_imx8m/spl.c create mode 100644 configs/kontron_pitx_imx8m_defconfig create mode 100644 doc/board/kontron/pitx-imx8m.rst create mode 100644 include/configs/kontron_pitx_imx8m.h
diff --git a/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi new file mode 100644 index 0000000000..cf649b0314 --- /dev/null +++ b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) + +#include <config.h> + +/ { + binman: binman { + multiple-images; + }; +}; + +&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + u-boot-nodtb { + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x910000>; + entry = <0x910000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + fdt { + description = "imx8mq-kontron-pitx-imx8m.dtb"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob: blob-ext { + filename = "u-boot.dtb"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + description = "imx8mq-kontron-pitx-imx8m.dtb"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; + + u-boot-update { + filename = "firmware-update.itb"; + + fit { + description = "Configuration for firmware update file"; + + images { + flash-bin { + description = "U-Boot flash image"; + type = "firmware"; + os = "u-boot"; + arch = "arm"; + compress = "none"; + load = <0>; /* unused */ + + blob { + filename = "flash.bin"; + }; + + }; + }; + }; + }; +}; + +®_usdhc2_vmmc { + off-on-delay-us = <0>; +}; + +&usdhc1 { + mmc-hs400-1_8v; +}; + +&usdhc2 { + sd-uhs-sdr104; + sd-uhs-ddr50; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ccaf106be5..86279dba93 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -101,6 +101,12 @@ config TARGET_PICO_IMX8MQ select IMX8MQ select IMX8M_LPDDR4
+config TARGET_KONTRON_PITX_IMX8M + bool "Support Kontron pITX-imx8m" + select BINMAN + select IMX8MQ + select IMX8M_LPDDR4 + config TARGET_VERDIN_IMX8MM bool "Support Toradex Verdin iMX8M Mini module" select IMX8MM @@ -150,6 +156,7 @@ source "board/freescale/imx8mn_evk/Kconfig" source "board/freescale/imx8mp_evk/Kconfig" source "board/gateworks/venice/Kconfig" source "board/google/imx8mq_phanbell/Kconfig" +source "board/kontron/pitx_imx8m/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/ronetix/imx8mq-cm/Kconfig" diff --git a/board/kontron/pitx_imx8m/Kconfig b/board/kontron/pitx_imx8m/Kconfig new file mode 100644 index 0000000000..5dce2cd37e --- /dev/null +++ b/board/kontron/pitx_imx8m/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KONTRON_PITX_IMX8M + +config SYS_BOARD + default "pitx_imx8m" + +config SYS_VENDOR + default "kontron" + +config SYS_CONFIG_NAME + default "kontron_pitx_imx8m" + +config IMX_CONFIG + default "board/kontron/pitx_imx8m/imximage.cfg" + +endif diff --git a/board/kontron/pitx_imx8m/MAINTAINERS b/board/kontron/pitx_imx8m/MAINTAINERS new file mode 100644 index 0000000000..aad84528e3 --- /dev/null +++ b/board/kontron/pitx_imx8m/MAINTAINERS @@ -0,0 +1,7 @@ +Kontron pITX-imx8m Board +M: Heiko Thiery heiko.thiery@gmail.com +S: Maintained +F: arch/arm/dts/imx8mq-kontron-pitx-imx8m* +F: board/kontron/pitx_imx8m/* +F: include/configs/kontron_pitx_imx8m.h +F: configs/kontron_pitx_imx8m_defconfig diff --git a/board/kontron/pitx_imx8m/Makefile b/board/kontron/pitx_imx8m/Makefile new file mode 100644 index 0000000000..904c480281 --- /dev/null +++ b/board/kontron/pitx_imx8m/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += pitx_imx8m.o + +ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_2gb.o lpddr4_timing_4gb.o +endif diff --git a/board/kontron/pitx_imx8m/imximage.cfg b/board/kontron/pitx_imx8m/imximage.cfg new file mode 100644 index 0000000000..4a110c8bcc --- /dev/null +++ b/board/kontron/pitx_imx8m/imximage.cfg @@ -0,0 +1,5 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +BOOT_FROM sd +SIGNED_HDMI signed_hdmi_imx8m.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c new file mode 100644 index 0000000000..b4647b9847 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa1080020 }, + { 0x3d400028, 0x0 }, + { 0x3d400020, 0x202 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x1800e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310008 }, + { 0x3d4000e8, 0x66004a }, + { 0x3d4000ec, 0x16004a }, + { 0x3d400100, 0x1a200624 }, + { 0x3d400104, 0x60636 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0x10040a10 }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0xc3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0x639 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x1f }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d402020, 0x0 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0x3001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004a }, + { 0x3d4020ec, 0x16004a }, + { 0x3d402100, 0xa040005 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0xc0640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x0 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004a }, + { 0x3d4030ec, 0x16004a }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0xc0190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400244, 0x0 }, + { 0x3d400250, 0x29001505 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x5900575b }, + { 0x3d400264, 0x90000096 }, + { 0x3d40026c, 0x1000012c }, + { 0x3d400300, 0x16 }, + { 0x3d400304, 0x0 }, + { 0x3d40030c, 0x0 }, + { 0x3d400320, 0x1 }, + { 0x3d40036c, 0x11 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x10f3 }, + { 0x3d400408, 0x72ff }, + { 0x3d400490, 0x1 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x62ffff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0xffff }, +}; + +/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x2 }, + { 0x100a1, 0x3 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x5 }, + { 0x100a5, 0x7 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x4 }, + { 0x110a0, 0x2 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x6 }, + { 0x110a5, 0x7 }, + { 0x110a6, 0x4 }, + { 0x110a7, 0x5 }, + { 0x120a0, 0x4 }, + { 0x120a1, 0x5 }, + { 0x120a2, 0x7 }, + { 0x120a3, 0x6 }, + { 0x120a4, 0x1 }, + { 0x120a5, 0x3 }, + { 0x120a6, 0x2 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x4 }, + { 0x130a1, 0x5 }, + { 0x130a2, 0x7 }, + { 0x130a3, 0x6 }, + { 0x130a4, 0x2 }, + { 0x130a5, 0x1 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x3 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x80 }, + { 0x1200c7, 0x80 }, + { 0x2200c7, 0x80 }, + { 0x200ca, 0x106 }, + { 0x1200ca, 0x106 }, + { 0x2200ca, 0x106 }, + { 0x20110, 0x2 }, + { 0x20111, 0x3 }, + { 0x20112, 0x4 }, + { 0x20113, 0x5 }, + { 0x20114, 0x0 }, + { 0x20115, 0x1 }, +}; + +/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x110 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x110 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x1 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +static struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c new file mode 100644 index 0000000000..fd7173bff1 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <linux/kernel.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h> + +static struct dram_cfg_param ddr_ddrc_cfg[] = { + /** Initialize DDRC registers **/ + { 0x3d400304, 0x1 }, + { 0x3d400030, 0x1 }, + { 0x3d400000, 0xa3080020 }, + { 0x3d400028, 0x0 }, + { 0x3d400020, 0x202 }, + { 0x3d400024, 0x3e800 }, + { 0x3d400064, 0x1800e0 }, + { 0x3d4000d0, 0xc003061c }, + { 0x3d4000d4, 0x9e0000 }, + { 0x3d4000dc, 0xd4002d }, + { 0x3d4000e0, 0x310008 }, + { 0x3d4000e8, 0x66004a }, + { 0x3d4000ec, 0x16004a }, + { 0x3d400100, 0x1a200624 }, + { 0x3d400104, 0x60636 }, + { 0x3d40010c, 0xc0c000 }, + { 0x3d400110, 0x10040a10 }, + { 0x3d400114, 0x2040c0c }, + { 0x3d400118, 0x1010007 }, + { 0x3d40011c, 0x401 }, + { 0x3d400130, 0x20600 }, + { 0x3d400134, 0xc100002 }, + { 0x3d400138, 0xe6 }, + { 0x3d400144, 0xa00050 }, + { 0x3d400180, 0xc3200018 }, + { 0x3d400184, 0x28061a8 }, + { 0x3d400188, 0x0 }, + { 0x3d400190, 0x497820a }, + { 0x3d400194, 0x80303 }, + { 0x3d4001a0, 0xe0400018 }, + { 0x3d4001a4, 0xdf00e4 }, + { 0x3d4001a8, 0x80000000 }, + { 0x3d4001b0, 0x11 }, + { 0x3d4001b4, 0x170a }, + { 0x3d4001c0, 0x1 }, + { 0x3d4001c4, 0x1 }, + { 0x3d4000f4, 0x639 }, + { 0x3d400108, 0x70e1617 }, + { 0x3d400200, 0x17 }, + { 0x3d40020c, 0x0 }, + { 0x3d400210, 0x1f1f }, + { 0x3d400204, 0x80808 }, + { 0x3d400214, 0x7070707 }, + { 0x3d400218, 0x7070707 }, + { 0x3d402020, 0x0 }, + { 0x3d402024, 0x7d00 }, + { 0x3d402050, 0x20d040 }, + { 0x3d402064, 0x3001c }, + { 0x3d4020dc, 0x840000 }, + { 0x3d4020e0, 0x310000 }, + { 0x3d4020e8, 0x66004a }, + { 0x3d4020ec, 0x16004a }, + { 0x3d402100, 0xa040005 }, + { 0x3d402104, 0x30407 }, + { 0x3d402108, 0x203060b }, + { 0x3d40210c, 0x505000 }, + { 0x3d402110, 0x2040202 }, + { 0x3d402114, 0x2030202 }, + { 0x3d402118, 0x1010004 }, + { 0x3d40211c, 0x301 }, + { 0x3d402130, 0x20300 }, + { 0x3d402134, 0xa100002 }, + { 0x3d402138, 0x1d }, + { 0x3d402144, 0x14000a }, + { 0x3d402180, 0xc0640004 }, + { 0x3d402190, 0x3818200 }, + { 0x3d402194, 0x80303 }, + { 0x3d4021b4, 0x100 }, + { 0x3d403020, 0x0 }, + { 0x3d403024, 0x1f40 }, + { 0x3d403050, 0x20d040 }, + { 0x3d403064, 0x30007 }, + { 0x3d4030dc, 0x840000 }, + { 0x3d4030e0, 0x310000 }, + { 0x3d4030e8, 0x66004a }, + { 0x3d4030ec, 0x16004a }, + { 0x3d403100, 0xa010102 }, + { 0x3d403104, 0x30404 }, + { 0x3d403108, 0x203060b }, + { 0x3d40310c, 0x505000 }, + { 0x3d403110, 0x2040202 }, + { 0x3d403114, 0x2030202 }, + { 0x3d403118, 0x1010004 }, + { 0x3d40311c, 0x301 }, + { 0x3d403130, 0x20300 }, + { 0x3d403134, 0xa100002 }, + { 0x3d403138, 0x8 }, + { 0x3d403144, 0x50003 }, + { 0x3d403180, 0xc0190004 }, + { 0x3d403190, 0x3818200 }, + { 0x3d403194, 0x80303 }, + { 0x3d4031b4, 0x100 }, + { 0x3d400244, 0x0 }, + { 0x3d400250, 0x29001505 }, + { 0x3d400254, 0x2c }, + { 0x3d40025c, 0x5900575b }, + { 0x3d400264, 0x90000096 }, + { 0x3d40026c, 0x1000012c }, + { 0x3d400300, 0x16 }, + { 0x3d400304, 0x0 }, + { 0x3d40030c, 0x0 }, + { 0x3d400320, 0x1 }, + { 0x3d40036c, 0x11 }, + { 0x3d400400, 0x111 }, + { 0x3d400404, 0x10f3 }, + { 0x3d400408, 0x72ff }, + { 0x3d400490, 0x1 }, + { 0x3d400494, 0xe00 }, + { 0x3d400498, 0x62ffff }, + { 0x3d40049c, 0xe00 }, + { 0x3d4004a0, 0xffff }, +}; + +/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = { + { 0x100a0, 0x2 }, + { 0x100a1, 0x3 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x1 }, + { 0x100a4, 0x5 }, + { 0x100a5, 0x7 }, + { 0x100a6, 0x6 }, + { 0x100a7, 0x4 }, + { 0x110a0, 0x2 }, + { 0x110a1, 0x1 }, + { 0x110a2, 0x3 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x6 }, + { 0x110a5, 0x7 }, + { 0x110a6, 0x4 }, + { 0x110a7, 0x5 }, + { 0x120a0, 0x4 }, + { 0x120a1, 0x5 }, + { 0x120a2, 0x7 }, + { 0x120a3, 0x6 }, + { 0x120a4, 0x1 }, + { 0x120a5, 0x3 }, + { 0x120a6, 0x2 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x4 }, + { 0x130a1, 0x5 }, + { 0x130a2, 0x7 }, + { 0x130a3, 0x6 }, + { 0x130a4, 0x2 }, + { 0x130a5, 0x1 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x3 }, + { 0x1005f, 0x1ff }, + { 0x1015f, 0x1ff }, + { 0x1105f, 0x1ff }, + { 0x1115f, 0x1ff }, + { 0x1205f, 0x1ff }, + { 0x1215f, 0x1ff }, + { 0x1305f, 0x1ff }, + { 0x1315f, 0x1ff }, + { 0x11005f, 0x1ff }, + { 0x11015f, 0x1ff }, + { 0x11105f, 0x1ff }, + { 0x11115f, 0x1ff }, + { 0x11205f, 0x1ff }, + { 0x11215f, 0x1ff }, + { 0x11305f, 0x1ff }, + { 0x11315f, 0x1ff }, + { 0x21005f, 0x1ff }, + { 0x21015f, 0x1ff }, + { 0x21105f, 0x1ff }, + { 0x21115f, 0x1ff }, + { 0x21205f, 0x1ff }, + { 0x21215f, 0x1ff }, + { 0x21305f, 0x1ff }, + { 0x21315f, 0x1ff }, + { 0x55, 0x1ff }, + { 0x1055, 0x1ff }, + { 0x2055, 0x1ff }, + { 0x3055, 0x1ff }, + { 0x4055, 0x1ff }, + { 0x5055, 0x1ff }, + { 0x6055, 0x1ff }, + { 0x7055, 0x1ff }, + { 0x8055, 0x1ff }, + { 0x9055, 0x1ff }, + { 0x200c5, 0x19 }, + { 0x1200c5, 0x7 }, + { 0x2200c5, 0x7 }, + { 0x2002e, 0x2 }, + { 0x12002e, 0x2 }, + { 0x22002e, 0x2 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x20024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x120024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x220024, 0x1ab }, + { 0x2003a, 0x0 }, + { 0x20056, 0x3 }, + { 0x120056, 0x3 }, + { 0x220056, 0x3 }, + { 0x1004d, 0xe00 }, + { 0x1014d, 0xe00 }, + { 0x1104d, 0xe00 }, + { 0x1114d, 0xe00 }, + { 0x1204d, 0xe00 }, + { 0x1214d, 0xe00 }, + { 0x1304d, 0xe00 }, + { 0x1314d, 0xe00 }, + { 0x11004d, 0xe00 }, + { 0x11014d, 0xe00 }, + { 0x11104d, 0xe00 }, + { 0x11114d, 0xe00 }, + { 0x11204d, 0xe00 }, + { 0x11214d, 0xe00 }, + { 0x11304d, 0xe00 }, + { 0x11314d, 0xe00 }, + { 0x21004d, 0xe00 }, + { 0x21014d, 0xe00 }, + { 0x21104d, 0xe00 }, + { 0x21114d, 0xe00 }, + { 0x21204d, 0xe00 }, + { 0x21214d, 0xe00 }, + { 0x21304d, 0xe00 }, + { 0x21314d, 0xe00 }, + { 0x10049, 0xeba }, + { 0x10149, 0xeba }, + { 0x11049, 0xeba }, + { 0x11149, 0xeba }, + { 0x12049, 0xeba }, + { 0x12149, 0xeba }, + { 0x13049, 0xeba }, + { 0x13149, 0xeba }, + { 0x110049, 0xeba }, + { 0x110149, 0xeba }, + { 0x111049, 0xeba }, + { 0x111149, 0xeba }, + { 0x112049, 0xeba }, + { 0x112149, 0xeba }, + { 0x113049, 0xeba }, + { 0x113149, 0xeba }, + { 0x210049, 0xeba }, + { 0x210149, 0xeba }, + { 0x211049, 0xeba }, + { 0x211149, 0xeba }, + { 0x212049, 0xeba }, + { 0x212149, 0xeba }, + { 0x213049, 0xeba }, + { 0x213149, 0xeba }, + { 0x43, 0x63 }, + { 0x1043, 0x63 }, + { 0x2043, 0x63 }, + { 0x3043, 0x63 }, + { 0x4043, 0x63 }, + { 0x5043, 0x63 }, + { 0x6043, 0x63 }, + { 0x7043, 0x63 }, + { 0x8043, 0x63 }, + { 0x9043, 0x63 }, + { 0x20018, 0x3 }, + { 0x20075, 0x4 }, + { 0x20050, 0x0 }, + { 0x20008, 0x320 }, + { 0x120008, 0x64 }, + { 0x220008, 0x19 }, + { 0x20088, 0x9 }, + { 0x200b2, 0xdc }, + { 0x10043, 0x5a1 }, + { 0x10143, 0x5a1 }, + { 0x11043, 0x5a1 }, + { 0x11143, 0x5a1 }, + { 0x12043, 0x5a1 }, + { 0x12143, 0x5a1 }, + { 0x13043, 0x5a1 }, + { 0x13143, 0x5a1 }, + { 0x1200b2, 0xdc }, + { 0x110043, 0x5a1 }, + { 0x110143, 0x5a1 }, + { 0x111043, 0x5a1 }, + { 0x111143, 0x5a1 }, + { 0x112043, 0x5a1 }, + { 0x112143, 0x5a1 }, + { 0x113043, 0x5a1 }, + { 0x113143, 0x5a1 }, + { 0x2200b2, 0xdc }, + { 0x210043, 0x5a1 }, + { 0x210143, 0x5a1 }, + { 0x211043, 0x5a1 }, + { 0x211143, 0x5a1 }, + { 0x212043, 0x5a1 }, + { 0x212143, 0x5a1 }, + { 0x213043, 0x5a1 }, + { 0x213143, 0x5a1 }, + { 0x200fa, 0x1 }, + { 0x1200fa, 0x1 }, + { 0x2200fa, 0x1 }, + { 0x20019, 0x1 }, + { 0x120019, 0x1 }, + { 0x220019, 0x1 }, + { 0x200f0, 0x660 }, + { 0x200f1, 0x0 }, + { 0x200f2, 0x4444 }, + { 0x200f3, 0x8888 }, + { 0x200f4, 0x5665 }, + { 0x200f5, 0x0 }, + { 0x200f6, 0x0 }, + { 0x200f7, 0xf000 }, + { 0x20025, 0x0 }, + { 0x2002d, 0x0 }, + { 0x12002d, 0x0 }, + { 0x22002d, 0x0 }, + { 0x200c7, 0x80 }, + { 0x1200c7, 0x80 }, + { 0x2200c7, 0x80 }, + { 0x200ca, 0x106 }, + { 0x1200ca, 0x106 }, + { 0x2200ca, 0x106 }, + { 0x20110, 0x2 }, + { 0x20111, 0x3 }, + { 0x20112, 0x4 }, + { 0x20113, 0x5 }, + { 0x20114, 0x0 }, + { 0x20115, 0x1 }, +}; + +/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = { + { 0x200b2, 0x0 }, + { 0x1200b2, 0x0 }, + { 0x2200b2, 0x0 }, + { 0x200cb, 0x0 }, + { 0x10043, 0x0 }, + { 0x110043, 0x0 }, + { 0x210043, 0x0 }, + { 0x10143, 0x0 }, + { 0x110143, 0x0 }, + { 0x210143, 0x0 }, + { 0x11043, 0x0 }, + { 0x111043, 0x0 }, + { 0x211043, 0x0 }, + { 0x11143, 0x0 }, + { 0x111143, 0x0 }, + { 0x211143, 0x0 }, + { 0x12043, 0x0 }, + { 0x112043, 0x0 }, + { 0x212043, 0x0 }, + { 0x12143, 0x0 }, + { 0x112143, 0x0 }, + { 0x212143, 0x0 }, + { 0x13043, 0x0 }, + { 0x113043, 0x0 }, + { 0x213043, 0x0 }, + { 0x13143, 0x0 }, + { 0x113143, 0x0 }, + { 0x213143, 0x0 }, + { 0x80, 0x0 }, + { 0x100080, 0x0 }, + { 0x200080, 0x0 }, + { 0x1080, 0x0 }, + { 0x101080, 0x0 }, + { 0x201080, 0x0 }, + { 0x2080, 0x0 }, + { 0x102080, 0x0 }, + { 0x202080, 0x0 }, + { 0x3080, 0x0 }, + { 0x103080, 0x0 }, + { 0x203080, 0x0 }, + { 0x4080, 0x0 }, + { 0x104080, 0x0 }, + { 0x204080, 0x0 }, + { 0x5080, 0x0 }, + { 0x105080, 0x0 }, + { 0x205080, 0x0 }, + { 0x6080, 0x0 }, + { 0x106080, 0x0 }, + { 0x206080, 0x0 }, + { 0x7080, 0x0 }, + { 0x107080, 0x0 }, + { 0x207080, 0x0 }, + { 0x8080, 0x0 }, + { 0x108080, 0x0 }, + { 0x208080, 0x0 }, + { 0x9080, 0x0 }, + { 0x109080, 0x0 }, + { 0x209080, 0x0 }, + { 0x10080, 0x0 }, + { 0x110080, 0x0 }, + { 0x210080, 0x0 }, + { 0x10180, 0x0 }, + { 0x110180, 0x0 }, + { 0x210180, 0x0 }, + { 0x11080, 0x0 }, + { 0x111080, 0x0 }, + { 0x211080, 0x0 }, + { 0x11180, 0x0 }, + { 0x111180, 0x0 }, + { 0x211180, 0x0 }, + { 0x12080, 0x0 }, + { 0x112080, 0x0 }, + { 0x212080, 0x0 }, + { 0x12180, 0x0 }, + { 0x112180, 0x0 }, + { 0x212180, 0x0 }, + { 0x13080, 0x0 }, + { 0x113080, 0x0 }, + { 0x213080, 0x0 }, + { 0x13180, 0x0 }, + { 0x113180, 0x0 }, + { 0x213180, 0x0 }, + { 0x10081, 0x0 }, + { 0x110081, 0x0 }, + { 0x210081, 0x0 }, + { 0x10181, 0x0 }, + { 0x110181, 0x0 }, + { 0x210181, 0x0 }, + { 0x11081, 0x0 }, + { 0x111081, 0x0 }, + { 0x211081, 0x0 }, + { 0x11181, 0x0 }, + { 0x111181, 0x0 }, + { 0x211181, 0x0 }, + { 0x12081, 0x0 }, + { 0x112081, 0x0 }, + { 0x212081, 0x0 }, + { 0x12181, 0x0 }, + { 0x112181, 0x0 }, + { 0x212181, 0x0 }, + { 0x13081, 0x0 }, + { 0x113081, 0x0 }, + { 0x213081, 0x0 }, + { 0x13181, 0x0 }, + { 0x113181, 0x0 }, + { 0x213181, 0x0 }, + { 0x100d0, 0x0 }, + { 0x1100d0, 0x0 }, + { 0x2100d0, 0x0 }, + { 0x101d0, 0x0 }, + { 0x1101d0, 0x0 }, + { 0x2101d0, 0x0 }, + { 0x110d0, 0x0 }, + { 0x1110d0, 0x0 }, + { 0x2110d0, 0x0 }, + { 0x111d0, 0x0 }, + { 0x1111d0, 0x0 }, + { 0x2111d0, 0x0 }, + { 0x120d0, 0x0 }, + { 0x1120d0, 0x0 }, + { 0x2120d0, 0x0 }, + { 0x121d0, 0x0 }, + { 0x1121d0, 0x0 }, + { 0x2121d0, 0x0 }, + { 0x130d0, 0x0 }, + { 0x1130d0, 0x0 }, + { 0x2130d0, 0x0 }, + { 0x131d0, 0x0 }, + { 0x1131d0, 0x0 }, + { 0x2131d0, 0x0 }, + { 0x100d1, 0x0 }, + { 0x1100d1, 0x0 }, + { 0x2100d1, 0x0 }, + { 0x101d1, 0x0 }, + { 0x1101d1, 0x0 }, + { 0x2101d1, 0x0 }, + { 0x110d1, 0x0 }, + { 0x1110d1, 0x0 }, + { 0x2110d1, 0x0 }, + { 0x111d1, 0x0 }, + { 0x1111d1, 0x0 }, + { 0x2111d1, 0x0 }, + { 0x120d1, 0x0 }, + { 0x1120d1, 0x0 }, + { 0x2120d1, 0x0 }, + { 0x121d1, 0x0 }, + { 0x1121d1, 0x0 }, + { 0x2121d1, 0x0 }, + { 0x130d1, 0x0 }, + { 0x1130d1, 0x0 }, + { 0x2130d1, 0x0 }, + { 0x131d1, 0x0 }, + { 0x1131d1, 0x0 }, + { 0x2131d1, 0x0 }, + { 0x10068, 0x0 }, + { 0x10168, 0x0 }, + { 0x10268, 0x0 }, + { 0x10368, 0x0 }, + { 0x10468, 0x0 }, + { 0x10568, 0x0 }, + { 0x10668, 0x0 }, + { 0x10768, 0x0 }, + { 0x10868, 0x0 }, + { 0x11068, 0x0 }, + { 0x11168, 0x0 }, + { 0x11268, 0x0 }, + { 0x11368, 0x0 }, + { 0x11468, 0x0 }, + { 0x11568, 0x0 }, + { 0x11668, 0x0 }, + { 0x11768, 0x0 }, + { 0x11868, 0x0 }, + { 0x12068, 0x0 }, + { 0x12168, 0x0 }, + { 0x12268, 0x0 }, + { 0x12368, 0x0 }, + { 0x12468, 0x0 }, + { 0x12568, 0x0 }, + { 0x12668, 0x0 }, + { 0x12768, 0x0 }, + { 0x12868, 0x0 }, + { 0x13068, 0x0 }, + { 0x13168, 0x0 }, + { 0x13268, 0x0 }, + { 0x13368, 0x0 }, + { 0x13468, 0x0 }, + { 0x13568, 0x0 }, + { 0x13668, 0x0 }, + { 0x13768, 0x0 }, + { 0x13868, 0x0 }, + { 0x10069, 0x0 }, + { 0x10169, 0x0 }, + { 0x10269, 0x0 }, + { 0x10369, 0x0 }, + { 0x10469, 0x0 }, + { 0x10569, 0x0 }, + { 0x10669, 0x0 }, + { 0x10769, 0x0 }, + { 0x10869, 0x0 }, + { 0x11069, 0x0 }, + { 0x11169, 0x0 }, + { 0x11269, 0x0 }, + { 0x11369, 0x0 }, + { 0x11469, 0x0 }, + { 0x11569, 0x0 }, + { 0x11669, 0x0 }, + { 0x11769, 0x0 }, + { 0x11869, 0x0 }, + { 0x12069, 0x0 }, + { 0x12169, 0x0 }, + { 0x12269, 0x0 }, + { 0x12369, 0x0 }, + { 0x12469, 0x0 }, + { 0x12569, 0x0 }, + { 0x12669, 0x0 }, + { 0x12769, 0x0 }, + { 0x12869, 0x0 }, + { 0x13069, 0x0 }, + { 0x13169, 0x0 }, + { 0x13269, 0x0 }, + { 0x13369, 0x0 }, + { 0x13469, 0x0 }, + { 0x13569, 0x0 }, + { 0x13669, 0x0 }, + { 0x13769, 0x0 }, + { 0x13869, 0x0 }, + { 0x1008c, 0x0 }, + { 0x11008c, 0x0 }, + { 0x21008c, 0x0 }, + { 0x1018c, 0x0 }, + { 0x11018c, 0x0 }, + { 0x21018c, 0x0 }, + { 0x1108c, 0x0 }, + { 0x11108c, 0x0 }, + { 0x21108c, 0x0 }, + { 0x1118c, 0x0 }, + { 0x11118c, 0x0 }, + { 0x21118c, 0x0 }, + { 0x1208c, 0x0 }, + { 0x11208c, 0x0 }, + { 0x21208c, 0x0 }, + { 0x1218c, 0x0 }, + { 0x11218c, 0x0 }, + { 0x21218c, 0x0 }, + { 0x1308c, 0x0 }, + { 0x11308c, 0x0 }, + { 0x21308c, 0x0 }, + { 0x1318c, 0x0 }, + { 0x11318c, 0x0 }, + { 0x21318c, 0x0 }, + { 0x1008d, 0x0 }, + { 0x11008d, 0x0 }, + { 0x21008d, 0x0 }, + { 0x1018d, 0x0 }, + { 0x11018d, 0x0 }, + { 0x21018d, 0x0 }, + { 0x1108d, 0x0 }, + { 0x11108d, 0x0 }, + { 0x21108d, 0x0 }, + { 0x1118d, 0x0 }, + { 0x11118d, 0x0 }, + { 0x21118d, 0x0 }, + { 0x1208d, 0x0 }, + { 0x11208d, 0x0 }, + { 0x21208d, 0x0 }, + { 0x1218d, 0x0 }, + { 0x11218d, 0x0 }, + { 0x21218d, 0x0 }, + { 0x1308d, 0x0 }, + { 0x11308d, 0x0 }, + { 0x21308d, 0x0 }, + { 0x1318d, 0x0 }, + { 0x11318d, 0x0 }, + { 0x21318d, 0x0 }, + { 0x100c0, 0x0 }, + { 0x1100c0, 0x0 }, + { 0x2100c0, 0x0 }, + { 0x101c0, 0x0 }, + { 0x1101c0, 0x0 }, + { 0x2101c0, 0x0 }, + { 0x102c0, 0x0 }, + { 0x1102c0, 0x0 }, + { 0x2102c0, 0x0 }, + { 0x103c0, 0x0 }, + { 0x1103c0, 0x0 }, + { 0x2103c0, 0x0 }, + { 0x104c0, 0x0 }, + { 0x1104c0, 0x0 }, + { 0x2104c0, 0x0 }, + { 0x105c0, 0x0 }, + { 0x1105c0, 0x0 }, + { 0x2105c0, 0x0 }, + { 0x106c0, 0x0 }, + { 0x1106c0, 0x0 }, + { 0x2106c0, 0x0 }, + { 0x107c0, 0x0 }, + { 0x1107c0, 0x0 }, + { 0x2107c0, 0x0 }, + { 0x108c0, 0x0 }, + { 0x1108c0, 0x0 }, + { 0x2108c0, 0x0 }, + { 0x110c0, 0x0 }, + { 0x1110c0, 0x0 }, + { 0x2110c0, 0x0 }, + { 0x111c0, 0x0 }, + { 0x1111c0, 0x0 }, + { 0x2111c0, 0x0 }, + { 0x112c0, 0x0 }, + { 0x1112c0, 0x0 }, + { 0x2112c0, 0x0 }, + { 0x113c0, 0x0 }, + { 0x1113c0, 0x0 }, + { 0x2113c0, 0x0 }, + { 0x114c0, 0x0 }, + { 0x1114c0, 0x0 }, + { 0x2114c0, 0x0 }, + { 0x115c0, 0x0 }, + { 0x1115c0, 0x0 }, + { 0x2115c0, 0x0 }, + { 0x116c0, 0x0 }, + { 0x1116c0, 0x0 }, + { 0x2116c0, 0x0 }, + { 0x117c0, 0x0 }, + { 0x1117c0, 0x0 }, + { 0x2117c0, 0x0 }, + { 0x118c0, 0x0 }, + { 0x1118c0, 0x0 }, + { 0x2118c0, 0x0 }, + { 0x120c0, 0x0 }, + { 0x1120c0, 0x0 }, + { 0x2120c0, 0x0 }, + { 0x121c0, 0x0 }, + { 0x1121c0, 0x0 }, + { 0x2121c0, 0x0 }, + { 0x122c0, 0x0 }, + { 0x1122c0, 0x0 }, + { 0x2122c0, 0x0 }, + { 0x123c0, 0x0 }, + { 0x1123c0, 0x0 }, + { 0x2123c0, 0x0 }, + { 0x124c0, 0x0 }, + { 0x1124c0, 0x0 }, + { 0x2124c0, 0x0 }, + { 0x125c0, 0x0 }, + { 0x1125c0, 0x0 }, + { 0x2125c0, 0x0 }, + { 0x126c0, 0x0 }, + { 0x1126c0, 0x0 }, + { 0x2126c0, 0x0 }, + { 0x127c0, 0x0 }, + { 0x1127c0, 0x0 }, + { 0x2127c0, 0x0 }, + { 0x128c0, 0x0 }, + { 0x1128c0, 0x0 }, + { 0x2128c0, 0x0 }, + { 0x130c0, 0x0 }, + { 0x1130c0, 0x0 }, + { 0x2130c0, 0x0 }, + { 0x131c0, 0x0 }, + { 0x1131c0, 0x0 }, + { 0x2131c0, 0x0 }, + { 0x132c0, 0x0 }, + { 0x1132c0, 0x0 }, + { 0x2132c0, 0x0 }, + { 0x133c0, 0x0 }, + { 0x1133c0, 0x0 }, + { 0x2133c0, 0x0 }, + { 0x134c0, 0x0 }, + { 0x1134c0, 0x0 }, + { 0x2134c0, 0x0 }, + { 0x135c0, 0x0 }, + { 0x1135c0, 0x0 }, + { 0x2135c0, 0x0 }, + { 0x136c0, 0x0 }, + { 0x1136c0, 0x0 }, + { 0x2136c0, 0x0 }, + { 0x137c0, 0x0 }, + { 0x1137c0, 0x0 }, + { 0x2137c0, 0x0 }, + { 0x138c0, 0x0 }, + { 0x1138c0, 0x0 }, + { 0x2138c0, 0x0 }, + { 0x100c1, 0x0 }, + { 0x1100c1, 0x0 }, + { 0x2100c1, 0x0 }, + { 0x101c1, 0x0 }, + { 0x1101c1, 0x0 }, + { 0x2101c1, 0x0 }, + { 0x102c1, 0x0 }, + { 0x1102c1, 0x0 }, + { 0x2102c1, 0x0 }, + { 0x103c1, 0x0 }, + { 0x1103c1, 0x0 }, + { 0x2103c1, 0x0 }, + { 0x104c1, 0x0 }, + { 0x1104c1, 0x0 }, + { 0x2104c1, 0x0 }, + { 0x105c1, 0x0 }, + { 0x1105c1, 0x0 }, + { 0x2105c1, 0x0 }, + { 0x106c1, 0x0 }, + { 0x1106c1, 0x0 }, + { 0x2106c1, 0x0 }, + { 0x107c1, 0x0 }, + { 0x1107c1, 0x0 }, + { 0x2107c1, 0x0 }, + { 0x108c1, 0x0 }, + { 0x1108c1, 0x0 }, + { 0x2108c1, 0x0 }, + { 0x110c1, 0x0 }, + { 0x1110c1, 0x0 }, + { 0x2110c1, 0x0 }, + { 0x111c1, 0x0 }, + { 0x1111c1, 0x0 }, + { 0x2111c1, 0x0 }, + { 0x112c1, 0x0 }, + { 0x1112c1, 0x0 }, + { 0x2112c1, 0x0 }, + { 0x113c1, 0x0 }, + { 0x1113c1, 0x0 }, + { 0x2113c1, 0x0 }, + { 0x114c1, 0x0 }, + { 0x1114c1, 0x0 }, + { 0x2114c1, 0x0 }, + { 0x115c1, 0x0 }, + { 0x1115c1, 0x0 }, + { 0x2115c1, 0x0 }, + { 0x116c1, 0x0 }, + { 0x1116c1, 0x0 }, + { 0x2116c1, 0x0 }, + { 0x117c1, 0x0 }, + { 0x1117c1, 0x0 }, + { 0x2117c1, 0x0 }, + { 0x118c1, 0x0 }, + { 0x1118c1, 0x0 }, + { 0x2118c1, 0x0 }, + { 0x120c1, 0x0 }, + { 0x1120c1, 0x0 }, + { 0x2120c1, 0x0 }, + { 0x121c1, 0x0 }, + { 0x1121c1, 0x0 }, + { 0x2121c1, 0x0 }, + { 0x122c1, 0x0 }, + { 0x1122c1, 0x0 }, + { 0x2122c1, 0x0 }, + { 0x123c1, 0x0 }, + { 0x1123c1, 0x0 }, + { 0x2123c1, 0x0 }, + { 0x124c1, 0x0 }, + { 0x1124c1, 0x0 }, + { 0x2124c1, 0x0 }, + { 0x125c1, 0x0 }, + { 0x1125c1, 0x0 }, + { 0x2125c1, 0x0 }, + { 0x126c1, 0x0 }, + { 0x1126c1, 0x0 }, + { 0x2126c1, 0x0 }, + { 0x127c1, 0x0 }, + { 0x1127c1, 0x0 }, + { 0x2127c1, 0x0 }, + { 0x128c1, 0x0 }, + { 0x1128c1, 0x0 }, + { 0x2128c1, 0x0 }, + { 0x130c1, 0x0 }, + { 0x1130c1, 0x0 }, + { 0x2130c1, 0x0 }, + { 0x131c1, 0x0 }, + { 0x1131c1, 0x0 }, + { 0x2131c1, 0x0 }, + { 0x132c1, 0x0 }, + { 0x1132c1, 0x0 }, + { 0x2132c1, 0x0 }, + { 0x133c1, 0x0 }, + { 0x1133c1, 0x0 }, + { 0x2133c1, 0x0 }, + { 0x134c1, 0x0 }, + { 0x1134c1, 0x0 }, + { 0x2134c1, 0x0 }, + { 0x135c1, 0x0 }, + { 0x1135c1, 0x0 }, + { 0x2135c1, 0x0 }, + { 0x136c1, 0x0 }, + { 0x1136c1, 0x0 }, + { 0x2136c1, 0x0 }, + { 0x137c1, 0x0 }, + { 0x1137c1, 0x0 }, + { 0x2137c1, 0x0 }, + { 0x138c1, 0x0 }, + { 0x1138c1, 0x0 }, + { 0x2138c1, 0x0 }, + { 0x10020, 0x0 }, + { 0x110020, 0x0 }, + { 0x210020, 0x0 }, + { 0x11020, 0x0 }, + { 0x111020, 0x0 }, + { 0x211020, 0x0 }, + { 0x12020, 0x0 }, + { 0x112020, 0x0 }, + { 0x212020, 0x0 }, + { 0x13020, 0x0 }, + { 0x113020, 0x0 }, + { 0x213020, 0x0 }, + { 0x20072, 0x0 }, + { 0x20073, 0x0 }, + { 0x20074, 0x0 }, + { 0x100aa, 0x0 }, + { 0x110aa, 0x0 }, + { 0x120aa, 0x0 }, + { 0x130aa, 0x0 }, + { 0x20010, 0x0 }, + { 0x120010, 0x0 }, + { 0x220010, 0x0 }, + { 0x20011, 0x0 }, + { 0x120011, 0x0 }, + { 0x220011, 0x0 }, + { 0x100ae, 0x0 }, + { 0x1100ae, 0x0 }, + { 0x2100ae, 0x0 }, + { 0x100af, 0x0 }, + { 0x1100af, 0x0 }, + { 0x2100af, 0x0 }, + { 0x110ae, 0x0 }, + { 0x1110ae, 0x0 }, + { 0x2110ae, 0x0 }, + { 0x110af, 0x0 }, + { 0x1110af, 0x0 }, + { 0x2110af, 0x0 }, + { 0x120ae, 0x0 }, + { 0x1120ae, 0x0 }, + { 0x2120ae, 0x0 }, + { 0x120af, 0x0 }, + { 0x1120af, 0x0 }, + { 0x2120af, 0x0 }, + { 0x130ae, 0x0 }, + { 0x1130ae, 0x0 }, + { 0x2130ae, 0x0 }, + { 0x130af, 0x0 }, + { 0x1130af, 0x0 }, + { 0x2130af, 0x0 }, + { 0x20020, 0x0 }, + { 0x120020, 0x0 }, + { 0x220020, 0x0 }, + { 0x100a0, 0x0 }, + { 0x100a1, 0x0 }, + { 0x100a2, 0x0 }, + { 0x100a3, 0x0 }, + { 0x100a4, 0x0 }, + { 0x100a5, 0x0 }, + { 0x100a6, 0x0 }, + { 0x100a7, 0x0 }, + { 0x110a0, 0x0 }, + { 0x110a1, 0x0 }, + { 0x110a2, 0x0 }, + { 0x110a3, 0x0 }, + { 0x110a4, 0x0 }, + { 0x110a5, 0x0 }, + { 0x110a6, 0x0 }, + { 0x110a7, 0x0 }, + { 0x120a0, 0x0 }, + { 0x120a1, 0x0 }, + { 0x120a2, 0x0 }, + { 0x120a3, 0x0 }, + { 0x120a4, 0x0 }, + { 0x120a5, 0x0 }, + { 0x120a6, 0x0 }, + { 0x120a7, 0x0 }, + { 0x130a0, 0x0 }, + { 0x130a1, 0x0 }, + { 0x130a2, 0x0 }, + { 0x130a3, 0x0 }, + { 0x130a4, 0x0 }, + { 0x130a5, 0x0 }, + { 0x130a6, 0x0 }, + { 0x130a7, 0x0 }, + { 0x2007c, 0x0 }, + { 0x12007c, 0x0 }, + { 0x22007c, 0x0 }, + { 0x2007d, 0x0 }, + { 0x12007d, 0x0 }, + { 0x22007d, 0x0 }, + { 0x400fd, 0x0 }, + { 0x400c0, 0x0 }, + { 0x90201, 0x0 }, + { 0x190201, 0x0 }, + { 0x290201, 0x0 }, + { 0x90202, 0x0 }, + { 0x190202, 0x0 }, + { 0x290202, 0x0 }, + { 0x90203, 0x0 }, + { 0x190203, 0x0 }, + { 0x290203, 0x0 }, + { 0x90204, 0x0 }, + { 0x190204, 0x0 }, + { 0x290204, 0x0 }, + { 0x90205, 0x0 }, + { 0x190205, 0x0 }, + { 0x290205, 0x0 }, + { 0x90206, 0x0 }, + { 0x190206, 0x0 }, + { 0x290206, 0x0 }, + { 0x90207, 0x0 }, + { 0x190207, 0x0 }, + { 0x290207, 0x0 }, + { 0x90208, 0x0 }, + { 0x190208, 0x0 }, + { 0x290208, 0x0 }, + { 0x10062, 0x0 }, + { 0x10162, 0x0 }, + { 0x10262, 0x0 }, + { 0x10362, 0x0 }, + { 0x10462, 0x0 }, + { 0x10562, 0x0 }, + { 0x10662, 0x0 }, + { 0x10762, 0x0 }, + { 0x10862, 0x0 }, + { 0x11062, 0x0 }, + { 0x11162, 0x0 }, + { 0x11262, 0x0 }, + { 0x11362, 0x0 }, + { 0x11462, 0x0 }, + { 0x11562, 0x0 }, + { 0x11662, 0x0 }, + { 0x11762, 0x0 }, + { 0x11862, 0x0 }, + { 0x12062, 0x0 }, + { 0x12162, 0x0 }, + { 0x12262, 0x0 }, + { 0x12362, 0x0 }, + { 0x12462, 0x0 }, + { 0x12562, 0x0 }, + { 0x12662, 0x0 }, + { 0x12762, 0x0 }, + { 0x12862, 0x0 }, + { 0x13062, 0x0 }, + { 0x13162, 0x0 }, + { 0x13262, 0x0 }, + { 0x13362, 0x0 }, + { 0x13462, 0x0 }, + { 0x13562, 0x0 }, + { 0x13662, 0x0 }, + { 0x13762, 0x0 }, + { 0x13862, 0x0 }, + { 0x20077, 0x0 }, + { 0x10001, 0x0 }, + { 0x11001, 0x0 }, + { 0x12001, 0x0 }, + { 0x13001, 0x0 }, + { 0x10040, 0x0 }, + { 0x10140, 0x0 }, + { 0x10240, 0x0 }, + { 0x10340, 0x0 }, + { 0x10440, 0x0 }, + { 0x10540, 0x0 }, + { 0x10640, 0x0 }, + { 0x10740, 0x0 }, + { 0x10840, 0x0 }, + { 0x10030, 0x0 }, + { 0x10130, 0x0 }, + { 0x10230, 0x0 }, + { 0x10330, 0x0 }, + { 0x10430, 0x0 }, + { 0x10530, 0x0 }, + { 0x10630, 0x0 }, + { 0x10730, 0x0 }, + { 0x10830, 0x0 }, + { 0x11040, 0x0 }, + { 0x11140, 0x0 }, + { 0x11240, 0x0 }, + { 0x11340, 0x0 }, + { 0x11440, 0x0 }, + { 0x11540, 0x0 }, + { 0x11640, 0x0 }, + { 0x11740, 0x0 }, + { 0x11840, 0x0 }, + { 0x11030, 0x0 }, + { 0x11130, 0x0 }, + { 0x11230, 0x0 }, + { 0x11330, 0x0 }, + { 0x11430, 0x0 }, + { 0x11530, 0x0 }, + { 0x11630, 0x0 }, + { 0x11730, 0x0 }, + { 0x11830, 0x0 }, + { 0x12040, 0x0 }, + { 0x12140, 0x0 }, + { 0x12240, 0x0 }, + { 0x12340, 0x0 }, + { 0x12440, 0x0 }, + { 0x12540, 0x0 }, + { 0x12640, 0x0 }, + { 0x12740, 0x0 }, + { 0x12840, 0x0 }, + { 0x12030, 0x0 }, + { 0x12130, 0x0 }, + { 0x12230, 0x0 }, + { 0x12330, 0x0 }, + { 0x12430, 0x0 }, + { 0x12530, 0x0 }, + { 0x12630, 0x0 }, + { 0x12730, 0x0 }, + { 0x12830, 0x0 }, + { 0x13040, 0x0 }, + { 0x13140, 0x0 }, + { 0x13240, 0x0 }, + { 0x13340, 0x0 }, + { 0x13440, 0x0 }, + { 0x13540, 0x0 }, + { 0x13640, 0x0 }, + { 0x13740, 0x0 }, + { 0x13840, 0x0 }, + { 0x13030, 0x0 }, + { 0x13130, 0x0 }, + { 0x13230, 0x0 }, + { 0x13330, 0x0 }, + { 0x13430, 0x0 }, + { 0x13530, 0x0 }, + { 0x13630, 0x0 }, + { 0x13730, 0x0 }, + { 0x13830, 0x0 }, +}; + +/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x131f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x101 }, + { 0x54003, 0x190 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54002, 0x102 }, + { 0x54003, 0x64 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x121f }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x54012, 0x310 }, + { 0x54019, 0x84 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x84 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0x8400 }, + { 0x54033, 0x3100 }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0x8400 }, + { 0x54039, 0x3100 }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = { + { 0xd0000, 0x0 }, + { 0x54003, 0xc80 }, + { 0x54004, 0x2 }, + { 0x54005, 0x2228 }, + { 0x54006, 0x11 }, + { 0x54008, 0x61 }, + { 0x54009, 0xc8 }, + { 0x5400b, 0x2 }, + { 0x5400d, 0x100 }, + { 0x5400f, 0x100 }, + { 0x54010, 0x1f7f }, + { 0x54012, 0x310 }, + { 0x54019, 0x2dd4 }, + { 0x5401a, 0x31 }, + { 0x5401b, 0x4a66 }, + { 0x5401c, 0x4a08 }, + { 0x5401e, 0x16 }, + { 0x5401f, 0x2dd4 }, + { 0x54020, 0x31 }, + { 0x54021, 0x4a66 }, + { 0x54022, 0x4a08 }, + { 0x54024, 0x16 }, + { 0x5402b, 0x1000 }, + { 0x5402c, 0x3 }, + { 0x54032, 0xd400 }, + { 0x54033, 0x312d }, + { 0x54034, 0x6600 }, + { 0x54035, 0x84a }, + { 0x54036, 0x4a }, + { 0x54037, 0x1600 }, + { 0x54038, 0xd400 }, + { 0x54039, 0x312d }, + { 0x5403a, 0x6600 }, + { 0x5403b, 0x84a }, + { 0x5403c, 0x4a }, + { 0x5403d, 0x1600 }, + { 0xd0000, 0x1 }, +}; + +/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = { + { 0xd0000, 0x0 }, + { 0x90000, 0x10 }, + { 0x90001, 0x400 }, + { 0x90002, 0x10e }, + { 0x90003, 0x0 }, + { 0x90004, 0x0 }, + { 0x90005, 0x8 }, + { 0x90029, 0xb }, + { 0x9002a, 0x480 }, + { 0x9002b, 0x109 }, + { 0x9002c, 0x8 }, + { 0x9002d, 0x448 }, + { 0x9002e, 0x139 }, + { 0x9002f, 0x8 }, + { 0x90030, 0x478 }, + { 0x90031, 0x109 }, + { 0x90032, 0x0 }, + { 0x90033, 0xe8 }, + { 0x90034, 0x109 }, + { 0x90035, 0x2 }, + { 0x90036, 0x10 }, + { 0x90037, 0x139 }, + { 0x90038, 0xf }, + { 0x90039, 0x7c0 }, + { 0x9003a, 0x139 }, + { 0x9003b, 0x44 }, + { 0x9003c, 0x630 }, + { 0x9003d, 0x159 }, + { 0x9003e, 0x14f }, + { 0x9003f, 0x630 }, + { 0x90040, 0x159 }, + { 0x90041, 0x47 }, + { 0x90042, 0x630 }, + { 0x90043, 0x149 }, + { 0x90044, 0x4f }, + { 0x90045, 0x630 }, + { 0x90046, 0x179 }, + { 0x90047, 0x8 }, + { 0x90048, 0xe0 }, + { 0x90049, 0x109 }, + { 0x9004a, 0x0 }, + { 0x9004b, 0x7c8 }, + { 0x9004c, 0x109 }, + { 0x9004d, 0x0 }, + { 0x9004e, 0x1 }, + { 0x9004f, 0x8 }, + { 0x90050, 0x0 }, + { 0x90051, 0x45a }, + { 0x90052, 0x9 }, + { 0x90053, 0x0 }, + { 0x90054, 0x448 }, + { 0x90055, 0x109 }, + { 0x90056, 0x40 }, + { 0x90057, 0x630 }, + { 0x90058, 0x179 }, + { 0x90059, 0x1 }, + { 0x9005a, 0x618 }, + { 0x9005b, 0x109 }, + { 0x9005c, 0x40c0 }, + { 0x9005d, 0x630 }, + { 0x9005e, 0x149 }, + { 0x9005f, 0x8 }, + { 0x90060, 0x4 }, + { 0x90061, 0x48 }, + { 0x90062, 0x4040 }, + { 0x90063, 0x630 }, + { 0x90064, 0x149 }, + { 0x90065, 0x0 }, + { 0x90066, 0x4 }, + { 0x90067, 0x48 }, + { 0x90068, 0x40 }, + { 0x90069, 0x630 }, + { 0x9006a, 0x149 }, + { 0x9006b, 0x10 }, + { 0x9006c, 0x4 }, + { 0x9006d, 0x18 }, + { 0x9006e, 0x0 }, + { 0x9006f, 0x4 }, + { 0x90070, 0x78 }, + { 0x90071, 0x549 }, + { 0x90072, 0x630 }, + { 0x90073, 0x159 }, + { 0x90074, 0xd49 }, + { 0x90075, 0x630 }, + { 0x90076, 0x159 }, + { 0x90077, 0x94a }, + { 0x90078, 0x630 }, + { 0x90079, 0x159 }, + { 0x9007a, 0x441 }, + { 0x9007b, 0x630 }, + { 0x9007c, 0x149 }, + { 0x9007d, 0x42 }, + { 0x9007e, 0x630 }, + { 0x9007f, 0x149 }, + { 0x90080, 0x1 }, + { 0x90081, 0x630 }, + { 0x90082, 0x149 }, + { 0x90083, 0x0 }, + { 0x90084, 0xe0 }, + { 0x90085, 0x109 }, + { 0x90086, 0xa }, + { 0x90087, 0x10 }, + { 0x90088, 0x109 }, + { 0x90089, 0x9 }, + { 0x9008a, 0x3c0 }, + { 0x9008b, 0x149 }, + { 0x9008c, 0x9 }, + { 0x9008d, 0x3c0 }, + { 0x9008e, 0x159 }, + { 0x9008f, 0x18 }, + { 0x90090, 0x10 }, + { 0x90091, 0x109 }, + { 0x90092, 0x0 }, + { 0x90093, 0x3c0 }, + { 0x90094, 0x109 }, + { 0x90095, 0x18 }, + { 0x90096, 0x4 }, + { 0x90097, 0x48 }, + { 0x90098, 0x18 }, + { 0x90099, 0x4 }, + { 0x9009a, 0x58 }, + { 0x9009b, 0xa }, + { 0x9009c, 0x10 }, + { 0x9009d, 0x109 }, + { 0x9009e, 0x2 }, + { 0x9009f, 0x10 }, + { 0x900a0, 0x109 }, + { 0x900a1, 0x5 }, + { 0x900a2, 0x7c0 }, + { 0x900a3, 0x109 }, + { 0x900a4, 0x10 }, + { 0x900a5, 0x10 }, + { 0x900a6, 0x109 }, + { 0x40000, 0x811 }, + { 0x40020, 0x880 }, + { 0x40040, 0x0 }, + { 0x40060, 0x0 }, + { 0x40001, 0x4008 }, + { 0x40021, 0x83 }, + { 0x40041, 0x4f }, + { 0x40061, 0x0 }, + { 0x40002, 0x4040 }, + { 0x40022, 0x83 }, + { 0x40042, 0x51 }, + { 0x40062, 0x0 }, + { 0x40003, 0x811 }, + { 0x40023, 0x880 }, + { 0x40043, 0x0 }, + { 0x40063, 0x0 }, + { 0x40004, 0x720 }, + { 0x40024, 0xf }, + { 0x40044, 0x1740 }, + { 0x40064, 0x0 }, + { 0x40005, 0x16 }, + { 0x40025, 0x83 }, + { 0x40045, 0x4b }, + { 0x40065, 0x0 }, + { 0x40006, 0x716 }, + { 0x40026, 0xf }, + { 0x40046, 0x2001 }, + { 0x40066, 0x0 }, + { 0x40007, 0x716 }, + { 0x40027, 0xf }, + { 0x40047, 0x2800 }, + { 0x40067, 0x0 }, + { 0x40008, 0x716 }, + { 0x40028, 0xf }, + { 0x40048, 0xf00 }, + { 0x40068, 0x0 }, + { 0x40009, 0x720 }, + { 0x40029, 0xf }, + { 0x40049, 0x1400 }, + { 0x40069, 0x0 }, + { 0x4000a, 0xe08 }, + { 0x4002a, 0xc15 }, + { 0x4004a, 0x0 }, + { 0x4006a, 0x0 }, + { 0x4000b, 0x623 }, + { 0x4002b, 0x15 }, + { 0x4004b, 0x0 }, + { 0x4006b, 0x0 }, + { 0x4000c, 0x4028 }, + { 0x4002c, 0x80 }, + { 0x4004c, 0x0 }, + { 0x4006c, 0x0 }, + { 0x4000d, 0xe08 }, + { 0x4002d, 0xc1a }, + { 0x4004d, 0x0 }, + { 0x4006d, 0x0 }, + { 0x4000e, 0x623 }, + { 0x4002e, 0x1a }, + { 0x4004e, 0x0 }, + { 0x4006e, 0x0 }, + { 0x4000f, 0x4040 }, + { 0x4002f, 0x80 }, + { 0x4004f, 0x0 }, + { 0x4006f, 0x0 }, + { 0x40010, 0x2604 }, + { 0x40030, 0x15 }, + { 0x40050, 0x0 }, + { 0x40070, 0x0 }, + { 0x40011, 0x708 }, + { 0x40031, 0x5 }, + { 0x40051, 0x0 }, + { 0x40071, 0x2002 }, + { 0x40012, 0x8 }, + { 0x40032, 0x80 }, + { 0x40052, 0x0 }, + { 0x40072, 0x0 }, + { 0x40013, 0x2604 }, + { 0x40033, 0x1a }, + { 0x40053, 0x0 }, + { 0x40073, 0x0 }, + { 0x40014, 0x708 }, + { 0x40034, 0xa }, + { 0x40054, 0x0 }, + { 0x40074, 0x2002 }, + { 0x40015, 0x4040 }, + { 0x40035, 0x80 }, + { 0x40055, 0x0 }, + { 0x40075, 0x0 }, + { 0x40016, 0x60a }, + { 0x40036, 0x15 }, + { 0x40056, 0x1200 }, + { 0x40076, 0x0 }, + { 0x40017, 0x61a }, + { 0x40037, 0x15 }, + { 0x40057, 0x1300 }, + { 0x40077, 0x0 }, + { 0x40018, 0x60a }, + { 0x40038, 0x1a }, + { 0x40058, 0x1200 }, + { 0x40078, 0x0 }, + { 0x40019, 0x642 }, + { 0x40039, 0x1a }, + { 0x40059, 0x1300 }, + { 0x40079, 0x0 }, + { 0x4001a, 0x4808 }, + { 0x4003a, 0x880 }, + { 0x4005a, 0x0 }, + { 0x4007a, 0x0 }, + { 0x900a7, 0x0 }, + { 0x900a8, 0x790 }, + { 0x900a9, 0x11a }, + { 0x900aa, 0x8 }, + { 0x900ab, 0x7aa }, + { 0x900ac, 0x2a }, + { 0x900ad, 0x10 }, + { 0x900ae, 0x7b2 }, + { 0x900af, 0x2a }, + { 0x900b0, 0x0 }, + { 0x900b1, 0x7c8 }, + { 0x900b2, 0x109 }, + { 0x900b3, 0x10 }, + { 0x900b4, 0x2a8 }, + { 0x900b5, 0x129 }, + { 0x900b6, 0x8 }, + { 0x900b7, 0x370 }, + { 0x900b8, 0x129 }, + { 0x900b9, 0xa }, + { 0x900ba, 0x3c8 }, + { 0x900bb, 0x1a9 }, + { 0x900bc, 0xc }, + { 0x900bd, 0x408 }, + { 0x900be, 0x199 }, + { 0x900bf, 0x14 }, + { 0x900c0, 0x790 }, + { 0x900c1, 0x11a }, + { 0x900c2, 0x8 }, + { 0x900c3, 0x4 }, + { 0x900c4, 0x18 }, + { 0x900c5, 0xe }, + { 0x900c6, 0x408 }, + { 0x900c7, 0x199 }, + { 0x900c8, 0x8 }, + { 0x900c9, 0x8568 }, + { 0x900ca, 0x108 }, + { 0x900cb, 0x18 }, + { 0x900cc, 0x790 }, + { 0x900cd, 0x16a }, + { 0x900ce, 0x8 }, + { 0x900cf, 0x1d8 }, + { 0x900d0, 0x169 }, + { 0x900d1, 0x10 }, + { 0x900d2, 0x8558 }, + { 0x900d3, 0x168 }, + { 0x900d4, 0x70 }, + { 0x900d5, 0x788 }, + { 0x900d6, 0x16a }, + { 0x900d7, 0x1ff8 }, + { 0x900d8, 0x85a8 }, + { 0x900d9, 0x1e8 }, + { 0x900da, 0x50 }, + { 0x900db, 0x798 }, + { 0x900dc, 0x16a }, + { 0x900dd, 0x60 }, + { 0x900de, 0x7a0 }, + { 0x900df, 0x16a }, + { 0x900e0, 0x8 }, + { 0x900e1, 0x8310 }, + { 0x900e2, 0x168 }, + { 0x900e3, 0x8 }, + { 0x900e4, 0xa310 }, + { 0x900e5, 0x168 }, + { 0x900e6, 0xa }, + { 0x900e7, 0x408 }, + { 0x900e8, 0x169 }, + { 0x900e9, 0x6e }, + { 0x900ea, 0x0 }, + { 0x900eb, 0x68 }, + { 0x900ec, 0x0 }, + { 0x900ed, 0x408 }, + { 0x900ee, 0x169 }, + { 0x900ef, 0x0 }, + { 0x900f0, 0x8310 }, + { 0x900f1, 0x168 }, + { 0x900f2, 0x0 }, + { 0x900f3, 0xa310 }, + { 0x900f4, 0x168 }, + { 0x900f5, 0x1ff8 }, + { 0x900f6, 0x85a8 }, + { 0x900f7, 0x1e8 }, + { 0x900f8, 0x68 }, + { 0x900f9, 0x798 }, + { 0x900fa, 0x16a }, + { 0x900fb, 0x78 }, + { 0x900fc, 0x7a0 }, + { 0x900fd, 0x16a }, + { 0x900fe, 0x68 }, + { 0x900ff, 0x790 }, + { 0x90100, 0x16a }, + { 0x90101, 0x8 }, + { 0x90102, 0x8b10 }, + { 0x90103, 0x168 }, + { 0x90104, 0x8 }, + { 0x90105, 0xab10 }, + { 0x90106, 0x168 }, + { 0x90107, 0xa }, + { 0x90108, 0x408 }, + { 0x90109, 0x169 }, + { 0x9010a, 0x58 }, + { 0x9010b, 0x0 }, + { 0x9010c, 0x68 }, + { 0x9010d, 0x0 }, + { 0x9010e, 0x408 }, + { 0x9010f, 0x169 }, + { 0x90110, 0x0 }, + { 0x90111, 0x8b10 }, + { 0x90112, 0x168 }, + { 0x90113, 0x0 }, + { 0x90114, 0xab10 }, + { 0x90115, 0x168 }, + { 0x90116, 0x0 }, + { 0x90117, 0x1d8 }, + { 0x90118, 0x169 }, + { 0x90119, 0x80 }, + { 0x9011a, 0x790 }, + { 0x9011b, 0x16a }, + { 0x9011c, 0x18 }, + { 0x9011d, 0x7aa }, + { 0x9011e, 0x6a }, + { 0x9011f, 0xa }, + { 0x90120, 0x0 }, + { 0x90121, 0x1e9 }, + { 0x90122, 0x8 }, + { 0x90123, 0x8080 }, + { 0x90124, 0x108 }, + { 0x90125, 0xf }, + { 0x90126, 0x408 }, + { 0x90127, 0x169 }, + { 0x90128, 0xc }, + { 0x90129, 0x0 }, + { 0x9012a, 0x68 }, + { 0x9012b, 0x9 }, + { 0x9012c, 0x0 }, + { 0x9012d, 0x1a9 }, + { 0x9012e, 0x0 }, + { 0x9012f, 0x408 }, + { 0x90130, 0x169 }, + { 0x90131, 0x0 }, + { 0x90132, 0x8080 }, + { 0x90133, 0x108 }, + { 0x90134, 0x8 }, + { 0x90135, 0x7aa }, + { 0x90136, 0x6a }, + { 0x90137, 0x0 }, + { 0x90138, 0x8568 }, + { 0x90139, 0x108 }, + { 0x9013a, 0xb7 }, + { 0x9013b, 0x790 }, + { 0x9013c, 0x16a }, + { 0x9013d, 0x1f }, + { 0x9013e, 0x0 }, + { 0x9013f, 0x68 }, + { 0x90140, 0x8 }, + { 0x90141, 0x8558 }, + { 0x90142, 0x168 }, + { 0x90143, 0xf }, + { 0x90144, 0x408 }, + { 0x90145, 0x169 }, + { 0x90146, 0xc }, + { 0x90147, 0x0 }, + { 0x90148, 0x68 }, + { 0x90149, 0x0 }, + { 0x9014a, 0x408 }, + { 0x9014b, 0x169 }, + { 0x9014c, 0x0 }, + { 0x9014d, 0x8558 }, + { 0x9014e, 0x168 }, + { 0x9014f, 0x8 }, + { 0x90150, 0x3c8 }, + { 0x90151, 0x1a9 }, + { 0x90152, 0x3 }, + { 0x90153, 0x370 }, + { 0x90154, 0x129 }, + { 0x90155, 0x20 }, + { 0x90156, 0x2aa }, + { 0x90157, 0x9 }, + { 0x90158, 0x0 }, + { 0x90159, 0x400 }, + { 0x9015a, 0x10e }, + { 0x9015b, 0x8 }, + { 0x9015c, 0xe8 }, + { 0x9015d, 0x109 }, + { 0x9015e, 0x0 }, + { 0x9015f, 0x8140 }, + { 0x90160, 0x10c }, + { 0x90161, 0x10 }, + { 0x90162, 0x8138 }, + { 0x90163, 0x10c }, + { 0x90164, 0x8 }, + { 0x90165, 0x7c8 }, + { 0x90166, 0x101 }, + { 0x90167, 0x8 }, + { 0x90168, 0x0 }, + { 0x90169, 0x8 }, + { 0x9016a, 0x8 }, + { 0x9016b, 0x448 }, + { 0x9016c, 0x109 }, + { 0x9016d, 0xf }, + { 0x9016e, 0x7c0 }, + { 0x9016f, 0x109 }, + { 0x90170, 0x0 }, + { 0x90171, 0xe8 }, + { 0x90172, 0x109 }, + { 0x90173, 0x47 }, + { 0x90174, 0x630 }, + { 0x90175, 0x109 }, + { 0x90176, 0x8 }, + { 0x90177, 0x618 }, + { 0x90178, 0x109 }, + { 0x90179, 0x8 }, + { 0x9017a, 0xe0 }, + { 0x9017b, 0x109 }, + { 0x9017c, 0x0 }, + { 0x9017d, 0x7c8 }, + { 0x9017e, 0x109 }, + { 0x9017f, 0x8 }, + { 0x90180, 0x8140 }, + { 0x90181, 0x10c }, + { 0x90182, 0x0 }, + { 0x90183, 0x1 }, + { 0x90184, 0x8 }, + { 0x90185, 0x8 }, + { 0x90186, 0x4 }, + { 0x90187, 0x8 }, + { 0x90188, 0x8 }, + { 0x90189, 0x7c8 }, + { 0x9018a, 0x101 }, + { 0x90006, 0x0 }, + { 0x90007, 0x0 }, + { 0x90008, 0x8 }, + { 0x90009, 0x0 }, + { 0x9000a, 0x0 }, + { 0x9000b, 0x0 }, + { 0xd00e7, 0x400 }, + { 0x90017, 0x0 }, + { 0x9001f, 0x2a }, + { 0x90026, 0x6a }, + { 0x400d0, 0x0 }, + { 0x400d1, 0x101 }, + { 0x400d2, 0x105 }, + { 0x400d3, 0x107 }, + { 0x400d4, 0x10f }, + { 0x400d5, 0x202 }, + { 0x400d6, 0x20a }, + { 0x400d7, 0x20b }, + { 0x2003a, 0x2 }, + { 0x2000b, 0x64 }, + { 0x2000c, 0xc8 }, + { 0x2000d, 0x7d0 }, + { 0x2000e, 0x2c }, + { 0x12000b, 0xc }, + { 0x12000c, 0x19 }, + { 0x12000d, 0xfa }, + { 0x12000e, 0x10 }, + { 0x22000b, 0x3 }, + { 0x22000c, 0x6 }, + { 0x22000d, 0x3e }, + { 0x22000e, 0x10 }, + { 0x9000c, 0x0 }, + { 0x9000d, 0x173 }, + { 0x9000e, 0x60 }, + { 0x9000f, 0x6110 }, + { 0x90010, 0x2152 }, + { 0x90011, 0xdfbd }, + { 0x90012, 0x60 }, + { 0x90013, 0x6152 }, + { 0x20010, 0x5a }, + { 0x20011, 0x3 }, + { 0x120010, 0x5a }, + { 0x120011, 0x3 }, + { 0x220010, 0x5a }, + { 0x220011, 0x3 }, + { 0x40080, 0xe0 }, + { 0x40081, 0x12 }, + { 0x40082, 0xe0 }, + { 0x40083, 0x12 }, + { 0x40084, 0xe0 }, + { 0x40085, 0x12 }, + { 0x140080, 0xe0 }, + { 0x140081, 0x12 }, + { 0x140082, 0xe0 }, + { 0x140083, 0x12 }, + { 0x140084, 0xe0 }, + { 0x140085, 0x12 }, + { 0x240080, 0xe0 }, + { 0x240081, 0x12 }, + { 0x240082, 0xe0 }, + { 0x240083, 0x12 }, + { 0x240084, 0xe0 }, + { 0x240085, 0x12 }, + { 0x400fd, 0xf }, + { 0x10011, 0x1 }, + { 0x10012, 0x1 }, + { 0x10013, 0x180 }, + { 0x10018, 0x1 }, + { 0x10002, 0x6209 }, + { 0x100b2, 0x1 }, + { 0x101b4, 0x1 }, + { 0x102b4, 0x1 }, + { 0x103b4, 0x1 }, + { 0x104b4, 0x1 }, + { 0x105b4, 0x1 }, + { 0x106b4, 0x1 }, + { 0x107b4, 0x1 }, + { 0x108b4, 0x1 }, + { 0x11011, 0x1 }, + { 0x11012, 0x1 }, + { 0x11013, 0x180 }, + { 0x11018, 0x1 }, + { 0x11002, 0x6209 }, + { 0x110b2, 0x1 }, + { 0x111b4, 0x1 }, + { 0x112b4, 0x1 }, + { 0x113b4, 0x1 }, + { 0x114b4, 0x1 }, + { 0x115b4, 0x1 }, + { 0x116b4, 0x1 }, + { 0x117b4, 0x1 }, + { 0x118b4, 0x1 }, + { 0x12011, 0x1 }, + { 0x12012, 0x1 }, + { 0x12013, 0x180 }, + { 0x12018, 0x1 }, + { 0x12002, 0x6209 }, + { 0x120b2, 0x1 }, + { 0x121b4, 0x1 }, + { 0x122b4, 0x1 }, + { 0x123b4, 0x1 }, + { 0x124b4, 0x1 }, + { 0x125b4, 0x1 }, + { 0x126b4, 0x1 }, + { 0x127b4, 0x1 }, + { 0x128b4, 0x1 }, + { 0x13011, 0x1 }, + { 0x13012, 0x1 }, + { 0x13013, 0x180 }, + { 0x13018, 0x1 }, + { 0x13002, 0x6209 }, + { 0x130b2, 0x1 }, + { 0x131b4, 0x1 }, + { 0x132b4, 0x1 }, + { 0x133b4, 0x1 }, + { 0x134b4, 0x1 }, + { 0x135b4, 0x1 }, + { 0x136b4, 0x1 }, + { 0x137b4, 0x1 }, + { 0x138b4, 0x1 }, + { 0x2003a, 0x2 }, + { 0xc0080, 0x2 }, + { 0xd0000, 0x1 } +}; + +struct dram_fsp_msg ddr_dram_fsp_msg[] = { + { + /* P0 3200mts 1D */ + .drate = 3200, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp0_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg), + }, + { + /* P1 400mts 1D */ + .drate = 400, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp1_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg), + }, + { + /* P2 100mts 1D */ + .drate = 100, + .fw_type = FW_1D_IMAGE, + .fsp_cfg = ddr_fsp2_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg), + }, + { + /* P0 3200mts 2D */ + .drate = 3200, + .fw_type = FW_2D_IMAGE, + .fsp_cfg = ddr_fsp0_2d_cfg, + .fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg), + }, +}; + +/* ddr timing config params */ +struct dram_timing_info dram_timing_4gb = { + .ddrc_cfg = ddr_ddrc_cfg, + .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg), + .ddrphy_cfg = ddr_ddrphy_cfg, + .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg), + .fsp_msg = ddr_dram_fsp_msg, + .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg), + .ddrphy_trained_csr = ddr_ddrphy_trained_csr, + .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr), + .ddrphy_pie = ddr_phy_pie, + .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie), + .fsp_table = { 3200, 400, 100, }, +}; + diff --git a/board/kontron/pitx_imx8m/pitx_imx8m.c b/board/kontron/pitx_imx8m/pitx_imx8m.c new file mode 100644 index 0000000000..b4d35fd2bb --- /dev/null +++ b/board/kontron/pitx_imx8m/pitx_imx8m.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <init.h> +#include <miiphy.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm-generic/gpio.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <linux/delay.h> + + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) + +static iomux_v3_cfg_t const wdog_pads[] = { + IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), +}; + +static iomux_v3_cfg_t const uart_pads[] = { + IMX8MQ_PAD_UART3_RXD__UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_UART3_TXD__UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_SS0__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), + IMX8MQ_PAD_ECSPI1_MISO__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL), +}; + +int board_early_init_f(void) +{ + struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; + + imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); + set_wdog_reset(wdog); + + imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); + + return 0; +} + +int board_phys_sdram_size(phys_size_t *memsize) +{ + /* + * Get real memory size by testing available memory in a + * given range starting at i.MX8M DRAM1 base address 0x40000000. + */ + *memsize = get_ram_size((long *)0x40000000, 0x100000000ULL); + debug("Memsize: %d MiB\n", (int)(*memsize >> 20)); + + return 0; +} + + +#ifdef CONFIG_FEC_MXC +#define FEC_RST_PAD IMX_GPIO_NR(1, 11) +static iomux_v3_cfg_t const fec1_rst_pads[] = { + IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_fec(void) +{ + imx_iomux_v3_setup_multiple_pads(fec1_rst_pads, + ARRAY_SIZE(fec1_rst_pads)); +} + +static int setup_fec(void) +{ + struct iomuxc_gpr_base_regs *gpr = + (struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR; + + setup_iomux_fec(); + + /* Use 125M anatop REF_CLK1 for ENET1, not from external */ + clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0); + return set_clk_enet(ENET_125MHZ); +} + +int board_phy_config(struct phy_device *phydev) +{ + unsigned int val; + + /* enable rgmii rxc skew and phy mode select to RGMII copper */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8); + + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05); + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100); + + /* + * Set LED configuration register 1: + * LED2_SEL: 0b1011 (link established, blink on activity) + */ + val = phy_read(phydev, MDIO_DEVAD_NONE, 0x18); + val &= 0xf0ff; + phy_write(phydev, MDIO_DEVAD_NONE, 0x18, val | (0xb << 8)); + + if (phydev->drv->config) + phydev->drv->config(phydev); + return 0; +} +#endif + +int board_init(void) +{ +#ifdef CONFIG_FEC_MXC + setup_fec(); +#endif + +#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_DWC3) + init_usb_clk(); +#endif + + return 0; +} + +#ifdef CONFIG_MISC_INIT_R +#define TPM_RESET IMX_GPIO_NR(3, 2) +#define USBHUB_RESET IMX_GPIO_NR(3, 4) + +static void reset_device_by_gpio(const char *label, int pin, int delay_ms) +{ + gpio_request(pin, label); + gpio_direction_output(pin, 0); + mdelay(delay_ms); + gpio_direction_output(pin, 1); +} + +int misc_init_r(void) +{ + /* + * reset TPM chip (Infineon SLB9670) as required by datasheet + * (60ms minimum Reset Inactive Time, 70ms implemented) + */ + reset_device_by_gpio("tpm_reset", TPM_RESET, 70); + + /* + * reset USB hub as required by datasheet + * (3ms minimum reset duration, 10ms implemented) + */ + reset_device_by_gpio("usbhub_reset", USBHUB_RESET, 10); + + return 0; +} +#endif + +int board_mmc_get_env_dev(int devno) +{ + return devno; +} + +int board_late_init(void) +{ + return 0; +} diff --git a/board/kontron/pitx_imx8m/spl.c b/board/kontron/pitx_imx8m/spl.c new file mode 100644 index 0000000000..ddf20d5e23 --- /dev/null +++ b/board/kontron/pitx_imx8m/spl.c @@ -0,0 +1,327 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <common.h> +#include <errno.h> +#include <fsl_esdhc_imx.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h> + +extern struct dram_timing_info dram_timing_2gb; +extern struct dram_timing_info dram_timing_4gb; + +DECLARE_GLOBAL_DATA_PTR; + +int pfuze_mode_init(struct pmic *p, u32 mode) +{ + unsigned char offset, i, switch_num; + u32 id; + int ret; + + pmic_reg_read(p, PFUZE100_DEVICEID, &id); + id = id & 0xf; + + if (id == 0) { + switch_num = 6; + offset = PFUZE100_SW1CMODE; + } else if (id == 1) { + switch_num = 4; + offset = PFUZE100_SW2MODE; + } else { + printf("Not supported, id=%d\n", id); + return -EINVAL; + } + + ret = pmic_reg_write(p, PFUZE100_SW1ABMODE, mode); + if (ret < 0) { + printf("Set SW1AB mode error!\n"); + return ret; + } + + for (i = 0; i < switch_num - 1; i++) { + ret = pmic_reg_write(p, offset + i * SWITCH_SIZE, mode); + if (ret < 0) { + printf("Set switch 0x%x mode error!\n", + offset + i * SWITCH_SIZE); + return ret; + } + } + + return ret; +} + +/* + * BRD_REV1 BRD_REV0 + * 0 0 n/a + * 0 1 n/a + * 1 0 2GB LPDDR4 + * 1 1 4GB LPDDR4 + */ + +#define BRD_REV0 IMX_GPIO_NR(5, 0) +#define BRD_REV1 IMX_GPIO_NR(5, 1) + +static iomux_v3_cfg_t const brdrev_pads[] = { + IMX8MQ_PAD_SAI3_TXC__GPIO5_IO0 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_SAI3_TXD__GPIO5_IO1 | MUX_PAD_CTRL(PAD_CTL_PUE), + IMX8MQ_PAD_SAI3_MCLK__GPIO5_IO2 | MUX_PAD_CTRL(PAD_CTL_PUE), +}; + +static void spl_dram_init(void) +{ + struct dram_timing_info *dram_timing; + int variant = 0, size; + + imx_iomux_v3_setup_multiple_pads(brdrev_pads, ARRAY_SIZE(brdrev_pads)); + + gpio_request(BRD_REV0, "BRD_REV0"); + gpio_direction_input(BRD_REV0); + gpio_request(BRD_REV1, "BRD_REV1"); + gpio_direction_input(BRD_REV1); + + variant |= !!gpio_get_value(BRD_REV0) << 0; + variant |= !!gpio_get_value(BRD_REV1) << 1; + + switch(variant) { + case 2: + dram_timing = &dram_timing_2gb; + size = 2; + break; + case 3: + dram_timing = &dram_timing_4gb; + size = 4; + break; + default: + printf("Unknown DDR type (%d)\n", variant); + return; + }; + + /* ddr init */ + ddr_init(dram_timing); +} + +#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = { + .scl = { + .i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC, + .gp = IMX_GPIO_NR(5, 14), + }, + .sda = { + .i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC, + .gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC, + .gp = IMX_GPIO_NR(5, 15), + }, +}; + +#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19) + +int board_mmc_getcd(struct mmc *mmc) +{ + struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; + int ret = 0; + + switch (cfg->esdhc_base) { + case USDHC1_BASE_ADDR: + ret = 1; + break; + case USDHC2_BASE_ADDR: + ret = !gpio_get_value(USDHC2_CD_GPIO); + return ret; + } + + return 1; +} + +#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \ + PAD_CTL_FSEL2) +#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1) + +static iomux_v3_cfg_t const usdhc1_pads[] = { + IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static iomux_v3_cfg_t const usdhc2_pads[] = { + IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0x16 */ + IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */ + IMX8MQ_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), + IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL), +}; + +static struct fsl_esdhc_cfg usdhc_cfg[2] = { + {USDHC1_BASE_ADDR, 0, 8}, + {USDHC2_BASE_ADDR, 0, 4}, +}; + +int board_mmc_init(struct bd_info *bis) +{ + int i, ret; + /* + * According to the board_mmc_init() the following map is done: + * (U-Boot device node) (Physical Port) + * mmc0 USDHC1 + * mmc1 USDHC2 + */ + for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { + switch (i) { + case 0: + init_clk_usdhc(0); + usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc1_pads, + ARRAY_SIZE(usdhc1_pads)); + gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset"); + gpio_direction_output(USDHC1_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC1_PWR_GPIO, 1); + break; + case 1: + init_clk_usdhc(1); + usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT); + imx_iomux_v3_setup_multiple_pads(usdhc2_pads, + ARRAY_SIZE(usdhc2_pads)); + gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset"); + gpio_direction_output(USDHC2_PWR_GPIO, 0); + udelay(500); + gpio_direction_output(USDHC2_PWR_GPIO, 1); + break; + default: + printf("Warning: you configured more USDHC controllers " + "(%d) than supported by the board\n", i + 1); + return -EINVAL; + } + + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; + } + + return 0; +} + +#if CONFIG_IS_ENABLED(POWER_LEGACY) +#define I2C_PMIC 0 +int power_init_board(void) +{ + struct pmic *p; + int ret; + unsigned int reg; + + ret = power_pfuze100_init(I2C_PMIC); + if (ret) + return -ENODEV; + + p = pmic_get("PFUZE100"); + ret = pmic_probe(p); + if (ret) + return -ENODEV; + + pmic_reg_read(p, PFUZE100_SW3AVOL, ®); + if ((reg & 0x3f) != 0x18) { + reg &= ~0x3f; + reg |= 0x18; + pmic_reg_write(p, PFUZE100_SW3AVOL, reg); + } + + ret = pfuze_mode_init(p, APS_PFM); + if (ret < 0) + return ret; + + /* set SW3A standby mode to off */ + pmic_reg_read(p, PFUZE100_SW3AMODE, ®); + reg &= ~0xf; + reg |= APS_OFF; + pmic_reg_write(p, PFUZE100_SW3AMODE, reg); + + return 0; +} +#endif + +void spl_board_init(void) +{ + u32 boot_device = spl_boot_device(); + + if (boot_device == BOOT_DEVICE_MMC1) { + puts("Booting from eMMC"); + } else if (boot_device == BOOT_DEVICE_MMC2) { + puts("Booting from SD card"); + } else { + puts("Unknown boot source"); + } +} + +#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + /* Just empty function now - can't decide what to choose */ + debug("%s: %s\n", __func__, name); + + return 0; +} +#endif + +void board_init_f(ulong dummy) +{ + int ret; + + /* Clear global data */ + memset((void *)gd, 0, sizeof(gd_t)); + + arch_cpu_init(); + + init_uart_clk(2); + + board_early_init_f(); + + timer_init(); + + preloader_console_init(); + + /* Clear the BSS. */ + memset(__bss_start, 0, __bss_end - __bss_start); + + ret = spl_init(); + if (ret) { + debug("spl_init() failed: %d\n", ret); + hang(); + } + + enable_tzc380(); + + setup_i2c(0, 100000, 0x7f, &i2c_pad_info1); + + power_init_board(); + + spl_dram_init(); + + board_init_r(NULL, 0); +} diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig new file mode 100644 index 0000000000..be01b3a918 --- /dev/null +++ b/configs/kontron_pitx_imx8m_defconfig @@ -0,0 +1,87 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x300000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_MALLOC_LEN=0x600000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-kontron-pitx-imx8m" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_KONTRON_PITX_IMX8M=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_BOARD_INIT=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_NVEDIT_EFI=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DFU_MMC=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_TI=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_SPL_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_POWER_I2C=y +CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_RV8803=y +CONFIG_MXC_UART=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_IGNORE_OSINDICATIONS=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y diff --git a/doc/board/kontron/index.rst b/doc/board/kontron/index.rst index 543b22e2f5..6baaf4d7a5 100644 --- a/doc/board/kontron/index.rst +++ b/doc/board/kontron/index.rst @@ -6,4 +6,5 @@ Kontron .. toctree:: :maxdepth: 2
+ pitx-imx8m sl28 diff --git a/doc/board/kontron/pitx-imx8m.rst b/doc/board/kontron/pitx-imx8m.rst new file mode 100644 index 0000000000..1f64cbd9b2 --- /dev/null +++ b/doc/board/kontron/pitx-imx8m.rst @@ -0,0 +1,67 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Kontron pitx-imx8m +================== + +The Kontron pitx-imx8m is an embedded board with an i.MX8MQ in the pITX +form factor. + +The board has two Ethernet ports, USB, HDMI/LVDS, m.2 slot, SD card, CAN, +RS232 and much more. + +Quick Start +----------- + +- Get and build the ARM Trusted firmware binary +- Get DDR and HDMI firmware +- Build U-Boot +- Install on SD card +- Boot + +Get and build the ARM Trusted firmware binary +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ + +Note: builddir is U-Boot build directory (source directory for in-tree builds) + +.. code-block:: bash + + $ git clone https://github.com/ARM-software/arm-trusted-firmware.git + $ git checkout v2.5 + $ make PLAT=imx8mq ARCH=aarch64 CROSS_COMPILE=aarch64-linux-gnu- bl31 + $ cp build/imx8mq/release/bl31.bin $(builddir) + +Get DDR and HDMI firmware +^^^^^^^^^^^^^^^^^^^^^^^^^ + +Note: builddir is U-Boot build directory (source directory for in-tree builds) + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.11.bin + $ chmod +x firmware-imx-8.11.bin + $ ./firmware-imx-8.11 + $ cp firmware-imx-8.11/firmware/ddr/synopsys/lpddr4*.bin $(builddir) + $ cp firmware-imx-8.11/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir) + +Build U-Boot +^^^^^^^^^^^^ + +.. code-block:: bash + + $ make kontron_pitx_imx8m_defconfig + $ make CROSS_COMPILE=aarch64-linux-gnu- + +Install on SD card +^^^^^^^^^^^^^^^^^^ + + +Burn the flash.bin to SD card at an offset of 33 KiB: + +.. code-block:: bash + + $ sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33 + +Boot +^^^^ + +Set the boot source selection to SD card boot and power on the board. diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h new file mode 100644 index 0000000000..952dbd445c --- /dev/null +++ b/include/configs/kontron_pitx_imx8m.h @@ -0,0 +1,111 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef __KONTRON_PITX_IMX8M_H +#define __KONTRON_PITX_IMX8M_H + +#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h> + +#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M) + +#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_WATCHDOG +#define CONFIG_SPL_DRIVERS_MISC +#define CONFIG_SPL_POWER +#define CONFIG_SPL_I2C +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO +#define CONFIG_SPL_MMC +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000 + +/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + +#undef CONFIG_DM_MMC + +#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 +#endif + +#define CONFIG_REMAKE_ELF + +/* ENET1 Config */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC" + +#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define FEC_QUIRK_ENET_MAC + +#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 +#define PHY_ANEG_TIMEOUT 20000 + +#endif + +#define ENV_MEM_LAYOUT_SETTINGS \ + "kernel_addr_r=0x40880000\0" \ + "fdt_addr_r=0x43000000\0" \ + "scriptaddr=0x43500000\0" \ + "initrd_addr=0x43800000\0" \ + "pxefile_addr_r=0x43500000\0" \ + "bootm_size=0x10000000\0" \ + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) \ + func(PXE, pxe, 0) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "image=Image\0" \ + "console=ttymxc2,115200\0" \ + "boot_fdt=try\0" \ + "fdtfile=freescale/imx8mq-kontron-pitx-imx8m.dtb\0" \ + "dfu_alt_info=mmc 0=flash-bin raw 0x42 0x1000 mmcpart 1\0"\ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV + + +#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB DDR */ + +#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR + +#define CONFIG_IMX_BOOTAUX + +#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 + +#define CONFIG_OF_SYSTEM_SETUP + +#endif
Hi Heiko,
On 14.10.21 20:08, Heiko Thiery wrote:
The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX form factor.
There is still something using binman that does not work with CI. Without CI, we load all firmware including signed_hdmi_imx8m.bin.
But on CI, file is not loaded, but instead of warnings, build for this board fails with :
+Image 'main-section' is missing external blobs and is non-functional: blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 +binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such file or directory +
Could you take a look ?
Best regards, Stefano Babic
Signed-off-by: Heiko Thiery heiko.thiery@gmail.com
v6:
- increase PHY_ANEG_TIMEOUT
- spl: print boot source on startup
- spl: remove PMIC output
- enable CONFIG_CMD_TIME
v5:
- save env in eMMC boot partition 0
v4: update board integration
- migrate to IMX_CONFIG
- convert config options to Kconfig
- CONFIG_POWER_I2C
- CONFIG_SPL_POWER_I2C
- CONFIG_POWER_LEGACY
- CONFIG_SYS_LOAD_ADDR
- CONFIG_SYS_I2C_MXC
- CONFIG_SYS_I2C_LEGACY
- CONFIG_SYS_I2C_MXC_I2C1
- CONFIG_SYS_I2C_MXC_I2C2
- CONFIG_SYS_I2C_MXC_I2C3
- CONFIG_MXC_GPIO
v3:
- enable EFI capsule support
- add update FIT image creation to binman config
- change env offset to fit into eMMC boot partition
v2:
- add support for 2/4GB variant
- enable config options
- CONFIG_CMD_GPT
- CONFIG_DM_ETH_PHY
- CONFIG_EFI_SET_TIME
- add pxefile_addr_r env variable
.../dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi | 163 ++ arch/arm/mach-imx/imx8m/Kconfig | 7 + board/kontron/pitx_imx8m/Kconfig | 15 + board/kontron/pitx_imx8m/MAINTAINERS | 7 + board/kontron/pitx_imx8m/Makefile | 8 + board/kontron/pitx_imx8m/imximage.cfg | 5 + board/kontron/pitx_imx8m/lpddr4_timing_2gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/lpddr4_timing_4gb.c | 1853 +++++++++++++++++ board/kontron/pitx_imx8m/pitx_imx8m.c | 156 ++ board/kontron/pitx_imx8m/spl.c | 327 +++ configs/kontron_pitx_imx8m_defconfig | 87 + doc/board/kontron/index.rst | 1 + doc/board/kontron/pitx-imx8m.rst | 67 + include/configs/kontron_pitx_imx8m.h | 111 + 14 files changed, 4660 insertions(+) create mode 100644 arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi create mode 100644 board/kontron/pitx_imx8m/Kconfig create mode 100644 board/kontron/pitx_imx8m/MAINTAINERS create mode 100644 board/kontron/pitx_imx8m/Makefile create mode 100644 board/kontron/pitx_imx8m/imximage.cfg create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_2gb.c create mode 100644 board/kontron/pitx_imx8m/lpddr4_timing_4gb.c create mode 100644 board/kontron/pitx_imx8m/pitx_imx8m.c create mode 100644 board/kontron/pitx_imx8m/spl.c create mode 100644 configs/kontron_pitx_imx8m_defconfig create mode 100644 doc/board/kontron/pitx-imx8m.rst create mode 100644 include/configs/kontron_pitx_imx8m.h
diff --git a/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi new file mode 100644 index 0000000000..cf649b0314 --- /dev/null +++ b/arch/arm/dts/imx8mq-kontron-pitx-imx8m-u-boot.dtsi @@ -0,0 +1,163 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT)
+#include <config.h>
- binman: binman {
multiple-images;
+&binman {
- u-boot-spl-ddr {
filename = "u-boot-spl-ddr.bin";
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
blob_1: blob-ext@1 {
filename = "lpddr4_pmu_train_1d_imem.bin";
size = <0x8000>;
blob_2: blob-ext@2 {
filename = "lpddr4_pmu_train_1d_dmem.bin";
size = <0x4000>;
blob_3: blob-ext@3 {
filename = "lpddr4_pmu_train_2d_imem.bin";
size = <0x8000>;
blob_4: blob-ext@4 {
filename = "lpddr4_pmu_train_2d_dmem.bin";
size = <0x4000>;
- spl {
filename = "spl.bin";
mkimage {
args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000";
blob {
- itb {
filename = "u-boot.itb";
fit {
description = "Configuration to load ATF before U-Boot";
#address-cells = <1>;
fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>;
images {
uboot {
description = "U-Boot (64-bit)";
type = "standalone";
arch = "arm64";
compression = "none";
load = <CONFIG_SYS_TEXT_BASE>;
u-boot-nodtb {
atf {
description = "ARM Trusted Firmware";
type = "firmware";
arch = "arm64";
load = <0x910000>;
entry = <0x910000>;
atf_blob: blob-ext {
filename = "bl31.bin";
fdt {
description = "imx8mq-kontron-pitx-imx8m.dtb";
type = "flat_dt";
uboot_fdt_blob: blob-ext {
filename = "u-boot.dtb";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
- imx-boot {
filename = "flash.bin";
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x57c00>;
- u-boot-update {
filename = "firmware-update.itb";
fit {
description = "Configuration for firmware update file";
images {
flash-bin {
description = "U-Boot flash image";
type = "firmware";
os = "u-boot";
arch = "arm";
compress = "none";
load = <0>; /* unused */
blob {
+®_usdhc2_vmmc {
- off-on-delay-us = <0>;
+&usdhc1 {
- mmc-hs400-1_8v;
+&usdhc2 {
- sd-uhs-sdr104;
- sd-uhs-ddr50;
+}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index ccaf106be5..86279dba93 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -101,6 +101,12 @@ config TARGET_PICO_IMX8MQ select IMX8MQ select IMX8M_LPDDR4
+config TARGET_KONTRON_PITX_IMX8M
- bool "Support Kontron pITX-imx8m"
- select BINMAN
- select IMX8MQ
- select IMX8M_LPDDR4
- config TARGET_VERDIN_IMX8MM bool "Support Toradex Verdin iMX8M Mini module" select IMX8MM
@@ -150,6 +156,7 @@ source "board/freescale/imx8mn_evk/Kconfig" source "board/freescale/imx8mp_evk/Kconfig" source "board/gateworks/venice/Kconfig" source "board/google/imx8mq_phanbell/Kconfig" +source "board/kontron/pitx_imx8m/Kconfig" source "board/phytec/phycore_imx8mm/Kconfig" source "board/phytec/phycore_imx8mp/Kconfig" source "board/ronetix/imx8mq-cm/Kconfig" diff --git a/board/kontron/pitx_imx8m/Kconfig b/board/kontron/pitx_imx8m/Kconfig new file mode 100644 index 0000000000..5dce2cd37e --- /dev/null +++ b/board/kontron/pitx_imx8m/Kconfig @@ -0,0 +1,15 @@ +if TARGET_KONTRON_PITX_IMX8M
+config SYS_BOARD
- default "pitx_imx8m"
+config SYS_VENDOR
- default "kontron"
+config SYS_CONFIG_NAME
- default "kontron_pitx_imx8m"
+config IMX_CONFIG
- default "board/kontron/pitx_imx8m/imximage.cfg"
+endif diff --git a/board/kontron/pitx_imx8m/MAINTAINERS b/board/kontron/pitx_imx8m/MAINTAINERS new file mode 100644 index 0000000000..aad84528e3 --- /dev/null +++ b/board/kontron/pitx_imx8m/MAINTAINERS @@ -0,0 +1,7 @@ +Kontron pITX-imx8m Board +M: Heiko Thiery heiko.thiery@gmail.com +S: Maintained +F: arch/arm/dts/imx8mq-kontron-pitx-imx8m* +F: board/kontron/pitx_imx8m/* +F: include/configs/kontron_pitx_imx8m.h +F: configs/kontron_pitx_imx8m_defconfig diff --git a/board/kontron/pitx_imx8m/Makefile b/board/kontron/pitx_imx8m/Makefile new file mode 100644 index 0000000000..904c480281 --- /dev/null +++ b/board/kontron/pitx_imx8m/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+
+obj-y += pitx_imx8m.o
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +obj-$(CONFIG_IMX8M_LPDDR4) += lpddr4_timing_2gb.o lpddr4_timing_4gb.o +endif diff --git a/board/kontron/pitx_imx8m/imximage.cfg b/board/kontron/pitx_imx8m/imximage.cfg new file mode 100644 index 0000000000..4a110c8bcc --- /dev/null +++ b/board/kontron/pitx_imx8m/imximage.cfg @@ -0,0 +1,5 @@ +/* SPDX-License-Identifier: GPL-2.0+ */
+BOOT_FROM sd +SIGNED_HDMI signed_hdmi_imx8m.bin +LOADER u-boot-spl-ddr.bin 0x7E1000 diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c new file mode 100644 index 0000000000..b4647b9847 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_2gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+
+#include <linux/kernel.h> +#include <asm/arch/ddr.h> +#include <asm/arch/lpddr4_define.h>
+static struct dram_cfg_param ddr_ddrc_cfg[] = {
- /** Initialize DDRC registers **/
- { 0x3d400304, 0x1 },
- { 0x3d400030, 0x1 },
- { 0x3d400000, 0xa1080020 },
- { 0x3d400028, 0x0 },
- { 0x3d400020, 0x202 },
- { 0x3d400024, 0x3e800 },
- { 0x3d400064, 0x1800e0 },
- { 0x3d4000d0, 0xc003061c },
- { 0x3d4000d4, 0x9e0000 },
- { 0x3d4000dc, 0xd4002d },
- { 0x3d4000e0, 0x310008 },
- { 0x3d4000e8, 0x66004a },
- { 0x3d4000ec, 0x16004a },
- { 0x3d400100, 0x1a200624 },
- { 0x3d400104, 0x60636 },
- { 0x3d40010c, 0xc0c000 },
- { 0x3d400110, 0x10040a10 },
- { 0x3d400114, 0x2040c0c },
- { 0x3d400118, 0x1010007 },
- { 0x3d40011c, 0x401 },
- { 0x3d400130, 0x20600 },
- { 0x3d400134, 0xc100002 },
- { 0x3d400138, 0xe6 },
- { 0x3d400144, 0xa00050 },
- { 0x3d400180, 0xc3200018 },
- { 0x3d400184, 0x28061a8 },
- { 0x3d400188, 0x0 },
- { 0x3d400190, 0x497820a },
- { 0x3d400194, 0x80303 },
- { 0x3d4001a0, 0xe0400018 },
- { 0x3d4001a4, 0xdf00e4 },
- { 0x3d4001a8, 0x80000000 },
- { 0x3d4001b0, 0x11 },
- { 0x3d4001b4, 0x170a },
- { 0x3d4001c0, 0x1 },
- { 0x3d4001c4, 0x1 },
- { 0x3d4000f4, 0x639 },
- { 0x3d400108, 0x70e1617 },
- { 0x3d400200, 0x1f },
- { 0x3d40020c, 0x0 },
- { 0x3d400210, 0x1f1f },
- { 0x3d400204, 0x80808 },
- { 0x3d400214, 0x7070707 },
- { 0x3d400218, 0x7070707 },
- { 0x3d402020, 0x0 },
- { 0x3d402024, 0x7d00 },
- { 0x3d402050, 0x20d040 },
- { 0x3d402064, 0x3001c },
- { 0x3d4020dc, 0x840000 },
- { 0x3d4020e0, 0x310000 },
- { 0x3d4020e8, 0x66004a },
- { 0x3d4020ec, 0x16004a },
- { 0x3d402100, 0xa040005 },
- { 0x3d402104, 0x30407 },
- { 0x3d402108, 0x203060b },
- { 0x3d40210c, 0x505000 },
- { 0x3d402110, 0x2040202 },
- { 0x3d402114, 0x2030202 },
- { 0x3d402118, 0x1010004 },
- { 0x3d40211c, 0x301 },
- { 0x3d402130, 0x20300 },
- { 0x3d402134, 0xa100002 },
- { 0x3d402138, 0x1d },
- { 0x3d402144, 0x14000a },
- { 0x3d402180, 0xc0640004 },
- { 0x3d402190, 0x3818200 },
- { 0x3d402194, 0x80303 },
- { 0x3d4021b4, 0x100 },
- { 0x3d403020, 0x0 },
- { 0x3d403024, 0x1f40 },
- { 0x3d403050, 0x20d040 },
- { 0x3d403064, 0x30007 },
- { 0x3d4030dc, 0x840000 },
- { 0x3d4030e0, 0x310000 },
- { 0x3d4030e8, 0x66004a },
- { 0x3d4030ec, 0x16004a },
- { 0x3d403100, 0xa010102 },
- { 0x3d403104, 0x30404 },
- { 0x3d403108, 0x203060b },
- { 0x3d40310c, 0x505000 },
- { 0x3d403110, 0x2040202 },
- { 0x3d403114, 0x2030202 },
- { 0x3d403118, 0x1010004 },
- { 0x3d40311c, 0x301 },
- { 0x3d403130, 0x20300 },
- { 0x3d403134, 0xa100002 },
- { 0x3d403138, 0x8 },
- { 0x3d403144, 0x50003 },
- { 0x3d403180, 0xc0190004 },
- { 0x3d403190, 0x3818200 },
- { 0x3d403194, 0x80303 },
- { 0x3d4031b4, 0x100 },
- { 0x3d400244, 0x0 },
- { 0x3d400250, 0x29001505 },
- { 0x3d400254, 0x2c },
- { 0x3d40025c, 0x5900575b },
- { 0x3d400264, 0x90000096 },
- { 0x3d40026c, 0x1000012c },
- { 0x3d400300, 0x16 },
- { 0x3d400304, 0x0 },
- { 0x3d40030c, 0x0 },
- { 0x3d400320, 0x1 },
- { 0x3d40036c, 0x11 },
- { 0x3d400400, 0x111 },
- { 0x3d400404, 0x10f3 },
- { 0x3d400408, 0x72ff },
- { 0x3d400490, 0x1 },
- { 0x3d400494, 0xe00 },
- { 0x3d400498, 0x62ffff },
- { 0x3d40049c, 0xe00 },
- { 0x3d4004a0, 0xffff },
+/* PHY Initialize Configuration */ +static struct dram_cfg_param ddr_ddrphy_cfg[] = {
- { 0x100a0, 0x2 },
- { 0x100a1, 0x3 },
- { 0x100a2, 0x0 },
- { 0x100a3, 0x1 },
- { 0x100a4, 0x5 },
- { 0x100a5, 0x7 },
- { 0x100a6, 0x6 },
- { 0x100a7, 0x4 },
- { 0x110a0, 0x2 },
- { 0x110a1, 0x1 },
- { 0x110a2, 0x3 },
- { 0x110a3, 0x0 },
- { 0x110a4, 0x6 },
- { 0x110a5, 0x7 },
- { 0x110a6, 0x4 },
- { 0x110a7, 0x5 },
- { 0x120a0, 0x4 },
- { 0x120a1, 0x5 },
- { 0x120a2, 0x7 },
- { 0x120a3, 0x6 },
- { 0x120a4, 0x1 },
- { 0x120a5, 0x3 },
- { 0x120a6, 0x2 },
- { 0x120a7, 0x0 },
- { 0x130a0, 0x4 },
- { 0x130a1, 0x5 },
- { 0x130a2, 0x7 },
- { 0x130a3, 0x6 },
- { 0x130a4, 0x2 },
- { 0x130a5, 0x1 },
- { 0x130a6, 0x0 },
- { 0x130a7, 0x3 },
- { 0x1005f, 0x1ff },
- { 0x1015f, 0x1ff },
- { 0x1105f, 0x1ff },
- { 0x1115f, 0x1ff },
- { 0x1205f, 0x1ff },
- { 0x1215f, 0x1ff },
- { 0x1305f, 0x1ff },
- { 0x1315f, 0x1ff },
- { 0x11005f, 0x1ff },
- { 0x11015f, 0x1ff },
- { 0x11105f, 0x1ff },
- { 0x11115f, 0x1ff },
- { 0x11205f, 0x1ff },
- { 0x11215f, 0x1ff },
- { 0x11305f, 0x1ff },
- { 0x11315f, 0x1ff },
- { 0x21005f, 0x1ff },
- { 0x21015f, 0x1ff },
- { 0x21105f, 0x1ff },
- { 0x21115f, 0x1ff },
- { 0x21205f, 0x1ff },
- { 0x21215f, 0x1ff },
- { 0x21305f, 0x1ff },
- { 0x21315f, 0x1ff },
- { 0x55, 0x1ff },
- { 0x1055, 0x1ff },
- { 0x2055, 0x1ff },
- { 0x3055, 0x1ff },
- { 0x4055, 0x1ff },
- { 0x5055, 0x1ff },
- { 0x6055, 0x1ff },
- { 0x7055, 0x1ff },
- { 0x8055, 0x1ff },
- { 0x9055, 0x1ff },
- { 0x200c5, 0x19 },
- { 0x1200c5, 0x7 },
- { 0x2200c5, 0x7 },
- { 0x2002e, 0x2 },
- { 0x12002e, 0x2 },
- { 0x22002e, 0x2 },
- { 0x90204, 0x0 },
- { 0x190204, 0x0 },
- { 0x290204, 0x0 },
- { 0x20024, 0x1ab },
- { 0x2003a, 0x0 },
- { 0x120024, 0x1ab },
- { 0x2003a, 0x0 },
- { 0x220024, 0x1ab },
- { 0x2003a, 0x0 },
- { 0x20056, 0x3 },
- { 0x120056, 0x3 },
- { 0x220056, 0x3 },
- { 0x1004d, 0xe00 },
- { 0x1014d, 0xe00 },
- { 0x1104d, 0xe00 },
- { 0x1114d, 0xe00 },
- { 0x1204d, 0xe00 },
- { 0x1214d, 0xe00 },
- { 0x1304d, 0xe00 },
- { 0x1314d, 0xe00 },
- { 0x11004d, 0xe00 },
- { 0x11014d, 0xe00 },
- { 0x11104d, 0xe00 },
- { 0x11114d, 0xe00 },
- { 0x11204d, 0xe00 },
- { 0x11214d, 0xe00 },
- { 0x11304d, 0xe00 },
- { 0x11314d, 0xe00 },
- { 0x21004d, 0xe00 },
- { 0x21014d, 0xe00 },
- { 0x21104d, 0xe00 },
- { 0x21114d, 0xe00 },
- { 0x21204d, 0xe00 },
- { 0x21214d, 0xe00 },
- { 0x21304d, 0xe00 },
- { 0x21314d, 0xe00 },
- { 0x10049, 0xeba },
- { 0x10149, 0xeba },
- { 0x11049, 0xeba },
- { 0x11149, 0xeba },
- { 0x12049, 0xeba },
- { 0x12149, 0xeba },
- { 0x13049, 0xeba },
- { 0x13149, 0xeba },
- { 0x110049, 0xeba },
- { 0x110149, 0xeba },
- { 0x111049, 0xeba },
- { 0x111149, 0xeba },
- { 0x112049, 0xeba },
- { 0x112149, 0xeba },
- { 0x113049, 0xeba },
- { 0x113149, 0xeba },
- { 0x210049, 0xeba },
- { 0x210149, 0xeba },
- { 0x211049, 0xeba },
- { 0x211149, 0xeba },
- { 0x212049, 0xeba },
- { 0x212149, 0xeba },
- { 0x213049, 0xeba },
- { 0x213149, 0xeba },
- { 0x43, 0x63 },
- { 0x1043, 0x63 },
- { 0x2043, 0x63 },
- { 0x3043, 0x63 },
- { 0x4043, 0x63 },
- { 0x5043, 0x63 },
- { 0x6043, 0x63 },
- { 0x7043, 0x63 },
- { 0x8043, 0x63 },
- { 0x9043, 0x63 },
- { 0x20018, 0x3 },
- { 0x20075, 0x4 },
- { 0x20050, 0x0 },
- { 0x20008, 0x320 },
- { 0x120008, 0x64 },
- { 0x220008, 0x19 },
- { 0x20088, 0x9 },
- { 0x200b2, 0xdc },
- { 0x10043, 0x5a1 },
- { 0x10143, 0x5a1 },
- { 0x11043, 0x5a1 },
- { 0x11143, 0x5a1 },
- { 0x12043, 0x5a1 },
- { 0x12143, 0x5a1 },
- { 0x13043, 0x5a1 },
- { 0x13143, 0x5a1 },
- { 0x1200b2, 0xdc },
- { 0x110043, 0x5a1 },
- { 0x110143, 0x5a1 },
- { 0x111043, 0x5a1 },
- { 0x111143, 0x5a1 },
- { 0x112043, 0x5a1 },
- { 0x112143, 0x5a1 },
- { 0x113043, 0x5a1 },
- { 0x113143, 0x5a1 },
- { 0x2200b2, 0xdc },
- { 0x210043, 0x5a1 },
- { 0x210143, 0x5a1 },
- { 0x211043, 0x5a1 },
- { 0x211143, 0x5a1 },
- { 0x212043, 0x5a1 },
- { 0x212143, 0x5a1 },
- { 0x213043, 0x5a1 },
- { 0x213143, 0x5a1 },
- { 0x200fa, 0x1 },
- { 0x1200fa, 0x1 },
- { 0x2200fa, 0x1 },
- { 0x20019, 0x1 },
- { 0x120019, 0x1 },
- { 0x220019, 0x1 },
- { 0x200f0, 0x660 },
- { 0x200f1, 0x0 },
- { 0x200f2, 0x4444 },
- { 0x200f3, 0x8888 },
- { 0x200f4, 0x5665 },
- { 0x200f5, 0x0 },
- { 0x200f6, 0x0 },
- { 0x200f7, 0xf000 },
- { 0x20025, 0x0 },
- { 0x2002d, 0x0 },
- { 0x12002d, 0x0 },
- { 0x22002d, 0x0 },
- { 0x200c7, 0x80 },
- { 0x1200c7, 0x80 },
- { 0x2200c7, 0x80 },
- { 0x200ca, 0x106 },
- { 0x1200ca, 0x106 },
- { 0x2200ca, 0x106 },
- { 0x20110, 0x2 },
- { 0x20111, 0x3 },
- { 0x20112, 0x4 },
- { 0x20113, 0x5 },
- { 0x20114, 0x0 },
- { 0x20115, 0x1 },
+/* ddr phy trained csr */ +static struct dram_cfg_param ddr_ddrphy_trained_csr[] = {
- { 0x200b2, 0x0 },
- { 0x1200b2, 0x0 },
- { 0x2200b2, 0x0 },
- { 0x200cb, 0x0 },
- { 0x10043, 0x0 },
- { 0x110043, 0x0 },
- { 0x210043, 0x0 },
- { 0x10143, 0x0 },
- { 0x110143, 0x0 },
- { 0x210143, 0x0 },
- { 0x11043, 0x0 },
- { 0x111043, 0x0 },
- { 0x211043, 0x0 },
- { 0x11143, 0x0 },
- { 0x111143, 0x0 },
- { 0x211143, 0x0 },
- { 0x12043, 0x0 },
- { 0x112043, 0x0 },
- { 0x212043, 0x0 },
- { 0x12143, 0x0 },
- { 0x112143, 0x0 },
- { 0x212143, 0x0 },
- { 0x13043, 0x0 },
- { 0x113043, 0x0 },
- { 0x213043, 0x0 },
- { 0x13143, 0x0 },
- { 0x113143, 0x0 },
- { 0x213143, 0x0 },
- { 0x80, 0x0 },
- { 0x100080, 0x0 },
- { 0x200080, 0x0 },
- { 0x1080, 0x0 },
- { 0x101080, 0x0 },
- { 0x201080, 0x0 },
- { 0x2080, 0x0 },
- { 0x102080, 0x0 },
- { 0x202080, 0x0 },
- { 0x3080, 0x0 },
- { 0x103080, 0x0 },
- { 0x203080, 0x0 },
- { 0x4080, 0x0 },
- { 0x104080, 0x0 },
- { 0x204080, 0x0 },
- { 0x5080, 0x0 },
- { 0x105080, 0x0 },
- { 0x205080, 0x0 },
- { 0x6080, 0x0 },
- { 0x106080, 0x0 },
- { 0x206080, 0x0 },
- { 0x7080, 0x0 },
- { 0x107080, 0x0 },
- { 0x207080, 0x0 },
- { 0x8080, 0x0 },
- { 0x108080, 0x0 },
- { 0x208080, 0x0 },
- { 0x9080, 0x0 },
- { 0x109080, 0x0 },
- { 0x209080, 0x0 },
- { 0x10080, 0x0 },
- { 0x110080, 0x0 },
- { 0x210080, 0x0 },
- { 0x10180, 0x0 },
- { 0x110180, 0x0 },
- { 0x210180, 0x0 },
- { 0x11080, 0x0 },
- { 0x111080, 0x0 },
- { 0x211080, 0x0 },
- { 0x11180, 0x0 },
- { 0x111180, 0x0 },
- { 0x211180, 0x0 },
- { 0x12080, 0x0 },
- { 0x112080, 0x0 },
- { 0x212080, 0x0 },
- { 0x12180, 0x0 },
- { 0x112180, 0x0 },
- { 0x212180, 0x0 },
- { 0x13080, 0x0 },
- { 0x113080, 0x0 },
- { 0x213080, 0x0 },
- { 0x13180, 0x0 },
- { 0x113180, 0x0 },
- { 0x213180, 0x0 },
- { 0x10081, 0x0 },
- { 0x110081, 0x0 },
- { 0x210081, 0x0 },
- { 0x10181, 0x0 },
- { 0x110181, 0x0 },
- { 0x210181, 0x0 },
- { 0x11081, 0x0 },
- { 0x111081, 0x0 },
- { 0x211081, 0x0 },
- { 0x11181, 0x0 },
- { 0x111181, 0x0 },
- { 0x211181, 0x0 },
- { 0x12081, 0x0 },
- { 0x112081, 0x0 },
- { 0x212081, 0x0 },
- { 0x12181, 0x0 },
- { 0x112181, 0x0 },
- { 0x212181, 0x0 },
- { 0x13081, 0x0 },
- { 0x113081, 0x0 },
- { 0x213081, 0x0 },
- { 0x13181, 0x0 },
- { 0x113181, 0x0 },
- { 0x213181, 0x0 },
- { 0x100d0, 0x0 },
- { 0x1100d0, 0x0 },
- { 0x2100d0, 0x0 },
- { 0x101d0, 0x0 },
- { 0x1101d0, 0x0 },
- { 0x2101d0, 0x0 },
- { 0x110d0, 0x0 },
- { 0x1110d0, 0x0 },
- { 0x2110d0, 0x0 },
- { 0x111d0, 0x0 },
- { 0x1111d0, 0x0 },
- { 0x2111d0, 0x0 },
- { 0x120d0, 0x0 },
- { 0x1120d0, 0x0 },
- { 0x2120d0, 0x0 },
- { 0x121d0, 0x0 },
- { 0x1121d0, 0x0 },
- { 0x2121d0, 0x0 },
- { 0x130d0, 0x0 },
- { 0x1130d0, 0x0 },
- { 0x2130d0, 0x0 },
- { 0x131d0, 0x0 },
- { 0x1131d0, 0x0 },
- { 0x2131d0, 0x0 },
- { 0x100d1, 0x0 },
- { 0x1100d1, 0x0 },
- { 0x2100d1, 0x0 },
- { 0x101d1, 0x0 },
- { 0x1101d1, 0x0 },
- { 0x2101d1, 0x0 },
- { 0x110d1, 0x0 },
- { 0x1110d1, 0x0 },
- { 0x2110d1, 0x0 },
- { 0x111d1, 0x0 },
- { 0x1111d1, 0x0 },
- { 0x2111d1, 0x0 },
- { 0x120d1, 0x0 },
- { 0x1120d1, 0x0 },
- { 0x2120d1, 0x0 },
- { 0x121d1, 0x0 },
- { 0x1121d1, 0x0 },
- { 0x2121d1, 0x0 },
- { 0x130d1, 0x0 },
- { 0x1130d1, 0x0 },
- { 0x2130d1, 0x0 },
- { 0x131d1, 0x0 },
- { 0x1131d1, 0x0 },
- { 0x2131d1, 0x0 },
- { 0x10068, 0x0 },
- { 0x10168, 0x0 },
- { 0x10268, 0x0 },
- { 0x10368, 0x0 },
- { 0x10468, 0x0 },
- { 0x10568, 0x0 },
- { 0x10668, 0x0 },
- { 0x10768, 0x0 },
- { 0x10868, 0x0 },
- { 0x11068, 0x0 },
- { 0x11168, 0x0 },
- { 0x11268, 0x0 },
- { 0x11368, 0x0 },
- { 0x11468, 0x0 },
- { 0x11568, 0x0 },
- { 0x11668, 0x0 },
- { 0x11768, 0x0 },
- { 0x11868, 0x0 },
- { 0x12068, 0x0 },
- { 0x12168, 0x0 },
- { 0x12268, 0x0 },
- { 0x12368, 0x0 },
- { 0x12468, 0x0 },
- { 0x12568, 0x0 },
- { 0x12668, 0x0 },
- { 0x12768, 0x0 },
- { 0x12868, 0x0 },
- { 0x13068, 0x0 },
- { 0x13168, 0x0 },
- { 0x13268, 0x0 },
- { 0x13368, 0x0 },
- { 0x13468, 0x0 },
- { 0x13568, 0x0 },
- { 0x13668, 0x0 },
- { 0x13768, 0x0 },
- { 0x13868, 0x0 },
- { 0x10069, 0x0 },
- { 0x10169, 0x0 },
- { 0x10269, 0x0 },
- { 0x10369, 0x0 },
- { 0x10469, 0x0 },
- { 0x10569, 0x0 },
- { 0x10669, 0x0 },
- { 0x10769, 0x0 },
- { 0x10869, 0x0 },
- { 0x11069, 0x0 },
- { 0x11169, 0x0 },
- { 0x11269, 0x0 },
- { 0x11369, 0x0 },
- { 0x11469, 0x0 },
- { 0x11569, 0x0 },
- { 0x11669, 0x0 },
- { 0x11769, 0x0 },
- { 0x11869, 0x0 },
- { 0x12069, 0x0 },
- { 0x12169, 0x0 },
- { 0x12269, 0x0 },
- { 0x12369, 0x0 },
- { 0x12469, 0x0 },
- { 0x12569, 0x0 },
- { 0x12669, 0x0 },
- { 0x12769, 0x0 },
- { 0x12869, 0x0 },
- { 0x13069, 0x0 },
- { 0x13169, 0x0 },
- { 0x13269, 0x0 },
- { 0x13369, 0x0 },
- { 0x13469, 0x0 },
- { 0x13569, 0x0 },
- { 0x13669, 0x0 },
- { 0x13769, 0x0 },
- { 0x13869, 0x0 },
- { 0x1008c, 0x0 },
- { 0x11008c, 0x0 },
- { 0x21008c, 0x0 },
- { 0x1018c, 0x0 },
- { 0x11018c, 0x0 },
- { 0x21018c, 0x0 },
- { 0x1108c, 0x0 },
- { 0x11108c, 0x0 },
- { 0x21108c, 0x0 },
- { 0x1118c, 0x0 },
- { 0x11118c, 0x0 },
- { 0x21118c, 0x0 },
- { 0x1208c, 0x0 },
- { 0x11208c, 0x0 },
- { 0x21208c, 0x0 },
- { 0x1218c, 0x0 },
- { 0x11218c, 0x0 },
- { 0x21218c, 0x0 },
- { 0x1308c, 0x0 },
- { 0x11308c, 0x0 },
- { 0x21308c, 0x0 },
- { 0x1318c, 0x0 },
- { 0x11318c, 0x0 },
- { 0x21318c, 0x0 },
- { 0x1008d, 0x0 },
- { 0x11008d, 0x0 },
- { 0x21008d, 0x0 },
- { 0x1018d, 0x0 },
- { 0x11018d, 0x0 },
- { 0x21018d, 0x0 },
- { 0x1108d, 0x0 },
- { 0x11108d, 0x0 },
- { 0x21108d, 0x0 },
- { 0x1118d, 0x0 },
- { 0x11118d, 0x0 },
- { 0x21118d, 0x0 },
- { 0x1208d, 0x0 },
- { 0x11208d, 0x0 },
- { 0x21208d, 0x0 },
- { 0x1218d, 0x0 },
- { 0x11218d, 0x0 },
- { 0x21218d, 0x0 },
- { 0x1308d, 0x0 },
- { 0x11308d, 0x0 },
- { 0x21308d, 0x0 },
- { 0x1318d, 0x0 },
- { 0x11318d, 0x0 },
- { 0x21318d, 0x0 },
- { 0x100c0, 0x0 },
- { 0x1100c0, 0x0 },
- { 0x2100c0, 0x0 },
- { 0x101c0, 0x0 },
- { 0x1101c0, 0x0 },
- { 0x2101c0, 0x0 },
- { 0x102c0, 0x0 },
- { 0x1102c0, 0x0 },
- { 0x2102c0, 0x0 },
- { 0x103c0, 0x0 },
- { 0x1103c0, 0x0 },
- { 0x2103c0, 0x0 },
- { 0x104c0, 0x0 },
- { 0x1104c0, 0x0 },
- { 0x2104c0, 0x0 },
- { 0x105c0, 0x0 },
- { 0x1105c0, 0x0 },
- { 0x2105c0, 0x0 },
- { 0x106c0, 0x0 },
- { 0x1106c0, 0x0 },
- { 0x2106c0, 0x0 },
- { 0x107c0, 0x0 },
- { 0x1107c0, 0x0 },
- { 0x2107c0, 0x0 },
- { 0x108c0, 0x0 },
- { 0x1108c0, 0x0 },
- { 0x2108c0, 0x0 },
- { 0x110c0, 0x0 },
- { 0x1110c0, 0x0 },
- { 0x2110c0, 0x0 },
- { 0x111c0, 0x0 },
- { 0x1111c0, 0x0 },
- { 0x2111c0, 0x0 },
- { 0x112c0, 0x0 },
- { 0x1112c0, 0x0 },
- { 0x2112c0, 0x0 },
- { 0x113c0, 0x0 },
- { 0x1113c0, 0x0 },
- { 0x2113c0, 0x0 },
- { 0x114c0, 0x0 },
- { 0x1114c0, 0x0 },
- { 0x2114c0, 0x0 },
- { 0x115c0, 0x0 },
- { 0x1115c0, 0x0 },
- { 0x2115c0, 0x0 },
- { 0x116c0, 0x0 },
- { 0x1116c0, 0x0 },
- { 0x2116c0, 0x0 },
- { 0x117c0, 0x0 },
- { 0x1117c0, 0x0 },
- { 0x2117c0, 0x0 },
- { 0x118c0, 0x0 },
- { 0x1118c0, 0x0 },
- { 0x2118c0, 0x0 },
- { 0x120c0, 0x0 },
- { 0x1120c0, 0x0 },
- { 0x2120c0, 0x0 },
- { 0x121c0, 0x0 },
- { 0x1121c0, 0x0 },
- { 0x2121c0, 0x0 },
- { 0x122c0, 0x0 },
- { 0x1122c0, 0x0 },
- { 0x2122c0, 0x0 },
- { 0x123c0, 0x0 },
- { 0x1123c0, 0x0 },
- { 0x2123c0, 0x0 },
- { 0x124c0, 0x0 },
- { 0x1124c0, 0x0 },
- { 0x2124c0, 0x0 },
- { 0x125c0, 0x0 },
- { 0x1125c0, 0x0 },
- { 0x2125c0, 0x0 },
- { 0x126c0, 0x0 },
- { 0x1126c0, 0x0 },
- { 0x2126c0, 0x0 },
- { 0x127c0, 0x0 },
- { 0x1127c0, 0x0 },
- { 0x2127c0, 0x0 },
- { 0x128c0, 0x0 },
- { 0x1128c0, 0x0 },
- { 0x2128c0, 0x0 },
- { 0x130c0, 0x0 },
- { 0x1130c0, 0x0 },
- { 0x2130c0, 0x0 },
- { 0x131c0, 0x0 },
- { 0x1131c0, 0x0 },
- { 0x2131c0, 0x0 },
- { 0x132c0, 0x0 },
- { 0x1132c0, 0x0 },
- { 0x2132c0, 0x0 },
- { 0x133c0, 0x0 },
- { 0x1133c0, 0x0 },
- { 0x2133c0, 0x0 },
- { 0x134c0, 0x0 },
- { 0x1134c0, 0x0 },
- { 0x2134c0, 0x0 },
- { 0x135c0, 0x0 },
- { 0x1135c0, 0x0 },
- { 0x2135c0, 0x0 },
- { 0x136c0, 0x0 },
- { 0x1136c0, 0x0 },
- { 0x2136c0, 0x0 },
- { 0x137c0, 0x0 },
- { 0x1137c0, 0x0 },
- { 0x2137c0, 0x0 },
- { 0x138c0, 0x0 },
- { 0x1138c0, 0x0 },
- { 0x2138c0, 0x0 },
- { 0x100c1, 0x0 },
- { 0x1100c1, 0x0 },
- { 0x2100c1, 0x0 },
- { 0x101c1, 0x0 },
- { 0x1101c1, 0x0 },
- { 0x2101c1, 0x0 },
- { 0x102c1, 0x0 },
- { 0x1102c1, 0x0 },
- { 0x2102c1, 0x0 },
- { 0x103c1, 0x0 },
- { 0x1103c1, 0x0 },
- { 0x2103c1, 0x0 },
- { 0x104c1, 0x0 },
- { 0x1104c1, 0x0 },
- { 0x2104c1, 0x0 },
- { 0x105c1, 0x0 },
- { 0x1105c1, 0x0 },
- { 0x2105c1, 0x0 },
- { 0x106c1, 0x0 },
- { 0x1106c1, 0x0 },
- { 0x2106c1, 0x0 },
- { 0x107c1, 0x0 },
- { 0x1107c1, 0x0 },
- { 0x2107c1, 0x0 },
- { 0x108c1, 0x0 },
- { 0x1108c1, 0x0 },
- { 0x2108c1, 0x0 },
- { 0x110c1, 0x0 },
- { 0x1110c1, 0x0 },
- { 0x2110c1, 0x0 },
- { 0x111c1, 0x0 },
- { 0x1111c1, 0x0 },
- { 0x2111c1, 0x0 },
- { 0x112c1, 0x0 },
- { 0x1112c1, 0x0 },
- { 0x2112c1, 0x0 },
- { 0x113c1, 0x0 },
- { 0x1113c1, 0x0 },
- { 0x2113c1, 0x0 },
- { 0x114c1, 0x0 },
- { 0x1114c1, 0x0 },
- { 0x2114c1, 0x0 },
- { 0x115c1, 0x0 },
- { 0x1115c1, 0x0 },
- { 0x2115c1, 0x0 },
- { 0x116c1, 0x0 },
- { 0x1116c1, 0x0 },
- { 0x2116c1, 0x0 },
- { 0x117c1, 0x0 },
- { 0x1117c1, 0x0 },
- { 0x2117c1, 0x0 },
- { 0x118c1, 0x0 },
- { 0x1118c1, 0x0 },
- { 0x2118c1, 0x0 },
- { 0x120c1, 0x0 },
- { 0x1120c1, 0x0 },
- { 0x2120c1, 0x0 },
- { 0x121c1, 0x0 },
- { 0x1121c1, 0x0 },
- { 0x2121c1, 0x0 },
- { 0x122c1, 0x0 },
- { 0x1122c1, 0x0 },
- { 0x2122c1, 0x0 },
- { 0x123c1, 0x0 },
- { 0x1123c1, 0x0 },
- { 0x2123c1, 0x0 },
- { 0x124c1, 0x0 },
- { 0x1124c1, 0x0 },
- { 0x2124c1, 0x0 },
- { 0x125c1, 0x0 },
- { 0x1125c1, 0x0 },
- { 0x2125c1, 0x0 },
- { 0x126c1, 0x0 },
- { 0x1126c1, 0x0 },
- { 0x2126c1, 0x0 },
- { 0x127c1, 0x0 },
- { 0x1127c1, 0x0 },
- { 0x2127c1, 0x0 },
- { 0x128c1, 0x0 },
- { 0x1128c1, 0x0 },
- { 0x2128c1, 0x0 },
- { 0x130c1, 0x0 },
- { 0x1130c1, 0x0 },
- { 0x2130c1, 0x0 },
- { 0x131c1, 0x0 },
- { 0x1131c1, 0x0 },
- { 0x2131c1, 0x0 },
- { 0x132c1, 0x0 },
- { 0x1132c1, 0x0 },
- { 0x2132c1, 0x0 },
- { 0x133c1, 0x0 },
- { 0x1133c1, 0x0 },
- { 0x2133c1, 0x0 },
- { 0x134c1, 0x0 },
- { 0x1134c1, 0x0 },
- { 0x2134c1, 0x0 },
- { 0x135c1, 0x0 },
- { 0x1135c1, 0x0 },
- { 0x2135c1, 0x0 },
- { 0x136c1, 0x0 },
- { 0x1136c1, 0x0 },
- { 0x2136c1, 0x0 },
- { 0x137c1, 0x0 },
- { 0x1137c1, 0x0 },
- { 0x2137c1, 0x0 },
- { 0x138c1, 0x0 },
- { 0x1138c1, 0x0 },
- { 0x2138c1, 0x0 },
- { 0x10020, 0x0 },
- { 0x110020, 0x0 },
- { 0x210020, 0x0 },
- { 0x11020, 0x0 },
- { 0x111020, 0x0 },
- { 0x211020, 0x0 },
- { 0x12020, 0x0 },
- { 0x112020, 0x0 },
- { 0x212020, 0x0 },
- { 0x13020, 0x0 },
- { 0x113020, 0x0 },
- { 0x213020, 0x0 },
- { 0x20072, 0x0 },
- { 0x20073, 0x0 },
- { 0x20074, 0x0 },
- { 0x100aa, 0x0 },
- { 0x110aa, 0x0 },
- { 0x120aa, 0x0 },
- { 0x130aa, 0x0 },
- { 0x20010, 0x0 },
- { 0x120010, 0x0 },
- { 0x220010, 0x0 },
- { 0x20011, 0x0 },
- { 0x120011, 0x0 },
- { 0x220011, 0x0 },
- { 0x100ae, 0x0 },
- { 0x1100ae, 0x0 },
- { 0x2100ae, 0x0 },
- { 0x100af, 0x0 },
- { 0x1100af, 0x0 },
- { 0x2100af, 0x0 },
- { 0x110ae, 0x0 },
- { 0x1110ae, 0x0 },
- { 0x2110ae, 0x0 },
- { 0x110af, 0x0 },
- { 0x1110af, 0x0 },
- { 0x2110af, 0x0 },
- { 0x120ae, 0x0 },
- { 0x1120ae, 0x0 },
- { 0x2120ae, 0x0 },
- { 0x120af, 0x0 },
- { 0x1120af, 0x0 },
- { 0x2120af, 0x0 },
- { 0x130ae, 0x0 },
- { 0x1130ae, 0x0 },
- { 0x2130ae, 0x0 },
- { 0x130af, 0x0 },
- { 0x1130af, 0x0 },
- { 0x2130af, 0x0 },
- { 0x20020, 0x0 },
- { 0x120020, 0x0 },
- { 0x220020, 0x0 },
- { 0x100a0, 0x0 },
- { 0x100a1, 0x0 },
- { 0x100a2, 0x0 },
- { 0x100a3, 0x0 },
- { 0x100a4, 0x0 },
- { 0x100a5, 0x0 },
- { 0x100a6, 0x0 },
- { 0x100a7, 0x0 },
- { 0x110a0, 0x0 },
- { 0x110a1, 0x0 },
- { 0x110a2, 0x0 },
- { 0x110a3, 0x0 },
- { 0x110a4, 0x0 },
- { 0x110a5, 0x0 },
- { 0x110a6, 0x0 },
- { 0x110a7, 0x0 },
- { 0x120a0, 0x0 },
- { 0x120a1, 0x0 },
- { 0x120a2, 0x0 },
- { 0x120a3, 0x0 },
- { 0x120a4, 0x0 },
- { 0x120a5, 0x0 },
- { 0x120a6, 0x0 },
- { 0x120a7, 0x0 },
- { 0x130a0, 0x0 },
- { 0x130a1, 0x0 },
- { 0x130a2, 0x0 },
- { 0x130a3, 0x0 },
- { 0x130a4, 0x0 },
- { 0x130a5, 0x0 },
- { 0x130a6, 0x0 },
- { 0x130a7, 0x0 },
- { 0x2007c, 0x0 },
- { 0x12007c, 0x0 },
- { 0x22007c, 0x0 },
- { 0x2007d, 0x0 },
- { 0x12007d, 0x0 },
- { 0x22007d, 0x0 },
- { 0x400fd, 0x0 },
- { 0x400c0, 0x0 },
- { 0x90201, 0x0 },
- { 0x190201, 0x0 },
- { 0x290201, 0x0 },
- { 0x90202, 0x0 },
- { 0x190202, 0x0 },
- { 0x290202, 0x0 },
- { 0x90203, 0x0 },
- { 0x190203, 0x0 },
- { 0x290203, 0x0 },
- { 0x90204, 0x0 },
- { 0x90205, 0x0 },
- { 0x190205, 0x0 },
- { 0x290205, 0x0 },
- { 0x90206, 0x0 },
- { 0x190206, 0x0 },
- { 0x290206, 0x0 },
- { 0x90207, 0x0 },
- { 0x190207, 0x0 },
- { 0x290207, 0x0 },
- { 0x90208, 0x0 },
- { 0x190208, 0x0 },
- { 0x290208, 0x0 },
- { 0x10062, 0x0 },
- { 0x10162, 0x0 },
- { 0x10262, 0x0 },
- { 0x10362, 0x0 },
- { 0x10462, 0x0 },
- { 0x10562, 0x0 },
- { 0x10662, 0x0 },
- { 0x10762, 0x0 },
- { 0x10862, 0x0 },
- { 0x11062, 0x0 },
- { 0x11162, 0x0 },
- { 0x11262, 0x0 },
- { 0x11362, 0x0 },
- { 0x11462, 0x0 },
- { 0x11562, 0x0 },
- { 0x11662, 0x0 },
- { 0x11762, 0x0 },
- { 0x11862, 0x0 },
- { 0x12062, 0x0 },
- { 0x12162, 0x0 },
- { 0x12262, 0x0 },
- { 0x12362, 0x0 },
- { 0x12462, 0x0 },
- { 0x12562, 0x0 },
- { 0x12662, 0x0 },
- { 0x12762, 0x0 },
- { 0x12862, 0x0 },
- { 0x13062, 0x0 },
- { 0x13162, 0x0 },
- { 0x13262, 0x0 },
- { 0x13362, 0x0 },
- { 0x13462, 0x0 },
- { 0x13562, 0x0 },
- { 0x13662, 0x0 },
- { 0x13762, 0x0 },
- { 0x13862, 0x0 },
- { 0x20077, 0x0 },
- { 0x10001, 0x0 },
- { 0x11001, 0x0 },
- { 0x12001, 0x0 },
- { 0x13001, 0x0 },
- { 0x10040, 0x0 },
- { 0x10140, 0x0 },
- { 0x10240, 0x0 },
- { 0x10340, 0x0 },
- { 0x10440, 0x0 },
- { 0x10540, 0x0 },
- { 0x10640, 0x0 },
- { 0x10740, 0x0 },
- { 0x10840, 0x0 },
- { 0x10030, 0x0 },
- { 0x10130, 0x0 },
- { 0x10230, 0x0 },
- { 0x10330, 0x0 },
- { 0x10430, 0x0 },
- { 0x10530, 0x0 },
- { 0x10630, 0x0 },
- { 0x10730, 0x0 },
- { 0x10830, 0x0 },
- { 0x11040, 0x0 },
- { 0x11140, 0x0 },
- { 0x11240, 0x0 },
- { 0x11340, 0x0 },
- { 0x11440, 0x0 },
- { 0x11540, 0x0 },
- { 0x11640, 0x0 },
- { 0x11740, 0x0 },
- { 0x11840, 0x0 },
- { 0x11030, 0x0 },
- { 0x11130, 0x0 },
- { 0x11230, 0x0 },
- { 0x11330, 0x0 },
- { 0x11430, 0x0 },
- { 0x11530, 0x0 },
- { 0x11630, 0x0 },
- { 0x11730, 0x0 },
- { 0x11830, 0x0 },
- { 0x12040, 0x0 },
- { 0x12140, 0x0 },
- { 0x12240, 0x0 },
- { 0x12340, 0x0 },
- { 0x12440, 0x0 },
- { 0x12540, 0x0 },
- { 0x12640, 0x0 },
- { 0x12740, 0x0 },
- { 0x12840, 0x0 },
- { 0x12030, 0x0 },
- { 0x12130, 0x0 },
- { 0x12230, 0x0 },
- { 0x12330, 0x0 },
- { 0x12430, 0x0 },
- { 0x12530, 0x0 },
- { 0x12630, 0x0 },
- { 0x12730, 0x0 },
- { 0x12830, 0x0 },
- { 0x13040, 0x0 },
- { 0x13140, 0x0 },
- { 0x13240, 0x0 },
- { 0x13340, 0x0 },
- { 0x13440, 0x0 },
- { 0x13540, 0x0 },
- { 0x13640, 0x0 },
- { 0x13740, 0x0 },
- { 0x13840, 0x0 },
- { 0x13030, 0x0 },
- { 0x13130, 0x0 },
- { 0x13230, 0x0 },
- { 0x13330, 0x0 },
- { 0x13430, 0x0 },
- { 0x13530, 0x0 },
- { 0x13630, 0x0 },
- { 0x13730, 0x0 },
- { 0x13830, 0x0 },
+/* P0 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54003, 0xc80 },
- { 0x54004, 0x2 },
- { 0x54005, 0x2228 },
- { 0x54006, 0x11 },
- { 0x54008, 0x131f },
- { 0x54009, 0xc8 },
- { 0x5400b, 0x2 },
- { 0x54012, 0x110 },
- { 0x54019, 0x2dd4 },
- { 0x5401a, 0x31 },
- { 0x5401b, 0x4a66 },
- { 0x5401c, 0x4a08 },
- { 0x5401e, 0x16 },
- { 0x5401f, 0x2dd4 },
- { 0x54020, 0x31 },
- { 0x54021, 0x4a66 },
- { 0x54022, 0x4a08 },
- { 0x54024, 0x16 },
- { 0x5402b, 0x1000 },
- { 0x5402c, 0x1 },
- { 0x54032, 0xd400 },
- { 0x54033, 0x312d },
- { 0x54034, 0x6600 },
- { 0x54035, 0x84a },
- { 0x54036, 0x4a },
- { 0x54037, 0x1600 },
- { 0x54038, 0xd400 },
- { 0x54039, 0x312d },
- { 0x5403a, 0x6600 },
- { 0x5403b, 0x84a },
- { 0x5403c, 0x4a },
- { 0x5403d, 0x1600 },
- { 0xd0000, 0x1 },
+/* P1 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp1_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54002, 0x101 },
- { 0x54003, 0x190 },
- { 0x54004, 0x2 },
- { 0x54008, 0x121f },
- { 0x5400b, 0x2 },
- { 0x54019, 0x84 },
- { 0x5401f, 0x84 },
- { 0x5402c, 0x1 },
- { 0x54032, 0x8400 },
- { 0x54033, 0x3100 },
- { 0x54038, 0x8400 },
- { 0x54039, 0x3100 },
- { 0xd0000, 0x1 },
+/* P2 message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp2_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54002, 0x102 },
- { 0x54003, 0x64 },
- { 0x54004, 0x2 },
- { 0x5400b, 0x2 },
- { 0x5402c, 0x1 },
- { 0xd0000, 0x1 },
+/* P0 2D message block paremeter for training firmware */ +static struct dram_cfg_param ddr_fsp0_2d_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54004, 0x2 },
- { 0x54008, 0x61 },
- { 0x5400b, 0x2 },
- { 0x5400d, 0x100 },
- { 0x5400f, 0x100 },
- { 0x54010, 0x1f7f },
- { 0x5402c, 0x1 },
- { 0xd0000, 0x1 },
+/* DRAM PHY init engine image */ +static struct dram_cfg_param ddr_phy_pie[] = {
- { 0xd0000, 0x0 },
- { 0x90000, 0x10 },
- { 0x90001, 0x400 },
- { 0x90002, 0x10e },
- { 0x90003, 0x0 },
- { 0x90004, 0x0 },
- { 0x90005, 0x8 },
- { 0x90029, 0xb },
- { 0x9002a, 0x480 },
- { 0x9002b, 0x109 },
- { 0x9002c, 0x8 },
- { 0x9002d, 0x448 },
- { 0x9002e, 0x139 },
- { 0x9002f, 0x8 },
- { 0x90030, 0x478 },
- { 0x90031, 0x109 },
- { 0x90032, 0x0 },
- { 0x90033, 0xe8 },
- { 0x90034, 0x109 },
- { 0x90035, 0x2 },
- { 0x90036, 0x10 },
- { 0x90037, 0x139 },
- { 0x90038, 0xf },
- { 0x90039, 0x7c0 },
- { 0x9003a, 0x139 },
- { 0x9003b, 0x44 },
- { 0x9003c, 0x630 },
- { 0x9003d, 0x159 },
- { 0x9003e, 0x14f },
- { 0x9003f, 0x630 },
- { 0x90040, 0x159 },
- { 0x90041, 0x47 },
- { 0x90042, 0x630 },
- { 0x90043, 0x149 },
- { 0x90044, 0x4f },
- { 0x90045, 0x630 },
- { 0x90046, 0x179 },
- { 0x90047, 0x8 },
- { 0x90048, 0xe0 },
- { 0x90049, 0x109 },
- { 0x9004a, 0x0 },
- { 0x9004b, 0x7c8 },
- { 0x9004c, 0x109 },
- { 0x9004d, 0x0 },
- { 0x9004e, 0x1 },
- { 0x9004f, 0x8 },
- { 0x90050, 0x0 },
- { 0x90051, 0x45a },
- { 0x90052, 0x9 },
- { 0x90053, 0x0 },
- { 0x90054, 0x448 },
- { 0x90055, 0x109 },
- { 0x90056, 0x40 },
- { 0x90057, 0x630 },
- { 0x90058, 0x179 },
- { 0x90059, 0x1 },
- { 0x9005a, 0x618 },
- { 0x9005b, 0x109 },
- { 0x9005c, 0x40c0 },
- { 0x9005d, 0x630 },
- { 0x9005e, 0x149 },
- { 0x9005f, 0x8 },
- { 0x90060, 0x4 },
- { 0x90061, 0x48 },
- { 0x90062, 0x4040 },
- { 0x90063, 0x630 },
- { 0x90064, 0x149 },
- { 0x90065, 0x0 },
- { 0x90066, 0x4 },
- { 0x90067, 0x48 },
- { 0x90068, 0x40 },
- { 0x90069, 0x630 },
- { 0x9006a, 0x149 },
- { 0x9006b, 0x10 },
- { 0x9006c, 0x4 },
- { 0x9006d, 0x18 },
- { 0x9006e, 0x0 },
- { 0x9006f, 0x4 },
- { 0x90070, 0x78 },
- { 0x90071, 0x549 },
- { 0x90072, 0x630 },
- { 0x90073, 0x159 },
- { 0x90074, 0xd49 },
- { 0x90075, 0x630 },
- { 0x90076, 0x159 },
- { 0x90077, 0x94a },
- { 0x90078, 0x630 },
- { 0x90079, 0x159 },
- { 0x9007a, 0x441 },
- { 0x9007b, 0x630 },
- { 0x9007c, 0x149 },
- { 0x9007d, 0x42 },
- { 0x9007e, 0x630 },
- { 0x9007f, 0x149 },
- { 0x90080, 0x1 },
- { 0x90081, 0x630 },
- { 0x90082, 0x149 },
- { 0x90083, 0x0 },
- { 0x90084, 0xe0 },
- { 0x90085, 0x109 },
- { 0x90086, 0xa },
- { 0x90087, 0x10 },
- { 0x90088, 0x109 },
- { 0x90089, 0x9 },
- { 0x9008a, 0x3c0 },
- { 0x9008b, 0x149 },
- { 0x9008c, 0x9 },
- { 0x9008d, 0x3c0 },
- { 0x9008e, 0x159 },
- { 0x9008f, 0x18 },
- { 0x90090, 0x10 },
- { 0x90091, 0x109 },
- { 0x90092, 0x0 },
- { 0x90093, 0x3c0 },
- { 0x90094, 0x109 },
- { 0x90095, 0x18 },
- { 0x90096, 0x4 },
- { 0x90097, 0x48 },
- { 0x90098, 0x18 },
- { 0x90099, 0x4 },
- { 0x9009a, 0x58 },
- { 0x9009b, 0xa },
- { 0x9009c, 0x10 },
- { 0x9009d, 0x109 },
- { 0x9009e, 0x2 },
- { 0x9009f, 0x10 },
- { 0x900a0, 0x109 },
- { 0x900a1, 0x5 },
- { 0x900a2, 0x7c0 },
- { 0x900a3, 0x109 },
- { 0x900a4, 0x10 },
- { 0x900a5, 0x10 },
- { 0x900a6, 0x109 },
- { 0x40000, 0x811 },
- { 0x40020, 0x880 },
- { 0x40040, 0x0 },
- { 0x40060, 0x0 },
- { 0x40001, 0x4008 },
- { 0x40021, 0x83 },
- { 0x40041, 0x4f },
- { 0x40061, 0x0 },
- { 0x40002, 0x4040 },
- { 0x40022, 0x83 },
- { 0x40042, 0x51 },
- { 0x40062, 0x0 },
- { 0x40003, 0x811 },
- { 0x40023, 0x880 },
- { 0x40043, 0x0 },
- { 0x40063, 0x0 },
- { 0x40004, 0x720 },
- { 0x40024, 0xf },
- { 0x40044, 0x1740 },
- { 0x40064, 0x0 },
- { 0x40005, 0x16 },
- { 0x40025, 0x83 },
- { 0x40045, 0x4b },
- { 0x40065, 0x0 },
- { 0x40006, 0x716 },
- { 0x40026, 0xf },
- { 0x40046, 0x2001 },
- { 0x40066, 0x0 },
- { 0x40007, 0x716 },
- { 0x40027, 0xf },
- { 0x40047, 0x2800 },
- { 0x40067, 0x0 },
- { 0x40008, 0x716 },
- { 0x40028, 0xf },
- { 0x40048, 0xf00 },
- { 0x40068, 0x0 },
- { 0x40009, 0x720 },
- { 0x40029, 0xf },
- { 0x40049, 0x1400 },
- { 0x40069, 0x0 },
- { 0x4000a, 0xe08 },
- { 0x4002a, 0xc15 },
- { 0x4004a, 0x0 },
- { 0x4006a, 0x0 },
- { 0x4000b, 0x623 },
- { 0x4002b, 0x15 },
- { 0x4004b, 0x0 },
- { 0x4006b, 0x0 },
- { 0x4000c, 0x4028 },
- { 0x4002c, 0x80 },
- { 0x4004c, 0x0 },
- { 0x4006c, 0x0 },
- { 0x4000d, 0xe08 },
- { 0x4002d, 0xc1a },
- { 0x4004d, 0x0 },
- { 0x4006d, 0x0 },
- { 0x4000e, 0x623 },
- { 0x4002e, 0x1a },
- { 0x4004e, 0x0 },
- { 0x4006e, 0x0 },
- { 0x4000f, 0x4040 },
- { 0x4002f, 0x80 },
- { 0x4004f, 0x0 },
- { 0x4006f, 0x0 },
- { 0x40010, 0x2604 },
- { 0x40030, 0x15 },
- { 0x40050, 0x0 },
- { 0x40070, 0x0 },
- { 0x40011, 0x708 },
- { 0x40031, 0x5 },
- { 0x40051, 0x0 },
- { 0x40071, 0x2002 },
- { 0x40012, 0x8 },
- { 0x40032, 0x80 },
- { 0x40052, 0x0 },
- { 0x40072, 0x0 },
- { 0x40013, 0x2604 },
- { 0x40033, 0x1a },
- { 0x40053, 0x0 },
- { 0x40073, 0x0 },
- { 0x40014, 0x708 },
- { 0x40034, 0xa },
- { 0x40054, 0x0 },
- { 0x40074, 0x2002 },
- { 0x40015, 0x4040 },
- { 0x40035, 0x80 },
- { 0x40055, 0x0 },
- { 0x40075, 0x0 },
- { 0x40016, 0x60a },
- { 0x40036, 0x15 },
- { 0x40056, 0x1200 },
- { 0x40076, 0x0 },
- { 0x40017, 0x61a },
- { 0x40037, 0x15 },
- { 0x40057, 0x1300 },
- { 0x40077, 0x0 },
- { 0x40018, 0x60a },
- { 0x40038, 0x1a },
- { 0x40058, 0x1200 },
- { 0x40078, 0x0 },
- { 0x40019, 0x642 },
- { 0x40039, 0x1a },
- { 0x40059, 0x1300 },
- { 0x40079, 0x0 },
- { 0x4001a, 0x4808 },
- { 0x4003a, 0x880 },
- { 0x4005a, 0x0 },
- { 0x4007a, 0x0 },
- { 0x900a7, 0x0 },
- { 0x900a8, 0x790 },
- { 0x900a9, 0x11a },
- { 0x900aa, 0x8 },
- { 0x900ab, 0x7aa },
- { 0x900ac, 0x2a },
- { 0x900ad, 0x10 },
- { 0x900ae, 0x7b2 },
- { 0x900af, 0x2a },
- { 0x900b0, 0x0 },
- { 0x900b1, 0x7c8 },
- { 0x900b2, 0x109 },
- { 0x900b3, 0x10 },
- { 0x900b4, 0x2a8 },
- { 0x900b5, 0x129 },
- { 0x900b6, 0x8 },
- { 0x900b7, 0x370 },
- { 0x900b8, 0x129 },
- { 0x900b9, 0xa },
- { 0x900ba, 0x3c8 },
- { 0x900bb, 0x1a9 },
- { 0x900bc, 0xc },
- { 0x900bd, 0x408 },
- { 0x900be, 0x199 },
- { 0x900bf, 0x14 },
- { 0x900c0, 0x790 },
- { 0x900c1, 0x11a },
- { 0x900c2, 0x8 },
- { 0x900c3, 0x4 },
- { 0x900c4, 0x18 },
- { 0x900c5, 0xe },
- { 0x900c6, 0x408 },
- { 0x900c7, 0x199 },
- { 0x900c8, 0x8 },
- { 0x900c9, 0x8568 },
- { 0x900ca, 0x108 },
- { 0x900cb, 0x18 },
- { 0x900cc, 0x790 },
- { 0x900cd, 0x16a },
- { 0x900ce, 0x8 },
- { 0x900cf, 0x1d8 },
- { 0x900d0, 0x169 },
- { 0x900d1, 0x10 },
- { 0x900d2, 0x8558 },
- { 0x900d3, 0x168 },
- { 0x900d4, 0x70 },
- { 0x900d5, 0x788 },
- { 0x900d6, 0x16a },
- { 0x900d7, 0x1ff8 },
- { 0x900d8, 0x85a8 },
- { 0x900d9, 0x1e8 },
- { 0x900da, 0x50 },
- { 0x900db, 0x798 },
- { 0x900dc, 0x16a },
- { 0x900dd, 0x60 },
- { 0x900de, 0x7a0 },
- { 0x900df, 0x16a },
- { 0x900e0, 0x8 },
- { 0x900e1, 0x8310 },
- { 0x900e2, 0x168 },
- { 0x900e3, 0x8 },
- { 0x900e4, 0xa310 },
- { 0x900e5, 0x168 },
- { 0x900e6, 0xa },
- { 0x900e7, 0x408 },
- { 0x900e8, 0x169 },
- { 0x900e9, 0x6e },
- { 0x900ea, 0x0 },
- { 0x900eb, 0x68 },
- { 0x900ec, 0x0 },
- { 0x900ed, 0x408 },
- { 0x900ee, 0x169 },
- { 0x900ef, 0x0 },
- { 0x900f0, 0x8310 },
- { 0x900f1, 0x168 },
- { 0x900f2, 0x0 },
- { 0x900f3, 0xa310 },
- { 0x900f4, 0x168 },
- { 0x900f5, 0x1ff8 },
- { 0x900f6, 0x85a8 },
- { 0x900f7, 0x1e8 },
- { 0x900f8, 0x68 },
- { 0x900f9, 0x798 },
- { 0x900fa, 0x16a },
- { 0x900fb, 0x78 },
- { 0x900fc, 0x7a0 },
- { 0x900fd, 0x16a },
- { 0x900fe, 0x68 },
- { 0x900ff, 0x790 },
- { 0x90100, 0x16a },
- { 0x90101, 0x8 },
- { 0x90102, 0x8b10 },
- { 0x90103, 0x168 },
- { 0x90104, 0x8 },
- { 0x90105, 0xab10 },
- { 0x90106, 0x168 },
- { 0x90107, 0xa },
- { 0x90108, 0x408 },
- { 0x90109, 0x169 },
- { 0x9010a, 0x58 },
- { 0x9010b, 0x0 },
- { 0x9010c, 0x68 },
- { 0x9010d, 0x0 },
- { 0x9010e, 0x408 },
- { 0x9010f, 0x169 },
- { 0x90110, 0x0 },
- { 0x90111, 0x8b10 },
- { 0x90112, 0x168 },
- { 0x90113, 0x0 },
- { 0x90114, 0xab10 },
- { 0x90115, 0x168 },
- { 0x90116, 0x0 },
- { 0x90117, 0x1d8 },
- { 0x90118, 0x169 },
- { 0x90119, 0x80 },
- { 0x9011a, 0x790 },
- { 0x9011b, 0x16a },
- { 0x9011c, 0x18 },
- { 0x9011d, 0x7aa },
- { 0x9011e, 0x6a },
- { 0x9011f, 0xa },
- { 0x90120, 0x0 },
- { 0x90121, 0x1e9 },
- { 0x90122, 0x8 },
- { 0x90123, 0x8080 },
- { 0x90124, 0x108 },
- { 0x90125, 0xf },
- { 0x90126, 0x408 },
- { 0x90127, 0x169 },
- { 0x90128, 0xc },
- { 0x90129, 0x0 },
- { 0x9012a, 0x68 },
- { 0x9012b, 0x9 },
- { 0x9012c, 0x0 },
- { 0x9012d, 0x1a9 },
- { 0x9012e, 0x0 },
- { 0x9012f, 0x408 },
- { 0x90130, 0x169 },
- { 0x90131, 0x0 },
- { 0x90132, 0x8080 },
- { 0x90133, 0x108 },
- { 0x90134, 0x8 },
- { 0x90135, 0x7aa },
- { 0x90136, 0x6a },
- { 0x90137, 0x0 },
- { 0x90138, 0x8568 },
- { 0x90139, 0x108 },
- { 0x9013a, 0xb7 },
- { 0x9013b, 0x790 },
- { 0x9013c, 0x16a },
- { 0x9013d, 0x1f },
- { 0x9013e, 0x0 },
- { 0x9013f, 0x68 },
- { 0x90140, 0x8 },
- { 0x90141, 0x8558 },
- { 0x90142, 0x168 },
- { 0x90143, 0xf },
- { 0x90144, 0x408 },
- { 0x90145, 0x169 },
- { 0x90146, 0xc },
- { 0x90147, 0x0 },
- { 0x90148, 0x68 },
- { 0x90149, 0x0 },
- { 0x9014a, 0x408 },
- { 0x9014b, 0x169 },
- { 0x9014c, 0x0 },
- { 0x9014d, 0x8558 },
- { 0x9014e, 0x168 },
- { 0x9014f, 0x8 },
- { 0x90150, 0x3c8 },
- { 0x90151, 0x1a9 },
- { 0x90152, 0x3 },
- { 0x90153, 0x370 },
- { 0x90154, 0x129 },
- { 0x90155, 0x20 },
- { 0x90156, 0x2aa },
- { 0x90157, 0x9 },
- { 0x90158, 0x0 },
- { 0x90159, 0x400 },
- { 0x9015a, 0x10e },
- { 0x9015b, 0x8 },
- { 0x9015c, 0xe8 },
- { 0x9015d, 0x109 },
- { 0x9015e, 0x0 },
- { 0x9015f, 0x8140 },
- { 0x90160, 0x10c },
- { 0x90161, 0x10 },
- { 0x90162, 0x8138 },
- { 0x90163, 0x10c },
- { 0x90164, 0x8 },
- { 0x90165, 0x7c8 },
- { 0x90166, 0x101 },
- { 0x90167, 0x8 },
- { 0x90168, 0x0 },
- { 0x90169, 0x8 },
- { 0x9016a, 0x8 },
- { 0x9016b, 0x448 },
- { 0x9016c, 0x109 },
- { 0x9016d, 0xf },
- { 0x9016e, 0x7c0 },
- { 0x9016f, 0x109 },
- { 0x90170, 0x0 },
- { 0x90171, 0xe8 },
- { 0x90172, 0x109 },
- { 0x90173, 0x47 },
- { 0x90174, 0x630 },
- { 0x90175, 0x109 },
- { 0x90176, 0x8 },
- { 0x90177, 0x618 },
- { 0x90178, 0x109 },
- { 0x90179, 0x8 },
- { 0x9017a, 0xe0 },
- { 0x9017b, 0x109 },
- { 0x9017c, 0x0 },
- { 0x9017d, 0x7c8 },
- { 0x9017e, 0x109 },
- { 0x9017f, 0x8 },
- { 0x90180, 0x8140 },
- { 0x90181, 0x10c },
- { 0x90182, 0x0 },
- { 0x90183, 0x1 },
- { 0x90184, 0x8 },
- { 0x90185, 0x8 },
- { 0x90186, 0x4 },
- { 0x90187, 0x8 },
- { 0x90188, 0x8 },
- { 0x90189, 0x7c8 },
- { 0x9018a, 0x101 },
- { 0x90006, 0x0 },
- { 0x90007, 0x0 },
- { 0x90008, 0x8 },
- { 0x90009, 0x0 },
- { 0x9000a, 0x0 },
- { 0x9000b, 0x0 },
- { 0xd00e7, 0x400 },
- { 0x90017, 0x0 },
- { 0x9001f, 0x2a },
- { 0x90026, 0x6a },
- { 0x400d0, 0x0 },
- { 0x400d1, 0x101 },
- { 0x400d2, 0x105 },
- { 0x400d3, 0x107 },
- { 0x400d4, 0x10f },
- { 0x400d5, 0x202 },
- { 0x400d6, 0x20a },
- { 0x400d7, 0x20b },
- { 0x2003a, 0x2 },
- { 0x2000b, 0x64 },
- { 0x2000c, 0xc8 },
- { 0x2000d, 0x7d0 },
- { 0x2000e, 0x2c },
- { 0x12000b, 0xc },
- { 0x12000c, 0x19 },
- { 0x12000d, 0xfa },
- { 0x12000e, 0x10 },
- { 0x22000b, 0x3 },
- { 0x22000c, 0x6 },
- { 0x22000d, 0x3e },
- { 0x22000e, 0x10 },
- { 0x9000c, 0x0 },
- { 0x9000d, 0x173 },
- { 0x9000e, 0x60 },
- { 0x9000f, 0x6110 },
- { 0x90010, 0x2152 },
- { 0x90011, 0xdfbd },
- { 0x90012, 0x60 },
- { 0x90013, 0x6152 },
- { 0x20010, 0x5a },
- { 0x20011, 0x3 },
- { 0x120010, 0x5a },
- { 0x120011, 0x3 },
- { 0x220010, 0x5a },
- { 0x220011, 0x3 },
- { 0x40080, 0xe0 },
- { 0x40081, 0x12 },
- { 0x40082, 0xe0 },
- { 0x40083, 0x12 },
- { 0x40084, 0xe0 },
- { 0x40085, 0x12 },
- { 0x140080, 0xe0 },
- { 0x140081, 0x12 },
- { 0x140082, 0xe0 },
- { 0x140083, 0x12 },
- { 0x140084, 0xe0 },
- { 0x140085, 0x12 },
- { 0x240080, 0xe0 },
- { 0x240081, 0x12 },
- { 0x240082, 0xe0 },
- { 0x240083, 0x12 },
- { 0x240084, 0xe0 },
- { 0x240085, 0x12 },
- { 0x400fd, 0xf },
- { 0x10011, 0x1 },
- { 0x10012, 0x1 },
- { 0x10013, 0x180 },
- { 0x10018, 0x1 },
- { 0x10002, 0x6209 },
- { 0x100b2, 0x1 },
- { 0x101b4, 0x1 },
- { 0x102b4, 0x1 },
- { 0x103b4, 0x1 },
- { 0x104b4, 0x1 },
- { 0x105b4, 0x1 },
- { 0x106b4, 0x1 },
- { 0x107b4, 0x1 },
- { 0x108b4, 0x1 },
- { 0x11011, 0x1 },
- { 0x11012, 0x1 },
- { 0x11013, 0x180 },
- { 0x11018, 0x1 },
- { 0x11002, 0x6209 },
- { 0x110b2, 0x1 },
- { 0x111b4, 0x1 },
- { 0x112b4, 0x1 },
- { 0x113b4, 0x1 },
- { 0x114b4, 0x1 },
- { 0x115b4, 0x1 },
- { 0x116b4, 0x1 },
- { 0x117b4, 0x1 },
- { 0x118b4, 0x1 },
- { 0x12011, 0x1 },
- { 0x12012, 0x1 },
- { 0x12013, 0x180 },
- { 0x12018, 0x1 },
- { 0x12002, 0x6209 },
- { 0x120b2, 0x1 },
- { 0x121b4, 0x1 },
- { 0x122b4, 0x1 },
- { 0x123b4, 0x1 },
- { 0x124b4, 0x1 },
- { 0x125b4, 0x1 },
- { 0x126b4, 0x1 },
- { 0x127b4, 0x1 },
- { 0x128b4, 0x1 },
- { 0x13011, 0x1 },
- { 0x13012, 0x1 },
- { 0x13013, 0x180 },
- { 0x13018, 0x1 },
- { 0x13002, 0x6209 },
- { 0x130b2, 0x1 },
- { 0x131b4, 0x1 },
- { 0x132b4, 0x1 },
- { 0x133b4, 0x1 },
- { 0x134b4, 0x1 },
- { 0x135b4, 0x1 },
- { 0x136b4, 0x1 },
- { 0x137b4, 0x1 },
- { 0x138b4, 0x1 },
- { 0x2003a, 0x2 },
- { 0xc0080, 0x2 },
- { 0xd0000, 0x1 }
+static struct dram_fsp_msg ddr_dram_fsp_msg[] = {
/* P0 3200mts 1D */
.drate = 3200,
.fw_type = FW_1D_IMAGE,
.fsp_cfg = ddr_fsp0_cfg,
.fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_cfg),
/* P1 400mts 1D */
.drate = 400,
.fsp_cfg = ddr_fsp1_cfg,
.fsp_cfg_num = ARRAY_SIZE(ddr_fsp1_cfg),
/* P2 100mts 1D */
.drate = 100,
.fsp_cfg = ddr_fsp2_cfg,
.fsp_cfg_num = ARRAY_SIZE(ddr_fsp2_cfg),
/* P0 3200mts 2D */
.drate = 3200,
.fw_type = FW_2D_IMAGE,
.fsp_cfg = ddr_fsp0_2d_cfg,
.fsp_cfg_num = ARRAY_SIZE(ddr_fsp0_2d_cfg),
+/* ddr timing config params */ +struct dram_timing_info dram_timing_2gb = {
- .ddrc_cfg = ddr_ddrc_cfg,
- .ddrc_cfg_num = ARRAY_SIZE(ddr_ddrc_cfg),
- .ddrphy_cfg = ddr_ddrphy_cfg,
- .ddrphy_cfg_num = ARRAY_SIZE(ddr_ddrphy_cfg),
- .fsp_msg = ddr_dram_fsp_msg,
- .fsp_msg_num = ARRAY_SIZE(ddr_dram_fsp_msg),
- .ddrphy_trained_csr = ddr_ddrphy_trained_csr,
- .ddrphy_trained_csr_num = ARRAY_SIZE(ddr_ddrphy_trained_csr),
- .ddrphy_pie = ddr_phy_pie,
- .ddrphy_pie_num = ARRAY_SIZE(ddr_phy_pie),
- .fsp_table = { 3200, 400, 100, },
diff --git a/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c new file mode 100644 index 0000000000..fd7173bff1 --- /dev/null +++ b/board/kontron/pitx_imx8m/lpddr4_timing_4gb.c @@ -0,0 +1,1853 @@ +// SPDX-License-Identifier: GPL-2.0+
- { 0x3d400000, 0xa3080020 },
- { 0x3d400200, 0x17 },
+/* PHY Initialize Configuration */ +struct dram_cfg_param ddr_ddrphy_cfg[] = {
- { 0x100a0, 0x2 },
- { 0x100a1, 0x3 },
- { 0x100a2, 0x0 },
- { 0x100a3, 0x1 },
- { 0x100a4, 0x5 },
- { 0x100a5, 0x7 },
- { 0x100a6, 0x6 },
- { 0x100a7, 0x4 },
- { 0x110a0, 0x2 },
- { 0x110a1, 0x1 },
- { 0x110a2, 0x3 },
- { 0x110a3, 0x0 },
- { 0x110a4, 0x6 },
- { 0x110a5, 0x7 },
- { 0x110a6, 0x4 },
- { 0x110a7, 0x5 },
- { 0x120a0, 0x4 },
- { 0x120a1, 0x5 },
- { 0x120a2, 0x7 },
- { 0x120a3, 0x6 },
- { 0x120a4, 0x1 },
- { 0x120a5, 0x3 },
- { 0x120a6, 0x2 },
- { 0x120a7, 0x0 },
- { 0x130a0, 0x4 },
- { 0x130a1, 0x5 },
- { 0x130a2, 0x7 },
- { 0x130a3, 0x6 },
- { 0x130a4, 0x2 },
- { 0x130a5, 0x1 },
- { 0x130a6, 0x0 },
- { 0x130a7, 0x3 },
- { 0x55, 0x1ff },
- { 0x2002e, 0x2 },
- { 0x90204, 0x0 },
- { 0x2003a, 0x0 },
- { 0x2003a, 0x0 },
- { 0x2003a, 0x0 },
- { 0x20056, 0x3 },
- { 0x43, 0x63 },
- { 0x1043, 0x63 },
- { 0x2043, 0x63 },
- { 0x3043, 0x63 },
- { 0x4043, 0x63 },
- { 0x5043, 0x63 },
- { 0x6043, 0x63 },
- { 0x7043, 0x63 },
- { 0x8043, 0x63 },
- { 0x9043, 0x63 },
- { 0x20018, 0x3 },
- { 0x20075, 0x4 },
- { 0x20050, 0x0 },
- { 0x20088, 0x9 },
- { 0x200fa, 0x1 },
- { 0x20019, 0x1 },
- { 0x200f1, 0x0 },
- { 0x200f5, 0x0 },
- { 0x200f6, 0x0 },
- { 0x20025, 0x0 },
- { 0x2002d, 0x0 },
- { 0x20110, 0x2 },
- { 0x20111, 0x3 },
- { 0x20112, 0x4 },
- { 0x20113, 0x5 },
- { 0x20114, 0x0 },
- { 0x20115, 0x1 },
+/* ddr phy trained csr */ +struct dram_cfg_param ddr_ddrphy_trained_csr[] = {
- { 0x200b2, 0x0 },
- { 0x200cb, 0x0 },
- { 0x10043, 0x0 },
- { 0x10143, 0x0 },
- { 0x11043, 0x0 },
- { 0x11143, 0x0 },
- { 0x12043, 0x0 },
- { 0x12143, 0x0 },
- { 0x13043, 0x0 },
- { 0x13143, 0x0 },
- { 0x80, 0x0 },
- { 0x1080, 0x0 },
- { 0x2080, 0x0 },
- { 0x3080, 0x0 },
- { 0x4080, 0x0 },
- { 0x5080, 0x0 },
- { 0x6080, 0x0 },
- { 0x7080, 0x0 },
- { 0x8080, 0x0 },
- { 0x9080, 0x0 },
- { 0x10080, 0x0 },
- { 0x10180, 0x0 },
- { 0x11080, 0x0 },
- { 0x11180, 0x0 },
- { 0x12080, 0x0 },
- { 0x12180, 0x0 },
- { 0x13080, 0x0 },
- { 0x13180, 0x0 },
- { 0x10081, 0x0 },
- { 0x10181, 0x0 },
- { 0x11081, 0x0 },
- { 0x11181, 0x0 },
- { 0x12081, 0x0 },
- { 0x12181, 0x0 },
- { 0x13081, 0x0 },
- { 0x13181, 0x0 },
- { 0x100d0, 0x0 },
- { 0x101d0, 0x0 },
- { 0x110d0, 0x0 },
- { 0x111d0, 0x0 },
- { 0x120d0, 0x0 },
- { 0x121d0, 0x0 },
- { 0x130d0, 0x0 },
- { 0x131d0, 0x0 },
- { 0x100d1, 0x0 },
- { 0x101d1, 0x0 },
- { 0x110d1, 0x0 },
- { 0x111d1, 0x0 },
- { 0x120d1, 0x0 },
- { 0x121d1, 0x0 },
- { 0x130d1, 0x0 },
- { 0x131d1, 0x0 },
- { 0x10068, 0x0 },
- { 0x10168, 0x0 },
- { 0x10268, 0x0 },
- { 0x10368, 0x0 },
- { 0x10468, 0x0 },
- { 0x10568, 0x0 },
- { 0x10668, 0x0 },
- { 0x10768, 0x0 },
- { 0x10868, 0x0 },
- { 0x11068, 0x0 },
- { 0x11168, 0x0 },
- { 0x11268, 0x0 },
- { 0x11368, 0x0 },
- { 0x11468, 0x0 },
- { 0x11568, 0x0 },
- { 0x11668, 0x0 },
- { 0x11768, 0x0 },
- { 0x11868, 0x0 },
- { 0x12068, 0x0 },
- { 0x12168, 0x0 },
- { 0x12268, 0x0 },
- { 0x12368, 0x0 },
- { 0x12468, 0x0 },
- { 0x12568, 0x0 },
- { 0x12668, 0x0 },
- { 0x12768, 0x0 },
- { 0x12868, 0x0 },
- { 0x13068, 0x0 },
- { 0x13168, 0x0 },
- { 0x13268, 0x0 },
- { 0x13368, 0x0 },
- { 0x13468, 0x0 },
- { 0x13568, 0x0 },
- { 0x13668, 0x0 },
- { 0x13768, 0x0 },
- { 0x13868, 0x0 },
- { 0x10069, 0x0 },
- { 0x10169, 0x0 },
- { 0x10269, 0x0 },
- { 0x10369, 0x0 },
- { 0x10469, 0x0 },
- { 0x10569, 0x0 },
- { 0x10669, 0x0 },
- { 0x10769, 0x0 },
- { 0x10869, 0x0 },
- { 0x11069, 0x0 },
- { 0x11169, 0x0 },
- { 0x11269, 0x0 },
- { 0x11369, 0x0 },
- { 0x11469, 0x0 },
- { 0x11569, 0x0 },
- { 0x11669, 0x0 },
- { 0x11769, 0x0 },
- { 0x11869, 0x0 },
- { 0x12069, 0x0 },
- { 0x12169, 0x0 },
- { 0x12269, 0x0 },
- { 0x12369, 0x0 },
- { 0x12469, 0x0 },
- { 0x12569, 0x0 },
- { 0x12669, 0x0 },
- { 0x12769, 0x0 },
- { 0x12869, 0x0 },
- { 0x13069, 0x0 },
- { 0x13169, 0x0 },
- { 0x13269, 0x0 },
- { 0x13369, 0x0 },
- { 0x13469, 0x0 },
- { 0x13569, 0x0 },
- { 0x13669, 0x0 },
- { 0x13769, 0x0 },
- { 0x13869, 0x0 },
- { 0x1008c, 0x0 },
- { 0x1018c, 0x0 },
- { 0x1108c, 0x0 },
- { 0x1118c, 0x0 },
- { 0x1208c, 0x0 },
- { 0x1218c, 0x0 },
- { 0x1308c, 0x0 },
- { 0x1318c, 0x0 },
- { 0x1008d, 0x0 },
- { 0x1018d, 0x0 },
- { 0x1108d, 0x0 },
- { 0x1118d, 0x0 },
- { 0x1208d, 0x0 },
- { 0x1218d, 0x0 },
- { 0x1308d, 0x0 },
- { 0x1318d, 0x0 },
- { 0x100c0, 0x0 },
- { 0x101c0, 0x0 },
- { 0x102c0, 0x0 },
- { 0x103c0, 0x0 },
- { 0x104c0, 0x0 },
- { 0x105c0, 0x0 },
- { 0x106c0, 0x0 },
- { 0x107c0, 0x0 },
- { 0x108c0, 0x0 },
- { 0x110c0, 0x0 },
- { 0x111c0, 0x0 },
- { 0x112c0, 0x0 },
- { 0x113c0, 0x0 },
- { 0x114c0, 0x0 },
- { 0x115c0, 0x0 },
- { 0x116c0, 0x0 },
- { 0x117c0, 0x0 },
- { 0x118c0, 0x0 },
- { 0x120c0, 0x0 },
- { 0x121c0, 0x0 },
- { 0x122c0, 0x0 },
- { 0x123c0, 0x0 },
- { 0x124c0, 0x0 },
- { 0x125c0, 0x0 },
- { 0x126c0, 0x0 },
- { 0x127c0, 0x0 },
- { 0x128c0, 0x0 },
- { 0x130c0, 0x0 },
- { 0x131c0, 0x0 },
- { 0x132c0, 0x0 },
- { 0x133c0, 0x0 },
- { 0x134c0, 0x0 },
- { 0x135c0, 0x0 },
- { 0x136c0, 0x0 },
- { 0x137c0, 0x0 },
- { 0x138c0, 0x0 },
- { 0x100c1, 0x0 },
- { 0x101c1, 0x0 },
- { 0x102c1, 0x0 },
- { 0x103c1, 0x0 },
- { 0x104c1, 0x0 },
- { 0x105c1, 0x0 },
- { 0x106c1, 0x0 },
- { 0x107c1, 0x0 },
- { 0x108c1, 0x0 },
- { 0x110c1, 0x0 },
- { 0x111c1, 0x0 },
- { 0x112c1, 0x0 },
- { 0x113c1, 0x0 },
- { 0x114c1, 0x0 },
- { 0x115c1, 0x0 },
- { 0x116c1, 0x0 },
- { 0x117c1, 0x0 },
- { 0x118c1, 0x0 },
- { 0x120c1, 0x0 },
- { 0x121c1, 0x0 },
- { 0x122c1, 0x0 },
- { 0x123c1, 0x0 },
- { 0x124c1, 0x0 },
- { 0x125c1, 0x0 },
- { 0x126c1, 0x0 },
- { 0x127c1, 0x0 },
- { 0x128c1, 0x0 },
- { 0x130c1, 0x0 },
- { 0x131c1, 0x0 },
- { 0x132c1, 0x0 },
- { 0x133c1, 0x0 },
- { 0x134c1, 0x0 },
- { 0x135c1, 0x0 },
- { 0x136c1, 0x0 },
- { 0x137c1, 0x0 },
- { 0x138c1, 0x0 },
- { 0x10020, 0x0 },
- { 0x11020, 0x0 },
- { 0x12020, 0x0 },
- { 0x13020, 0x0 },
- { 0x20072, 0x0 },
- { 0x20073, 0x0 },
- { 0x20074, 0x0 },
- { 0x100aa, 0x0 },
- { 0x110aa, 0x0 },
- { 0x120aa, 0x0 },
- { 0x130aa, 0x0 },
- { 0x20010, 0x0 },
- { 0x20011, 0x0 },
- { 0x100ae, 0x0 },
- { 0x100af, 0x0 },
- { 0x110ae, 0x0 },
- { 0x110af, 0x0 },
- { 0x120ae, 0x0 },
- { 0x120af, 0x0 },
- { 0x130ae, 0x0 },
- { 0x130af, 0x0 },
- { 0x20020, 0x0 },
- { 0x100a0, 0x0 },
- { 0x100a1, 0x0 },
- { 0x100a2, 0x0 },
- { 0x100a3, 0x0 },
- { 0x100a4, 0x0 },
- { 0x100a5, 0x0 },
- { 0x100a6, 0x0 },
- { 0x100a7, 0x0 },
- { 0x110a0, 0x0 },
- { 0x110a1, 0x0 },
- { 0x110a2, 0x0 },
- { 0x110a3, 0x0 },
- { 0x110a4, 0x0 },
- { 0x110a5, 0x0 },
- { 0x110a6, 0x0 },
- { 0x110a7, 0x0 },
- { 0x120a0, 0x0 },
- { 0x120a1, 0x0 },
- { 0x120a2, 0x0 },
- { 0x120a3, 0x0 },
- { 0x120a4, 0x0 },
- { 0x120a5, 0x0 },
- { 0x120a6, 0x0 },
- { 0x120a7, 0x0 },
- { 0x130a0, 0x0 },
- { 0x130a1, 0x0 },
- { 0x130a2, 0x0 },
- { 0x130a3, 0x0 },
- { 0x130a4, 0x0 },
- { 0x130a5, 0x0 },
- { 0x130a6, 0x0 },
- { 0x130a7, 0x0 },
- { 0x2007c, 0x0 },
- { 0x2007d, 0x0 },
- { 0x400fd, 0x0 },
- { 0x400c0, 0x0 },
- { 0x90201, 0x0 },
- { 0x90202, 0x0 },
- { 0x90203, 0x0 },
- { 0x90204, 0x0 },
- { 0x90205, 0x0 },
- { 0x90206, 0x0 },
- { 0x90207, 0x0 },
- { 0x90208, 0x0 },
- { 0x10062, 0x0 },
- { 0x10162, 0x0 },
- { 0x10262, 0x0 },
- { 0x10362, 0x0 },
- { 0x10462, 0x0 },
- { 0x10562, 0x0 },
- { 0x10662, 0x0 },
- { 0x10762, 0x0 },
- { 0x10862, 0x0 },
- { 0x11062, 0x0 },
- { 0x11162, 0x0 },
- { 0x11262, 0x0 },
- { 0x11362, 0x0 },
- { 0x11462, 0x0 },
- { 0x11562, 0x0 },
- { 0x11662, 0x0 },
- { 0x11762, 0x0 },
- { 0x11862, 0x0 },
- { 0x12062, 0x0 },
- { 0x12162, 0x0 },
- { 0x12262, 0x0 },
- { 0x12362, 0x0 },
- { 0x12462, 0x0 },
- { 0x12562, 0x0 },
- { 0x12662, 0x0 },
- { 0x12762, 0x0 },
- { 0x12862, 0x0 },
- { 0x13062, 0x0 },
- { 0x13162, 0x0 },
- { 0x13262, 0x0 },
- { 0x13362, 0x0 },
- { 0x13462, 0x0 },
- { 0x13562, 0x0 },
- { 0x13662, 0x0 },
- { 0x13762, 0x0 },
- { 0x13862, 0x0 },
- { 0x20077, 0x0 },
- { 0x10001, 0x0 },
- { 0x11001, 0x0 },
- { 0x12001, 0x0 },
- { 0x13001, 0x0 },
- { 0x10040, 0x0 },
- { 0x10140, 0x0 },
- { 0x10240, 0x0 },
- { 0x10340, 0x0 },
- { 0x10440, 0x0 },
- { 0x10540, 0x0 },
- { 0x10640, 0x0 },
- { 0x10740, 0x0 },
- { 0x10840, 0x0 },
- { 0x10030, 0x0 },
- { 0x10130, 0x0 },
- { 0x10230, 0x0 },
- { 0x10330, 0x0 },
- { 0x10430, 0x0 },
- { 0x10530, 0x0 },
- { 0x10630, 0x0 },
- { 0x10730, 0x0 },
- { 0x10830, 0x0 },
- { 0x11040, 0x0 },
- { 0x11140, 0x0 },
- { 0x11240, 0x0 },
- { 0x11340, 0x0 },
- { 0x11440, 0x0 },
- { 0x11540, 0x0 },
- { 0x11640, 0x0 },
- { 0x11740, 0x0 },
- { 0x11840, 0x0 },
- { 0x11030, 0x0 },
- { 0x11130, 0x0 },
- { 0x11230, 0x0 },
- { 0x11330, 0x0 },
- { 0x11430, 0x0 },
- { 0x11530, 0x0 },
- { 0x11630, 0x0 },
- { 0x11730, 0x0 },
- { 0x11830, 0x0 },
- { 0x12040, 0x0 },
- { 0x12140, 0x0 },
- { 0x12240, 0x0 },
- { 0x12340, 0x0 },
- { 0x12440, 0x0 },
- { 0x12540, 0x0 },
- { 0x12640, 0x0 },
- { 0x12740, 0x0 },
- { 0x12840, 0x0 },
- { 0x12030, 0x0 },
- { 0x12130, 0x0 },
- { 0x12230, 0x0 },
- { 0x12330, 0x0 },
- { 0x12430, 0x0 },
- { 0x12530, 0x0 },
- { 0x12630, 0x0 },
- { 0x12730, 0x0 },
- { 0x12830, 0x0 },
- { 0x13040, 0x0 },
- { 0x13140, 0x0 },
- { 0x13240, 0x0 },
- { 0x13340, 0x0 },
- { 0x13440, 0x0 },
- { 0x13540, 0x0 },
- { 0x13640, 0x0 },
- { 0x13740, 0x0 },
- { 0x13840, 0x0 },
- { 0x13030, 0x0 },
- { 0x13130, 0x0 },
- { 0x13230, 0x0 },
- { 0x13330, 0x0 },
- { 0x13430, 0x0 },
- { 0x13530, 0x0 },
- { 0x13630, 0x0 },
- { 0x13730, 0x0 },
- { 0x13830, 0x0 },
+/* P0 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54004, 0x2 },
- { 0x5400b, 0x2 },
- { 0x54012, 0x310 },
- { 0x5402c, 0x3 },
- { 0xd0000, 0x1 },
+/* P1 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp1_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54004, 0x2 },
- { 0x5400b, 0x2 },
- { 0x5402c, 0x3 },
- { 0xd0000, 0x1 },
+/* P2 message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp2_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54004, 0x2 },
- { 0x5400b, 0x2 },
- { 0x5402c, 0x3 },
- { 0xd0000, 0x1 },
+/* P0 2D message block paremeter for training firmware */ +struct dram_cfg_param ddr_fsp0_2d_cfg[] = {
- { 0xd0000, 0x0 },
- { 0x54004, 0x2 },
- { 0x5400b, 0x2 },
- { 0x5402c, 0x3 },
- { 0xd0000, 0x1 },
+/* DRAM PHY init engine image */ +struct dram_cfg_param ddr_phy_pie[] = {
- { 0xd0000, 0x0 },
- { 0x90003, 0x0 },
- { 0x90004, 0x0 },
- { 0x90005, 0x8 },
- { 0x90029, 0xb },
- { 0x9002c, 0x8 },
- { 0x9002f, 0x8 },
- { 0x90032, 0x0 },
- { 0x90035, 0x2 },
- { 0x90038, 0xf },
- { 0x90047, 0x8 },
- { 0x9004a, 0x0 },
- { 0x9004d, 0x0 },
- { 0x9004e, 0x1 },
- { 0x9004f, 0x8 },
- { 0x90050, 0x0 },
- { 0x90052, 0x9 },
- { 0x90053, 0x0 },
- { 0x90059, 0x1 },
- { 0x9005f, 0x8 },
- { 0x90060, 0x4 },
- { 0x90065, 0x0 },
- { 0x90066, 0x4 },
- { 0x9006c, 0x4 },
- { 0x9006e, 0x0 },
- { 0x9006f, 0x4 },
- { 0x90080, 0x1 },
- { 0x90083, 0x0 },
- { 0x90086, 0xa },
- { 0x90089, 0x9 },
- { 0x9008c, 0x9 },
- { 0x90092, 0x0 },
- { 0x90096, 0x4 },
- { 0x90099, 0x4 },
- { 0x9009b, 0xa },
- { 0x9009e, 0x2 },
- { 0x900a1, 0x5 },
- { 0x40040, 0x0 },
- { 0x40060, 0x0 },
- { 0x40061, 0x0 },
- { 0x40062, 0x0 },
- { 0x40043, 0x0 },
- { 0x40063, 0x0 },
- { 0x40024, 0xf },
- { 0x40064, 0x0 },
- { 0x40065, 0x0 },
- { 0x40026, 0xf },
- { 0x40066, 0x0 },
- { 0x40027, 0xf },
- { 0x40067, 0x0 },
- { 0x40028, 0xf },
- { 0x40068, 0x0 },
- { 0x40029, 0xf },
- { 0x40069, 0x0 },
- { 0x4004a, 0x0 },
- { 0x4006a, 0x0 },
- { 0x4004b, 0x0 },
- { 0x4006b, 0x0 },
- { 0x4004c, 0x0 },
- { 0x4006c, 0x0 },
- { 0x4004d, 0x0 },
- { 0x4006d, 0x0 },
- { 0x4004e, 0x0 },
- { 0x4006e, 0x0 },
- { 0x4004f, 0x0 },
- { 0x4006f, 0x0 },
- { 0x40050, 0x0 },
- { 0x40070, 0x0 },
- { 0x40031, 0x5 },
- { 0x40051, 0x0 },
- { 0x40012, 0x8 },
- { 0x40052, 0x0 },
- { 0x40072, 0x0 },
- { 0x40053, 0x0 },
- { 0x40073, 0x0 },
- { 0x40034, 0xa },
- { 0x40054, 0x0 },
- { 0x40055, 0x0 },
- { 0x40075, 0x0 },
- { 0x40076, 0x0 },
- { 0x40077, 0x0 },
- { 0x40078, 0x0 },
- { 0x40079, 0x0 },
- { 0x4005a, 0x0 },
- { 0x4007a, 0x0 },
- { 0x900a7, 0x0 },
- { 0x900aa, 0x8 },
- { 0x900b0, 0x0 },
- { 0x900b6, 0x8 },
- { 0x900b9, 0xa },
- { 0x900bc, 0xc },
- { 0x900c2, 0x8 },
- { 0x900c3, 0x4 },
- { 0x900c5, 0xe },
- { 0x900c8, 0x8 },
- { 0x900ce, 0x8 },
- { 0x900e0, 0x8 },
- { 0x900e3, 0x8 },
- { 0x900e6, 0xa },
- { 0x900ea, 0x0 },
- { 0x900ec, 0x0 },
- { 0x900ef, 0x0 },
- { 0x900f2, 0x0 },
- { 0x90101, 0x8 },
- { 0x90104, 0x8 },
- { 0x90107, 0xa },
- { 0x9010b, 0x0 },
- { 0x9010d, 0x0 },
- { 0x90110, 0x0 },
- { 0x90113, 0x0 },
- { 0x90116, 0x0 },
- { 0x9011f, 0xa },
- { 0x90120, 0x0 },
- { 0x90122, 0x8 },
- { 0x90125, 0xf },
- { 0x90128, 0xc },
- { 0x90129, 0x0 },
- { 0x9012b, 0x9 },
- { 0x9012c, 0x0 },
- { 0x9012e, 0x0 },
- { 0x90131, 0x0 },
- { 0x90134, 0x8 },
- { 0x90137, 0x0 },
- { 0x9013e, 0x0 },
- { 0x90140, 0x8 },
- { 0x90143, 0xf },
- { 0x90146, 0xc },
- { 0x90147, 0x0 },
- { 0x90149, 0x0 },
- { 0x9014c, 0x0 },
- { 0x9014f, 0x8 },
- { 0x90152, 0x3 },
- { 0x90157, 0x9 },
- { 0x90158, 0x0 },
- { 0x9015b, 0x8 },
- { 0x9015e, 0x0 },
- { 0x90164, 0x8 },
- { 0x90167, 0x8 },
- { 0x90168, 0x0 },
- { 0x90169, 0x8 },
- { 0x9016a, 0x8 },
- { 0x9016d, 0xf },
- { 0x90170, 0x0 },
- { 0x90176, 0x8 },
- { 0x90179, 0x8 },
- { 0x9017c, 0x0 },
- { 0x9017f, 0x8 },
- { 0x90182, 0x0 },
- { 0x90183, 0x1 },
- { 0x90184, 0x8 },
- { 0x90185, 0x8 },
- { 0x90186, 0x4 },
- { 0x90187, 0x8 },
- { 0x90188, 0x8 },
- { 0x90006, 0x0 },
- { 0x90007, 0x0 },
- { 0x90008, 0x8 },
- { 0x90009, 0x0 },
- { 0x9000a, 0x0 },
- { 0x9000b, 0x0 },
- { 0x90017, 0x0 },
- { 0x400d0, 0x0 },
- { 0x2003a, 0x2 },
- { 0x9000c, 0x0 },
- { 0x20011, 0x3 },
- { 0x400fd, 0xf },
- { 0x10011, 0x1 },
- { 0x10012, 0x1 },
- { 0x10018, 0x1 },
- { 0x100b2, 0x1 },
- { 0x101b4, 0x1 },
- { 0x102b4, 0x1 },
- { 0x103b4, 0x1 },
- { 0x104b4, 0x1 },
- { 0x105b4, 0x1 },
- { 0x106b4, 0x1 },
- { 0x107b4, 0x1 },
- { 0x108b4, 0x1 },
- { 0x11011, 0x1 },
- { 0x11012, 0x1 },
- { 0x11018, 0x1 },
- { 0x110b2, 0x1 },
- { 0x111b4, 0x1 },
- { 0x112b4, 0x1 },
- { 0x113b4, 0x1 },
- { 0x114b4, 0x1 },
- { 0x115b4, 0x1 },
- { 0x116b4, 0x1 },
- { 0x117b4, 0x1 },
- { 0x118b4, 0x1 },
- { 0x12011, 0x1 },
- { 0x12012, 0x1 },
- { 0x12018, 0x1 },
- { 0x120b2, 0x1 },
- { 0x121b4, 0x1 },
- { 0x122b4, 0x1 },
- { 0x123b4, 0x1 },
- { 0x124b4, 0x1 },
- { 0x125b4, 0x1 },
- { 0x126b4, 0x1 },
- { 0x127b4, 0x1 },
- { 0x128b4, 0x1 },
- { 0x13011, 0x1 },
- { 0x13012, 0x1 },
- { 0x13018, 0x1 },
- { 0x130b2, 0x1 },
- { 0x131b4, 0x1 },
- { 0x132b4, 0x1 },
- { 0x133b4, 0x1 },
- { 0x134b4, 0x1 },
- { 0x135b4, 0x1 },
- { 0x136b4, 0x1 },
- { 0x137b4, 0x1 },
- { 0x138b4, 0x1 },
- { 0x2003a, 0x2 },
- { 0xc0080, 0x2 },
- { 0xd0000, 0x1 }
+struct dram_fsp_msg ddr_dram_fsp_msg[] = {
/* P0 3200mts 1D */
.drate = 3200,
/* P1 400mts 1D */
.drate = 400,
/* P2 100mts 1D */
.drate = 100,
/* P0 3200mts 2D */
.drate = 3200,
+/* ddr timing config params */ +struct dram_timing_info dram_timing_4gb = {
diff --git a/board/kontron/pitx_imx8m/pitx_imx8m.c b/board/kontron/pitx_imx8m/pitx_imx8m.c new file mode 100644 index 0000000000..b4d35fd2bb --- /dev/null +++ b/board/kontron/pitx_imx8m/pitx_imx8m.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0+
+#include <common.h> +#include <init.h> +#include <miiphy.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm-generic/gpio.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/iomux-v3.h> +#include <linux/delay.h>
+DECLARE_GLOBAL_DATA_PTR;
+#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) +#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE)
+static iomux_v3_cfg_t const wdog_pads[] = {
- IMX8MQ_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL),
+static iomux_v3_cfg_t const uart_pads[] = {
- IMX8MQ_PAD_UART3_RXD__UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_UART3_TXD__UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_ECSPI1_SS0__UART3_RTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
- IMX8MQ_PAD_ECSPI1_MISO__UART3_CTS_B | MUX_PAD_CTRL(UART_PAD_CTRL),
+int board_early_init_f(void) +{
- struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
- imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads));
- set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads));
+int board_phys_sdram_size(phys_size_t *memsize) +{
* Get real memory size by testing available memory in a
* given range starting at i.MX8M DRAM1 base address 0x40000000.
- *memsize = get_ram_size((long *)0x40000000, 0x100000000ULL);
- debug("Memsize: %d MiB\n", (int)(*memsize >> 20));
+#ifdef CONFIG_FEC_MXC +#define FEC_RST_PAD IMX_GPIO_NR(1, 11) +static iomux_v3_cfg_t const fec1_rst_pads[] = {
- IMX8MQ_PAD_GPIO1_IO11__GPIO1_IO11 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static void setup_iomux_fec(void) +{
- imx_iomux_v3_setup_multiple_pads(fec1_rst_pads,
ARRAY_SIZE(fec1_rst_pads));
+static int setup_fec(void) +{
- struct iomuxc_gpr_base_regs *gpr =
(struct iomuxc_gpr_base_regs *)IOMUXC_GPR_BASE_ADDR;
- setup_iomux_fec();
- /* Use 125M anatop REF_CLK1 for ENET1, not from external */
- clrsetbits_le32(&gpr->gpr[1], BIT(13) | BIT(17), 0);
- return set_clk_enet(ENET_125MHZ);
+int board_phy_config(struct phy_device *phydev) +{
- unsigned int val;
- /* enable rgmii rxc skew and phy mode select to RGMII copper */
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x1f);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x8);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x05);
- phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, 0x100);
* Set LED configuration register 1:
* LED2_SEL: 0b1011 (link established, blink on activity)
- val = phy_read(phydev, MDIO_DEVAD_NONE, 0x18);
- val &= 0xf0ff;
- phy_write(phydev, MDIO_DEVAD_NONE, 0x18, val | (0xb << 8));
- if (phydev->drv->config)
phydev->drv->config(phydev);
+} +#endif
+int board_init(void) +{ +#ifdef CONFIG_FEC_MXC
- setup_fec();
+#if defined(CONFIG_USB_DWC3) || defined(CONFIG_USB_XHCI_DWC3)
- init_usb_clk();
+#ifdef CONFIG_MISC_INIT_R +#define TPM_RESET IMX_GPIO_NR(3, 2) +#define USBHUB_RESET IMX_GPIO_NR(3, 4)
+static void reset_device_by_gpio(const char *label, int pin, int delay_ms) +{
- gpio_request(pin, label);
- gpio_direction_output(pin, 0);
- mdelay(delay_ms);
- gpio_direction_output(pin, 1);
+int misc_init_r(void) +{
* reset TPM chip (Infineon SLB9670) as required by datasheet
* (60ms minimum Reset Inactive Time, 70ms implemented)
- reset_device_by_gpio("tpm_reset", TPM_RESET, 70);
* reset USB hub as required by datasheet
* (3ms minimum reset duration, 10ms implemented)
- reset_device_by_gpio("usbhub_reset", USBHUB_RESET, 10);
+} +#endif
+int board_mmc_get_env_dev(int devno) +{
- return devno;
+int board_late_init(void) +{
+} diff --git a/board/kontron/pitx_imx8m/spl.c b/board/kontron/pitx_imx8m/spl.c new file mode 100644 index 0000000000..ddf20d5e23 --- /dev/null +++ b/board/kontron/pitx_imx8m/spl.c @@ -0,0 +1,327 @@ +// SPDX-License-Identifier: GPL-2.0+
+#include <common.h> +#include <errno.h> +#include <fsl_esdhc_imx.h> +#include <hang.h> +#include <init.h> +#include <log.h> +#include <spl.h> +#include <asm/arch/ddr.h> +#include <asm/arch/imx8mq_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/clock.h> +#include <asm/global_data.h> +#include <asm/io.h> +#include <asm/mach-imx/iomux-v3.h> +#include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/mxc_i2c.h> +#include <linux/delay.h> +#include <power/pmic.h> +#include <power/pfuze100_pmic.h>
+extern struct dram_timing_info dram_timing_2gb; +extern struct dram_timing_info dram_timing_4gb;
+int pfuze_mode_init(struct pmic *p, u32 mode) +{
- unsigned char offset, i, switch_num;
- u32 id;
- int ret;
- pmic_reg_read(p, PFUZE100_DEVICEID, &id);
- id = id & 0xf;
- if (id == 0) {
switch_num = 6;
offset = PFUZE100_SW1CMODE;
- } else if (id == 1) {
switch_num = 4;
offset = PFUZE100_SW2MODE;
- } else {
printf("Not supported, id=%d\n", id);
return -EINVAL;
- ret = pmic_reg_write(p, PFUZE100_SW1ABMODE, mode);
- if (ret < 0) {
printf("Set SW1AB mode error!\n");
return ret;
- for (i = 0; i < switch_num - 1; i++) {
ret = pmic_reg_write(p, offset + i * SWITCH_SIZE, mode);
if (ret < 0) {
printf("Set switch 0x%x mode error!\n",
offset + i * SWITCH_SIZE);
return ret;
- return ret;
- BRD_REV1 BRD_REV0
0 0 n/a
0 1 n/a
1 0 2GB LPDDR4
1 1 4GB LPDDR4
+#define BRD_REV0 IMX_GPIO_NR(5, 0) +#define BRD_REV1 IMX_GPIO_NR(5, 1)
+static iomux_v3_cfg_t const brdrev_pads[] = {
- IMX8MQ_PAD_SAI3_TXC__GPIO5_IO0 | MUX_PAD_CTRL(PAD_CTL_PUE),
- IMX8MQ_PAD_SAI3_TXD__GPIO5_IO1 | MUX_PAD_CTRL(PAD_CTL_PUE),
- IMX8MQ_PAD_SAI3_MCLK__GPIO5_IO2 | MUX_PAD_CTRL(PAD_CTL_PUE),
+static void spl_dram_init(void) +{
- struct dram_timing_info *dram_timing;
- int variant = 0, size;
- imx_iomux_v3_setup_multiple_pads(brdrev_pads, ARRAY_SIZE(brdrev_pads));
- gpio_request(BRD_REV0, "BRD_REV0");
- gpio_direction_input(BRD_REV0);
- gpio_request(BRD_REV1, "BRD_REV1");
- gpio_direction_input(BRD_REV1);
- variant |= !!gpio_get_value(BRD_REV0) << 0;
- variant |= !!gpio_get_value(BRD_REV1) << 1;
- switch(variant) {
- case 2:
dram_timing = &dram_timing_2gb;
size = 2;
break;
- case 3:
dram_timing = &dram_timing_4gb;
size = 4;
break;
- default:
printf("Unknown DDR type (%d)\n", variant);
return;
- /* ddr init */
- ddr_init(dram_timing);
+#define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) +#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) +static struct i2c_pads_info i2c_pad_info1 = {
- .scl = {
.i2c_mode = IMX8MQ_PAD_I2C1_SCL__I2C1_SCL | PC,
.gpio_mode = IMX8MQ_PAD_I2C1_SCL__GPIO5_IO14 | PC,
.gp = IMX_GPIO_NR(5, 14),
- .sda = {
.i2c_mode = IMX8MQ_PAD_I2C1_SDA__I2C1_SDA | PC,
.gpio_mode = IMX8MQ_PAD_I2C1_SDA__GPIO5_IO15 | PC,
.gp = IMX_GPIO_NR(5, 15),
+#define USDHC2_CD_GPIO IMX_GPIO_NR(2, 12) +#define USDHC1_PWR_GPIO IMX_GPIO_NR(2, 10) +#define USDHC2_PWR_GPIO IMX_GPIO_NR(2, 19)
+int board_mmc_getcd(struct mmc *mmc) +{
- struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv;
- int ret = 0;
- switch (cfg->esdhc_base) {
- case USDHC1_BASE_ADDR:
ret = 1;
break;
- case USDHC2_BASE_ADDR:
ret = !gpio_get_value(USDHC2_CD_GPIO);
return ret;
- return 1;
+#define USDHC_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE | \
PAD_CTL_FSEL2)
+#define USDHC_GPIO_PAD_CTRL (PAD_CTL_PUE | PAD_CTL_DSE1)
+static iomux_v3_cfg_t const usdhc1_pads[] = {
- IMX8MQ_PAD_SD1_CLK__USDHC1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_CMD__USDHC1_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA0__USDHC1_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA1__USDHC1_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA2__USDHC1_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA3__USDHC1_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA4__USDHC1_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA5__USDHC1_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA6__USDHC1_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_DATA7__USDHC1_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL),
- IMX8MQ_PAD_SD1_RESET_B__GPIO2_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL),
+static iomux_v3_cfg_t const usdhc2_pads[] = {
- IMX8MQ_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA0__USDHC2_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA1__USDHC2_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_DATA2__USDHC2_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0x16 */
- IMX8MQ_PAD_SD2_DATA3__USDHC2_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), /* 0xd6 */
- IMX8MQ_PAD_SD2_CD_B__GPIO2_IO12 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL),
- IMX8MQ_PAD_SD2_RESET_B__GPIO2_IO19 | MUX_PAD_CTRL(USDHC_GPIO_PAD_CTRL),
+static struct fsl_esdhc_cfg usdhc_cfg[2] = {
- {USDHC1_BASE_ADDR, 0, 8},
- {USDHC2_BASE_ADDR, 0, 4},
+int board_mmc_init(struct bd_info *bis) +{
- int i, ret;
* According to the board_mmc_init() the following map is done:
* (U-Boot device node) (Physical Port)
* mmc0 USDHC1
* mmc1 USDHC2
- for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) {
switch (i) {
case 0:
init_clk_usdhc(0);
usdhc_cfg[0].sdhc_clk = mxc_get_clock(USDHC1_CLK_ROOT);
imx_iomux_v3_setup_multiple_pads(usdhc1_pads,
ARRAY_SIZE(usdhc1_pads));
gpio_request(USDHC1_PWR_GPIO, "usdhc1_reset");
gpio_direction_output(USDHC1_PWR_GPIO, 0);
udelay(500);
gpio_direction_output(USDHC1_PWR_GPIO, 1);
break;
case 1:
init_clk_usdhc(1);
usdhc_cfg[1].sdhc_clk = mxc_get_clock(USDHC2_CLK_ROOT);
imx_iomux_v3_setup_multiple_pads(usdhc2_pads,
ARRAY_SIZE(usdhc2_pads));
gpio_request(USDHC2_PWR_GPIO, "usdhc2_reset");
gpio_direction_output(USDHC2_PWR_GPIO, 0);
udelay(500);
gpio_direction_output(USDHC2_PWR_GPIO, 1);
break;
default:
printf("Warning: you configured more USDHC controllers "
"(%d) than supported by the board\n", i + 1);
return -EINVAL;
ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]);
if (ret)
return ret;
+#if CONFIG_IS_ENABLED(POWER_LEGACY) +#define I2C_PMIC 0 +int power_init_board(void) +{
- struct pmic *p;
- int ret;
- unsigned int reg;
- ret = power_pfuze100_init(I2C_PMIC);
- if (ret)
return -ENODEV;
- p = pmic_get("PFUZE100");
- ret = pmic_probe(p);
- if (ret)
return -ENODEV;
- pmic_reg_read(p, PFUZE100_SW3AVOL, ®);
- if ((reg & 0x3f) != 0x18) {
reg &= ~0x3f;
reg |= 0x18;
pmic_reg_write(p, PFUZE100_SW3AVOL, reg);
- ret = pfuze_mode_init(p, APS_PFM);
- if (ret < 0)
return ret;
- /* set SW3A standby mode to off */
- pmic_reg_read(p, PFUZE100_SW3AMODE, ®);
- reg &= ~0xf;
- reg |= APS_OFF;
- pmic_reg_write(p, PFUZE100_SW3AMODE, reg);
+} +#endif
+void spl_board_init(void) +{
- u32 boot_device = spl_boot_device();
- if (boot_device == BOOT_DEVICE_MMC1) {
puts("Booting from eMMC");
- } else if (boot_device == BOOT_DEVICE_MMC2) {
puts("Booting from SD card");
- } else {
puts("Unknown boot source");
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{
- /* Just empty function now - can't decide what to choose */
- debug("%s: %s\n", __func__, name);
+} +#endif
+void board_init_f(ulong dummy) +{
- int ret;
- /* Clear global data */
- memset((void *)gd, 0, sizeof(gd_t));
- arch_cpu_init();
- init_uart_clk(2);
- board_early_init_f();
- timer_init();
- preloader_console_init();
- /* Clear the BSS. */
- memset(__bss_start, 0, __bss_end - __bss_start);
- ret = spl_init();
- if (ret) {
debug("spl_init() failed: %d\n", ret);
hang();
- enable_tzc380();
- setup_i2c(0, 100000, 0x7f, &i2c_pad_info1);
- power_init_board();
- spl_dram_init();
- board_init_r(NULL, 0);
+} diff --git a/configs/kontron_pitx_imx8m_defconfig b/configs/kontron_pitx_imx8m_defconfig new file mode 100644 index 0000000000..be01b3a918 --- /dev/null +++ b/configs/kontron_pitx_imx8m_defconfig @@ -0,0 +1,87 @@ +CONFIG_ARM=y +CONFIG_ARCH_IMX8M=y +CONFIG_SYS_TEXT_BASE=0x40200000 +CONFIG_ENV_SIZE=0x4000 +CONFIG_ENV_OFFSET=0x300000 +CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_SYS_I2C_MXC_I2C2=y +CONFIG_SYS_I2C_MXC_I2C3=y +CONFIG_SYS_MALLOC_LEN=0x600000 +CONFIG_DM_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="imx8mq-kontron-pitx-imx8m" +CONFIG_SPL_TEXT_BASE=0x7E1000 +CONFIG_TARGET_KONTRON_PITX_IMX8M=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL=y +CONFIG_DISTRO_DEFAULTS=y +CONFIG_SYS_LOAD_ADDR=0x40480000 +CONFIG_FIT=y +CONFIG_SPL_FIT_PRINT=y +CONFIG_SPL_LOAD_FIT=y +# CONFIG_USE_SPL_FIT_GENERATOR is not set +CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_BOARD_LATE_INIT=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_BOARD_INIT=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_NVEDIT_EFI=y +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_DFU=y +CONFIG_CMD_FUSE=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +# CONFIG_RANDOM_UUID is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_MDIO is not set +CONFIG_CMD_CACHE=y +CONFIG_CMD_EFIDEBUG=y +CONFIG_CMD_RTC=y +CONFIG_CMD_TIME=y +CONFIG_CMD_REGULATOR=y +CONFIG_CMD_HASH=y +CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_OVERWRITE=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_SYS_MMC_ENV_PART=1 +CONFIG_SAVED_DRAM_TIMING_BASE=0x40000000 +CONFIG_DFU_MMC=y +CONFIG_MXC_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SPL_SYS_I2C_LEGACY=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_FSL_USDHC=y +CONFIG_PHYLIB=y +CONFIG_PHY_TI=y +CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX8M=y +CONFIG_SPL_POWER_LEGACY=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_GPIO=y +CONFIG_SPL_POWER_I2C=y +CONFIG_DM_RESET=y +CONFIG_DM_RTC=y +CONFIG_RTC_RV8803=y +CONFIG_MXC_UART=y +CONFIG_DM_THERMAL=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_DWC3=y +CONFIG_EFI_SET_TIME=y +CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y +CONFIG_EFI_CAPSULE_ON_DISK=y +CONFIG_EFI_IGNORE_OSINDICATIONS=y +CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y diff --git a/doc/board/kontron/index.rst b/doc/board/kontron/index.rst index 543b22e2f5..6baaf4d7a5 100644 --- a/doc/board/kontron/index.rst +++ b/doc/board/kontron/index.rst @@ -6,4 +6,5 @@ Kontron .. toctree:: :maxdepth: 2
- pitx-imx8m sl28
diff --git a/doc/board/kontron/pitx-imx8m.rst b/doc/board/kontron/pitx-imx8m.rst new file mode 100644 index 0000000000..1f64cbd9b2 --- /dev/null +++ b/doc/board/kontron/pitx-imx8m.rst @@ -0,0 +1,67 @@ +.. SPDX-License-Identifier: GPL-2.0+
+Kontron pitx-imx8m +==================
+The Kontron pitx-imx8m is an embedded board with an i.MX8MQ in the pITX +form factor.
+The board has two Ethernet ports, USB, HDMI/LVDS, m.2 slot, SD card, CAN, +RS232 and much more.
+Quick Start +-----------
+- Get and build the ARM Trusted firmware binary +- Get DDR and HDMI firmware +- Build U-Boot +- Install on SD card +- Boot
+Get and build the ARM Trusted firmware binary +^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
+Note: builddir is U-Boot build directory (source directory for in-tree builds)
+.. code-block:: bash
- $ git clone https://github.com/ARM-software/arm-trusted-firmware.git
- $ git checkout v2.5
- $ make PLAT=imx8mq ARCH=aarch64 CROSS_COMPILE=aarch64-linux-gnu- bl31
- $ cp build/imx8mq/release/bl31.bin $(builddir)
+Get DDR and HDMI firmware +^^^^^^^^^^^^^^^^^^^^^^^^^
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.11.bin
- $ chmod +x firmware-imx-8.11.bin
- $ ./firmware-imx-8.11
- $ cp firmware-imx-8.11/firmware/ddr/synopsys/lpddr4*.bin $(builddir)
- $ cp firmware-imx-8.11/firmware/hdmi/cadence/signed_hdmi_imx8m.bin $(builddir)
+Build U-Boot +^^^^^^^^^^^^
- $ make kontron_pitx_imx8m_defconfig
- $ make CROSS_COMPILE=aarch64-linux-gnu-
+Install on SD card +^^^^^^^^^^^^^^^^^^
+Burn the flash.bin to SD card at an offset of 33 KiB:
- $ sudo dd if=flash.bin of=/dev/sd[x] bs=1024 seek=33
+Boot +^^^^
+Set the boot source selection to SD card boot and power on the board. diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h new file mode 100644 index 0000000000..952dbd445c --- /dev/null +++ b/include/configs/kontron_pitx_imx8m.h @@ -0,0 +1,111 @@ +/* SPDX-License-Identifier: GPL-2.0+ */
+#ifndef __KONTRON_PITX_IMX8M_H +#define __KONTRON_PITX_IMX8M_H
+#include <linux/sizes.h> +#include <linux/stringify.h> +#include <asm/arch/imx-regs.h>
+#define CONFIG_SYS_BOOTM_LEN (32 * SZ_1M)
+#define CONFIG_SPL_MAX_SIZE (124 * SZ_1K) +#define CONFIG_SYS_MONITOR_LEN (512 * SZ_1K) +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300
+#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_WATCHDOG +#define CONFIG_SPL_DRIVERS_MISC +#define CONFIG_SPL_POWER +#define CONFIG_SPL_I2C +#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" +#define CONFIG_SPL_STACK 0x187FF0 +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_GPIO +#define CONFIG_SPL_MMC +#define CONFIG_SPL_BSS_START_ADDR 0x00180000 +#define CONFIG_SPL_BSS_MAX_SIZE SZ_8K +#define CONFIG_SYS_SPL_MALLOC_START 0x42200000 +#define CONFIG_SYS_SPL_MALLOC_SIZE SZ_512K +#define CONFIG_SYS_SPL_PTE_RAM_BASE 0x41580000
+/* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ +#define CONFIG_MALLOC_F_ADDR 0x182000 +/* For RAW image gives a error info not panic */ +#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
+#undef CONFIG_DM_MMC
+#define CONFIG_POWER_PFUZE100 +#define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 +#endif
+#define CONFIG_REMAKE_ELF
+/* ENET1 Config */ +#if defined(CONFIG_CMD_NET) +#define CONFIG_MII +#define CONFIG_ETHPRIME "FEC"
+#define CONFIG_FEC_MXC +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_FEC_MXC_PHYADDR 0 +#define FEC_QUIRK_ENET_MAC
+#define CONFIG_PHY_GIGE +#define IMX_FEC_BASE 0x30BE0000 +#define PHY_ANEG_TIMEOUT 20000
+#define ENV_MEM_LAYOUT_SETTINGS \
- "kernel_addr_r=0x40880000\0" \
- "fdt_addr_r=0x43000000\0" \
- "scriptaddr=0x43500000\0" \
- "initrd_addr=0x43800000\0" \
- "pxefile_addr_r=0x43500000\0" \
- "bootm_size=0x10000000\0" \
+#define BOOT_TARGET_DEVICES(func) \
- func(MMC, mmc, 0) \
- func(MMC, mmc, 1) \
- func(USB, usb, 0) \
- func(DHCP, dhcp, na) \
- func(PXE, pxe, 0)
+#include <config_distro_bootcmd.h>
+/* Initial environment variables */ +#define CONFIG_EXTRA_ENV_SETTINGS \
- "image=Image\0" \
- "console=ttymxc2,115200\0" \
- "boot_fdt=try\0" \
- "fdtfile=freescale/imx8mq-kontron-pitx-imx8m.dtb\0" \
- "dfu_alt_info=mmc 0=flash-bin raw 0x42 0x1000 mmcpart 1\0"\
- ENV_MEM_LAYOUT_SETTINGS \
- BOOTENV
+#define CONFIG_SYS_INIT_RAM_ADDR 0x40000000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x80000 +#define CONFIG_SYS_INIT_SP_OFFSET \
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
+#define CONFIG_SYS_INIT_SP_ADDR \
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
+#define CONFIG_SYS_SDRAM_BASE 0x40000000 +#define PHYS_SDRAM 0x40000000 +#define PHYS_SDRAM_SIZE 0xC0000000 /* 3GB DDR */
+#define CONFIG_MXC_UART_BASE UART3_BASE_ADDR
+#define CONFIG_IMX_BOOTAUX
+#define CONFIG_SYS_FSL_USDHC_NUM 2 +#define CONFIG_SYS_FSL_ESDHC_ADDR 0
+#define CONFIG_OF_SYSTEM_SETUP
Hi Stefano,
Am Do., 21. Okt. 2021 um 13:31 Uhr schrieb Stefano Babic sbabic@denx.de:
Hi Heiko,
On 14.10.21 20:08, Heiko Thiery wrote:
The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX form factor.
There is still something using binman that does not work with CI. Without CI, we load all firmware including signed_hdmi_imx8m.bin.
But on CI, file is not loaded, but instead of warnings, build for this board fails with :
+Image 'main-section' is missing external blobs and is non-functional: blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 +binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such file or directory
Could you take a look ?
Sure. Could you point me to the right CI configuration?
I need to understand how the required imx-firmware files are copied to the u-boot dir. This seems to work already for e. g. the imx8mm boards. These require the lpdd* train fw files.
On 21.10.21 15:17, Heiko Thiery wrote:
Hi Stefano,
Hi Heiko,
Configuration is in .gitlab-ci.yml. For thsi board, buildman is called as part of aarch64 target, that is
buildman -o /tmp -P -E -W arm -x aarch64
Regards, Stefano
Hi Stefano, Hi Simon,
Am Do., 21. Okt. 2021 um 15:29 Uhr schrieb Stefano Babic sbabic@denx.de:
Hi Stefano,
Hi Heiko,
Here we seem to hit an issue with the CI. blobs (lpddr*) are required for the imx8mm boards. Binman reports the missing files only as a warning and buildman does not care about that: ---- +WARNING 'mkimage.flash.mkimage' not found, resulting binary is not-functional ----
With the imx8mq boards switching to binman we also need an additional fw part (signed_hdmi_imx8m.bin). But other than the lpddr firmware as blob the signed_hmdi'_imx8m.bin is passed to mkimage and mkimage exits with an error. Thats leads to the error: ---- binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such file or directory ----
Currently I do not have an idea how to handle that. Anyone else?
Am Do., 21. Okt. 2021 um 15:57 Uhr schrieb Heiko Thiery heiko.thiery@gmail.com:
Hi Stefano,
Hi Heiko,
I thought about it a little and did a quick hack. What do you think about dummy files being generated for buildman? I had buildman generate the blobs needed by binman. So at least the build runs through successfully. I don't know yet how to integrate this sensibly into buildman or if this is useful for the maintainers at all. But this would get rid of the warnings and errors that come from binman.
diff --git a/tools/buildman/board.py b/tools/buildman/board.py index 447aaabea8..cf270c8b72 100644 --- a/tools/buildman/board.py +++ b/tools/buildman/board.py @@ -96,6 +96,28 @@ class Board: self.vendor, self.soc, self.options] self.build_it = False
+ def create_dummy_files(self, work_dir): + import configparser + import os + + settings = configparser.SafeConfigParser() + config_fname = '%s/.buildman/' % os.getenv('HOME') + if os.path.exists(config_fname): + settings.read(config_fname) + + if self.target == "kontron_pitx_imx8m": + + dummy_files = ['bl31.bin', + 'signed_hdmi_imx8m.bin', + 'lpddr4_pmu_train_1d_imem.bin', + 'lpddr4_pmu_train_1d_dmem.bin', + 'lpddr4_pmu_train_2d_imem.bin', + 'lpddr4_pmu_train_2d_dmem.bin' + ] + for dummy_file in dummy_files: + dummy = os.path.join(work_dir, 'build', dummy_file) + with open(dummy, "wb") as out: + out.truncate(1024)
class Boards: """Manage a list of boards.""" diff --git a/tools/buildman/builderthread.py b/tools/buildman/builderthread.py index 48128cf673..dee7d9b0fe 100644 --- a/tools/buildman/builderthread.py +++ b/tools/buildman/builderthread.py @@ -475,6 +475,7 @@ class BuilderThread(threading.Thread): """ brd = job.board work_dir = self.builder.GetThreadDir(self.thread_num) + brd.create_dummy_files(work_dir) self.toolchain = None if job.commits: # Run 'make board_defconfig' on the first commit
Hi Heiko,
Hi Stefano,
Hi Heiko,
I had quite the same idea...
But it should be checked if files are present - I guess there are people relying on buildman to produce the functional bootloader, and a dummy file cannot overwrite the right one if present.
import configparser
import os
out.truncate(1024)
Best regards, Stefano
Am Fr., 22. Okt. 2021 um 14:37 Uhr schrieb Stefano Babic sbabic@denx.de:
Hi Heiko,
Hi Stefano,
Hi Heiko,
On 14.10.21 20:08, Heiko Thiery wrote: > The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX > form factor. >
Sure. As said ,this was only a quick hack to see if it could work. Another thing is if there should be a config for each board that says what files have to be created.
import configparser
import os
out.truncate(1024)
Hi Heiko,
Hi Heiko,
Hi Stefano,
Am Do., 21. Okt. 2021 um 13:31 Uhr schrieb Stefano Babic sbabic@denx.de: > > Hi Heiko, > > On 14.10.21 20:08, Heiko Thiery wrote: >> The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX >> form factor. >> > > There is still something using binman that does not work with CI. > Without CI, we load all firmware including signed_hdmi_imx8m.bin. > > But on CI, file is not loaded, but instead of warnings, build for this > board fails with : > > +Image 'main-section' is missing external blobs and is non-functional: > blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 > +binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n > spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 > ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such > file or directory > + > > Could you take a look ?
If I understand correctly:
1.You don't have these blobs in the tree so don't want to fail a build in CI, which is why binman's blob-ext is used 2. You sometimes need to ensure that they do exist
Should we add a cmdline flag to binman to require all external blobs?
Could we drop the blobs and add code to generate them, or put the date in a C struct?
import configparser
import os
out.truncate(1024)
-- Heiko
Hi Simon,
Am Fr., 22. Okt. 2021 um 18:07 Uhr schrieb Simon Glass sjg@chromium.org:
Hi Heiko,
Hi Heiko,
On 21.10.21 15:17, Heiko Thiery wrote: > Hi Stefano, > > > Am Do., 21. Okt. 2021 um 13:31 Uhr schrieb Stefano Babic sbabic@denx.de: >> >> Hi Heiko, >> >> On 14.10.21 20:08, Heiko Thiery wrote: >>> The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX >>> form factor. >>> >> >> There is still something using binman that does not work with CI. >> Without CI, we load all firmware including signed_hdmi_imx8m.bin. >> >> But on CI, file is not loaded, but instead of warnings, build for this >> board fails with : >> >> +Image 'main-section' is missing external blobs and is non-functional: >> blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 >> +binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n >> spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 >> ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such >> file or directory >> + >> >> Could you take a look ? > > Sure. Could you point me to the right CI configuration? >
> I need to understand how the required imx-firmware files are copied to > the u-boot dir. This seems to work already for e. g. the imx8mm > boards. These require the lpdd* train fw files.
Correct, for the imx8mq e.g. the signed_hdmi_imx8m.bin is required that comes from NXP and has to be copied to the u-boot build dir.
- You sometimes need to ensure that they do exist
For the build the "signed_hdmi_imx8m.bin" is required to successfully build.
I do not understand that. What should happen if this flag is present?
No, this is not possible because they are delivered by NXP from the firmware-imx package and has to be copied from there.
import configparser
import os
out.truncate(1024)
-- Heiko
Hi Heiko,
On Fri, 22 Oct 2021 at 11:54, Heiko Thiery heiko.thiery@gmail.com wrote:
Hi Simon,
Hi Heiko,
Hi Heiko,
Am Do., 21. Okt. 2021 um 15:29 Uhr schrieb Stefano Babic sbabic@denx.de: > > On 21.10.21 15:17, Heiko Thiery wrote: >> Hi Stefano, >> >> >> Am Do., 21. Okt. 2021 um 13:31 Uhr schrieb Stefano Babic sbabic@denx.de: >>> >>> Hi Heiko, >>> >>> On 14.10.21 20:08, Heiko Thiery wrote: >>>> The Kontron pitx-imx8m is an NXP i.MX8MQ based board in the pITX >>>> form factor. >>>> >>> >>> There is still something using binman that does not work with CI. >>> Without CI, we load all firmware including signed_hdmi_imx8m.bin. >>> >>> But on CI, file is not loaded, but instead of warnings, build for this >>> board fails with : >>> >>> +Image 'main-section' is missing external blobs and is non-functional: >>> blob-ext@1 blob-ext@2 blob-ext@3 blob-ext@4 >>> +binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n >>> spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 >>> ./mkimage-out.spl.mkimage': signed_hdmi_imx8m.bin: Can't open: No such >>> file or directory >>> + >>> >>> Could you take a look ? >> >> Sure. Could you point me to the right CI configuration? >> > > Configuration is in .gitlab-ci.yml. For thsi board, buildman is called > as part of aarch64 target, that is > > buildman -o /tmp -P -E -W arm -x aarch64 > >> I need to understand how the required imx-firmware files are copied to >> the u-boot dir. This seems to work already for e. g. the imx8mm >> boards. These require the lpdd* train fw files.
Perhaps they should upstream that stuff and turn it into code in U-Boot?
Anyway, I think you are working on this, per the irc chat. [..]
Heiko Thiery
Stefano Babic
