[U-Boot] [PATCH] powerpc/85xx: improve definition of BR_PHYS_ADDR macro
The BR_PHYS_ADDR(x) macro was missing parentheses around "x" in the macro definition, so callers had to supply their own parenthesis.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/include/asm/fsl_lbc.h | 6 +++--- include/configs/MPC8536DS.h | 9 ++++----- include/configs/MPC8548CDS.h | 3 +-- include/configs/MPC8572DS.h | 9 ++++----- include/configs/P1022DS.h | 2 +- include/configs/P2020DS.h | 9 +++++---- include/configs/corenet_ds.h | 2 +- include/configs/p1_p2_rdb_pc.h | 4 ++-- 8 files changed, 21 insertions(+), 23 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index 2a23d84..d1def75 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -82,10 +82,10 @@ void lbc_sdram_init(void);
/* Convert an address into the right format for the BR registers */ #if defined(CONFIG_PHYS_64BIT) && !defined(CONFIG_FSL_ELBC) -#define BR_PHYS_ADDR(x) ((unsigned long)((x & 0x0ffff8000ULL) | \ - ((x & 0x300000000ULL) >> 19))) +#define BR_PHYS_ADDR(x) \ + ((u32)(((x) & 0x0ffff8000ULL) | (((x) & 0x300000000ULL) >> 19))) #else -#define BR_PHYS_ADDR(x) (x & 0xffff8000) +#define BR_PHYS_ADDR(x) ((u32)(x) & 0xffff8000) #endif
/* OR - Option Registers diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index c26cb63..4a6b64f 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -217,8 +217,7 @@ #endif
#define CONFIG_FLASH_BR_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) \ - | BR_PS_16 | BR_V) + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) | BR_PS_16 | BR_V) #define CONFIG_FLASH_OR_PRELIM 0xf8000ff7
#define CONFIG_SYS_BR1_PRELIM \ @@ -380,14 +379,14 @@ #endif
#define CONFIG_SYS_BR4_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000)) \ + (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x40000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ #define CONFIG_SYS_OR4_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #define CONFIG_SYS_BR5_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x80000)) \ + (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x80000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ @@ -395,7 +394,7 @@ #define CONFIG_SYS_OR5_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
#define CONFIG_SYS_BR6_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0xc0000)) \ + (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0xc0000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 1a6ba69..82bbb3e 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -189,8 +189,7 @@ extern unsigned long get_clock_freq(void); #endif
#define CONFIG_SYS_BR0_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x800000)) \ - | BR_PS_16 | BR_V) + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x800000) | BR_PS_16 | BR_V) #define CONFIG_SYS_BR1_PRELIM \ (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V)
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index d7910e1..eeb9a8d 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -205,8 +205,7 @@
#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) @@ -376,20 +375,20 @@ #define CONFIG_SYS_BR2_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ #define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ #endif -#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000))\ +#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x40000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ #define CONFIG_SYS_OR4_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ -#define CONFIG_SYS_BR5_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x80000))\ +#define CONFIG_SYS_BR5_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x80000)\ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ #define CONFIG_SYS_OR5_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
-#define CONFIG_SYS_BR6_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0xc0000))\ +#define CONFIG_SYS_BR6_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0xc0000)\ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 70d751d..ae7c90e 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -118,7 +118,7 @@ #endif
#define CONFIG_FLASH_BR_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) | BR_PS_16 | BR_V) #define CONFIG_FLASH_OR_PRELIM (OR_AM_128MB | 0xff7)
#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ diff --git a/include/configs/P2020DS.h b/include/configs/P2020DS.h index f0eb029..5a25b56 100644 --- a/include/configs/P2020DS.h +++ b/include/configs/P2020DS.h @@ -239,7 +239,8 @@ #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) | BR_PS_16 | BR_V) +#define CONFIG_FLASH_BR_PRELIM \ + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) | BR_PS_16 | BR_V) #define CONFIG_FLASH_OR_PRELIM 0xf8000ff7
#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) @@ -342,20 +343,20 @@ #define CONFIG_SYS_BR2_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Address */ #define CONFIG_SYS_OR2_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
-#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x40000))\ +#define CONFIG_SYS_BR4_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x40000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ #define CONFIG_SYS_OR4_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ -#define CONFIG_SYS_BR5_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0x80000))\ +#define CONFIG_SYS_BR5_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0x80000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ #define CONFIG_SYS_OR5_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
-#define CONFIG_SYS_BR6_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS + 0xc0000))\ +#define CONFIG_SYS_BR6_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS + 0xc0000) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 8ed37a5..976dfe9 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -211,7 +211,7 @@ #endif
#define CONFIG_SYS_FLASH_BR_PRELIM \ - (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000)) \ + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) \ | BR_PS_16 | BR_V) #define CONFIG_SYS_FLASH_OR_PRELIM ((0xf8000ff7 & ~OR_GPCM_SCY & ~OR_GPCM_EHTR) \ | OR_GPCM_SCY_8 | OR_GPCM_EHTR_CLEAR) diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 9f2951d..f6677c8 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -357,7 +357,7 @@ #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
-#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_FLASH_BASE_PHYS)) \ +#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ | BR_PS_16 | BR_V)
#define CONFIG_FLASH_OR_PRELIM 0xfc000ff7 @@ -401,7 +401,7 @@ #define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 #define CONFIG_SYS_NAND_U_BOOT_RELOC_SP (CONFIG_SYS_NAND_U_BOOT_RELOC + 0x10000)
-#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR((CONFIG_SYS_NAND_BASE_PHYS)) \ +#define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \
The P3060 was cancelled before it went into production, so there's no point in supporting it.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/Makefile | 3 - arch/powerpc/cpu/mpc85xx/fdt.c | 2 +- arch/powerpc/cpu/mpc85xx/p3060_ids.c | 117 ------- arch/powerpc/cpu/mpc85xx/p3060_serdes.c | 118 ------- arch/powerpc/cpu/mpc8xxx/cpu.c | 2 - arch/powerpc/include/asm/config_mpc85xx.h | 19 -- arch/powerpc/include/asm/immap_85xx.h | 2 +- arch/powerpc/include/asm/processor.h | 2 - board/freescale/common/Makefile | 2 - board/freescale/p3060qds/Makefile | 54 ---- board/freescale/p3060qds/ddr.c | 248 --------------- board/freescale/p3060qds/eth.c | 482 ----------------------------- board/freescale/p3060qds/fixed_ddr.c | 214 ------------- board/freescale/p3060qds/p3060qds.c | 338 -------------------- board/freescale/p3060qds/p3060qds.h | 30 -- board/freescale/p3060qds/p3060qds_qixis.h | 74 ----- boards.cfg | 3 - doc/README.p3060qds | 110 ------- drivers/net/fm/Makefile | 1 - drivers/net/fm/p3060.c | 97 ------ include/configs/P3060QDS.h | 48 --- include/configs/corenet_ds.h | 6 +- 22 files changed, 3 insertions(+), 1969 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/p3060_ids.c delete mode 100644 arch/powerpc/cpu/mpc85xx/p3060_serdes.c delete mode 100644 board/freescale/p3060qds/Makefile delete mode 100644 board/freescale/p3060qds/ddr.c delete mode 100644 board/freescale/p3060qds/eth.c delete mode 100644 board/freescale/p3060qds/fixed_ddr.c delete mode 100644 board/freescale/p3060qds/p3060qds.c delete mode 100644 board/freescale/p3060qds/p3060qds.h delete mode 100644 board/freescale/p3060qds/p3060qds_qixis.h delete mode 100644 doc/README.p3060qds delete mode 100644 drivers/net/fm/p3060.c delete mode 100644 include/configs/P3060QDS.h
diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 058d609..7026bca 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -67,7 +67,6 @@ COBJS-$(CONFIG_P2020) += ddr-gen3.o COBJS-$(CONFIG_PPC_P2040) += ddr-gen3.o COBJS-$(CONFIG_PPC_P2041) += ddr-gen3.o COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P3060) += ddr-gen3.o COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o
@@ -82,7 +81,6 @@ COBJS-$(CONFIG_SYS_DPAA_QBMAN) += portals.o COBJS-$(CONFIG_PPC_P2040) += p2041_ids.o COBJS-$(CONFIG_PPC_P2041) += p2041_ids.o COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o -COBJS-$(CONFIG_PPC_P3060) += p3060_ids.o COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o COBJS-$(CONFIG_PPC_P5020) += p5020_ids.o
@@ -116,7 +114,6 @@ COBJS-$(CONFIG_P2020) += p2020_serdes.o COBJS-$(CONFIG_PPC_P2040) += p2041_serdes.o COBJS-$(CONFIG_PPC_P2041) += p2041_serdes.o COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o -COBJS-$(CONFIG_PPC_P3060) += p3060_serdes.o COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o COBJS-$(CONFIG_PPC_P5020) += p5020_serdes.o
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 977770e..58ad323 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -537,7 +537,7 @@ void fdt_fixup_fman_firmware(void *blob) #define fdt_fixup_fman_firmware(x) #endif
-#if defined(CONFIG_PPC_P4080) || defined(CONFIG_PPC_P3060) +#if defined(CONFIG_PPC_P4080) static void fdt_fixup_usb(void *fdt) { ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); diff --git a/arch/powerpc/cpu/mpc85xx/p3060_ids.c b/arch/powerpc/cpu/mpc85xx/p3060_ids.c deleted file mode 100644 index d32142f..0000000 --- a/arch/powerpc/cpu/mpc85xx/p3060_ids.c +++ /dev/null @@ -1,117 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> - -#ifdef CONFIG_SYS_DPAA_QBMAN -struct qportal_info qp_info[CONFIG_SYS_QMAN_NUM_PORTALS] = { - /* dqrr liodn, frame data liodn, liodn off, sdest */ - SET_QP_INFO( 1, 2, 1, 0), - SET_QP_INFO( 3, 4, 2, 1), - SET_QP_INFO( 5, 6, 3, 2), - SET_QP_INFO( 7, 8, 4, 3), - SET_QP_INFO( 9, 10, 5, 4), - SET_QP_INFO(11, 12, 6, 5), - SET_QP_INFO(13, 14, 7, 6), - SET_QP_INFO(15, 16, 8, 7), - SET_QP_INFO(17, 18, 9, 0), /* for now sdest to 0 */ - SET_QP_INFO(19, 20, 10, 0), /* for now sdest to 0 */ -}; -#endif - -struct srio_liodn_id_table srio_liodn_tbl[] = { - SET_SRIO_LIODN_1(1, 198), - SET_SRIO_LIODN_1(2, 199), -}; -int srio_liodn_tbl_sz = ARRAY_SIZE(srio_liodn_tbl); - -struct liodn_id_table liodn_tbl[] = { - SET_USB_LIODN(1, "fsl-usb2-mph", 127), - SET_USB_LIODN(2, "fsl-usb2-dr", 157), - - SET_PCI_LIODN("fsl,qoriq-pcie-v2.2", 1, 193), - SET_PCI_LIODN("fsl,qoriq-pcie-v2.2", 2, 194), - - SET_DMA_LIODN(1, 196), - SET_DMA_LIODN(2, 197), - - SET_GUTS_LIODN("fsl,srio-rmu", 200, rmuliodnr, 0xd3000), - -#ifdef CONFIG_SYS_DPAA_QBMAN - SET_QMAN_LIODN(31), - SET_BMAN_LIODN(32), -#endif - SET_PME_LIODN(128), -}; -int liodn_tbl_sz = ARRAY_SIZE(liodn_tbl); - -#ifdef CONFIG_SYS_DPAA_FMAN -struct liodn_id_table fman1_liodn_tbl[] = { - SET_FMAN_RX_1G_LIODN(1, 0, 11), - SET_FMAN_RX_1G_LIODN(1, 1, 12), - SET_FMAN_RX_1G_LIODN(1, 2, 13), - SET_FMAN_RX_1G_LIODN(1, 3, 14), -}; -int fman1_liodn_tbl_sz = ARRAY_SIZE(fman1_liodn_tbl); - -#if (CONFIG_SYS_NUM_FMAN == 2) -struct liodn_id_table fman2_liodn_tbl[] = { - SET_FMAN_RX_1G_LIODN(2, 0, 16), - SET_FMAN_RX_1G_LIODN(2, 1, 17), - SET_FMAN_RX_1G_LIODN(2, 2, 18), - SET_FMAN_RX_1G_LIODN(2, 3, 19), -}; -int fman2_liodn_tbl_sz = ARRAY_SIZE(fman2_liodn_tbl); -#endif -#endif - -struct liodn_id_table sec_liodn_tbl[] = { - SET_SEC_JR_LIODN_ENTRY(0, 146, 154), - SET_SEC_JR_LIODN_ENTRY(1, 147, 155), - SET_SEC_JR_LIODN_ENTRY(2, 178, 186), - SET_SEC_JR_LIODN_ENTRY(3, 179, 187), - SET_SEC_RTIC_LIODN_ENTRY(a, 144), - SET_SEC_RTIC_LIODN_ENTRY(b, 145), - SET_SEC_RTIC_LIODN_ENTRY(c, 176), - SET_SEC_RTIC_LIODN_ENTRY(d, 177), - SET_SEC_DECO_LIODN_ENTRY(0, 129, 161), - SET_SEC_DECO_LIODN_ENTRY(1, 130, 162), - SET_SEC_DECO_LIODN_ENTRY(2, 131, 163), - SET_SEC_DECO_LIODN_ENTRY(3, 132, 164), - SET_SEC_DECO_LIODN_ENTRY(4, 133, 165), -}; -int sec_liodn_tbl_sz = ARRAY_SIZE(sec_liodn_tbl); - -struct liodn_id_table liodn_bases[] = { - [FSL_HW_PORTAL_SEC] = SET_LIODN_BASE_2(96, 106), -#ifdef CONFIG_SYS_DPAA_FMAN - [FSL_HW_PORTAL_FMAN1] = SET_LIODN_BASE_1(32), -#if (CONFIG_SYS_NUM_FMAN == 2) - [FSL_HW_PORTAL_FMAN2] = SET_LIODN_BASE_1(64), -#endif -#endif -#ifdef CONFIG_SYS_DPAA_PME - [FSL_HW_PORTAL_PME] = SET_LIODN_BASE_2(116, 133), -#endif -}; diff --git a/arch/powerpc/cpu/mpc85xx/p3060_serdes.c b/arch/powerpc/cpu/mpc85xx/p3060_serdes.c deleted file mode 100644 index e720dcf..0000000 --- a/arch/powerpc/cpu/mpc85xx/p3060_serdes.c +++ /dev/null @@ -1,118 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <asm/io.h> -#include <asm/fsl_serdes.h> -#include <asm/processor.h> -#include <asm/io.h> -#include "fsl_corenet_serdes.h" - -static u8 serdes_cfg_tbl[][SRDS_MAX_LANES] = { - [0x03] = {PCIE1, PCIE1, PCIE1, PCIE1, PCIE2, PCIE2, PCIE2, PCIE2, - SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC4, SGMII_FM2_DTSEC1, - SGMII_FM1_DTSEC1, SGMII_FM2_DTSEC2, SGMII_FM1_DTSEC2, - NONE, NONE, AURORA, AURORA}, - [0x06] = {PCIE1, PCIE1, PCIE1, PCIE1, NONE, NONE, SGMII_FM2_DTSEC3, - SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC4, - SGMII_FM2_DTSEC1, SGMII_FM1_DTSEC1, SGMII_FM2_DTSEC2, - SGMII_FM1_DTSEC2, NONE, NONE, AURORA, AURORA}, - [0x16] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, - AURORA, AURORA, SGMII_FM2_DTSEC1, SGMII_FM1_DTSEC1, - SGMII_FM2_DTSEC2, SGMII_FM1_DTSEC2, SGMII_FM2_DTSEC3, - SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC4}, - [0x19] = {SRIO2, SRIO2, SRIO2, SRIO2, SRIO1, SRIO1, SRIO1, SRIO1, - AURORA, AURORA, PCIE2, PCIE2, PCIE2, PCIE2, SGMII_FM2_DTSEC3, - SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC4}, - [0x1c] = {NONE, NONE, SRIO1, SRIO2, NONE, NONE, NONE, NONE, - AURORA, AURORA, SGMII_FM2_DTSEC1, SGMII_FM1_DTSEC1, - SGMII_FM2_DTSEC2, SGMII_FM1_DTSEC2, SGMII_FM2_DTSEC3, - SGMII_FM1_DTSEC3, SGMII_FM2_DTSEC4, SGMII_FM1_DTSEC4}, -}; - -enum srds_prtcl serdes_get_prtcl(int cfg, int lane) -{ - if (!serdes_lane_enabled(lane)) - return NONE; - - return serdes_cfg_tbl[cfg][lane]; -} - -int is_serdes_prtcl_valid(u32 prtcl) -{ - int i; - - if (prtcl > ARRAY_SIZE(serdes_cfg_tbl)) - return 0; - - for (i = 0; i < SRDS_MAX_LANES; i++) { - if (serdes_cfg_tbl[prtcl][i] != NONE) - return 1; - } - - return 0; -} - -void soc_serdes_init(void) -{ - /* - * On the P3060 the devdisr2 register does not correctly reflect - * the state of the MACs based on the RCW fields. So disable the MACs - * based on the srds_prtcl and ec1, ec2, ec3 fields - */ - - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 devdisr2 = in_be32(&gur->devdisr2); - u32 rcwsr11 = in_be32(&gur->rcwsr[11]); - - /* NOTE: Leave FM1-1,FM1-2 alone for MDIO access */ - - if (!is_serdes_configured(SGMII_FM1_DTSEC3)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC1_3; - - if (!is_serdes_configured(SGMII_FM1_DTSEC4)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC1_4; - - if (!is_serdes_configured(SGMII_FM2_DTSEC1)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC2_1; - - if (!is_serdes_configured(SGMII_FM2_DTSEC2)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC2_2; - - if (!is_serdes_configured(SGMII_FM2_DTSEC3)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC2_3; - - if (!is_serdes_configured(SGMII_FM2_DTSEC4)) - devdisr2 |= FSL_CORENET_DEVDISR2_DTSEC2_4; - - if ((rcwsr11 & FSL_CORENET_RCWSR11_EC2) == - FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2) { - devdisr2 &= ~FSL_CORENET_DEVDISR2_DTSEC1_2; - } - - if ((rcwsr11 & FSL_CORENET_RCWSR11_EC2) == - FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1) { - devdisr2 &= ~FSL_CORENET_DEVDISR2_DTSEC2_1; - } - - out_be32(&gur->devdisr2, devdisr2); -} diff --git a/arch/powerpc/cpu/mpc8xxx/cpu.c b/arch/powerpc/cpu/mpc8xxx/cpu.c index 0365ca8..c80567a 100644 --- a/arch/powerpc/cpu/mpc8xxx/cpu.c +++ b/arch/powerpc/cpu/mpc8xxx/cpu.c @@ -103,8 +103,6 @@ struct cpu_type cpu_type_list [] = { CPU_TYPE_ENTRY(P2041, P2041_E, 4), CPU_TYPE_ENTRY(P3041, P3041, 4), CPU_TYPE_ENTRY(P3041, P3041_E, 4), - CPU_TYPE_ENTRY_MASK(P3060, P3060, 6, 0xf3), - CPU_TYPE_ENTRY_MASK(P3060, P3060_E, 6, 0xf3), CPU_TYPE_ENTRY(P4040, P4040, 4), CPU_TYPE_ENTRY(P4040, P4040_E, 4), CPU_TYPE_ENTRY(P4080, P4080, 8), diff --git a/arch/powerpc/include/asm/config_mpc85xx.h b/arch/powerpc/include/asm/config_mpc85xx.h index 191629b..e36b8b2 100644 --- a/arch/powerpc/include/asm/config_mpc85xx.h +++ b/arch/powerpc/include/asm/config_mpc85xx.h @@ -389,25 +389,6 @@ #define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 #define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5
-#elif defined(CONFIG_PPC_P3060) -#define CONFIG_MAX_CPUS 8 -#define CONFIG_SYS_FSL_NUM_CC_PLLS 4 -#define CONFIG_SYS_FSL_NUM_LAWS 32 -#define CONFIG_SYS_FSL_SEC_COMPAT 4 -#define CONFIG_SYS_NUM_FMAN 2 -#define CONFIG_SYS_NUM_FM1_DTSEC 4 -#define CONFIG_SYS_NUM_FM2_DTSEC 4 -#define CONFIG_NUM_DDR_CONTROLLERS 1 -#define CONFIG_SYS_FM_MURAM_SIZE 0x28000 -#define CONFIG_SYS_FSL_TBCLK_DIV 16 -#define CONFIG_SYS_FSL_PCIE_COMPAT "fsl,qoriq-pcie-v2.2" -#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 -#define CONFIG_SYS_FSL_ERRATUM_DDR_A003 -#define CONFIG_SYS_FSL_ERRATUM_CPU_A003999 -#define CONFIG_SYS_FSL_SRIO_MAX_PORTS 2 -#define CONFIG_SYS_FSL_SRIO_OB_WIN_NUM 9 -#define CONFIG_SYS_FSL_SRIO_IB_WIN_NUM 5 - #elif defined(CONFIG_PPC_P4040) #define CONFIG_MAX_CPUS 4 #define CONFIG_SYS_FSL_NUM_CC_PLLS 4 diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 632e3c1..a684a58b 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1764,7 +1764,7 @@ typedef struct ccsr_gur { #define FSL_CORENET_RCWSR8_HOST_AGT_B1 0x00e00000 #define FSL_CORENET_RCWSR8_HOST_AGT_B2 0x00100000 #define FSL_CORENET_RCWSR11_EC1 0x00c00000 /* bits 360..361 */ -#if defined(CONFIG_PPC_P4080) || defined(CONFIG_PPC_P3060) +#ifdef CONFIG_PPC_P4080 #define FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1 0x00000000 #define FSL_CORENET_RCWSR11_EC1_FM1_USB1 0x00800000 #define FSL_CORENET_RCWSR11_EC2 0x001c0000 /* bits 363..365 */ diff --git a/arch/powerpc/include/asm/processor.h b/arch/powerpc/include/asm/processor.h index 4e32639..a8882d1 100644 --- a/arch/powerpc/include/asm/processor.h +++ b/arch/powerpc/include/asm/processor.h @@ -1121,8 +1121,6 @@ #define SVR_P2041_E 0x821801 #define SVR_P3041 0x821103 #define SVR_P3041_E 0x821903 -#define SVR_P3060 0x820002 -#define SVR_P3060_E 0x820802 #define SVR_P4040 0x820100 #define SVR_P4040_E 0x820900 #define SVR_P4080 0x820000 diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 0b40dc7..54cb098 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -51,14 +51,12 @@ COBJS-$(CONFIG_MPC8572DS) += ics307_clk.o COBJS-$(CONFIG_P1022DS) += ics307_clk.o COBJS-$(CONFIG_P2020DS) += ics307_clk.o COBJS-$(CONFIG_P3041DS) += ics307_clk.o -COBJS-$(CONFIG_P3060QDS) += ics307_clk.o COBJS-$(CONFIG_P4080DS) += ics307_clk.o COBJS-$(CONFIG_P5020DS) += ics307_clk.o
# deal with common files for P-series corenet based devices SUBLIB-$(CONFIG_P2041RDB) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P3041DS) += p_corenet/libp_corenet.o -SUBLIB-$(CONFIG_P3060QDS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P4080DS) += p_corenet/libp_corenet.o SUBLIB-$(CONFIG_P5020DS) += p_corenet/libp_corenet.o
diff --git a/board/freescale/p3060qds/Makefile b/board/freescale/p3060qds/Makefile deleted file mode 100644 index ae136f4..0000000 --- a/board/freescale/p3060qds/Makefile +++ /dev/null @@ -1,54 +0,0 @@ -# -# Copyright 2011 Freescale Semiconductor, Inc. -# (C) Copyright 2001-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# See file CREDITS for list of people who contributed to this -# project. -# -# This program is free software; you can redistribute it and/or -# modify it under the terms of the GNU General Public License as -# published by the Free Software Foundation; either version 2 of -# the License, or (at your option) any later version. -# -# This program is distributed in the hope that it will be useful, -# but WITHOUT ANY WARRANTY; without even the implied warranty of -# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -# GNU General Public License for more details. -# -# You should have received a copy of the GNU General Public License -# along with this program; if not, write to the Free Software -# Foundation, Inc., 59 Temple Place, Suite 330, Boston, -# MA 02111-1307 USA -# - -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y += $(BOARD).o -COBJS-y += ddr.o -COBJS-y += eth.o -COBJS-y += fixed_ddr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) $(SOBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/freescale/p3060qds/ddr.c b/board/freescale/p3060qds/ddr.c deleted file mode 100644 index 9affbf0..0000000 --- a/board/freescale/p3060qds/ddr.c +++ /dev/null @@ -1,248 +0,0 @@ -/* - * Copyright 2009-2011 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * Version 2 as published by the Free Software Foundation. - */ - -#include <common.h> -#include <i2c.h> -#include <hwconfig.h> -#include <asm/mmu.h> -#include <asm/fsl_ddr_sdram.h> -#include <asm/fsl_ddr_dimm_params.h> -#include <asm/fsl_law.h> - -#include "p3060qds.h" - -/* - * Fixed sdram init -- doesn't use serial presence detect. - */ - -phys_size_t fixed_sdram(void) -{ - int i; - char buf[32]; - fsl_ddr_cfg_regs_t ddr_cfg_regs; - phys_size_t ddr_size; - unsigned int lawbar1_target_id; - ulong ddr_freq, ddr_freq_mhz; - - ddr_freq = get_ddr_freq(0); - ddr_freq_mhz = ddr_freq / 1000000; - - printf("Configuring DDR for %s MT/s data rate\n", - strmhz(buf, ddr_freq)); - - for (i = 0; fixed_ddr_parm_0[i].max_freq > 0; i++) { - if ((ddr_freq_mhz > fixed_ddr_parm_0[i].min_freq) && - (ddr_freq_mhz <= fixed_ddr_parm_0[i].max_freq)) { - memcpy(&ddr_cfg_regs, - fixed_ddr_parm_0[i].ddr_settings, - sizeof(ddr_cfg_regs)); - break; - } - } - - if (fixed_ddr_parm_0[i].max_freq == 0) - panic("Unsupported DDR data rate %s MT/s data rate\n", - strmhz(buf, ddr_freq)); - - ddr_size = (phys_size_t) CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; - ddr_cfg_regs.ddr_cdr1 = DDR_CDR1_DHC_EN; - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0); - - /* - * setup laws for DDR. If not interleaving, presuming half memory on - * DDR1 and the other half on DDR2 - */ - if (fixed_ddr_parm_0[i].ddr_settings->cs[0].config & 0x20000000) { - if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, - ddr_size, - LAW_TRGT_IF_DDR_INTRLV) < 0) { - printf("ERROR setting Local Access Windows for DDR\n"); - return 0; - } - } else { - lawbar1_target_id = LAW_TRGT_IF_DDR_1; - if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, - ddr_size, - lawbar1_target_id) < 0) { - printf("ERROR setting Local Access Windows for DDR\n"); - return 0; - } - } - return ddr_size; -} - -struct board_specific_params { - u32 n_ranks; - u32 datarate_mhz_high; - u32 clk_adjust; - u32 wrlvl_start; - u32 cpo; - u32 write_data_delay; - u32 force_2T; -}; - -/* - * This table contains all valid speeds we want to override with board - * specific parameters. datarate_mhz_high values need to be in ascending order - * for each n_ranks group. - */ -static const struct board_specific_params udimm[] = { - /* - * memory controller 0 - * num| hi| clk| wrlvl | cpo |wrdata|2T - * ranks| mhz|adjst| start | |delay | - */ - {4, 850, 4, 6, 0xff, 2, 0}, - {4, 950, 5, 7, 0xff, 2, 0}, - {4, 1050, 5, 8, 0xff, 2, 0}, - {4, 1250, 5, 10, 0xff, 2, 0}, - {4, 1350, 5, 11, 0xff, 2, 0}, - {4, 1666, 5, 12, 0xff, 2, 0}, - {2, 850, 5, 6, 0xff, 2, 0}, - {2, 950, 5, 7, 0xff, 2, 0}, - {2, 1250, 4, 6, 0xff, 2, 0}, - {2, 1350, 5, 7, 0xff, 2, 0}, - {2, 1666, 5, 8, 0xff, 2, 0}, - {1, 850, 4, 5, 0xff, 2, 0}, - {1, 950, 4, 7, 0xff, 2, 0}, - {1, 1666, 4, 8, 0xff, 2, 0}, - {} -}; - -static const struct board_specific_params rdimm[] = { - /* - * memory controller 0 - * num| hi| clk| wrlvl | cpo |wrdata|2T - * ranks| mhz|adjst| start | |delay | - */ - {4, 850, 4, 6, 0xff, 2, 0}, - {4, 950, 5, 7, 0xff, 2, 0}, - {4, 1050, 5, 8, 0xff, 2, 0}, - {4, 1250, 5, 10, 0xff, 2, 0}, - {4, 1350, 5, 11, 0xff, 2, 0}, - {4, 1666, 5, 12, 0xff, 2, 0}, - {2, 850, 4, 6, 0xff, 2, 0}, - {2, 1050, 4, 7, 0xff, 2, 0}, - {2, 1666, 4, 8, 0xff, 2, 0}, - {1, 850, 4, 5, 0xff, 2, 0}, - {1, 950, 4, 7, 0xff, 2, 0}, - {1, 1666, 4, 8, 0xff, 2, 0}, - {} -}; - -void fsl_ddr_board_options(memctl_options_t *popts, - dimm_params_t *pdimm, - unsigned int ctrl_num) -{ - const struct board_specific_params *pbsp, *pbsp_highest = NULL; - ulong ddr_freq; - - if (ctrl_num) { - printf("Wrong parameter for controller number %d", ctrl_num); - return; - } - if (!pdimm->n_ranks) - return; - - if (popts->registered_dimm_en) - pbsp = rdimm; - else - pbsp = udimm; - - /* Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr - * freqency and n_banks specified in board_specific_parameters table. - */ - ddr_freq = get_ddr_freq(0) / 1000000; - while (pbsp->datarate_mhz_high) { - if (pbsp->n_ranks == pdimm->n_ranks) { - if (ddr_freq <= pbsp->datarate_mhz_high) { - popts->cpo_override = pbsp->cpo; - popts->write_data_delay = - pbsp->write_data_delay; - popts->clk_adjust = pbsp->clk_adjust; - popts->wrlvl_start = pbsp->wrlvl_start; - popts->twoT_en = pbsp->force_2T; - goto found; - } - pbsp_highest = pbsp; - } - pbsp++; - } - - if (pbsp_highest) { - printf("Error: board specific timing not found " - "for data rate %lu MT/s!\n" - "Trying to use the highest speed (%u) parameters\n", - ddr_freq, pbsp_highest->datarate_mhz_high); - popts->cpo_override = pbsp_highest->cpo; - popts->write_data_delay = pbsp_highest->write_data_delay; - popts->clk_adjust = pbsp_highest->clk_adjust; - popts->wrlvl_start = pbsp_highest->wrlvl_start; - popts->twoT_en = pbsp_highest->force_2T; - } else { - panic("DIMM is not supported by this board"); - } - - -found: - - /* - * The datasheet of HMT125U7BFR8C-H9 blocks CL=7 as reservered. - * However SPD still claims CL=7 is supported. Extensive tests - * confirmed this board cannot work stably with CL=7 with this - * particular DIMM. - */ - if (ddr_freq >= 800 && ddr_freq < 1066 && \ - !strncmp(pdimm[0].mpart, "HMT125U7BFR8C-H9", 16)) { - popts->cas_latency_override = 1; - popts->cas_latency_override_value = 8; - debug("Override CL to 8\n"); - } - /* - * Factors to consider for half-strength driver enable: - * - number of DIMMs installed - */ - popts->half_strength_driver_enable = 0; - /* - * Write leveling override - */ - popts->wrlvl_override = 1; - popts->wrlvl_sample = 0xf; - - /* - * Rtt and Rtt_WR override - */ - popts->rtt_override = 0; - - /* Enable ZQ calibration */ - popts->zq_en = 1; - - /* DHC_EN =1, ODT = 60 Ohm */ - popts->ddr_cdr1 = DDR_CDR1_DHC_EN; -} - -phys_size_t initdram(int board_type) -{ - phys_size_t dram_size; - - puts("Initializing...."); - - if (fsl_use_spd()) { - puts("using SPD\n"); - dram_size = fsl_ddr_sdram(); - } else { - puts("using fixed parameters\n"); - dram_size = fixed_sdram(); - } - - dram_size = setup_ddr_tlbs(dram_size / 0x100000); - dram_size *= 0x100000; - - debug(" DDR: "); - return dram_size; -} diff --git a/board/freescale/p3060qds/eth.c b/board/freescale/p3060qds/eth.c deleted file mode 100644 index 3f812db..0000000 --- a/board/freescale/p3060qds/eth.c +++ /dev/null @@ -1,482 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <netdev.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/cache.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_ddr_sdram.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <malloc.h> -#include <fm_eth.h> -#include <fsl_mdio.h> -#include <miiphy.h> -#include <phy.h> -#include <asm/fsl_dtsec.h> - -#include "../common/qixis.h" -#include "../common/fman.h" - -#include "p3060qds_qixis.h" - -#define EMI_NONE 0xffffffff -#define EMI1_RGMII1 0 -#define EMI1_SLOT1 1 -#define EMI1_SLOT2 2 -#define EMI1_SLOT3 3 -#define EMI1_RGMII2 4 - -static int mdio_mux[NUM_FM_PORTS]; - -static char *mdio_names[5] = { - "P3060QDS_MDIO0", - "P3060QDS_MDIO1", - "P3060QDS_MDIO2", - "P3060QDS_MDIO3", - "P3060QDS_MDIO4", -}; - -/* - * Mapping of all 18 SERDES lanes to board slots. - * A value of '0' here means that the mapping must be determined - * dynamically, Lane 8/9/16/17 map to Slot1 or Aurora debug - */ -static u8 lane_to_slot[] = { - 4, 4, 4, 4, 3, 3, 3, 3, 0, 0, 2, 2, 2, 2, 1, 1, 0, 0 -}; - -static char *p3060qds_mdio_name_for_muxval(u32 muxval) -{ - return mdio_names[muxval]; -} - -struct mii_dev *mii_dev_for_muxval(u32 muxval) -{ - struct mii_dev *bus; - char *name = p3060qds_mdio_name_for_muxval(muxval); - - if (!name) { - printf("No bus for muxval %x\n", muxval); - return NULL; - } - - bus = miiphy_get_dev_by_name(name); - - if (!bus) { - printf("No bus by name %s\n", name); - return NULL; - } - - return bus; -} - -struct p3060qds_mdio { - u32 muxval; - struct mii_dev *realbus; -}; - -static void p3060qds_mux_mdio(u32 muxval) -{ - u8 brdcfg4; - - brdcfg4 = QIXIS_READ(brdcfg[4]); - brdcfg4 &= ~BRDCFG4_EMISEL_MASK; - brdcfg4 |= (muxval << 4); - QIXIS_WRITE(brdcfg[4], brdcfg4); -} - -static int p3060qds_mdio_read(struct mii_dev *bus, int addr, int devad, - int regnum) -{ - struct p3060qds_mdio *priv = bus->priv; - - p3060qds_mux_mdio(priv->muxval); - - return priv->realbus->read(priv->realbus, addr, devad, regnum); -} - -static int p3060qds_mdio_write(struct mii_dev *bus, int addr, int devad, - int regnum, u16 value) -{ - struct p3060qds_mdio *priv = bus->priv; - - p3060qds_mux_mdio(priv->muxval); - - return priv->realbus->write(priv->realbus, addr, devad, regnum, value); -} - -static int p3060qds_mdio_reset(struct mii_dev *bus) -{ - struct p3060qds_mdio *priv = bus->priv; - - return priv->realbus->reset(priv->realbus); -} - -static int p3060qds_mdio_init(char *realbusname, u32 muxval) -{ - struct p3060qds_mdio *pmdio; - struct mii_dev *bus = mdio_alloc(); - - if (!bus) { - printf("Failed to allocate P3060QDS MDIO bus\n"); - return -1; - } - - pmdio = malloc(sizeof(*pmdio)); - if (!pmdio) { - printf("Failed to allocate P3060QDS private data\n"); - free(bus); - return -1; - } - - bus->read = p3060qds_mdio_read; - bus->write = p3060qds_mdio_write; - bus->reset = p3060qds_mdio_reset; - sprintf(bus->name, p3060qds_mdio_name_for_muxval(muxval)); - - pmdio->realbus = miiphy_get_dev_by_name(realbusname); - - if (!pmdio->realbus) { - printf("No bus with name %s\n", realbusname); - free(bus); - free(pmdio); - return -1; - } - - pmdio->muxval = muxval; - bus->priv = pmdio; - - return mdio_register(bus); -} - -void board_ft_fman_fixup_port(void *blob, char * prop, phys_addr_t pa, - enum fm_port port, int offset) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - int srds_prtcl = (in_be32(&gur->rcwsr[4]) & - FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; - - if (mdio_mux[port] == EMI1_RGMII1) - fdt_set_phy_handle(blob, prop, pa, "phy_rgmii1"); - - if (mdio_mux[port] == EMI1_RGMII2) - fdt_set_phy_handle(blob, prop, pa, "phy_rgmii2"); - - if ((mdio_mux[port] == EMI1_SLOT1) && ((srds_prtcl == 0x3) - || (srds_prtcl == 0x6))) { - switch (port) { - case FM2_DTSEC4: - fdt_set_phy_handle(blob, prop, pa, "phy2_slot1"); - break; - case FM1_DTSEC4: - fdt_set_phy_handle(blob, prop, pa, "phy3_slot1"); - break; - default: - break; - } - } - - if (mdio_mux[port] == EMI1_SLOT3) { - switch (port) { - case FM2_DTSEC3: - fdt_set_phy_handle(blob, prop, pa, "phy0_slot3"); - break; - case FM1_DTSEC3: - fdt_set_phy_handle(blob, prop, pa, "phy1_slot3"); - break; - default: - break; - } - } -} - -void fdt_fixup_board_enet(void *fdt) -{ - int i, lane, idx; - - for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { - idx = i - FM1_DTSEC1; - switch (fm_info_get_enet_if(i)) { - case PHY_INTERFACE_MODE_SGMII: - lane = serdes_get_first_lane(SGMII_FM1_DTSEC1 + idx); - if (lane < 0) - break; - - switch (mdio_mux[i]) { - case EMI1_SLOT1: - if (lane >= 14) { - fdt_status_okay_by_alias(fdt, - "emi1_slot1"); - fdt_status_disabled_by_alias(fdt, - "emi1_slot1_bk1"); - } else { - fdt_status_disabled_by_alias(fdt, - "emi1_slot1"); - fdt_status_okay_by_alias(fdt, - "emi1_slot1_bk1"); - } - break; - case EMI1_SLOT2: - fdt_status_okay_by_alias(fdt, "emi1_slot2"); - break; - case EMI1_SLOT3: - fdt_status_okay_by_alias(fdt, "emi1_slot3"); - break; - } - break; - case PHY_INTERFACE_MODE_RGMII: - if (i == FM1_DTSEC1) - fdt_status_okay_by_alias(fdt, "emi1_rgmii1"); - - if (i == FM1_DTSEC2) - fdt_status_okay_by_alias(fdt, "emi1_rgmii2"); - break; - default: - break; - } - } -#if (CONFIG_SYS_NUM_FMAN == 2) - for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { - idx = i - FM2_DTSEC1; - switch (fm_info_get_enet_if(i)) { - case PHY_INTERFACE_MODE_SGMII: - lane = serdes_get_first_lane(SGMII_FM2_DTSEC1 + idx); - if (lane >= 0) { - switch (mdio_mux[i]) { - case EMI1_SLOT1: - if (lane >= 14) - fdt_status_okay_by_alias(fdt, - "emi1_slot1"); - else - fdt_status_okay_by_alias(fdt, - "emi1_slot1_bk1"); - break; - case EMI1_SLOT2: - fdt_status_okay_by_alias(fdt, - "emi1_slot2"); - break; - case EMI1_SLOT3: - fdt_status_okay_by_alias(fdt, - "emi1_slot3"); - break; - } - } - break; - default: - break; - } - } -#endif -} - -static void initialize_lane_to_slot(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - int sdprtl = (in_be32(&gur->rcwsr[4]) & - FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; - - switch (sdprtl) { - case 0x03: - case 0x06: - lane_to_slot[8] = 1; - lane_to_slot[9] = lane_to_slot[8]; - lane_to_slot[16] = 5; - lane_to_slot[17] = lane_to_slot[16]; - break; - case 0x16: - case 0x19: - case 0x1C: - lane_to_slot[8] = 5; - lane_to_slot[9] = lane_to_slot[8]; - lane_to_slot[16] = 1; - lane_to_slot[17] = lane_to_slot[16]; - break; - default: - puts("Invalid SerDes protocol for P3060QDS\n"); - break; - } -} - -int board_eth_init(bd_t *bis) -{ -#ifdef CONFIG_FMAN_ENET - struct dtsec *tsec = (void *)CONFIG_SYS_FSL_FM1_DTSEC1_ADDR; - int i; - struct fsl_pq_mdio_info dtsec_mdio_info; - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - int srds_cfg = (in_be32(&gur->rcwsr[4]) & - FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; - - initialize_lane_to_slot(); - - /* - * Set TBIPA on FM1@DTSEC1. This is needed for configurations - * where FM1@DTSEC1 isn't used directly, since it provides - * MDIO for other ports. - */ - out_be32(&tsec->tbipa, CONFIG_SYS_TBIPA_VALUE); - - /* Initialize the mdio_mux array so we can recognize empty elements */ - for (i = 0; i < NUM_FM_PORTS; i++) - mdio_mux[i] = EMI_NONE; - - dtsec_mdio_info.regs = - (struct tsec_mii_mng *)CONFIG_SYS_FM1_DTSEC1_MDIO_ADDR; - dtsec_mdio_info.name = DEFAULT_FM_MDIO_NAME; - - /* Register the 1G MDIO bus */ - fsl_pq_mdio_init(bis, &dtsec_mdio_info); - - /* Register the 5 muxing front-ends to the MDIO buses */ - if (fm_info_get_enet_if(FM1_DTSEC1) == PHY_INTERFACE_MODE_RGMII) - p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII1); - - if (fm_info_get_enet_if(FM1_DTSEC2) == PHY_INTERFACE_MODE_RGMII) - p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_RGMII2); - p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT1); - p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT2); - p3060qds_mdio_init(DEFAULT_FM_MDIO_NAME, EMI1_SLOT3); - - if (fm_info_get_enet_if(FM1_DTSEC1) == PHY_INTERFACE_MODE_RGMII) - fm_info_set_phy_address(FM1_DTSEC1, 1); /* RGMII1 */ - else if (fm_info_get_enet_if(FM1_DTSEC1) == PHY_INTERFACE_MODE_SGMII) - fm_info_set_phy_address(FM1_DTSEC1, SGMII_CARD_PORT2_PHY_ADDR); - - if (fm_info_get_enet_if(FM1_DTSEC2) == PHY_INTERFACE_MODE_RGMII) - fm_info_set_phy_address(FM1_DTSEC2, 2); /* RGMII2 */ - else if (fm_info_get_enet_if(FM1_DTSEC2) == PHY_INTERFACE_MODE_SGMII) - fm_info_set_phy_address(FM1_DTSEC2, SGMII_CARD_PORT4_PHY_ADDR); - - fm_info_set_phy_address(FM2_DTSEC1, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC2, SGMII_CARD_PORT3_PHY_ADDR); - - switch (srds_cfg) { - case 0x03: - case 0x06: - fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC3, SGMII_CARD_PORT4_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC4, SGMII_CARD_PORT2_PHY_ADDR); - break; - case 0x16: - case 0x19: - case 0x1C: - fm_info_set_phy_address(FM2_DTSEC3, SGMII_CARD_PORT1_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC3, SGMII_CARD_PORT2_PHY_ADDR); - fm_info_set_phy_address(FM2_DTSEC4, SGMII_CARD_PORT3_PHY_ADDR); - fm_info_set_phy_address(FM1_DTSEC4, SGMII_CARD_PORT4_PHY_ADDR); - break; - default: - puts("Invalid SerDes protocol for P3060QDS\n"); - break; - } - - for (i = FM1_DTSEC1; i < FM1_DTSEC1 + CONFIG_SYS_NUM_FM1_DTSEC; i++) { - int idx = i - FM1_DTSEC1, lane, slot; - switch (fm_info_get_enet_if(i)) { - case PHY_INTERFACE_MODE_SGMII: - lane = serdes_get_first_lane(SGMII_FM1_DTSEC1 + idx); - if (lane < 0) - break; - slot = lane_to_slot[lane]; - if (QIXIS_READ(present) & (1 << (slot - 1))) - fm_disable_port(i); - switch (slot) { - case 1: - mdio_mux[i] = EMI1_SLOT1; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - case 2: - mdio_mux[i] = EMI1_SLOT2; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - case 3: - mdio_mux[i] = EMI1_SLOT3; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - }; - break; - case PHY_INTERFACE_MODE_RGMII: - if (i == FM1_DTSEC1) { - mdio_mux[i] = EMI1_RGMII1; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - } else if (i == FM1_DTSEC2) { - mdio_mux[i] = EMI1_RGMII2; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - } - break; - default: - break; - } - } - -#if (CONFIG_SYS_NUM_FMAN == 2) - for (i = FM2_DTSEC1; i < FM2_DTSEC1 + CONFIG_SYS_NUM_FM2_DTSEC; i++) { - int idx = i - FM2_DTSEC1, lane, slot; - switch (fm_info_get_enet_if(i)) { - case PHY_INTERFACE_MODE_SGMII: - lane = serdes_get_first_lane(SGMII_FM2_DTSEC1 + idx); - if (lane < 0) - break; - slot = lane_to_slot[lane]; - if (QIXIS_READ(present) & (1 << (slot - 1))) - fm_disable_port(i); - switch (slot) { - case 1: - mdio_mux[i] = EMI1_SLOT1; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - case 2: - mdio_mux[i] = EMI1_SLOT2; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - case 3: - mdio_mux[i] = EMI1_SLOT3; - fm_info_set_mdio(i, - mii_dev_for_muxval(mdio_mux[i])); - break; - }; - break; - default: - break; - } - } -#endif /* CONFIG_SYS_NUM_FMAN */ - - cpu_eth_init(bis); -#endif /* CONFIG_FMAN_ENET */ - - return pci_eth_init(bis); -} diff --git a/board/freescale/p3060qds/fixed_ddr.c b/board/freescale/p3060qds/fixed_ddr.c deleted file mode 100644 index 125988d..0000000 --- a/board/freescale/p3060qds/fixed_ddr.c +++ /dev/null @@ -1,214 +0,0 @@ -/* - * Copyright 2009-2011 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License - * Version 2 as published by the Free Software Foundation. - */ - -#include <common.h> -#include <asm/fsl_ddr_sdram.h> - -#define CONFIG_SYS_DDR_TIMING_3_1200 0x01030000 -#define CONFIG_SYS_DDR_TIMING_0_1200 0xCC550104 -#define CONFIG_SYS_DDR_TIMING_1_1200 0x868FAA45 -#define CONFIG_SYS_DDR_TIMING_2_1200 0x0FB8A912 -#define CONFIG_SYS_DDR_MODE_1_1200 0x00441A40 -#define CONFIG_SYS_DDR_MODE_2_1200 0x00100000 -#define CONFIG_SYS_DDR_INTERVAL_1200 0x12480100 -#define CONFIG_SYS_DDR_CLK_CTRL_1200 0x02800000 - -#define CONFIG_SYS_DDR_TIMING_3_1000 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0_1000 0xCC440104 -#define CONFIG_SYS_DDR_TIMING_1_1000 0x727DF944 -#define CONFIG_SYS_DDR_TIMING_2_1000 0x0FB088CF -#define CONFIG_SYS_DDR_MODE_1_1000 0x00441830 -#define CONFIG_SYS_DDR_MODE_2_1000 0x00080000 -#define CONFIG_SYS_DDR_INTERVAL_1000 0x0F3C0100 -#define CONFIG_SYS_DDR_CLK_CTRL_1000 0x02800000 - -#define CONFIG_SYS_DDR_TIMING_3_900 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0_900 0xCC440104 -#define CONFIG_SYS_DDR_TIMING_1_900 0x616ba844 -#define CONFIG_SYS_DDR_TIMING_2_900 0x0fb088ce -#define CONFIG_SYS_DDR_MODE_1_900 0x00441620 -#define CONFIG_SYS_DDR_MODE_2_900 0x00080000 -#define CONFIG_SYS_DDR_INTERVAL_900 0x0db60100 -#define CONFIG_SYS_DDR_CLK_CTRL_900 0x02800000 - -#define CONFIG_SYS_DDR_TIMING_3_800 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0_800 0xcc330104 -#define CONFIG_SYS_DDR_TIMING_1_800 0x6f6b4744 -#define CONFIG_SYS_DDR_TIMING_2_800 0x0fa888cc -#define CONFIG_SYS_DDR_MODE_1_800 0x00441420 -#define CONFIG_SYS_DDR_MODE_2_800 0x00000000 -#define CONFIG_SYS_DDR_INTERVAL_800 0x0c300100 -#define CONFIG_SYS_DDR_CLK_CTRL_800 0x02800000 - -#define CONFIG_SYS_DDR_CS0_BNDS 0x000000FF -#define CONFIG_SYS_DDR_CS1_BNDS 0x00000000 -#define CONFIG_SYS_DDR_CS2_BNDS 0x000000FF -#define CONFIG_SYS_DDR_CS3_BNDS 0x000000FF -#define CONFIG_SYS_DDR2_CS0_BNDS 0x000000FF -#define CONFIG_SYS_DDR2_CS1_BNDS 0x00000000 -#define CONFIG_SYS_DDR2_CS2_BNDS 0x000000FF -#define CONFIG_SYS_DDR2_CS3_BNDS 0x000000FF -#define CONFIG_SYS_DDR_CS0_CONFIG 0xA0044202 -#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 -#define CONFIG_SYS_DDR_CS1_CONFIG 0x80004202 -#define CONFIG_SYS_DDR_CS2_CONFIG 0x00000000 -#define CONFIG_SYS_DDR_CS3_CONFIG 0x00000000 -#define CONFIG_SYS_DDR2_CS0_CONFIG 0x80044202 -#define CONFIG_SYS_DDR2_CS1_CONFIG 0x80004202 -#define CONFIG_SYS_DDR2_CS2_CONFIG 0x00000000 -#define CONFIG_SYS_DDR2_CS3_CONFIG 0x00000000 -#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_CS1_CONFIG 0x80004202 -#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef -#define CONFIG_SYS_DDR_TIMING_4 0x00000001 -#define CONFIG_SYS_DDR_TIMING_5 0x02401400 -#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 -#define CONFIG_SYS_DDR_ZQ_CNTL 0x89080600 -#define CONFIG_SYS_DDR_WRLVL_CNTL 0x8675F607 -#define CONFIG_SYS_DDR_SDRAM_CFG 0xE7044000 -#define CONFIG_SYS_DDR_SDRAM_CFG2 0x24401031 -#define CONFIG_SYS_DDR_RCW_1 0x00000000 -#define CONFIG_SYS_DDR_RCW_2 0x00000000 -#define CONFIG_MEM_INIT_VALUE 0xdeadbeef - -fsl_ddr_cfg_regs_t ddr_cfg_regs_800 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, - .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, - .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, - .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, - .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_800, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_800, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_800, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_800, - .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_800, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_800, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_800, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_800, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fsl_ddr_cfg_regs_t ddr_cfg_regs_900 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, - .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, - .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, - .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, - .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_900, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_900, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_900, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_900, - .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_900, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_900, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_900, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_900, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fsl_ddr_cfg_regs_t ddr_cfg_regs_1000 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, - .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, - .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, - .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, - .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_1000, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_1000, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_1000, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_1000, - .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_1000, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_1000, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_1000, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_1000, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fsl_ddr_cfg_regs_t ddr_cfg_regs_1200 = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, - .cs[2].bnds = CONFIG_SYS_DDR_CS2_BNDS, - .cs[3].bnds = CONFIG_SYS_DDR_CS3_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, - .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, - .cs[2].config = CONFIG_SYS_DDR_CS2_CONFIG, - .cs[3].config = CONFIG_SYS_DDR_CS3_CONFIG, - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3_1200, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0_1200, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_1200, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_1200, - .ddr_sdram_cfg = CONFIG_SYS_DDR_SDRAM_CFG, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_SDRAM_CFG2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1_1200, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_1200, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL_1200, - .ddr_data_init = CONFIG_MEM_INIT_VALUE, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL_1200, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CNTL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CNTL, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 -}; - -fixed_ddr_parm_t fixed_ddr_parm_0[] = { - {750, 850, &ddr_cfg_regs_800}, - {850, 950, &ddr_cfg_regs_900}, - {950, 1050, &ddr_cfg_regs_1000}, - {1050, 1250, &ddr_cfg_regs_1200}, - {0, 0, NULL} -}; diff --git a/board/freescale/p3060qds/p3060qds.c b/board/freescale/p3060qds/p3060qds.c deleted file mode 100644 index c7cca2a..0000000 --- a/board/freescale/p3060qds/p3060qds.c +++ /dev/null @@ -1,338 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <command.h> -#include <netdev.h> -#include <linux/compiler.h> -#include <asm/mmu.h> -#include <asm/processor.h> -#include <asm/cache.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_law.h> -#include <asm/fsl_serdes.h> -#include <asm/fsl_portals.h> -#include <asm/fsl_liodn.h> -#include <fm_eth.h> -#include <configs/P3060QDS.h> -#include <libfdt.h> -#include <fdt_support.h> - -#include "../common/qixis.h" -#include "p3060qds.h" -#include "p3060qds_qixis.h" - -DECLARE_GLOBAL_DATA_PTR; - -int checkboard(void) -{ - u8 sw; - struct cpu_type *cpu = gd->cpu; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - unsigned int i; - - printf("Board: %s", cpu->name); - puts("QDS, "); - - printf("Sys ID: 0x%02x, Sys Ver: 0x%02x, FPGA Ver: 0x%02x, ", - QIXIS_READ(id), QIXIS_READ(arch), QIXIS_READ(scver)); - - sw = QIXIS_READ(brdcfg[0]); - sw = (sw & QIXIS_LBMAP_MASK) >> QIXIS_LBMAP_SHIFT; - - if (sw < 0x8) - printf("vBank: %d\n", sw); - else if (sw == 0x8) - puts("Promjet\n"); - else if (sw == 0x9) - puts("NAND\n"); - else - printf("invalid setting of SW%u\n", PIXIS_LBMAP_SWITCH); - - puts("Reset Configuration Word (RCW):"); - for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { - u32 rcw = in_be32(&gur->rcwsr[i]); - - if ((i % 4) == 0) - printf("\n %08x:", i * 4); - printf(" %08x", rcw); - } - puts("\n"); - - puts("SERDES Reference Clocks: "); - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < 3; i++) { - static const char * const freq[] = {"100", "125", "Reserved", - "156.25"}; - unsigned int clock = (sw >> (2 * i)) & 3; - - printf("Bank%u=%sMhz ", i+1, freq[clock]); - } - puts("\n"); - - return 0; -} - -int board_early_init_f(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - - /* only single DDR controller on QDS board, disable DDR1_MCK4/5 */ - setbits_be32(&gur->ddrclkdr, 0x00030000); - - return 0; -} - -void board_config_serdes_mux(void) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - int cfg = (in_be32(&gur->rcwsr[4]) & - FSL_CORENET_RCWSR4_SRDS_PRTCL) >> 26; - - switch (cfg) { - case 0x03: - case 0x06: - /* set Lane I,J as SGMII */ - QIXIS_WRITE(brdcfg[6], BRDCFG6_SD4MX_B | BRDCFG6_SD3MX_A | - BRDCFG6_SD2MX_B | BRDCFG6_SD1MX_A); - break; - case 0x16: - case 0x19: - case 0x1c: - /* set Lane I,J as Aurora Debug */ - QIXIS_WRITE(brdcfg[6], BRDCFG6_SD4MX_A | BRDCFG6_SD3MX_B | - BRDCFG6_SD2MX_A | BRDCFG6_SD1MX_B); - break; - default: - puts("Invalid SerDes protocol for P3060QDS\n"); - break; - } -} - -void board_config_usb_mux(void) -{ - u8 brdcfg4, brdcfg5, brdcfg7; - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 rcwsr11 = in_be32(&gur->rcwsr[11]); - u32 ec1 = rcwsr11 & FSL_CORENET_RCWSR11_EC1; - u32 ec2 = rcwsr11 & FSL_CORENET_RCWSR11_EC2; - - brdcfg4 = QIXIS_READ(brdcfg[4]); - brdcfg4 &= ~BRDCFG4_EC_MODE_MASK; - if ((ec1 == FSL_CORENET_RCWSR11_EC1_FM1_USB1) && - (ec2 == FSL_CORENET_RCWSR11_EC2_USB2)) { - brdcfg4 |= BRDCFG4_EC2_USB_EC1_USB; - - } else if ((ec1 == FSL_CORENET_RCWSR11_EC1_FM1_USB1) && - ((ec2 == FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2) || - (ec2 == FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1))) { - brdcfg4 |= BRDCFG4_EC2_RGMII_EC1_USB; - - } else if ((ec1 == FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1) && - (ec2 == FSL_CORENET_RCWSR11_EC2_USB2)) { - brdcfg4 |= BRDCFG4_EC2_USB_EC1_RGMII; - - } else if ((ec1 == FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1) && - ((ec2 == FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2) || - (ec2 == FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1))) { - brdcfg4 |= BRDCFG4_EC2_RGMII_EC1_RGMII; - } else { - brdcfg4 |= BRDCFG4_EC2_MII_EC1_MII; - } - QIXIS_WRITE(brdcfg[4], brdcfg4); - - brdcfg5 = QIXIS_READ(brdcfg[5]); - brdcfg5 &= ~(BRDCFG5_USB1ID_MASK | BRDCFG5_USB2ID_MASK); - brdcfg5 |= (BRDCFG5_USB1ID_CTRL | BRDCFG5_USB2ID_CTRL); - QIXIS_WRITE(brdcfg[5], brdcfg5); - - brdcfg7 = BRDCFG7_JTAGMX_COP_JTAG | BRDCFG7_IQ1MX_IRQ_EVT | - BRDCFG7_G1MX_USB1 | BRDCFG7_D1MX_TSEC3USB | BRDCFG7_I3MX_USB1; - QIXIS_WRITE(brdcfg[7], brdcfg7); -} - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash + PROMJET region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash + promjet */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, - 0, flash_esel, BOOKE_PAGESZ_256M, 1); - - set_liodns(); -#ifdef CONFIG_SYS_DPAA_QBMAN - setup_portals(); -#endif - board_config_serdes_mux(); - board_config_usb_mux(); - - return 0; -} - -static const char *serdes_clock_to_string(u32 clock) -{ - switch (clock) { - case SRDS_PLLCR0_RFCK_SEL_100: - return "100"; - case SRDS_PLLCR0_RFCK_SEL_125: - return "125"; - case SRDS_PLLCR0_RFCK_SEL_156_25: - return "156.25"; - default: - return "150"; - } -} - -#define NUM_SRDS_BANKS 3 - -int misc_init_r(void) -{ - serdes_corenet_t *srds_regs; - u32 actual[NUM_SRDS_BANKS]; - unsigned int i; - u8 sw; - - sw = QIXIS_READ(brdcfg[2]); - for (i = 0; i < 3; i++) { - unsigned int clock = (sw >> (2 * i)) & 3; - switch (clock) { - case 0: - actual[i] = SRDS_PLLCR0_RFCK_SEL_100; - break; - case 1: - actual[i] = SRDS_PLLCR0_RFCK_SEL_125; - break; - case 3: - actual[i] = SRDS_PLLCR0_RFCK_SEL_156_25; - break; - default: - printf("Warning: SDREFCLK%u switch setting of '10' is " - "unsupported\n", i + 1); - break; - } - } - - srds_regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; - for (i = 0; i < NUM_SRDS_BANKS; i++) { - u32 pllcr0 = in_be32(&srds_regs->bank[i].pllcr0); - u32 expected = pllcr0 & SRDS_PLLCR0_RFCK_SEL_MASK; - if (expected != actual[i]) { - printf("Warning: SERDES bank %u expects reference clock" - " %sMHz, but actual is %sMHz\n", i + 1, - serdes_clock_to_string(expected), - serdes_clock_to_string(actual[i])); - } - } - - return 0; -} - -/* - * This is map of CVDD values. 33 means CVDD is 3.3v, 25 means CVDD is 2.5v, - * 18 means CVDD is 1.8v. - */ -static u8 IO_VSEL[] = { - 33, 33, 33, 25, 25, 25, 18, 18, 18, - 33, 33, 33, 25, 25, 25, 18, 18, 18, - 33, 33, 33, 25, 25, 25, 18, 18, 18, - 33, 33, 33, 33, 33 -}; - -#define IO_VSEL_MASK 0x1f - -/* - * different CVDD selects diffenert spi flashs, read dutcfg[3] to get CVDD, - * then set status of spi flash nodes to 'disabled' according to CVDD. - * CVDD '33' will select spi flash0 and flash1, CVDD '25' will select spi - * flash2, CVDD '18' will select spi flash3. - */ -void fdt_fixup_board_spi(void *blob) -{ - u8 sw5 = QIXIS_READ(dutcfg[3]); - - switch (IO_VSEL[sw5 & IO_VSEL_MASK]) { - /* 3.3v */ - case 33: - do_fixup_by_compat(blob, "atmel,at45db081d", "status", - "disabled", strlen("disabled") + 1, 1); - do_fixup_by_compat(blob, "spansion,sst25wf040", "status", - "disabled", strlen("disabled") + 1, 1); - break; - /* 2.5v */ - case 25: - do_fixup_by_compat(blob, "spansion,s25sl12801", "status", - "disabled", strlen("disabled") + 1, 1); - do_fixup_by_compat(blob, "spansion,en25q32", "status", - "disabled", strlen("disabled") + 1, 1); - do_fixup_by_compat(blob, "spansion,sst25wf040", "status", - "disabled", strlen("disabled") + 1, 1); - break; - /* 1.8v */ - case 18: - do_fixup_by_compat(blob, "spansion,s25sl12801", "status", - "disabled", strlen("disabled") + 1, 1); - do_fixup_by_compat(blob, "spansion,en25q32", "status", - "disabled", strlen("disabled") + 1, 1); - do_fixup_by_compat(blob, "atmel,at45db081d", "status", - "disabled", strlen("disabled") + 1, 1); - break; - } -} - -void ft_board_setup(void *blob, bd_t *bd) -{ - phys_addr_t base; - phys_size_t size; - - ft_cpu_setup(blob, bd); - - base = getenv_bootm_low(); - size = getenv_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - -#ifdef CONFIG_PCI - pci_of_setup(blob, bd); -#endif - - fdt_fixup_liodn(blob); - fdt_fixup_dr_usb(blob, bd); - fdt_fixup_board_spi(blob); - -#ifdef CONFIG_SYS_DPAA_FMAN - fdt_fixup_fman_ethernet(blob); - fdt_fixup_board_enet(blob); -#endif -} diff --git a/board/freescale/p3060qds/p3060qds.h b/board/freescale/p3060qds/p3060qds.h deleted file mode 100644 index 3da6815..0000000 --- a/board/freescale/p3060qds/p3060qds.h +++ /dev/null @@ -1,30 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __P3060QDS_H__ -#define __P3060QDS_H__ - -#include <asm/fsl_ddr_sdram.h> -#include <asm/u-boot.h> - -void fdt_fixup_board_enet(void *blob); -void pci_of_setup(void *blob, bd_t *bd); -extern fixed_ddr_parm_t fixed_ddr_parm_0[]; - -#endif diff --git a/board/freescale/p3060qds/p3060qds_qixis.h b/board/freescale/p3060qds/p3060qds_qixis.h deleted file mode 100644 index 4d5d6a2..0000000 --- a/board/freescale/p3060qds/p3060qds_qixis.h +++ /dev/null @@ -1,74 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __P3060QDS_QIXIS_H__ -#define __P3060QDS_QIXIS_H__ - -/* Definitions of QIXIS Registers for P3060QDS */ - -/* BRDCFG4[4:7]] select EC1 and EC2 as a pair */ -#define BRDCFG4_EC_MODE_MASK 0x0F -#define BRDCFG4_EC2_MII_EC1_MII 0x00 -#define BRDCFG4_EC2_MII_EC1_USB 0x03 -#define BRDCFG4_EC2_USB_EC1_MII 0x0C -#define BRDCFG4_EC2_USB_EC1_USB 0x0F -#define BRDCFG4_EC2_USB_EC1_RGMII 0x0E -#define BRDCFG4_EC2_RGMII_EC1_USB 0x0B -#define BRDCFG4_EC2_RGMII_EC1_RGMII 0x0A -#define BRDCFG4_EMISEL_MASK 0xF0 - -#define BRDCFG5_ECLKS_MASK 0x80 -#define BRDCFG5_USB1ID_MASK 0x40 -#define BRDCFG5_USB2ID_MASK 0x20 -#define BRDCFG5_GC2MX_MASK 0x0C -#define BRDCFG5_T15MX_MASK 0x03 -#define BRDCFG5_ECLKS_IEEE1588_CM 0x80 -#define BRDCFG5_USB1ID_CTRL 0x40 -#define BRDCFG5_USB2ID_CTRL 0x20 - -#define BRDCFG6_SD1MX_A 0x01 -#define BRDCFG6_SD1MX_B 0x00 -#define BRDCFG6_SD2MX_A 0x02 -#define BRDCFG6_SD2MX_B 0x00 -#define BRDCFG6_SD3MX_A 0x04 -#define BRDCFG6_SD3MX_B 0x00 -#define BRDCFG6_SD4MX_A 0x08 -#define BRDCFG6_SD4MX_B 0x00 - -#define BRDCFG7_JTAGMX_MASK 0xC0 -#define BRDCFG7_IQ1MX_MASK 0x20 -#define BRDCFG7_G1MX_MASK 0x10 -#define BRDCFG7_D1MX_MASK 0x0C -#define BRDCFG7_I3MX_MASK 0x03 -#define BRDCFG7_JTAGMX_AURORA 0x00 -#define BRDCFG7_JTAGMX_FPGA 0x80 -#define BRDCFG7_JTAGMX_COP_JTAG 0xC0 -#define BRDCFG7_IQ1MX_IRQ_EVT 0x00 -#define BRDCFG7_IQ1MX_USB2 0x20 -#define BRDCFG7_G1MX_USB1 0x00 -#define BRDCFG7_G1MX_TSEC3 0x10 -#define BRDCFG7_D1MX_DMA 0x00 -#define BRDCFG7_D1MX_TSEC3USB 0x04 -#define BRDCFG7_D1MX_HDLC2 0x08 -#define BRDCFG7_I3MX_UART2_I2C34 0x00 -#define BRDCFG7_I3MX_GPIO_EVT 0x01 -#define BRDCFG7_I3MX_USB1 0x02 -#define BRDCFG7_I3MX_TSEC3 0x03 - -#endif diff --git a/boards.cfg b/boards.cfg index 7194e08..a64dd23 100644 --- a/boards.cfg +++ b/boards.cfg @@ -753,9 +753,6 @@ P3041DS_SECURE_BOOT powerpc mpc85xx corenet_ds freesca P3041DS_SPIFLASH powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 P3041DS_SRIOBOOT_MASTER powerpc mpc85xx corenet_ds freescale - P3041DS:SRIOBOOT_MASTER P3041DS_SRIOBOOT_SLAVE powerpc mpc85xx corenet_ds freescale - P3041DS:SRIOBOOT_SLAVE,SYS_TEXT_BASE=0xFFF80000 -P3060QDS powerpc mpc85xx p3060qds freescale -P3060QDS_NAND powerpc mpc85xx p3060qds freescale - P3060QDS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 -P3060QDS_SECURE_BOOT powerpc mpc85xx p3060qds freescale - P3060QDS:SECURE_BOOT P4080DS powerpc mpc85xx corenet_ds freescale P4080DS_SDCARD powerpc mpc85xx corenet_ds freescale - P4080DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 P4080DS_SECURE_BOOT powerpc mpc85xx corenet_ds freescale - P4080DS:SECURE_BOOT diff --git a/doc/README.p3060qds b/doc/README.p3060qds deleted file mode 100644 index ec62798..0000000 --- a/doc/README.p3060qds +++ /dev/null @@ -1,110 +0,0 @@ -Overview -========= -The P3060QDS is a Freescale reference board that hosts the six-core P3060 SOC. - -The P3060 Processor combines six e500mc Power Architecture processor -cores(1.2GHz) with high-performance datapath acceleration -architecture(DPAA), CoreNet fabric infrastructure, as well as network -and peripheral bus interfaces required for networking, telecom/datacom, -wireless infrastructure, and military/aerospace applications. - - -P3060QDS Board Specifications: -============================== -Memory subsystem: - * 2G Bytes UDIMM DDR3(64bit bus) with ECC on - * 128M Bytes NOR flash single-chip memory - * 16M Bytes SPI flash - * 8K Bytes AT24C64 I2C EEPROM for RCW - -Ethernet(Default SERDES 0x19): - * FM1-dTSEC1: connected to RGMII PHY1 (Vitesse VSC8641 on board,Bottom of dual RJ45) - * FM1-dTSEC2: connected to RGMII PHY2 (Vitesse VSC8641 on board,Top of dual RJ45) - * FM1-dTSEC3: connected to SGMII PHY (Vitesse VSC8234 port1 in slot1) - * FM1-dTSEC4: connected to SGMII PHY (Vitesse VSC8234 port3 in slot1) - * FM2-dTSEC1: connected to SGMII PHY (Vitesse VSC8234 port0 in slot2) - * FM2-dTSEC2: connected to SGMII PHY (Vitesse VSC8234 port2 in slot2) - * FM2-dTSEC3: connected to SGMII PHY (Vitesse VSC8234 port0 in slot1) - * FM2-dTSEC4: connected to SGMII PHY (Vitesse VSC8234 port2 in slot1) - -PCIe: - * PCIe1: Lanes A, B, C and D of Bank1 are connected to one x4 PCIe SLOT4 - * PCIe2: Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT3 - -RapidIO: - * sRIO1: Lanes E, F, G and H of Bank1 are connected to sRIO1 (SLOT3) - * sRIO2: Lanes A, B, C and D of Bank1 are connected to sRIO2 (SLOT4) - -USB: - * USB1: connected via an external ULPI PHY SMC3315 to a TYPE-A interface - * USB2: connected via an external ULPI PHY SMC3315 to a TYPE-AB interface - -I2C: - * I2C1_CH0: EEPROM AT24C64(0x50) RCW, AT24C02(0x51) DDR SPD, - AT24C02(0x53) DDR SPD, AT24C02(0x57) SystemID, RTC DS3232(0x68) - * I2C1_CH1: 1588 RiserCard(0x55), HSLB Testport, TempMon - ADT7461(0x4C), SerDesMux DS64MB201(0x51/59/5C/5D) - * I2C1_CH2: VDD/GVDD/GIDD ZL6100 (0x21/0x22/0x23/0x24/0x40) - * I2C1_CH3: OCM CFG AT24C02(0x55), OCM IPL AT24C64(0x56) - * I2C1_CH4: PCIe SLOT1 - * I2C1_CH5: PCIe SLOT2 - * I2C1_CH6: PCIe SLOT3 - * I2C1_CH7: PCIe SLOT4 - * I2C2: NULL - * I2C3: NULL - -UART: - * Supports two UARTs up to 115200 bps for console - - -Boot from NOR flash -=================== -1. Build image - export ARCH=powerpc - export CROSS_COMPILE=/your_path/gcc-4.5.xx-eglibc-2.11.xx/powerpc-linux-gnu/bin/powerpc-linux-gnu- - make P3060QDS_config - make - -2. Program image - => tftp 1000000 u-boot.bin - => protect off all - => erase eff80000 efffffff - => cp.b 1000000 eff80000 80000 - -3. Program RCW - => tftp 1000000 rcw.bin - => protect off all - => erase e8000000 e801ffff - => cp.b 1000000 e8000000 50 - -4. Program FMAN Firmware ucode - => tftp 1000000 ucode.bin - => protect off all - => erase ef000000 ef0fffff - => cp.b 1000000 ef000000 2000 - -5. Change DIP-switch - RCW Location: SW1[1-5] = 01101 (eLBC 16bit NOR flash) - Note: 1 stands for 'on', 0 stands for 'off' - - -Using the Device Tree Source File -================================= -To create the DTB (Device Tree Binary) image file, use a command -similar to this: - dtc -O dtb -b 0 -p 1024 p3060qds.dts > p3060qds.dtb - -Or use the following command: - {linux-2.6}/make p3060qds.dtb ARCH=powerpc - -then the dtb file will be generated under the following directory: - {linux-2.6}/arch/powerpc/boot/p3060qds.dtb - - -Booting Linux -============= -Place a linux uImage in the TFTP disk area. - tftp 1000000 uImage - tftp 2000000 rootfs.ext2.gz.uboot - tftp 3000000 p3060rdb.dtb - bootm 1000000 2000000 3000000 diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index 072b178..9692575 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -39,7 +39,6 @@ COBJS-$(CONFIG_P1023) += p1023.o COBJS-$(CONFIG_PPC_P2040) += p5020.o COBJS-$(CONFIG_PPC_P2041) += p5020.o COBJS-$(CONFIG_PPC_P3041) += p5020.o -COBJS-$(CONFIG_PPC_P3060) += p3060.o COBJS-$(CONFIG_PPC_P4080) += p4080.o COBJS-$(CONFIG_PPC_P5020) += p5020.o endif diff --git a/drivers/net/fm/p3060.c b/drivers/net/fm/p3060.c deleted file mode 100644 index c9748a9..0000000 --- a/drivers/net/fm/p3060.c +++ /dev/null @@ -1,97 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ -#include <common.h> -#include <phy.h> -#include <fm_eth.h> -#include <asm/io.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_serdes.h> - -u32 port_to_devdisr[] = { - [FM1_DTSEC1] = FSL_CORENET_DEVDISR2_DTSEC1_1, - [FM1_DTSEC2] = FSL_CORENET_DEVDISR2_DTSEC1_2, - [FM1_DTSEC3] = FSL_CORENET_DEVDISR2_DTSEC1_3, - [FM1_DTSEC4] = FSL_CORENET_DEVDISR2_DTSEC1_4, - [FM2_DTSEC1] = FSL_CORENET_DEVDISR2_DTSEC2_1, - [FM2_DTSEC2] = FSL_CORENET_DEVDISR2_DTSEC2_2, - [FM2_DTSEC3] = FSL_CORENET_DEVDISR2_DTSEC2_3, - [FM2_DTSEC4] = FSL_CORENET_DEVDISR2_DTSEC2_4, -}; - -static int is_device_disabled(enum fm_port port) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 devdisr2 = in_be32(&gur->devdisr2); - - return port_to_devdisr[port] & devdisr2; -} - -void fman_disable_port(enum fm_port port) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - - /* don't allow disabling of DTSEC1 as its needed for MDIO */ - if (port == FM1_DTSEC1) - return; - - setbits_be32(&gur->devdisr2, port_to_devdisr[port]); -} - -phy_interface_t fman_port_enet_if(enum fm_port port) -{ - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 rcwsr11 = in_be32(&gur->rcwsr[11]); - - if (is_device_disabled(port)) - return PHY_INTERFACE_MODE_NONE; - - /* handle RGMII/MII first */ - if ((port == FM1_DTSEC1) && ((rcwsr11 & FSL_CORENET_RCWSR11_EC1) == - FSL_CORENET_RCWSR11_EC1_FM1_DTSEC1)) - return PHY_INTERFACE_MODE_RGMII; - - if ((port == FM1_DTSEC2) && ((rcwsr11 & FSL_CORENET_RCWSR11_EC2) == - FSL_CORENET_RCWSR11_EC2_FM1_DTSEC2)) - return PHY_INTERFACE_MODE_RGMII; - - if ((port == FM2_DTSEC1) && ((rcwsr11 & FSL_CORENET_RCWSR11_EC2) == - FSL_CORENET_RCWSR11_EC2_FM2_DTSEC1)) - return PHY_INTERFACE_MODE_RGMII; - - switch (port) { - case FM1_DTSEC1: - case FM1_DTSEC2: - case FM1_DTSEC3: - case FM1_DTSEC4: - if (is_serdes_configured(SGMII_FM1_DTSEC1 + port - FM1_DTSEC1)) - return PHY_INTERFACE_MODE_SGMII; - break; - case FM2_DTSEC1: - case FM2_DTSEC2: - case FM2_DTSEC3: - case FM2_DTSEC4: - if (is_serdes_configured(SGMII_FM2_DTSEC1 + port - FM2_DTSEC1)) - return PHY_INTERFACE_MODE_SGMII; - break; - default: - return PHY_INTERFACE_MODE_NONE; - } - - return PHY_INTERFACE_MODE_NONE; -} diff --git a/include/configs/P3060QDS.h b/include/configs/P3060QDS.h deleted file mode 100644 index 8006547..0000000 --- a/include/configs/P3060QDS.h +++ /dev/null @@ -1,48 +0,0 @@ -/* - * Copyright 2011 Freescale Semiconductor, Inc. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * P3060 QDS board configuration file - */ -#define CONFIG_P3060QDS -#define CONFIG_PHYS_64BIT -#define CONFIG_PPC_P3060 -#define CONFIG_FSL_QIXIS - -#define CONFIG_NAND_FSL_ELBC - -#define CONFIG_ICS307_REFCLK_HZ 25000000 /* ICS307 ref clk freq */ - -#define CONFIG_SPI_FLASH_ATMEL -#define CONFIG_SPI_FLASH_EON -#define CONFIG_SPI_FLASH_SST - -#include "corenet_ds.h" - -#define SGMII_CARD_PORT1_PHY_ADDR 0x1C -#define SGMII_CARD_PORT2_PHY_ADDR 0x1D -#define SGMII_CARD_PORT3_PHY_ADDR 0x1E -#define SGMII_CARD_PORT4_PHY_ADDR 0x1F - -/* There is a PCA9547 8-channel I2C-bus multiplexer on P3060QDS board */ -#define CONFIG_I2C_MUX -#define CONFIG_I2C_MULTI_BUS diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 976dfe9..baa2913 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -186,11 +186,7 @@ #define CONFIG_DDR_SPD #define CONFIG_FSL_DDR3
-#ifdef CONFIG_P3060QDS -#define CONFIG_SYS_SPD_BUS_NUM 0 -#else #define CONFIG_SYS_SPD_BUS_NUM 1 -#endif #define SPD_EEPROM_ADDRESS1 0x51 #define SPD_EEPROM_ADDRESS2 0x52 #define SPD_EEPROM_ADDRESS SPD_EEPROM_ADDRESS1 /* for p3041/p5010 */ @@ -721,7 +717,7 @@
#define CONFIG_BAUDRATE 115200
-#if defined(CONFIG_P4080DS) || defined(CONFIG_P3060QDS) +#ifdef CONFIG_P4080DS #define __USB_PHY_TYPE ulpi #else #define __USB_PHY_TYPE utmi
On Fri, Jul 6, 2012 at 12:39 PM, Timur Tabi timur@freescale.com wrote:
The P3060 was cancelled before it went into production, so there's no point in supporting it.
Signed-off-by: Timur Tabi timur@freescale.com
Please rebase this off the top of my current tree.
The BR_PHYS_ADDR(x) macro was missing parentheses around "x" in the macro definition, so callers had to supply their own parenthesis.
Applied, thanks
Andy Fleming
Timur Tabi
