[PATCH] riscv: binman: fix the load field format
The #address-cells is now equal to 2. The format of the load field for the Linux kernel doesn't match.
Signed-off-by: Randolph randolph@andestech.com --- arch/riscv/dts/binman.dtsi | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/riscv/dts/binman.dtsi b/arch/riscv/dts/binman.dtsi index 6b4eb8dc7b..5117d7c8c9 100644 --- a/arch/riscv/dts/binman.dtsi +++ b/arch/riscv/dts/binman.dtsi @@ -50,7 +50,8 @@ os = "Linux"; arch = "riscv"; compression = "none"; - load = <CONFIG_TEXT_BASE>; + load = <U64_TO_U32_H(CONFIG_TEXT_BASE) + U64_TO_U32_L(CONFIG_TEXT_BASE)>;
linux_blob: blob-ext { filename = "Image";
Hi Randolph,
Does this work?
load = /bits 64/ <CONFIG_TEXT_BASE>
-- 2.34.1
Hi Simon, Thanks a lot. On Fri, Nov 10, 2023 at 04:50:24AM -0700, Simon Glass wrote:
Hi Randolph,
I just see the #address-cells changed from 1 to 2 in commit id: 5a348ccf0257. In my last commit for binman.dtsi (commit id: d311df8b3169), it is based on the value of #address-cells being 1. That's the reason for my patch submission.
Does this work?
Yes, it works. We use this way for the DDR memory start address above 4G platform. We find the example for 64bit address in the document tools/binman/binman.rst and use it. What is the method that we should continue to use in the binman.dtsi? 1. #address-cells = 2 2. append /bits/64
-- 2.34.1
Hi Randolph,
Hi Randolph,
Does this work?
- #address-cells = 2
- append /bits/64
I believe these go together. Using (1) means you have a 2-cell value, which is 64 bits since each cell is 32-bits.
Or perhaps I misunderstand what you are asking?
-- 2.34.1
Randolph
Randolph Lin
