[U-Boot] [PATCH v2 00/19] driver model bring-up of omap timer on dra72, dra74, am335x and am437x-sk evm
This patch series enables omap timer to adopt driver model. This has been tested on the following evms (logs [1]) by invoking 'sleep 10' command with minicom timestamps. * dra72 evm * dra74 evm * am335x evm * am335x bbb * am437x-sk evm * am437x-gp evm
Also pushed a branch for testing [2]
[1] - http://pastebin.ubuntu.com/14190309/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git dm-timer-v2
Changes from initial->v2: * Moved get timer either from choosen/first available timer from dm_timer_init to timer_init. * Fixed typo errors in doc and comments * Changed omap_timer_get_count dedfinition as per latest code base.
Mugunthan V N (19): arm: omap-common: do not build timer when CONFIG_TIMER defined dm: timer: uclass: add timer init to add timer device dm: timer: uclass: Add flag to control sequence numbering drivers: timer: omap_timer: add timer driver for omap devices based on dm am43xx_evm: timer: do not define CONFIG_TIMER for spl arm: dts: am437x-sk-evm: add tick-timer to chosen node defconfig: am437x_sk_evm: enable timer driver model arm: dts: am437x-gp-evm: add tick-timer to chosen node defconfig: am437x_gp_evm: enable timer driver model am335x_evm: timer: do not define CONFIG_TIMER for spl arm: dts: am335x-boneblack: add tick-timer to chosen node defconfig: am335x_boneblack_vboot: enable timer driver model arm: dts: am335x-evm: add tick-timer to chosen node defconfig: am335x_gp_evm: enable timer driver model ti_omap5_common: timer: do not define CONFIG_TIMER for spl arm: dts: dra72-evm: add tick-timer to chosen node defconfig: dra72_evm: enable timer driver model arm: dts: dra7-evm: add tick-timer to chosen node defconfig: dra74_evm: enable timer driver model
arch/arm/cpu/armv7/omap-common/Makefile | 6 ++ arch/arm/dts/am335x-boneblack.dts | 1 + arch/arm/dts/am335x-evm.dts | 1 + arch/arm/dts/am437x-gp-evm.dts | 1 + arch/arm/dts/am437x-sk-evm.dts | 1 + arch/arm/dts/dra7-evm.dts | 1 + arch/arm/dts/dra72-evm.dts | 1 + configs/am335x_boneblack_vboot_defconfig | 2 + configs/am335x_gp_evm_defconfig | 2 + configs/am437x_gp_evm_defconfig | 2 + configs/am437x_sk_evm_defconfig | 2 + configs/dra72_evm_defconfig | 2 + configs/dra74_evm_defconfig | 2 + doc/device-tree-bindings/chosen.txt | 43 ++++++++++++ drivers/timer/Kconfig | 6 ++ drivers/timer/Makefile | 1 + drivers/timer/omap-timer.c | 108 +++++++++++++++++++++++++++++++ drivers/timer/timer-uclass.c | 43 ++++++++++++ include/configs/am335x_evm.h | 1 + include/configs/am43xx_evm.h | 1 + include/configs/ti_omap5_common.h | 1 + lib/time.c | 13 +--- 22 files changed, 230 insertions(+), 11 deletions(-) create mode 100644 doc/device-tree-bindings/chosen.txt create mode 100644 drivers/timer/omap-timer.c
To prepare timer driver to DM/DT conversion do not build the exiting timer driver when CONFIG_TIMER is defined. But since omap's SPL doesn't support DM yet so built timer driver only for SPL build when CONFIG_TIMER is defined.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/cpu/armv7/omap-common/Makefile | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 464a5d1..87a7ac0 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -6,7 +6,13 @@ #
obj-y := reset.o +ifeq ($(CONFIG_TIMER),) obj-y += timer.o +else +ifdef CONFIG_SPL_BUILD +obj-y += timer.o +endif +endif obj-y += utils.o
ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),)
-- Tom
Applied to u-boot-dm, thanks!
Adding timer_init function to create and initialize the timer device on platforms where u-boot,dm-pre-reloc is not used. Since there will be multiple timer devices in the system, adding a tick-timer node in chosen node to know which timer device to be used as tick timer in u-boot.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- doc/device-tree-bindings/chosen.txt | 43 +++++++++++++++++++++++++++++++++++++ drivers/timer/timer-uclass.c | 42 ++++++++++++++++++++++++++++++++++++ lib/time.c | 13 ++--------- 3 files changed, 87 insertions(+), 11 deletions(-) create mode 100644 doc/device-tree-bindings/chosen.txt
diff --git a/doc/device-tree-bindings/chosen.txt b/doc/device-tree-bindings/chosen.txt new file mode 100644 index 0000000..bf9a30a --- /dev/null +++ b/doc/device-tree-bindings/chosen.txt @@ -0,0 +1,43 @@ +The chosen node +--------------- +The chosen node does not represent a real device, but serves as a place +for passing data like which serial device to used to print the logs etc + + +stdout-path property +-------------------- +Device trees may specify the device to be used for boot console output +with a stdout-path property under /chosen. + +Example +------- +/ { + chosen { + stdout-path = "/serial@f00:115200"; + }; + + serial@f00 { + compatible = "vendor,some-uart"; + reg = <0xf00 0x10>; + }; +}; + +tick-timer property +------------------- +In a system there are multiple timers, specify which timer to be used +as the tick-timer. Earlier it was hardcoded in the timer driver now +since device tree has all the timer nodes. Specify which timer to be +used as tick timer. + +Example +------- +/ { + chosen { + tick-timer = "/timer2@f00"; + }; + + timer2@f00 { + compatible = "vendor,some-timer"; + reg = <0xf00 0x10>; + }; +}; diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index aca421b..db43611 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -6,6 +6,8 @@
#include <common.h> #include <dm.h> +#include <dm/lists.h> +#include <dm/device-internal.h> #include <errno.h> #include <timer.h>
@@ -56,6 +58,46 @@ u64 timer_conv_64(u32 count) return ((u64)gd->timebase_h << 32) | gd->timebase_l; }
+int timer_init(void) +{ + const void *blob = gd->fdt_blob; + struct udevice *dev; + int node; + int ret; + + /* Check for a chosen timer to be used for tick */ + node = fdtdec_get_chosen_node(blob, "tick-timer"); + if (node < 0) + return -ENODEV; + + if (uclass_get_device_by_of_offset(UCLASS_TIMER, node, &dev)) { + /* + * If the timer is not marked to be bound before + * relocation, bind it anyway. + */ + if (node > 0 && + !lists_bind_fdt(gd->dm_root, blob, node, &dev)) { + int ret = device_probe(dev); + if (ret) + return ret; + } + } + + if (dev) { + gd->timer = dev; + return 0; + } + + ret = uclass_first_device(UCLASS_TIMER, &dev); + if (ret) + return ret; + if (!dev) + return -ENODEV; + + gd->timer = dev; + return 0; +} + UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", diff --git a/lib/time.c b/lib/time.c index f37a662..d4060f1 100644 --- a/lib/time.c +++ b/lib/time.c @@ -43,17 +43,8 @@ extern unsigned long __weak timer_read_counter(void); #ifdef CONFIG_TIMER static int notrace dm_timer_init(void) { - struct udevice *dev; - int ret; - - if (!gd->timer) { - ret = uclass_first_device(UCLASS_TIMER, &dev); - if (ret) - return ret; - if (!dev) - return -ENODEV; - gd->timer = dev; - } + if (!gd->timer) + return timer_init();
return 0; }
Hi Mugunthan,
chosen {
serial@f00 {
reg = <0xf00 0x10>;
chosen {
timer2@f00 {
reg = <0xf00 0x10>;
int node;
int ret;
if (node < 0)
return -ENODEV;
This changes now require every device tree provide a "tick-timer" under /chosen, which break all the existing dm timer enabled boards, and is not necessary.
We should do:
if (node < 0) { ret = uclass_first_device(UCLASS_TIMER, &dev); if (ret) return ret; if (!dev) return -ENODEV; gd->timer = dev; } else { .... }
if (node > 0 &&
if (ret)
return ret;
if (dev) {
gd->timer = dev;
if (ret)
return ret;
if (!dev)
return -ENODEV;
gd->timer = dev;
int ret;
if (!gd->timer) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
gd->timer = dev;
if (!gd->timer)
Looks timer_init() is only called in timer-uclass.c, should we declare it as static? Otherwise timer_init() will be called in either board_f.c or board_r.c on different architectures. This causes timer devices to be probed twice. We may just simply move all codes in timer_init() into dm_timer_init().
Regards, Bin
if (node < 0)
return -ENODEV;
We should do:
Oops!, will fix it in next version.
Regards Mugunthan V N
Submitting 02/19 only for v3 as there is no change on other patches and to reduce traffic.
This patch is verified on AM437x SK and DRA74 EVM logs [1] and pushed a branch for testing
[1] - http://pastebin.ubuntu.com/14205433/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git dm-timer-v3
Changes from v2->v3: * Fixed issue which is in v2 that if no chosen timer node is present in DT then timer init always fails without trying first available timer.
--- doc/device-tree-bindings/chosen.txt | 43 +++++++++++++++++++++++++++++++++++++ drivers/timer/timer-uclass.c | 41 +++++++++++++++++++++++++++++++++++ lib/time.c | 13 ++--------- 3 files changed, 86 insertions(+), 11 deletions(-) create mode 100644 doc/device-tree-bindings/chosen.txt
diff --git a/doc/device-tree-bindings/chosen.txt b/doc/device-tree-bindings/chosen.txt new file mode 100644 index 0000000..bf9a30a --- /dev/null +++ b/doc/device-tree-bindings/chosen.txt @@ -0,0 +1,43 @@ +The chosen node +--------------- +The chosen node does not represent a real device, but serves as a place +for passing data like which serial device to used to print the logs etc + + +stdout-path property +-------------------- +Device trees may specify the device to be used for boot console output +with a stdout-path property under /chosen. + +Example +------- +/ { + chosen { + stdout-path = "/serial@f00:115200"; + }; + + serial@f00 { + compatible = "vendor,some-uart"; + reg = <0xf00 0x10>; + }; +}; + +tick-timer property +------------------- +In a system there are multiple timers, specify which timer to be used +as the tick-timer. Earlier it was hardcoded in the timer driver now +since device tree has all the timer nodes. Specify which timer to be +used as tick timer. + +Example +------- +/ { + chosen { + tick-timer = "/timer2@f00"; + }; + + timer2@f00 { + compatible = "vendor,some-timer"; + reg = <0xf00 0x10>; + }; +}; diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index aca421b..b6699f2 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -6,6 +6,8 @@
@@ -56,6 +58,45 @@ u64 timer_conv_64(u32 count) return ((u64)gd->timebase_h << 32) | gd->timebase_l; }
+int timer_init(void) +{ + const void *blob = gd->fdt_blob; + struct udevice *dev = NULL; + int node; + int ret; + + /* Check for a chosen timer to be used for tick */ + node = fdtdec_get_chosen_node(blob, "tick-timer"); + if (node < 0) { + /* No chosen timer, trying first available timer */ + ret = uclass_first_device(UCLASS_TIMER, &dev); + if (ret) + return ret; + if (!dev) + return -ENODEV; + } else { + if (uclass_get_device_by_of_offset(UCLASS_TIMER, node, &dev)) { + /* + * If the timer is not marked to be bound before + * relocation, bind it anyway. + */ + if (node > 0 && + !lists_bind_fdt(gd->dm_root, blob, node, &dev)) { + int ret = device_probe(dev); + if (ret) + return ret; + } + } + } + + if (dev) { + gd->timer = dev; + return 0; + } + + return -ENODEV; +} + UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", diff --git a/lib/time.c b/lib/time.c index f37a662..d4060f1 100644 --- a/lib/time.c +++ b/lib/time.c @@ -43,17 +43,8 @@ extern unsigned long __weak timer_read_counter(void); #ifdef CONFIG_TIMER static int notrace dm_timer_init(void) { - struct udevice *dev; - int ret; - - if (!gd->timer) { - ret = uclass_first_device(UCLASS_TIMER, &dev); - if (ret) - return ret; - if (!dev) - return -ENODEV; - gd->timer = dev; - } + if (!gd->timer) + return timer_init();
return 0; }
Hi Mugunthan,
- Fixed issue which is in v2 that if no chosen timer node is present in DT then timer init always fails without trying first available timer.
chosen {
serial@f00 {
reg = <0xf00 0x10>;
chosen {
timer2@f00 {
reg = <0xf00 0x10>;
int node;
int ret;
if (node < 0) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
Thanks for the quick v3!
} else {
if (node > 0 &&
nits: no need to declare another ret. Just "ret = device_probe(dev)".
if (ret)
return ret;
if (dev) {
gd->timer = dev;
return -ENODEV;
int ret;
if (!gd->timer) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
gd->timer = dev;
if (!gd->timer)
What about my comments in v2, that make timer_init() static or just move codes in timer_init() into this dm_timer_init()?
Regards, Bin
On Friday 25 December 2015 05:43 PM, Bin Meng wrote:
Hi Mugunthan,
chosen {
serial@f00 {
reg = <0xf00 0x10>;
chosen {
timer2@f00 {
reg = <0xf00 0x10>;
int node;
int ret;
if (node < 0) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
} else {
if (node > 0 &&
Hmmm, yep not needed.
if (ret)
return ret;
if (dev) {
gd->timer = dev;
return -ENODEV;
int ret;
if (!gd->timer) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
gd->timer = dev;
if (!gd->timer)
Oops, missed :)
The timer_init() code can be moved to dm_timer_init(), but since it provides timer uclass functionality I kept the code in timer-uclass driver.
Now since dm_timer_init() doesn't have any thing other than calling timer_init, I will move the dm_timer_init() to timer_uclass and move timer_init code to it.
Hi Mugunthan,
chosen {
serial@f00 {
reg = <0xf00 0x10>;
chosen {
timer2@f00 {
reg = <0xf00 0x10>;
int node;
int ret;
if (node < 0) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
} else {
if (node > 0 &&
if (ret)
return ret;
if (dev) {
gd->timer = dev;
return -ENODEV;
int ret;
if (!gd->timer) {
if (ret)
return ret;
if (!dev)
return -ENODEV;
gd->timer = dev;
if (!gd->timer)
Oops, missed :)
Can you please add these changes in a follow-up commit? I'd like to apply this series.
Adding timer init function in timer-uclass driver to create and initialize the timer device on platforms where u-boot,dm-pre-reloc is not used. Since there will be multiple timer devices in the system, adding a tick-timer node in chosen node to know which timer device to be used as tick timer in u-boot.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- doc/device-tree-bindings/chosen.txt | 43 ++++++++++++++++++++++++++++++++++++ drivers/timer/timer-uclass.c | 44 +++++++++++++++++++++++++++++++++++++ include/timer.h | 9 ++++++++ lib/time.c | 17 -------------- 4 files changed, 96 insertions(+), 17 deletions(-) create mode 100644 doc/device-tree-bindings/chosen.txt
Changes from v3: * removed dm_timer_init() in lib/time.c as it doesn't add anything and simply calls uclass driver's init and also renamed timer_init() to dm_timer_init() as many platforms calls timer_init() before dm init. * removed re-declaring of ret in dm_timer_init()
Tested this patch on DRA74x EVM (logs [1]) with sleep 10 with minicom timestamps and pushed a branch [2] for testing.
[1] - http://pastebin.ubuntu.com/14520385/ [2] - git://git.ti.com/~mugunthanvnm/ti-u-boot/mugunth-ti-u-boot.git dm-timer-v4
diff --git a/doc/device-tree-bindings/chosen.txt b/doc/device-tree-bindings/chosen.txt new file mode 100644 index 0000000..bf9a30a --- /dev/null +++ b/doc/device-tree-bindings/chosen.txt @@ -0,0 +1,43 @@ +The chosen node +--------------- +The chosen node does not represent a real device, but serves as a place +for passing data like which serial device to used to print the logs etc + + +stdout-path property +-------------------- +Device trees may specify the device to be used for boot console output +with a stdout-path property under /chosen. + +Example +------- +/ { + chosen { + stdout-path = "/serial@f00:115200"; + }; + + serial@f00 { + compatible = "vendor,some-uart"; + reg = <0xf00 0x10>; + }; +}; + +tick-timer property +------------------- +In a system there are multiple timers, specify which timer to be used +as the tick-timer. Earlier it was hardcoded in the timer driver now +since device tree has all the timer nodes. Specify which timer to be +used as tick timer. + +Example +------- +/ { + chosen { + tick-timer = "/timer2@f00"; + }; + + timer2@f00 { + compatible = "vendor,some-timer"; + reg = <0xf00 0x10>; + }; +}; diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index aca421b..0480178 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -6,6 +6,8 @@
@@ -56,6 +58,48 @@ u64 timer_conv_64(u32 count) return ((u64)gd->timebase_h << 32) | gd->timebase_l; }
+int notrace dm_timer_init(void) +{ + const void *blob = gd->fdt_blob; + struct udevice *dev = NULL; + int node; + int ret; + + if (gd->timer) + return 0; + + /* Check for a chosen timer to be used for tick */ + node = fdtdec_get_chosen_node(blob, "tick-timer"); + if (node < 0) { + /* No chosen timer, trying first available timer */ + ret = uclass_first_device(UCLASS_TIMER, &dev); + if (ret) + return ret; + if (!dev) + return -ENODEV; + } else { + if (uclass_get_device_by_of_offset(UCLASS_TIMER, node, &dev)) { + /* + * If the timer is not marked to be bound before + * relocation, bind it anyway. + */ + if (node > 0 && + !lists_bind_fdt(gd->dm_root, blob, node, &dev)) { + ret = device_probe(dev); + if (ret) + return ret; + } + } + } + + if (dev) { + gd->timer = dev; + return 0; + } + + return -ENODEV; +} + UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", diff --git a/include/timer.h b/include/timer.h index 7fee17e..f14725c 100644 --- a/include/timer.h +++ b/include/timer.h @@ -8,6 +8,15 @@ #define _TIMER_H_
/* + * dm_timer_init - initialize a timer for time keeping. On success + * initializes gd->timer so that lib/timer can use it for future + * referrence. + * + * @return - 0 on success or error number + */ +int dm_timer_init(void); + +/* * timer_conv_64 - convert 32-bit counter value to 64-bit * * @count: 32-bit counter value diff --git a/lib/time.c b/lib/time.c index f37a662..e9f6861 100644 --- a/lib/time.c +++ b/lib/time.c @@ -41,23 +41,6 @@ extern unsigned long __weak timer_read_counter(void); #endif
#ifdef CONFIG_TIMER -static int notrace dm_timer_init(void) -{ - struct udevice *dev; - int ret; - - if (!gd->timer) { - ret = uclass_first_device(UCLASS_TIMER, &dev); - if (ret) - return ret; - if (!dev) - return -ENODEV; - gd->timer = dev; - } - - return 0; -} - ulong notrace get_tbclk(void) { int ret;
Please drop this patch, will send a fixup patch as the series is already applied to u-boot-dm tree.
Hi Mugunthan,
You can send a new patch if you like and I can replace it. Either works for me.
On Saturday 16 January 2016 10:11 PM, Simon Glass wrote:
Hi Mugunthan,
Just sent a follow-up patch. Its good to not change the pushed history.
Hi Mugunthan,
Hi Mugunthan,
I actually do this all the time as I rebase against master before testing and sending pull requests. It helps to avoid conflicts for Tom to deal with.
So since you have given me two options, I've pick up this patch and replaced the v3 patch with it. I checked that the effect is the same as applying your fix-up. The patches were sitting around since Christmas so I wanted to get them in to permit the maximum possible testing window.
Like SPI and I2C, timer devices also have multiple chip instances. This patch adds the flag 'DM_UC_FLAG_SEQ_ALIAS' in timer_uclass driver to control device sequence numbering.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com --- drivers/timer/timer-uclass.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index db43611..abeb060 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -102,5 +102,6 @@ UCLASS_DRIVER(timer) = { .id = UCLASS_TIMER, .name = "timer", .pre_probe = timer_pre_probe, + .flags = DM_UC_FLAG_SEQ_ALIAS, .per_device_auto_alloc_size = sizeof(struct timer_dev_priv), };
Adding a timer driver for omap devices based on driver model and device tree.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- drivers/timer/Kconfig | 6 +++ drivers/timer/Makefile | 1 + drivers/timer/omap-timer.c | 108 +++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 115 insertions(+) create mode 100644 drivers/timer/omap-timer.c
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 2b10d2b..ff65a73 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -30,4 +30,10 @@ config X86_TSC_TIMER help Select this to enable Time-Stamp Counter (TSC) timer for x86.
+config OMAP_TIMER + bool "Omap timer support" + depends on TIMER + help + Select this to enable an timer for Omap devices. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index fe954ec..f351fbb 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -8,3 +8,4 @@ obj-$(CONFIG_TIMER) += timer-uclass.o obj-$(CONFIG_ALTERA_TIMER) += altera_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o +obj-$(CONFIG_OMAP_TIMER) += omap-timer.o diff --git a/drivers/timer/omap-timer.c b/drivers/timer/omap-timer.c new file mode 100644 index 0000000..3bb38c5 --- /dev/null +++ b/drivers/timer/omap-timer.c @@ -0,0 +1,108 @@ +/* + * TI OMAP timer driver + * + * Copyright (C) 2015, Texas Instruments, Incorporated + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> +#include <asm/io.h> +#include <asm/arch/clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Timer register bits */ +#define TCLR_START BIT(0) /* Start=1 */ +#define TCLR_AUTO_RELOAD BIT(1) /* Auto reload */ +#define TCLR_PRE_EN BIT(5) /* Pre-scaler enable */ +#define TCLR_PTV_SHIFT (2) /* Pre-scaler shift value */ + +#define TIMER_CLOCK (V_SCLK / (2 << CONFIG_SYS_PTV)) + +struct omap_gptimer_regs { + unsigned int tidr; /* offset 0x00 */ + unsigned char res1[12]; + unsigned int tiocp_cfg; /* offset 0x10 */ + unsigned char res2[12]; + unsigned int tier; /* offset 0x20 */ + unsigned int tistatr; /* offset 0x24 */ + unsigned int tistat; /* offset 0x28 */ + unsigned int tisr; /* offset 0x2c */ + unsigned int tcicr; /* offset 0x30 */ + unsigned int twer; /* offset 0x34 */ + unsigned int tclr; /* offset 0x38 */ + unsigned int tcrr; /* offset 0x3c */ + unsigned int tldr; /* offset 0x40 */ + unsigned int ttgr; /* offset 0x44 */ + unsigned int twpc; /* offset 0x48 */ + unsigned int tmar; /* offset 0x4c */ + unsigned int tcar1; /* offset 0x50 */ + unsigned int tscir; /* offset 0x54 */ + unsigned int tcar2; /* offset 0x58 */ +}; + +/* Omap Timer Priv */ +struct omap_timer_priv { + struct omap_gptimer_regs *regs; +}; + +static int omap_timer_get_count(struct udevice *dev, u64 *count) +{ + struct omap_timer_priv *priv = dev_get_priv(dev); + + *count = readl(&priv->regs->tcrr); + + return 0; +} + +static int omap_timer_probe(struct udevice *dev) +{ + struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct omap_timer_priv *priv = dev_get_priv(dev); + + uc_priv->clock_rate = TIMER_CLOCK; + + /* start the counter ticking up, reload value on overflow */ + writel(0, &priv->regs->tldr); + /* enable timer */ + writel((CONFIG_SYS_PTV << 2) | TCLR_PRE_EN | TCLR_AUTO_RELOAD | + TCLR_START, &priv->regs->tclr); + + return 0; +} + +static int omap_timer_ofdata_to_platdata(struct udevice *dev) +{ + struct omap_timer_priv *priv = dev_get_priv(dev); + + priv->regs = (struct omap_gptimer_regs *)dev_get_addr(dev); + + return 0; +} + + +static const struct timer_ops omap_timer_ops = { + .get_count = omap_timer_get_count, +}; + +static const struct udevice_id omap_timer_ids[] = { + { .compatible = "ti,am335x-timer" }, + { .compatible = "ti,am4372-timer" }, + { .compatible = "ti,omap5430-timer" }, + {} +}; + +U_BOOT_DRIVER(omap_timer) = { + .name = "omap_timer", + .id = UCLASS_TIMER, + .of_match = omap_timer_ids, + .ofdata_to_platdata = omap_timer_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct omap_timer_priv), + .probe = omap_timer_probe, + .ops = &omap_timer_ops, + .flags = DM_FLAG_PRE_RELOC, +};
[snip]
- { .compatible = "ti,am335x-timer" },
- { .compatible = "ti,am4372-timer" },
- { .compatible = "ti,omap5430-timer" },
This is the same IP block that's been used "forever" yes? Can we add in the compatibles for omap3 (and ti81xx?) as well so it will just work as those get brought over as well?
Please address comments in a follow-up patch.
Since OMAP's spl doesn't support DM currently, do not define CONFIG_TIMER for spl build.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- include/configs/am43xx_evm.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index aac550a..9980203 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -142,6 +142,7 @@ */ #ifdef CONFIG_SPL_BUILD #undef CONFIG_DM_MMC +#undef CONFIG_TIMER #endif
#ifndef CONFIG_SPL_BUILD
Specify which timer to be used as tick-timer in chosen node.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/am437x-sk-evm.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/am437x-sk-evm.dts b/arch/arm/dts/am437x-sk-evm.dts index 3f9d808..85d3381 100644 --- a/arch/arm/dts/am437x-sk-evm.dts +++ b/arch/arm/dts/am437x-sk-evm.dts @@ -26,6 +26,7 @@
chosen { stdout-path = &uart0; + tick-timer = &timer2; };
backlight {
Enable timer driver model for am437x_sk_evm as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am437x_sk_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/am437x_sk_evm_defconfig b/configs/am437x_sk_evm_defconfig index a9b6f52..56a7b11 100644 --- a/configs/am437x_sk_evm_defconfig +++ b/configs/am437x_sk_evm_defconfig @@ -18,3 +18,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/am437x-gp-evm.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/am437x-gp-evm.dts b/arch/arm/dts/am437x-gp-evm.dts index b5f0b4e..8e23b96 100644 --- a/arch/arm/dts/am437x-gp-evm.dts +++ b/arch/arm/dts/am437x-gp-evm.dts @@ -26,6 +26,7 @@
vmmcsd_fixed: fixedregulator-sd {
-- Tom
Enable timer driver model for am437x_gp_evm as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am437x_gp_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/am437x_gp_evm_defconfig b/configs/am437x_gp_evm_defconfig index 7155c98..1d79ba19 100644 --- a/configs/am437x_gp_evm_defconfig +++ b/configs/am437x_gp_evm_defconfig @@ -18,3 +18,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- include/configs/am335x_evm.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index c51db8c..d93fdf1 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -361,6 +361,7 @@ */ #ifdef CONFIG_SPL_BUILD #undef CONFIG_DM_MMC +#undef CONFIG_TIMER #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT)
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/am335x-boneblack.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/am335x-boneblack.dts b/arch/arm/dts/am335x-boneblack.dts index 679248a..27ebe4a 100644 --- a/arch/arm/dts/am335x-boneblack.dts +++ b/arch/arm/dts/am335x-boneblack.dts @@ -15,6 +15,7 @@ compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx"; chosen { stdout-path = &uart0; + tick-timer = &timer2; }; };
-- Tom
Enable timer driver model for am335x_boneblack_vboot as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am335x_boneblack_vboot_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index ad40b07..888d5b1 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -18,3 +18,5 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Specify timer2 to be used as tick-timer in chosen node.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/am335x-evm.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/am335x-evm.dts b/arch/arm/dts/am335x-evm.dts index e1c5d4f..c0bc2af 100644 --- a/arch/arm/dts/am335x-evm.dts +++ b/arch/arm/dts/am335x-evm.dts @@ -16,6 +16,7 @@
cpus {
-- Tom
Enable timer driver model for am335x_gp_evm as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/am335x_gp_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index 74d9ffb..49461e2 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -16,3 +16,5 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y CONFIG_RSA=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- include/configs/ti_omap5_common.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 2d492f8..d164e6a 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -164,6 +164,7 @@ */ #ifdef CONFIG_SPL_BUILD #undef CONFIG_DM_MMC +#undef CONFIG_TIMER #endif
#endif /* __CONFIG_TI_OMAP5_COMMON_H */
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/dra72-evm.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/dra72-evm.dts b/arch/arm/dts/dra72-evm.dts index efb544c..6e3bbfd 100644 --- a/arch/arm/dts/dra72-evm.dts +++ b/arch/arm/dts/dra72-evm.dts @@ -16,6 +16,7 @@
chosen { stdout-path = &uart1; + tick-timer = &timer2; };
memory {
-- Tom
Enable timer driver model for dra72_evm_defconfig as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/dra72_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index 3205bd5..530a25e 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -20,3 +20,5 @@ CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- arch/arm/dts/dra7-evm.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/dra7-evm.dts b/arch/arm/dts/dra7-evm.dts index e4daa99..2568aad 100644 --- a/arch/arm/dts/dra7-evm.dts +++ b/arch/arm/dts/dra7-evm.dts @@ -16,6 +16,7 @@
memory {
-- Tom
Enable timer driver model for dra74_evm_defconfig as omap-timer supports driver model.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com --- configs/dra74_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index 394edbe..a68870e 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -19,3 +19,5 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_TI_QSPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y
-- Tom
Bin Meng
Mugunthan V N
