[U-Boot] [PATCH 0/5] Update LS2080A SoC code to support LS2088A SoC
LS2088A is similar to LS2080A SoC with some differences like 1)Timer controller offset is different 2)It has A72 cores 3)Process to release secondary cores is different 4)LS2088A SoC has TZASC controller
In preparation of using same binary for LS2088A and LS2080A as both are using same development boards. code is update to detect difference based on SVR at runtime
Priyanka Jain (5): armv8: lsch3: Use SVR based timer base address detection armv8: fsl-layerscape: Update TZASC registers type armv8: fsl-layerscape : Check SVR for initializing TZASC armv8: fsl-layerscape: Add NXP LS2088A SoC support armv8/fsl-lsch3: Update code to release secondary cores
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 16 +++++- arch/arm/cpu/armv8/fsl-layerscape/cpu.h | 1 + arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 +++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 47 +++++++++++----- arch/arm/cpu/armv8/fsl-layerscape/mp.c | 59 ++++++++++++++++++- arch/arm/cpu/armv8/fsl-layerscape/soc.c | 6 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 + .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 7 ++- arch/arm/include/asm/arch-fsl-layerscape/soc.h | 10 +++ board/freescale/ls2080a/MAINTAINERS | 2 +- board/freescale/ls2080aqds/MAINTAINERS | 2 +- board/freescale/ls2080aqds/README | 12 ++-- board/freescale/ls2080ardb/MAINTAINERS | 2 +- board/freescale/ls2080ardb/README | 8 +- 15 files changed, 198 insertions(+), 37 deletions(-)
Timer base address has been changed from LS2080A SoC to new SoCs like LS2088A, LS1088A.
Use SVR based timer base address detection to avoid compile time #ifdef.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 14 +++++++++++++- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 3 ++- 2 files changed, 15 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index b7a2e0c..ce04e48 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -424,8 +424,10 @@ int arch_early_init_r(void)
int timer_init(void) { - u32 __iomem *cntcr = (u32 *)CONFIG_SYS_FSL_TIMER_ADDR; + u32 __iomem *cntcr; #ifdef CONFIG_FSL_LSCH3 + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + u32 svr, ver; u32 __iomem *cltbenr = (u32 *)CONFIG_SYS_FSL_PMU_CLTBENR; #endif #ifdef CONFIG_LS2080A @@ -439,6 +441,16 @@ int timer_init(void) #endif
#ifdef CONFIG_FSL_LSCH3 + svr = gur_in32(&gur->svr); + ver = SVR_SOC_VER(svr); + if ((ver == SVR_LS2080A) || (ver == SVR_LS2040A) || + (ver == SVR_LS2085A) || (ver == SVR_LS2045A)) + cntcr = (u32 *)LS2080A_LS2085A_TIMER_ADDR; + else +#endif + cntcr = (u32 *)CONFIG_SYS_FSL_TIMER_ADDR; + +#ifdef CONFIG_FSL_LSCH3 /* Enable timebase for all clusters. * It is safe to do so even some clusters are not enabled. */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index 7acba27..e6cdfcb 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -23,7 +23,8 @@ #define CONFIG_SYS_IFC_ADDR (CONFIG_SYS_IMMR + 0x01240000) #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011C0500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011C0600) -#define CONFIG_SYS_FSL_TIMER_ADDR 0x023d0000 +#define LS2080A_LS2085A_TIMER_ADDR 0x023d0000 +#define CONFIG_SYS_FSL_TIMER_ADDR 0x023e0000 #define CONFIG_SYS_FSL_PMU_CLTBENR (CONFIG_SYS_FSL_PMU_ADDR + \ 0x18A0) #define FSL_PMU_PCTBENR_OFFSET (CONFIG_SYS_FSL_PMU_ADDR + 0x8A0)
Hi York
-----Original Message----- From: Priyanka Jain [mailto:priyanka.jain@nxp.com] Sent: Wednesday, October 19, 2016 3:07 PM To: u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: [PATCH 1/5] armv8: lsch3: Use SVR based timer base address detection
- u32 __iomem *cntcr;
- struct ccsr_gur __iomem *gur = (void
- u32 svr, ver; u32 __iomem *cltbenr = (u32 *)CONFIG_SYS_FSL_PMU_CLTBENR;
- svr = gur_in32(&gur->svr);
- ver = SVR_SOC_VER(svr);
- if ((ver == SVR_LS2080A) || (ver == SVR_LS2040A) ||
- else
Is this ok to define new constant without CONFIG_? Only problem, it is not consistent with existing defines.
-prabhakar
On 10/19/2016 10:28 PM, Prabhakar Kushwaha wrote:
Hi York
- else
Prabhakar,
I opinion on this is
1) Let's check if a Kconfig option is better for it If yes, let's convert it to Kconfig. If not, go to 2)
2) Let's use a different name space for the macros. I suggest to use SYS_FSL_* for fixed value for our hardware.
York
-----Original Message----- From: york sun Sent: Thursday, October 20, 2016 10:46 AM To: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; u- boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: Re: [PATCH 1/5] armv8: lsch3: Use SVR based timer base address detection
Hi York
#endif
- else
(CONFIG_SYS_IMMR +
(CONFIG_SYS_IMMR +
Prabhakar,
- Let's check if a Kconfig option is better for it If yes, let's convert it to
- Let's use a different name space for the macros.
York
LS2080A_LS2085A_TIMER_ADDR is defining the timer controller (register) offset. Kconfig option does not look to be very helpful here. I am thinking of renaming this to "SYS_FSL_LS2080A_LS2085A_TIMER_ADDR"
Please confirm if this is fine.
Priyanka
Hi York
#endif
- else
(CONFIG_SYS_IMMR +
(CONFIG_SYS_IMMR +
Prabhakar,
York
Sorry for late reply. The new name is OK. Please consider to change other existing CONFIG_* macros to SYS_FSL_* space, and remove them from the white list.
York
TZASC registers like TZASC_GATE_KEEPER, TZASC_REGION_ATTRIBUTES are 32-bit regsiters. So while doing register load-store operations, 32-bit intermediate register, w0 should be used. Update x0 register to w0 register type.
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 28 +++++++++++++------------- 1 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 5d0b7a4..3274cad 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -145,26 +145,26 @@ ENTRY(lowlevel_init) * placeholders. */ ldr x1, =TZASC_GATE_KEEPER(0) - ldr x0, [x1] /* Filter 0 Gate Keeper Register */ - orr x0, x0, #1 << 0 /* Set open_request for Filter 0 */ - str x0, [x1] + ldr w0, [x1] /* Filter 0 Gate Keeper Register */ + orr w0, w0, #1 << 0 /* Set open_request for Filter 0 */ + str w0, [x1]
ldr x1, =TZASC_GATE_KEEPER(1) - ldr x0, [x1] /* Filter 0 Gate Keeper Register */ - orr x0, x0, #1 << 0 /* Set open_request for Filter 0 */ - str x0, [x1] + ldr w0, [x1] /* Filter 0 Gate Keeper Register */ + orr w0, w0, #1 << 0 /* Set open_request for Filter 0 */ + str w0, [x1]
ldr x1, =TZASC_REGION_ATTRIBUTES_0(0) - ldr x0, [x1] /* Region-0 Attributes Register */ - orr x0, x0, #1 << 31 /* Set Sec global write en, Bit[31] */ - orr x0, x0, #1 << 30 /* Set Sec global read en, Bit[30] */ - str x0, [x1] + ldr w0, [x1] /* Region-0 Attributes Register */ + orr w0, w0, #1 << 31 /* Set Sec global write en, Bit[31] */ + orr w0, w0, #1 << 30 /* Set Sec global read en, Bit[30] */ + str w0, [x1]
ldr x1, =TZASC_REGION_ATTRIBUTES_0(1) - ldr x0, [x1] /* Region-1 Attributes Register */ - orr x0, x0, #1 << 31 /* Set Sec global write en, Bit[31] */ - orr x0, x0, #1 << 30 /* Set Sec global read en, Bit[30] */ - str x0, [x1] + ldr w0, [x1] /* Region-1 Attributes Register */ + orr w0, w0, #1 << 31 /* Set Sec global write en, Bit[31] */ + orr w0, w0, #1 << 30 /* Set Sec global read en, Bit[30] */ + str w0, [x1]
ldr x1, =TZASC_REGION_ID_ACCESS_0(0) ldr w0, [x1] /* Region-0 Access Register */
LS2080 SoC and its personalities does not support TZASC But other new SoCs like LS2088A, LS1088A supports TASC
Hence, skip initializing TZASC for Ls2080A based on SVR
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S | 19 ++++++++++++++++++- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 4 ++++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 6 ++++++ 3 files changed, 28 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S index 3274cad..82b7696 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S +++ b/arch/arm/cpu/armv8/fsl-layerscape/lowlevel.S @@ -10,6 +10,8 @@ #include <linux/linkage.h> #include <asm/gic.h> #include <asm/macro.h> +#include <asm/arch-fsl-layerscape/immap_lsch3.h> +#include <asm/arch-fsl-layerscape/soc.h> #ifdef CONFIG_MP #include <asm/arch/mp.h> #endif @@ -137,6 +139,15 @@ ENTRY(lowlevel_init) #endif
#ifdef CONFIG_FSL_TZASC_400 + bl svr_dev_id /* get high 16 bits of SVR */ + /* + * LS2080 and its personalities does not support TZASC + * So skip TZASC related operations + */ + ldr x1, =SVR_DEV_LS2080A + cmp x0, x1 + b.eq 1f + /* Set TZASC so that: * a. We use only Region0 whose global secure write/read is EN * b. We use only Region0 whose NSAID write/read is EN @@ -179,7 +190,7 @@ ENTRY(lowlevel_init) isb dsb sy #endif - +1: #ifdef CONFIG_ARCH_LS1046A /* Initialize the L2 RAM latency */ mrs x1, S3_1_c11_c0_2 @@ -198,6 +209,12 @@ ENTRY(lowlevel_init) ret ENDPROC(lowlevel_init)
+svr_dev_id: + ldr x1, =FSL_LSCH3_SVR + ldr w0, [x1] + lsr w0, w0, #16 + ret + #ifdef CONFIG_FSL_LSCH3 hnf_pstate_poll: /* x0 has the desired status, return 0 for success, 1 for timeout diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index e6cdfcb..1034bf4 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -28,6 +28,8 @@ #define CONFIG_SYS_FSL_PMU_CLTBENR (CONFIG_SYS_FSL_PMU_ADDR + \ 0x18A0) #define FSL_PMU_PCTBENR_OFFSET (CONFIG_SYS_FSL_PMU_ADDR + 0x8A0) +#define FSL_LSCH3_SVR (CONFIG_SYS_FSL_GUTS_ADDR + \ + 0xA4)
#define CONFIG_SYS_FSL_WRIOP1_ADDR (CONFIG_SYS_IMMR + 0x7B80000) #define CONFIG_SYS_FSL_WRIOP1_MDIO1 (CONFIG_SYS_FSL_WRIOP1_ADDR + 0x16000) @@ -155,6 +157,7 @@ #define TP_INIT_PER_CLUSTER 4 /* This is chassis generation 3 */
+#ifndef __ASSEMBLY__ struct sys_info { unsigned long freq_processor[CONFIG_MAX_CPUS]; unsigned long freq_systembus; @@ -320,4 +323,5 @@ struct ccsr_reset {
uint get_svr(void);
+#endif #endif /* __ARCH_FSL_LSCH3_IMMAP_H_ */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index 58e90d8..c20fa97 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -31,6 +31,7 @@ #define pex_lut_out32(a, v) out_be32(a, v) #endif
+#ifndef __ASSEMBLY__ struct cpu_type { char name[15]; u32 soc_ver; @@ -39,6 +40,7 @@ struct cpu_type {
#define CPU_TYPE_ENTRY(n, v, nc) \ { .name = #n, .soc_ver = SVR_##v, .num_cores = (nc)} +#endif
#define SVR_WO_E 0xFFFFFE #define SVR_LS1012A 0x870400 @@ -51,6 +53,8 @@ struct cpu_type { #define SVR_LS2085A 0x870100 #define SVR_LS2040A 0x870130
+#define SVR_DEV_LS2080A 0x8701 + #define SVR_MAJ(svr) (((svr) >> 4) & 0xf) #define SVR_MIN(svr) (((svr) >> 0) & 0xf) #define SVR_SOC_VER(svr) (((svr) >> 8) & SVR_WO_E) @@ -63,6 +67,7 @@ struct cpu_type { #define AHCI_PORT_TRANS_CFG 0x08000029 #define AHCI_PORT_AXICC_CFG 0x3fffffff
+#ifndef __ASSEMBLY__ /* AHCI (sata) register map */ struct ccsr_ahci { u32 res1[0xa4/4]; /* 0x0 - 0xa4 */ @@ -105,4 +110,5 @@ void erratum_a010315(void);
bool soc_has_dp_ddr(void); bool soc_has_aiop(void); +#endif #endif /* _ASM_ARMV8_FSL_LAYERSCAPE_SOC_H_ */
The QorIQ LS2088A SoC is built on layerscape architecture.
It is similar to LS2080A SoC with some differences like 1)Timer controller offset is different 2)It has A72 cores 3)It supports TZASC module
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc | 58 +++++++++++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/soc.c | 6 ++- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 + arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 4 ++ arch/arm/include/asm/arch-fsl-layerscape/soc.h | 4 ++ board/freescale/ls2080a/MAINTAINERS | 2 +- board/freescale/ls2080aqds/MAINTAINERS | 2 +- board/freescale/ls2080aqds/README | 12 ++-- board/freescale/ls2080ardb/MAINTAINERS | 2 +- board/freescale/ls2080ardb/README | 8 ++-- 10 files changed, 84 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc index f7b949a..c7496c0 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc @@ -4,6 +4,7 @@ SoC overview 2. LS2080A 3. LS1012A 4. LS1046A + 5. LS2088A
LS1043A --------- @@ -169,3 +170,60 @@ The LS1046A SoC includes the following function and features: - Two DUARTs - Integrated flash controller (IFC) supporting NAND and NOR flash - QorIQ platform's trust architecture 2.1 + +LS2088A +-------- +The LS2088A integrated multicore processor combines eight ARM Cortex-A72 +processor cores with high-performance data path acceleration logic and network +and peripheral bus interfaces required for networking, telecom/datacom, +wireless infrastructure, and mil/aerospace applications. + +The LS2088A SoC includes the following function and features: + + - Eight 64-bit ARM Cortex-A72 CPUs + - 1 MB platform cache with ECC + - Two 64-bit DDR4 SDRAM memory controllers with ECC and interleaving support + - One secondary 32-bit DDR4 SDRAM memory controller, intended for use by + the AIOP + - Data path acceleration architecture (DPAA2) incorporating acceleration for + the following functions: + - Packet parsing, classification, and distribution (WRIOP) + - Queue and Hardware buffer management for scheduling, packet sequencing, and + congestion management, buffer allocation and de-allocation (QBMan) + - Cryptography acceleration (SEC) at up to 10 Gbps + - RegEx pattern matching acceleration (PME) at up to 10 Gbps + - Decompression/compression acceleration (DCE) at up to 20 Gbps + - Accelerated I/O processing (AIOP) at up to 20 Gbps + - QDMA engine + - 16 SerDes lanes at up to 10.3125 GHz + - Ethernet interfaces + - Up to eight 10 Gbps Ethernet MACs + - Up to eight 1 / 2.5 Gbps Ethernet MACs + - High-speed peripheral interfaces + - Four PCIe 3.0 controllers, one supporting SR-IOV + - Additional peripheral interfaces + - Two serial ATA (SATA 3.0) controllers + - Two high-speed USB 3.0 controllers with integrated PHY + - Enhanced secure digital host controller (eSDXC/eMMC) + - Serial peripheral interface (SPI) controller + - Quad Serial Peripheral Interface (QSPI) Controller + - Four I2C controllers + - Two DUARTs + - Integrated flash controller (IFC 2.0) supporting NAND and NOR flash + - Support for hardware virtualization and partitioning enforcement + - QorIQ platform's trust architecture 3.0 + - Service processor (SP) provides pre-boot initialization and secure-boot + capabilities + +LS2088A SoC has 3 more similar SoC personalities +1)LS2048A, few difference w.r.t. LS2088A: + a) Four 64-bit ARM v8 Cortex-A72 CPUs + +2)LS2084A, few difference w.r.t. LS2088A: + a) No AIOP + b) No 32-bit DDR3 SDRAM memory + c) 5 * 1/10G + 5 *1G WRIOP + d) No L2 switch + +3)LS2044A, few difference w.r.t. LS2084A: + a) Four 64-bit ARM v8 Cortex-A72 CPUs diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index d68eeba..d43361f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -31,8 +31,10 @@ bool soc_has_dp_ddr(void) struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); u32 svr = gur_in32(&gur->svr);
- /* LS2085A has DP_DDR */ - if (SVR_SOC_VER(svr) == SVR_LS2085A) + /* LS2085A, LS2088A, LS2048A has DP_DDR */ + if ((SVR_SOC_VER(svr) == SVR_LS2085A) || + (SVR_SOC_VER(svr) == SVR_LS2088A) || + (SVR_SOC_VER(svr) == SVR_LS2048A)) return true;
return false; diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 4201e0f..6c3ba49 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -25,6 +25,7 @@ #ifndef L1_CACHE_BYTES #define L1_CACHE_SHIFT 6 #define L1_CACHE_BYTES BIT(L1_CACHE_SHIFT) +#define CONFIG_FSL_TZASC_400 #endif
#define CONFIG_SYS_FSL_OCRAM_BASE 0x18000000 /* initial RAM */ diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index e2d96a1..a97be5c 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -11,6 +11,10 @@ static struct cpu_type cpu_type_list[] = { CPU_TYPE_ENTRY(LS2080A, LS2080A, 8), CPU_TYPE_ENTRY(LS2085A, LS2085A, 8), CPU_TYPE_ENTRY(LS2045A, LS2045A, 4), + CPU_TYPE_ENTRY(LS2088A, LS2088A, 8), + CPU_TYPE_ENTRY(LS2084A, LS2084A, 8), + CPU_TYPE_ENTRY(LS2048A, LS2048A, 4), + CPU_TYPE_ENTRY(LS2044A, LS2044A, 4), CPU_TYPE_ENTRY(LS1043A, LS1043A, 4), CPU_TYPE_ENTRY(LS1023A, LS1023A, 2), CPU_TYPE_ENTRY(LS1046A, LS1046A, 4), diff --git a/arch/arm/include/asm/arch-fsl-layerscape/soc.h b/arch/arm/include/asm/arch-fsl-layerscape/soc.h index c20fa97..5622e74 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/soc.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/soc.h @@ -52,6 +52,10 @@ struct cpu_type { #define SVR_LS2080A 0x870110 #define SVR_LS2085A 0x870100 #define SVR_LS2040A 0x870130 +#define SVR_LS2088A 0x870900 +#define SVR_LS2084A 0x870910 +#define SVR_LS2048A 0x870920 +#define SVR_LS2044A 0x870930
diff --git a/board/freescale/ls2080a/MAINTAINERS b/board/freescale/ls2080a/MAINTAINERS index c8dac99..de137ef 100644 --- a/board/freescale/ls2080a/MAINTAINERS +++ b/board/freescale/ls2080a/MAINTAINERS @@ -1,5 +1,5 @@ LS2080A BOARD -M: York Sun york.sun@nxp.com +M: York Sun york.sun@nxp.com, Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/ls2080a/ F: include/configs/ls2080a_emu.h diff --git a/board/freescale/ls2080aqds/MAINTAINERS b/board/freescale/ls2080aqds/MAINTAINERS index 8f78b67..79877d7 100644 --- a/board/freescale/ls2080aqds/MAINTAINERS +++ b/board/freescale/ls2080aqds/MAINTAINERS @@ -1,5 +1,5 @@ LS2080A BOARD -M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com, Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/ls2080aqds/ F: board/freescale/ls2080a/ls2080aqds.c diff --git a/board/freescale/ls2080aqds/README b/board/freescale/ls2080aqds/README index f288750..2808bd5 100644 --- a/board/freescale/ls2080aqds/README +++ b/board/freescale/ls2080aqds/README @@ -2,14 +2,14 @@ Overview -------- The LS2080A Development System (QDS) is a high-performance computing, evaluation, and development platform that supports the QorIQ LS2080A -Layerscape Architecture processor. The LS2080AQDS provides validation and -SW development platform for the Freescale LS2080A processor series, with -a complete debugging environment. +and LS2088A Layerscape Architecture processor. The LS2080AQDS provides +validation and SW development platform for the Freescale LS2080A, LS2088A +processor series, with a complete debugging environment.
-LS2080A SoC Overview +LS2080A, LS2088A SoC Overview -------------------- -Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS2080A -SoC overview. +Please refer arch/arm/cpu/armv8/fsl-layerscape/doc/README.soc for LS2080A, +LS2088A SoC overview.
LS2080AQDS board Overview ----------------------- diff --git a/board/freescale/ls2080ardb/MAINTAINERS b/board/freescale/ls2080ardb/MAINTAINERS index a20c003..759a146 100644 --- a/board/freescale/ls2080ardb/MAINTAINERS +++ b/board/freescale/ls2080ardb/MAINTAINERS @@ -1,5 +1,5 @@ LS2080A BOARD -M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com +M: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com, Priyanka Jain priyanka.jain@nxp.com S: Maintained F: board/freescale/ls2080ardb/ F: board/freescale/ls2080a/ls2080ardb.c diff --git a/board/freescale/ls2080ardb/README b/board/freescale/ls2080ardb/README index b1613ba..0c9c574 100644 --- a/board/freescale/ls2080ardb/README +++ b/board/freescale/ls2080ardb/README @@ -1,13 +1,13 @@ Overview -------- The LS2080A Reference Design (RDB) is a high-performance computing, -evaluation, and development platform that supports the QorIQ LS2080A +evaluation, and development platform that supports the QorIQ LS2080A, LS2088A Layerscape Architecture processor.
LS2080ARDB board Overview -----------------------
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Priyanka Jain Sent: Wednesday, October 19, 2016 3:07 PM To: u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: [U-Boot] [PATCH 4/5] armv8: fsl-layerscape: Add NXP LS2088A SoC support
- LS2088A
LS1043A
support
- the AIOP
- the following functions:
sequencing, and
- QDMA engine
- Two DUARTs
- capabilities
a) No AIOP
d) No L2 switch
return true;
return false;
Looks like this is getting enabled even for LS2080, LS2085A. Will it not create any problem?
--prabhakar
-----Original Message----- From: Prabhakar Kushwaha Sent: Thursday, October 20, 2016 9:03 AM To: u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: RE: [U-Boot] [PATCH 4/5] armv8: fsl-layerscape: Add NXP LS2088A SoC support
- LS2088A
LS1043A
+LS2088A +-------- +The LS2088A integrated multicore processor combines eight ARM +Cortex-A72 processor cores with high-performance data path +acceleration logic and network +and peripheral bus interfaces required for networking, +telecom/datacom, wireless infrastructure, and mil/aerospace
applications.
support
use by
- the AIOP
for
sequencing, and
- QDMA engine
- Two DUARTs
- flash
- secure-boot capabilities
+LS2088A SoC has 3 more similar SoC personalities 1)LS2048A, few +difference w.r.t. LS2088A:
a) No AIOP
d) No L2 switch
return true;
return false;
--prabhakar
As both LS2088A, LS2080A share same config file, CONFIG_FSL_TZASC_400 is enabled by default. Another patch " [PATCH 3/5] armv8: fsl-layerscape : Check SVR for initializing TZASC" checks SVR before doing TZASC operations. So, this ensures that things work fine on LS2080, LS2085 as well
--Priyanka
NXP ARMv8 SoC LS2080A release all secondary cores in one-go. But other new SoCs like LS2088A, LS1088A release secondary cores one by one to avoid power spike.
Update code to release secondary cores based on SoC SVR Add code to release cores one by one for non LS2080A SoCs
Signed-off-by: Priyanka Jain priyanka.jain@nxp.com Signed-off-by: Raghav Dogra raghav.dogra@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- arch/arm/cpu/armv8/fsl-layerscape/cpu.h | 1 + arch/arm/cpu/armv8/fsl-layerscape/mp.c | 59 ++++++++++++++++++++++++++++-- 3 files changed, 57 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index ce04e48..15d157c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -190,7 +190,7 @@ void enable_caches(void) } #endif
-static inline u32 initiator_type(u32 cluster, int init_id) +inline u32 initiator_type(u32 cluster, int init_id) { struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); u32 idx = (cluster >> (init_id * 8)) & TP_CLUSTER_INIT_MASK; diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.h b/arch/arm/cpu/armv8/fsl-layerscape/cpu.h index 8072f3c..a05f8aa 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.h +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.h @@ -5,4 +5,5 @@ */
int fsl_qoriq_core_to_cluster(unsigned int core); +u32 initiator_type(u32 cluster, int init_id); u32 cpu_mask(void); diff --git a/arch/arm/cpu/armv8/fsl-layerscape/mp.c b/arch/arm/cpu/armv8/fsl-layerscape/mp.c index f607c39..5cf080f 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/mp.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/mp.c @@ -9,6 +9,8 @@ #include <asm/system.h> #include <asm/arch/mp.h> #include <asm/arch/soc.h> +#include "cpu.h" +#include <asm/arch-fsl-layerscape/soc.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -22,11 +24,30 @@ phys_addr_t determine_mp_bootpg(void) return (phys_addr_t)&secondary_boot_code; }
+#ifdef CONFIG_FSL_LSCH3 +void wake_secondary_core_n(int cluster, int core, int cluster_cores) +{ + struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); + struct ccsr_reset __iomem *rst = (void *)(CONFIG_SYS_FSL_RST_ADDR); + u32 mpidr = 0; + + mpidr = ((cluster << 8) | core); + gur_out32(&gur->scratchrw[6], mpidr); + asm volatile("dsb st" : : : "memory"); + rst->brrl |= 1 << ((cluster * cluster_cores) + core); + asm volatile("dsb st" : : : "memory"); + while (gur_in32(&gur->scratchrw[6]) != 0) + ; +} +#endif + int fsl_layerscape_wake_seconday_cores(void) { struct ccsr_gur __iomem *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); #ifdef CONFIG_FSL_LSCH3 struct ccsr_reset __iomem *rst = (void *)(CONFIG_SYS_FSL_RST_ADDR); + u32 svr, ver, cluster, type; + int j = 0, cluster_cores = 0; #elif defined(CONFIG_FSL_LSCH2) struct ccsr_scfg __iomem *scfg = (void *)(CONFIG_SYS_FSL_SCFG_ADDR); #endif @@ -55,10 +76,40 @@ int fsl_layerscape_wake_seconday_cores(void) #ifdef CONFIG_FSL_LSCH3 gur_out32(&gur->bootlocptrh, (u32)(gd->relocaddr >> 32)); gur_out32(&gur->bootlocptrl, (u32)gd->relocaddr); - gur_out32(&gur->scratchrw[6], 1); - asm volatile("dsb st" : : : "memory"); - rst->brrl = cores; - asm volatile("dsb st" : : : "memory"); + + svr = gur_in32(&gur->svr); + ver = SVR_SOC_VER(svr); + if (ver == SVR_LS2080A || ver == SVR_LS2085A) { + gur_out32(&gur->scratchrw[6], 1); + asm volatile("dsb st" : : : "memory"); + rst->brrl = cores; + asm volatile("dsb st" : : : "memory"); + } else { + /* + * Release the cores out of reset one-at-a-time to avoid + * power spikes + */ + i = 0; + cluster = in_le32(&gur->tp_cluster[i].lower); + for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { + type = initiator_type(cluster, j); + if (type && + TP_ITYP_TYPE(type) == TP_ITYP_TYPE_ARM) + cluster_cores++; + } + + do { + cluster = in_le32(&gur->tp_cluster[i].lower); + for (j = 0; j < TP_INIT_PER_CLUSTER; j++) { + type = initiator_type(cluster, j); + if (type && + TP_ITYP_TYPE(type) == TP_ITYP_TYPE_ARM) + wake_secondary_core_n(i, j, + cluster_cores); + } + i++; + } while ((cluster & TP_CLUSTER_EOC) != TP_CLUSTER_EOC); + } #elif defined(CONFIG_FSL_LSCH2) scfg_out32(&scfg->scratchrw[0], (u32)(gd->relocaddr >> 32)); scfg_out32(&scfg->scratchrw[1], (u32)gd->relocaddr);
Prabhakar Kushwaha
Priyanka Jain
york sun
