[U-Boot] [PATCH] whitespace cleanups
Whitespace cleanups.
Signed-off-by: Pavel Machek pavel@denx.de
diff --git a/disk/part.c b/disk/part.c index baceb19..ecc5e7e 100644 --- a/disk/part.c +++ b/disk/part.c @@ -333,7 +333,7 @@ static void print_part_header (const char *type, block_dev_desc_t * dev_desc)
#endif /* any CONFIG_..._PARTITION */
-void print_part (block_dev_desc_t * dev_desc) +void print_part(block_dev_desc_t * dev_desc) {
switch (dev_desc->part_type) { @@ -381,8 +381,8 @@ void print_part (block_dev_desc_t * dev_desc)
#endif /* HAVE_BLOCK_DEVICE */
-int get_partition_info(block_dev_desc_t *dev_desc, int part - , disk_partition_t *info) +int get_partition_info(block_dev_desc_t *dev_desc, int part, + disk_partition_t *info) { #ifdef HAVE_BLOCK_DEVICE
@@ -511,7 +511,7 @@ int get_device_and_partition(const char *ifname, const char *dev_part_str, disk_partition_t tmpinfo;
/* - * Special-case a psuedo block device "hostfs", to allow access to the + * Special-case a pseudo block device "hostfs", to allow access to the * host's own filesystem. */ if (0 == strcmp(ifname, "hostfs")) { diff --git a/include/altera.h b/include/altera.h index 0327a1b..ae5f7ee 100644 --- a/include/altera.h +++ b/include/altera.h @@ -26,7 +26,7 @@ typedef enum { /* typedef Altera_Family */ min_altera_type, /* insert all new types after this */ Altera_ACEX1K, /* ACEX1K Family */ Altera_CYC2, /* CYCLONII Family */ - Altera_StratixII, /* StratixII Familiy */ + Altera_StratixII, /* StratixII Family */ /* Add new models here */ max_altera_type /* insert all new types before this */ } Altera_Family; /* end, typedef Altera_Family */
Hello Pavel,
checkpatch says: ;)
ERROR: "foo * bar" should be "foo *bar" #26: FILE: disk/part.c:336: +void print_part(block_dev_desc_t * dev_desc)
Regards, Jeroen
On Sun 2014-07-20 00:02:37, Jeroen Hofstee wrote:
Hello Pavel,
diff --git a/disk/part.c b/disk/part.c index baceb19..ecc5e7e 100644 --- a/disk/part.c +++ b/disk/part.c @@ -333,7 +333,7 @@ static void print_part_header (const char *type, block_dev_desc_t * dev_desc) #endif /* any CONFIG_..._PARTITION */ -void print_part (block_dev_desc_t * dev_desc) +void print_part(block_dev_desc_t * dev_desc) { switch (dev_desc->part_type) { @@ -381,8 +381,8 @@ void print_part (block_dev_desc_t * dev_desc)
checkpatch says: ;)
Yeah, I did not fix _all_ broken whitespace, just some. Note that I'm not adding the error. Pavel
Hello Pavel,
Hello Pavel,
checkpatch says: ;)
This is only about a line you touch. And patch submissions should be checked by checkpatch or at least mention why you don't comply.
Regards, Jeroen
Cleanup disk/part.c
diff --git a/disk/part.c b/disk/part.c index ecc5e7e..cfd77b0 100644 --- a/disk/part.c +++ b/disk/part.c @@ -133,7 +133,7 @@ typedef lbaint_t lba512_t; * Overflowless variant of (block_count * mul_by / div_by) * when div_by > mul_by */ -static lba512_t lba512_muldiv (lba512_t block_count, lba512_t mul_by, lba512_t div_by) +static lba512_t lba512_muldiv(lba512_t block_count, lba512_t mul_by, lba512_t div_by) { lba512_t bc_quot, bc_rem;
@@ -215,7 +215,8 @@ void dev_print (block_dev_desc_t *dev_desc)
lba512 = (lba * (dev_desc->blksz/512)); /* round to 1 digit */ - mb = lba512_muldiv(lba512, 10, 2048); /* 2048 = (1024 * 1024) / 512 MB */ + /* 2048 = (1024 * 1024) / 512 MB */ + mb = lba512_muldiv(lba512, 10, 2048);
mb_quot = mb / 10; mb_rem = mb - (10 * mb_quot); @@ -248,7 +249,7 @@ void dev_print (block_dev_desc_t *dev_desc)
-void init_part (block_dev_desc_t * dev_desc) +void init_part(block_dev_desc_t *dev_desc) { #ifdef CONFIG_ISO_PARTITION if (test_part_iso(dev_desc) == 0) { @@ -295,7 +296,7 @@ void init_part (block_dev_desc_t * dev_desc) defined(CONFIG_AMIGA_PARTITION) || \ defined(CONFIG_EFI_PARTITION)
-static void print_part_header (const char *type, block_dev_desc_t * dev_desc) +static void print_part_header(const char *type, block_dev_desc_t *dev_desc) { puts ("\nPartition Map for "); switch (dev_desc->if_type) {
On Tue, Sep 09, 2014 at 03:19:42PM +0200, Pavel Machek wrote:
Cleanup disk/part.c
Jeroen Hofstee
Pavel Machek
