[U-Boot] [PATCH 0/2] Enable fastboot support for Poplar board
It enables DWC2 OTG gadget driver and fastboot support for Poplar board.
Shawn Guo (2): poplar: add DWC2 OTG gadget support poplar_defconfig: enable fastboot support
.../asm/arch-hi3798cv200/hi3798cv200.h | 5 ++++ board/hisilicon/poplar/poplar.c | 28 +++++++++++++++++++ configs/poplar_defconfig | 14 ++++++++++ 3 files changed, 47 insertions(+)
It enables DWC2 OTG gadget driver support for Poplar board. As usb2_phy_init() is being always called from board_init(), we can save the call from board_usb_init().
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- .../asm/arch-hi3798cv200/hi3798cv200.h | 5 ++++ board/hisilicon/poplar/poplar.c | 28 +++++++++++++++++++ 2 files changed, 33 insertions(+)
diff --git a/arch/arm/include/asm/arch-hi3798cv200/hi3798cv200.h b/arch/arm/include/asm/arch-hi3798cv200/hi3798cv200.h index f97b1eb29f84..bb221e17e0ed 100644 --- a/arch/arm/include/asm/arch-hi3798cv200/hi3798cv200.h +++ b/arch/arm/include/asm/arch-hi3798cv200/hi3798cv200.h @@ -13,11 +13,16 @@ /* DEVICES */ #define REG_BASE_MCI 0xF9830000 #define REG_BASE_UART0 0xF8B00000 +#define HIOTG_BASE_ADDR 0xF98C0000
/* PERI control registers (4KB) */ /* USB2 PHY01 configuration register */ #define PERI_CTRL_USB0 (REG_BASE_PERI_CTRL + 0x120)
+ /* USB2 controller configuration register */ +#define PERI_CTRL_USB3 (REG_BASE_PERI_CTRL + 0x12c) +#define USB2_2P_CHIPID (1 << 28) + /* PERI CRG registers (4KB) */ /* USB2 CTRL0 clock and soft reset */ #define PERI_CRG46 (REG_BASE_CRG + 0xb8) diff --git a/board/hisilicon/poplar/poplar.c b/board/hisilicon/poplar/poplar.c index e1fbd5d0c669..af018ad2f8e4 100644 --- a/board/hisilicon/poplar/poplar.c +++ b/board/hisilicon/poplar/poplar.c @@ -168,6 +168,34 @@ int board_mmc_init(bd_t *bis) } #endif
+#if defined(CONFIG_USB_GADGET) && defined(CONFIG_USB_GADGET_DWC2_OTG) +#include <usb.h> +#include <usb/dwc2_udc.h> +#include <g_dnl.h> + +static struct dwc2_plat_otg_data poplar_otg_data = { + .regs_otg = HIOTG_BASE_ADDR +}; + +static void set_usb_to_device(void) +{ + setbits_le32(PERI_CTRL_USB3, USB2_2P_CHIPID); +} + +int board_usb_init(int index, enum usb_init_type init) +{ + set_usb_to_device(); + return dwc2_udc_probe(&poplar_otg_data); +} + +int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) +{ + if (!env_get("serial#")) + g_dnl_set_serialnumber("0123456789POPLAR"); + return 0; +} +#endif + int board_init(void) { usb2_phy_init();
It enables fastboot support on Poplar board by using DWC2 OTG gadget driver.
Signed-off-by: Shawn Guo shawn.guo@linaro.org --- configs/poplar_defconfig | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 946e7caf6bea..48e9c6eaac26 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -6,6 +6,13 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=2 # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SYS_PROMPT="poplar# " +CONFIG_FASTBOOT=y +CONFIG_USB_FUNCTION_FASTBOOT=y +CONFIG_CMD_FASTBOOT=y +CONFIG_FASTBOOT_BUF_ADDR=0x20000000 +CONFIG_FASTBOOT_BUF_SIZE=0x10000000 +CONFIG_FASTBOOT_FLASH=y +CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_ISO_PARTITION is not set @@ -18,6 +25,13 @@ CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_USB_GADGET_MANUFACTURER="HiSilicon" +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd00d CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_FAT_WRITE=y
Hi Tom,
Are you okay with these two patches?
Shawn
Hi Tom,
Yes, but I'll pick them up once the merge window opens again.
Shawn Guo
Shawn Guo
