[U-Boot] [UBOOT PATCH v2 0/2] spi: Moved spi u-bbot headers to Kconfig
This seris of patch moved spi headers to Kconfig. These are the configs: -CONFIG_SYS_ZYNQ_SPI_WAIT -CONFIG_XILINX_SPI_IDLE_VAL -CONFIG_SYS_ZYNQ_QSPI_WAIT
-Changes in V2: - Added depends on ZYNQ_QSPI - Added depends on XILINX_SPI - Branch: u-boot-microblaze/kconfig
Vipul Kumar (2): qspi: Added Kconfig support for CONFIG_SYS_ZYNQ_QSPI_WAIT spi: Added Kconfig support for SYS_ZYNQ_SPI_WAIT and XILINX_SPI_IDLE_VAL
drivers/spi/Kconfig | 21 +++++++++++++++++++++ drivers/spi/xilinx_spi.c | 4 ---- drivers/spi/zynq_qspi.c | 3 --- drivers/spi/zynq_spi.c | 3 --- 4 files changed, 21 insertions(+), 10 deletions(-)
-- 2.7.4
This email and any attachments are intended for the sole use of the named recipient(s) and contain(s) confidential information that may be proprietary, privileged or copyrighted under applicable law. If you are not the intended recipient, do not read, copy, or forward this email message or any attachments. Delete this email message and any attachments immediately.
This patch added Kconfig support for CONFIG_SYS_ZYNQ_QSPI_WAIT and set it to default value 10 milliseconds.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- -Changes in v2: - Added depends on ZYNQ_QSPI - Branch: u-boot-microblaze/kconfig --- drivers/spi/Kconfig | 7 +++++++ drivers/spi/zynq_qspi.c | 3 --- 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 235a8c7..94f6d7d 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -204,6 +204,13 @@ config ZYNQ_QSPI Zynq QSPI IP core. This IP is used to connect the flash in 4-bit qspi, 8-bit dual stacked and shared 4-bit dual parallel.
+config SYS_ZYNQ_QSPI_WAIT + int "Define Zynq QSPI wait time in ms" + depends on ZYNQ_QSPI + default 10 + help + Define default Zynq QSPI wait time in milliseconds. + endif # if DM_SPI
config SOFT_SPI diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 255e02f..c9241aa 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -46,9 +46,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_QSPI_CR_SS_SHIFT 10 /* Slave select shift */
#define ZYNQ_QSPI_FIFO_DEPTH 63 -#ifndef CONFIG_SYS_ZYNQ_QSPI_WAIT -#define CONFIG_SYS_ZYNQ_QSPI_WAIT CONFIG_SYS_HZ/100 /* 10 ms */ -#endif
/* zynq qspi register set */ struct zynq_qspi_regs { -- 2.7.4
This patch added Kconfig support for CONFIG_SYS_ZYNQ_SPI_WAIT and CONFIG_XILINX_SPI_IDLE_VAL and set default value.
Signed-off-by: Vipul Kumar vipulk@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- - Changes in V2: - Added depends on XILINX_SPI - Branch: u-boot-microblaze/kconfig --- drivers/spi/Kconfig | 14 ++++++++++++++ drivers/spi/xilinx_spi.c | 4 ---- drivers/spi/zynq_spi.c | 3 --- 3 files changed, 14 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 94f6d7d..d8e17cd 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -211,6 +211,20 @@ config SYS_ZYNQ_QSPI_WAIT help Define default Zynq QSPI wait time in milliseconds.
+config SYS_ZYNQ_SPI_WAIT + int "Define Zynq SPI wait time in ms" + depends on XILINX_SPI + default 10 + help + Define default Zynq SPI wait time in milliseconds. + +config XILINX_SPI_IDLE_VAL + hex "Define the default SPI idle value" + depends on XILINX_SPI + default 0xFFFFFFFF + help + Set the default SPI idle value. + endif # if DM_SPI
config SOFT_SPI diff --git a/drivers/spi/xilinx_spi.c b/drivers/spi/xilinx_spi.c index a951a77..9781ea9 100644 --- a/drivers/spi/xilinx_spi.c +++ b/drivers/spi/xilinx_spi.c @@ -74,10 +74,6 @@ SPICR_SPE) #define XILSPI_SPICR_DFLT_OFF (SPICR_MASTER_INHIBIT | SPICR_MANUAL_SS)
-#ifndef CONFIG_XILINX_SPI_IDLE_VAL -#define CONFIG_XILINX_SPI_IDLE_VAL GENMASK(7, 0) -#endif - #ifndef CONFIG_SYS_XILINX_SPI_LIST #define CONFIG_SYS_XILINX_SPI_LIST { CONFIG_SYS_SPI_BASE } #endif diff --git a/drivers/spi/zynq_spi.c b/drivers/spi/zynq_spi.c index ed2b8cb..be8f525 100644 --- a/drivers/spi/zynq_spi.c +++ b/drivers/spi/zynq_spi.c @@ -33,9 +33,6 @@ DECLARE_GLOBAL_DATA_PTR; #define ZYNQ_SPI_CR_SS_SHIFT 10 /* Slave select shift */
#define ZYNQ_SPI_FIFO_DEPTH 128 -#ifndef CONFIG_SYS_ZYNQ_SPI_WAIT -#define CONFIG_SYS_ZYNQ_SPI_WAIT (CONFIG_SYS_HZ/100) /* 10 ms */ -#endif
/* zynq spi register set */ struct zynq_spi_regs { -- 2.7.4
This make unnecessary of adding Kconfig options for local defined macros, Better keep this as it is or try with ant dt property,
If there is not configuration in board header file that I also think that there is no reason to move them to Kconfig.
Just remove that CONFIG_ prefix and they can be removed from whitelist.
Thanks, Michal
Jagan Teki
Michal Simek
Vipul Kumar
