[PATCH] actions: Fix syntax for enabling SYS_RELOC_GD_ENV_ADDR
The correct syntax is 'select SYS_...' and not 'select CONFIG_SYS...'
Fixes: d5c819b885c2 ("actions: Move defconfig options to Kconfig") Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8e67e1c58733..3383b05e480b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -881,7 +881,7 @@ config ARCH_OWL select CLK select CLK_OWL select OF_CONTROL - select CONFIG_SYS_RELOC_GD_ENV_ADDR + select SYS_RELOC_GD_ENV_ADDR imply CMD_DM
config ARCH_QEMU
