[PATCH v2 2/3] rpi5: initial support
rpi5: add alternative way to get MBOX address via FDT node
MBOX on RPI5/bcm2712 has a different offset. Find it via "brcm,bcm2835-mbox" node.
Signed-off-by: Dmitry Malkin dmitry@bedrocksystems.com --- v2: new patch --- arch/arm/mach-bcm283x/include/mach/base.h | 1 + arch/arm/mach-bcm283x/include/mach/mbox.h | 4 ++-- arch/arm/mach-bcm283x/init.c | 12 +++++++++++- 3 files changed, 14 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-bcm283x/include/mach/base.h b/arch/arm/mach-bcm283x/include/mach/base.h index 4ccaf69693..8cd224921e 100644 --- a/arch/arm/mach-bcm283x/include/mach/base.h +++ b/arch/arm/mach-bcm283x/include/mach/base.h @@ -7,6 +7,7 @@ #define _BCM283x_BASE_H_
extern unsigned long rpi_bcm283x_base; +extern unsigned long rpi_bcm283x_mbox_addr;
#ifdef CONFIG_ARMV7_LPAE #ifdef CONFIG_TARGET_RPI_4_32B diff --git a/arch/arm/mach-bcm283x/include/mach/mbox.h b/arch/arm/mach-bcm283x/include/mach/mbox.h index 490664f878..ad086be467 100644 --- a/arch/arm/mach-bcm283x/include/mach/mbox.h +++ b/arch/arm/mach-bcm283x/include/mach/mbox.h @@ -38,8 +38,8 @@
/* Raw mailbox HW */
-#define BCM2835_MBOX_PHYSADDR ({ BUG_ON(!rpi_bcm283x_base); \ - rpi_bcm283x_base + 0x0000b880; }) +#define BCM2835_MBOX_PHYSADDR ({ BUG_ON(!rpi_bcm283x_mbox_addr); \ + rpi_bcm283x_mbox_addr; })
struct bcm2835_mbox_regs { u32 read; diff --git a/arch/arm/mach-bcm283x/init.c b/arch/arm/mach-bcm283x/init.c index 362838e9b9..aef3a31f29 100644 --- a/arch/arm/mach-bcm283x/init.c +++ b/arch/arm/mach-bcm283x/init.c @@ -145,6 +145,11 @@ static void rpi_update_mem_map(void) {}
unsigned long rpi_bcm283x_base = 0x3f000000;
+/* This is intialized before relocation. Enforce .data section usage. + * Otherwise it's going to .bss and will be zero after relocation. + */ +unsigned long __section(".data") rpi_bcm283x_mbox_addr; + int arch_cpu_init(void) { icache_enable(); @@ -154,7 +159,7 @@ int arch_cpu_init(void)
int mach_cpu_init(void) { - int ret, soc_offset; + int ret, soc_offset, mbox_offset; u64 io_base, size;
rpi_update_mem_map(); @@ -170,6 +175,11 @@ int mach_cpu_init(void) return ret;
rpi_bcm283x_base = io_base; + rpi_bcm283x_mbox_addr = rpi_bcm283x_base + 0xb880; + + mbox_offset = fdt_node_offset_by_compatible((void*)gd->fdt_blob, soc_offset, "brcm,bcm2835-mbox"); + if (mbox_offset > soc_offset) + rpi_bcm283x_mbox_addr = fdt_get_base_address((void*)gd->fdt_blob, mbox_offset);
return 0; }
Same note about descriptive commit titles, it's useful not to have 3 consecutive commits with the same title.
Do we do use the DT node just for the RPi5 and the old method for all older RPi, or do we move all generations to finding it by DT?
v2: new patch
- Otherwise it's going to .bss and will be zero after relocation.
- rpi_bcm283x_mbox_addr = rpi_bcm283x_base + 0xb880;
- mbox_offset = fdt_node_offset_by_compatible((void*)gd->fdt_blob,
- if (mbox_offset > soc_offset)
2.40.1
Dmitry Malkin
Peter Robinson
