[PATCH v2] cmd: ubi: add a command to rename volume
This commit add the command ubi rename to rename an ubi volume. The format of the command is: ubi rename <oldname> <newname>. To enable this command, the option CMD_UBI_RENAME must be selected.
Signed-off-by: Philippe Reynes philippe.reynes@softathome.com --- cmd/Kconfig | 8 ++++++++ cmd/ubi.c | 43 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 51 insertions(+)
Changelog: v2: - added an option CMD_UBI_RENAME (feedback from Wolfgang)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 6403bc4..1564694 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -2172,6 +2172,14 @@ config CMD_UBI It is also strongly encouraged to also enable CONFIG_MTD to get full partition support.
+config CMD_UBI_RENAME + bool "Enable rename" + depends on CMD_UBI + default n + help + Enable a "ubi" command to rename ubi volume: + ubi rename <oldname> <newname> + config CMD_UBIFS tristate "Enable UBIFS - Unsorted block images filesystem commands" depends on CMD_UBI diff --git a/cmd/ubi.c b/cmd/ubi.c index cecf251..4885661 100644 --- a/cmd/ubi.c +++ b/cmd/ubi.c @@ -251,6 +251,41 @@ out_err: return err; }
+#ifdef CONFIG_CMD_UBI_RENAME +static int ubi_rename_vol(char *oldname, char *newname) +{ + struct ubi_volume *vol; + struct ubi_rename_entry rename; + struct ubi_volume_desc desc; + struct list_head list; + + vol = ubi_find_volume(oldname); + if (!vol) { + printf("%s: volume %s doesn't exist\n", __func__, oldname); + return ENODEV; + } + + printf("Rename UBI volume %s to %s\n", oldname, newname); + + if (ubi->ro_mode) { + printf("%s: ubi device is in read-only mode\n", __func__); + return EROFS; + } + + rename.new_name_len = strlen(newname); + strcpy(rename.new_name, newname); + rename.remove = 0; + desc.vol = vol; + desc.mode = 0; + rename.desc = &desc; + INIT_LIST_HEAD(&rename.list); + INIT_LIST_HEAD(&list); + list_add(&rename.list, &list); + + return ubi_rename_volumes(ubi, &list); +} +#endif /* CONFIG_CMD_UBI_RENAME */ + static int ubi_volume_continue_write(char *volume, void *buf, size_t size) { int err = 1; @@ -604,6 +639,11 @@ static int do_ubi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return ubi_remove_vol(argv[2]); }
+#ifdef CONFIG_CMD_UBI_RENAME + if (strncmp(argv[1], "rename", 6) == 0) + return ubi_rename_vol(argv[2], argv[3]); +#endif + if (strncmp(argv[1], "skipcheck", 9) == 0) { /* E.g., change skip_check flag */ if (argc == 4) { @@ -692,6 +732,9 @@ U_BOOT_CMD( " - Read volume to address with size\n" "ubi remove[vol] volume" " - Remove volume\n" +#ifdef CONFIG_CMD_UBI_RENAME + "ubi rename oldname newname\n" +#endif "ubi skipcheck volume on/off - Set or clear skip_check flag in volume header\n" "[Legends]\n" " volume: character name\n"
Hi Philippe,
On Fri, 20 Mar 2020 at 03:55, Philippe Reynes philippe.reynes@softathome.com wrote:
adds
Changelog: v2:
depends on CMD_UBI
default n
help
if (!vol) {
return ENODEV;
if (ubi->ro_mode) {
return EROFS;
rename.remove = 0;
desc.vol = vol;
desc.mode = 0;
Can you use IS_ENABLED(CONFIG_...) and drop the #ifdef way above?
Hi Simon,
Hi Philippe,
adds
Changelog: v2:
- bool "Enable rename"
- depends on CMD_UBI
- default n
- help
- Enable a "ubi" command to rename ubi volume:
- ubi rename <oldname> <newname>
- struct ubi_volume *vol;
- struct ubi_rename_entry rename;
- struct ubi_volume_desc desc;
- struct list_head list;
- vol = ubi_find_volume(oldname);
- if (!vol) {
- printf("%s: volume %s doesn't exist\n", __func__, oldname);
- return ENODEV;
- printf("Rename UBI volume %s to %s\n", oldname, newname);
- if (ubi->ro_mode) {
- printf("%s: ubi device is in read-only mode\n", __func__);
- return EROFS;
- rename.new_name_len = strlen(newname);
- strcpy(rename.new_name, newname);
- rename.remove = 0;
- desc.vol = vol;
- desc.mode = 0;
- rename.desc = &desc;
- INIT_LIST_HEAD(&rename.list);
- INIT_LIST_HEAD(&list);
- list_add(&rename.list, &list);
- return ubi_rename_volumes(ubi, &list);
I've sent a v3 where I use IS_ENABLED instead of #ifdef. But I've kept a #if IS_ENABLED(...) around the function ubi_rename_vol. Otherwise if this option is not enabled, there is a warning when building :
CC cmd/ubi.o cmd/ubi.c:254:12: warning: 'ubi_rename_vol' defined but not used [-Wunused-function] static int ubi_rename_vol(char *oldname, char *newname) ^~~~~~~~~~~~~~
- if (strncmp(argv[1], "rename", 6) == 0)
- return ubi_rename_vol(argv[2], argv[3]);
Regards, Philippe
Use C
if (IS_ENABLED(CONFIG_...) && !strcmp(cmd, "rename"))
not cpp
#if IS_ENABLED(CONFIG_...) if (!strcmp(cmd, "rename"))
That way the compiler sees ubi_rename_vol is used, but also knows that it is dead code that can be eliminated. Less ifdeffery (none, actually), and the code in ubi_rename_vol gets compile coverage regardless of configuration.
Rasmus
Hi Rasmus,
Use C
not cpp
Thanks a lot for this explanation.
I have sent a v4. And it works as expected, without the #if ... before the function ubi_rename_vol, there isn't a warning if ubi rename is not enabled in the config.
Rasmus
Regards, Philippe
Philippe REYNES
Philippe Reynes
Rasmus Villemoes
