[U-Boot] Pull request: u-boot-net.git master
The following changes since commit 1733259d25015c28c47990ec11af99b3f62f811c:
Merge branch 'master' of git://git.denx.de/u-boot-video (2015-04-20 09:13:52 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to 523bb66f5a8e2cee22535e509c4e762bbc774406:
net: pch_gbe: Fix pch_gbe device name (2015-04-20 17:57:13 -0500)
---------------------------------------------------------------- Bin Meng (1): net: pch_gbe: Fix pch_gbe device name
Codrin Ciubotariu (1): net: phy: realtek: Disable interrupt on Realtek Ethernet PHY drivers
Joe Hershberger (1): Update MAINTAINERS and git-mailrc for net
Luca Ellero (1): net: phy: micrel: add support for KSZ8081MNX
Michal Simek (1): net: gem: Use correct type for casting
Shengzhou Liu (1): net/phy: fixup for get_phy_id
Thierry Reding (1): net: rtl8169: Build warning fixes for 64-bit
Tim James (1): mii: add read-modify-write option to mii command
MAINTAINERS | 3 ++- common/cmd_mii.c | 47 ++++++++++++++++++++++++++++++++++++++--------- doc/git-mailrc | 4 +++- drivers/net/pch_gbe.c | 2 +- drivers/net/phy/micrel.c | 11 +++++++++++ drivers/net/phy/phy.c | 2 +- drivers/net/phy/realtek.c | 18 +++++++++++++++++- drivers/net/rtl8169.c | 24 +++++++++++++----------- drivers/net/zynq_gem.c | 3 ++- include/phy.h | 1 + 10 files changed, 89 insertions(+), 26 deletions(-)
Joe Hershberger
