[PATCH v3 07/20] configs: enable CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards
This patch enables CONFIG_RESTORE_EXCEPTION_VECTOR_BASE for all mtmips boards.
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v2: none --- configs/gardena-smart-gateway-mt7688-ram_defconfig | 1 + configs/gardena-smart-gateway-mt7688_defconfig | 1 + configs/linkit-smart-7688-ram_defconfig | 1 + configs/linkit-smart-7688_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 01fbc6e1a2..38c9272723 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 9156c70155..cc0fa7f65b 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -10,6 +10,7 @@ CONFIG_ARCH_MTMIPS=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 10a0438245..6d8969aacb 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_FIT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 9e12d164e1..9824c77aae 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -9,6 +9,7 @@ CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_FIT=y
Thanks, Stefan
Am 21.01.20 um 09:18 schrieb Weijie Gao:
applied to u-boot-mips, thanks.
Daniel Schwierzeck
Stefan Roese
Weijie Gao
