Re: [DNX#2006040142000688] [U-Boot-Users] Re: parse bug in cmd_mii.c
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006040142000688] was created:
<snip>
Sorry, it looks like I never sent it in. Here goes:
CHANGELOG
- entering 'mii' with no arguments causes a null pointer reference.
Check argc is >=2 before dereferencing argv[1]. Print the usage message if not. Patch by Andrew Dyer amdyer@gmail.com, Sat Mar 11 21:42:12 CST 2006
Signed-off-by: Andrew Dyer amdyer@gmail.com
Index: cmd_mii.c
RCS file: /home/cvsroot/Projects/u-boot/common/cmd_mii.c,v retrieving revision 1.1.1.5 retrieving revision 1.8 diff -u -r1.1.1.5 -r1.8 --- cmd_mii.c 7 Feb 2006 09:51:23 -0000 1.1.1.5 +++ cmd_mii.c 12 Mar 2006 03:33:56 -0000 1.8 @@ -61,6 +61,11 @@ mii_init (); #endif
if (argc < 2) {
printf ("Usage:\n%s\n", cmdtp->usage);
return 1;
/* * We use the last specified parameters, unless new ones are * entered.
@@ -438,6 +443,11 @@ #ifdef CONFIG_8xx mii_init (); #endif
if (argc < 2) {
return 1;
} /* * We use the last specified parameters, unless new ones are
On 3/11/06, Wolfgang Denk wd@denx.de wrote:
In message c166aa9f0506131006ba8f552@mail.gmail.com you wrote:
I noticed that in do_mii() the code is dereferencing argv[1] without checking what value argc has. This leads to an exception if a command line like 'mii ' is given where argv[1] is NULL.
I have a patch, but my cmd_mii.c is carrying around some other patches (some submitted to the list, some local). Is there a good way to separate out the patches I want to submit by themselves?
Did I miss it, or did you never send a patch for the problem you mentioned?
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de "'Tis true, 'tis pity, and pity 'tis 'tis true." - Poloniouius, in Willie the Shake's _Hamlet, Prince of Darkness_
-- Hardware, n.: The parts of a computer system that can be kicked.
This SF.Net email is sponsored by xPML, a groundbreaking scripting language that extends applications into web and mobile media. Attend the live webcast and join the prime developer group breaking into this new coding territory! http://sel.as-us.falkag.net/sel?cmd=lnk&kid%110944&bid$1720&dat%... _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
</snip>
Your U-Boot support team
DENX Support System
