Re: [DNX#2006033142000231] [U-Boot-Users] [Patch] KVME080 Support
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006033142000231] was created:
<snip>
Hi Wolfgang,
Wolfgang Denk wrote:
In message 004e01c5a3db$3840e6f0$212d4cdc@smkim you wrote:
[snip]
And please cleanup your code before re-submitting:
It violates the coding style requirements (trailing white space).
Using globally visible preprocessor defines like FLASH_WRITE64 is not acceptable (you also forgot to document these, but that would help either), and defining such code in the board config file is the wrong way to implement it either. The board config file is - ummm, a _configuration_ file, but does not contain source code.
IIRC, you posted a couple of scripts that tested for formatting violations. Per my previous suggestion of putting the patch rules on your web site, I would like to see the formatting test scripts posted too. If these were on the DULG twiki, they could be collaboratively tuned.
[snip]
Rejected, sorry.
Thanks, gvb
</snip>
Your U-Boot support team
DENX Support System
