[U-Boot] please pull u-boot-samsung master
Dear Albert,
The following changes since commit ccfa398547ce0b579f2e7874e78948246c739237:
arm1136: Fix enable_caches() (2012-11-10 12:28:22 +0100)
git://git.denx.de/u-boot-samsung master
for you to fetch changes up to 7a5337732e3e05b2b0de1b592fa031b2c7b4f632:
EXYNOS5: Enable SPI booting. (2012-11-15 21:08:21 +0900)
---------------------------------------------------------------- Ashok Kumar Reddy (1): ARM: arm1176: Define arch_cpu_init() for s3c64xx
Chander Kashyap (1): Exynos5250: Enable PXE Support
Hatim RV (3): EXYNOS: Add clock for SPI EXYNOS5: Add base address for SPI EXYNOS5: Enable SPI
Marek Vasut (1): dm: wdt: Move s5p watchdog timer to drivers/watchdog/
Minkyu Kang (3): ARCH: EXYNOS: add support to match product id EXYNOS: Clock: Add common function for pll rate calculation s3c64xx: fix the compiler error and warning
Piotr Wilczek (12): arm:exynos4:trats: Correct SDRAM configuration for trats arm:exynos4:trats: Fix SDRAM size arm:exynos4:pinmux: Modify the gpio function for mmc arm:exynos4:trats: Use pinmux for mmc configuration arm:exynos4:universal: Use pinmux for mmc configuration arm:exynos4:universal: Eliminated low level init arm: trats: Power down core 1 exynos4: universal_C210: use software SPI misc:max8998 Add LDO macros drivers: video: Add ld9040 video driver drivers: video: fix image position exynos4: universal_C210: add display support
Rajeshwari Shinde (14): PMIC: MAX77686: Add support for MAX77686 SMDK5250: Config: Enable MAX77686 pmic chip SOUND: SAMSUNG: Add I2S driver SOUND: Add WM8994 codec Sound: Add command for audio playback EXYNOS: Add I2S registers EXYNOS: Add parameters required by I2S EXYNOS: Add pinmux for I2S EXYNOS: Add I2S base address EXYNOS: Add clock for I2S SMDK5250: Enable Sound EXYNOS5: Add pinmux support for SPI SPI: Add SPI Driver for EXYNOS. EXYNOS5: Enable SPI booting.
Łukasz Majewski (1): gpio:fix: Proper handling of GPIO subsystem parts at Samsung devices
Makefile | 1 + arch/arm/cpu/arm1176/s3c64xx/Makefile | 2 +- arch/arm/cpu/arm1176/s3c64xx/init.c | 26 + arch/arm/cpu/armv7/exynos/clock.c | 350 +++++++-- arch/arm/cpu/armv7/exynos/pinmux.c | 122 +++ arch/arm/cpu/armv7/s5p-common/Makefile | 1 - arch/arm/include/asm/arch-exynos/clk.h | 4 + arch/arm/include/asm/arch-exynos/clock.h | 29 + arch/arm/include/asm/arch-exynos/cpu.h | 18 + arch/arm/include/asm/arch-exynos/gpio.h | 19 + arch/arm/include/asm/arch-exynos/i2s-regs.h | 66 ++ arch/arm/include/asm/arch-exynos/periph.h | 7 + arch/arm/include/asm/arch-exynos/sound.h | 44 ++ arch/arm/include/asm/arch-exynos/spi.h | 78 ++ arch/arm/include/asm/arch-s5pc1xx/gpio.h | 7 +- board/samsung/smdk5250/Makefile | 2 +- board/samsung/smdk5250/smdk5250.c | 8 + board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} | 31 +- board/samsung/trats/trats.c | 80 +- board/samsung/universal_c210/Makefile | 1 - board/samsung/universal_c210/lowlevel_init.S | 395 ---------- board/samsung/universal_c210/universal.c | 335 +++++++-- common/Makefile | 1 + common/cmd_sound.c | 96 +++ drivers/gpio/s5p_gpio.c | 6 +- drivers/misc/Makefile | 1 + drivers/misc/pmic_max77686.c | 42 ++ drivers/serial/s3c64xx.c | 3 +- drivers/sound/Makefile | 48 ++ drivers/sound/samsung-i2s.c | 358 +++++++++ drivers/sound/sound.c | 228 ++++++ drivers/sound/wm8994.c | 792 ++++++++++++++++++++ drivers/sound/wm8994.h | 87 +++ drivers/sound/wm8994_registers.h | 299 ++++++++ drivers/spi/Makefile | 1 + drivers/spi/exynos_spi.c | 367 +++++++++ drivers/video/Makefile | 1 + drivers/video/exynos_fb.c | 15 +- drivers/video/ld9040.c | 144 ++++ drivers/watchdog/Makefile | 1 + .../s5p-common/wdt.c => drivers/watchdog/s5p_wdt.c | 0 include/configs/s5pc210_universal.h | 36 + include/configs/smdk5250.h | 46 +- include/configs/trats.h | 17 +- include/i2s.h | 127 ++++ include/ld9040.h | 32 + include/max77686_pmic.h | 158 ++++ include/max8998_pmic.h | 2 + include/sound.h | 62 ++ 49 files changed, 3983 insertions(+), 613 deletions(-) create mode 100644 arch/arm/cpu/arm1176/s3c64xx/init.c create mode 100644 arch/arm/include/asm/arch-exynos/i2s-regs.h create mode 100644 arch/arm/include/asm/arch-exynos/sound.h create mode 100644 arch/arm/include/asm/arch-exynos/spi.h rename board/samsung/smdk5250/{mmc_boot.c => spl_boot.c} (66%) delete mode 100644 board/samsung/universal_c210/lowlevel_init.S create mode 100644 common/cmd_sound.c create mode 100644 drivers/misc/pmic_max77686.c create mode 100644 drivers/sound/Makefile create mode 100644 drivers/sound/samsung-i2s.c create mode 100644 drivers/sound/sound.c create mode 100644 drivers/sound/wm8994.c create mode 100644 drivers/sound/wm8994.h create mode 100644 drivers/sound/wm8994_registers.h create mode 100644 drivers/spi/exynos_spi.c create mode 100644 drivers/video/ld9040.c rename arch/arm/cpu/armv7/s5p-common/wdt.c => drivers/watchdog/s5p_wdt.c (100%) create mode 100644 include/i2s.h create mode 100644 include/ld9040.h create mode 100644 include/max77686_pmic.h create mode 100644 include/sound.h
Hi Minkyu,
On Thu, 15 Nov 2012 21:12:52 +0900, Minkyu Kang mk7.kang@samsung.com wrote:
Dear Albert,
(Was your master branch rebased?)
Applied to u-boot-arm/master, thanks!
Amicalement,
On 16/11/12 08:50, Albert ARIBAUD wrote:
Hi Minkyu,
Yes. Is it not recommended?
Amicalement,
Thanks. Minkyu Kang.
Hi Minkyu,
Hi Minkyu,
The wiki may still be lagging behind but it has been discussed here and master branches should never be rebased, they should merge. Merges can fast-forward, though, if possible. The idea is that custodian master branches should be fairly autonomous projects, synchronizing to/from upstream as required, but not rebasing. 'Next' branches should try to follow this too, although rebasing a 'next' is allowed.
Amicalement,
Albert ARIBAUD
Minkyu Kang
