[PATCH v2] arm: dts: rockchip: rk3399: usb: ehci: Fix EHCI probe in rk3399 to access peripherals by USB 2.
arch/arm/dts/rk3399.dtsi has a node
usb_host0_ehci: usb@fe380000 { compatible = "generic-ehci";
with clocks:
clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, <&u2phy0>;
The first 2 refer to nodes with class UCLASS_CLK, but &u2phy0 has class UCLASS_PHY.
u2phy0: usb2phy@e450 { compatible = "rockchip,rk3399-usb2phy";
Since clk_get_bulk() only looks for devices with UCLASS_CLK, it fails with -ENODEV and then ehci_usb_probe() aborts.
The consequence is peripherals connected to a USB 2 port (e.g. in a Rock Pi 4 the white port, nearer the edge) not being detected. They're detected if CONFIG_USB_OHCI_GENERIC is selected in Kconfig, because ohci_usb_probe() does not abort when one clk_get_by_index() fails, but then they work in USB 1 mode,.
rk3399.dtsi comes from linux and the u2phy0 was added[1] to the clock list in:
commit b5d1c57299734f5b54035ef2e61706b83041f20c Author: William wu wulf@rock-chips.com Date: Wed Dec 21 18:41:05 2016 +0800
arm64: dts: rockchip: add u2phy clock for ehci and ohci of rk3399
We found that the suspend process was blocked when it run into ehci/ohci module due to clk-480m of usb2-phy was disabled. [...]
Suspend concerns don't apply to U-Boot, and the problem with U-Boot failing to probe EHCI doesn't apply to linux, because in linux rockchip_usb2phy_clk480m_register makes u2phy0 a proper clock provider when called by rockchip_usb2phy_probe().
So I can think of a few alternative solutions:
1- Change ehci_usb_probe() to make it more similar to ohci_usb_probe(), and survive failure to get one clock. Looks a little harder, and I don't know whether it could break something if it ignored a clock that was important for something else than suspend.
2- Change rk3399.dtsi effecttively reverting the linux commit b5d1c57299734f5b54035ef2e61706b83041f20c. This dealigns the .dtsi from linux and seems fragile at the next synchronisation.
3- Change the clock list in rk3399-u-boot.dtsi or somewhere else. This survives .dts* sync but may survive "too much" and miss some change from linux that we might want.
4- Enable CONFIG_USB_OHCI_GENERIC and use the ports in USB 1 mode. This would need to be made for all boards using rk3399. In a simple test reading one file from USB storage it gave 769.5 KiB/s instead of 20.5 MiB/s with solution 2.
5- Trying to replicate linux and have usb2phy somehow provide a clk, or have a separate clock device for usb2phy in addition to the phy device. I just can't seem to imagine how to achieve this with the U-Boot driver model, maybe because of my limited familiarity with it.
This patch is option 1 as Kever Yang requested on August 27th[2] when option 3 didn't get through. Sorry for the delay.
Yet maybe the get_some_clks() function should be added to clk-uclass.c if it may be useful elsewhere. Or alternatively, clk_get_bulk() could be changed to the lenient behaviour of get_some_clks(), but that seems too invasive to me. Either of these changes can always be done in a later patch if needed.
If so, one possibility would be to call it from ohci-generic.c. As it is now it looks like if it ever misses a clock but finds a subsequent clock, assigned to a higher index in the clock table, it may leave clock_count too low to release all found clocks. I don't know of a case where this happens, for rk3399 usb, even with non-default CONFIG_OHCI_GENERIC, the missing clock is the last one, and so the release iteration happens to find all found clocks.
Link: [1] https://lkml.kernel.org/lkml/1731551.Q6cHK6n5ZM@phil/T/ [2] https://patchwork.ozlabs.org/project/uboot/patch/20220701185959.GC1700@begut...
Cc: Simon Glass sjg@chromium.org Cc: Philipp Tomsich philipp.tomsich@vrull.eu Cc: Kever Yang kever.yang@rock-chips.com Cc: Lukasz Majewski lukma@denx.de Cc: Sean Anderson seanga2@gmail.com Cc: Marek Vasut marex@denx.de
Signed-off-by: Xavier Drudis Ferran xdrudis@tinet.cat ---
Changes:
v2: implement option 1 (ehci-generic.c tolerates missing clocks) instead of option 3 (change dts node to remove the missing clock).
--- drivers/usb/host/ehci-generic.c | 59 ++++++++++++++++++++++++++++++++- 1 file changed, 58 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/host/ehci-generic.c b/drivers/usb/host/ehci-generic.c index a765a307a3..aa86dcc435 100644 --- a/drivers/usb/host/ehci-generic.c +++ b/drivers/usb/host/ehci-generic.c @@ -60,6 +60,63 @@ static int ehci_disable_vbus_supply(struct generic_ehci *priv) return 0; }
+/** + * get_some_clks() - Get/request all available clocks of a + * device. Leave other as null. + * + * @dev: The client device. + * @bulk: A pointer to a clock bulk struct to initialize. + * + * This looks up and requests all clocks of the client device; each + * device is assumed to have n clocks associated with it somehow, and + * this function tries to find and request all of them in a separate + * structure. The mapping of client device clock indices to provider + * clocks may be via device-tree properties, board-provided mapping + * tables, or some other mechanism. + * + * This is like clk_get_bulk() in clk uclass, but failure to get some + * of the clocks is accepted and only the available ones are assigned + * to bulk->clks. So bulk->clks may contain invalid (zeroed) clk + * structs. clk_release_bulk(), clk_enable_bulk() and + * clk_disable_bulk() can deal with that. + * + * bulk->count will contain the number of attempted clocks (size of + * bulk->clks). Or an error when getting the clocks phandle if + * negative. + * + * Return: If some clocks could be successfully located and requested, + * it returns 0. If all failed, then returns the last error code. + */ +static int get_some_clks(struct udevice *dev, struct clk_bulk *bulk) +{ + int i, ret, count; + + count = 0; + + bulk->count = dev_count_phandle_with_args(dev, "clocks", "#clock-cells", 0); + if (bulk->count < 1) + return bulk->count; + + bulk->clks = devm_kcalloc(dev, bulk->count, sizeof(struct clk), GFP_KERNEL); + if (!bulk->clks) + return -ENOMEM; + + for (i = 0; i < bulk->count; i++) { + ret = clk_get_by_index(dev, i, &bulk->clks[i]); + if (ret < 0) { + dev_warn(dev, "Failed to get clock %i/%i (ret=%d)\n", i, bulk->count, ret); + break; + } + + ++count; + } + + if (!count) + return ret; + + return 0; +} + static int ehci_usb_probe(struct udevice *dev) { struct generic_ehci *priv = dev_get_priv(dev); @@ -68,7 +125,7 @@ static int ehci_usb_probe(struct udevice *dev) int err, ret;
err = 0; - ret = clk_get_bulk(dev, &priv->clocks); + ret = get_some_clks(dev, &priv->clocks); if (ret && ret != -ENOENT) { dev_err(dev, "Failed to get clocks (ret=%d)\n", ret); return ret;
with clocks:
Yes please
Have a look at the end of drivers/led/led_gpio.c and how gpio_led_wrap binds a gpio_led driver to each LED. You can bind an UCLASS_PHY and UCLASS_CLK driver to the u2phy0 the same way, the u2phy0 would behave the same way as gpio_led_wrap wrapper . You would likely be using device_bind_driver() instead of device_bind_driver_to_node() in the bind callback.
El Mon, Dec 05, 2022 at 08:08:40PM +0100, Marek Vasut deia:
Yes please
Ok, I will take a look and send a v3 if I understand it.
Thank you.
