[PATCH v2 00/52] mips: octeon: Add ethernet support
This patchset adds the networking files and drivers including device helper headers and C files. Please excuse the massive amount of files in this patch series. Also the sometimes huge files (mostly headers with register definitions) that I needed to include.
The infrastructure code with all the headers is ported mistly without any intended functional changes from the 2013 Cavium / Marvell U-Boot version. It has undergone many hours of extensive code cleanup and reformatting. Some of it done by using tools (checkpatch, Lindent, clang format etc) and also some of it done manually, as I couldn't find some tools that could do the needed work in a reliable and functional way. The result is that checkpatch now only throws a "few" warnings that are left. Some of those can't be removed without an even more extensive cleanup / rewrite of the code, like the addition of typedefs.
The added header, helper and infrastructure files in the first part of the patch-series (patches 1-43) are the foundation, that is used by the main Octeon U-Boot ethernet driver (patch 50/52). Patches 47-49 add the DT nodes and properties to the corresponding dtsi / dts files. Patches 51 & 52 finally enable the ethernet support both MIPS Octeon boards, EBB7304 & NIC23.
All this is tested on the 2 Cavium / Marvell MIPS Octeon boards: EBB7304 & NIC23
This patchset including the small Marvell PHY patches is available in this gitlab branch:
https://source.denx.de/u-boot/custodians/u-boot-marvell/-/tree/mips-octeon-e...
Changes in v2: - As suggested by Daniel, remove all unreferenced functions from the source code by manually inspecting u-boot.map [1] - Rebased on latest TOT
[1] Here the diffstat comarison between v1 and v2: v1: 77 files changed, 42315 insertions(+), 586 deletions(-) v2: 78 files changed, 33672 insertions(+), 2524 deletions(-)
Thanks, Stefan
Aaron Williams (40): mips: octeon: Add misc cvmx-* header files mips: octeon: Add cvmx-ilk-defs.h header file mips: octeon: Add cvmx-iob-defs.h header file mips: octeon: Add cvmx-lbk-defs.h header file mips: octeon: Add cvmx-npei-defs.h header file mips: octeon: Add cvmx-pcsxx-defs.h header file mips: octeon: Add cvmx-xcv-defs.h header file mips: octeon: Add cvmx-helper-agl.c mips: octeon: Add cvmx-helper-bgx.c mips: octeon: Add cvmx-helper-board.c mips: octeon: Add cvmx-helper-fpa.c mips: octeon: Add cvmx-helper-ilk.c mips: octeon: Add cvmx-helper-ipd.c mips: octeon: Add cvmx-helper-loop.c mips: octeon: Add cvmx-helper-npi.c mips: octeon: Add cvmx-helper-pki.c mips: octeon: Add cvmx-helper-pko.c mips: octeon: Add cvmx-helper-pko3.c mips: octeon: Add cvmx-helper-rgmii.c mips: octeon: Add cvmx-helper-sgmii.c mips: octeon: Add cvmx-helper-sfp.c mips: octeon: Add cvmx-helper-xaui.c mips: octeon: Add cvmx-agl.c mips: octeon: Add cvmx-cmd-queue.c mips: octeon: Add cvmx-fau-compat.c mips: octeon: Add cvmx-fpa.c mips: octeon: Add cvmx-fpa-resource.c mips: octeon: Add cvmx-global-resource.c mips: octeon: Add cvmx-ilk.c mips: octeon: Add cvmx-ipd.c mips: octeon: Add cvmx-pki.c mips: octeon: Add cvmx-pki-resources.c mips: octeon: Add cvmx-pko.c mips: octeon: Add cvmx-pko3.c mips: octeon: Add cvmx-pko3-queue.c mips: octeon: Add cvmx-pko3-compat.c mips: octeon: Add cvmx-pko3-resources.c mips: octeon: Add cvmx-pko-internal-ports-range.c mips: octeon: Add cvmx-qlm-tables.c mips: octeon: Add cvmx-range.c
Stefan Roese (12): mips: octeon: Misc changes to existing headers for upcoming eth support mips: octeon: Misc changes to existing C files for upcoming eth support mips: octeon: Makefile: Enable building of the newly added C files mips: octeon: cpu.c: Move bootmem init to arch_early_init_r() mips: octeon: cpu.c: Implement configure_lmtdma_window() mips: octeon: octeon_common.h: Move init SP because of increased image size mips: octeon: mrvl,cn73xx.dtsi: Add ethernet (BGX) and SMI DT nodes mips: octeon: mrvl,octeon-ebb7304.dts: Add ethernet DT support mips: octeon: mrvl,octeon-nic23.dts: Add ethernet DT support net: Add ethernet support for MIPS Octeon mips: octeon: ebb7304: Enable ethernet support mips: octeon: nic23: Enable ethernet support
arch/mips/Kconfig | 1 + arch/mips/dts/mrvl,cn73xx.dtsi | 35 + arch/mips/dts/mrvl,octeon-ebb7304.dts | 45 + arch/mips/dts/mrvl,octeon-nic23.dts | 238 ++ arch/mips/mach-octeon/Makefile | 35 +- arch/mips/mach-octeon/cpu.c | 47 +- arch/mips/mach-octeon/cvmx-agl.c | 216 + arch/mips/mach-octeon/cvmx-bootmem.c | 3 +- arch/mips/mach-octeon/cvmx-cmd-queue.c | 355 ++ arch/mips/mach-octeon/cvmx-fau-compat.c | 53 + arch/mips/mach-octeon/cvmx-fpa-resource.c | 219 + arch/mips/mach-octeon/cvmx-fpa.c | 1127 ++++++ arch/mips/mach-octeon/cvmx-global-resources.c | 517 +++ arch/mips/mach-octeon/cvmx-helper-agl.c | 231 ++ arch/mips/mach-octeon/cvmx-helper-bgx.c | 2737 +++++++++++++ arch/mips/mach-octeon/cvmx-helper-board.c | 1824 +++++++++ arch/mips/mach-octeon/cvmx-helper-cfg.c | 655 +-- arch/mips/mach-octeon/cvmx-helper-fdt.c | 898 +---- arch/mips/mach-octeon/cvmx-helper-fpa.c | 76 + arch/mips/mach-octeon/cvmx-helper-ilk.c | 902 +++++ arch/mips/mach-octeon/cvmx-helper-ipd.c | 286 ++ arch/mips/mach-octeon/cvmx-helper-loop.c | 178 + arch/mips/mach-octeon/cvmx-helper-npi.c | 137 + arch/mips/mach-octeon/cvmx-helper-pki.c | 549 +++ arch/mips/mach-octeon/cvmx-helper-pko.c | 203 + arch/mips/mach-octeon/cvmx-helper-pko3.c | 1088 +++++ arch/mips/mach-octeon/cvmx-helper-rgmii.c | 398 ++ arch/mips/mach-octeon/cvmx-helper-sfp.c | 1309 ++++++ arch/mips/mach-octeon/cvmx-helper-sgmii.c | 781 ++++ arch/mips/mach-octeon/cvmx-helper-util.c | 248 -- arch/mips/mach-octeon/cvmx-helper-xaui.c | 518 +++ arch/mips/mach-octeon/cvmx-helper.c | 845 +--- arch/mips/mach-octeon/cvmx-ilk.c | 1199 ++++++ arch/mips/mach-octeon/cvmx-ipd.c | 149 + arch/mips/mach-octeon/cvmx-pki-resources.c | 285 ++ arch/mips/mach-octeon/cvmx-pki.c | 910 +++++ .../cvmx-pko-internal-ports-range.c | 99 + arch/mips/mach-octeon/cvmx-pko.c | 788 ++++ arch/mips/mach-octeon/cvmx-pko3-compat.c | 656 +++ arch/mips/mach-octeon/cvmx-pko3-queue.c | 879 ++++ arch/mips/mach-octeon/cvmx-pko3-resources.c | 213 + arch/mips/mach-octeon/cvmx-pko3.c | 786 ++++ arch/mips/mach-octeon/cvmx-qlm-tables.c | 292 ++ arch/mips/mach-octeon/cvmx-range.c | 259 ++ arch/mips/mach-octeon/include/mach/cvmx-agl.h | 45 + .../mach-octeon/include/mach/cvmx-bootmem.h | 3 +- .../mach-octeon/include/mach/cvmx-config.h | 128 + arch/mips/mach-octeon/include/mach/cvmx-fau.h | 581 +++ arch/mips/mach-octeon/include/mach/cvmx-fpa.h | 3 +- .../mips/mach-octeon/include/mach/cvmx-fpa3.h | 37 - .../include/mach/cvmx-helper-board.h | 6 +- .../include/mach/cvmx-helper-fdt.h | 40 +- .../include/mach/cvmx-helper-pko.h | 2 +- .../mach-octeon/include/mach/cvmx-helper.h | 20 + .../mach-octeon/include/mach/cvmx-ilk-defs.h | 2269 +++++++++++ .../mach-octeon/include/mach/cvmx-iob-defs.h | 1328 ++++++ .../mach-octeon/include/mach/cvmx-lbk-defs.h | 157 + .../mips/mach-octeon/include/mach/cvmx-mdio.h | 516 +++ .../mach-octeon/include/mach/cvmx-npei-defs.h | 3550 +++++++++++++++++ .../include/mach/cvmx-pcsxx-defs.h | 787 ++++ .../include/mach/cvmx-pki-cluster.h | 343 ++ arch/mips/mach-octeon/include/mach/cvmx-pko.h | 213 + .../include/mach/cvmx-pko3-resources.h | 36 + .../mips/mach-octeon/include/mach/cvmx-pko3.h | 1052 +++++ .../mach-octeon/include/mach/cvmx-range.h | 23 + .../mips/mach-octeon/include/mach/cvmx-regs.h | 100 +- .../mach-octeon/include/mach/cvmx-xcv-defs.h | 226 ++ .../mach-octeon/include/mach/octeon_eth.h | 54 +- board/Marvell/octeon_nic23/board.c | 87 +- configs/octeon_ebb7304_defconfig | 7 + configs/octeon_nic23_defconfig | 10 +- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/octeon/Makefile | 6 + drivers/net/octeon/octeon_eth.c | 1060 +++++ drivers/net/octeon/octeon_mdio.c | 226 ++ include/configs/octeon_common.h | 2 +- include/configs/octeon_ebb7304.h | 2 + 78 files changed, 33672 insertions(+), 2524 deletions(-) create mode 100644 arch/mips/mach-octeon/cvmx-agl.c create mode 100644 arch/mips/mach-octeon/cvmx-cmd-queue.c create mode 100644 arch/mips/mach-octeon/cvmx-fau-compat.c create mode 100644 arch/mips/mach-octeon/cvmx-fpa-resource.c create mode 100644 arch/mips/mach-octeon/cvmx-fpa.c create mode 100644 arch/mips/mach-octeon/cvmx-global-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-agl.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-bgx.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-board.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-fpa.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-ilk.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-ipd.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-loop.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-npi.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pki.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko3.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-rgmii.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-sfp.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-sgmii.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-xaui.c create mode 100644 arch/mips/mach-octeon/cvmx-ilk.c create mode 100644 arch/mips/mach-octeon/cvmx-ipd.c create mode 100644 arch/mips/mach-octeon/cvmx-pki-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-pki.c create mode 100644 arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c create mode 100644 arch/mips/mach-octeon/cvmx-pko.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-compat.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-queue.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3.c create mode 100644 arch/mips/mach-octeon/cvmx-qlm-tables.c create mode 100644 arch/mips/mach-octeon/cvmx-range.c create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-agl.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-config.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-fau.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-mdio.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-range.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h create mode 100644 drivers/net/octeon/Makefile create mode 100644 drivers/net/octeon/octeon_eth.c create mode 100644 drivers/net/octeon/octeon_mdio.c
Import misc cvmx-helper header files from 2013 U-Boot. They will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/include/mach/cvmx-agl.h | 45 + .../mach-octeon/include/mach/cvmx-config.h | 128 ++ arch/mips/mach-octeon/include/mach/cvmx-fau.h | 581 +++++++++ .../mips/mach-octeon/include/mach/cvmx-mdio.h | 516 ++++++++ .../include/mach/cvmx-pki-cluster.h | 343 ++++++ arch/mips/mach-octeon/include/mach/cvmx-pko.h | 213 ++++ .../include/mach/cvmx-pko3-resources.h | 36 + .../mips/mach-octeon/include/mach/cvmx-pko3.h | 1052 +++++++++++++++++ .../mach-octeon/include/mach/cvmx-range.h | 23 + 9 files changed, 2937 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-agl.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-config.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-fau.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-mdio.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-range.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-agl.h b/arch/mips/mach-octeon/include/mach/cvmx-agl.h new file mode 100644 index 000000000000..4afb3a48bfdc --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-agl.h @@ -0,0 +1,45 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for AGL (RGMII) commong initialization, configuration. + */ + +#ifndef __CVMX_AGL_H__ +#define __CVMX_AGL_H__ + +/* + * @param port to enable + * + * @return Zero on success, negative on failure + */ +int cvmx_agl_enable(int port); + +cvmx_helper_link_info_t cvmx_agl_link_get(int port); + +/* + * Set MII/RGMII link based on mode. + * + * @param port interface port to set the link. + * @param link_info Link status + * + * @return 0 on success and 1 on failure + */ +int cvmx_agl_link_set(int port, cvmx_helper_link_info_t link_info); + +/** + * Disables the sending of flow control (pause) frames on the specified + * AGL (RGMII) port(s). + * + * @param interface Which interface (0 or 1) + * @param port_mask Mask (4bits) of which ports on the interface to disable + * backpressure on. + * 1 => disable backpressure + * 0 => enable backpressure + * + * @return 0 on success + * -1 on error + */ +int cvmx_agl_set_backpressure_override(u32 interface, uint32_t port_mask); + +#endif /* __CVMX_AGL_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-config.h b/arch/mips/mach-octeon/include/mach/cvmx-config.h new file mode 100644 index 000000000000..4f66a3cce524 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-config.h @@ -0,0 +1,128 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#ifndef __CVMX_CONFIG_H__ +#define __CVMX_CONFIG_H__ + +/************************* Config Specific Defines ************************/ +#define CVMX_LLM_NUM_PORTS 1 + +/**< PKO queues per port for interface 0 (ports 0-15) */ +#define CVMX_PKO_QUEUES_PER_PORT_INTERFACE0 1 + +/**< PKO queues per port for interface 1 (ports 16-31) */ +#define CVMX_PKO_QUEUES_PER_PORT_INTERFACE1 1 + +/**< PKO queues per port for interface 4 (AGL) */ +#define CVMX_PKO_QUEUES_PER_PORT_INTERFACE4 1 + +/**< Limit on the number of PKO ports enabled for interface 0 */ +#define CVMX_PKO_MAX_PORTS_INTERFACE0 CVMX_HELPER_PKO_MAX_PORTS_INTERFACE0 + +/**< Limit on the number of PKO ports enabled for interface 1 */ +#define CVMX_PKO_MAX_PORTS_INTERFACE1 CVMX_HELPER_PKO_MAX_PORTS_INTERFACE1 + +/**< PKO queues per port for PCI (ports 32-35) */ +#define CVMX_PKO_QUEUES_PER_PORT_PCI 1 + +/**< PKO queues per port for Loop devices (ports 36-39) */ +#define CVMX_PKO_QUEUES_PER_PORT_LOOP 1 + +/**< PKO queues per port for SRIO0 devices (ports 40-41) */ +#define CVMX_PKO_QUEUES_PER_PORT_SRIO0 1 + +/**< PKO queues per port for SRIO1 devices (ports 42-43) */ +#define CVMX_PKO_QUEUES_PER_PORT_SRIO1 1 + +/************************* FPA allocation *********************************/ +/* Pool sizes in bytes, must be multiple of a cache line */ +#define CVMX_FPA_POOL_0_SIZE (16 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_1_SIZE (1 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_2_SIZE (8 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_3_SIZE (2 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_4_SIZE (0 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_5_SIZE (0 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_6_SIZE (8 * CVMX_CACHE_LINE_SIZE) +#define CVMX_FPA_POOL_7_SIZE (0 * CVMX_CACHE_LINE_SIZE) + +/* Pools in use */ +/**< Packet buffers */ +#define CVMX_FPA_PACKET_POOL (0) +#ifndef CVMX_FPA_PACKET_POOL_SIZE +#define CVMX_FPA_PACKET_POOL_SIZE CVMX_FPA_POOL_0_SIZE +#endif + +/**< Work queue entries */ +#define CVMX_FPA_WQE_POOL (1) +#define CVMX_FPA_WQE_POOL_SIZE CVMX_FPA_POOL_1_SIZE + +/**< PKO queue command buffers */ +#define CVMX_FPA_OUTPUT_BUFFER_POOL (2) +#define CVMX_FPA_OUTPUT_BUFFER_POOL_SIZE CVMX_FPA_POOL_2_SIZE + +/**< BCH queue command buffers */ +#define CVMX_FPA_BCH_POOL (6) +#define CVMX_FPA_BCH_POOL_SIZE CVMX_FPA_POOL6_SIZE + +/************************* FAU allocation ********************************/ +/* The fetch and add registers are allocated here. They are arranged + * in order of descending size so that all alignment constraints are + * automatically met. + * The enums are linked so that the following enum continues allocating + * where the previous one left off, so the numbering within each + * enum always starts with zero. The macros take care of the address + * increment size, so the values entered always increase by 1. + * FAU registers are accessed with byte addresses. + */ + +#define CVMX_FAU_REG_64_ADDR(x) (((x) << 3) + CVMX_FAU_REG_64_START) +typedef enum { + CVMX_FAU_REG_64_START = 0, + /**< FAU registers for the position in PKO command buffers */ + CVMX_FAU_REG_OQ_ADDR_INDEX = CVMX_FAU_REG_64_ADDR(0), + /* Array of 36 */ + CVMX_FAU_REG_64_END = CVMX_FAU_REG_64_ADDR(36), +} cvmx_fau_reg_64_t; + +#define CVMX_FAU_REG_32_ADDR(x) (((x) << 2) + CVMX_FAU_REG_32_START) +typedef enum { + CVMX_FAU_REG_32_START = CVMX_FAU_REG_64_END, + CVMX_FAU_REG_32_END = CVMX_FAU_REG_32_ADDR(0), +} cvmx_fau_reg_32_t; + +#define CVMX_FAU_REG_16_ADDR(x) (((x) << 1) + CVMX_FAU_REG_16_START) +typedef enum { + CVMX_FAU_REG_16_START = CVMX_FAU_REG_32_END, + CVMX_FAU_REG_16_END = CVMX_FAU_REG_16_ADDR(0), +} cvmx_fau_reg_16_t; + +#define CVMX_FAU_REG_8_ADDR(x) ((x) + CVMX_FAU_REG_8_START) +typedef enum { + CVMX_FAU_REG_8_START = CVMX_FAU_REG_16_END, + CVMX_FAU_REG_8_END = CVMX_FAU_REG_8_ADDR(0), +} cvmx_fau_reg_8_t; + +/* The name CVMX_FAU_REG_AVAIL_BASE is provided to indicate the first available + * FAU address that is not allocated in cvmx-config.h. This is 64 bit aligned. + */ +#define CVMX_FAU_REG_AVAIL_BASE ((CVMX_FAU_REG_8_END + 0x7) & (~0x7ULL)) +#define CVMX_FAU_REG_END (2048) + +/********************** scratch memory allocation *************************/ +/* Scratchpad memory allocation. Note that these are byte memory addresses. + * Some uses of scratchpad (IOBDMA for example) require the use of 8-byte + * aligned addresses, so proper alignment needs to be taken into account. + */ + +/**< Pre allocation for PKO queue command buffers */ +#define CVMX_SCR_OQ_BUF_PRE_ALLOC (0) + +/**< Generic scratch iobdma area */ +#define CVMX_SCR_SCRATCH (8) + +/**< First location available after cvmx-config.h allocated region. */ +#define CVMX_SCR_REG_AVAIL_BASE (16) + +#endif /* __CVMX_CONFIG_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-fau.h b/arch/mips/mach-octeon/include/mach/cvmx-fau.h new file mode 100644 index 000000000000..d795ff6e9b06 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-fau.h @@ -0,0 +1,581 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Interface to the hardware Fetch and Add Unit. + */ + +#ifndef __CVMX_FAU_H__ +#define __CVMX_FAU_H__ + +extern u8 *cvmx_fau_regs_ptr; + +/** + * Initializes fau, on devices with FAU hw this is a noop. + */ +int cvmx_fau_init(void); + +/** + * Return the location of emulated FAU register + */ +static inline u8 *__cvmx_fau_sw_addr(int reg) +{ + if (cvmx_unlikely(!cvmx_fau_regs_ptr)) + cvmx_fau_init(); + return (cvmx_fau_regs_ptr + reg); +} + +/** + * Perform an atomic 64 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Value of the register before the update + */ +static inline int64_t cvmx_fau_fetch_and_add64(cvmx_fau_reg64_t reg, + int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_fetch_and_add64(reg, value); + + return __atomic_fetch_add(CASTPTR(int64_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 32 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Value of the register before the update + */ +static inline int32_t cvmx_fau_fetch_and_add32(cvmx_fau_reg32_t reg, + int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_fetch_and_add32(reg, value); + + reg ^= SWIZZLE_32; + return __atomic_fetch_add(CASTPTR(int32_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 16 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to add. + * @return Value of the register before the update + */ +static inline int16_t cvmx_fau_fetch_and_add16(cvmx_fau_reg16_t reg, + int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_fetch_and_add16(reg, value); + + reg ^= SWIZZLE_16; + return __atomic_fetch_add(CASTPTR(int16_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 8 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to add. + * @return Value of the register before the update + */ +static inline int8_t cvmx_fau_fetch_and_add8(cvmx_fau_reg8_t reg, int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_fetch_and_add8(reg, value); + + reg ^= SWIZZLE_8; + return __atomic_fetch_add(CASTPTR(int8_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 64 bit add after the current tag switch + * completes + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return If a timeout occurs, the error bit will be set. Otherwise + * the value of the register before the update will be + * returned + */ +static inline cvmx_fau_tagwait64_t +cvmx_fau_tagwait_fetch_and_add64(cvmx_fau_reg64_t reg, int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_tagwait_fetch_and_add64(reg, value); + + /* not implemented yet.*/ + return (cvmx_fau_tagwait64_t){ 1, 0 }; +} + +/** + * Perform an atomic 32 bit add after the current tag switch + * completes + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return If a timeout occurs, the error bit will be set. Otherwise + * the value of the register before the update will be + * returned + */ +static inline cvmx_fau_tagwait32_t +cvmx_fau_tagwait_fetch_and_add32(cvmx_fau_reg32_t reg, int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_tagwait_fetch_and_add32(reg, value); + + /* not implemented yet.*/ + return (cvmx_fau_tagwait32_t){ 1, 0 }; +} + +/** + * Perform an atomic 16 bit add after the current tag switch + * completes + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to add. + * @return If a timeout occurs, the error bit will be set. Otherwise + * the value of the register before the update will be + * returned + */ +static inline cvmx_fau_tagwait16_t +cvmx_fau_tagwait_fetch_and_add16(cvmx_fau_reg16_t reg, int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_tagwait_fetch_and_add16(reg, value); + + /* not implemented yet.*/ + return (cvmx_fau_tagwait16_t){ 1, 0 }; +} + +/** + * Perform an atomic 8 bit add after the current tag switch + * completes + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to add. + * @return If a timeout occurs, the error bit will be set. Otherwise + * the value of the register before the update will be + * returned + */ +static inline cvmx_fau_tagwait8_t +cvmx_fau_tagwait_fetch_and_add8(cvmx_fau_reg8_t reg, int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) + return cvmx_hwfau_tagwait_fetch_and_add8(reg, value); + + /* not implemented yet.*/ + return (cvmx_fau_tagwait8_t){ 1, 0 }; +} + +/** + * Perform an async atomic 64 bit add. The old value is + * placed in the scratch memory at byte address scraddr. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Placed in the scratch pad register + */ +static inline void +cvmx_fau_async_fetch_and_add64(u64 scraddr, cvmx_fau_reg64_t reg, int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_fetch_and_add64(scraddr, reg, value); + return; + } + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int64_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 32 bit add. The old value is + * placed in the scratch memory at byte address scraddr. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Placed in the scratch pad register + */ +static inline void +cvmx_fau_async_fetch_and_add32(u64 scraddr, cvmx_fau_reg32_t reg, int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_fetch_and_add32(scraddr, reg, value); + return; + } + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int32_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 16 bit add. The old value is + * placed in the scratch memory at byte address scraddr. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to add. + * @return Placed in the scratch pad register + */ +static inline void +cvmx_fau_async_fetch_and_add16(u64 scraddr, cvmx_fau_reg16_t reg, int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_fetch_and_add16(scraddr, reg, value); + return; + } + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int16_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 8 bit add. The old value is + * placed in the scratch memory at byte address scraddr. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to add. + * @return Placed in the scratch pad register + */ +static inline void +cvmx_fau_async_fetch_and_add8(u64 scraddr, cvmx_fau_reg8_t reg, int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_fetch_and_add8(scraddr, reg, value); + return; + } + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int8_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 64 bit add after the current tag + * switch completes. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * If a timeout occurs, the error bit (63) will be set. Otherwise + * the value of the register before the update will be + * returned + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Placed in the scratch pad register + */ +static inline void cvmx_fau_async_tagwait_fetch_and_add64(u64 scraddr, + cvmx_fau_reg64_t reg, + int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_tagwait_fetch_and_add64(scraddr, reg, value); + return; + } + + /* Broken. Where is the tag wait? */ + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int64_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 32 bit add after the current tag + * switch completes. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * If a timeout occurs, the error bit (63) will be set. Otherwise + * the value of the register before the update will be + * returned + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to add. + * Note: Only the low 22 bits are available. + * @return Placed in the scratch pad register + */ +static inline void cvmx_fau_async_tagwait_fetch_and_add32(u64 scraddr, + cvmx_fau_reg32_t reg, + int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_tagwait_fetch_and_add32(scraddr, reg, value); + return; + } + /* Broken. Where is the tag wait? */ + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int32_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 16 bit add after the current tag + * switch completes. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * If a timeout occurs, the error bit (63) will be set. Otherwise + * the value of the register before the update will be + * returned + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to add. + * @return Placed in the scratch pad register + */ +static inline void cvmx_fau_async_tagwait_fetch_and_add16(u64 scraddr, + cvmx_fau_reg16_t reg, + int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_tagwait_fetch_and_add16(scraddr, reg, value); + return; + } + /* Broken. Where is the tag wait? */ + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int16_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an async atomic 8 bit add after the current tag + * switch completes. + * + * @param scraddr Scratch memory byte address to put response in. + * Must be 8 byte aligned. + * If a timeout occurs, the error bit (63) will be set. Otherwise + * the value of the register before the update will be + * returned + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to add. + * @return Placed in the scratch pad register + */ +static inline void cvmx_fau_async_tagwait_fetch_and_add8(u64 scraddr, + cvmx_fau_reg8_t reg, + int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_async_tagwait_fetch_and_add8(scraddr, reg, value); + return; + } + /* Broken. Where is the tag wait? */ + cvmx_scratch_write64( + scraddr, + __atomic_fetch_add(CASTPTR(int8_t, __cvmx_fau_sw_addr(reg)), + value, __ATOMIC_SEQ_CST)); +} + +/** + * Perform an atomic 64 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to add. + */ +static inline void cvmx_fau_atomic_add64(cvmx_fau_reg64_t reg, int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_add64(reg, value); + return; + } + /* Ignored fetch values should be optimized away */ + __atomic_add_fetch(CASTPTR(int64_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 32 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to add. + */ +static inline void cvmx_fau_atomic_add32(cvmx_fau_reg32_t reg, int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_add32(reg, value); + return; + } + reg ^= SWIZZLE_32; + /* Ignored fetch values should be optimized away */ + __atomic_add_fetch(CASTPTR(int32_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 16 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to add. + */ +static inline void cvmx_fau_atomic_add16(cvmx_fau_reg16_t reg, int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_add16(reg, value); + return; + } + reg ^= SWIZZLE_16; + /* Ignored fetch values should be optimized away */ + __atomic_add_fetch(CASTPTR(int16_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 8 bit add + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to add. + */ +static inline void cvmx_fau_atomic_add8(cvmx_fau_reg8_t reg, int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_add8(reg, value); + return; + } + reg ^= SWIZZLE_8; + /* Ignored fetch values should be optimized away */ + __atomic_add_fetch(CASTPTR(int8_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 64 bit write + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 8 for 64 bit access. + * @param value Signed value to write. + */ +static inline void cvmx_fau_atomic_write64(cvmx_fau_reg64_t reg, int64_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_write64(reg, value); + return; + } + __atomic_store_n(CASTPTR(int64_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 32 bit write + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 4 for 32 bit access. + * @param value Signed value to write. + */ +static inline void cvmx_fau_atomic_write32(cvmx_fau_reg32_t reg, int32_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_write32(reg, value); + return; + } + reg ^= SWIZZLE_32; + __atomic_store_n(CASTPTR(int32_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 16 bit write + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * - Step by 2 for 16 bit access. + * @param value Signed value to write. + */ +static inline void cvmx_fau_atomic_write16(cvmx_fau_reg16_t reg, int16_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_write16(reg, value); + return; + } + reg ^= SWIZZLE_16; + __atomic_store_n(CASTPTR(int16_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** + * Perform an atomic 8 bit write + * + * @param reg FAU atomic register to access. 0 <= reg < 2048. + * @param value Signed value to write. + */ +static inline void cvmx_fau_atomic_write8(cvmx_fau_reg8_t reg, int8_t value) +{ + if (octeon_has_feature(OCTEON_FEATURE_FAU)) { + cvmx_hwfau_atomic_write8(reg, value); + return; + } + reg ^= SWIZZLE_8; + __atomic_store_n(CASTPTR(int8_t, __cvmx_fau_sw_addr(reg)), value, + __ATOMIC_SEQ_CST); +} + +/** Allocates 64bit FAU register. + * @param reserve base address to reserve + * @return value is the base address of allocated FAU register + */ +int cvmx_fau64_alloc(int reserve); + +/** Allocates 32bit FAU register. + * @param reserve base address to reserve + * @return value is the base address of allocated FAU register + */ +int cvmx_fau32_alloc(int reserve); + +/** Allocates 16bit FAU register. + * @param reserve base address to reserve + * @return value is the base address of allocated FAU register + */ +int cvmx_fau16_alloc(int reserve); + +/** Allocates 8bit FAU register. + * @param reserve base address to reserve + * @return value is the base address of allocated FAU register + */ +int cvmx_fau8_alloc(int reserve); + +/** Frees the specified FAU register. + * @param address base address of register to release. + * @return 0 on success; -1 on failure + */ +int cvmx_fau_free(int address); + +/** Display the fau registers array + */ +void cvmx_fau_show(void); + +#endif /* __CVMX_FAU_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-mdio.h b/arch/mips/mach-octeon/include/mach/cvmx-mdio.h new file mode 100644 index 000000000000..9bc138fa2770 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-mdio.h @@ -0,0 +1,516 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Interface to the SMI/MDIO hardware, including support for both IEEE 802.3 + * clause 22 and clause 45 operations. + */ + +#ifndef __CVMX_MIO_H__ +#define __CVMX_MIO_H__ + +/** + * PHY register 0 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_CONTROL 0 + +typedef union { + u16 u16; + struct { + u16 reset : 1; + u16 loopback : 1; + u16 speed_lsb : 1; + u16 autoneg_enable : 1; + u16 power_down : 1; + u16 isolate : 1; + u16 restart_autoneg : 1; + u16 duplex : 1; + u16 collision_test : 1; + u16 speed_msb : 1; + u16 unidirectional_enable : 1; + u16 reserved_0_4 : 5; + } s; +} cvmx_mdio_phy_reg_control_t; + +/** + * PHY register 1 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_STATUS 1 +typedef union { + u16 u16; + struct { + u16 capable_100base_t4 : 1; + u16 capable_100base_x_full : 1; + u16 capable_100base_x_half : 1; + u16 capable_10_full : 1; + u16 capable_10_half : 1; + u16 capable_100base_t2_full : 1; + u16 capable_100base_t2_half : 1; + u16 capable_extended_status : 1; + u16 capable_unidirectional : 1; + u16 capable_mf_preamble_suppression : 1; + u16 autoneg_complete : 1; + u16 remote_fault : 1; + u16 capable_autoneg : 1; + u16 link_status : 1; + u16 jabber_detect : 1; + u16 capable_extended_registers : 1; + + } s; +} cvmx_mdio_phy_reg_status_t; + +/** + * PHY register 2 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_ID1 2 +typedef union { + u16 u16; + struct { + u16 oui_bits_3_18; + } s; +} cvmx_mdio_phy_reg_id1_t; + +/** + * PHY register 3 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_ID2 3 +typedef union { + u16 u16; + struct { + u16 oui_bits_19_24 : 6; + u16 model : 6; + u16 revision : 4; + } s; +} cvmx_mdio_phy_reg_id2_t; + +/** + * PHY register 4 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_AUTONEG_ADVER 4 +typedef union { + u16 u16; + struct { + u16 next_page : 1; + u16 reserved_14 : 1; + u16 remote_fault : 1; + u16 reserved_12 : 1; + u16 asymmetric_pause : 1; + u16 pause : 1; + u16 advert_100base_t4 : 1; + u16 advert_100base_tx_full : 1; + u16 advert_100base_tx_half : 1; + u16 advert_10base_tx_full : 1; + u16 advert_10base_tx_half : 1; + u16 selector : 5; + } s; +} cvmx_mdio_phy_reg_autoneg_adver_t; + +/** + * PHY register 5 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_LINK_PARTNER_ABILITY 5 +typedef union { + u16 u16; + struct { + u16 next_page : 1; + u16 ack : 1; + u16 remote_fault : 1; + u16 reserved_12 : 1; + u16 asymmetric_pause : 1; + u16 pause : 1; + u16 advert_100base_t4 : 1; + u16 advert_100base_tx_full : 1; + u16 advert_100base_tx_half : 1; + u16 advert_10base_tx_full : 1; + u16 advert_10base_tx_half : 1; + u16 selector : 5; + } s; +} cvmx_mdio_phy_reg_link_partner_ability_t; + +/** + * PHY register 6 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_AUTONEG_EXPANSION 6 +typedef union { + u16 u16; + struct { + u16 reserved_5_15 : 11; + u16 parallel_detection_fault : 1; + u16 link_partner_next_page_capable : 1; + u16 local_next_page_capable : 1; + u16 page_received : 1; + u16 link_partner_autoneg_capable : 1; + + } s; +} cvmx_mdio_phy_reg_autoneg_expansion_t; + +/** + * PHY register 9 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_CONTROL_1000 9 +typedef union { + u16 u16; + struct { + u16 test_mode : 3; + u16 manual_master_slave : 1; + u16 master : 1; + u16 port_type : 1; + u16 advert_1000base_t_full : 1; + u16 advert_1000base_t_half : 1; + u16 reserved_0_7 : 8; + } s; +} cvmx_mdio_phy_reg_control_1000_t; + +/** + * PHY register 10 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_STATUS_1000 10 +typedef union { + u16 u16; + struct { + u16 master_slave_fault : 1; + u16 is_master : 1; + u16 local_receiver_ok : 1; + u16 remote_receiver_ok : 1; + u16 remote_capable_1000base_t_full : 1; + u16 remote_capable_1000base_t_half : 1; + u16 reserved_8_9 : 2; + u16 idle_error_count : 8; + } s; +} cvmx_mdio_phy_reg_status_1000_t; + +/** + * PHY register 15 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_EXTENDED_STATUS 15 +typedef union { + u16 u16; + struct { + u16 capable_1000base_x_full : 1; + u16 capable_1000base_x_half : 1; + u16 capable_1000base_t_full : 1; + u16 capable_1000base_t_half : 1; + u16 reserved_0_11 : 12; + } s; +} cvmx_mdio_phy_reg_extended_status_t; + +/** + * PHY register 13 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_MMD_CONTROL 13 +typedef union { + u16 u16; + struct { + u16 function : 2; + u16 reserved_5_13 : 9; + u16 devad : 5; + } s; +} cvmx_mdio_phy_reg_mmd_control_t; + +/** + * PHY register 14 from the 802.3 spec + */ +#define CVMX_MDIO_PHY_REG_MMD_ADDRESS_DATA 14 +typedef union { + u16 u16; + struct { + u16 address_data : 16; + } s; +} cvmx_mdio_phy_reg_mmd_address_data_t; + +/* Operating request encodings. */ +#define MDIO_CLAUSE_22_WRITE 0 +#define MDIO_CLAUSE_22_READ 1 + +#define MDIO_CLAUSE_45_ADDRESS 0 +#define MDIO_CLAUSE_45_WRITE 1 +#define MDIO_CLAUSE_45_READ_INC 2 +#define MDIO_CLAUSE_45_READ 3 + +/* MMD identifiers, mostly for accessing devices within XENPAK modules. */ +#define CVMX_MMD_DEVICE_PMA_PMD 1 +#define CVMX_MMD_DEVICE_WIS 2 +#define CVMX_MMD_DEVICE_PCS 3 +#define CVMX_MMD_DEVICE_PHY_XS 4 +#define CVMX_MMD_DEVICE_DTS_XS 5 +#define CVMX_MMD_DEVICE_TC 6 +#define CVMX_MMD_DEVICE_CL22_EXT 29 +#define CVMX_MMD_DEVICE_VENDOR_1 30 +#define CVMX_MMD_DEVICE_VENDOR_2 31 + +#define CVMX_MDIO_TIMEOUT 100000 /* 100 millisec */ + +static inline int cvmx_mdio_bus_id_to_node(int bus_id) +{ + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + return (bus_id >> 2) & CVMX_NODE_MASK; + else + return 0; +} + +static inline int cvmx_mdio_bus_id_to_bus(int bus_id) +{ + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + return bus_id & 3; + else + return bus_id; +} + +/* Helper function to put MDIO interface into clause 45 mode */ +static inline void __cvmx_mdio_set_clause45_mode(int bus_id) +{ + cvmx_smix_clk_t smi_clk; + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + + /* Put bus into clause 45 mode */ + smi_clk.u64 = csr_rd_node(node, CVMX_SMIX_CLK(bus)); + smi_clk.s.mode = 1; + smi_clk.s.preamble = 1; + csr_wr_node(node, CVMX_SMIX_CLK(bus), smi_clk.u64); +} + +/* Helper function to put MDIO interface into clause 22 mode */ +static inline void __cvmx_mdio_set_clause22_mode(int bus_id) +{ + cvmx_smix_clk_t smi_clk; + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + + /* Put bus into clause 22 mode */ + smi_clk.u64 = csr_rd_node(node, CVMX_SMIX_CLK(bus)); + smi_clk.s.mode = 0; + csr_wr_node(node, CVMX_SMIX_CLK(bus), smi_clk.u64); +} + +/** + * @INTERNAL + * Function to read SMIX_RD_DAT and check for timeouts. This + * code sequence is done fairly often, so put in one spot. + * + * @param bus_id SMI/MDIO bus to read + * + * @return Value of SMIX_RD_DAT. pending will be set on + * a timeout. + */ +static inline cvmx_smix_rd_dat_t __cvmx_mdio_read_rd_dat(int bus_id) +{ + cvmx_smix_rd_dat_t smi_rd; + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + u64 done; + + done = get_timer(0); + + do { + mdelay(1); + smi_rd.u64 = csr_rd_node(node, CVMX_SMIX_RD_DAT(bus)); + if (get_timer(done) > (CVMX_MDIO_TIMEOUT / 1000)) + break; + } while (smi_rd.s.pending); + + return smi_rd; +} + +/** + * Perform an MII read. This function is used to read PHY + * registers controlling auto negotiation. + * + * @param bus_id MDIO bus number. Zero on most chips, but some chips (ex CN56XX) + * support multiple busses. + * @param phy_id The MII phy id + * @param location Register location to read + * + * @return Result from the read or -1 on failure + */ +static inline int cvmx_mdio_read(int bus_id, int phy_id, int location) +{ + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + cvmx_smix_cmd_t smi_cmd; + cvmx_smix_rd_dat_t smi_rd; + + if (octeon_has_feature(OCTEON_FEATURE_MDIO_CLAUSE_45)) + __cvmx_mdio_set_clause22_mode(bus_id); + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_22_READ; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = location; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + smi_rd = __cvmx_mdio_read_rd_dat(bus_id); + if (smi_rd.s.val) + return smi_rd.s.dat; + else + return -1; +} + +/** + * Perform an MII write. This function is used to write PHY + * registers controlling auto negotiation. + * + * @param bus_id MDIO bus number. Zero on most chips, but some chips (ex CN56XX) + * support multiple busses. + * @param phy_id The MII phy id + * @param location Register location to write + * @param val Value to write + * + * @return -1 on error + * 0 on success + */ +static inline int cvmx_mdio_write(int bus_id, int phy_id, int location, int val) +{ + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + cvmx_smix_cmd_t smi_cmd; + cvmx_smix_wr_dat_t smi_wr; + + if (octeon_has_feature(OCTEON_FEATURE_MDIO_CLAUSE_45)) + __cvmx_mdio_set_clause22_mode(bus_id); + + smi_wr.u64 = 0; + smi_wr.s.dat = val; + csr_wr_node(node, CVMX_SMIX_WR_DAT(bus), smi_wr.u64); + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_22_WRITE; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = location; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + if (CVMX_WAIT_FOR_FIELD64_NODE(node, CVMX_SMIX_WR_DAT(bus), + cvmx_smix_wr_dat_t, pending, ==, 0, + CVMX_MDIO_TIMEOUT)) + return -1; + + return 0; +} + +/** + * Perform an IEEE 802.3 clause 45 MII read. This function is used to read PHY + * registers controlling auto negotiation. + * + * @param bus_id MDIO bus number. Zero on most chips, but some chips (ex CN56XX) + * support multiple busses. + * @param phy_id The MII phy id + * @param device MDIO Manageable Device (MMD) id + * @param location Register location to read + * + * @return Result from the read or -1 on failure + */ + +static inline int cvmx_mdio_45_read(int bus_id, int phy_id, int device, + int location) +{ + cvmx_smix_cmd_t smi_cmd; + cvmx_smix_rd_dat_t smi_rd; + cvmx_smix_wr_dat_t smi_wr; + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + + if (!octeon_has_feature(OCTEON_FEATURE_MDIO_CLAUSE_45)) + return -1; + + __cvmx_mdio_set_clause45_mode(bus_id); + + smi_wr.u64 = 0; + smi_wr.s.dat = location; + csr_wr_node(node, CVMX_SMIX_WR_DAT(bus), smi_wr.u64); + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_45_ADDRESS; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = device; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + if (CVMX_WAIT_FOR_FIELD64_NODE(node, CVMX_SMIX_WR_DAT(bus), + cvmx_smix_wr_dat_t, pending, ==, 0, + CVMX_MDIO_TIMEOUT)) { + debug("cvmx_mdio_45_read: bus_id %d phy_id %2d device %2d register %2d TIME OUT(address)\n", + bus_id, phy_id, device, location); + return -1; + } + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_45_READ; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = device; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + smi_rd = __cvmx_mdio_read_rd_dat(bus_id); + if (smi_rd.s.pending) { + debug("cvmx_mdio_45_read: bus_id %d phy_id %2d device %2d register %2d TIME OUT(data)\n", + bus_id, phy_id, device, location); + return -1; + } + + if (smi_rd.s.val) + return smi_rd.s.dat; + + debug("cvmx_mdio_45_read: bus_id %d phy_id %2d device %2d register %2d INVALID READ\n", + bus_id, phy_id, device, location); + return -1; +} + +/** + * Perform an IEEE 802.3 clause 45 MII write. This function is used to write PHY + * registers controlling auto negotiation. + * + * @param bus_id MDIO bus number. Zero on most chips, but some chips (ex CN56XX) + * support multiple busses. + * @param phy_id The MII phy id + * @param device MDIO Manageable Device (MMD) id + * @param location Register location to write + * @param val Value to write + * + * @return -1 on error + * 0 on success + */ +static inline int cvmx_mdio_45_write(int bus_id, int phy_id, int device, + int location, int val) +{ + cvmx_smix_cmd_t smi_cmd; + cvmx_smix_wr_dat_t smi_wr; + int node = cvmx_mdio_bus_id_to_node(bus_id); + int bus = cvmx_mdio_bus_id_to_bus(bus_id); + + if (!octeon_has_feature(OCTEON_FEATURE_MDIO_CLAUSE_45)) + return -1; + + __cvmx_mdio_set_clause45_mode(bus_id); + + smi_wr.u64 = 0; + smi_wr.s.dat = location; + csr_wr_node(node, CVMX_SMIX_WR_DAT(bus), smi_wr.u64); + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_45_ADDRESS; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = device; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + if (CVMX_WAIT_FOR_FIELD64_NODE(node, CVMX_SMIX_WR_DAT(bus), + cvmx_smix_wr_dat_t, pending, ==, 0, + CVMX_MDIO_TIMEOUT)) + return -1; + + smi_wr.u64 = 0; + smi_wr.s.dat = val; + csr_wr_node(node, CVMX_SMIX_WR_DAT(bus), smi_wr.u64); + + smi_cmd.u64 = 0; + smi_cmd.s.phy_op = MDIO_CLAUSE_45_WRITE; + smi_cmd.s.phy_adr = phy_id; + smi_cmd.s.reg_adr = device; + csr_wr_node(node, CVMX_SMIX_CMD(bus), smi_cmd.u64); + + if (CVMX_WAIT_FOR_FIELD64_NODE(node, CVMX_SMIX_WR_DAT(bus), + cvmx_smix_wr_dat_t, pending, ==, 0, + CVMX_MDIO_TIMEOUT)) + return -1; + + return 0; +} + +#endif diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h b/arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h new file mode 100644 index 000000000000..4d5a9d4ec829 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h @@ -0,0 +1,343 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +/* L4_PORT_CHECK_DISABLE_LF tag */ +/* This file is autogenerated from ipemainc.elf */ +const int cvmx_pki_cluster_code_length = 997; +const u64 cvmx_pki_cluster_code_default[] = { + 0x000000000a000000ull, 0x0000413a68024070ull, 0x0000813800200020ull, + 0x900081b800200020ull, 0x0004da00ffff0001ull, 0x000455ab68010b0eull, + 0x00045fba46010000ull, 0x9046898120002000ull, 0x0004418068010028ull, + 0x90665300680100f0ull, 0x0004413f68004070ull, 0x00065380680100f0ull, + 0x00045a346803a0f0ull, 0x000401b448000001ull, 0x00045cb968030870ull, + 0x0007debd00100010ull, 0x0000813b80008000ull, 0x000441bb68004070ull, + 0xd001c00000000000ull, 0xd021c00000000000ull, 0x00045f80680100f0ull, + 0x0004c639ff000200ull, 0x0004403f72010000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x000041ba68034078ull, 0x0000512268030870ull, + 0x000041bc68034070ull, 0x00005d3a68030870ull, 0x00045cb942080000ull, + 0x0004552a4e09312dull, 0x00045cb968082868ull, 0x0004410246090000ull, + 0x0000813800800080ull, 0x000401a486000005ull, 0x000615ab74000123ull, + 0x0007122448000004ull, 0x0000813901000000ull, 0x000481b800010001ull, + 0x000685b800020002ull, 0xa006823800010001ull, 0x0006c639ff000400ull, + 0x00085f3e68010a00ull, 0xa0885f3e68010f01ull, 0x00085f3e68010405ull, + 0x00085f3e68010906ull, 0xa0485f3e68010e07ull, 0xa061c00000000000ull, + 0xa4085f3e68010b28ull, 0xa421c00000000000ull, 0x00095f3e68010940ull, + 0xa066403e72010000ull, 0x000941be68034039ull, 0x00085f3e68010305ull, + 0xa4685f3e68010028ull, 0x00095f3e68030030ull, 0x00095f3e68010416ull, + 0x0001c00000000000ull, 0x00065cb942080000ull, 0xa046552a4e09312dull, + 0xa446c639ff000500ull, 0x0006debd00010001ull, 0x0006403e72010001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x00065cb942080000ull, 0x0006552a4e09312dull, + 0x00065cb968082868ull, 0x0006410246090000ull, 0x9060813901000000ull, + 0x0004c639ff000800ull, 0x0004400072010000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x00045cb942080000ull, + 0x9084552a4e09312dull, 0x90a4c639ff000900ull, 0x00045f80680100f0ull, + 0x0004403f72010001ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x00045cb942080000ull, 0x9004552a4e09312dull, + 0x0004c639ff000a00ull, 0x0004400072010000ull, 0x00048181ff00ff00ull, + 0x0007820101000100ull, 0x0006898100ff00ffull, 0x00048301ffff0180ull, + 0x0008d5ab10001000ull, 0x0004d4a900010001ull, 0x0001c00000000000ull, + 0x00045cb942080000ull, 0x9024552a4e09312dull, 0x0004c639ff000b00ull, + 0x90445f80680100f0ull, 0x000459b368020070ull, 0x000401024000000cull, + 0x0006823fffffffffull, 0x00088281ffffffffull, 0x000ad5ab20002000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0004403f72010001ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x000c8b3fffffc200ull, 0x000c8b01ffff0001ull, + 0x000ddebd00020002ull, 0x00045cb942080000ull, 0x0004552a4e09312dull, + 0x00045cb968082868ull, 0x0004410246090000ull, 0x0000813901000000ull, + 0x000481b800080008ull, 0x9846c639ff001200ull, 0x9861c00000000000ull, + 0x00064180680100f0ull, 0x0006400372010000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x000683891f000200ull, + 0x000ed52a00800080ull, 0x000e5e3c68020070ull, 0x00065cb942080000ull, + 0x0006552a4e09312dull, 0x00065cb968082868ull, 0x0006410246090000ull, + 0x0000813d00020002ull, 0x0004893901000000ull, 0x9004893800040004ull, + 0x9024c639ff001300ull, 0x00044180680100f0ull, 0x9044400372010001ull, + 0x0001c00000000000ull, 0x00045f3e68010044ull, 0x0004debd00040004ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000483891f000200ull, 0x000ed52a00800080ull, 0x000e5e3c68020070ull, + 0x00045cb942080000ull, 0x0004552a4e09312dull, 0x00045cb968082868ull, + 0x0004410246090000ull, 0x000581b902000000ull, 0x9826c639ff001800ull, + 0x9801c00000000000ull, 0x00064180680100f0ull, 0x0006400172030000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000682091f000200ull, 0x000883aa00800080ull, 0x000ed52a00400040ull, + 0x000e5e3c68020870ull, 0x000fd52a00800080ull, 0x000f5e3c68020070ull, + 0x000983891f000000ull, 0x000f54a968090148ull, 0x000f59b368020870ull, + 0x00065cb942080000ull, 0x0006552a4e09312dull, 0x00065cb968082868ull, + 0x0006410246090000ull, 0x000081b902000000ull, 0x9826c639ff001900ull, + 0x9801c00000000000ull, 0x00064180680100f0ull, 0x0006400172030001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000682091f000200ull, 0x000883aa00800080ull, 0x000ed52a00400040ull, + 0x000e5e3c68020870ull, 0x000fd52a00800080ull, 0x000f5e3c68020070ull, + 0x000983891f000000ull, 0x000f54a968090148ull, 0x000f59b368020870ull, + 0x00065cb942080000ull, 0x0006552a4e09312dull, 0x00065cb968082868ull, + 0x0006410246090000ull, 0x000081b902000000ull, 0x9826c639ff001a00ull, + 0x9801c00000000000ull, 0x00064180680100f0ull, 0x0006400172030000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000682091f000200ull, 0x000883aa00800080ull, 0x000ed52a00400040ull, + 0x000e5e3c68020870ull, 0x000fd52a00800080ull, 0x000f5e3c68020070ull, + 0x000983891f000000ull, 0x000f54a968090148ull, 0x000f59b368020870ull, + 0x00065cb942080000ull, 0x0006552a4e09312dull, 0x00065cb968082868ull, + 0x0006410246090000ull, 0x000081b902000000ull, 0x9826c639ff001b00ull, + 0x9801c00000000000ull, 0x00064180680100f0ull, 0x0006400172030001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000682091f000200ull, 0x000883aa00800080ull, 0x000ed52a00400040ull, + 0x000e5e3c68020870ull, 0x000fd52a00800080ull, 0x000f5e3c68020070ull, + 0x000983891f000000ull, 0x000f54a968090148ull, 0x000f59b368020870ull, + 0x00065cb942080000ull, 0x0006552a4e09312dull, 0x00065cb968082868ull, + 0x0006410246090000ull, 0x9000813902000000ull, 0x000481b800400040ull, + 0x00068981ffff8847ull, 0x00068581ffff8848ull, 0x0006debd00080008ull, + 0x0006c639ff001e00ull, 0x0006010240000002ull, 0x9801c00000000000ull, + 0x9821c00000000000ull, 0x00065f80680100f0ull, 0x0006403f72010000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x00065cb942080000ull, 0x0006552a4e09312dull, 0x00065cb968082868ull, + 0x0006010240000004ull, 0x0006823902000000ull, 0x00065f3e68010629ull, + 0xac28828101000100ull, 0x000b010240000004ull, 0xa42b820101000100ull, + 0x0009010240000004ull, 0xac29828101000100ull, 0x000b010240000004ull, + 0xa42b820101000100ull, 0x0009010240000004ull, 0xac29828101000100ull, + 0x000b010240000004ull, 0x0006823904000000ull, 0x0008d4a907c00200ull, + 0x0008593268020070ull, 0x0008dcb902000200ull, 0x9000813902000000ull, + 0x0001c00000000000ull, 0x00040181840005ffull, 0x0006010240000008ull, + 0x9801c00000000000ull, 0x0006debd00200020ull, 0x00048181ffff0806ull, + 0x0006d4a907c00180ull, 0x00048201ffff8035ull, 0x00068581ffff8035ull, + 0x0008d4a907c001c0ull, 0x0006dcb97c007c00ull, 0x00048201ffff0800ull, + 0x00088601ffff86ddull, 0x00068581ffff0800ull, 0x00068581ffff86ddull, + 0x0008d4a907c00200ull, 0x0009dcb97c007c00ull, 0x0007823d00200020ull, + 0x000685bd00200020ull, 0x0008d4a907c00140ull, 0x0004010240000002ull, + 0x0006593268020070ull, 0x000042a486020000ull, 0x000a15ab74000124ull, + 0x9000813904000000ull, 0x0001c00000000000ull, 0x00048181f0004000ull, + 0x9886593268020070ull, 0x0006d4a907c00200ull, 0x00068201ff000000ull, + 0xa40815ab74000345ull, 0x0009debd01000100ull, 0xa429418068010038ull, + 0x00095a3468010870ull, 0x0009028386000005ull, 0x000a068186000014ull, + 0xacca15ab74000343ull, 0xacebc639ff002200ull, 0x000b5f80680100f0ull, + 0xac8b403f72010000ull, 0x000b8203000f0005ull, 0x000b5a3468010070ull, + 0x0009d4a907c00240ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x000b5cb942080000ull, 0xad0b552a4e09312dull, + 0xad2bc639ff002700ull, 0x000b5f80680100f0ull, 0xac6b403f72010001ull, + 0x0001c00000000000ull, 0x000b82013fff0000ull, 0x0009d52a00010001ull, + 0x0009d4a9f8006800ull, 0x0009593268020870ull, 0x0006418068030230ull, + 0x000b5cb942080000ull, 0x000b552a4e09312dull, 0x0006410240030000ull, + 0x9c01c00000000000ull, 0x0001c00000000000ull, 0x00078201f0006000ull, + 0x0008593268020070ull, 0x0008d4a907c00280ull, 0xa069d4a907c00000ull, + 0x00085a3468010874ull, 0x0008818100ff0000ull, 0x000615ab74000345ull, + 0x00075a3468010078ull, 0x9c8741b9680040f0ull, 0x9ca7c603ff001f00ull, + 0x00075f80680100f0ull, 0x0007403f72010001ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0007418342080000ull, + 0x9cc7552a4e09312dull, 0x9ce7c603ff002000ull, 0x00075f80680100f0ull, + 0x0007403f72010000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0007418342080000ull, 0x9d07552a4e09312dull, + 0x9d27c603ff002100ull, 0x00075f80680100f0ull, 0x0007403f72010001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0007418342080000ull, 0x0007552a4e09312dull, 0x9d475c80680300f0ull, + 0x9d67c639ff002200ull, 0x00075f80680100f0ull, 0x0007403f72010000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x00075cb942080000ull, 0x0007552a4e09312dull, 0x9d8741b9680040f0ull, + 0x9da7c603ff002400ull, 0x00075f80680100f0ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0007403f72010000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0007418342080000ull, 0x9dc7552a4e09312dull, + 0x9de7c603ff002500ull, 0x00075f80680100f0ull, 0x0007403f72010001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0007418342080000ull, 0x0007552a4e09312dull, 0x0007010240000020ull, + 0x9c01c00000000000ull, 0x9c27c603ff002600ull, 0x00075f80680100f0ull, + 0x0007403f72010000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0007418342080000ull, 0x0007552a4e09312dull, + 0x9c475c80680300f0ull, 0x9c67c639ff002700ull, 0x00075f80680100f0ull, + 0x0007403f72010001ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x00075cb942080000ull, 0x0007552a4e09312dull, + 0x0007010240000008ull, 0xa80782b400ff0000ull, 0x000ad4a907c002c0ull, + 0x000a5a3468010078ull, 0x000a410244010000ull, 0xa80782b400ff003cull, + 0x000ad4a907c002c0ull, 0x000a5a3468010078ull, 0x000a410244010000ull, + 0xa80782b400ff002bull, 0x000ad4a907c002c0ull, 0x000a5a3468010078ull, + 0x000a410244010000ull, 0xa80782b400ff002cull, 0x000ad4a9ffc06ac0ull, + 0x000a593268020870ull, 0x000ad52a00010001ull, 0x000a5a3468010078ull, + 0x000a010240000008ull, 0x0007debd01000100ull, 0x000481bd01000100ull, + 0x0006c639ff002300ull, 0x000641aa68034000ull, 0x000641a968034846ull, + 0x0006403472030001ull, 0x0004822907000200ull, 0x000915ab74000341ull, + 0x000082aa00010001ull, 0x000a86ab00ff0045ull, 0x000adcb978007800ull, + 0x0000822907000200ull, 0x00088a3908000000ull, 0x00065cb942080000ull, + 0x0006552a4e09312dull, 0x00065cb968082868ull, 0x0006410246090000ull, + 0x000042a486020000ull, 0x000a15ab74000343ull, 0x000081b940004000ull, + 0x000685a907c00000ull, 0x000782b807000100ull, 0x000a41b268004070ull, + 0x000a410040030000ull, 0x000a41ba68004078ull, 0x000a410240030000ull, + 0xa801c00000000000ull, 0xa821c00000000000ull, 0x000a4180680100f0ull, + 0x000ac639ff003900ull, 0x000a400372010001ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x000a83891f000000ull, + 0x000f542868090a48ull, 0x000f583068020070ull, 0x000a5cb942080000ull, + 0x000a552a4e09312dull, 0x000a5cb968082868ull, 0x000a410246090000ull, + 0x982881b400ff0011ull, 0x9881c00000000000ull, 0x00064180680100f0ull, + 0x00068283ffff12b5ull, 0x000a8a8108000800ull, 0x000ad4a9f8009800ull, + 0x00068303ffff17c1ull, 0x000c8b01c0000000ull, 0xb0ac5bb768010a58ull, + 0x000cd4a9f800b800ull, 0x000c8281ffff6558ull, 0x000adbb701000100ull, + 0x000c8281ffff86ddull, 0x000a8681ffff0800ull, 0x000adbb702000200ull, + 0x000682a9c8009800ull, 0x000adebd02000200ull, 0x000a593268020870ull, + 0x000a010240000008ull, 0x9c21c00000000000ull, 0x0007813400ff002full, + 0x90048201ffff6558ull, 0x00098381ffff0800ull, 0x00088281b0002000ull, + 0x000a593268020870ull, 0x000ad4a9f800a800ull, 0x000adebd02000200ull, + 0x000e593268020870ull, 0x000ed4a9f800a000ull, 0x000e010240000004ull, + 0x000e828180008000ull, 0x000a010240000004ull, 0x000e828120002000ull, + 0x000a010240000004ull, 0x000e828110001000ull, 0x000a010240000004ull, + 0x000082bd02000200ull, 0xa80ac639ff002800ull, 0xa861c00000000000ull, + 0x000a418368010526ull, 0xa84a418368010878ull, 0x000a5bb768030078ull, + 0x000a400172030000ull, 0x000a5b00680100f0ull, 0x000041b468034878ull, + 0x00005fbf68030878ull, 0x00068229c8009800ull, 0x0008010248000008ull, + 0xa001c00000000000ull, 0x000843a486020000ull, 0x00088101ffff0000ull, + 0x000415ab74000464ull, 0x000e15ab74000461ull, 0x0008010240000008ull, + 0x000c41b76800425aull, 0x000c410240030000ull, 0x000a010240000008ull, + 0x000a5cb942080000ull, 0x000a552a4e09312dull, 0x000a5cb968082868ull, + 0x000a410246090000ull, 0x0000422486020000ull, 0x000815ab74000461ull, + 0x000081b940004000ull, 0x000685a9f8000000ull, 0x000782b807000200ull, + 0x000a41b268004078ull, 0x000a410040030000ull, 0x000a41ba68004078ull, + 0x000a410240030000ull, 0xa801c00000000000ull, 0xa821c00000000000ull, + 0x000a4180680100f0ull, 0x000ac639ff003900ull, 0x000a400372010001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x000a83891f000000ull, 0x000f542868090a48ull, 0x000f583068020070ull, + 0x000a5cb942080000ull, 0x000a552a4e09312dull, 0x000a5cb968082868ull, + 0x000a410246090000ull, 0x000081a9f800b800ull, 0x000689b701000100ull, + 0x000685a9f8009800ull, 0x000685a9f800a800ull, 0x00078229f800b800ull, + 0x000601024000000cull, 0x9801c00000000000ull, 0x00088a3702000200ull, + 0x00088629f800a000ull, 0x00068101ffff8100ull, 0x0004010240000004ull, + 0x9801c00000000000ull, 0x0009dcb910001000ull, 0x00068101ffff86ddull, + 0x00048501ffff0800ull, 0x0005dcb978003800ull, 0x0006010240000002ull, + 0x000081a9f8000000ull, 0x9007813910000000ull, 0x0001c00000000000ull, + 0x00048181f0004000ull, 0x988658b168020070ull, 0x0006d428001f0008ull, + 0x00068201ff000000ull, 0xa40815ab74000545ull, 0x0009debd04000400ull, + 0xa429418068010038ull, 0x00095a3468010870ull, 0x0009028386000005ull, + 0xac8a068186000014ull, 0x000a15ab74000543ull, 0x000b5a3468010070ull, + 0xac6b8303000f0005ull, 0x000dd428001f0009ull, 0x000b83013fff0000ull, + 0x000dd42803e001a0ull, 0x000d58b168020870ull, 0x000ddcb960006000ull, + 0x0006418068030230ull, 0x0006410240030000ull, 0x9c01c00000000000ull, + 0x0001c00000000000ull, 0x00078201f0006000ull, 0x000858b168020070ull, + 0xa068d428001f000aull, 0x00085a3468010874ull, 0x0008818100ff0000ull, + 0x000615ab74000545ull, 0x00075a3468010078ull, 0x0007010240000028ull, + 0xa80782b400ff0000ull, 0x000ad428001f000bull, 0x000a5a3468010078ull, + 0x000a410244010000ull, 0xa80782b400ff003cull, 0x000ad428001f000bull, + 0x000a5a3468010078ull, 0x000a410244010000ull, 0xa80782b400ff002bull, + 0x000ad428001f000bull, 0x000a5a3468010078ull, 0x000a410244010000ull, + 0xa80782b400ff002cull, 0x000ad42803ff01abull, 0x000adcb960006000ull, + 0x000a58b168020870ull, 0x000a5a3468010078ull, 0x000a010240000008ull, + 0x0007debd04000400ull, 0x000481bd04000400ull, 0x0006c639ff002b00ull, + 0x0006832803e001a0ull, 0x000cc18300010001ull, 0x000dc18300010000ull, + 0x000641a868034840ull, 0x0006403472030001ull, 0x00048228001c0008ull, + 0x000915ab74000541ull, 0x000082ab00ff0045ull, 0x000adcb960006000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x00065cb942080000ull, + 0x0006552a4e09312dull, 0x00065cb968082868ull, 0x0006410246090000ull, + 0x000042a486020000ull, 0x000a15ab74000543ull, 0x000081b940004000ull, + 0x000685a8001f0000ull, 0x000782b807000300ull, 0x000a41b168004070ull, + 0x000a410040030000ull, 0x000a41ba68004078ull, 0x000a410240030000ull, + 0xa801c00000000000ull, 0xa821c00000000000ull, 0x000a4180680100f0ull, + 0x000ac639ff003900ull, 0x000a400372010001ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x000a83891f000000ull, + 0x000f542868090a48ull, 0x000f583068020070ull, 0x000a5cb942080000ull, + 0x000a552a4e09312dull, 0x000a5cb968082868ull, 0x000a410246090000ull, + 0x00008329ff000200ull, 0x000c8728001c0008ull, 0x000c813920000000ull, + 0x000481b400ff006cull, 0x0006d42803e001c0ull, 0x000658b168020870ull, + 0xa047823400ff0033ull, 0x0008d42803e00180ull, 0xa0685f80680100f0ull, + 0xa007823400ff0032ull, 0x0008d42803e00180ull, 0xa0285f80680100f0ull, + 0x0007822803e00180ull, 0x0008c639ff002e00ull, 0x0008403f72010000ull, + 0x000858b168020870ull, 0x00085abf680040f0ull, 0x00085d80680100f0ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x00085cb942080000ull, 0x0008552a4e09312dull, 0x00085cb968082868ull, + 0x0008410246090000ull, 0x986981b400ff002full, 0x0006d42803e00280ull, + 0x00065a80680100f0ull, 0x000658b168020870ull, 0x000481b400ff0084ull, + 0x0006d42803e00240ull, 0x0004823400ff0011ull, 0x0008d42803e00220ull, + 0x98c481b400ff0006ull, 0x0006d42803e00200ull, 0x00065ebd68010b31ull, + 0x000641806801003cull, 0x0006028386000005ull, 0x000a15ab74000661ull, + 0x0006418068030230ull, 0x0008c180ffff0008ull, 0x0008863400ff0006ull, + 0x0008418240030000ull, 0x000842a486030000ull, 0x000a15ab74000661ull, + 0x9008863400ff0084ull, 0x0004c639ff002f00ull, 0x0004400072010001ull, + 0x000858b168020870ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x00085cb942080000ull, 0x9028552a4e09312dull, + 0x0004c639ff003000ull, 0x0004403472010000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x000858b168020870ull, 0x0001c00000000000ull, + 0x000081b940004000ull, 0x000685a803e00000ull, 0x00045cb942080000ull, + 0x0004552a4e09312dull, 0x00045cb968082868ull, 0x0004410246090000ull, + 0x000483891f000000ull, 0x000f542868090a48ull, 0x000f583068020070ull, + 0x000042a486020000ull, 0x000a15ab74000661ull, 0x000782b807000400ull, + 0x000a41b168004078ull, 0x000a410040030000ull, 0x000a41ba68004078ull, + 0x000a410240030000ull, 0xa801c00000000000ull, 0xa821c00000000000ull, + 0x000a4180680100f0ull, 0x000ac639ff003900ull, 0x000a400372010001ull, + 0x0001c00000000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull, 0x000041bf68034878ull, 0x00005a3468030878ull, + 0x000a83891f000000ull, 0x000f542868090a48ull, 0x000f583068020070ull, + 0x000a5cb942080000ull, 0x000a552a4e09312dull, 0x000a5cb968082868ull, + 0x000a410246090000ull, 0x00005fb968004250ull, 0x0000003f70000000ull, + 0x000041b968034070ull, 0x0000512268030070ull, 0x0000813800200020ull, + 0x0004413a68024070ull, 0x9001c00000000000ull, 0x000081b800200020ull, + 0x9026898180008000ull, 0x0004890110001000ull, 0x000456ad680100a0ull, + 0x0006898180008000ull, 0x000652a56801001dull, 0x000456ad68090b5bull, + 0x00055680680900f0ull, 0x0005debd00400040ull, 0x00005600680800f0ull, + 0x0000833d00200020ull, 0x000c872907c00000ull, 0x000dd62c20000000ull, + 0x0000822902800280ull, 0x000841b268034070ull, 0x000982a8000a000aull, + 0x000a41b168034070ull, 0x000b822907c00000ull, 0x0000003f70000800ull, + 0x000941b268034070ull, 0x0000418048030000ull, 0x0000018340000008ull, + 0x0009018348000004ull, 0x000050a168030c20ull, 0x000082aa00800080ull, + 0x000850a168080c2bull, 0x0000820800010001ull, 0x000850a168000c20ull, + 0x000752a56808001eull, 0x000a822a00400040ull, 0x00088a0900010001ull, + 0x000841bc68034078ull, 0x000941bc68034070ull, 0x000a583068030870ull, + 0x0000813d00400000ull, 0x0005c180ffff0000ull, 0x00058288001e0000ull, + 0x000b8208001e0008ull, 0x00085d2168004030ull, 0x00098308001e0010ull, + 0x00088608001e0010ull, 0x000c5d2168004070ull, 0x0008418068080025ull, + 0x000841ba6803a0f0ull, 0x000856ad40030000ull, 0x0008c180ffff0000ull, + 0x0005820807000500ull, 0x00088a3d00010001ull, 0x000841be68004050ull, + 0x0005828807000300ull, 0x000a8abd00040004ull, 0x000a41be68004040ull, + 0x0005820807000100ull, 0x00088a2a00800080ull, 0x0008413068004078ull, + 0xa021c00000000000ull, 0x0005828807000200ull, 0x000841806801002dull, + 0x000a8abd00080008ull, 0x000a41be68004026ull, 0x0005820807000400ull, + 0x00088a2907000200ull, 0x000841b46800405aull, 0x000556ad40030000ull, + 0x000081bd00100010ull, 0x0006c180ffff0000ull, 0x0006822a00800080ull, + 0x00088a0900100010ull, 0x0008413c68024070ull, 0xa021c00000000000ull, + 0x0006832907000200ull, 0x0008c181f0008000ull, 0x000841834c00ffffull, + 0x0006822a00400040ull, 0x00088a0900200020ull, 0x0008413c68024078ull, + 0xa021c00000000000ull, 0x000c8b0900400040ull, 0x0008dc01f0008000ull, + 0x000841b84c03ffffull, 0x000c8b2a00010000ull, 0x000c41b44c0300ffull, + 0x000682a9f800a800ull, 0x000a86a9f8009800ull, 0x000a8a8904000400ull, + 0x000a41b64c03ffffull, 0x000a41b74c0300ffull, 0x0000828901000100ull, + 0x000a822803e00180ull, 0x0008413168024078ull, 0x0008833400ff0033ull, + 0x000c010240000004ull, 0xa001c00000000000ull, 0xa021c00000000000ull, + 0x000841814c03ffffull, 0x000841814c03ffffull, 0x000a822803e00280ull, + 0x000841b54c03ffffull, 0x000682287c005800ull, 0x00088a0902000200ull, + 0x0008413068024070ull, 0xa001c00000000000ull, 0x0006830900020002ull, + 0x00088281e0002000ull, 0xa84a868108000800ull, 0xa861c00000000000ull, + 0x000a41814c03ffffull, 0x000a41814c03ffffull, 0x00065380680300f0ull, + 0x000c5321680040b0ull, 0x000dd3260fff0fffull, 0x0006810900800080ull, + 0x0000003f70000400ull, 0x000082a907000200ull, 0x000a413268024070ull, + 0xa50a822902800280ull, 0x0004893d08000800ull, 0x00098301ffffffffull, + 0xa4c98381f000e000ull, 0x00095f00680100f0ull, 0xa5295f3e64010000ull, + 0x0001c00000000000ull, 0xa4ec8b01ffffffffull, 0x00095d00680100f0ull, + 0xa1895d3a64010000ull, 0x000cd5ab80008000ull, 0x00088a01ff00ff00ull, + 0x0008d5ab40004000ull, 0x000ed5ab40004000ull, 0x0004893d40000000ull, + 0x00005700680800f0ull, 0x00005780680900f0ull, 0x00008229f800a000ull, + 0x0008c180ffff0018ull, 0x000857af680320f0ull, 0x0007d72ef1ff0000ull, + 0x0007d7aff0000000ull, 0x0004d72e00fc0000ull, 0x0000812c00020002ull, + 0x0004892907c00200ull, 0x000441a7680040f0ull, 0x000441be4c03ffffull, + 0x000441ba4c03ffffull, 0x000481a803c00200ull, 0x0006413168024078ull, + 0x9801c00000000000ull, 0x9821c00000000000ull, 0x00065f80680100f0ull, + 0x00065fbf64010000ull, 0x000641bf4c03ffffull, 0x000452a568030250ull, + 0x0000000008000000ull, 0x0001c00000000000ull, 0x0001c00000000000ull, + 0x0001c00000000000ull +}; diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pko.h b/arch/mips/mach-octeon/include/mach/cvmx-pko.h new file mode 100644 index 000000000000..26e7a9adf4b3 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-pko.h @@ -0,0 +1,213 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Backward compatibility for packet transmission using legacy PKO command. + */ + +#ifndef __CVMX_PKO_H__ +#define __CVMX_PKO_H__ + +extern cvmx_pko_return_value_t +cvmx_pko3_legacy_xmit(unsigned int dq, cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, uint64_t addr, bool tag_sw); + +/** + * Complete packet output. cvmx_pko_send_packet_prepare() must be called exactly + * once before this, and the same parameters must be passed to both + * cvmx_pko_send_packet_prepare() and cvmx_pko_send_packet_finish(). + * + * WARNING: This function may have to look up the proper PKO port in + * the IPD port to PKO port map, and is thus slower than calling + * cvmx_pko_send_packet_finish_pkoid() directly if the PKO port + * identifier is known. + * + * @param ipd_port The IPD port corresponding the to pko port the packet is for + * @param queue Queue to use + * @param pko_command + * PKO HW command word + * @param packet to send + * @param use_locking + * CVMX_PKO_LOCK_NONE, CVMX_PKO_LOCK_ATOMIC_TAG, + * or CVMX_PKO_LOCK_CMD_QUEUE + * + * @return returns CVMX_PKO_SUCCESS on success, or error code on failure of output + */ +static inline cvmx_pko_return_value_t +cvmx_pko_send_packet_finish(u64 ipd_port, uint64_t queue, + cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, cvmx_pko_lock_t use_locking) +{ + cvmx_cmd_queue_result_t result; + + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_legacy_xmit(queue, pko_command, packet, 0, + use_locking == + CVMX_PKO_LOCK_ATOMIC_TAG); + } + + if (use_locking == CVMX_PKO_LOCK_ATOMIC_TAG) + cvmx_pow_tag_sw_wait(); + + result = cvmx_cmd_queue_write2(CVMX_CMD_QUEUE_PKO(queue), + (use_locking == CVMX_PKO_LOCK_CMD_QUEUE), + pko_command.u64, packet.u64); + if (cvmx_likely(result == CVMX_CMD_QUEUE_SUCCESS)) { + cvmx_pko_doorbell(ipd_port, queue, 2); + return CVMX_PKO_SUCCESS; + } else if ((result == CVMX_CMD_QUEUE_NO_MEMORY) || + (result == CVMX_CMD_QUEUE_FULL)) { + return CVMX_PKO_NO_MEMORY; + } else { + return CVMX_PKO_INVALID_QUEUE; + } +} + +/** + * Complete packet output. cvmx_pko_send_packet_prepare() must be called exactly + * once before this, and the same parameters must be passed to both + * cvmx_pko_send_packet_prepare() and cvmx_pko_send_packet_finish(). + * + * WARNING: This function may have to look up the proper PKO port in + * the IPD port to PKO port map, and is thus slower than calling + * cvmx_pko_send_packet_finish3_pkoid() directly if the PKO port + * identifier is known. + * + * @param ipd_port The IPD port corresponding the to pko port the packet is for + * @param queue Queue to use + * @param pko_command + * PKO HW command word + * @param packet to send + * @param addr Physical address of a work queue entry or physical address to zero + * on complete. + * @param use_locking + * CVMX_PKO_LOCK_NONE, CVMX_PKO_LOCK_ATOMIC_TAG, + * or CVMX_PKO_LOCK_CMD_QUEUE + * + * @return returns CVMX_PKO_SUCCESS on success, or error code on failure of output + */ +static inline cvmx_pko_return_value_t +cvmx_pko_send_packet_finish3(u64 ipd_port, uint64_t queue, + cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, uint64_t addr, + cvmx_pko_lock_t use_locking) +{ + cvmx_cmd_queue_result_t result; + + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_legacy_xmit(queue, pko_command, packet, addr, + use_locking == + CVMX_PKO_LOCK_ATOMIC_TAG); + } + + if (use_locking == CVMX_PKO_LOCK_ATOMIC_TAG) + cvmx_pow_tag_sw_wait(); + + result = cvmx_cmd_queue_write3(CVMX_CMD_QUEUE_PKO(queue), + (use_locking == CVMX_PKO_LOCK_CMD_QUEUE), + pko_command.u64, packet.u64, addr); + if (cvmx_likely(result == CVMX_CMD_QUEUE_SUCCESS)) { + cvmx_pko_doorbell(ipd_port, queue, 3); + return CVMX_PKO_SUCCESS; + } else if ((result == CVMX_CMD_QUEUE_NO_MEMORY) || + (result == CVMX_CMD_QUEUE_FULL)) { + return CVMX_PKO_NO_MEMORY; + } else { + return CVMX_PKO_INVALID_QUEUE; + } +} + +/** + * Complete packet output. cvmx_pko_send_packet_prepare() must be called exactly + * once before this, and the same parameters must be passed to both + * cvmx_pko_send_packet_prepare() and cvmx_pko_send_packet_finish_pkoid(). + * + * @param pko_port Port to send it on + * @param queue Queue to use + * @param pko_command + * PKO HW command word + * @param packet to send + * @param use_locking + * CVMX_PKO_LOCK_NONE, CVMX_PKO_LOCK_ATOMIC_TAG, + * or CVMX_PKO_LOCK_CMD_QUEUE + * + * @return returns CVMX_PKO_SUCCESS on success, or error code on failure of output + */ +static inline cvmx_pko_return_value_t +cvmx_pko_send_packet_finish_pkoid(int pko_port, uint64_t queue, + cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, cvmx_pko_lock_t use_locking) +{ + cvmx_cmd_queue_result_t result; + + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_legacy_xmit(queue, pko_command, packet, 0, + use_locking == + CVMX_PKO_LOCK_ATOMIC_TAG); + } + + if (use_locking == CVMX_PKO_LOCK_ATOMIC_TAG) + cvmx_pow_tag_sw_wait(); + result = cvmx_cmd_queue_write2(CVMX_CMD_QUEUE_PKO(queue), + (use_locking == CVMX_PKO_LOCK_CMD_QUEUE), + pko_command.u64, packet.u64); + if (cvmx_likely(result == CVMX_CMD_QUEUE_SUCCESS)) { + cvmx_pko_doorbell_pkoid(pko_port, queue, 2); + return CVMX_PKO_SUCCESS; + } else if ((result == CVMX_CMD_QUEUE_NO_MEMORY) || + (result == CVMX_CMD_QUEUE_FULL)) { + return CVMX_PKO_NO_MEMORY; + } else { + return CVMX_PKO_INVALID_QUEUE; + } +} + +/** + * Complete packet output. cvmx_pko_send_packet_prepare() must be called exactly + * once before this, and the same parameters must be passed to both + * cvmx_pko_send_packet_prepare() and cvmx_pko_send_packet_finish_pkoid(). + * + * @param pko_port The PKO port the packet is for + * @param queue Queue to use + * @param pko_command + * PKO HW command word + * @param packet to send + * @param addr Plysical address of a work queue entry or physical address to zero + * on complete. + * @param use_locking + * CVMX_PKO_LOCK_NONE, CVMX_PKO_LOCK_ATOMIC_TAG, + * or CVMX_PKO_LOCK_CMD_QUEUE + * + * @return returns CVMX_PKO_SUCCESS on success, or error code on failure of output + */ +static inline cvmx_pko_return_value_t +cvmx_pko_send_packet_finish3_pkoid(u64 pko_port, uint64_t queue, + cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, uint64_t addr, + cvmx_pko_lock_t use_locking) +{ + cvmx_cmd_queue_result_t result; + + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_legacy_xmit(queue, pko_command, packet, addr, + use_locking == + CVMX_PKO_LOCK_ATOMIC_TAG); + } + + if (use_locking == CVMX_PKO_LOCK_ATOMIC_TAG) + cvmx_pow_tag_sw_wait(); + result = cvmx_cmd_queue_write3(CVMX_CMD_QUEUE_PKO(queue), + (use_locking == CVMX_PKO_LOCK_CMD_QUEUE), + pko_command.u64, packet.u64, addr); + if (cvmx_likely(result == CVMX_CMD_QUEUE_SUCCESS)) { + cvmx_pko_doorbell_pkoid(pko_port, queue, 3); + return CVMX_PKO_SUCCESS; + } else if ((result == CVMX_CMD_QUEUE_NO_MEMORY) || + (result == CVMX_CMD_QUEUE_FULL)) { + return CVMX_PKO_NO_MEMORY; + } else { + return CVMX_PKO_INVALID_QUEUE; + } +} + +#endif /* __CVMX_PKO_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h b/arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h new file mode 100644 index 000000000000..cc9f37500b0e --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#ifndef __CVMX_PKO3_RESOURCES_H__ +#define __CVMX_PKO3_RESOURCES_H__ + +/* + * Allocate or reserve contiguous list of PKO queues. + * + * @param node is the node number for PKO queues. + * @param level is the PKO queue level. + * @param owner is the owner of PKO queue resources. + * @param base_queue is the PKO queue base number(specify -1 to allocate). + * @param num_queues is the number of PKO queues that have to be reserved or allocated. + * @return returns queue_base if successful or -1 on failure. + */ +int cvmx_pko_alloc_queues(int node, int level, int owner, int base_queue, + int num_queues); + +/** + * Free an allocated/reserved PKO queues for a certain level and owner + * + * @param node on which to allocate/reserve PKO queues + * @param level of PKO queue + * @param owner of reserved/allocated resources + * @return 0 on success, -1 on failure + */ +int cvmx_pko_free_queues(int node, int level, int owner); + +int __cvmx_pko3_dq_param_setup(unsigned node); + +int cvmx_pko3_num_level_queues(enum cvmx_pko3_level_e level); + +#endif /* __CVMX_PKO3_RESOURCES_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pko3.h b/arch/mips/mach-octeon/include/mach/cvmx-pko3.h new file mode 100644 index 000000000000..86f89be855fe --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-pko3.h @@ -0,0 +1,1052 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + */ + +#ifndef __CVMX_PKO3_H__ +#define __CVMX_PKO3_H__ + +DECLARE_GLOBAL_DATA_PTR; + +/* Use full LMTDMA when PARAMETER_CHECKINS is enabled */ +#undef CVMX_ENABLE_PARAMETER_CHECKING +#define CVMX_ENABLE_PARAMETER_CHECKING 0 + +/* + * CVMSEG, scratch line for LMTDMA/LMTST operations: + * 1. It should differ from other CVMSEG uses, e.g. IOBDMA, + * 2. It must agree with the setting of CvmCtl[LMTLINE] control register. + * Contains 16 words, words 1-15 are cleared when word 0 is written to. + */ +#define CVMX_PKO_LMTLINE 2ull + +/* PKO3 queue level identifier */ +enum cvmx_pko3_level_e { + CVMX_PKO_LEVEL_INVAL = 0, + CVMX_PKO_PORT_QUEUES = 0xd1, + CVMX_PKO_L2_QUEUES = 0xc2, + CVMX_PKO_L3_QUEUES = 0xb3, + CVMX_PKO_L4_QUEUES = 0xa4, + CVMX_PKO_L5_QUEUES = 0x95, + CVMX_PKO_DESCR_QUEUES = 0x86, +}; + +enum cvmx_pko_dqop { + CVMX_PKO_DQ_SEND = 0ULL, + CVMX_PKO_DQ_OPEN = 1ULL, + CVMX_PKO_DQ_CLOSE = 2ULL, + CVMX_PKO_DQ_QUERY = 3ULL +}; + +/** + * Returns the PKO DQ..L2 Shaper Time-Wheel clock rate for specified node. + */ +static inline u64 cvmx_pko3_dq_tw_clock_rate_node(int node) +{ + return gd->bus_clk / 768; +} + +/** + * Returns the PKO Port Shaper Time-Wheel clock rate for specified node. + */ +static inline u64 cvmx_pko3_pq_tw_clock_rate_node(int node) +{ + int div; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + div = 96; + else + div = 48; + return gd->bus_clk / div; +} + +/** + * @INTERNAL + * Return the number of MACs in the PKO (exclusing the NULL MAC) + * in a model-dependent manner. + */ +static inline unsigned int __cvmx_pko3_num_macs(void) +{ + if (OCTEON_IS_MODEL(OCTEON_CNF75XX)) + return 10; + if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + return 14; + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + return 28; + return 0; +} + +/** + * @INTERNAL + * Return the number of queue levels, depending on SoC model + */ +static inline int __cvmx_pko3_sq_lvl_max(void) +{ + if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + return CVMX_PKO_L3_QUEUES; + if (OCTEON_IS_MODEL(OCTEON_CNF75XX)) + return CVMX_PKO_L3_QUEUES; + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + return CVMX_PKO_L5_QUEUES; + return -1; +} + +/** + * @INTERNAL + * Return the next (lower) queue level for a given level + */ +static inline enum cvmx_pko3_level_e +__cvmx_pko3_sq_lvl_next(enum cvmx_pko3_level_e level) +{ + switch (level) { + default: + return CVMX_PKO_LEVEL_INVAL; + case CVMX_PKO_PORT_QUEUES: + return CVMX_PKO_L2_QUEUES; + case CVMX_PKO_L2_QUEUES: + return CVMX_PKO_L3_QUEUES; + case CVMX_PKO_L3_QUEUES: + if (OCTEON_IS_MODEL(OCTEON_CN73XX) || + OCTEON_IS_MODEL(OCTEON_CNF75XX)) + return CVMX_PKO_DESCR_QUEUES; + return CVMX_PKO_L4_QUEUES; + case CVMX_PKO_L4_QUEUES: + if (OCTEON_IS_MODEL(OCTEON_CN73XX) || + OCTEON_IS_MODEL(OCTEON_CNF75XX)) + return CVMX_PKO_LEVEL_INVAL; + return CVMX_PKO_L5_QUEUES; + case CVMX_PKO_L5_QUEUES: + if (OCTEON_IS_MODEL(OCTEON_CN73XX) || + OCTEON_IS_MODEL(OCTEON_CNF75XX)) + return CVMX_PKO_LEVEL_INVAL; + return CVMX_PKO_DESCR_QUEUES; + } +} + +/** + * @INTERNAL + * Return an SQ identifier string, for debug messages. + */ +static inline char *__cvmx_pko3_sq_str(char *buf, enum cvmx_pko3_level_e level, + unsigned int q) +{ + char *p; + + switch (level) { + default: + strcpy(buf, "ERR-SQ/"); + break; + case CVMX_PKO_PORT_QUEUES: + strcpy(buf, "PQ_L1/"); + break; + case CVMX_PKO_L2_QUEUES: + strcpy(buf, "SQ_L2/"); + break; + case CVMX_PKO_L3_QUEUES: + strcpy(buf, "SQ_L3/"); + break; + case CVMX_PKO_L4_QUEUES: + strcpy(buf, "SQ_L4/"); + break; + case CVMX_PKO_L5_QUEUES: + strcpy(buf, "SQ_L5/"); + break; + case CVMX_PKO_DESCR_QUEUES: + strcpy(buf, "DQ/"); + break; + } + + for (p = buf; *p; p++) + ; + *p++ = '0' + q / 1000; + q -= (q / 1000) * 1000; + *p++ = '0' + q / 100; + q -= (q / 100) * 100; + *p++ = '0' + q / 10; + q -= (q / 10) * 10; + *p++ = '0' + q; + *p++ = ':'; + *p++ = '\0'; + return buf; +} + +union cvmx_pko_query_rtn { + u64 u64; + struct { + u64 dqstatus : 4; + u64 rsvd_50_59 : 10; + u64 dqop : 2; + u64 depth : 48; + } s; +}; + +typedef union cvmx_pko_query_rtn cvmx_pko_query_rtn_t; + +/* PKO_QUERY_RTN_S[DQSTATUS] - cvmx_pko_query_rtn_t->s.dqstatus */ +enum pko_query_dqstatus { + PKO_DQSTATUS_PASS = 0, /* No error */ + PKO_DQSTATUS_BADSTATE = 0x8, /* queue was not ready to enqueue */ + PKO_DQSTATUS_NOFPABUF = 0x9, /* FPA out of buffers */ + PKO_DQSTATUS_NOPKOBUF = 0xA, /* PKO out of buffers */ + PKO_DQSTATUS_FAILRTNPTR = 0xB, /* can't return buffer ptr to FPA */ + PKO_DQSTATUS_ALREADY = 0xC, /* already created */ + PKO_DQSTATUS_NOTCREATED = 0xD, /* not created */ + PKO_DQSTATUS_NOTEMPTY = 0xE, /* queue not empty */ + PKO_DQSTATUS_SENDPKTDROP = 0xF /* packet dropped, illegal construct */ +}; + +typedef enum pko_query_dqstatus pko_query_dqstatus_t; + +/* Sub-command three bit codes (SUBDC3) */ +#define CVMX_PKO_SENDSUBDC_LINK 0x0 +#define CVMX_PKO_SENDSUBDC_GATHER 0x1 +#define CVMX_PKO_SENDSUBDC_JUMP 0x2 +/* Sub-command four bit codes (SUBDC4) */ +#define CVMX_PKO_SENDSUBDC_TSO 0x8 +#define CVMX_PKO_SENDSUBDC_FREE 0x9 +#define CVMX_PKO_SENDSUBDC_WORK 0xA +#define CVMX_PKO_SENDSUBDC_AURA 0xB +#define CVMX_PKO_SENDSUBDC_MEM 0xC +#define CVMX_PKO_SENDSUBDC_EXT 0xD +#define CVMX_PKO_SENDSUBDC_CRC 0xE +#define CVMX_PKO_SENDSUBDC_IMM 0xF + +/** + * pko buf ptr + * This is good for LINK_S, GATHER_S and PKI_BUFLINK_S structure use. + * It can also be used for JUMP_S with F-bit represented by "i" field, + * and the size limited to 8-bit. + */ + +union cvmx_pko_buf_ptr { + u64 u64; + struct { + u64 size : 16; + u64 subdc3 : 3; + u64 i : 1; + u64 rsvd_42_43 : 2; + u64 addr : 42; + } s; +}; + +typedef union cvmx_pko_buf_ptr cvmx_pko_buf_ptr_t; + +/** + * pko_auraalg_e + */ +enum pko_auraalg_e { + AURAALG_NOP = 0x0, /* aura_cnt = No change */ + AURAALG_SUB = 0x3, /* aura_cnt -= pko_send_aura_t.offset */ + AURAALG_SUBLEN = 0x7, /* aura_cnt -= pko_send_aura_t.offset + + * pko_send_hdr_t.total_bytes + */ + AURAALG_SUBMBUF = 0xB /* aura_cnt -= pko_send_aura_t.offset + + * mbufs_freed + */ +}; + +/** + * PKO_CKL4ALG_E + */ +enum pko_clk4alg_e { + CKL4ALG_NONE = 0x0, /* No checksum. */ + CKL4ALG_UDP = 0x1, /* UDP L4 checksum. */ + CKL4ALG_TCP = 0x2, /* TCP L4 checksum. */ + CKL4ALG_SCTP = 0x3, /* SCTP L4 checksum. */ +}; + +/** + * pko_send_aura + */ +union cvmx_pko_send_aura { + u64 u64; + struct { + u64 rsvd_60_63 : 4; + u64 aura : 12; /* NODE+LAURA */ + u64 subdc4 : 4; + u64 alg : 4; /* pko_auraalg_e */ + u64 rsvd_08_39 : 32; + u64 offset : 8; + } s; +}; + +typedef union cvmx_pko_send_aura cvmx_pko_send_aura_t; + +/** + * pko_send_tso + */ +union cvmx_pko_send_tso { + u64 u64; + struct { + u64 l2len : 8; + u64 rsvd_48_55 : 8; + u64 subdc4 : 4; /* 0x8 */ + u64 rsvd_32_43 : 12; + u64 sb : 8; + u64 mss : 16; + u64 eom : 1; + u64 fn : 7; + } s; +}; + +typedef union cvmx_pko_send_tso cvmx_pko_send_tso_t; + +/** + * pko_send_free + */ +union cvmx_pko_send_free { + u64 u64; + struct { + u64 rsvd_48_63 : 16; + u64 subdc4 : 4; /* 0x9 */ + u64 rsvd : 2; + u64 addr : 42; + } s; +}; + +typedef union cvmx_pko_send_free cvmx_pko_send_free_t; + +/* PKO_SEND_HDR_S - PKO header subcommand */ +union cvmx_pko_send_hdr { + u64 u64; + struct { + u64 rsvd_60_63 : 4; + u64 aura : 12; + u64 ckl4 : 2; /* PKO_CKL4ALG_E */ + u64 ckl3 : 1; + u64 ds : 1; + u64 le : 1; + u64 n2 : 1; + u64 ii : 1; + u64 df : 1; + u64 rsvd_39 : 1; + u64 format : 7; + u64 l4ptr : 8; + u64 l3ptr : 8; + u64 total : 16; + } s; +}; + +typedef union cvmx_pko_send_hdr cvmx_pko_send_hdr_t; + +/* PKO_SEND_EXT_S - extended header subcommand */ +union cvmx_pko_send_ext { + u64 u64; + struct { + u64 rsvd_48_63 : 16; + u64 subdc4 : 4; /* _SENDSUBDC_EXT */ + u64 col : 2; /* _COLORALG_E */ + u64 ra : 2; /* _REDALG_E */ + u64 tstmp : 1; + u64 rsvd_24_38 : 15; + u64 markptr : 8; + u64 rsvd_9_15 : 7; + u64 shapechg : 9; + } s; +}; + +typedef union cvmx_pko_send_ext cvmx_pko_send_ext_t; + +/* PKO_MEMDSZ_E */ +enum cvmx_pko_memdsz_e { + MEMDSZ_B64 = 0, + MEMDSZ_B32 = 1, + MEMDSZ_B16 = 2, /* Not in HRM, assumed unsupported */ + MEMDSZ_B8 = 3 +}; + +/* PKO_MEMALG_E */ +enum cvmx_pko_memalg_e { + MEMALG_SET = 0, /* Set mem = PKO_SEND_MEM_S[OFFSET] */ + MEMALG_SETTSTMP = 1, /* Set the memory location to the timestamp + * PKO_SEND_MEM_S[DSZ] must be B64 and a + * PKO_SEND_EXT_S subdescriptor must be in + * the descriptor with PKO_SEND_EXT_S[TSTMP]=1 + */ + MEMALG_SETRSLT = 2, /* [DSZ] = B64; mem = PKO_MEM_RESULT_S. */ + MEMALG_ADD = 8, /* mem = mem + PKO_SEND_MEM_S[OFFSET] */ + MEMALG_SUB = 9, /* mem = mem – PKO_SEND_MEM_S[OFFSET] */ + MEMALG_ADDLEN = 0xA, /* mem += [OFFSET] + PKO_SEND_HDR_S[TOTAL] */ + MEMALG_SUBLEN = 0xB, /* mem -= [OFFSET] + PKO_SEND_HDR_S[TOTAL] */ + MEMALG_ADDMBUF = 0xC, /* mem += [OFFSET] + mbufs_freed */ + MEMALG_SUBMBUF = 0xD /* mem -= [OFFSET] + mbufs_freed */ +}; + +union cvmx_pko_send_mem { + u64 u64; + struct { + u64 rsvd_63 : 1; + u64 wmem : 1; + u64 dsz : 2; + u64 alg : 4; + u64 offset : 8; + u64 subdc4 : 4; + u64 rsvd_42_43 : 2; + u64 addr : 42; + } s; +}; + +typedef union cvmx_pko_send_mem cvmx_pko_send_mem_t; + +union cvmx_pko_send_work { + u64 u64; + struct { + u64 rsvd_62_63 : 2; + u64 grp : 10; + u64 tt : 2; + u64 rsvd_48_49 : 2; + u64 subdc4 : 4; + u64 rsvd_42_43 : 2; + u64 addr : 42; + } s; +}; + +typedef union cvmx_pko_send_work cvmx_pko_send_work_t; + +/*** PKO_SEND_DMA_S - format of IOBDMA/LMTDMA data word ***/ +union cvmx_pko_lmtdma_data { + u64 u64; + struct { + u64 scraddr : 8; + u64 rtnlen : 8; + u64 did : 8; /* 0x51 */ + u64 node : 4; + u64 rsvd_34_35 : 2; + u64 dqop : 2; /* PKO_DQOP_E */ + u64 rsvd_26_31 : 6; + u64 dq : 10; + u64 rsvd_0_15 : 16; + } s; +}; + +typedef union cvmx_pko_lmtdma_data cvmx_pko_lmtdma_data_t; + +typedef struct cvmx_pko3_dq_params_s { + s32 depth; + s32 limit; + u64 pad[15]; +} cvmx_pko3_dq_params_t; + +/* DQ depth cached value */ +extern cvmx_pko3_dq_params_t *__cvmx_pko3_dq_params[CVMX_MAX_NODES]; + +int cvmx_pko3_internal_buffer_count(unsigned int node); + +/** + * @INTERNAL + * PKO3 DQ parameter location + * @param node node + * @param dq dq + */ +static inline cvmx_pko3_dq_params_t *cvmx_pko3_dq_parameters(unsigned int node, + unsigned int dq) +{ + cvmx_pko3_dq_params_t *pparam = NULL; + static cvmx_pko3_dq_params_t dummy; + + dummy.depth = 0; + dummy.limit = (1 << 16); + + if (cvmx_likely(node < CVMX_MAX_NODES)) + pparam = __cvmx_pko3_dq_params[node]; + + if (cvmx_likely(pparam)) + pparam += dq; + else + pparam = &dummy; + + return pparam; +} + +static inline void cvmx_pko3_dq_set_limit(unsigned int node, unsigned int dq, + unsigned int limit) +{ + cvmx_pko3_dq_params_t *pparam; + + pparam = cvmx_pko3_dq_parameters(node, dq); + pparam->limit = limit; +} + +/** + * PKO descriptor queue operation error string + * + * @param dqstatus is the enumeration returned from hardware, + * PKO_QUERY_RTN_S[DQSTATUS]. + * + * @return static constant string error description + */ +const char *pko_dqstatus_error(pko_query_dqstatus_t dqstatus); + +/* + * This function gets PKO mac num for a interface/port. + * + * @param interface is the interface number. + * @param index is the port number. + * @return returns mac number if successful or -1 on failure. + */ +static inline int __cvmx_pko3_get_mac_num(int xiface, int index) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + cvmx_helper_interface_mode_t mode; + int interface_index; + int ilk_mac_base = -1, bgx_mac_base = -1, bgx_ports = 4; + + if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + bgx_mac_base = 2; + + if (OCTEON_IS_MODEL(OCTEON_CNF75XX)) + bgx_mac_base = 2; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + ilk_mac_base = 2; + bgx_mac_base = 4; + } + + mode = cvmx_helper_interface_get_mode(xiface); + switch (mode) { + case CVMX_HELPER_INTERFACE_MODE_LOOP: + return 0; + case CVMX_HELPER_INTERFACE_MODE_NPI: + return 1; + case CVMX_HELPER_INTERFACE_MODE_ILK: + if (ilk_mac_base < 0) + return -1; + interface_index = (xi.interface - CVMX_ILK_GBL_BASE()); + if (interface_index < 0) + return -1; + return (ilk_mac_base + interface_index); + case CVMX_HELPER_INTERFACE_MODE_SRIO: + return (4 + 2 * xi.interface + index); + default: + if (xi.interface >= CVMX_ILK_GBL_BASE() && ilk_mac_base >= 0) + return -1; + /* All other modes belong to BGX */ + return (bgx_mac_base + bgx_ports * xi.interface + index); + } +} + +/** + * @INTERNAL + * + * Get scratch offset for LMTDMA/LMTST data buffer + * + */ +static inline unsigned int cvmx_pko3_lmtdma_scr_base(void) +{ + return CVMX_PKO_LMTLINE * CVMX_CACHE_LINE_SIZE; +} + +/** + * @INTERNAL + * + * Get address for LMTDMA/LMTST data buffer + * + */ +static inline u64 *cvmx_pko3_cvmseg_addr(void) +{ + const unsigned int scr = cvmx_pko3_lmtdma_scr_base(); + + return (u64 *)(CVMX_SCRATCH_BASE + scr); +} + +/** + * Save scratchpad area + * @param buf storage buffer for saving previous scratchpad contents. + * + * This function should be used whenever the cache line is used + * from a context that might preempt another context that too uses + * the same cache line designated for LMTST/LMTDMA and Wide-Atomic + * operations, such as the hard interrupt context in Linux kernel, + * that could preempt a user-space application on the same processor + * core also using the same scratchpad. + * 'cvmx_lmtline_save()' should be called upon entry into the + * potentially interrupting context, and 'cvmx_lmtline_restore()' should + * be called prior to exitting that context. + */ +static inline void cvmx_lmtline_save(u64 buf[16]) +{ + unsigned int i, scr_off = cvmx_pko3_lmtdma_scr_base(); + unsigned int sz = CVMX_CACHE_LINE_SIZE / sizeof(u64); + + /* wait LMTDMA to finish (if any) */ + CVMX_SYNCIOBDMA; + + /* Copy LMTLINE to user-provided buffer */ + for (i = 0; i < sz; i++) + buf[i] = cvmx_scratch_read64(scr_off + i * sizeof(u64)); +} + +/** + * Restore scratchpad area + * @param buf storage buffer containing the previous content of scratchpad. + */ +static inline void cvmx_lmtline_restore(const u64 buf[16]) +{ + unsigned int i, scr_off = cvmx_pko3_lmtdma_scr_base(); + unsigned int sz = CVMX_CACHE_LINE_SIZE / sizeof(u64); + + /* wait LMTDMA to finsh (if any) */ + CVMX_SYNCIOBDMA; + + /* restore scratchpad area from buf[] */ + for (i = 0; i < sz; i++) + cvmx_scratch_write64(scr_off + i * sizeof(u64), buf[i]); +} + +/* + * @INTERNAL + * Deliver PKO SEND commands via CVMSEG LM and LMTDMA/LMTST. + * The command should be already stored in the CVMSEG address. + * + * @param node is the destination node + * @param dq is the destination descriptor queue. + * @param numwords is the number of outgoing words + * @param tag_wait Wait to finish tag switch just before issueing LMTDMA + * @return the PKO3 native query result structure. + * + * <numwords> must be between 1 and 15 for CVMX_PKO_DQ_SEND command + * + * NOTE: Internal use only. + */ +static inline cvmx_pko_query_rtn_t +__cvmx_pko3_lmtdma(u8 node, uint16_t dq, unsigned int numwords, bool tag_wait) +{ + const enum cvmx_pko_dqop dqop = CVMX_PKO_DQ_SEND; + cvmx_pko_query_rtn_t pko_status; + cvmx_pko_lmtdma_data_t pko_send_dma_data; + u64 dma_addr; + unsigned int scr_base = cvmx_pko3_lmtdma_scr_base(); + unsigned int scr_off; + cvmx_pko3_dq_params_t *pparam; + + if (cvmx_unlikely(numwords < 1 || numwords > 15)) { + debug("%s: ERROR: Internal error\n", __func__); + pko_status.u64 = ~0ull; + return pko_status; + } + + pparam = cvmx_pko3_dq_parameters(node, dq); + + pko_status.u64 = 0; + pko_send_dma_data.u64 = 0; + + /* LMTDMA address offset is (nWords-1) */ + dma_addr = CVMX_LMTDMA_ORDERED_IO_ADDR; + dma_addr += (numwords - 1) << 3; + + scr_off = scr_base + numwords * sizeof(u64); + + /* Write all-ones into the return area */ + cvmx_scratch_write64(scr_off, ~0ull); + + /* Barrier: make sure all prior writes complete before the following */ + CVMX_SYNCWS; + + /* If cached depth exceeds limit, check the real depth */ + if (cvmx_unlikely(pparam->depth > pparam->limit)) { + cvmx_pko_dqx_wm_cnt_t wm_cnt; + + wm_cnt.u64 = csr_rd_node(node, CVMX_PKO_DQX_WM_CNT(dq)); + pko_status.s.depth = wm_cnt.s.count; + pparam->depth = pko_status.s.depth; + + if (pparam->depth > pparam->limit) { + pko_status.s.dqop = dqop; + pko_status.s.dqstatus = PKO_DQSTATUS_NOFPABUF; + return pko_status; + } + } else { + cvmx_atomic_add32_nosync(&pparam->depth, 1); + } + + if (CVMX_ENABLE_PARAMETER_CHECKING) { + /* Request one return word */ + pko_send_dma_data.s.rtnlen = 1; + } else { + /* Do not expect a return word */ + pko_send_dma_data.s.rtnlen = 0; + } + + /* build store data for DMA */ + pko_send_dma_data.s.scraddr = scr_off >> 3; + pko_send_dma_data.s.did = 0x51; + pko_send_dma_data.s.node = node; + pko_send_dma_data.s.dqop = dqop; + pko_send_dma_data.s.dq = dq; + + /* Wait to finish tag switch just before issueing LMTDMA */ + if (tag_wait) + cvmx_pow_tag_sw_wait(); + + /* issue PKO DMA */ + cvmx_write64_uint64(dma_addr, pko_send_dma_data.u64); + + if (cvmx_unlikely(pko_send_dma_data.s.rtnlen)) { + /* Wait for LMTDMA completion */ + CVMX_SYNCIOBDMA; + + /* Retrieve real result */ + pko_status.u64 = cvmx_scratch_read64(scr_off); + pparam->depth = pko_status.s.depth; + } else { + /* Fake positive result */ + pko_status.s.dqop = dqop; + pko_status.s.dqstatus = PKO_DQSTATUS_PASS; + } + + return pko_status; +} + +/* + * @INTERNAL + * Sends PKO descriptor commands via CVMSEG LM and LMTDMA. + * @param node is the destination node + * @param dq is the destination descriptor queue. + * @param cmds[] is an array of 64-bit PKO3 headers/subheaders + * @param numwords is the number of outgoing words + * @param dqop is the operation code + * @return the PKO3 native query result structure. + * + * <numwords> must be between 1 and 15 for CVMX_PKO_DQ_SEND command + * otherwise it must be 0. + * + * NOTE: Internal use only. + */ +static inline cvmx_pko_query_rtn_t __cvmx_pko3_do_dma(u8 node, uint16_t dq, + u64 cmds[], + unsigned int numwords, + enum cvmx_pko_dqop dqop) +{ + const unsigned int scr_base = cvmx_pko3_lmtdma_scr_base(); + cvmx_pko_query_rtn_t pko_status; + cvmx_pko_lmtdma_data_t pko_send_dma_data; + u64 dma_addr; + unsigned int i, scr_off; + cvmx_pko3_dq_params_t *pparam; + + pparam = cvmx_pko3_dq_parameters(node, dq); + CVMX_PREFETCH0(pparam); + /* Push WB */ + CVMX_SYNCWS; + + pko_status.u64 = 0; + pko_send_dma_data.u64 = 0; + + if (cvmx_unlikely(numwords > 15)) { + debug("%s: ERROR: Internal error\n", __func__); + pko_status.u64 = ~0ull; + return pko_status; + } + + /* Store the command words into CVMSEG LM */ + for (i = 0, scr_off = scr_base; i < numwords; i++) { + cvmx_scratch_write64(scr_off, cmds[i]); + scr_off += sizeof(cmds[0]); + } + + /* With 0 data to send, this is an IOBDMA, else LMTDMA operation */ + if (numwords == 0) { + dma_addr = CVMX_IOBDMA_ORDERED_IO_ADDR; + } else { + /* LMTDMA address offset is (nWords-1) */ + dma_addr = CVMX_LMTDMA_ORDERED_IO_ADDR; + dma_addr += (numwords - 1) << 3; + } + + if (cvmx_likely(dqop == CVMX_PKO_DQ_SEND)) { + if (cvmx_unlikely(pparam->depth > pparam->limit)) { + cvmx_pko_dqx_wm_cnt_t wm_cnt; + + wm_cnt.u64 = csr_rd_node(node, CVMX_PKO_DQX_WM_CNT(dq)); + pko_status.s.depth = wm_cnt.s.count; + pparam->depth = pko_status.s.depth; + } + + if (cvmx_unlikely(pparam->depth > pparam->limit)) { + pko_status.s.dqop = dqop; + pko_status.s.dqstatus = PKO_DQSTATUS_NOFPABUF; + return pko_status; + } + + cvmx_atomic_add32_nosync(&pparam->depth, 1); + } + + if (cvmx_unlikely(dqop != CVMX_PKO_DQ_SEND) || + CVMX_ENABLE_PARAMETER_CHECKING) { + /* Request one return word */ + pko_send_dma_data.s.rtnlen = 1; + /* Write all-ones into the return area */ + cvmx_scratch_write64(scr_off, ~0ull); + } else { + /* Do not expext a return word */ + pko_send_dma_data.s.rtnlen = 0; + } + + /* build store data for DMA */ + pko_send_dma_data.s.scraddr = scr_off >> 3; + pko_send_dma_data.s.did = 0x51; + pko_send_dma_data.s.node = node; + pko_send_dma_data.s.dqop = dqop; + pko_send_dma_data.s.dq = dq; + + /* Barrier: make sure all prior writes complete before the following */ + CVMX_SYNCWS; + + /* Wait to finish tag switch just before issueing LMTDMA */ + cvmx_pow_tag_sw_wait(); + + /* issue PKO DMA */ + cvmx_write64_uint64(dma_addr, pko_send_dma_data.u64); + + if (pko_send_dma_data.s.rtnlen) { + /* Wait LMTDMA for completion */ + CVMX_SYNCIOBDMA; + + /* Retrieve real result */ + pko_status.u64 = cvmx_scratch_read64(scr_off); + pparam->depth = pko_status.s.depth; + } else { + /* Fake positive result */ + pko_status.s.dqop = dqop; + pko_status.s.dqstatus = PKO_DQSTATUS_PASS; + } + + return pko_status; +} + +/* + * Transmit packets through PKO, simplified API + * + * @INTERNAL + * + * @param dq is a global destination queue number + * @param pki_ptr specifies packet first linked pointer as returned from + * 'cvmx_wqe_get_pki_pkt_ptr()'. + * @param len is the total number of bytes in the packet. + * @param gaura is the aura to free packet buffers after trasnmit. + * @param pCounter is an address of a 64-bit counter to atomically + * @param ptag is a Flow Tag pointer for packet odering or NULL + * decrement when packet transmission is complete. + * + * @return returns 0 if successful and -1 on failure. + * + * + * NOTE: This is a provisional API, and is subject to change. + */ +static inline int cvmx_pko3_xmit_link_buf(int dq, cvmx_buf_ptr_pki_t pki_ptr, + unsigned int len, int gaura, + u64 *pcounter, u32 *ptag) +{ + cvmx_pko_query_rtn_t pko_status; + cvmx_pko_send_hdr_t hdr_s; + cvmx_pko_buf_ptr_t gtr_s; + unsigned int node, nwords; + unsigned int scr_base = cvmx_pko3_lmtdma_scr_base(); + + /* Separate global DQ# into node and local DQ */ + node = dq >> 10; + dq &= (1 << 10) - 1; + + /* Fill in header */ + hdr_s.u64 = 0; + hdr_s.s.total = len; + hdr_s.s.df = (gaura < 0); + hdr_s.s.ii = 1; + hdr_s.s.aura = (gaura >= 0) ? gaura : 0; + + /* Fill in gather */ + gtr_s.u64 = 0; + gtr_s.s.subdc3 = CVMX_PKO_SENDSUBDC_LINK; + gtr_s.s.addr = pki_ptr.addr; + gtr_s.s.size = pki_ptr.size; + + /* Setup command word pointers */ + cvmx_scratch_write64(scr_base + sizeof(u64) * 0, hdr_s.u64); + cvmx_scratch_write64(scr_base + sizeof(u64) * 1, gtr_s.u64); + nwords = 2; + + /* Conditionally setup an atomic decrement counter */ + if (pcounter) { + cvmx_pko_send_mem_t mem_s; + + mem_s.s.subdc4 = CVMX_PKO_SENDSUBDC_MEM; + mem_s.s.dsz = MEMDSZ_B64; + mem_s.s.alg = MEMALG_SUB; + mem_s.s.offset = 1; + mem_s.s.wmem = 0; + mem_s.s.addr = cvmx_ptr_to_phys(CASTPTR(void, pcounter)); + cvmx_scratch_write64(scr_base + sizeof(u64) * nwords++, + mem_s.u64); + } + + /* To preserve packet order, go atomic with DQ-specific tag */ + if (ptag) + cvmx_pow_tag_sw(*ptag ^ dq, CVMX_POW_TAG_TYPE_ATOMIC); + + /* Do LMTDMA */ + pko_status = __cvmx_pko3_lmtdma(node, dq, nwords, ptag); + + if (cvmx_likely(pko_status.s.dqstatus == PKO_DQSTATUS_PASS)) + return 0; + else + return -1; +} + +/** + * @INTERNAL + * + * Retrieve PKO internal AURA from register. + */ +static inline unsigned int __cvmx_pko3_aura_get(unsigned int node) +{ + static s16 aura = -1; + cvmx_pko_dpfi_fpa_aura_t pko_aura; + + if (aura >= 0) + return aura; + + pko_aura.u64 = csr_rd_node(node, CVMX_PKO_DPFI_FPA_AURA); + + aura = (pko_aura.s.node << 10) | pko_aura.s.laura; + return aura; +} + +/** Open configured descriptor queues before queueing packets into them. + * + * @param node is to specify the node to which this configuration is applied. + * @param dq is the descriptor queue number to be opened. + * @return returns 0 on success or -1 on failure. + */ +int cvmx_pko_dq_open(int node, int dq); + +/** Close a descriptor queue + * + * @param node is to specify the node to which this configuration is applied. + * @param dq is the descriptor queue number to be opened. + * @return returns 0 on success or -1 on failure. + * + * This should be called before changing the DQ parent link, topology, + * or when shutting down the PKO. + */ +int cvmx_pko3_dq_close(int node, int dq); + +/** Query a descriptor queue + * + * @param node is to specify the node to which this configuration is applied. + * @param dq is the descriptor queue number to be opened. + * @return returns the descriptor queue depth on success or -1 on failure. + * + * This should be called before changing the DQ parent link, topology, + * or when shutting down the PKO. + */ +int cvmx_pko3_dq_query(int node, int dq); + +/** Drain a descriptor queue + * + * Before closing a DQ, this call will drain all pending traffic + * on the DQ to the NULL MAC, which will circumvent any traffic + * shaping and flow control to quickly reclaim all packet buffers. + */ +void cvmx_pko3_dq_drain(int node, int dq); + +/* + * PKO global initialization for 78XX. + * + * @param node is the node on which PKO block is initialized. + * @param aura is the 12-bit AURA (including node) for PKO internal use. + * @return none. + */ +int cvmx_pko3_hw_init_global(int node, uint16_t aura); + +/** + * Shutdown the entire PKO + */ +int cvmx_pko3_hw_disable(int node); + +/* Define legacy type here to break circular dependency */ +typedef struct cvmx_pko_port_status cvmx_pko_port_status_t; + +/** + * @INTERNAL + * Backward compatibility for collecting statistics from PKO3 + * + */ +void cvmx_pko3_get_legacy_port_stats(u16 ipd_port, unsigned int clear, + cvmx_pko_port_status_t *status); + +/** Set MAC options + * + * The options supported are the parameters below: + * + * @param xiface The physical interface number + * @param index The physical sub-interface port + * @param fcs_enable Enable FCS generation + * @param pad_enable Enable padding to minimum packet size + * @param fcs_sop_off Number of bytes at start of packet to exclude from FCS + * + * The typical use for `fcs_sop_off` is when the interface is configured + * to use a header such as HighGig to precede every Ethernet packet, + * such a header usually does not partake in the CRC32 computation stream, + * and its size must be set with this parameter. + * + * @return Returns 0 on success, -1 if interface/port is invalid. + */ +int cvmx_pko3_interface_options(int xiface, int index, bool fcs_enable, + bool pad_enable, unsigned int fcs_sop_off); + +/** Set Descriptor Queue options + * + * The `min_pad` parameter must be in agreement with the interface-level + * padding option for all descriptor queues assigned to that particular + * interface/port. + */ +void cvmx_pko3_dq_options(unsigned int node, unsigned int dq, bool min_pad); + +int cvmx_pko3_port_fifo_size(unsigned int xiface, unsigned int index); +int cvmx_pko3_channel_credit_level(int node, enum cvmx_pko3_level_e level); +int cvmx_pko3_port_xoff(unsigned int xiface, unsigned int index); +int cvmx_pko3_port_xon(unsigned int xiface, unsigned int index); + +/* Packet descriptor - PKO3 command buffer + internal state */ +typedef struct cvmx_pko3_pdesc_s { + u64 *jump_buf; /**< jump buffer vaddr */ + s16 last_aura; /**< AURA of the latest LINK_S/GATHER_S */ + unsigned num_words : 5, /**< valid words in word array 2..16 */ + headroom : 10, /**< free bytes at start of 1st buf */ + hdr_offsets : 1, pki_word4_present : 1; + /* PKO3 command buffer: */ + cvmx_pko_send_hdr_t *hdr_s; + u64 word[16]; /**< header and subcommands buffer */ + /* Bookkeeping fields: */ + u64 send_work_s; /**< SEND_WORK_S must be the very last subdc */ + s16 jb_aura; /**< AURA where the jump buffer belongs */ + u16 mem_s_ix; /**< index of first MEM_S subcommand */ + u8 ckl4_alg; /**< L3/L4 alg to use if recalc is needed */ + /* Fields saved from WQE for later inspection */ + cvmx_pki_wqe_word4_t pki_word4; + cvmx_pki_wqe_word2_t pki_word2; +} cvmx_pko3_pdesc_t; + +void cvmx_pko3_pdesc_init(cvmx_pko3_pdesc_t *pdesc); +int cvmx_pko3_pdesc_from_wqe(cvmx_pko3_pdesc_t *pdesc, cvmx_wqe_78xx_t *wqe, + bool free_bufs); +int cvmx_pko3_pdesc_transmit(cvmx_pko3_pdesc_t *pdesc, uint16_t dq, + u32 *flow_tag); +int cvmx_pko3_pdesc_notify_decrement(cvmx_pko3_pdesc_t *pdesc, + volatile u64 *p_counter); +int cvmx_pko3_pdesc_notify_wqe(cvmx_pko3_pdesc_t *pdesc, cvmx_wqe_78xx_t *wqe, + u8 node, uint8_t group, uint8_t tt, u32 tag); +int cvmx_pko3_pdesc_buf_append(cvmx_pko3_pdesc_t *pdesc, void *p_data, + unsigned int data_bytes, unsigned int gaura); +int cvmx_pko3_pdesc_append_free(cvmx_pko3_pdesc_t *pdesc, u64 addr, + unsigned int gaura); +int cvmx_pko3_pdesc_hdr_push(cvmx_pko3_pdesc_t *pdesc, const void *p_data, + u8 data_bytes, uint8_t layer); +int cvmx_pko3_pdesc_hdr_pop(cvmx_pko3_pdesc_t *pdesc, void *hdr_buf, + unsigned int num_bytes); +int cvmx_pko3_pdesc_hdr_peek(cvmx_pko3_pdesc_t *pdesc, void *hdr_buf, + unsigned int num_bytes, unsigned int offset); +void cvmx_pko3_pdesc_set_free(cvmx_pko3_pdesc_t *pdesc, bool free_bufs); + +#endif /* __CVMX_PKO3_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-range.h b/arch/mips/mach-octeon/include/mach/cvmx-range.h new file mode 100644 index 000000000000..f0c1307e6173 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-range.h @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#ifndef __CVMX_RANGE_H__ +#define __CVMX_RANGE_H__ + +int cvmx_range_init(u64 range_addr, int size); +int cvmx_range_alloc(u64 range_addr, uint64_t owner, uint64_t cnt, int align); +int cvmx_range_alloc_ordered(u64 range_addr, uint64_t owner, u64 cnt, int align, + int reverse); +int cvmx_range_alloc_non_contiguos(u64 range_addr, uint64_t owner, u64 cnt, + int elements[]); +int cvmx_range_reserve(u64 range_addr, uint64_t owner, u64 base, uint64_t cnt); +int cvmx_range_free_with_base(u64 range_addr, int base, int cnt); +int cvmx_range_free_with_owner(u64 range_addr, uint64_t owner); +u64 cvmx_range_get_owner(u64 range_addr, uint64_t base); +void cvmx_range_show(uint64_t range_addr); +int cvmx_range_memory_size(int nelements); +int cvmx_range_free_mutiple(u64 range_addr, int bases[], int count); + +#endif // __CVMX_RANGE_H__
Import cvmx-igl-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-ilk-defs.h | 2269 +++++++++++++++++ 1 file changed, 2269 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h new file mode 100644 index 000000000000..d54f9ca792f5 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h @@ -0,0 +1,2269 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon ilk. + */ + +#ifndef __CVMX_ILK_DEFS_H__ +#define __CVMX_ILK_DEFS_H__ + +#define CVMX_ILK_BIST_SUM (0x0001180014000038ull) +#define CVMX_ILK_GBL_CFG (0x0001180014000000ull) +#define CVMX_ILK_GBL_ERR_CFG (0x0001180014000058ull) +#define CVMX_ILK_GBL_INT (0x0001180014000008ull) +#define CVMX_ILK_GBL_INT_EN (0x0001180014000010ull) +#define CVMX_ILK_INT_SUM (0x0001180014000030ull) +#define CVMX_ILK_LNEX_TRN_CTL(offset) \ + (0x00011800140380F0ull + ((offset) & 15) * 1024) +#define CVMX_ILK_LNEX_TRN_LD(offset) \ + (0x00011800140380E0ull + ((offset) & 15) * 1024) +#define CVMX_ILK_LNEX_TRN_LP(offset) \ + (0x00011800140380E8ull + ((offset) & 15) * 1024) +#define CVMX_ILK_LNE_DBG (0x0001180014030008ull) +#define CVMX_ILK_LNE_STS_MSG (0x0001180014030000ull) +#define CVMX_ILK_RID_CFG (0x0001180014000050ull) +#define CVMX_ILK_RXF_IDX_PMAP (0x0001180014000020ull) +#define CVMX_ILK_RXF_MEM_PMAP (0x0001180014000028ull) +#define CVMX_ILK_RXX_BYTE_CNTX(offset, block_id) \ + (0x0001180014023000ull + \ + (((offset) & 255) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_RXX_CAL_ENTRYX(offset, block_id) \ + (0x0001180014021000ull + \ + (((offset) & 511) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_RXX_CFG0(offset) (0x0001180014020000ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_CFG1(offset) (0x0001180014020008ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_CHAX(offset, block_id) \ + (0x0001180014002000ull + \ + (((offset) & 255) + ((block_id) & 1) * 0x200ull) * 8) +#define CVMX_ILK_RXX_CHA_XONX(offset, block_id) \ + (0x0001180014020400ull + (((offset) & 3) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_RXX_ERR_CFG(offset) \ + (0x00011800140200E0ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_FLOW_CTL0(offset) \ + (0x0001180014020090ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_FLOW_CTL1(offset) \ + (0x0001180014020098ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_IDX_CAL(offset) \ + (0x00011800140200A0ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_IDX_STAT0(offset) \ + (0x0001180014020070ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_IDX_STAT1(offset) \ + (0x0001180014020078ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_INT(offset) (0x0001180014020010ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_INT_EN(offset) \ + (0x0001180014020018ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_JABBER(offset) \ + (0x00011800140200B8ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_MEM_CAL0(offset) \ + (0x00011800140200A8ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_MEM_CAL1(offset) \ + (0x00011800140200B0ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_MEM_STAT0(offset) \ + (0x0001180014020080ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_MEM_STAT1(offset) \ + (0x0001180014020088ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_PKT_CNTX(offset, block_id) \ + (0x0001180014022000ull + \ + (((offset) & 255) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_RXX_RID(offset) (0x00011800140200C0ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT0(offset) \ + (0x0001180014020020ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT1(offset) \ + (0x0001180014020028ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT2(offset) \ + (0x0001180014020030ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT3(offset) \ + (0x0001180014020038ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT4(offset) \ + (0x0001180014020040ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT5(offset) \ + (0x0001180014020048ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT6(offset) \ + (0x0001180014020050ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT7(offset) \ + (0x0001180014020058ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT8(offset) \ + (0x0001180014020060ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RXX_STAT9(offset) \ + (0x0001180014020068ull + ((offset) & 1) * 16384) +#define CVMX_ILK_RX_LNEX_CFG(offset) \ + (0x0001180014038000ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_INT(offset) \ + (0x0001180014038008ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_INT_EN(offset) \ + (0x0001180014038010ull + ((offset) & 7) * 1024) +#define CVMX_ILK_RX_LNEX_STAT0(offset) \ + (0x0001180014038018ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT1(offset) \ + (0x0001180014038020ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT10(offset) \ + (0x0001180014038068ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT2(offset) \ + (0x0001180014038028ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT3(offset) \ + (0x0001180014038030ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT4(offset) \ + (0x0001180014038038ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT5(offset) \ + (0x0001180014038040ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT6(offset) \ + (0x0001180014038048ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT7(offset) \ + (0x0001180014038050ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT8(offset) \ + (0x0001180014038058ull + ((offset) & 15) * 1024) +#define CVMX_ILK_RX_LNEX_STAT9(offset) \ + (0x0001180014038060ull + ((offset) & 15) * 1024) +#define CVMX_ILK_SER_CFG (0x0001180014000018ull) +#define CVMX_ILK_TXX_BYTE_CNTX(offset, block_id) \ + (0x0001180014013000ull + \ + (((offset) & 255) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_TXX_CAL_ENTRYX(offset, block_id) \ + (0x0001180014011000ull + \ + (((offset) & 511) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_TXX_CFG0(offset) (0x0001180014010000ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_CFG1(offset) (0x0001180014010008ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_CHA_XONX(offset, block_id) \ + (0x0001180014010400ull + (((offset) & 3) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_TXX_DBG(offset) (0x0001180014010070ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_ERR_CFG(offset) \ + (0x00011800140100B0ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_FLOW_CTL0(offset) \ + (0x0001180014010048ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_FLOW_CTL1(offset) \ + (0x0001180014010050ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_IDX_CAL(offset) \ + (0x0001180014010058ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_IDX_PMAP(offset) \ + (0x0001180014010010ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_IDX_STAT0(offset) \ + (0x0001180014010020ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_IDX_STAT1(offset) \ + (0x0001180014010028ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_INT(offset) (0x0001180014010078ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_INT_EN(offset) \ + (0x0001180014010080ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_MEM_CAL0(offset) \ + (0x0001180014010060ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_MEM_CAL1(offset) \ + (0x0001180014010068ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_MEM_PMAP(offset) \ + (0x0001180014010018ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_MEM_STAT0(offset) \ + (0x0001180014010030ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_MEM_STAT1(offset) \ + (0x0001180014010038ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_PIPE(offset) (0x0001180014010088ull + ((offset) & 1) * 16384) +#define CVMX_ILK_TXX_PKT_CNTX(offset, block_id) \ + (0x0001180014012000ull + \ + (((offset) & 255) + ((block_id) & 1) * 0x800ull) * 8) +#define CVMX_ILK_TXX_RMATCH(offset) \ + (0x0001180014010040ull + ((offset) & 1) * 16384) + +/** + * cvmx_ilk_bist_sum + */ +union cvmx_ilk_bist_sum { + u64 u64; + struct cvmx_ilk_bist_sum_s { + u64 rxf_x2p : 1; + u64 rxf_mem19 : 1; + u64 rxf_mem18 : 1; + u64 rxf_mem17 : 1; + u64 rxf_mem16 : 1; + u64 rxf_mem15 : 1; + u64 reserved_52_57 : 6; + u64 rxf_mem8 : 1; + u64 rxf_mem7 : 1; + u64 rxf_mem6 : 1; + u64 rxf_mem5 : 1; + u64 rxf_mem4 : 1; + u64 rxf_mem3 : 1; + u64 reserved_36_45 : 10; + u64 rle7_dsk1 : 1; + u64 rle7_dsk0 : 1; + u64 rle6_dsk1 : 1; + u64 rle6_dsk0 : 1; + u64 rle5_dsk1 : 1; + u64 rle5_dsk0 : 1; + u64 rle4_dsk1 : 1; + u64 rle4_dsk0 : 1; + u64 rle3_dsk1 : 1; + u64 rle3_dsk0 : 1; + u64 rle2_dsk1 : 1; + u64 rle2_dsk0 : 1; + u64 rle1_dsk1 : 1; + u64 rle1_dsk0 : 1; + u64 rle0_dsk1 : 1; + u64 rle0_dsk0 : 1; + u64 rlk1_pmap : 1; + u64 reserved_18_18 : 1; + u64 rlk1_fwc : 1; + u64 reserved_16_16 : 1; + u64 rlk0_pmap : 1; + u64 rlk0_stat1 : 1; + u64 rlk0_fwc : 1; + u64 rlk0_stat : 1; + u64 tlk1_stat1 : 1; + u64 tlk1_fwc : 1; + u64 reserved_9_9 : 1; + u64 tlk1_txf2 : 1; + u64 tlk1_txf1 : 1; + u64 tlk1_txf0 : 1; + u64 tlk0_stat1 : 1; + u64 tlk0_fwc : 1; + u64 reserved_3_3 : 1; + u64 tlk0_txf2 : 1; + u64 tlk0_txf1 : 1; + u64 tlk0_txf0 : 1; + } s; + struct cvmx_ilk_bist_sum_cn68xx { + u64 reserved_58_63 : 6; + u64 rxf_x2p1 : 1; + u64 rxf_x2p0 : 1; + u64 rxf_pmap : 1; + u64 rxf_mem2 : 1; + u64 rxf_mem1 : 1; + u64 rxf_mem0 : 1; + u64 reserved_36_51 : 16; + u64 rle7_dsk1 : 1; + u64 rle7_dsk0 : 1; + u64 rle6_dsk1 : 1; + u64 rle6_dsk0 : 1; + u64 rle5_dsk1 : 1; + u64 rle5_dsk0 : 1; + u64 rle4_dsk1 : 1; + u64 rle4_dsk0 : 1; + u64 rle3_dsk1 : 1; + u64 rle3_dsk0 : 1; + u64 rle2_dsk1 : 1; + u64 rle2_dsk0 : 1; + u64 rle1_dsk1 : 1; + u64 rle1_dsk0 : 1; + u64 rle0_dsk1 : 1; + u64 rle0_dsk0 : 1; + u64 reserved_19_19 : 1; + u64 rlk1_stat1 : 1; + u64 rlk1_fwc : 1; + u64 rlk1_stat : 1; + u64 reserved_15_15 : 1; + u64 rlk0_stat1 : 1; + u64 rlk0_fwc : 1; + u64 rlk0_stat : 1; + u64 tlk1_stat1 : 1; + u64 tlk1_fwc : 1; + u64 tlk1_stat0 : 1; + u64 tlk1_txf2 : 1; + u64 tlk1_txf1 : 1; + u64 tlk1_txf0 : 1; + u64 tlk0_stat1 : 1; + u64 tlk0_fwc : 1; + u64 tlk0_stat0 : 1; + u64 tlk0_txf2 : 1; + u64 tlk0_txf1 : 1; + u64 tlk0_txf0 : 1; + } cn68xx; + struct cvmx_ilk_bist_sum_cn68xxp1 { + u64 reserved_58_63 : 6; + u64 rxf_x2p1 : 1; + u64 rxf_x2p0 : 1; + u64 rxf_pmap : 1; + u64 rxf_mem2 : 1; + u64 rxf_mem1 : 1; + u64 rxf_mem0 : 1; + u64 reserved_36_51 : 16; + u64 rle7_dsk1 : 1; + u64 rle7_dsk0 : 1; + u64 rle6_dsk1 : 1; + u64 rle6_dsk0 : 1; + u64 rle5_dsk1 : 1; + u64 rle5_dsk0 : 1; + u64 rle4_dsk1 : 1; + u64 rle4_dsk0 : 1; + u64 rle3_dsk1 : 1; + u64 rle3_dsk0 : 1; + u64 rle2_dsk1 : 1; + u64 rle2_dsk0 : 1; + u64 rle1_dsk1 : 1; + u64 rle1_dsk0 : 1; + u64 rle0_dsk1 : 1; + u64 rle0_dsk0 : 1; + u64 reserved_18_19 : 2; + u64 rlk1_fwc : 1; + u64 rlk1_stat : 1; + u64 reserved_14_15 : 2; + u64 rlk0_fwc : 1; + u64 rlk0_stat : 1; + u64 reserved_11_11 : 1; + u64 tlk1_fwc : 1; + u64 tlk1_stat : 1; + u64 tlk1_txf2 : 1; + u64 tlk1_txf1 : 1; + u64 tlk1_txf0 : 1; + u64 reserved_5_5 : 1; + u64 tlk0_fwc : 1; + u64 tlk0_stat : 1; + u64 tlk0_txf2 : 1; + u64 tlk0_txf1 : 1; + u64 tlk0_txf0 : 1; + } cn68xxp1; + struct cvmx_ilk_bist_sum_cn78xx { + u64 rxf_x2p : 1; + u64 rxf_mem19 : 1; + u64 rxf_mem18 : 1; + u64 rxf_mem17 : 1; + u64 rxf_mem16 : 1; + u64 rxf_mem15 : 1; + u64 rxf_mem14 : 1; + u64 rxf_mem13 : 1; + u64 rxf_mem12 : 1; + u64 rxf_mem11 : 1; + u64 rxf_mem10 : 1; + u64 rxf_mem9 : 1; + u64 rxf_mem8 : 1; + u64 rxf_mem7 : 1; + u64 rxf_mem6 : 1; + u64 rxf_mem5 : 1; + u64 rxf_mem4 : 1; + u64 rxf_mem3 : 1; + u64 rxf_mem2 : 1; + u64 rxf_mem1 : 1; + u64 rxf_mem0 : 1; + u64 reserved_36_42 : 7; + u64 rle7_dsk1 : 1; + u64 rle7_dsk0 : 1; + u64 rle6_dsk1 : 1; + u64 rle6_dsk0 : 1; + u64 rle5_dsk1 : 1; + u64 rle5_dsk0 : 1; + u64 rle4_dsk1 : 1; + u64 rle4_dsk0 : 1; + u64 rle3_dsk1 : 1; + u64 rle3_dsk0 : 1; + u64 rle2_dsk1 : 1; + u64 rle2_dsk0 : 1; + u64 rle1_dsk1 : 1; + u64 rle1_dsk0 : 1; + u64 rle0_dsk1 : 1; + u64 rle0_dsk0 : 1; + u64 rlk1_pmap : 1; + u64 rlk1_stat : 1; + u64 rlk1_fwc : 1; + u64 rlk1_stat1 : 1; + u64 rlk0_pmap : 1; + u64 rlk0_stat1 : 1; + u64 rlk0_fwc : 1; + u64 rlk0_stat : 1; + u64 tlk1_stat1 : 1; + u64 tlk1_fwc : 1; + u64 tlk1_stat0 : 1; + u64 tlk1_txf2 : 1; + u64 tlk1_txf1 : 1; + u64 tlk1_txf0 : 1; + u64 tlk0_stat1 : 1; + u64 tlk0_fwc : 1; + u64 tlk0_stat0 : 1; + u64 tlk0_txf2 : 1; + u64 tlk0_txf1 : 1; + u64 tlk0_txf0 : 1; + } cn78xx; + struct cvmx_ilk_bist_sum_cn78xx cn78xxp1; +}; + +typedef union cvmx_ilk_bist_sum cvmx_ilk_bist_sum_t; + +/** + * cvmx_ilk_gbl_cfg + */ +union cvmx_ilk_gbl_cfg { + u64 u64; + struct cvmx_ilk_gbl_cfg_s { + u64 reserved_4_63 : 60; + u64 rid_rstdis : 1; + u64 reset : 1; + u64 cclk_dis : 1; + u64 rxf_xlink : 1; + } s; + struct cvmx_ilk_gbl_cfg_s cn68xx; + struct cvmx_ilk_gbl_cfg_cn68xxp1 { + u64 reserved_2_63 : 62; + u64 cclk_dis : 1; + u64 rxf_xlink : 1; + } cn68xxp1; + struct cvmx_ilk_gbl_cfg_s cn78xx; + struct cvmx_ilk_gbl_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_gbl_cfg cvmx_ilk_gbl_cfg_t; + +/** + * cvmx_ilk_gbl_err_cfg + */ +union cvmx_ilk_gbl_err_cfg { + u64 u64; + struct cvmx_ilk_gbl_err_cfg_s { + u64 reserved_20_63 : 44; + u64 rxf_flip : 2; + u64 x2p_flip : 2; + u64 reserved_2_15 : 14; + u64 rxf_cor_dis : 1; + u64 x2p_cor_dis : 1; + } s; + struct cvmx_ilk_gbl_err_cfg_s cn78xx; + struct cvmx_ilk_gbl_err_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_gbl_err_cfg cvmx_ilk_gbl_err_cfg_t; + +/** + * cvmx_ilk_gbl_int + */ +union cvmx_ilk_gbl_int { + u64 u64; + struct cvmx_ilk_gbl_int_s { + u64 reserved_9_63 : 55; + u64 x2p_dbe : 1; + u64 x2p_sbe : 1; + u64 rxf_dbe : 1; + u64 rxf_sbe : 1; + u64 rxf_push_full : 1; + u64 rxf_pop_empty : 1; + u64 rxf_ctl_perr : 1; + u64 rxf_lnk1_perr : 1; + u64 rxf_lnk0_perr : 1; + } s; + struct cvmx_ilk_gbl_int_cn68xx { + u64 reserved_5_63 : 59; + u64 rxf_push_full : 1; + u64 rxf_pop_empty : 1; + u64 rxf_ctl_perr : 1; + u64 rxf_lnk1_perr : 1; + u64 rxf_lnk0_perr : 1; + } cn68xx; + struct cvmx_ilk_gbl_int_cn68xx cn68xxp1; + struct cvmx_ilk_gbl_int_s cn78xx; + struct cvmx_ilk_gbl_int_s cn78xxp1; +}; + +typedef union cvmx_ilk_gbl_int cvmx_ilk_gbl_int_t; + +/** + * cvmx_ilk_gbl_int_en + */ +union cvmx_ilk_gbl_int_en { + u64 u64; + struct cvmx_ilk_gbl_int_en_s { + u64 reserved_5_63 : 59; + u64 rxf_push_full : 1; + u64 rxf_pop_empty : 1; + u64 rxf_ctl_perr : 1; + u64 rxf_lnk1_perr : 1; + u64 rxf_lnk0_perr : 1; + } s; + struct cvmx_ilk_gbl_int_en_s cn68xx; + struct cvmx_ilk_gbl_int_en_s cn68xxp1; +}; + +typedef union cvmx_ilk_gbl_int_en cvmx_ilk_gbl_int_en_t; + +/** + * cvmx_ilk_int_sum + */ +union cvmx_ilk_int_sum { + u64 u64; + struct cvmx_ilk_int_sum_s { + u64 reserved_13_63 : 51; + u64 rle7_int : 1; + u64 rle6_int : 1; + u64 rle5_int : 1; + u64 rle4_int : 1; + u64 rle3_int : 1; + u64 rle2_int : 1; + u64 rle1_int : 1; + u64 rle0_int : 1; + u64 rlk1_int : 1; + u64 rlk0_int : 1; + u64 tlk1_int : 1; + u64 tlk0_int : 1; + u64 gbl_int : 1; + } s; + struct cvmx_ilk_int_sum_s cn68xx; + struct cvmx_ilk_int_sum_s cn68xxp1; +}; + +typedef union cvmx_ilk_int_sum cvmx_ilk_int_sum_t; + +/** + * cvmx_ilk_lne#_trn_ctl + */ +union cvmx_ilk_lnex_trn_ctl { + u64 u64; + struct cvmx_ilk_lnex_trn_ctl_s { + u64 reserved_4_63 : 60; + u64 trn_lock : 1; + u64 trn_done : 1; + u64 trn_ena : 1; + u64 eie_det : 1; + } s; + struct cvmx_ilk_lnex_trn_ctl_s cn78xx; + struct cvmx_ilk_lnex_trn_ctl_s cn78xxp1; +}; + +typedef union cvmx_ilk_lnex_trn_ctl cvmx_ilk_lnex_trn_ctl_t; + +/** + * cvmx_ilk_lne#_trn_ld + */ +union cvmx_ilk_lnex_trn_ld { + u64 u64; + struct cvmx_ilk_lnex_trn_ld_s { + u64 lp_manual : 1; + u64 reserved_49_62 : 14; + u64 ld_cu_val : 1; + u64 ld_cu_dat : 16; + u64 reserved_17_31 : 15; + u64 ld_sr_val : 1; + u64 ld_sr_dat : 16; + } s; + struct cvmx_ilk_lnex_trn_ld_s cn78xx; + struct cvmx_ilk_lnex_trn_ld_s cn78xxp1; +}; + +typedef union cvmx_ilk_lnex_trn_ld cvmx_ilk_lnex_trn_ld_t; + +/** + * cvmx_ilk_lne#_trn_lp + */ +union cvmx_ilk_lnex_trn_lp { + u64 u64; + struct cvmx_ilk_lnex_trn_lp_s { + u64 reserved_49_63 : 15; + u64 lp_cu_val : 1; + u64 lp_cu_dat : 16; + u64 reserved_17_31 : 15; + u64 lp_sr_val : 1; + u64 lp_sr_dat : 16; + } s; + struct cvmx_ilk_lnex_trn_lp_s cn78xx; + struct cvmx_ilk_lnex_trn_lp_s cn78xxp1; +}; + +typedef union cvmx_ilk_lnex_trn_lp cvmx_ilk_lnex_trn_lp_t; + +/** + * cvmx_ilk_lne_dbg + */ +union cvmx_ilk_lne_dbg { + u64 u64; + struct cvmx_ilk_lne_dbg_s { + u64 reserved_60_63 : 4; + u64 tx_bad_crc32 : 1; + u64 tx_bad_6467_cnt : 5; + u64 tx_bad_sync_cnt : 3; + u64 tx_bad_scram_cnt : 3; + u64 tx_bad_lane_sel : 16; + u64 tx_dis_dispr : 16; + u64 tx_dis_scram : 16; + } s; + struct cvmx_ilk_lne_dbg_cn68xx { + u64 reserved_60_63 : 4; + u64 tx_bad_crc32 : 1; + u64 tx_bad_6467_cnt : 5; + u64 tx_bad_sync_cnt : 3; + u64 tx_bad_scram_cnt : 3; + u64 reserved_40_47 : 8; + u64 tx_bad_lane_sel : 8; + u64 reserved_24_31 : 8; + u64 tx_dis_dispr : 8; + u64 reserved_8_15 : 8; + u64 tx_dis_scram : 8; + } cn68xx; + struct cvmx_ilk_lne_dbg_cn68xx cn68xxp1; + struct cvmx_ilk_lne_dbg_s cn78xx; + struct cvmx_ilk_lne_dbg_s cn78xxp1; +}; + +typedef union cvmx_ilk_lne_dbg cvmx_ilk_lne_dbg_t; + +/** + * cvmx_ilk_lne_sts_msg + */ +union cvmx_ilk_lne_sts_msg { + u64 u64; + struct cvmx_ilk_lne_sts_msg_s { + u64 rx_lnk_stat : 16; + u64 rx_lne_stat : 16; + u64 tx_lnk_stat : 16; + u64 tx_lne_stat : 16; + } s; + struct cvmx_ilk_lne_sts_msg_cn68xx { + u64 reserved_56_63 : 8; + u64 rx_lnk_stat : 8; + u64 reserved_40_47 : 8; + u64 rx_lne_stat : 8; + u64 reserved_24_31 : 8; + u64 tx_lnk_stat : 8; + u64 reserved_8_15 : 8; + u64 tx_lne_stat : 8; + } cn68xx; + struct cvmx_ilk_lne_sts_msg_cn68xx cn68xxp1; + struct cvmx_ilk_lne_sts_msg_s cn78xx; + struct cvmx_ilk_lne_sts_msg_s cn78xxp1; +}; + +typedef union cvmx_ilk_lne_sts_msg cvmx_ilk_lne_sts_msg_t; + +/** + * cvmx_ilk_rid_cfg + */ +union cvmx_ilk_rid_cfg { + u64 u64; + struct cvmx_ilk_rid_cfg_s { + u64 reserved_39_63 : 25; + u64 max_cnt : 7; + u64 reserved_7_31 : 25; + u64 base : 7; + } s; + struct cvmx_ilk_rid_cfg_s cn78xx; + struct cvmx_ilk_rid_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_rid_cfg cvmx_ilk_rid_cfg_t; + +/** + * cvmx_ilk_rx#_byte_cnt# + */ +union cvmx_ilk_rxx_byte_cntx { + u64 u64; + struct cvmx_ilk_rxx_byte_cntx_s { + u64 reserved_40_63 : 24; + u64 rx_bytes : 40; + } s; + struct cvmx_ilk_rxx_byte_cntx_s cn78xx; + struct cvmx_ilk_rxx_byte_cntx_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_byte_cntx cvmx_ilk_rxx_byte_cntx_t; + +/** + * cvmx_ilk_rx#_cal_entry# + */ +union cvmx_ilk_rxx_cal_entryx { + u64 u64; + struct cvmx_ilk_rxx_cal_entryx_s { + u64 reserved_34_63 : 30; + u64 ctl : 2; + u64 reserved_8_31 : 24; + u64 channel : 8; + } s; + struct cvmx_ilk_rxx_cal_entryx_s cn78xx; + struct cvmx_ilk_rxx_cal_entryx_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_cal_entryx cvmx_ilk_rxx_cal_entryx_t; + +/** + * cvmx_ilk_rx#_cfg0 + */ +union cvmx_ilk_rxx_cfg0 { + u64 u64; + struct cvmx_ilk_rxx_cfg0_s { + u64 ext_lpbk_fc : 1; + u64 ext_lpbk : 1; + u64 reserved_60_61 : 2; + u64 lnk_stats_wrap : 1; + u64 bcw_push : 1; + u64 mproto_ign : 1; + u64 ptrn_mode : 1; + u64 lnk_stats_rdclr : 1; + u64 lnk_stats_ena : 1; + u64 mltuse_fc_ena : 1; + u64 cal_ena : 1; + u64 mfrm_len : 13; + u64 brst_shrt : 7; + u64 lane_rev : 1; + u64 brst_max : 5; + u64 reserved_25_25 : 1; + u64 cal_depth : 9; + u64 lane_ena : 16; + } s; + struct cvmx_ilk_rxx_cfg0_cn68xx { + u64 ext_lpbk_fc : 1; + u64 ext_lpbk : 1; + u64 reserved_60_61 : 2; + u64 lnk_stats_wrap : 1; + u64 bcw_push : 1; + u64 mproto_ign : 1; + u64 ptrn_mode : 1; + u64 lnk_stats_rdclr : 1; + u64 lnk_stats_ena : 1; + u64 mltuse_fc_ena : 1; + u64 cal_ena : 1; + u64 mfrm_len : 13; + u64 brst_shrt : 7; + u64 lane_rev : 1; + u64 brst_max : 5; + u64 reserved_25_25 : 1; + u64 cal_depth : 9; + u64 reserved_8_15 : 8; + u64 lane_ena : 8; + } cn68xx; + struct cvmx_ilk_rxx_cfg0_cn68xxp1 { + u64 ext_lpbk_fc : 1; + u64 ext_lpbk : 1; + u64 reserved_57_61 : 5; + u64 ptrn_mode : 1; + u64 lnk_stats_rdclr : 1; + u64 lnk_stats_ena : 1; + u64 mltuse_fc_ena : 1; + u64 cal_ena : 1; + u64 mfrm_len : 13; + u64 brst_shrt : 7; + u64 lane_rev : 1; + u64 brst_max : 5; + u64 reserved_25_25 : 1; + u64 cal_depth : 9; + u64 reserved_8_15 : 8; + u64 lane_ena : 8; + } cn68xxp1; + struct cvmx_ilk_rxx_cfg0_s cn78xx; + struct cvmx_ilk_rxx_cfg0_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_cfg0 cvmx_ilk_rxx_cfg0_t; + +/** + * cvmx_ilk_rx#_cfg1 + */ +union cvmx_ilk_rxx_cfg1 { + u64 u64; + struct cvmx_ilk_rxx_cfg1_s { + u64 reserved_62_63 : 2; + u64 rx_fifo_cnt : 12; + u64 reserved_49_49 : 1; + u64 rx_fifo_hwm : 13; + u64 reserved_35_35 : 1; + u64 rx_fifo_max : 13; + u64 pkt_flush : 1; + u64 pkt_ena : 1; + u64 la_mode : 1; + u64 tx_link_fc : 1; + u64 rx_link_fc : 1; + u64 rx_align_ena : 1; + u64 rx_bdry_lock_ena : 16; + } s; + struct cvmx_ilk_rxx_cfg1_cn68xx { + u64 reserved_62_63 : 2; + u64 rx_fifo_cnt : 12; + u64 reserved_48_49 : 2; + u64 rx_fifo_hwm : 12; + u64 reserved_34_35 : 2; + u64 rx_fifo_max : 12; + u64 pkt_flush : 1; + u64 pkt_ena : 1; + u64 la_mode : 1; + u64 tx_link_fc : 1; + u64 rx_link_fc : 1; + u64 rx_align_ena : 1; + u64 reserved_8_15 : 8; + u64 rx_bdry_lock_ena : 8; + } cn68xx; + struct cvmx_ilk_rxx_cfg1_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_cfg1_s cn78xx; + struct cvmx_ilk_rxx_cfg1_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_cfg1 cvmx_ilk_rxx_cfg1_t; + +/** + * cvmx_ilk_rx#_cha# + */ +union cvmx_ilk_rxx_chax { + u64 u64; + struct cvmx_ilk_rxx_chax_s { + u64 reserved_6_63 : 58; + u64 port_kind : 6; + } s; + struct cvmx_ilk_rxx_chax_s cn78xx; + struct cvmx_ilk_rxx_chax_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_chax cvmx_ilk_rxx_chax_t; + +/** + * cvmx_ilk_rx#_cha_xon# + */ +union cvmx_ilk_rxx_cha_xonx { + u64 u64; + struct cvmx_ilk_rxx_cha_xonx_s { + u64 xon : 64; + } s; + struct cvmx_ilk_rxx_cha_xonx_s cn78xx; + struct cvmx_ilk_rxx_cha_xonx_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_cha_xonx cvmx_ilk_rxx_cha_xonx_t; + +/** + * cvmx_ilk_rx#_err_cfg + */ +union cvmx_ilk_rxx_err_cfg { + u64 u64; + struct cvmx_ilk_rxx_err_cfg_s { + u64 reserved_20_63 : 44; + u64 fwc_flip : 2; + u64 pmap_flip : 2; + u64 reserved_2_15 : 14; + u64 fwc_cor_dis : 1; + u64 pmap_cor_dis : 1; + } s; + struct cvmx_ilk_rxx_err_cfg_s cn78xx; + struct cvmx_ilk_rxx_err_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_err_cfg cvmx_ilk_rxx_err_cfg_t; + +/** + * cvmx_ilk_rx#_flow_ctl0 + */ +union cvmx_ilk_rxx_flow_ctl0 { + u64 u64; + struct cvmx_ilk_rxx_flow_ctl0_s { + u64 status : 64; + } s; + struct cvmx_ilk_rxx_flow_ctl0_s cn68xx; + struct cvmx_ilk_rxx_flow_ctl0_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_flow_ctl0 cvmx_ilk_rxx_flow_ctl0_t; + +/** + * cvmx_ilk_rx#_flow_ctl1 + */ +union cvmx_ilk_rxx_flow_ctl1 { + u64 u64; + struct cvmx_ilk_rxx_flow_ctl1_s { + u64 status : 64; + } s; + struct cvmx_ilk_rxx_flow_ctl1_s cn68xx; + struct cvmx_ilk_rxx_flow_ctl1_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_flow_ctl1 cvmx_ilk_rxx_flow_ctl1_t; + +/** + * cvmx_ilk_rx#_idx_cal + */ +union cvmx_ilk_rxx_idx_cal { + u64 u64; + struct cvmx_ilk_rxx_idx_cal_s { + u64 reserved_14_63 : 50; + u64 inc : 6; + u64 reserved_6_7 : 2; + u64 index : 6; + } s; + struct cvmx_ilk_rxx_idx_cal_s cn68xx; + struct cvmx_ilk_rxx_idx_cal_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_idx_cal cvmx_ilk_rxx_idx_cal_t; + +/** + * cvmx_ilk_rx#_idx_stat0 + */ +union cvmx_ilk_rxx_idx_stat0 { + u64 u64; + struct cvmx_ilk_rxx_idx_stat0_s { + u64 reserved_32_63 : 32; + u64 clr : 1; + u64 reserved_24_30 : 7; + u64 inc : 8; + u64 reserved_8_15 : 8; + u64 index : 8; + } s; + struct cvmx_ilk_rxx_idx_stat0_s cn68xx; + struct cvmx_ilk_rxx_idx_stat0_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_idx_stat0 cvmx_ilk_rxx_idx_stat0_t; + +/** + * cvmx_ilk_rx#_idx_stat1 + */ +union cvmx_ilk_rxx_idx_stat1 { + u64 u64; + struct cvmx_ilk_rxx_idx_stat1_s { + u64 reserved_32_63 : 32; + u64 clr : 1; + u64 reserved_24_30 : 7; + u64 inc : 8; + u64 reserved_8_15 : 8; + u64 index : 8; + } s; + struct cvmx_ilk_rxx_idx_stat1_s cn68xx; + struct cvmx_ilk_rxx_idx_stat1_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_idx_stat1 cvmx_ilk_rxx_idx_stat1_t; + +/** + * cvmx_ilk_rx#_int + */ +union cvmx_ilk_rxx_int { + u64 u64; + struct cvmx_ilk_rxx_int_s { + u64 reserved_13_63 : 51; + u64 pmap_dbe : 1; + u64 pmap_sbe : 1; + u64 fwc_dbe : 1; + u64 fwc_sbe : 1; + u64 pkt_drop_sop : 1; + u64 pkt_drop_rid : 1; + u64 pkt_drop_rxf : 1; + u64 lane_bad_word : 1; + u64 stat_cnt_ovfl : 1; + u64 lane_align_done : 1; + u64 word_sync_done : 1; + u64 crc24_err : 1; + u64 lane_align_fail : 1; + } s; + struct cvmx_ilk_rxx_int_cn68xx { + u64 reserved_9_63 : 55; + u64 pkt_drop_sop : 1; + u64 pkt_drop_rid : 1; + u64 pkt_drop_rxf : 1; + u64 lane_bad_word : 1; + u64 stat_cnt_ovfl : 1; + u64 lane_align_done : 1; + u64 word_sync_done : 1; + u64 crc24_err : 1; + u64 lane_align_fail : 1; + } cn68xx; + struct cvmx_ilk_rxx_int_cn68xxp1 { + u64 reserved_8_63 : 56; + u64 pkt_drop_rid : 1; + u64 pkt_drop_rxf : 1; + u64 lane_bad_word : 1; + u64 stat_cnt_ovfl : 1; + u64 lane_align_done : 1; + u64 word_sync_done : 1; + u64 crc24_err : 1; + u64 lane_align_fail : 1; + } cn68xxp1; + struct cvmx_ilk_rxx_int_s cn78xx; + struct cvmx_ilk_rxx_int_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_int cvmx_ilk_rxx_int_t; + +/** + * cvmx_ilk_rx#_int_en + */ +union cvmx_ilk_rxx_int_en { + u64 u64; + struct cvmx_ilk_rxx_int_en_s { + u64 reserved_9_63 : 55; + u64 pkt_drop_sop : 1; + u64 pkt_drop_rid : 1; + u64 pkt_drop_rxf : 1; + u64 lane_bad_word : 1; + u64 stat_cnt_ovfl : 1; + u64 lane_align_done : 1; + u64 word_sync_done : 1; + u64 crc24_err : 1; + u64 lane_align_fail : 1; + } s; + struct cvmx_ilk_rxx_int_en_s cn68xx; + struct cvmx_ilk_rxx_int_en_cn68xxp1 { + u64 reserved_8_63 : 56; + u64 pkt_drop_rid : 1; + u64 pkt_drop_rxf : 1; + u64 lane_bad_word : 1; + u64 stat_cnt_ovfl : 1; + u64 lane_align_done : 1; + u64 word_sync_done : 1; + u64 crc24_err : 1; + u64 lane_align_fail : 1; + } cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_int_en cvmx_ilk_rxx_int_en_t; + +/** + * cvmx_ilk_rx#_jabber + */ +union cvmx_ilk_rxx_jabber { + u64 u64; + struct cvmx_ilk_rxx_jabber_s { + u64 reserved_16_63 : 48; + u64 cnt : 16; + } s; + struct cvmx_ilk_rxx_jabber_s cn68xx; + struct cvmx_ilk_rxx_jabber_s cn68xxp1; + struct cvmx_ilk_rxx_jabber_s cn78xx; + struct cvmx_ilk_rxx_jabber_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_jabber cvmx_ilk_rxx_jabber_t; + +/** + * cvmx_ilk_rx#_mem_cal0 + * + * Notes: + * Software must program the calendar table prior to enabling the + * link. + * + * Software must always write ILK_RXx_MEM_CAL0 then ILK_RXx_MEM_CAL1. + * Software must never write them in reverse order or write one without + * writing the other. + * + * A given calendar table entry has no effect on PKO pipe + * backpressure when either: + * - ENTRY_CTLx=Link (1), or + * - ENTRY_CTLx=XON (3) and PORT_PIPEx is outside the range of ILK_TXx_PIPE[BASE/NUMP]. + * + * Within the 8 calendar table entries of one IDX value, if more + * than one affects the same PKO pipe, XOFF always wins over XON, + * regardless of the calendar table order. + * + * Software must always read ILK_RXx_MEM_CAL0 then ILK_RXx_MEM_CAL1. Software + * must never read them in reverse order or read one without reading the + * other. + */ +union cvmx_ilk_rxx_mem_cal0 { + u64 u64; + struct cvmx_ilk_rxx_mem_cal0_s { + u64 reserved_36_63 : 28; + u64 entry_ctl3 : 2; + u64 port_pipe3 : 7; + u64 entry_ctl2 : 2; + u64 port_pipe2 : 7; + u64 entry_ctl1 : 2; + u64 port_pipe1 : 7; + u64 entry_ctl0 : 2; + u64 port_pipe0 : 7; + } s; + struct cvmx_ilk_rxx_mem_cal0_s cn68xx; + struct cvmx_ilk_rxx_mem_cal0_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_mem_cal0 cvmx_ilk_rxx_mem_cal0_t; + +/** + * cvmx_ilk_rx#_mem_cal1 + * + * Notes: + * Software must program the calendar table prior to enabling the + * link. + * + * Software must always write ILK_RXx_MEM_CAL0 then ILK_RXx_MEM_CAL1. + * Software must never write them in reverse order or write one without + * writing the other. + * + * A given calendar table entry has no effect on PKO pipe + * backpressure when either: + * - ENTRY_CTLx=Link (1), or + * - ENTRY_CTLx=XON (3) and PORT_PIPEx is outside the range of ILK_TXx_PIPE[BASE/NUMP]. + * + * Within the 8 calendar table entries of one IDX value, if more + * than one affects the same PKO pipe, XOFF always wins over XON, + * regardless of the calendar table order. + * + * Software must always read ILK_RXx_MEM_CAL0 then ILK_Rx_MEM_CAL1. Software + * must never read them in reverse order or read one without reading the + * other. + */ +union cvmx_ilk_rxx_mem_cal1 { + u64 u64; + struct cvmx_ilk_rxx_mem_cal1_s { + u64 reserved_36_63 : 28; + u64 entry_ctl7 : 2; + u64 port_pipe7 : 7; + u64 entry_ctl6 : 2; + u64 port_pipe6 : 7; + u64 entry_ctl5 : 2; + u64 port_pipe5 : 7; + u64 entry_ctl4 : 2; + u64 port_pipe4 : 7; + } s; + struct cvmx_ilk_rxx_mem_cal1_s cn68xx; + struct cvmx_ilk_rxx_mem_cal1_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_mem_cal1 cvmx_ilk_rxx_mem_cal1_t; + +/** + * cvmx_ilk_rx#_mem_stat0 + */ +union cvmx_ilk_rxx_mem_stat0 { + u64 u64; + struct cvmx_ilk_rxx_mem_stat0_s { + u64 reserved_28_63 : 36; + u64 rx_pkt : 28; + } s; + struct cvmx_ilk_rxx_mem_stat0_s cn68xx; + struct cvmx_ilk_rxx_mem_stat0_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_mem_stat0 cvmx_ilk_rxx_mem_stat0_t; + +/** + * cvmx_ilk_rx#_mem_stat1 + */ +union cvmx_ilk_rxx_mem_stat1 { + u64 u64; + struct cvmx_ilk_rxx_mem_stat1_s { + u64 reserved_36_63 : 28; + u64 rx_bytes : 36; + } s; + struct cvmx_ilk_rxx_mem_stat1_s cn68xx; + struct cvmx_ilk_rxx_mem_stat1_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxx_mem_stat1 cvmx_ilk_rxx_mem_stat1_t; + +/** + * cvmx_ilk_rx#_pkt_cnt# + */ +union cvmx_ilk_rxx_pkt_cntx { + u64 u64; + struct cvmx_ilk_rxx_pkt_cntx_s { + u64 reserved_34_63 : 30; + u64 rx_pkt : 34; + } s; + struct cvmx_ilk_rxx_pkt_cntx_s cn78xx; + struct cvmx_ilk_rxx_pkt_cntx_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_pkt_cntx cvmx_ilk_rxx_pkt_cntx_t; + +/** + * cvmx_ilk_rx#_rid + */ +union cvmx_ilk_rxx_rid { + u64 u64; + struct cvmx_ilk_rxx_rid_s { + u64 reserved_7_63 : 57; + u64 max_cnt : 7; + } s; + struct cvmx_ilk_rxx_rid_cn68xx { + u64 reserved_6_63 : 58; + u64 max_cnt : 6; + } cn68xx; + struct cvmx_ilk_rxx_rid_s cn78xx; + struct cvmx_ilk_rxx_rid_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_rid cvmx_ilk_rxx_rid_t; + +/** + * cvmx_ilk_rx#_stat0 + */ +union cvmx_ilk_rxx_stat0 { + u64 u64; + struct cvmx_ilk_rxx_stat0_s { + u64 reserved_35_63 : 29; + u64 crc24_match_cnt : 35; + } s; + struct cvmx_ilk_rxx_stat0_cn68xx { + u64 reserved_33_63 : 31; + u64 crc24_match_cnt : 33; + } cn68xx; + struct cvmx_ilk_rxx_stat0_cn68xxp1 { + u64 reserved_27_63 : 37; + u64 crc24_match_cnt : 27; + } cn68xxp1; + struct cvmx_ilk_rxx_stat0_s cn78xx; + struct cvmx_ilk_rxx_stat0_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat0 cvmx_ilk_rxx_stat0_t; + +/** + * cvmx_ilk_rx#_stat1 + */ +union cvmx_ilk_rxx_stat1 { + u64 u64; + struct cvmx_ilk_rxx_stat1_s { + u64 reserved_20_63 : 44; + u64 crc24_err_cnt : 20; + } s; + struct cvmx_ilk_rxx_stat1_cn68xx { + u64 reserved_18_63 : 46; + u64 crc24_err_cnt : 18; + } cn68xx; + struct cvmx_ilk_rxx_stat1_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_stat1_s cn78xx; + struct cvmx_ilk_rxx_stat1_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat1 cvmx_ilk_rxx_stat1_t; + +/** + * cvmx_ilk_rx#_stat2 + */ +union cvmx_ilk_rxx_stat2 { + u64 u64; + struct cvmx_ilk_rxx_stat2_s { + u64 reserved_50_63 : 14; + u64 brst_not_full_cnt : 18; + u64 reserved_30_31 : 2; + u64 brst_cnt : 30; + } s; + struct cvmx_ilk_rxx_stat2_cn68xx { + u64 reserved_48_63 : 16; + u64 brst_not_full_cnt : 16; + u64 reserved_28_31 : 4; + u64 brst_cnt : 28; + } cn68xx; + struct cvmx_ilk_rxx_stat2_cn68xxp1 { + u64 reserved_48_63 : 16; + u64 brst_not_full_cnt : 16; + u64 reserved_16_31 : 16; + u64 brst_cnt : 16; + } cn68xxp1; + struct cvmx_ilk_rxx_stat2_s cn78xx; + struct cvmx_ilk_rxx_stat2_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat2 cvmx_ilk_rxx_stat2_t; + +/** + * cvmx_ilk_rx#_stat3 + */ +union cvmx_ilk_rxx_stat3 { + u64 u64; + struct cvmx_ilk_rxx_stat3_s { + u64 reserved_18_63 : 46; + u64 brst_max_err_cnt : 18; + } s; + struct cvmx_ilk_rxx_stat3_cn68xx { + u64 reserved_16_63 : 48; + u64 brst_max_err_cnt : 16; + } cn68xx; + struct cvmx_ilk_rxx_stat3_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_stat3_s cn78xx; + struct cvmx_ilk_rxx_stat3_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat3 cvmx_ilk_rxx_stat3_t; + +/** + * cvmx_ilk_rx#_stat4 + */ +union cvmx_ilk_rxx_stat4 { + u64 u64; + struct cvmx_ilk_rxx_stat4_s { + u64 reserved_18_63 : 46; + u64 brst_shrt_err_cnt : 18; + } s; + struct cvmx_ilk_rxx_stat4_cn68xx { + u64 reserved_16_63 : 48; + u64 brst_shrt_err_cnt : 16; + } cn68xx; + struct cvmx_ilk_rxx_stat4_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_stat4_s cn78xx; + struct cvmx_ilk_rxx_stat4_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat4 cvmx_ilk_rxx_stat4_t; + +/** + * cvmx_ilk_rx#_stat5 + */ +union cvmx_ilk_rxx_stat5 { + u64 u64; + struct cvmx_ilk_rxx_stat5_s { + u64 reserved_25_63 : 39; + u64 align_cnt : 25; + } s; + struct cvmx_ilk_rxx_stat5_cn68xx { + u64 reserved_23_63 : 41; + u64 align_cnt : 23; + } cn68xx; + struct cvmx_ilk_rxx_stat5_cn68xxp1 { + u64 reserved_16_63 : 48; + u64 align_cnt : 16; + } cn68xxp1; + struct cvmx_ilk_rxx_stat5_s cn78xx; + struct cvmx_ilk_rxx_stat5_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat5 cvmx_ilk_rxx_stat5_t; + +/** + * cvmx_ilk_rx#_stat6 + */ +union cvmx_ilk_rxx_stat6 { + u64 u64; + struct cvmx_ilk_rxx_stat6_s { + u64 reserved_18_63 : 46; + u64 align_err_cnt : 18; + } s; + struct cvmx_ilk_rxx_stat6_cn68xx { + u64 reserved_16_63 : 48; + u64 align_err_cnt : 16; + } cn68xx; + struct cvmx_ilk_rxx_stat6_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_stat6_s cn78xx; + struct cvmx_ilk_rxx_stat6_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat6 cvmx_ilk_rxx_stat6_t; + +/** + * cvmx_ilk_rx#_stat7 + */ +union cvmx_ilk_rxx_stat7 { + u64 u64; + struct cvmx_ilk_rxx_stat7_s { + u64 reserved_18_63 : 46; + u64 bad_64b67b_cnt : 18; + } s; + struct cvmx_ilk_rxx_stat7_cn68xx { + u64 reserved_16_63 : 48; + u64 bad_64b67b_cnt : 16; + } cn68xx; + struct cvmx_ilk_rxx_stat7_cn68xx cn68xxp1; + struct cvmx_ilk_rxx_stat7_s cn78xx; + struct cvmx_ilk_rxx_stat7_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat7 cvmx_ilk_rxx_stat7_t; + +/** + * cvmx_ilk_rx#_stat8 + */ +union cvmx_ilk_rxx_stat8 { + u64 u64; + struct cvmx_ilk_rxx_stat8_s { + u64 reserved_32_63 : 32; + u64 pkt_drop_rid_cnt : 16; + u64 pkt_drop_rxf_cnt : 16; + } s; + struct cvmx_ilk_rxx_stat8_s cn68xx; + struct cvmx_ilk_rxx_stat8_s cn68xxp1; + struct cvmx_ilk_rxx_stat8_s cn78xx; + struct cvmx_ilk_rxx_stat8_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat8 cvmx_ilk_rxx_stat8_t; + +/** + * cvmx_ilk_rx#_stat9 + * + * This register is reserved. + * + */ +union cvmx_ilk_rxx_stat9 { + u64 u64; + struct cvmx_ilk_rxx_stat9_s { + u64 reserved_0_63 : 64; + } s; + struct cvmx_ilk_rxx_stat9_s cn68xx; + struct cvmx_ilk_rxx_stat9_s cn68xxp1; + struct cvmx_ilk_rxx_stat9_s cn78xx; + struct cvmx_ilk_rxx_stat9_s cn78xxp1; +}; + +typedef union cvmx_ilk_rxx_stat9 cvmx_ilk_rxx_stat9_t; + +/** + * cvmx_ilk_rx_lne#_cfg + */ +union cvmx_ilk_rx_lnex_cfg { + u64 u64; + struct cvmx_ilk_rx_lnex_cfg_s { + u64 reserved_9_63 : 55; + u64 rx_dis_psh_skip : 1; + u64 reserved_7_7 : 1; + u64 rx_dis_disp_chk : 1; + u64 rx_scrm_sync : 1; + u64 rx_bdry_sync : 1; + u64 rx_dis_ukwn : 1; + u64 rx_dis_scram : 1; + u64 stat_rdclr : 1; + u64 stat_ena : 1; + } s; + struct cvmx_ilk_rx_lnex_cfg_cn68xx { + u64 reserved_9_63 : 55; + u64 rx_dis_psh_skip : 1; + u64 reserved_6_7 : 2; + u64 rx_scrm_sync : 1; + u64 rx_bdry_sync : 1; + u64 rx_dis_ukwn : 1; + u64 rx_dis_scram : 1; + u64 stat_rdclr : 1; + u64 stat_ena : 1; + } cn68xx; + struct cvmx_ilk_rx_lnex_cfg_cn68xxp1 { + u64 reserved_5_63 : 59; + u64 rx_bdry_sync : 1; + u64 rx_dis_ukwn : 1; + u64 rx_dis_scram : 1; + u64 stat_rdclr : 1; + u64 stat_ena : 1; + } cn68xxp1; + struct cvmx_ilk_rx_lnex_cfg_s cn78xx; + struct cvmx_ilk_rx_lnex_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_cfg cvmx_ilk_rx_lnex_cfg_t; + +/** + * cvmx_ilk_rx_lne#_int + */ +union cvmx_ilk_rx_lnex_int { + u64 u64; + struct cvmx_ilk_rx_lnex_int_s { + u64 reserved_10_63 : 54; + u64 disp_err : 1; + u64 bad_64b67b : 1; + u64 stat_cnt_ovfl : 1; + u64 stat_msg : 1; + u64 dskew_fifo_ovfl : 1; + u64 scrm_sync_loss : 1; + u64 ukwn_cntl_word : 1; + u64 crc32_err : 1; + u64 bdry_sync_loss : 1; + u64 serdes_lock_loss : 1; + } s; + struct cvmx_ilk_rx_lnex_int_cn68xx { + u64 reserved_9_63 : 55; + u64 bad_64b67b : 1; + u64 stat_cnt_ovfl : 1; + u64 stat_msg : 1; + u64 dskew_fifo_ovfl : 1; + u64 scrm_sync_loss : 1; + u64 ukwn_cntl_word : 1; + u64 crc32_err : 1; + u64 bdry_sync_loss : 1; + u64 serdes_lock_loss : 1; + } cn68xx; + struct cvmx_ilk_rx_lnex_int_cn68xx cn68xxp1; + struct cvmx_ilk_rx_lnex_int_s cn78xx; + struct cvmx_ilk_rx_lnex_int_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_int cvmx_ilk_rx_lnex_int_t; + +/** + * cvmx_ilk_rx_lne#_int_en + */ +union cvmx_ilk_rx_lnex_int_en { + u64 u64; + struct cvmx_ilk_rx_lnex_int_en_s { + u64 reserved_9_63 : 55; + u64 bad_64b67b : 1; + u64 stat_cnt_ovfl : 1; + u64 stat_msg : 1; + u64 dskew_fifo_ovfl : 1; + u64 scrm_sync_loss : 1; + u64 ukwn_cntl_word : 1; + u64 crc32_err : 1; + u64 bdry_sync_loss : 1; + u64 serdes_lock_loss : 1; + } s; + struct cvmx_ilk_rx_lnex_int_en_s cn68xx; + struct cvmx_ilk_rx_lnex_int_en_s cn68xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_int_en cvmx_ilk_rx_lnex_int_en_t; + +/** + * cvmx_ilk_rx_lne#_stat0 + */ +union cvmx_ilk_rx_lnex_stat0 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat0_s { + u64 reserved_18_63 : 46; + u64 ser_lock_loss_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat0_s cn68xx; + struct cvmx_ilk_rx_lnex_stat0_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat0_s cn78xx; + struct cvmx_ilk_rx_lnex_stat0_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat0 cvmx_ilk_rx_lnex_stat0_t; + +/** + * cvmx_ilk_rx_lne#_stat1 + */ +union cvmx_ilk_rx_lnex_stat1 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat1_s { + u64 reserved_18_63 : 46; + u64 bdry_sync_loss_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat1_s cn68xx; + struct cvmx_ilk_rx_lnex_stat1_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat1_s cn78xx; + struct cvmx_ilk_rx_lnex_stat1_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat1 cvmx_ilk_rx_lnex_stat1_t; + +/** + * cvmx_ilk_rx_lne#_stat10 + */ +union cvmx_ilk_rx_lnex_stat10 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat10_s { + u64 reserved_43_63 : 21; + u64 prbs_bad : 11; + u64 reserved_11_31 : 21; + u64 prbs_good : 11; + } s; + struct cvmx_ilk_rx_lnex_stat10_s cn78xx; + struct cvmx_ilk_rx_lnex_stat10_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat10 cvmx_ilk_rx_lnex_stat10_t; + +/** + * cvmx_ilk_rx_lne#_stat2 + */ +union cvmx_ilk_rx_lnex_stat2 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat2_s { + u64 reserved_50_63 : 14; + u64 syncw_good_cnt : 18; + u64 reserved_18_31 : 14; + u64 syncw_bad_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat2_s cn68xx; + struct cvmx_ilk_rx_lnex_stat2_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat2_s cn78xx; + struct cvmx_ilk_rx_lnex_stat2_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat2 cvmx_ilk_rx_lnex_stat2_t; + +/** + * cvmx_ilk_rx_lne#_stat3 + */ +union cvmx_ilk_rx_lnex_stat3 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat3_s { + u64 reserved_18_63 : 46; + u64 bad_64b67b_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat3_s cn68xx; + struct cvmx_ilk_rx_lnex_stat3_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat3_s cn78xx; + struct cvmx_ilk_rx_lnex_stat3_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat3 cvmx_ilk_rx_lnex_stat3_t; + +/** + * cvmx_ilk_rx_lne#_stat4 + */ +union cvmx_ilk_rx_lnex_stat4 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat4_s { + u64 reserved_59_63 : 5; + u64 cntl_word_cnt : 27; + u64 reserved_27_31 : 5; + u64 data_word_cnt : 27; + } s; + struct cvmx_ilk_rx_lnex_stat4_s cn68xx; + struct cvmx_ilk_rx_lnex_stat4_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat4_s cn78xx; + struct cvmx_ilk_rx_lnex_stat4_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat4 cvmx_ilk_rx_lnex_stat4_t; + +/** + * cvmx_ilk_rx_lne#_stat5 + */ +union cvmx_ilk_rx_lnex_stat5 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat5_s { + u64 reserved_18_63 : 46; + u64 unkwn_word_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat5_s cn68xx; + struct cvmx_ilk_rx_lnex_stat5_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat5_s cn78xx; + struct cvmx_ilk_rx_lnex_stat5_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat5 cvmx_ilk_rx_lnex_stat5_t; + +/** + * cvmx_ilk_rx_lne#_stat6 + */ +union cvmx_ilk_rx_lnex_stat6 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat6_s { + u64 reserved_18_63 : 46; + u64 scrm_sync_loss_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat6_s cn68xx; + struct cvmx_ilk_rx_lnex_stat6_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat6_s cn78xx; + struct cvmx_ilk_rx_lnex_stat6_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat6 cvmx_ilk_rx_lnex_stat6_t; + +/** + * cvmx_ilk_rx_lne#_stat7 + */ +union cvmx_ilk_rx_lnex_stat7 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat7_s { + u64 reserved_18_63 : 46; + u64 scrm_match_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat7_s cn68xx; + struct cvmx_ilk_rx_lnex_stat7_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat7_s cn78xx; + struct cvmx_ilk_rx_lnex_stat7_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat7 cvmx_ilk_rx_lnex_stat7_t; + +/** + * cvmx_ilk_rx_lne#_stat8 + */ +union cvmx_ilk_rx_lnex_stat8 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat8_s { + u64 reserved_18_63 : 46; + u64 skipw_good_cnt : 18; + } s; + struct cvmx_ilk_rx_lnex_stat8_s cn68xx; + struct cvmx_ilk_rx_lnex_stat8_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat8_s cn78xx; + struct cvmx_ilk_rx_lnex_stat8_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat8 cvmx_ilk_rx_lnex_stat8_t; + +/** + * cvmx_ilk_rx_lne#_stat9 + */ +union cvmx_ilk_rx_lnex_stat9 { + u64 u64; + struct cvmx_ilk_rx_lnex_stat9_s { + u64 reserved_50_63 : 14; + u64 crc32_err_cnt : 18; + u64 reserved_27_31 : 5; + u64 crc32_match_cnt : 27; + } s; + struct cvmx_ilk_rx_lnex_stat9_s cn68xx; + struct cvmx_ilk_rx_lnex_stat9_s cn68xxp1; + struct cvmx_ilk_rx_lnex_stat9_s cn78xx; + struct cvmx_ilk_rx_lnex_stat9_s cn78xxp1; +}; + +typedef union cvmx_ilk_rx_lnex_stat9 cvmx_ilk_rx_lnex_stat9_t; + +/** + * cvmx_ilk_rxf_idx_pmap + */ +union cvmx_ilk_rxf_idx_pmap { + u64 u64; + struct cvmx_ilk_rxf_idx_pmap_s { + u64 reserved_25_63 : 39; + u64 inc : 9; + u64 reserved_9_15 : 7; + u64 index : 9; + } s; + struct cvmx_ilk_rxf_idx_pmap_s cn68xx; + struct cvmx_ilk_rxf_idx_pmap_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxf_idx_pmap cvmx_ilk_rxf_idx_pmap_t; + +/** + * cvmx_ilk_rxf_mem_pmap + */ +union cvmx_ilk_rxf_mem_pmap { + u64 u64; + struct cvmx_ilk_rxf_mem_pmap_s { + u64 reserved_6_63 : 58; + u64 port_kind : 6; + } s; + struct cvmx_ilk_rxf_mem_pmap_s cn68xx; + struct cvmx_ilk_rxf_mem_pmap_s cn68xxp1; +}; + +typedef union cvmx_ilk_rxf_mem_pmap cvmx_ilk_rxf_mem_pmap_t; + +/** + * cvmx_ilk_ser_cfg + */ +union cvmx_ilk_ser_cfg { + u64 u64; + struct cvmx_ilk_ser_cfg_s { + u64 reserved_57_63 : 7; + u64 ser_rxpol_auto : 1; + u64 ser_rxpol : 16; + u64 ser_txpol : 16; + u64 ser_reset_n : 16; + u64 ser_pwrup : 4; + u64 ser_haul : 4; + } s; + struct cvmx_ilk_ser_cfg_cn68xx { + u64 reserved_57_63 : 7; + u64 ser_rxpol_auto : 1; + u64 reserved_48_55 : 8; + u64 ser_rxpol : 8; + u64 reserved_32_39 : 8; + u64 ser_txpol : 8; + u64 reserved_16_23 : 8; + u64 ser_reset_n : 8; + u64 reserved_6_7 : 2; + u64 ser_pwrup : 2; + u64 reserved_2_3 : 2; + u64 ser_haul : 2; + } cn68xx; + struct cvmx_ilk_ser_cfg_cn68xx cn68xxp1; + struct cvmx_ilk_ser_cfg_s cn78xx; + struct cvmx_ilk_ser_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_ser_cfg cvmx_ilk_ser_cfg_t; + +/** + * cvmx_ilk_tx#_byte_cnt# + */ +union cvmx_ilk_txx_byte_cntx { + u64 u64; + struct cvmx_ilk_txx_byte_cntx_s { + u64 reserved_40_63 : 24; + u64 tx_bytes : 40; + } s; + struct cvmx_ilk_txx_byte_cntx_s cn78xx; + struct cvmx_ilk_txx_byte_cntx_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_byte_cntx cvmx_ilk_txx_byte_cntx_t; + +/** + * cvmx_ilk_tx#_cal_entry# + */ +union cvmx_ilk_txx_cal_entryx { + u64 u64; + struct cvmx_ilk_txx_cal_entryx_s { + u64 reserved_34_63 : 30; + u64 ctl : 2; + u64 reserved_8_31 : 24; + u64 channel : 8; + } s; + struct cvmx_ilk_txx_cal_entryx_s cn78xx; + struct cvmx_ilk_txx_cal_entryx_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_cal_entryx cvmx_ilk_txx_cal_entryx_t; + +/** + * cvmx_ilk_tx#_cfg0 + */ +union cvmx_ilk_txx_cfg0 { + u64 u64; + struct cvmx_ilk_txx_cfg0_s { + u64 ext_lpbk_fc : 1; + u64 ext_lpbk : 1; + u64 int_lpbk : 1; + u64 txf_byp_dis : 1; + u64 reserved_57_59 : 3; + u64 ptrn_mode : 1; + u64 lnk_stats_rdclr : 1; + u64 lnk_stats_ena : 1; + u64 mltuse_fc_ena : 1; + u64 cal_ena : 1; + u64 mfrm_len : 13; + u64 brst_shrt : 7; + u64 lane_rev : 1; + u64 brst_max : 5; + u64 reserved_25_25 : 1; + u64 cal_depth : 9; + u64 lane_ena : 16; + } s; + struct cvmx_ilk_txx_cfg0_cn68xx { + u64 ext_lpbk_fc : 1; + u64 ext_lpbk : 1; + u64 int_lpbk : 1; + u64 reserved_57_60 : 4; + u64 ptrn_mode : 1; + u64 reserved_55_55 : 1; + u64 lnk_stats_ena : 1; + u64 mltuse_fc_ena : 1; + u64 cal_ena : 1; + u64 mfrm_len : 13; + u64 brst_shrt : 7; + u64 lane_rev : 1; + u64 brst_max : 5; + u64 reserved_25_25 : 1; + u64 cal_depth : 9; + u64 reserved_8_15 : 8; + u64 lane_ena : 8; + } cn68xx; + struct cvmx_ilk_txx_cfg0_cn68xx cn68xxp1; + struct cvmx_ilk_txx_cfg0_s cn78xx; + struct cvmx_ilk_txx_cfg0_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_cfg0 cvmx_ilk_txx_cfg0_t; + +/** + * cvmx_ilk_tx#_cfg1 + */ +union cvmx_ilk_txx_cfg1 { + u64 u64; + struct cvmx_ilk_txx_cfg1_s { + u64 ser_low : 4; + u64 reserved_53_59 : 7; + u64 brst_min : 5; + u64 reserved_43_47 : 5; + u64 ser_limit : 10; + u64 pkt_busy : 1; + u64 pipe_crd_dis : 1; + u64 ptp_delay : 5; + u64 skip_cnt : 4; + u64 pkt_flush : 1; + u64 pkt_ena : 1; + u64 la_mode : 1; + u64 tx_link_fc : 1; + u64 rx_link_fc : 1; + u64 reserved_12_16 : 5; + u64 tx_link_fc_jam : 1; + u64 rx_link_fc_pkt : 1; + u64 rx_link_fc_ign : 1; + u64 rmatch : 1; + u64 tx_mltuse : 8; + } s; + struct cvmx_ilk_txx_cfg1_cn68xx { + u64 reserved_33_63 : 31; + u64 pkt_busy : 1; + u64 pipe_crd_dis : 1; + u64 ptp_delay : 5; + u64 skip_cnt : 4; + u64 pkt_flush : 1; + u64 pkt_ena : 1; + u64 la_mode : 1; + u64 tx_link_fc : 1; + u64 rx_link_fc : 1; + u64 reserved_12_16 : 5; + u64 tx_link_fc_jam : 1; + u64 rx_link_fc_pkt : 1; + u64 rx_link_fc_ign : 1; + u64 rmatch : 1; + u64 tx_mltuse : 8; + } cn68xx; + struct cvmx_ilk_txx_cfg1_cn68xxp1 { + u64 reserved_32_63 : 32; + u64 pipe_crd_dis : 1; + u64 ptp_delay : 5; + u64 skip_cnt : 4; + u64 pkt_flush : 1; + u64 pkt_ena : 1; + u64 la_mode : 1; + u64 tx_link_fc : 1; + u64 rx_link_fc : 1; + u64 reserved_12_16 : 5; + u64 tx_link_fc_jam : 1; + u64 rx_link_fc_pkt : 1; + u64 rx_link_fc_ign : 1; + u64 rmatch : 1; + u64 tx_mltuse : 8; + } cn68xxp1; + struct cvmx_ilk_txx_cfg1_s cn78xx; + struct cvmx_ilk_txx_cfg1_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_cfg1 cvmx_ilk_txx_cfg1_t; + +/** + * cvmx_ilk_tx#_cha_xon# + */ +union cvmx_ilk_txx_cha_xonx { + u64 u64; + struct cvmx_ilk_txx_cha_xonx_s { + u64 status : 64; + } s; + struct cvmx_ilk_txx_cha_xonx_s cn78xx; + struct cvmx_ilk_txx_cha_xonx_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_cha_xonx cvmx_ilk_txx_cha_xonx_t; + +/** + * cvmx_ilk_tx#_dbg + */ +union cvmx_ilk_txx_dbg { + u64 u64; + struct cvmx_ilk_txx_dbg_s { + u64 reserved_29_63 : 35; + u64 data_rate : 13; + u64 low_delay : 6; + u64 reserved_3_9 : 7; + u64 tx_bad_crc24 : 1; + u64 tx_bad_ctlw2 : 1; + u64 tx_bad_ctlw1 : 1; + } s; + struct cvmx_ilk_txx_dbg_cn68xx { + u64 reserved_3_63 : 61; + u64 tx_bad_crc24 : 1; + u64 tx_bad_ctlw2 : 1; + u64 tx_bad_ctlw1 : 1; + } cn68xx; + struct cvmx_ilk_txx_dbg_cn68xx cn68xxp1; + struct cvmx_ilk_txx_dbg_s cn78xx; + struct cvmx_ilk_txx_dbg_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_dbg cvmx_ilk_txx_dbg_t; + +/** + * cvmx_ilk_tx#_err_cfg + */ +union cvmx_ilk_txx_err_cfg { + u64 u64; + struct cvmx_ilk_txx_err_cfg_s { + u64 reserved_20_63 : 44; + u64 fwc_flip : 2; + u64 txf_flip : 2; + u64 reserved_2_15 : 14; + u64 fwc_cor_dis : 1; + u64 txf_cor_dis : 1; + } s; + struct cvmx_ilk_txx_err_cfg_s cn78xx; + struct cvmx_ilk_txx_err_cfg_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_err_cfg cvmx_ilk_txx_err_cfg_t; + +/** + * cvmx_ilk_tx#_flow_ctl0 + */ +union cvmx_ilk_txx_flow_ctl0 { + u64 u64; + struct cvmx_ilk_txx_flow_ctl0_s { + u64 status : 64; + } s; + struct cvmx_ilk_txx_flow_ctl0_s cn68xx; + struct cvmx_ilk_txx_flow_ctl0_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_flow_ctl0 cvmx_ilk_txx_flow_ctl0_t; + +/** + * cvmx_ilk_tx#_flow_ctl1 + * + * Notes: + * Do not publish. + * + */ +union cvmx_ilk_txx_flow_ctl1 { + u64 u64; + struct cvmx_ilk_txx_flow_ctl1_s { + u64 reserved_0_63 : 64; + } s; + struct cvmx_ilk_txx_flow_ctl1_s cn68xx; + struct cvmx_ilk_txx_flow_ctl1_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_flow_ctl1 cvmx_ilk_txx_flow_ctl1_t; + +/** + * cvmx_ilk_tx#_idx_cal + */ +union cvmx_ilk_txx_idx_cal { + u64 u64; + struct cvmx_ilk_txx_idx_cal_s { + u64 reserved_14_63 : 50; + u64 inc : 6; + u64 reserved_6_7 : 2; + u64 index : 6; + } s; + struct cvmx_ilk_txx_idx_cal_s cn68xx; + struct cvmx_ilk_txx_idx_cal_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_idx_cal cvmx_ilk_txx_idx_cal_t; + +/** + * cvmx_ilk_tx#_idx_pmap + */ +union cvmx_ilk_txx_idx_pmap { + u64 u64; + struct cvmx_ilk_txx_idx_pmap_s { + u64 reserved_23_63 : 41; + u64 inc : 7; + u64 reserved_7_15 : 9; + u64 index : 7; + } s; + struct cvmx_ilk_txx_idx_pmap_s cn68xx; + struct cvmx_ilk_txx_idx_pmap_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_idx_pmap cvmx_ilk_txx_idx_pmap_t; + +/** + * cvmx_ilk_tx#_idx_stat0 + */ +union cvmx_ilk_txx_idx_stat0 { + u64 u64; + struct cvmx_ilk_txx_idx_stat0_s { + u64 reserved_32_63 : 32; + u64 clr : 1; + u64 reserved_24_30 : 7; + u64 inc : 8; + u64 reserved_8_15 : 8; + u64 index : 8; + } s; + struct cvmx_ilk_txx_idx_stat0_s cn68xx; + struct cvmx_ilk_txx_idx_stat0_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_idx_stat0 cvmx_ilk_txx_idx_stat0_t; + +/** + * cvmx_ilk_tx#_idx_stat1 + */ +union cvmx_ilk_txx_idx_stat1 { + u64 u64; + struct cvmx_ilk_txx_idx_stat1_s { + u64 reserved_32_63 : 32; + u64 clr : 1; + u64 reserved_24_30 : 7; + u64 inc : 8; + u64 reserved_8_15 : 8; + u64 index : 8; + } s; + struct cvmx_ilk_txx_idx_stat1_s cn68xx; + struct cvmx_ilk_txx_idx_stat1_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_idx_stat1 cvmx_ilk_txx_idx_stat1_t; + +/** + * cvmx_ilk_tx#_int + */ +union cvmx_ilk_txx_int { + u64 u64; + struct cvmx_ilk_txx_int_s { + u64 reserved_8_63 : 56; + u64 fwc_dbe : 1; + u64 fwc_sbe : 1; + u64 txf_dbe : 1; + u64 txf_sbe : 1; + u64 stat_cnt_ovfl : 1; + u64 bad_pipe : 1; + u64 bad_seq : 1; + u64 txf_err : 1; + } s; + struct cvmx_ilk_txx_int_cn68xx { + u64 reserved_4_63 : 60; + u64 stat_cnt_ovfl : 1; + u64 bad_pipe : 1; + u64 bad_seq : 1; + u64 txf_err : 1; + } cn68xx; + struct cvmx_ilk_txx_int_cn68xx cn68xxp1; + struct cvmx_ilk_txx_int_s cn78xx; + struct cvmx_ilk_txx_int_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_int cvmx_ilk_txx_int_t; + +/** + * cvmx_ilk_tx#_int_en + */ +union cvmx_ilk_txx_int_en { + u64 u64; + struct cvmx_ilk_txx_int_en_s { + u64 reserved_4_63 : 60; + u64 stat_cnt_ovfl : 1; + u64 bad_pipe : 1; + u64 bad_seq : 1; + u64 txf_err : 1; + } s; + struct cvmx_ilk_txx_int_en_s cn68xx; + struct cvmx_ilk_txx_int_en_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_int_en cvmx_ilk_txx_int_en_t; + +/** + * cvmx_ilk_tx#_mem_cal0 + * + * Notes: + * Software must always read ILK_TXx_MEM_CAL0 then ILK_TXx_MEM_CAL1. Software + * must never read them in reverse order or read one without reading the + * other. + * + * Software must always write ILK_TXx_MEM_CAL0 then ILK_TXx_MEM_CAL1. + * Software must never write them in reverse order or write one without + * writing the other. + */ +union cvmx_ilk_txx_mem_cal0 { + u64 u64; + struct cvmx_ilk_txx_mem_cal0_s { + u64 reserved_36_63 : 28; + u64 entry_ctl3 : 2; + u64 reserved_33_33 : 1; + u64 bpid3 : 6; + u64 entry_ctl2 : 2; + u64 reserved_24_24 : 1; + u64 bpid2 : 6; + u64 entry_ctl1 : 2; + u64 reserved_15_15 : 1; + u64 bpid1 : 6; + u64 entry_ctl0 : 2; + u64 reserved_6_6 : 1; + u64 bpid0 : 6; + } s; + struct cvmx_ilk_txx_mem_cal0_s cn68xx; + struct cvmx_ilk_txx_mem_cal0_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_mem_cal0 cvmx_ilk_txx_mem_cal0_t; + +/** + * cvmx_ilk_tx#_mem_cal1 + * + * Notes: + * Software must always read ILK_TXx_MEM_CAL0 then ILK_TXx_MEM_CAL1. Software + * must never read them in reverse order or read one without reading the + * other. + * + * Software must always write ILK_TXx_MEM_CAL0 then ILK_TXx_MEM_CAL1. + * Software must never write them in reverse order or write one without + * writing the other. + */ +union cvmx_ilk_txx_mem_cal1 { + u64 u64; + struct cvmx_ilk_txx_mem_cal1_s { + u64 reserved_36_63 : 28; + u64 entry_ctl7 : 2; + u64 reserved_33_33 : 1; + u64 bpid7 : 6; + u64 entry_ctl6 : 2; + u64 reserved_24_24 : 1; + u64 bpid6 : 6; + u64 entry_ctl5 : 2; + u64 reserved_15_15 : 1; + u64 bpid5 : 6; + u64 entry_ctl4 : 2; + u64 reserved_6_6 : 1; + u64 bpid4 : 6; + } s; + struct cvmx_ilk_txx_mem_cal1_s cn68xx; + struct cvmx_ilk_txx_mem_cal1_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_mem_cal1 cvmx_ilk_txx_mem_cal1_t; + +/** + * cvmx_ilk_tx#_mem_pmap + */ +union cvmx_ilk_txx_mem_pmap { + u64 u64; + struct cvmx_ilk_txx_mem_pmap_s { + u64 reserved_17_63 : 47; + u64 remap : 1; + u64 reserved_8_15 : 8; + u64 channel : 8; + } s; + struct cvmx_ilk_txx_mem_pmap_s cn68xx; + struct cvmx_ilk_txx_mem_pmap_cn68xxp1 { + u64 reserved_8_63 : 56; + u64 channel : 8; + } cn68xxp1; +}; + +typedef union cvmx_ilk_txx_mem_pmap cvmx_ilk_txx_mem_pmap_t; + +/** + * cvmx_ilk_tx#_mem_stat0 + */ +union cvmx_ilk_txx_mem_stat0 { + u64 u64; + struct cvmx_ilk_txx_mem_stat0_s { + u64 reserved_28_63 : 36; + u64 tx_pkt : 28; + } s; + struct cvmx_ilk_txx_mem_stat0_s cn68xx; + struct cvmx_ilk_txx_mem_stat0_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_mem_stat0 cvmx_ilk_txx_mem_stat0_t; + +/** + * cvmx_ilk_tx#_mem_stat1 + */ +union cvmx_ilk_txx_mem_stat1 { + u64 u64; + struct cvmx_ilk_txx_mem_stat1_s { + u64 reserved_36_63 : 28; + u64 tx_bytes : 36; + } s; + struct cvmx_ilk_txx_mem_stat1_s cn68xx; + struct cvmx_ilk_txx_mem_stat1_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_mem_stat1 cvmx_ilk_txx_mem_stat1_t; + +/** + * cvmx_ilk_tx#_pipe + */ +union cvmx_ilk_txx_pipe { + u64 u64; + struct cvmx_ilk_txx_pipe_s { + u64 reserved_24_63 : 40; + u64 nump : 8; + u64 reserved_7_15 : 9; + u64 base : 7; + } s; + struct cvmx_ilk_txx_pipe_s cn68xx; + struct cvmx_ilk_txx_pipe_s cn68xxp1; +}; + +typedef union cvmx_ilk_txx_pipe cvmx_ilk_txx_pipe_t; + +/** + * cvmx_ilk_tx#_pkt_cnt# + */ +union cvmx_ilk_txx_pkt_cntx { + u64 u64; + struct cvmx_ilk_txx_pkt_cntx_s { + u64 reserved_34_63 : 30; + u64 tx_pkt : 34; + } s; + struct cvmx_ilk_txx_pkt_cntx_s cn78xx; + struct cvmx_ilk_txx_pkt_cntx_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_pkt_cntx cvmx_ilk_txx_pkt_cntx_t; + +/** + * cvmx_ilk_tx#_rmatch + */ +union cvmx_ilk_txx_rmatch { + u64 u64; + struct cvmx_ilk_txx_rmatch_s { + u64 reserved_50_63 : 14; + u64 grnlrty : 2; + u64 brst_limit : 16; + u64 time_limit : 16; + u64 rate_limit : 16; + } s; + struct cvmx_ilk_txx_rmatch_s cn68xx; + struct cvmx_ilk_txx_rmatch_s cn68xxp1; + struct cvmx_ilk_txx_rmatch_s cn78xx; + struct cvmx_ilk_txx_rmatch_s cn78xxp1; +}; + +typedef union cvmx_ilk_txx_rmatch cvmx_ilk_txx_rmatch_t; + +#endif
Import cvmx-iob-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-iob-defs.h | 1328 +++++++++++++++++ 1 file changed, 1328 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h new file mode 100644 index 000000000000..0af444daf418 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h @@ -0,0 +1,1328 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon iob. + */ + +#ifndef __CVMX_IOB_DEFS_H__ +#define __CVMX_IOB_DEFS_H__ + +#define CVMX_IOB_BIST_STATUS (0x00011800F00007F8ull) +#define CVMX_IOB_CHIP_CUR_PWR (0x00011800F0000828ull) +#define CVMX_IOB_CHIP_GLB_PWR_THROTTLE (0x00011800F0000808ull) +#define CVMX_IOB_CHIP_PWR_OUT (0x00011800F0000818ull) +#define CVMX_IOB_CTL_STATUS (0x00011800F0000050ull) +#define CVMX_IOB_DWB_PRI_CNT (0x00011800F0000028ull) +#define CVMX_IOB_FAU_TIMEOUT (0x00011800F0000000ull) +#define CVMX_IOB_I2C_PRI_CNT (0x00011800F0000010ull) +#define CVMX_IOB_INB_CONTROL_MATCH (0x00011800F0000078ull) +#define CVMX_IOB_INB_CONTROL_MATCH_ENB (0x00011800F0000088ull) +#define CVMX_IOB_INB_DATA_MATCH (0x00011800F0000070ull) +#define CVMX_IOB_INB_DATA_MATCH_ENB (0x00011800F0000080ull) +#define CVMX_IOB_INT_ENB (0x00011800F0000060ull) +#define CVMX_IOB_INT_SUM (0x00011800F0000058ull) +#define CVMX_IOB_N2C_L2C_PRI_CNT (0x00011800F0000020ull) +#define CVMX_IOB_N2C_RSP_PRI_CNT (0x00011800F0000008ull) +#define CVMX_IOB_OUTB_COM_PRI_CNT (0x00011800F0000040ull) +#define CVMX_IOB_OUTB_CONTROL_MATCH (0x00011800F0000098ull) +#define CVMX_IOB_OUTB_CONTROL_MATCH_ENB (0x00011800F00000A8ull) +#define CVMX_IOB_OUTB_DATA_MATCH (0x00011800F0000090ull) +#define CVMX_IOB_OUTB_DATA_MATCH_ENB (0x00011800F00000A0ull) +#define CVMX_IOB_OUTB_FPA_PRI_CNT (0x00011800F0000048ull) +#define CVMX_IOB_OUTB_REQ_PRI_CNT (0x00011800F0000038ull) +#define CVMX_IOB_P2C_REQ_PRI_CNT (0x00011800F0000018ull) +#define CVMX_IOB_PKT_ERR (0x00011800F0000068ull) +#define CVMX_IOB_PP_BIST_STATUS (0x00011800F0000700ull) +#define CVMX_IOB_TO_CMB_CREDITS (0x00011800F00000B0ull) +#define CVMX_IOB_TO_NCB_DID_00_CREDITS (0x00011800F0000800ull) +#define CVMX_IOB_TO_NCB_DID_111_CREDITS (0x00011800F0000B78ull) +#define CVMX_IOB_TO_NCB_DID_223_CREDITS (0x00011800F0000EF8ull) +#define CVMX_IOB_TO_NCB_DID_24_CREDITS (0x00011800F00008C0ull) +#define CVMX_IOB_TO_NCB_DID_32_CREDITS (0x00011800F0000900ull) +#define CVMX_IOB_TO_NCB_DID_40_CREDITS (0x00011800F0000940ull) +#define CVMX_IOB_TO_NCB_DID_55_CREDITS (0x00011800F00009B8ull) +#define CVMX_IOB_TO_NCB_DID_64_CREDITS (0x00011800F0000A00ull) +#define CVMX_IOB_TO_NCB_DID_79_CREDITS (0x00011800F0000A78ull) +#define CVMX_IOB_TO_NCB_DID_96_CREDITS (0x00011800F0000B00ull) +#define CVMX_IOB_TO_NCB_DID_98_CREDITS (0x00011800F0000B10ull) + +/** + * cvmx_iob_bist_status + * + * The result of the BIST run on the IOB memories. + * + */ +union cvmx_iob_bist_status { + u64 u64; + struct cvmx_iob_bist_status_s { + u64 reserved_2_63 : 62; + u64 ibd : 1; + u64 icd : 1; + } s; + struct cvmx_iob_bist_status_cn30xx { + u64 reserved_18_63 : 46; + u64 icnrcb : 1; + u64 icr0 : 1; + u64 icr1 : 1; + u64 icnr1 : 1; + u64 icnr0 : 1; + u64 ibdr0 : 1; + u64 ibdr1 : 1; + u64 ibr0 : 1; + u64 ibr1 : 1; + u64 icnrt : 1; + u64 ibrq0 : 1; + u64 ibrq1 : 1; + u64 icrn0 : 1; + u64 icrn1 : 1; + u64 icrp0 : 1; + u64 icrp1 : 1; + u64 ibd : 1; + u64 icd : 1; + } cn30xx; + struct cvmx_iob_bist_status_cn30xx cn31xx; + struct cvmx_iob_bist_status_cn30xx cn38xx; + struct cvmx_iob_bist_status_cn30xx cn38xxp2; + struct cvmx_iob_bist_status_cn30xx cn50xx; + struct cvmx_iob_bist_status_cn30xx cn52xx; + struct cvmx_iob_bist_status_cn30xx cn52xxp1; + struct cvmx_iob_bist_status_cn30xx cn56xx; + struct cvmx_iob_bist_status_cn30xx cn56xxp1; + struct cvmx_iob_bist_status_cn30xx cn58xx; + struct cvmx_iob_bist_status_cn30xx cn58xxp1; + struct cvmx_iob_bist_status_cn61xx { + u64 reserved_23_63 : 41; + u64 xmdfif : 1; + u64 xmcfif : 1; + u64 iorfif : 1; + u64 rsdfif : 1; + u64 iocfif : 1; + u64 icnrcb : 1; + u64 icr0 : 1; + u64 icr1 : 1; + u64 icnr1 : 1; + u64 icnr0 : 1; + u64 ibdr0 : 1; + u64 ibdr1 : 1; + u64 ibr0 : 1; + u64 ibr1 : 1; + u64 icnrt : 1; + u64 ibrq0 : 1; + u64 ibrq1 : 1; + u64 icrn0 : 1; + u64 icrn1 : 1; + u64 icrp0 : 1; + u64 icrp1 : 1; + u64 ibd : 1; + u64 icd : 1; + } cn61xx; + struct cvmx_iob_bist_status_cn61xx cn63xx; + struct cvmx_iob_bist_status_cn61xx cn63xxp1; + struct cvmx_iob_bist_status_cn61xx cn66xx; + struct cvmx_iob_bist_status_cn68xx { + u64 reserved_18_63 : 46; + u64 xmdfif : 1; + u64 xmcfif : 1; + u64 iorfif : 1; + u64 rsdfif : 1; + u64 iocfif : 1; + u64 icnrcb : 1; + u64 icr0 : 1; + u64 icr1 : 1; + u64 icnr0 : 1; + u64 ibr0 : 1; + u64 ibr1 : 1; + u64 icnrt : 1; + u64 ibrq0 : 1; + u64 ibrq1 : 1; + u64 icrn0 : 1; + u64 icrn1 : 1; + u64 ibd : 1; + u64 icd : 1; + } cn68xx; + struct cvmx_iob_bist_status_cn68xx cn68xxp1; + struct cvmx_iob_bist_status_cn61xx cn70xx; + struct cvmx_iob_bist_status_cn61xx cn70xxp1; + struct cvmx_iob_bist_status_cn61xx cnf71xx; +}; + +typedef union cvmx_iob_bist_status cvmx_iob_bist_status_t; + +/** + * cvmx_iob_chip_cur_pwr + */ +union cvmx_iob_chip_cur_pwr { + u64 u64; + struct cvmx_iob_chip_cur_pwr_s { + u64 reserved_8_63 : 56; + u64 current_power_setting : 8; + } s; + struct cvmx_iob_chip_cur_pwr_s cn70xx; + struct cvmx_iob_chip_cur_pwr_s cn70xxp1; +}; + +typedef union cvmx_iob_chip_cur_pwr cvmx_iob_chip_cur_pwr_t; + +/** + * cvmx_iob_chip_glb_pwr_throttle + * + * Controls the min/max power settings. + * + */ +union cvmx_iob_chip_glb_pwr_throttle { + u64 u64; + struct cvmx_iob_chip_glb_pwr_throttle_s { + u64 reserved_34_63 : 30; + u64 pwr_bw : 2; + u64 pwr_max : 8; + u64 pwr_min : 8; + u64 pwr_setting : 16; + } s; + struct cvmx_iob_chip_glb_pwr_throttle_s cn70xx; + struct cvmx_iob_chip_glb_pwr_throttle_s cn70xxp1; +}; + +typedef union cvmx_iob_chip_glb_pwr_throttle cvmx_iob_chip_glb_pwr_throttle_t; + +/** + * cvmx_iob_chip_pwr_out + * + * Power numbers from the various partitions on the chip. + * + */ +union cvmx_iob_chip_pwr_out { + u64 u64; + struct cvmx_iob_chip_pwr_out_s { + u64 cpu_pwr : 16; + u64 chip_power : 16; + u64 coproc_power : 16; + u64 avg_chip_power : 16; + } s; + struct cvmx_iob_chip_pwr_out_s cn70xx; + struct cvmx_iob_chip_pwr_out_s cn70xxp1; +}; + +typedef union cvmx_iob_chip_pwr_out cvmx_iob_chip_pwr_out_t; + +/** + * cvmx_iob_ctl_status + * + * IOB Control Status = IOB Control and Status Register + * Provides control for IOB functions. + */ +union cvmx_iob_ctl_status { + u64 u64; + struct cvmx_iob_ctl_status_s { + u64 reserved_11_63 : 53; + u64 fif_dly : 1; + u64 xmc_per : 4; + u64 reserved_3_5 : 3; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } s; + struct cvmx_iob_ctl_status_cn30xx { + u64 reserved_5_63 : 59; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn30xx; + struct cvmx_iob_ctl_status_cn30xx cn31xx; + struct cvmx_iob_ctl_status_cn30xx cn38xx; + struct cvmx_iob_ctl_status_cn30xx cn38xxp2; + struct cvmx_iob_ctl_status_cn30xx cn50xx; + struct cvmx_iob_ctl_status_cn52xx { + u64 reserved_6_63 : 58; + u64 rr_mode : 1; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn52xx; + struct cvmx_iob_ctl_status_cn30xx cn52xxp1; + struct cvmx_iob_ctl_status_cn30xx cn56xx; + struct cvmx_iob_ctl_status_cn30xx cn56xxp1; + struct cvmx_iob_ctl_status_cn30xx cn58xx; + struct cvmx_iob_ctl_status_cn30xx cn58xxp1; + struct cvmx_iob_ctl_status_cn61xx { + u64 reserved_11_63 : 53; + u64 fif_dly : 1; + u64 xmc_per : 4; + u64 rr_mode : 1; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn61xx; + struct cvmx_iob_ctl_status_cn63xx { + u64 reserved_10_63 : 54; + u64 xmc_per : 4; + u64 rr_mode : 1; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn63xx; + struct cvmx_iob_ctl_status_cn63xx cn63xxp1; + struct cvmx_iob_ctl_status_cn61xx cn66xx; + struct cvmx_iob_ctl_status_cn68xx { + u64 reserved_11_63 : 53; + u64 fif_dly : 1; + u64 xmc_per : 4; + u64 rsvr5 : 1; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn68xx; + struct cvmx_iob_ctl_status_cn68xx cn68xxp1; + struct cvmx_iob_ctl_status_cn70xx { + u64 reserved_10_63 : 54; + u64 xmc_per : 4; + u64 rr_mode : 1; + u64 rsv4 : 1; + u64 rsv3 : 1; + u64 pko_enb : 1; + u64 dwb_enb : 1; + u64 fau_end : 1; + } cn70xx; + struct cvmx_iob_ctl_status_cn70xx cn70xxp1; + struct cvmx_iob_ctl_status_cn61xx cnf71xx; +}; + +typedef union cvmx_iob_ctl_status cvmx_iob_ctl_status_t; + +/** + * cvmx_iob_dwb_pri_cnt + * + * DWB To CMB Priority Counter = Don't Write Back to CMB Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of Don't Write Back request to + * the L2C. + */ +union cvmx_iob_dwb_pri_cnt { + u64 u64; + struct cvmx_iob_dwb_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_dwb_pri_cnt_s cn38xx; + struct cvmx_iob_dwb_pri_cnt_s cn38xxp2; + struct cvmx_iob_dwb_pri_cnt_s cn52xx; + struct cvmx_iob_dwb_pri_cnt_s cn52xxp1; + struct cvmx_iob_dwb_pri_cnt_s cn56xx; + struct cvmx_iob_dwb_pri_cnt_s cn56xxp1; + struct cvmx_iob_dwb_pri_cnt_s cn58xx; + struct cvmx_iob_dwb_pri_cnt_s cn58xxp1; + struct cvmx_iob_dwb_pri_cnt_s cn61xx; + struct cvmx_iob_dwb_pri_cnt_s cn63xx; + struct cvmx_iob_dwb_pri_cnt_s cn63xxp1; + struct cvmx_iob_dwb_pri_cnt_s cn66xx; + struct cvmx_iob_dwb_pri_cnt_s cn70xx; + struct cvmx_iob_dwb_pri_cnt_s cn70xxp1; + struct cvmx_iob_dwb_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_dwb_pri_cnt cvmx_iob_dwb_pri_cnt_t; + +/** + * cvmx_iob_fau_timeout + * + * FAU Timeout = Fetch and Add Unit Tag-Switch Timeout + * How many clokc ticks the FAU unit will wait for a tag-switch before timing out. + * for Queue 0. + */ +union cvmx_iob_fau_timeout { + u64 u64; + struct cvmx_iob_fau_timeout_s { + u64 reserved_13_63 : 51; + u64 tout_enb : 1; + u64 tout_val : 12; + } s; + struct cvmx_iob_fau_timeout_s cn30xx; + struct cvmx_iob_fau_timeout_s cn31xx; + struct cvmx_iob_fau_timeout_s cn38xx; + struct cvmx_iob_fau_timeout_s cn38xxp2; + struct cvmx_iob_fau_timeout_s cn50xx; + struct cvmx_iob_fau_timeout_s cn52xx; + struct cvmx_iob_fau_timeout_s cn52xxp1; + struct cvmx_iob_fau_timeout_s cn56xx; + struct cvmx_iob_fau_timeout_s cn56xxp1; + struct cvmx_iob_fau_timeout_s cn58xx; + struct cvmx_iob_fau_timeout_s cn58xxp1; + struct cvmx_iob_fau_timeout_s cn61xx; + struct cvmx_iob_fau_timeout_s cn63xx; + struct cvmx_iob_fau_timeout_s cn63xxp1; + struct cvmx_iob_fau_timeout_s cn66xx; + struct cvmx_iob_fau_timeout_s cn68xx; + struct cvmx_iob_fau_timeout_s cn68xxp1; + struct cvmx_iob_fau_timeout_s cn70xx; + struct cvmx_iob_fau_timeout_s cn70xxp1; + struct cvmx_iob_fau_timeout_s cnf71xx; +}; + +typedef union cvmx_iob_fau_timeout cvmx_iob_fau_timeout_t; + +/** + * cvmx_iob_i2c_pri_cnt + * + * IPD To CMB Store Priority Counter = IPD to CMB Store Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of IPD Store access to the + * CMB. + */ +union cvmx_iob_i2c_pri_cnt { + u64 u64; + struct cvmx_iob_i2c_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_i2c_pri_cnt_s cn38xx; + struct cvmx_iob_i2c_pri_cnt_s cn38xxp2; + struct cvmx_iob_i2c_pri_cnt_s cn52xx; + struct cvmx_iob_i2c_pri_cnt_s cn52xxp1; + struct cvmx_iob_i2c_pri_cnt_s cn56xx; + struct cvmx_iob_i2c_pri_cnt_s cn56xxp1; + struct cvmx_iob_i2c_pri_cnt_s cn58xx; + struct cvmx_iob_i2c_pri_cnt_s cn58xxp1; + struct cvmx_iob_i2c_pri_cnt_s cn61xx; + struct cvmx_iob_i2c_pri_cnt_s cn63xx; + struct cvmx_iob_i2c_pri_cnt_s cn63xxp1; + struct cvmx_iob_i2c_pri_cnt_s cn66xx; + struct cvmx_iob_i2c_pri_cnt_s cn70xx; + struct cvmx_iob_i2c_pri_cnt_s cn70xxp1; + struct cvmx_iob_i2c_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_i2c_pri_cnt cvmx_iob_i2c_pri_cnt_t; + +/** + * cvmx_iob_inb_control_match + * + * Match pattern for the inbound control to set the INB_MATCH_BIT. + * + */ +union cvmx_iob_inb_control_match { + u64 u64; + struct cvmx_iob_inb_control_match_s { + u64 reserved_29_63 : 35; + u64 mask : 8; + u64 opc : 4; + u64 dst : 9; + u64 src : 8; + } s; + struct cvmx_iob_inb_control_match_s cn30xx; + struct cvmx_iob_inb_control_match_s cn31xx; + struct cvmx_iob_inb_control_match_s cn38xx; + struct cvmx_iob_inb_control_match_s cn38xxp2; + struct cvmx_iob_inb_control_match_s cn50xx; + struct cvmx_iob_inb_control_match_s cn52xx; + struct cvmx_iob_inb_control_match_s cn52xxp1; + struct cvmx_iob_inb_control_match_s cn56xx; + struct cvmx_iob_inb_control_match_s cn56xxp1; + struct cvmx_iob_inb_control_match_s cn58xx; + struct cvmx_iob_inb_control_match_s cn58xxp1; + struct cvmx_iob_inb_control_match_s cn61xx; + struct cvmx_iob_inb_control_match_s cn63xx; + struct cvmx_iob_inb_control_match_s cn63xxp1; + struct cvmx_iob_inb_control_match_s cn66xx; + struct cvmx_iob_inb_control_match_s cn68xx; + struct cvmx_iob_inb_control_match_s cn68xxp1; + struct cvmx_iob_inb_control_match_s cn70xx; + struct cvmx_iob_inb_control_match_s cn70xxp1; + struct cvmx_iob_inb_control_match_s cnf71xx; +}; + +typedef union cvmx_iob_inb_control_match cvmx_iob_inb_control_match_t; + +/** + * cvmx_iob_inb_control_match_enb + * + * Enables the match of the corresponding bit in the IOB_INB_CONTROL_MATCH reister. + * + */ +union cvmx_iob_inb_control_match_enb { + u64 u64; + struct cvmx_iob_inb_control_match_enb_s { + u64 reserved_29_63 : 35; + u64 mask : 8; + u64 opc : 4; + u64 dst : 9; + u64 src : 8; + } s; + struct cvmx_iob_inb_control_match_enb_s cn30xx; + struct cvmx_iob_inb_control_match_enb_s cn31xx; + struct cvmx_iob_inb_control_match_enb_s cn38xx; + struct cvmx_iob_inb_control_match_enb_s cn38xxp2; + struct cvmx_iob_inb_control_match_enb_s cn50xx; + struct cvmx_iob_inb_control_match_enb_s cn52xx; + struct cvmx_iob_inb_control_match_enb_s cn52xxp1; + struct cvmx_iob_inb_control_match_enb_s cn56xx; + struct cvmx_iob_inb_control_match_enb_s cn56xxp1; + struct cvmx_iob_inb_control_match_enb_s cn58xx; + struct cvmx_iob_inb_control_match_enb_s cn58xxp1; + struct cvmx_iob_inb_control_match_enb_s cn61xx; + struct cvmx_iob_inb_control_match_enb_s cn63xx; + struct cvmx_iob_inb_control_match_enb_s cn63xxp1; + struct cvmx_iob_inb_control_match_enb_s cn66xx; + struct cvmx_iob_inb_control_match_enb_s cn68xx; + struct cvmx_iob_inb_control_match_enb_s cn68xxp1; + struct cvmx_iob_inb_control_match_enb_s cn70xx; + struct cvmx_iob_inb_control_match_enb_s cn70xxp1; + struct cvmx_iob_inb_control_match_enb_s cnf71xx; +}; + +typedef union cvmx_iob_inb_control_match_enb cvmx_iob_inb_control_match_enb_t; + +/** + * cvmx_iob_inb_data_match + * + * Match pattern for the inbound data to set the INB_MATCH_BIT. + * + */ +union cvmx_iob_inb_data_match { + u64 u64; + struct cvmx_iob_inb_data_match_s { + u64 data : 64; + } s; + struct cvmx_iob_inb_data_match_s cn30xx; + struct cvmx_iob_inb_data_match_s cn31xx; + struct cvmx_iob_inb_data_match_s cn38xx; + struct cvmx_iob_inb_data_match_s cn38xxp2; + struct cvmx_iob_inb_data_match_s cn50xx; + struct cvmx_iob_inb_data_match_s cn52xx; + struct cvmx_iob_inb_data_match_s cn52xxp1; + struct cvmx_iob_inb_data_match_s cn56xx; + struct cvmx_iob_inb_data_match_s cn56xxp1; + struct cvmx_iob_inb_data_match_s cn58xx; + struct cvmx_iob_inb_data_match_s cn58xxp1; + struct cvmx_iob_inb_data_match_s cn61xx; + struct cvmx_iob_inb_data_match_s cn63xx; + struct cvmx_iob_inb_data_match_s cn63xxp1; + struct cvmx_iob_inb_data_match_s cn66xx; + struct cvmx_iob_inb_data_match_s cn68xx; + struct cvmx_iob_inb_data_match_s cn68xxp1; + struct cvmx_iob_inb_data_match_s cn70xx; + struct cvmx_iob_inb_data_match_s cn70xxp1; + struct cvmx_iob_inb_data_match_s cnf71xx; +}; + +typedef union cvmx_iob_inb_data_match cvmx_iob_inb_data_match_t; + +/** + * cvmx_iob_inb_data_match_enb + * + * Enables the match of the corresponding bit in the IOB_INB_DATA_MATCH reister. + * + */ +union cvmx_iob_inb_data_match_enb { + u64 u64; + struct cvmx_iob_inb_data_match_enb_s { + u64 data : 64; + } s; + struct cvmx_iob_inb_data_match_enb_s cn30xx; + struct cvmx_iob_inb_data_match_enb_s cn31xx; + struct cvmx_iob_inb_data_match_enb_s cn38xx; + struct cvmx_iob_inb_data_match_enb_s cn38xxp2; + struct cvmx_iob_inb_data_match_enb_s cn50xx; + struct cvmx_iob_inb_data_match_enb_s cn52xx; + struct cvmx_iob_inb_data_match_enb_s cn52xxp1; + struct cvmx_iob_inb_data_match_enb_s cn56xx; + struct cvmx_iob_inb_data_match_enb_s cn56xxp1; + struct cvmx_iob_inb_data_match_enb_s cn58xx; + struct cvmx_iob_inb_data_match_enb_s cn58xxp1; + struct cvmx_iob_inb_data_match_enb_s cn61xx; + struct cvmx_iob_inb_data_match_enb_s cn63xx; + struct cvmx_iob_inb_data_match_enb_s cn63xxp1; + struct cvmx_iob_inb_data_match_enb_s cn66xx; + struct cvmx_iob_inb_data_match_enb_s cn68xx; + struct cvmx_iob_inb_data_match_enb_s cn68xxp1; + struct cvmx_iob_inb_data_match_enb_s cn70xx; + struct cvmx_iob_inb_data_match_enb_s cn70xxp1; + struct cvmx_iob_inb_data_match_enb_s cnf71xx; +}; + +typedef union cvmx_iob_inb_data_match_enb cvmx_iob_inb_data_match_enb_t; + +/** + * cvmx_iob_int_enb + * + * The IOB's interrupt enable register. + * + */ +union cvmx_iob_int_enb { + u64 u64; + struct cvmx_iob_int_enb_s { + u64 reserved_8_63 : 56; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 p_dat : 1; + u64 np_dat : 1; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } s; + struct cvmx_iob_int_enb_cn30xx { + u64 reserved_4_63 : 60; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } cn30xx; + struct cvmx_iob_int_enb_cn30xx cn31xx; + struct cvmx_iob_int_enb_cn30xx cn38xx; + struct cvmx_iob_int_enb_cn30xx cn38xxp2; + struct cvmx_iob_int_enb_cn50xx { + u64 reserved_6_63 : 58; + u64 p_dat : 1; + u64 np_dat : 1; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } cn50xx; + struct cvmx_iob_int_enb_cn50xx cn52xx; + struct cvmx_iob_int_enb_cn50xx cn52xxp1; + struct cvmx_iob_int_enb_cn50xx cn56xx; + struct cvmx_iob_int_enb_cn50xx cn56xxp1; + struct cvmx_iob_int_enb_cn50xx cn58xx; + struct cvmx_iob_int_enb_cn50xx cn58xxp1; + struct cvmx_iob_int_enb_cn50xx cn61xx; + struct cvmx_iob_int_enb_cn50xx cn63xx; + struct cvmx_iob_int_enb_cn50xx cn63xxp1; + struct cvmx_iob_int_enb_cn50xx cn66xx; + struct cvmx_iob_int_enb_cn68xx { + u64 reserved_0_63 : 64; + } cn68xx; + struct cvmx_iob_int_enb_cn68xx cn68xxp1; + struct cvmx_iob_int_enb_s cn70xx; + struct cvmx_iob_int_enb_s cn70xxp1; + struct cvmx_iob_int_enb_cn50xx cnf71xx; +}; + +typedef union cvmx_iob_int_enb cvmx_iob_int_enb_t; + +/** + * cvmx_iob_int_sum + * + * Contains the different interrupt summary bits of the IOB. + * + */ +union cvmx_iob_int_sum { + u64 u64; + struct cvmx_iob_int_sum_s { + u64 reserved_8_63 : 56; + u64 outb_mat : 1; + u64 inb_mat : 1; + u64 p_dat : 1; + u64 np_dat : 1; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } s; + struct cvmx_iob_int_sum_cn30xx { + u64 reserved_4_63 : 60; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } cn30xx; + struct cvmx_iob_int_sum_cn30xx cn31xx; + struct cvmx_iob_int_sum_cn30xx cn38xx; + struct cvmx_iob_int_sum_cn30xx cn38xxp2; + struct cvmx_iob_int_sum_cn50xx { + u64 reserved_6_63 : 58; + u64 p_dat : 1; + u64 np_dat : 1; + u64 p_eop : 1; + u64 p_sop : 1; + u64 np_eop : 1; + u64 np_sop : 1; + } cn50xx; + struct cvmx_iob_int_sum_cn50xx cn52xx; + struct cvmx_iob_int_sum_cn50xx cn52xxp1; + struct cvmx_iob_int_sum_cn50xx cn56xx; + struct cvmx_iob_int_sum_cn50xx cn56xxp1; + struct cvmx_iob_int_sum_cn50xx cn58xx; + struct cvmx_iob_int_sum_cn50xx cn58xxp1; + struct cvmx_iob_int_sum_cn50xx cn61xx; + struct cvmx_iob_int_sum_cn50xx cn63xx; + struct cvmx_iob_int_sum_cn50xx cn63xxp1; + struct cvmx_iob_int_sum_cn50xx cn66xx; + struct cvmx_iob_int_sum_cn68xx { + u64 reserved_0_63 : 64; + } cn68xx; + struct cvmx_iob_int_sum_cn68xx cn68xxp1; + struct cvmx_iob_int_sum_s cn70xx; + struct cvmx_iob_int_sum_s cn70xxp1; + struct cvmx_iob_int_sum_cn50xx cnf71xx; +}; + +typedef union cvmx_iob_int_sum cvmx_iob_int_sum_t; + +/** + * cvmx_iob_n2c_l2c_pri_cnt + * + * NCB To CMB L2C Priority Counter = NCB to CMB L2C Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of NCB Store/Load access to + * the CMB. + */ +union cvmx_iob_n2c_l2c_pri_cnt { + u64 u64; + struct cvmx_iob_n2c_l2c_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn38xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn38xxp2; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn52xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn52xxp1; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn56xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn56xxp1; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn58xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn58xxp1; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn61xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn63xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn63xxp1; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn66xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn70xx; + struct cvmx_iob_n2c_l2c_pri_cnt_s cn70xxp1; + struct cvmx_iob_n2c_l2c_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_n2c_l2c_pri_cnt cvmx_iob_n2c_l2c_pri_cnt_t; + +/** + * cvmx_iob_n2c_rsp_pri_cnt + * + * NCB To CMB Response Priority Counter = NCB to CMB Response Priority Counter Enable and Timer + * Value + * Enables and supplies the timeout count for raising the priority of NCB Responses access to the + * CMB. + */ +union cvmx_iob_n2c_rsp_pri_cnt { + u64 u64; + struct cvmx_iob_n2c_rsp_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn38xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn38xxp2; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn52xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn52xxp1; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn56xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn56xxp1; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn58xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn58xxp1; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn61xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn63xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn63xxp1; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn66xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn70xx; + struct cvmx_iob_n2c_rsp_pri_cnt_s cn70xxp1; + struct cvmx_iob_n2c_rsp_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_n2c_rsp_pri_cnt cvmx_iob_n2c_rsp_pri_cnt_t; + +/** + * cvmx_iob_outb_com_pri_cnt + * + * Commit To NCB Priority Counter = Commit to NCB Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of Commit request to the + * Outbound NCB. + */ +union cvmx_iob_outb_com_pri_cnt { + u64 u64; + struct cvmx_iob_outb_com_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_outb_com_pri_cnt_s cn38xx; + struct cvmx_iob_outb_com_pri_cnt_s cn38xxp2; + struct cvmx_iob_outb_com_pri_cnt_s cn52xx; + struct cvmx_iob_outb_com_pri_cnt_s cn52xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cn56xx; + struct cvmx_iob_outb_com_pri_cnt_s cn56xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cn58xx; + struct cvmx_iob_outb_com_pri_cnt_s cn58xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cn61xx; + struct cvmx_iob_outb_com_pri_cnt_s cn63xx; + struct cvmx_iob_outb_com_pri_cnt_s cn63xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cn66xx; + struct cvmx_iob_outb_com_pri_cnt_s cn68xx; + struct cvmx_iob_outb_com_pri_cnt_s cn68xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cn70xx; + struct cvmx_iob_outb_com_pri_cnt_s cn70xxp1; + struct cvmx_iob_outb_com_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_outb_com_pri_cnt cvmx_iob_outb_com_pri_cnt_t; + +/** + * cvmx_iob_outb_control_match + * + * Match pattern for the outbound control to set the OUTB_MATCH_BIT. + * + */ +union cvmx_iob_outb_control_match { + u64 u64; + struct cvmx_iob_outb_control_match_s { + u64 reserved_26_63 : 38; + u64 mask : 8; + u64 eot : 1; + u64 dst : 8; + u64 src : 9; + } s; + struct cvmx_iob_outb_control_match_s cn30xx; + struct cvmx_iob_outb_control_match_s cn31xx; + struct cvmx_iob_outb_control_match_s cn38xx; + struct cvmx_iob_outb_control_match_s cn38xxp2; + struct cvmx_iob_outb_control_match_s cn50xx; + struct cvmx_iob_outb_control_match_s cn52xx; + struct cvmx_iob_outb_control_match_s cn52xxp1; + struct cvmx_iob_outb_control_match_s cn56xx; + struct cvmx_iob_outb_control_match_s cn56xxp1; + struct cvmx_iob_outb_control_match_s cn58xx; + struct cvmx_iob_outb_control_match_s cn58xxp1; + struct cvmx_iob_outb_control_match_s cn61xx; + struct cvmx_iob_outb_control_match_s cn63xx; + struct cvmx_iob_outb_control_match_s cn63xxp1; + struct cvmx_iob_outb_control_match_s cn66xx; + struct cvmx_iob_outb_control_match_s cn68xx; + struct cvmx_iob_outb_control_match_s cn68xxp1; + struct cvmx_iob_outb_control_match_s cn70xx; + struct cvmx_iob_outb_control_match_s cn70xxp1; + struct cvmx_iob_outb_control_match_s cnf71xx; +}; + +typedef union cvmx_iob_outb_control_match cvmx_iob_outb_control_match_t; + +/** + * cvmx_iob_outb_control_match_enb + * + * Enables the match of the corresponding bit in the IOB_OUTB_CONTROL_MATCH reister. + * + */ +union cvmx_iob_outb_control_match_enb { + u64 u64; + struct cvmx_iob_outb_control_match_enb_s { + u64 reserved_26_63 : 38; + u64 mask : 8; + u64 eot : 1; + u64 dst : 8; + u64 src : 9; + } s; + struct cvmx_iob_outb_control_match_enb_s cn30xx; + struct cvmx_iob_outb_control_match_enb_s cn31xx; + struct cvmx_iob_outb_control_match_enb_s cn38xx; + struct cvmx_iob_outb_control_match_enb_s cn38xxp2; + struct cvmx_iob_outb_control_match_enb_s cn50xx; + struct cvmx_iob_outb_control_match_enb_s cn52xx; + struct cvmx_iob_outb_control_match_enb_s cn52xxp1; + struct cvmx_iob_outb_control_match_enb_s cn56xx; + struct cvmx_iob_outb_control_match_enb_s cn56xxp1; + struct cvmx_iob_outb_control_match_enb_s cn58xx; + struct cvmx_iob_outb_control_match_enb_s cn58xxp1; + struct cvmx_iob_outb_control_match_enb_s cn61xx; + struct cvmx_iob_outb_control_match_enb_s cn63xx; + struct cvmx_iob_outb_control_match_enb_s cn63xxp1; + struct cvmx_iob_outb_control_match_enb_s cn66xx; + struct cvmx_iob_outb_control_match_enb_s cn68xx; + struct cvmx_iob_outb_control_match_enb_s cn68xxp1; + struct cvmx_iob_outb_control_match_enb_s cn70xx; + struct cvmx_iob_outb_control_match_enb_s cn70xxp1; + struct cvmx_iob_outb_control_match_enb_s cnf71xx; +}; + +typedef union cvmx_iob_outb_control_match_enb cvmx_iob_outb_control_match_enb_t; + +/** + * cvmx_iob_outb_data_match + * + * Match pattern for the outbound data to set the OUTB_MATCH_BIT. + * + */ +union cvmx_iob_outb_data_match { + u64 u64; + struct cvmx_iob_outb_data_match_s { + u64 data : 64; + } s; + struct cvmx_iob_outb_data_match_s cn30xx; + struct cvmx_iob_outb_data_match_s cn31xx; + struct cvmx_iob_outb_data_match_s cn38xx; + struct cvmx_iob_outb_data_match_s cn38xxp2; + struct cvmx_iob_outb_data_match_s cn50xx; + struct cvmx_iob_outb_data_match_s cn52xx; + struct cvmx_iob_outb_data_match_s cn52xxp1; + struct cvmx_iob_outb_data_match_s cn56xx; + struct cvmx_iob_outb_data_match_s cn56xxp1; + struct cvmx_iob_outb_data_match_s cn58xx; + struct cvmx_iob_outb_data_match_s cn58xxp1; + struct cvmx_iob_outb_data_match_s cn61xx; + struct cvmx_iob_outb_data_match_s cn63xx; + struct cvmx_iob_outb_data_match_s cn63xxp1; + struct cvmx_iob_outb_data_match_s cn66xx; + struct cvmx_iob_outb_data_match_s cn68xx; + struct cvmx_iob_outb_data_match_s cn68xxp1; + struct cvmx_iob_outb_data_match_s cn70xx; + struct cvmx_iob_outb_data_match_s cn70xxp1; + struct cvmx_iob_outb_data_match_s cnf71xx; +}; + +typedef union cvmx_iob_outb_data_match cvmx_iob_outb_data_match_t; + +/** + * cvmx_iob_outb_data_match_enb + * + * Enables the match of the corresponding bit in the IOB_OUTB_DATA_MATCH reister. + * + */ +union cvmx_iob_outb_data_match_enb { + u64 u64; + struct cvmx_iob_outb_data_match_enb_s { + u64 data : 64; + } s; + struct cvmx_iob_outb_data_match_enb_s cn30xx; + struct cvmx_iob_outb_data_match_enb_s cn31xx; + struct cvmx_iob_outb_data_match_enb_s cn38xx; + struct cvmx_iob_outb_data_match_enb_s cn38xxp2; + struct cvmx_iob_outb_data_match_enb_s cn50xx; + struct cvmx_iob_outb_data_match_enb_s cn52xx; + struct cvmx_iob_outb_data_match_enb_s cn52xxp1; + struct cvmx_iob_outb_data_match_enb_s cn56xx; + struct cvmx_iob_outb_data_match_enb_s cn56xxp1; + struct cvmx_iob_outb_data_match_enb_s cn58xx; + struct cvmx_iob_outb_data_match_enb_s cn58xxp1; + struct cvmx_iob_outb_data_match_enb_s cn61xx; + struct cvmx_iob_outb_data_match_enb_s cn63xx; + struct cvmx_iob_outb_data_match_enb_s cn63xxp1; + struct cvmx_iob_outb_data_match_enb_s cn66xx; + struct cvmx_iob_outb_data_match_enb_s cn68xx; + struct cvmx_iob_outb_data_match_enb_s cn68xxp1; + struct cvmx_iob_outb_data_match_enb_s cn70xx; + struct cvmx_iob_outb_data_match_enb_s cn70xxp1; + struct cvmx_iob_outb_data_match_enb_s cnf71xx; +}; + +typedef union cvmx_iob_outb_data_match_enb cvmx_iob_outb_data_match_enb_t; + +/** + * cvmx_iob_outb_fpa_pri_cnt + * + * FPA To NCB Priority Counter = FPA Returns to NCB Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of FPA Rreturn Page request to + * the Outbound NCB. + */ +union cvmx_iob_outb_fpa_pri_cnt { + u64 u64; + struct cvmx_iob_outb_fpa_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_outb_fpa_pri_cnt_s cn38xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn38xxp2; + struct cvmx_iob_outb_fpa_pri_cnt_s cn52xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn52xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cn56xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn56xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cn58xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn58xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cn61xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn63xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn63xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cn66xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn68xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn68xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cn70xx; + struct cvmx_iob_outb_fpa_pri_cnt_s cn70xxp1; + struct cvmx_iob_outb_fpa_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_outb_fpa_pri_cnt cvmx_iob_outb_fpa_pri_cnt_t; + +/** + * cvmx_iob_outb_req_pri_cnt + * + * Request To NCB Priority Counter = Request to NCB Priority Counter Enable and Timer Value + * Enables and supplies the timeout count for raising the priority of Request transfers to the + * Outbound NCB. + */ +union cvmx_iob_outb_req_pri_cnt { + u64 u64; + struct cvmx_iob_outb_req_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_outb_req_pri_cnt_s cn38xx; + struct cvmx_iob_outb_req_pri_cnt_s cn38xxp2; + struct cvmx_iob_outb_req_pri_cnt_s cn52xx; + struct cvmx_iob_outb_req_pri_cnt_s cn52xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cn56xx; + struct cvmx_iob_outb_req_pri_cnt_s cn56xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cn58xx; + struct cvmx_iob_outb_req_pri_cnt_s cn58xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cn61xx; + struct cvmx_iob_outb_req_pri_cnt_s cn63xx; + struct cvmx_iob_outb_req_pri_cnt_s cn63xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cn66xx; + struct cvmx_iob_outb_req_pri_cnt_s cn68xx; + struct cvmx_iob_outb_req_pri_cnt_s cn68xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cn70xx; + struct cvmx_iob_outb_req_pri_cnt_s cn70xxp1; + struct cvmx_iob_outb_req_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_outb_req_pri_cnt cvmx_iob_outb_req_pri_cnt_t; + +/** + * cvmx_iob_p2c_req_pri_cnt + * + * PKO To CMB Response Priority Counter = PKO to CMB Response Priority Counter Enable and Timer + * Value + * Enables and supplies the timeout count for raising the priority of PKO Load access to the CMB. + */ +union cvmx_iob_p2c_req_pri_cnt { + u64 u64; + struct cvmx_iob_p2c_req_pri_cnt_s { + u64 reserved_16_63 : 48; + u64 cnt_enb : 1; + u64 cnt_val : 15; + } s; + struct cvmx_iob_p2c_req_pri_cnt_s cn38xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn38xxp2; + struct cvmx_iob_p2c_req_pri_cnt_s cn52xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn52xxp1; + struct cvmx_iob_p2c_req_pri_cnt_s cn56xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn56xxp1; + struct cvmx_iob_p2c_req_pri_cnt_s cn58xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn58xxp1; + struct cvmx_iob_p2c_req_pri_cnt_s cn61xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn63xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn63xxp1; + struct cvmx_iob_p2c_req_pri_cnt_s cn66xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn70xx; + struct cvmx_iob_p2c_req_pri_cnt_s cn70xxp1; + struct cvmx_iob_p2c_req_pri_cnt_s cnf71xx; +}; + +typedef union cvmx_iob_p2c_req_pri_cnt cvmx_iob_p2c_req_pri_cnt_t; + +/** + * cvmx_iob_pkt_err + * + * Provides status about the failing packet recevie error. + * + */ +union cvmx_iob_pkt_err { + u64 u64; + struct cvmx_iob_pkt_err_s { + u64 reserved_12_63 : 52; + u64 vport : 6; + u64 port : 6; + } s; + struct cvmx_iob_pkt_err_cn30xx { + u64 reserved_6_63 : 58; + u64 port : 6; + } cn30xx; + struct cvmx_iob_pkt_err_cn30xx cn31xx; + struct cvmx_iob_pkt_err_cn30xx cn38xx; + struct cvmx_iob_pkt_err_cn30xx cn38xxp2; + struct cvmx_iob_pkt_err_cn30xx cn50xx; + struct cvmx_iob_pkt_err_cn30xx cn52xx; + struct cvmx_iob_pkt_err_cn30xx cn52xxp1; + struct cvmx_iob_pkt_err_cn30xx cn56xx; + struct cvmx_iob_pkt_err_cn30xx cn56xxp1; + struct cvmx_iob_pkt_err_cn30xx cn58xx; + struct cvmx_iob_pkt_err_cn30xx cn58xxp1; + struct cvmx_iob_pkt_err_s cn61xx; + struct cvmx_iob_pkt_err_s cn63xx; + struct cvmx_iob_pkt_err_s cn63xxp1; + struct cvmx_iob_pkt_err_s cn66xx; + struct cvmx_iob_pkt_err_s cn70xx; + struct cvmx_iob_pkt_err_s cn70xxp1; + struct cvmx_iob_pkt_err_s cnf71xx; +}; + +typedef union cvmx_iob_pkt_err cvmx_iob_pkt_err_t; + +/** + * cvmx_iob_pp_bist_status + * + * The result of the BIST run on the PPs. + * + */ +union cvmx_iob_pp_bist_status { + u64 u64; + struct cvmx_iob_pp_bist_status_s { + u64 reserved_4_63 : 60; + u64 pp_bstat : 4; + } s; + struct cvmx_iob_pp_bist_status_s cn70xx; + struct cvmx_iob_pp_bist_status_s cn70xxp1; +}; + +typedef union cvmx_iob_pp_bist_status cvmx_iob_pp_bist_status_t; + +/** + * cvmx_iob_to_cmb_credits + * + * Controls the number of reads and writes that may be outstanding to the L2C (via the CMB). + * + */ +union cvmx_iob_to_cmb_credits { + u64 u64; + struct cvmx_iob_to_cmb_credits_s { + u64 reserved_6_63 : 58; + u64 ncb_rd : 3; + u64 ncb_wr : 3; + } s; + struct cvmx_iob_to_cmb_credits_cn52xx { + u64 reserved_9_63 : 55; + u64 pko_rd : 3; + u64 ncb_rd : 3; + u64 ncb_wr : 3; + } cn52xx; + struct cvmx_iob_to_cmb_credits_cn52xx cn61xx; + struct cvmx_iob_to_cmb_credits_cn52xx cn63xx; + struct cvmx_iob_to_cmb_credits_cn52xx cn63xxp1; + struct cvmx_iob_to_cmb_credits_cn52xx cn66xx; + struct cvmx_iob_to_cmb_credits_cn68xx { + u64 reserved_9_63 : 55; + u64 dwb : 3; + u64 ncb_rd : 3; + u64 ncb_wr : 3; + } cn68xx; + struct cvmx_iob_to_cmb_credits_cn68xx cn68xxp1; + struct cvmx_iob_to_cmb_credits_cn52xx cn70xx; + struct cvmx_iob_to_cmb_credits_cn52xx cn70xxp1; + struct cvmx_iob_to_cmb_credits_cn52xx cnf71xx; +}; + +typedef union cvmx_iob_to_cmb_credits cvmx_iob_to_cmb_credits_t; + +/** + * cvmx_iob_to_ncb_did_00_credits + * + * IOB_TO_NCB_DID_00_CREDITS = IOB NCB DID 00 Credits + * + * Number of credits for NCB DID 00. + */ +union cvmx_iob_to_ncb_did_00_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_00_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_00_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_00_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_00_credits cvmx_iob_to_ncb_did_00_credits_t; + +/** + * cvmx_iob_to_ncb_did_111_credits + * + * IOB_TO_NCB_DID_111_CREDITS = IOB NCB DID 111 Credits + * + * Number of credits for NCB DID 111. + */ +union cvmx_iob_to_ncb_did_111_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_111_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_111_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_111_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_111_credits cvmx_iob_to_ncb_did_111_credits_t; + +/** + * cvmx_iob_to_ncb_did_223_credits + * + * IOB_TO_NCB_DID_223_CREDITS = IOB NCB DID 223 Credits + * + * Number of credits for NCB DID 223. + */ +union cvmx_iob_to_ncb_did_223_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_223_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_223_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_223_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_223_credits cvmx_iob_to_ncb_did_223_credits_t; + +/** + * cvmx_iob_to_ncb_did_24_credits + * + * IOB_TO_NCB_DID_24_CREDITS = IOB NCB DID 24 Credits + * + * Number of credits for NCB DID 24. + */ +union cvmx_iob_to_ncb_did_24_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_24_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_24_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_24_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_24_credits cvmx_iob_to_ncb_did_24_credits_t; + +/** + * cvmx_iob_to_ncb_did_32_credits + * + * IOB_TO_NCB_DID_32_CREDITS = IOB NCB DID 32 Credits + * + * Number of credits for NCB DID 32. + */ +union cvmx_iob_to_ncb_did_32_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_32_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_32_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_32_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_32_credits cvmx_iob_to_ncb_did_32_credits_t; + +/** + * cvmx_iob_to_ncb_did_40_credits + * + * IOB_TO_NCB_DID_40_CREDITS = IOB NCB DID 40 Credits + * + * Number of credits for NCB DID 40. + */ +union cvmx_iob_to_ncb_did_40_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_40_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_40_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_40_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_40_credits cvmx_iob_to_ncb_did_40_credits_t; + +/** + * cvmx_iob_to_ncb_did_55_credits + * + * IOB_TO_NCB_DID_55_CREDITS = IOB NCB DID 55 Credits + * + * Number of credits for NCB DID 55. + */ +union cvmx_iob_to_ncb_did_55_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_55_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_55_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_55_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_55_credits cvmx_iob_to_ncb_did_55_credits_t; + +/** + * cvmx_iob_to_ncb_did_64_credits + * + * IOB_TO_NCB_DID_64_CREDITS = IOB NCB DID 64 Credits + * + * Number of credits for NCB DID 64. + */ +union cvmx_iob_to_ncb_did_64_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_64_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_64_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_64_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_64_credits cvmx_iob_to_ncb_did_64_credits_t; + +/** + * cvmx_iob_to_ncb_did_79_credits + * + * IOB_TO_NCB_DID_79_CREDITS = IOB NCB DID 79 Credits + * + * Number of credits for NCB DID 79. + */ +union cvmx_iob_to_ncb_did_79_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_79_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_79_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_79_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_79_credits cvmx_iob_to_ncb_did_79_credits_t; + +/** + * cvmx_iob_to_ncb_did_96_credits + * + * IOB_TO_NCB_DID_96_CREDITS = IOB NCB DID 96 Credits + * + * Number of credits for NCB DID 96. + */ +union cvmx_iob_to_ncb_did_96_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_96_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_96_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_96_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_96_credits cvmx_iob_to_ncb_did_96_credits_t; + +/** + * cvmx_iob_to_ncb_did_98_credits + * + * IOB_TO_NCB_DID_98_CREDITS = IOB NCB DID 96 Credits + * + * Number of credits for NCB DID 98. + */ +union cvmx_iob_to_ncb_did_98_credits { + u64 u64; + struct cvmx_iob_to_ncb_did_98_credits_s { + u64 reserved_7_63 : 57; + u64 crd : 7; + } s; + struct cvmx_iob_to_ncb_did_98_credits_s cn68xx; + struct cvmx_iob_to_ncb_did_98_credits_s cn68xxp1; +}; + +typedef union cvmx_iob_to_ncb_did_98_credits cvmx_iob_to_ncb_did_98_credits_t; + +#endif
Import cvmx-lbk-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-lbk-defs.h | 157 ++++++++++++++++++ 1 file changed, 157 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h new file mode 100644 index 000000000000..1068a19ad80b --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h @@ -0,0 +1,157 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon lbk. + */ + +#ifndef __CVMX_LBK_DEFS_H__ +#define __CVMX_LBK_DEFS_H__ + +#define CVMX_LBK_BIST_RESULT (0x0001180012000020ull) +#define CVMX_LBK_CHX_PKIND(offset) (0x0001180012000200ull + ((offset) & 63) * 8) +#define CVMX_LBK_CLK_GATE_CTL (0x0001180012000008ull) +#define CVMX_LBK_DAT_ERR_INFO (0x0001180012000050ull) +#define CVMX_LBK_ECC_CFG (0x0001180012000060ull) +#define CVMX_LBK_INT (0x0001180012000040ull) +#define CVMX_LBK_SFT_RST (0x0001180012000000ull) + +/** + * cvmx_lbk_bist_result + * + * This register provides access to the internal BIST results. Each bit is the + * BIST result of an individual memory (per bit, 0 = pass and 1 = fail). + */ +union cvmx_lbk_bist_result { + u64 u64; + struct cvmx_lbk_bist_result_s { + u64 reserved_1_63 : 63; + u64 dat : 1; + } s; + struct cvmx_lbk_bist_result_s cn73xx; + struct cvmx_lbk_bist_result_s cn78xx; + struct cvmx_lbk_bist_result_s cn78xxp1; + struct cvmx_lbk_bist_result_s cnf75xx; +}; + +typedef union cvmx_lbk_bist_result cvmx_lbk_bist_result_t; + +/** + * cvmx_lbk_ch#_pkind + */ +union cvmx_lbk_chx_pkind { + u64 u64; + struct cvmx_lbk_chx_pkind_s { + u64 reserved_6_63 : 58; + u64 pkind : 6; + } s; + struct cvmx_lbk_chx_pkind_s cn73xx; + struct cvmx_lbk_chx_pkind_s cn78xx; + struct cvmx_lbk_chx_pkind_s cn78xxp1; + struct cvmx_lbk_chx_pkind_s cnf75xx; +}; + +typedef union cvmx_lbk_chx_pkind cvmx_lbk_chx_pkind_t; + +/** + * cvmx_lbk_clk_gate_ctl + * + * This register is for diagnostic use only. + * + */ +union cvmx_lbk_clk_gate_ctl { + u64 u64; + struct cvmx_lbk_clk_gate_ctl_s { + u64 reserved_1_63 : 63; + u64 dis : 1; + } s; + struct cvmx_lbk_clk_gate_ctl_s cn73xx; + struct cvmx_lbk_clk_gate_ctl_s cn78xx; + struct cvmx_lbk_clk_gate_ctl_s cn78xxp1; + struct cvmx_lbk_clk_gate_ctl_s cnf75xx; +}; + +typedef union cvmx_lbk_clk_gate_ctl cvmx_lbk_clk_gate_ctl_t; + +/** + * cvmx_lbk_dat_err_info + */ +union cvmx_lbk_dat_err_info { + u64 u64; + struct cvmx_lbk_dat_err_info_s { + u64 reserved_58_63 : 6; + u64 dbe_ecc_out : 9; + u64 dbe_synd : 9; + u64 dbe_addr : 8; + u64 reserved_26_31 : 6; + u64 sbe_ecc_out : 9; + u64 sbe_synd : 9; + u64 sbe_addr : 8; + } s; + struct cvmx_lbk_dat_err_info_s cn73xx; + struct cvmx_lbk_dat_err_info_s cn78xx; + struct cvmx_lbk_dat_err_info_s cn78xxp1; + struct cvmx_lbk_dat_err_info_s cnf75xx; +}; + +typedef union cvmx_lbk_dat_err_info cvmx_lbk_dat_err_info_t; + +/** + * cvmx_lbk_ecc_cfg + */ +union cvmx_lbk_ecc_cfg { + u64 u64; + struct cvmx_lbk_ecc_cfg_s { + u64 reserved_3_63 : 61; + u64 dat_flip : 2; + u64 dat_cdis : 1; + } s; + struct cvmx_lbk_ecc_cfg_s cn73xx; + struct cvmx_lbk_ecc_cfg_s cn78xx; + struct cvmx_lbk_ecc_cfg_s cn78xxp1; + struct cvmx_lbk_ecc_cfg_s cnf75xx; +}; + +typedef union cvmx_lbk_ecc_cfg cvmx_lbk_ecc_cfg_t; + +/** + * cvmx_lbk_int + */ +union cvmx_lbk_int { + u64 u64; + struct cvmx_lbk_int_s { + u64 reserved_6_63 : 58; + u64 chan_oflow : 1; + u64 chan_uflow : 1; + u64 dat_oflow : 1; + u64 dat_uflow : 1; + u64 dat_dbe : 1; + u64 dat_sbe : 1; + } s; + struct cvmx_lbk_int_s cn73xx; + struct cvmx_lbk_int_s cn78xx; + struct cvmx_lbk_int_s cn78xxp1; + struct cvmx_lbk_int_s cnf75xx; +}; + +typedef union cvmx_lbk_int cvmx_lbk_int_t; + +/** + * cvmx_lbk_sft_rst + */ +union cvmx_lbk_sft_rst { + u64 u64; + struct cvmx_lbk_sft_rst_s { + u64 reserved_1_63 : 63; + u64 reset : 1; + } s; + struct cvmx_lbk_sft_rst_s cn73xx; + struct cvmx_lbk_sft_rst_s cn78xx; + struct cvmx_lbk_sft_rst_s cn78xxp1; + struct cvmx_lbk_sft_rst_s cnf75xx; +}; + +typedef union cvmx_lbk_sft_rst cvmx_lbk_sft_rst_t; + +#endif
Import cvmx-npei-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-npei-defs.h | 3550 +++++++++++++++++ 1 file changed, 3550 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h new file mode 100644 index 000000000000..2e2c24819445 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h @@ -0,0 +1,3550 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon npei. + */ + +#ifndef __CVMX_NPEI_DEFS_H__ +#define __CVMX_NPEI_DEFS_H__ + +#define CVMX_NPEI_BAR1_INDEXX(offset) \ + (0x0000000000000000ull + ((offset) & 31) * 16) +#define CVMX_NPEI_BIST_STATUS (0x0000000000000580ull) +#define CVMX_NPEI_BIST_STATUS2 (0x0000000000000680ull) +#define CVMX_NPEI_CTL_PORT0 (0x0000000000000250ull) +#define CVMX_NPEI_CTL_PORT1 (0x0000000000000260ull) +#define CVMX_NPEI_CTL_STATUS (0x0000000000000570ull) +#define CVMX_NPEI_CTL_STATUS2 (0x0000000000003C00ull) +#define CVMX_NPEI_DATA_OUT_CNT (0x00000000000005F0ull) +#define CVMX_NPEI_DBG_DATA (0x0000000000000510ull) +#define CVMX_NPEI_DBG_SELECT (0x0000000000000500ull) +#define CVMX_NPEI_DMA0_INT_LEVEL (0x00000000000005C0ull) +#define CVMX_NPEI_DMA1_INT_LEVEL (0x00000000000005D0ull) +#define CVMX_NPEI_DMAX_COUNTS(offset) \ + (0x0000000000000450ull + ((offset) & 7) * 16) +#define CVMX_NPEI_DMAX_DBELL(offset) (0x00000000000003B0ull + ((offset) & 7) * 16) +#define CVMX_NPEI_DMAX_IBUFF_SADDR(offset) \ + (0x0000000000000400ull + ((offset) & 7) * 16) +#define CVMX_NPEI_DMAX_NADDR(offset) (0x00000000000004A0ull + ((offset) & 7) * 16) +#define CVMX_NPEI_DMA_CNTS (0x00000000000005E0ull) +#define CVMX_NPEI_DMA_CONTROL (0x00000000000003A0ull) +#define CVMX_NPEI_DMA_PCIE_REQ_NUM (0x00000000000005B0ull) +#define CVMX_NPEI_DMA_STATE1 (0x00000000000006C0ull) +#define CVMX_NPEI_DMA_STATE1_P1 (0x0000000000000680ull) +#define CVMX_NPEI_DMA_STATE2 (0x00000000000006D0ull) +#define CVMX_NPEI_DMA_STATE2_P1 (0x0000000000000690ull) +#define CVMX_NPEI_DMA_STATE3_P1 (0x00000000000006A0ull) +#define CVMX_NPEI_DMA_STATE4_P1 (0x00000000000006B0ull) +#define CVMX_NPEI_DMA_STATE5_P1 (0x00000000000006C0ull) +#define CVMX_NPEI_INT_A_ENB (0x0000000000000560ull) +#define CVMX_NPEI_INT_A_ENB2 (0x0000000000003CE0ull) +#define CVMX_NPEI_INT_A_SUM (0x0000000000000550ull) +#define CVMX_NPEI_INT_ENB (0x0000000000000540ull) +#define CVMX_NPEI_INT_ENB2 (0x0000000000003CD0ull) +#define CVMX_NPEI_INT_INFO (0x0000000000000590ull) +#define CVMX_NPEI_INT_SUM (0x0000000000000530ull) +#define CVMX_NPEI_INT_SUM2 (0x0000000000003CC0ull) +#define CVMX_NPEI_LAST_WIN_RDATA0 (0x0000000000000600ull) +#define CVMX_NPEI_LAST_WIN_RDATA1 (0x0000000000000610ull) +#define CVMX_NPEI_MEM_ACCESS_CTL (0x00000000000004F0ull) +#define CVMX_NPEI_MEM_ACCESS_SUBIDX(offset) \ + (0x0000000000000280ull + ((offset) & 31) * 16 - 16 * 12) +#define CVMX_NPEI_MSI_ENB0 (0x0000000000003C50ull) +#define CVMX_NPEI_MSI_ENB1 (0x0000000000003C60ull) +#define CVMX_NPEI_MSI_ENB2 (0x0000000000003C70ull) +#define CVMX_NPEI_MSI_ENB3 (0x0000000000003C80ull) +#define CVMX_NPEI_MSI_RCV0 (0x0000000000003C10ull) +#define CVMX_NPEI_MSI_RCV1 (0x0000000000003C20ull) +#define CVMX_NPEI_MSI_RCV2 (0x0000000000003C30ull) +#define CVMX_NPEI_MSI_RCV3 (0x0000000000003C40ull) +#define CVMX_NPEI_MSI_RD_MAP (0x0000000000003CA0ull) +#define CVMX_NPEI_MSI_W1C_ENB0 (0x0000000000003CF0ull) +#define CVMX_NPEI_MSI_W1C_ENB1 (0x0000000000003D00ull) +#define CVMX_NPEI_MSI_W1C_ENB2 (0x0000000000003D10ull) +#define CVMX_NPEI_MSI_W1C_ENB3 (0x0000000000003D20ull) +#define CVMX_NPEI_MSI_W1S_ENB0 (0x0000000000003D30ull) +#define CVMX_NPEI_MSI_W1S_ENB1 (0x0000000000003D40ull) +#define CVMX_NPEI_MSI_W1S_ENB2 (0x0000000000003D50ull) +#define CVMX_NPEI_MSI_W1S_ENB3 (0x0000000000003D60ull) +#define CVMX_NPEI_MSI_WR_MAP (0x0000000000003C90ull) +#define CVMX_NPEI_PCIE_CREDIT_CNT (0x0000000000003D70ull) +#define CVMX_NPEI_PCIE_MSI_RCV (0x0000000000003CB0ull) +#define CVMX_NPEI_PCIE_MSI_RCV_B1 (0x0000000000000650ull) +#define CVMX_NPEI_PCIE_MSI_RCV_B2 (0x0000000000000660ull) +#define CVMX_NPEI_PCIE_MSI_RCV_B3 (0x0000000000000670ull) +#define CVMX_NPEI_PKTX_CNTS(offset) (0x0000000000002400ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_INSTR_BADDR(offset) \ + (0x0000000000002800ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_INSTR_BAOFF_DBELL(offset) \ + (0x0000000000002C00ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_INSTR_FIFO_RSIZE(offset) \ + (0x0000000000003000ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_INSTR_HEADER(offset) \ + (0x0000000000003400ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_IN_BP(offset) \ + (0x0000000000003800ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_SLIST_BADDR(offset) \ + (0x0000000000001400ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_SLIST_BAOFF_DBELL(offset) \ + (0x0000000000001800ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKTX_SLIST_FIFO_RSIZE(offset) \ + (0x0000000000001C00ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKT_CNT_INT (0x0000000000001110ull) +#define CVMX_NPEI_PKT_CNT_INT_ENB (0x0000000000001130ull) +#define CVMX_NPEI_PKT_DATA_OUT_ES (0x00000000000010B0ull) +#define CVMX_NPEI_PKT_DATA_OUT_NS (0x00000000000010A0ull) +#define CVMX_NPEI_PKT_DATA_OUT_ROR (0x0000000000001090ull) +#define CVMX_NPEI_PKT_DPADDR (0x0000000000001080ull) +#define CVMX_NPEI_PKT_INPUT_CONTROL (0x0000000000001150ull) +#define CVMX_NPEI_PKT_INSTR_ENB (0x0000000000001000ull) +#define CVMX_NPEI_PKT_INSTR_RD_SIZE (0x0000000000001190ull) +#define CVMX_NPEI_PKT_INSTR_SIZE (0x0000000000001020ull) +#define CVMX_NPEI_PKT_INT_LEVELS (0x0000000000001100ull) +#define CVMX_NPEI_PKT_IN_BP (0x00000000000006B0ull) +#define CVMX_NPEI_PKT_IN_DONEX_CNTS(offset) \ + (0x0000000000002000ull + ((offset) & 31) * 16) +#define CVMX_NPEI_PKT_IN_INSTR_COUNTS (0x00000000000006A0ull) +#define CVMX_NPEI_PKT_IN_PCIE_PORT (0x00000000000011A0ull) +#define CVMX_NPEI_PKT_IPTR (0x0000000000001070ull) +#define CVMX_NPEI_PKT_OUTPUT_WMARK (0x0000000000001160ull) +#define CVMX_NPEI_PKT_OUT_BMODE (0x00000000000010D0ull) +#define CVMX_NPEI_PKT_OUT_ENB (0x0000000000001010ull) +#define CVMX_NPEI_PKT_PCIE_PORT (0x00000000000010E0ull) +#define CVMX_NPEI_PKT_PORT_IN_RST (0x0000000000000690ull) +#define CVMX_NPEI_PKT_SLIST_ES (0x0000000000001050ull) +#define CVMX_NPEI_PKT_SLIST_ID_SIZE (0x0000000000001180ull) +#define CVMX_NPEI_PKT_SLIST_NS (0x0000000000001040ull) +#define CVMX_NPEI_PKT_SLIST_ROR (0x0000000000001030ull) +#define CVMX_NPEI_PKT_TIME_INT (0x0000000000001120ull) +#define CVMX_NPEI_PKT_TIME_INT_ENB (0x0000000000001140ull) +#define CVMX_NPEI_RSL_INT_BLOCKS (0x0000000000000520ull) +#define CVMX_NPEI_SCRATCH_1 (0x0000000000000270ull) +#define CVMX_NPEI_STATE1 (0x0000000000000620ull) +#define CVMX_NPEI_STATE2 (0x0000000000000630ull) +#define CVMX_NPEI_STATE3 (0x0000000000000640ull) +#define CVMX_NPEI_WINDOW_CTL (0x0000000000000380ull) +#define CVMX_NPEI_WIN_RD_ADDR (0x0000000000000210ull) +#define CVMX_NPEI_WIN_RD_DATA (0x0000000000000240ull) +#define CVMX_NPEI_WIN_WR_ADDR (0x0000000000000200ull) +#define CVMX_NPEI_WIN_WR_DATA (0x0000000000000220ull) +#define CVMX_NPEI_WIN_WR_MASK (0x0000000000000230ull) + +/** + * cvmx_npei_bar1_index# + * + * Total Address is 16Kb; 0x0000 - 0x3fff, 0x000 - 0x7fe(Reg, every other 8B) + * + * General 5kb; 0x0000 - 0x13ff, 0x000 - 0x27e(Reg-General) + * PktMem 10Kb; 0x1400 - 0x3bff, 0x280 - 0x77e(Reg-General-Packet) + * Rsvd 1Kb; 0x3c00 - 0x3fff, 0x780 - 0x7fe(Reg-NCB Only Mode) + * == NPEI_PKT_CNT_INT_ENB[PORT] + * == NPEI_PKT_TIME_INT_ENB[PORT] + * == NPEI_PKT_CNT_INT[PORT] + * == NPEI_PKT_TIME_INT[PORT] + * == NPEI_PKT_PCIE_PORT[PP] + * == NPEI_PKT_SLIST_ROR[ROR] + * == NPEI_PKT_SLIST_ROR[NSR] ? + * == NPEI_PKT_SLIST_ES[ES] + * == NPEI_PKTn_SLIST_BAOFF_DBELL[AOFF] + * == NPEI_PKTn_SLIST_BAOFF_DBELL[DBELL] + * == NPEI_PKTn_CNTS[CNT] + * NPEI_CTL_STATUS[OUTn_ENB] == NPEI_PKT_OUT_ENB[ENB] + * NPEI_BASE_ADDRESS_OUTPUTn[BADDR] == NPEI_PKTn_SLIST_BADDR[ADDR] + * NPEI_DESC_OUTPUTn[SIZE] == NPEI_PKTn_SLIST_FIFO_RSIZE[RSIZE] + * NPEI_Pn_DBPAIR_ADDR[NADDR] == NPEI_PKTn_SLIST_BADDR[ADDR] + + * NPEI_PKTn_SLIST_BAOFF_DBELL[AOFF] + * NPEI_PKT_CREDITSn[PTR_CNT] == NPEI_PKTn_SLIST_BAOFF_DBELL[DBELL] + * NPEI_P0_PAIR_CNTS[AVAIL] == NPEI_PKTn_SLIST_BAOFF_DBELL[DBELL] + * NPEI_P0_PAIR_CNTS[FCNT] == + * NPEI_PKTS_SENTn[PKT_CNT] == NPEI_PKTn_CNTS[CNT] + * NPEI_OUTPUT_CONTROL[Pn_BMODE] == NPEI_PKT_OUT_BMODE[BMODE] + * NPEI_PKT_CREDITSn[PKT_CNT] == NPEI_PKTn_CNTS[CNT] + * NPEI_BUFF_SIZE_OUTPUTn[BSIZE] == NPEI_PKT_SLIST_ID_SIZE[BSIZE] + * NPEI_BUFF_SIZE_OUTPUTn[ISIZE] == NPEI_PKT_SLIST_ID_SIZE[ISIZE] + * NPEI_OUTPUT_CONTROL[On_CSRM] == NPEI_PKT_DPADDR[DPTR] & + * NPEI_PKT_OUT_USE_IPTR[PORT] + * NPEI_OUTPUT_CONTROL[On_ES] == NPEI_PKT_DATA_OUT_ES[ES] + * NPEI_OUTPUT_CONTROL[On_NS] == NPEI_PKT_DATA_OUT_NS[NSR] ? + * NPEI_OUTPUT_CONTROL[On_RO] == NPEI_PKT_DATA_OUT_ROR[ROR] + * NPEI_PKTS_SENT_INT_LEVn[PKT_CNT] == NPEI_PKT_INT_LEVELS[CNT] + * NPEI_PKTS_SENT_TIMEn[PKT_TIME] == NPEI_PKT_INT_LEVELS[TIME] + * NPEI_OUTPUT_CONTROL[IPTR_On] == NPEI_PKT_IPTR[IPTR] + * NPEI_PCIE_PORT_OUTPUT[] == NPEI_PKT_PCIE_PORT[PP] + * + * NPEI_BAR1_INDEXX = NPEI BAR1 IndexX Register + * + * Contains address index and control bits for access to memory ranges of + * BAR-1. Index is build from supplied address [25:22]. + * NPEI_BAR1_INDEX0 through NPEI_BAR1_INDEX15 is used for transactions + * orginating with PCIE-PORT0 and NPEI_BAR1_INDEX16 + * through NPEI_BAR1_INDEX31 is used for transactions originating with + * PCIE-PORT1. + */ +union cvmx_npei_bar1_indexx { + u32 u32; + struct cvmx_npei_bar1_indexx_s { + u32 reserved_18_31 : 14; + u32 addr_idx : 14; + u32 ca : 1; + u32 end_swp : 2; + u32 addr_v : 1; + } s; + struct cvmx_npei_bar1_indexx_s cn52xx; + struct cvmx_npei_bar1_indexx_s cn52xxp1; + struct cvmx_npei_bar1_indexx_s cn56xx; + struct cvmx_npei_bar1_indexx_s cn56xxp1; +}; + +typedef union cvmx_npei_bar1_indexx cvmx_npei_bar1_indexx_t; + +/** + * cvmx_npei_bist_status + * + * NPEI_BIST_STATUS = NPI's BIST Status Register + * + * Results from BIST runs of NPEI's memories. + */ +union cvmx_npei_bist_status { + u64 u64; + struct cvmx_npei_bist_status_s { + u64 pkt_rdf : 1; + u64 reserved_60_62 : 3; + u64 pcr_gim : 1; + u64 pkt_pif : 1; + u64 pcsr_int : 1; + u64 pcsr_im : 1; + u64 pcsr_cnt : 1; + u64 pcsr_id : 1; + u64 pcsr_sl : 1; + u64 reserved_50_52 : 3; + u64 pkt_ind : 1; + u64 pkt_slm : 1; + u64 reserved_36_47 : 12; + u64 d0_pst : 1; + u64 d1_pst : 1; + u64 d2_pst : 1; + u64 d3_pst : 1; + u64 reserved_31_31 : 1; + u64 n2p0_c : 1; + u64 n2p0_o : 1; + u64 n2p1_c : 1; + u64 n2p1_o : 1; + u64 cpl_p0 : 1; + u64 cpl_p1 : 1; + u64 p2n1_po : 1; + u64 p2n1_no : 1; + u64 p2n1_co : 1; + u64 p2n0_po : 1; + u64 p2n0_no : 1; + u64 p2n0_co : 1; + u64 p2n0_c0 : 1; + u64 p2n0_c1 : 1; + u64 p2n0_n : 1; + u64 p2n0_p0 : 1; + u64 p2n0_p1 : 1; + u64 p2n1_c0 : 1; + u64 p2n1_c1 : 1; + u64 p2n1_n : 1; + u64 p2n1_p0 : 1; + u64 p2n1_p1 : 1; + u64 csm0 : 1; + u64 csm1 : 1; + u64 dif0 : 1; + u64 dif1 : 1; + u64 dif2 : 1; + u64 dif3 : 1; + u64 reserved_2_2 : 1; + u64 msi : 1; + u64 ncb_cmd : 1; + } s; + struct cvmx_npei_bist_status_cn52xx { + u64 pkt_rdf : 1; + u64 reserved_60_62 : 3; + u64 pcr_gim : 1; + u64 pkt_pif : 1; + u64 pcsr_int : 1; + u64 pcsr_im : 1; + u64 pcsr_cnt : 1; + u64 pcsr_id : 1; + u64 pcsr_sl : 1; + u64 pkt_imem : 1; + u64 pkt_pfm : 1; + u64 pkt_pof : 1; + u64 reserved_48_49 : 2; + u64 pkt_pop0 : 1; + u64 pkt_pop1 : 1; + u64 d0_mem : 1; + u64 d1_mem : 1; + u64 d2_mem : 1; + u64 d3_mem : 1; + u64 d4_mem : 1; + u64 ds_mem : 1; + u64 reserved_36_39 : 4; + u64 d0_pst : 1; + u64 d1_pst : 1; + u64 d2_pst : 1; + u64 d3_pst : 1; + u64 d4_pst : 1; + u64 n2p0_c : 1; + u64 n2p0_o : 1; + u64 n2p1_c : 1; + u64 n2p1_o : 1; + u64 cpl_p0 : 1; + u64 cpl_p1 : 1; + u64 p2n1_po : 1; + u64 p2n1_no : 1; + u64 p2n1_co : 1; + u64 p2n0_po : 1; + u64 p2n0_no : 1; + u64 p2n0_co : 1; + u64 p2n0_c0 : 1; + u64 p2n0_c1 : 1; + u64 p2n0_n : 1; + u64 p2n0_p0 : 1; + u64 p2n0_p1 : 1; + u64 p2n1_c0 : 1; + u64 p2n1_c1 : 1; + u64 p2n1_n : 1; + u64 p2n1_p0 : 1; + u64 p2n1_p1 : 1; + u64 csm0 : 1; + u64 csm1 : 1; + u64 dif0 : 1; + u64 dif1 : 1; + u64 dif2 : 1; + u64 dif3 : 1; + u64 dif4 : 1; + u64 msi : 1; + u64 ncb_cmd : 1; + } cn52xx; + struct cvmx_npei_bist_status_cn52xxp1 { + u64 reserved_46_63 : 18; + u64 d0_mem0 : 1; + u64 d1_mem1 : 1; + u64 d2_mem2 : 1; + u64 d3_mem3 : 1; + u64 dr0_mem : 1; + u64 d0_mem : 1; + u64 d1_mem : 1; + u64 d2_mem : 1; + u64 d3_mem : 1; + u64 dr1_mem : 1; + u64 d0_pst : 1; + u64 d1_pst : 1; + u64 d2_pst : 1; + u64 d3_pst : 1; + u64 dr2_mem : 1; + u64 n2p0_c : 1; + u64 n2p0_o : 1; + u64 n2p1_c : 1; + u64 n2p1_o : 1; + u64 cpl_p0 : 1; + u64 cpl_p1 : 1; + u64 p2n1_po : 1; + u64 p2n1_no : 1; + u64 p2n1_co : 1; + u64 p2n0_po : 1; + u64 p2n0_no : 1; + u64 p2n0_co : 1; + u64 p2n0_c0 : 1; + u64 p2n0_c1 : 1; + u64 p2n0_n : 1; + u64 p2n0_p0 : 1; + u64 p2n0_p1 : 1; + u64 p2n1_c0 : 1; + u64 p2n1_c1 : 1; + u64 p2n1_n : 1; + u64 p2n1_p0 : 1; + u64 p2n1_p1 : 1; + u64 csm0 : 1; + u64 csm1 : 1; + u64 dif0 : 1; + u64 dif1 : 1; + u64 dif2 : 1; + u64 dif3 : 1; + u64 dr3_mem : 1; + u64 msi : 1; + u64 ncb_cmd : 1; + } cn52xxp1; + struct cvmx_npei_bist_status_cn52xx cn56xx; + struct cvmx_npei_bist_status_cn56xxp1 { + u64 reserved_58_63 : 6; + u64 pcsr_int : 1; + u64 pcsr_im : 1; + u64 pcsr_cnt : 1; + u64 pcsr_id : 1; + u64 pcsr_sl : 1; + u64 pkt_pout : 1; + u64 pkt_imem : 1; + u64 pkt_cntm : 1; + u64 pkt_ind : 1; + u64 pkt_slm : 1; + u64 pkt_odf : 1; + u64 pkt_oif : 1; + u64 pkt_out : 1; + u64 pkt_i0 : 1; + u64 pkt_i1 : 1; + u64 pkt_s0 : 1; + u64 pkt_s1 : 1; + u64 d0_mem : 1; + u64 d1_mem : 1; + u64 d2_mem : 1; + u64 d3_mem : 1; + u64 d4_mem : 1; + u64 d0_pst : 1; + u64 d1_pst : 1; + u64 d2_pst : 1; + u64 d3_pst : 1; + u64 d4_pst : 1; + u64 n2p0_c : 1; + u64 n2p0_o : 1; + u64 n2p1_c : 1; + u64 n2p1_o : 1; + u64 cpl_p0 : 1; + u64 cpl_p1 : 1; + u64 p2n1_po : 1; + u64 p2n1_no : 1; + u64 p2n1_co : 1; + u64 p2n0_po : 1; + u64 p2n0_no : 1; + u64 p2n0_co : 1; + u64 p2n0_c0 : 1; + u64 p2n0_c1 : 1; + u64 p2n0_n : 1; + u64 p2n0_p0 : 1; + u64 p2n0_p1 : 1; + u64 p2n1_c0 : 1; + u64 p2n1_c1 : 1; + u64 p2n1_n : 1; + u64 p2n1_p0 : 1; + u64 p2n1_p1 : 1; + u64 csm0 : 1; + u64 csm1 : 1; + u64 dif0 : 1; + u64 dif1 : 1; + u64 dif2 : 1; + u64 dif3 : 1; + u64 dif4 : 1; + u64 msi : 1; + u64 ncb_cmd : 1; + } cn56xxp1; +}; + +typedef union cvmx_npei_bist_status cvmx_npei_bist_status_t; + +/** + * cvmx_npei_bist_status2 + * + * NPEI_BIST_STATUS2 = NPI's BIST Status Register2 + * + * Results from BIST runs of NPEI's memories. + */ +union cvmx_npei_bist_status2 { + u64 u64; + struct cvmx_npei_bist_status2_s { + u64 reserved_14_63 : 50; + u64 prd_tag : 1; + u64 prd_st0 : 1; + u64 prd_st1 : 1; + u64 prd_err : 1; + u64 nrd_st : 1; + u64 nwe_st : 1; + u64 nwe_wr0 : 1; + u64 nwe_wr1 : 1; + u64 pkt_rd : 1; + u64 psc_p0 : 1; + u64 psc_p1 : 1; + u64 pkt_gd : 1; + u64 pkt_gl : 1; + u64 pkt_blk : 1; + } s; + struct cvmx_npei_bist_status2_s cn52xx; + struct cvmx_npei_bist_status2_s cn56xx; +}; + +typedef union cvmx_npei_bist_status2 cvmx_npei_bist_status2_t; + +/** + * cvmx_npei_ctl_port0 + * + * NPEI_CTL_PORT0 = NPEI's Control Port 0 + * + * Contains control for access for Port0 + */ +union cvmx_npei_ctl_port0 { + u64 u64; + struct cvmx_npei_ctl_port0_s { + u64 reserved_21_63 : 43; + u64 waitl_com : 1; + u64 intd : 1; + u64 intc : 1; + u64 intb : 1; + u64 inta : 1; + u64 intd_map : 2; + u64 intc_map : 2; + u64 intb_map : 2; + u64 inta_map : 2; + u64 ctlp_ro : 1; + u64 reserved_6_6 : 1; + u64 ptlp_ro : 1; + u64 bar2_enb : 1; + u64 bar2_esx : 2; + u64 bar2_cax : 1; + u64 wait_com : 1; + } s; + struct cvmx_npei_ctl_port0_s cn52xx; + struct cvmx_npei_ctl_port0_s cn52xxp1; + struct cvmx_npei_ctl_port0_s cn56xx; + struct cvmx_npei_ctl_port0_s cn56xxp1; +}; + +typedef union cvmx_npei_ctl_port0 cvmx_npei_ctl_port0_t; + +/** + * cvmx_npei_ctl_port1 + * + * NPEI_CTL_PORT1 = NPEI's Control Port1 + * + * Contains control for access for Port1 + */ +union cvmx_npei_ctl_port1 { + u64 u64; + struct cvmx_npei_ctl_port1_s { + u64 reserved_21_63 : 43; + u64 waitl_com : 1; + u64 intd : 1; + u64 intc : 1; + u64 intb : 1; + u64 inta : 1; + u64 intd_map : 2; + u64 intc_map : 2; + u64 intb_map : 2; + u64 inta_map : 2; + u64 ctlp_ro : 1; + u64 reserved_6_6 : 1; + u64 ptlp_ro : 1; + u64 bar2_enb : 1; + u64 bar2_esx : 2; + u64 bar2_cax : 1; + u64 wait_com : 1; + } s; + struct cvmx_npei_ctl_port1_s cn52xx; + struct cvmx_npei_ctl_port1_s cn52xxp1; + struct cvmx_npei_ctl_port1_s cn56xx; + struct cvmx_npei_ctl_port1_s cn56xxp1; +}; + +typedef union cvmx_npei_ctl_port1 cvmx_npei_ctl_port1_t; + +/** + * cvmx_npei_ctl_status + * + * NPEI_CTL_STATUS = NPEI Control Status Register + * + * Contains control and status for NPEI. Writes to this register are not + * oSrdered with writes/reads to the PCIe Memory space. + * To ensure that a write has completed the user must read the register + * before making an access(i.e. PCIe memory space) + * that requires the value of this register to be updated. + */ +union cvmx_npei_ctl_status { + u64 u64; + struct cvmx_npei_ctl_status_s { + u64 reserved_44_63 : 20; + u64 p1_ntags : 6; + u64 p0_ntags : 6; + u64 cfg_rtry : 16; + u64 ring_en : 1; + u64 lnk_rst : 1; + u64 arb : 1; + u64 pkt_bp : 4; + u64 host_mode : 1; + u64 chip_rev : 8; + } s; + struct cvmx_npei_ctl_status_s cn52xx; + struct cvmx_npei_ctl_status_cn52xxp1 { + u64 reserved_44_63 : 20; + u64 p1_ntags : 6; + u64 p0_ntags : 6; + u64 cfg_rtry : 16; + u64 reserved_15_15 : 1; + u64 lnk_rst : 1; + u64 arb : 1; + u64 reserved_9_12 : 4; + u64 host_mode : 1; + u64 chip_rev : 8; + } cn52xxp1; + struct cvmx_npei_ctl_status_s cn56xx; + struct cvmx_npei_ctl_status_cn56xxp1 { + u64 reserved_15_63 : 49; + u64 lnk_rst : 1; + u64 arb : 1; + u64 pkt_bp : 4; + u64 host_mode : 1; + u64 chip_rev : 8; + } cn56xxp1; +}; + +typedef union cvmx_npei_ctl_status cvmx_npei_ctl_status_t; + +/** + * cvmx_npei_ctl_status2 + * + * NPEI_CTL_STATUS2 = NPEI's Control Status2 Register + * + * Contains control and status for NPEI. + * Writes to this register are not ordered with writes/reads to the PCI + * Memory space. + * To ensure that a write has completed the user must read the register before + * making an access(i.e. PCI memory space) that requires the value of this + * register to be updated. + */ +union cvmx_npei_ctl_status2 { + u64 u64; + struct cvmx_npei_ctl_status2_s { + u64 reserved_16_63 : 48; + u64 mps : 1; + u64 mrrs : 3; + u64 c1_w_flt : 1; + u64 c0_w_flt : 1; + u64 c1_b1_s : 3; + u64 c0_b1_s : 3; + u64 c1_wi_d : 1; + u64 c1_b0_d : 1; + u64 c0_wi_d : 1; + u64 c0_b0_d : 1; + } s; + struct cvmx_npei_ctl_status2_s cn52xx; + struct cvmx_npei_ctl_status2_s cn52xxp1; + struct cvmx_npei_ctl_status2_s cn56xx; + struct cvmx_npei_ctl_status2_s cn56xxp1; +}; + +typedef union cvmx_npei_ctl_status2 cvmx_npei_ctl_status2_t; + +/** + * cvmx_npei_data_out_cnt + * + * NPEI_DATA_OUT_CNT = NPEI DATA OUT COUNT + * + * The EXEC data out fifo-count and the data unload counter. + */ +union cvmx_npei_data_out_cnt { + u64 u64; + struct cvmx_npei_data_out_cnt_s { + u64 reserved_44_63 : 20; + u64 p1_ucnt : 16; + u64 p1_fcnt : 6; + u64 p0_ucnt : 16; + u64 p0_fcnt : 6; + } s; + struct cvmx_npei_data_out_cnt_s cn52xx; + struct cvmx_npei_data_out_cnt_s cn52xxp1; + struct cvmx_npei_data_out_cnt_s cn56xx; + struct cvmx_npei_data_out_cnt_s cn56xxp1; +}; + +typedef union cvmx_npei_data_out_cnt cvmx_npei_data_out_cnt_t; + +/** + * cvmx_npei_dbg_data + * + * NPEI_DBG_DATA = NPEI Debug Data Register + * + * Value returned on the debug-data lines from the RSLs + */ +union cvmx_npei_dbg_data { + u64 u64; + struct cvmx_npei_dbg_data_s { + u64 reserved_28_63 : 36; + u64 qlm0_rev_lanes : 1; + u64 reserved_25_26 : 2; + u64 qlm1_spd : 2; + u64 c_mul : 5; + u64 dsel_ext : 1; + u64 data : 17; + } s; + struct cvmx_npei_dbg_data_cn52xx { + u64 reserved_29_63 : 35; + u64 qlm0_link_width : 1; + u64 qlm0_rev_lanes : 1; + u64 qlm1_mode : 2; + u64 qlm1_spd : 2; + u64 c_mul : 5; + u64 dsel_ext : 1; + u64 data : 17; + } cn52xx; + struct cvmx_npei_dbg_data_cn52xx cn52xxp1; + struct cvmx_npei_dbg_data_cn56xx { + u64 reserved_29_63 : 35; + u64 qlm2_rev_lanes : 1; + u64 qlm0_rev_lanes : 1; + u64 qlm3_spd : 2; + u64 qlm1_spd : 2; + u64 c_mul : 5; + u64 dsel_ext : 1; + u64 data : 17; + } cn56xx; + struct cvmx_npei_dbg_data_cn56xx cn56xxp1; +}; + +typedef union cvmx_npei_dbg_data cvmx_npei_dbg_data_t; + +/** + * cvmx_npei_dbg_select + * + * NPEI_DBG_SELECT = Debug Select Register + * + * Contains the debug select value last written to the RSLs. + */ +union cvmx_npei_dbg_select { + u64 u64; + struct cvmx_npei_dbg_select_s { + u64 reserved_16_63 : 48; + u64 dbg_sel : 16; + } s; + struct cvmx_npei_dbg_select_s cn52xx; + struct cvmx_npei_dbg_select_s cn52xxp1; + struct cvmx_npei_dbg_select_s cn56xx; + struct cvmx_npei_dbg_select_s cn56xxp1; +}; + +typedef union cvmx_npei_dbg_select cvmx_npei_dbg_select_t; + +/** + * cvmx_npei_dma#_counts + * + * NPEI_DMA[0..4]_COUNTS = DMA Instruction Counts + * + * Values for determing the number of instructions for DMA[0..4] in the NPEI. + */ +union cvmx_npei_dmax_counts { + u64 u64; + struct cvmx_npei_dmax_counts_s { + u64 reserved_39_63 : 25; + u64 fcnt : 7; + u64 dbell : 32; + } s; + struct cvmx_npei_dmax_counts_s cn52xx; + struct cvmx_npei_dmax_counts_s cn52xxp1; + struct cvmx_npei_dmax_counts_s cn56xx; + struct cvmx_npei_dmax_counts_s cn56xxp1; +}; + +typedef union cvmx_npei_dmax_counts cvmx_npei_dmax_counts_t; + +/** + * cvmx_npei_dma#_dbell + * + * NPEI_DMA_DBELL[0..4] = DMA Door Bell + * + * The door bell register for DMA[0..4] queue. + */ +union cvmx_npei_dmax_dbell { + u32 u32; + struct cvmx_npei_dmax_dbell_s { + u32 reserved_16_31 : 16; + u32 dbell : 16; + } s; + struct cvmx_npei_dmax_dbell_s cn52xx; + struct cvmx_npei_dmax_dbell_s cn52xxp1; + struct cvmx_npei_dmax_dbell_s cn56xx; + struct cvmx_npei_dmax_dbell_s cn56xxp1; +}; + +typedef union cvmx_npei_dmax_dbell cvmx_npei_dmax_dbell_t; + +/** + * cvmx_npei_dma#_ibuff_saddr + * + * NPEI_DMA[0..4]_IBUFF_SADDR = DMA Instruction Buffer Starting Address + * + * The address to start reading Instructions from for DMA[0..4]. + */ +union cvmx_npei_dmax_ibuff_saddr { + u64 u64; + struct cvmx_npei_dmax_ibuff_saddr_s { + u64 reserved_37_63 : 27; + u64 idle : 1; + u64 saddr : 29; + u64 reserved_0_6 : 7; + } s; + struct cvmx_npei_dmax_ibuff_saddr_s cn52xx; + struct cvmx_npei_dmax_ibuff_saddr_cn52xxp1 { + u64 reserved_36_63 : 28; + u64 saddr : 29; + u64 reserved_0_6 : 7; + } cn52xxp1; + struct cvmx_npei_dmax_ibuff_saddr_s cn56xx; + struct cvmx_npei_dmax_ibuff_saddr_cn52xxp1 cn56xxp1; +}; + +typedef union cvmx_npei_dmax_ibuff_saddr cvmx_npei_dmax_ibuff_saddr_t; + +/** + * cvmx_npei_dma#_naddr + * + * NPEI_DMA[0..4]_NADDR = DMA Next Ichunk Address + * + * Place NPEI will read the next Ichunk data from. This is valid when state is 0 + */ +union cvmx_npei_dmax_naddr { + u64 u64; + struct cvmx_npei_dmax_naddr_s { + u64 reserved_36_63 : 28; + u64 addr : 36; + } s; + struct cvmx_npei_dmax_naddr_s cn52xx; + struct cvmx_npei_dmax_naddr_s cn52xxp1; + struct cvmx_npei_dmax_naddr_s cn56xx; + struct cvmx_npei_dmax_naddr_s cn56xxp1; +}; + +typedef union cvmx_npei_dmax_naddr cvmx_npei_dmax_naddr_t; + +/** + * cvmx_npei_dma0_int_level + * + * NPEI_DMA0_INT_LEVEL = NPEI DMA0 Interrupt Level + * + * Thresholds for DMA count and timer interrupts for DMA0. + */ +union cvmx_npei_dma0_int_level { + u64 u64; + struct cvmx_npei_dma0_int_level_s { + u64 time : 32; + u64 cnt : 32; + } s; + struct cvmx_npei_dma0_int_level_s cn52xx; + struct cvmx_npei_dma0_int_level_s cn52xxp1; + struct cvmx_npei_dma0_int_level_s cn56xx; + struct cvmx_npei_dma0_int_level_s cn56xxp1; +}; + +typedef union cvmx_npei_dma0_int_level cvmx_npei_dma0_int_level_t; + +/** + * cvmx_npei_dma1_int_level + * + * NPEI_DMA1_INT_LEVEL = NPEI DMA1 Interrupt Level + * + * Thresholds for DMA count and timer interrupts for DMA1. + */ +union cvmx_npei_dma1_int_level { + u64 u64; + struct cvmx_npei_dma1_int_level_s { + u64 time : 32; + u64 cnt : 32; + } s; + struct cvmx_npei_dma1_int_level_s cn52xx; + struct cvmx_npei_dma1_int_level_s cn52xxp1; + struct cvmx_npei_dma1_int_level_s cn56xx; + struct cvmx_npei_dma1_int_level_s cn56xxp1; +}; + +typedef union cvmx_npei_dma1_int_level cvmx_npei_dma1_int_level_t; + +/** + * cvmx_npei_dma_cnts + * + * NPEI_DMA_CNTS = NPEI DMA Count + * + * The DMA Count values for DMA0 and DMA1. + */ +union cvmx_npei_dma_cnts { + u64 u64; + struct cvmx_npei_dma_cnts_s { + u64 dma1 : 32; + u64 dma0 : 32; + } s; + struct cvmx_npei_dma_cnts_s cn52xx; + struct cvmx_npei_dma_cnts_s cn52xxp1; + struct cvmx_npei_dma_cnts_s cn56xx; + struct cvmx_npei_dma_cnts_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_cnts cvmx_npei_dma_cnts_t; + +/** + * cvmx_npei_dma_control + * + * NPEI_DMA_CONTROL = DMA Control Register + * + * Controls operation of the DMA IN/OUT. + */ +union cvmx_npei_dma_control { + u64 u64; + struct cvmx_npei_dma_control_s { + u64 reserved_40_63 : 24; + u64 p_32b_m : 1; + u64 dma4_enb : 1; + u64 dma3_enb : 1; + u64 dma2_enb : 1; + u64 dma1_enb : 1; + u64 dma0_enb : 1; + u64 b0_lend : 1; + u64 dwb_denb : 1; + u64 dwb_ichk : 9; + u64 fpa_que : 3; + u64 o_add1 : 1; + u64 o_ro : 1; + u64 o_ns : 1; + u64 o_es : 2; + u64 o_mode : 1; + u64 csize : 14; + } s; + struct cvmx_npei_dma_control_s cn52xx; + struct cvmx_npei_dma_control_cn52xxp1 { + u64 reserved_38_63 : 26; + u64 dma3_enb : 1; + u64 dma2_enb : 1; + u64 dma1_enb : 1; + u64 dma0_enb : 1; + u64 b0_lend : 1; + u64 dwb_denb : 1; + u64 dwb_ichk : 9; + u64 fpa_que : 3; + u64 o_add1 : 1; + u64 o_ro : 1; + u64 o_ns : 1; + u64 o_es : 2; + u64 o_mode : 1; + u64 csize : 14; + } cn52xxp1; + struct cvmx_npei_dma_control_s cn56xx; + struct cvmx_npei_dma_control_cn56xxp1 { + u64 reserved_39_63 : 25; + u64 dma4_enb : 1; + u64 dma3_enb : 1; + u64 dma2_enb : 1; + u64 dma1_enb : 1; + u64 dma0_enb : 1; + u64 b0_lend : 1; + u64 dwb_denb : 1; + u64 dwb_ichk : 9; + u64 fpa_que : 3; + u64 o_add1 : 1; + u64 o_ro : 1; + u64 o_ns : 1; + u64 o_es : 2; + u64 o_mode : 1; + u64 csize : 14; + } cn56xxp1; +}; + +typedef union cvmx_npei_dma_control cvmx_npei_dma_control_t; + +/** + * cvmx_npei_dma_pcie_req_num + * + * NPEI_DMA_PCIE_REQ_NUM = NPEI DMA PCIE Outstanding Read Request Number + * + * Outstanding PCIE read request number for DMAs and Packet, maximum number + * is 16 + */ +union cvmx_npei_dma_pcie_req_num { + u64 u64; + struct cvmx_npei_dma_pcie_req_num_s { + u64 dma_arb : 1; + u64 reserved_53_62 : 10; + u64 pkt_cnt : 5; + u64 reserved_45_47 : 3; + u64 dma4_cnt : 5; + u64 reserved_37_39 : 3; + u64 dma3_cnt : 5; + u64 reserved_29_31 : 3; + u64 dma2_cnt : 5; + u64 reserved_21_23 : 3; + u64 dma1_cnt : 5; + u64 reserved_13_15 : 3; + u64 dma0_cnt : 5; + u64 reserved_5_7 : 3; + u64 dma_cnt : 5; + } s; + struct cvmx_npei_dma_pcie_req_num_s cn52xx; + struct cvmx_npei_dma_pcie_req_num_s cn56xx; +}; + +typedef union cvmx_npei_dma_pcie_req_num cvmx_npei_dma_pcie_req_num_t; + +/** + * cvmx_npei_dma_state1 + * + * NPEI_DMA_STATE1 = NPI's DMA State 1 + * + * Results from DMA state register 1 + */ +union cvmx_npei_dma_state1 { + u64 u64; + struct cvmx_npei_dma_state1_s { + u64 reserved_40_63 : 24; + u64 d4_dwe : 8; + u64 d3_dwe : 8; + u64 d2_dwe : 8; + u64 d1_dwe : 8; + u64 d0_dwe : 8; + } s; + struct cvmx_npei_dma_state1_s cn52xx; +}; + +typedef union cvmx_npei_dma_state1 cvmx_npei_dma_state1_t; + +/** + * cvmx_npei_dma_state1_p1 + * + * NPEI_DMA_STATE1_P1 = NPEI DMA Request and Instruction State + * + * DMA engine Debug information. + */ +union cvmx_npei_dma_state1_p1 { + u64 u64; + struct cvmx_npei_dma_state1_p1_s { + u64 reserved_60_63 : 4; + u64 d0_difst : 7; + u64 d1_difst : 7; + u64 d2_difst : 7; + u64 d3_difst : 7; + u64 d4_difst : 7; + u64 d0_reqst : 5; + u64 d1_reqst : 5; + u64 d2_reqst : 5; + u64 d3_reqst : 5; + u64 d4_reqst : 5; + } s; + struct cvmx_npei_dma_state1_p1_cn52xxp1 { + u64 reserved_60_63 : 4; + u64 d0_difst : 7; + u64 d1_difst : 7; + u64 d2_difst : 7; + u64 d3_difst : 7; + u64 reserved_25_31 : 7; + u64 d0_reqst : 5; + u64 d1_reqst : 5; + u64 d2_reqst : 5; + u64 d3_reqst : 5; + u64 reserved_0_4 : 5; + } cn52xxp1; + struct cvmx_npei_dma_state1_p1_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_state1_p1 cvmx_npei_dma_state1_p1_t; + +/** + * cvmx_npei_dma_state2 + * + * NPEI_DMA_STATE2 = NPI's DMA State 2 + * + * Results from DMA state register 2 + */ +union cvmx_npei_dma_state2 { + u64 u64; + struct cvmx_npei_dma_state2_s { + u64 reserved_28_63 : 36; + u64 ndwe : 4; + u64 reserved_21_23 : 3; + u64 ndre : 5; + u64 reserved_10_15 : 6; + u64 prd : 10; + } s; + struct cvmx_npei_dma_state2_s cn52xx; +}; + +typedef union cvmx_npei_dma_state2 cvmx_npei_dma_state2_t; + +/** + * cvmx_npei_dma_state2_p1 + * + * NPEI_DMA_STATE2_P1 = NPEI DMA Instruction Fetch State + * + * DMA engine Debug information. + */ +union cvmx_npei_dma_state2_p1 { + u64 u64; + struct cvmx_npei_dma_state2_p1_s { + u64 reserved_45_63 : 19; + u64 d0_dffst : 9; + u64 d1_dffst : 9; + u64 d2_dffst : 9; + u64 d3_dffst : 9; + u64 d4_dffst : 9; + } s; + struct cvmx_npei_dma_state2_p1_cn52xxp1 { + u64 reserved_45_63 : 19; + u64 d0_dffst : 9; + u64 d1_dffst : 9; + u64 d2_dffst : 9; + u64 d3_dffst : 9; + u64 reserved_0_8 : 9; + } cn52xxp1; + struct cvmx_npei_dma_state2_p1_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_state2_p1 cvmx_npei_dma_state2_p1_t; + +/** + * cvmx_npei_dma_state3_p1 + * + * NPEI_DMA_STATE3_P1 = NPEI DMA DRE State + * + * DMA engine Debug information. + */ +union cvmx_npei_dma_state3_p1 { + u64 u64; + struct cvmx_npei_dma_state3_p1_s { + u64 reserved_60_63 : 4; + u64 d0_drest : 15; + u64 d1_drest : 15; + u64 d2_drest : 15; + u64 d3_drest : 15; + } s; + struct cvmx_npei_dma_state3_p1_s cn52xxp1; + struct cvmx_npei_dma_state3_p1_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_state3_p1 cvmx_npei_dma_state3_p1_t; + +/** + * cvmx_npei_dma_state4_p1 + * + * NPEI_DMA_STATE4_P1 = NPEI DMA DWE State + * + * DMA engine Debug information. + */ +union cvmx_npei_dma_state4_p1 { + u64 u64; + struct cvmx_npei_dma_state4_p1_s { + u64 reserved_52_63 : 12; + u64 d0_dwest : 13; + u64 d1_dwest : 13; + u64 d2_dwest : 13; + u64 d3_dwest : 13; + } s; + struct cvmx_npei_dma_state4_p1_s cn52xxp1; + struct cvmx_npei_dma_state4_p1_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_state4_p1 cvmx_npei_dma_state4_p1_t; + +/** + * cvmx_npei_dma_state5_p1 + * + * NPEI_DMA_STATE5_P1 = NPEI DMA DWE and DRE State + * + * DMA engine Debug information. + */ +union cvmx_npei_dma_state5_p1 { + u64 u64; + struct cvmx_npei_dma_state5_p1_s { + u64 reserved_28_63 : 36; + u64 d4_drest : 15; + u64 d4_dwest : 13; + } s; + struct cvmx_npei_dma_state5_p1_s cn56xxp1; +}; + +typedef union cvmx_npei_dma_state5_p1 cvmx_npei_dma_state5_p1_t; + +/** + * cvmx_npei_int_a_enb + * + * NPEI_INTERRUPT_A_ENB = NPI's Interrupt A Enable Register + * + * Used to allow the generation of interrupts (MSI/INTA) to the PCIe + * CoresUsed to enable the various interrupting conditions of NPEI + */ +union cvmx_npei_int_a_enb { + u64 u64; + struct cvmx_npei_int_a_enb_s { + u64 reserved_10_63 : 54; + u64 pout_err : 1; + u64 pin_bp : 1; + u64 p1_rdlk : 1; + u64 p0_rdlk : 1; + u64 pgl_err : 1; + u64 pdi_err : 1; + u64 pop_err : 1; + u64 pins_err : 1; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } s; + struct cvmx_npei_int_a_enb_s cn52xx; + struct cvmx_npei_int_a_enb_cn52xxp1 { + u64 reserved_2_63 : 62; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } cn52xxp1; + struct cvmx_npei_int_a_enb_s cn56xx; +}; + +typedef union cvmx_npei_int_a_enb cvmx_npei_int_a_enb_t; + +/** + * cvmx_npei_int_a_enb2 + * + * NPEI_INTERRUPT_A_ENB2 = NPEI's Interrupt A Enable2 Register + * + * Used to enable the various interrupting conditions of NPEI + */ +union cvmx_npei_int_a_enb2 { + u64 u64; + struct cvmx_npei_int_a_enb2_s { + u64 reserved_10_63 : 54; + u64 pout_err : 1; + u64 pin_bp : 1; + u64 p1_rdlk : 1; + u64 p0_rdlk : 1; + u64 pgl_err : 1; + u64 pdi_err : 1; + u64 pop_err : 1; + u64 pins_err : 1; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } s; + struct cvmx_npei_int_a_enb2_s cn52xx; + struct cvmx_npei_int_a_enb2_cn52xxp1 { + u64 reserved_2_63 : 62; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } cn52xxp1; + struct cvmx_npei_int_a_enb2_s cn56xx; +}; + +typedef union cvmx_npei_int_a_enb2 cvmx_npei_int_a_enb2_t; + +/** + * cvmx_npei_int_a_sum + * + * NPEI_INTERRUPT_A_SUM = NPI Interrupt A Summary Register + * + * Set when an interrupt condition occurs, write '1' to clear. When an + * interrupt bitin this register is set and + * the cooresponding bit in the NPEI_INT_A_ENB register is set, then + * NPEI_INT_SUM[61] will be set. + */ +union cvmx_npei_int_a_sum { + u64 u64; + struct cvmx_npei_int_a_sum_s { + u64 reserved_10_63 : 54; + u64 pout_err : 1; + u64 pin_bp : 1; + u64 p1_rdlk : 1; + u64 p0_rdlk : 1; + u64 pgl_err : 1; + u64 pdi_err : 1; + u64 pop_err : 1; + u64 pins_err : 1; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } s; + struct cvmx_npei_int_a_sum_s cn52xx; + struct cvmx_npei_int_a_sum_cn52xxp1 { + u64 reserved_2_63 : 62; + u64 dma1_cpl : 1; + u64 dma0_cpl : 1; + } cn52xxp1; + struct cvmx_npei_int_a_sum_s cn56xx; +}; + +typedef union cvmx_npei_int_a_sum cvmx_npei_int_a_sum_t; + +/** + * cvmx_npei_int_enb + * + * NPEI_INTERRUPT_ENB = NPI's Interrupt Enable Register + * + * Used to allow the generation of interrupts (MSI/INTA) to the PCIe + * CoresUsed to enable the various interrupting conditions of NPI + */ +union cvmx_npei_int_enb { + u64 u64; + struct cvmx_npei_int_enb_s { + u64 mio_inta : 1; + u64 reserved_62_62 : 1; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } s; + struct cvmx_npei_int_enb_s cn52xx; + struct cvmx_npei_int_enb_cn52xxp1 { + u64 mio_inta : 1; + u64 reserved_62_62 : 1; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 reserved_8_8 : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn52xxp1; + struct cvmx_npei_int_enb_s cn56xx; + struct cvmx_npei_int_enb_cn56xxp1 { + u64 mio_inta : 1; + u64 reserved_61_62 : 2; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 reserved_29_29 : 1; + u64 c1_se : 1; + u64 reserved_27_27 : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 reserved_22_22 : 1; + u64 c0_se : 1; + u64 reserved_20_20 : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn56xxp1; +}; + +typedef union cvmx_npei_int_enb cvmx_npei_int_enb_t; + +/** + * cvmx_npei_int_enb2 + * + * NPEI_INTERRUPT_ENB2 = NPI's Interrupt Enable2 Register + * + * Used to enable the various interrupting conditions of NPI + */ +union cvmx_npei_int_enb2 { + u64 u64; + struct cvmx_npei_int_enb2_s { + u64 reserved_62_63 : 2; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } s; + struct cvmx_npei_int_enb2_s cn52xx; + struct cvmx_npei_int_enb2_cn52xxp1 { + u64 reserved_62_63 : 2; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 reserved_8_8 : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn52xxp1; + struct cvmx_npei_int_enb2_s cn56xx; + struct cvmx_npei_int_enb2_cn56xxp1 { + u64 reserved_61_63 : 3; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 reserved_29_29 : 1; + u64 c1_se : 1; + u64 reserved_27_27 : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 reserved_22_22 : 1; + u64 c0_se : 1; + u64 reserved_20_20 : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn56xxp1; +}; + +typedef union cvmx_npei_int_enb2 cvmx_npei_int_enb2_t; + +/** + * cvmx_npei_int_info + * + * NPEI_INT_INFO = NPI Interrupt Information + * + * Contains information about some of the interrupt condition that can occur + * in the NPEI_INTERRUPT_SUM register. + */ +union cvmx_npei_int_info { + u64 u64; + struct cvmx_npei_int_info_s { + u64 reserved_12_63 : 52; + u64 pidbof : 6; + u64 psldbof : 6; + } s; + struct cvmx_npei_int_info_s cn52xx; + struct cvmx_npei_int_info_s cn56xx; + struct cvmx_npei_int_info_s cn56xxp1; +}; + +typedef union cvmx_npei_int_info cvmx_npei_int_info_t; + +/** + * cvmx_npei_int_sum + * + * NPEI_INTERRUPT_SUM = NPI Interrupt Summary Register + * + * Set when an interrupt condition occurs, write '1' to clear. + */ +union cvmx_npei_int_sum { + u64 u64; + struct cvmx_npei_int_sum_s { + u64 mio_inta : 1; + u64 reserved_62_62 : 1; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 ptime : 1; + u64 pcnt : 1; + u64 pidbof : 1; + u64 psldbof : 1; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } s; + struct cvmx_npei_int_sum_s cn52xx; + struct cvmx_npei_int_sum_cn52xxp1 { + u64 mio_inta : 1; + u64 reserved_62_62 : 1; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 reserved_15_18 : 4; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 reserved_8_8 : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn52xxp1; + struct cvmx_npei_int_sum_s cn56xx; + struct cvmx_npei_int_sum_cn56xxp1 { + u64 mio_inta : 1; + u64 reserved_61_62 : 2; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 reserved_29_29 : 1; + u64 c1_se : 1; + u64 reserved_27_27 : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 reserved_22_22 : 1; + u64 c0_se : 1; + u64 reserved_20_20 : 1; + u64 c0_aeri : 1; + u64 reserved_15_18 : 4; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 dma4dbo : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } cn56xxp1; +}; + +typedef union cvmx_npei_int_sum cvmx_npei_int_sum_t; + +/** + * cvmx_npei_int_sum2 + * + * NPEI_INTERRUPT_SUM2 = NPI Interrupt Summary2 Register + * + * This is a read only copy of the NPEI_INTERRUPT_SUM register with bit + * variances. + */ +union cvmx_npei_int_sum2 { + u64 u64; + struct cvmx_npei_int_sum2_s { + u64 mio_inta : 1; + u64 reserved_62_62 : 1; + u64 int_a : 1; + u64 c1_ldwn : 1; + u64 c0_ldwn : 1; + u64 c1_exc : 1; + u64 c0_exc : 1; + u64 c1_up_wf : 1; + u64 c0_up_wf : 1; + u64 c1_un_wf : 1; + u64 c0_un_wf : 1; + u64 c1_un_bx : 1; + u64 c1_un_wi : 1; + u64 c1_un_b2 : 1; + u64 c1_un_b1 : 1; + u64 c1_un_b0 : 1; + u64 c1_up_bx : 1; + u64 c1_up_wi : 1; + u64 c1_up_b2 : 1; + u64 c1_up_b1 : 1; + u64 c1_up_b0 : 1; + u64 c0_un_bx : 1; + u64 c0_un_wi : 1; + u64 c0_un_b2 : 1; + u64 c0_un_b1 : 1; + u64 c0_un_b0 : 1; + u64 c0_up_bx : 1; + u64 c0_up_wi : 1; + u64 c0_up_b2 : 1; + u64 c0_up_b1 : 1; + u64 c0_up_b0 : 1; + u64 c1_hpint : 1; + u64 c1_pmei : 1; + u64 c1_wake : 1; + u64 crs1_dr : 1; + u64 c1_se : 1; + u64 crs1_er : 1; + u64 c1_aeri : 1; + u64 c0_hpint : 1; + u64 c0_pmei : 1; + u64 c0_wake : 1; + u64 crs0_dr : 1; + u64 c0_se : 1; + u64 crs0_er : 1; + u64 c0_aeri : 1; + u64 reserved_15_18 : 4; + u64 dtime1 : 1; + u64 dtime0 : 1; + u64 dcnt1 : 1; + u64 dcnt0 : 1; + u64 dma1fi : 1; + u64 dma0fi : 1; + u64 reserved_8_8 : 1; + u64 dma3dbo : 1; + u64 dma2dbo : 1; + u64 dma1dbo : 1; + u64 dma0dbo : 1; + u64 iob2big : 1; + u64 bar0_to : 1; + u64 rml_wto : 1; + u64 rml_rto : 1; + } s; + struct cvmx_npei_int_sum2_s cn52xx; + struct cvmx_npei_int_sum2_s cn52xxp1; + struct cvmx_npei_int_sum2_s cn56xx; +}; + +typedef union cvmx_npei_int_sum2 cvmx_npei_int_sum2_t; + +/** + * cvmx_npei_last_win_rdata0 + * + * NPEI_LAST_WIN_RDATA0 = NPEI Last Window Read Data Port0 + * + * The data from the last initiated window read. + */ +union cvmx_npei_last_win_rdata0 { + u64 u64; + struct cvmx_npei_last_win_rdata0_s { + u64 data : 64; + } s; + struct cvmx_npei_last_win_rdata0_s cn52xx; + struct cvmx_npei_last_win_rdata0_s cn52xxp1; + struct cvmx_npei_last_win_rdata0_s cn56xx; + struct cvmx_npei_last_win_rdata0_s cn56xxp1; +}; + +typedef union cvmx_npei_last_win_rdata0 cvmx_npei_last_win_rdata0_t; + +/** + * cvmx_npei_last_win_rdata1 + * + * NPEI_LAST_WIN_RDATA1 = NPEI Last Window Read Data Port1 + * + * The data from the last initiated window read. + */ +union cvmx_npei_last_win_rdata1 { + u64 u64; + struct cvmx_npei_last_win_rdata1_s { + u64 data : 64; + } s; + struct cvmx_npei_last_win_rdata1_s cn52xx; + struct cvmx_npei_last_win_rdata1_s cn52xxp1; + struct cvmx_npei_last_win_rdata1_s cn56xx; + struct cvmx_npei_last_win_rdata1_s cn56xxp1; +}; + +typedef union cvmx_npei_last_win_rdata1 cvmx_npei_last_win_rdata1_t; + +/** + * cvmx_npei_mem_access_ctl + * + * NPEI_MEM_ACCESS_CTL = NPEI's Memory Access Control + * + * Contains control for access to the PCIe address space. + */ +union cvmx_npei_mem_access_ctl { + u64 u64; + struct cvmx_npei_mem_access_ctl_s { + u64 reserved_14_63 : 50; + u64 max_word : 4; + u64 timer : 10; + } s; + struct cvmx_npei_mem_access_ctl_s cn52xx; + struct cvmx_npei_mem_access_ctl_s cn52xxp1; + struct cvmx_npei_mem_access_ctl_s cn56xx; + struct cvmx_npei_mem_access_ctl_s cn56xxp1; +}; + +typedef union cvmx_npei_mem_access_ctl cvmx_npei_mem_access_ctl_t; + +/** + * cvmx_npei_mem_access_subid# + * + * NPEI_MEM_ACCESS_SUBIDX = NPEI Memory Access SubidX Register + * + * Contains address index and control bits for access to memory from Core PPs. + */ +union cvmx_npei_mem_access_subidx { + u64 u64; + struct cvmx_npei_mem_access_subidx_s { + u64 reserved_42_63 : 22; + u64 zero : 1; + u64 port : 2; + u64 nmerge : 1; + u64 esr : 2; + u64 esw : 2; + u64 nsr : 1; + u64 nsw : 1; + u64 ror : 1; + u64 row : 1; + u64 ba : 30; + } s; + struct cvmx_npei_mem_access_subidx_s cn52xx; + struct cvmx_npei_mem_access_subidx_s cn52xxp1; + struct cvmx_npei_mem_access_subidx_s cn56xx; + struct cvmx_npei_mem_access_subidx_s cn56xxp1; +}; + +typedef union cvmx_npei_mem_access_subidx cvmx_npei_mem_access_subidx_t; + +/** + * cvmx_npei_msi_enb0 + * + * NPEI_MSI_ENB0 = NPEI MSI Enable0 + * + * Used to enable the interrupt generation for the bits in the NPEI_MSI_RCV0. + */ +union cvmx_npei_msi_enb0 { + u64 u64; + struct cvmx_npei_msi_enb0_s { + u64 enb : 64; + } s; + struct cvmx_npei_msi_enb0_s cn52xx; + struct cvmx_npei_msi_enb0_s cn52xxp1; + struct cvmx_npei_msi_enb0_s cn56xx; + struct cvmx_npei_msi_enb0_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_enb0 cvmx_npei_msi_enb0_t; + +/** + * cvmx_npei_msi_enb1 + * + * NPEI_MSI_ENB1 = NPEI MSI Enable1 + * + * Used to enable the interrupt generation for the bits in the NPEI_MSI_RCV1. + */ +union cvmx_npei_msi_enb1 { + u64 u64; + struct cvmx_npei_msi_enb1_s { + u64 enb : 64; + } s; + struct cvmx_npei_msi_enb1_s cn52xx; + struct cvmx_npei_msi_enb1_s cn52xxp1; + struct cvmx_npei_msi_enb1_s cn56xx; + struct cvmx_npei_msi_enb1_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_enb1 cvmx_npei_msi_enb1_t; + +/** + * cvmx_npei_msi_enb2 + * + * NPEI_MSI_ENB2 = NPEI MSI Enable2 + * + * Used to enable the interrupt generation for the bits in the NPEI_MSI_RCV2. + */ +union cvmx_npei_msi_enb2 { + u64 u64; + struct cvmx_npei_msi_enb2_s { + u64 enb : 64; + } s; + struct cvmx_npei_msi_enb2_s cn52xx; + struct cvmx_npei_msi_enb2_s cn52xxp1; + struct cvmx_npei_msi_enb2_s cn56xx; + struct cvmx_npei_msi_enb2_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_enb2 cvmx_npei_msi_enb2_t; + +/** + * cvmx_npei_msi_enb3 + * + * NPEI_MSI_ENB3 = NPEI MSI Enable3 + * + * Used to enable the interrupt generation for the bits in the NPEI_MSI_RCV3. + */ +union cvmx_npei_msi_enb3 { + u64 u64; + struct cvmx_npei_msi_enb3_s { + u64 enb : 64; + } s; + struct cvmx_npei_msi_enb3_s cn52xx; + struct cvmx_npei_msi_enb3_s cn52xxp1; + struct cvmx_npei_msi_enb3_s cn56xx; + struct cvmx_npei_msi_enb3_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_enb3 cvmx_npei_msi_enb3_t; + +/** + * cvmx_npei_msi_rcv0 + * + * NPEI_MSI_RCV0 = NPEI MSI Receive0 + * + * Contains bits [63:0] of the 256 bits oof MSI interrupts. + */ +union cvmx_npei_msi_rcv0 { + u64 u64; + struct cvmx_npei_msi_rcv0_s { + u64 intr : 64; + } s; + struct cvmx_npei_msi_rcv0_s cn52xx; + struct cvmx_npei_msi_rcv0_s cn52xxp1; + struct cvmx_npei_msi_rcv0_s cn56xx; + struct cvmx_npei_msi_rcv0_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_rcv0 cvmx_npei_msi_rcv0_t; + +/** + * cvmx_npei_msi_rcv1 + * + * NPEI_MSI_RCV1 = NPEI MSI Receive1 + * + * Contains bits [127:64] of the 256 bits oof MSI interrupts. + */ +union cvmx_npei_msi_rcv1 { + u64 u64; + struct cvmx_npei_msi_rcv1_s { + u64 intr : 64; + } s; + struct cvmx_npei_msi_rcv1_s cn52xx; + struct cvmx_npei_msi_rcv1_s cn52xxp1; + struct cvmx_npei_msi_rcv1_s cn56xx; + struct cvmx_npei_msi_rcv1_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_rcv1 cvmx_npei_msi_rcv1_t; + +/** + * cvmx_npei_msi_rcv2 + * + * NPEI_MSI_RCV2 = NPEI MSI Receive2 + * + * Contains bits [191:128] of the 256 bits oof MSI interrupts. + */ +union cvmx_npei_msi_rcv2 { + u64 u64; + struct cvmx_npei_msi_rcv2_s { + u64 intr : 64; + } s; + struct cvmx_npei_msi_rcv2_s cn52xx; + struct cvmx_npei_msi_rcv2_s cn52xxp1; + struct cvmx_npei_msi_rcv2_s cn56xx; + struct cvmx_npei_msi_rcv2_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_rcv2 cvmx_npei_msi_rcv2_t; + +/** + * cvmx_npei_msi_rcv3 + * + * NPEI_MSI_RCV3 = NPEI MSI Receive3 + * + * Contains bits [255:192] of the 256 bits oof MSI interrupts. + */ +union cvmx_npei_msi_rcv3 { + u64 u64; + struct cvmx_npei_msi_rcv3_s { + u64 intr : 64; + } s; + struct cvmx_npei_msi_rcv3_s cn52xx; + struct cvmx_npei_msi_rcv3_s cn52xxp1; + struct cvmx_npei_msi_rcv3_s cn56xx; + struct cvmx_npei_msi_rcv3_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_rcv3 cvmx_npei_msi_rcv3_t; + +/** + * cvmx_npei_msi_rd_map + * + * NPEI_MSI_RD_MAP = NPEI MSI Read MAP + * + * Used to read the mapping function of the NPEI_PCIE_MSI_RCV to NPEI_MSI_RCV + * registers. + */ +union cvmx_npei_msi_rd_map { + u64 u64; + struct cvmx_npei_msi_rd_map_s { + u64 reserved_16_63 : 48; + u64 rd_int : 8; + u64 msi_int : 8; + } s; + struct cvmx_npei_msi_rd_map_s cn52xx; + struct cvmx_npei_msi_rd_map_s cn52xxp1; + struct cvmx_npei_msi_rd_map_s cn56xx; + struct cvmx_npei_msi_rd_map_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_rd_map cvmx_npei_msi_rd_map_t; + +/** + * cvmx_npei_msi_w1c_enb0 + * + * NPEI_MSI_W1C_ENB0 = NPEI MSI Write 1 To Clear Enable0 + * + * Used to clear bits in NPEI_MSI_ENB0. This is a PASS2 register. + */ +union cvmx_npei_msi_w1c_enb0 { + u64 u64; + struct cvmx_npei_msi_w1c_enb0_s { + u64 clr : 64; + } s; + struct cvmx_npei_msi_w1c_enb0_s cn52xx; + struct cvmx_npei_msi_w1c_enb0_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1c_enb0 cvmx_npei_msi_w1c_enb0_t; + +/** + * cvmx_npei_msi_w1c_enb1 + * + * NPEI_MSI_W1C_ENB1 = NPEI MSI Write 1 To Clear Enable1 + * + * Used to clear bits in NPEI_MSI_ENB1. This is a PASS2 register. + */ +union cvmx_npei_msi_w1c_enb1 { + u64 u64; + struct cvmx_npei_msi_w1c_enb1_s { + u64 clr : 64; + } s; + struct cvmx_npei_msi_w1c_enb1_s cn52xx; + struct cvmx_npei_msi_w1c_enb1_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1c_enb1 cvmx_npei_msi_w1c_enb1_t; + +/** + * cvmx_npei_msi_w1c_enb2 + * + * NPEI_MSI_W1C_ENB2 = NPEI MSI Write 1 To Clear Enable2 + * + * Used to clear bits in NPEI_MSI_ENB2. This is a PASS2 register. + */ +union cvmx_npei_msi_w1c_enb2 { + u64 u64; + struct cvmx_npei_msi_w1c_enb2_s { + u64 clr : 64; + } s; + struct cvmx_npei_msi_w1c_enb2_s cn52xx; + struct cvmx_npei_msi_w1c_enb2_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1c_enb2 cvmx_npei_msi_w1c_enb2_t; + +/** + * cvmx_npei_msi_w1c_enb3 + * + * NPEI_MSI_W1C_ENB3 = NPEI MSI Write 1 To Clear Enable3 + * + * Used to clear bits in NPEI_MSI_ENB3. This is a PASS2 register. + */ +union cvmx_npei_msi_w1c_enb3 { + u64 u64; + struct cvmx_npei_msi_w1c_enb3_s { + u64 clr : 64; + } s; + struct cvmx_npei_msi_w1c_enb3_s cn52xx; + struct cvmx_npei_msi_w1c_enb3_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1c_enb3 cvmx_npei_msi_w1c_enb3_t; + +/** + * cvmx_npei_msi_w1s_enb0 + * + * NPEI_MSI_W1S_ENB0 = NPEI MSI Write 1 To Set Enable0 + * + * Used to set bits in NPEI_MSI_ENB0. This is a PASS2 register. + */ +union cvmx_npei_msi_w1s_enb0 { + u64 u64; + struct cvmx_npei_msi_w1s_enb0_s { + u64 set : 64; + } s; + struct cvmx_npei_msi_w1s_enb0_s cn52xx; + struct cvmx_npei_msi_w1s_enb0_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1s_enb0 cvmx_npei_msi_w1s_enb0_t; + +/** + * cvmx_npei_msi_w1s_enb1 + * + * NPEI_MSI_W1S_ENB0 = NPEI MSI Write 1 To Set Enable1 + * + * Used to set bits in NPEI_MSI_ENB1. This is a PASS2 register. + */ +union cvmx_npei_msi_w1s_enb1 { + u64 u64; + struct cvmx_npei_msi_w1s_enb1_s { + u64 set : 64; + } s; + struct cvmx_npei_msi_w1s_enb1_s cn52xx; + struct cvmx_npei_msi_w1s_enb1_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1s_enb1 cvmx_npei_msi_w1s_enb1_t; + +/** + * cvmx_npei_msi_w1s_enb2 + * + * NPEI_MSI_W1S_ENB2 = NPEI MSI Write 1 To Set Enable2 + * + * Used to set bits in NPEI_MSI_ENB2. This is a PASS2 register. + */ +union cvmx_npei_msi_w1s_enb2 { + u64 u64; + struct cvmx_npei_msi_w1s_enb2_s { + u64 set : 64; + } s; + struct cvmx_npei_msi_w1s_enb2_s cn52xx; + struct cvmx_npei_msi_w1s_enb2_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1s_enb2 cvmx_npei_msi_w1s_enb2_t; + +/** + * cvmx_npei_msi_w1s_enb3 + * + * NPEI_MSI_W1S_ENB3 = NPEI MSI Write 1 To Set Enable3 + * + * Used to set bits in NPEI_MSI_ENB3. This is a PASS2 register. + */ +union cvmx_npei_msi_w1s_enb3 { + u64 u64; + struct cvmx_npei_msi_w1s_enb3_s { + u64 set : 64; + } s; + struct cvmx_npei_msi_w1s_enb3_s cn52xx; + struct cvmx_npei_msi_w1s_enb3_s cn56xx; +}; + +typedef union cvmx_npei_msi_w1s_enb3 cvmx_npei_msi_w1s_enb3_t; + +/** + * cvmx_npei_msi_wr_map + * + * NPEI_MSI_WR_MAP = NPEI MSI Write MAP + * + * Used to write the mapping function of the NPEI_PCIE_MSI_RCV to NPEI_MSI_RCV + * registers. + */ +union cvmx_npei_msi_wr_map { + u64 u64; + struct cvmx_npei_msi_wr_map_s { + u64 reserved_16_63 : 48; + u64 ciu_int : 8; + u64 msi_int : 8; + } s; + struct cvmx_npei_msi_wr_map_s cn52xx; + struct cvmx_npei_msi_wr_map_s cn52xxp1; + struct cvmx_npei_msi_wr_map_s cn56xx; + struct cvmx_npei_msi_wr_map_s cn56xxp1; +}; + +typedef union cvmx_npei_msi_wr_map cvmx_npei_msi_wr_map_t; + +/** + * cvmx_npei_pcie_credit_cnt + * + * NPEI_PCIE_CREDIT_CNT = NPEI PCIE Credit Count + * + * Contains the number of credits for the pcie port FIFOs used by the NPEI. + * This value needs to be set BEFORE PCIe traffic + * flow from NPEI to PCIE Ports starts. A write to this register will cause + * the credit counts in the NPEI for the two + * PCIE ports to be reset to the value in this register. + */ +union cvmx_npei_pcie_credit_cnt { + u64 u64; + struct cvmx_npei_pcie_credit_cnt_s { + u64 reserved_48_63 : 16; + u64 p1_ccnt : 8; + u64 p1_ncnt : 8; + u64 p1_pcnt : 8; + u64 p0_ccnt : 8; + u64 p0_ncnt : 8; + u64 p0_pcnt : 8; + } s; + struct cvmx_npei_pcie_credit_cnt_s cn52xx; + struct cvmx_npei_pcie_credit_cnt_s cn56xx; +}; + +typedef union cvmx_npei_pcie_credit_cnt cvmx_npei_pcie_credit_cnt_t; + +/** + * cvmx_npei_pcie_msi_rcv + * + * NPEI_PCIE_MSI_RCV = NPEI PCIe MSI Receive + * + * Register where MSI writes are directed from the PCIe. + */ +union cvmx_npei_pcie_msi_rcv { + u64 u64; + struct cvmx_npei_pcie_msi_rcv_s { + u64 reserved_8_63 : 56; + u64 intr : 8; + } s; + struct cvmx_npei_pcie_msi_rcv_s cn52xx; + struct cvmx_npei_pcie_msi_rcv_s cn52xxp1; + struct cvmx_npei_pcie_msi_rcv_s cn56xx; + struct cvmx_npei_pcie_msi_rcv_s cn56xxp1; +}; + +typedef union cvmx_npei_pcie_msi_rcv cvmx_npei_pcie_msi_rcv_t; + +/** + * cvmx_npei_pcie_msi_rcv_b1 + * + * NPEI_PCIE_MSI_RCV_B1 = NPEI PCIe MSI Receive Byte 1 + * + * Register where MSI writes are directed from the PCIe. + */ +union cvmx_npei_pcie_msi_rcv_b1 { + u64 u64; + struct cvmx_npei_pcie_msi_rcv_b1_s { + u64 reserved_16_63 : 48; + u64 intr : 8; + u64 reserved_0_7 : 8; + } s; + struct cvmx_npei_pcie_msi_rcv_b1_s cn52xx; + struct cvmx_npei_pcie_msi_rcv_b1_s cn52xxp1; + struct cvmx_npei_pcie_msi_rcv_b1_s cn56xx; + struct cvmx_npei_pcie_msi_rcv_b1_s cn56xxp1; +}; + +typedef union cvmx_npei_pcie_msi_rcv_b1 cvmx_npei_pcie_msi_rcv_b1_t; + +/** + * cvmx_npei_pcie_msi_rcv_b2 + * + * NPEI_PCIE_MSI_RCV_B2 = NPEI PCIe MSI Receive Byte 2 + * + * Register where MSI writes are directed from the PCIe. + */ +union cvmx_npei_pcie_msi_rcv_b2 { + u64 u64; + struct cvmx_npei_pcie_msi_rcv_b2_s { + u64 reserved_24_63 : 40; + u64 intr : 8; + u64 reserved_0_15 : 16; + } s; + struct cvmx_npei_pcie_msi_rcv_b2_s cn52xx; + struct cvmx_npei_pcie_msi_rcv_b2_s cn52xxp1; + struct cvmx_npei_pcie_msi_rcv_b2_s cn56xx; + struct cvmx_npei_pcie_msi_rcv_b2_s cn56xxp1; +}; + +typedef union cvmx_npei_pcie_msi_rcv_b2 cvmx_npei_pcie_msi_rcv_b2_t; + +/** + * cvmx_npei_pcie_msi_rcv_b3 + * + * NPEI_PCIE_MSI_RCV_B3 = NPEI PCIe MSI Receive Byte 3 + * + * Register where MSI writes are directed from the PCIe. + */ +union cvmx_npei_pcie_msi_rcv_b3 { + u64 u64; + struct cvmx_npei_pcie_msi_rcv_b3_s { + u64 reserved_32_63 : 32; + u64 intr : 8; + u64 reserved_0_23 : 24; + } s; + struct cvmx_npei_pcie_msi_rcv_b3_s cn52xx; + struct cvmx_npei_pcie_msi_rcv_b3_s cn52xxp1; + struct cvmx_npei_pcie_msi_rcv_b3_s cn56xx; + struct cvmx_npei_pcie_msi_rcv_b3_s cn56xxp1; +}; + +typedef union cvmx_npei_pcie_msi_rcv_b3 cvmx_npei_pcie_msi_rcv_b3_t; + +/** + * cvmx_npei_pkt#_cnts + * + * NPEI_PKT[0..31]_CNTS = NPEI Packet ring# Counts + * + * The counters for output rings. + */ +union cvmx_npei_pktx_cnts { + u64 u64; + struct cvmx_npei_pktx_cnts_s { + u64 reserved_54_63 : 10; + u64 timer : 22; + u64 cnt : 32; + } s; + struct cvmx_npei_pktx_cnts_s cn52xx; + struct cvmx_npei_pktx_cnts_s cn56xx; +}; + +typedef union cvmx_npei_pktx_cnts cvmx_npei_pktx_cnts_t; + +/** + * cvmx_npei_pkt#_in_bp + * + * NPEI_PKT[0..31]_IN_BP = NPEI Packet ring# Input Backpressure + * + * The counters and thresholds for input packets to apply backpressure to + * processing of the packets. + */ +union cvmx_npei_pktx_in_bp { + u64 u64; + struct cvmx_npei_pktx_in_bp_s { + u64 wmark : 32; + u64 cnt : 32; + } s; + struct cvmx_npei_pktx_in_bp_s cn52xx; + struct cvmx_npei_pktx_in_bp_s cn56xx; +}; + +typedef union cvmx_npei_pktx_in_bp cvmx_npei_pktx_in_bp_t; + +/** + * cvmx_npei_pkt#_instr_baddr + * + * NPEI_PKT[0..31]_INSTR_BADDR = NPEI Packet ring# Instruction Base Address + * + * Start of Instruction for input packets. + */ +union cvmx_npei_pktx_instr_baddr { + u64 u64; + struct cvmx_npei_pktx_instr_baddr_s { + u64 addr : 61; + u64 reserved_0_2 : 3; + } s; + struct cvmx_npei_pktx_instr_baddr_s cn52xx; + struct cvmx_npei_pktx_instr_baddr_s cn56xx; +}; + +typedef union cvmx_npei_pktx_instr_baddr cvmx_npei_pktx_instr_baddr_t; + +/** + * cvmx_npei_pkt#_instr_baoff_dbell + * + * NPEI_PKT[0..31]_INSTR_BAOFF_DBELL = NPEI Packet ring# Instruction Base + * Address Offset and Doorbell + * + * The doorbell and base address offset for next read. + */ +union cvmx_npei_pktx_instr_baoff_dbell { + u64 u64; + struct cvmx_npei_pktx_instr_baoff_dbell_s { + u64 aoff : 32; + u64 dbell : 32; + } s; + struct cvmx_npei_pktx_instr_baoff_dbell_s cn52xx; + struct cvmx_npei_pktx_instr_baoff_dbell_s cn56xx; +}; + +typedef union cvmx_npei_pktx_instr_baoff_dbell + cvmx_npei_pktx_instr_baoff_dbell_t; + +/** + * cvmx_npei_pkt#_instr_fifo_rsize + * + * NPEI_PKT[0..31]_INSTR_FIFO_RSIZE = NPEI Packet ring# Instruction FIFO and + * Ring Size. + * + * Fifo field and ring size for Instructions. + */ +union cvmx_npei_pktx_instr_fifo_rsize { + u64 u64; + struct cvmx_npei_pktx_instr_fifo_rsize_s { + u64 max : 9; + u64 rrp : 9; + u64 wrp : 9; + u64 fcnt : 5; + u64 rsize : 32; + } s; + struct cvmx_npei_pktx_instr_fifo_rsize_s cn52xx; + struct cvmx_npei_pktx_instr_fifo_rsize_s cn56xx; +}; + +typedef union cvmx_npei_pktx_instr_fifo_rsize cvmx_npei_pktx_instr_fifo_rsize_t; + +/** + * cvmx_npei_pkt#_instr_header + * + * NPEI_PKT[0..31]_INSTR_HEADER = NPEI Packet ring# Instruction Header. + * + * VAlues used to build input packet header. + */ +union cvmx_npei_pktx_instr_header { + u64 u64; + struct cvmx_npei_pktx_instr_header_s { + u64 reserved_44_63 : 20; + u64 pbp : 1; + u64 reserved_38_42 : 5; + u64 rparmode : 2; + u64 reserved_35_35 : 1; + u64 rskp_len : 7; + u64 reserved_22_27 : 6; + u64 use_ihdr : 1; + u64 reserved_16_20 : 5; + u64 par_mode : 2; + u64 reserved_13_13 : 1; + u64 skp_len : 7; + u64 reserved_0_5 : 6; + } s; + struct cvmx_npei_pktx_instr_header_s cn52xx; + struct cvmx_npei_pktx_instr_header_s cn56xx; +}; + +typedef union cvmx_npei_pktx_instr_header cvmx_npei_pktx_instr_header_t; + +/** + * cvmx_npei_pkt#_slist_baddr + * + * NPEI_PKT[0..31]_SLIST_BADDR = NPEI Packet ring# Scatter List Base Address + * + * Start of Scatter List for output packet pointers - MUST be 16 byte aligned + */ +union cvmx_npei_pktx_slist_baddr { + u64 u64; + struct cvmx_npei_pktx_slist_baddr_s { + u64 addr : 60; + u64 reserved_0_3 : 4; + } s; + struct cvmx_npei_pktx_slist_baddr_s cn52xx; + struct cvmx_npei_pktx_slist_baddr_s cn56xx; +}; + +typedef union cvmx_npei_pktx_slist_baddr cvmx_npei_pktx_slist_baddr_t; + +/** + * cvmx_npei_pkt#_slist_baoff_dbell + * + * NPEI_PKT[0..31]_SLIST_BAOFF_DBELL = NPEI Packet ring# Scatter List Base + * Address Offset and Doorbell + * + * The doorbell and base address offset for next read. + */ +union cvmx_npei_pktx_slist_baoff_dbell { + u64 u64; + struct cvmx_npei_pktx_slist_baoff_dbell_s { + u64 aoff : 32; + u64 dbell : 32; + } s; + struct cvmx_npei_pktx_slist_baoff_dbell_s cn52xx; + struct cvmx_npei_pktx_slist_baoff_dbell_s cn56xx; +}; + +typedef union cvmx_npei_pktx_slist_baoff_dbell + cvmx_npei_pktx_slist_baoff_dbell_t; + +/** + * cvmx_npei_pkt#_slist_fifo_rsize + * + * NPEI_PKT[0..31]_SLIST_FIFO_RSIZE = NPEI Packet ring# Scatter List FIFO and + * Ring Size. + * + * The number of scatter pointer pairs in the scatter list. + */ +union cvmx_npei_pktx_slist_fifo_rsize { + u64 u64; + struct cvmx_npei_pktx_slist_fifo_rsize_s { + u64 reserved_32_63 : 32; + u64 rsize : 32; + } s; + struct cvmx_npei_pktx_slist_fifo_rsize_s cn52xx; + struct cvmx_npei_pktx_slist_fifo_rsize_s cn56xx; +}; + +typedef union cvmx_npei_pktx_slist_fifo_rsize cvmx_npei_pktx_slist_fifo_rsize_t; + +/** + * cvmx_npei_pkt_cnt_int + * + * NPEI_PKT_CNT_INT = NPI Packet Counter Interrupt + * + * The packets rings that are interrupting because of Packet Counters. + */ +union cvmx_npei_pkt_cnt_int { + u64 u64; + struct cvmx_npei_pkt_cnt_int_s { + u64 reserved_32_63 : 32; + u64 port : 32; + } s; + struct cvmx_npei_pkt_cnt_int_s cn52xx; + struct cvmx_npei_pkt_cnt_int_s cn56xx; +}; + +typedef union cvmx_npei_pkt_cnt_int cvmx_npei_pkt_cnt_int_t; + +/** + * cvmx_npei_pkt_cnt_int_enb + * + * NPEI_PKT_CNT_INT_ENB = NPI Packet Counter Interrupt Enable + * + * Enable for the packets rings that are interrupting because of Packet Counters. + */ +union cvmx_npei_pkt_cnt_int_enb { + u64 u64; + struct cvmx_npei_pkt_cnt_int_enb_s { + u64 reserved_32_63 : 32; + u64 port : 32; + } s; + struct cvmx_npei_pkt_cnt_int_enb_s cn52xx; + struct cvmx_npei_pkt_cnt_int_enb_s cn56xx; +}; + +typedef union cvmx_npei_pkt_cnt_int_enb cvmx_npei_pkt_cnt_int_enb_t; + +/** + * cvmx_npei_pkt_data_out_es + * + * NPEI_PKT_DATA_OUT_ES = NPEI's Packet Data Out Endian Swap + * + * The Endian Swap for writing Data Out. + */ +union cvmx_npei_pkt_data_out_es { + u64 u64; + struct cvmx_npei_pkt_data_out_es_s { + u64 es : 64; + } s; + struct cvmx_npei_pkt_data_out_es_s cn52xx; + struct cvmx_npei_pkt_data_out_es_s cn56xx; +}; + +typedef union cvmx_npei_pkt_data_out_es cvmx_npei_pkt_data_out_es_t; + +/** + * cvmx_npei_pkt_data_out_ns + * + * NPEI_PKT_DATA_OUT_NS = NPEI's Packet Data Out No Snoop + * + * The NS field for the TLP when writing packet data. + */ +union cvmx_npei_pkt_data_out_ns { + u64 u64; + struct cvmx_npei_pkt_data_out_ns_s { + u64 reserved_32_63 : 32; + u64 nsr : 32; + } s; + struct cvmx_npei_pkt_data_out_ns_s cn52xx; + struct cvmx_npei_pkt_data_out_ns_s cn56xx; +}; + +typedef union cvmx_npei_pkt_data_out_ns cvmx_npei_pkt_data_out_ns_t; + +/** + * cvmx_npei_pkt_data_out_ror + * + * NPEI_PKT_DATA_OUT_ROR = NPEI's Packet Data Out Relaxed Ordering + * + * The ROR field for the TLP when writing Packet Data. + */ +union cvmx_npei_pkt_data_out_ror { + u64 u64; + struct cvmx_npei_pkt_data_out_ror_s { + u64 reserved_32_63 : 32; + u64 ror : 32; + } s; + struct cvmx_npei_pkt_data_out_ror_s cn52xx; + struct cvmx_npei_pkt_data_out_ror_s cn56xx; +}; + +typedef union cvmx_npei_pkt_data_out_ror cvmx_npei_pkt_data_out_ror_t; + +/** + * cvmx_npei_pkt_dpaddr + * + * NPEI_PKT_DPADDR = NPEI's Packet Data Pointer Addr + * + * Used to detemine address and attributes for packet data writes. + */ +union cvmx_npei_pkt_dpaddr { + u64 u64; + struct cvmx_npei_pkt_dpaddr_s { + u64 reserved_32_63 : 32; + u64 dptr : 32; + } s; + struct cvmx_npei_pkt_dpaddr_s cn52xx; + struct cvmx_npei_pkt_dpaddr_s cn56xx; +}; + +typedef union cvmx_npei_pkt_dpaddr cvmx_npei_pkt_dpaddr_t; + +/** + * cvmx_npei_pkt_in_bp + * + * NPEI_PKT_IN_BP = NPEI Packet Input Backpressure + * + * Which input rings have backpressure applied. + */ +union cvmx_npei_pkt_in_bp { + u64 u64; + struct cvmx_npei_pkt_in_bp_s { + u64 reserved_32_63 : 32; + u64 bp : 32; + } s; + struct cvmx_npei_pkt_in_bp_s cn52xx; + struct cvmx_npei_pkt_in_bp_s cn56xx; +}; + +typedef union cvmx_npei_pkt_in_bp cvmx_npei_pkt_in_bp_t; + +/** + * cvmx_npei_pkt_in_done#_cnts + * + * NPEI_PKT_IN_DONE[0..31]_CNTS = NPEI Instruction Done ring# Counts + * + * Counters for instructions completed on Input rings. + */ +union cvmx_npei_pkt_in_donex_cnts { + u64 u64; + struct cvmx_npei_pkt_in_donex_cnts_s { + u64 reserved_32_63 : 32; + u64 cnt : 32; + } s; + struct cvmx_npei_pkt_in_donex_cnts_s cn52xx; + struct cvmx_npei_pkt_in_donex_cnts_s cn56xx; +}; + +typedef union cvmx_npei_pkt_in_donex_cnts cvmx_npei_pkt_in_donex_cnts_t; + +/** + * cvmx_npei_pkt_in_instr_counts + * + * NPEI_PKT_IN_INSTR_COUNTS = NPEI Packet Input Instrutction Counts + * + * Keeps track of the number of instructions read into the FIFO and Packets + * sent to IPD. + */ +union cvmx_npei_pkt_in_instr_counts { + u64 u64; + struct cvmx_npei_pkt_in_instr_counts_s { + u64 wr_cnt : 32; + u64 rd_cnt : 32; + } s; + struct cvmx_npei_pkt_in_instr_counts_s cn52xx; + struct cvmx_npei_pkt_in_instr_counts_s cn56xx; +}; + +typedef union cvmx_npei_pkt_in_instr_counts cvmx_npei_pkt_in_instr_counts_t; + +/** + * cvmx_npei_pkt_in_pcie_port + * + * NPEI_PKT_IN_PCIE_PORT = NPEI's Packet In To PCIe Port Assignment + * + * Assigns Packet Input rings to PCIe ports. + */ +union cvmx_npei_pkt_in_pcie_port { + u64 u64; + struct cvmx_npei_pkt_in_pcie_port_s { + u64 pp : 64; + } s; + struct cvmx_npei_pkt_in_pcie_port_s cn52xx; + struct cvmx_npei_pkt_in_pcie_port_s cn56xx; +}; + +typedef union cvmx_npei_pkt_in_pcie_port cvmx_npei_pkt_in_pcie_port_t; + +/** + * cvmx_npei_pkt_input_control + * + * NPEI_PKT_INPUT_CONTROL = NPEI's Packet Input Control + * + * Control for reads for gather list and instructions. + */ +union cvmx_npei_pkt_input_control { + u64 u64; + struct cvmx_npei_pkt_input_control_s { + u64 reserved_23_63 : 41; + u64 pkt_rr : 1; + u64 pbp_dhi : 13; + u64 d_nsr : 1; + u64 d_esr : 2; + u64 d_ror : 1; + u64 use_csr : 1; + u64 nsr : 1; + u64 esr : 2; + u64 ror : 1; + } s; + struct cvmx_npei_pkt_input_control_s cn52xx; + struct cvmx_npei_pkt_input_control_s cn56xx; +}; + +typedef union cvmx_npei_pkt_input_control cvmx_npei_pkt_input_control_t; + +/** + * cvmx_npei_pkt_instr_enb + * + * NPEI_PKT_INSTR_ENB = NPEI's Packet Instruction Enable + * + * Enables the instruction fetch for a Packet-ring. + */ +union cvmx_npei_pkt_instr_enb { + u64 u64; + struct cvmx_npei_pkt_instr_enb_s { + u64 reserved_32_63 : 32; + u64 enb : 32; + } s; + struct cvmx_npei_pkt_instr_enb_s cn52xx; + struct cvmx_npei_pkt_instr_enb_s cn56xx; +}; + +typedef union cvmx_npei_pkt_instr_enb cvmx_npei_pkt_instr_enb_t; + +/** + * cvmx_npei_pkt_instr_rd_size + * + * NPEI_PKT_INSTR_RD_SIZE = NPEI Instruction Read Size + * + * The number of instruction allowed to be read at one time. + */ +union cvmx_npei_pkt_instr_rd_size { + u64 u64; + struct cvmx_npei_pkt_instr_rd_size_s { + u64 rdsize : 64; + } s; + struct cvmx_npei_pkt_instr_rd_size_s cn52xx; + struct cvmx_npei_pkt_instr_rd_size_s cn56xx; +}; + +typedef union cvmx_npei_pkt_instr_rd_size cvmx_npei_pkt_instr_rd_size_t; + +/** + * cvmx_npei_pkt_instr_size + * + * NPEI_PKT_INSTR_SIZE = NPEI's Packet Instruction Size + * + * Determines if instructions are 64 or 32 byte in size for a Packet-ring. + */ +union cvmx_npei_pkt_instr_size { + u64 u64; + struct cvmx_npei_pkt_instr_size_s { + u64 reserved_32_63 : 32; + u64 is_64b : 32; + } s; + struct cvmx_npei_pkt_instr_size_s cn52xx; + struct cvmx_npei_pkt_instr_size_s cn56xx; +}; + +typedef union cvmx_npei_pkt_instr_size cvmx_npei_pkt_instr_size_t; + +/** + * cvmx_npei_pkt_int_levels + * + * 0x90F0 reserved NPEI_PKT_PCIE_PORT2 + * + * + * NPEI_PKT_INT_LEVELS = NPEI's Packet Interrupt Levels + * + * Output packet interrupt levels. + */ +union cvmx_npei_pkt_int_levels { + u64 u64; + struct cvmx_npei_pkt_int_levels_s { + u64 reserved_54_63 : 10; + u64 time : 22; + u64 cnt : 32; + } s; + struct cvmx_npei_pkt_int_levels_s cn52xx; + struct cvmx_npei_pkt_int_levels_s cn56xx; +}; + +typedef union cvmx_npei_pkt_int_levels cvmx_npei_pkt_int_levels_t; + +/** + * cvmx_npei_pkt_iptr + * + * NPEI_PKT_IPTR = NPEI's Packet Info Poitner + * + * Controls using the Info-Pointer to store length and data. + */ +union cvmx_npei_pkt_iptr { + u64 u64; + struct cvmx_npei_pkt_iptr_s { + u64 reserved_32_63 : 32; + u64 iptr : 32; + } s; + struct cvmx_npei_pkt_iptr_s cn52xx; + struct cvmx_npei_pkt_iptr_s cn56xx; +}; + +typedef union cvmx_npei_pkt_iptr cvmx_npei_pkt_iptr_t; + +/** + * cvmx_npei_pkt_out_bmode + * + * NPEI_PKT_OUT_BMODE = NPEI's Packet Out Byte Mode + * + * Control the updating of the NPEI_PKT#_CNT register. + */ +union cvmx_npei_pkt_out_bmode { + u64 u64; + struct cvmx_npei_pkt_out_bmode_s { + u64 reserved_32_63 : 32; + u64 bmode : 32; + } s; + struct cvmx_npei_pkt_out_bmode_s cn52xx; + struct cvmx_npei_pkt_out_bmode_s cn56xx; +}; + +typedef union cvmx_npei_pkt_out_bmode cvmx_npei_pkt_out_bmode_t; + +/** + * cvmx_npei_pkt_out_enb + * + * NPEI_PKT_OUT_ENB = NPEI's Packet Output Enable + * + * Enables the output packet engines. + */ +union cvmx_npei_pkt_out_enb { + u64 u64; + struct cvmx_npei_pkt_out_enb_s { + u64 reserved_32_63 : 32; + u64 enb : 32; + } s; + struct cvmx_npei_pkt_out_enb_s cn52xx; + struct cvmx_npei_pkt_out_enb_s cn56xx; +}; + +typedef union cvmx_npei_pkt_out_enb cvmx_npei_pkt_out_enb_t; + +/** + * cvmx_npei_pkt_output_wmark + * + * NPEI_PKT_OUTPUT_WMARK = NPEI's Packet Output Water Mark + * + * Value that when the NPEI_PKT#_SLIST_BAOFF_DBELL[DBELL] value is less then + * that backpressure for the rings will be applied. + */ +union cvmx_npei_pkt_output_wmark { + u64 u64; + struct cvmx_npei_pkt_output_wmark_s { + u64 reserved_32_63 : 32; + u64 wmark : 32; + } s; + struct cvmx_npei_pkt_output_wmark_s cn52xx; + struct cvmx_npei_pkt_output_wmark_s cn56xx; +}; + +typedef union cvmx_npei_pkt_output_wmark cvmx_npei_pkt_output_wmark_t; + +/** + * cvmx_npei_pkt_pcie_port + * + * NPEI_PKT_PCIE_PORT = NPEI's Packet To PCIe Port Assignment + * + * Assigns Packet Ports to PCIe ports. + */ +union cvmx_npei_pkt_pcie_port { + u64 u64; + struct cvmx_npei_pkt_pcie_port_s { + u64 pp : 64; + } s; + struct cvmx_npei_pkt_pcie_port_s cn52xx; + struct cvmx_npei_pkt_pcie_port_s cn56xx; +}; + +typedef union cvmx_npei_pkt_pcie_port cvmx_npei_pkt_pcie_port_t; + +/** + * cvmx_npei_pkt_port_in_rst + * + * NPEI_PKT_PORT_IN_RST = NPEI Packet Port In Reset + * + * Vector bits related to ring-port for ones that are reset. + */ +union cvmx_npei_pkt_port_in_rst { + u64 u64; + struct cvmx_npei_pkt_port_in_rst_s { + u64 in_rst : 32; + u64 out_rst : 32; + } s; + struct cvmx_npei_pkt_port_in_rst_s cn52xx; + struct cvmx_npei_pkt_port_in_rst_s cn56xx; +}; + +typedef union cvmx_npei_pkt_port_in_rst cvmx_npei_pkt_port_in_rst_t; + +/** + * cvmx_npei_pkt_slist_es + * + * NPEI_PKT_SLIST_ES = NPEI's Packet Scatter List Endian Swap + * + * The Endian Swap for Scatter List Read. + */ +union cvmx_npei_pkt_slist_es { + u64 u64; + struct cvmx_npei_pkt_slist_es_s { + u64 es : 64; + } s; + struct cvmx_npei_pkt_slist_es_s cn52xx; + struct cvmx_npei_pkt_slist_es_s cn56xx; +}; + +typedef union cvmx_npei_pkt_slist_es cvmx_npei_pkt_slist_es_t; + +/** + * cvmx_npei_pkt_slist_id_size + * + * NPEI_PKT_SLIST_ID_SIZE = NPEI Packet Scatter List Info and Data Size + * + * The Size of the information and data fields pointed to by Scatter List + * pointers. + */ +union cvmx_npei_pkt_slist_id_size { + u64 u64; + struct cvmx_npei_pkt_slist_id_size_s { + u64 reserved_23_63 : 41; + u64 isize : 7; + u64 bsize : 16; + } s; + struct cvmx_npei_pkt_slist_id_size_s cn52xx; + struct cvmx_npei_pkt_slist_id_size_s cn56xx; +}; + +typedef union cvmx_npei_pkt_slist_id_size cvmx_npei_pkt_slist_id_size_t; + +/** + * cvmx_npei_pkt_slist_ns + * + * NPEI_PKT_SLIST_NS = NPEI's Packet Scatter List No Snoop + * + * The NS field for the TLP when fetching Scatter List. + */ +union cvmx_npei_pkt_slist_ns { + u64 u64; + struct cvmx_npei_pkt_slist_ns_s { + u64 reserved_32_63 : 32; + u64 nsr : 32; + } s; + struct cvmx_npei_pkt_slist_ns_s cn52xx; + struct cvmx_npei_pkt_slist_ns_s cn56xx; +}; + +typedef union cvmx_npei_pkt_slist_ns cvmx_npei_pkt_slist_ns_t; + +/** + * cvmx_npei_pkt_slist_ror + * + * NPEI_PKT_SLIST_ROR = NPEI's Packet Scatter List Relaxed Ordering + * + * The ROR field for the TLP when fetching Scatter List. + */ +union cvmx_npei_pkt_slist_ror { + u64 u64; + struct cvmx_npei_pkt_slist_ror_s { + u64 reserved_32_63 : 32; + u64 ror : 32; + } s; + struct cvmx_npei_pkt_slist_ror_s cn52xx; + struct cvmx_npei_pkt_slist_ror_s cn56xx; +}; + +typedef union cvmx_npei_pkt_slist_ror cvmx_npei_pkt_slist_ror_t; + +/** + * cvmx_npei_pkt_time_int + * + * NPEI_PKT_TIME_INT = NPEI Packet Timer Interrupt + * + * The packets rings that are interrupting because of Packet Timers. + */ +union cvmx_npei_pkt_time_int { + u64 u64; + struct cvmx_npei_pkt_time_int_s { + u64 reserved_32_63 : 32; + u64 port : 32; + } s; + struct cvmx_npei_pkt_time_int_s cn52xx; + struct cvmx_npei_pkt_time_int_s cn56xx; +}; + +typedef union cvmx_npei_pkt_time_int cvmx_npei_pkt_time_int_t; + +/** + * cvmx_npei_pkt_time_int_enb + * + * NPEI_PKT_TIME_INT_ENB = NPEI Packet Timer Interrupt Enable + * + * The packets rings that are interrupting because of Packet Timers. + */ +union cvmx_npei_pkt_time_int_enb { + u64 u64; + struct cvmx_npei_pkt_time_int_enb_s { + u64 reserved_32_63 : 32; + u64 port : 32; + } s; + struct cvmx_npei_pkt_time_int_enb_s cn52xx; + struct cvmx_npei_pkt_time_int_enb_s cn56xx; +}; + +typedef union cvmx_npei_pkt_time_int_enb cvmx_npei_pkt_time_int_enb_t; + +/** + * cvmx_npei_rsl_int_blocks + * + * NPEI_RSL_INT_BLOCKS = NPEI RSL Interrupt Blocks Register + * + * Reading this register will return a vector with a bit set '1' for a + * corresponding RSL block + * that presently has an interrupt pending. The Field Description below + * supplies the name of the + * register that software should read to find out why that intterupt bit is set. + */ +union cvmx_npei_rsl_int_blocks { + u64 u64; + struct cvmx_npei_rsl_int_blocks_s { + u64 reserved_31_63 : 33; + u64 iob : 1; + u64 lmc1 : 1; + u64 agl : 1; + u64 reserved_24_27 : 4; + u64 asxpcs1 : 1; + u64 asxpcs0 : 1; + u64 reserved_21_21 : 1; + u64 pip : 1; + u64 spx1 : 1; + u64 spx0 : 1; + u64 lmc0 : 1; + u64 l2c : 1; + u64 usb1 : 1; + u64 rad : 1; + u64 usb : 1; + u64 pow : 1; + u64 tim : 1; + u64 pko : 1; + u64 ipd : 1; + u64 reserved_8_8 : 1; + u64 zip : 1; + u64 dfa : 1; + u64 fpa : 1; + u64 key : 1; + u64 npei : 1; + u64 gmx1 : 1; + u64 gmx0 : 1; + u64 mio : 1; + } s; + struct cvmx_npei_rsl_int_blocks_s cn52xx; + struct cvmx_npei_rsl_int_blocks_s cn52xxp1; + struct cvmx_npei_rsl_int_blocks_s cn56xx; + struct cvmx_npei_rsl_int_blocks_s cn56xxp1; +}; + +typedef union cvmx_npei_rsl_int_blocks cvmx_npei_rsl_int_blocks_t; + +/** + * cvmx_npei_scratch_1 + * + * NPEI_SCRATCH_1 = NPEI's Scratch 1 + * + * A general purpose 64 bit register for SW use. + */ +union cvmx_npei_scratch_1 { + u64 u64; + struct cvmx_npei_scratch_1_s { + u64 data : 64; + } s; + struct cvmx_npei_scratch_1_s cn52xx; + struct cvmx_npei_scratch_1_s cn52xxp1; + struct cvmx_npei_scratch_1_s cn56xx; + struct cvmx_npei_scratch_1_s cn56xxp1; +}; + +typedef union cvmx_npei_scratch_1 cvmx_npei_scratch_1_t; + +/** + * cvmx_npei_state1 + * + * NPEI_STATE1 = NPEI State 1 + * + * State machines in NPEI. For debug. + */ +union cvmx_npei_state1 { + u64 u64; + struct cvmx_npei_state1_s { + u64 cpl1 : 12; + u64 cpl0 : 12; + u64 arb : 1; + u64 csr : 39; + } s; + struct cvmx_npei_state1_s cn52xx; + struct cvmx_npei_state1_s cn52xxp1; + struct cvmx_npei_state1_s cn56xx; + struct cvmx_npei_state1_s cn56xxp1; +}; + +typedef union cvmx_npei_state1 cvmx_npei_state1_t; + +/** + * cvmx_npei_state2 + * + * NPEI_STATE2 = NPEI State 2 + * + * State machines in NPEI. For debug. + */ +union cvmx_npei_state2 { + u64 u64; + struct cvmx_npei_state2_s { + u64 reserved_48_63 : 16; + u64 npei : 1; + u64 rac : 1; + u64 csm1 : 15; + u64 csm0 : 15; + u64 nnp0 : 8; + u64 nnd : 8; + } s; + struct cvmx_npei_state2_s cn52xx; + struct cvmx_npei_state2_s cn52xxp1; + struct cvmx_npei_state2_s cn56xx; + struct cvmx_npei_state2_s cn56xxp1; +}; + +typedef union cvmx_npei_state2 cvmx_npei_state2_t; + +/** + * cvmx_npei_state3 + * + * NPEI_STATE3 = NPEI State 3 + * + * State machines in NPEI. For debug. + */ +union cvmx_npei_state3 { + u64 u64; + struct cvmx_npei_state3_s { + u64 reserved_56_63 : 8; + u64 psm1 : 15; + u64 psm0 : 15; + u64 nsm1 : 13; + u64 nsm0 : 13; + } s; + struct cvmx_npei_state3_s cn52xx; + struct cvmx_npei_state3_s cn52xxp1; + struct cvmx_npei_state3_s cn56xx; + struct cvmx_npei_state3_s cn56xxp1; +}; + +typedef union cvmx_npei_state3 cvmx_npei_state3_t; + +/** + * cvmx_npei_win_rd_addr + * + * NPEI_WIN_RD_ADDR = NPEI Window Read Address Register + * + * The address to be read when the NPEI_WIN_RD_DATA register is read. + */ +union cvmx_npei_win_rd_addr { + u64 u64; + struct cvmx_npei_win_rd_addr_s { + u64 reserved_51_63 : 13; + u64 ld_cmd : 2; + u64 iobit : 1; + u64 rd_addr : 48; + } s; + struct cvmx_npei_win_rd_addr_s cn52xx; + struct cvmx_npei_win_rd_addr_s cn52xxp1; + struct cvmx_npei_win_rd_addr_s cn56xx; + struct cvmx_npei_win_rd_addr_s cn56xxp1; +}; + +typedef union cvmx_npei_win_rd_addr cvmx_npei_win_rd_addr_t; + +/** + * cvmx_npei_win_rd_data + * + * NPEI_WIN_RD_DATA = NPEI Window Read Data Register + * + * Reading this register causes a window read operation to take place. + * Address read is that contained in the NPEI_WIN_RD_ADDR + * register. + */ +union cvmx_npei_win_rd_data { + u64 u64; + struct cvmx_npei_win_rd_data_s { + u64 rd_data : 64; + } s; + struct cvmx_npei_win_rd_data_s cn52xx; + struct cvmx_npei_win_rd_data_s cn52xxp1; + struct cvmx_npei_win_rd_data_s cn56xx; + struct cvmx_npei_win_rd_data_s cn56xxp1; +}; + +typedef union cvmx_npei_win_rd_data cvmx_npei_win_rd_data_t; + +/** + * cvmx_npei_win_wr_addr + * + * NPEI_WIN_WR_ADDR = NPEI Window Write Address Register + * + * Contains the address to be writen to when a write operation is started by + * writing the + * NPEI_WIN_WR_DATA register (see below). + * + * Notes: + * Even though address bit [2] can be set, it should always be kept to '0'. + * + */ +union cvmx_npei_win_wr_addr { + u64 u64; + struct cvmx_npei_win_wr_addr_s { + u64 reserved_49_63 : 15; + u64 iobit : 1; + u64 wr_addr : 46; + u64 reserved_0_1 : 2; + } s; + struct cvmx_npei_win_wr_addr_s cn52xx; + struct cvmx_npei_win_wr_addr_s cn52xxp1; + struct cvmx_npei_win_wr_addr_s cn56xx; + struct cvmx_npei_win_wr_addr_s cn56xxp1; +}; + +typedef union cvmx_npei_win_wr_addr cvmx_npei_win_wr_addr_t; + +/** + * cvmx_npei_win_wr_data + * + * NPEI_WIN_WR_DATA = NPEI Window Write Data Register + * + * Contains the data to write to the address located in the NPEI_WIN_WR_ADDR + * Register. + * Writing the least-significant-byte of this register will cause a write + * operation to take place. + */ +union cvmx_npei_win_wr_data { + u64 u64; + struct cvmx_npei_win_wr_data_s { + u64 wr_data : 64; + } s; + struct cvmx_npei_win_wr_data_s cn52xx; + struct cvmx_npei_win_wr_data_s cn52xxp1; + struct cvmx_npei_win_wr_data_s cn56xx; + struct cvmx_npei_win_wr_data_s cn56xxp1; +}; + +typedef union cvmx_npei_win_wr_data cvmx_npei_win_wr_data_t; + +/** + * cvmx_npei_win_wr_mask + * + * NPEI_WIN_WR_MASK = NPEI Window Write Mask Register + * + * Contains the mask for the data in the NPEI_WIN_WR_DATA Register. + */ +union cvmx_npei_win_wr_mask { + u64 u64; + struct cvmx_npei_win_wr_mask_s { + u64 reserved_8_63 : 56; + u64 wr_mask : 8; + } s; + struct cvmx_npei_win_wr_mask_s cn52xx; + struct cvmx_npei_win_wr_mask_s cn52xxp1; + struct cvmx_npei_win_wr_mask_s cn56xx; + struct cvmx_npei_win_wr_mask_s cn56xxp1; +}; + +typedef union cvmx_npei_win_wr_mask cvmx_npei_win_wr_mask_t; + +/** + * cvmx_npei_window_ctl + * + * NPEI_WINDOW_CTL = NPEI's Window Control + * + * The name of this register is misleading. The timeout value is used for BAR0 + * access from PCIE0 and PCIE1. + * Any access to the regigisters on the RML will timeout as 0xFFFF clock cycle. + * At time of timeout the next + * RML access will start, and interrupt will be set, and in the case of reads + * no data will be returned. + * + * The value of this register should be set to a minimum of 0x200000 to ensure + * that a timeout to an RML register + * occurs on the RML 0xFFFF timer before the timeout for a BAR0 access from + * the PCIE#. + */ +union cvmx_npei_window_ctl { + u64 u64; + struct cvmx_npei_window_ctl_s { + u64 reserved_32_63 : 32; + u64 time : 32; + } s; + struct cvmx_npei_window_ctl_s cn52xx; + struct cvmx_npei_window_ctl_s cn52xxp1; + struct cvmx_npei_window_ctl_s cn56xx; + struct cvmx_npei_window_ctl_s cn56xxp1; +}; + +typedef union cvmx_npei_window_ctl cvmx_npei_window_ctl_t; + +#endif
Import cvmx-pcsxxx-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../include/mach/cvmx-pcsxx-defs.h | 787 ++++++++++++++++++ 1 file changed, 787 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h new file mode 100644 index 000000000000..e16a4c404f63 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h @@ -0,0 +1,787 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon pcsxx. + */ + +#ifndef __CVMX_PCSXX_DEFS_H__ +#define __CVMX_PCSXX_DEFS_H__ + +static inline u64 CVMX_PCSXX_10GBX_STATUS_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000828ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000828ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000828ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000828ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_BIST_STATUS_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000870ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000870ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000870ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000870ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_BIT_LOCK_STATUS_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000850ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000850ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000850ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000850ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_CONTROL1_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000800ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000800ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000800ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000800ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_CONTROL2_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000818ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000818ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000818ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000818ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_INT_EN_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000860ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000860ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000860ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000860ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_INT_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000858ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000858ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000858ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000858ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_LOG_ANL_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000868ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000868ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000868ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000868ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_MISC_CTL_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000848ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000848ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000848ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000848ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_RX_SYNC_STATES_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000838ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000838ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000838ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000838ull + (offset) * 0x8000000ull; +} + +#define CVMX_PCSXX_SERDES_CRDT_CNT_REG(offset) (0x00011800B0000880ull) +static inline u64 CVMX_PCSXX_SPD_ABIL_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000810ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000810ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000810ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000810ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_STATUS1_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000808ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000808ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000808ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000808ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_STATUS2_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000820ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000820ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000820ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000820ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_TX_RX_POLARITY_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000840ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000840ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000840ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000840ull + (offset) * 0x8000000ull; +} + +static inline u64 CVMX_PCSXX_TX_RX_STATES_REG(unsigned long offset) +{ + switch (cvmx_get_octeon_family()) { + case OCTEON_CN66XX & OCTEON_FAMILY_MASK: + case OCTEON_CN61XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000830ull + (offset) * 0x8000000ull; + case OCTEON_CN70XX & OCTEON_FAMILY_MASK: + case OCTEON_CN63XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000830ull + (offset) * 0x8000000ull; + case OCTEON_CN68XX & OCTEON_FAMILY_MASK: + return 0x00011800B0000830ull + (offset) * 0x1000000ull; + } + return 0x00011800B0000830ull + (offset) * 0x8000000ull; +} + +/** + * cvmx_pcsx#_10gbx_status_reg + * + * PCSX_10GBX_STATUS_REG = 10gbx_status_reg + * + */ +union cvmx_pcsxx_10gbx_status_reg { + u64 u64; + struct cvmx_pcsxx_10gbx_status_reg_s { + u64 reserved_13_63 : 51; + u64 alignd : 1; + u64 pattst : 1; + u64 reserved_4_10 : 7; + u64 l3sync : 1; + u64 l2sync : 1; + u64 l1sync : 1; + u64 l0sync : 1; + } s; + struct cvmx_pcsxx_10gbx_status_reg_s cn52xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn52xxp1; + struct cvmx_pcsxx_10gbx_status_reg_s cn56xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn56xxp1; + struct cvmx_pcsxx_10gbx_status_reg_s cn61xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn63xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn63xxp1; + struct cvmx_pcsxx_10gbx_status_reg_s cn66xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn68xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn68xxp1; + struct cvmx_pcsxx_10gbx_status_reg_s cn70xx; + struct cvmx_pcsxx_10gbx_status_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_10gbx_status_reg cvmx_pcsxx_10gbx_status_reg_t; + +/** + * cvmx_pcsx#_bist_status_reg + * + * PCSX Bist Status Register + * + */ +union cvmx_pcsxx_bist_status_reg { + u64 u64; + struct cvmx_pcsxx_bist_status_reg_s { + u64 reserved_1_63 : 63; + u64 bist_status : 1; + } s; + struct cvmx_pcsxx_bist_status_reg_s cn52xx; + struct cvmx_pcsxx_bist_status_reg_s cn52xxp1; + struct cvmx_pcsxx_bist_status_reg_s cn56xx; + struct cvmx_pcsxx_bist_status_reg_s cn56xxp1; + struct cvmx_pcsxx_bist_status_reg_s cn61xx; + struct cvmx_pcsxx_bist_status_reg_s cn63xx; + struct cvmx_pcsxx_bist_status_reg_s cn63xxp1; + struct cvmx_pcsxx_bist_status_reg_s cn66xx; + struct cvmx_pcsxx_bist_status_reg_s cn68xx; + struct cvmx_pcsxx_bist_status_reg_s cn68xxp1; + struct cvmx_pcsxx_bist_status_reg_s cn70xx; + struct cvmx_pcsxx_bist_status_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_bist_status_reg cvmx_pcsxx_bist_status_reg_t; + +/** + * cvmx_pcsx#_bit_lock_status_reg + * + * PCSX Bit Lock Status Register + * + */ +union cvmx_pcsxx_bit_lock_status_reg { + u64 u64; + struct cvmx_pcsxx_bit_lock_status_reg_s { + u64 reserved_4_63 : 60; + u64 bitlck3 : 1; + u64 bitlck2 : 1; + u64 bitlck1 : 1; + u64 bitlck0 : 1; + } s; + struct cvmx_pcsxx_bit_lock_status_reg_s cn52xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn52xxp1; + struct cvmx_pcsxx_bit_lock_status_reg_s cn56xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn56xxp1; + struct cvmx_pcsxx_bit_lock_status_reg_s cn61xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn63xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn63xxp1; + struct cvmx_pcsxx_bit_lock_status_reg_s cn66xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn68xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn68xxp1; + struct cvmx_pcsxx_bit_lock_status_reg_s cn70xx; + struct cvmx_pcsxx_bit_lock_status_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_bit_lock_status_reg cvmx_pcsxx_bit_lock_status_reg_t; + +/** + * cvmx_pcsx#_control1_reg + * + * NOTE: Logic Analyzer is enabled with LA_EN for the specified PCS lane only. + * PKT_SZ is effective only when LA_EN=1 + * For normal operation(sgmii or 1000Base-X), this bit must be 0. + * See pcsx.csr for xaui logic analyzer mode. + * For full description see document at .../rtl/pcs/readme_logic_analyzer.txt + * + * + * PCSX regs follow IEEE Std 802.3-2005, Section: 45.2.3 + * + * + * PCSX_CONTROL1_REG = Control Register1 + */ +union cvmx_pcsxx_control1_reg { + u64 u64; + struct cvmx_pcsxx_control1_reg_s { + u64 reserved_16_63 : 48; + u64 reset : 1; + u64 loopbck1 : 1; + u64 spdsel1 : 1; + u64 reserved_12_12 : 1; + u64 lo_pwr : 1; + u64 reserved_7_10 : 4; + u64 spdsel0 : 1; + u64 spd : 4; + u64 reserved_0_1 : 2; + } s; + struct cvmx_pcsxx_control1_reg_s cn52xx; + struct cvmx_pcsxx_control1_reg_s cn52xxp1; + struct cvmx_pcsxx_control1_reg_s cn56xx; + struct cvmx_pcsxx_control1_reg_s cn56xxp1; + struct cvmx_pcsxx_control1_reg_s cn61xx; + struct cvmx_pcsxx_control1_reg_s cn63xx; + struct cvmx_pcsxx_control1_reg_s cn63xxp1; + struct cvmx_pcsxx_control1_reg_s cn66xx; + struct cvmx_pcsxx_control1_reg_s cn68xx; + struct cvmx_pcsxx_control1_reg_s cn68xxp1; + struct cvmx_pcsxx_control1_reg_s cn70xx; + struct cvmx_pcsxx_control1_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_control1_reg cvmx_pcsxx_control1_reg_t; + +/** + * cvmx_pcsx#_control2_reg + * + * PCSX_CONTROL2_REG = Control Register2 + * + */ +union cvmx_pcsxx_control2_reg { + u64 u64; + struct cvmx_pcsxx_control2_reg_s { + u64 reserved_2_63 : 62; + u64 type : 2; + } s; + struct cvmx_pcsxx_control2_reg_s cn52xx; + struct cvmx_pcsxx_control2_reg_s cn52xxp1; + struct cvmx_pcsxx_control2_reg_s cn56xx; + struct cvmx_pcsxx_control2_reg_s cn56xxp1; + struct cvmx_pcsxx_control2_reg_s cn61xx; + struct cvmx_pcsxx_control2_reg_s cn63xx; + struct cvmx_pcsxx_control2_reg_s cn63xxp1; + struct cvmx_pcsxx_control2_reg_s cn66xx; + struct cvmx_pcsxx_control2_reg_s cn68xx; + struct cvmx_pcsxx_control2_reg_s cn68xxp1; + struct cvmx_pcsxx_control2_reg_s cn70xx; + struct cvmx_pcsxx_control2_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_control2_reg cvmx_pcsxx_control2_reg_t; + +/** + * cvmx_pcsx#_int_en_reg + * + * PCSX Interrupt Enable Register + * + */ +union cvmx_pcsxx_int_en_reg { + u64 u64; + struct cvmx_pcsxx_int_en_reg_s { + u64 reserved_7_63 : 57; + u64 dbg_sync_en : 1; + u64 algnlos_en : 1; + u64 synlos_en : 1; + u64 bitlckls_en : 1; + u64 rxsynbad_en : 1; + u64 rxbad_en : 1; + u64 txflt_en : 1; + } s; + struct cvmx_pcsxx_int_en_reg_cn52xx { + u64 reserved_6_63 : 58; + u64 algnlos_en : 1; + u64 synlos_en : 1; + u64 bitlckls_en : 1; + u64 rxsynbad_en : 1; + u64 rxbad_en : 1; + u64 txflt_en : 1; + } cn52xx; + struct cvmx_pcsxx_int_en_reg_cn52xx cn52xxp1; + struct cvmx_pcsxx_int_en_reg_cn52xx cn56xx; + struct cvmx_pcsxx_int_en_reg_cn52xx cn56xxp1; + struct cvmx_pcsxx_int_en_reg_s cn61xx; + struct cvmx_pcsxx_int_en_reg_s cn63xx; + struct cvmx_pcsxx_int_en_reg_s cn63xxp1; + struct cvmx_pcsxx_int_en_reg_s cn66xx; + struct cvmx_pcsxx_int_en_reg_s cn68xx; + struct cvmx_pcsxx_int_en_reg_s cn68xxp1; + struct cvmx_pcsxx_int_en_reg_s cn70xx; + struct cvmx_pcsxx_int_en_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_int_en_reg cvmx_pcsxx_int_en_reg_t; + +/** + * cvmx_pcsx#_int_reg + * + * PCSX Interrupt Register + * Note: DBG_SYNC is a edge triggered interrupt. When set it indicates PCS Synchronization state + * machine in + * Figure 48-7 state diagram in IEEE Std 802.3-2005 changes state SYNC_ACQUIRED_1 to + * SYNC_ACQUIRED_2 + * indicating an invalid code group was received on one of the 4 receive lanes. + * This interrupt should be always disabled and used only for link problem debugging help. + */ +union cvmx_pcsxx_int_reg { + u64 u64; + struct cvmx_pcsxx_int_reg_s { + u64 reserved_7_63 : 57; + u64 dbg_sync : 1; + u64 algnlos : 1; + u64 synlos : 1; + u64 bitlckls : 1; + u64 rxsynbad : 1; + u64 rxbad : 1; + u64 txflt : 1; + } s; + struct cvmx_pcsxx_int_reg_cn52xx { + u64 reserved_6_63 : 58; + u64 algnlos : 1; + u64 synlos : 1; + u64 bitlckls : 1; + u64 rxsynbad : 1; + u64 rxbad : 1; + u64 txflt : 1; + } cn52xx; + struct cvmx_pcsxx_int_reg_cn52xx cn52xxp1; + struct cvmx_pcsxx_int_reg_cn52xx cn56xx; + struct cvmx_pcsxx_int_reg_cn52xx cn56xxp1; + struct cvmx_pcsxx_int_reg_s cn61xx; + struct cvmx_pcsxx_int_reg_s cn63xx; + struct cvmx_pcsxx_int_reg_s cn63xxp1; + struct cvmx_pcsxx_int_reg_s cn66xx; + struct cvmx_pcsxx_int_reg_s cn68xx; + struct cvmx_pcsxx_int_reg_s cn68xxp1; + struct cvmx_pcsxx_int_reg_s cn70xx; + struct cvmx_pcsxx_int_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_int_reg cvmx_pcsxx_int_reg_t; + +/** + * cvmx_pcsx#_log_anl_reg + * + * PCSX Logic Analyzer Register + * NOTE: Logic Analyzer is enabled with LA_EN for xaui only. PKT_SZ is effective only when + * LA_EN=1 + * For normal operation(xaui), this bit must be 0. The dropped lane is used to send rxc[3:0]. + * See pcs.csr for sgmii/1000Base-X logic analyzer mode. + * For full description see document at .../rtl/pcs/readme_logic_analyzer.txt + */ +union cvmx_pcsxx_log_anl_reg { + u64 u64; + struct cvmx_pcsxx_log_anl_reg_s { + u64 reserved_7_63 : 57; + u64 enc_mode : 1; + u64 drop_ln : 2; + u64 lafifovfl : 1; + u64 la_en : 1; + u64 pkt_sz : 2; + } s; + struct cvmx_pcsxx_log_anl_reg_s cn52xx; + struct cvmx_pcsxx_log_anl_reg_s cn52xxp1; + struct cvmx_pcsxx_log_anl_reg_s cn56xx; + struct cvmx_pcsxx_log_anl_reg_s cn56xxp1; + struct cvmx_pcsxx_log_anl_reg_s cn61xx; + struct cvmx_pcsxx_log_anl_reg_s cn63xx; + struct cvmx_pcsxx_log_anl_reg_s cn63xxp1; + struct cvmx_pcsxx_log_anl_reg_s cn66xx; + struct cvmx_pcsxx_log_anl_reg_s cn68xx; + struct cvmx_pcsxx_log_anl_reg_s cn68xxp1; + struct cvmx_pcsxx_log_anl_reg_s cn70xx; + struct cvmx_pcsxx_log_anl_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_log_anl_reg cvmx_pcsxx_log_anl_reg_t; + +/** + * cvmx_pcsx#_misc_ctl_reg + * + * PCSX Misc Control Register + * LN_SWAP for XAUI is to simplify interconnection layout between devices + */ +union cvmx_pcsxx_misc_ctl_reg { + u64 u64; + struct cvmx_pcsxx_misc_ctl_reg_s { + u64 reserved_4_63 : 60; + u64 tx_swap : 1; + u64 rx_swap : 1; + u64 xaui : 1; + u64 gmxeno : 1; + } s; + struct cvmx_pcsxx_misc_ctl_reg_s cn52xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn52xxp1; + struct cvmx_pcsxx_misc_ctl_reg_s cn56xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn56xxp1; + struct cvmx_pcsxx_misc_ctl_reg_s cn61xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn63xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn63xxp1; + struct cvmx_pcsxx_misc_ctl_reg_s cn66xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn68xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn68xxp1; + struct cvmx_pcsxx_misc_ctl_reg_s cn70xx; + struct cvmx_pcsxx_misc_ctl_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_misc_ctl_reg cvmx_pcsxx_misc_ctl_reg_t; + +/** + * cvmx_pcsx#_rx_sync_states_reg + * + * PCSX_RX_SYNC_STATES_REG = Receive Sync States Register + * + */ +union cvmx_pcsxx_rx_sync_states_reg { + u64 u64; + struct cvmx_pcsxx_rx_sync_states_reg_s { + u64 reserved_16_63 : 48; + u64 sync3st : 4; + u64 sync2st : 4; + u64 sync1st : 4; + u64 sync0st : 4; + } s; + struct cvmx_pcsxx_rx_sync_states_reg_s cn52xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn52xxp1; + struct cvmx_pcsxx_rx_sync_states_reg_s cn56xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn56xxp1; + struct cvmx_pcsxx_rx_sync_states_reg_s cn61xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn63xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn63xxp1; + struct cvmx_pcsxx_rx_sync_states_reg_s cn66xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn68xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn68xxp1; + struct cvmx_pcsxx_rx_sync_states_reg_s cn70xx; + struct cvmx_pcsxx_rx_sync_states_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_rx_sync_states_reg cvmx_pcsxx_rx_sync_states_reg_t; + +/** + * cvmx_pcsx#_serdes_crdt_cnt_reg + * + * PCSX SERDES Credit Count + * + */ +union cvmx_pcsxx_serdes_crdt_cnt_reg { + u64 u64; + struct cvmx_pcsxx_serdes_crdt_cnt_reg_s { + u64 reserved_5_63 : 59; + u64 cnt : 5; + } s; + struct cvmx_pcsxx_serdes_crdt_cnt_reg_s cn70xx; + struct cvmx_pcsxx_serdes_crdt_cnt_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_serdes_crdt_cnt_reg cvmx_pcsxx_serdes_crdt_cnt_reg_t; + +/** + * cvmx_pcsx#_spd_abil_reg + * + * PCSX_SPD_ABIL_REG = Speed ability register + * + */ +union cvmx_pcsxx_spd_abil_reg { + u64 u64; + struct cvmx_pcsxx_spd_abil_reg_s { + u64 reserved_2_63 : 62; + u64 tenpasst : 1; + u64 tengb : 1; + } s; + struct cvmx_pcsxx_spd_abil_reg_s cn52xx; + struct cvmx_pcsxx_spd_abil_reg_s cn52xxp1; + struct cvmx_pcsxx_spd_abil_reg_s cn56xx; + struct cvmx_pcsxx_spd_abil_reg_s cn56xxp1; + struct cvmx_pcsxx_spd_abil_reg_s cn61xx; + struct cvmx_pcsxx_spd_abil_reg_s cn63xx; + struct cvmx_pcsxx_spd_abil_reg_s cn63xxp1; + struct cvmx_pcsxx_spd_abil_reg_s cn66xx; + struct cvmx_pcsxx_spd_abil_reg_s cn68xx; + struct cvmx_pcsxx_spd_abil_reg_s cn68xxp1; + struct cvmx_pcsxx_spd_abil_reg_s cn70xx; + struct cvmx_pcsxx_spd_abil_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_spd_abil_reg cvmx_pcsxx_spd_abil_reg_t; + +/** + * cvmx_pcsx#_status1_reg + * + * PCSX_STATUS1_REG = Status Register1 + * + */ +union cvmx_pcsxx_status1_reg { + u64 u64; + struct cvmx_pcsxx_status1_reg_s { + u64 reserved_8_63 : 56; + u64 flt : 1; + u64 reserved_3_6 : 4; + u64 rcv_lnk : 1; + u64 lpable : 1; + u64 reserved_0_0 : 1; + } s; + struct cvmx_pcsxx_status1_reg_s cn52xx; + struct cvmx_pcsxx_status1_reg_s cn52xxp1; + struct cvmx_pcsxx_status1_reg_s cn56xx; + struct cvmx_pcsxx_status1_reg_s cn56xxp1; + struct cvmx_pcsxx_status1_reg_s cn61xx; + struct cvmx_pcsxx_status1_reg_s cn63xx; + struct cvmx_pcsxx_status1_reg_s cn63xxp1; + struct cvmx_pcsxx_status1_reg_s cn66xx; + struct cvmx_pcsxx_status1_reg_s cn68xx; + struct cvmx_pcsxx_status1_reg_s cn68xxp1; + struct cvmx_pcsxx_status1_reg_s cn70xx; + struct cvmx_pcsxx_status1_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_status1_reg cvmx_pcsxx_status1_reg_t; + +/** + * cvmx_pcsx#_status2_reg + * + * PCSX_STATUS2_REG = Status Register2 + * + */ +union cvmx_pcsxx_status2_reg { + u64 u64; + struct cvmx_pcsxx_status2_reg_s { + u64 reserved_16_63 : 48; + u64 dev : 2; + u64 reserved_12_13 : 2; + u64 xmtflt : 1; + u64 rcvflt : 1; + u64 reserved_3_9 : 7; + u64 tengb_w : 1; + u64 tengb_x : 1; + u64 tengb_r : 1; + } s; + struct cvmx_pcsxx_status2_reg_s cn52xx; + struct cvmx_pcsxx_status2_reg_s cn52xxp1; + struct cvmx_pcsxx_status2_reg_s cn56xx; + struct cvmx_pcsxx_status2_reg_s cn56xxp1; + struct cvmx_pcsxx_status2_reg_s cn61xx; + struct cvmx_pcsxx_status2_reg_s cn63xx; + struct cvmx_pcsxx_status2_reg_s cn63xxp1; + struct cvmx_pcsxx_status2_reg_s cn66xx; + struct cvmx_pcsxx_status2_reg_s cn68xx; + struct cvmx_pcsxx_status2_reg_s cn68xxp1; + struct cvmx_pcsxx_status2_reg_s cn70xx; + struct cvmx_pcsxx_status2_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_status2_reg cvmx_pcsxx_status2_reg_t; + +/** + * cvmx_pcsx#_tx_rx_polarity_reg + * + * RX lane polarity vector [3:0] = XOR_RXPLRT<9:6> ^ [4[RXPLRT<1>]]; + * TX lane polarity vector [3:0] = XOR_TXPLRT<5:2> ^ [4[TXPLRT<0>]]; + * In short keep <1:0> to 2'b00, and use <5:2> and <9:6> fields to define per lane polarities + */ +union cvmx_pcsxx_tx_rx_polarity_reg { + u64 u64; + struct cvmx_pcsxx_tx_rx_polarity_reg_s { + u64 reserved_10_63 : 54; + u64 xor_rxplrt : 4; + u64 xor_txplrt : 4; + u64 rxplrt : 1; + u64 txplrt : 1; + } s; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn52xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_cn52xxp1 { + u64 reserved_2_63 : 62; + u64 rxplrt : 1; + u64 txplrt : 1; + } cn52xxp1; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn56xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_cn52xxp1 cn56xxp1; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn61xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn63xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn63xxp1; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn66xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn68xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn68xxp1; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn70xx; + struct cvmx_pcsxx_tx_rx_polarity_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_tx_rx_polarity_reg cvmx_pcsxx_tx_rx_polarity_reg_t; + +/** + * cvmx_pcsx#_tx_rx_states_reg + * + * PCSX_TX_RX_STATES_REG = Transmit Receive States Register + * + */ +union cvmx_pcsxx_tx_rx_states_reg { + u64 u64; + struct cvmx_pcsxx_tx_rx_states_reg_s { + u64 reserved_14_63 : 50; + u64 term_err : 1; + u64 syn3bad : 1; + u64 syn2bad : 1; + u64 syn1bad : 1; + u64 syn0bad : 1; + u64 rxbad : 1; + u64 algn_st : 3; + u64 rx_st : 2; + u64 tx_st : 3; + } s; + struct cvmx_pcsxx_tx_rx_states_reg_s cn52xx; + struct cvmx_pcsxx_tx_rx_states_reg_cn52xxp1 { + u64 reserved_13_63 : 51; + u64 syn3bad : 1; + u64 syn2bad : 1; + u64 syn1bad : 1; + u64 syn0bad : 1; + u64 rxbad : 1; + u64 algn_st : 3; + u64 rx_st : 2; + u64 tx_st : 3; + } cn52xxp1; + struct cvmx_pcsxx_tx_rx_states_reg_s cn56xx; + struct cvmx_pcsxx_tx_rx_states_reg_cn52xxp1 cn56xxp1; + struct cvmx_pcsxx_tx_rx_states_reg_s cn61xx; + struct cvmx_pcsxx_tx_rx_states_reg_s cn63xx; + struct cvmx_pcsxx_tx_rx_states_reg_s cn63xxp1; + struct cvmx_pcsxx_tx_rx_states_reg_s cn66xx; + struct cvmx_pcsxx_tx_rx_states_reg_s cn68xx; + struct cvmx_pcsxx_tx_rx_states_reg_s cn68xxp1; + struct cvmx_pcsxx_tx_rx_states_reg_s cn70xx; + struct cvmx_pcsxx_tx_rx_states_reg_s cn70xxp1; +}; + +typedef union cvmx_pcsxx_tx_rx_states_reg cvmx_pcsxx_tx_rx_states_reg_t; + +#endif
Import cvmx-xcv-defs.h header file from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-xcv-defs.h | 226 ++++++++++++++++++ 1 file changed, 226 insertions(+) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h b/arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h new file mode 100644 index 000000000000..4fd4d163eae1 --- /dev/null +++ b/arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h @@ -0,0 +1,226 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Configuration and status register (CSR) type definitions for + * Octeon xcv. + */ + +#ifndef __CVMX_XCV_DEFS_H__ +#define __CVMX_XCV_DEFS_H__ + +#define CVMX_XCV_BATCH_CRD_RET (0x00011800DB000100ull) +#define CVMX_XCV_COMP_CTL (0x00011800DB000020ull) +#define CVMX_XCV_CTL (0x00011800DB000030ull) +#define CVMX_XCV_DLL_CTL (0x00011800DB000010ull) +#define CVMX_XCV_ECO (0x00011800DB000200ull) +#define CVMX_XCV_INBND_STATUS (0x00011800DB000080ull) +#define CVMX_XCV_INT (0x00011800DB000040ull) +#define CVMX_XCV_RESET (0x00011800DB000000ull) + +/** + * cvmx_xcv_batch_crd_ret + */ +union cvmx_xcv_batch_crd_ret { + u64 u64; + struct cvmx_xcv_batch_crd_ret_s { + u64 reserved_1_63 : 63; + u64 crd_ret : 1; + } s; + struct cvmx_xcv_batch_crd_ret_s cn73xx; +}; + +typedef union cvmx_xcv_batch_crd_ret cvmx_xcv_batch_crd_ret_t; + +/** + * cvmx_xcv_comp_ctl + * + * This register controls programmable compensation. + * + */ +union cvmx_xcv_comp_ctl { + u64 u64; + struct cvmx_xcv_comp_ctl_s { + u64 drv_byp : 1; + u64 reserved_61_62 : 2; + u64 cmp_pctl : 5; + u64 reserved_53_55 : 3; + u64 cmp_nctl : 5; + u64 reserved_45_47 : 3; + u64 drv_pctl : 5; + u64 reserved_37_39 : 3; + u64 drv_nctl : 5; + u64 reserved_31_31 : 1; + u64 pctl_lock : 1; + u64 pctl_sat : 1; + u64 reserved_28_28 : 1; + u64 nctl_lock : 1; + u64 reserved_1_26 : 26; + u64 nctl_sat : 1; + } s; + struct cvmx_xcv_comp_ctl_s cn73xx; +}; + +typedef union cvmx_xcv_comp_ctl cvmx_xcv_comp_ctl_t; + +/** + * cvmx_xcv_ctl + * + * This register contains the status control bits. + * + */ +union cvmx_xcv_ctl { + u64 u64; + struct cvmx_xcv_ctl_s { + u64 reserved_4_63 : 60; + u64 lpbk_ext : 1; + u64 lpbk_int : 1; + u64 speed : 2; + } s; + struct cvmx_xcv_ctl_s cn73xx; +}; + +typedef union cvmx_xcv_ctl cvmx_xcv_ctl_t; + +/** + * cvmx_xcv_dll_ctl + * + * The RGMII timing specification requires that devices transmit clock and + * data synchronously. The specification requires external sources (namely + * the PC board trace routes) to introduce the appropriate 1.5 to 2.0 ns of + * delay. + * + * To eliminate the need for the PC board delays, the RGMII interface has optional + * on-board DLLs for both transmit and receive. For correct operation, at most one + * of the transmitter, board, or receiver involved in an RGMII link should + * introduce delay. By default/reset, the RGMII receivers delay the received clock, + * and the RGMII transmitters do not delay the transmitted clock. Whether this + * default works as-is with a given link partner depends on the behavior of the + * link partner and the PC board. + * + * These are the possible modes of RGMII receive operation: + * + * * XCV_DLL_CTL[CLKRX_BYP] = 0 (reset value) - The RGMII + * receive interface introduces clock delay using its internal DLL. + * This mode is appropriate if neither the remote + * transmitter nor the PC board delays the clock. + * + * * XCV_DLL_CTL[CLKRX_BYP] = 1, [CLKRX_SET] = 0x0 - The + * RGMII receive interface introduces no clock delay. This mode + * is appropriate if either the remote transmitter or the PC board + * delays the clock. + * + * These are the possible modes of RGMII transmit operation: + * + * * XCV_DLL_CTL[CLKTX_BYP] = 1, [CLKTX_SET] = 0x0 (reset value) - + * The RGMII transmit interface introduces no clock + * delay. This mode is appropriate is either the remote receiver + * or the PC board delays the clock. + * + * * XCV_DLL_CTL[CLKTX_BYP] = 0 - The RGMII transmit + * interface introduces clock delay using its internal DLL. + * This mode is appropriate if neither the remote receiver + * nor the PC board delays the clock. + */ +union cvmx_xcv_dll_ctl { + u64 u64; + struct cvmx_xcv_dll_ctl_s { + u64 reserved_32_63 : 32; + u64 lock : 1; + u64 clk_set : 7; + u64 clkrx_byp : 1; + u64 clkrx_set : 7; + u64 clktx_byp : 1; + u64 clktx_set : 7; + u64 reserved_2_7 : 6; + u64 refclk_sel : 2; + } s; + struct cvmx_xcv_dll_ctl_s cn73xx; +}; + +typedef union cvmx_xcv_dll_ctl cvmx_xcv_dll_ctl_t; + +/** + * cvmx_xcv_eco + */ +union cvmx_xcv_eco { + u64 u64; + struct cvmx_xcv_eco_s { + u64 reserved_16_63 : 48; + u64 eco_rw : 16; + } s; + struct cvmx_xcv_eco_s cn73xx; +}; + +typedef union cvmx_xcv_eco cvmx_xcv_eco_t; + +/** + * cvmx_xcv_inbnd_status + * + * This register contains RGMII in-band status. + * + */ +union cvmx_xcv_inbnd_status { + u64 u64; + struct cvmx_xcv_inbnd_status_s { + u64 reserved_4_63 : 60; + u64 duplex : 1; + u64 speed : 2; + u64 link : 1; + } s; + struct cvmx_xcv_inbnd_status_s cn73xx; +}; + +typedef union cvmx_xcv_inbnd_status cvmx_xcv_inbnd_status_t; + +/** + * cvmx_xcv_int + * + * This register controls interrupts. + * + */ +union cvmx_xcv_int { + u64 u64; + struct cvmx_xcv_int_s { + u64 reserved_7_63 : 57; + u64 tx_ovrflw : 1; + u64 tx_undflw : 1; + u64 incomp_byte : 1; + u64 duplex : 1; + u64 reserved_2_2 : 1; + u64 speed : 1; + u64 link : 1; + } s; + struct cvmx_xcv_int_s cn73xx; +}; + +typedef union cvmx_xcv_int cvmx_xcv_int_t; + +/** + * cvmx_xcv_reset + * + * This register controls reset. + * + */ +union cvmx_xcv_reset { + u64 u64; + struct cvmx_xcv_reset_s { + u64 enable : 1; + u64 reserved_16_62 : 47; + u64 clkrst : 1; + u64 reserved_12_14 : 3; + u64 dllrst : 1; + u64 reserved_8_10 : 3; + u64 comp : 1; + u64 reserved_4_6 : 3; + u64 tx_pkt_rst_n : 1; + u64 tx_dat_rst_n : 1; + u64 rx_pkt_rst_n : 1; + u64 rx_dat_rst_n : 1; + } s; + struct cvmx_xcv_reset_s cn73xx; +}; + +typedef union cvmx_xcv_reset cvmx_xcv_reset_t; + +#endif
This patch includes misc changes to already present Octeon MIPS header files, which are necessary for the upcoming ethernet support.
The changes are mostly: - DM GPIO & I2C infrastructure - Coding style cleanup while reworking the headers
Signed-off-by: Stefan Roese sr@denx.de --- .../mach-octeon/include/mach/cvmx-bootmem.h | 3 +- arch/mips/mach-octeon/include/mach/cvmx-fpa.h | 3 +- .../mips/mach-octeon/include/mach/cvmx-fpa3.h | 37 ------- .../include/mach/cvmx-helper-board.h | 6 +- .../include/mach/cvmx-helper-fdt.h | 40 +++---- .../include/mach/cvmx-helper-pko.h | 2 +- .../mach-octeon/include/mach/cvmx-helper.h | 20 ++++ .../mips/mach-octeon/include/mach/cvmx-regs.h | 100 ++++++++++++++++-- .../mach-octeon/include/mach/octeon_eth.h | 54 +++++----- 9 files changed, 166 insertions(+), 99 deletions(-)
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-bootmem.h b/arch/mips/mach-octeon/include/mach/cvmx-bootmem.h index 283ac5c6bb56..d5c004d017ef 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-bootmem.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-bootmem.h @@ -26,7 +26,8 @@
/* Real physical addresses of memory regions */ #define OCTEON_DDR0_BASE (0x0ULL) -#define OCTEON_DDR0_SIZE (0x010000000ULL) +/* Use 16MiB here, as 256 leads to overwriting U-Boot reloc space */ +#define OCTEON_DDR0_SIZE (0x001000000ULL) #define OCTEON_DDR1_BASE ((OCTEON_IS_OCTEON2() || OCTEON_IS_OCTEON3()) \ ? 0x20000000ULL : 0x410000000ULL) #define OCTEON_DDR1_SIZE (0x010000000ULL) diff --git a/arch/mips/mach-octeon/include/mach/cvmx-fpa.h b/arch/mips/mach-octeon/include/mach/cvmx-fpa.h index aa238a885072..0660c31b4f59 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-fpa.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-fpa.h @@ -104,8 +104,9 @@ static inline void *cvmx_fpa_alloc(u64 pool) /* FPA3 is handled differently */ if ((octeon_has_feature(OCTEON_FEATURE_FPA3))) { return cvmx_fpa3_alloc(cvmx_fpa1_pool_to_fpa3_aura(pool)); - } else + } else { return cvmx_fpa1_alloc(pool); + } }
/** diff --git a/arch/mips/mach-octeon/include/mach/cvmx-fpa3.h b/arch/mips/mach-octeon/include/mach/cvmx-fpa3.h index b3e04d7f02a1..9bab03f59a09 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-fpa3.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-fpa3.h @@ -526,41 +526,4 @@ const char *cvmx_fpa3_get_pool_name(cvmx_fpa3_pool_t pool); int cvmx_fpa3_get_pool_buf_size(cvmx_fpa3_pool_t pool); const char *cvmx_fpa3_get_aura_name(cvmx_fpa3_gaura_t aura);
-/* FIXME: Need a different macro for stage2 of u-boot */ - -static inline void cvmx_fpa3_stage2_init(int aura, int pool, u64 stack_paddr, int stacklen, - int buffer_sz, int buf_cnt) -{ - cvmx_fpa_poolx_cfg_t pool_cfg; - - /* Configure pool stack */ - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_BASE(pool), stack_paddr); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_ADDR(pool), stack_paddr); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_END(pool), stack_paddr + stacklen); - - /* Configure pool with buffer size */ - pool_cfg.u64 = 0; - pool_cfg.cn78xx.nat_align = 1; - pool_cfg.cn78xx.buf_size = buffer_sz >> 7; - pool_cfg.cn78xx.l_type = 0x2; - pool_cfg.cn78xx.ena = 0; - cvmx_write_csr_node(0, CVMX_FPA_POOLX_CFG(pool), pool_cfg.u64); - /* Reset pool before starting */ - pool_cfg.cn78xx.ena = 1; - cvmx_write_csr_node(0, CVMX_FPA_POOLX_CFG(pool), pool_cfg.u64); - - cvmx_write_csr_node(0, CVMX_FPA_AURAX_CFG(aura), 0); - cvmx_write_csr_node(0, CVMX_FPA_AURAX_CNT_ADD(aura), buf_cnt); - cvmx_write_csr_node(0, CVMX_FPA_AURAX_POOL(aura), (u64)pool); -} - -static inline void cvmx_fpa3_stage2_disable(int aura, int pool) -{ - cvmx_write_csr_node(0, CVMX_FPA_AURAX_POOL(aura), 0); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_CFG(pool), 0); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_BASE(pool), 0); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_ADDR(pool), 0); - cvmx_write_csr_node(0, CVMX_FPA_POOLX_STACK_END(pool), 0); -} - #endif /* __CVMX_FPA3_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/cvmx-helper-board.h b/arch/mips/mach-octeon/include/mach/cvmx-helper-board.h index 5837592d21aa..9cc61b1a350e 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-helper-board.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-helper-board.h @@ -9,6 +9,8 @@ #ifndef __CVMX_HELPER_BOARD_H__ #define __CVMX_HELPER_BOARD_H__
+#include <asm-generic/gpio.h> + #define CVMX_VSC7224_NAME_LEN 16
typedef enum { @@ -185,8 +187,8 @@ struct cvmx_vsc7224 { struct cvmx_fdt_i2c_bus_info *i2c_bus; /** Address of VSC7224 on i2c bus */ int i2c_addr; - struct cvmx_fdt_gpio_info *los_gpio; /** LoS GPIO pin */ - struct cvmx_fdt_gpio_info *reset_gpio; /** Reset GPIO pin */ + struct gpio_desc los_gpio; /** LoS GPIO pin */ + struct gpio_desc reset_gpio; /** Reset GPIO pin */ int of_offset; /** Offset in device tree */ };
diff --git a/arch/mips/mach-octeon/include/mach/cvmx-helper-fdt.h b/arch/mips/mach-octeon/include/mach/cvmx-helper-fdt.h index 332884557031..c3ce35958372 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-helper-fdt.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-helper-fdt.h @@ -14,10 +14,13 @@ #include <fdtdec.h> #include <time.h> #include <asm/global_data.h> +#include <asm-generic/gpio.h> +#include <dm/device.h> #include <linux/libfdt.h>
#include <mach/cvmx-helper-sfp.h>
+/* todo: this is deprecated and some of it can be removed at some time */ enum cvmx_i2c_bus_type { CVMX_I2C_BUS_OCTEON, CVMX_I2C_MUX_PCA9540, @@ -55,6 +58,8 @@ struct cvmx_fdt_i2c_bus_info { u8 enable_bit; /** True if mux, false if switch */ bool is_mux; + + struct udevice *i2c_bus; };
/** @@ -85,22 +90,24 @@ struct cvmx_fdt_sfp_info { bool is_qsfp; /** True if EEPROM data is valid */ bool valid; + /** SFP tx_disable GPIO descriptor */ - struct cvmx_fdt_gpio_info *tx_disable; + struct gpio_desc tx_disable; /** SFP mod_abs/QSFP mod_prs GPIO descriptor */ - struct cvmx_fdt_gpio_info *mod_abs; + struct gpio_desc mod_abs; /** SFP tx_error GPIO descriptor */ - struct cvmx_fdt_gpio_info *tx_error; + struct gpio_desc tx_error; /** SFP rx_los GPIO discriptor */ - struct cvmx_fdt_gpio_info *rx_los; + struct gpio_desc rx_los; /** QSFP select GPIO descriptor */ - struct cvmx_fdt_gpio_info *select; + struct gpio_desc select; /** QSFP reset GPIO descriptor */ - struct cvmx_fdt_gpio_info *reset; + struct gpio_desc reset; /** QSFP interrupt GPIO descriptor */ - struct cvmx_fdt_gpio_info *interrupt; + struct gpio_desc interrupt; /** QSFP lp_mode GPIO descriptor */ - struct cvmx_fdt_gpio_info *lp_mode; + struct gpio_desc lp_mode; + /** Last mod_abs value */ int last_mod_abs; /** Last rx_los value */ @@ -146,6 +153,9 @@ struct cvmx_fdt_sfp_info { int cvmx_fdt_lookup_phandles(const void *fdt_addr, int node, const char *prop_name, int *lenp, int *nodes);
+int cvmx_ofnode_lookup_phandles(ofnode node, const char *prop_name, + int *lenp, ofnode *nodes); + /** * Helper to return the address property * @@ -341,8 +351,7 @@ int cvmx_fdt_node_offset_by_compatible_list(const void *fdt_addr, int startoffse * Given the parent offset of an i2c device build up a list describing the bus * which can contain i2c muxes and switches. * - * @param[in] fdt_addr address of device tree - * @param of_offset Offset of the parent node of a GPIO device in + * @param[in] node ofnode of the parent node of a GPIO device in * the device tree. * * Return: pointer to list of i2c devices starting from the root which @@ -351,7 +360,7 @@ int cvmx_fdt_node_offset_by_compatible_list(const void *fdt_addr, int startoffse * * @see cvmx_fdt_free_i2c_bus() */ -struct cvmx_fdt_i2c_bus_info *cvmx_fdt_get_i2c_bus(const void *fdt_addr, int of_offset); +struct cvmx_fdt_i2c_bus_info *cvmx_ofnode_get_i2c_bus(ofnode node);
/** * Return the Octeon bus number for a bus descriptor @@ -496,15 +505,6 @@ int __cvmx_fdt_parse_vsc7224(const void *fdt_addr); */ int __cvmx_fdt_parse_avsp5410(const void *fdt_addr);
-/** - * Parse SFP information from device tree - * - * @param[in] fdt_addr Address of flat device tree - * - * Return: pointer to sfp info or NULL if error - */ -struct cvmx_fdt_sfp_info *cvmx_helper_fdt_parse_sfp_info(const void *fdt_addr, int of_offset); - /** * @INTERNAL * Parses either a CS4343 phy or a slice of the phy from the device tree diff --git a/arch/mips/mach-octeon/include/mach/cvmx-helper-pko.h b/arch/mips/mach-octeon/include/mach/cvmx-helper-pko.h index 806102df2243..e1eb824c9346 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-helper-pko.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-helper-pko.h @@ -17,7 +17,7 @@ * number. Users should set this pointer to a function before * calling any cvmx-helper operations. */ -void (*cvmx_override_pko_queue_priority)(int ipd_port, u8 *priorities); +extern void (*cvmx_override_pko_queue_priority)(int ipd_port, u8 *priorities);
/** * Gets the fpa pool number of pko pool diff --git a/arch/mips/mach-octeon/include/mach/cvmx-helper.h b/arch/mips/mach-octeon/include/mach/cvmx-helper.h index caa0c69fc05e..2a7b13322db2 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-helper.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-helper.h @@ -127,6 +127,26 @@ enum cvmx_pko_padding { CVMX_PKO_PADDING_60 = 1, };
+/** + * cvmx_override_iface_phy_mode(int interface, int index) is a function pointer. + * It is meant to allow customization of interfaces which do not have a PHY. + * + * @returns 0 if MAC decides TX_CONFIG_REG or 1 if PHY decides TX_CONFIG_REG. + * + * If this function pointer is NULL then it defaults to the MAC. + */ +extern int (*cvmx_override_iface_phy_mode) (int interface, int index); + +/** + * cvmx_override_ipd_port_setup(int ipd_port) is a function + * pointer. It is meant to allow customization of the IPD port/port kind + * setup before packet input/output comes online. It is called + * after cvmx-helper does the default IPD configuration, but + * before IPD is enabled. Users should set this pointer to a + * function before calling any cvmx-helper operations. + */ +extern void (*cvmx_override_ipd_port_setup) (int ipd_port); + /** * This function enables the IPD and also enables the packet interfaces. * The packet interfaces (RGMII and SPI) must be enabled after the diff --git a/arch/mips/mach-octeon/include/mach/cvmx-regs.h b/arch/mips/mach-octeon/include/mach/cvmx-regs.h index dbb77232e262..f97c1e907f0b 100644 --- a/arch/mips/mach-octeon/include/mach/cvmx-regs.h +++ b/arch/mips/mach-octeon/include/mach/cvmx-regs.h @@ -6,6 +6,7 @@ #ifndef __CVMX_REGS_H__ #define __CVMX_REGS_H__
+#include <log.h> #include <linux/bitfield.h> #include <linux/bitops.h> #include <linux/io.h> @@ -32,6 +33,7 @@
/* Regs */ #define CVMX_CIU3_NMI 0x0001010000000160ULL +#define CVMX_CIU3_ISCX_W1C(x) (0x0001010090000000ull + ((x) & 1048575) * 8)
#define CVMX_MIO_BOOT_LOC_CFGX(x) (0x0001180000000080ULL + ((x) & 1) * 8) #define MIO_BOOT_LOC_CFG_BASE GENMASK_ULL(27, 3) @@ -55,11 +57,19 @@ #define CVMX_RNM_CTL_STATUS 0x0001180040000000ULL #define RNM_CTL_STATUS_EER_VAL BIT_ULL(9)
+/* IOBDMA/LMTDMA IO addresses */ +#define CVMX_LMTDMA_ORDERED_IO_ADDR 0xffffffffffffa400ull #define CVMX_IOBDMA_ORDERED_IO_ADDR 0xffffffffffffa200ull
/* turn the variable name into a string */ #define CVMX_TMP_STR(x) CVMX_TMP_STR2(x) #define CVMX_TMP_STR2(x) #x +#define VASTR(...) #__VA_ARGS__ + +#define CVMX_PKO_LMTLINE 2ull +#define CVMX_SCRATCH_BASE (-32768l) /* 0xffffffffffff8000 */ + +#define COP0_CVMMEMCTL $11,7 /* Cavium memory control */
#define CVMX_RDHWR(result, regstr) \ asm volatile("rdhwr %[rt],$" CVMX_TMP_STR(regstr) : [rt] "=d"(result)) @@ -67,6 +77,13 @@ asm("rdhwr %[rt],$" CVMX_TMP_STR(regstr) : [rt] "=d"(result)) #define CVMX_POP(result, input) \ asm("pop %[rd],%[rs]" : [rd] "=d"(result) : [rs] "d"(input)) +#define CVMX_MF_COP0(val, cop0) \ + asm("dmfc0 %[rt]," VASTR(cop0) : [rt] "=d" (val)) +#define CVMX_MT_COP0(val, cop0) \ + asm("dmtc0 %[rt]," VASTR(cop0) : : [rt] "d" (val)) + +#define CVMX_MF_CVM_MEM_CTL(val) CVMX_MF_COP0(val, COP0_CVMMEMCTL) +#define CVMX_MT_CVM_MEM_CTL(val) CVMX_MT_COP0(val, COP0_CVMMEMCTL)
#define CVMX_SYNC asm volatile("sync\n" : : : "memory") #define CVMX_SYNCW asm volatile("syncw\nsyncw\n" : : : "memory") @@ -81,6 +98,18 @@
#define CVMX_MF_CHORD(dest) CVMX_RDHWR(dest, 30)
+#define CVMX_PREFETCH0(address) CVMX_PREFETCH(address, 0) +#define CVMX_PREFETCH128(address) CVMX_PREFETCH(address, 128) + +/** a normal prefetch */ +#define CVMX_PREFETCH(address, offset) CVMX_PREFETCH_PREF0(address, offset) + +/** normal prefetches that use the pref instruction */ +#define CVMX_PREFETCH_PREFX(X, address, offset) \ + asm volatile ("pref %[type], %[off](%[rbase])" : : [rbase] "d" (address), [off] "I" (offset), [type] "n" (X)) +#define CVMX_PREFETCH_PREF0(address, offset) \ + CVMX_PREFETCH_PREFX(0, address, offset) + /* * The macros cvmx_likely and cvmx_unlikely use the * __builtin_expect GCC operation to control branch @@ -405,6 +434,30 @@ static inline unsigned int cvmx_get_local_core_num(void) return core_num & core_mask; }
+/** + * Given a CSR address return the node number of that address + * + * @param addr Address to extract node number from + * + * @return node number + */ +static inline u8 cvmx_csr_addr_to_node(u64 addr) +{ + return (addr >> CVMX_NODE_IO_SHIFT) & CVMX_NODE_MASK; +} + +/** + * Strip the node address bits from a CSR address + * + * @param addr CSR address to strip the node bits from + * + * @return CSR address with the node bits set to zero + */ +static inline u64 cvmx_csr_addr_strip_node(u64 addr) +{ + return addr & ~((u64)CVMX_NODE_MASK << CVMX_NODE_IO_SHIFT); +} + /** * Returns the number of bits set in the provided value. * Simple wrapper for POP instruction. @@ -428,14 +481,45 @@ static inline u32 cvmx_pop(u32 val) #define cvmx_printf printf #define cvmx_vprintf vprintf
-#if defined(DEBUG) -void cvmx_warn(const char *format, ...) __printf(1, 2); -#else -void cvmx_warn(const char *format, ...); -#endif +/* Use common debug macros */ +#define cvmx_warn debug +#define cvmx_warn_if debug_cond + +/** + * Atomically adds a signed value to a 32 bit (aligned) memory location, + * and returns previous value. + * + * Memory access ordering is enforced before/after the atomic operation, + * so no additional 'sync' instructions are required. + * + * @param ptr address in memory to add incr to + * @param incr amount to increment memory location by (signed) + * + * @return Value of memory location before increment + */ +static inline int32_t cvmx_atomic_fetch_and_add32(int32_t * ptr, int32_t incr) +{ + int32_t val;
-#define cvmx_warn_if(expression, format, ...) \ - if (expression) \ - cvmx_warn(format, ##__VA_ARGS__) + val = *ptr; + *ptr += incr; + return val; +} + +/** + * Atomically adds a signed value to a 32 bit (aligned) memory location. + * + * This version does not perform 'sync' operations to enforce memory + * operations. This should only be used when there are no memory operation + * ordering constraints. (This should NOT be used for reference counting - + * use the standard version instead.) + * + * @param ptr address in memory to add incr to + * @param incr amount to increment memory location by (signed) + */ +static inline void cvmx_atomic_add32_nosync(int32_t * ptr, int32_t incr) +{ + *ptr += incr; +}
#endif /* __CVMX_REGS_H__ */ diff --git a/arch/mips/mach-octeon/include/mach/octeon_eth.h b/arch/mips/mach-octeon/include/mach/octeon_eth.h index 096fcfbfcfaa..83e62075ed9f 100644 --- a/arch/mips/mach-octeon/include/mach/octeon_eth.h +++ b/arch/mips/mach-octeon/include/mach/octeon_eth.h @@ -1,17 +1,13 @@ /* SPDX-License-Identifier: GPL-2.0 */ /* - * Copyright (C) 2020 Marvell International Ltd. + * Copyright (C) 2020-2022 Marvell International Ltd. */
#ifndef __OCTEON_ETH_H__ #define __OCTEON_ETH_H__
-#include <phy.h> -#include <miiphy.h> - #include <mach/cvmx-helper.h> #include <mach/cvmx-helper-board.h> -#include <mach/octeon_fdt.h>
struct eth_device;
@@ -27,33 +23,25 @@ struct octeon_eth_info { struct phy_device *phydev; /** PHY device */ struct eth_device *ethdev; /** Eth device this priv is part of */ int mii_addr; - int phy_fdt_offset; /** Offset of PHY info in device tree */ - int fdt_offset; /** Offset of Eth interface in DT */ - int phy_offset; /** Offset of PHY dev in device tree */ + int phy_fdt_offset; /** Offset of PHY info in device tree */ + int fdt_offset; /** Offset of Eth interface in DT */ + int phy_offset; /** Offset of PHY device in device tree */ enum cvmx_phy_type phy_device_type; /** Type of PHY */ /* current link status, use to reconfigure on status changes */ u64 packets_sent; u64 packets_received; - u32 link_speed : 2; - u32 link_duplex : 1; - u32 link_status : 1; - u32 loopback : 1; - u32 enabled : 1; - u32 is_c45 : 1; /** Set if we need to use clause 45 */ - u32 vitesse_sfp_config : 1; /** Need Vitesse SFP config */ - u32 ti_gpio_config : 1; /** Need TI GPIO config */ - u32 bgx_mac_set : 1; /** Has the BGX MAC been set already */ - u64 last_bgx_mac; /** Last BGX MAC address set */ - u64 gmx_base; /** Base address to access GMX CSRs */ - bool mod_abs; /** True if module is absent */ - - /** - * User defined function to check if a SFP+ module is absent or not. - * - * @param dev Ethernet device - * @param data User supplied data - */ - int (*check_mod_abs)(struct eth_device *dev, void *data); + uint32_t link_speed : 2; + uint32_t link_duplex : 1; + uint32_t link_status : 1; + uint32_t loopback : 1; + uint32_t enabled : 1; + uint32_t is_c45 : 1; /** Set if we need to use clause 45 */ + uint32_t vitesse_sfp_config : 1; /** Need Vitesse SFP config */ + uint32_t ti_gpio_config : 1; /** Need TI GPIO configuration */ + uint32_t bgx_mac_set : 1; /** Has the BGX MAC been set already */ + u64 last_bgx_mac; /** Last BGX MAC address set */ + u64 gmx_base; /** Base address to access GMX CSRs */ + bool mod_abs; /** True if module is absent */
/** User supplied data for check_mod_abs */ void *mod_abs_data; @@ -71,12 +59,20 @@ struct octeon_eth_info { * @return 0 for success, otherwise error */ int (*mod_abs_changed)(struct eth_device *dev, bool mod_abs); + /** SDK phy information data structure */ cvmx_phy_info_t phy_info; + + struct udevice *mdio_dev; + struct mii_dev *bus; + struct phy_device *phy_dev; + #ifdef CONFIG_OCTEON_SFP /** Information about connected SFP/SFP+/SFP28/QSFP+/QSFP28 module */ struct octeon_sfp_info sfp; #endif + + cvmx_wqe_t *work; };
/** @@ -136,6 +132,6 @@ void octeon_eth_register_mod_abs_changed(struct eth_device *dev, * * NOTE: If the module state is changed then the module callback is called. */ -void octeon_phy_port_check(struct eth_device *dev); +void octeon_phy_port_check(struct udevice *dev);
#endif /* __OCTEON_ETH_H__ */
Import cvmx-helper-agl.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-agl.c | 231 ++++++++++++++++++++++++ 1 file changed, 231 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-agl.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-agl.c b/arch/mips/mach-octeon/cvmx-helper-agl.c new file mode 100644 index 000000000000..7eb99ac7c22b --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-agl.c @@ -0,0 +1,231 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for AGL (RGMII) initialization, configuration, + * and monitoring. + */ + +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-agl.h> +#include <mach/cvmx-pki.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-pko-defs.h> + +int __cvmx_helper_agl_enumerate(int xiface) +{ + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + union cvmx_agl_prtx_ctl agl_prtx_ctl; + + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(0)); + if (agl_prtx_ctl.s.mode == 0) /* RGMII */ + return 1; + } + return 0; +} + +/** + * @INTERNAL + * Convert interface to port to assess CSRs. + * + * @param xiface Interface to probe + * @return The port corresponding to the interface + */ +int cvmx_helper_agl_get_port(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) + return xi.interface - 4; + return -1; +} + +/** + * @INTERNAL + * Probe a RGMII interface and determine the number of ports + * connected to it. The RGMII interface should still be down + * after this call. + * + * @param interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_agl_probe(int interface) +{ + int port = cvmx_helper_agl_get_port(interface); + union cvmx_agl_gmx_bist gmx_bist; + union cvmx_agl_gmx_prtx_cfg gmx_prtx_cfg; + union cvmx_agl_prtx_ctl agl_prtx_ctl; + int result; + + result = __cvmx_helper_agl_enumerate(interface); + if (result == 0) + return 0; + + /* Check BIST status */ + gmx_bist.u64 = csr_rd(CVMX_AGL_GMX_BIST); + if (gmx_bist.u64) + printf("Management port AGL failed BIST (0x%016llx) on AGL%d\n", + CAST64(gmx_bist.u64), port); + + /* Disable the external input/output */ + gmx_prtx_cfg.u64 = csr_rd(CVMX_AGL_GMX_PRTX_CFG(port)); + gmx_prtx_cfg.s.en = 0; + csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), gmx_prtx_cfg.u64); + + /* Set the rgx_ref_clk MUX with AGL_PRTx_CTL[REFCLK_SEL]. Default value + * is 0 (RGMII REFCLK). Recommended to use RGMII RXC(1) or sclk/4 (2) + * to save cost. + */ + + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.clkrst = 0; + agl_prtx_ctl.s.dllrst = 0; + agl_prtx_ctl.s.clktx_byp = 0; + + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + bool tx_enable_bypass; + int tx_delay; + + agl_prtx_ctl.s.refclk_sel = + cvmx_helper_get_agl_refclk_sel(interface, port); + agl_prtx_ctl.s.clkrx_set = + cvmx_helper_get_agl_rx_clock_skew(interface, port); + agl_prtx_ctl.s.clkrx_byp = + cvmx_helper_get_agl_rx_clock_delay_bypass(interface, + port); + cvmx_helper_cfg_get_rgmii_tx_clk_delay( + interface, port, &tx_enable_bypass, &tx_delay); + agl_prtx_ctl.s.clktx_byp = tx_enable_bypass; + agl_prtx_ctl.s.clktx_set = tx_delay; + } + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + /* Force write out before wait */ + csr_rd(CVMX_AGL_PRTX_CTL(port)); + udelay(500); + + /* Enable the componsation controller */ + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.drv_byp = 0; + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + /* Force write out before wait */ + csr_rd(CVMX_AGL_PRTX_CTL(port)); + + if (!OCTEON_IS_OCTEON3()) { + /* Enable the interface */ + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.enable = 1; + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + /* Read the value back to force the previous write */ + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + } + + /* Enable the compensation controller */ + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.comp = 1; + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + /* Force write out before wait */ + csr_rd(CVMX_AGL_PRTX_CTL(port)); + + /* for componsation state to lock. */ + udelay(500); + + return result; +} + +/** + * @INTERNAL + * Bringup and enable a RGMII interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_agl_enable(int interface) +{ + int port = cvmx_helper_agl_get_port(interface); + int ipd_port = cvmx_helper_get_ipd_port(interface, port); + union cvmx_pko_mem_port_ptrs pko_mem_port_ptrs; + union cvmx_pko_reg_read_idx read_idx; + int do_link_set = 1; + int i; + + /* Setup PKO for AGL interface. Back pressure is not supported. */ + pko_mem_port_ptrs.u64 = 0; + read_idx.u64 = 0; + read_idx.s.inc = 1; + csr_wr(CVMX_PKO_REG_READ_IDX, read_idx.u64); + + for (i = 0; i < 40; i++) { + pko_mem_port_ptrs.u64 = csr_rd(CVMX_PKO_MEM_PORT_PTRS); + if (pko_mem_port_ptrs.s.pid == 24) { + pko_mem_port_ptrs.s.eid = 10; + pko_mem_port_ptrs.s.bp_port = 40; + csr_wr(CVMX_PKO_MEM_PORT_PTRS, pko_mem_port_ptrs.u64); + break; + } + } + + cvmx_agl_enable(port); + if (do_link_set) + cvmx_agl_link_set(port, cvmx_agl_link_get(ipd_port)); + + return 0; +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_agl_link_get(int ipd_port) +{ + return cvmx_agl_link_get(ipd_port); +} + +/** + * @INTERNAL + * Configure an IPD/PKO port for the specified link state. This + * function does not influence auto negotiation at the PHY level. + * The passed link state must always match the link state returned + * by cvmx_helper_link_get(). It is normally best to use + * cvmx_helper_link_autoconf() instead. + * + * @param ipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_agl_link_set(int ipd_port, cvmx_helper_link_info_t link_info) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + int port = cvmx_helper_agl_get_port(interface); + + return cvmx_agl_link_set(port, link_info); +}
Import cvmx-helper-bgx.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-bgx.c | 2737 +++++++++++++++++++++++ 1 file changed, 2737 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-bgx.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-bgx.c b/arch/mips/mach-octeon/cvmx-helper-bgx.c new file mode 100644 index 000000000000..7d6e178a447a --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-bgx.c @@ -0,0 +1,2737 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions to configure the BGX MAC. + */ + +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-fdt.h> +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +#include <mach/cvmx-global-resources.h> +#include <mach/cvmx-pko-internal-ports-range.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pip.h> + +/* Enable this define to see BGX error messages */ +/*#define DEBUG_BGX */ + +/* Enable this variable to trace functions called for initializing BGX */ +static const int debug; + +/** + * cvmx_helper_bgx_override_autoneg(int xiface, int index) is a function pointer + * to override enabling/disabling of autonegotiation for SGMII, 10G-KR or 40G-KR4 + * interfaces. This function is called when interface is initialized. + */ +int (*cvmx_helper_bgx_override_autoneg)(int xiface, int index) = NULL; + +/* + * cvmx_helper_bgx_override_fec(int xiface) is a function pointer + * to override enabling/disabling of FEC for 10G interfaces. This function + * is called when interface is initialized. + */ +int (*cvmx_helper_bgx_override_fec)(int xiface, int index) = NULL; + +/** + * Delay after enabling an interface based on the mode. Different modes take + * different amounts of time. + */ +static void +__cvmx_helper_bgx_interface_enable_delay(cvmx_helper_interface_mode_t mode) +{ + switch (mode) { + case CVMX_HELPER_INTERFACE_MODE_10G_KR: + case CVMX_HELPER_INTERFACE_MODE_40G_KR4: + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_XFI: + mdelay(250); + break; + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_XAUI: + mdelay(100); + break; + case CVMX_HELPER_INTERFACE_MODE_SGMII: + mdelay(50); + break; + default: + mdelay(50); + break; + } +} + +/** + * @INTERNAL + * + * Returns number of ports based on interface + * @param xiface Which xiface + * @return Number of ports based on xiface + */ +int __cvmx_helper_bgx_enumerate(int xiface) +{ + cvmx_bgxx_cmr_tx_lmacs_t lmacs; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + lmacs.u64 = csr_rd_node(xi.node, CVMX_BGXX_CMR_TX_LMACS(xi.interface)); + return lmacs.s.lmacs; +} + +/** + * @INTERNAL + * + * Returns mode of each BGX LMAC (port). + * This is different than 'cvmx_helper_interface_get_mode()' which + * provides mode of an entire interface, but when BGX is in "mixed" + * mode this function should be called instead to get the protocol + * for each port (BGX LMAC) individually. + * Both function return the same enumerated mode. + * + * @param xiface is the global interface identifier + * @param index is the interface port index + * @returns mode of the individual port + */ +cvmx_helper_interface_mode_t cvmx_helper_bgx_get_mode(int xiface, int index) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_bgxx_spux_br_pmd_control_t pmd_control; + + cmr_config.u64 = csr_rd_node( + xi.node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + + switch (cmr_config.s.lmac_type) { + case 0: + return CVMX_HELPER_INTERFACE_MODE_SGMII; + case 1: + return CVMX_HELPER_INTERFACE_MODE_XAUI; + case 2: + return CVMX_HELPER_INTERFACE_MODE_RXAUI; + case 3: + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) + return cvmx_helper_interface_get_mode(xiface); + pmd_control.u64 = csr_rd_node( + xi.node, + CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, xi.interface)); + if (pmd_control.s.train_en) + return CVMX_HELPER_INTERFACE_MODE_10G_KR; + else + return CVMX_HELPER_INTERFACE_MODE_XFI; + break; + case 4: + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) + return cvmx_helper_interface_get_mode(xiface); + pmd_control.u64 = csr_rd_node( + xi.node, + CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, xi.interface)); + if (pmd_control.s.train_en) + return CVMX_HELPER_INTERFACE_MODE_40G_KR4; + else + return CVMX_HELPER_INTERFACE_MODE_XLAUI; + break; + case 5: + return CVMX_HELPER_INTERFACE_MODE_RGMII; + default: + return CVMX_HELPER_INTERFACE_MODE_DISABLED; + } +} + +static int __cvmx_helper_bgx_rgmii_speed(cvmx_helper_link_info_t link_info) +{ + cvmx_xcv_reset_t xcv_reset; + cvmx_xcv_ctl_t xcv_ctl; + cvmx_xcv_batch_crd_ret_t crd_ret; + cvmx_xcv_dll_ctl_t dll_ctl; + cvmx_xcv_comp_ctl_t comp_ctl; + int speed; + int up = link_info.s.link_up; + int do_credits; + + if (link_info.s.speed == 100) + speed = 1; + else if (link_info.s.speed == 10) + speed = 0; + else + speed = 2; + + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_ctl.u64 = csr_rd(CVMX_XCV_CTL); + do_credits = up && !xcv_reset.s.enable; + + if (xcv_ctl.s.lpbk_int) { + xcv_reset.s.clkrst = 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + } + + if (up && (!xcv_reset.s.enable || xcv_ctl.s.speed != speed)) { + if (debug) + debug("%s: *** Enabling XCV block\n", __func__); + /* Enable the XCV block */ + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.enable = 1; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + + /* Set operating mode */ + xcv_ctl.u64 = csr_rd(CVMX_XCV_CTL); + xcv_ctl.s.speed = speed; + csr_wr(CVMX_XCV_CTL, xcv_ctl.u64); + + /* Configure DLL - enable or bypass */ + /* TX no bypass, RX bypass */ + dll_ctl.u64 = csr_rd(CVMX_XCV_DLL_CTL); + dll_ctl.s.clkrx_set = 0; + dll_ctl.s.clkrx_byp = 1; + dll_ctl.s.clktx_byp = 0; + csr_wr(CVMX_XCV_DLL_CTL, dll_ctl.u64); + + /* Enable */ + dll_ctl.u64 = csr_rd(CVMX_XCV_DLL_CTL); + dll_ctl.s.refclk_sel = 0; + csr_wr(CVMX_XCV_DLL_CTL, dll_ctl.u64); + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.dllrst = 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + + /* Delay deems to be need so XCV_DLL_CTL[CLK_SET] works */ + udelay(10); + + comp_ctl.u64 = csr_rd(CVMX_XCV_COMP_CTL); + //comp_ctl.s.drv_pctl = 0; + //comp_ctl.s.drv_nctl = 0; + comp_ctl.s.drv_byp = 0; + csr_wr(CVMX_XCV_COMP_CTL, comp_ctl.u64); + + /* enable */ + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.comp = 1; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + + /* setup the RXC */ + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.clkrst = !xcv_ctl.s.lpbk_int; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + + /* datapaths come out of the reset + * - the datapath resets will disengage BGX from the RGMII + * interface + * - XCV will continue to return TX credits for each tick that + * is sent on the TX data path + */ + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.tx_dat_rst_n = 1; + xcv_reset.s.rx_dat_rst_n = 1; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + } else if (debug) { + debug("%s: *** Not enabling XCV\n", __func__); + debug(" up: %s, xcv_reset.s.enable: %d, xcv_ctl.s.speed: %d, speed: %d\n", + up ? "true" : "false", (unsigned int)xcv_reset.s.enable, + (unsigned int)xcv_ctl.s.speed, speed); + } + + /* enable the packet flow + * - The packet resets will be only disengage on packet boundaries + * - XCV will continue to return TX credits for each tick that is + * sent on the TX datapath + */ + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.tx_pkt_rst_n = up; + xcv_reset.s.rx_pkt_rst_n = up; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + + /* Full reset when link is down */ + if (!up) { + if (debug) + debug("%s: *** Disabling XCV reset\n", __func__); + /* wait 2*MTU in time */ + mdelay(10); + /* reset the world */ + csr_wr(CVMX_XCV_RESET, 0); + } + + /* grant PKO TX credits */ + if (do_credits) { + crd_ret.u64 = csr_rd(CVMX_XCV_BATCH_CRD_RET); + crd_ret.s.crd_ret = 1; + csr_wr(CVMX_XCV_BATCH_CRD_RET, crd_ret.u64); + } + + return 0; +} + +static void __cvmx_bgx_common_init_pknd(int xiface, int index) +{ + int num_ports; + int num_chl = 16; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + int pknd; + cvmx_bgxx_cmrx_rx_bp_on_t bgx_rx_bp_on; + cvmx_bgxx_cmrx_rx_id_map_t cmr_rx_id_map; + cvmx_bgxx_cmr_chan_msk_and_t chan_msk_and; + cvmx_bgxx_cmr_chan_msk_or_t chan_msk_or; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + num_ports = cvmx_helper_ports_on_interface(xiface); + /* Modify bp_on mark, depending on number of LMACS on that interface + * and write it for every port + */ + bgx_rx_bp_on.u64 = 0; + bgx_rx_bp_on.s.mark = (CVMX_BGX_RX_FIFO_SIZE / (num_ports * 4 * 16)); + + /* Setup pkind */ + pknd = cvmx_helper_get_pknd(xiface, index); + cmr_rx_id_map.u64 = csr_rd_node( + node, CVMX_BGXX_CMRX_RX_ID_MAP(index, xi.interface)); + cmr_rx_id_map.s.pknd = pknd; + /* Change the default reassembly id (RID), as max 14 RIDs allowed */ + if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + cmr_rx_id_map.s.rid = ((4 * xi.interface) + 2 + index); + csr_wr_node(node, CVMX_BGXX_CMRX_RX_ID_MAP(index, xi.interface), + cmr_rx_id_map.u64); + /* Set backpressure channel mask AND/OR registers */ + chan_msk_and.u64 = + csr_rd_node(node, CVMX_BGXX_CMR_CHAN_MSK_AND(xi.interface)); + chan_msk_or.u64 = + csr_rd_node(node, CVMX_BGXX_CMR_CHAN_MSK_OR(xi.interface)); + chan_msk_and.s.msk_and |= ((1 << num_chl) - 1) << (16 * index); + chan_msk_or.s.msk_or |= ((1 << num_chl) - 1) << (16 * index); + csr_wr_node(node, CVMX_BGXX_CMR_CHAN_MSK_AND(xi.interface), + chan_msk_and.u64); + csr_wr_node(node, CVMX_BGXX_CMR_CHAN_MSK_OR(xi.interface), + chan_msk_or.u64); + /* set rx back pressure (bp_on) on value */ + csr_wr_node(node, CVMX_BGXX_CMRX_RX_BP_ON(index, xi.interface), + bgx_rx_bp_on.u64); +} + +/** + * @INTERNAL + * Probe a SGMII interface and determine the number of ports + * connected to it. The SGMII interface should still be down after + * this call. This is used by interfaces using the bgx mac. + * + * @param xiface Interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_bgx_probe(int xiface) +{ + return __cvmx_helper_bgx_enumerate(xiface); +} + +/** + * @INTERNAL + * Return the size of the BGX TX_FIFO for a given LMAC, + * or 0 if the requested LMAC is inactive. + * + * TBD: Need also to add a "__cvmx_helper_bgx_speed()" function to + * return the speed of each LMAC. + */ +int __cvmx_helper_bgx_fifo_size(int xiface, unsigned int lmac) +{ + cvmx_bgxx_cmr_tx_lmacs_t lmacs; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + unsigned int tx_fifo_size = CVMX_BGX_TX_FIFO_SIZE; + + /* FIXME: Add validation for interface# < BGX_count */ + lmacs.u64 = csr_rd_node(xi.node, CVMX_BGXX_CMR_TX_LMACS(xi.interface)); + + switch (lmacs.s.lmacs) { + case 1: + if (lmac > 0) + return 0; + else + return tx_fifo_size; + case 2: + if (lmac > 1) + return 0; + else + return tx_fifo_size >> 1; + case 3: + if (lmac > 2) + return 0; + else + return tx_fifo_size >> 2; + case 4: + if (lmac > 3) + return 0; + else + return tx_fifo_size >> 2; + default: + return 0; + } +} + +/** + * @INTERNAL + * Perform initialization required only once for an SGMII port. + * + * @param xiface Interface to init + * @param index Index of prot on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_bgx_sgmii_hardware_init_one_time(int xiface, int index) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + const u64 clock_mhz = 1200; /* todo: fixme */ + cvmx_bgxx_gmp_pcs_miscx_ctl_t gmp_misc_ctl; + cvmx_bgxx_gmp_pcs_linkx_timer_t gmp_timer; + + if (!cvmx_helper_is_port_valid(xi.interface, index)) + return 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + /* + * Write PCS*_LINK*_TIMER_COUNT_REG[COUNT] with the + * appropriate value. 1000BASE-X specifies a 10ms + * interval. SGMII specifies a 1.6ms interval. + */ + gmp_misc_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface)); + /* Adjust the MAC mode if requested by device tree */ + gmp_misc_ctl.s.mac_phy = cvmx_helper_get_mac_phy_mode(xiface, index); + gmp_misc_ctl.s.mode = cvmx_helper_get_1000x_mode(xiface, index); + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface), + gmp_misc_ctl.u64); + + gmp_timer.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_LINKX_TIMER(index, xi.interface)); + if (gmp_misc_ctl.s.mode) + /* 1000BASE-X */ + gmp_timer.s.count = (10000ull * clock_mhz) >> 10; + else + /* SGMII */ + gmp_timer.s.count = (1600ull * clock_mhz) >> 10; + + csr_wr_node(node, CVMX_BGXX_GMP_PCS_LINKX_TIMER(index, xi.interface), + gmp_timer.u64); + + /* + * Write the advertisement register to be used as the + * tx_Config_RegD15:D0 of the autonegotiation. In + * 1000BASE-X mode, tx_Config_RegD15:D0 is PCS*_AN*_ADV_REG. + * In SGMII PHY mode, tx_Config_RegD15:D0 is + * PCS*_SGM*_AN_ADV_REG. In SGMII MAC mode, + * tx_Config_RegD15:D0 is the fixed value 0x4001, so this + * step can be skipped. + */ + if (gmp_misc_ctl.s.mode) { + /* 1000BASE-X */ + cvmx_bgxx_gmp_pcs_anx_adv_t gmp_an_adv; + + gmp_an_adv.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_ANX_ADV(index, xi.interface)); + gmp_an_adv.s.rem_flt = 0; + gmp_an_adv.s.pause = 3; + gmp_an_adv.s.hfd = 1; + gmp_an_adv.s.fd = 1; + csr_wr_node(node, + CVMX_BGXX_GMP_PCS_ANX_ADV(index, xi.interface), + gmp_an_adv.u64); + } else { + if (gmp_misc_ctl.s.mac_phy) { + /* PHY Mode */ + cvmx_bgxx_gmp_pcs_sgmx_an_adv_t gmp_sgmx_an_adv; + + gmp_sgmx_an_adv.u64 = + csr_rd_node(node, CVMX_BGXX_GMP_PCS_SGMX_AN_ADV( + index, xi.interface)); + gmp_sgmx_an_adv.s.dup = 1; + gmp_sgmx_an_adv.s.speed = 2; + csr_wr_node(node, + CVMX_BGXX_GMP_PCS_SGMX_AN_ADV(index, + xi.interface), + gmp_sgmx_an_adv.u64); + } else { + /* MAC Mode - Nothing to do */ + } + } + return 0; +} + +/** + * @INTERNAL + * Bring up the SGMII interface to be ready for packet I/O but + * leave I/O disabled using the GMX override. This function + * follows the bringup documented in 10.6.3 of the manual. + * + * @param xiface Interface to bringup + * @param num_ports Number of ports on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_bgx_sgmii_hardware_init(int xiface, int num_ports) +{ + int index; + int do_link_set = 1; + + for (index = 0; index < num_ports; index++) { + int xipd_port = cvmx_helper_get_ipd_port(xiface, index); + cvmx_helper_interface_mode_t mode; + + if (!cvmx_helper_is_port_valid(xiface, index)) + continue; + + __cvmx_helper_bgx_port_init(xipd_port, 0); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + continue; + + if (do_link_set) + __cvmx_helper_bgx_sgmii_link_set( + xipd_port, + __cvmx_helper_bgx_sgmii_link_get(xipd_port)); + } + + return 0; +} + +/** + * @INTERNAL + * Bringup and enable a SGMII interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. This is used by interfaces using + * the bgx mac. + * + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_bgx_sgmii_enable(int xiface) +{ + int num_ports; + + num_ports = cvmx_helper_ports_on_interface(xiface); + __cvmx_helper_bgx_sgmii_hardware_init(xiface, num_ports); + + return 0; +} + +/** + * @INTERNAL + * Initialize the SERDES link for the first time or after a loss + * of link. + * + * @param xiface Interface to init + * @param index Index of prot on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_bgx_sgmii_hardware_init_link(int xiface, int index) +{ + cvmx_bgxx_gmp_pcs_mrx_control_t gmp_control; + cvmx_bgxx_gmp_pcs_miscx_ctl_t gmp_misc_ctl; + cvmx_bgxx_cmrx_config_t cmr_config; + int phy_mode, mode_1000x; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + int node = xi.node; + int autoneg = 0; + + if (!cvmx_helper_is_port_valid(xiface, index)) + return 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + gmp_control.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface)); + /* Take PCS through a reset sequence */ + gmp_control.s.reset = 1; + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface), + gmp_control.u64); + + /* Wait until GMP_PCS_MRX_CONTROL[reset] comes out of reset */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface), + cvmx_bgxx_gmp_pcs_mrx_control_t, reset, ==, 0, 10000)) { + debug("SGMII%d: Timeout waiting for port %d to finish reset\n", + interface, index); + return -1; + } + + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + + gmp_control.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface)); + if (cvmx_helper_get_port_phy_present(xiface, index)) { + gmp_control.s.pwr_dn = 0; + } else { + gmp_control.s.spdmsb = 1; + gmp_control.s.spdlsb = 0; + gmp_control.s.pwr_dn = 0; + } + /* Write GMP_PCS_MR*_CONTROL[RST_AN]=1 to ensure a fresh SGMII + * negotiation starts. + */ + autoneg = cvmx_helper_get_port_autonegotiation(xiface, index); + gmp_control.s.rst_an = 1; + gmp_control.s.an_en = (cmr_config.s.lmac_type != 5) && autoneg; + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface), + gmp_control.u64); + + phy_mode = cvmx_helper_get_mac_phy_mode(xiface, index); + mode_1000x = cvmx_helper_get_1000x_mode(xiface, index); + + gmp_misc_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface)); + gmp_misc_ctl.s.mac_phy = phy_mode; + gmp_misc_ctl.s.mode = mode_1000x; + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface), + gmp_misc_ctl.u64); + + if (phy_mode || !autoneg) + /* In PHY mode we can't query the link status so we just + * assume that the link is up + */ + return 0; + + /* Wait for GMP_PCS_MRX_CONTROL[an_cpt] to be set, indicating that + * SGMII autonegotiation is complete. In MAC mode this isn't an + * ethernet link, but a link between OCTEON and PHY. + */ + if (cmr_config.s.lmac_type != 5 && + CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_GMP_PCS_MRX_STATUS(index, xi.interface), + cvmx_bgxx_gmp_pcs_mrx_status_t, an_cpt, ==, 1, 10000)) { + debug("SGMII%d: Port %d link timeout\n", interface, index); + return -1; + } + + return 0; +} + +/** + * @INTERNAL + * Configure an SGMII link to the specified speed after the SERDES + * link is up. + * + * @param xiface Interface to init + * @param index Index of prot on the interface + * @param link_info Link state to configure + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_bgx_sgmii_hardware_init_link_speed( + int xiface, int index, cvmx_helper_link_info_t link_info) +{ + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_bgxx_gmp_pcs_miscx_ctl_t gmp_miscx_ctl; + cvmx_bgxx_gmp_gmi_prtx_cfg_t gmp_prtx_cfg; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + + if (!cvmx_helper_is_port_valid(xiface, index)) + return 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + /* Disable GMX before we make any changes. */ + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.data_pkt_tx_en = 0; + cmr_config.s.data_pkt_rx_en = 0; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + + /* Wait for GMX to be idle */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_GMP_GMI_PRTX_CFG(index, xi.interface), + cvmx_bgxx_gmp_gmi_prtx_cfg_t, rx_idle, ==, 1, 10000) || + CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_GMP_GMI_PRTX_CFG(index, xi.interface), + cvmx_bgxx_gmp_gmi_prtx_cfg_t, tx_idle, ==, 1, 10000)) { + debug("SGMII%d:%d: Timeout waiting for port %d to be idle\n", + node, xi.interface, index); + return -1; + } + + /* Read GMX CFG again to make sure the disable completed */ + gmp_prtx_cfg.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_GMI_PRTX_CFG(index, xi.interface)); + + /* + * Get the misc control for PCS. We will need to set the + * duplication amount. + */ + gmp_miscx_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface)); + + /* + * Use GMXENO to force the link down if the status we get says + * it should be down. + */ + gmp_miscx_ctl.s.gmxeno = !link_info.s.link_up; + + /* Only change the duplex setting if the link is up */ + if (link_info.s.link_up) + gmp_prtx_cfg.s.duplex = link_info.s.full_duplex; + + /* Do speed based setting for GMX */ + switch (link_info.s.speed) { + case 10: + gmp_prtx_cfg.s.speed = 0; + gmp_prtx_cfg.s.speed_msb = 1; + gmp_prtx_cfg.s.slottime = 0; + /* Setting from GMX-603 */ + gmp_miscx_ctl.s.samp_pt = 25; + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_SLOT(index, xi.interface), + 64); + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_BURST(index, xi.interface), + 0); + break; + case 100: + gmp_prtx_cfg.s.speed = 0; + gmp_prtx_cfg.s.speed_msb = 0; + gmp_prtx_cfg.s.slottime = 0; + gmp_miscx_ctl.s.samp_pt = 0x5; + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_SLOT(index, xi.interface), + 64); + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_BURST(index, xi.interface), + 0); + break; + case 1000: + gmp_prtx_cfg.s.speed = 1; + gmp_prtx_cfg.s.speed_msb = 0; + gmp_prtx_cfg.s.slottime = 1; + gmp_miscx_ctl.s.samp_pt = 1; + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_SLOT(index, xi.interface), + 512); + if (gmp_prtx_cfg.s.duplex) + /* full duplex */ + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_BURST(index, + xi.interface), + 0); + else + /* half duplex */ + csr_wr_node(node, + CVMX_BGXX_GMP_GMI_TXX_BURST(index, + xi.interface), + 8192); + break; + default: + break; + } + + /* Write the new misc control for PCS */ + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface), + gmp_miscx_ctl.u64); + + /* Write the new GMX settings with the port still disabled */ + csr_wr_node(node, CVMX_BGXX_GMP_GMI_PRTX_CFG(index, xi.interface), + gmp_prtx_cfg.u64); + + /* Read GMX CFG again to make sure the config completed */ + csr_rd_node(node, CVMX_BGXX_GMP_GMI_PRTX_CFG(index, xi.interface)); + + /* Enable back BGX. */ + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + if (debug) + debug("%s: Enabling tx and rx packets on %d:%d\n", __func__, + xi.interface, index); + cmr_config.s.data_pkt_tx_en = 1; + cmr_config.s.data_pkt_rx_en = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + + return 0; +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). This is used by + * interfaces using the bgx mac. + * + * @param xipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_bgx_sgmii_link_get(int xipd_port) +{ + cvmx_helper_link_info_t result; + cvmx_bgxx_gmp_pcs_mrx_control_t gmp_control; + cvmx_bgxx_gmp_pcs_miscx_ctl_t gmp_misc_ctl; + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int node = xi.node; + int index = cvmx_helper_get_interface_index_num(xp.port); + + result.u64 = 0; + + if (!cvmx_helper_is_port_valid(xiface, index)) + return result; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + gmp_control.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface)); + if (gmp_control.s.loopbck1) { + int qlm = cvmx_qlm_lmac(xiface, index); + int speed; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + speed = cvmx_qlm_get_gbaud_mhz_node(node, qlm); + else + speed = cvmx_qlm_get_gbaud_mhz(qlm); + /* Force 1Gbps full duplex link for internal loopback */ + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = speed * 8 / 10; + return result; + } + + gmp_misc_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface)); + if (gmp_misc_ctl.s.mac_phy || + cvmx_helper_get_port_force_link_up(xiface, index)) { + int qlm = cvmx_qlm_lmac(xiface, index); + int speed; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + speed = cvmx_qlm_get_gbaud_mhz_node(node, qlm); + else + speed = cvmx_qlm_get_gbaud_mhz(qlm); + /* PHY Mode */ + /* Note that this also works for 1000base-X mode */ + + result.s.speed = speed * 8 / 10; + result.s.full_duplex = 1; + result.s.link_up = 1; + return result; + } + + /* MAC Mode */ + return __cvmx_helper_board_link_get(xipd_port); +} + +/** + * This sequence brings down the link for the XCV RGMII interface + * + * @param interface Interface (BGX) number. Port index is always 0 + */ +static void __cvmx_helper_bgx_rgmii_link_set_down(int interface) +{ + union cvmx_xcv_reset xcv_reset; + union cvmx_bgxx_cmrx_config cmr_config; + union cvmx_bgxx_gmp_pcs_mrx_control mr_control; + union cvmx_bgxx_cmrx_rx_fifo_len rx_fifo_len; + union cvmx_bgxx_cmrx_tx_fifo_len tx_fifo_len; + + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.rx_pkt_rst_n = 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + csr_rd(CVMX_XCV_RESET); + mdelay(10); /* Wait for 1 MTU */ + + cmr_config.u64 = csr_rd(CVMX_BGXX_CMRX_CONFIG(0, interface)); + cmr_config.s.data_pkt_rx_en = 0; + csr_wr(CVMX_BGXX_CMRX_CONFIG(0, interface), cmr_config.u64); + + /* Wait for RX and TX to be idle */ + do { + rx_fifo_len.u64 = + csr_rd(CVMX_BGXX_CMRX_RX_FIFO_LEN(0, interface)); + tx_fifo_len.u64 = + csr_rd(CVMX_BGXX_CMRX_TX_FIFO_LEN(0, interface)); + } while (rx_fifo_len.s.fifo_len > 0 && tx_fifo_len.s.lmac_idle != 1); + + cmr_config.u64 = csr_rd(CVMX_BGXX_CMRX_CONFIG(0, interface)); + cmr_config.s.data_pkt_tx_en = 0; + csr_wr(CVMX_BGXX_CMRX_CONFIG(0, interface), cmr_config.u64); + + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.tx_pkt_rst_n = 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + mr_control.u64 = csr_rd(CVMX_BGXX_GMP_PCS_MRX_CONTROL(0, interface)); + mr_control.s.pwr_dn = 1; + csr_wr(CVMX_BGXX_GMP_PCS_MRX_CONTROL(0, interface), mr_control.u64); +} + +/** + * Sets a BGS SGMII link down. + * + * @param node Octeon node number + * @param iface BGX interface number + * @param index BGX port index + */ +static void __cvmx_helper_bgx_sgmii_link_set_down(int node, int iface, + int index) +{ + union cvmx_bgxx_gmp_pcs_miscx_ctl gmp_misc_ctl; + union cvmx_bgxx_gmp_pcs_mrx_control gmp_control; + union cvmx_bgxx_cmrx_config cmr_config; + + cmr_config.u64 = csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, iface)); + cmr_config.s.data_pkt_tx_en = 0; + cmr_config.s.data_pkt_rx_en = 0; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, iface), cmr_config.u64); + + gmp_misc_ctl.u64 = + csr_rd_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, iface)); + + /* Disable autonegotiation only when in MAC mode. */ + if (gmp_misc_ctl.s.mac_phy == 0) { + gmp_control.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, iface)); + gmp_control.s.an_en = 0; + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, iface), + gmp_control.u64); + } + + /* Use GMXENO to force the link down. It will get reenabled later... */ + gmp_misc_ctl.s.gmxeno = 1; + csr_wr_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, iface), + gmp_misc_ctl.u64); + csr_rd_node(node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, iface)); +} + +/** + * @INTERNAL + * Configure an IPD/PKO port for the specified link state. This + * function does not influence auto negotiation at the PHY level. + * The passed link state must always match the link state returned + * by cvmx_helper_link_get(). It is normally best to use + * cvmx_helper_link_autoconf() instead. This is used by interfaces + * using the bgx mac. + * + * @param xipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_bgx_sgmii_link_set(int xipd_port, + cvmx_helper_link_info_t link_info) +{ + cvmx_bgxx_cmrx_config_t cmr_config; + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int node = xi.node; + int index = cvmx_helper_get_interface_index_num(xp.port); + const int iface = xi.interface; + int rc = 0; + + if (!cvmx_helper_is_port_valid(xiface, index)) + return 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + cmr_config.u64 = csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, iface)); + if (link_info.s.link_up) { + cmr_config.s.enable = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, iface), + cmr_config.u64); + /* Apply workaround for errata BGX-22429 */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X) && index) { + cvmx_bgxx_cmrx_config_t cmr0; + + cmr0.u64 = csr_rd_node(node, + CVMX_BGXX_CMRX_CONFIG(0, iface)); + cmr0.s.enable = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(0, iface), + cmr0.u64); + } + __cvmx_helper_bgx_sgmii_hardware_init_link(xiface, index); + } else if (cvmx_helper_bgx_is_rgmii(xi.interface, index)) { + if (debug) + debug("%s: Bringing down XCV RGMII interface %d\n", + __func__, xi.interface); + __cvmx_helper_bgx_rgmii_link_set_down(xi.interface); + } else { /* Link is down, not RGMII */ + __cvmx_helper_bgx_sgmii_link_set_down(node, iface, index); + return 0; + } + rc = __cvmx_helper_bgx_sgmii_hardware_init_link_speed(xiface, index, + link_info); + if (cvmx_helper_bgx_is_rgmii(xiface, index)) + rc = __cvmx_helper_bgx_rgmii_speed(link_info); + + return rc; +} + +/** + * @INTERNAL + * Bringup XAUI interface. After this call packet I/O should be + * fully functional. + * + * @param index port on interface to bring up + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_bgx_xaui_init(int index, int xiface) +{ + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_bgxx_spux_br_pmd_control_t pmd_control; + cvmx_bgxx_spux_misc_control_t spu_misc_control; + cvmx_bgxx_spux_control1_t spu_control1; + cvmx_bgxx_spux_an_control_t spu_an_control; + cvmx_bgxx_spux_an_adv_t spu_an_adv; + cvmx_bgxx_spux_fec_control_t spu_fec_control; + cvmx_bgxx_spu_dbg_control_t spu_dbg_control; + cvmx_bgxx_smux_tx_append_t smu_tx_append; + cvmx_bgxx_smux_tx_ctl_t smu_tx_ctl; + cvmx_helper_interface_mode_t mode; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + int node = xi.node; + int use_auto_neg = 0; + int kr_mode = 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + + if (mode == CVMX_HELPER_INTERFACE_MODE_10G_KR || + mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4) { + kr_mode = 1; + if (cvmx_helper_bgx_override_autoneg) + use_auto_neg = + cvmx_helper_bgx_override_autoneg(xiface, index); + else + use_auto_neg = cvmx_helper_get_port_autonegotiation( + xiface, index); + } + + /* NOTE: This code was moved first, out of order compared to the HRM + * because the RESET causes all SPU registers to loose their value + */ + /* 4. Next, bring up the SMU/SPU and the BGX reconciliation layer + * logic: + */ + /* 4a. Take SMU/SPU through a reset sequence. Write + * BGX(0..5)_SPU(0..3)_CONTROL1[RESET] = 1. Read + * BGX(0..5)_SPU(0..3)_CONTROL1[RESET] until it changes value to 0. Keep + * BGX(0..5)_SPU(0..3)_MISC_CONTROL[RX_PACKET_DIS] = 1 to disable + * reception. + */ + spu_control1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + spu_control1.s.reset = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + spu_control1.u64); + + /* 1. Wait for PCS to come out of reset */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + cvmx_bgxx_spux_control1_t, reset, ==, 0, 10000)) { + debug("BGX%d:%d: SPU stuck in reset\n", node, interface); + return -1; + } + + /* 2. Write BGX(0..5)_CMR(0..3)_CONFIG[ENABLE] to 0, + * BGX(0..5)_SPU(0..3)_CONTROL1[LO_PWR] = 1 and + * BGX(0..5)_SPU(0..3)_MISC_CONTROL[RX_PACKET_DIS] = 1. + */ + spu_control1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + spu_control1.s.lo_pwr = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + spu_control1.u64); + + spu_misc_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface)); + spu_misc_control.s.rx_packet_dis = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface), + spu_misc_control.u64); + + /* 3. At this point, it may be appropriate to disable all BGX and + * SMU/SPU interrupts, as a number of them will occur during bring-up + * of the Link. + * - zero BGX(0..5)_SMU(0..3)_RX_INT + * - zero BGX(0..5)_SMU(0..3)_TX_INT + * - zero BGX(0..5)_SPU(0..3)_INT + */ + csr_wr_node(node, CVMX_BGXX_SMUX_RX_INT(index, xi.interface), + csr_rd_node(node, + CVMX_BGXX_SMUX_RX_INT(index, xi.interface))); + csr_wr_node(node, CVMX_BGXX_SMUX_TX_INT(index, xi.interface), + csr_rd_node(node, + CVMX_BGXX_SMUX_TX_INT(index, xi.interface))); + csr_wr_node(node, CVMX_BGXX_SPUX_INT(index, xi.interface), + csr_rd_node(node, CVMX_BGXX_SPUX_INT(index, xi.interface))); + + /* 4. Configure the BGX LMAC. */ + /* 4a. Configure the LMAC type (40GBASE-R/10GBASE-R/RXAUI/XAUI) and + * SerDes selection in the BGX(0..5)_CMR(0..3)_CONFIG register, but keep + * the ENABLE, DATA_PKT_TX_EN and DATA_PKT_RX_EN bits clear. + */ + /* Already done in bgx_setup_one_time */ + + /* 4b. Write BGX(0..5)_SPU(0..3)_CONTROL1[LO_PWR] = 1 and + * BGX(0..5)_SPU(0..3)_MISC_CONTROL[RX_PACKET_DIS] = 1. + */ + /* 4b. Initialize the selected SerDes lane(s) in the QLM. See Section + * 28.1.2.2 in the GSER chapter. + */ + /* Already done in QLM setup */ + + /* 4c. For 10GBASE-KR or 40GBASE-KR, enable link training by writing + * BGX(0..5)_SPU(0..3)_BR_PMD_CONTROL[TRAIN_EN] = 1. + */ + + if (kr_mode && !OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_PMD_LP_CUP(index, interface), 0); + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_PMD_LD_CUP(index, interface), 0); + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_PMD_LD_REP(index, interface), 0); + pmd_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, interface)); + pmd_control.s.train_en = 1; + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, interface), + pmd_control.u64); + } + + /* 4d. Program all other relevant BGX configuration while + * BGX(0..5)_CMR(0..3)_CONFIG[ENABLE] = 0. This includes all things + * described in this chapter. + */ + /* Always add FCS to PAUSE frames */ + smu_tx_append.u64 = csr_rd_node( + node, CVMX_BGXX_SMUX_TX_APPEND(index, xi.interface)); + smu_tx_append.s.fcs_c = 1; + csr_wr_node(node, CVMX_BGXX_SMUX_TX_APPEND(index, xi.interface), + smu_tx_append.u64); + + /* 4e. If Forward Error Correction is desired for 10GBASE-R or + * 40GBASE-R, enable it by writing + * BGX(0..5)_SPU(0..3)_FEC_CONTROL[FEC_EN] = 1. + */ + /* FEC is optional for 10GBASE-KR, 40GBASE-KR4, and XLAUI. We're going + * to disable it by default + */ + spu_fec_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_FEC_CONTROL(index, xi.interface)); + if (cvmx_helper_bgx_override_fec) + spu_fec_control.s.fec_en = + cvmx_helper_bgx_override_fec(xiface, index); + else + spu_fec_control.s.fec_en = + cvmx_helper_get_port_fec(xiface, index); + csr_wr_node(node, CVMX_BGXX_SPUX_FEC_CONTROL(index, xi.interface), + spu_fec_control.u64); + + /* 4f. If Auto-Negotiation is desired, configure and enable + * Auto-Negotiation as described in Section 33.6.2. + */ + spu_an_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_AN_CONTROL(index, xi.interface)); + /* Disable extended next pages */ + spu_an_control.s.xnp_en = 0; + spu_an_control.s.an_en = use_auto_neg; + csr_wr_node(node, CVMX_BGXX_SPUX_AN_CONTROL(index, xi.interface), + spu_an_control.u64); + + spu_fec_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_FEC_CONTROL(index, xi.interface)); + spu_an_adv.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_AN_ADV(index, xi.interface)); + spu_an_adv.s.fec_req = spu_fec_control.s.fec_en; + spu_an_adv.s.fec_able = 1; + spu_an_adv.s.a100g_cr10 = 0; + spu_an_adv.s.a40g_cr4 = 0; + spu_an_adv.s.a40g_kr4 = (mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4); + spu_an_adv.s.a10g_kr = (mode == CVMX_HELPER_INTERFACE_MODE_10G_KR); + spu_an_adv.s.a10g_kx4 = 0; + spu_an_adv.s.a1g_kx = 0; + spu_an_adv.s.xnp_able = 0; + spu_an_adv.s.rf = 0; + csr_wr_node(node, CVMX_BGXX_SPUX_AN_ADV(index, xi.interface), + spu_an_adv.u64); + + /* 3. Set BGX(0..5)_SPU_DBG_CONTROL[AN_ARB_LINK_CHK_EN] = 1. */ + spu_dbg_control.u64 = + csr_rd_node(node, CVMX_BGXX_SPU_DBG_CONTROL(xi.interface)); + spu_dbg_control.s.an_nonce_match_dis = 1; /* Needed for loopback */ + spu_dbg_control.s.an_arb_link_chk_en |= kr_mode; + csr_wr_node(node, CVMX_BGXX_SPU_DBG_CONTROL(xi.interface), + spu_dbg_control.u64); + + /* 4. Execute the link bring-up sequence in Section 33.6.3. */ + + /* 5. If the auto-negotiation protocol is successful, + * BGX(0..5)_SPU(0..3)_AN_ADV[AN_COMPLETE] is set along with + * BGX(0..5)_SPU(0..3)_INT[AN_COMPLETE] when the link is up. + */ + + /* 3h. Set BGX(0..5)_CMR(0..3)_CONFIG[ENABLE] = 1 and + * BGX(0..5)_SPU(0..3)_CONTROL1[LO_PWR] = 0 to enable the LMAC. + */ + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.enable = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + /* Apply workaround for errata BGX-22429 */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X) && index) { + cvmx_bgxx_cmrx_config_t cmr0; + + cmr0.u64 = csr_rd_node(node, + CVMX_BGXX_CMRX_CONFIG(0, xi.interface)); + cmr0.s.enable = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(0, xi.interface), + cmr0.u64); + } + + spu_control1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + spu_control1.s.lo_pwr = 0; + csr_wr_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + spu_control1.u64); + + /* 4g. Set the polarity and lane swapping of the QLM SerDes. Refer to + * Section 33.4.1, BGX(0..5)_SPU(0..3)_MISC_CONTROL[XOR_TXPLRT,XOR_RXPLRT] + * and BGX(0..5)_SPU(0..3)_MISC_CONTROL[TXPLRT,RXPLRT]. + */ + + /* 4c. Write BGX(0..5)_SPU(0..3)_CONTROL1[LO_PWR] = 0. */ + spu_control1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + spu_control1.s.lo_pwr = 0; + csr_wr_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + spu_control1.u64); + + /* 4d. Select Deficit Idle Count mode and unidirectional enable/disable + * via BGX(0..5)_SMU(0..3)_TX_CTL[DIC_EN,UNI_EN]. + */ + smu_tx_ctl.u64 = + csr_rd_node(node, CVMX_BGXX_SMUX_TX_CTL(index, xi.interface)); + smu_tx_ctl.s.dic_en = 1; + smu_tx_ctl.s.uni_en = 0; + csr_wr_node(node, CVMX_BGXX_SMUX_TX_CTL(index, xi.interface), + smu_tx_ctl.u64); + + { + /* Calculate the number of s-clk cycles per usec. */ + const u64 clock_mhz = 1200; /* todo: fixme */ + cvmx_bgxx_spu_dbg_control_t dbg_control; + + dbg_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPU_DBG_CONTROL(xi.interface)); + dbg_control.s.us_clk_period = clock_mhz - 1; + csr_wr_node(node, CVMX_BGXX_SPU_DBG_CONTROL(xi.interface), + dbg_control.u64); + } + /* The PHY often takes at least 100ms to stabilize */ + __cvmx_helper_bgx_interface_enable_delay(mode); + return 0; +} + +static void __cvmx_bgx_start_training(int node, int unit, int index) +{ + cvmx_bgxx_spux_int_t spu_int; + cvmx_bgxx_spux_br_pmd_control_t pmd_control; + cvmx_bgxx_spux_an_control_t an_control; + + /* Clear the training interrupts (W1C) */ + spu_int.u64 = 0; + spu_int.s.training_failure = 1; + spu_int.s.training_done = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_INT(index, unit), spu_int.u64); + + /* These registers aren't cleared when training is restarted. Manually + * clear them as per Errata BGX-20968. + */ + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LP_CUP(index, unit), 0); + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LD_CUP(index, unit), 0); + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LD_REP(index, unit), 0); + + /* Disable autonegotiation */ + an_control.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_AN_CONTROL(index, unit)); + an_control.s.an_en = 0; + csr_wr_node(node, CVMX_BGXX_SPUX_AN_CONTROL(index, unit), + an_control.u64); + udelay(1); + + /* Restart training */ + pmd_control.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit)); + pmd_control.s.train_en = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit), + pmd_control.u64); + + udelay(1); + pmd_control.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit)); + pmd_control.s.train_restart = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit), + pmd_control.u64); +} + +static void __cvmx_bgx_restart_training(int node, int unit, int index) +{ + cvmx_bgxx_spux_int_t spu_int; + cvmx_bgxx_spux_br_pmd_control_t pmd_control; + + /* Clear the training interrupts (W1C) */ + spu_int.u64 = 0; + spu_int.s.training_failure = 1; + spu_int.s.training_done = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_INT(index, unit), spu_int.u64); + + udelay(1700); /* Wait 1.7 msec */ + + /* These registers aren't cleared when training is restarted. Manually + * clear them as per Errata BGX-20968. + */ + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LP_CUP(index, unit), 0); + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LD_CUP(index, unit), 0); + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_LD_REP(index, unit), 0); + + /* Restart training */ + pmd_control.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit)); + pmd_control.s.train_restart = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, unit), + pmd_control.u64); +} + +/* + * @INTERNAL + * Wrapper function to configure the BGX, does not enable. + * + * @param xipd_port IPD/PKO port to configure. + * @param phy_pres If set, enable disparity, only applies to RXAUI interface + * + * @return Zero on success, negative on failure. + */ +int __cvmx_helper_bgx_port_init(int xipd_port, int phy_pres) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int index = cvmx_helper_get_interface_index_num(xp.port); + cvmx_helper_interface_mode_t mode; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + + __cvmx_bgx_common_init_pknd(xiface, index); + + if (mode == CVMX_HELPER_INTERFACE_MODE_SGMII || + mode == CVMX_HELPER_INTERFACE_MODE_RGMII) { + cvmx_bgxx_gmp_gmi_txx_thresh_t gmi_tx_thresh; + cvmx_bgxx_gmp_gmi_txx_append_t gmp_txx_append; + cvmx_bgxx_gmp_gmi_txx_sgmii_ctl_t gmp_sgmii_ctl; + + /* Set TX Threshold */ + gmi_tx_thresh.u64 = 0; + gmi_tx_thresh.s.cnt = 0x20; + csr_wr_node(xi.node, + CVMX_BGXX_GMP_GMI_TXX_THRESH(index, xi.interface), + gmi_tx_thresh.u64); + __cvmx_helper_bgx_sgmii_hardware_init_one_time(xiface, index); + gmp_txx_append.u64 = csr_rd_node( + xi.node, + CVMX_BGXX_GMP_GMI_TXX_APPEND(index, xi.interface)); + gmp_sgmii_ctl.u64 = csr_rd_node( + xi.node, + CVMX_BGXX_GMP_GMI_TXX_SGMII_CTL(index, xi.interface)); + gmp_sgmii_ctl.s.align = gmp_txx_append.s.preamble ? 0 : 1; + csr_wr_node(xi.node, + CVMX_BGXX_GMP_GMI_TXX_SGMII_CTL(index, + xi.interface), + gmp_sgmii_ctl.u64); + if (mode == CVMX_HELPER_INTERFACE_MODE_RGMII) { + /* Disable XCV interface when initialized */ + union cvmx_xcv_reset xcv_reset; + + if (debug) + debug("%s: Disabling RGMII XCV interface\n", + __func__); + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.enable = 0; + xcv_reset.s.tx_pkt_rst_n = 0; + xcv_reset.s.rx_pkt_rst_n = 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); + } + } else { + int res, cred; + cvmx_bgxx_smux_tx_thresh_t smu_tx_thresh; + + res = __cvmx_helper_bgx_xaui_init(index, xiface); + if (res == -1) { +#ifdef DEBUG_BGX + debug("Failed to enable XAUI for %d:BGX(%d,%d)\n", + xi.node, xi.interface, index); +#endif + return res; + } + /* See BVX_SMU_TX_THRESH register descriptin */ + cred = __cvmx_helper_bgx_fifo_size(xiface, index) >> 4; + smu_tx_thresh.u64 = 0; + smu_tx_thresh.s.cnt = cred - 10; + csr_wr_node(xi.node, + CVMX_BGXX_SMUX_TX_THRESH(index, xi.interface), + smu_tx_thresh.u64); + if (debug) + debug("%s: BGX%d:%d TX-thresh=%d\n", __func__, + xi.interface, index, + (unsigned int)smu_tx_thresh.s.cnt); + + /* Set disparity for RXAUI interface as described in the + * Marvell RXAUI Interface specification. + */ + if (mode == CVMX_HELPER_INTERFACE_MODE_RXAUI && phy_pres) { + cvmx_bgxx_spux_misc_control_t misc_control; + + misc_control.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SPUX_MISC_CONTROL( + index, xi.interface)); + misc_control.s.intlv_rdisp = 1; + csr_wr_node(xi.node, + CVMX_BGXX_SPUX_MISC_CONTROL(index, + xi.interface), + misc_control.u64); + } + } + return 0; +} + +/** + * @INTERNAL + * Configure a port for internal and/or external loopback. Internal loopback + * causes packets sent by the port to be received by Octeon. External loopback + * causes packets received from the wire to sent out again. This is used by + * interfaces using the bgx mac. + * + * @param xipd_port IPD/PKO port to loopback. + * @param enable_internal + * Non zero if you want internal loopback + * @param enable_external + * Non zero if you want external loopback + * + * @return Zero on success, negative on failure. + */ +int __cvmx_helper_bgx_sgmii_configure_loopback(int xipd_port, + int enable_internal, + int enable_external) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int node = xi.node; + int index = cvmx_helper_get_interface_index_num(xp.port); + cvmx_bgxx_gmp_pcs_mrx_control_t gmp_mrx_control; + cvmx_bgxx_gmp_pcs_miscx_ctl_t gmp_misc_ctl; + + if (!cvmx_helper_is_port_valid(xiface, index)) + return 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + if (cvmx_helper_bgx_is_rgmii(xi.interface, index)) { + cvmx_xcv_ctl_t xcv_ctl; + cvmx_helper_link_info_t link_info; + + xcv_ctl.u64 = csr_rd(CVMX_XCV_CTL); + xcv_ctl.s.lpbk_int = enable_internal; + xcv_ctl.s.lpbk_ext = enable_external; + csr_wr(CVMX_XCV_CTL, xcv_ctl.u64); + + /* Initialize link and speed */ + __cvmx_helper_bgx_sgmii_hardware_init_link(xiface, index); + link_info = __cvmx_helper_bgx_sgmii_link_get(xipd_port); + __cvmx_helper_bgx_sgmii_hardware_init_link_speed(xiface, index, + link_info); + __cvmx_helper_bgx_rgmii_speed(link_info); + } else { + gmp_mrx_control.u64 = csr_rd_node( + node, + CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface)); + gmp_mrx_control.s.loopbck1 = enable_internal; + csr_wr_node(node, + CVMX_BGXX_GMP_PCS_MRX_CONTROL(index, xi.interface), + gmp_mrx_control.u64); + + gmp_misc_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface)); + gmp_misc_ctl.s.loopbck2 = enable_external; + csr_wr_node(node, + CVMX_BGXX_GMP_PCS_MISCX_CTL(index, xi.interface), + gmp_misc_ctl.u64); + __cvmx_helper_bgx_sgmii_hardware_init_link(xiface, index); + } + + return 0; +} + +static int __cvmx_helper_bgx_xaui_link_init(int index, int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + cvmx_bgxx_spux_status1_t spu_status1; + cvmx_bgxx_spux_status2_t spu_status2; + cvmx_bgxx_spux_br_status2_t br_status2; + cvmx_bgxx_spux_int_t spu_int; + cvmx_bgxx_spux_misc_control_t spu_misc_control; + cvmx_bgxx_spux_an_control_t spu_an_control; + cvmx_bgxx_spux_an_status_t spu_an_status; + cvmx_bgxx_spux_br_pmd_control_t pmd_control; + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_helper_interface_mode_t mode; + int use_training = 0; + int rgmii_first = 0; + int qlm = cvmx_qlm_lmac(xiface, index); + int use_ber = 0; + u64 err_blks; + u64 ber_cnt; + u64 error_debounce; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + rgmii_first = cvmx_helper_bgx_is_rgmii(xi.interface, index); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_10G_KR || + mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4) + use_training = 1; + + if ((mode == CVMX_HELPER_INTERFACE_MODE_XFI || + mode == CVMX_HELPER_INTERFACE_MODE_XLAUI || + mode == CVMX_HELPER_INTERFACE_MODE_10G_KR || + mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4)) + use_ber = 1; + + /* Disable packet reception, CMR as well as SPU block */ + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.data_pkt_tx_en = 0; + cmr_config.s.data_pkt_rx_en = 0; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + spu_misc_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface)); + spu_misc_control.s.rx_packet_dis = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface), + spu_misc_control.u64); + + spu_an_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_AN_CONTROL(index, xi.interface)); + if (spu_an_control.s.an_en) { + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + cvmx_bgxx_spux_int_t spu_int; + + spu_int.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_INT(index, xi.interface)); + if (!spu_int.s.an_link_good) { + static u64 restart_auto_neg[2][6][4] = { + [0 ... 1][0 ... 5] = { [0 ... 3] = 0 } + }; + u64 now = get_timer(0); + u64 next_restart = + restart_auto_neg[node][xi.interface] + [index] + + 2000; + + if (now >= next_restart) + return -1; + + restart_auto_neg[node][xi.interface][index] = + now; + + /* Clear the auto negotiation (W1C) */ + spu_int.u64 = 0; + spu_int.s.an_complete = 1; + spu_int.s.an_link_good = 1; + spu_int.s.an_page_rx = 1; + csr_wr_node(node, + CVMX_BGXX_SPUX_INT(index, + xi.interface), + spu_int.u64); + /* Restart auto negotiation */ + spu_an_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_AN_CONTROL( + index, xi.interface)); + spu_an_control.s.an_restart = 1; + csr_wr_node(node, + CVMX_BGXX_SPUX_AN_CONTROL( + index, xi.interface), + spu_an_control.u64); + return -1; + } + } else { + spu_an_status.u64 = csr_rd_node( + node, + CVMX_BGXX_SPUX_AN_STATUS(index, xi.interface)); + if (!spu_an_status.s.an_complete) { + static u64 restart_auto_neg[2][6][4] = { + [0 ... 1][0 ... 5] = { [0 ... 3] = 0 } + }; + u64 now = get_timer(0); + u64 next_restart = + restart_auto_neg[node][xi.interface] + [index] + + 2000; + if (now >= next_restart) { +#ifdef DEBUG_BGX + debug("WARNING: BGX%d:%d: Waiting for autoneg to complete\n", + xi.interface, index); +#endif + return -1; + } + + restart_auto_neg[node][xi.interface][index] = + now; + /* Restart auto negotiation */ + spu_an_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_AN_CONTROL( + index, xi.interface)); + spu_an_control.s.an_restart = 1; + csr_wr_node(node, + CVMX_BGXX_SPUX_AN_CONTROL( + index, xi.interface), + spu_an_control.u64); + return -1; + } + } + } + + if (use_training) { + spu_int.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_INT(index, xi.interface)); + pmd_control.u64 = csr_rd_node( + node, + CVMX_BGXX_SPUX_BR_PMD_CONTROL(index, xi.interface)); + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X) && + pmd_control.s.train_en == 0) { + __cvmx_bgx_start_training(node, xi.interface, index); + return -1; + } + cvmx_qlm_gser_errata_27882(node, qlm, index); + spu_int.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_INT(index, xi.interface)); + + if (spu_int.s.training_failure && + !OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + __cvmx_bgx_restart_training(node, xi.interface, index); + return -1; + } + if (!spu_int.s.training_done) { + debug("Waiting for link training\n"); + return -1; + } + } + + /* (GSER-21957) GSER RX Equalization may make >= 5gbaud non-KR + * channel with DXAUI, RXAUI, XFI and XLAUI, we need to perform + * RX equalization when the link is receiving data the first time + */ + if (use_training == 0) { + int lane = index; + cvmx_bgxx_spux_control1_t control1; + + cmr_config.u64 = csr_rd_node( + node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + control1.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + if (control1.s.loopbck) { + /* Skip RX equalization when in loopback */ + } else if (mode == CVMX_HELPER_INTERFACE_MODE_XLAUI || + mode == CVMX_HELPER_INTERFACE_MODE_XAUI) { + lane = -1; + if (__cvmx_qlm_rx_equalization(node, qlm, lane)) { +#ifdef DEBUG_BGX + debug("%d:%d:%d: Waiting for RX Equalization on QLM%d\n", + node, xi.interface, index, qlm); +#endif + return -1; + } + /* If BGX2 uses both dlms, then configure other dlm also. */ + if (OCTEON_IS_MODEL(OCTEON_CN73XX) && + xi.interface == 2) { + if (__cvmx_qlm_rx_equalization(node, 6, lane)) { +#ifdef DEBUG_BGX + debug("%d:%d:%d: Waiting for RX Equalization on QLM%d\n", + node, xi.interface, index, qlm); +#endif + return -1; + } + } + /* RXAUI */ + } else if (mode == CVMX_HELPER_INTERFACE_MODE_RXAUI) { + lane = index * 2; + if (OCTEON_IS_MODEL(OCTEON_CN73XX) && index >= 2 && + xi.interface == 2) { + lane = 0; + } + if (rgmii_first) + lane--; + if (__cvmx_qlm_rx_equalization(node, qlm, lane) || + __cvmx_qlm_rx_equalization(node, qlm, lane + 1)) { +#ifdef DEBUG_BGX + debug("%d:%d:%d: Waiting for RX Equalization on QLM%d\n", + node, xi.interface, index, qlm); +#endif + return -1; + } + /* XFI */ + } else if (cmr_config.s.lmac_type != 5) { + if (rgmii_first) + lane--; + if (OCTEON_IS_MODEL(OCTEON_CN73XX) && index >= 2 && + xi.interface == 2) { + lane = index - 2; + } else if (OCTEON_IS_MODEL(OCTEON_CNF75XX) && + index >= 2) { + lane = index - 2; + } + if (__cvmx_qlm_rx_equalization(node, qlm, lane)) { +#ifdef DEBUG_BGX + debug("%d:%d:%d: Waiting for RX Equalization on QLM%d\n", + node, xi.interface, index, qlm); +#endif + return -1; + } + } + } + + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + cvmx_bgxx_spux_control1_t, reset, ==, 0, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: PCS in reset", node, xi.interface, + index); +#endif + return -1; + } + + if (use_ber) { + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, + CVMX_BGXX_SPUX_BR_STATUS1(index, xi.interface), + cvmx_bgxx_spux_br_status1_t, blk_lock, ==, 1, + 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: BASE-R PCS block not locked\n", + node, xi.interface, index); + + if (mode == CVMX_HELPER_INTERFACE_MODE_XLAUI || + mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4) { + cvmx_bgxx_spux_br_algn_status_t bstatus; + + bstatus.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_BR_ALGN_STATUS( + index, xi.interface)); + debug("ERROR: %d:BGX%d:%d: LANE BLOCK_LOCK:%x LANE MARKER_LOCK:%x\n", + node, xi.interface, index, + bstatus.s.block_lock, + bstatus.s.marker_lock); + } +#endif + return -1; + } + } else { + /* (5) Check to make sure that the link appears up and stable. + */ + /* Wait for PCS to be aligned */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SPUX_BX_STATUS(index, xi.interface), + cvmx_bgxx_spux_bx_status_t, alignd, ==, 1, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: PCS not aligned\n", node, + xi.interface, index); +#endif + return -1; + } + } + + if (use_ber) { + /* Set the BGXX_SPUX_BR_STATUS2.latched_lock bit (latching low). + * This will be checked prior to enabling packet tx and rx, + * ensuring block lock is sustained throughout the BGX link-up + * procedure + */ + br_status2.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface)); + br_status2.s.latched_lock = 1; + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface), + br_status2.u64); + } + + /* Clear rcvflt bit (latching high) and read it back */ + spu_status2.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_STATUS2(index, xi.interface)); + spu_status2.s.rcvflt = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_STATUS2(index, xi.interface), + spu_status2.u64); + + spu_status2.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_STATUS2(index, xi.interface)); + if (spu_status2.s.rcvflt) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: Receive fault, need to retry\n", + node, xi.interface, index); +#endif + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X) && use_training) + __cvmx_bgx_restart_training(node, xi.interface, index); + /* debug("training restarting\n"); */ + return -1; + } + + /* Wait for MAC RX to be ready */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SMUX_RX_CTL(index, xi.interface), + cvmx_bgxx_smux_rx_ctl_t, status, ==, 0, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: RX not ready\n", node, xi.interface, + index); +#endif + return -1; + } + + /* Wait for BGX RX to be idle */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SMUX_CTRL(index, xi.interface), + cvmx_bgxx_smux_ctrl_t, rx_idle, ==, 1, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: RX not idle\n", node, xi.interface, + index); +#endif + return -1; + } + + /* Wait for GMX TX to be idle */ + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SMUX_CTRL(index, xi.interface), + cvmx_bgxx_smux_ctrl_t, tx_idle, ==, 1, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: TX not idle\n", node, xi.interface, + index); +#endif + return -1; + } + + /* rcvflt should still be 0 */ + spu_status2.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_STATUS2(index, xi.interface)); + if (spu_status2.s.rcvflt) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: Receive fault, need to retry\n", + node, xi.interface, index); +#endif + return -1; + } + + /* Receive link is latching low. Force it high and verify it */ + spu_status1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_STATUS1(index, xi.interface)); + spu_status1.s.rcv_lnk = 1; + csr_wr_node(node, CVMX_BGXX_SPUX_STATUS1(index, xi.interface), + spu_status1.u64); + + if (CVMX_WAIT_FOR_FIELD64_NODE( + node, CVMX_BGXX_SPUX_STATUS1(index, xi.interface), + cvmx_bgxx_spux_status1_t, rcv_lnk, ==, 1, 10000)) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: Receive link down\n", node, + xi.interface, index); +#endif + return -1; + } + + if (use_ber) { + /* Clearing BER_CNT and ERR_BLKs */ + br_status2.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface)); + + /* If set, clear the LATCHED_BER by writing it to a one. */ + if (br_status2.s.latched_ber) + csr_wr_node(node, + CVMX_BGXX_SPUX_BR_STATUS2(index, + xi.interface), + br_status2.u64); + + error_debounce = get_timer(0); + + /* Clear error counts */ + err_blks = 0; + ber_cnt = 0; + + /* Verify that the link is up and error free for 100ms */ + while (get_timer(error_debounce) < 100) { + spu_status1.u64 = csr_rd_node( + node, + CVMX_BGXX_SPUX_STATUS1(index, xi.interface)); + /* Checking that Receive link is still up (rcv_lnk = 1 (up)) */ + if (!spu_status1.s.rcv_lnk) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: Receive link down\n", + node, xi.interface, index); +#endif + return -1; + } + + /* Checking if latched_ber = 1 (BER >= 10e^4) */ + br_status2.u64 = csr_rd_node( + node, + CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface)); + err_blks += br_status2.s.err_blks; + ber_cnt += br_status2.s.ber_cnt; + + if (br_status2.s.latched_ber) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: BER test failed, BER >= 10e^4, need to retry\n", + node, xi.interface, index); +#endif + return -1; + } + /* Checking that latched BLOCK_LOCK is still set (Block Lock never lost) */ + if (!br_status2.s.latched_lock) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: BASE-R PCS block lock lost, need to retry\n", + node, xi.interface, index); +#endif + return -1; + } + + /* Check error counters. Must be 0 (this error rate# + * is much higher than 1E-12) + */ + if (err_blks > 0) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: BASE-R errored-blocks (%llu) detected, need to retry\n", + node, xi.interface, index, + (unsigned long long)err_blks); +#endif + return -1; + } + + if (ber_cnt > 0) { +#ifdef DEBUG_BGX + debug("ERROR: %d:BGX%d:%d: BASE-R bit-errors (%llu) detected, need to retry\n", + node, xi.interface, index, + (unsigned long long)ber_cnt); +#endif + return -1; + } + + udelay(1000); + } + + /* Clear out the BGX error counters/bits. These errors are + * expected as part of the BGX link up procedure + */ + /* BIP_ERR counters clear as part of this read */ + csr_rd_node(node, + CVMX_BGXX_SPUX_BR_BIP_ERR_CNT(index, xi.interface)); + /* BER_CNT and ERR_BLKs clear as part of this read */ + br_status2.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface)); + } + + /* (7) Enable packet transmit and receive */ + spu_misc_control.u64 = csr_rd_node( + node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface)); + spu_misc_control.s.rx_packet_dis = 0; + csr_wr_node(node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface), + spu_misc_control.u64); + + if (debug) + debug("%s: Enabling tx and rx data packets\n", __func__); + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.data_pkt_tx_en = 1; + cmr_config.s.data_pkt_rx_en = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + return 0; +} + +int __cvmx_helper_bgx_xaui_enable(int xiface) +{ + int index; + cvmx_helper_interface_mode_t mode; + int num_ports = cvmx_helper_ports_on_interface(xiface); + + for (index = 0; index < num_ports; index++) { + int res; + int xipd_port = cvmx_helper_get_ipd_port(xiface, index); + int phy_pres; + struct cvmx_xiface xi = + cvmx_helper_xiface_to_node_interface(xiface); + static int count + [CVMX_MAX_NODES][CVMX_HELPER_MAX_IFACE] + [CVMX_HELPER_CFG_MAX_PORT_PER_IFACE] = { + [0 ... CVMX_MAX_NODES - + 1][0 ... CVMX_HELPER_MAX_IFACE - + 1] = { [0 ... CVMX_HELPER_CFG_MAX_PORT_PER_IFACE - + 1] = 0 } + }; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + + /* Set disparity for RXAUI interface as described in the + * Marvell RXAUI Interface specification. + */ + if (mode == CVMX_HELPER_INTERFACE_MODE_RXAUI && + (cvmx_helper_get_port_phy_present(xiface, index))) + phy_pres = 1; + else + phy_pres = 0; + __cvmx_helper_bgx_port_init(xipd_port, phy_pres); + +retry_link: + res = __cvmx_helper_bgx_xaui_link_init(index, xiface); + /* RX Equalization or autonegotiation can take little longer + * retry the link maybe 5 times for now + */ + if (res == -1 && count[xi.node][xi.interface][index] < 5) { + count[xi.node][xi.interface][index]++; +#ifdef DEBUG_BGX + debug("%d:BGX(%d,%d): Failed to get link, retrying\n", + xi.node, xi.interface, index); +#endif + goto retry_link; + } + + if (res == -1) { +#ifdef DEBUG_BGX + debug("%d:BGX(%d,%d): Failed to get link\n", xi.node, + xi.interface, index); +#endif + continue; + } + } + return 0; +} + +cvmx_helper_link_info_t __cvmx_helper_bgx_xaui_link_get(int xipd_port) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int index = cvmx_helper_get_interface_index_num(xp.port); + cvmx_bgxx_spux_status1_t spu_status1; + cvmx_bgxx_smux_tx_ctl_t smu_tx_ctl; + cvmx_bgxx_smux_rx_ctl_t smu_rx_ctl; + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_helper_link_info_t result; + cvmx_helper_interface_mode_t mode; + cvmx_bgxx_spux_misc_control_t spu_misc_control; + cvmx_bgxx_spux_br_status2_t br_status2; + + result.u64 = 0; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + return __cvmx_helper_bgx_sgmii_link_get(xipd_port); + + /* Reading current rx/tx link status */ + spu_status1.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SPUX_STATUS1(index, xi.interface)); + smu_tx_ctl.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SMUX_TX_CTL(index, xi.interface)); + smu_rx_ctl.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SMUX_RX_CTL(index, xi.interface)); + /* Reading tx/rx packet enables */ + cmr_config.u64 = csr_rd_node( + xi.node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + spu_misc_control.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface)); + + if (smu_tx_ctl.s.ls == 0 && smu_rx_ctl.s.status == 0 && + cmr_config.s.data_pkt_tx_en == 1 && + cmr_config.s.data_pkt_rx_en == 1 && + spu_misc_control.s.rx_packet_dis == 0 && + spu_status1.s.rcv_lnk) { + int lanes; + int qlm = cvmx_qlm_lmac(xiface, index); + u64 speed; + + result.s.link_up = 1; + result.s.full_duplex = 1; + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + speed = cvmx_qlm_get_gbaud_mhz_node(xi.node, qlm); + else + speed = cvmx_qlm_get_gbaud_mhz(qlm); + + cmr_config.u64 = csr_rd_node( + xi.node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + switch (cmr_config.s.lmac_type) { + default: + case 1: // XAUI + speed = (speed * 8 + 5) / 10; + lanes = 4; + break; + case 2: // RXAUI + speed = (speed * 8 + 5) / 10; + lanes = 2; + break; + case 3: // XFI + speed = (speed * 64 + 33) / 66; + lanes = 1; + break; + case 4: // XLAUI + /* Adjust the speed when XLAUI is configured at 6.250Gbps */ + if (speed == 6250) + speed = 6445; + speed = (speed * 64 + 33) / 66; + lanes = 4; + break; + } + + if (debug) + debug("%s: baud: %llu, lanes: %d\n", __func__, + (unsigned long long)speed, lanes); + speed *= lanes; + result.s.speed = speed; + } else { + int res; + u64 err_blks = 0; + u64 ber_cnt = 0; + + /* Check for err_blk and ber errors if 10G or 40G */ + if ((mode == CVMX_HELPER_INTERFACE_MODE_XFI || + mode == CVMX_HELPER_INTERFACE_MODE_XLAUI || + mode == CVMX_HELPER_INTERFACE_MODE_10G_KR || + mode == CVMX_HELPER_INTERFACE_MODE_40G_KR4)) { + br_status2.u64 = csr_rd_node( + xi.node, + CVMX_BGXX_SPUX_BR_STATUS2(index, xi.interface)); + err_blks = br_status2.s.err_blks; + ber_cnt = br_status2.s.ber_cnt; + } + + /* Checking if the link is up and error-free but we are receiving remote-faults */ + if (smu_tx_ctl.s.ls != 1 && smu_rx_ctl.s.status != 1 && + cmr_config.s.data_pkt_tx_en == 1 && + cmr_config.s.data_pkt_rx_en == 1 && + spu_misc_control.s.rx_packet_dis == 0 && + err_blks == 0 && ber_cnt == 0 && + spu_status1.s.rcv_lnk) { + result.s.init_success = 1; +#ifdef DEBUG_BGX + debug("Receiving remote-fault ordered sets %d:BGX(%d,%d)\n", + xi.node, xi.interface, index); +#endif + + } else { + res = __cvmx_helper_bgx_xaui_link_init(index, xiface); + if (res == -1) { +#ifdef DEBUG_BGX + debug("Failed to get %d:BGX(%d,%d) link\n", + xi.node, xi.interface, index); +#endif + } else { +#ifdef DEBUG_BGX + debug("Link initialization successful %d:BGX(%d,%d)\n", + xi.node, xi.interface, index); +#endif + result.s.init_success = 1; + } + } + } + + return result; +} + +int __cvmx_helper_bgx_xaui_link_set(int xipd_port, + cvmx_helper_link_info_t link_info) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int node = xi.node; + int index = cvmx_helper_get_interface_index_num(xp.port); + cvmx_bgxx_smux_tx_ctl_t smu_tx_ctl; + cvmx_bgxx_smux_rx_ctl_t smu_rx_ctl; + cvmx_bgxx_spux_status1_t spu_status1; + cvmx_helper_interface_mode_t mode; + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_bgxx_spux_misc_control_t spu_misc_control; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + return __cvmx_helper_bgx_sgmii_link_set(xipd_port, link_info); + + /* Reading current rx/tx link status */ + smu_tx_ctl.u64 = + csr_rd_node(node, CVMX_BGXX_SMUX_TX_CTL(index, xi.interface)); + smu_rx_ctl.u64 = + csr_rd_node(node, CVMX_BGXX_SMUX_RX_CTL(index, xi.interface)); + spu_status1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_STATUS1(index, xi.interface)); + /* Reading tx/rx packet enables */ + cmr_config.u64 = csr_rd_node( + xi.node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + spu_misc_control.u64 = csr_rd_node( + xi.node, CVMX_BGXX_SPUX_MISC_CONTROL(index, xi.interface)); + + /* If the link shouldn't be up, then just return */ + if (!link_info.s.link_up) + return 0; + + /* Do nothing if both RX and TX are happy and packet + * transmission/reception is enabled + */ + if (smu_tx_ctl.s.ls == 0 && smu_rx_ctl.s.status == 0 && + cmr_config.s.data_pkt_tx_en == 1 && + cmr_config.s.data_pkt_rx_en == 1 && + spu_misc_control.s.rx_packet_dis == 0 && spu_status1.s.rcv_lnk) + return 0; + + /* Bring the link up */ + return __cvmx_helper_bgx_xaui_link_init(index, xiface); +} + +int __cvmx_helper_bgx_xaui_configure_loopback(int xipd_port, + int enable_internal, + int enable_external) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + int node = xi.node; + int index = cvmx_helper_get_interface_index_num(xp.port); + cvmx_bgxx_spux_control1_t spu_control1; + cvmx_bgxx_smux_ext_loopback_t smu_ext_loopback; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + /* INT_BEAT_GEN must be set for loopback if the QLMs are not clocked. + * Set it whenever we use internal loopback + */ + if (enable_internal) { + cvmx_bgxx_cmrx_config_t cmr_config; + + cmr_config.u64 = csr_rd_node( + node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.int_beat_gen = 1; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + } + /* Set the internal loop */ + spu_control1.u64 = + csr_rd_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface)); + spu_control1.s.loopbck = enable_internal; + csr_wr_node(node, CVMX_BGXX_SPUX_CONTROL1(index, xi.interface), + spu_control1.u64); + /* Set the external loop */ + smu_ext_loopback.u64 = csr_rd_node( + node, CVMX_BGXX_SMUX_EXT_LOOPBACK(index, xi.interface)); + smu_ext_loopback.s.en = enable_external; + csr_wr_node(node, CVMX_BGXX_SMUX_EXT_LOOPBACK(index, xi.interface), + smu_ext_loopback.u64); + + return __cvmx_helper_bgx_xaui_link_init(index, xiface); +} + +int __cvmx_helper_bgx_mixed_enable(int xiface) +{ + int index; + int num_ports = cvmx_helper_ports_on_interface(xiface); + cvmx_helper_interface_mode_t mode; + + for (index = 0; index < num_ports; index++) { + int xipd_port, phy_pres = 0; + + if (!cvmx_helper_is_port_valid(xiface, index)) + continue; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + + xipd_port = cvmx_helper_get_ipd_port(xiface, index); + + if (mode == CVMX_HELPER_INTERFACE_MODE_RXAUI && + (cvmx_helper_get_port_phy_present(xiface, index))) + phy_pres = 1; + + if (__cvmx_helper_bgx_port_init(xipd_port, phy_pres)) + continue; + + /* For RGMII interface, initialize the link after PKO is setup */ + if (mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + continue; + /* Call SGMII init code for lmac_type = 0|5 */ + else if (mode == CVMX_HELPER_INTERFACE_MODE_SGMII) { + int do_link_set = 1; + + if (do_link_set) + __cvmx_helper_bgx_sgmii_link_set( + xipd_port, + __cvmx_helper_bgx_sgmii_link_get( + xipd_port)); + /* All other lmac type call XAUI init code */ + } else { + int res; + struct cvmx_xiface xi = + cvmx_helper_xiface_to_node_interface(xiface); + static int count + [CVMX_MAX_NODES][CVMX_HELPER_MAX_IFACE] + [CVMX_HELPER_CFG_MAX_PORT_PER_IFACE] = { + [0 ... CVMX_MAX_NODES - + 1][0 ... CVMX_HELPER_MAX_IFACE - + 1] = { [0 ... CVMX_HELPER_CFG_MAX_PORT_PER_IFACE - + 1] = 0 } + }; + +retry_link: + res = __cvmx_helper_bgx_xaui_link_init(index, xiface); + /* RX Equalization or autonegotiation can take little + * longer retry the link maybe 5 times for now + */ + if (res == -1 && + count[xi.node][xi.interface][index] < 5) { + count[xi.node][xi.interface][index]++; + goto retry_link; + } + + if (res == -1) { +#ifdef DEBUG_BGX + debug("Failed to get %d:BGX(%d,%d) link\n", + xi.node, xi.interface, index); +#endif + continue; + } + } + } + return 0; +} + +cvmx_helper_link_info_t __cvmx_helper_bgx_mixed_link_get(int xipd_port) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + int index = cvmx_helper_get_interface_index_num(xipd_port); + cvmx_helper_interface_mode_t mode; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_SGMII || + mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + return __cvmx_helper_bgx_sgmii_link_get(xipd_port); + else + return __cvmx_helper_bgx_xaui_link_get(xipd_port); +} + +int __cvmx_helper_bgx_mixed_link_set(int xipd_port, + cvmx_helper_link_info_t link_info) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + int index = cvmx_helper_get_interface_index_num(xipd_port); + cvmx_helper_interface_mode_t mode; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_SGMII || + mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + return __cvmx_helper_bgx_sgmii_link_set(xipd_port, link_info); + else + return __cvmx_helper_bgx_xaui_link_set(xipd_port, link_info); +} + +int __cvmx_helper_bgx_mixed_configure_loopback(int xipd_port, + int enable_internal, + int enable_external) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + int index = cvmx_helper_get_interface_index_num(xipd_port); + cvmx_helper_interface_mode_t mode; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + if (mode == CVMX_HELPER_INTERFACE_MODE_SGMII || + mode == CVMX_HELPER_INTERFACE_MODE_RGMII) + return __cvmx_helper_bgx_sgmii_configure_loopback( + xipd_port, enable_internal, enable_external); + else + return __cvmx_helper_bgx_xaui_configure_loopback( + xipd_port, enable_internal, enable_external); +} + +/** + * @INTERNAL + * Configure Priority-Based Flow Control (a.k.a. PFC/CBFC) + * on a specific BGX interface/port. + */ +void __cvmx_helper_bgx_xaui_config_pfc(unsigned int node, + unsigned int interface, + unsigned int index, bool pfc_enable) +{ + int xiface = cvmx_helper_node_interface_to_xiface(node, interface); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + cvmx_bgxx_smux_cbfc_ctl_t cbfc_ctl; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + cbfc_ctl.u64 = + csr_rd_node(node, CVMX_BGXX_SMUX_CBFC_CTL(index, xi.interface)); + + /* Enable all PFC controls if requiested */ + cbfc_ctl.s.rx_en = pfc_enable; + cbfc_ctl.s.tx_en = pfc_enable; + if (debug) + debug("%s: CVMX_BGXX_SMUX_CBFC_CTL(%d,%d)=%#llx\n", __func__, + index, xi.interface, (unsigned long long)cbfc_ctl.u64); + csr_wr_node(node, CVMX_BGXX_SMUX_CBFC_CTL(index, xi.interface), + cbfc_ctl.u64); +} + +/** + * Function to control the generation of FCS, padding by the BGX + * + */ +void cvmx_helper_bgx_tx_options(unsigned int node, unsigned int interface, + unsigned int index, bool fcs_enable, + bool pad_enable) +{ + cvmx_bgxx_cmrx_config_t cmr_config; + cvmx_bgxx_gmp_gmi_txx_append_t gmp_txx_append; + cvmx_bgxx_gmp_gmi_txx_min_pkt_t gmp_min_pkt; + cvmx_bgxx_smux_tx_min_pkt_t smu_min_pkt; + cvmx_bgxx_smux_tx_append_t smu_tx_append; + int xiface = cvmx_helper_node_interface_to_xiface(node, interface); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + if (!cvmx_helper_is_port_valid(xiface, index)) + return; + + if (debug) + debug("%s: interface %u:%d/%d, fcs: %s, pad: %s\n", __func__, + xi.node, xi.interface, index, + fcs_enable ? "true" : "false", + pad_enable ? "true" : "false"); + + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + + (void)cmr_config; /* In case we need LMAC_TYPE later */ + + /* Setting options for both BGX subsystems, regardless of LMAC type */ + + /* Set GMP (SGMII) Tx options */ + gmp_min_pkt.u64 = 0; + /* per HRM Sec 34.3.4.4 */ + gmp_min_pkt.s.min_size = 59; + csr_wr_node(node, CVMX_BGXX_GMP_GMI_TXX_MIN_PKT(index, xi.interface), + gmp_min_pkt.u64); + gmp_txx_append.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_GMI_TXX_APPEND(index, xi.interface)); + gmp_txx_append.s.fcs = fcs_enable; + gmp_txx_append.s.pad = pad_enable; + csr_wr_node(node, CVMX_BGXX_GMP_GMI_TXX_APPEND(index, xi.interface), + gmp_txx_append.u64); + + /* Set SMUX (XAUI/XFI) Tx options */ + /* HRM Sec 33.3.4.3 should read 64 */ + smu_min_pkt.u64 = 0; + smu_min_pkt.s.min_size = 0x40; + csr_wr_node(node, CVMX_BGXX_SMUX_TX_MIN_PKT(index, xi.interface), + smu_min_pkt.u64); + smu_tx_append.u64 = csr_rd_node( + node, CVMX_BGXX_SMUX_TX_APPEND(index, xi.interface)); + smu_tx_append.s.fcs_d = fcs_enable; /* Set data-packet FCS */ + smu_tx_append.s.pad = pad_enable; + csr_wr_node(node, CVMX_BGXX_SMUX_TX_APPEND(index, xi.interface), + smu_tx_append.u64); +} + +/** + * Set mac for the ipd_port + * + * @param xipd_port ipd_port to set the mac + * @param bcst If set, accept all broadcast packets + * @param mcst Multicast mode + * 0 = Force reject all multicast packets + * 1 = Force accept all multicast packets + * 2 = use the address filter CAM. + * @param mac mac address for the ipd_port, or 0 to disable MAC filtering + */ +void cvmx_helper_bgx_set_mac(int xipd_port, int bcst, int mcst, u64 mac) +{ + int xiface = cvmx_helper_get_interface_num(xipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + int index; + cvmx_bgxx_cmr_rx_adrx_cam_t adr_cam; + cvmx_bgxx_cmrx_rx_adr_ctl_t adr_ctl; + cvmx_bgxx_cmrx_config_t cmr_config; + int saved_state_tx, saved_state_rx; + + index = cvmx_helper_get_interface_index_num(xipd_port); + + if (!cvmx_helper_is_port_valid(xiface, index)) + return; + + if (debug) + debug("%s: interface %u:%d/%d\n", __func__, xi.node, + xi.interface, index); + + cmr_config.u64 = + csr_rd_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + saved_state_tx = cmr_config.s.data_pkt_tx_en; + saved_state_rx = cmr_config.s.data_pkt_rx_en; + cmr_config.s.data_pkt_tx_en = 0; + cmr_config.s.data_pkt_rx_en = 0; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + + /* Set the mac */ + adr_cam.u64 = 0; + adr_cam.s.id = index; + + if (mac != 0ull) + adr_cam.s.en = 1; + adr_cam.s.adr = mac; + + csr_wr_node(node, CVMX_BGXX_CMR_RX_ADRX_CAM(index * 8, xi.interface), + adr_cam.u64); + + adr_ctl.u64 = csr_rd_node( + node, CVMX_BGXX_CMRX_RX_ADR_CTL(index, xi.interface)); + if (mac != 0ull) + adr_ctl.s.cam_accept = + 1; /* Accept the packet on DMAC CAM address */ + else + adr_ctl.s.cam_accept = 0; /* No filtering, promiscuous */ + + adr_ctl.s.mcst_mode = mcst; /* Use the address filter CAM */ + adr_ctl.s.bcst_accept = bcst; /* Accept all broadcast packets */ + csr_wr_node(node, CVMX_BGXX_CMRX_RX_ADR_CTL(index, xi.interface), + adr_ctl.u64); + /* Set SMAC for PAUSE frames */ + csr_wr_node(node, CVMX_BGXX_GMP_GMI_SMACX(index, xi.interface), mac); + + /* Restore back the interface state */ + cmr_config.s.data_pkt_tx_en = saved_state_tx; + cmr_config.s.data_pkt_rx_en = saved_state_rx; + csr_wr_node(node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + + /* Wait 100ms after bringing up the link to give the PHY some time */ + if (cmr_config.s.enable) { + cvmx_helper_interface_mode_t mode; + + mode = cvmx_helper_bgx_get_mode(xiface, index); + __cvmx_helper_bgx_interface_enable_delay(mode); + } +} + +/** + * Disables the sending of flow control (pause) frames on the specified + * BGX port(s). + * + * @param xiface Which xiface + * @param port_mask Mask (4bits) of which ports on the interface to disable + * backpressure on. + * 1 => disable backpressure + * 0 => enable backpressure + * + * @return 0 on success + * -1 on error + * + * FIXME: Should change the API to handle a single port in every + * invocation, for consistency with other API calls. + */ +int cvmx_bgx_set_backpressure_override(int xiface, unsigned int port_mask) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + cvmx_bgxx_cmr_rx_ovr_bp_t rx_ovr_bp; + int node = xi.node; + + if (xi.interface >= CVMX_HELPER_MAX_GMX) + return 0; + + if (debug) + debug("%s: interface %u:%d port_mask=%#x\n", __func__, xi.node, + xi.interface, port_mask); + + /* Check for valid arguments */ + rx_ovr_bp.u64 = 0; + rx_ovr_bp.s.en = port_mask; /* Per port Enable back pressure override */ + rx_ovr_bp.s.ign_fifo_bp = + port_mask; /* Ignore the RX FIFO full when computing BP */ + + csr_wr_node(node, CVMX_BGXX_CMR_RX_OVR_BP(xi.interface), rx_ovr_bp.u64); + return 0; +} + +int cvmx_bgx_set_flowctl_mode(int xipd_port, cvmx_qos_proto_t qos, + cvmx_qos_pkt_mode_t fc_mode) +{ + int node, xiface, iface, index, mode; + struct cvmx_xiface xi; + const struct { + int bck; + int drp; + } fcmode[4] = { [CVMX_QOS_PKT_MODE_HWONLY] = { 1, 1 }, + [CVMX_QOS_PKT_MODE_SWONLY] = { 0, 0 }, + [CVMX_QOS_PKT_MODE_HWSW] = { 1, 0 }, + [CVMX_QOS_PKT_MODE_DROP] = { 0, 1 } }; + + xiface = cvmx_helper_get_interface_num(xipd_port); + xi = cvmx_helper_xiface_to_node_interface(xiface); + node = xi.node; + iface = xi.interface; + + if (xi.interface >= CVMX_HELPER_MAX_GMX) + return 0; + + index = cvmx_helper_get_interface_index_num(xipd_port); + mode = cvmx_helper_bgx_get_mode(xiface, index); + switch (mode) { + case CVMX_HELPER_INTERFACE_MODE_10G_KR: + case CVMX_HELPER_INTERFACE_MODE_40G_KR4: + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_XFI: + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_XAUI: { + cvmx_bgxx_smux_tx_ctl_t txctl; + cvmx_bgxx_smux_cbfc_ctl_t cbfc; + cvmx_bgxx_smux_rx_frm_ctl_t frmctl; + cvmx_bgxx_smux_hg2_control_t hg2ctl; + + txctl.u64 = + csr_rd_node(node, CVMX_BGXX_SMUX_TX_CTL(index, iface)); + cbfc.u64 = csr_rd_node(node, + CVMX_BGXX_SMUX_CBFC_CTL(index, iface)); + frmctl.u64 = csr_rd_node( + node, CVMX_BGXX_SMUX_RX_FRM_CTL(index, iface)); + hg2ctl.u64 = csr_rd_node( + node, CVMX_BGXX_SMUX_HG2_CONTROL(index, iface)); + switch (qos) { + case CVMX_QOS_PROTO_PAUSE: + cbfc.u64 = 0; + hg2ctl.u64 = 0; + frmctl.s.ctl_bck = fcmode[fc_mode].bck; + frmctl.s.ctl_drp = fcmode[fc_mode].drp; + frmctl.s.ctl_mcst = 1; + txctl.s.l2p_bp_conv = 1; + break; + case CVMX_QOS_PROTO_PFC: + hg2ctl.u64 = 0; + hg2ctl.s.logl_en = 0xff; + frmctl.s.ctl_bck = fcmode[fc_mode].bck; + frmctl.s.ctl_drp = fcmode[fc_mode].drp; + frmctl.s.ctl_mcst = 1; + cbfc.s.bck_en = fcmode[fc_mode].bck; + cbfc.s.drp_en = fcmode[fc_mode].drp; + cbfc.s.phys_en = 0; + cbfc.s.logl_en = 0xff; + cbfc.s.tx_en = 1; + cbfc.s.rx_en = 1; + break; + case CVMX_QOS_PROTO_NONE: + cbfc.u64 = 0; + hg2ctl.u64 = 0; + frmctl.s.ctl_bck = fcmode[CVMX_QOS_PKT_MODE_DROP].bck; + frmctl.s.ctl_drp = fcmode[CVMX_QOS_PKT_MODE_DROP].drp; + txctl.s.l2p_bp_conv = 0; + break; + default: + break; + } + csr_wr_node(node, CVMX_BGXX_SMUX_CBFC_CTL(index, iface), + cbfc.u64); + csr_wr_node(node, CVMX_BGXX_SMUX_RX_FRM_CTL(index, iface), + frmctl.u64); + csr_wr_node(node, CVMX_BGXX_SMUX_HG2_CONTROL(index, iface), + hg2ctl.u64); + csr_wr_node(node, CVMX_BGXX_SMUX_TX_CTL(index, iface), + txctl.u64); + break; + } + case CVMX_HELPER_INTERFACE_MODE_SGMII: + case CVMX_HELPER_INTERFACE_MODE_RGMII: { + cvmx_bgxx_gmp_gmi_rxx_frm_ctl_t gmi_frmctl; + + gmi_frmctl.u64 = csr_rd_node( + node, CVMX_BGXX_GMP_GMI_RXX_FRM_CTL(index, iface)); + switch (qos) { + case CVMX_QOS_PROTO_PAUSE: + gmi_frmctl.s.ctl_bck = fcmode[fc_mode].bck; + gmi_frmctl.s.ctl_drp = fcmode[fc_mode].drp; + gmi_frmctl.s.ctl_mcst = 1; + break; + case CVMX_QOS_PROTO_NONE: + gmi_frmctl.s.ctl_bck = + fcmode[CVMX_QOS_PKT_MODE_DROP].bck; + gmi_frmctl.s.ctl_drp = + fcmode[CVMX_QOS_PKT_MODE_DROP].drp; + break; + default: + break; + } + csr_wr_node(node, CVMX_BGXX_GMP_GMI_RXX_FRM_CTL(index, iface), + gmi_frmctl.u64); + } + } /*switch*/ + + return 0; +}
Import cvmx-helper-board.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-board.c | 1824 +++++++++++++++++++++ 1 file changed, 1824 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-board.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-board.c b/arch/mips/mach-octeon/cvmx-helper-board.c new file mode 100644 index 000000000000..6dcc4e557e12 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-board.c @@ -0,0 +1,1824 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Helper functions to abstract board specific data about + * network ports from the rest of the cvmx-helper files. + */ + +#include <i2c.h> +#include <log.h> +#include <malloc.h> +#include <net.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/octeon_fdt.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-fdt.h> +#include <mach/cvmx-helper-gpio.h> + +#include <mach/cvmx-smix-defs.h> +#include <mach/cvmx-mdio.h> +#include <mach/cvmx-qlm.h> + +DECLARE_GLOBAL_DATA_PTR; + +static bool sfp_parsed; + +static int __cvmx_helper_78xx_parse_phy(struct cvmx_phy_info *phy_info, + int ipd_port); +static int __get_phy_info_from_dt(cvmx_phy_info_t *phy_info, int ipd_port); + +/** + * Writes to a Microsemi VSC7224 16-bit register + * + * @param[in] i2c_bus i2c bus data structure (must be enabled) + * @param addr Address of VSC7224 on the i2c bus + * @param reg 8-bit register number to write to + * @param val 16-bit value to write + * + * @return 0 for success + */ +static int cvmx_write_vsc7224_reg(const struct cvmx_fdt_i2c_bus_info *i2c_bus, + u8 addr, u8 reg, u16 val) +{ + struct udevice *dev; + u8 buffer[2]; + int ret; + + ret = i2c_get_chip(i2c_bus->i2c_bus, addr, 1, &dev); + if (ret) { + debug("Cannot find I2C device: %d\n", ret); + return -1; + } + + ret = dm_i2c_write(dev, reg, buffer, 2); + if (ret) { + debug("Cannot write I2C device: %d\n", ret); + return -1; + } + + return 0; +} + +/** + * Writes to a Microsemi VSC7224 16-bit register + * + * @param[in] i2c_bus i2c bus data structure (must be enabled) + * @param addr Address of VSC7224 on the i2c bus + * @param reg 8-bit register number to write to + * + * @return 16-bit value or error if < 0 + */ +static int cvmx_read_vsc7224_reg(const struct cvmx_fdt_i2c_bus_info *i2c_bus, + u8 addr, u8 reg) +{ + struct udevice *dev; + u8 buffer[2]; + int ret; + + ret = i2c_get_chip(i2c_bus->i2c_bus, addr, 1, &dev); + if (ret) { + debug("Cannot find I2C device: %d\n", ret); + return -1; + } + + ret = dm_i2c_read(dev, reg, buffer, 2); + if (ret) { + debug("Cannot read I2C device: %d\n", ret); + return -1; + } + + return (buffer[0] << 8) | buffer[1]; +} + +/** + * Function called whenever mod_abs/mod_prs has changed for Microsemi VSC7224 + * + * @param sfp pointer to SFP data structure + * @param val 1 if absent, 0 if present, otherwise not set + * @param data user-defined data + * + * @return 0 for success, -1 on error + */ +int cvmx_sfp_vsc7224_mod_abs_changed(struct cvmx_fdt_sfp_info *sfp, int val, + void *data) +{ + int err; + struct cvmx_sfp_mod_info *mod_info; + int length; + struct cvmx_vsc7224 *vsc7224; + struct cvmx_vsc7224_chan *vsc7224_chan; + struct cvmx_vsc7224_tap *taps, *match = NULL; + int i; + + debug("%s(%s, %d, %p): Module %s\n", __func__, sfp->name, val, data, + val ? "absent" : "present"); + if (val) + return 0; + + /* We're here if we detect that the module is now present */ + err = cvmx_sfp_read_i2c_eeprom(sfp); + if (err) { + debug("%s: Error reading the SFP module eeprom for %s\n", + __func__, sfp->name); + return err; + } + mod_info = &sfp->sfp_info; + + if (!mod_info->valid || !sfp->valid) { + debug("%s: Module data is invalid\n", __func__); + return -1; + } + + vsc7224_chan = sfp->vsc7224_chan; + while (vsc7224_chan) { + /* We don't do any rx tuning */ + if (!vsc7224_chan->is_tx) { + vsc7224_chan = vsc7224_chan->next; + continue; + } + + /* Walk through all the channels */ + taps = vsc7224_chan->taps; + if (mod_info->limiting) + length = 0; + else + length = mod_info->max_copper_cable_len; + debug("%s: limiting: %d, length: %d\n", __func__, + mod_info->limiting, length); + + /* Find a matching length in the taps table */ + for (i = 0; i < vsc7224_chan->num_taps; i++) { + if (length >= taps->len) + match = taps; + taps++; + } + if (!match) { + debug("%s(%s, %d, %p): Error: no matching tap for length %d\n", + __func__, sfp->name, val, data, length); + return -1; + } + debug("%s(%s): Applying %cx taps to vsc7224 %s:%d for cable length %d+\n", + __func__, sfp->name, vsc7224_chan->is_tx ? 't' : 'r', + vsc7224_chan->vsc7224->name, vsc7224_chan->lane, + match->len); + /* Program the taps */ + vsc7224 = vsc7224_chan->vsc7224; + cvmx_write_vsc7224_reg(vsc7224->i2c_bus, vsc7224->i2c_addr, + 0x7f, vsc7224_chan->lane); + if (!vsc7224_chan->maintap_disable) + cvmx_write_vsc7224_reg(vsc7224->i2c_bus, + vsc7224->i2c_addr, 0x99, + match->main_tap); + if (!vsc7224_chan->pretap_disable) + cvmx_write_vsc7224_reg(vsc7224->i2c_bus, + vsc7224->i2c_addr, 0x9a, + match->pre_tap); + if (!vsc7224_chan->posttap_disable) + cvmx_write_vsc7224_reg(vsc7224->i2c_bus, + vsc7224->i2c_addr, 0x9b, + match->post_tap); + + /* Re-use val and disable taps if needed */ + if (vsc7224_chan->maintap_disable || + vsc7224_chan->pretap_disable || + vsc7224_chan->posttap_disable) { + val = cvmx_read_vsc7224_reg(vsc7224->i2c_bus, + vsc7224->i2c_addr, 0x97); + if (vsc7224_chan->maintap_disable) + val |= 0x800; + if (vsc7224_chan->pretap_disable) + val |= 0x1000; + if (vsc7224_chan->posttap_disable) + val |= 0x400; + cvmx_write_vsc7224_reg(vsc7224->i2c_bus, + vsc7224->i2c_addr, 0x97, val); + } + vsc7224_chan = vsc7224_chan->next; + } + + return err; +} + +/** + * Update the mod_abs and error LED + * + * @param ipd_port ipd port number + * @param link link information + */ +static void __cvmx_helper_update_sfp(int ipd_port, + struct cvmx_fdt_sfp_info *sfp_info, + cvmx_helper_link_info_t link) +{ + debug("%s(%d): checking mod_abs\n", __func__, ipd_port); + + cvmx_sfp_check_mod_abs(sfp_info, sfp_info->mod_abs_data); +} + +static void cvmx_sfp_update_link(struct cvmx_fdt_sfp_info *sfp, + cvmx_helper_link_info_t link) +{ + while (sfp) { + debug("%s(%s): checking mod_abs\n", __func__, sfp->name); + if (link.s.link_up && sfp->last_mod_abs) + cvmx_sfp_check_mod_abs(sfp, sfp->mod_abs_data); + sfp = sfp->next_iface_sfp; + } +} + +/** + * @INTERNAL + * This function is used ethernet ports link speed. This functions uses the + * device tree information to determine the phy address and type of PHY. + * The only supproted PHYs are Marvell and Broadcom. + * + * @param ipd_port IPD input port associated with the port we want to get link + * status for. + * + * @return The ports link status. If the link isn't fully resolved, this must + * return zero. + */ +cvmx_helper_link_info_t __cvmx_helper_board_link_get_from_dt(int ipd_port) +{ + cvmx_helper_link_info_t result; + cvmx_phy_info_t *phy_info = NULL; + cvmx_phy_info_t local_phy_info; + int xiface = 0, index = 0; + bool use_inband = false; + struct cvmx_fdt_sfp_info *sfp_info; + const void *fdt_addr = CASTPTR(const void *, gd->fdt_blob); + + result.u64 = 0; + + if (ipd_port >= 0) { + int mode; + + xiface = cvmx_helper_get_interface_num(ipd_port); + index = cvmx_helper_get_interface_index_num(ipd_port); + mode = cvmx_helper_interface_get_mode(xiface); + if (!cvmx_helper_get_port_autonegotiation(xiface, index)) { + result.s.link_up = 1; + result.s.full_duplex = 1; + switch (mode) { + case CVMX_HELPER_INTERFACE_MODE_RGMII: + case CVMX_HELPER_INTERFACE_MODE_GMII: + case CVMX_HELPER_INTERFACE_MODE_SGMII: + case CVMX_HELPER_INTERFACE_MODE_QSGMII: + case CVMX_HELPER_INTERFACE_MODE_AGL: + case CVMX_HELPER_INTERFACE_MODE_SPI: + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + struct cvmx_xiface xi = + cvmx_helper_xiface_to_node_interface( + xiface); + u64 gbaud = cvmx_qlm_get_gbaud_mhz(0); + + result.s.speed = gbaud * 8 / 10; + if (cvmx_qlm_get_dlm_mode( + 0, xi.interface) == + CVMX_QLM_MODE_SGMII) + result.s.speed >>= 1; + else + result.s.speed >>= 2; + } else { + result.s.speed = 1000; + } + break; + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_XAUI: + case CVMX_HELPER_INTERFACE_MODE_10G_KR: + case CVMX_HELPER_INTERFACE_MODE_XFI: + result.s.speed = 10000; + break; + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_40G_KR4: + result.s.speed = 40000; + break; + default: + break; + } + + sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, index); + /* Initialize the SFP info if it hasn't already been + * done. + */ + if (!sfp_info && !sfp_parsed) { + cvmx_sfp_parse_device_tree(fdt_addr); + sfp_parsed = true; + cvmx_sfp_read_all_modules(); + sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, + index); + } + /* If the link is down or the link is up but we still + * register the module as being absent, re-check + * mod_abs. + */ + cvmx_sfp_update_link(sfp_info, result); + + cvmx_helper_update_link_led(xiface, index, result); + + return result; + } + phy_info = cvmx_helper_get_port_phy_info(xiface, index); + if (!phy_info) { + debug("%s: phy info not saved in config, allocating for 0x%x:%d\n", + __func__, xiface, index); + + phy_info = (cvmx_phy_info_t *)cvmx_bootmem_alloc( + sizeof(*phy_info), 0); + if (!phy_info) { + debug("%s: Out of memory\n", __func__); + return result; + } + memset(phy_info, 0, sizeof(*phy_info)); + phy_info->phy_addr = -1; + debug("%s: Setting phy info for 0x%x:%d to %p\n", + __func__, xiface, index, phy_info); + cvmx_helper_set_port_phy_info(xiface, index, phy_info); + } + } else { + /* For management ports we don't store the PHY information + * so we use a local copy instead. + */ + phy_info = &local_phy_info; + memset(phy_info, 0, sizeof(*phy_info)); + phy_info->phy_addr = -1; + } + + if (phy_info->phy_addr == -1) { + if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + if (__cvmx_helper_78xx_parse_phy(phy_info, ipd_port)) { + phy_info->phy_addr = -1; + use_inband = true; + } + } else if (__get_phy_info_from_dt(phy_info, ipd_port) < 0) { + phy_info->phy_addr = -1; + use_inband = true; + } + } + + /* If we can't get the PHY info from the device tree then try + * the inband state. + */ + if (use_inband) { + result.s.full_duplex = 1; + result.s.link_up = 1; + result.s.speed = 1000; + return result; + } + + if (phy_info->phy_addr < 0) + return result; + + if (phy_info->link_function) + result = phy_info->link_function(phy_info); + else + result = cvmx_helper_link_get(ipd_port); + + sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, index); + while (sfp_info) { + /* If the link is down or the link is up but we still register + * the module as being absent, re-check mod_abs. + */ + if (!result.s.link_up || + (result.s.link_up && sfp_info->last_mod_abs)) + __cvmx_helper_update_sfp(ipd_port, sfp_info, result); + sfp_info = sfp_info->next_iface_sfp; + } + + return result; +} + +cvmx_helper_link_info_t __cvmx_helper_board_link_get(int ipd_port) +{ + cvmx_helper_link_info_t result; + + /* Unless we fix it later, all links are defaulted to down */ + result.u64 = 0; + + return __cvmx_helper_board_link_get_from_dt(ipd_port); +} + +void cvmx_helper_update_link_led(int xiface, int index, + cvmx_helper_link_info_t result) +{ +} + +void cvmx_helper_leds_show_error(struct cvmx_phy_gpio_leds *leds, bool error) +{ +} + +int __cvmx_helper_board_interface_probe(int interface, int supported_ports) +{ + return supported_ports; +} + +/** + * Returns the Ethernet node offset in the device tree + * + * @param fdt_addr - pointer to flat device tree in memory + * @param aliases - offset of alias in device tree + * @param ipd_port - ipd port number to look up + * + * @returns offset of Ethernet node if >= 0, error if -1 + */ +int __pip_eth_node(const void *fdt_addr, int aliases, int ipd_port) +{ + char name_buffer[20]; + const char *pip_path; + int pip, iface, eth; + int interface_num = cvmx_helper_get_interface_num(ipd_port); + int interface_index = cvmx_helper_get_interface_index_num(ipd_port); + cvmx_helper_interface_mode_t interface_mode = + cvmx_helper_interface_get_mode(interface_num); + + /* The following are not found in the device tree */ + switch (interface_mode) { + case CVMX_HELPER_INTERFACE_MODE_ILK: + case CVMX_HELPER_INTERFACE_MODE_LOOP: + case CVMX_HELPER_INTERFACE_MODE_SRIO: + debug("ERROR: No node expected for interface: %d, port: %d, mode: %s\n", + interface_index, ipd_port, + cvmx_helper_interface_mode_to_string(interface_mode)); + return -1; + default: + break; + } + pip_path = (const char *)fdt_getprop(fdt_addr, aliases, "pip", NULL); + if (!pip_path) { + debug("ERROR: pip path not found in device tree\n"); + return -1; + } + pip = fdt_path_offset(fdt_addr, pip_path); + debug("ipdd_port=%d pip_path=%s pip=%d ", ipd_port, pip_path, pip); + if (pip < 0) { + debug("ERROR: pip not found in device tree\n"); + return -1; + } + snprintf(name_buffer, sizeof(name_buffer), "interface@%d", + interface_num); + iface = fdt_subnode_offset(fdt_addr, pip, name_buffer); + debug("iface=%d ", iface); + if (iface < 0) { + debug("ERROR : pip intf %d not found in device tree\n", + interface_num); + return -1; + } + snprintf(name_buffer, sizeof(name_buffer), "ethernet@%x", + interface_index); + eth = fdt_subnode_offset(fdt_addr, iface, name_buffer); + debug("eth=%d\n", eth); + if (eth < 0) { + debug("ERROR : pip interface@%d ethernet@%d not found in device tree\n", + interface_num, interface_index); + return -1; + } + return eth; +} + +int __mix_eth_node(const void *fdt_addr, int aliases, int interface_index) +{ + char name_buffer[20]; + const char *mix_path; + int mix; + + snprintf(name_buffer, sizeof(name_buffer), "mix%d", interface_index); + mix_path = + (const char *)fdt_getprop(fdt_addr, aliases, name_buffer, NULL); + if (!mix_path) { + debug("ERROR: mix%d path not found in device tree\n", + interface_index); + } + mix = fdt_path_offset(fdt_addr, mix_path); + if (mix < 0) { + debug("ERROR: %s not found in device tree\n", mix_path); + return -1; + } + return mix; +} + +static int __mdiobus_addr_to_unit(u32 addr) +{ + int unit = (addr >> 7) & 3; + + if (!OCTEON_IS_MODEL(OCTEON_CN68XX) && !OCTEON_IS_MODEL(OCTEON_CN78XX)) + unit >>= 1; + return unit; +} + +/** + * Parse the muxed MDIO interface information from the device tree + * + * @param phy_info - pointer to phy info data structure to update + * @param mdio_offset - offset of MDIO bus + * @param mux_offset - offset of MUX, parent of mdio_offset + * + * @return 0 for success or -1 + */ +static int __get_muxed_mdio_info_from_dt(cvmx_phy_info_t *phy_info, + int mdio_offset, int mux_offset) +{ + const void *fdt_addr = CASTPTR(const void *, gd->fdt_blob); + int phandle; + int smi_offset; + int gpio_offset; + u64 smi_addr = 0; + int len; + u32 *pgpio_handle; + int gpio_count = 0; + u32 *prop_val; + int offset; + const char *prop_name; + + debug("%s(%p, 0x%x, 0x%x)\n", __func__, phy_info, mdio_offset, + mux_offset); + + /* Get register value to put onto the GPIO lines to select */ + phy_info->gpio_value = + cvmx_fdt_get_int(fdt_addr, mdio_offset, "reg", -1); + if (phy_info->gpio_value < 0) { + debug("Could not get register value for muxed MDIO bus from DT\n"); + return -1; + } + + smi_offset = cvmx_fdt_lookup_phandle(fdt_addr, mux_offset, + "mdio-parent-bus"); + if (smi_offset < 0) { + debug("Invalid SMI offset for muxed MDIO interface in device tree\n"); + return -1; + } + smi_addr = cvmx_fdt_get_uint64(fdt_addr, smi_offset, "reg", 0); + + /* Convert SMI address to a MDIO interface */ + switch (smi_addr) { + case 0x1180000001800: + case 0x1180000003800: /* 68XX address */ + phy_info->mdio_unit = 0; + break; + case 0x1180000001900: + case 0x1180000003880: + phy_info->mdio_unit = 1; + break; + case 0x1180000003900: + phy_info->mdio_unit = 2; + break; + case 0x1180000003980: + phy_info->mdio_unit = 3; + break; + default: + phy_info->mdio_unit = 1; + break; + } + /* Find the GPIO MUX controller */ + pgpio_handle = + (u32 *)fdt_getprop(fdt_addr, mux_offset, "gpios", &len); + if (!pgpio_handle || len < 12 || (len % 12) != 0 || + len > CVMX_PHY_MUX_MAX_GPIO * 12) { + debug("Invalid GPIO for muxed MDIO controller in DT\n"); + return -1; + } + + for (gpio_count = 0; gpio_count < len / 12; gpio_count++) { + phandle = fdt32_to_cpu(pgpio_handle[gpio_count * 3]); + phy_info->gpio[gpio_count] = + fdt32_to_cpu(pgpio_handle[gpio_count * 3 + 1]); + gpio_offset = fdt_node_offset_by_phandle(fdt_addr, phandle); + if (gpio_offset < 0) { + debug("Cannot access parent GPIO node in DT\n"); + return -1; + } + if (!fdt_node_check_compatible(fdt_addr, gpio_offset, + "cavium,octeon-3860-gpio")) { + phy_info->gpio_type[gpio_count] = GPIO_OCTEON; + } else if (!fdt_node_check_compatible(fdt_addr, gpio_offset, + "nxp,pca8574")) { + /* GPIO is a TWSI GPIO unit which might sit behind + * another mux. + */ + phy_info->gpio_type[gpio_count] = GPIO_PCA8574; + prop_val = (u32 *)fdt_getprop( + fdt_addr, gpio_offset, "reg", NULL); + if (!prop_val) { + debug("Could not find TWSI address of npx pca8574 GPIO from DT\n"); + return -1; + } + /* Get the TWSI address of the GPIO unit */ + phy_info->cvmx_gpio_twsi[gpio_count] = + fdt32_to_cpu(*prop_val); + /* Get the selector on the GPIO mux if present */ + offset = fdt_parent_offset(fdt_addr, gpio_offset); + prop_val = (u32 *)fdt_getprop(fdt_addr, offset, + "reg", NULL); + if (prop_val) { + phy_info->gpio_parent_mux_select = + fdt32_to_cpu(*prop_val); + /* Go up another level */ + offset = fdt_parent_offset(fdt_addr, offset); + if (!fdt_node_check_compatible(fdt_addr, offset, + "nxp,pca9548")) { + prop_val = (u32 *)fdt_getprop( + fdt_addr, offset, "reg", NULL); + if (!prop_val) { + debug("Could not read MUX TWSI address from DT\n"); + return -1; + } + phy_info->gpio_parent_mux_twsi = + fdt32_to_cpu(*prop_val); + } + } + } else { + prop_name = (char *)fdt_getprop(fdt_addr, gpio_offset, + "compatible", NULL); + debug("Unknown GPIO type %s\n", prop_name); + return -1; + } + } + return 0; +} + +/** + * @INTERNAL + * Converts a BGX address to the node, interface and port number + * + * @param bgx_addr Address of CSR register + * + * @return node, interface and port number, will be -1 for invalid address. + */ +static struct cvmx_xiface __cvmx_bgx_reg_addr_to_xiface(u64 bgx_addr) +{ + struct cvmx_xiface xi = { -1, -1 }; + + xi.node = cvmx_csr_addr_to_node(bgx_addr); + bgx_addr = cvmx_csr_addr_strip_node(bgx_addr); + if ((bgx_addr & 0xFFFFFFFFF0000000) != 0x00011800E0000000) { + debug("%s: Invalid BGX address 0x%llx\n", __func__, + (unsigned long long)bgx_addr); + xi.node = -1; + return xi; + } + xi.interface = (bgx_addr >> 24) & 0x0F; + + return xi; +} + +static cvmx_helper_link_info_t +__get_marvell_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + int phy_status; + u32 phy_addr = phy_info->phy_addr; + + result.u64 = 0; + /* Set to page 0 */ + cvmx_mdio_write(phy_addr >> 8, phy_addr & 0xff, 22, 0); + /* All the speed information can be read from register 17 in one go. */ + phy_status = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 17); + + /* If the resolve bit 11 isn't set, see if autoneg is turned off + * (bit 12, reg 0). The resolve bit doesn't get set properly when + * autoneg is off, so force it + */ + if ((phy_status & (1 << 11)) == 0) { + int auto_status = + cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0); + if ((auto_status & (1 << 12)) == 0) + phy_status |= 1 << 11; + } + + /* Link is up = Speed/Duplex Resolved + RT-Link Up + G-Link Up. */ + if ((phy_status & 0x0c08) == 0x0c08) { + result.s.link_up = 1; + result.s.full_duplex = ((phy_status >> 13) & 1); + switch ((phy_status >> 14) & 3) { + case 0: /* 10 Mbps */ + result.s.speed = 10; + break; + case 1: /* 100 Mbps */ + result.s.speed = 100; + break; + case 2: /* 1 Gbps */ + result.s.speed = 1000; + break; + case 3: /* Illegal */ + result.u64 = 0; + break; + } + } + return result; +} + +/** + * @INTERNAL + * Get link state of broadcom PHY + * + * @param phy_info PHY information + */ +static cvmx_helper_link_info_t +__get_broadcom_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + u32 phy_addr = phy_info->phy_addr; + int phy_status; + + result.u64 = 0; + /* Below we are going to read SMI/MDIO register 0x19 which works + * on Broadcom parts + */ + phy_status = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0x19); + switch ((phy_status >> 8) & 0x7) { + case 0: + result.u64 = 0; + break; + case 1: + result.s.link_up = 1; + result.s.full_duplex = 0; + result.s.speed = 10; + break; + case 2: + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 10; + break; + case 3: + result.s.link_up = 1; + result.s.full_duplex = 0; + result.s.speed = 100; + break; + case 4: + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 100; + break; + case 5: + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 100; + break; + case 6: + result.s.link_up = 1; + result.s.full_duplex = 0; + result.s.speed = 1000; + break; + case 7: + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 1000; + break; + } + return result; +} + +/** + * @INTERNAL + * Get link state of generic gigabit PHY + * + * @param phy_info - information about the PHY + * + * @returns link status of the PHY + */ +static cvmx_helper_link_info_t +__cvmx_get_generic_8023_c22_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + u32 phy_addr = phy_info->phy_addr; + int phy_basic_control; /* Register 0x0 */ + int phy_basic_status; /* Register 0x1 */ + int phy_anog_adv; /* Register 0x4 */ + int phy_link_part_avail; /* Register 0x5 */ + int phy_control; /* Register 0x9 */ + int phy_status; /* Register 0xA */ + + result.u64 = 0; + + phy_basic_status = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 1); + if (!(phy_basic_status & 0x4)) /* Check if link is up */ + return result; /* Link is down, return link down */ + + result.s.link_up = 1; + phy_basic_control = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0); + /* Check if autonegotiation is enabled and completed */ + if ((phy_basic_control & (1 << 12)) && (phy_basic_status & (1 << 5))) { + phy_status = + cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0xA); + phy_control = + cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0x9); + + phy_status &= phy_control << 2; + phy_link_part_avail = + cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0x5); + phy_anog_adv = + cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0x4); + phy_link_part_avail &= phy_anog_adv; + + if (phy_status & 0xC00) { /* Gigabit full or half */ + result.s.speed = 1000; + result.s.full_duplex = !!(phy_status & 0x800); + } else if (phy_link_part_avail & + 0x0180) { /* 100 full or half */ + result.s.speed = 100; + result.s.full_duplex = !!(phy_link_part_avail & 0x100); + } else if (phy_link_part_avail & 0x0060) { + result.s.speed = 10; + result.s.full_duplex = !!(phy_link_part_avail & 0x0040); + } + } else { + /* Not autonegotiated */ + result.s.full_duplex = !!(phy_basic_control & (1 << 8)); + + if (phy_basic_control & (1 << 6)) + result.s.speed = 1000; + else if (phy_basic_control & (1 << 13)) + result.s.speed = 100; + else + result.s.speed = 10; + } + return result; +} + +static cvmx_helper_link_info_t +__cvmx_get_qualcomm_s17_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + u32 phy_addr = phy_info->phy_addr; + int phy_status; + int auto_status; + + result.u64 = 0; + + phy_status = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 17); + + /* If bit 11 isn't set see if autonegotiation is turned off + * (bit 12, reg 0). The resolved bit doesn't get set properly when + * autonegotiation is off, so force it. + */ + if ((phy_status & (1 << 11)) == 0) { + auto_status = cvmx_mdio_read(phy_addr >> 8, phy_addr & 0xff, 0); + if ((auto_status & (1 << 12)) == 0) + phy_status |= 1 << 11; + } + /* Only return a link if the PHY has finished autonegotiation and set + * the resolved bit (bit 11). + */ + if (phy_status & (1 << 11)) { + result.s.link_up = 1; + result.s.full_duplex = !!(phy_status & (1 << 13)); + switch ((phy_status >> 14) & 3) { + case 0: /* 10Mbps */ + result.s.speed = 10; + break; + case 1: /* 100Mbps */ + result.s.speed = 100; + break; + case 2: /* 1Gbps */ + result.s.speed = 1000; + break; + default: /* Illegal */ + result.u64 = 0; + break; + } + } + debug(" link: %s, duplex: %s, speed: %lu\n", + result.s.link_up ? "up" : "down", + result.s.full_duplex ? "full" : "half", + (unsigned long)result.s.speed); + return result; +} + +static cvmx_helper_link_info_t +__get_generic_8023_c45_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + int phy_status; + int pma_ctrl1; + u32 phy_addr = phy_info->phy_addr; + + result.u64 = 0; + pma_ctrl1 = cvmx_mdio_45_read(phy_addr >> 8, phy_addr & 0xff, 1, 0); + if ((pma_ctrl1 & 0x207c) == 0x2040) + result.s.speed = 10000; + /* PMA Status 1 (1x0001) */ + phy_status = cvmx_mdio_45_read(phy_addr >> 8, phy_addr & 0xff, 1, 0xa); + if (phy_status < 0) + return result; + + result.s.full_duplex = 1; + if ((phy_status & 1) == 0) + return result; + phy_status = cvmx_mdio_45_read(phy_addr >> 8, phy_addr & 0xff, 4, 0x18); + if (phy_status < 0) + return result; + result.s.link_up = (phy_status & 0x1000) ? 1 : 0; + + return result; +} + +static cvmx_helper_link_info_t +__cvmx_get_cortina_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 1000; + return result; +} + +static cvmx_helper_link_info_t +__get_vitesse_vsc8490_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 1000; + return result; +} + +static cvmx_helper_link_info_t +__get_aquantia_phy_link_state(cvmx_phy_info_t *phy_info) +{ + cvmx_helper_link_info_t result; + + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = 1000; + return result; +} + +static int __cvmx_helper_78xx_parse_phy(struct cvmx_phy_info *phy_info, + int ipd_port) +{ + const void *fdt_addr = CASTPTR(const void *, gd->fdt_blob); + const char *compat; + int phy; + int parent; + u64 mdio_base; + int node, bus; + int phy_addr; + int index = cvmx_helper_get_interface_index_num(ipd_port); + int xiface = cvmx_helper_get_interface_num(ipd_port); + int compat_len = 0; + + debug("%s(0x%p, %d) ENTER\n", __func__, phy_info, ipd_port); + + phy = cvmx_helper_get_phy_fdt_node_offset(xiface, index); + debug("%s: xiface: 0x%x, index: %d, ipd_port: %d, phy fdt offset: %d\n", + __func__, xiface, index, ipd_port, phy); + if (phy < 0) { + /* If this is the first time through we need to first parse the + * device tree to get the node offsets. + */ + debug("No config present, calling __cvmx_helper_parse_bgx_dt\n"); + if (__cvmx_helper_parse_bgx_dt(fdt_addr)) { + printf("Error: could not parse BGX device tree\n"); + return -1; + } + if (__cvmx_fdt_parse_vsc7224(fdt_addr)) { + debug("Error: could not parse Microsemi VSC7224 in DT\n"); + return -1; + } + if (octeon_has_feature(OCTEON_FEATURE_BGX_XCV) && + __cvmx_helper_parse_bgx_rgmii_dt(fdt_addr)) { + printf("Error: could not parse BGX XCV device tree\n"); + return -1; + } + phy = cvmx_helper_get_phy_fdt_node_offset(xiface, index); + if (phy < 0) { + debug("%s: Could not get PHY node offset for IPD port 0x%x, xiface: 0x%x, index: %d\n", + __func__, ipd_port, xiface, index); + return -1; + } + debug("%s: phy: %d (%s)\n", __func__, phy, + fdt_get_name(fdt_addr, phy, NULL)); + } + + compat = (const char *)fdt_getprop(fdt_addr, phy, "compatible", + &compat_len); + if (!compat) { + printf("ERROR: %d:%d:no compatible prop in phy\n", xiface, + index); + return -1; + } + + debug(" compatible: %s\n", compat); + + phy_info->fdt_offset = phy; + phy_addr = cvmx_fdt_get_int(fdt_addr, phy, "reg", -1); + if (phy_addr == -1) { + printf("Error: %d:%d:could not get PHY address\n", xiface, + index); + return -1; + } + debug(" PHY address: %d, compat: %s\n", phy_addr, compat); + + if (!memcmp("marvell", compat, strlen("marvell"))) { + phy_info->phy_type = MARVELL_GENERIC_PHY; + phy_info->link_function = __get_marvell_phy_link_state; + } else if (!memcmp("broadcom", compat, strlen("broadcom"))) { + phy_info->phy_type = BROADCOM_GENERIC_PHY; + phy_info->link_function = __get_broadcom_phy_link_state; + } else if (!memcmp("cortina", compat, strlen("cortina"))) { + phy_info->phy_type = CORTINA_PHY; + phy_info->link_function = __cvmx_get_cortina_phy_link_state; + } else if (!strcmp("vitesse,vsc8490", compat)) { + phy_info->phy_type = VITESSE_VSC8490_PHY; + phy_info->link_function = __get_vitesse_vsc8490_phy_link_state; + } else if (fdt_stringlist_contains(compat, compat_len, + "ethernet-phy-ieee802.3-c22")) { + phy_info->phy_type = GENERIC_8023_C22_PHY; + phy_info->link_function = + __cvmx_get_generic_8023_c22_phy_link_state; + } else if (fdt_stringlist_contains(compat, compat_len, + "ethernet-phy-ieee802.3-c45")) { + phy_info->phy_type = GENERIC_8023_C22_PHY; + phy_info->link_function = __get_generic_8023_c45_phy_link_state; + } + + phy_info->ipd_port = ipd_port; + phy_info->phy_sub_addr = 0; + phy_info->direct_connect = 1; + + parent = fdt_parent_offset(fdt_addr, phy); + if (!fdt_node_check_compatible(fdt_addr, parent, + "ethernet-phy-nexus")) { + debug(" nexus PHY found\n"); + if (phy_info->phy_type == CORTINA_PHY) { + /* The Cortina CS422X uses the same PHY device for + * multiple ports for XFI. In this case we use a + * nexus and each PHY address is the slice or + * sub-address and the actual PHY address is the + * nexus address. + */ + phy_info->phy_sub_addr = phy_addr; + phy_addr = + cvmx_fdt_get_int(fdt_addr, parent, "reg", -1); + debug(" Cortina PHY real address: 0x%x\n", phy_addr); + } + parent = fdt_parent_offset(fdt_addr, parent); + } + + debug(" Parent: %s\n", fdt_get_name(fdt_addr, parent, NULL)); + if (!fdt_node_check_compatible(fdt_addr, parent, + "cavium,octeon-3860-mdio")) { + debug(" Found Octeon MDIO\n"); + mdio_base = cvmx_fdt_get_uint64(fdt_addr, parent, "reg", + FDT_ADDR_T_NONE); + debug(" MDIO address: 0x%llx\n", + (unsigned long long)mdio_base); + + mdio_base = cvmx_fdt_translate_address(fdt_addr, parent, + (u32 *)&mdio_base); + debug(" Translated: 0x%llx\n", (unsigned long long)mdio_base); + if (mdio_base == FDT_ADDR_T_NONE) { + printf("Could not get MDIO base address from reg field\n"); + return -1; + } + __cvmx_mdio_addr_to_node_bus(mdio_base, &node, &bus); + if (bus < 0) { + printf("Invalid MDIO address 0x%llx, could not detect bus and node\n", + (unsigned long long)mdio_base); + return -1; + } + debug(" MDIO node: %d, bus: %d\n", node, bus); + phy_info->mdio_unit = (node << 2) | (bus & 3); + phy_info->phy_addr = phy_addr | (phy_info->mdio_unit << 8); + } else { + printf("%s: Error: incompatible MDIO bus %s for IPD port %d\n", + __func__, + (const char *)fdt_get_name(fdt_addr, parent, NULL), + ipd_port); + return -1; + } + + debug("%s: EXIT 0\n", __func__); + + return 0; +} + +/** + * Return the MII PHY address associated with the given IPD + * port. The phy address is obtained from the device tree. + * + * @param[out] phy_info - PHY information data structure updated + * @param ipd_port Octeon IPD port to get the MII address for. + * + * @return MII PHY address and bus number, -1 on error, -2 if PHY info missing (OK). + */ +static int __get_phy_info_from_dt(cvmx_phy_info_t *phy_info, int ipd_port) +{ + const void *fdt_addr = CASTPTR(const void *, gd->fdt_blob); + int aliases, eth, phy, phy_parent, ret, i; + int mdio_parent; + const char *phy_compatible_str; + const char *host_mode_str = NULL; + int interface; + int phy_addr_offset = 0; + + debug("%s(%p, %d)\n", __func__, phy_info, ipd_port); + + if (octeon_has_feature(OCTEON_FEATURE_BGX)) + return __cvmx_helper_78xx_parse_phy(phy_info, ipd_port); + + phy_info->phy_addr = -1; + phy_info->phy_sub_addr = 0; + phy_info->ipd_port = ipd_port; + phy_info->direct_connect = -1; + phy_info->phy_type = (cvmx_phy_type_t)-1; + for (i = 0; i < CVMX_PHY_MUX_MAX_GPIO; i++) + phy_info->gpio[i] = -1; + phy_info->mdio_unit = -1; + phy_info->gpio_value = -1; + phy_info->gpio_parent_mux_twsi = -1; + phy_info->gpio_parent_mux_select = -1; + phy_info->link_function = NULL; + phy_info->fdt_offset = -1; + if (!fdt_addr) { + debug("No device tree found.\n"); + return -1; + } + + aliases = fdt_path_offset(fdt_addr, "/aliases"); + if (aliases < 0) { + debug("Error: No /aliases node in device tree.\n"); + return -1; + } + if (ipd_port < 0) { + int interface_index = + ipd_port - CVMX_HELPER_BOARD_MGMT_IPD_PORT; + eth = __mix_eth_node(fdt_addr, aliases, interface_index); + } else { + eth = __pip_eth_node(fdt_addr, aliases, ipd_port); + } + if (eth < 0) { + debug("ERROR : cannot find interface for ipd_port=%d\n", + ipd_port); + return -1; + } + + interface = cvmx_helper_get_interface_num(ipd_port); + /* Get handle to phy */ + phy = cvmx_fdt_lookup_phandle(fdt_addr, eth, "phy-handle"); + if (phy < 0) { + cvmx_helper_interface_mode_t if_mode; + + /* Note that it's OK for RXAUI and ILK to not have a PHY + * connected (i.e. EBB boards in loopback). + */ + debug("Cannot get phy-handle for ipd_port: %d\n", ipd_port); + if_mode = cvmx_helper_interface_get_mode(interface); + if (if_mode != CVMX_HELPER_INTERFACE_MODE_RXAUI && + if_mode != CVMX_HELPER_INTERFACE_MODE_ILK) { + debug("ERROR : phy handle not found in device tree ipd_port=%d\n", + ipd_port); + return -1; + } else { + return -2; + } + } + + phy_compatible_str = + (const char *)fdt_getprop(fdt_addr, phy, "compatible", NULL); + if (!phy_compatible_str) { + debug("ERROR: no compatible prop in phy\n"); + return -1; + } + debug("Checking compatible string "%s" for ipd port %d\n", + phy_compatible_str, ipd_port); + phy_info->fdt_offset = phy; + if (!memcmp("marvell", phy_compatible_str, strlen("marvell"))) { + debug("Marvell PHY detected for ipd_port %d\n", ipd_port); + phy_info->phy_type = MARVELL_GENERIC_PHY; + phy_info->link_function = __get_marvell_phy_link_state; + } else if (!memcmp("broadcom", phy_compatible_str, + strlen("broadcom"))) { + phy_info->phy_type = BROADCOM_GENERIC_PHY; + phy_info->link_function = __get_broadcom_phy_link_state; + debug("Broadcom PHY detected for ipd_port %d\n", ipd_port); + } else if (!memcmp("vitesse", phy_compatible_str, strlen("vitesse"))) { + debug("Vitesse PHY detected for ipd_port %d\n", ipd_port); + if (!fdt_node_check_compatible(fdt_addr, phy, + "vitesse,vsc8490")) { + phy_info->phy_type = VITESSE_VSC8490_PHY; + debug("Vitesse VSC8490 detected\n"); + phy_info->link_function = + __get_vitesse_vsc8490_phy_link_state; + } else if (!fdt_node_check_compatible( + fdt_addr, phy, + "ethernet-phy-ieee802.3-c22")) { + phy_info->phy_type = GENERIC_8023_C22_PHY; + phy_info->link_function = + __cvmx_get_generic_8023_c22_phy_link_state; + debug("Vitesse 802.3 c22 detected\n"); + } else { + phy_info->phy_type = GENERIC_8023_C45_PHY; + phy_info->link_function = + __get_generic_8023_c45_phy_link_state; + debug("Vitesse 802.3 c45 detected\n"); + } + } else if (!memcmp("aquantia", phy_compatible_str, + strlen("aquantia"))) { + phy_info->phy_type = AQUANTIA_PHY; + phy_info->link_function = __get_aquantia_phy_link_state; + debug("Aquantia c45 PHY detected\n"); + } else if (!memcmp("cortina", phy_compatible_str, strlen("cortina"))) { + phy_info->phy_type = CORTINA_PHY; + phy_info->link_function = __cvmx_get_cortina_phy_link_state; + host_mode_str = (const char *)fdt_getprop( + fdt_addr, phy, "cortina,host-mode", NULL); + debug("Cortina PHY detected for ipd_port %d\n", ipd_port); + } else if (!memcmp("ti", phy_compatible_str, strlen("ti"))) { + phy_info->phy_type = GENERIC_8023_C45_PHY; + phy_info->link_function = __get_generic_8023_c45_phy_link_state; + debug("TI PHY detected for ipd_port %d\n", ipd_port); + } else if (!fdt_node_check_compatible(fdt_addr, phy, + "atheros,ar8334") || + !fdt_node_check_compatible(fdt_addr, phy, + "qualcomm,qca8334") || + !fdt_node_check_compatible(fdt_addr, phy, + "atheros,ar8337") || + !fdt_node_check_compatible(fdt_addr, phy, + "qualcomm,qca8337")) { + phy_info->phy_type = QUALCOMM_S17; + phy_info->link_function = + __cvmx_get_qualcomm_s17_phy_link_state; + debug("Qualcomm QCA833X switch detected\n"); + } else if (!fdt_node_check_compatible(fdt_addr, phy, + "ethernet-phy-ieee802.3-c22")) { + phy_info->phy_type = GENERIC_8023_C22_PHY; + phy_info->link_function = + __cvmx_get_generic_8023_c22_phy_link_state; + debug("Generic 802.3 c22 PHY detected\n"); + } else if (!fdt_node_check_compatible(fdt_addr, phy, + "ethernet-phy-ieee802.3-c45")) { + phy_info->phy_type = GENERIC_8023_C45_PHY; + phy_info->link_function = __get_generic_8023_c45_phy_link_state; + debug("Generic 802.3 c45 PHY detected\n"); + } else { + debug("Unknown PHY compatibility\n"); + phy_info->phy_type = (cvmx_phy_type_t)-1; + phy_info->link_function = NULL; + } + + phy_info->host_mode = CVMX_PHY_HOST_MODE_UNKNOWN; + if (host_mode_str) { + if (strcmp(host_mode_str, "rxaui") == 0) + phy_info->host_mode = CVMX_PHY_HOST_MODE_RXAUI; + else if (strcmp(host_mode_str, "xaui") == 0) + phy_info->host_mode = CVMX_PHY_HOST_MODE_XAUI; + else if (strcmp(host_mode_str, "sgmii") == 0) + phy_info->host_mode = CVMX_PHY_HOST_MODE_SGMII; + else if (strcmp(host_mode_str, "qsgmii") == 0) + phy_info->host_mode = CVMX_PHY_HOST_MODE_QSGMII; + else + debug("Unknown PHY host mode\n"); + } + + /* Check if PHY parent is the octeon MDIO bus. Some boards are connected + * though a MUX and for them direct_connect_to_phy will be 0 + */ + phy_parent = fdt_parent_offset(fdt_addr, phy); + if (phy_parent < 0) { + debug("ERROR : cannot find phy parent for ipd_port=%d ret=%d\n", + ipd_port, phy_parent); + return -1; + } + /* For multi-phy devices and devices on a MUX, go to the parent */ + ret = fdt_node_check_compatible(fdt_addr, phy_parent, + "ethernet-phy-nexus"); + if (ret == 0) { + /* It's a nexus so check the grandparent. */ + phy_addr_offset = + cvmx_fdt_get_int(fdt_addr, phy_parent, "reg", 0); + phy_parent = fdt_parent_offset(fdt_addr, phy_parent); + } + + /* Check for a muxed MDIO interface */ + mdio_parent = fdt_parent_offset(fdt_addr, phy_parent); + ret = fdt_node_check_compatible(fdt_addr, mdio_parent, + "cavium,mdio-mux"); + if (ret == 0) { + ret = __get_muxed_mdio_info_from_dt(phy_info, phy_parent, + mdio_parent); + if (ret) { + printf("Error reading mdio mux information for ipd port %d\n", + ipd_port); + return -1; + } + } + ret = fdt_node_check_compatible(fdt_addr, phy_parent, + "cavium,octeon-3860-mdio"); + if (ret == 0) { + u32 *mdio_reg_base = + (u32 *)fdt_getprop(fdt_addr, phy_parent, "reg", 0); + phy_info->direct_connect = 1; + if (mdio_reg_base == 0) { + debug("ERROR : unable to get reg property in phy mdio\n"); + return -1; + } + phy_info->mdio_unit = + __mdiobus_addr_to_unit(fdt32_to_cpu(mdio_reg_base[1])); + debug("phy parent=%s reg_base=%08x mdio_unit=%d\n", + fdt_get_name(fdt_addr, phy_parent, NULL), + (int)mdio_reg_base[1], phy_info->mdio_unit); + } else { + phy_info->direct_connect = 0; + /* The PHY is not directly connected to the Octeon MDIO bus. + * SE doesn't have abstractions for MDIO MUX or MDIO MUX + * drivers and hence for the non direct cases code will be + * needed which is board specific. + * For now the MDIO Unit is defaulted to 1. + */ + debug("%s PHY at address: %d is not directly connected\n", + __func__, phy_info->phy_addr); + } + + phy_info->phy_addr = cvmx_fdt_get_int(fdt_addr, phy, "reg", -1); + if (phy_info->phy_addr < 0) { + debug("ERROR: Could not read phy address from reg in DT\n"); + return -1; + } + phy_info->phy_addr += phy_addr_offset; + phy_info->phy_addr |= phy_info->mdio_unit << 8; + debug("%s(%p, %d) => 0x%x\n", __func__, phy_info, ipd_port, + phy_info->phy_addr); + return phy_info->phy_addr; +} + +/** + * @INTERNAL + * Parse the device tree and set whether a port is valid or not. + * + * @param fdt_addr Pointer to device tree + * + * @return 0 for success, -1 on error. + */ +int __cvmx_helper_parse_bgx_dt(const void *fdt_addr) +{ + int port_index; + struct cvmx_xiface xi; + int fdt_port_node = -1; + int fdt_interface_node; + int fdt_phy_node; + u64 reg_addr; + int xiface; + struct cvmx_phy_info *phy_info; + static bool parsed; + int err; + int ipd_port; + + if (parsed) { + debug("%s: Already parsed\n", __func__); + return 0; + } + while ((fdt_port_node = fdt_node_offset_by_compatible( + fdt_addr, fdt_port_node, + "cavium,octeon-7890-bgx-port")) >= 0) { + /* Get the port number */ + port_index = + cvmx_fdt_get_int(fdt_addr, fdt_port_node, "reg", -1); + if (port_index < 0) { + debug("Error: missing reg field for bgx port in device tree\n"); + return -1; + } + debug("%s: Parsing BGX port %d\n", __func__, port_index); + /* Get the interface number */ + fdt_interface_node = fdt_parent_offset(fdt_addr, fdt_port_node); + if (fdt_interface_node < 0) { + debug("Error: device tree corrupt!\n"); + return -1; + } + if (fdt_node_check_compatible(fdt_addr, fdt_interface_node, + "cavium,octeon-7890-bgx")) { + debug("Error: incompatible Ethernet MAC Nexus in device tree!\n"); + return -1; + } + reg_addr = + cvmx_fdt_get_addr(fdt_addr, fdt_interface_node, "reg"); + debug("%s: BGX interface address: 0x%llx\n", __func__, + (unsigned long long)reg_addr); + if (reg_addr == FDT_ADDR_T_NONE) { + debug("Device tree BGX node has invalid address 0x%llx\n", + (unsigned long long)reg_addr); + return -1; + } + reg_addr = cvmx_fdt_translate_address(fdt_addr, + fdt_interface_node, + (u32 *)®_addr); + xi = __cvmx_bgx_reg_addr_to_xiface(reg_addr); + if (xi.node < 0) { + debug("Device tree BGX node has invalid address 0x%llx\n", + (unsigned long long)reg_addr); + return -1; + } + debug("%s: Found BGX node %d, interface %d\n", __func__, + xi.node, xi.interface); + xiface = cvmx_helper_node_interface_to_xiface(xi.node, + xi.interface); + cvmx_helper_set_port_fdt_node_offset(xiface, port_index, + fdt_port_node); + cvmx_helper_set_port_valid(xiface, port_index, true); + + cvmx_helper_set_port_fdt_node_offset(xiface, port_index, + fdt_port_node); + if (fdt_getprop(fdt_addr, fdt_port_node, + "cavium,sgmii-mac-phy-mode", NULL)) + cvmx_helper_set_mac_phy_mode(xiface, port_index, true); + else + cvmx_helper_set_mac_phy_mode(xiface, port_index, false); + + if (fdt_getprop(fdt_addr, fdt_port_node, "cavium,force-link-up", + NULL)) + cvmx_helper_set_port_force_link_up(xiface, port_index, + true); + else + cvmx_helper_set_port_force_link_up(xiface, port_index, + false); + + if (fdt_getprop(fdt_addr, fdt_port_node, + "cavium,sgmii-mac-1000x-mode", NULL)) + cvmx_helper_set_1000x_mode(xiface, port_index, true); + else + cvmx_helper_set_1000x_mode(xiface, port_index, false); + + if (fdt_getprop(fdt_addr, fdt_port_node, + "cavium,disable-autonegotiation", NULL)) + cvmx_helper_set_port_autonegotiation(xiface, port_index, + false); + else + cvmx_helper_set_port_autonegotiation(xiface, port_index, + true); + + fdt_phy_node = cvmx_fdt_lookup_phandle(fdt_addr, fdt_port_node, + "phy-handle"); + if (fdt_phy_node >= 0) { + cvmx_helper_set_phy_fdt_node_offset(xiface, port_index, + fdt_phy_node); + debug("%s: Setting PHY fdt node offset for interface 0x%x, port %d to %d\n", + __func__, xiface, port_index, fdt_phy_node); + debug("%s: PHY node name: %s\n", __func__, + fdt_get_name(fdt_addr, fdt_phy_node, NULL)); + cvmx_helper_set_port_phy_present(xiface, port_index, + true); + ipd_port = cvmx_helper_get_ipd_port(xiface, port_index); + if (ipd_port >= 0) { + debug("%s: Allocating phy info for 0x%x:%d\n", + __func__, xiface, port_index); + phy_info = + (cvmx_phy_info_t *)cvmx_bootmem_alloc( + sizeof(*phy_info), 0); + if (!phy_info) { + debug("%s: Out of memory\n", __func__); + return -1; + } + memset(phy_info, 0, sizeof(*phy_info)); + phy_info->phy_addr = -1; + err = __get_phy_info_from_dt(phy_info, + ipd_port); + if (err) { + debug("%s: Error parsing phy info for ipd port %d\n", + __func__, ipd_port); + return -1; + } + cvmx_helper_set_port_phy_info( + xiface, port_index, phy_info); + debug("%s: Saved phy info\n", __func__); + } + } else { + cvmx_helper_set_phy_fdt_node_offset(xiface, port_index, + -1); + debug("%s: No PHY fdt node offset for interface 0x%x, port %d to %d\n", + __func__, xiface, port_index, fdt_phy_node); + cvmx_helper_set_port_phy_present(xiface, port_index, + false); + } + } + if (!sfp_parsed) + if (cvmx_sfp_parse_device_tree(fdt_addr)) + debug("%s: Error parsing SFP device tree\n", __func__); + parsed = true; + return 0; +} + +int __cvmx_helper_parse_bgx_rgmii_dt(const void *fdt_addr) +{ + u64 reg_addr; + struct cvmx_xiface xi; + int fdt_port_node = -1; + int fdt_interface_node; + int fdt_phy_node; + int port_index; + int xiface; + + /* There's only one xcv (RGMII) interface, so just search for the one + * that's part of a BGX entry. + */ + while ((fdt_port_node = fdt_node_offset_by_compatible( + fdt_addr, fdt_port_node, "cavium,octeon-7360-xcv")) >= + 0) { + fdt_interface_node = fdt_parent_offset(fdt_addr, fdt_port_node); + if (fdt_interface_node < 0) { + printf("Error: device tree corrupt!\n"); + return -1; + } + debug("%s: XCV parent node compatible: %s\n", __func__, + (char *)fdt_getprop(fdt_addr, fdt_interface_node, + "compatible", NULL)); + if (!fdt_node_check_compatible(fdt_addr, fdt_interface_node, + "cavium,octeon-7890-bgx")) + break; + } + if (fdt_port_node == -FDT_ERR_NOTFOUND) { + debug("No XCV/RGMII interface found in device tree\n"); + return 0; + } else if (fdt_port_node < 0) { + debug("%s: Error %d parsing device tree\n", __func__, + fdt_port_node); + return -1; + } + port_index = cvmx_fdt_get_int(fdt_addr, fdt_port_node, "reg", -1); + if (port_index != 0) { + printf("%s: Error: port index (reg) must be 0, not %d.\n", + __func__, port_index); + return -1; + } + reg_addr = cvmx_fdt_get_addr(fdt_addr, fdt_interface_node, "reg"); + if (reg_addr == FDT_ADDR_T_NONE) { + printf("%s: Error: could not get BGX interface address\n", + __func__); + return -1; + } + /* We don't have to bother translating since only 78xx supports OCX and + * doesn't support RGMII. + */ + xi = __cvmx_bgx_reg_addr_to_xiface(reg_addr); + debug("%s: xi.node: %d, xi.interface: 0x%x, addr: 0x%llx\n", __func__, + xi.node, xi.interface, (unsigned long long)reg_addr); + if (xi.node < 0) { + printf("%s: Device tree BGX node has invalid address 0x%llx\n", + __func__, (unsigned long long)reg_addr); + return -1; + } + debug("%s: Found XCV (RGMII) interface on interface %d\n", __func__, + xi.interface); + debug(" phy handle: 0x%x\n", + cvmx_fdt_get_int(fdt_addr, fdt_port_node, "phy-handle", -1)); + fdt_phy_node = + cvmx_fdt_lookup_phandle(fdt_addr, fdt_port_node, "phy-handle"); + debug("%s: phy-handle node: 0x%x\n", __func__, fdt_phy_node); + xiface = cvmx_helper_node_interface_to_xiface(xi.node, xi.interface); + + cvmx_helper_set_port_fdt_node_offset(xiface, port_index, fdt_port_node); + if (fdt_phy_node >= 0) { + debug("%s: Setting PHY fdt node offset for interface 0x%x, port %d to %d\n", + __func__, xiface, port_index, fdt_phy_node); + debug("%s: PHY node name: %s\n", __func__, + fdt_get_name(fdt_addr, fdt_phy_node, NULL)); + cvmx_helper_set_phy_fdt_node_offset(xiface, port_index, + fdt_phy_node); + cvmx_helper_set_port_phy_present(xiface, port_index, true); + } else { + cvmx_helper_set_phy_fdt_node_offset(xiface, port_index, -1); + debug("%s: No PHY fdt node offset for interface 0x%x, port %d to %d\n", + __func__, xiface, port_index, fdt_phy_node); + cvmx_helper_set_port_phy_present(xiface, port_index, false); + } + + return 0; +} + +/** + * Returns if a port is present on an interface + * + * @param fdt_addr - address fo flat device tree + * @param ipd_port - IPD port number + * + * @return 1 if port is present, 0 if not present, -1 if error + */ +int __cvmx_helper_board_get_port_from_dt(void *fdt_addr, int ipd_port) +{ + int port_index; + int aliases; + const char *pip_path; + char name_buffer[24]; + int pip, iface, eth; + cvmx_helper_interface_mode_t mode; + int xiface = cvmx_helper_get_interface_num(ipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + u32 val; + int phy_node_offset; + int parse_bgx_dt_err; + int parse_vsc7224_err; + + debug("%s(%p, %d)\n", __func__, fdt_addr, ipd_port); + if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + static int fdt_ports_initialized; + + port_index = cvmx_helper_get_interface_index_num(ipd_port); + + if (!fdt_ports_initialized) { + if (octeon_has_feature(OCTEON_FEATURE_BGX_XCV)) { + if (!__cvmx_helper_parse_bgx_rgmii_dt(fdt_addr)) + fdt_ports_initialized = 1; + parse_bgx_dt_err = + __cvmx_helper_parse_bgx_dt(fdt_addr); + parse_vsc7224_err = + __cvmx_fdt_parse_vsc7224(fdt_addr); + if (!parse_bgx_dt_err && !parse_vsc7224_err) + fdt_ports_initialized = 1; + } else { + debug("%s: Error parsing FDT\n", __func__); + return -1; + } + } + + return cvmx_helper_is_port_valid(xiface, port_index); + } + + mode = cvmx_helper_interface_get_mode(xiface); + + switch (mode) { + /* Device tree has information about the following mode types. */ + case CVMX_HELPER_INTERFACE_MODE_RGMII: + case CVMX_HELPER_INTERFACE_MODE_GMII: + case CVMX_HELPER_INTERFACE_MODE_SPI: + case CVMX_HELPER_INTERFACE_MODE_XAUI: + case CVMX_HELPER_INTERFACE_MODE_SGMII: + case CVMX_HELPER_INTERFACE_MODE_QSGMII: + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_AGL: + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_XFI: + aliases = 1; + break; + default: + aliases = 0; + break; + } + + /* The device tree information is present on interfaces that have phy */ + if (!aliases) + return 1; + + port_index = cvmx_helper_get_interface_index_num(ipd_port); + + aliases = fdt_path_offset(fdt_addr, "/aliases"); + if (aliases < 0) { + debug("%s: ERROR: /aliases not found in device tree fdt_addr=%p\n", + __func__, fdt_addr); + return -1; + } + + pip_path = (const char *)fdt_getprop(fdt_addr, aliases, "pip", NULL); + if (!pip_path) { + debug("%s: ERROR: interface %x pip path not found in device tree\n", + __func__, xiface); + return -1; + } + pip = fdt_path_offset(fdt_addr, pip_path); + if (pip < 0) { + debug("%s: ERROR: interface %x pip not found in device tree\n", + __func__, xiface); + return -1; + } + snprintf(name_buffer, sizeof(name_buffer), "interface@%d", + xi.interface); + iface = fdt_subnode_offset(fdt_addr, pip, name_buffer); + if (iface < 0) + return 0; + snprintf(name_buffer, sizeof(name_buffer), "ethernet@%x", port_index); + eth = fdt_subnode_offset(fdt_addr, iface, name_buffer); + debug("%s: eth subnode offset %d from %s\n", __func__, eth, + name_buffer); + + if (eth < 0) + return -1; + + cvmx_helper_set_port_fdt_node_offset(xiface, port_index, eth); + + phy_node_offset = cvmx_fdt_get_int(fdt_addr, eth, "phy", -1); + cvmx_helper_set_phy_fdt_node_offset(xiface, port_index, + phy_node_offset); + + if (fdt_getprop(fdt_addr, eth, "cavium,sgmii-mac-phy-mode", NULL)) + cvmx_helper_set_mac_phy_mode(xiface, port_index, true); + else + cvmx_helper_set_mac_phy_mode(xiface, port_index, false); + + if (fdt_getprop(fdt_addr, eth, "cavium,force-link-up", NULL)) + cvmx_helper_set_port_force_link_up(xiface, port_index, true); + else + cvmx_helper_set_port_force_link_up(xiface, port_index, false); + + if (fdt_getprop(fdt_addr, eth, "cavium,sgmii-mac-1000x-mode", NULL)) + cvmx_helper_set_1000x_mode(xiface, port_index, true); + else + cvmx_helper_set_1000x_mode(xiface, port_index, false); + + if (fdt_getprop(fdt_addr, eth, "cavium,disable-autonegotiation", NULL)) + cvmx_helper_set_port_autonegotiation(xiface, port_index, false); + else + cvmx_helper_set_port_autonegotiation(xiface, port_index, true); + + if (mode == CVMX_HELPER_INTERFACE_MODE_AGL) { + bool tx_bypass = false; + + if (fdt_getprop(fdt_addr, eth, "cavium,rx-clk-delay-bypass", + NULL)) + cvmx_helper_set_agl_rx_clock_delay_bypass( + xiface, port_index, true); + else + cvmx_helper_set_agl_rx_clock_delay_bypass( + xiface, port_index, false); + + val = cvmx_fdt_get_int(fdt_addr, eth, "cavium,rx-clk-skew", 0); + cvmx_helper_set_agl_rx_clock_skew(xiface, port_index, val); + + if (fdt_getprop(fdt_addr, eth, "cavium,tx-clk-delay-bypass", + NULL)) + tx_bypass = true; + + val = cvmx_fdt_get_int(fdt_addr, eth, "tx-clk-delay", 0); + cvmx_helper_cfg_set_rgmii_tx_clk_delay(xiface, port_index, + tx_bypass, val); + + val = cvmx_fdt_get_int(fdt_addr, eth, "cavium,refclk-sel", 0); + cvmx_helper_set_agl_refclk_sel(xiface, port_index, val); + } + + return (eth >= 0); +} + +/** + * Given the address of the MDIO registers, output the CPU node and MDIO bus + * + * @param addr 64-bit address of MDIO registers (from device tree) + * @param[out] node CPU node number (78xx) + * @param[out] bus MDIO bus number + */ +void __cvmx_mdio_addr_to_node_bus(u64 addr, int *node, int *bus) +{ + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + if (node) + *node = cvmx_csr_addr_to_node(addr); + addr = cvmx_csr_addr_strip_node(addr); + } else { + if (node) + *node = 0; + } + if (OCTEON_IS_MODEL(OCTEON_CN68XX) || OCTEON_IS_MODEL(OCTEON_CN78XX)) { + switch (addr) { + case 0x0001180000003800: + *bus = 0; + break; + case 0x0001180000003880: + *bus = 1; + break; + case 0x0001180000003900: + *bus = 2; + break; + case 0x0001180000003980: + *bus = 3; + break; + default: + *bus = -1; + printf("%s: Invalid SMI bus address 0x%llx\n", __func__, + (unsigned long long)addr); + break; + } + } else if (OCTEON_IS_MODEL(OCTEON_CN73XX) || + OCTEON_IS_MODEL(OCTEON_CNF75XX)) { + switch (addr) { + case 0x0001180000003800: + *bus = 0; + break; + case 0x0001180000003880: + *bus = 1; + break; + default: + *bus = -1; + printf("%s: Invalid SMI bus address 0x%llx\n", __func__, + (unsigned long long)addr); + break; + } + } else { + switch (addr) { + case 0x0001180000001800: + *bus = 0; + break; + case 0x0001180000001900: + *bus = 1; + break; + default: + *bus = -1; + printf("%s: Invalid SMI bus address 0x%llx\n", __func__, + (unsigned long long)addr); + break; + } + } +}
Import cvmx-helper-fpa.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-fpa.c | 76 +++++++++++++++++++++++++ 1 file changed, 76 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-fpa.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-fpa.c b/arch/mips/mach-octeon/cvmx-helper-fpa.c new file mode 100644 index 000000000000..e87082934739 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-fpa.c @@ -0,0 +1,76 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Helper functions for FPA setup. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-ipd.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> +#include <mach/cvmx-pip.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> +#include <mach/cvmx-helper-pko.h> + +/** + * @INTERNAL + * OBSOLETE + * + * Allocate memory for and initialize a single FPA pool. + * + * @param pool Pool to initialize + * @param buffer_size Size of buffers to allocate in bytes + * @param buffers Number of buffers to put in the pool. Zero is allowed + * @param name String name of the pool for debugging purposes + * @return Zero on success, non-zero on failure + * + * This function is only for transition, will be removed. + */ +int __cvmx_helper_initialize_fpa_pool(int pool, u64 buffer_size, u64 buffers, + const char *name) +{ + return cvmx_fpa_setup_pool(pool, name, NULL, buffer_size, buffers); +}
Import cvmx-helper-ilk.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-ilk.c | 902 ++++++++++++++++++++++++ 1 file changed, 902 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-ilk.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-ilk.c b/arch/mips/mach-octeon/cvmx-helper-ilk.c new file mode 100644 index 000000000000..9e882f133323 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-ilk.c @@ -0,0 +1,902 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for ILK initialization, configuration, + * and monitoring. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +int __cvmx_helper_ilk_enumerate(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + xi.interface -= CVMX_ILK_GBL_BASE(); + return cvmx_ilk_chans[xi.node][xi.interface]; +} + +/** + * @INTERNAL + * Initialize all tx calendar entries to the xoff state. + * Initialize all rx calendar entries to the xon state. The rx calendar entries + * must be in the xon state to allow new pko pipe assignments. If a calendar + * entry is assigned a different pko pipe while in the xoff state, the old pko + * pipe will stay in the xoff state even when no longer used by ilk. + * + * @param intf Interface whose calendar are to be initialized. + */ +static void __cvmx_ilk_clear_cal_cn78xx(int intf) +{ + cvmx_ilk_txx_cal_entryx_t tx_entry; + cvmx_ilk_rxx_cal_entryx_t rx_entry; + int i; + int node = (intf >> 4) & 0xf; + int interface = (intf & 0xf); + + /* Initialize all tx calendar entries to off */ + tx_entry.u64 = 0; + tx_entry.s.ctl = XOFF; + for (i = 0; i < CVMX_ILK_MAX_CAL; i++) { + csr_wr_node(node, CVMX_ILK_TXX_CAL_ENTRYX(i, interface), + tx_entry.u64); + } + + /* Initialize all rx calendar entries to on */ + rx_entry.u64 = 0; + rx_entry.s.ctl = XOFF; + for (i = 0; i < CVMX_ILK_MAX_CAL; i++) { + csr_wr_node(node, CVMX_ILK_RXX_CAL_ENTRYX(i, interface), + rx_entry.u64); + } +} + +/** + * @INTERNAL + * Initialize all tx calendar entries to the xoff state. + * Initialize all rx calendar entries to the xon state. The rx calendar entries + * must be in the xon state to allow new pko pipe assignments. If a calendar + * entry is assigned a different pko pipe while in the xoff state, the old pko + * pipe will stay in the xoff state even when no longer used by ilk. + * + * @param interface whose calendar are to be initialized. + */ +static void __cvmx_ilk_clear_cal_cn68xx(int interface) +{ + cvmx_ilk_txx_idx_cal_t tx_idx; + cvmx_ilk_txx_mem_cal0_t tx_cal0; + cvmx_ilk_txx_mem_cal1_t tx_cal1; + cvmx_ilk_rxx_idx_cal_t rx_idx; + cvmx_ilk_rxx_mem_cal0_t rx_cal0; + cvmx_ilk_rxx_mem_cal1_t rx_cal1; + int i; + + /* + * First we initialize the tx calendar starting from entry 0, + * incrementing the entry with every write. + */ + tx_idx.u64 = 0; + tx_idx.s.inc = 1; + csr_wr(CVMX_ILK_TXX_IDX_CAL(interface), tx_idx.u64); + + /* Set state to xoff for all entries */ + tx_cal0.u64 = 0; + tx_cal0.s.entry_ctl0 = XOFF; + tx_cal0.s.entry_ctl1 = XOFF; + tx_cal0.s.entry_ctl2 = XOFF; + tx_cal0.s.entry_ctl3 = XOFF; + + tx_cal1.u64 = 0; + tx_cal1.s.entry_ctl4 = XOFF; + tx_cal1.s.entry_ctl5 = XOFF; + tx_cal1.s.entry_ctl6 = XOFF; + tx_cal1.s.entry_ctl7 = XOFF; + + /* Write all 288 entries */ + for (i = 0; i < CVMX_ILK_MAX_CAL_IDX; i++) { + csr_wr(CVMX_ILK_TXX_MEM_CAL0(interface), tx_cal0.u64); + csr_wr(CVMX_ILK_TXX_MEM_CAL1(interface), tx_cal1.u64); + } + + /* + * Next we initialize the rx calendar starting from entry 0, + * incrementing the entry with every write. + */ + rx_idx.u64 = 0; + rx_idx.s.inc = 1; + csr_wr(CVMX_ILK_RXX_IDX_CAL(interface), rx_idx.u64); + + /* Set state to xon for all entries */ + rx_cal0.u64 = 0; + rx_cal0.s.entry_ctl0 = XON; + rx_cal0.s.entry_ctl1 = XON; + rx_cal0.s.entry_ctl2 = XON; + rx_cal0.s.entry_ctl3 = XON; + + rx_cal1.u64 = 0; + rx_cal1.s.entry_ctl4 = XON; + rx_cal1.s.entry_ctl5 = XON; + rx_cal1.s.entry_ctl6 = XON; + rx_cal1.s.entry_ctl7 = XON; + + /* Write all 288 entries */ + for (i = 0; i < CVMX_ILK_MAX_CAL_IDX; i++) { + csr_wr(CVMX_ILK_RXX_MEM_CAL0(interface), rx_cal0.u64); + csr_wr(CVMX_ILK_RXX_MEM_CAL1(interface), rx_cal1.u64); + } +} + +/** + * @INTERNAL + * Initialize all calendar entries. + * + * @param interface whose calendar is to be initialized. + */ +void __cvmx_ilk_clear_cal(int interface) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + __cvmx_ilk_clear_cal_cn68xx(interface); + else if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + __cvmx_ilk_clear_cal_cn78xx(interface); +} + +void __cvmx_ilk_write_tx_cal_entry_cn68xx(int interface, int channel, + unsigned char bpid) +{ + cvmx_ilk_txx_idx_cal_t tx_idx; + cvmx_ilk_txx_mem_cal0_t tx_cal0; + cvmx_ilk_txx_mem_cal1_t tx_cal1; + int entry; + int window; + int window_entry; + + /* + * The calendar has 288 entries. Each calendar entry represents a + * channel's flow control state or the link flow control state. + * Starting with the first entry, every sixteenth entry is used for the + * link flow control state. The other 15 entries are used for the + * channels flow control state: + * entry 0 ----> link flow control state + * entry 1 ----> channel 0 flow control state + * entry 2 ----> channel 1 flow control state + * ... + * entry 15 ----> channel 14 flow control state + * entry 16 ----> link flow control state + * entry 17 ----> channel 15 flow control state + * + * Also, the calendar is accessed via windows into it. Each window maps + * to 8 entries. + */ + entry = 1 + channel + (channel / 15); + window = entry / 8; + window_entry = entry % 8; + + /* Indicate the window we need to access */ + tx_idx.u64 = 0; + tx_idx.s.index = window; + csr_wr(CVMX_ILK_TXX_IDX_CAL(interface), tx_idx.u64); + + /* Get the window's current value */ + tx_cal0.u64 = csr_rd(CVMX_ILK_TXX_MEM_CAL0(interface)); + tx_cal1.u64 = csr_rd(CVMX_ILK_TXX_MEM_CAL1(interface)); + + /* Force every sixteenth entry as link flow control state */ + if ((window & 1) == 0) + tx_cal0.s.entry_ctl0 = LINK; + + /* Update the entry */ + switch (window_entry) { + case 0: + tx_cal0.s.entry_ctl0 = 0; + tx_cal0.s.bpid0 = bpid; + break; + case 1: + tx_cal0.s.entry_ctl1 = 0; + tx_cal0.s.bpid1 = bpid; + break; + case 2: + tx_cal0.s.entry_ctl2 = 0; + tx_cal0.s.bpid2 = bpid; + break; + case 3: + tx_cal0.s.entry_ctl3 = 0; + tx_cal0.s.bpid3 = bpid; + break; + case 4: + tx_cal1.s.entry_ctl4 = 0; + tx_cal1.s.bpid4 = bpid; + break; + case 5: + tx_cal1.s.entry_ctl5 = 0; + tx_cal1.s.bpid5 = bpid; + break; + case 6: + tx_cal1.s.entry_ctl6 = 0; + tx_cal1.s.bpid6 = bpid; + break; + case 7: + tx_cal1.s.entry_ctl7 = 0; + tx_cal1.s.bpid7 = bpid; + break; + } + + /* Write the window new value */ + csr_wr(CVMX_ILK_TXX_MEM_CAL0(interface), tx_cal0.u64); + csr_wr(CVMX_ILK_TXX_MEM_CAL1(interface), tx_cal1.u64); +} + +void __cvmx_ilk_write_tx_cal_entry_cn78xx(int intf, int channel, + unsigned char bpid) +{ + cvmx_ilk_txx_cal_entryx_t tx_cal; + int calender_16_block = channel / 15; + int calender_16_index = channel % 15 + 1; + int index = calender_16_block * 16 + calender_16_index; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + /* Program the link status on first channel */ + if (calender_16_index == 1) { + tx_cal.u64 = 0; + tx_cal.s.ctl = 1; + csr_wr_node(node, CVMX_ILK_TXX_CAL_ENTRYX(index - 1, interface), + tx_cal.u64); + } + tx_cal.u64 = 0; + tx_cal.s.ctl = 0; + tx_cal.s.channel = channel; + csr_wr_node(node, CVMX_ILK_TXX_CAL_ENTRYX(index, interface), + tx_cal.u64); +} + +/** + * @INTERNAL + * Setup the channel's tx calendar entry. + * + * @param interface channel belongs to + * @param channel whose calendar entry is to be updated + * @param bpid assigned to the channel + */ +void __cvmx_ilk_write_tx_cal_entry(int interface, int channel, + unsigned char bpid) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + __cvmx_ilk_write_tx_cal_entry_cn68xx(interface, channel, bpid); + else + __cvmx_ilk_write_tx_cal_entry_cn78xx(interface, channel, bpid); +} + +void __cvmx_ilk_write_rx_cal_entry_cn78xx(int intf, int channel, + unsigned char bpid) +{ + cvmx_ilk_rxx_cal_entryx_t rx_cal; + int calender_16_block = channel / 15; + int calender_16_index = channel % 15 + 1; + int index = calender_16_block * 16 + calender_16_index; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + /* Program the link status on first channel */ + if (calender_16_index == 1) { + rx_cal.u64 = 0; + rx_cal.s.ctl = 1; + csr_wr_node(node, CVMX_ILK_RXX_CAL_ENTRYX(index - 1, interface), + rx_cal.u64); + } + rx_cal.u64 = 0; + rx_cal.s.ctl = 0; + rx_cal.s.channel = channel; + csr_wr_node(node, CVMX_ILK_RXX_CAL_ENTRYX(index, interface), + rx_cal.u64); +} + +void __cvmx_ilk_write_rx_cal_entry_cn68xx(int interface, int channel, + unsigned char pipe) +{ + cvmx_ilk_rxx_idx_cal_t rx_idx; + cvmx_ilk_rxx_mem_cal0_t rx_cal0; + cvmx_ilk_rxx_mem_cal1_t rx_cal1; + int entry; + int window; + int window_entry; + + /* + * The calendar has 288 entries. Each calendar entry represents a + * channel's flow control state or the link flow control state. + * Starting with the first entry, every sixteenth entry is used for the + * link flow control state. The other 15 entries are used for the + * channels flow control state: + * entry 0 ----> link flow control state + * entry 1 ----> channel 0 flow control state + * entry 2 ----> channel 1 flow control state + * ... + * entry 15 ----> channel 14 flow control state + * entry 16 ----> link flow control state + * entry 17 ----> channel 15 flow control state + * + * Also, the calendar is accessed via windows into it. Each window maps + * to 8 entries. + */ + entry = 1 + channel + (channel / 15); + window = entry / 8; + window_entry = entry % 8; + + /* Indicate the window we need to access */ + rx_idx.u64 = 0; + rx_idx.s.index = window; + csr_wr(CVMX_ILK_RXX_IDX_CAL(interface), rx_idx.u64); + + /* Get the window's current value */ + rx_cal0.u64 = csr_rd(CVMX_ILK_RXX_MEM_CAL0(interface)); + rx_cal1.u64 = csr_rd(CVMX_ILK_RXX_MEM_CAL1(interface)); + + /* Force every sixteenth entry as link flow control state */ + if ((window & 1) == 0) + rx_cal0.s.entry_ctl0 = LINK; + + /* Update the entry */ + switch (window_entry) { + case 0: + rx_cal0.s.entry_ctl0 = 0; + rx_cal0.s.port_pipe0 = pipe; + break; + case 1: + rx_cal0.s.entry_ctl1 = 0; + rx_cal0.s.port_pipe1 = pipe; + break; + case 2: + rx_cal0.s.entry_ctl2 = 0; + rx_cal0.s.port_pipe2 = pipe; + break; + case 3: + rx_cal0.s.entry_ctl3 = 0; + rx_cal0.s.port_pipe3 = pipe; + break; + case 4: + rx_cal1.s.entry_ctl4 = 0; + rx_cal1.s.port_pipe4 = pipe; + break; + case 5: + rx_cal1.s.entry_ctl5 = 0; + rx_cal1.s.port_pipe5 = pipe; + break; + case 6: + rx_cal1.s.entry_ctl6 = 0; + rx_cal1.s.port_pipe6 = pipe; + break; + case 7: + rx_cal1.s.entry_ctl7 = 0; + rx_cal1.s.port_pipe7 = pipe; + break; + } + + /* Write the window new value */ + csr_wr(CVMX_ILK_RXX_MEM_CAL0(interface), rx_cal0.u64); + csr_wr(CVMX_ILK_RXX_MEM_CAL1(interface), rx_cal1.u64); +} + +/** + * @INTERNAL + * Setup the channel's rx calendar entry. + * + * @param interface channel belongs to + * @param channel whose calendar entry is to be updated + * @param pipe PKO assigned to the channel + */ +void __cvmx_ilk_write_rx_cal_entry(int interface, int channel, + unsigned char pipe) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + __cvmx_ilk_write_rx_cal_entry_cn68xx(interface, channel, pipe); + else + __cvmx_ilk_write_rx_cal_entry_cn78xx(interface, channel, pipe); +} + +/** + * @INTERNAL + * Probe a ILK interface and determine the number of ports + * connected to it. The ILK interface should still be down + * after this call. + * + * @param xiface Interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_ilk_probe(int xiface) +{ + int res = 0; + int interface; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + interface = xi.interface - CVMX_ILK_GBL_BASE(); + if (interface >= CVMX_NUM_ILK_INTF) + return 0; + + /* the configuration should be done only once */ + if (cvmx_ilk_get_intf_ena(xiface)) + return cvmx_ilk_chans[xi.node][interface]; + + /* configure lanes and enable the link */ + res = cvmx_ilk_start_interface(((xi.node << 4) | interface), + cvmx_ilk_lane_mask[xi.node][interface]); + if (res < 0) + return 0; + + res = __cvmx_helper_ilk_enumerate(xiface); + + return res; +} + +static int __cvmx_helper_ilk_init_port_cn68xx(int xiface) +{ + int i, j, res = -1; + static int pipe_base = 0, pknd_base; + static cvmx_ilk_pipe_chan_t *pch = NULL, *tmp; + static cvmx_ilk_chan_pknd_t *chpknd = NULL, *tmp1; + static cvmx_ilk_cal_entry_t *calent = NULL, *tmp2; + int enable_rx_cal = 1; + int interface; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int intf; + int num_chans; + + interface = xi.interface - CVMX_ILK_GBL_BASE(); + intf = (xi.node << 4) | interface; + if (interface >= CVMX_NUM_ILK_INTF) + return 0; + + num_chans = cvmx_ilk_chans[0][interface]; + + /* set up channel to pkind mapping */ + if (pknd_base == 0) + pknd_base = cvmx_helper_get_pknd(xiface, 0); + + /* set up the group of pipes available to ilk */ + if (pipe_base == 0) + pipe_base = + __cvmx_pko_get_pipe(interface + CVMX_ILK_GBL_BASE(), 0); + + if (pipe_base == -1) { + pipe_base = 0; + return 0; + } + + res = cvmx_ilk_set_pipe(xiface, pipe_base, + cvmx_ilk_chans[0][interface]); + if (res < 0) + return 0; + + /* set up pipe to channel mapping */ + i = pipe_base; + if (!pch) { + pch = (cvmx_ilk_pipe_chan_t *)cvmx_bootmem_alloc( + num_chans * sizeof(cvmx_ilk_pipe_chan_t), + sizeof(cvmx_ilk_pipe_chan_t)); + if (!pch) + return 0; + } + + memset(pch, 0, num_chans * sizeof(cvmx_ilk_pipe_chan_t)); + tmp = pch; + for (j = 0; j < num_chans; j++) { + tmp->pipe = i++; + tmp->chan = j; + tmp++; + } + res = cvmx_ilk_tx_set_channel(interface, pch, + cvmx_ilk_chans[0][interface]); + if (res < 0) { + res = 0; + goto err_free_pch; + } + pipe_base += cvmx_ilk_chans[0][interface]; + i = pknd_base; + if (!chpknd) { + chpknd = (cvmx_ilk_chan_pknd_t *)cvmx_bootmem_alloc( + CVMX_ILK_MAX_PKNDS * sizeof(cvmx_ilk_chan_pknd_t), + sizeof(cvmx_ilk_chan_pknd_t)); + if (!chpknd) { + pipe_base -= cvmx_ilk_chans[xi.node][interface]; + res = 0; + goto err_free_pch; + } + } + + memset(chpknd, 0, CVMX_ILK_MAX_PKNDS * sizeof(cvmx_ilk_chan_pknd_t)); + tmp1 = chpknd; + for (j = 0; j < cvmx_ilk_chans[xi.node][interface]; j++) { + tmp1->chan = j; + tmp1->pknd = i++; + tmp1++; + } + + res = cvmx_ilk_rx_set_pknd(xiface, chpknd, + cvmx_ilk_chans[xi.node][interface]); + if (res < 0) { + pipe_base -= cvmx_ilk_chans[xi.node][interface]; + res = 0; + goto err_free_chpknd; + } + pknd_base += cvmx_ilk_chans[xi.node][interface]; + + /* Set up tx calendar */ + if (!calent) { + calent = (cvmx_ilk_cal_entry_t *)cvmx_bootmem_alloc( + CVMX_ILK_MAX_PIPES * sizeof(cvmx_ilk_cal_entry_t), + sizeof(cvmx_ilk_cal_entry_t)); + if (!calent) { + pipe_base -= cvmx_ilk_chans[xi.node][interface]; + pknd_base -= cvmx_ilk_chans[xi.node][interface]; + res = 0; + goto err_free_chpknd; + } + } + + memset(calent, 0, CVMX_ILK_MAX_PIPES * sizeof(cvmx_ilk_cal_entry_t)); + tmp1 = chpknd; + tmp2 = calent; + for (j = 0; j < cvmx_ilk_chans[xi.node][interface]; j++) { + tmp2->pipe_bpid = tmp1->pknd; + tmp2->ent_ctrl = PIPE_BPID; + tmp1++; + tmp2++; + } + res = cvmx_ilk_cal_setup_tx(intf, cvmx_ilk_chans[xi.node][interface], + calent, 1); + if (res < 0) { + pipe_base -= cvmx_ilk_chans[xi.node][interface]; + pknd_base -= cvmx_ilk_chans[xi.node][interface]; + res = 0; + goto err_free_calent; + } + + /* set up rx calendar. allocated memory can be reused. + * this is because max pkind is always less than max pipe + */ + memset(calent, 0, CVMX_ILK_MAX_PIPES * sizeof(cvmx_ilk_cal_entry_t)); + tmp = pch; + tmp2 = calent; + for (j = 0; j < cvmx_ilk_chans[0][interface]; j++) { + tmp2->pipe_bpid = tmp->pipe; + tmp2->ent_ctrl = PIPE_BPID; + tmp++; + tmp2++; + } + if (cvmx_ilk_use_la_mode(interface, 0)) + enable_rx_cal = cvmx_ilk_la_mode_enable_rx_calendar(interface); + else + enable_rx_cal = 1; + + res = cvmx_ilk_cal_setup_rx(intf, cvmx_ilk_chans[xi.node][interface], + calent, CVMX_ILK_RX_FIFO_WM, enable_rx_cal); + if (res < 0) { + pipe_base -= cvmx_ilk_chans[xi.node][interface]; + pknd_base -= cvmx_ilk_chans[xi.node][interface]; + res = 0; + goto err_free_calent; + } + goto out; + +err_free_calent: + /* no free() for cvmx_bootmem_alloc() */ + +err_free_chpknd: + /* no free() for cvmx_bootmem_alloc() */ + +err_free_pch: + /* no free() for cvmx_bootmem_alloc() */ +out: + return res; +} + +static int __cvmx_helper_ilk_init_port_cn78xx(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface; + int intf; + + interface = xi.interface - CVMX_ILK_GBL_BASE(); + intf = (xi.node << 4) | interface; + if (interface >= CVMX_NUM_ILK_INTF) + return 0; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + struct cvmx_pki_style_config style_cfg; + int num_channels = cvmx_ilk_chans[xi.node][interface]; + int index, i; + + for (i = 0; i < num_channels; i++) { + int pknd; + + index = (i % 8); + + /* Set jabber to allow max sized packets */ + if (i == 0) + csr_wr_node(xi.node, + CVMX_ILK_RXX_JABBER(interface), + 0xfff8); + + /* Setup PKND */ + pknd = cvmx_helper_get_pknd(xiface, index); + csr_wr_node(xi.node, CVMX_ILK_RXX_CHAX(i, interface), + pknd); + cvmx_pki_read_style_config( + 0, pknd, CVMX_PKI_CLUSTER_ALL, &style_cfg); + style_cfg.parm_cfg.qpg_port_sh = 0; + /* 256 channels */ + style_cfg.parm_cfg.qpg_port_msb = 8; + cvmx_pki_write_style_config( + 0, pknd, CVMX_PKI_CLUSTER_ALL, &style_cfg); + } + + cvmx_ilk_cal_setup_tx(intf, num_channels, NULL, 1); + cvmx_ilk_cal_setup_rx(intf, num_channels, NULL, + CVMX_ILK_RX_FIFO_WM, 1); + } + return 0; +} + +static int __cvmx_helper_ilk_init_port(int xiface) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + return __cvmx_helper_ilk_init_port_cn68xx(xiface); + else + return __cvmx_helper_ilk_init_port_cn78xx(xiface); +} + +/** + * @INTERNAL + * Bringup and enable ILK interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_ilk_enable(int xiface) +{ + if (__cvmx_helper_ilk_init_port(xiface) < 0) + return -1; + + return cvmx_ilk_enable(xiface); +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by ILK link status. + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_ilk_link_get(int ipd_port) +{ + cvmx_helper_link_info_t result; + int xiface = cvmx_helper_get_interface_num(ipd_port); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface; + int retry_count = 0; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; + cvmx_ilk_rxx_int_t ilk_rxx_int; + int lane_mask = 0; + int i; + int node = xi.node; + + result.u64 = 0; + interface = xi.interface - CVMX_ILK_GBL_BASE(); + +retry: + retry_count++; + if (retry_count > 200) + goto fail; + + /* Read RX config and status bits */ + ilk_rxx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + ilk_rxx_int.u64 = csr_rd_node(node, CVMX_ILK_RXX_INT(interface)); + + if (ilk_rxx_cfg1.s.rx_bdry_lock_ena == 0) { + /* (GSER-21957) GSER RX Equalization may make >= 5gbaud non-KR + * channel better + */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + int qlm, lane_mask; + + for (qlm = 4; qlm < 8; qlm++) { + lane_mask = 1 << (qlm - 4) * 4; + if (lane_mask & + cvmx_ilk_lane_mask[node][interface]) { + if (__cvmx_qlm_rx_equalization( + node, qlm, -1)) + goto retry; + } + } + } + + /* Clear the boundary lock status bit */ + ilk_rxx_int.u64 = 0; + ilk_rxx_int.s.word_sync_done = 1; + csr_wr_node(node, CVMX_ILK_RXX_INT(interface), ilk_rxx_int.u64); + + /* We need to start looking for word boundary lock */ + ilk_rxx_cfg1.s.rx_bdry_lock_ena = + cvmx_ilk_lane_mask[node][interface]; + ilk_rxx_cfg1.s.rx_align_ena = 0; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), + ilk_rxx_cfg1.u64); + //debug("ILK%d: Looking for word boundary lock\n", interface); + udelay(50); + goto retry; + } + + if (ilk_rxx_cfg1.s.rx_align_ena == 0) { + if (ilk_rxx_int.s.word_sync_done) { + /* Clear the lane align status bits */ + ilk_rxx_int.u64 = 0; + ilk_rxx_int.s.lane_align_fail = 1; + ilk_rxx_int.s.lane_align_done = 1; + csr_wr_node(node, CVMX_ILK_RXX_INT(interface), + ilk_rxx_int.u64); + + ilk_rxx_cfg1.s.rx_align_ena = 1; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), + ilk_rxx_cfg1.u64); + //printf("ILK%d: Looking for lane alignment\n", interface); + } + udelay(50); + goto retry; + } + + if (ilk_rxx_int.s.lane_align_fail) { + ilk_rxx_cfg1.s.rx_bdry_lock_ena = 0; + ilk_rxx_cfg1.s.rx_align_ena = 0; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), + ilk_rxx_cfg1.u64); + //debug("ILK%d: Lane alignment failed\n", interface); + goto fail; + } + + lane_mask = ilk_rxx_cfg1.s.rx_bdry_lock_ena; + + if (ilk_rxx_cfg1.s.pkt_ena == 0 && ilk_rxx_int.s.lane_align_done) { + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + + ilk_txx_cfg1.u64 = + csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + ilk_rxx_cfg1.u64 = + csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + ilk_rxx_cfg1.s.pkt_ena = ilk_txx_cfg1.s.pkt_ena; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), + ilk_rxx_cfg1.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + /* + * Enable rxf_ctl_perr, rxf_lnk0_perr, rxf_lnk1_perr, + * pop_empty, push_full. + */ + csr_wr(CVMX_ILK_GBL_INT_EN, 0x1f); + /* Enable bad_pipe, bad_seq, txf_err */ + csr_wr(CVMX_ILK_TXX_INT_EN(interface), 0x7); + + /* + * Enable crc24_err, lane_bad_word, + * pkt_drop_{rid,rxf,sop} + */ + csr_wr(CVMX_ILK_RXX_INT_EN(interface), 0x1e2); + } + /* Need to enable ILK interrupts for 78xx */ + + for (i = 0; i < CVMX_ILK_MAX_LANES(); i++) { + if ((1 << i) & lane_mask) { + /* clear pending interrupts, before enabling. */ + csr_wr_node(node, CVMX_ILK_RX_LNEX_INT(i), + 0x1ff); + /* Enable bad_64b67b, bdry_sync_loss, crc32_err, + * dskew_fifo_ovfl, scrm_sync_loss, + * serdes_lock_loss, stat_msg, ukwn_cntl_word + */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + csr_wr(CVMX_ILK_RX_LNEX_INT_EN(i), + 0x1ff); + } + } + + //debug("ILK%d: Lane alignment complete\n", interface); + } + + /* Enable error interrupts, now link is up */ + cvmx_error_enable_group(CVMX_ERROR_GROUP_ILK, + node | (interface << 2) | (lane_mask << 4)); + + result.s.link_up = 1; + result.s.full_duplex = 1; + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + int qlm = cvmx_qlm_lmac(xiface, 0); + + result.s.speed = cvmx_qlm_get_gbaud_mhz(qlm) * 64 / 67; + } else { + result.s.speed = + cvmx_qlm_get_gbaud_mhz(1 + interface) * 64 / 67; + } + result.s.speed *= cvmx_pop(lane_mask); + + return result; + +fail: + if (ilk_rxx_cfg1.s.pkt_ena) { + /* Disable the interface */ + ilk_rxx_cfg1.s.pkt_ena = 0; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), + ilk_rxx_cfg1.u64); + + /* Disable error interrupts */ + for (i = 0; i < CVMX_ILK_MAX_LANES(); i++) { + /* Disable bad_64b67b, bdry_sync_loss, crc32_err, + * dskew_fifo_ovfl, scrm_sync_loss, serdes_lock_loss, + * stat_msg, ukwn_cntl_word + */ + if ((1 << i) & lane_mask) { + csr_wr_node(node, CVMX_ILK_RX_LNEX_INT(i), + 0x1ff); + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + csr_wr(CVMX_ILK_RX_LNEX_INT_EN(i), + ~0x1ff); + } + } + /* Disable error interrupts */ + cvmx_error_enable_group(CVMX_ERROR_GROUP_ILK, 0); + } + + return result; +} + +/** + * @INTERNAL + * Set the link state of an IPD/PKO port. + * + * @param ipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_ilk_link_set(int ipd_port, cvmx_helper_link_info_t link_info) +{ + /* Do nothing */ + return 0; +}
Import cvmx-helper-ipd.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-ipd.c | 286 ++++++++++++++++++++++++ 1 file changed, 286 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-ipd.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-ipd.c b/arch/mips/mach-octeon/cvmx-helper-ipd.c new file mode 100644 index 000000000000..cb04b63b9b07 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-ipd.c @@ -0,0 +1,286 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * IPD helper functions. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-ipd.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> +#include <mach/cvmx-pip.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +/** It allocate pools for packet and wqe pools + * and sets up the FPA hardware + */ +int __cvmx_helper_ipd_setup_fpa_pools(void) +{ + cvmx_fpa_global_initialize(); + if (cvmx_ipd_cfg.packet_pool.buffer_count == 0) + return 0; + __cvmx_helper_initialize_fpa_pool(cvmx_ipd_cfg.packet_pool.pool_num, + cvmx_ipd_cfg.packet_pool.buffer_size, + cvmx_ipd_cfg.packet_pool.buffer_count, + "Packet Buffers"); + if (cvmx_ipd_cfg.wqe_pool.buffer_count == 0) + return 0; + __cvmx_helper_initialize_fpa_pool(cvmx_ipd_cfg.wqe_pool.pool_num, + cvmx_ipd_cfg.wqe_pool.buffer_size, + cvmx_ipd_cfg.wqe_pool.buffer_count, + "WQE Buffers"); + return 0; +} + +/** + * @INTERNAL + * Setup global setting for IPD/PIP not related to a specific + * interface or port. This must be called before IPD is enabled. + * + * @return Zero on success, negative on failure. + */ +int __cvmx_helper_ipd_global_setup(void) +{ + /* Setup the packet and wqe pools*/ + __cvmx_helper_ipd_setup_fpa_pools(); + /* Setup the global packet input options */ + cvmx_ipd_config(cvmx_ipd_cfg.packet_pool.buffer_size / 8, + cvmx_ipd_cfg.first_mbuf_skip / 8, + cvmx_ipd_cfg.not_first_mbuf_skip / 8, + /* The +8 is to account for the next ptr */ + (cvmx_ipd_cfg.first_mbuf_skip + 8) / 128, + /* The +8 is to account for the next ptr */ + (cvmx_ipd_cfg.not_first_mbuf_skip + 8) / 128, + cvmx_ipd_cfg.wqe_pool.pool_num, + (cvmx_ipd_mode_t)(cvmx_ipd_cfg.cache_mode), 1); + return 0; +} + +/** + * Enable or disable FCS stripping for all the ports on an interface. + * + * @param xiface + * @param nports number of ports + * @param has_fcs 0 for disable and !0 for enable + */ +static int cvmx_helper_fcs_op(int xiface, int nports, int has_fcs) +{ + u64 port_bit; + int index; + int pknd; + union cvmx_pip_sub_pkind_fcsx pkind_fcsx; + union cvmx_pip_prt_cfgx port_cfg; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + if (!octeon_has_feature(OCTEON_FEATURE_PKND)) + return 0; + if (octeon_has_feature(OCTEON_FEATURE_PKI)) { + cvmx_helper_pki_set_fcs_op(xi.node, xi.interface, nports, + has_fcs); + return 0; + } + + port_bit = 0; + for (index = 0; index < nports; index++) + port_bit |= ((u64)1 << cvmx_helper_get_pknd(xiface, index)); + + pkind_fcsx.u64 = csr_rd(CVMX_PIP_SUB_PKIND_FCSX(0)); + if (has_fcs) + pkind_fcsx.s.port_bit |= port_bit; + else + pkind_fcsx.s.port_bit &= ~port_bit; + csr_wr(CVMX_PIP_SUB_PKIND_FCSX(0), pkind_fcsx.u64); + + for (pknd = 0; pknd < 64; pknd++) { + if ((1ull << pknd) & port_bit) { + port_cfg.u64 = csr_rd(CVMX_PIP_PRT_CFGX(pknd)); + port_cfg.s.crc_en = (has_fcs) ? 1 : 0; + csr_wr(CVMX_PIP_PRT_CFGX(pknd), port_cfg.u64); + } + } + + return 0; +} + +/** + * @INTERNAL + * Configure the IPD/PIP tagging and QoS options for a specific + * port. This function determines the POW work queue entry + * contents for a port. The setup performed here is controlled by + * the defines in executive-config.h. + * + * @param ipd_port Port/Port kind to configure. This follows the IPD numbering, + * not the per interface numbering + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_ipd_port_setup(int ipd_port) +{ + union cvmx_pip_prt_cfgx port_config; + union cvmx_pip_prt_tagx tag_config; + + if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + int xiface, index, pknd; + union cvmx_pip_prt_cfgbx prt_cfgbx; + + xiface = cvmx_helper_get_interface_num(ipd_port); + index = cvmx_helper_get_interface_index_num(ipd_port); + pknd = cvmx_helper_get_pknd(xiface, index); + + port_config.u64 = csr_rd(CVMX_PIP_PRT_CFGX(pknd)); + tag_config.u64 = csr_rd(CVMX_PIP_PRT_TAGX(pknd)); + + port_config.s.qos = pknd & 0x7; + + /* Default BPID to use for packets on this port-kind */ + prt_cfgbx.u64 = csr_rd(CVMX_PIP_PRT_CFGBX(pknd)); + prt_cfgbx.s.bpid = pknd; + csr_wr(CVMX_PIP_PRT_CFGBX(pknd), prt_cfgbx.u64); + } else { + port_config.u64 = csr_rd(CVMX_PIP_PRT_CFGX(ipd_port)); + tag_config.u64 = csr_rd(CVMX_PIP_PRT_TAGX(ipd_port)); + + /* Have each port go to a different POW queue */ + port_config.s.qos = ipd_port & 0x7; + } + + /* Process the headers and place the IP header in the work queue */ + port_config.s.mode = + (cvmx_pip_port_parse_mode_t)cvmx_ipd_cfg.port_config.parse_mode; + + tag_config.s.ip6_src_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv6_src_ip; + tag_config.s.ip6_dst_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv6_dst_ip; + tag_config.s.ip6_sprt_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv6_src_port; + tag_config.s.ip6_dprt_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv6_dst_port; + tag_config.s.ip6_nxth_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv6_next_header; + tag_config.s.ip4_src_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv4_src_ip; + tag_config.s.ip4_dst_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv4_dst_ip; + tag_config.s.ip4_sprt_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv4_src_port; + tag_config.s.ip4_dprt_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv4_dst_port; + tag_config.s.ip4_pctl_flag = + cvmx_ipd_cfg.port_config.tag_fields.ipv4_protocol; + tag_config.s.inc_prt_flag = + cvmx_ipd_cfg.port_config.tag_fields.input_port; + tag_config.s.tcp6_tag_type = + (cvmx_pow_tag_type_t)cvmx_ipd_cfg.port_config.tag_type; + tag_config.s.tcp4_tag_type = + (cvmx_pow_tag_type_t)cvmx_ipd_cfg.port_config.tag_type; + tag_config.s.ip6_tag_type = + (cvmx_pow_tag_type_t)cvmx_ipd_cfg.port_config.tag_type; + tag_config.s.ip4_tag_type = + (cvmx_pow_tag_type_t)cvmx_ipd_cfg.port_config.tag_type; + tag_config.s.non_tag_type = + (cvmx_pow_tag_type_t)cvmx_ipd_cfg.port_config.tag_type; + + /* Put all packets in group 0. Other groups can be used by the app */ + tag_config.s.grp = 0; + + cvmx_pip_config_port(ipd_port, port_config, tag_config); + + /* Give the user a chance to override our setting for each port */ + if (cvmx_override_ipd_port_setup) + cvmx_override_ipd_port_setup(ipd_port); + + return 0; +} + +/** + * @INTERNAL + * Setup the IPD/PIP for the ports on an interface. Packet + * classification and tagging are set for every port on the + * interface. The number of ports on the interface must already + * have been probed. + * + * @param xiface to setup IPD/PIP for + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_ipd_setup_interface(int xiface) +{ + cvmx_helper_interface_mode_t mode; + int num_ports = cvmx_helper_ports_on_interface(xiface); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int ipd_port = cvmx_helper_get_ipd_port(xiface, 0); + int delta; + + if (num_ports == CVMX_HELPER_CFG_INVALID_VALUE) + return 0; + + delta = 1; + if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + if (xi.interface < CVMX_HELPER_MAX_GMX) + delta = 16; + } + + while (num_ports--) { + if (!cvmx_helper_is_port_valid(xiface, num_ports)) + continue; + if (octeon_has_feature(OCTEON_FEATURE_PKI)) + __cvmx_helper_pki_port_setup(xi.node, ipd_port); + else + __cvmx_helper_ipd_port_setup(ipd_port); + ipd_port += delta; + } + /* FCS settings */ + cvmx_helper_fcs_op(xiface, cvmx_helper_ports_on_interface(xiface), + __cvmx_helper_get_has_fcs(xiface)); + + mode = cvmx_helper_interface_get_mode(xiface); + + if (mode == CVMX_HELPER_INTERFACE_MODE_LOOP) + __cvmx_helper_loop_enable(xiface); + + return 0; +}
Import cvmx-helper-loop.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-loop.c | 178 +++++++++++++++++++++++ 1 file changed, 178 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-loop.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-loop.c b/arch/mips/mach-octeon/cvmx-helper-loop.c new file mode 100644 index 000000000000..8eaeac387df4 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-loop.c @@ -0,0 +1,178 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for LOOP initialization, configuration, + * and monitoring. + */ + +#include <log.h> +#include <malloc.h> +#include <net.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/octeon_fdt.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-fdt.h> +#include <mach/cvmx-helper-gpio.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-lbk-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> + +int __cvmx_helper_loop_enumerate(int xiface) +{ + return OCTEON_IS_MODEL(OCTEON_CN68XX) ? + 8 : (OCTEON_IS_MODEL(OCTEON_CNF71XX) ? 2 : 4); +} + +/** + * @INTERNAL + * Probe a LOOP interface and determine the number of ports + * connected to it. The LOOP interface should still be down + * after this call. + * + * @param xiface Interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_loop_probe(int xiface) +{ + return __cvmx_helper_loop_enumerate(xiface); +} + +/** + * @INTERNAL + * Bringup and enable a LOOP interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_loop_enable(int xiface) +{ + cvmx_pip_prt_cfgx_t port_cfg; + int num_ports, index; + unsigned long offset; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + num_ports = __cvmx_helper_get_num_ipd_ports(xiface); + /* + * We need to disable length checking so packet < 64 bytes and jumbo + * frames don't get errors + */ + for (index = 0; index < num_ports; index++) { + offset = ((octeon_has_feature(OCTEON_FEATURE_PKND)) ? + cvmx_helper_get_pknd(xiface, index) : + cvmx_helper_get_ipd_port(xiface, index)); + + if (octeon_has_feature(OCTEON_FEATURE_PKI)) { + cvmx_pki_endis_l2_errs(xi.node, offset, 1, 0, 0); + cvmx_pki_endis_fcs_check(xi.node, offset, 0, 0); + } else { + port_cfg.u64 = csr_rd(CVMX_PIP_PRT_CFGX(offset)); + port_cfg.s.maxerr_en = 0; + port_cfg.s.minerr_en = 0; + csr_wr(CVMX_PIP_PRT_CFGX(offset), port_cfg.u64); + } + } + + /* + * Disable FCS stripping for loopback ports + */ + if (!octeon_has_feature(OCTEON_FEATURE_PKND)) { + cvmx_ipd_sub_port_fcs_t ipd_sub_port_fcs; + + ipd_sub_port_fcs.u64 = csr_rd(CVMX_IPD_SUB_PORT_FCS); + ipd_sub_port_fcs.s.port_bit2 = 0; + csr_wr(CVMX_IPD_SUB_PORT_FCS, ipd_sub_port_fcs.u64); + } + /* + * Set PKND and BPID for loopback ports. + */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + cvmx_pko_reg_loopback_pkind_t lp_pknd; + cvmx_pko_reg_loopback_bpid_t lp_bpid; + + for (index = 0; index < num_ports; index++) { + int pknd = cvmx_helper_get_pknd(xiface, index); + int bpid = cvmx_helper_get_bpid(xiface, index); + + lp_pknd.u64 = csr_rd(CVMX_PKO_REG_LOOPBACK_PKIND); + lp_bpid.u64 = csr_rd(CVMX_PKO_REG_LOOPBACK_BPID); + + if (index == 0) + lp_pknd.s.num_ports = num_ports; + + switch (index) { + case 0: + lp_pknd.s.pkind0 = pknd; + lp_bpid.s.bpid0 = bpid; + break; + case 1: + lp_pknd.s.pkind1 = pknd; + lp_bpid.s.bpid1 = bpid; + break; + case 2: + lp_pknd.s.pkind2 = pknd; + lp_bpid.s.bpid2 = bpid; + break; + case 3: + lp_pknd.s.pkind3 = pknd; + lp_bpid.s.bpid3 = bpid; + break; + case 4: + lp_pknd.s.pkind4 = pknd; + lp_bpid.s.bpid4 = bpid; + break; + case 5: + lp_pknd.s.pkind5 = pknd; + lp_bpid.s.bpid5 = bpid; + break; + case 6: + lp_pknd.s.pkind6 = pknd; + lp_bpid.s.bpid6 = bpid; + break; + case 7: + lp_pknd.s.pkind7 = pknd; + lp_bpid.s.bpid7 = bpid; + break; + } + csr_wr(CVMX_PKO_REG_LOOPBACK_PKIND, lp_pknd.u64); + csr_wr(CVMX_PKO_REG_LOOPBACK_BPID, lp_bpid.u64); + } + } else if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + cvmx_lbk_chx_pkind_t lbk_pkind; + + for (index = 0; index < num_ports; index++) { + lbk_pkind.u64 = 0; + lbk_pkind.s.pkind = cvmx_helper_get_pknd(xiface, index); + csr_wr_node(xi.node, CVMX_LBK_CHX_PKIND(index), + lbk_pkind.u64); + } + } + + return 0; +}
Import cvmx-helper-npi.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-npi.c | 137 ++++++++++++++++++++++++ 1 file changed, 137 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-npi.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-npi.c b/arch/mips/mach-octeon/cvmx-helper-npi.c new file mode 100644 index 000000000000..92ee1a80215a --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-npi.c @@ -0,0 +1,137 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for NPI initialization, configuration, + * and monitoring. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pexp-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-sli-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +static int cvmx_npi_num_pipes = -1; + +/** + * @INTERNAL + * Probe a NPI interface and determine the number of ports + * connected to it. The NPI interface should still be down + * after this call. + * + * @param interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_npi_probe(int interface) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + return 32; + else if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + return 128; + else if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + return 64; + + return 0; +} + +/** + * @INTERNAL + * Bringup and enable a NPI interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_npi_enable(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + int port; + int num_ports = cvmx_helper_ports_on_interface(interface); + + /* + * On CN50XX, CN52XX, and CN56XX we need to disable length + * checking so packet < 64 bytes and jumbo frames don't get + * errors. + */ + for (port = 0; port < num_ports; port++) { + union cvmx_pip_prt_cfgx port_cfg; + int ipd_port = + (octeon_has_feature(OCTEON_FEATURE_PKND)) ? + cvmx_helper_get_pknd(interface, port) : + cvmx_helper_get_ipd_port(interface, port); + if (octeon_has_feature(OCTEON_FEATURE_PKI)) { + unsigned int node = cvmx_get_node_num(); + + cvmx_pki_endis_l2_errs(node, ipd_port, 0, 0, 0); + + } else { + port_cfg.u64 = csr_rd(CVMX_PIP_PRT_CFGX(ipd_port)); + port_cfg.s.lenerr_en = 0; + port_cfg.s.maxerr_en = 0; + port_cfg.s.minerr_en = 0; + csr_wr(CVMX_PIP_PRT_CFGX(ipd_port), port_cfg.u64); + } + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + /* Set up pknd and bpid */ + union cvmx_sli_portx_pkind config; + + config.u64 = csr_rd(CVMX_PEXP_SLI_PORTX_PKIND(port)); + config.s.bpkind = cvmx_helper_get_bpid(interface, port); + config.s.pkind = cvmx_helper_get_pknd(interface, port); + csr_wr(CVMX_PEXP_SLI_PORTX_PKIND(port), config.u64); + } + } + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + /* + * Set up pko pipes. + */ + union cvmx_sli_tx_pipe config; + + config.u64 = csr_rd(CVMX_PEXP_SLI_TX_PIPE); + config.s.base = __cvmx_pko_get_pipe(interface, 0); + config.s.nump = + cvmx_npi_num_pipes < 0 ? num_ports : cvmx_npi_num_pipes; + csr_wr(CVMX_PEXP_SLI_TX_PIPE, config.u64); + } + + /* Enables are controlled by the remote host, so nothing to do here */ + return 0; +}
Import cvmx-helper-pki.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-pki.c | 549 ++++++++++++++++++++++++ 1 file changed, 549 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-pki.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-pki.c b/arch/mips/mach-octeon/cvmx-helper-pki.c new file mode 100644 index 000000000000..51fa4fb5f054 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-pki.c @@ -0,0 +1,549 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * PKI helper functions. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pexp-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-sli-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-pki.h> + +#include <mach/cvmx-global-resources.h> +#include <mach/cvmx-pko-internal-ports-range.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pip.h> + +static int pki_helper_debug; + +bool cvmx_pki_dflt_init[CVMX_MAX_NODES] = { [0 ... CVMX_MAX_NODES - 1] = 1 }; + +static bool cvmx_pki_dflt_bp_en[CVMX_MAX_NODES] = { [0 ... CVMX_MAX_NODES - 1] = + true }; +static struct cvmx_pki_cluster_grp_config pki_dflt_clgrp[CVMX_MAX_NODES] = { + { 0, 0xf }, + { 0, 0xf } +}; + +struct cvmx_pki_pool_config pki_dflt_pool[CVMX_MAX_NODES] = { + [0 ... CVMX_MAX_NODES - + 1] = { .pool_num = -1, .buffer_size = 2048, .buffer_count = 0 } +}; + +struct cvmx_pki_aura_config pki_dflt_aura[CVMX_MAX_NODES] = { + [0 ... CVMX_MAX_NODES - + 1] = { .aura_num = 0, .pool_num = -1, .buffer_count = 0 } +}; + +struct cvmx_pki_style_config pki_dflt_style[CVMX_MAX_NODES] = { + [0 ... CVMX_MAX_NODES - 1] = { .parm_cfg = { .lenerr_en = 1, + .maxerr_en = 1, + .minerr_en = 1, + .fcs_strip = 1, + .fcs_chk = 1, + .first_skip = 40, + .mbuff_size = 2048 } } +}; + +struct cvmx_pki_sso_grp_config pki_dflt_sso_grp[CVMX_MAX_NODES]; +struct cvmx_pki_qpg_config pki_dflt_qpg[CVMX_MAX_NODES]; +struct cvmx_pki_pkind_config pki_dflt_pkind[CVMX_MAX_NODES]; +u64 pkind_style_map[CVMX_MAX_NODES][CVMX_PKI_NUM_PKIND] = { + [0 ... CVMX_MAX_NODES - + 1] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, + 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, + 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, + 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63 } +}; + +/* To store the qos watcher values before they are written to pcam when watcher + * is enabled. There is no cvmx-pip.c file exist so it ended up here + */ +struct cvmx_pki_legacy_qos_watcher qos_watcher[8]; + +/** @INTERNAL + * This function setsup default ltype map + * @param node node number + */ +void __cvmx_helper_pki_set_dflt_ltype_map(int node) +{ + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_NONE, + CVMX_PKI_BELTYPE_NONE); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_ENET, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_VLAN, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SNAP_PAYLD, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_ARP, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_RARP, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IP4, + CVMX_PKI_BELTYPE_IP4); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IP4_OPT, + CVMX_PKI_BELTYPE_IP4); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IP6, + CVMX_PKI_BELTYPE_IP6); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IP6_OPT, + CVMX_PKI_BELTYPE_IP6); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IPSEC_ESP, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IPFRAG, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_IPCOMP, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_TCP, + CVMX_PKI_BELTYPE_TCP); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_UDP, + CVMX_PKI_BELTYPE_UDP); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SCTP, + CVMX_PKI_BELTYPE_SCTP); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_UDP_VXLAN, + CVMX_PKI_BELTYPE_UDP); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_GRE, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_NVGRE, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_GTP, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SW28, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SW29, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SW30, + CVMX_PKI_BELTYPE_MISC); + cvmx_pki_write_ltype_map(node, CVMX_PKI_LTYPE_E_SW31, + CVMX_PKI_BELTYPE_MISC); +} + +/** @INTERNAL + * This function installs the default VLAN entries to identify + * the VLAN and set WQE[vv], WQE[vs] if VLAN is found. In 78XX + * hardware (PKI) is not hardwired to recognize any 802.1Q VLAN + * Ethertypes + * + * @param node node number + */ +int __cvmx_helper_pki_install_dflt_vlan(int node) +{ + struct cvmx_pki_pcam_input pcam_input; + struct cvmx_pki_pcam_action pcam_action; + enum cvmx_pki_term field; + int index; + int bank; + u64 cl_mask = CVMX_PKI_CLUSTER_ALL; + + memset(&pcam_input, 0, sizeof(pcam_input)); + memset(&pcam_action, 0, sizeof(pcam_action)); + + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + /* PKI-20858 */ + int i; + + for (i = 0; i < 4; i++) { + union cvmx_pki_clx_ecc_ctl ecc_ctl; + + ecc_ctl.u64 = + csr_rd_node(node, CVMX_PKI_CLX_ECC_CTL(i)); + ecc_ctl.s.pcam_en = 0; + ecc_ctl.s.pcam0_cdis = 1; + ecc_ctl.s.pcam1_cdis = 1; + csr_wr_node(node, CVMX_PKI_CLX_ECC_CTL(i), ecc_ctl.u64); + } + } + + for (field = CVMX_PKI_PCAM_TERM_ETHTYPE0; + field < CVMX_PKI_PCAM_TERM_ETHTYPE2; field++) { + bank = field & 0x01; + + index = cvmx_pki_pcam_entry_alloc( + node, CVMX_PKI_FIND_AVAL_ENTRY, bank, cl_mask); + if (index < 0) { + debug("ERROR: Allocating pcam entry node=%d bank=%d\n", + node, bank); + return -1; + } + pcam_input.style = 0; + pcam_input.style_mask = 0; + pcam_input.field = field; + pcam_input.field_mask = 0xfd; + pcam_input.data = 0x81000000; + pcam_input.data_mask = 0xffff0000; + pcam_action.parse_mode_chg = CVMX_PKI_PARSE_NO_CHG; + pcam_action.layer_type_set = CVMX_PKI_LTYPE_E_VLAN; + pcam_action.style_add = 0; + pcam_action.pointer_advance = 4; + cvmx_pki_pcam_write_entry( + node, index, cl_mask, pcam_input, + pcam_action); /*cluster_mask in pass2*/ + + index = cvmx_pki_pcam_entry_alloc( + node, CVMX_PKI_FIND_AVAL_ENTRY, bank, cl_mask); + if (index < 0) { + debug("ERROR: Allocating pcam entry node=%d bank=%d\n", + node, bank); + return -1; + } + pcam_input.data = 0x88a80000; + cvmx_pki_pcam_write_entry(node, index, cl_mask, pcam_input, + pcam_action); + + index = cvmx_pki_pcam_entry_alloc( + node, CVMX_PKI_FIND_AVAL_ENTRY, bank, cl_mask); + if (index < 0) { + debug("ERROR: Allocating pcam entry node=%d bank=%d\n", + node, bank); + return -1; + } + pcam_input.data = 0x92000000; + cvmx_pki_pcam_write_entry( + node, index, cl_mask, pcam_input, + pcam_action); /* cluster_mask in pass2*/ + + index = cvmx_pki_pcam_entry_alloc( + node, CVMX_PKI_FIND_AVAL_ENTRY, bank, cl_mask); + if (index < 0) { + debug("ERROR: Allocating pcam entry node=%d bank=%d\n", + node, bank); + return -1; + } + pcam_input.data = 0x91000000; + cvmx_pki_pcam_write_entry(node, index, cl_mask, pcam_input, + pcam_action); + } + return 0; +} + +static int __cvmx_helper_setup_pki_cluster_groups(int node) +{ + u64 cl_mask; + int cl_group; + + cl_group = + cvmx_pki_cluster_grp_alloc(node, pki_dflt_clgrp[node].grp_num); + if (cl_group == CVMX_RESOURCE_ALLOC_FAILED) + return -1; + else if (cl_group == CVMX_RESOURCE_ALREADY_RESERVED) { + if (pki_dflt_clgrp[node].grp_num == -1) + return -1; + else + return 0; /* cluster already configured, share it */ + } + cl_mask = pki_dflt_clgrp[node].cluster_mask; + if (pki_helper_debug) + debug("pki-helper: setup pki cluster grp %d with cl_mask 0x%llx\n", + (int)cl_group, (unsigned long long)cl_mask); + cvmx_pki_attach_cluster_to_group(node, cl_group, cl_mask); + return 0; +} + +/** + * This function sets up pools/auras to be used by PKI + * @param node node number + */ +static int __cvmx_helper_pki_setup_fpa_pools(int node) +{ + u64 buffer_count; + u64 buffer_size; + + if (__cvmx_fpa3_aura_valid(pki_dflt_aura[node].aura)) + return 0; /* aura already configured, share it */ + + buffer_count = pki_dflt_pool[node].buffer_count; + buffer_size = pki_dflt_pool[node].buffer_size; + + if (buffer_count != 0) { + pki_dflt_pool[node].pool = cvmx_fpa3_setup_fill_pool( + node, pki_dflt_pool[node].pool_num, "PKI POOL DFLT", + buffer_size, buffer_count, NULL); + if (!__cvmx_fpa3_pool_valid(pki_dflt_pool[node].pool)) { + cvmx_printf("ERROR: %s: Failed to allocate pool %d\n", + __func__, pki_dflt_pool[node].pool_num); + return -1; + } + pki_dflt_pool[node].pool_num = pki_dflt_pool[node].pool.lpool; + + if (pki_helper_debug) + debug("%s pool %d with buffer size %d cnt %d\n", + __func__, pki_dflt_pool[node].pool_num, + (int)buffer_size, (int)buffer_count); + + pki_dflt_aura[node].pool_num = pki_dflt_pool[node].pool_num; + pki_dflt_aura[node].pool = pki_dflt_pool[node].pool; + } + + buffer_count = pki_dflt_aura[node].buffer_count; + + if (buffer_count != 0) { + pki_dflt_aura[node].aura = cvmx_fpa3_set_aura_for_pool( + pki_dflt_aura[node].pool, pki_dflt_aura[node].aura_num, + "PKI DFLT AURA", buffer_size, buffer_count); + + if (!__cvmx_fpa3_aura_valid(pki_dflt_aura[node].aura)) { + debug("ERROR: %sL Failed to allocate aura %d\n", + __func__, pki_dflt_aura[node].aura_num); + return -1; + } + } + return 0; +} + +static int __cvmx_helper_setup_pki_qpg_table(int node) +{ + int offset; + + offset = cvmx_pki_qpg_entry_alloc(node, pki_dflt_qpg[node].qpg_base, 1); + if (offset == CVMX_RESOURCE_ALLOC_FAILED) + return -1; + else if (offset == CVMX_RESOURCE_ALREADY_RESERVED) + return 0; /* share the qpg table entry */ + if (pki_helper_debug) + debug("pki-helper: set qpg entry at offset %d with port add %d aura %d grp_ok %d grp_bad %d\n", + offset, pki_dflt_qpg[node].port_add, + pki_dflt_qpg[node].aura_num, pki_dflt_qpg[node].grp_ok, + pki_dflt_qpg[node].grp_bad); + cvmx_pki_write_qpg_entry(node, offset, &pki_dflt_qpg[node]); + return 0; +} + +int __cvmx_helper_pki_port_setup(int node, int ipd_port) +{ + int xiface, index; + int pknd, style_num; + int rs; + struct cvmx_pki_pkind_config pkind_cfg; + + if (!cvmx_pki_dflt_init[node]) + return 0; + xiface = cvmx_helper_get_interface_num(ipd_port); + index = cvmx_helper_get_interface_index_num(ipd_port); + + pknd = cvmx_helper_get_pknd(xiface, index); + style_num = pkind_style_map[node][pknd]; + + /* try to reserve the style, if it is not configured already, reserve + and configure it */ + rs = cvmx_pki_style_alloc(node, style_num); + if (rs < 0) { + if (rs == CVMX_RESOURCE_ALLOC_FAILED) + return -1; + } else { + if (pki_helper_debug) + debug("pki-helper: set style %d with default parameters\n", + style_num); + pkind_style_map[node][pknd] = style_num; + /* configure style with default parameters */ + cvmx_pki_write_style_config(node, style_num, + CVMX_PKI_CLUSTER_ALL, + &pki_dflt_style[node]); + } + if (pki_helper_debug) + debug("pki-helper: set pkind %d with initial style %d\n", pknd, + style_num); + /* write pkind configuration */ + pkind_cfg = pki_dflt_pkind[node]; + pkind_cfg.initial_style = style_num; + cvmx_pki_write_pkind_config(node, pknd, &pkind_cfg); + return 0; +} + +int __cvmx_helper_pki_global_setup(int node) +{ + __cvmx_helper_pki_set_dflt_ltype_map(node); + if (!cvmx_pki_dflt_init[node]) + return 0; + /* Setup the packet pools*/ + __cvmx_helper_pki_setup_fpa_pools(node); + /*set up default cluster*/ + __cvmx_helper_setup_pki_cluster_groups(node); + //__cvmx_helper_pki_setup_sso_groups(node); + __cvmx_helper_setup_pki_qpg_table(node); + /* + * errata PKI-19103 backward compat has only 1 aura + * no head line blocking + */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + cvmx_pki_buf_ctl_t buf_ctl; + + buf_ctl.u64 = csr_rd_node(node, CVMX_PKI_BUF_CTL); + buf_ctl.s.fpa_wait = 1; + csr_wr_node(node, CVMX_PKI_BUF_CTL, buf_ctl.u64); + } + return 0; +} + +/** + * This function Enabled the PKI hardware to + * start accepting/processing packets. + * + * @param node node number + */ +void cvmx_helper_pki_enable(int node) +{ + if (pki_helper_debug) + debug("enable PKI on node %d\n", node); + __cvmx_helper_pki_install_dflt_vlan(node); + cvmx_pki_setup_clusters(node); + if (cvmx_pki_dflt_bp_en[node]) + cvmx_pki_enable_backpressure(node); + cvmx_pki_parse_enable(node, 0); + cvmx_pki_enable(node); +} + +/** + * This function setups the qos table by allocating qpg entry and writing + * the provided parameters to that entry (offset). + * @param node node number. + * @param qpg_cfg pointer to struct containing qpg configuration + */ +int cvmx_helper_pki_set_qpg_entry(int node, struct cvmx_pki_qpg_config *qpg_cfg) +{ + int offset; + + offset = cvmx_pki_qpg_entry_alloc(node, qpg_cfg->qpg_base, 1); + if (pki_helper_debug) + debug("pki-helper:set qpg entry at offset %d\n", offset); + if (offset == CVMX_RESOURCE_ALREADY_RESERVED) { + debug("INFO:setup_qpg_table: offset %d already reserved\n", + qpg_cfg->qpg_base); + return CVMX_RESOURCE_ALREADY_RESERVED; + } else if (offset == CVMX_RESOURCE_ALLOC_FAILED) { + debug("ERROR:setup_qpg_table: no more entries available\n"); + return CVMX_RESOURCE_ALLOC_FAILED; + } + qpg_cfg->qpg_base = offset; + cvmx_pki_write_qpg_entry(node, offset, qpg_cfg); + return offset; +} + +/** + * This function gets all the PKI parameters related to that + * particular port from hardware. + * @param xipd_port xipd_port port number with node to get parameter of + * @param port_cfg pointer to structure where to store read parameters + */ +void cvmx_pki_get_port_config(int xipd_port, + struct cvmx_pki_port_config *port_cfg) +{ + int xiface, index, pknd; + int style, cl_mask; + cvmx_pki_icgx_cfg_t pki_cl_msk; + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + + /* get the pkind used by this ipd port */ + xiface = cvmx_helper_get_interface_num(xipd_port); + index = cvmx_helper_get_interface_index_num(xipd_port); + pknd = cvmx_helper_get_pknd(xiface, index); + + cvmx_pki_read_pkind_config(xp.node, pknd, &port_cfg->pkind_cfg); + style = port_cfg->pkind_cfg.initial_style; + pki_cl_msk.u64 = csr_rd_node( + xp.node, CVMX_PKI_ICGX_CFG(port_cfg->pkind_cfg.cluster_grp)); + cl_mask = pki_cl_msk.s.clusters; + cvmx_pki_read_style_config(xp.node, style, cl_mask, + &port_cfg->style_cfg); +} + +/** + * This function sets all the PKI parameters related to that + * particular port in hardware. + * @param xipd_port ipd port number with node to get parameter of + * @param port_cfg pointer to structure containing port parameters + */ +void cvmx_pki_set_port_config(int xipd_port, + struct cvmx_pki_port_config *port_cfg) +{ + int xiface, index, pknd; + int style, cl_mask; + cvmx_pki_icgx_cfg_t pki_cl_msk; + struct cvmx_xport xp = cvmx_helper_ipd_port_to_xport(xipd_port); + + /* get the pkind used by this ipd port */ + xiface = cvmx_helper_get_interface_num(xipd_port); + index = cvmx_helper_get_interface_index_num(xipd_port); + pknd = cvmx_helper_get_pknd(xiface, index); + + if (cvmx_pki_write_pkind_config(xp.node, pknd, &port_cfg->pkind_cfg)) + return; + style = port_cfg->pkind_cfg.initial_style; + pki_cl_msk.u64 = csr_rd_node( + xp.node, CVMX_PKI_ICGX_CFG(port_cfg->pkind_cfg.cluster_grp)); + cl_mask = pki_cl_msk.s.clusters; + cvmx_pki_write_style_config(xp.node, style, cl_mask, + &port_cfg->style_cfg); +} + +/** + * This function sets up all th eports of particular interface + * for chosen fcs mode. (only use for backward compatibility). + * New application can control it via init_interface calls. + * @param node node number. + * @param interface interface number. + * @param nports number of ports + * @param has_fcs 1 -- enable fcs check and fcs strip. + * 0 -- disable fcs check. + */ +void cvmx_helper_pki_set_fcs_op(int node, int interface, int nports, + int has_fcs) +{ + int xiface, index; + int pknd; + unsigned int cluster = 0; + cvmx_pki_clx_pkindx_cfg_t pkind_cfg; + + xiface = cvmx_helper_node_interface_to_xiface(node, interface); + for (index = 0; index < nports; index++) { + pknd = cvmx_helper_get_pknd(xiface, index); + while (cluster < CVMX_PKI_NUM_CLUSTER) { + /*find the cluster in use pass2*/ + pkind_cfg.u64 = csr_rd_node( + node, CVMX_PKI_CLX_PKINDX_CFG(pknd, cluster)); + pkind_cfg.s.fcs_pres = has_fcs; + csr_wr_node(node, + CVMX_PKI_CLX_PKINDX_CFG(pknd, cluster), + pkind_cfg.u64); + cluster++; + } + /* make sure fcs_strip and fcs_check is also enable/disable + * for the style used by that port + */ + cvmx_pki_endis_fcs_check(node, pknd, has_fcs, has_fcs); + cluster = 0; + } +}
Import cvmx-helper-pko.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-pko.c | 203 ++++++++++++++++++++++++ 1 file changed, 203 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-pko.c b/arch/mips/mach-octeon/cvmx-helper-pko.c new file mode 100644 index 000000000000..b9ac22cf0081 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-pko.c @@ -0,0 +1,203 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Helper Functions for the PKO + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-ipd.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +static s64 pko_fpa_config_pool = -1; +static u64 pko_fpa_config_size = 1024; + +/** + * cvmx_override_pko_queue_priority(int pko_port, u64 + * priorities[16]) is a function pointer. It is meant to allow + * customization of the PKO queue priorities based on the port + * number. Users should set this pointer to a function before + * calling any cvmx-helper operations. + */ +void (*cvmx_override_pko_queue_priority)(int ipd_port, + uint8_t *priorities) = NULL; + +int64_t cvmx_fpa_get_pko_pool(void) +{ + return pko_fpa_config_pool; +} + +/** + * Gets the buffer size of pko pool + */ +u64 cvmx_fpa_get_pko_pool_block_size(void) +{ + return pko_fpa_config_size; +} + +/** + * Initialize PKO command queue buffer pool + */ +static int cvmx_helper_pko_pool_init(void) +{ + u8 pool; + unsigned int buf_count; + unsigned int pkt_buf_count; + int rc; + + /* Reserve pool */ + pool = cvmx_fpa_get_pko_pool(); + + /* Avoid redundant pool creation */ + if (cvmx_fpa_get_block_size(pool) > 0) { +#ifdef DEBUG + debug("WARNING: %s: pool %d already initialized\n", __func__, + pool); +#endif + /* It is up to the app to have sufficient buffer count */ + return pool; + } + + /* Calculate buffer count: one per queue + 3-word-cmds * max_pkts */ + pkt_buf_count = cvmx_fpa_get_packet_pool_buffer_count(); + buf_count = CVMX_PKO_MAX_OUTPUT_QUEUES + (pkt_buf_count * 3) / 8; + + /* Allocate pools for pko command queues */ + rc = __cvmx_helper_initialize_fpa_pool(pool, + cvmx_fpa_get_pko_pool_block_size(), + buf_count, "PKO Cmd-bufs"); + + if (rc < 0) + debug("%s: ERROR: in PKO buffer pool\n", __func__); + + pool = rc; + return pool; +} + +/** + * Initialize the PKO + * + */ +int cvmx_helper_pko_init(void) +{ + int rc; + + rc = cvmx_helper_pko_pool_init(); + if (rc < 0) + return rc; + + __cvmx_helper_init_port_config_data(0); + + cvmx_pko_hw_init(cvmx_fpa_get_pko_pool(), + cvmx_fpa_get_pko_pool_block_size()); + return 0; +} + +/** + * @INTERNAL + * Setup the PKO for the ports on an interface. The number of + * queues per port and the priority of each PKO output queue + * is set here. PKO must be disabled when this function is called. + * + * @param interface to setup PKO for + * + * @return Zero on success, negative on failure + * + * @note This is for PKO1/PKO2, and is not used for PKO3. + */ +int __cvmx_helper_interface_setup_pko(int interface) +{ + /* + * Each packet output queue has an associated priority. The + * higher the priority, the more often it can send a packet. A + * priority of 8 means it can send in all 8 rounds of + * contention. We're going to make each queue one less than + * the last. The vector of priorities has been extended to + * support CN5xxx CPUs, where up to 16 queues can be + * associated to a port. To keep backward compatibility we + * don't change the initial 8 priorities and replicate them in + * the second half. With per-core PKO queues (PKO lockless + * operation) all queues have the same priority. + */ + /* uint8_t priorities[16] = {8,7,6,5,4,3,2,1,8,7,6,5,4,3,2,1}; */ + u8 priorities[16] = { [0 ... 15] = 8 }; + + /* + * Setup the IPD/PIP and PKO for the ports discovered + * above. Here packet classification, tagging and output + * priorities are set. + */ + int num_ports = cvmx_helper_ports_on_interface(interface); + + while (num_ports--) { + int ipd_port; + + if (!cvmx_helper_is_port_valid(interface, num_ports)) + continue; + + ipd_port = cvmx_helper_get_ipd_port(interface, num_ports); + /* + * Give the user a chance to override the per queue + * priorities. + */ + if (cvmx_override_pko_queue_priority) + cvmx_override_pko_queue_priority(ipd_port, priorities); + + cvmx_pko_config_port(ipd_port, + cvmx_pko_get_base_queue(ipd_port), + cvmx_pko_get_num_queues(ipd_port), + priorities); + ipd_port++; + } + return 0; + /* NOTE: + * Now this function is called for all chips including 68xx, + * but on the 68xx it does not enable multiple pko_iports per + * eport, while before it was doing 3 pko_iport per eport + * buf the reason for that is not clear. + */ +}
Import cvmx-helper-pko3.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-pko3.c | 1088 ++++++++++++++++++++++ 1 file changed, 1088 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko3.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-pko3.c b/arch/mips/mach-octeon/cvmx-helper-pko3.c new file mode 100644 index 000000000000..37fe45d71f4b --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-pko3.c @@ -0,0 +1,1088 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * PKOv3 helper file + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-ipd.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +/* channels are present at L2 queue level by default */ +static const enum cvmx_pko3_level_e cvmx_pko_default_channel_level = + CVMX_PKO_L2_QUEUES; + +static const int debug; + +static int __pko_pkt_budget, __pko_pkt_quota; + +/* These global variables are relevant for boot CPU only */ +static cvmx_fpa3_gaura_t __cvmx_pko3_aura[CVMX_MAX_NODES]; + +/* This constant can not be modified, defined here for clarity only */ +#define CVMX_PKO3_POOL_BUFFER_SIZE 4096 /* 78XX PKO requires 4KB */ + +/** + * @INTERNAL + * + * Build an owner tag based on interface/port + */ +static int __cvmx_helper_pko3_res_owner(int ipd_port) +{ + int res_owner; + const int res_owner_pfix = 0x19d0 << 14; + + ipd_port &= 0x3fff; /* 12-bit for local CHAN_E value + node */ + + res_owner = res_owner_pfix | ipd_port; + + return res_owner; +} + +/** + * Configure an AURA/POOL designated for PKO internal use. + * + * This pool is used for (a) memory buffers that store PKO descriptor queues, + * (b) buffers for use with PKO_SEND_JUMP_S sub-header. + * + * The buffers of type (a) are never accessed by software, and their number + * should be at least equal to 4 times the number of descriptor queues + * in use. + * + * Type (b) buffers are consumed by PKO3 command-composition code, + * and are released by the hardware upon completion of transmission. + * + * @returns -1 if the pool could not be established or 12-bit AURA + * that includes the node number for use in PKO3 initialization call. + * + * NOTE: Linux kernel should pass its own aura to PKO3 initialization + * function so that the buffers can be mapped into kernel space + * for when software needs to adccess their contents. + * + */ +static int __cvmx_pko3_config_memory(unsigned int node) +{ + cvmx_fpa3_gaura_t aura; + int aura_num; + unsigned int buf_count; + bool small_mem; + int i, num_intf = 0; + const unsigned int pkt_per_buf = + (CVMX_PKO3_POOL_BUFFER_SIZE / sizeof(u64) / 16); + const unsigned int base_buf_count = 1024 * 4; + + /* Simulator has limited memory, but uses one interface at a time */ + // small_mem = cvmx_sysinfo_get()->board_type == CVMX_BOARD_TYPE_SIM; + small_mem = false; + + /* Count the number of live interfaces */ + for (i = 0; i < cvmx_helper_get_number_of_interfaces(); i++) { + int xiface = cvmx_helper_node_interface_to_xiface(node, i); + + if (CVMX_HELPER_INTERFACE_MODE_DISABLED != + cvmx_helper_interface_get_mode(xiface)) + num_intf++; + } + + buf_count = 1024; + __pko_pkt_quota = buf_count * pkt_per_buf; + __pko_pkt_budget = __pko_pkt_quota * num_intf; + (void)small_mem; + (void)base_buf_count; + + if (debug) + debug("%s: Creating AURA with %u buffers for up to %d total packets, %d packets per interface\n", + __func__, buf_count, __pko_pkt_budget, __pko_pkt_quota); + + aura = cvmx_fpa3_setup_aura_and_pool(node, -1, "PKO3 AURA", NULL, + CVMX_PKO3_POOL_BUFFER_SIZE, + buf_count); + + if (!__cvmx_fpa3_aura_valid(aura)) { + printf("ERROR: %s AURA create failed\n", __func__); + return -1; + } + + aura_num = aura.node << 10 | aura.laura; + + /* Store handle for destruction */ + __cvmx_pko3_aura[node] = aura; + + return aura_num; +} + +/** Initialize a channelized port + * This is intended for LOOP, ILK and NPI interfaces which have one MAC + * per interface and need a channel per subinterface (e.g. ring). + * Each channel then may have 'num_queues' descriptor queues + * attached to it, which can also be prioritized or fair. + */ +static int __cvmx_pko3_config_chan_interface(int xiface, unsigned int num_chans, + u8 num_queues, bool prioritized) +{ + int l1_q_num; + int l2_q_base; + enum cvmx_pko3_level_e level; + int res; + int parent_q, child_q; + unsigned int chan, dq; + int pko_mac_num; + u16 ipd_port; + int res_owner, prio; + unsigned int i; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + unsigned int node = xi.node; + char b1[12]; + + if (num_queues == 0) + num_queues = 1; + if ((cvmx_pko3_num_level_queues(CVMX_PKO_DESCR_QUEUES) / num_chans) < 3) + num_queues = 1; + + if (prioritized && num_queues > 1) + prio = num_queues; + else + prio = -1; + + if (debug) + debug("%s: configuring xiface %u:%u with %u chans %u queues each\n", + __func__, xi.node, xi.interface, num_chans, num_queues); + + /* all channels all go to the same mac */ + pko_mac_num = __cvmx_pko3_get_mac_num(xiface, 0); + if (pko_mac_num < 0) { + printf("ERROR: %s: Invalid interface\n", __func__); + return -1; + } + + /* Resources of all channels on this port have common owner */ + ipd_port = cvmx_helper_get_ipd_port(xiface, 0); + + /* Build an identifiable owner */ + res_owner = __cvmx_helper_pko3_res_owner(ipd_port); + + /* Start configuration at L1/PQ */ + level = CVMX_PKO_PORT_QUEUES; + + /* Reserve port queue to make sure the MAC is not already configured */ + l1_q_num = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (l1_q_num < 0) { + printf("ERROR: %s: Reserving L1 PQ\n", __func__); + return -1; + } + + res = cvmx_pko3_pq_config(node, pko_mac_num, l1_q_num); + if (res < 0) { + printf("ERROR: %s: Configuring L1 PQ\n", __func__); + return -1; + } + + /* next queue level = L2/SQ */ + level = __cvmx_pko3_sq_lvl_next(level); + + /* allocate level 2 queues, one per channel */ + l2_q_base = + cvmx_pko_alloc_queues(node, level, res_owner, -1, num_chans); + if (l2_q_base < 0) { + printf("ERROR: %s: allocation L2 SQ\n", __func__); + return -1; + } + + /* Configre <num_chans> L2 children for PQ, non-prioritized */ + res = cvmx_pko3_sq_config_children(node, level, l1_q_num, l2_q_base, + num_chans, -1); + + if (res < 0) { + printf("ERROR: %s: Failed channel queues\n", __func__); + return -1; + } + + /* map channels to l2 queues */ + for (chan = 0; chan < num_chans; chan++) { + ipd_port = cvmx_helper_get_ipd_port(xiface, chan); + cvmx_pko3_map_channel(node, l1_q_num, l2_q_base + chan, + ipd_port); + } + + /* next queue level = L3/SQ */ + level = __cvmx_pko3_sq_lvl_next(level); + parent_q = l2_q_base; + + do { + child_q = cvmx_pko_alloc_queues(node, level, res_owner, -1, + num_chans); + + if (child_q < 0) { + printf("ERROR: %s: allocating %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + for (i = 0; i < num_chans; i++) { + res = cvmx_pko3_sq_config_children( + node, level, parent_q + i, child_q + i, 1, 1); + + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + } /* for i */ + + parent_q = child_q; + level = __cvmx_pko3_sq_lvl_next(level); + + /* Terminate loop on DQ level, it has special handling */ + } while (level != CVMX_PKO_DESCR_QUEUES && + level != CVMX_PKO_LEVEL_INVAL); + + if (level != CVMX_PKO_DESCR_QUEUES) { + printf("ERROR: %s: level sequence error\n", __func__); + return -1; + } + + /* Configure DQs, num_dqs per chan */ + for (chan = 0; chan < num_chans; chan++) { + res = cvmx_pko_alloc_queues(node, level, res_owner, -1, + num_queues); + + if (res < 0) + goto _fail; + dq = res; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0) && (dq & 7)) + debug("WARNING: %s: DQ# %u not integral of 8\n", + __func__, dq); + + res = cvmx_pko3_sq_config_children(node, level, parent_q + chan, + dq, num_queues, prio); + if (res < 0) + goto _fail; + + /* register DQ range with the translation table */ + res = __cvmx_pko3_ipd_dq_register(xiface, chan, dq, num_queues); + if (res < 0) + goto _fail; + } + + return 0; +_fail: + debug("ERROR: %s: configuring queues for xiface %u:%u chan %u\n", + __func__, xi.node, xi.interface, i); + return -1; +} + +/** Initialize a single Ethernet port with PFC-style channels + * + * One interface can contain multiple ports, this function is per-port + * Here, a physical port is allocated 8 logical channel, one per VLAN + * tag priority, one DQ is assigned to each channel, and all 8 DQs + * are registered for that IPD port. + * Note that the DQs are arrange such that the Ethernet QoS/PCP field + * can be used as an offset to the value returned by cvmx_pko_base_queue_get(). + * + * For HighGig2 mode, 16 channels may be desired, instead of 8, + * but this function does not support that. + */ +static int __cvmx_pko3_config_pfc_interface(int xiface, unsigned int port) +{ + enum cvmx_pko3_level_e level; + int pko_mac_num; + int l1_q_num, l2_q_base; + int child_q, parent_q; + int dq_base; + int res; + const unsigned int num_chans = 8; + cvmx_xiface_t xi = cvmx_helper_xiface_to_node_interface(xiface); + unsigned int node = xi.node; + u16 ipd_port; + int res_owner; + char b1[12]; + unsigned int i; + + if (debug) + debug("%s: configuring xiface %u:%u port %u with %u PFC channels\n", + __func__, node, xi.interface, port, num_chans); + + /* Get MAC number for the iface/port */ + pko_mac_num = __cvmx_pko3_get_mac_num(xiface, port); + if (pko_mac_num < 0) { + printf("ERROR: %s: Invalid interface\n", __func__); + return -1; + } + + ipd_port = cvmx_helper_get_ipd_port(xiface, port); + + /* Build an identifiable owner identifier */ + res_owner = __cvmx_helper_pko3_res_owner(ipd_port); + + level = CVMX_PKO_PORT_QUEUES; + + /* Allocate port queue to make sure the MAC is not already configured */ + l1_q_num = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (l1_q_num < 0) { + printf("ERROR: %s: allocation L1 PQ\n", __func__); + return -1; + } + + res = cvmx_pko3_pq_config(xi.node, pko_mac_num, l1_q_num); + if (res < 0) { + printf("ERROR: %s: Configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, l1_q_num)); + return -1; + } + + /* Determine the next queue level */ + level = __cvmx_pko3_sq_lvl_next(level); + + /* Allocate 'num_chans' L2 queues, one per channel */ + l2_q_base = + cvmx_pko_alloc_queues(node, level, res_owner, -1, num_chans); + if (l2_q_base < 0) { + printf("ERROR: %s: allocation L2 SQ\n", __func__); + return -1; + } + + /* Configre <num_chans> L2 children for PQ, with static priority */ + res = cvmx_pko3_sq_config_children(node, level, l1_q_num, l2_q_base, + num_chans, num_chans); + + if (res < 0) { + printf("ERROR: %s: Configuring %s for PFC\n", __func__, + __cvmx_pko3_sq_str(b1, level, l1_q_num)); + return -1; + } + + /* Map each of the allocated channels */ + for (i = 0; i < num_chans; i++) { + u16 chan; + + /* Get CHAN_E value for this PFC channel, PCP in low 3 bits */ + chan = ipd_port | cvmx_helper_prio2qos(i); + + cvmx_pko3_map_channel(node, l1_q_num, l2_q_base + i, chan); + } + + /* Iterate through the levels until DQ and allocate 'num_chans' + * consecutive queues at each level and hook them up + * one-to-one with the parent level queues + */ + + parent_q = l2_q_base; + level = __cvmx_pko3_sq_lvl_next(level); + + do { + child_q = cvmx_pko_alloc_queues(node, level, res_owner, -1, + num_chans); + + if (child_q < 0) { + printf("ERROR: %s: allocating %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + for (i = 0; i < num_chans; i++) { + res = cvmx_pko3_sq_config_children( + node, level, parent_q + i, child_q + i, 1, 1); + + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + } /* for i */ + + parent_q = child_q; + level = __cvmx_pko3_sq_lvl_next(level); + + /* Terminate loop on DQ level, it has special handling */ + } while (level != CVMX_PKO_DESCR_QUEUES && + level != CVMX_PKO_LEVEL_INVAL); + + if (level != CVMX_PKO_DESCR_QUEUES) { + printf("ERROR: %s: level sequence error\n", __func__); + return -1; + } + + dq_base = cvmx_pko_alloc_queues(node, level, res_owner, -1, num_chans); + if (dq_base < 0) { + printf("ERROR: %s: allocating %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, dq_base)); + return -1; + } + + /* Configure DQs in QoS order, so that QoS/PCP can be index */ + for (i = 0; i < num_chans; i++) { + int dq_num = dq_base + cvmx_helper_prio2qos(i); + + res = cvmx_pko3_sq_config_children(node, level, parent_q + i, + dq_num, 1, 1); + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, dq_num)); + return -1; + } + } + + /* register entire DQ range with the IPD translation table */ + __cvmx_pko3_ipd_dq_register(xiface, port, dq_base, num_chans); + + return 0; +} + +/** + * Initialize a simple interface with a a given number of + * fair or prioritized queues. + * This function will assign one channel per sub-interface. + */ +int __cvmx_pko3_config_gen_interface(int xiface, uint8_t subif, u8 num_queues, + bool prioritized) +{ + cvmx_xiface_t xi = cvmx_helper_xiface_to_node_interface(xiface); + u8 node = xi.node; + int l1_q_num; + int parent_q, child_q; + int dq; + int res, res_owner; + int pko_mac_num; + enum cvmx_pko3_level_e level; + u16 ipd_port; + int static_pri; + char b1[12]; + + num_queues = 1; + + if (num_queues == 0) { + num_queues = 1; + printf("WARNING: %s: xiface %#x misconfigured\n", __func__, + xiface); + } + + /* Configure DQs relative priority (a.k.a. scheduling) */ + if (prioritized) { + /* With 8 queues or fewer, use static priority, else WRR */ + static_pri = (num_queues < 9) ? num_queues : 0; + } else { + /* Set equal-RR scheduling among queues */ + static_pri = -1; + } + + if (debug) + debug("%s: configuring xiface %u:%u/%u nq=%u %s\n", __func__, + xi.node, xi.interface, subif, num_queues, + (prioritized) ? "qos" : "fair"); + + /* Get MAC number for the iface/port */ + pko_mac_num = __cvmx_pko3_get_mac_num(xiface, subif); + if (pko_mac_num < 0) { + printf("ERROR: %s: Invalid interface %u:%u\n", __func__, + xi.node, xi.interface); + return -1; + } + + ipd_port = cvmx_helper_get_ipd_port(xiface, subif); + + if (debug) + debug("%s: xiface %u:%u/%u ipd_port=%#03x\n", __func__, xi.node, + xi.interface, subif, ipd_port); + + /* Build an identifiable owner identifier */ + res_owner = __cvmx_helper_pko3_res_owner(ipd_port); + + level = CVMX_PKO_PORT_QUEUES; + + /* Reserve port queue to make sure the MAC is not already configured */ + l1_q_num = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (l1_q_num < 0) { + printf("ERROR %s: xiface %u:%u/%u failed allocation L1 PQ\n", + __func__, xi.node, xi.interface, subif); + return -1; + } + + res = cvmx_pko3_pq_config(node, pko_mac_num, l1_q_num); + if (res < 0) { + printf("ERROR %s: Configuring L1 PQ\n", __func__); + return -1; + } + + parent_q = l1_q_num; + + /* Determine the next queue level */ + level = __cvmx_pko3_sq_lvl_next(level); + + /* Simply chain queues 1-to-1 from L2 to one before DQ level */ + do { + /* allocate next level queue */ + child_q = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (child_q < 0) { + printf("ERROR: %s: allocating %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + /* Configre newly allocated queue */ + res = cvmx_pko3_sq_config_children(node, level, parent_q, + child_q, 1, 1); + + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + /* map IPD/channel to L2/L3 queues */ + if (level == cvmx_pko_default_channel_level) + cvmx_pko3_map_channel(node, l1_q_num, child_q, + ipd_port); + + /* Prepare for next level */ + level = __cvmx_pko3_sq_lvl_next(level); + parent_q = child_q; + + /* Terminate loop on DQ level, it has special handling */ + } while (level != CVMX_PKO_DESCR_QUEUES && + level != CVMX_PKO_LEVEL_INVAL); + + if (level != CVMX_PKO_DESCR_QUEUES) { + printf("ERROR: %s: level sequence error\n", __func__); + return -1; + } + + /* Allocate descriptor queues for the port */ + dq = cvmx_pko_alloc_queues(node, level, res_owner, -1, num_queues); + if (dq < 0) { + printf("ERROR: %s: could not reserve DQs\n", __func__); + return -1; + } + + res = cvmx_pko3_sq_config_children(node, level, parent_q, dq, + num_queues, static_pri); + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, dq)); + return -1; + } + + /* register DQ/IPD translation */ + __cvmx_pko3_ipd_dq_register(xiface, subif, dq, num_queues); + + if (debug) + debug("%s: xiface %u:%u/%u qs %u-%u\n", __func__, xi.node, + xi.interface, subif, dq, dq + num_queues - 1); + return 0; +} + +/** Initialize the NULL interface + * + * A NULL interface is a special case in that it is not + * one of the enumerated interfaces in the system, and does + * not apply to input either. Still, it can be very handy + * for dealing with packets that should be discarded in + * a generic, streamlined way. + * + * The Descriptor Queue 0 will be reserved for the NULL interface + * and the normalized (i.e. IPD) port number has the all-ones value. + */ +static int __cvmx_pko3_config_null_interface(unsigned int node) +{ + int l1_q_num; + int parent_q, child_q; + enum cvmx_pko3_level_e level; + int i, res, res_owner; + int xiface, ipd_port; + int num_dq = 1; /* # of DQs for NULL */ + const int dq = 0; /* Reserve DQ#0 for NULL */ + char pko_mac_num; + char b1[12]; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + pko_mac_num = 0x1C; /* MAC# 28 virtual MAC for NULL */ + else if (OCTEON_IS_MODEL(OCTEON_CN73XX)) + pko_mac_num = 0x0F; /* MAC# 16 virtual MAC for NULL */ + else if (OCTEON_IS_MODEL(OCTEON_CNF75XX)) + pko_mac_num = 0x0A; /* MAC# 10 virtual MAC for NULL */ + else + return -1; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0)) + num_dq = 8; + + if (debug) + debug("%s: null iface dq=%u-%u\n", __func__, dq, + dq + num_dq - 1); + + ipd_port = cvmx_helper_node_to_ipd_port(node, CVMX_PKO3_IPD_PORT_NULL); + + /* Build an identifiable owner identifier by MAC# for easy release */ + res_owner = __cvmx_helper_pko3_res_owner(ipd_port); + if (res_owner < 0) { + debug("%s: ERROR Invalid interface\n", __func__); + return -1; + } + + level = CVMX_PKO_PORT_QUEUES; + + /* Allocate a port queue */ + l1_q_num = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (l1_q_num < 0) { + debug("%s: ERROR reserving L1 SQ\n", __func__); + return -1; + } + + res = cvmx_pko3_pq_config(node, pko_mac_num, l1_q_num); + if (res < 0) { + printf("ERROR: %s: PQ/L1 queue configuration\n", __func__); + return -1; + } + + parent_q = l1_q_num; + + /* Determine the next queue level */ + level = __cvmx_pko3_sq_lvl_next(level); + + /* Simply chain queues 1-to-1 from L2 to one before DQ level */ + do { + /* allocate next level queue */ + child_q = cvmx_pko_alloc_queues(node, level, res_owner, -1, 1); + + if (child_q < 0) { + printf("ERROR: %s: allocating %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + /* Configre newly allocated queue */ + res = cvmx_pko3_sq_config_children(node, level, parent_q, + child_q, 1, 1); + + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, child_q)); + return -1; + } + + /* Prepare for next level */ + level = __cvmx_pko3_sq_lvl_next(level); + parent_q = child_q; + + /* Terminate loop on DQ level, it has special handling */ + } while (level != CVMX_PKO_DESCR_QUEUES && + level != CVMX_PKO_LEVEL_INVAL); + + if (level != CVMX_PKO_DESCR_QUEUES) { + printf("ERROR: %s: level sequence error\n", __func__); + return -1; + } + + /* Reserve 'num_dq' DQ's at 0 by convention */ + res = cvmx_pko_alloc_queues(node, level, res_owner, dq, num_dq); + if (dq != res) { + debug("%s: ERROR: could not reserve DQs\n", __func__); + return -1; + } + + res = cvmx_pko3_sq_config_children(node, level, parent_q, dq, num_dq, + num_dq); + if (res < 0) { + printf("ERROR: %s: configuring %s\n", __func__, + __cvmx_pko3_sq_str(b1, level, dq)); + return -1; + } + + /* NULL interface does not need to map to a CHAN_E */ + + /* register DQ/IPD translation */ + xiface = cvmx_helper_node_interface_to_xiface(node, __CVMX_XIFACE_NULL); + __cvmx_pko3_ipd_dq_register(xiface, 0, dq, num_dq); + + /* open the null DQs here */ + for (i = 0; i < num_dq; i++) { + unsigned int limit = 128; /* NULL never really uses much */ + + cvmx_pko_dq_open(node, dq + i); + cvmx_pko3_dq_set_limit(node, dq + i, limit); + } + + return 0; +} + +/** Open all descriptor queues belonging to an interface/port + * @INTERNAL + */ +int __cvmx_pko3_helper_dqs_activate(int xiface, int index, bool min_pad) +{ + int ipd_port, dq_base, dq_count, i; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + unsigned int limit; + + /* Get local IPD port for the interface */ + ipd_port = cvmx_helper_get_ipd_port(xiface, index); + if (ipd_port < 0) { + printf("ERROR: %s: No IPD port for interface %d port %d\n", + __func__, xiface, index); + return -1; + } + + /* Get DQ# range for the IPD port */ + dq_base = cvmx_pko3_get_queue_base(ipd_port); + dq_count = cvmx_pko3_get_queue_num(ipd_port); + if (dq_base < 0 || dq_count <= 0) { + printf("ERROR: %s: No descriptor queues for interface %d port %d\n", + __func__, xiface, index); + return -1; + } + + /* Mask out node from global DQ# */ + dq_base &= (1 << 10) - 1; + + limit = __pko_pkt_quota / dq_count / + cvmx_helper_interface_enumerate(xiface); + + for (i = 0; i < dq_count; i++) { + /* FIXME: 2ms at 1Gbps max packet rate, make speed dependent */ + cvmx_pko_dq_open(xi.node, dq_base + i); + cvmx_pko3_dq_options(xi.node, dq_base + i, min_pad); + + if (debug) + debug("%s: DQ%u limit %d\n", __func__, dq_base + i, + limit); + + cvmx_pko3_dq_set_limit(xi.node, dq_base + i, limit); + __pko_pkt_budget -= limit; + } + + if (__pko_pkt_budget < 0) + printf("WARNING: %s: PKO buffer deficit %d\n", __func__, + __pko_pkt_budget); + else if (debug) + debug("%s: PKO remaining packet budget: %d\n", __func__, + __pko_pkt_budget); + + return i; +} + +/** Configure and initialize PKO3 for an interface + * + * @param xiface is the interface number to configure + * @return 0 on success. + */ +int cvmx_helper_pko3_init_interface(int xiface) +{ + cvmx_helper_interface_mode_t mode; + int node, iface, subif, num_ports; + bool fcs_enable, pad_enable, pad_enable_pko; + u8 fcs_sof_off = 0; + u8 num_queues = 1; + bool qos = false, pfc = false; + int res = -1; + cvmx_xiface_t xi = cvmx_helper_xiface_to_node_interface(xiface); + + node = xi.node; + iface = xi.interface; + mode = cvmx_helper_interface_get_mode(xiface); + num_ports = cvmx_helper_interface_enumerate(xiface); + subif = 0; + + if ((unsigned int)iface < + NUM_ELEMENTS(__cvmx_pko_queue_static_config[node].pknd.pko_cfg_iface)) { + pfc = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_iface[iface] + .pfc_enable; + num_queues = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_iface[iface] + .queues_per_port; + qos = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_iface[iface] + .qos_enable; + } + + /* Force 8 DQs per port for pass 1.0 to circumvent limitations */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0)) + num_queues = 8; + + /* For ILK there is one IPD port per channel */ + if (mode == CVMX_HELPER_INTERFACE_MODE_ILK) + num_ports = __cvmx_helper_ilk_enumerate(xiface); + + /* Skip non-existent interfaces */ + if (num_ports < 1) { + debug("ERROR: %s: invalid iface %u:%u\n", __func__, node, + iface); + return -1; + } + + if (mode == CVMX_HELPER_INTERFACE_MODE_LOOP) { + num_queues = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_loop.queues_per_port; + qos = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_loop.qos_enable; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0)) + num_queues = 8; + + res = __cvmx_pko3_config_chan_interface(xiface, num_ports, + num_queues, qos); + if (res < 0) + goto __cfg_error; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_NPI) { + num_queues = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_npi.queues_per_port; + qos = __cvmx_pko_queue_static_config[node] + .pknd.pko_cfg_npi.qos_enable; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0)) + num_queues = 8; + + res = __cvmx_pko3_config_chan_interface(xiface, num_ports, + num_queues, qos); + if (res < 0) + goto __cfg_error; + } + /* ILK-specific queue configuration */ + else if (mode == CVMX_HELPER_INTERFACE_MODE_ILK) { + unsigned int num_chans = __cvmx_helper_ilk_enumerate(xiface); + + num_queues = 8; + qos = true; + pfc = false; + + if (num_chans >= 128) + num_queues = 1; + else if (num_chans >= 64) + num_queues = 2; + else if (num_chans >= 32) + num_queues = 4; + else + num_queues = 8; + + res = __cvmx_pko3_config_chan_interface(xiface, num_chans, + num_queues, qos); + } + /* Setup all ethernet configured for PFC */ + else if (pfc) { + /* PFC interfaces have 8 prioritized queues */ + for (subif = 0; subif < num_ports; subif++) { + res = __cvmx_pko3_config_pfc_interface(xiface, subif); + if (res < 0) + goto __cfg_error; + + /* Enable PFC/CBFC on BGX */ + __cvmx_helper_bgx_xaui_config_pfc(node, iface, subif, + true); + } + } else { + /* All other interfaces follow static configuration */ + for (subif = 0; subif < num_ports; subif++) { + res = __cvmx_pko3_config_gen_interface(xiface, subif, + num_queues, qos); + if (res < 0) + goto __cfg_error; + } + } + + fcs_enable = __cvmx_helper_get_has_fcs(xiface); + pad_enable = __cvmx_helper_get_pko_padding(xiface); + + /* Do not use PKO PAD/FCS generation on o78p1.x on BGX interfaces */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) + pad_enable_pko = false; + else + pad_enable_pko = pad_enable; + + if (debug) + debug("%s: iface %u:%u FCS=%d pad=%d pko=%d\n", __func__, node, + iface, fcs_enable, pad_enable, pad_enable_pko); + + /* Setup interface options */ + for (subif = 0; subif < num_ports; subif++) { + /* Open interface/port DQs to allow transmission to begin */ + res = __cvmx_pko3_helper_dqs_activate(xiface, subif, + pad_enable_pko); + + if (res < 0) + goto __cfg_error; + + /* ILK has only one MAC, subif == logical-channel */ + if (mode == CVMX_HELPER_INTERFACE_MODE_ILK && subif > 0) + continue; + + /* LOOP has only one MAC, subif == logical-channel */ + if (mode == CVMX_HELPER_INTERFACE_MODE_LOOP && subif > 0) + continue; + + /* NPI has only one MAC, subif == 'ring' */ + if (mode == CVMX_HELPER_INTERFACE_MODE_NPI && subif > 0) + continue; + + /* for sRIO there is 16 byte sRIO header, outside of FCS */ + if (mode == CVMX_HELPER_INTERFACE_MODE_SRIO) + fcs_sof_off = 16; + + if (iface >= CVMX_HELPER_MAX_GMX) { + /* Non-BGX interface, use PKO for FCS/PAD */ + res = cvmx_pko3_interface_options(xiface, subif, + fcs_enable, + pad_enable_pko, + fcs_sof_off); + } else if (pad_enable == pad_enable_pko) { + /* BGX interface: FCS/PAD done by PKO */ + res = cvmx_pko3_interface_options(xiface, subif, + fcs_enable, + pad_enable, + fcs_sof_off); + cvmx_helper_bgx_tx_options(node, iface, subif, false, + false); + } else { + /* BGX interface: FCS/PAD done by BGX */ + res = cvmx_pko3_interface_options(xiface, subif, false, + false, fcs_sof_off); + cvmx_helper_bgx_tx_options(node, iface, subif, + fcs_enable, pad_enable); + } + + if (res < 0) + debug("WARNING: %s: option set failed on iface %u:%u/%u\n", + __func__, node, iface, subif); + if (debug) + debug("%s: face %u:%u/%u fifo size %d\n", __func__, + node, iface, subif, + cvmx_pko3_port_fifo_size(xiface, subif)); + } + return 0; + +__cfg_error: + debug("ERROR: %s: failed on iface %u:%u/%u\n", __func__, node, iface, + subif); + return -1; +} + +/** + * Global initialization for PKO3 + * + * Should only be called once on each node + * + * TBD: Resolve the kernel case. + * When Linux eats up the entire memory, bootmem will be unable to + * satisfy our request, and the memory needs to come from Linux free pages. + */ +int __cvmx_helper_pko3_init_global(unsigned int node, uint16_t gaura) +{ + int res; + + res = cvmx_pko3_hw_init_global(node, gaura); + if (res < 0) { + debug("ERROR: %s:failed block initialization\n", __func__); + return res; + } + + /* configure channel level */ + cvmx_pko3_channel_credit_level(node, cvmx_pko_default_channel_level); + + /* add NULL MAC/DQ setup */ + res = __cvmx_pko3_config_null_interface(node); + if (res < 0) + debug("ERROR: %s: creating NULL interface\n", __func__); + + return res; +} + +/** + * Global initialization for PKO3 + * + * Should only be called once on each node + * + * When Linux eats up the entire memory, bootmem will be unable to + * satisfy our request, and the memory needs to come from Linux free pages. + */ +int cvmx_helper_pko3_init_global(unsigned int node) +{ + void *ptr; + int res = -1; + unsigned int aura_num = ~0; + cvmx_fpa3_gaura_t aura; + + /* Allocate memory required by PKO3 */ + res = __cvmx_pko3_config_memory(node); + if (res < 0) { + debug("ERROR: %s: PKO3 memory allocation error\n", __func__); + return res; + } + + aura_num = res; + aura = __cvmx_pko3_aura[node]; + + /* Exercise the FPA to make sure the AURA is functional */ + ptr = cvmx_fpa3_alloc(aura); + + if (!ptr) { + res = -1; + } else { + cvmx_fpa3_free_nosync(ptr, aura, 0); + res = 0; + } + + if (res < 0) { + debug("ERROR: %s: FPA failure AURA=%u:%d\n", __func__, + aura.node, aura.laura); + return -1; + } + + res = __cvmx_helper_pko3_init_global(node, aura_num); + + if (res < 0) + debug("ERROR: %s: failed to start PPKO\n", __func__); + + return res; +}
Import cvmx-helper-rgmii.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-rgmii.c | 398 ++++++++++++++++++++++ 1 file changed, 398 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-rgmii.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-rgmii.c b/arch/mips/mach-octeon/cvmx-helper-rgmii.c new file mode 100644 index 000000000000..dc19c3bc1d9b --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-rgmii.c @@ -0,0 +1,398 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for RGMII/GMII/MII initialization, configuration, + * and monitoring. + */ + +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> + +#include <mach/cvmx-hwpko.h> + +#include <mach/cvmx-asxx-defs.h> +#include <mach/cvmx-dbg-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-npi-defs.h> +#include <mach/cvmx-pko-defs.h> + +/** + * @INTERNAL + * Probe RGMII ports and determine the number present + * + * @param xiface Interface to probe + * + * @return Number of RGMII/GMII/MII ports (0-4). + */ +int __cvmx_helper_rgmii_probe(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int num_ports = 0; + union cvmx_gmxx_inf_mode mode; + + mode.u64 = csr_rd(CVMX_GMXX_INF_MODE(xi.interface)); + + if (mode.s.type) + debug("ERROR: Unsupported Octeon model in %s\n", __func__); + else + debug("ERROR: Unsupported Octeon model in %s\n", __func__); + return num_ports; +} + +/** + * @INTERNAL + * Configure all of the ASX, GMX, and PKO regsiters required + * to get RGMII to function on the supplied interface. + * + * @param xiface PKO Interface to configure (0 or 1) + * + * @return Zero on success + */ +int __cvmx_helper_rgmii_enable(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + int num_ports = cvmx_helper_ports_on_interface(interface); + int port; + union cvmx_gmxx_inf_mode mode; + union cvmx_asxx_tx_prt_en asx_tx; + union cvmx_asxx_rx_prt_en asx_rx; + + mode.u64 = csr_rd(CVMX_GMXX_INF_MODE(interface)); + + if (num_ports == -1) + return -1; + if (mode.s.en == 0) + return -1; + + /* Configure the ASX registers needed to use the RGMII ports */ + asx_tx.u64 = 0; + asx_tx.s.prt_en = cvmx_build_mask(num_ports); + csr_wr(CVMX_ASXX_TX_PRT_EN(interface), asx_tx.u64); + + asx_rx.u64 = 0; + asx_rx.s.prt_en = cvmx_build_mask(num_ports); + csr_wr(CVMX_ASXX_RX_PRT_EN(interface), asx_rx.u64); + + /* Configure the GMX registers needed to use the RGMII ports */ + for (port = 0; port < num_ports; port++) { + /* + * Configure more flexible RGMII preamble + * checking. Pass 1 doesn't support this feature. + */ + union cvmx_gmxx_rxx_frm_ctl frm_ctl; + + frm_ctl.u64 = csr_rd(CVMX_GMXX_RXX_FRM_CTL(port, interface)); + /* New field, so must be compile time */ + frm_ctl.s.pre_free = 1; + csr_wr(CVMX_GMXX_RXX_FRM_CTL(port, interface), frm_ctl.u64); + + /* + * Each pause frame transmitted will ask for about 10M + * bit times before resume. If buffer space comes + * available before that time has expired, an XON + * pause frame (0 time) will be transmitted to restart + * the flow. + */ + csr_wr(CVMX_GMXX_TXX_PAUSE_PKT_TIME(port, interface), 20000); + csr_wr(CVMX_GMXX_TXX_PAUSE_PKT_INTERVAL(port, interface), + 19000); + + csr_wr(CVMX_ASXX_TX_CLK_SETX(port, interface), 24); + csr_wr(CVMX_ASXX_RX_CLK_SETX(port, interface), 24); + } + + __cvmx_helper_setup_gmx(interface, num_ports); + + /* enable the ports now */ + for (port = 0; port < num_ports; port++) { + union cvmx_gmxx_prtx_cfg gmx_cfg; + + cvmx_helper_link_autoconf( + cvmx_helper_get_ipd_port(interface, port)); + gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(port, interface)); + gmx_cfg.s.en = 1; + csr_wr(CVMX_GMXX_PRTX_CFG(port, interface), gmx_cfg.u64); + } + return 0; +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_rgmii_link_get(int ipd_port) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + union cvmx_asxx_prt_loop asxx_prt_loop; + + asxx_prt_loop.u64 = csr_rd(CVMX_ASXX_PRT_LOOP(interface)); + if (asxx_prt_loop.s.int_loop & (1 << index)) { + /* Force 1Gbps full duplex on internal loopback */ + cvmx_helper_link_info_t result; + + result.u64 = 0; + result.s.full_duplex = 1; + result.s.link_up = 1; + result.s.speed = 1000; + return result; + } else { + return __cvmx_helper_board_link_get(ipd_port); + } +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_gmii_link_get(int ipd_port) +{ + cvmx_helper_link_info_t result; + int index = cvmx_helper_get_interface_index_num(ipd_port); + + if (index == 0) { + result = __cvmx_helper_rgmii_link_get(ipd_port); + } else { + result.s.full_duplex = 1; + result.s.link_up = 1; + result.s.speed = 1000; + } + + return result; +} + +/** + * @INTERNAL + * Configure an IPD/PKO port for the specified link state. This + * function does not influence auto negotiation at the PHY level. + * The passed link state must always match the link state returned + * by cvmx_helper_link_get(). It is normally best to use + * cvmx_helper_link_autoconf() instead. + * + * @param ipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_rgmii_link_set(int ipd_port, + cvmx_helper_link_info_t link_info) +{ + int result = 0; + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + union cvmx_gmxx_prtx_cfg original_gmx_cfg; + union cvmx_gmxx_prtx_cfg new_gmx_cfg; + union cvmx_pko_mem_queue_qos pko_mem_queue_qos; + union cvmx_pko_mem_queue_qos pko_mem_queue_qos_save[16]; + union cvmx_gmxx_tx_ovr_bp gmx_tx_ovr_bp; + union cvmx_gmxx_tx_ovr_bp gmx_tx_ovr_bp_save; + int i; + + /* Read the current settings so we know the current enable state */ + original_gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + new_gmx_cfg = original_gmx_cfg; + + /* Disable the lowest level RX */ + csr_wr(CVMX_ASXX_RX_PRT_EN(interface), + csr_rd(CVMX_ASXX_RX_PRT_EN(interface)) & ~(1 << index)); + + memset(pko_mem_queue_qos_save, 0, sizeof(pko_mem_queue_qos_save)); + /* Disable all queues so that TX should become idle */ + for (i = 0; i < cvmx_pko_get_num_queues(ipd_port); i++) { + int queue = cvmx_pko_get_base_queue(ipd_port) + i; + + csr_wr(CVMX_PKO_REG_READ_IDX, queue); + pko_mem_queue_qos.u64 = csr_rd(CVMX_PKO_MEM_QUEUE_QOS); + pko_mem_queue_qos.s.pid = ipd_port; + pko_mem_queue_qos.s.qid = queue; + pko_mem_queue_qos_save[i] = pko_mem_queue_qos; + pko_mem_queue_qos.s.qos_mask = 0; + csr_wr(CVMX_PKO_MEM_QUEUE_QOS, pko_mem_queue_qos.u64); + } + + /* Disable backpressure */ + gmx_tx_ovr_bp.u64 = csr_rd(CVMX_GMXX_TX_OVR_BP(interface)); + gmx_tx_ovr_bp_save = gmx_tx_ovr_bp; + gmx_tx_ovr_bp.s.bp &= ~(1 << index); + gmx_tx_ovr_bp.s.en |= 1 << index; + csr_wr(CVMX_GMXX_TX_OVR_BP(interface), gmx_tx_ovr_bp.u64); + csr_rd(CVMX_GMXX_TX_OVR_BP(interface)); + + /* + * Poll the GMX state machine waiting for it to become + * idle. Preferably we should only change speed when it is + * idle. If it doesn't become idle we will still do the speed + * change, but there is a slight chance that GMX will + * lockup. + */ + csr_wr(CVMX_NPI_DBG_SELECT, interface * 0x800 + index * 0x100 + 0x880); + CVMX_WAIT_FOR_FIELD64(CVMX_DBG_DATA, cvmx_dbg_data_t, data & 7, ==, 0, + 10000); + CVMX_WAIT_FOR_FIELD64(CVMX_DBG_DATA, cvmx_dbg_data_t, data & 0xf, ==, 0, + 10000); + + /* Disable the port before we make any changes */ + new_gmx_cfg.s.en = 0; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), new_gmx_cfg.u64); + csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + + /* Set full/half duplex */ + if (!link_info.s.link_up) + /* Force full duplex on down links */ + new_gmx_cfg.s.duplex = 1; + else + new_gmx_cfg.s.duplex = link_info.s.full_duplex; + + /* Set the link speed. Anything unknown is set to 1Gbps */ + if (link_info.s.speed == 10) { + new_gmx_cfg.s.slottime = 0; + new_gmx_cfg.s.speed = 0; + } else if (link_info.s.speed == 100) { + new_gmx_cfg.s.slottime = 0; + new_gmx_cfg.s.speed = 0; + } else { + new_gmx_cfg.s.slottime = 1; + new_gmx_cfg.s.speed = 1; + } + + /* Adjust the clocks */ + if (link_info.s.speed == 10) { + csr_wr(CVMX_GMXX_TXX_CLK(index, interface), 50); + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 0x40); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0); + } else if (link_info.s.speed == 100) { + csr_wr(CVMX_GMXX_TXX_CLK(index, interface), 5); + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 0x40); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0); + } else { + csr_wr(CVMX_GMXX_TXX_CLK(index, interface), 1); + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 0x200); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0x2000); + } + + /* Do a read to make sure all setup stuff is complete */ + csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + + /* Save the new GMX setting without enabling the port */ + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), new_gmx_cfg.u64); + + /* Enable the lowest level RX */ + if (link_info.s.link_up) + csr_wr(CVMX_ASXX_RX_PRT_EN(interface), + csr_rd(CVMX_ASXX_RX_PRT_EN(interface)) | (1 << index)); + + /* Re-enable the TX path */ + for (i = 0; i < cvmx_pko_get_num_queues(ipd_port); i++) { + int queue = cvmx_pko_get_base_queue(ipd_port) + i; + + csr_wr(CVMX_PKO_REG_READ_IDX, queue); + csr_wr(CVMX_PKO_MEM_QUEUE_QOS, pko_mem_queue_qos_save[i].u64); + } + + /* Restore backpressure */ + csr_wr(CVMX_GMXX_TX_OVR_BP(interface), gmx_tx_ovr_bp_save.u64); + + /* Restore the GMX enable state. Port config is complete */ + new_gmx_cfg.s.en = original_gmx_cfg.s.en; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), new_gmx_cfg.u64); + + return result; +} + +/** + * @INTERNAL + * Configure a port for internal and/or external loopback. Internal loopback + * causes packets sent by the port to be received by Octeon. External loopback + * causes packets received from the wire to sent out again. + * + * @param ipd_port IPD/PKO port to loopback. + * @param enable_internal + * Non zero if you want internal loopback + * @param enable_external + * Non zero if you want external loopback + * + * @return Zero on success, negative on failure. + */ +int __cvmx_helper_rgmii_configure_loopback(int ipd_port, int enable_internal, + int enable_external) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + int original_enable; + union cvmx_gmxx_prtx_cfg gmx_cfg; + union cvmx_asxx_prt_loop asxx_prt_loop; + + /* Read the current enable state and save it */ + gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + original_enable = gmx_cfg.s.en; + /* Force port to be disabled */ + gmx_cfg.s.en = 0; + if (enable_internal) { + /* Force speed if we're doing internal loopback */ + gmx_cfg.s.duplex = 1; + gmx_cfg.s.slottime = 1; + gmx_cfg.s.speed = 1; + csr_wr(CVMX_GMXX_TXX_CLK(index, interface), 1); + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 0x200); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0x2000); + } + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmx_cfg.u64); + + /* Set the loopback bits */ + asxx_prt_loop.u64 = csr_rd(CVMX_ASXX_PRT_LOOP(interface)); + if (enable_internal) + asxx_prt_loop.s.int_loop |= 1 << index; + else + asxx_prt_loop.s.int_loop &= ~(1 << index); + if (enable_external) + asxx_prt_loop.s.ext_loop |= 1 << index; + else + asxx_prt_loop.s.ext_loop &= ~(1 << index); + csr_wr(CVMX_ASXX_PRT_LOOP(interface), asxx_prt_loop.u64); + + /* Force enables in internal loopback */ + if (enable_internal) { + u64 tmp; + + tmp = csr_rd(CVMX_ASXX_TX_PRT_EN(interface)); + csr_wr(CVMX_ASXX_TX_PRT_EN(interface), (1 << index) | tmp); + tmp = csr_rd(CVMX_ASXX_RX_PRT_EN(interface)); + csr_wr(CVMX_ASXX_RX_PRT_EN(interface), (1 << index) | tmp); + original_enable = 1; + } + + /* Restore the enable state */ + gmx_cfg.s.en = original_enable; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmx_cfg.u64); + return 0; +}
Import cvmx-helper-sgmii.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-sgmii.c | 781 ++++++++++++++++++++++ 1 file changed, 781 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-sgmii.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-sgmii.c b/arch/mips/mach-octeon/cvmx-helper-sgmii.c new file mode 100644 index 000000000000..b789ad5d1913 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-sgmii.c @@ -0,0 +1,781 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for SGMII initialization, configuration, + * and monitoring. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +/** + * @INTERNAL + * Perform initialization required only once for an SGMII port. + * + * @param interface to init + * @param index Index of prot on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_sgmii_hardware_init_one_time(int interface, int index) +{ + const u64 clock_mhz = 1200; /* todo: fixme */ + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + union cvmx_pcsx_linkx_timer_count_reg pcsx_linkx_timer_count_reg; + union cvmx_gmxx_prtx_cfg gmxx_prtx_cfg; + + if (!cvmx_helper_is_port_valid(interface, index)) + return 0; + + /* Disable GMX */ + gmxx_prtx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + gmxx_prtx_cfg.s.en = 0; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmxx_prtx_cfg.u64); + + /* + * Write PCS*_LINK*_TIMER_COUNT_REG[COUNT] with the + * appropriate value. 1000BASE-X specifies a 10ms + * interval. SGMII specifies a 1.6ms interval. + */ + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + /* Adjust the MAC mode if requested by device tree */ + pcsx_miscx_ctl_reg.s.mac_phy = + cvmx_helper_get_mac_phy_mode(interface, index); + pcsx_miscx_ctl_reg.s.mode = + cvmx_helper_get_1000x_mode(interface, index); + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + + pcsx_linkx_timer_count_reg.u64 = + csr_rd(CVMX_PCSX_LINKX_TIMER_COUNT_REG(index, interface)); + if (pcsx_miscx_ctl_reg.s.mode) + /* 1000BASE-X */ + pcsx_linkx_timer_count_reg.s.count = + (10000ull * clock_mhz) >> 10; + else + /* SGMII */ + pcsx_linkx_timer_count_reg.s.count = + (1600ull * clock_mhz) >> 10; + + csr_wr(CVMX_PCSX_LINKX_TIMER_COUNT_REG(index, interface), + pcsx_linkx_timer_count_reg.u64); + + /* + * Write the advertisement register to be used as the + * tx_Config_RegD15:D0 of the autonegotiation. In + * 1000BASE-X mode, tx_Config_RegD15:D0 is PCS*_AN*_ADV_REG. + * In SGMII PHY mode, tx_Config_RegD15:D0 is + * PCS*_SGM*_AN_ADV_REG. In SGMII MAC mode, + * tx_Config_RegD15:D0 is the fixed value 0x4001, so this + * step can be skipped. + */ + if (pcsx_miscx_ctl_reg.s.mode) { + /* 1000BASE-X */ + union cvmx_pcsx_anx_adv_reg pcsx_anx_adv_reg; + + pcsx_anx_adv_reg.u64 = + csr_rd(CVMX_PCSX_ANX_ADV_REG(index, interface)); + pcsx_anx_adv_reg.s.rem_flt = 0; + pcsx_anx_adv_reg.s.pause = 3; + pcsx_anx_adv_reg.s.hfd = 1; + pcsx_anx_adv_reg.s.fd = 1; + csr_wr(CVMX_PCSX_ANX_ADV_REG(index, interface), + pcsx_anx_adv_reg.u64); + } else { + if (pcsx_miscx_ctl_reg.s.mac_phy) { + /* PHY Mode */ + union cvmx_pcsx_sgmx_an_adv_reg pcsx_sgmx_an_adv_reg; + + pcsx_sgmx_an_adv_reg.u64 = csr_rd( + CVMX_PCSX_SGMX_AN_ADV_REG(index, interface)); + pcsx_sgmx_an_adv_reg.s.dup = 1; + pcsx_sgmx_an_adv_reg.s.speed = 2; + csr_wr(CVMX_PCSX_SGMX_AN_ADV_REG(index, interface), + pcsx_sgmx_an_adv_reg.u64); + } else { + /* MAC Mode - Nothing to do */ + } + } + return 0; +} + +static int __cvmx_helper_need_g15618(void) +{ + if (OCTEON_IS_MODEL(OCTEON_CN63XX) || + OCTEON_IS_MODEL(OCTEON_CN66XX_PASS1_X) || + OCTEON_IS_MODEL(OCTEON_CN68XX)) + return 1; + else + return 0; +} + +/** + * @INTERNAL + * Initialize the SERTES link for the first time or after a loss + * of link. + * + * @param interface to init + * @param index Index of prot on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_sgmii_hardware_init_link(int interface, int index) +{ + union cvmx_pcsx_mrx_control_reg control_reg; + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + bool phy_mode; + bool an_disable; /** Disable autonegotiation */ + bool mode_1000x; /** 1000Base-X mode */ + + if (!cvmx_helper_is_port_valid(interface, index)) + return 0; + + /* + * Take PCS through a reset sequence. + * PCS*_MR*_CONTROL_REG[PWR_DN] should be cleared to zero. + * Write PCS*_MR*_CONTROL_REG[RESET]=1 (while not changing the + * value of the other PCS*_MR*_CONTROL_REG bits). Read + * PCS*_MR*_CONTROL_REG[RESET] until it changes value to + * zero. + */ + control_reg.u64 = csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + + /* + * Errata G-15618 requires disabling PCS soft reset in CN63XX + * pass upto 2.1. + */ + if (!__cvmx_helper_need_g15618()) { + control_reg.s.reset = 1; + csr_wr(CVMX_PCSX_MRX_CONTROL_REG(index, interface), + control_reg.u64); + if (CVMX_WAIT_FOR_FIELD64( + CVMX_PCSX_MRX_CONTROL_REG(index, interface), + cvmx_pcsx_mrx_control_reg_t, reset, ==, 0, 10000)) { + debug("SGMII%x: Timeout waiting for port %d to finish reset\n", + interface, index); + return -1; + } + } + + /* + * Write PCS*_MR*_CONTROL_REG[RST_AN]=1 to ensure a fresh + * sgmii negotiation starts. + */ + phy_mode = cvmx_helper_get_mac_phy_mode(interface, index); + an_disable = (phy_mode || + !cvmx_helper_get_port_autonegotiation(interface, index)); + + control_reg.s.an_en = !an_disable; + + /* Force a PCS reset by powering down the PCS interface + * This is needed to deal with broken Qualcomm/Atheros PHYs and switches + * which never recover if PCS is not power cycled. The alternative + * is to power cycle or hardware reset the Qualcomm devices whenever + * SGMII is initialized. + * + * This is needed for the QCA8033 PHYs as well as the QCA833X switches + * to work. The QCA8337 switch has additional SGMII problems and is + * best avoided if at all possible. Failure to power cycle PCS prevents + * any traffic from flowing between Octeon and Qualcomm devices if there + * is a warm reset. Even a software reset to the Qualcomm device will + * not work. + * + * Note that this problem has been reported between Qualcomm and other + * vendor's processors as well so this problem is not unique to + * Qualcomm and Octeon. + * + * Power cycling PCS doesn't hurt anything with non-Qualcomm devices + * other than adding a 25ms delay during initialization. + */ + control_reg.s.pwr_dn = 1; + csr_wr(CVMX_PCSX_MRX_CONTROL_REG(index, interface), control_reg.u64); + csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + + /* 25ms should be enough, 10ms is too short */ + mdelay(25); + + control_reg.s.pwr_dn = 0; + csr_wr(CVMX_PCSX_MRX_CONTROL_REG(index, interface), control_reg.u64); + + /* The Cortina PHY runs in 1000base-X mode */ + mode_1000x = cvmx_helper_get_1000x_mode(interface, index); + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + pcsx_miscx_ctl_reg.s.mode = mode_1000x; + pcsx_miscx_ctl_reg.s.mac_phy = phy_mode; + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + if (an_disable) + /* In PHY mode we can't query the link status so we just + * assume that the link is up. + */ + return 0; + + /* + * Wait for PCS*_MR*_STATUS_REG[AN_CPT] to be set, indicating + * that sgmii autonegotiation is complete. In MAC mode this + * isn't an ethernet link, but a link between Octeon and the + * PHY. + */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSX_MRX_STATUS_REG(index, interface), + union cvmx_pcsx_mrx_status_reg, an_cpt, ==, 1, + 10000)) { + debug("SGMII%x: Port %d link timeout\n", interface, index); + return -1; + } + return 0; +} + +/** + * @INTERNAL + * Configure an SGMII link to the specified speed after the SERTES + * link is up. + * + * @param interface to init + * @param index Index of prot on the interface + * @param link_info Link state to configure + * + * @return Zero on success, negative on failure + */ +static int +__cvmx_helper_sgmii_hardware_init_link_speed(int interface, int index, + cvmx_helper_link_info_t link_info) +{ + int is_enabled; + union cvmx_gmxx_prtx_cfg gmxx_prtx_cfg; + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + + if (!cvmx_helper_is_port_valid(interface, index)) + return 0; + + /* Disable GMX before we make any changes. Remember the enable state */ + gmxx_prtx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + is_enabled = gmxx_prtx_cfg.s.en; + gmxx_prtx_cfg.s.en = 0; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmxx_prtx_cfg.u64); + + /* Wait for GMX to be idle */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(index, interface), + cvmx_gmxx_prtx_cfg_t, rx_idle, ==, 1, + 10000) || + CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(index, interface), + cvmx_gmxx_prtx_cfg_t, tx_idle, ==, 1, + 10000)) { + debug("SGMII%d: Timeout waiting for port %d to be idle\n", + interface, index); + return -1; + } + + /* Read GMX CFG again to make sure the disable completed */ + gmxx_prtx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + + /* + * Get the misc control for PCS. We will need to set the + * duplication amount. + */ + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + + /* + * Use GMXENO to force the link down if the status we get says + * it should be down. + */ + pcsx_miscx_ctl_reg.s.gmxeno = !link_info.s.link_up; + + /* Only change the duplex setting if the link is up */ + if (link_info.s.link_up) + gmxx_prtx_cfg.s.duplex = link_info.s.full_duplex; + + /* Do speed based setting for GMX */ + switch (link_info.s.speed) { + case 10: + gmxx_prtx_cfg.s.speed = 0; + gmxx_prtx_cfg.s.speed_msb = 1; + gmxx_prtx_cfg.s.slottime = 0; + /* Setting from GMX-603 */ + pcsx_miscx_ctl_reg.s.samp_pt = 25; + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 64); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0); + break; + case 100: + gmxx_prtx_cfg.s.speed = 0; + gmxx_prtx_cfg.s.speed_msb = 0; + gmxx_prtx_cfg.s.slottime = 0; + pcsx_miscx_ctl_reg.s.samp_pt = 0x5; + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 64); + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0); + break; + case 1000: + gmxx_prtx_cfg.s.speed = 1; + gmxx_prtx_cfg.s.speed_msb = 0; + gmxx_prtx_cfg.s.slottime = 1; + pcsx_miscx_ctl_reg.s.samp_pt = 1; + csr_wr(CVMX_GMXX_TXX_SLOT(index, interface), 512); + if (gmxx_prtx_cfg.s.duplex) + /* full duplex */ + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 0); + else + /* half duplex */ + csr_wr(CVMX_GMXX_TXX_BURST(index, interface), 8192); + break; + default: + break; + } + + /* Write the new misc control for PCS */ + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + + /* Write the new GMX settings with the port still disabled */ + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmxx_prtx_cfg.u64); + + /* Read GMX CFG again to make sure the config completed */ + gmxx_prtx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + + /* Restore the enabled / disabled state */ + gmxx_prtx_cfg.s.en = is_enabled; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmxx_prtx_cfg.u64); + + return 0; +} + +/** + * @INTERNAL + * Bring up the SGMII interface to be ready for packet I/O but + * leave I/O disabled using the GMX override. This function + * follows the bringup documented in 10.6.3 of the manual. + * + * @param interface to bringup + * @param num_ports Number of ports on the interface + * + * @return Zero on success, negative on failure + */ +static int __cvmx_helper_sgmii_hardware_init(int interface, int num_ports) +{ + int index; + int do_link_set = 1; + + /* + * CN63XX Pass 1.0 errata G-14395 requires the QLM De-emphasis + * be programmed. + */ + if (OCTEON_IS_MODEL(OCTEON_CN63XX_PASS1_0)) { + union cvmx_ciu_qlm2 ciu_qlm; + + ciu_qlm.u64 = csr_rd(CVMX_CIU_QLM2); + ciu_qlm.s.txbypass = 1; + ciu_qlm.s.txdeemph = 0xf; + ciu_qlm.s.txmargin = 0xd; + csr_wr(CVMX_CIU_QLM2, ciu_qlm.u64); + } + + /* + * CN63XX Pass 2.x errata G-15273 requires the QLM De-emphasis + * be programmed when using a 156.25Mhz ref clock. + */ + if (OCTEON_IS_MODEL(OCTEON_CN63XX_PASS2_X)) { + /* Read the QLM speed pins */ + union cvmx_mio_rst_boot mio_rst_boot; + + mio_rst_boot.u64 = csr_rd(CVMX_MIO_RST_BOOT); + + if (mio_rst_boot.cn63xx.qlm2_spd == 4) { + union cvmx_ciu_qlm2 ciu_qlm; + + ciu_qlm.u64 = csr_rd(CVMX_CIU_QLM2); + ciu_qlm.s.txbypass = 1; + ciu_qlm.s.txdeemph = 0x0; + ciu_qlm.s.txmargin = 0xf; + csr_wr(CVMX_CIU_QLM2, ciu_qlm.u64); + } + } + + __cvmx_helper_setup_gmx(interface, num_ports); + + for (index = 0; index < num_ports; index++) { + int ipd_port = cvmx_helper_get_ipd_port(interface, index); + + if (!cvmx_helper_is_port_valid(interface, index)) + continue; + __cvmx_helper_sgmii_hardware_init_one_time(interface, index); + if (do_link_set) + __cvmx_helper_sgmii_link_set(ipd_port, + __cvmx_helper_sgmii_link_get(ipd_port)); + } + + return 0; +} + +int __cvmx_helper_sgmii_enumerate(int xiface) +{ + if (OCTEON_IS_MODEL(OCTEON_CNF71XX)) + return 2; + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + struct cvmx_xiface xi = + cvmx_helper_xiface_to_node_interface(xiface); + enum cvmx_qlm_mode qlm_mode = + cvmx_qlm_get_dlm_mode(0, xi.interface); + + if (qlm_mode == CVMX_QLM_MODE_SGMII) + return 1; + else if (qlm_mode == CVMX_QLM_MODE_QSGMII) + return 4; + return 0; + } + return 4; +} + +/** + * @INTERNAL + * Probe a SGMII interface and determine the number of ports + * connected to it. The SGMII interface should still be down after + * this call. + * + * @param xiface Interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_sgmii_probe(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + union cvmx_gmxx_inf_mode mode; + int ports; + + /* + * Check if QLM is configured correct for SGMII, verify the + * speed as well as mode. + */ + if (OCTEON_IS_OCTEON2()) { + int qlm = cvmx_qlm_interface(xiface); + + if (cvmx_qlm_get_mode(qlm) != CVMX_QLM_MODE_SGMII) + return 0; + } + + /* Do not enable the interface if is not in SGMII mode */ + ports = __cvmx_helper_sgmii_enumerate(xiface); + + if (ports <= 0) + return 0; + + /* + * Due to errata GMX-700 on CN56XXp1.x and CN52XXp1.x, the + * interface needs to be enabled before IPD otherwise per port + * backpressure may not work properly. + */ + mode.u64 = csr_rd(CVMX_GMXX_INF_MODE(interface)); + mode.s.en = 1; + csr_wr(CVMX_GMXX_INF_MODE(interface), mode.u64); + + return ports; +} + +/** + * @INTERNAL + * Bringup and enable a SGMII interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_sgmii_enable(int xiface) +{ + int num_ports = cvmx_helper_ports_on_interface(xiface); + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + int index; + + /* Setup PKND and BPID */ + if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + for (index = 0; index < num_ports; index++) { + union cvmx_gmxx_bpid_msk bpid_msk; + union cvmx_gmxx_bpid_mapx bpid_map; + union cvmx_gmxx_prtx_cfg gmxx_prtx_cfg; + + if (!cvmx_helper_is_port_valid(interface, index)) + continue; + /* Setup PKIND */ + gmxx_prtx_cfg.u64 = + csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + gmxx_prtx_cfg.s.pknd = + cvmx_helper_get_pknd(interface, index); + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), + gmxx_prtx_cfg.u64); + + /* Setup BPID */ + bpid_map.u64 = + csr_rd(CVMX_GMXX_BPID_MAPX(index, interface)); + bpid_map.s.val = 1; + bpid_map.s.bpid = + cvmx_helper_get_bpid(interface, index); + csr_wr(CVMX_GMXX_BPID_MAPX(index, interface), + bpid_map.u64); + + bpid_msk.u64 = csr_rd(CVMX_GMXX_BPID_MSK(interface)); + bpid_msk.s.msk_or |= (1 << index); + bpid_msk.s.msk_and &= ~(1 << index); + csr_wr(CVMX_GMXX_BPID_MSK(interface), bpid_msk.u64); + } + } + + __cvmx_helper_sgmii_hardware_init(interface, num_ports); + + /* CN68XX adds the padding and FCS in PKO, not GMX */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + union cvmx_gmxx_txx_append gmxx_txx_append_cfg; + + for (index = 0; index < num_ports; index++) { + if (!cvmx_helper_is_port_valid(interface, index)) + continue; + gmxx_txx_append_cfg.u64 = + csr_rd(CVMX_GMXX_TXX_APPEND(index, interface)); + gmxx_txx_append_cfg.s.fcs = 0; + gmxx_txx_append_cfg.s.pad = 0; + csr_wr(CVMX_GMXX_TXX_APPEND(index, interface), + gmxx_txx_append_cfg.u64); + } + } + + /* Enable running disparity check for QSGMII interface */ + if (OCTEON_IS_MODEL(OCTEON_CN70XX) && num_ports > 1) { + union cvmx_gmxx_qsgmii_ctl qsgmii_ctl; + + qsgmii_ctl.u64 = 0; + qsgmii_ctl.s.disparity = 1; + csr_wr(CVMX_GMXX_QSGMII_CTL(interface), qsgmii_ctl.u64); + } + + for (index = 0; index < num_ports; index++) { + union cvmx_gmxx_txx_append append_cfg; + union cvmx_gmxx_txx_sgmii_ctl sgmii_ctl; + union cvmx_gmxx_prtx_cfg gmxx_prtx_cfg; + + if (!cvmx_helper_is_port_valid(interface, index)) + continue; + /* + * Clear the align bit if preamble is set to attain + * maximum tx rate. + */ + append_cfg.u64 = csr_rd(CVMX_GMXX_TXX_APPEND(index, interface)); + sgmii_ctl.u64 = + csr_rd(CVMX_GMXX_TXX_SGMII_CTL(index, interface)); + sgmii_ctl.s.align = append_cfg.s.preamble ? 0 : 1; + csr_wr(CVMX_GMXX_TXX_SGMII_CTL(index, interface), + sgmii_ctl.u64); + + gmxx_prtx_cfg.u64 = + csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); + gmxx_prtx_cfg.s.en = 1; + csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmxx_prtx_cfg.u64); + } + return 0; +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_sgmii_link_get(int ipd_port) +{ + cvmx_helper_link_info_t result; + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + union cvmx_pcsx_mrx_control_reg pcsx_mrx_control_reg; + int speed = 1000; + int qlm; + + result.u64 = 0; + + if (!cvmx_helper_is_port_valid(interface, index)) + return result; + + if (OCTEON_IS_MODEL(OCTEON_CN66XX)) { + union cvmx_gmxx_inf_mode inf_mode; + + inf_mode.u64 = csr_rd(CVMX_GMXX_INF_MODE(interface)); + if (inf_mode.s.rate & (1 << index)) + speed = 2500; + else + speed = 1000; + } else if (OCTEON_IS_MODEL(OCTEON_CN6XXX)) { + qlm = cvmx_qlm_interface(interface); + speed = cvmx_qlm_get_gbaud_mhz(qlm) * 8 / 10; + } else if (OCTEON_IS_MODEL(OCTEON_CNF71XX)) { + speed = cvmx_qlm_get_gbaud_mhz(0) * 8 / 10; + } else if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + speed = cvmx_qlm_get_gbaud_mhz(0) * 8 / 10; + if (cvmx_qlm_get_dlm_mode(0, interface) == CVMX_QLM_MODE_SGMII) + speed >>= 1; + else + speed >>= 2; + } + + pcsx_mrx_control_reg.u64 = + csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + if (pcsx_mrx_control_reg.s.loopbck1) { + /* Force 1Gbps full duplex link for internal loopback */ + result.s.link_up = 1; + result.s.full_duplex = 1; + result.s.speed = speed; + return result; + } + + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + if (pcsx_miscx_ctl_reg.s.mac_phy || + cvmx_helper_get_port_force_link_up(interface, index)) { + /* PHY Mode */ + /* Note that this also works for 1000base-X mode */ + + result.s.speed = speed; + result.s.full_duplex = 1; + result.s.link_up = 1; + return result; + } + + /* MAC Mode */ + return __cvmx_helper_board_link_get(ipd_port); +} + +/** + * @INTERNAL + * Configure an IPD/PKO port for the specified link state. This + * function does not influence auto negotiation at the PHY level. + * The passed link state must always match the link state returned + * by cvmx_helper_link_get(). It is normally best to use + * cvmx_helper_link_autoconf() instead. + * + * @param ipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_sgmii_link_set(int ipd_port, + cvmx_helper_link_info_t link_info) +{ + union cvmx_pcsx_mrx_control_reg control_reg; + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + + if (!cvmx_helper_is_port_valid(interface, index)) + return 0; + + /* For some devices, i.e. the Qualcomm QCA8337 switch we need to power + * down the PCS interface when the link goes down and power it back + * up when the link returns. + */ + if (link_info.s.link_up || !__cvmx_helper_need_g15618()) { + __cvmx_helper_sgmii_hardware_init_link(interface, index); + } else { + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + + /* Disable autonegotiation when MAC mode is enabled or + * autonegotiation is disabled. + */ + control_reg.u64 = + csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + if (pcsx_miscx_ctl_reg.s.mac_phy == 0 || + !cvmx_helper_get_port_autonegotiation(interface, index)) { + control_reg.s.an_en = 0; + control_reg.s.spdmsb = 1; + control_reg.s.spdlsb = 0; + control_reg.s.dup = 1; + } + csr_wr(CVMX_PCSX_MRX_CONTROL_REG(index, interface), + control_reg.u64); + csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + /* + * Use GMXENO to force the link down it will get + * reenabled later... + */ + pcsx_miscx_ctl_reg.s.gmxeno = 1; + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + return 0; + } + return __cvmx_helper_sgmii_hardware_init_link_speed(interface, index, + link_info); +} + +/** + * @INTERNAL + * Configure a port for internal and/or external loopback. Internal loopback + * causes packets sent by the port to be received by Octeon. External loopback + * causes packets received from the wire to sent out again. + * + * @param ipd_port IPD/PKO port to loopback. + * @param enable_internal + * Non zero if you want internal loopback + * @param enable_external + * Non zero if you want external loopback + * + * @return Zero on success, negative on failure. + */ +int __cvmx_helper_sgmii_configure_loopback(int ipd_port, int enable_internal, + int enable_external) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + int index = cvmx_helper_get_interface_index_num(ipd_port); + union cvmx_pcsx_mrx_control_reg pcsx_mrx_control_reg; + union cvmx_pcsx_miscx_ctl_reg pcsx_miscx_ctl_reg; + + if (!cvmx_helper_is_port_valid(interface, index)) + return 0; + + pcsx_mrx_control_reg.u64 = + csr_rd(CVMX_PCSX_MRX_CONTROL_REG(index, interface)); + pcsx_mrx_control_reg.s.loopbck1 = enable_internal; + csr_wr(CVMX_PCSX_MRX_CONTROL_REG(index, interface), + pcsx_mrx_control_reg.u64); + + pcsx_miscx_ctl_reg.u64 = + csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + pcsx_miscx_ctl_reg.s.loopbck2 = enable_external; + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + + __cvmx_helper_sgmii_hardware_init_link(interface, index); + return 0; +}
Import cvmx-helper-xaui.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-helper-xaui.c | 518 +++++++++++++++++++++++ 1 file changed, 518 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-helper-xaui.c
diff --git a/arch/mips/mach-octeon/cvmx-helper-xaui.c b/arch/mips/mach-octeon/cvmx-helper-xaui.c new file mode 100644 index 000000000000..2eb3b7d9c462 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-helper-xaui.c @@ -0,0 +1,518 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for XAUI initialization, configuration, + * and monitoring. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +int __cvmx_helper_xaui_enumerate(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + union cvmx_gmxx_hg2_control gmx_hg2_control; + + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + enum cvmx_qlm_mode qlm_mode = + cvmx_qlm_get_dlm_mode(0, interface); + + if (qlm_mode == CVMX_QLM_MODE_RXAUI) + return 1; + return 0; + } + /* If HiGig2 is enabled return 16 ports, otherwise return 1 port */ + gmx_hg2_control.u64 = csr_rd(CVMX_GMXX_HG2_CONTROL(interface)); + if (gmx_hg2_control.s.hg2tx_en) + return 16; + else + return 1; +} + +/** + * @INTERNAL + * Probe a XAUI interface and determine the number of ports + * connected to it. The XAUI interface should still be down + * after this call. + * + * @param xiface Interface to probe + * + * @return Number of ports on the interface. Zero to disable. + */ +int __cvmx_helper_xaui_probe(int xiface) +{ + int i, ports; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + union cvmx_gmxx_inf_mode mode; + + /* + * CN63XX Pass 1.0 errata G-14395 requires the QLM De-emphasis + * be programmed. + */ + if (OCTEON_IS_MODEL(OCTEON_CN63XX_PASS1_0)) { + union cvmx_ciu_qlm2 ciu_qlm; + + ciu_qlm.u64 = csr_rd(CVMX_CIU_QLM2); + ciu_qlm.s.txbypass = 1; + ciu_qlm.s.txdeemph = 0x5; + ciu_qlm.s.txmargin = 0x1a; + csr_wr(CVMX_CIU_QLM2, ciu_qlm.u64); + } + + /* + * CN63XX Pass 2.x errata G-15273 requires the QLM De-emphasis + * be programmed when using a 156.25Mhz ref clock. + */ + if (OCTEON_IS_MODEL(OCTEON_CN63XX_PASS2_X)) { + /* Read the QLM speed pins */ + union cvmx_mio_rst_boot mio_rst_boot; + + mio_rst_boot.u64 = csr_rd(CVMX_MIO_RST_BOOT); + + if (mio_rst_boot.cn63xx.qlm2_spd == 0xb) { + union cvmx_ciu_qlm2 ciu_qlm; + + ciu_qlm.u64 = csr_rd(CVMX_CIU_QLM2); + ciu_qlm.s.txbypass = 1; + ciu_qlm.s.txdeemph = 0xa; + ciu_qlm.s.txmargin = 0x1f; + csr_wr(CVMX_CIU_QLM2, ciu_qlm.u64); + } + } + + /* + * Check if QLM is configured correct for XAUI/RXAUI, verify + * the speed as well as mode. + */ + if (OCTEON_IS_MODEL(OCTEON_CN6XXX)) { + int qlm = cvmx_qlm_interface(xiface); + enum cvmx_qlm_mode mode = cvmx_qlm_get_mode(qlm); + + if (mode != CVMX_QLM_MODE_XAUI && mode != CVMX_QLM_MODE_RXAUI) + return 0; + } + + ports = __cvmx_helper_xaui_enumerate(xiface); + + if (ports <= 0) + return 0; + + /* + * Due to errata GMX-700 on CN56XXp1.x and CN52XXp1.x, the + * interface needs to be enabled before IPD otherwise per port + * backpressure may not work properly. + */ + mode.u64 = csr_rd(CVMX_GMXX_INF_MODE(interface)); + mode.s.en = 1; + csr_wr(CVMX_GMXX_INF_MODE(interface), mode.u64); + + if (!OCTEON_IS_MODEL(OCTEON_CN68XX) && + !OCTEON_IS_MODEL(OCTEON_CN70XX)) { + /* + * Setup PKO to support 16 ports for HiGig2 virtual + * ports. We're pointing all of the PKO packet ports + * for this interface to the XAUI. This allows us to + * use HiGig2 backpressure per port. + */ + for (i = 0; i < 16; i++) { + union cvmx_pko_mem_port_ptrs pko_mem_port_ptrs; + + pko_mem_port_ptrs.u64 = 0; + /* + * We set each PKO port to have equal priority + * in a round robin fashion. + */ + pko_mem_port_ptrs.s.static_p = 0; + pko_mem_port_ptrs.s.qos_mask = 0xff; + /* All PKO ports map to the same XAUI hardware port */ + pko_mem_port_ptrs.s.eid = interface * 4; + pko_mem_port_ptrs.s.pid = interface * 16 + i; + pko_mem_port_ptrs.s.bp_port = interface * 16 + i; + csr_wr(CVMX_PKO_MEM_PORT_PTRS, pko_mem_port_ptrs.u64); + } + } + + return ports; +} + +/** + * @INTERNAL + * Bringup XAUI interface. After this call packet I/O should be + * fully functional. + * + * @param interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_xaui_link_init(int interface) +{ + union cvmx_gmxx_prtx_cfg gmx_cfg; + union cvmx_pcsxx_control1_reg xaui_ctl; + union cvmx_pcsxx_misc_ctl_reg misc_ctl; + union cvmx_gmxx_tx_xaui_ctl tx_ctl; + + /* (1) Interface has already been enabled. */ + + /* (2) Disable GMX. */ + misc_ctl.u64 = csr_rd(CVMX_PCSXX_MISC_CTL_REG(interface)); + misc_ctl.s.gmxeno = 1; + csr_wr(CVMX_PCSXX_MISC_CTL_REG(interface), misc_ctl.u64); + + /* (3) Disable GMX and PCSX interrupts. */ + csr_wr(CVMX_GMXX_RXX_INT_EN(0, interface), 0x0); + csr_wr(CVMX_GMXX_TX_INT_EN(interface), 0x0); + csr_wr(CVMX_PCSXX_INT_EN_REG(interface), 0x0); + + /* (4) Bring up the PCSX and GMX reconciliation layer. */ + /* (4)a Set polarity and lane swapping. */ + /* (4)b */ + tx_ctl.u64 = csr_rd(CVMX_GMXX_TX_XAUI_CTL(interface)); + /* Enable better IFG packing and improves performance */ + tx_ctl.s.dic_en = 1; + tx_ctl.s.uni_en = 0; + csr_wr(CVMX_GMXX_TX_XAUI_CTL(interface), tx_ctl.u64); + + /* (4)c Aply reset sequence */ + xaui_ctl.u64 = csr_rd(CVMX_PCSXX_CONTROL1_REG(interface)); + xaui_ctl.s.lo_pwr = 0; + + /* + * Errata G-15618 requires disabling PCS soft reset in some + * OCTEON II models. + */ + if (!OCTEON_IS_MODEL(OCTEON_CN63XX) && + !OCTEON_IS_MODEL(OCTEON_CN66XX_PASS1_X) && + !OCTEON_IS_MODEL(OCTEON_CN68XX)) + xaui_ctl.s.reset = 1; + csr_wr(CVMX_PCSXX_CONTROL1_REG(interface), xaui_ctl.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX_PASS2_X) && interface != 1) { + /* + * Note that GMX 1 was skipped as GMX0 is on the same + * QLM and will always be done first + * + * Workaround for Errata (G-16467). + */ + int qlm = interface; +#ifdef CVMX_QLM_DUMP_STATE + debug("%s:%d: XAUI%d: Applying workaround for Errata G-16467\n", + __func__, __LINE__, qlm); + cvmx_qlm_display_registers(qlm); + debug("\n"); +#endif + /* + * This workaround only applies to QLMs running XAUI + * at 6.25Ghz + */ + if ((cvmx_qlm_get_gbaud_mhz(qlm) == 6250) && + (cvmx_qlm_jtag_get(qlm, 0, "clkf_byp") != 20)) { + /* Wait 100us for links to stabalize */ + udelay(100); + cvmx_qlm_jtag_set(qlm, -1, "clkf_byp", 20); + /* Allow the QLM to exit reset */ + cvmx_qlm_jtag_set(qlm, -1, "cfg_rst_n_clr", 0); + /* Wait 100us for links to stabalize */ + udelay(100); + /* Allow TX on QLM */ + cvmx_qlm_jtag_set(qlm, -1, "cfg_tx_idle_set", 0); + } +#ifdef CVMX_QLM_DUMP_STATE + debug("%s:%d: XAUI%d: Done applying workaround for Errata G-16467\n", + __func__, __LINE__, qlm); + cvmx_qlm_display_registers(qlm); + debug("\n\n"); +#endif + } + + /* Wait for PCS to come out of reset */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSXX_CONTROL1_REG(interface), + cvmx_pcsxx_control1_reg_t, reset, ==, 0, + 10000)) + return -1; + /* Wait for PCS to be aligned */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSXX_10GBX_STATUS_REG(interface), + cvmx_pcsxx_10gbx_status_reg_t, alignd, ==, 1, + 10000)) + return -1; + /* Wait for RX to be ready */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_RX_XAUI_CTL(interface), + cvmx_gmxx_rx_xaui_ctl_t, status, ==, 0, + 10000)) + return -1; + + /* (6) Configure GMX */ + + /* Wait for GMX RX to be idle */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(0, interface), + cvmx_gmxx_prtx_cfg_t, rx_idle, ==, 1, 10000)) + return -1; + /* Wait for GMX TX to be idle */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(0, interface), + cvmx_gmxx_prtx_cfg_t, tx_idle, ==, 1, 10000)) + return -1; + + /* GMX configure */ + gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(0, interface)); + gmx_cfg.s.speed = 1; + gmx_cfg.s.speed_msb = 0; + gmx_cfg.s.slottime = 1; + csr_wr(CVMX_GMXX_TX_PRTS(interface), 1); + csr_wr(CVMX_GMXX_TXX_SLOT(0, interface), 512); + csr_wr(CVMX_GMXX_TXX_BURST(0, interface), 8192); + csr_wr(CVMX_GMXX_PRTX_CFG(0, interface), gmx_cfg.u64); + + /* Wait for receive link */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSXX_STATUS1_REG(interface), + cvmx_pcsxx_status1_reg_t, rcv_lnk, ==, 1, + 10000)) + return -1; + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSXX_STATUS2_REG(interface), + cvmx_pcsxx_status2_reg_t, xmtflt, ==, 0, + 10000)) + return -1; + if (CVMX_WAIT_FOR_FIELD64(CVMX_PCSXX_STATUS2_REG(interface), + cvmx_pcsxx_status2_reg_t, rcvflt, ==, 0, + 10000)) + return -1; + + /* (8) Enable packet reception */ + misc_ctl.s.gmxeno = 0; + csr_wr(CVMX_PCSXX_MISC_CTL_REG(interface), misc_ctl.u64); + + /* Clear all error interrupts before enabling the interface. */ + csr_wr(CVMX_GMXX_RXX_INT_REG(0, interface), ~0x0ull); + csr_wr(CVMX_GMXX_TX_INT_REG(interface), ~0x0ull); + csr_wr(CVMX_PCSXX_INT_REG(interface), ~0x0ull); + + /* Enable GMX */ + gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(0, interface)); + gmx_cfg.s.en = 1; + csr_wr(CVMX_GMXX_PRTX_CFG(0, interface), gmx_cfg.u64); + + return 0; +} + +/** + * @INTERNAL + * Bringup and enable a XAUI interface. After this call packet + * I/O should be fully functional. This is called with IPD + * enabled but PKO disabled. + * + * @param xiface Interface to bring up + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_xaui_enable(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface; + + __cvmx_helper_setup_gmx(interface, 1); + + /* Setup PKND and BPID */ + if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + union cvmx_gmxx_bpid_msk bpid_msk; + union cvmx_gmxx_bpid_mapx bpid_map; + union cvmx_gmxx_prtx_cfg gmxx_prtx_cfg; + union cvmx_gmxx_txx_append gmxx_txx_append_cfg; + + /* Setup PKIND */ + gmxx_prtx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(0, interface)); + gmxx_prtx_cfg.s.pknd = cvmx_helper_get_pknd(interface, 0); + csr_wr(CVMX_GMXX_PRTX_CFG(0, interface), gmxx_prtx_cfg.u64); + + /* Setup BPID */ + bpid_map.u64 = csr_rd(CVMX_GMXX_BPID_MAPX(0, interface)); + bpid_map.s.val = 1; + bpid_map.s.bpid = cvmx_helper_get_bpid(interface, 0); + csr_wr(CVMX_GMXX_BPID_MAPX(0, interface), bpid_map.u64); + + bpid_msk.u64 = csr_rd(CVMX_GMXX_BPID_MSK(interface)); + bpid_msk.s.msk_or |= 1; + bpid_msk.s.msk_and &= ~1; + csr_wr(CVMX_GMXX_BPID_MSK(interface), bpid_msk.u64); + + /* CN68XX adds the padding and FCS in PKO, not GMX */ + gmxx_txx_append_cfg.u64 = + csr_rd(CVMX_GMXX_TXX_APPEND(0, interface)); + gmxx_txx_append_cfg.s.fcs = 0; + gmxx_txx_append_cfg.s.pad = 0; + csr_wr(CVMX_GMXX_TXX_APPEND(0, interface), + gmxx_txx_append_cfg.u64); + } + + /* 70XX eval boards use Marvel phy, set disparity accordingly. */ + if (OCTEON_IS_MODEL(OCTEON_CN70XX)) { + union cvmx_gmxx_rxaui_ctl rxaui_ctl; + + rxaui_ctl.u64 = csr_rd(CVMX_GMXX_RXAUI_CTL(interface)); + rxaui_ctl.s.disparity = 1; + csr_wr(CVMX_GMXX_RXAUI_CTL(interface), rxaui_ctl.u64); + } + + __cvmx_helper_xaui_link_init(interface); + + return 0; +} + +/** + * @INTERNAL + * Return the link state of an IPD/PKO port as returned by + * auto negotiation. The result of this function may not match + * Octeon's link config if auto negotiation has changed since + * the last call to cvmx_helper_link_set(). + * + * @param ipd_port IPD/PKO port to query + * + * @return Link state + */ +cvmx_helper_link_info_t __cvmx_helper_xaui_link_get(int ipd_port) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + union cvmx_gmxx_tx_xaui_ctl gmxx_tx_xaui_ctl; + union cvmx_gmxx_rx_xaui_ctl gmxx_rx_xaui_ctl; + union cvmx_pcsxx_status1_reg pcsxx_status1_reg; + cvmx_helper_link_info_t result; + + gmxx_tx_xaui_ctl.u64 = csr_rd(CVMX_GMXX_TX_XAUI_CTL(interface)); + gmxx_rx_xaui_ctl.u64 = csr_rd(CVMX_GMXX_RX_XAUI_CTL(interface)); + pcsxx_status1_reg.u64 = csr_rd(CVMX_PCSXX_STATUS1_REG(interface)); + result.u64 = 0; + + /* Only return a link if both RX and TX are happy */ + if (gmxx_tx_xaui_ctl.s.ls == 0 && gmxx_rx_xaui_ctl.s.status == 0 && + pcsxx_status1_reg.s.rcv_lnk == 1) { + union cvmx_pcsxx_misc_ctl_reg misc_ctl; + + result.s.link_up = 1; + result.s.full_duplex = 1; + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + union cvmx_mio_qlmx_cfg qlm_cfg; + int lanes; + int qlm = (interface == 1) ? 0 : interface; + + qlm_cfg.u64 = csr_rd(CVMX_MIO_QLMX_CFG(qlm)); + result.s.speed = cvmx_qlm_get_gbaud_mhz(qlm) * 8 / 10; + lanes = (qlm_cfg.s.qlm_cfg == 7) ? 2 : 4; + result.s.speed *= lanes; + } else if (OCTEON_IS_MODEL(OCTEON_CN6XXX)) { + int qlm = cvmx_qlm_interface(interface); + + result.s.speed = cvmx_qlm_get_gbaud_mhz(qlm) * 8 / 10; + result.s.speed *= 4; + } else { + result.s.speed = 10000; + } + misc_ctl.u64 = csr_rd(CVMX_PCSXX_MISC_CTL_REG(interface)); + if (misc_ctl.s.gmxeno) + __cvmx_helper_xaui_link_init(interface); + } else { + /* Disable GMX and PCSX interrupts. */ + csr_wr(CVMX_GMXX_RXX_INT_EN(0, interface), 0x0); + csr_wr(CVMX_GMXX_TX_INT_EN(interface), 0x0); + csr_wr(CVMX_PCSXX_INT_EN_REG(interface), 0x0); + } + return result; +} + +/** + * @INTERNAL + * Configure an IPD/PKO port for the specified link state. This + * function does not influence auto negotiation at the PHY level. + * The passed link state must always match the link state returned + * by cvmx_helper_link_get(). It is normally best to use + * cvmx_helper_link_autoconf() instead. + * + * @param ipd_port IPD/PKO port to configure + * @param link_info The new link state + * + * @return Zero on success, negative on failure + */ +int __cvmx_helper_xaui_link_set(int ipd_port, cvmx_helper_link_info_t link_info) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + union cvmx_gmxx_tx_xaui_ctl gmxx_tx_xaui_ctl; + union cvmx_gmxx_rx_xaui_ctl gmxx_rx_xaui_ctl; + + gmxx_tx_xaui_ctl.u64 = csr_rd(CVMX_GMXX_TX_XAUI_CTL(interface)); + gmxx_rx_xaui_ctl.u64 = csr_rd(CVMX_GMXX_RX_XAUI_CTL(interface)); + + /* If the link shouldn't be up, then just return */ + if (!link_info.s.link_up) + return 0; + + /* Do nothing if both RX and TX are happy */ + if (gmxx_tx_xaui_ctl.s.ls == 0 && gmxx_rx_xaui_ctl.s.status == 0) + return 0; + + /* Bring the link up */ + return __cvmx_helper_xaui_link_init(interface); +} + +/** + * @INTERNAL + * Configure a port for internal and/or external loopback. Internal loopback + * causes packets sent by the port to be received by Octeon. External loopback + * causes packets received from the wire to sent out again. + * + * @param ipd_port IPD/PKO port to loopback. + * @param enable_internal + * Non zero if you want internal loopback + * @param enable_external + * Non zero if you want external loopback + * + * @return Zero on success, negative on failure. + */ +extern int __cvmx_helper_xaui_configure_loopback(int ipd_port, + int enable_internal, + int enable_external) +{ + int interface = cvmx_helper_get_interface_num(ipd_port); + union cvmx_pcsxx_control1_reg pcsxx_control1_reg; + union cvmx_gmxx_xaui_ext_loopback gmxx_xaui_ext_loopback; + + /* Set the internal loop */ + pcsxx_control1_reg.u64 = csr_rd(CVMX_PCSXX_CONTROL1_REG(interface)); + pcsxx_control1_reg.s.loopbck1 = enable_internal; + csr_wr(CVMX_PCSXX_CONTROL1_REG(interface), pcsxx_control1_reg.u64); + + /* Set the external loop */ + gmxx_xaui_ext_loopback.u64 = + csr_rd(CVMX_GMXX_XAUI_EXT_LOOPBACK(interface)); + gmxx_xaui_ext_loopback.s.en = enable_external; + csr_wr(CVMX_GMXX_XAUI_EXT_LOOPBACK(interface), + gmxx_xaui_ext_loopback.u64); + + /* Take the link through a reset */ + return __cvmx_helper_xaui_link_init(interface); +}
Import cvmx-agl.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-agl.c | 216 +++++++++++++++++++++++++++++++ 1 file changed, 216 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-agl.c
diff --git a/arch/mips/mach-octeon/cvmx-agl.c b/arch/mips/mach-octeon/cvmx-agl.c new file mode 100644 index 000000000000..9eea857e47c7 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-agl.c @@ -0,0 +1,216 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Functions for RGMII (MGMT) initialization, configuration, + * and monitoring. + */ + +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-pki.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-agl.h> +#include <mach/cvmx-agl-defs.h> + +/* + * @param port to enable + * + * @return Zero on success, negative on failure + */ +int cvmx_agl_enable(int port) +{ + cvmx_agl_gmx_rxx_frm_ctl_t rxx_frm_ctl; + + rxx_frm_ctl.u64 = 0; + rxx_frm_ctl.s.pre_align = 1; + /* When set, disables the length check for non-min sized pkts with + * padding in the client data + */ + rxx_frm_ctl.s.pad_len = 1; + /* When set, disables the length check for VLAN pkts */ + rxx_frm_ctl.s.vlan_len = 1; + /* When set, PREAMBLE checking is less strict */ + rxx_frm_ctl.s.pre_free = 1; + /* Control Pause Frames can match station SMAC */ + rxx_frm_ctl.s.ctl_smac = 0; + /* Control Pause Frames can match globally assign Multicast address */ + rxx_frm_ctl.s.ctl_mcst = 1; + rxx_frm_ctl.s.ctl_bck = 1; /* Forward pause information to TX block */ + rxx_frm_ctl.s.ctl_drp = 1; /* Drop Control Pause Frames */ + rxx_frm_ctl.s.pre_strp = 1; /* Strip off the preamble */ + /* This port is configured to send PREAMBLE+SFD to begin every frame. + * GMX checks that the PREAMBLE is sent correctly + */ + rxx_frm_ctl.s.pre_chk = 1; + csr_wr(CVMX_AGL_GMX_RXX_FRM_CTL(port), rxx_frm_ctl.u64); + + return 0; +} + +cvmx_helper_link_info_t cvmx_agl_link_get(int port) +{ + cvmx_helper_link_info_t result; + int interface, port_index; + + /* Fake IPD port is used on some older models. */ + if (port < 0) + return __cvmx_helper_board_link_get(port); + + /* Simulator does not have PHY, use some defaults. */ + interface = cvmx_helper_get_interface_num(port); + port_index = cvmx_helper_get_interface_index_num(port); + if (cvmx_helper_get_port_force_link_up(interface, port_index)) { + result.u64 = 0; + result.s.full_duplex = 1; + result.s.link_up = 1; + result.s.speed = 1000; + return result; + } + + return __cvmx_helper_board_link_get(port); +} + +/* + * Set MII/RGMII link based on mode. + * + * @param port interface port to set the link. + * @param link_info Link status + * + * @return 0 on success and 1 on failure + */ +int cvmx_agl_link_set(int port, cvmx_helper_link_info_t link_info) +{ + cvmx_agl_gmx_prtx_cfg_t agl_gmx_prtx; + + /* Disable GMX before we make any changes. */ + agl_gmx_prtx.u64 = csr_rd(CVMX_AGL_GMX_PRTX_CFG(port)); + agl_gmx_prtx.s.en = 0; + agl_gmx_prtx.s.tx_en = 0; + agl_gmx_prtx.s.rx_en = 0; + csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), agl_gmx_prtx.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN6XXX) || OCTEON_IS_OCTEON3()) { + u64 one_second = 0x1000000; /* todo: this needs checking */ + + /* Wait for GMX to be idle */ + if (CVMX_WAIT_FOR_FIELD64(CVMX_AGL_GMX_PRTX_CFG(port), + cvmx_agl_gmx_prtx_cfg_t, rx_idle, ==, + 1, one_second) || + CVMX_WAIT_FOR_FIELD64(CVMX_AGL_GMX_PRTX_CFG(port), + cvmx_agl_gmx_prtx_cfg_t, tx_idle, ==, + 1, one_second)) { + debug("AGL%d: Timeout waiting for GMX to be idle\n", + port); + return -1; + } + } + + agl_gmx_prtx.u64 = csr_rd(CVMX_AGL_GMX_PRTX_CFG(port)); + + /* Set duplex mode */ + if (!link_info.s.link_up) + agl_gmx_prtx.s.duplex = 1; /* Force full duplex on down links */ + else + agl_gmx_prtx.s.duplex = link_info.s.full_duplex; + + switch (link_info.s.speed) { + case 10: + agl_gmx_prtx.s.speed = 0; + agl_gmx_prtx.s.slottime = 0; + if (OCTEON_IS_MODEL(OCTEON_CN6XXX) || OCTEON_IS_OCTEON3()) { + agl_gmx_prtx.s.speed_msb = 1; + agl_gmx_prtx.s.burst = 1; + } + break; + + case 100: + agl_gmx_prtx.s.speed = 0; + agl_gmx_prtx.s.slottime = 0; + if (OCTEON_IS_MODEL(OCTEON_CN6XXX) || OCTEON_IS_OCTEON3()) { + agl_gmx_prtx.s.speed_msb = 0; + agl_gmx_prtx.s.burst = 1; + } + break; + + case 1000: + /* 1000 MBits is only supported on 6XXX chips */ + if (OCTEON_IS_MODEL(OCTEON_CN6XXX) || OCTEON_IS_OCTEON3()) { + agl_gmx_prtx.s.speed_msb = 0; + agl_gmx_prtx.s.speed = 1; + agl_gmx_prtx.s.slottime = + 1; /* Only matters for half-duplex */ + agl_gmx_prtx.s.burst = agl_gmx_prtx.s.duplex; + } + break; + + /* No link */ + case 0: + default: + break; + } + + /* Write the new GMX setting with the port still disabled. */ + csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), agl_gmx_prtx.u64); + + /* Read GMX CFG again to make sure the config is completed. */ + agl_gmx_prtx.u64 = csr_rd(CVMX_AGL_GMX_PRTX_CFG(port)); + + if (OCTEON_IS_MODEL(OCTEON_CN6XXX) || OCTEON_IS_OCTEON3()) { + cvmx_agl_gmx_txx_clk_t agl_clk; + cvmx_agl_prtx_ctl_t prt_ctl; + + prt_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_clk.u64 = csr_rd(CVMX_AGL_GMX_TXX_CLK(port)); + /* MII (both speeds) and RGMII 1000 setting */ + agl_clk.s.clk_cnt = 1; + /* Check other speeds for RGMII mode */ + if (prt_ctl.s.mode == 0 || OCTEON_IS_OCTEON3()) { + if (link_info.s.speed == 10) + agl_clk.s.clk_cnt = 50; + else if (link_info.s.speed == 100) + agl_clk.s.clk_cnt = 5; + } + csr_wr(CVMX_AGL_GMX_TXX_CLK(port), agl_clk.u64); + } + + /* Enable transmit and receive ports */ + agl_gmx_prtx.s.tx_en = 1; + agl_gmx_prtx.s.rx_en = 1; + csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), agl_gmx_prtx.u64); + + /* Enable the link. */ + agl_gmx_prtx.s.en = 1; + csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), agl_gmx_prtx.u64); + + if (OCTEON_IS_OCTEON3()) { + union cvmx_agl_prtx_ctl agl_prtx_ctl; + /* Enable the interface, set clkrst */ + agl_prtx_ctl.u64 = csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.clkrst = 1; + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + csr_rd(CVMX_AGL_PRTX_CTL(port)); + agl_prtx_ctl.s.enable = 1; + csr_wr(CVMX_AGL_PRTX_CTL(port), agl_prtx_ctl.u64); + /* Read the value back to force the previous write */ + csr_rd(CVMX_AGL_PRTX_CTL(port)); + } + + return 0; +}
Import cvmx-fau-compat.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-fau-compat.c | 53 +++++++++++++++++++++++++ 1 file changed, 53 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-fau-compat.c
diff --git a/arch/mips/mach-octeon/cvmx-fau-compat.c b/arch/mips/mach-octeon/cvmx-fau-compat.c new file mode 100644 index 000000000000..9c2ff763ad53 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-fau-compat.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-pki.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-hwfau.h> + +u8 *cvmx_fau_regs_ptr; + +void cvmx_fau_bootmem_init(void *bootmem) +{ + memset(bootmem, 0, CVMX_FAU_MAX_REGISTERS_8); +} + +/** + * Initializes FAU region for devices without FAU unit. + * @return 0 on success -1 on failure + */ +int cvmx_fau_init(void) +{ + cvmx_fau_regs_ptr = (u8 *)cvmx_bootmem_alloc_named_range_once( + CVMX_FAU_MAX_REGISTERS_8, 0, 1ull << 31, 128, + "cvmx_fau_registers", cvmx_fau_bootmem_init); + + if (cvmx_fau_regs_ptr == 0ull) { + debug("ERROR: Failed to alloc named block for software FAU.\n"); + return -1; + } + + return 0; +}
Import cvmx-fpa.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-fpa.c | 1127 ++++++++++++++++++++++++++++++ 1 file changed, 1127 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-fpa.c
diff --git a/arch/mips/mach-octeon/cvmx-fpa.c b/arch/mips/mach-octeon/cvmx-fpa.c new file mode 100644 index 000000000000..14fe87c739c9 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-fpa.c @@ -0,0 +1,1127 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Support library for the hardware Free Pool Allocator. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +static const int debug; + +/* Due to suspected errata, we may not be able to let the FPA_AURAX_CNT + * get too close to 0, to avoid a spurious wrap-around error + */ +const unsigned int __cvmx_fpa3_cnt_offset = 32; + +/* For advanced checks, a guard-band is created around the internal + * stack, to make sure the stack is not overwritten. + */ +const u64 magic_pattern = 0xbab4faced095f00d; +const unsigned int guard_band_size = 0 << 10; /* 1KiB default*/ + +#define CVMX_CACHE_LINE_SHIFT (7) + +#define CVMX_FPA3_NAME_LEN (16) + +typedef struct { + char name[CVMX_FPA3_NAME_LEN]; + u64 stack_paddr; /* Internal stack storage */ + u64 bufs_paddr; /* Buffer pool base address */ + u64 stack_psize; /* Internal stack storage size */ + u64 bufs_psize; /* Buffer pool raw size */ + u64 buf_count; /* Number of buffer filled */ + u64 buf_size; /* Buffer size */ +} cvmx_fpa3_poolx_info_t; + +typedef struct { + char name[CVMX_FPA3_NAME_LEN]; + unsigned int buf_size; /* Buffer size */ +} cvmx_fpa3_aurax_info_t; + +typedef struct { + char name[CVMX_FPA1_NAME_SIZE]; + u64 size; /* Block size of pool buffers */ + u64 buffer_count; + u64 base_paddr; /* Base physical addr */ + /* if buffer is allocated at initialization */ +} cvmx_fpa1_pool_info_t; + +/** + * FPA1/FPA3 info structure is stored in a named block + * that is allocated once and shared among applications. + */ +static cvmx_fpa1_pool_info_t *cvmx_fpa1_pool_info; +static cvmx_fpa3_poolx_info_t *cvmx_fpa3_pool_info[CVMX_MAX_NODES]; +static cvmx_fpa3_aurax_info_t *cvmx_fpa3_aura_info[CVMX_MAX_NODES]; + +/** + * Return the size of buffers held in a POOL + * + * @param pool is the POOL handle + * @return buffer size in bytes + * + */ +int cvmx_fpa3_get_pool_buf_size(cvmx_fpa3_pool_t pool) +{ + cvmx_fpa_poolx_cfg_t pool_cfg; + + if (!__cvmx_fpa3_pool_valid(pool)) + return -1; + + pool_cfg.u64 = csr_rd_node(pool.node, CVMX_FPA_POOLX_CFG(pool.lpool)); + return pool_cfg.cn78xx.buf_size << CVMX_CACHE_LINE_SHIFT; +} + +/** + * Return the size of buffers held in a buffer pool + * + * @param pool is the pool number + * + * This function will work with CN78XX models in backward-compatible mode + */ +unsigned int cvmx_fpa_get_block_size(int pool) +{ + if (octeon_has_feature(OCTEON_FEATURE_FPA3)) { + return cvmx_fpa3_get_pool_buf_size(cvmx_fpa3_aura_to_pool( + cvmx_fpa1_pool_to_fpa3_aura(pool))); + } else { + if ((unsigned int)pool >= CVMX_FPA1_NUM_POOLS) + return 0; + if (!cvmx_fpa1_pool_info) + cvmx_fpa_global_init_node(0); + return cvmx_fpa1_pool_info[pool].size; + } +} + +static void cvmx_fpa3_set_aura_name(cvmx_fpa3_gaura_t aura, const char *name) +{ + cvmx_fpa3_aurax_info_t *pinfo; + + pinfo = cvmx_fpa3_aura_info[aura.node]; + if (!pinfo) + return; + pinfo += aura.laura; + memset(pinfo->name, 0, sizeof(pinfo->name)); + if (name) + strlcpy(pinfo->name, name, sizeof(pinfo->name)); +} + +static void cvmx_fpa3_set_pool_name(cvmx_fpa3_pool_t pool, const char *name) +{ + cvmx_fpa3_poolx_info_t *pinfo; + + pinfo = cvmx_fpa3_pool_info[pool.node]; + if (!pinfo) + return; + pinfo += pool.lpool; + memset(pinfo->name, 0, sizeof(pinfo->name)); + if (name) + strlcpy(pinfo->name, name, sizeof(pinfo->name)); +} + +static void cvmx_fpa_set_name(int pool_num, const char *name) +{ + if (octeon_has_feature(OCTEON_FEATURE_FPA3)) { + cvmx_fpa3_set_aura_name(cvmx_fpa1_pool_to_fpa3_aura(pool_num), + name); + } else { + cvmx_fpa1_pool_info_t *pinfo; + + if ((unsigned int)pool_num >= CVMX_FPA1_NUM_POOLS) + return; + if (!cvmx_fpa1_pool_info) + cvmx_fpa_global_init_node(0); + pinfo = &cvmx_fpa1_pool_info[pool_num]; + memset(pinfo->name, 0, sizeof(pinfo->name)); + if (name) + strlcpy(pinfo->name, name, sizeof(pinfo->name)); + } +} + +static int cvmx_fpa3_aura_cfg(cvmx_fpa3_gaura_t aura, cvmx_fpa3_pool_t pool, + u64 limit, u64 threshold, int ptr_dis) +{ + cvmx_fpa3_aurax_info_t *pinfo; + cvmx_fpa_aurax_cfg_t aura_cfg; + cvmx_fpa_poolx_cfg_t pool_cfg; + cvmx_fpa_aurax_cnt_t cnt_reg; + cvmx_fpa_aurax_cnt_limit_t limit_reg; + cvmx_fpa_aurax_cnt_threshold_t thresh_reg; + cvmx_fpa_aurax_int_t int_reg; + unsigned int block_size; + + if (debug) + debug("%s: AURA %u:%u POOL %u:%u\n", __func__, aura.node, + aura.laura, pool.node, pool.lpool); + + if (aura.node != pool.node) { + printf("ERROR: %s: AURA/POOL node mismatch\n", __func__); + return -1; + } + + if (!__cvmx_fpa3_aura_valid(aura)) { + printf("ERROR: %s: AURA invalid\n", __func__); + return -1; + } + + if (!__cvmx_fpa3_pool_valid(pool)) { + printf("ERROR: %s: POOL invalid\n", __func__); + return -1; + } + + /* Record POOL block size in AURA info entry */ + pool_cfg.u64 = csr_rd_node(pool.node, CVMX_FPA_POOLX_CFG(pool.lpool)); + + block_size = pool_cfg.cn78xx.buf_size << 7; + pinfo = cvmx_fpa3_aura_info[aura.node]; + if (!pinfo) + return -1; + pinfo += aura.laura; + + pinfo->buf_size = block_size; + + /* block_size should be >0 except for POOL=0 which is never enabled*/ + if (pool_cfg.cn78xx.ena && block_size == 0) { + printf("ERROR; %s: POOL buf_size invalid\n", __func__); + return -1; + } + + /* Initialize AURA count, limit and threshold registers */ + cnt_reg.u64 = 0; + cnt_reg.cn78xx.cnt = 0 + __cvmx_fpa3_cnt_offset; + + limit_reg.u64 = 0; + limit_reg.cn78xx.limit = limit; + /* Apply count offset, unless it cases a wrap-around */ + if ((limit + __cvmx_fpa3_cnt_offset) < CVMX_FPA3_AURAX_LIMIT_MAX) + limit_reg.cn78xx.limit += __cvmx_fpa3_cnt_offset; + + thresh_reg.u64 = 0; + thresh_reg.cn78xx.thresh = threshold; + /* Apply count offset, unless it cases a wrap-around */ + if ((threshold + __cvmx_fpa3_cnt_offset) < CVMX_FPA3_AURAX_LIMIT_MAX) + thresh_reg.cn78xx.thresh += __cvmx_fpa3_cnt_offset; + + csr_wr_node(aura.node, CVMX_FPA_AURAX_CNT(aura.laura), cnt_reg.u64); + csr_wr_node(aura.node, CVMX_FPA_AURAX_CNT_LIMIT(aura.laura), + limit_reg.u64); + csr_wr_node(aura.node, CVMX_FPA_AURAX_CNT_THRESHOLD(aura.laura), + thresh_reg.u64); + + /* Clear any pending error interrupts */ + int_reg.u64 = 0; + int_reg.cn78xx.thresh = 1; + + /* Follow a write to clear FPA_AURAX_INT[THRESH] with a read as + * a workaround to Errata FPA-23410. If FPA_AURAX_INT[THRESH] + * isn't clear, try again. + */ + do { + csr_wr_node(aura.node, CVMX_FPA_AURAX_INT(aura.laura), + int_reg.u64); + int_reg.u64 = + csr_rd_node(aura.node, CVMX_FPA_AURAX_INT(aura.laura)); + } while (int_reg.s.thresh); + + /* Disable backpressure etc.*/ + csr_wr_node(aura.node, CVMX_FPA_AURAX_CNT_LEVELS(aura.laura), 0); + csr_wr_node(aura.node, CVMX_FPA_AURAX_POOL_LEVELS(aura.laura), 0); + + aura_cfg.u64 = 0; + aura_cfg.s.ptr_dis = ptr_dis; + csr_wr_node(aura.node, CVMX_FPA_AURAX_CFG(aura.laura), aura_cfg.u64); + csr_wr_node(aura.node, CVMX_FPA_AURAX_POOL(aura.laura), pool.lpool); + + return 0; +} + +/** + * @INTERNAL + * + * Fill a newly created FPA3 POOL with buffers + * using a temporary AURA. + */ +static int cvmx_fpa3_pool_populate(cvmx_fpa3_pool_t pool, unsigned int buf_cnt, + unsigned int buf_sz, void *mem_ptr, + unsigned int mem_node) +{ + cvmx_fpa3_poolx_info_t *pinfo; + cvmx_fpa3_gaura_t aura; + cvmx_fpa3_pool_t zero_pool; + cvmx_fpa_poolx_cfg_t pool_cfg; + cvmx_fpa_poolx_start_addr_t pool_start_reg; + cvmx_fpa_poolx_end_addr_t pool_end_reg; + cvmx_fpa_poolx_available_t avail_reg; + cvmx_fpa_poolx_threshold_t thresh_reg; + cvmx_fpa_poolx_int_t int_reg; + unsigned int block_size, align; + unsigned long long mem_size; + u64 paddr; + unsigned int i; + + if (debug) + debug("%s: POOL %u:%u buf_sz=%u count=%d\n", __func__, + pool.node, pool.lpool, buf_sz, buf_cnt); + + if (!__cvmx_fpa3_pool_valid(pool)) + return -1; + + zero_pool = __cvmx_fpa3_pool(pool.node, 0); + + pool_cfg.u64 = csr_rd_node(pool.node, CVMX_FPA_POOLX_CFG(pool.lpool)); + + block_size = pool_cfg.cn78xx.buf_size << 7; + + if (pool_cfg.cn78xx.nat_align) { + /* Assure block_size is legit */ + if (block_size > (1 << 17)) { + printf("ERROR: %s: POOL %u:%u block size %u is not valid\n", + __func__, pool.node, pool.lpool, block_size); + return -1; + } + } + align = CVMX_CACHE_LINE_SIZE; + + pinfo = cvmx_fpa3_pool_info[pool.node]; + if (!pinfo) + return -1; + pinfo += pool.lpool; + + if (pinfo->buf_size != block_size || block_size != buf_sz) { + printf("ERROR: %s: POOL %u:%u buffer size mismatch\n", __func__, + pool.node, pool.lpool); + return -1; + } + + if (!mem_ptr) { + /* When allocating our own memory + * make sure at least 'buf_cnt' blocks + * will fit into it. + */ + mem_size = (long long)buf_cnt * block_size + (block_size - 128); + + mem_ptr = cvmx_helper_mem_alloc(mem_node, mem_size, align); + + if (!mem_ptr) { + printf("ERROR: %s: POOL %u:%u out of memory, could not allocate %llu bytes\n", + __func__, pool.node, pool.lpool, mem_size); + return -1; + } + + /* Record memory base for use in shutdown */ + pinfo->bufs_paddr = cvmx_ptr_to_phys(mem_ptr); + } else { + /* caller-allocated memory is sized simply, may reduce count */ + mem_size = (long long)buf_cnt * block_size; + /* caller responsable to free this memory too */ + } + + /* Recalculate buf_cnt after possible alignment adjustment */ + buf_cnt = mem_size / block_size; + + /* Get temporary AURA */ + aura = cvmx_fpa3_reserve_aura(pool.node, -1); + if (!__cvmx_fpa3_aura_valid(aura)) + return -1; + + /* Attach the temporary AURA to the POOL */ + (void)cvmx_fpa3_aura_cfg(aura, pool, buf_cnt, buf_cnt + 1, 0); + + /* Set AURA count to buffer count to avoid wrap-around */ + csr_wr_node(aura.node, CVMX_FPA_AURAX_CNT(aura.laura), buf_cnt); + + /* Set POOL threshold just above buf count so it does not misfire */ + thresh_reg.u64 = 0; + thresh_reg.cn78xx.thresh = buf_cnt + 1; + csr_wr_node(pool.node, CVMX_FPA_POOLX_THRESHOLD(pool.lpool), + thresh_reg.u64); + + /* Set buffer memory region bounds checking */ + paddr = (cvmx_ptr_to_phys(mem_ptr) >> 7) << 7; + pool_start_reg.u64 = 0; + pool_end_reg.u64 = 0; + pool_start_reg.cn78xx.addr = paddr >> 7; + pool_end_reg.cn78xx.addr = (paddr + mem_size + 127) >> 7; + + csr_wr_node(pool.node, CVMX_FPA_POOLX_START_ADDR(pool.lpool), + pool_start_reg.u64); + csr_wr_node(pool.node, CVMX_FPA_POOLX_END_ADDR(pool.lpool), + pool_end_reg.u64); + + /* Make sure 'paddr' is divisible by 'block_size' */ + i = (paddr % block_size); + if (i > 0) { + i = block_size - i; + paddr += i; + mem_size -= i; + } + + /* The above alignment mimics how the FPA3 hardware + * aligns pointers to the buffer size, which only + * needs to be multiple of cache line size + */ + + if (debug && paddr != cvmx_ptr_to_phys(mem_ptr)) + debug("%s: pool mem paddr %#llx adjusted to %#llx for block size %#x\n", + __func__, CAST_ULL(cvmx_ptr_to_phys(mem_ptr)), + CAST_ULL(paddr), block_size); + + for (i = 0; i < buf_cnt; i++) { + void *ptr = cvmx_phys_to_ptr(paddr); + + cvmx_fpa3_free_nosync(ptr, aura, 0); + + paddr += block_size; + + if ((paddr + block_size - 1) >= (paddr + mem_size)) + break; + } + + if (debug && i < buf_cnt) { + debug("%s: buffer count reduced from %u to %u\n", __func__, + buf_cnt, i); + buf_cnt = i; + } + + /* Wait for all buffers to reach the POOL before removing temp AURA */ + do { + CVMX_SYNC; + avail_reg.u64 = csr_rd_node( + pool.node, CVMX_FPA_POOLX_AVAILABLE(pool.lpool)); + } while (avail_reg.cn78xx.count < buf_cnt); + + /* Detach the temporary AURA */ + (void)cvmx_fpa3_aura_cfg(aura, zero_pool, 0, 0, 0); + + /* Release temporary AURA */ + (void)cvmx_fpa3_release_aura(aura); + + /* Clear all POOL interrupts */ + int_reg.u64 = 0; + int_reg.cn78xx.ovfls = 1; + int_reg.cn78xx.crcerr = 1; + int_reg.cn78xx.range = 1; + int_reg.cn78xx.thresh = 1; + csr_wr_node(pool.node, CVMX_FPA_POOLX_INT(pool.lpool), int_reg.u64); + + /* Record buffer count for shutdown */ + pinfo->buf_count = buf_cnt; + + return buf_cnt; +} + +/** + * @INTERNAL + * + * Fill a legacy FPA pool with buffers + */ +static int cvmx_fpa1_fill_pool(cvmx_fpa1_pool_t pool, int num_blocks, + void *buffer) +{ + cvmx_fpa_poolx_start_addr_t pool_start_reg; + cvmx_fpa_poolx_end_addr_t pool_end_reg; + unsigned int block_size = cvmx_fpa_get_block_size(pool); + unsigned int mem_size; + char *bufp; + + if ((unsigned int)pool >= CVMX_FPA1_NUM_POOLS) + return -1; + + mem_size = block_size * num_blocks; + + if (!buffer) { + buffer = cvmx_helper_mem_alloc(0, mem_size, + CVMX_CACHE_LINE_SIZE); + + cvmx_fpa1_pool_info[pool].base_paddr = cvmx_ptr_to_phys(buffer); + } else { + /* Align user-supplied buffer to cache line size */ + unsigned int off = + (CVMX_CACHE_LINE_SIZE - 1) & cvmx_ptr_to_phys(buffer); + if (off > 0) { + // buffer += CVMX_CACHE_LINE_SIZE - off; + buffer = (char *)buffer + CVMX_CACHE_LINE_SIZE - off; + mem_size -= CVMX_CACHE_LINE_SIZE - off; + num_blocks = mem_size / block_size; + } + } + + if (debug) + debug("%s: memory at %p size %#x\n", __func__, buffer, + mem_size); + + pool_start_reg.u64 = 0; + pool_end_reg.u64 = 0; + + /* buffer pointer range checks are highly recommended, but optional */ + pool_start_reg.cn61xx.addr = 1; /* catch NULL pointers */ + pool_end_reg.cn61xx.addr = (1ull << (40 - 7)) - 1; /* max paddr */ + if (!OCTEON_IS_MODEL(OCTEON_CN63XX)) { + csr_wr(CVMX_FPA_POOLX_START_ADDR(pool), pool_start_reg.u64); + csr_wr(CVMX_FPA_POOLX_END_ADDR(pool), pool_end_reg.u64); + } + + bufp = (char *)buffer; + while (num_blocks--) { + cvmx_fpa1_free(bufp, pool, 0); + cvmx_fpa1_pool_info[pool].buffer_count++; + bufp += block_size; + } + return 0; +} + +/** + * @INTERNAL + * + * Setup a legacy FPA pool + */ +static int cvmx_fpa1_pool_init(cvmx_fpa1_pool_t pool_id, int num_blocks, + int block_size, void *buffer) +{ + int max_pool = cvmx_fpa_get_max_pools(); + + if (pool_id < 0 || pool_id >= max_pool) { + printf("ERROR: %s pool %d invalid\n", __func__, pool_id); + return -1; + } + + if (!cvmx_fpa1_pool_info) + cvmx_fpa_global_init_node(0); + + if (debug) + debug("%s: initializing info pool %d\n", __func__, pool_id); + + cvmx_fpa1_pool_info[pool_id].size = block_size; + cvmx_fpa1_pool_info[pool_id].buffer_count = 0; + + if (debug) + debug("%s: enabling unit for pool %d\n", __func__, pool_id); + + return 0; +} + +/** + * Initialize global configuration for FPA block for specified node. + * + * @param node is the node number + * + * @note this function sets the initial QoS averaging timing parameters, + * for the entire FPA unit (per node), which may be overridden on a + * per AURA basis. + */ +int cvmx_fpa_global_init_node(int node) +{ + /* There are just the initial parameter values */ +#define FPA_RED_AVG_DLY 1 +#define FPA_RED_LVL_DLY 3 +#define FPA_QOS_AVRG 0 + /* Setting up avg_dly and prb_dly, enable bits */ + if (octeon_has_feature(OCTEON_FEATURE_FPA3)) { + char pool_info_name[32] = "cvmx_fpa3_pools_"; + char aura_info_name[32] = "cvmx_fpa3_auras_"; + char ns[2] = "0"; + + ns[0] += node; + strcat(pool_info_name, ns); + strcat(aura_info_name, ns); + + cvmx_fpa3_config_red_params(node, FPA_QOS_AVRG, FPA_RED_LVL_DLY, + FPA_RED_AVG_DLY); + + /* Allocate the pinfo named block */ + cvmx_fpa3_pool_info[node] = (cvmx_fpa3_poolx_info_t *) + cvmx_bootmem_alloc_named_range_once( + sizeof(cvmx_fpa3_pool_info[0][0]) * + cvmx_fpa3_num_pools(), + 0, 0, 0, pool_info_name, NULL); + + cvmx_fpa3_aura_info[node] = (cvmx_fpa3_aurax_info_t *) + cvmx_bootmem_alloc_named_range_once( + sizeof(cvmx_fpa3_aura_info[0][0]) * + cvmx_fpa3_num_auras(), + 0, 0, 0, aura_info_name, NULL); + + //XXX add allocation error check + + /* Setup zero_pool on this node */ + cvmx_fpa3_reserve_pool(node, 0); + cvmx_fpa3_pool_info[node][0].buf_count = 0; + } else { + char pool_info_name[32] = "cvmx_fpa_pool"; + + /* Allocate the pinfo named block */ + cvmx_fpa1_pool_info = (cvmx_fpa1_pool_info_t *) + cvmx_bootmem_alloc_named_range_once( + sizeof(cvmx_fpa1_pool_info[0]) * + CVMX_FPA1_NUM_POOLS, + 0, 0, 0, pool_info_name, NULL); + + cvmx_fpa1_enable(); + } + + return 0; +} + +static void __memset_u64(u64 *ptr, u64 pattern, unsigned int words) +{ + while (words--) + *ptr++ = pattern; +} + +/** + * @INTERNAL + * Initialize pool pointer-storage memory + * + * Unlike legacy FPA, which used free buffers to store pointers that + * exceed on-chip memory, FPA3 requires a dedicated memory buffer for + * free pointer stack back-store. + * + * @param pool - pool to initialize + * @param mem_node - if memory should be allocated from a different node + * @param max_buffer_cnt - maximum block capacity of pool + * @param align - buffer alignment mode, + * current FPA_NATURAL_ALIGNMENT is supported + * @param buffer_sz - size of buffers in pool + */ +static int cvmx_fpa3_pool_stack_init(cvmx_fpa3_pool_t pool, + unsigned int mem_node, + unsigned int max_buffer_cnt, + enum cvmx_fpa3_pool_alignment_e align, + unsigned int buffer_sz) +{ + cvmx_fpa3_poolx_info_t *pinfo; + u64 stack_paddr; + void *mem_ptr; + unsigned int stack_memory_size; + cvmx_fpa_poolx_cfg_t pool_cfg; + cvmx_fpa_poolx_fpf_marks_t pool_fpf_marks; + + if (debug) + debug("%s: POOL %u:%u bufsz=%u maxbuf=%u\n", __func__, + pool.node, pool.lpool, buffer_sz, max_buffer_cnt); + + if (!__cvmx_fpa3_pool_valid(pool)) { + printf("ERROR: %s: POOL invalid\n", __func__); + return -1; + } + + pinfo = cvmx_fpa3_pool_info[pool.node]; + if (!pinfo) { + printf("ERROR: %s: FPA on node#%u is not initialized\n", + __func__, pool.node); + return -1; + } + pinfo += pool.lpool; + + /* Calculate stack size based on buffer count with one line to spare */ + stack_memory_size = (max_buffer_cnt * 128) / 29 + 128 + 127; + + /* Increase stack size by band guard */ + stack_memory_size += guard_band_size << 1; + + /* Align size to cache line */ + stack_memory_size = (stack_memory_size >> 7) << 7; + + /* Allocate internal stack */ + mem_ptr = cvmx_helper_mem_alloc(mem_node, stack_memory_size, + CVMX_CACHE_LINE_SIZE); + + if (debug) + debug("%s: stack_mem=%u ptr=%p\n", __func__, stack_memory_size, + mem_ptr); + + if (!mem_ptr) { + debug("ERROR: %sFailed to allocate stack for POOL %u:%u\n", + __func__, pool.node, pool.lpool); + return -1; + } + + /* Initialize guard bands */ + if (guard_band_size > 0) { + __memset_u64((u64 *)mem_ptr, magic_pattern, + guard_band_size >> 3); + __memset_u64((u64 *)((char *)mem_ptr + stack_memory_size - + guard_band_size), + magic_pattern, guard_band_size >> 3); + } + + pinfo->stack_paddr = cvmx_ptr_to_phys(mem_ptr); + pinfo->stack_psize = stack_memory_size; + + /* Calculate usable stack start */ + stack_paddr = cvmx_ptr_to_phys((char *)mem_ptr + guard_band_size); + + csr_wr_node(pool.node, CVMX_FPA_POOLX_STACK_BASE(pool.lpool), + stack_paddr); + csr_wr_node(pool.node, CVMX_FPA_POOLX_STACK_ADDR(pool.lpool), + stack_paddr); + + /* Calculate usable stack end - start of last cache line */ + stack_paddr = stack_paddr + stack_memory_size - (guard_band_size << 1); + + csr_wr_node(pool.node, CVMX_FPA_POOLX_STACK_END(pool.lpool), + stack_paddr); + + if (debug) + debug("%s: Stack paddr %#llx - %#llx\n", __func__, + CAST_ULL(csr_rd_node(pool.node, CVMX_FPA_POOLX_STACK_BASE( + pool.lpool))), + CAST_ULL(csr_rd_node(pool.node, CVMX_FPA_POOLX_STACK_END( + pool.lpool)))); + + /* Setup buffer size for this pool until it is shutdown */ + pinfo->buf_size = buffer_sz; + + pool_cfg.u64 = 0; + pool_cfg.cn78xx.buf_size = buffer_sz >> 7; + pool_cfg.cn78xx.l_type = 0x2; + pool_cfg.cn78xx.ena = 0; + if (align == FPA_NATURAL_ALIGNMENT) + pool_cfg.cn78xx.nat_align = 1; + + /* FPA-26117, FPA-22443 */ + pool_fpf_marks.u64 = + csr_rd_node(pool.node, CVMX_FPA_POOLX_FPF_MARKS(pool.lpool)); + pool_fpf_marks.s.fpf_rd = 0x80; + csr_wr_node(pool.node, CVMX_FPA_POOLX_FPF_MARKS(pool.lpool), + pool_fpf_marks.u64); + + csr_wr_node(pool.node, CVMX_FPA_POOLX_CFG(pool.lpool), pool_cfg.u64); + pool_cfg.cn78xx.ena = 1; + csr_wr_node(pool.node, CVMX_FPA_POOLX_CFG(pool.lpool), pool_cfg.u64); + + /* Pool is now ready to be filled up */ + return 0; +} + +/** + * Create an FPA POOL and fill it up with buffers + * + * @param node is the node number for the pool and memory location + * @param desired_pool is the local pool number desired + * or -1 for first available + * @param name is the symbolic name to assign the POOL + * @param block_size is the size of all buffers held in this POOL + * @param num_blocks is the number of free buffers to fill into the POOL + * @param buffer is an optionally caller-supplied memory for the buffers + * or NULL to cause the buffer memory to be allocated automatically. + * @return the POOL handle + * + * Note: if the buffer memory is supplied by caller, the application + * will be responsable to free this memory. + * + * Only supported on CN78XX. + */ +cvmx_fpa3_pool_t cvmx_fpa3_setup_fill_pool(int node, int desired_pool, + const char *name, + unsigned int block_size, + unsigned int num_blocks, + void *buffer) +{ + cvmx_fpa3_pool_t pool; + unsigned int mem_node; + int rc; + + if (node < 0) + node = cvmx_get_node_num(); + + if (debug) + debug("%s: desired pool=%d bufsize=%u cnt=%u '%s'\n", __func__, + desired_pool, block_size, num_blocks, name); + + /* Use memory from the node local to the AURA/POOL */ + mem_node = node; + + if (num_blocks == 0 || num_blocks > 1 << 30) { + printf("ERROR: %s: invalid block count %u\n", __func__, + num_blocks); + return CVMX_FPA3_INVALID_POOL; + } + + /* + * Check for block size validity: + * With user-supplied buffer, can't increase block size, + * so make sure it is at least 128, and is aligned to 128 + * For all cases make sure it is not too big + */ + if ((buffer && (block_size < CVMX_CACHE_LINE_SIZE || + (block_size & (CVMX_CACHE_LINE_SIZE - 1)))) || + (block_size > (1 << 17))) { + printf("ERROR: %s: invalid block size %u\n", __func__, + block_size); + return CVMX_FPA3_INVALID_POOL; + } + + if (block_size < CVMX_CACHE_LINE_SIZE) + block_size = CVMX_CACHE_LINE_SIZE; + + /* Reserve POOL */ + pool = cvmx_fpa3_reserve_pool(node, desired_pool); + + if (!__cvmx_fpa3_pool_valid(pool)) { + printf("ERROR: %s: POOL %u:%d not available\n", __func__, node, + desired_pool); + return CVMX_FPA3_INVALID_POOL; + } + + /* Initialize POOL with stack storage */ + rc = cvmx_fpa3_pool_stack_init(pool, mem_node, num_blocks, + FPA_NATURAL_ALIGNMENT, block_size); + if (rc < 0) { + printf("ERROR: %s: POOL %u:%u stack setup failed\n", __func__, + pool.node, pool.lpool); + cvmx_fpa3_release_pool(pool); + return CVMX_FPA3_INVALID_POOL; + } + + /* Populate the POOL with buffers */ + rc = cvmx_fpa3_pool_populate(pool, num_blocks, block_size, buffer, + mem_node); + if (rc < 0) { + printf("ERROR: %s: POOL %u:%u memory fill failed\n", __func__, + pool.node, pool.lpool); + cvmx_fpa3_release_pool(pool); + return CVMX_FPA3_INVALID_POOL; + } + + cvmx_fpa3_set_pool_name(pool, name); + + return pool; +} + +/** + * Attach an AURA to an existing POOL + * + * @param pool is the handle of the POOL to be attached + * @param desired_aura is the number of the AURA resired + * or -1 for the AURA to be automatically assigned + * @param name is a symbolic name for the new AURA + * @param block_size is the size of all buffers that will be handed + * out by this AURA + * @param num_blocks is the maximum number of buffers that can be + * handed out by this AURA, and can not exceed the number + * of buffers filled into the attached POOL + * @return the AURA handle + * + * Only supported on CN78XX. + */ +cvmx_fpa3_gaura_t cvmx_fpa3_set_aura_for_pool(cvmx_fpa3_pool_t pool, + int desired_aura, + const char *name, + unsigned int block_size, + unsigned int num_blocks) +{ + cvmx_fpa3_gaura_t aura; + cvmx_fpa_poolx_available_t avail_reg; + const char *emsg; + int rc; + + if (debug) + debug("%s: aura=%d bufsize=%u cnt=%u '%s'\n", __func__, + desired_aura, block_size, num_blocks, name); + + if (!__cvmx_fpa3_pool_valid(pool)) { + printf("ERROR: %s: POOL argument invalid\n", __func__); + return CVMX_FPA3_INVALID_GAURA; + } + + /* Verify the AURA buffer count limit is not above POOL buffer count */ + avail_reg.u64 = + csr_rd_node(pool.node, CVMX_FPA_POOLX_AVAILABLE(pool.lpool)); + if (avail_reg.cn78xx.count < num_blocks) { + printf("WARNING: %s: AURA %u:%u buffer count limit %u reduced to POOL available count %u\n", + __func__, aura.node, aura.laura, num_blocks, + (unsigned int)avail_reg.cn78xx.count); + num_blocks = avail_reg.cn78xx.count; + } + + /* Reserve an AURA number, follow desired number */ + aura = cvmx_fpa3_reserve_aura(pool.node, desired_aura); + + if (!__cvmx_fpa3_aura_valid(aura)) { + printf("ERROR: %s: AURA %u:%d not available\n", __func__, + pool.node, desired_aura); + return CVMX_FPA3_INVALID_GAURA; + } + + /* Initialize AURA attached to the above POOL */ + rc = cvmx_fpa3_aura_cfg(aura, pool, num_blocks, num_blocks + 1, 0); + if (rc < 0) { + emsg = "AURA configuration"; + goto _fail; + } + + cvmx_fpa3_set_aura_name(aura, name); + + return aura; + +_fail: + printf("ERROR: %s: %s\n", __func__, emsg); + cvmx_fpa3_release_aura(aura); + return CVMX_FPA3_INVALID_GAURA; +} + +/** + * Create a combination of an AURA and a POOL + * + * @param node is the node number for the pool and memory location + * @param desired_aura is the number of the AURA resired + * or -1 for the AURA to be automatically assigned + * @param name is a symbolic name for the new AURA + * @param block_size is the size of all buffers that will be handed + * out by this AURA + * @param num_blocks is the maximum number of buffers that can be + * handed out by this AURA, and can not exceed the number + * of buffers filled into the attached POOL + * @param buffer is an optionally caller-supplied memory for the buffers + * or NULL to cause the buffer memory to be allocated automatically. + * + * @return the AURA handle + * + * Note: if the buffer memory is supplied by caller, the application + * will be responsable to free this memory. + * The POOL number is always automatically assigned. + * + * Only supported on CN78XX. + */ +cvmx_fpa3_gaura_t cvmx_fpa3_setup_aura_and_pool(int node, int desired_aura, + const char *name, void *buffer, + unsigned int block_size, + unsigned int num_blocks) +{ + cvmx_fpa3_gaura_t aura = CVMX_FPA3_INVALID_GAURA; + cvmx_fpa3_pool_t pool = CVMX_FPA3_INVALID_POOL; + const char *emsg = ""; + unsigned int mem_node; + int rc; + + if (debug) + debug("%s: aura=%d size=%u cnt=%u '%s'\n", __func__, + desired_aura, block_size, num_blocks, name); + + if (node < 0) + node = cvmx_get_node_num(); + + if (num_blocks == 0 || num_blocks > 1 << 30) { + printf("ERROR: %s: invalid block count %u\n", __func__, + num_blocks); + return CVMX_FPA3_INVALID_GAURA; + } + + /* Use memory from the node local to the AURA/POOL */ + mem_node = node; + + /* Reserve an AURA number, follow desired number */ + aura = cvmx_fpa3_reserve_aura(node, desired_aura); + + if (!__cvmx_fpa3_aura_valid(aura)) { + emsg = "AURA not available"; + goto _fail; + } + + /* Reserve POOL dynamically to underpin this AURA */ + pool = cvmx_fpa3_reserve_pool(node, -1); + + if (!__cvmx_fpa3_pool_valid(pool)) { + emsg = "POOL not available"; + goto _fail; + } + + /* + * Check for block size validity: + * With user-supplied buffer, can't increase block size, + * so make sure it is at least 128, and is aligned to 128 + * For all cases make sure it is not too big + */ + if ((buffer && (block_size < CVMX_CACHE_LINE_SIZE || + (block_size & (CVMX_CACHE_LINE_SIZE - 1)))) || + block_size > (1 << 17)) { + printf("ERROR: %s: invalid block size %u\n", __func__, + block_size); + emsg = "invalid block size"; + goto _fail; + } + + if (block_size < CVMX_CACHE_LINE_SIZE) + block_size = CVMX_CACHE_LINE_SIZE; + + /* Initialize POOL with stack storage */ + rc = cvmx_fpa3_pool_stack_init(pool, mem_node, num_blocks, + FPA_NATURAL_ALIGNMENT, block_size); + if (rc < 0) { + emsg = "POOL Stack setup"; + goto _fail; + } + + /* Populate the AURA/POOL with buffers */ + rc = cvmx_fpa3_pool_populate(pool, num_blocks, block_size, buffer, + mem_node); + if (rc < 0) { + emsg = "POOL buffer memory"; + goto _fail; + } + + /* Initialize AURA attached to the above POOL */ + rc = cvmx_fpa3_aura_cfg(aura, pool, num_blocks, num_blocks + 1, 0); + if (rc < 0) { + emsg = "AURA configuration"; + goto _fail; + } + + cvmx_fpa3_set_aura_name(aura, name); + cvmx_fpa3_set_pool_name(pool, name); + + if (debug) + debug("%s: AURA %u:%u ready, avail=%lld\n", __func__, aura.node, + aura.laura, cvmx_fpa3_get_available(aura)); + + return aura; + +_fail: + printf("ERROR: %s: Failed in %s\n", __func__, emsg); + /* These will silently fail if POOL/AURA is not valid */ + cvmx_fpa3_release_aura(aura); + cvmx_fpa3_release_pool(pool); + return CVMX_FPA3_INVALID_GAURA; +} + +/** + * Setup a legacy FPA pool + * + * @param desired_pool is the POOL number desired or -1 for automatic + * assignment + * @param name is the symbolic POOL name + * @param block_size is the size of all buffers held in this POOL + * @param num_blocks is the number of free buffers to fill into the POOL + * @param buffer is an optionally caller-supplied memory for the buffers + * or NULL to cause the buffer memory to be allocated automatically. + * @return pool number or -1 on error. + * + * Note: if the buffer memory is supplied by caller, the application + * will be responsable to free this memory. + */ +int cvmx_fpa1_setup_pool(int desired_pool, const char *name, void *buffer, + unsigned int block_size, unsigned int num_blocks) +{ + cvmx_fpa1_pool_t pool = CVMX_FPA1_INVALID_POOL; + int rc; + + if (debug) + debug("%s: desired pool %d, name '%s', mem %p size %u count %u\n", + __func__, desired_pool, name, buffer, block_size, + num_blocks); + + /* Reserve desired pool or get one dynamically */ + pool = cvmx_fpa1_reserve_pool(desired_pool); + + /* Validate reserved pool, if successful */ + if (pool < 0 || pool >= cvmx_fpa_get_max_pools()) { + /* global resources would have printed an error message here */ + return CVMX_FPA1_INVALID_POOL; + } + + /* Initialize the pool */ + rc = cvmx_fpa1_pool_init(pool, num_blocks, block_size, buffer); + if (rc < 0) { + printf("ERROR: %s: failed pool %u init\n", __func__, pool); + cvmx_fpa1_release_pool(pool); + return CVMX_FPA1_INVALID_POOL; + } + + rc = cvmx_fpa1_fill_pool(pool, num_blocks, buffer); + if (rc < 0) { + printf("ERROR: %s: failed pool %u memory\n", __func__, pool); + cvmx_fpa1_release_pool(pool); + return CVMX_FPA1_INVALID_POOL; + } + + if (debug) + debug("%s: pool %d filled up\b", __func__, pool); + + cvmx_fpa_set_name(pool, name); + return pool; +} + +/** + * Setup an FPA pool with buffers + * + * @param pool is the POOL number desired or -1 for automatic assignment + * @param name is the symbolic POOL name + * @param buffer is an optionally caller-supplied memory for the buffers + * or NULL to cause the buffer memory to be allocated automatically. + * @param block_size is the size of all buffers held in this POOL + * @param num_blocks is the number of free buffers to fill into the POOL + * @param buffer is an optionally caller-supplied memory for the buffers + * or NULL to cause the buffer memory to be allocated automatically. + * + * @return pool number or -1 on error. + * + * Note: if the buffer memory is supplied by caller, the application + * will be responsable to free this memory. + * This function will work with CN78XX models in backward-compatible mode + */ +int cvmx_fpa_setup_pool(int pool, const char *name, void *buffer, + u64 block_size, u64 num_blocks) +{ + if (octeon_has_feature(OCTEON_FEATURE_FPA3)) { + cvmx_fpa3_gaura_t aura; + + aura = cvmx_fpa3_setup_aura_and_pool(-1, pool, name, buffer, + block_size, num_blocks); + if (!__cvmx_fpa3_aura_valid(aura)) + return -1; + if (aura.laura >= CVMX_FPA1_NUM_POOLS && pool >= 0) + printf("WARNING: %s: AURA %u is out of range for backward-compatible operation\n", + __func__, aura.laura); + return aura.laura; + } else { + return cvmx_fpa1_setup_pool(pool, name, buffer, block_size, + num_blocks); + } +}
Import cvmx-ilk.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-ilk.c | 1199 ++++++++++++++++++++++++++++++ 1 file changed, 1199 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-ilk.c
diff --git a/arch/mips/mach-octeon/cvmx-ilk.c b/arch/mips/mach-octeon/cvmx-ilk.c new file mode 100644 index 000000000000..6223ff2c84b2 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-ilk.c @@ -0,0 +1,1199 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Support library for the ILK + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +/* + * global configurations. + * + * for cn68, the default is {0xf, 0xf0}. to disable the 2nd ILK, set + * cvmx_ilk_lane_mask[CVMX_NUM_ILK_INTF] = {0xff, 0x0} and + * cvmx_ilk_chans[CVMX_NUM_ILK_INTF] = {8, 0} + */ +unsigned short cvmx_ilk_lane_mask[CVMX_MAX_NODES][CVMX_NUM_ILK_INTF] = { + [0 ... CVMX_MAX_NODES - 1] = { 0x000f, 0x00f0 } +}; + +int cvmx_ilk_chans[CVMX_MAX_NODES][CVMX_NUM_ILK_INTF] = { + [0 ... CVMX_MAX_NODES - 1] = { 8, 8 } +}; + +static cvmx_ilk_intf_t cvmx_ilk_intf_cfg[CVMX_MAX_NODES][CVMX_NUM_ILK_INTF]; + +cvmx_ilk_LA_mode_t cvmx_ilk_LA_mode[CVMX_NUM_ILK_INTF] = { { 0, 0 }, { 0, 0 } }; +/** + * User-overrideable callback function that returns whether or not an interface + * should use look-aside mode. + * + * @param interface - interface being checked + * @param channel - channel number, can be 0 or 1 or -1 to see if LA mode + * should be enabled for the interface. + * @return 0 to not use LA-mode, 1 to use LA-mode. + */ +int cvmx_ilk_use_la_mode(int interface, int channel) +{ + if (OCTEON_IS_MODEL(OCTEON_CN68XX_PASS1_0)) + return 0; + + if (interface >= CVMX_NUM_ILK_INTF) { + debug("ERROR: invalid interface=%d in %s\n", + interface, __func__); + return -1; + } + return cvmx_ilk_LA_mode[interface].ilk_LA_mode; +} + +/** + * User-overrideable callback function that returns whether or not an interface + * in look-aside mode should enable the RX calendar. + * + * @param interface - interface to check + * @return 1 to enable RX calendar, 0 to disable RX calendar. + * + * NOTE: For the CN68XX pass 2.0 this will enable the RX calendar for interface + * 0 and not interface 1. It is up to the customer to override this behavior. + */ +int cvmx_ilk_la_mode_enable_rx_calendar(int interface) +{ + /* There is an errata in the CN68XX pass 2.0 where if connected + * in a loopback configuration or back to back then only one interface + * can have the RX calendar enabled. + */ + if (interface >= CVMX_NUM_ILK_INTF) { + debug("ERROR: invalid interface=%d in %s\n", + interface, __func__); + return -1; + } + return cvmx_ilk_LA_mode[interface].ilk_LA_mode_cal_ena; +} + +/** + * Initialize and start the ILK interface. + * + * @param interface The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param lane_mask the lane group for this interface + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_start_interface(int interface, unsigned short lane_mask) +{ + int res = -1; + int other_intf, this_qlm, other_qlm; + unsigned short uni_mask; + cvmx_ilk_txx_cfg0_t ilk_txx_cfg0; + cvmx_ilk_rxx_cfg0_t ilk_rxx_cfg0; + cvmx_ilk_ser_cfg_t ilk_ser_cfg; + int node = (interface >> 4) & 0xf; + + interface &= 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (lane_mask == 0) + return res; + + /* check conflicts between 2 ilk interfaces. 1 lane can be assigned to 1 + * interface only + */ + other_intf = !interface; + if (cvmx_ilk_lane_mask[node][other_intf] & lane_mask) { + debug("ILK%d:%d: %s: lane assignment conflict\n", node, + interface, __func__); + return res; + } + + /* check the legality of the lane mask. interface 0 can have 8 lanes, + * while interface 1 can have 4 lanes at most + */ + uni_mask = lane_mask >> (interface * 4); + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + cvmx_mio_qlmx_cfg_t mio_qlmx_cfg, other_mio_qlmx_cfg; + + if ((uni_mask != 0x1 && uni_mask != 0x3 && uni_mask != 0xf && + uni_mask != 0xff) || + (interface == 1 && lane_mask > 0xf0)) { + debug("ILK%d: %s: incorrect lane mask: 0x%x\n", + interface, __func__, uni_mask); + return res; + } + /* check the availability of qlms. qlm_cfg = 001 means the chip + * is fused to give this qlm to ilk + */ + this_qlm = interface + CVMX_ILK_QLM_BASE(); + other_qlm = other_intf + CVMX_ILK_QLM_BASE(); + mio_qlmx_cfg.u64 = csr_rd(CVMX_MIO_QLMX_CFG(this_qlm)); + other_mio_qlmx_cfg.u64 = csr_rd(CVMX_MIO_QLMX_CFG(other_qlm)); + if (mio_qlmx_cfg.s.qlm_cfg != 1 || + (uni_mask == 0xff && other_mio_qlmx_cfg.s.qlm_cfg != 1)) { + debug("ILK%d: %s: qlm unavailable\n", interface, + __func__); + return res; + } + /* Has 8 lanes */ + lane_mask &= 0xff; + } + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + int qlm; + unsigned short lane_mask_all = 0; + + /* QLM 4 - QLM 7 can be configured for ILK. Get the lane mask + * of all the qlms that are configured for ilk + */ + for (qlm = 4; qlm < 8; qlm++) { + cvmx_gserx_cfg_t gserx_cfg; + cvmx_gserx_phy_ctl_t phy_ctl; + + /* Make sure QLM is powered and out of reset */ + phy_ctl.u64 = + csr_rd_node(node, CVMX_GSERX_PHY_CTL(qlm)); + if (phy_ctl.s.phy_pd || phy_ctl.s.phy_reset) + continue; + + /* Make sure QLM is in ILK mode */ + gserx_cfg.u64 = csr_rd_node(node, CVMX_GSERX_CFG(qlm)); + if (gserx_cfg.s.ila) + lane_mask_all |= ((1 << 4) - 1) + << (4 * (qlm - 4)); + } + + if ((lane_mask_all & lane_mask) != lane_mask) { + debug("ILK%d: %s: incorrect lane mask: 0x%x\n", + interface, __func__, lane_mask); + return res; + } + } + + /* power up the serdes */ + ilk_ser_cfg.u64 = csr_rd_node(node, CVMX_ILK_SER_CFG); + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + if (ilk_ser_cfg.cn68xx.ser_pwrup == 0) { + ilk_ser_cfg.cn68xx.ser_rxpol_auto = 1; + ilk_ser_cfg.cn68xx.ser_rxpol = 0; + ilk_ser_cfg.cn68xx.ser_txpol = 0; + ilk_ser_cfg.cn68xx.ser_reset_n = 0xff; + ilk_ser_cfg.cn68xx.ser_haul = 0; + } + ilk_ser_cfg.cn68xx.ser_pwrup |= + ((interface == 0) && (lane_mask > 0xf)) ? + 0x3 : + (1 << interface); + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + ilk_ser_cfg.cn78xx.ser_rxpol_auto = 1; + ilk_ser_cfg.cn78xx.ser_rxpol = 0; + ilk_ser_cfg.cn78xx.ser_txpol = 0; + ilk_ser_cfg.cn78xx.ser_reset_n = 0xffff; + } + csr_wr_node(node, CVMX_ILK_SER_CFG, ilk_ser_cfg.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX_PASS2_X)) { + /* Workaround for Errata (G-16467) */ + int qlm = (interface) ? 2 : 1; + int start_qlm, end_qlm; + + /* Apply the workaround to both the QLMs if configured for x8 lanes */ + if (cvmx_pop(lane_mask) > 4) { + start_qlm = 1; + end_qlm = 2; + } else { + start_qlm = qlm; + end_qlm = qlm; + } + + for (qlm = start_qlm; qlm <= end_qlm; qlm++) { +#ifdef CVMX_QLM_DUMP_STATE + debug("%s:%d: ILK%d: Applying workaround for Errata G-16467\n", + __func__, __LINE__, qlm); + cvmx_qlm_display_registers(qlm); + debug("\n"); +#endif + /* This workaround only applies to QLMs running ILK at 6.25Ghz */ + if ((cvmx_qlm_get_gbaud_mhz(qlm) == 6250) && + (cvmx_qlm_jtag_get(qlm, 0, "clkf_byp") != 20)) { + udelay(100); /* Wait 100us for links to stabalize */ + cvmx_qlm_jtag_set(qlm, -1, "clkf_byp", 20); + /* Allow the QLM to exit reset */ + cvmx_qlm_jtag_set(qlm, -1, "cfg_rst_n_clr", 0); + udelay(100); /* Wait 100us for links to stabalize */ + /* Allow TX on QLM */ + cvmx_qlm_jtag_set(qlm, -1, "cfg_tx_idle_set", + 0); + } +#ifdef CVMX_QLM_DUMP_STATE + debug("%s:%d: ILK%d: Done applying workaround for Errata G-16467\n", + __func__, __LINE__, qlm); + cvmx_qlm_display_registers(qlm); + debug("\n\n"); +#endif + } + } + + /* Initialize all calendar entries to xoff state */ + __cvmx_ilk_clear_cal((node << 4) | interface); + + /* Enable ILK LA mode if configured. */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + if (cvmx_ilk_use_la_mode(interface, 0)) { + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; + + ilk_txx_cfg1.u64 = csr_rd(CVMX_ILK_TXX_CFG1(interface)); + ilk_rxx_cfg1.u64 = csr_rd(CVMX_ILK_RXX_CFG1(interface)); + ilk_txx_cfg1.s.la_mode = 1; + ilk_txx_cfg1.s.tx_link_fc_jam = 1; + ilk_txx_cfg1.s.rx_link_fc_ign = 1; + ilk_rxx_cfg1.s.la_mode = 1; + csr_wr(CVMX_ILK_TXX_CFG1(interface), ilk_txx_cfg1.u64); + csr_wr(CVMX_ILK_RXX_CFG1(interface), ilk_rxx_cfg1.u64); + cvmx_ilk_intf_cfg[node][interface].la_mode = + 1; /* Enable look-aside mode */ + } else { + cvmx_ilk_intf_cfg[node][interface].la_mode = + 0; /* Disable look-aside mode */ + } + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + cvmx_ilk_intf_cfg[node][interface].la_mode = 0; + + /* configure the lane enable of the interface */ + ilk_txx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + ilk_rxx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + ilk_rxx_cfg0.s.lane_ena = lane_mask; + ilk_txx_cfg0.s.lane_ena = lane_mask; + csr_wr_node(node, CVMX_ILK_TXX_CFG0(interface), ilk_txx_cfg0.u64); + csr_wr_node(node, CVMX_ILK_RXX_CFG0(interface), ilk_rxx_cfg0.u64); + + /* For 10.3125Gbs data rate, set SER_LIMIT to 0x3ff for x8 & x12 mode */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + cvmx_gserx_lane_mode_t lmode0, lmode1; + + lmode0.u64 = csr_rd_node(node, CVMX_GSERX_LANE_MODE(5)); + lmode1.u64 = csr_rd_node(node, CVMX_GSERX_LANE_MODE(7)); + if ((lmode0.s.lmode == 5 || lmode1.s.lmode == 5) && + (lane_mask == 0xfff || lane_mask == 0xfff0 || + lane_mask == 0xff || lane_mask == 0xff00)) { + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + + ilk_txx_cfg1.u64 = + csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + ilk_txx_cfg1.s.ser_limit = 0x3ff; + csr_wr_node(node, CVMX_ILK_TXX_CFG1(interface), + ilk_txx_cfg1.u64); + } + } + + /* write to local cache. for lane speed, if interface 0 has 8 lanes, + * assume both qlms have the same speed + */ + cvmx_ilk_intf_cfg[node][interface].intf_en = 1; + res = 0; + + return res; +} + +/** + * set pipe group base and length for the interface + * + * @param xiface The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param pipe_base the base of the pipe group + * @param pipe_len the length of the pipe group + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_set_pipe(int xiface, int pipe_base, unsigned int pipe_len) +{ + int res = -1; + cvmx_ilk_txx_pipe_t ilk_txx_pipe; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface - CVMX_ILK_GBL_BASE(); + + if (!(OCTEON_IS_MODEL(OCTEON_CN68XX))) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + /* set them in ilk tx section */ + ilk_txx_pipe.u64 = csr_rd_node(xi.node, CVMX_ILK_TXX_PIPE(interface)); + ilk_txx_pipe.s.base = pipe_base; + ilk_txx_pipe.s.nump = pipe_len; + csr_wr_node(xi.node, CVMX_ILK_TXX_PIPE(interface), ilk_txx_pipe.u64); + res = 0; + + return res; +} + +/** + * set logical channels for tx + * + * @param interface The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param pch pointer to an array of pipe-channel pair + * @param num_chs the number of entries in the pipe-channel array + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_tx_set_channel(int interface, cvmx_ilk_pipe_chan_t *pch, + unsigned int num_chs) +{ + int res = -1; + cvmx_ilk_txx_idx_pmap_t ilk_txx_idx_pmap; + cvmx_ilk_txx_mem_pmap_t ilk_txx_mem_pmap; + unsigned int i; + + if (!(OCTEON_IS_MODEL(OCTEON_CN68XX))) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (!pch || num_chs > CVMX_ILK_MAX_PIPES) + return res; + + if (cvmx_ilk_use_la_mode(interface, 0)) { + ilk_txx_idx_pmap.u64 = 0; + ilk_txx_mem_pmap.u64 = 0; + for (i = 0; i < num_chs; i++) { + ilk_txx_idx_pmap.s.index = pch->pipe; + ilk_txx_mem_pmap.s.channel = pch->chan; + ilk_txx_mem_pmap.s.remap = 1; + csr_wr(CVMX_ILK_TXX_IDX_PMAP(interface), + ilk_txx_idx_pmap.u64); + csr_wr(CVMX_ILK_TXX_MEM_PMAP(interface), + ilk_txx_mem_pmap.u64); + pch++; + } + } else { + /* write the pair to ilk tx */ + ilk_txx_mem_pmap.u64 = 0; + ilk_txx_idx_pmap.u64 = 0; + for (i = 0; i < num_chs; i++) { + ilk_txx_idx_pmap.s.index = pch->pipe; + ilk_txx_mem_pmap.s.channel = pch->chan; + csr_wr(CVMX_ILK_TXX_IDX_PMAP(interface), + ilk_txx_idx_pmap.u64); + csr_wr(CVMX_ILK_TXX_MEM_PMAP(interface), + ilk_txx_mem_pmap.u64); + pch++; + } + } + res = 0; + + return res; +} + +/** + * set pkind for rx + * + * @param xiface The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param chpknd pointer to an array of channel-pkind pair + * @param num_pknd the number of entries in the channel-pkind array + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_rx_set_pknd(int xiface, cvmx_ilk_chan_pknd_t *chpknd, + unsigned int num_pknd) +{ + int res = -1; + cvmx_ilk_rxf_idx_pmap_t ilk_rxf_idx_pmap; + unsigned int i; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface - CVMX_ILK_GBL_BASE(); + + if (!(OCTEON_IS_MODEL(OCTEON_CN68XX))) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (!chpknd || num_pknd > CVMX_ILK_MAX_PKNDS) + return res; + + res = 0; + + for (i = 0; i < num_pknd; i++) { + ilk_rxf_idx_pmap.u64 = 0; + /* write the pair to ilk rx. note the channels for different + * interfaces are given in *chpknd and interface is not used + * as a param + */ + if (chpknd->chan < 2 && + cvmx_ilk_use_la_mode(interface, chpknd->chan)) { + ilk_rxf_idx_pmap.s.index = + interface * 256 + 128 + chpknd->chan; + csr_wr(CVMX_ILK_RXF_IDX_PMAP, ilk_rxf_idx_pmap.u64); + csr_wr(CVMX_ILK_RXF_MEM_PMAP, chpknd->pknd); + } + ilk_rxf_idx_pmap.s.index = interface * 256 + chpknd->chan; + csr_wr(CVMX_ILK_RXF_IDX_PMAP, ilk_rxf_idx_pmap.u64); + csr_wr(CVMX_ILK_RXF_MEM_PMAP, chpknd->pknd); + chpknd++; + } + + return res; +} + +/** + * configure calendar for rx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_depth the number of calendar entries + * @param pent pointer to calendar entries + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_rx_cal_conf(int intf, int cal_depth, cvmx_ilk_cal_entry_t *pent) +{ + int res = -1, i; + cvmx_ilk_rxx_cfg0_t ilk_rxx_cfg0; + int num_entries; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (cal_depth < CVMX_ILK_RX_MIN_CAL || cal_depth > CVMX_ILK_MAX_CAL || + (OCTEON_IS_MODEL(OCTEON_CN68XX) && !pent)) + return res; + + /* mandatory link-level fc as workarounds for ILK-15397 and + * ILK-15479 + */ + /* TODO: test effectiveness */ + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + /* Update the calendar for each channel */ + if ((cvmx_ilk_use_la_mode(interface, 0) == 0) || + (cvmx_ilk_use_la_mode(interface, 0) && + cvmx_ilk_la_mode_enable_rx_calendar(interface))) { + for (i = 0; i < cal_depth; i++) { + __cvmx_ilk_write_rx_cal_entry( + interface, i, pent[i].pipe_bpid); + } + } + + /* Update the depth */ + ilk_rxx_cfg0.u64 = csr_rd(CVMX_ILK_RXX_CFG0(interface)); + num_entries = 1 + cal_depth + (cal_depth - 1) / 15; + ilk_rxx_cfg0.s.cal_depth = num_entries; + if (cvmx_ilk_use_la_mode(interface, 0)) { + ilk_rxx_cfg0.s.mproto_ign = 1; + ilk_rxx_cfg0.s.lnk_stats_ena = 1; + ilk_rxx_cfg0.s.lnk_stats_wrap = 1; + } + csr_wr(CVMX_ILK_RXX_CFG0(interface), ilk_rxx_cfg0.u64); + } + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + ilk_rxx_cfg0.u64 = + csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + /* + * Make sure cal_ena is 0 for programming the calendar table, + * as per Errata ILK-19398 + */ + ilk_rxx_cfg0.s.cal_ena = 0; + csr_wr_node(node, CVMX_ILK_RXX_CFG0(interface), + ilk_rxx_cfg0.u64); + + for (i = 0; i < cal_depth; i++) + __cvmx_ilk_write_rx_cal_entry(intf, i, 0); + + ilk_rxx_cfg0.u64 = + csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + num_entries = 1 + cal_depth + (cal_depth - 1) / 15; + ilk_rxx_cfg0.s.cal_depth = num_entries; + csr_wr_node(node, CVMX_ILK_RXX_CFG0(interface), + ilk_rxx_cfg0.u64); + } + + return 0; +} + +/** + * set high water mark for rx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param hi_wm high water mark for this interface + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_rx_set_hwm(int intf, int hi_wm) +{ + int res = -1; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (hi_wm <= 0) + return res; + + /* set the hwm */ + ilk_rxx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + ilk_rxx_cfg1.s.rx_fifo_hwm = hi_wm; + csr_wr_node(node, CVMX_ILK_RXX_CFG1(interface), ilk_rxx_cfg1.u64); + res = 0; + + return res; +} + +/** + * enable calendar for rx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_ena enable or disable calendar + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_rx_cal_ena(int intf, unsigned char cal_ena) +{ + int res = -1; + cvmx_ilk_rxx_cfg0_t ilk_rxx_cfg0; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (cvmx_ilk_use_la_mode(interface, 0) && + !cvmx_ilk_la_mode_enable_rx_calendar(interface)) + return 0; + + /* set the enable */ + ilk_rxx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + ilk_rxx_cfg0.s.cal_ena = cal_ena; + csr_wr_node(node, CVMX_ILK_RXX_CFG0(interface), ilk_rxx_cfg0.u64); + csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + res = 0; + + return res; +} + +/** + * set up calendar for rx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_depth the number of calendar entries + * @param pent pointer to calendar entries + * @param hi_wm high water mark for this interface + * @param cal_ena enable or disable calendar + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_cal_setup_rx(int intf, int cal_depth, cvmx_ilk_cal_entry_t *pent, + int hi_wm, unsigned char cal_ena) +{ + int res = -1; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + res = cvmx_ilk_rx_cal_conf(intf, cal_depth, pent); + if (res < 0) + return res; + + res = cvmx_ilk_rx_set_hwm(intf, hi_wm); + if (res < 0) + return res; + + res = cvmx_ilk_rx_cal_ena(intf, cal_ena); + return res; +} + +/** + * configure calendar for tx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_depth the number of calendar entries + * @param pent pointer to calendar entries + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_tx_cal_conf(int intf, int cal_depth, cvmx_ilk_cal_entry_t *pent) +{ + int res = -1, i; + cvmx_ilk_txx_cfg0_t ilk_txx_cfg0; + int num_entries; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + if (cal_depth < CVMX_ILK_TX_MIN_CAL || cal_depth > CVMX_ILK_MAX_CAL || + (OCTEON_IS_MODEL(OCTEON_CN68XX) && !pent)) + return res; + + /* mandatory link-level fc as workarounds for ILK-15397 and + * ILK-15479 + */ + /* TODO: test effectiveness */ + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + /* Update the calendar for each channel */ + for (i = 0; i < cal_depth; i++) { + __cvmx_ilk_write_tx_cal_entry(interface, i, + pent[i].pipe_bpid); + } + + /* Set the depth (must be multiple of 8)*/ + ilk_txx_cfg0.u64 = csr_rd(CVMX_ILK_TXX_CFG0(interface)); + num_entries = 1 + cal_depth + (cal_depth - 1) / 15; + ilk_txx_cfg0.s.cal_depth = (num_entries + 7) & ~7; + csr_wr(CVMX_ILK_TXX_CFG0(interface), ilk_txx_cfg0.u64); + } + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + ilk_txx_cfg0.u64 = + csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + /* + * Make sure cal_ena is 0 for programming the calendar table, + * as per Errata ILK-19398 + */ + ilk_txx_cfg0.s.cal_ena = 0; + csr_wr_node(node, CVMX_ILK_TXX_CFG0(interface), + ilk_txx_cfg0.u64); + + for (i = 0; i < cal_depth; i++) + __cvmx_ilk_write_tx_cal_entry(intf, i, 0); + + ilk_txx_cfg0.u64 = + csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + num_entries = 1 + cal_depth + (cal_depth - 1) / 15; + /* cal_depth[2:0] needs to be zero, round up */ + ilk_txx_cfg0.s.cal_depth = (num_entries + 7) & 0x1f8; + csr_wr_node(node, CVMX_ILK_TXX_CFG0(interface), + ilk_txx_cfg0.u64); + } + + return 0; +} + +/** + * enable calendar for tx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_ena enable or disable calendar + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_tx_cal_ena(int intf, unsigned char cal_ena) +{ + int res = -1; + cvmx_ilk_txx_cfg0_t ilk_txx_cfg0; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + /* set the enable */ + ilk_txx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + ilk_txx_cfg0.s.cal_ena = cal_ena; + csr_wr_node(node, CVMX_ILK_TXX_CFG0(interface), ilk_txx_cfg0.u64); + csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + res = 0; + + return res; +} + +/** + * set up calendar for tx + * + * @param intf The identifier of the packet interface to configure and + * use as a ILK interface. cn68xx has 2 interfaces: ilk0 and + * ilk1. + * + * @param cal_depth the number of calendar entries + * @param pent pointer to calendar entries + * @param cal_ena enable or disable calendar + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_cal_setup_tx(int intf, int cal_depth, cvmx_ilk_cal_entry_t *pent, + unsigned char cal_ena) +{ + int res = -1; + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + res = cvmx_ilk_tx_cal_conf(intf, cal_depth, pent); + if (res < 0) + return res; + + res = cvmx_ilk_tx_cal_ena(intf, cal_ena); + return res; +} + +/* #define CVMX_ILK_STATS_ENA 1 */ +#ifdef CVMX_ILK_STATS_ENA +static void cvmx_ilk_reg_dump_rx(int intf) +{ + int i; + cvmx_ilk_rxx_cfg0_t ilk_rxx_cfg0; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; + cvmx_ilk_rxx_int_t ilk_rxx_int; + cvmx_ilk_rxx_jabber_t ilk_rxx_jabber; + cvmx_ilk_rx_lnex_cfg_t ilk_rx_lnex_cfg; + cvmx_ilk_rx_lnex_int_t ilk_rx_lnex_int; + cvmx_ilk_gbl_cfg_t ilk_gbl_cfg; + cvmx_ilk_ser_cfg_t ilk_ser_cfg; + cvmx_ilk_rxf_idx_pmap_t ilk_rxf_idx_pmap; + cvmx_ilk_rxf_mem_pmap_t ilk_rxf_mem_pmap; + cvmx_ilk_rxx_idx_cal_t ilk_rxx_idx_cal; + cvmx_ilk_rxx_mem_cal0_t ilk_rxx_mem_cal0; + cvmx_ilk_rxx_mem_cal1_t ilk_rxx_mem_cal1; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + ilk_rxx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + debug("ilk rxx cfg0: 0x%16lx\n", ilk_rxx_cfg0.u64); + + ilk_rxx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + debug("ilk rxx cfg1: 0x%16lx\n", ilk_rxx_cfg1.u64); + + ilk_rxx_int.u64 = csr_rd_node(node, CVMX_ILK_RXX_INT(interface)); + debug("ilk rxx int: 0x%16lx\n", ilk_rxx_int.u64); + csr_wr_node(node, CVMX_ILK_RXX_INT(interface), ilk_rxx_int.u64); + + ilk_rxx_jabber.u64 = csr_rd_node(node, CVMX_ILK_RXX_JABBER(interface)); + debug("ilk rxx jabber: 0x%16lx\n", ilk_rxx_jabber.u64); + +#define LNE_NUM_DBG 4 + for (i = 0; i < LNE_NUM_DBG; i++) { + ilk_rx_lnex_cfg.u64 = + csr_rd_node(node, CVMX_ILK_RX_LNEX_CFG(i)); + debug("ilk rx lnex cfg lane: %d 0x%16lx\n", i, + ilk_rx_lnex_cfg.u64); + } + + for (i = 0; i < LNE_NUM_DBG; i++) { + ilk_rx_lnex_int.u64 = + csr_rd_node(node, CVMX_ILK_RX_LNEX_INT(i)); + debug("ilk rx lnex int lane: %d 0x%16lx\n", i, + ilk_rx_lnex_int.u64); + csr_wr_node(node, CVMX_ILK_RX_LNEX_INT(i), ilk_rx_lnex_int.u64); + } + + ilk_gbl_cfg.u64 = csr_rd_node(node, CVMX_ILK_GBL_CFG); + debug("ilk gbl cfg: 0x%16lx\n", ilk_gbl_cfg.u64); + + ilk_ser_cfg.u64 = csr_rd_node(node, CVMX_ILK_SER_CFG); + debug("ilk ser cfg: 0x%16lx\n", ilk_ser_cfg.u64); + +#define CHAN_NUM_DBG 8 + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_rxf_idx_pmap.u64 = 0; + ilk_rxf_idx_pmap.s.index = interface * 256; + ilk_rxf_idx_pmap.s.inc = 1; + csr_wr(CVMX_ILK_RXF_IDX_PMAP, ilk_rxf_idx_pmap.u64); + for (i = 0; i < CHAN_NUM_DBG; i++) { + ilk_rxf_mem_pmap.u64 = csr_rd(CVMX_ILK_RXF_MEM_PMAP); + debug("ilk rxf mem pmap chan: %3d 0x%16lx\n", i, + ilk_rxf_mem_pmap.u64); + } + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + cvmx_ilk_rxx_chax_t rxx_chax; + + for (i = 0; i < CHAN_NUM_DBG; i++) { + rxx_chax.u64 = csr_rd_node( + node, CVMX_ILK_RXX_CHAX(i, interface)); + debug("ilk chan: %d pki chan: 0x%x\n", i, + rxx_chax.s.port_kind); + } + } + +#define CAL_NUM_DBG 2 + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_rxx_idx_cal.u64 = 0; + ilk_rxx_idx_cal.s.inc = 1; + csr_wr(CVMX_ILK_RXX_IDX_CAL(interface), ilk_rxx_idx_cal.u64); + for (i = 0; i < CAL_NUM_DBG; i++) { + ilk_rxx_idx_cal.u64 = + csr_rd(CVMX_ILK_RXX_IDX_CAL(interface)); + debug("ilk rxx idx cal: 0x%16lx\n", + ilk_rxx_idx_cal.u64); + + ilk_rxx_mem_cal0.u64 = + csr_rd(CVMX_ILK_RXX_MEM_CAL0(interface)); + debug("ilk rxx mem cal0: 0x%16lx\n", + ilk_rxx_mem_cal0.u64); + ilk_rxx_mem_cal1.u64 = + csr_rd(CVMX_ILK_RXX_MEM_CAL1(interface)); + debug("ilk rxx mem cal1: 0x%16lx\n", + ilk_rxx_mem_cal1.u64); + } + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + cvmx_ilk_rxx_cal_entryx_t rxx_cal_entryx; + + for (i = 0; i < CAL_NUM_DBG; i++) { + rxx_cal_entryx.u64 = csr_rd_node( + node, CVMX_ILK_RXX_CAL_ENTRYX(i, interface)); + debug("ilk rxx cal idx: %d\n", i); + debug("ilk rxx cal ctl: 0x%x\n", rxx_cal_entryx.s.ctl); + debug("ilk rxx cal pko chan: 0x%x\n", + rxx_cal_entryx.s.channel); + } + } +} + +static void cvmx_ilk_reg_dump_tx(int intf) +{ + int i; + cvmx_ilk_txx_cfg0_t ilk_txx_cfg0; + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + cvmx_ilk_txx_idx_pmap_t ilk_txx_idx_pmap; + cvmx_ilk_txx_mem_pmap_t ilk_txx_mem_pmap; + cvmx_ilk_txx_int_t ilk_txx_int; + cvmx_ilk_txx_pipe_t ilk_txx_pipe; + cvmx_ilk_txx_idx_cal_t ilk_txx_idx_cal; + cvmx_ilk_txx_mem_cal0_t ilk_txx_mem_cal0; + cvmx_ilk_txx_mem_cal1_t ilk_txx_mem_cal1; + int node = (intf >> 4) & 0xf; + int interface = intf & 0xf; + + ilk_txx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + debug("ilk txx cfg0: 0x%16lx\n", ilk_txx_cfg0.u64); + + ilk_txx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + debug("ilk txx cfg1: 0x%16lx\n", ilk_txx_cfg1.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_txx_pipe.u64 = csr_rd(CVMX_ILK_TXX_PIPE(interface)); + debug("ilk txx pipe: 0x%16lx\n", ilk_txx_pipe.u64); + + ilk_txx_idx_pmap.u64 = 0; + ilk_txx_idx_pmap.s.index = ilk_txx_pipe.s.base; + ilk_txx_idx_pmap.s.inc = 1; + csr_wr(CVMX_ILK_TXX_IDX_PMAP(interface), ilk_txx_idx_pmap.u64); + for (i = 0; i < CHAN_NUM_DBG; i++) { + ilk_txx_mem_pmap.u64 = + csr_rd(CVMX_ILK_TXX_MEM_PMAP(interface)); + debug("ilk txx mem pmap pipe: %3d 0x%16lx\n", + ilk_txx_pipe.s.base + i, ilk_txx_mem_pmap.u64); + } + } + + ilk_txx_int.u64 = csr_rd_node(node, CVMX_ILK_TXX_INT(interface)); + debug("ilk txx int: 0x%16lx\n", ilk_txx_int.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_txx_idx_cal.u64 = 0; + ilk_txx_idx_cal.s.inc = 1; + csr_wr(CVMX_ILK_TXX_IDX_CAL(interface), ilk_txx_idx_cal.u64); + for (i = 0; i < CAL_NUM_DBG; i++) { + ilk_txx_idx_cal.u64 = + csr_rd(CVMX_ILK_TXX_IDX_CAL(interface)); + debug("ilk txx idx cal: 0x%16lx\n", + ilk_txx_idx_cal.u64); + + ilk_txx_mem_cal0.u64 = + csr_rd(CVMX_ILK_TXX_MEM_CAL0(interface)); + debug("ilk txx mem cal0: 0x%16lx\n", + ilk_txx_mem_cal0.u64); + ilk_txx_mem_cal1.u64 = + csr_rd(CVMX_ILK_TXX_MEM_CAL1(interface)); + debug("ilk txx mem cal1: 0x%16lx\n", + ilk_txx_mem_cal1.u64); + } + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + cvmx_ilk_txx_cal_entryx_t txx_cal_entryx; + + for (i = 0; i < CAL_NUM_DBG; i++) { + txx_cal_entryx.u64 = csr_rd_node( + node, CVMX_ILK_TXX_CAL_ENTRYX(i, interface)); + debug("ilk txx cal idx: %d\n", i); + debug("ilk txx cal ctl: 0x%x\n", txx_cal_entryx.s.ctl); + debug("ilk txx cal pki chan: 0x%x\n", + txx_cal_entryx.s.channel); + } + } +} +#endif + +/** + * show run time status + * + * @param interface The identifier of the packet interface to enable. cn68xx + * has 2 interfaces: ilk0 and ilk1. + * + * @return nothing + */ +#ifdef CVMX_ILK_RUNTIME_DBG +void cvmx_ilk_runtime_status(int interface) +{ + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + cvmx_ilk_txx_flow_ctl0_t ilk_txx_flow_ctl0; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; + cvmx_ilk_rxx_int_t ilk_rxx_int; + cvmx_ilk_rxx_flow_ctl0_t ilk_rxx_flow_ctl0; + cvmx_ilk_rxx_flow_ctl1_t ilk_rxx_flow_ctl1; + cvmx_ilk_gbl_int_t ilk_gbl_int; + + debug("\nilk run-time status: interface: %d\n", interface); + + ilk_txx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + debug("\nilk txx cfg1: 0x%16lx\n", ilk_txx_cfg1.u64); + if (ilk_txx_cfg1.s.rx_link_fc) + debug("link flow control received\n"); + if (ilk_txx_cfg1.s.tx_link_fc) + debug("link flow control sent\n"); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_txx_flow_ctl0.u64 = + csr_rd(CVMX_ILK_TXX_FLOW_CTL0(interface)); + debug("\nilk txx flow ctl0: 0x%16lx\n", ilk_txx_flow_ctl0.u64); + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + int i; + cvmx_ilk_txx_cha_xonx_t txx_cha_xonx; + + for (i = 0; i < 4; i++) { + txx_cha_xonx.u64 = csr_rd_node( + node, CVMX_ILK_TXX_CHA_XONX(i, interface)); + debug("\nilk txx cha xon: 0x%16lx\n", txx_cha_xonx.u64); + } + } + + ilk_rxx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + debug("\nilk rxx cfg1: 0x%16lx\n", ilk_rxx_cfg1.u64); + debug("rx fifo count: %d\n", ilk_rxx_cfg1.s.rx_fifo_cnt); + + ilk_rxx_int.u64 = csr_rd_node(node, CVMX_ILK_RXX_INT(interface)); + debug("\nilk rxx int: 0x%16lx\n", ilk_rxx_int.u64); + if (ilk_rxx_int.s.pkt_drop_rxf) + debug("rx fifo packet drop\n"); + if (ilk_rxx_int.u64) + csr_wr_node(node, CVMX_ILK_RXX_INT(interface), ilk_rxx_int.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + ilk_rxx_flow_ctl0.u64 = + csr_rd(CVMX_ILK_RXX_FLOW_CTL0(interface)); + debug("\nilk rxx flow ctl0: 0x%16lx\n", ilk_rxx_flow_ctl0.u64); + + ilk_rxx_flow_ctl1.u64 = + csr_rd(CVMX_ILK_RXX_FLOW_CTL1(interface)); + debug("\nilk rxx flow ctl1: 0x%16lx\n", ilk_rxx_flow_ctl1.u64); + } + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + int i; + cvmx_ilk_rxx_cha_xonx_t rxx_cha_xonx; + + for (i = 0; i < 4; i++) { + rxx_cha_xonx.u64 = csr_rd_node( + node, CVMX_ILK_RXX_CHA_XONX(i, interface)); + debug("\nilk rxx cha xon: 0x%16lx\n", rxx_cha_xonx.u64); + } + } + + ilk_gbl_int.u64 = csr_rd_node(node, CVMX_ILK_GBL_INT); + debug("\nilk gbl int: 0x%16lx\n", ilk_gbl_int.u64); + if (ilk_gbl_int.s.rxf_push_full) + debug("rx fifo overflow\n"); + if (ilk_gbl_int.u64) + csr_wr_node(node, CVMX_ILK_GBL_INT, ilk_gbl_int.u64); +} +#endif + +/** + * enable interface + * + * @param xiface The identifier of the packet interface to enable. cn68xx + * has 2 interfaces: ilk0 and ilk1. + * + * @return Zero on success, negative on failure. + */ +int cvmx_ilk_enable(int xiface) +{ + int res = -1; + int retry_count = 0; + cvmx_helper_link_info_t result; + cvmx_ilk_txx_cfg1_t ilk_txx_cfg1; + cvmx_ilk_rxx_cfg1_t ilk_rxx_cfg1; +#ifdef CVMX_ILK_STATS_ENA + cvmx_ilk_rxx_cfg0_t ilk_rxx_cfg0; + cvmx_ilk_txx_cfg0_t ilk_txx_cfg0; +#endif + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int node = xi.node; + int interface = xi.interface - CVMX_ILK_GBL_BASE(); + + if (!octeon_has_feature(OCTEON_FEATURE_ILK)) + return res; + + if (interface >= CVMX_NUM_ILK_INTF) + return res; + + result.u64 = 0; + +#ifdef CVMX_ILK_STATS_ENA + debug("\n"); + debug("<<<< ILK%d: Before enabling ilk\n", interface); + cvmx_ilk_reg_dump_rx(intf); + cvmx_ilk_reg_dump_tx(intf); +#endif + + /* RX packet will be enabled only if link is up */ + + /* TX side */ + ilk_txx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + ilk_txx_cfg1.s.pkt_ena = 1; + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + if (cvmx_ilk_use_la_mode(interface, 0)) { + ilk_txx_cfg1.s.la_mode = 1; + ilk_txx_cfg1.s.tx_link_fc_jam = 1; + } + } + csr_wr_node(node, CVMX_ILK_TXX_CFG1(interface), ilk_txx_cfg1.u64); + csr_rd_node(node, CVMX_ILK_TXX_CFG1(interface)); + +#ifdef CVMX_ILK_STATS_ENA + /* RX side stats */ + ilk_rxx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG0(interface)); + ilk_rxx_cfg0.s.lnk_stats_ena = 1; + csr_wr_node(node, CVMX_ILK_RXX_CFG0(interface), ilk_rxx_cfg0.u64); + + /* TX side stats */ + ilk_txx_cfg0.u64 = csr_rd_node(node, CVMX_ILK_TXX_CFG0(interface)); + ilk_txx_cfg0.s.lnk_stats_ena = 1; + csr_wr_node(node, CVMX_ILK_TXX_CFG0(interface), ilk_txx_cfg0.u64); +#endif + +retry: + retry_count++; + if (retry_count > 10) + goto out; + + /* Make sure the link is up, so that packets can be sent. */ + result = __cvmx_helper_ilk_link_get( + cvmx_helper_get_ipd_port((interface + CVMX_ILK_GBL_BASE()), 0)); + + /* Small delay before another retry. */ + udelay(100); + + ilk_rxx_cfg1.u64 = csr_rd_node(node, CVMX_ILK_RXX_CFG1(interface)); + if (ilk_rxx_cfg1.s.pkt_ena == 0) + goto retry; + +out: + +#ifdef CVMX_ILK_STATS_ENA + debug(">>>> ILK%d: After ILK is enabled\n", interface); + cvmx_ilk_reg_dump_rx(intf); + cvmx_ilk_reg_dump_tx(intf); +#endif + + if (result.s.link_up) + return 0; + + return -1; +} + +/** + * Provide interface enable status + * + * @param xiface The identifier of the packet xiface to disable. cn68xx + * has 2 interfaces: ilk0 and ilk1. + * + * @return Zero, not enabled; One, enabled. + */ +int cvmx_ilk_get_intf_ena(int xiface) +{ + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + int interface = xi.interface - CVMX_ILK_GBL_BASE(); + return cvmx_ilk_intf_cfg[xi.node][interface].intf_en; +}
Import cvmx-pki-resources.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pki-resources.c | 285 +++++++++++++++++++++ 1 file changed, 285 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pki-resources.c
diff --git a/arch/mips/mach-octeon/cvmx-pki-resources.c b/arch/mips/mach-octeon/cvmx-pki-resources.c new file mode 100644 index 000000000000..ab8417216241 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pki-resources.c @@ -0,0 +1,285 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * PKI Support. + */ + +#include <time.h> +#include <log.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> + +#include <mach/cvmx-pki.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +static s32 cvmx_pki_style_refcnt[CVMX_MAX_NODES][CVMX_PKI_NUM_INTERNAL_STYLE]; + +/** + * This function allocates/reserves a style from pool of global styles per node. + * @param node node to allocate style from. + * @param style style to allocate, if -1 it will be allocated + * first available style from style resource. If index is positive + * number and in range, it will try to allocate specified style. + * @return style number on success, + * -1 on alloc failure. + * -2 on resource already reserved. + */ +int cvmx_pki_style_alloc(int node, int style) +{ + int rs; + + if (cvmx_create_global_resource_range(CVMX_GR_TAG_STYLE(node), + CVMX_PKI_NUM_INTERNAL_STYLE)) { + printf("ERROR: Failed to create styles global resource\n"); + return -1; + } + if (style >= 0) { + /* Reserving specific style, use refcnt for sharing */ + rs = cvmx_atomic_fetch_and_add32( + &cvmx_pki_style_refcnt[node][style], 1); + if (rs > 0) + return CVMX_RESOURCE_ALREADY_RESERVED; + + rs = cvmx_reserve_global_resource_range(CVMX_GR_TAG_STYLE(node), + style, style, 1); + if (rs == -1) { + /* This means the style is taken by another app */ + printf("ERROR: style %d is reserved by another app\n", + style); + cvmx_atomic_fetch_and_add32( + &cvmx_pki_style_refcnt[node][style], -1); + return CVMX_RESOURCE_ALLOC_FAILED; + } + } else { + /* Allocate first available style */ + rs = cvmx_allocate_global_resource_range( + CVMX_GR_TAG_STYLE(node), style, 1, 1); + if (rs < 0) { + printf("ERROR: Failed to allocate style, none available\n"); + return CVMX_RESOURCE_ALLOC_FAILED; + } + style = rs; + /* Increment refcnt for newly created style */ + cvmx_atomic_fetch_and_add32(&cvmx_pki_style_refcnt[node][style], + 1); + } + return style; +} + +/** + * This function frees a style from pool of global styles per node. + * @param node node to free style from. + * @param style style to free + * @return 0 on success, -1 on failure or + * if the style is shared a positive count of remaining users for this style. + */ +int cvmx_pki_style_free(int node, int style) +{ + int rs; + + rs = cvmx_atomic_fetch_and_add32(&cvmx_pki_style_refcnt[node][style], + -1); + if (rs > 1) + return rs - 1; + + if (cvmx_free_global_resource_range_with_base(CVMX_GR_TAG_STYLE(node), + style, 1) == -1) { + printf("ERROR Failed to release style %d\n", (int)style); + return -1; + } + return 0; +} + +/** + * This function allocates/reserves a cluster group from per node + cluster group resources. + * @param node node to allocate cluster group from. + @param cl_grp cluster group to allocate/reserve, if -1 , + * allocate any available cluster group. + * @return cluster group number + * -1 on alloc failure. + * -2 on resource already reserved. + */ +int cvmx_pki_cluster_grp_alloc(int node, int cl_grp) +{ + int rs; + + if (node >= CVMX_MAX_NODES) { + printf("ERROR: Invalid node number %d\n", node); + return -1; + } + if (cvmx_create_global_resource_range(CVMX_GR_TAG_CLUSTER_GRP(node), + CVMX_PKI_NUM_CLUSTER_GROUP)) { + printf("ERROR: Failed to create Cluster group global resource\n"); + return -1; + } + if (cl_grp >= 0) { + rs = cvmx_reserve_global_resource_range( + CVMX_GR_TAG_CLUSTER_GRP(node), 0, cl_grp, 1); + if (rs == -1) { + debug("INFO: cl_grp %d is already reserved\n", + (int)cl_grp); + return CVMX_RESOURCE_ALREADY_RESERVED; + } + } else { + rs = cvmx_allocate_global_resource_range( + CVMX_GR_TAG_CLUSTER_GRP(node), 0, 1, 1); + if (rs == -1) { + debug("Warning: Failed to alloc cluster grp\n"); + return CVMX_RESOURCE_ALLOC_FAILED; + } + } + cl_grp = rs; + return cl_grp; +} + +/** + * This function allocates/reserves a pcam entry from node + * @param node node to allocate pcam entry from. + * @param index index of pacm entry (0-191), if -1 , + * allocate any available pcam entry. + * @param bank pcam bank where to allocate/reserve pcan entry from + * @param cluster_mask mask of clusters from which pcam entry is needed. + * @return pcam entry of -1 on failure + */ +int cvmx_pki_pcam_entry_alloc(int node, int index, int bank, u64 cluster_mask) +{ + int rs = 0; + unsigned int cluster; + + for (cluster = 0; cluster < CVMX_PKI_NUM_CLUSTER; cluster++) { + if ((cluster_mask & (1 << cluster)) == 0) + continue; + rs = cvmx_create_global_resource_range( + CVMX_GR_TAG_PCAM(node, cluster, bank), + CVMX_PKI_TOTAL_PCAM_ENTRY); + if (rs != 0) { + printf("ERROR: Failed to create pki pcam global resource\n"); + return -1; + } + if (index >= 0) + rs = cvmx_reserve_global_resource_range( + CVMX_GR_TAG_PCAM(node, cluster, bank), cluster, + index, 1); + else + rs = cvmx_allocate_global_resource_range( + CVMX_GR_TAG_PCAM(node, cluster, bank), cluster, + 1, 1); + if (rs == -1) { + printf("ERROR: PCAM :index %d not available in cluster %d bank %d", + (int)index, (int)cluster, bank); + return -1; + } + } /* for cluster */ + index = rs; + /* implement cluster handle for pass2, for now assume + all clusters will have same base index*/ + return index; +} + +/** + * This function allocates/reserves QPG table entries per node. + * @param node node number. + * @param base_offset base_offset in qpg table. If -1, first available + * qpg base_offset will be allocated. If base_offset is positive + * number and in range, it will try to allocate specified base_offset. + * @param count number of consecutive qpg entries to allocate. They will be consecutive + * from base offset. + * @return qpg table base offset number on success + * -1 on alloc failure. + * -2 on resource already reserved. + */ +int cvmx_pki_qpg_entry_alloc(int node, int base_offset, int count) +{ + int rs; + + if (cvmx_create_global_resource_range(CVMX_GR_TAG_QPG_ENTRY(node), + CVMX_PKI_NUM_QPG_ENTRY)) { + printf("ERROR: Failed to create qpg_entry global resource\n"); + return -1; + } + if (base_offset >= 0) { + rs = cvmx_reserve_global_resource_range( + CVMX_GR_TAG_QPG_ENTRY(node), base_offset, base_offset, + count); + if (rs == -1) { + debug("INFO: qpg entry %d is already reserved\n", + (int)base_offset); + return CVMX_RESOURCE_ALREADY_RESERVED; + } + } else { + rs = cvmx_allocate_global_resource_range( + CVMX_GR_TAG_QPG_ENTRY(node), base_offset, count, 1); + if (rs == -1) { + printf("ERROR: Failed to allocate qpg entry\n"); + return CVMX_RESOURCE_ALLOC_FAILED; + } + } + base_offset = rs; + return base_offset; +} + +/** + * This function frees QPG table entries per node. + * @param node node number. + * @param base_offset base_offset in qpg table. If -1, first available + * qpg base_offset will be allocated. If base_offset is positive + * number and in range, it will try to allocate specified base_offset. + * @param count number of consecutive qpg entries to allocate. They will be consecutive + * from base offset. + * @return qpg table base offset number on success, -1 on failure. + */ +int cvmx_pki_qpg_entry_free(int node, int base_offset, int count) +{ + if (cvmx_free_global_resource_range_with_base( + CVMX_GR_TAG_QPG_ENTRY(node), base_offset, count) == -1) { + printf("ERROR Failed to release qpg offset %d", + (int)base_offset); + return -1; + } + return 0; +} + +int cvmx_pki_mtag_idx_alloc(int node, int idx) +{ + if (cvmx_create_global_resource_range(CVMX_GR_TAG_MTAG_IDX(node), + CVMX_PKI_NUM_MTAG_IDX)) { + printf("ERROR: Failed to create MTAG-IDX global resource\n"); + return -1; + } + if (idx >= 0) { + idx = cvmx_reserve_global_resource_range( + CVMX_GR_TAG_MTAG_IDX(node), idx, idx, 1); + if (idx == -1) { + debug("INFO: MTAG index %d is already reserved\n", + (int)idx); + return CVMX_RESOURCE_ALREADY_RESERVED; + } + } else { + idx = cvmx_allocate_global_resource_range( + CVMX_GR_TAG_MTAG_IDX(node), idx, 1, 1); + if (idx == -1) { + printf("ERROR: Failed to allocate MTAG index\n"); + return CVMX_RESOURCE_ALLOC_FAILED; + } + } + return idx; +}
Import cvmx-pko.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pko.c | 788 +++++++++++++++++++++++++++++++ 1 file changed, 788 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pko.c
diff --git a/arch/mips/mach-octeon/cvmx-pko.c b/arch/mips/mach-octeon/cvmx-pko.c new file mode 100644 index 000000000000..8a9181362bda --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pko.c @@ -0,0 +1,788 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * Support library for the hardware Packet Output unit. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-iob-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> +#include <mach/cvmx-helper-pko.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define CVMX_PKO_NQ_PER_PORT_MAX 32 + +static cvmx_pko_return_value_t cvmx_pko2_config_port(short ipd_port, + int base_queue, + int num_queues, + const u8 priority[]); + +static const int debug; + +/** + * Internal state of packet output + */ + +/* + * PKO port iterator + * XXX this macro only works for 68XX + */ + +#define pko_for_each_port(__p) \ + for (__p = 0; __p < CVMX_HELPER_CFG_MAX_PKO_PORT; __p++) \ + if (__cvmx_helper_cfg_pko_queue_base(__p) != \ + CVMX_HELPER_CFG_INVALID_VALUE) + +/* + * @INTERNAL + * + * Get INT for a port + * + * @param interface + * @param index + * @return the INT value on success and -1 on error + * + * This function is only for CN68XX. + */ +static int __cvmx_pko_int(int interface, int index) +{ + cvmx_helper_cfg_assert(interface < CVMX_HELPER_MAX_IFACE); + cvmx_helper_cfg_assert(index >= 0); + + switch (interface) { + case 0: + cvmx_helper_cfg_assert(index < 4); + return index; + case 1: + cvmx_helper_cfg_assert(index == 0); + return 4; + case 2: + cvmx_helper_cfg_assert(index < 4); + return index + 8; + case 3: + cvmx_helper_cfg_assert(index < 4); + return index + 0xC; + case 4: + cvmx_helper_cfg_assert(index < 4); + return index + 0x10; + case 5: + cvmx_helper_cfg_assert(index < 256); + return 0x1C; + case 6: + cvmx_helper_cfg_assert(index < 256); + return 0x1D; + case 7: + cvmx_helper_cfg_assert(index < 32); + return 0x1E; + case 8: + cvmx_helper_cfg_assert(index < 8); + return 0x1F; + } + + return -1; +} + +int cvmx_pko_get_base_pko_port(int interface, int index) +{ + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) + return cvmx_helper_get_ipd_port(interface, index); + else if (octeon_has_feature(OCTEON_FEATURE_PKND)) + return __cvmx_helper_cfg_pko_port_base(interface, index); + else + return cvmx_helper_get_ipd_port(interface, index); +} + +int cvmx_pko_get_base_queue(int port) +{ + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_get_queue_base(port); + } else if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + return __cvmx_helper_cfg_pko_queue_base( + cvmx_helper_cfg_ipd2pko_port_base(port)); + } else { + if (port < 48) + return cvmx_pko_queue_table[port].ccppp_queue_base; + else + return CVMX_PKO_ILLEGAL_QUEUE; + } +} + +int cvmx_pko_get_num_queues(int port) +{ + if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + return cvmx_pko3_get_queue_num(port); + } else if (octeon_has_feature(OCTEON_FEATURE_PKND)) { + return __cvmx_helper_cfg_pko_queue_num( + cvmx_helper_cfg_ipd2pko_port_base(port)); + } else { + if (port < 48) + return cvmx_pko_queue_table[port].ccppp_num_queues; + } + return 0; +} + +/* + * Allocate memory for PKO engines. + * + * @param engine is the PKO engine ID. + * @return # of 2KB-chunks allocated to this PKO engine. + */ +static int __cvmx_pko_memory_per_engine_o68(int engine) +{ + /* CN68XX has 40KB to devide between the engines in 2KB chunks */ + int max_engine; + int size_per_engine; + int size; + + max_engine = __cvmx_helper_cfg_pko_max_engine(); + size_per_engine = 40 / 2 / max_engine; + + if (engine >= max_engine) + /* Unused engines get no space */ + size = 0; + else if (engine == max_engine - 1) + /* + * The last engine gets all the space lost by rounding. This means + * the ILK gets the most space + */ + size = 40 / 2 - engine * size_per_engine; + else + /* All other engines get the same space */ + size = size_per_engine; + + return size; +} + +/* + * Setup one-to-one mapping between PKO2 iport and eport. + * @INTERNAL + */ +static void __cvmx_pko2_chip_init(void) +{ + int i; + int interface, index, port; + cvmx_helper_interface_mode_t mode; + union cvmx_pko_mem_iport_ptrs config; + + /* + * Initialize every iport with the invalid eid. + */ +#define CVMX_O68_PKO2_INVALID_EID 31 + config.u64 = 0; + config.s.eid = CVMX_O68_PKO2_INVALID_EID; + for (i = 0; i < CVMX_HELPER_CFG_MAX_PKO_PORT; i++) { + config.s.ipid = i; + csr_wr(CVMX_PKO_MEM_IPORT_PTRS, config.u64); + } + + /* + * Set up PKO_MEM_IPORT_PTRS + */ + pko_for_each_port(port) { + interface = __cvmx_helper_cfg_pko_port_interface(port); + index = __cvmx_helper_cfg_pko_port_index(port); + mode = cvmx_helper_interface_get_mode(interface); + + if (mode == CVMX_HELPER_INTERFACE_MODE_DISABLED) + continue; + + config.s.ipid = port; + config.s.qos_mask = 0xff; + config.s.crc = __cvmx_helper_get_has_fcs(interface); + config.s.min_pkt = __cvmx_helper_get_pko_padding(interface); + config.s.intr = __cvmx_pko_int(interface, index); + config.s.eid = __cvmx_helper_cfg_pko_port_eid(port); + config.s.pipe = (mode == CVMX_HELPER_INTERFACE_MODE_LOOP) ? + index : + port; + csr_wr(CVMX_PKO_MEM_IPORT_PTRS, config.u64); + } +} + +int __cvmx_pko_get_pipe(int interface, int index) +{ + /* The loopback ports do not have pipes */ + if (cvmx_helper_interface_get_mode(interface) == + CVMX_HELPER_INTERFACE_MODE_LOOP) + return -1; + /* We use pko_port as the pipe. See __cvmx_pko_port_map_o68(). */ + return cvmx_helper_get_pko_port(interface, index); +} + +static void __cvmx_pko1_chip_init(void) +{ + int queue; + union cvmx_pko_mem_queue_ptrs config; + union cvmx_pko_reg_queue_ptrs1 config1; + const int port = CVMX_PKO_MEM_QUEUE_PTRS_ILLEGAL_PID; + + /* Initialize all queues to connect to port 63 (ILLEGAL_PID) */ + for (queue = 0; queue < CVMX_PKO_MAX_OUTPUT_QUEUES; queue++) { + config1.u64 = 0; + config1.s.idx3 = 0; + config1.s.qid7 = queue >> 7; + + config.u64 = 0; + config.s.tail = 1; + config.s.index = 0; + config.s.port = port; + config.s.queue = queue; + config.s.buf_ptr = 0; + + csr_wr(CVMX_PKO_REG_QUEUE_PTRS1, config1.u64); + csr_wr(CVMX_PKO_MEM_QUEUE_PTRS, config.u64); + } +} + +/** + * Call before any other calls to initialize the packet + * output system. This does chip global config, and should only be + * done by one core. + */ +void cvmx_pko_hw_init(u8 pool, unsigned int bufsize) +{ + union cvmx_pko_reg_cmd_buf config; + union cvmx_iob_fau_timeout fau_to; + int i; + + if (debug) + debug("%s: pool=%u bufsz=%u\n", __func__, pool, bufsize); + + /* chip-specific setup. */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + __cvmx_pko2_chip_init(); + else + __cvmx_pko1_chip_init(); + + /* + * Set the size of the PKO command buffers to an odd number of + * 64bit words. This allows the normal two word send to stay + * aligned and never span a command word buffer. + */ + config.u64 = 0; + config.s.pool = pool; + config.s.size = bufsize / 8 - 1; + csr_wr(CVMX_PKO_REG_CMD_BUF, config.u64); + + /* + * Disable tagwait FAU timeout. This needs to be done before + * anyone might start packet output using tags. + */ + fau_to.u64 = 0; + fau_to.s.tout_val = 0xfff; + fau_to.s.tout_enb = 0; + csr_wr(CVMX_IOB_FAU_TIMEOUT, fau_to.u64); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + union cvmx_pko_reg_min_pkt min_pkt; + + min_pkt.u64 = 0; + min_pkt.s.size1 = 59; + min_pkt.s.size2 = 59; + min_pkt.s.size3 = 59; + min_pkt.s.size4 = 59; + min_pkt.s.size5 = 59; + min_pkt.s.size6 = 59; + min_pkt.s.size7 = 59; + csr_wr(CVMX_PKO_REG_MIN_PKT, min_pkt.u64); + } + + /* + * If we aren't using all of the queues optimize PKO's + * internal memory. + */ + if (OCTEON_IS_OCTEON2() || OCTEON_IS_MODEL(OCTEON_CN70XX)) { + int max_queues = __cvmx_helper_cfg_pko_max_queue(); + + if (OCTEON_IS_MODEL(OCTEON_CN68XX) && max_queues <= 32) + csr_wr(CVMX_PKO_REG_QUEUE_MODE, 3); + else if (max_queues <= 64) + csr_wr(CVMX_PKO_REG_QUEUE_MODE, 2); + else if (max_queues <= 128) + csr_wr(CVMX_PKO_REG_QUEUE_MODE, 1); + else + csr_wr(CVMX_PKO_REG_QUEUE_MODE, 0); + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) { + for (i = 0; i < 2; i++) { + union cvmx_pko_reg_engine_storagex + engine_storage; + +#define PKO_ASSIGN_ENGINE_STORAGE(index) \ + engine_storage.s.engine##index = \ + __cvmx_pko_memory_per_engine_o68(16 * i + (index)) + + engine_storage.u64 = 0; + PKO_ASSIGN_ENGINE_STORAGE(0); + PKO_ASSIGN_ENGINE_STORAGE(1); + PKO_ASSIGN_ENGINE_STORAGE(2); + PKO_ASSIGN_ENGINE_STORAGE(3); + PKO_ASSIGN_ENGINE_STORAGE(4); + PKO_ASSIGN_ENGINE_STORAGE(5); + PKO_ASSIGN_ENGINE_STORAGE(6); + PKO_ASSIGN_ENGINE_STORAGE(7); + PKO_ASSIGN_ENGINE_STORAGE(8); + PKO_ASSIGN_ENGINE_STORAGE(9); + PKO_ASSIGN_ENGINE_STORAGE(10); + PKO_ASSIGN_ENGINE_STORAGE(11); + PKO_ASSIGN_ENGINE_STORAGE(12); + PKO_ASSIGN_ENGINE_STORAGE(13); + PKO_ASSIGN_ENGINE_STORAGE(14); + PKO_ASSIGN_ENGINE_STORAGE(15); + csr_wr(CVMX_PKO_REG_ENGINE_STORAGEX(i), + engine_storage.u64); + } + } + } +} + +/** + * Enables the packet output hardware. It must already be + * configured. + */ +void cvmx_pko_enable(void) +{ + union cvmx_pko_reg_flags flags; + + flags.u64 = csr_rd(CVMX_PKO_REG_FLAGS); + if (flags.s.ena_pko) + debug("Warning: Enabling PKO when PKO already enabled.\n"); + + flags.s.ena_dwb = cvmx_helper_cfg_opt_get(CVMX_HELPER_CFG_OPT_USE_DWB); + flags.s.ena_pko = 1; + /* + * always enable big endian for 3-word command. Does nothing + * for 2-word. + */ + flags.s.store_be = 1; + csr_wr(CVMX_PKO_REG_FLAGS, flags.u64); +} + +/** + * Configure a output port and the associated queues for use. + * + * @param port Port to configure. + * @param base_queue First queue number to associate with this port. + * @param num_queues Number of queues to associate with this port + * @param priority Array of priority levels for each queue. Values are + * allowed to be 0-8. A value of 8 get 8 times the traffic + * of a value of 1. A value of 0 indicates that no rounds + * will be participated in. These priorities can be changed + * on the fly while the pko is enabled. A priority of 9 + * indicates that static priority should be used. If static + * priority is used all queues with static priority must be + * contiguous starting at the base_queue, and lower numbered + * queues have higher priority than higher numbered queues. + * There must be num_queues elements in the array. + */ +cvmx_pko_return_value_t cvmx_pko_config_port(int port, int base_queue, + int num_queues, + const u8 priority[]) +{ + cvmx_pko_return_value_t result_code; + int queue; + union cvmx_pko_mem_queue_ptrs config; + union cvmx_pko_reg_queue_ptrs1 config1; + int static_priority_base = -1; + int static_priority_end = -1; + int outputbuffer_pool = (int)cvmx_fpa_get_pko_pool(); + u64 outputbuffer_pool_size = cvmx_fpa_get_pko_pool_block_size(); + + /* This function is not used for CN68XX */ + if (OCTEON_IS_MODEL(OCTEON_CN68XX)) + return cvmx_pko2_config_port(port, base_queue, num_queues, + priority); + + if (debug) + debug("%s: port=%d queue=%d-%d pri %#x %#x %#x %#x\n", __func__, + port, base_queue, (base_queue + num_queues - 1), + priority[0], priority[1], priority[2], priority[3]); + + /* The need to handle ILLEGAL_PID port argument + * is obsolete now, the code here can be simplified. + */ + + if (port >= CVMX_PKO_NUM_OUTPUT_PORTS && + port != CVMX_PKO_MEM_QUEUE_PTRS_ILLEGAL_PID) { + debug("ERROR: %s: Invalid port %llu\n", __func__, + (unsigned long long)port); + return CVMX_PKO_INVALID_PORT; + } + + if (base_queue + num_queues > CVMX_PKO_MAX_OUTPUT_QUEUES) { + debug("ERROR: %s: Invalid queue range port = %lld base=%llu numques=%lld\n", + __func__, (unsigned long long)port, + (unsigned long long)base_queue, + (unsigned long long)num_queues); + return CVMX_PKO_INVALID_QUEUE; + } + + if (port != CVMX_PKO_MEM_QUEUE_PTRS_ILLEGAL_PID) { + /* + * Validate the static queue priority setup and set + * static_priority_base and static_priority_end + * accordingly. + */ + for (queue = 0; queue < num_queues; queue++) { + /* Find first queue of static priority */ + int p_queue = queue % 16; + + if (static_priority_base == -1 && + priority[p_queue] == CVMX_PKO_QUEUE_STATIC_PRIORITY) + static_priority_base = queue; + /* Find last queue of static priority */ + if (static_priority_base != -1 && + static_priority_end == -1 && + priority[p_queue] != + CVMX_PKO_QUEUE_STATIC_PRIORITY && + queue) + static_priority_end = queue - 1; + else if (static_priority_base != -1 && + static_priority_end == -1 && + queue == num_queues - 1) + /* all queues're static priority */ + static_priority_end = queue; + + /* + * Check to make sure all static priority + * queues are contiguous. Also catches some + * cases of static priorites not starting at + * queue 0. + */ + if (static_priority_end != -1 && + (int)queue > static_priority_end && + priority[p_queue] == + CVMX_PKO_QUEUE_STATIC_PRIORITY) { + debug("ERROR: %s: Static priority queues aren't contiguous or don't start at base queue. q: %d, eq: %d\n", + __func__, (int)queue, static_priority_end); + return CVMX_PKO_INVALID_PRIORITY; + } + } + if (static_priority_base > 0) { + debug("ERROR: %s: Static priority queues don't start at base queue. sq: %d\n", + __func__, static_priority_base); + return CVMX_PKO_INVALID_PRIORITY; + } + } + + /* + * At this point, static_priority_base and static_priority_end + * are either both -1, or are valid start/end queue numbers + */ + + result_code = CVMX_PKO_SUCCESS; + + for (queue = 0; queue < num_queues; queue++) { + u64 *buf_ptr = NULL; + int p_queue = queue % 16; + + config1.u64 = 0; + config1.s.idx3 = queue >> 3; + config1.s.qid7 = (base_queue + queue) >> 7; + + config.u64 = 0; + config.s.tail = queue == (num_queues - 1); + config.s.index = queue; + config.s.port = port; + config.s.queue = base_queue + queue; + + config.s.static_p = static_priority_base >= 0; + config.s.static_q = (int)queue <= static_priority_end; + config.s.s_tail = (int)queue == static_priority_end; + /* + * Convert the priority into an enable bit field. Try + * to space the bits out evenly so the packet don't + * get grouped up. + */ + switch ((int)priority[p_queue]) { + case 0: + config.s.qos_mask = 0x00; + break; + case 1: + config.s.qos_mask = 0x01; + break; + case 2: + config.s.qos_mask = 0x11; + break; + case 3: + config.s.qos_mask = 0x49; + break; + case 4: + config.s.qos_mask = 0x55; + break; + case 5: + config.s.qos_mask = 0x57; + break; + case 6: + config.s.qos_mask = 0x77; + break; + case 7: + config.s.qos_mask = 0x7f; + break; + case 8: + config.s.qos_mask = 0xff; + break; + case CVMX_PKO_QUEUE_STATIC_PRIORITY: + config.s.qos_mask = 0xff; + break; + default: + debug("ERROR: %s: Invalid priority %llu\n", __func__, + (unsigned long long)priority[p_queue]); + config.s.qos_mask = 0xff; + result_code = CVMX_PKO_INVALID_PRIORITY; + break; + } + + if (port != CVMX_PKO_MEM_QUEUE_PTRS_ILLEGAL_PID) { + cvmx_cmd_queue_result_t cmd_res; + + cmd_res = cvmx_cmd_queue_initialize( + CVMX_CMD_QUEUE_PKO(base_queue + queue), + CVMX_PKO_MAX_QUEUE_DEPTH, outputbuffer_pool, + outputbuffer_pool_size - + CVMX_PKO_COMMAND_BUFFER_SIZE_ADJUST * + 8); + if (cmd_res != CVMX_CMD_QUEUE_SUCCESS) { + switch (cmd_res) { + case CVMX_CMD_QUEUE_NO_MEMORY: + debug("ERROR: %s: Unable to allocate output buffer\n", + __func__); + return CVMX_PKO_NO_MEMORY; + case CVMX_CMD_QUEUE_ALREADY_SETUP: + debug("ERROR: %s: Port already setup. port=%d\n", + __func__, (int)port); + return CVMX_PKO_PORT_ALREADY_SETUP; + case CVMX_CMD_QUEUE_INVALID_PARAM: + default: + debug("ERROR: %s: Command queue initialization failed.\n", + __func__); + return CVMX_PKO_CMD_QUEUE_INIT_ERROR; + } + } + + buf_ptr = (u64 *)cvmx_cmd_queue_buffer( + CVMX_CMD_QUEUE_PKO(base_queue + queue)); + config.s.buf_ptr = cvmx_ptr_to_phys(buf_ptr); + } else { + config.s.buf_ptr = 0; + } + + CVMX_SYNCWS; + + csr_wr(CVMX_PKO_REG_QUEUE_PTRS1, config1.u64); + csr_wr(CVMX_PKO_MEM_QUEUE_PTRS, config.u64); + } + + return result_code; +} + +/* + * Configure queues for an internal port. + * @INTERNAL + * @param pko_port PKO internal port number + * @note this is the PKO2 equivalent to cvmx_pko_config_port() + */ +static cvmx_pko_return_value_t cvmx_pko2_config_port(short ipd_port, + int base_queue, + int num_queues, + const u8 priority[]) +{ + int queue, pko_port; + int static_priority_base; + int static_priority_end; + union cvmx_pko_mem_iqueue_ptrs config; + u64 *buf_ptr = NULL; + int outputbuffer_pool = (int)cvmx_fpa_get_pko_pool(); + u64 outputbuffer_pool_size = cvmx_fpa_get_pko_pool_block_size(); + + pko_port = cvmx_helper_cfg_ipd2pko_port_base(ipd_port); + + if (debug) + debug("%s: ipd_port %d pko_iport %d qbase %d qnum %d\n", + __func__, ipd_port, pko_port, base_queue, num_queues); + + static_priority_base = -1; + static_priority_end = -1; + + /* + * static queue priority validation + */ + for (queue = 0; queue < num_queues; queue++) { + int p_queue = queue % 16; + + if (static_priority_base == -1 && + priority[p_queue] == CVMX_PKO_QUEUE_STATIC_PRIORITY) + static_priority_base = queue; + + if (static_priority_base != -1 && static_priority_end == -1 && + priority[p_queue] != CVMX_PKO_QUEUE_STATIC_PRIORITY && + queue) + static_priority_end = queue - 1; + else if (static_priority_base != -1 && + static_priority_end == -1 && queue == num_queues - 1) + static_priority_end = + queue; /* all queues are static priority */ + + /* + * Check to make sure all static priority queues are contiguous. + * Also catches some cases of static priorites not starting from + * queue 0. + */ + if (static_priority_end != -1 && + (int)queue > static_priority_end && + priority[p_queue] == CVMX_PKO_QUEUE_STATIC_PRIORITY) { + debug("ERROR: %s: Static priority queues aren't contiguous or don't start at base queue. q: %d, eq: %d\n", + __func__, (int)queue, static_priority_end); + } + if (static_priority_base > 0) { + debug("ERROR: %s: Static priority queues don't start at base queue. sq: %d\n", + __func__, static_priority_base); + } + } + + /* + * main loop to set the fields of CVMX_PKO_MEM_IQUEUE_PTRS for + * each queue + */ + for (queue = 0; queue < num_queues; queue++) { + int p_queue = queue % 8; + + config.u64 = 0; + config.s.index = queue; + config.s.qid = base_queue + queue; + config.s.ipid = pko_port; + config.s.tail = (queue == (num_queues - 1)); + config.s.s_tail = (queue == static_priority_end); + config.s.static_p = (static_priority_base >= 0); + config.s.static_q = (queue <= static_priority_end); + + /* + * Convert the priority into an enable bit field. + * Try to space the bits out evenly so the packet + * don't get grouped up. + */ + switch ((int)priority[p_queue]) { + case 0: + config.s.qos_mask = 0x00; + break; + case 1: + config.s.qos_mask = 0x01; + break; + case 2: + config.s.qos_mask = 0x11; + break; + case 3: + config.s.qos_mask = 0x49; + break; + case 4: + config.s.qos_mask = 0x55; + break; + case 5: + config.s.qos_mask = 0x57; + break; + case 6: + config.s.qos_mask = 0x77; + break; + case 7: + config.s.qos_mask = 0x7f; + break; + case 8: + config.s.qos_mask = 0xff; + break; + case CVMX_PKO_QUEUE_STATIC_PRIORITY: + config.s.qos_mask = 0xff; + break; + default: + debug("ERROR: %s: Invalid priority %llu\n", __func__, + (unsigned long long)priority[p_queue]); + config.s.qos_mask = 0xff; + break; + } + + /* + * The command queues + */ + { + cvmx_cmd_queue_result_t cmd_res; + + cmd_res = cvmx_cmd_queue_initialize( + CVMX_CMD_QUEUE_PKO(base_queue + queue), + CVMX_PKO_MAX_QUEUE_DEPTH, outputbuffer_pool, + (outputbuffer_pool_size - + CVMX_PKO_COMMAND_BUFFER_SIZE_ADJUST * 8)); + + if (cmd_res != CVMX_CMD_QUEUE_SUCCESS) { + switch (cmd_res) { + case CVMX_CMD_QUEUE_NO_MEMORY: + debug("ERROR: %s: Unable to allocate output buffer\n", + __func__); + break; + case CVMX_CMD_QUEUE_ALREADY_SETUP: + debug("ERROR: %s: Port already setup\n", + __func__); + break; + case CVMX_CMD_QUEUE_INVALID_PARAM: + default: + debug("ERROR: %s: Command queue initialization failed.", + __func__); + break; + } + debug(" pko_port%d base_queue%d num_queues%d queue%d.\n", + pko_port, base_queue, num_queues, queue); + } + + buf_ptr = (u64 *)cvmx_cmd_queue_buffer( + CVMX_CMD_QUEUE_PKO(base_queue + queue)); + config.s.buf_ptr = cvmx_ptr_to_phys(buf_ptr) >> 7; + } + + CVMX_SYNCWS; + csr_wr(CVMX_PKO_MEM_IQUEUE_PTRS, config.u64); + } + + /* Error detection is resirable here */ + return 0; +}
Import cvmx-pko3.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pko3.c | 786 ++++++++++++++++++++++++++++++ 1 file changed, 786 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pko3.c
diff --git a/arch/mips/mach-octeon/cvmx-pko3.c b/arch/mips/mach-octeon/cvmx-pko3.c new file mode 100644 index 000000000000..d8ce02a2717a --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pko3.c @@ -0,0 +1,786 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +static const int debug; + +#define CVMX_DUMP_REGX(reg) \ + if (debug) \ + debug("%s=%#llx\n", #reg, (long long)csr_rd_node(node, reg)) + +static int cvmx_pko_setup_macs(int node); + +/* + * PKO descriptor queue operation error string + * + * @param dqstatus is the enumeration returned from hardware, + * PKO_QUERY_RTN_S[DQSTATUS]. + * + * @return static constant string error description + */ +const char *pko_dqstatus_error(pko_query_dqstatus_t dqstatus) +{ + char *str = "PKO Undefined error"; + + switch (dqstatus) { + case PKO_DQSTATUS_PASS: + str = "No error"; + break; + case PKO_DQSTATUS_BADSTATE: + str = "PKO queue not ready"; + break; + case PKO_DQSTATUS_NOFPABUF: + str = "PKO failed to allocate buffer from FPA"; + break; + case PKO_DQSTATUS_NOPKOBUF: + str = "PKO out of buffers"; + break; + case PKO_DQSTATUS_FAILRTNPTR: + str = "PKO failed to return buffer to FPA"; + break; + case PKO_DQSTATUS_ALREADY: + str = "PKO queue already opened"; + break; + case PKO_DQSTATUS_NOTCREATED: + str = "PKO queue has not been created"; + break; + case PKO_DQSTATUS_NOTEMPTY: + str = "PKO queue is not empty"; + break; + case PKO_DQSTATUS_SENDPKTDROP: + str = "Illegal PKO command construct"; + break; + } + return str; +} + +/* + * PKO global initialization for 78XX. + * + * @param node is the node on which PKO block is initialized. + * @return none. + */ +int cvmx_pko3_hw_init_global(int node, uint16_t aura) +{ + cvmx_pko_dpfi_flush_t pko_flush; + cvmx_pko_dpfi_fpa_aura_t pko_aura; + cvmx_pko_dpfi_ena_t dpfi_enable; + cvmx_pko_ptf_iobp_cfg_t ptf_iobp_cfg; + cvmx_pko_pdm_cfg_t pko_pdm_cfg; + cvmx_pko_enable_t pko_enable; + cvmx_pko_dpfi_status_t dpfi_status; + cvmx_pko_status_t pko_status; + cvmx_pko_shaper_cfg_t shaper_cfg; + u64 cycles; + const unsigned int timeout = 100; /* 100 milliseconds */ + + if (node != (aura >> 10)) + cvmx_printf("WARNING: AURA vs PKO node mismatch\n"); + + pko_enable.u64 = csr_rd_node(node, CVMX_PKO_ENABLE); + if (pko_enable.s.enable) { + cvmx_printf("WARNING: %s: PKO already enabled on node %u\n", + __func__, node); + return 0; + } + /* Enable color awareness. */ + shaper_cfg.u64 = csr_rd_node(node, CVMX_PKO_SHAPER_CFG); + shaper_cfg.s.color_aware = 1; + csr_wr_node(node, CVMX_PKO_SHAPER_CFG, shaper_cfg.u64); + + /* Clear FLUSH command to be sure */ + pko_flush.u64 = 0; + pko_flush.s.flush_en = 0; + csr_wr_node(node, CVMX_PKO_DPFI_FLUSH, pko_flush.u64); + + /* set the aura number in pko, use aura node from parameter */ + pko_aura.u64 = 0; + pko_aura.s.node = aura >> 10; + pko_aura.s.laura = aura; + csr_wr_node(node, CVMX_PKO_DPFI_FPA_AURA, pko_aura.u64); + + CVMX_DUMP_REGX(CVMX_PKO_DPFI_FPA_AURA); + + dpfi_enable.u64 = 0; + dpfi_enable.s.enable = 1; + csr_wr_node(node, CVMX_PKO_DPFI_ENA, dpfi_enable.u64); + + /* Prepare timeout */ + cycles = get_timer(0); + + /* Wait until all pointers have been returned */ + do { + pko_status.u64 = csr_rd_node(node, CVMX_PKO_STATUS); + if (get_timer(cycles) > timeout) + break; + } while (!pko_status.s.pko_rdy); + + if (!pko_status.s.pko_rdy) { + dpfi_status.u64 = csr_rd_node(node, CVMX_PKO_DPFI_STATUS); + cvmx_printf("ERROR: %s: PKO DFPI failed, PKO_STATUS=%#llx DPFI_STATUS=%#llx\n", + __func__, (unsigned long long)pko_status.u64, + (unsigned long long)dpfi_status.u64); + return -1; + } + + /* Set max outstanding requests in IOBP for any FIFO.*/ + ptf_iobp_cfg.u64 = csr_rd_node(node, CVMX_PKO_PTF_IOBP_CFG); + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) + ptf_iobp_cfg.s.max_read_size = 0x10; /* Recommended by HRM.*/ + else + /* Reduce the value from recommended 0x10 to avoid + * getting "underflow" condition in the BGX TX FIFO. + */ + ptf_iobp_cfg.s.max_read_size = 3; + csr_wr_node(node, CVMX_PKO_PTF_IOBP_CFG, ptf_iobp_cfg.u64); + + /* Set minimum packet size per Ethernet standard */ + pko_pdm_cfg.u64 = 0; + pko_pdm_cfg.s.pko_pad_minlen = 0x3c; /* 60 bytes before FCS */ + csr_wr_node(node, CVMX_PKO_PDM_CFG, pko_pdm_cfg.u64); + + /* Initialize MACs and FIFOs */ + cvmx_pko_setup_macs(node); + + /* enable PKO, although interfaces and queues are not up yet */ + pko_enable.u64 = 0; + pko_enable.s.enable = 1; + csr_wr_node(node, CVMX_PKO_ENABLE, pko_enable.u64); + + /* PKO_RDY set indicates successful initialization */ + pko_status.u64 = csr_rd_node(node, CVMX_PKO_STATUS); + if (pko_status.s.pko_rdy) + return 0; + + cvmx_printf("ERROR: %s: failed, PKO_STATUS=%#llx\n", __func__, + (unsigned long long)pko_status.u64); + return -1; +} + +/* + * Configure Channel credit level in PKO. + * + * @param node is to specify the node to which this configuration is applied. + * @param level specifies the level at which pko channel queues will be configured, + * @return returns 0 if successful and -1 on failure. + */ +int cvmx_pko3_channel_credit_level(int node, enum cvmx_pko3_level_e level) +{ + union cvmx_pko_channel_level channel_level; + + channel_level.u64 = 0; + + if (level == CVMX_PKO_L2_QUEUES) + channel_level.s.cc_level = 0; + else if (level == CVMX_PKO_L3_QUEUES) + channel_level.s.cc_level = 1; + else + return -1; + + csr_wr_node(node, CVMX_PKO_CHANNEL_LEVEL, channel_level.u64); + + return 0; +} + +/** Open configured descriptor queues before queueing packets into them. + * + * @param node is to specify the node to which this configuration is applied. + * @param dq is the descriptor queue number to be opened. + * @return returns 0 on success or -1 on failure. + */ +int cvmx_pko_dq_open(int node, int dq) +{ + cvmx_pko_query_rtn_t pko_status; + pko_query_dqstatus_t dqstatus; + cvmx_pko3_dq_params_t *p_param; + + if (debug) + debug("%s: DEBUG: dq %u\n", __func__, dq); + + __cvmx_pko3_dq_param_setup(node); + + pko_status = __cvmx_pko3_do_dma(node, dq, NULL, 0, CVMX_PKO_DQ_OPEN); + + dqstatus = pko_status.s.dqstatus; + + if (dqstatus == PKO_DQSTATUS_ALREADY) + return 0; + if (dqstatus != PKO_DQSTATUS_PASS) { + cvmx_printf("%s: ERROR: Failed to open dq :%u: %s\n", __func__, + dq, pko_dqstatus_error(dqstatus)); + return -1; + } + + /* Setup the descriptor queue software parameters */ + p_param = cvmx_pko3_dq_parameters(node, dq); + if (p_param) { + p_param->depth = pko_status.s.depth; + if (p_param->limit == 0) + p_param->limit = 1024; /* last-resort default */ + } + + return 0; +} + +/* + * PKO initialization of MACs and FIFOs + * + * All MACs are configured and assigned a specific FIFO, + * and each FIFO is configured with size for a best utilization + * of available FIFO resources. + * + * @param node is to specify which node's pko block for this setup. + * @return returns 0 if successful and -1 on failure. + * + * Note: This function contains model-specific code. + */ +static int cvmx_pko_setup_macs(int node) +{ + unsigned int interface; + unsigned int port, num_ports; + unsigned int mac_num, fifo, pri, cnt; + cvmx_helper_interface_mode_t mode; + const unsigned int num_interfaces = + cvmx_helper_get_number_of_interfaces(); + u8 fifo_group_cfg[8]; + u8 fifo_group_spd[8]; + unsigned int fifo_count = 0; + unsigned int max_fifos = 0, fifo_groups = 0; + struct { + u8 fifo_cnt; + u8 fifo_id; + u8 pri; + u8 spd; + u8 mac_fifo_cnt; + } cvmx_pko3_mac_table[32]; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + max_fifos = 28; /* exclusive of NULL FIFO */ + fifo_groups = 8; /* inclusive of NULL PTGF */ + } + if (OCTEON_IS_MODEL(OCTEON_CN73XX) || OCTEON_IS_MODEL(OCTEON_CNF75XX)) { + max_fifos = 16; + fifo_groups = 5; + } + + /* Initialize FIFO allocation table */ + memset(&fifo_group_cfg, 0, sizeof(fifo_group_cfg)); + memset(&fifo_group_spd, 0, sizeof(fifo_group_spd)); + memset(cvmx_pko3_mac_table, 0, sizeof(cvmx_pko3_mac_table)); + + /* Initialize all MACs as disabled */ + for (mac_num = 0; mac_num < __cvmx_pko3_num_macs(); mac_num++) { + cvmx_pko3_mac_table[mac_num].pri = 0; + cvmx_pko3_mac_table[mac_num].fifo_cnt = 0; + cvmx_pko3_mac_table[mac_num].fifo_id = 0x1f; + } + + for (interface = 0; interface < num_interfaces; interface++) { + int xiface = + cvmx_helper_node_interface_to_xiface(node, interface); + /* Interface type for ALL interfaces */ + mode = cvmx_helper_interface_get_mode(xiface); + num_ports = cvmx_helper_interface_enumerate(xiface); + + if (mode == CVMX_HELPER_INTERFACE_MODE_DISABLED) + continue; + /* + * Non-BGX interfaces: + * Each of these interfaces has a single MAC really. + */ + if (mode == CVMX_HELPER_INTERFACE_MODE_ILK || + mode == CVMX_HELPER_INTERFACE_MODE_NPI || + mode == CVMX_HELPER_INTERFACE_MODE_LOOP) + num_ports = 1; + + for (port = 0; port < num_ports; port++) { + int i; + + /* Get the per-port mode for BGX-interfaces */ + if (interface < CVMX_HELPER_MAX_GMX) + mode = cvmx_helper_bgx_get_mode(xiface, port); + /* In MIXED mode, LMACs can run different protocols */ + + /* convert interface/port to mac number */ + i = __cvmx_pko3_get_mac_num(xiface, port); + if (i < 0 || i >= (int)__cvmx_pko3_num_macs()) { + cvmx_printf("%s: ERROR: interface %d:%u port %d has no MAC %d/%d\n", + __func__, node, interface, port, i, + __cvmx_pko3_num_macs()); + continue; + } + + if (mode == CVMX_HELPER_INTERFACE_MODE_RXAUI) { + unsigned int bgx_fifo_size = + __cvmx_helper_bgx_fifo_size(xiface, + port); + + cvmx_pko3_mac_table[i].mac_fifo_cnt = + bgx_fifo_size / + (CVMX_BGX_TX_FIFO_SIZE / 4); + cvmx_pko3_mac_table[i].pri = 2; + cvmx_pko3_mac_table[i].spd = 10; + cvmx_pko3_mac_table[i].fifo_cnt = 2; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_XLAUI) { + unsigned int bgx_fifo_size = + __cvmx_helper_bgx_fifo_size(xiface, + port); + + cvmx_pko3_mac_table[i].mac_fifo_cnt = + bgx_fifo_size / + (CVMX_BGX_TX_FIFO_SIZE / 4); + cvmx_pko3_mac_table[i].pri = 4; + cvmx_pko3_mac_table[i].spd = 40; + cvmx_pko3_mac_table[i].fifo_cnt = 4; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_XAUI) { + unsigned int bgx_fifo_size = + __cvmx_helper_bgx_fifo_size(xiface, + port); + + cvmx_pko3_mac_table[i].mac_fifo_cnt = + bgx_fifo_size / + (CVMX_BGX_TX_FIFO_SIZE / 4); + cvmx_pko3_mac_table[i].pri = 3; + cvmx_pko3_mac_table[i].fifo_cnt = 4; + /* DXAUI at 20G, or XAU at 10G */ + cvmx_pko3_mac_table[i].spd = 20; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_XFI) { + unsigned int bgx_fifo_size = + __cvmx_helper_bgx_fifo_size(xiface, + port); + + cvmx_pko3_mac_table[i].mac_fifo_cnt = + bgx_fifo_size / + (CVMX_BGX_TX_FIFO_SIZE / 4); + cvmx_pko3_mac_table[i].pri = 3; + cvmx_pko3_mac_table[i].fifo_cnt = 4; + cvmx_pko3_mac_table[i].spd = 10; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_LOOP) { + cvmx_pko3_mac_table[i].fifo_cnt = 1; + cvmx_pko3_mac_table[i].pri = 1; + cvmx_pko3_mac_table[i].spd = 1; + cvmx_pko3_mac_table[i].mac_fifo_cnt = 1; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_ILK || + mode == CVMX_HELPER_INTERFACE_MODE_SRIO) { + cvmx_pko3_mac_table[i].fifo_cnt = 4; + cvmx_pko3_mac_table[i].pri = 3; + /* ILK/SRIO: speed depends on lane count */ + cvmx_pko3_mac_table[i].spd = 40; + cvmx_pko3_mac_table[i].mac_fifo_cnt = 4; + } else if (mode == CVMX_HELPER_INTERFACE_MODE_NPI) { + cvmx_pko3_mac_table[i].fifo_cnt = 4; + cvmx_pko3_mac_table[i].pri = 2; + /* Actual speed depends on PCIe lanes/mode */ + cvmx_pko3_mac_table[i].spd = 50; + /* SLI Tx FIFO size to be revisitted */ + cvmx_pko3_mac_table[i].mac_fifo_cnt = 1; + } else { + /* Other BGX interface modes: SGMII/RGMII */ + unsigned int bgx_fifo_size = + __cvmx_helper_bgx_fifo_size(xiface, + port); + + cvmx_pko3_mac_table[i].mac_fifo_cnt = + bgx_fifo_size / + (CVMX_BGX_TX_FIFO_SIZE / 4); + cvmx_pko3_mac_table[i].fifo_cnt = 1; + cvmx_pko3_mac_table[i].pri = 1; + cvmx_pko3_mac_table[i].spd = 1; + } + + if (debug) + debug("%s: intf %d:%u port %u %s mac %02u cnt %u macfifo %uk spd %u\n", + __func__, node, interface, port, + cvmx_helper_interface_mode_to_string(mode), + i, cvmx_pko3_mac_table[i].fifo_cnt, + cvmx_pko3_mac_table[i].mac_fifo_cnt * 8, + cvmx_pko3_mac_table[i].spd); + + } /* for port */ + } /* for interface */ + + /* Count the number of requested FIFOs */ + for (fifo_count = mac_num = 0; mac_num < __cvmx_pko3_num_macs(); + mac_num++) + fifo_count += cvmx_pko3_mac_table[mac_num].fifo_cnt; + + if (debug) + debug("%s: initially requested FIFO count %u\n", __func__, + fifo_count); + + /* Heuristically trim FIFO count to fit in available number */ + pri = 1; + cnt = 4; + while (fifo_count > max_fifos) { + for (mac_num = 0; mac_num < __cvmx_pko3_num_macs(); mac_num++) { + if (cvmx_pko3_mac_table[mac_num].fifo_cnt == cnt && + cvmx_pko3_mac_table[mac_num].pri <= pri) { + cvmx_pko3_mac_table[mac_num].fifo_cnt >>= 1; + fifo_count -= + cvmx_pko3_mac_table[mac_num].fifo_cnt; + } + if (fifo_count <= max_fifos) + break; + } + if (pri >= 4) { + pri = 1; + cnt >>= 1; + } else { + pri++; + } + if (cnt == 0) + break; + } + + if (debug) + debug("%s: adjusted FIFO count %u\n", __func__, fifo_count); + + /* Special case for NULL Virtual FIFO */ + fifo_group_cfg[fifo_groups - 1] = 0; + /* there is no MAC connected to NULL FIFO */ + + /* Configure MAC units, and attach a FIFO to each */ + for (fifo = 0, cnt = 4; cnt > 0; cnt >>= 1) { + unsigned int g; + + for (mac_num = 0; mac_num < __cvmx_pko3_num_macs(); mac_num++) { + if (cvmx_pko3_mac_table[mac_num].fifo_cnt < cnt || + cvmx_pko3_mac_table[mac_num].fifo_id != 0x1f) + continue; + + /* Attach FIFO to MAC */ + cvmx_pko3_mac_table[mac_num].fifo_id = fifo; + g = fifo >> 2; + /* Sum speed for FIFO group */ + fifo_group_spd[g] += cvmx_pko3_mac_table[mac_num].spd; + + if (cnt == 4) + fifo_group_cfg[g] = 4; /* 10k,0,0,0 */ + else if (cnt == 2 && (fifo & 0x3) == 0) + fifo_group_cfg[g] = 3; /* 5k,0,5k,0 */ + else if (cnt == 2 && fifo_group_cfg[g] == 3) + /* no change */; + else if (cnt == 1 && (fifo & 0x2) && + fifo_group_cfg[g] == 3) + fifo_group_cfg[g] = 1; /* 5k,0,2.5k 2.5k*/ + else if (cnt == 1 && (fifo & 0x3) == 0x3) + /* no change */; + else if (cnt == 1) + fifo_group_cfg[g] = 0; /* 2.5k x 4 */ + else + cvmx_printf("ERROR: %s: internal error\n", + __func__); + + fifo += cnt; + } + } + + /* Check if there was no error in FIFO allocation */ + if (fifo > max_fifos) { + cvmx_printf("ERROR: %s: Internal error FIFO %u\n", __func__, + fifo); + return -1; + } + + if (debug) + debug("%s: used %u of FIFOs\n", __func__, fifo); + + /* Now configure all FIFO groups */ + for (fifo = 0; fifo < fifo_groups; fifo++) { + cvmx_pko_ptgfx_cfg_t pko_ptgfx_cfg; + + pko_ptgfx_cfg.u64 = csr_rd_node(node, CVMX_PKO_PTGFX_CFG(fifo)); + if (pko_ptgfx_cfg.s.size != fifo_group_cfg[fifo]) + pko_ptgfx_cfg.s.reset = 1; + pko_ptgfx_cfg.s.size = fifo_group_cfg[fifo]; + if (fifo_group_spd[fifo] >= 40) + if (pko_ptgfx_cfg.s.size >= 3) + pko_ptgfx_cfg.s.rate = 3; /* 50 Gbps */ + else + pko_ptgfx_cfg.s.rate = 2; /* 25 Gbps */ + else if (fifo_group_spd[fifo] >= 20) + pko_ptgfx_cfg.s.rate = 2; /* 25 Gbps */ + else if (fifo_group_spd[fifo] >= 10) + pko_ptgfx_cfg.s.rate = 1; /* 12.5 Gbps */ + else + pko_ptgfx_cfg.s.rate = 0; /* 6.25 Gbps */ + + if (debug) + debug("%s: FIFO %#x-%#x size=%u speed=%d rate=%d\n", + __func__, fifo * 4, fifo * 4 + 3, + pko_ptgfx_cfg.s.size, fifo_group_spd[fifo], + pko_ptgfx_cfg.s.rate); + + csr_wr_node(node, CVMX_PKO_PTGFX_CFG(fifo), pko_ptgfx_cfg.u64); + pko_ptgfx_cfg.s.reset = 0; + csr_wr_node(node, CVMX_PKO_PTGFX_CFG(fifo), pko_ptgfx_cfg.u64); + } + + /* Configure all MACs assigned FIFO number */ + for (mac_num = 0; mac_num < __cvmx_pko3_num_macs(); mac_num++) { + cvmx_pko_macx_cfg_t pko_mac_cfg; + + if (debug) + debug("%s: mac#%02u: fifo=%#x cnt=%u speed=%d\n", + __func__, mac_num, + cvmx_pko3_mac_table[mac_num].fifo_id, + cvmx_pko3_mac_table[mac_num].fifo_cnt, + cvmx_pko3_mac_table[mac_num].spd); + + pko_mac_cfg.u64 = csr_rd_node(node, CVMX_PKO_MACX_CFG(mac_num)); + pko_mac_cfg.s.fifo_num = cvmx_pko3_mac_table[mac_num].fifo_id; + csr_wr_node(node, CVMX_PKO_MACX_CFG(mac_num), pko_mac_cfg.u64); + } + + /* Setup PKO MCI0/MCI1/SKID credits */ + for (mac_num = 0; mac_num < __cvmx_pko3_num_macs(); mac_num++) { + cvmx_pko_mci0_max_credx_t pko_mci0_max_cred; + cvmx_pko_mci1_max_credx_t pko_mci1_max_cred; + cvmx_pko_macx_cfg_t pko_mac_cfg; + unsigned int fifo_credit, mac_credit, skid_credit; + unsigned int pko_fifo_cnt, fifo_size; + unsigned int mac_fifo_cnt; + unsigned int tmp; + int saved_fifo_num; + + pko_fifo_cnt = cvmx_pko3_mac_table[mac_num].fifo_cnt; + mac_fifo_cnt = cvmx_pko3_mac_table[mac_num].mac_fifo_cnt; + + /* Skip unused MACs */ + if (pko_fifo_cnt == 0) + continue; + + /* Check for sanity */ + if (pko_fifo_cnt > 4) + pko_fifo_cnt = 1; + + fifo_size = (2 * 1024) + (1024 / 2); /* 2.5KiB */ + fifo_credit = pko_fifo_cnt * fifo_size; + + if (mac_num == 0) { + /* loopback */ + mac_credit = 4096; /* From HRM Sec 13.0 */ + skid_credit = 0; + } else if (mac_num == 1) { + /* DPI */ + mac_credit = 2 * 1024; + skid_credit = 0; + } else if (octeon_has_feature(OCTEON_FEATURE_ILK) && + (mac_num & 0xfe) == 2) { + /* ILK0, ILK1: MAC 2,3 */ + mac_credit = 4 * 1024; /* 4KB fifo */ + skid_credit = 0; + } else if (octeon_has_feature(OCTEON_FEATURE_SRIO) && + (mac_num >= 6) && (mac_num <= 9)) { + /* SRIO0, SRIO1: MAC 6..9 */ + mac_credit = 1024 / 2; + skid_credit = 0; + } else { + /* BGX */ + mac_credit = mac_fifo_cnt * 8 * 1024; + skid_credit = mac_fifo_cnt * 256; + } + + if (debug) + debug("%s: mac %u pko_fifo_credit=%u mac_credit=%u\n", + __func__, mac_num, fifo_credit, mac_credit); + + tmp = (fifo_credit + mac_credit) / 16; + pko_mci0_max_cred.u64 = 0; + pko_mci0_max_cred.s.max_cred_lim = tmp; + + /* Check for overflow */ + if (pko_mci0_max_cred.s.max_cred_lim != tmp) { + cvmx_printf("WARNING: %s: MCI0 credit overflow\n", + __func__); + pko_mci0_max_cred.s.max_cred_lim = 0xfff; + } + + /* Pass 2 PKO hardware does not use the MCI0 credits */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) + csr_wr_node(node, CVMX_PKO_MCI0_MAX_CREDX(mac_num), + pko_mci0_max_cred.u64); + + /* The original CSR formula is the correct one after all */ + tmp = (mac_credit) / 16; + pko_mci1_max_cred.u64 = 0; + pko_mci1_max_cred.s.max_cred_lim = tmp; + + /* Check for overflow */ + if (pko_mci1_max_cred.s.max_cred_lim != tmp) { + cvmx_printf("WARNING: %s: MCI1 credit overflow\n", + __func__); + pko_mci1_max_cred.s.max_cred_lim = 0xfff; + } + + csr_wr_node(node, CVMX_PKO_MCI1_MAX_CREDX(mac_num), + pko_mci1_max_cred.u64); + + tmp = (skid_credit / 256) >> 1; /* valid 0,1,2 */ + pko_mac_cfg.u64 = csr_rd_node(node, CVMX_PKO_MACX_CFG(mac_num)); + + /* The PKO_MACX_CFG bits cannot be changed unless FIFO_MUM=0x1f (unused fifo) */ + saved_fifo_num = pko_mac_cfg.s.fifo_num; + pko_mac_cfg.s.fifo_num = 0x1f; + pko_mac_cfg.s.skid_max_cnt = tmp; + csr_wr_node(node, CVMX_PKO_MACX_CFG(mac_num), pko_mac_cfg.u64); + + pko_mac_cfg.u64 = csr_rd_node(node, CVMX_PKO_MACX_CFG(mac_num)); + pko_mac_cfg.s.fifo_num = saved_fifo_num; + csr_wr_node(node, CVMX_PKO_MACX_CFG(mac_num), pko_mac_cfg.u64); + + if (debug) { + pko_mci0_max_cred.u64 = + csr_rd_node(node, CVMX_PKO_MCI0_MAX_CREDX(mac_num)); + pko_mci1_max_cred.u64 = + csr_rd_node(node, CVMX_PKO_MCI1_MAX_CREDX(mac_num)); + pko_mac_cfg.u64 = + csr_rd_node(node, CVMX_PKO_MACX_CFG(mac_num)); + debug("%s: mac %u PKO_MCI0_MAX_CREDX=%u PKO_MCI1_MAX_CREDX=%u PKO_MACX_CFG[SKID_MAX_CNT]=%u\n", + __func__, mac_num, + pko_mci0_max_cred.s.max_cred_lim, + pko_mci1_max_cred.s.max_cred_lim, + pko_mac_cfg.s.skid_max_cnt); + } + } /* for mac_num */ + + return 0; +} + +/** Set MAC options + * + * The options supported are the parameters below: + * + * @param xiface The physical interface number + * @param index The physical sub-interface port + * @param fcs_enable Enable FCS generation + * @param pad_enable Enable padding to minimum packet size + * @param fcs_sop_off Number of bytes at start of packet to exclude from FCS + * + * The typical use for `fcs_sop_off` is when the interface is configured + * to use a header such as HighGig to precede every Ethernet packet, + * such a header usually does not partake in the CRC32 computation stream, + * and its size must be set with this parameter. + * + * @return Returns 0 on success, -1 if interface/port is invalid. + */ +int cvmx_pko3_interface_options(int xiface, int index, bool fcs_enable, + bool pad_enable, unsigned int fcs_sop_off) +{ + int mac_num; + cvmx_pko_macx_cfg_t pko_mac_cfg; + unsigned int fifo_num; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + if (debug) + debug("%s: intf %u:%u/%u fcs=%d pad=%d\n", __func__, xi.node, + xi.interface, index, fcs_enable, pad_enable); + + mac_num = __cvmx_pko3_get_mac_num(xiface, index); + if (mac_num < 0) { + cvmx_printf("ERROR: %s: invalid interface %u:%u/%u\n", __func__, + xi.node, xi.interface, index); + return -1; + } + + pko_mac_cfg.u64 = csr_rd_node(xi.node, CVMX_PKO_MACX_CFG(mac_num)); + + /* If MAC is not assigned, return an error */ + if (pko_mac_cfg.s.fifo_num == 0x1f) { + cvmx_printf("ERROR: %s: unused interface %u:%u/%u\n", __func__, + xi.node, xi.interface, index); + return -1; + } + + if (pko_mac_cfg.s.min_pad_ena == pad_enable && + pko_mac_cfg.s.fcs_ena == fcs_enable) { + if (debug) + debug("%s: mac %#x unchanged\n", __func__, mac_num); + return 0; + } + + /* WORKAROUND: Pass1 won't allow change any bits unless FIFO_NUM=0x1f */ + fifo_num = pko_mac_cfg.s.fifo_num; + pko_mac_cfg.s.fifo_num = 0x1f; + + pko_mac_cfg.s.min_pad_ena = pad_enable; + pko_mac_cfg.s.fcs_ena = fcs_enable; + pko_mac_cfg.s.fcs_sop_off = fcs_sop_off; + + csr_wr_node(xi.node, CVMX_PKO_MACX_CFG(mac_num), pko_mac_cfg.u64); + + pko_mac_cfg.s.fifo_num = fifo_num; + csr_wr_node(xi.node, CVMX_PKO_MACX_CFG(mac_num), pko_mac_cfg.u64); + + if (debug) + debug("%s: PKO_MAC[%u]CFG=%#llx\n", __func__, mac_num, + (unsigned long long)csr_rd_node(xi.node, CVMX_PKO_MACX_CFG(mac_num))); + + return 0; +} + +/** Set Descriptor Queue options + * + * The `min_pad` parameter must be in agreement with the interface-level + * padding option for all descriptor queues assigned to that particular + * interface/port. + * + * @param node on which to operate + * @param dq descriptor queue to set + * @param min_pad minimum padding to set for dq + */ +void cvmx_pko3_dq_options(unsigned int node, unsigned int dq, bool min_pad) +{ + cvmx_pko_pdm_dqx_minpad_t reg; + + dq &= (1 << 10) - 1; + reg.u64 = csr_rd_node(node, CVMX_PKO_PDM_DQX_MINPAD(dq)); + reg.s.minpad = min_pad; + csr_wr_node(node, CVMX_PKO_PDM_DQX_MINPAD(dq), reg.u64); +}
Import cvmx-pko3-compat.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pko3-compat.c | 656 +++++++++++++++++++++++ 1 file changed, 656 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pko3-compat.c
diff --git a/arch/mips/mach-octeon/cvmx-pko3-compat.c b/arch/mips/mach-octeon/cvmx-pko3-compat.c new file mode 100644 index 000000000000..3e142322dbfb --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pko3-compat.c @@ -0,0 +1,656 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-scratch.h> +#include <mach/cvmx-hwfau.h> +#include <mach/cvmx-fau.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +/* #undef CVMX_ENABLE_PARAMETER_CHECKING */ +/* #define CVMX_ENABLE_PARAMETER_CHECKING 1 */ +/* #define __PKO3_NATIVE_PTR */ + +static inline u64 cvmx_pko3_legacy_paddr(unsigned int node, u64 addr) +{ + u64 paddr; + + paddr = node; + paddr = (addr & ((1ull << 40) - 1)) | (paddr << 40); + return paddr; +} + +#if CVMX_ENABLE_PARAMETER_CHECKING +/** + * @INTERNAL + * + * Verify the integrity of a legacy buffer link pointer, + * + * Note that the IPD/PIP/PKO hardware would sometimes + * round-up the buf_ptr->size field of the last buffer in a chain to the next + * cache line size, so the sum of buf_ptr->size + * fields for a packet may exceed total_bytes by up to 127 bytes. + * + * @returns 0 on success, a negative number on error. + */ +static int cvmx_pko3_legacy_bufptr_validate(cvmx_buf_ptr_t buf_ptr, + unsigned int gather, + unsigned int buffers, + unsigned int total_bytes) +{ + unsigned int node = cvmx_get_node_num(); + unsigned int segs = 0, bytes = 0; + unsigned int phys_addr; + cvmx_buf_ptr_t ptr; + int delta; + + if (buffers == 0) { + return -1; + } else if (buffers == 1) { + delta = buf_ptr.s.size - total_bytes; + if (delta < 0 || delta > 127) + return -2; + } else if (gather) { + cvmx_buf_ptr_t *vptr; + /* Validate gather list */ + if (buf_ptr.s.size < buffers) + return -3; + phys_addr = cvmx_pko3_legacy_paddr(node, buf_ptr.s.addr); + vptr = cvmx_phys_to_ptr(phys_addr); + for (segs = 0; segs < buffers; segs++) + bytes += vptr[segs].s.size; + delta = bytes - total_bytes; + if (delta < 0 || delta > 127) + return -4; + } else { + void *vptr; + /* Validate linked buffers */ + ptr = buf_ptr; + for (segs = 0; segs < buffers; segs++) { + bytes += ptr.s.size; + phys_addr = cvmx_pko3_legacy_paddr(node, ptr.s.addr); + vptr = cvmx_phys_to_ptr(phys_addr); + memcpy(&ptr, vptr - sizeof(u64), sizeof(u64)); + } + delta = bytes - total_bytes; + if (delta < 0 || delta > 127) + return -5; + } + return 0; +} +#endif /* CVMX_ENABLE_PARAMETER_CHECKING */ + +/* + * @INTERNAL + * + * Implementation note: + * When the packet is sure to not need a jump_buf, + * it will be written directly into cvmseg. + * When the packet might not fit into cvmseg with all + * of its descriptors, a jump_buf is allocated a priori, + * and only header is first placed into cvmseg, all other + * descriptors are placed into jump_buf, and finally + * the PKO_SEND_JUMP_S is written to cvmseg. + * This is because if there are no EXT or TSO descriptors, + * then HDR must be first, and JMP second and that is all + * that should go into cvmseg. + */ +struct __cvmx_pko3_legacy_desc { + u64 *cmd_words; + u64 *jump_buf_base_ptr; + unsigned short word_count; + short last_pool; + u8 port_node; + u8 aura_node; + u8 jump_buf_size; +}; + +/** + * @INTERNAL + * + * Add a subdescriptor into a command buffer, + * and handle command-buffer overflow by allocating a JUMP_s buffer + * from PKO3 internal AURA. + */ +static int __cvmx_pko3_cmd_subdc_add(struct __cvmx_pko3_legacy_desc *desc, + u64 subdc) +{ + /* SEND_JUMP_S missing on Pass1.X */ + if (desc->word_count >= 15) { + printf("%s: ERROR: too many segments\n", __func__); + return -EBADF; + } + + /* Handle small commands simply */ + if (cvmx_likely(!desc->jump_buf_base_ptr)) { + desc->cmd_words[desc->word_count] = subdc; + (desc->word_count)++; + return desc->word_count; + } + + if (cvmx_unlikely(desc->jump_buf_size >= 255)) + return -ENOMEM; + + desc->jump_buf_base_ptr[desc->jump_buf_size++] = subdc; + + return desc->word_count + desc->jump_buf_size; +} + +/** + * @INTERNAL + * + * Finalize command buffer + * + * @returns: number of command words in command buffer and jump buffer + * or negative number on error. + */ + +static int __cvmx_pko3_cmd_done(struct __cvmx_pko3_legacy_desc *desc) +{ + short pko_aura; + cvmx_pko_buf_ptr_t jump_s; + cvmx_pko_send_aura_t aura_s; + + /* no jump buffer, nothing to do */ + if (!desc->jump_buf_base_ptr) + return desc->word_count; + + desc->word_count++; + + /* Verify number of words is 15 */ + if (desc->word_count != 2) { + printf("ERROR: %s: internal error, word_count=%d\n", __func__, + desc->word_count); + return -EINVAL; + } + + /* Add SEND_AURA_S at the end of jump_buf */ + pko_aura = __cvmx_pko3_aura_get(desc->port_node); + + aura_s.u64 = 0; + aura_s.s.aura = pko_aura; + aura_s.s.offset = 0; + aura_s.s.alg = AURAALG_NOP; + aura_s.s.subdc4 = CVMX_PKO_SENDSUBDC_AURA; + + desc->jump_buf_base_ptr[desc->jump_buf_size++] = aura_s.u64; + + /* Add SEND_JUMPS to point to jump_buf */ + jump_s.u64 = 0; + jump_s.s.subdc3 = CVMX_PKO_SENDSUBDC_JUMP; + jump_s.s.addr = cvmx_ptr_to_phys(desc->jump_buf_base_ptr); + jump_s.s.i = 1; /* F=1: Free this buffer when done */ + jump_s.s.size = desc->jump_buf_size; + desc->cmd_words[1] = jump_s.u64; + + return desc->word_count + desc->jump_buf_size; +} + +/** + * @INTERNAL + * + * Handle buffer pools for PKO legacy transmit operation + */ +static inline int cvmx_pko3_legacy_pool(struct __cvmx_pko3_legacy_desc *desc, + int pool) +{ + cvmx_pko_send_aura_t aura_s; + unsigned int aura; + + if (cvmx_unlikely(desc->last_pool == pool)) + return 0; + + aura = desc->aura_node << 10; /* LAURA=AURA[0..9] */ + aura |= pool; + + if (cvmx_likely(desc->last_pool < 0)) { + cvmx_pko_send_hdr_t *hdr_s; + + hdr_s = (void *)&desc->cmd_words[0]; + /* Create AURA from legacy pool (assume LAURA==POOL */ + hdr_s->s.aura = aura; + desc->last_pool = pool; + return 0; + } + + aura_s.u64 = 0; + aura_s.s.subdc4 = CVMX_PKO_SENDSUBDC_AURA; + aura_s.s.offset = 0; + aura_s.s.alg = AURAALG_NOP; + aura |= pool; + aura_s.s.aura = aura; + desc->last_pool = pool; + return __cvmx_pko3_cmd_subdc_add(desc, aura_s.u64); +} + +/** + * @INTERNAL + * + * Backward compatibility for packet transmission using legacy PKO command. + * + * NOTE: Only supports output on node-local ports. + * + * TBD: Could embed destination node in extended DQ number. + */ +cvmx_pko_return_value_t +cvmx_pko3_legacy_xmit(unsigned int dq, cvmx_pko_command_word0_t pko_command, + cvmx_buf_ptr_t packet, u64 addr, bool tag_sw) +{ + cvmx_pko_query_rtn_t pko_status; + cvmx_pko_send_hdr_t *hdr_s; + struct __cvmx_pko3_legacy_desc desc; + u8 *data_ptr; + unsigned int node, seg_cnt; + int res; + cvmx_buf_ptr_pki_t bptr; + + seg_cnt = pko_command.s.segs; + desc.cmd_words = cvmx_pko3_cvmseg_addr(); + + /* Allocate from local aura, assume all old-pools are local */ + node = cvmx_get_node_num(); + desc.aura_node = node; + + /* Derive destination node from dq */ + desc.port_node = dq >> 10; + dq &= (1 << 10) - 1; + + desc.word_count = 1; + desc.last_pool = -1; + + /* For small packets, write descriptors directly to CVMSEG + * but for longer packets use jump_buf + */ + if (seg_cnt < 7 || OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) { + desc.jump_buf_size = 0; + desc.jump_buf_base_ptr = NULL; + } else { + unsigned int pko_aura = __cvmx_pko3_aura_get(desc.port_node); + + cvmx_fpa3_gaura_t aura = + __cvmx_fpa3_gaura(pko_aura >> 10, pko_aura & 0x3ff); + + /* Allocate from internal AURA, size is 4KiB */ + desc.jump_buf_base_ptr = cvmx_fpa3_alloc(aura); + + if (!desc.jump_buf_base_ptr) + return -ENOMEM; + desc.jump_buf_size = 0; + } + + /* Native buffer-pointer for error checiing */ + bptr.u64 = packet.u64; + +#if CVMX_ENABLE_PARAMETER_CHECKING + if (seg_cnt == 1 && bptr.size == pko_command.s.total_bytes) { + /* + * Special case for native buffer pointer: + * This is the only case where the native pointer-style can be + * automatically identified, that is when an entire packet + * fits into a single buffer by the PKI. + * The use of the native buffers with this function + * should be avoided. + */ + debug("%s: WARNING: Native buffer-pointer\n", __func__); + } else { + /* The buffer ptr is assume to be received in legacy format */ + res = cvmx_pko3_legacy_bufptr_validate( + packet, pko_command.s.gather, pko_command.s.segs, + pko_command.s.total_bytes); + if (res < 0) { + debug("%s: ERROR: Not a valid packet pointer <%d>\n", + __func__, res); + return CVMX_PKO_CMD_QUEUE_INIT_ERROR; + } + } +#endif /* CVMX_ENABLE_PARAMETER_CHECKING */ + + /* Squash warnings */ + (void)bptr; + + /*** Translate legacy PKO fields into PKO3 PKO_SEND_HDR_S ***/ + + /* PKO_SEND_HDR_S is alwasy the first word in the command */ + hdr_s = (void *)&desc.cmd_words[0]; + hdr_s->u64 = 0; + + /* Copy total packet size */ + hdr_s->s.total = pko_command.s.total_bytes; + + /* Endianness */ + hdr_s->s.le = pko_command.s.le; + + /* N2 is the same meaning */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_X)) + hdr_s->s.n2 = 0; /* L2 allocate everything */ + else + hdr_s->s.n2 = pko_command.s.n2; + + /* DF bit has the same meaning */ + hdr_s->s.df = pko_command.s.dontfree; + + /* II bit has the same meaning */ + hdr_s->s.ii = pko_command.s.ignore_i; + + /* non-zero IP header offset requires L3/L4 checksum calculation */ + if (cvmx_unlikely(pko_command.s.ipoffp1 > 0)) { + u8 ipoff, ip0, l4_proto = 0; + + /* Get data pointer for header inspection below */ + if (pko_command.s.gather) { + cvmx_buf_ptr_t *p_ptr; + cvmx_buf_ptr_t blk; + + p_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, packet.s.addr)); + blk = p_ptr[0]; + data_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, blk.s.addr)); + } else { + data_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, packet.s.addr)); + } + + /* Get IP header offset */ + ipoff = pko_command.s.ipoffp1 - 1; + + /* Parse IP header, version, L4 protocol */ + hdr_s->s.l3ptr = ipoff; + ip0 = data_ptr[ipoff]; + + /* IPv4 header length, checksum offload */ + if ((ip0 >> 4) == 4) { + hdr_s->s.l4ptr = hdr_s->s.l3ptr + ((ip0 & 0xf) << 2); + l4_proto = data_ptr[ipoff + 9]; + hdr_s->s.ckl3 = 1; /* Only valid for IPv4 */ + } + /* IPv6 header length is fixed, no checksum */ + if ((ip0 >> 4) == 6) { + hdr_s->s.l4ptr = hdr_s->s.l3ptr + 40; + l4_proto = data_ptr[ipoff + 6]; + } + /* Set L4 checksum algo based on L4 protocol */ + if (l4_proto == 6) + hdr_s->s.ckl4 = /* TCP */ 2; + else if (l4_proto == 17) + hdr_s->s.ckl4 = /* UDP */ 1; + else if (l4_proto == 132) + hdr_s->s.ckl4 = /* SCTP */ 3; + else + hdr_s->s.ckl4 = /* Unknown */ 0; + } + + if (pko_command.s.gather) { + /* Process legacy gather list */ + cvmx_pko_buf_ptr_t gather_s; + cvmx_buf_ptr_t *p_ptr; + cvmx_buf_ptr_t blk; + unsigned int i; + + /* Get gather list pointer */ + p_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, packet.s.addr)); + blk = p_ptr[0]; + /* setup data_ptr */ + data_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, blk.s.addr)); + + for (i = 0; i < seg_cnt; i++) { + if (cvmx_unlikely(cvmx_pko3_legacy_pool( + &desc, blk.s.pool) < 0)) + return CVMX_PKO_NO_MEMORY; + + /* Insert PKO_SEND_GATHER_S for the current buffer */ + gather_s.u64 = 0; + gather_s.s.subdc3 = CVMX_PKO_SENDSUBDC_GATHER; + gather_s.s.size = blk.s.size; + gather_s.s.i = blk.s.i; + gather_s.s.addr = + cvmx_pko3_legacy_paddr(node, blk.s.addr); + + res = __cvmx_pko3_cmd_subdc_add(&desc, gather_s.u64); + if (res < 0) + return CVMX_PKO_NO_MEMORY; + + /* get next bufptr */ + blk = p_ptr[i + 1]; + } /* for i */ + + /* Free original gather-list buffer */ + if ((pko_command.s.ignore_i && !pko_command.s.dontfree) || + packet.s.i == pko_command.s.dontfree) + cvmx_fpa_free_nosync(p_ptr, packet.s.pool, + (i - 1) / 16 + 1); + } else { + /* Process legacy linked buffer list */ + cvmx_pko_buf_ptr_t gather_s; + cvmx_buf_ptr_t blk; + void *vptr; + + data_ptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, packet.s.addr)); + blk = packet; + + /* + * Legacy linked-buffers converted into flat gather list + * so that the AURA can optionally be changed to reflect + * the POOL number in the legacy pointers + */ + do { + /* Insert PKO_SEND_AURA_S if pool changes */ + if (cvmx_unlikely(cvmx_pko3_legacy_pool( + &desc, blk.s.pool) < 0)) + return CVMX_PKO_NO_MEMORY; + + /* Insert PKO_SEND_GATHER_S for the current buffer */ + gather_s.u64 = 0; + gather_s.s.subdc3 = CVMX_PKO_SENDSUBDC_GATHER; + gather_s.s.size = blk.s.size; + gather_s.s.i = blk.s.i; + gather_s.s.addr = + cvmx_pko3_legacy_paddr(node, blk.s.addr); + + res = __cvmx_pko3_cmd_subdc_add(&desc, gather_s.u64); + if (res < 0) + return CVMX_PKO_NO_MEMORY; + + /* Get the next buffer pointer */ + vptr = cvmx_phys_to_ptr( + cvmx_pko3_legacy_paddr(node, blk.s.addr)); + memcpy(&blk, vptr - sizeof(blk), sizeof(blk)); + + /* Decrement segment count */ + seg_cnt--; + + } while (seg_cnt > 0); + } + + /* This field indicates the presence of 3rd legacy command word */ + /* NOTE: legacy 3rd word may contain CN78XX native phys addr already */ + if (cvmx_unlikely(pko_command.s.rsp)) { + /* PTP bit in word3 is not supported - + * can not be distibguished from larger phys_addr[42..41] + */ + if (pko_command.s.wqp) { + /* <addr> is an SSO WQE */ + cvmx_wqe_word1_t *wqe_p; + cvmx_pko_send_work_t work_s; + + work_s.u64 = 0; + work_s.s.subdc4 = CVMX_PKO_SENDSUBDC_WORK; + work_s.s.addr = addr; + /* Assume WQE is legacy format too */ + wqe_p = cvmx_phys_to_ptr(addr + sizeof(u64)); + work_s.s.grp = wqe_p->cn38xx.grp; + work_s.s.tt = wqe_p->tag_type; + + res = __cvmx_pko3_cmd_subdc_add(&desc, work_s.u64); + } else { + cvmx_pko_send_mem_t mem_s; + /* MEMALG_SET broken on Pass1 */ + if (OCTEON_IS_MODEL(OCTEON_CN78XX_PASS1_0)) { + debug("%s: ERROR: PKO byte-clear not supported\n", + __func__); + } + /* <addr> is a physical address of byte clear */ + mem_s.u64 = 0; + mem_s.s.subdc4 = CVMX_PKO_SENDSUBDC_MEM; + mem_s.s.addr = addr; + mem_s.s.dsz = MEMDSZ_B8; + mem_s.s.alg = MEMALG_SET; + mem_s.s.offset = 0; + + res = __cvmx_pko3_cmd_subdc_add(&desc, mem_s.u64); + } + if (res < 0) + return CVMX_PKO_NO_MEMORY; + } + + /* FAU counter binding reg0 */ + if (pko_command.s.reg0) { + cvmx_pko_send_mem_t mem_s; + + debug("%s: Legacy FAU commands: reg0=%#x sz0=%#x\n", __func__, + pko_command.s.reg0, pko_command.s.size0); + mem_s.u64 = 0; + mem_s.s.subdc4 = CVMX_PKO_SENDSUBDC_MEM; + mem_s.s.addr = cvmx_ptr_to_phys( + CASTPTR(void, __cvmx_fau_sw_addr(pko_command.s.reg0))); + if (cvmx_likely(pko_command.s.size0 == CVMX_FAU_OP_SIZE_64)) + mem_s.s.dsz = MEMDSZ_B64; + else if (pko_command.s.size0 == CVMX_FAU_OP_SIZE_32) + mem_s.s.dsz = MEMDSZ_B32; + else if (pko_command.s.size0 == CVMX_FAU_OP_SIZE_16) + mem_s.s.dsz = MEMDSZ_B16; + else + mem_s.s.dsz = MEMDSZ_B8; + + if (mem_s.s.dsz == MEMDSZ_B16 || mem_s.s.dsz == MEMDSZ_B8) + debug("%s: ERROR: 8/16 bit decrement unsupported", + __func__); + + mem_s.s.offset = pko_command.s.subone0; + if (mem_s.s.offset) + mem_s.s.alg = MEMALG_SUB; + else + mem_s.s.alg = MEMALG_SUBLEN; + + res = __cvmx_pko3_cmd_subdc_add(&desc, mem_s.u64); + if (res < 0) + return CVMX_PKO_NO_MEMORY; + } + + /* FAU counter binding reg1 */ + if (cvmx_unlikely(pko_command.s.reg1)) { + cvmx_pko_send_mem_t mem_s; + + debug("%s: Legacy FAU commands: reg1=%#x sz1=%#x\n", __func__, + pko_command.s.reg1, pko_command.s.size1); + mem_s.u64 = 0; + mem_s.s.subdc4 = CVMX_PKO_SENDSUBDC_MEM; + mem_s.s.addr = cvmx_ptr_to_phys( + CASTPTR(void, __cvmx_fau_sw_addr(pko_command.s.reg1))); + if (cvmx_likely(pko_command.s.size1 == CVMX_FAU_OP_SIZE_64)) + mem_s.s.dsz = MEMDSZ_B64; + else if (pko_command.s.size1 == CVMX_FAU_OP_SIZE_32) + mem_s.s.dsz = MEMDSZ_B32; + else if (pko_command.s.size1 == CVMX_FAU_OP_SIZE_16) + mem_s.s.dsz = MEMDSZ_B16; + else + mem_s.s.dsz = MEMDSZ_B8; + + if (mem_s.s.dsz == MEMDSZ_B16 || mem_s.s.dsz == MEMDSZ_B8) + printf("%s: ERROR: 8/16 bit decrement unsupported", + __func__); + + mem_s.s.offset = pko_command.s.subone1; + if (mem_s.s.offset) + mem_s.s.alg = MEMALG_SUB; + else + mem_s.s.alg = MEMALG_SUBLEN; + + res = __cvmx_pko3_cmd_subdc_add(&desc, mem_s.u64); + if (res < 0) + return CVMX_PKO_NO_MEMORY; + } + + /* These PKO_HDR_S fields are not used: */ + /* hdr_s->s.ds does not have legacy equivalent, remains 0 */ + /* hdr_s->s.format has no legacy equivalent, remains 0 */ + + /*** Finalize command buffer ***/ + res = __cvmx_pko3_cmd_done(&desc); + if (res < 0) + return CVMX_PKO_NO_MEMORY; + + /*** Send the PKO3 command into the Descriptor Queue ***/ + pko_status = + __cvmx_pko3_lmtdma(desc.port_node, dq, desc.word_count, tag_sw); + + /*** Map PKO3 result codes to legacy return values ***/ + if (cvmx_likely(pko_status.s.dqstatus == PKO_DQSTATUS_PASS)) + return CVMX_PKO_SUCCESS; + + debug("%s: ERROR: failed to enqueue: %s\n", __func__, + pko_dqstatus_error(pko_status.s.dqstatus)); + + if (pko_status.s.dqstatus == PKO_DQSTATUS_ALREADY) + return CVMX_PKO_PORT_ALREADY_SETUP; + if (pko_status.s.dqstatus == PKO_DQSTATUS_NOFPABUF || + pko_status.s.dqstatus == PKO_DQSTATUS_NOPKOBUF) + return CVMX_PKO_NO_MEMORY; + if (pko_status.s.dqstatus == PKO_DQSTATUS_NOTCREATED) + return CVMX_PKO_INVALID_QUEUE; + if (pko_status.s.dqstatus == PKO_DQSTATUS_BADSTATE) + return CVMX_PKO_CMD_QUEUE_INIT_ERROR; + if (pko_status.s.dqstatus == PKO_DQSTATUS_SENDPKTDROP) + return CVMX_PKO_INVALID_PORT; + + return CVMX_PKO_INVALID_PORT; +}
Import cvmx-pko3-resources.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-pko3-resources.c | 213 ++++++++++++++++++++ 1 file changed, 213 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pko3-resources.c
diff --git a/arch/mips/mach-octeon/cvmx-pko3-resources.c b/arch/mips/mach-octeon/cvmx-pko3-resources.c new file mode 100644 index 000000000000..ab04e9acb558 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pko3-resources.c @@ -0,0 +1,213 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + * + * PKO resources. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +#define CVMX_GR_TAG_PKO_PORT_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'p', 'o', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_L2_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'l', '2', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_L3_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'l', '3', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_L4_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'l', '4', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_L5_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'l', '5', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_DESCR_QUEUES(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'd', 'e', 'q', '_', \ + ((x) + '0'), '.', '.', '.', '.') +#define CVMX_GR_TAG_PKO_PORT_INDEX(x) \ + cvmx_get_gr_tag('c', 'v', 'm', '_', 'p', 'k', 'o', 'p', 'i', 'd', '_', \ + ((x) + '0'), '.', '.', '.', '.') + +/* + * @INRWENAL + * Per-DQ parameters, current and maximum queue depth counters + */ +cvmx_pko3_dq_params_t *__cvmx_pko3_dq_params[CVMX_MAX_NODES]; + +static const short cvmx_pko_num_queues_78XX[256] = { + [CVMX_PKO_PORT_QUEUES] = 32, [CVMX_PKO_L2_QUEUES] = 512, + [CVMX_PKO_L3_QUEUES] = 512, [CVMX_PKO_L4_QUEUES] = 1024, + [CVMX_PKO_L5_QUEUES] = 1024, [CVMX_PKO_DESCR_QUEUES] = 1024 +}; + +static const short cvmx_pko_num_queues_73XX[256] = { + [CVMX_PKO_PORT_QUEUES] = 16, [CVMX_PKO_L2_QUEUES] = 256, + [CVMX_PKO_L3_QUEUES] = 256, [CVMX_PKO_L4_QUEUES] = 0, + [CVMX_PKO_L5_QUEUES] = 0, [CVMX_PKO_DESCR_QUEUES] = 256 +}; + +int cvmx_pko3_num_level_queues(enum cvmx_pko3_level_e level) +{ + unsigned int nq = 0, ne = 0; + + if (OCTEON_IS_MODEL(OCTEON_CN78XX)) { + ne = NUM_ELEMENTS(cvmx_pko_num_queues_78XX); + nq = cvmx_pko_num_queues_78XX[level]; + } + if (OCTEON_IS_MODEL(OCTEON_CN73XX) || OCTEON_IS_MODEL(OCTEON_CNF75XX)) { + ne = NUM_ELEMENTS(cvmx_pko_num_queues_73XX); + nq = cvmx_pko_num_queues_73XX[level]; + } + + if (nq == 0 || level >= ne) { + printf("ERROR: %s: queue level %#x invalid\n", __func__, level); + return -1; + } + + return nq; +} + +static inline struct global_resource_tag +__cvmx_pko_get_queues_resource_tag(int node, enum cvmx_pko3_level_e queue_level) +{ + if (cvmx_pko3_num_level_queues(queue_level) == 0) { + printf("ERROR: %s: queue level %#x invalid\n", __func__, + queue_level); + return CVMX_GR_TAG_INVALID; + } + + switch (queue_level) { + case CVMX_PKO_PORT_QUEUES: + return CVMX_GR_TAG_PKO_PORT_QUEUES(node); + case CVMX_PKO_L2_QUEUES: + return CVMX_GR_TAG_PKO_L2_QUEUES(node); + case CVMX_PKO_L3_QUEUES: + return CVMX_GR_TAG_PKO_L3_QUEUES(node); + case CVMX_PKO_L4_QUEUES: + return CVMX_GR_TAG_PKO_L4_QUEUES(node); + case CVMX_PKO_L5_QUEUES: + return CVMX_GR_TAG_PKO_L5_QUEUES(node); + case CVMX_PKO_DESCR_QUEUES: + return CVMX_GR_TAG_PKO_DESCR_QUEUES(node); + default: + printf("ERROR: %s: queue level %#x invalid\n", __func__, + queue_level); + return CVMX_GR_TAG_INVALID; + } +} + +/** + * Allocate or reserve a pko resource - called by wrapper functions + * @param tag processed global resource tag + * @param base_queue if specified the queue to reserve + * @param owner to be specified for resource + * @param num_queues to allocate + * @param max_num_queues for global resource + */ +int cvmx_pko_alloc_global_resource(struct global_resource_tag tag, + int base_queue, int owner, int num_queues, + int max_num_queues) +{ + int res; + + if (cvmx_create_global_resource_range(tag, max_num_queues)) { + debug("ERROR: Failed to create PKO3 resource: %lx-%lx\n", + (unsigned long)tag.hi, (unsigned long)tag.lo); + return -1; + } + if (base_queue >= 0) { + res = cvmx_reserve_global_resource_range(tag, owner, base_queue, + num_queues); + } else { + res = cvmx_allocate_global_resource_range(tag, owner, + num_queues, 1); + } + if (res < 0) { + debug("ERROR: Failed to %s PKO3 tag %lx:%lx, %i %i %i %i.\n", + ((base_queue < 0) ? "allocate" : "reserve"), + (unsigned long)tag.hi, (unsigned long)tag.lo, base_queue, + owner, num_queues, max_num_queues); + return -1; + } + + return res; +} + +/** + * Allocate or reserve PKO queues - wrapper for cvmx_pko_alloc_global_resource + * + * @param node on which to allocate/reserve PKO queues + * @param level of PKO queue + * @param owner of reserved/allocated resources + * @param base_queue to start reservation/allocatation + * @param num_queues number of queues to be allocated + * @return 0 on success, -1 on failure + */ +int cvmx_pko_alloc_queues(int node, int level, int owner, int base_queue, + int num_queues) +{ + struct global_resource_tag tag = + __cvmx_pko_get_queues_resource_tag(node, level); + int max_num_queues = cvmx_pko3_num_level_queues(level); + + return cvmx_pko_alloc_global_resource(tag, base_queue, owner, + num_queues, max_num_queues); +} + +/** + * @INTERNAL + * + * Initialize the pointer to the descriptor queue parameter table. + * The table is one named block per node, and may be shared between + * applications. + */ +int __cvmx_pko3_dq_param_setup(unsigned int node) +{ + return 0; +}
Import cvmx-pko-internal-ports-range.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- .../cvmx-pko-internal-ports-range.c | 99 +++++++++++++++++++ 1 file changed, 99 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c
diff --git a/arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c b/arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c new file mode 100644 index 000000000000..694b4e3d9c55 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c @@ -0,0 +1,99 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <errno.h> +#include <log.h> +#include <time.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> +#include <mach/cvmx-range.h> +#include <mach/cvmx-global-resources.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-ciu-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ilk-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pcsxx-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-xcv-defs.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-ilk.h> +#include <mach/cvmx-ipd.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-pko3.h> +#include <mach/cvmx-pko3-queue.h> +#include <mach/cvmx-pko3-resources.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> +#include <mach/cvmx-helper-util.h> +#include <mach/cvmx-helper-pki.h> + +union interface_port { + struct { + int port; + int interface; + } s; + u64 u64; +}; + +static int dbg; + +static int port_range_init; + +int __cvmx_pko_internal_ports_range_init(void) +{ + int rv = 0; + + if (port_range_init) + return 0; + port_range_init = 1; + rv = cvmx_create_global_resource_range(CVMX_GR_TAG_PKO_IPORTS, + CVMX_HELPER_CFG_MAX_PKO_QUEUES); + if (rv != 0) + debug("ERROR : Failed to initialize pko internal port range\n"); + return rv; +} + +int cvmx_pko_internal_ports_alloc(int xiface, int port, u64 count) +{ + int ret_val = -1; + union interface_port inf_port; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + __cvmx_pko_internal_ports_range_init(); + inf_port.s.interface = xi.interface; + inf_port.s.port = port; + ret_val = cvmx_allocate_global_resource_range(CVMX_GR_TAG_PKO_IPORTS, + inf_port.u64, count, 1); + if (dbg) + debug("internal port alloc : port=%02d base=%02d count=%02d\n", + (int)port, ret_val, (int)count); + if (ret_val == -1) + return ret_val; + cvmx_cfg_port[xi.node][xi.interface][port].ccpp_pko_port_base = ret_val; + cvmx_cfg_port[xi.node][xi.interface][port].ccpp_pko_num_ports = count; + return 0; +}
Import cvmx-qlm-tables.c from 2013 U-Boot. It will be used by the later added drivers to support networking on the MIPS Octeon II / III platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-qlm-tables.c | 292 ++++++++++++++++++++++++ 1 file changed, 292 insertions(+) create mode 100644 arch/mips/mach-octeon/cvmx-qlm-tables.c
diff --git a/arch/mips/mach-octeon/cvmx-qlm-tables.c b/arch/mips/mach-octeon/cvmx-qlm-tables.c new file mode 100644 index 000000000000..ca2289225d37 --- /dev/null +++ b/arch/mips/mach-octeon/cvmx-qlm-tables.c @@ -0,0 +1,292 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <mach/cvmx-regs.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_qlm.h> + +const __cvmx_qlm_jtag_field_t __cvmx_qlm_jtag_field_cn63xx[] = { + { "prbs_err_cnt", 299, 252 }, // prbs_err_cnt[47..0] + { "prbs_lock", 251, 251 }, // prbs_lock + { "jtg_prbs_rst_n", 250, 250 }, // jtg_prbs_rst_n + { "jtg_run_prbs31", 249, 249 }, // jtg_run_prbs31 + { "jtg_run_prbs7", 248, 248 }, // jtg_run_prbs7 + { "Unused1", 247, 245 }, // 0 + { "cfg_pwrup_set", 244, 244 }, // cfg_pwrup_set + { "cfg_pwrup_clr", 243, 243 }, // cfg_pwrup_clr + { "cfg_rst_n_set", 242, 242 }, // cfg_rst_n_set + { "cfg_rst_n_clr", 241, 241 }, // cfg_rst_n_clr + { "cfg_tx_idle_set", 240, 240 }, // cfg_tx_idle_set + { "cfg_tx_idle_clr", 239, 239 }, // cfg_tx_idle_clr + { "cfg_tx_byp", 238, 238 }, // cfg_tx_byp + { "cfg_tx_byp_inv", 237, 237 }, // cfg_tx_byp_inv + { "cfg_tx_byp_val", 236, 227 }, // cfg_tx_byp_val[9..0] + { "cfg_loopback", 226, 226 }, // cfg_loopback + { "shlpbck", 225, 224 }, // shlpbck[1..0] + { "sl_enable", 223, 223 }, // sl_enable + { "sl_posedge_sample", 222, 222 }, // sl_posedge_sample + { "trimen", 221, 220 }, // trimen[1..0] + { "serdes_tx_byp", 219, 219 }, // serdes_tx_byp + { "serdes_pll_byp", 218, 218 }, // serdes_pll_byp + { "lowf_byp", 217, 217 }, // lowf_byp + { "spdsel_byp", 216, 216 }, // spdsel_byp + { "div4_byp", 215, 215 }, // div4_byp + { "clkf_byp", 214, 208 }, // clkf_byp[6..0] + { "Unused2", 207, 206 }, // 0 + { "biasdrv_hs_ls_byp", 205, 201 }, // biasdrv_hs_ls_byp[4..0] + { "tcoeff_hf_ls_byp", 200, 197 }, // tcoeff_hf_ls_byp[3..0] + { "biasdrv_hf_byp", 196, 192 }, // biasdrv_hf_byp[4..0] + { "tcoeff_hf_byp", 191, 188 }, // tcoeff_hf_byp[3..0] + { "Unused3", 187, 186 }, // 0 + { "biasdrv_lf_ls_byp", 185, 181 }, // biasdrv_lf_ls_byp[4..0] + { "tcoeff_lf_ls_byp", 180, 177 }, // tcoeff_lf_ls_byp[3..0] + { "biasdrv_lf_byp", 176, 172 }, // biasdrv_lf_byp[4..0] + { "tcoeff_lf_byp", 171, 168 }, // tcoeff_lf_byp[3..0] + { "Unused4", 167, 167 }, // 0 + { "interpbw", 166, 162 }, // interpbw[4..0] + { "pll_cpb", 161, 159 }, // pll_cpb[2..0] + { "pll_cps", 158, 156 }, // pll_cps[2..0] + { "pll_diffamp", 155, 152 }, // pll_diffamp[3..0] + { "Unused5", 151, 150 }, // 0 + { "cfg_rx_idle_set", 149, 149 }, // cfg_rx_idle_set + { "cfg_rx_idle_clr", 148, 148 }, // cfg_rx_idle_clr + { "cfg_rx_idle_thr", 147, 144 }, // cfg_rx_idle_thr[3..0] + { "cfg_com_thr", 143, 140 }, // cfg_com_thr[3..0] + { "cfg_rx_offset", 139, 136 }, // cfg_rx_offset[3..0] + { "cfg_skp_max", 135, 132 }, // cfg_skp_max[3..0] + { "cfg_skp_min", 131, 128 }, // cfg_skp_min[3..0] + { "cfg_fast_pwrup", 127, 127 }, // cfg_fast_pwrup + { "Unused6", 126, 100 }, // 0 + { "detected_n", 99, 99 }, // detected_n + { "detected_p", 98, 98 }, // detected_p + { "dbg_res_rx", 97, 94 }, // dbg_res_rx[3..0] + { "dbg_res_tx", 93, 90 }, // dbg_res_tx[3..0] + { "cfg_tx_pol_set", 89, 89 }, // cfg_tx_pol_set + { "cfg_tx_pol_clr", 88, 88 }, // cfg_tx_pol_clr + { "cfg_rx_pol_set", 87, 87 }, // cfg_rx_pol_set + { "cfg_rx_pol_clr", 86, 86 }, // cfg_rx_pol_clr + { "cfg_rxd_set", 85, 85 }, // cfg_rxd_set + { "cfg_rxd_clr", 84, 84 }, // cfg_rxd_clr + { "cfg_rxd_wait", 83, 80 }, // cfg_rxd_wait[3..0] + { "cfg_cdr_limit", 79, 79 }, // cfg_cdr_limit + { "cfg_cdr_rotate", 78, 78 }, // cfg_cdr_rotate + { "cfg_cdr_bw_ctl", 77, 76 }, // cfg_cdr_bw_ctl[1..0] + { "cfg_cdr_trunc", 75, 74 }, // cfg_cdr_trunc[1..0] + { "cfg_cdr_rqoffs", 73, 64 }, // cfg_cdr_rqoffs[9..0] + { "cfg_cdr_inc2", 63, 58 }, // cfg_cdr_inc2[5..0] + { "cfg_cdr_inc1", 57, 52 }, // cfg_cdr_inc1[5..0] + { "fusopt_voter_sync", 51, 51 }, // fusopt_voter_sync + { "rndt", 50, 50 }, // rndt + { "hcya", 49, 49 }, // hcya + { "hyst", 48, 48 }, // hyst + { "idle_dac", 47, 45 }, // idle_dac[2..0] + { "bg_ref_sel", 44, 44 }, // bg_ref_sel + { "ic50dac", 43, 39 }, // ic50dac[4..0] + { "ir50dac", 38, 34 }, // ir50dac[4..0] + { "tx_rout_comp_bypass", 33, 33 }, // tx_rout_comp_bypass + { "tx_rout_comp_value", 32, 29 }, // tx_rout_comp_value[3..0] + { "tx_res_offset", 28, 25 }, // tx_res_offset[3..0] + { "rx_rout_comp_bypass", 24, 24 }, // rx_rout_comp_bypass + { "rx_rout_comp_value", 23, 20 }, // rx_rout_comp_value[3..0] + { "rx_res_offset", 19, 16 }, // rx_res_offset[3..0] + { "rx_cap_gen2", 15, 12 }, // rx_cap_gen2[3..0] + { "rx_eq_gen2", 11, 8 }, // rx_eq_gen2[3..0] + { "rx_cap_gen1", 7, 4 }, // rx_cap_gen1[3..0] + { "rx_eq_gen1", 3, 0 }, // rx_eq_gen1[3..0] + { NULL, -1, -1 } +}; + +const __cvmx_qlm_jtag_field_t __cvmx_qlm_jtag_field_cn66xx[] = { + { "prbs_err_cnt", 303, 256 }, // prbs_err_cnt[47..0] + { "prbs_lock", 255, 255 }, // prbs_lock + { "jtg_prbs_rx_rst_n", 254, 254 }, // jtg_prbs_rx_rst_n + { "jtg_prbs_tx_rst_n", 253, 253 }, // jtg_prbs_tx_rst_n + { "jtg_prbs_mode", 252, 251 }, // jtg_prbs_mode[252:251] + { "jtg_prbs_rst_n", 250, 250 }, // jtg_prbs_rst_n + { "jtg_run_prbs31", 249, + 249 }, // jtg_run_prbs31 - Use jtg_prbs_mode instead + { "jtg_run_prbs7", 248, + 248 }, // jtg_run_prbs7 - Use jtg_prbs_mode instead + { "Unused1", 247, 246 }, // 0 + { "div5_byp", 245, 245 }, // div5_byp + { "cfg_pwrup_set", 244, 244 }, // cfg_pwrup_set + { "cfg_pwrup_clr", 243, 243 }, // cfg_pwrup_clr + { "cfg_rst_n_set", 242, 242 }, // cfg_rst_n_set + { "cfg_rst_n_clr", 241, 241 }, // cfg_rst_n_clr + { "cfg_tx_idle_set", 240, 240 }, // cfg_tx_idle_set + { "cfg_tx_idle_clr", 239, 239 }, // cfg_tx_idle_clr + { "cfg_tx_byp", 238, 238 }, // cfg_tx_byp + { "cfg_tx_byp_inv", 237, 237 }, // cfg_tx_byp_inv + { "cfg_tx_byp_val", 236, 227 }, // cfg_tx_byp_val[9..0] + { "cfg_loopback", 226, 226 }, // cfg_loopback + { "shlpbck", 225, 224 }, // shlpbck[1..0] + { "sl_enable", 223, 223 }, // sl_enable + { "sl_posedge_sample", 222, 222 }, // sl_posedge_sample + { "trimen", 221, 220 }, // trimen[1..0] + { "serdes_tx_byp", 219, 219 }, // serdes_tx_byp + { "serdes_pll_byp", 218, 218 }, // serdes_pll_byp + { "lowf_byp", 217, 217 }, // lowf_byp + { "spdsel_byp", 216, 216 }, // spdsel_byp + { "div4_byp", 215, 215 }, // div4_byp + { "clkf_byp", 214, 208 }, // clkf_byp[6..0] + { "biasdrv_hs_ls_byp", 207, 203 }, // biasdrv_hs_ls_byp[4..0] + { "tcoeff_hf_ls_byp", 202, 198 }, // tcoeff_hf_ls_byp[4..0] + { "biasdrv_hf_byp", 197, 193 }, // biasdrv_hf_byp[4..0] + { "tcoeff_hf_byp", 192, 188 }, // tcoeff_hf_byp[4..0] + { "biasdrv_lf_ls_byp", 187, 183 }, // biasdrv_lf_ls_byp[4..0] + { "tcoeff_lf_ls_byp", 182, 178 }, // tcoeff_lf_ls_byp[4..0] + { "biasdrv_lf_byp", 177, 173 }, // biasdrv_lf_byp[4..0] + { "tcoeff_lf_byp", 172, 168 }, // tcoeff_lf_byp[4..0] + { "Unused4", 167, 167 }, // 0 + { "interpbw", 166, 162 }, // interpbw[4..0] + { "pll_cpb", 161, 159 }, // pll_cpb[2..0] + { "pll_cps", 158, 156 }, // pll_cps[2..0] + { "pll_diffamp", 155, 152 }, // pll_diffamp[3..0] + { "cfg_err_thr", 151, 150 }, // cfg_err_thr + { "cfg_rx_idle_set", 149, 149 }, // cfg_rx_idle_set + { "cfg_rx_idle_clr", 148, 148 }, // cfg_rx_idle_clr + { "cfg_rx_idle_thr", 147, 144 }, // cfg_rx_idle_thr[3..0] + { "cfg_com_thr", 143, 140 }, // cfg_com_thr[3..0] + { "cfg_rx_offset", 139, 136 }, // cfg_rx_offset[3..0] + { "cfg_skp_max", 135, 132 }, // cfg_skp_max[3..0] + { "cfg_skp_min", 131, 128 }, // cfg_skp_min[3..0] + { "cfg_fast_pwrup", 127, 127 }, // cfg_fast_pwrup + { "Unused6", 126, 101 }, // 0 + { "cfg_indep_dis", 100, 100 }, // cfg_indep_dis + { "detected_n", 99, 99 }, // detected_n + { "detected_p", 98, 98 }, // detected_p + { "dbg_res_rx", 97, 94 }, // dbg_res_rx[3..0] + { "dbg_res_tx", 93, 90 }, // dbg_res_tx[3..0] + { "cfg_tx_pol_set", 89, 89 }, // cfg_tx_pol_set + { "cfg_tx_pol_clr", 88, 88 }, // cfg_tx_pol_clr + { "cfg_rx_pol_set", 87, 87 }, // cfg_rx_pol_set + { "cfg_rx_pol_clr", 86, 86 }, // cfg_rx_pol_clr + { "cfg_rxd_set", 85, 85 }, // cfg_rxd_set + { "cfg_rxd_clr", 84, 84 }, // cfg_rxd_clr + { "cfg_rxd_wait", 83, 80 }, // cfg_rxd_wait[3..0] + { "cfg_cdr_limit", 79, 79 }, // cfg_cdr_limit + { "cfg_cdr_rotate", 78, 78 }, // cfg_cdr_rotate + { "cfg_cdr_bw_ctl", 77, 76 }, // cfg_cdr_bw_ctl[1..0] + { "cfg_cdr_trunc", 75, 74 }, // cfg_cdr_trunc[1..0] + { "cfg_cdr_rqoffs", 73, 64 }, // cfg_cdr_rqoffs[9..0] + { "cfg_cdr_inc2", 63, 58 }, // cfg_cdr_inc2[5..0] + { "cfg_cdr_inc1", 57, 52 }, // cfg_cdr_inc1[5..0] + { "fusopt_voter_sync", 51, 51 }, // fusopt_voter_sync + { "rndt", 50, 50 }, // rndt + { "hcya", 49, 49 }, // hcya + { "hyst", 48, 48 }, // hyst + { "idle_dac", 47, 45 }, // idle_dac[2..0] + { "bg_ref_sel", 44, 44 }, // bg_ref_sel + { "ic50dac", 43, 39 }, // ic50dac[4..0] + { "ir50dac", 38, 34 }, // ir50dac[4..0] + { "tx_rout_comp_bypass", 33, 33 }, // tx_rout_comp_bypass + { "tx_rout_comp_value", 32, 29 }, // tx_rout_comp_value[3..0] + { "tx_res_offset", 28, 25 }, // tx_res_offset[3..0] + { "rx_rout_comp_bypass", 24, 24 }, // rx_rout_comp_bypass + { "rx_rout_comp_value", 23, 20 }, // rx_rout_comp_value[3..0] + { "rx_res_offset", 19, 16 }, // rx_res_offset[3..0] + { "rx_cap_gen2", 15, 12 }, // rx_cap_gen2[3..0] + { "rx_eq_gen2", 11, 8 }, // rx_eq_gen2[3..0] + { "rx_cap_gen1", 7, 4 }, // rx_cap_gen1[3..0] + { "rx_eq_gen1", 3, 0 }, // rx_eq_gen1[3..0] + { NULL, -1, -1 } +}; + +const __cvmx_qlm_jtag_field_t __cvmx_qlm_jtag_field_cn68xx[] = { + { "prbs_err_cnt", 303, 256 }, // prbs_err_cnt[47..0] + { "prbs_lock", 255, 255 }, // prbs_lock + { "jtg_prbs_rx_rst_n", 254, 254 }, // jtg_prbs_rx_rst_n + { "jtg_prbs_tx_rst_n", 253, 253 }, // jtg_prbs_tx_rst_n + { "jtg_prbs_mode", 252, 251 }, // jtg_prbs_mode[252:251] + { "jtg_prbs_rst_n", 250, 250 }, // jtg_prbs_rst_n + { "jtg_run_prbs31", 249, + 249 }, // jtg_run_prbs31 - Use jtg_prbs_mode instead + { "jtg_run_prbs7", 248, + 248 }, // jtg_run_prbs7 - Use jtg_prbs_mode instead + { "Unused1", 247, 245 }, // 0 + { "cfg_pwrup_set", 244, 244 }, // cfg_pwrup_set + { "cfg_pwrup_clr", 243, 243 }, // cfg_pwrup_clr + { "cfg_rst_n_set", 242, 242 }, // cfg_rst_n_set + { "cfg_rst_n_clr", 241, 241 }, // cfg_rst_n_clr + { "cfg_tx_idle_set", 240, 240 }, // cfg_tx_idle_set + { "cfg_tx_idle_clr", 239, 239 }, // cfg_tx_idle_clr + { "cfg_tx_byp", 238, 238 }, // cfg_tx_byp + { "cfg_tx_byp_inv", 237, 237 }, // cfg_tx_byp_inv + { "cfg_tx_byp_val", 236, 227 }, // cfg_tx_byp_val[9..0] + { "cfg_loopback", 226, 226 }, // cfg_loopback + { "shlpbck", 225, 224 }, // shlpbck[1..0] + { "sl_enable", 223, 223 }, // sl_enable + { "sl_posedge_sample", 222, 222 }, // sl_posedge_sample + { "trimen", 221, 220 }, // trimen[1..0] + { "serdes_tx_byp", 219, 219 }, // serdes_tx_byp + { "serdes_pll_byp", 218, 218 }, // serdes_pll_byp + { "lowf_byp", 217, 217 }, // lowf_byp + { "spdsel_byp", 216, 216 }, // spdsel_byp + { "div4_byp", 215, 215 }, // div4_byp + { "clkf_byp", 214, 208 }, // clkf_byp[6..0] + { "biasdrv_hs_ls_byp", 207, 203 }, // biasdrv_hs_ls_byp[4..0] + { "tcoeff_hf_ls_byp", 202, 198 }, // tcoeff_hf_ls_byp[4..0] + { "biasdrv_hf_byp", 197, 193 }, // biasdrv_hf_byp[4..0] + { "tcoeff_hf_byp", 192, 188 }, // tcoeff_hf_byp[4..0] + { "biasdrv_lf_ls_byp", 187, 183 }, // biasdrv_lf_ls_byp[4..0] + { "tcoeff_lf_ls_byp", 182, 178 }, // tcoeff_lf_ls_byp[4..0] + { "biasdrv_lf_byp", 177, 173 }, // biasdrv_lf_byp[4..0] + { "tcoeff_lf_byp", 172, 168 }, // tcoeff_lf_byp[4..0] + { "Unused4", 167, 167 }, // 0 + { "interpbw", 166, 162 }, // interpbw[4..0] + { "pll_cpb", 161, 159 }, // pll_cpb[2..0] + { "pll_cps", 158, 156 }, // pll_cps[2..0] + { "pll_diffamp", 155, 152 }, // pll_diffamp[3..0] + { "cfg_err_thr", 151, 150 }, // cfg_err_thr + { "cfg_rx_idle_set", 149, 149 }, // cfg_rx_idle_set + { "cfg_rx_idle_clr", 148, 148 }, // cfg_rx_idle_clr + { "cfg_rx_idle_thr", 147, 144 }, // cfg_rx_idle_thr[3..0] + { "cfg_com_thr", 143, 140 }, // cfg_com_thr[3..0] + { "cfg_rx_offset", 139, 136 }, // cfg_rx_offset[3..0] + { "cfg_skp_max", 135, 132 }, // cfg_skp_max[3..0] + { "cfg_skp_min", 131, 128 }, // cfg_skp_min[3..0] + { "cfg_fast_pwrup", 127, 127 }, // cfg_fast_pwrup + { "Unused6", 126, 100 }, // 0 + { "detected_n", 99, 99 }, // detected_n + { "detected_p", 98, 98 }, // detected_p + { "dbg_res_rx", 97, 94 }, // dbg_res_rx[3..0] + { "dbg_res_tx", 93, 90 }, // dbg_res_tx[3..0] + { "cfg_tx_pol_set", 89, 89 }, // cfg_tx_pol_set + { "cfg_tx_pol_clr", 88, 88 }, // cfg_tx_pol_clr + { "cfg_rx_pol_set", 87, 87 }, // cfg_rx_pol_set + { "cfg_rx_pol_clr", 86, 86 }, // cfg_rx_pol_clr + { "cfg_rxd_set", 85, 85 }, // cfg_rxd_set + { "cfg_rxd_clr", 84, 84 }, // cfg_rxd_clr + { "cfg_rxd_wait", 83, 80 }, // cfg_rxd_wait[3..0] + { "cfg_cdr_limit", 79, 79 }, // cfg_cdr_limit + { "cfg_cdr_rotate", 78, 78 }, // cfg_cdr_rotate + { "cfg_cdr_bw_ctl", 77, 76 }, // cfg_cdr_bw_ctl[1..0] + { "cfg_cdr_trunc", 75, 74 }, // cfg_cdr_trunc[1..0] + { "cfg_cdr_rqoffs", 73, 64 }, // cfg_cdr_rqoffs[9..0] + { "cfg_cdr_inc2", 63, 58 }, // cfg_cdr_inc2[5..0] + { "cfg_cdr_inc1", 57, 52 }, // cfg_cdr_inc1[5..0] + { "fusopt_voter_sync", 51, 51 }, // fusopt_voter_sync + { "rndt", 50, 50 }, // rndt + { "hcya", 49, 49 }, // hcya + { "hyst", 48, 48 }, // hyst + { "idle_dac", 47, 45 }, // idle_dac[2..0] + { "bg_ref_sel", 44, 44 }, // bg_ref_sel + { "ic50dac", 43, 39 }, // ic50dac[4..0] + { "ir50dac", 38, 34 }, // ir50dac[4..0] + { "tx_rout_comp_bypass", 33, 33 }, // tx_rout_comp_bypass + { "tx_rout_comp_value", 32, 29 }, // tx_rout_comp_value[3..0] + { "tx_res_offset", 28, 25 }, // tx_res_offset[3..0] + { "rx_rout_comp_bypass", 24, 24 }, // rx_rout_comp_bypass + { "rx_rout_comp_value", 23, 20 }, // rx_rout_comp_value[3..0] + { "rx_res_offset", 19, 16 }, // rx_res_offset[3..0] + { "rx_cap_gen2", 15, 12 }, // rx_cap_gen2[3..0] + { "rx_eq_gen2", 11, 8 }, // rx_eq_gen2[3..0] + { "rx_cap_gen1", 7, 4 }, // rx_cap_gen1[3..0] + { "rx_eq_gen1", 3, 0 }, // rx_eq_gen1[3..0] + { NULL, -1, -1 } +};
This patch includes misc changes to already present Octeon MIPS C files files, which are necessary for the upcoming ethernet support.
The changes are mostly: - DM GPIO & I2C infrastructure - Coding style cleanup while reworking of the code
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cvmx-bootmem.c | 3 +- arch/mips/mach-octeon/cvmx-helper-cfg.c | 655 +---------------- arch/mips/mach-octeon/cvmx-helper-fdt.c | 898 ++++++----------------- arch/mips/mach-octeon/cvmx-helper-util.c | 248 ------- arch/mips/mach-octeon/cvmx-helper.c | 845 +-------------------- 5 files changed, 230 insertions(+), 2419 deletions(-)
diff --git a/arch/mips/mach-octeon/cvmx-bootmem.c b/arch/mips/mach-octeon/cvmx-bootmem.c index 9bd644d68bd8..52e58b4c1761 100644 --- a/arch/mips/mach-octeon/cvmx-bootmem.c +++ b/arch/mips/mach-octeon/cvmx-bootmem.c @@ -1189,7 +1189,7 @@ s64 cvmx_bootmem_phy_mem_list_init(u64 mem_size, if (mem_size > OCTEON_DDR1_SIZE) { __cvmx_bootmem_phy_free(OCTEON_DDR1_BASE, OCTEON_DDR1_SIZE, 0); __cvmx_bootmem_phy_free(OCTEON_DDR2_BASE, - mem_size - OCTEON_DDR1_SIZE, 0); + mem_size - OCTEON_DDR2_BASE, 0); } else { __cvmx_bootmem_phy_free(OCTEON_DDR1_BASE, mem_size, 0); } @@ -1349,7 +1349,6 @@ s64 cvmx_bootmem_phy_mem_list_init_multi(u8 node_mask, addr += sizeof(struct cvmx_bootmem_named_block_desc); }
- // test-only: DEBUG ifdef??? cvmx_bootmem_phy_list_print();
return 1; diff --git a/arch/mips/mach-octeon/cvmx-helper-cfg.c b/arch/mips/mach-octeon/cvmx-helper-cfg.c index 494108f0cdb7..a3f4ff0eeb5f 100644 --- a/arch/mips/mach-octeon/cvmx-helper-cfg.c +++ b/arch/mips/mach-octeon/cvmx-helper-cfg.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Marvell International Ltd. + * Copyright (C) 2020-2022 Marvell International Ltd. * * Helper Functions for the Configuration Framework */ @@ -100,7 +100,6 @@ static u64 cvmx_cfg_opts[CVMX_HELPER_CFG_OPT_MAX] = { static int cvmx_cfg_max_pko_engines; /* # of PKO DMA engines allocated */ static int cvmx_pko_queue_alloc(u64 port, int count); static void cvmx_init_port_cfg(void); -static const int dbg;
int __cvmx_helper_cfg_pknd(int xiface, int index) { @@ -184,16 +183,6 @@ int __cvmx_helper_cfg_pko_max_engine(void) return cvmx_cfg_max_pko_engines; }
-int cvmx_helper_cfg_opt_set(cvmx_helper_cfg_option_t opt, uint64_t val) -{ - if (opt >= CVMX_HELPER_CFG_OPT_MAX) - return -1; - - cvmx_cfg_opts[opt] = val; - - return 0; -} - uint64_t cvmx_helper_cfg_opt_get(cvmx_helper_cfg_option_t opt) { if (opt >= CVMX_HELPER_CFG_OPT_MAX) @@ -298,18 +287,6 @@ int cvmx_pko_queue_init_from_cvmx_config_non_pknd(void) return 0; }
-int cvmx_helper_pko_queue_config_get(int node, cvmx_user_static_pko_queue_config_t *cfg) -{ - *cfg = __cvmx_pko_queue_static_config[node]; - return 0; -} - -int cvmx_helper_pko_queue_config_set(int node, cvmx_user_static_pko_queue_config_t *cfg) -{ - __cvmx_pko_queue_static_config[node] = *cfg; - return 0; -} - static int queue_range_init;
int init_cvmx_pko_que_range(void) @@ -376,91 +353,6 @@ static int cvmx_pko_queue_alloc(u64 port, int count) return 0; }
-/* - * return the queues for "port" - * - * @param port the port for which the queues are returned - * - * Return: 0 on success - * -1 on failure - */ -int cvmx_pko_queue_free(uint64_t port) -{ - int ret_val = -1; - - init_cvmx_pko_que_range(); - if (port >= CVMX_HELPER_CFG_MAX_PKO_QUEUES) { - debug("ERROR: %s port=%d > %d", __func__, (int)port, - CVMX_HELPER_CFG_MAX_PKO_QUEUES); - return -1; - } - - ret_val = cvmx_free_global_resource_range_with_base( - CVMX_GR_TAG_PKO_QUEUES, cvmx_pko_queue_table[port].ccppp_queue_base, - cvmx_pko_queue_table[port].ccppp_num_queues); - if (ret_val != 0) - return ret_val; - - cvmx_pko_queue_table[port].ccppp_num_queues = 0; - cvmx_pko_queue_table[port].ccppp_queue_base = CVMX_HELPER_CFG_INVALID_VALUE; - ret_val = 0; - return ret_val; -} - -void cvmx_pko_queue_free_all(void) -{ - int i; - - for (i = 0; i < CVMX_HELPER_CFG_MAX_PKO_PORT; i++) - if (cvmx_pko_queue_table[i].ccppp_queue_base != - CVMX_HELPER_CFG_INVALID_VALUE) - cvmx_pko_queue_free(i); -} - -void cvmx_pko_queue_show(void) -{ - int i; - - cvmx_show_global_resource_range(CVMX_GR_TAG_PKO_QUEUES); - for (i = 0; i < CVMX_HELPER_CFG_MAX_PKO_PORT; i++) - if (cvmx_pko_queue_table[i].ccppp_queue_base != - CVMX_HELPER_CFG_INVALID_VALUE) - debug("port=%d que_base=%d que_num=%d\n", i, - (int)cvmx_pko_queue_table[i].ccppp_queue_base, - (int)cvmx_pko_queue_table[i].ccppp_num_queues); -} - -void cvmx_helper_cfg_show_cfg(void) -{ - int i, j; - - for (i = 0; i < cvmx_helper_get_number_of_interfaces(); i++) { - debug("%s: interface%d mode %10s nports%4d\n", __func__, i, - cvmx_helper_interface_mode_to_string(cvmx_helper_interface_get_mode(i)), - cvmx_helper_interface_enumerate(i)); - - for (j = 0; j < cvmx_helper_interface_enumerate(i); j++) { - debug("\tpknd[%i][%d]%d", i, j, - __cvmx_helper_cfg_pknd(i, j)); - debug(" pko_port_base[%i][%d]%d", i, j, - __cvmx_helper_cfg_pko_port_base(i, j)); - debug(" pko_port_num[%i][%d]%d\n", i, j, - __cvmx_helper_cfg_pko_port_num(i, j)); - } - } - - for (i = 0; i < CVMX_HELPER_CFG_MAX_PKO_PORT; i++) { - if (__cvmx_helper_cfg_pko_queue_base(i) != - CVMX_HELPER_CFG_INVALID_VALUE) { - debug("%s: pko_port%d qbase%d nqueues%d interface%d index%d\n", - __func__, i, __cvmx_helper_cfg_pko_queue_base(i), - __cvmx_helper_cfg_pko_queue_num(i), - __cvmx_helper_cfg_pko_port_interface(i), - __cvmx_helper_cfg_pko_port_index(i)); - } - } -} - /* * initialize cvmx_cfg_pko_port_map */ @@ -515,141 +407,6 @@ void cvmx_helper_cfg_init_pko_port_map(void) cvmx_cfg_max_pko_engines = pko_eid; }
-void cvmx_helper_cfg_set_jabber_and_frame_max(void) -{ - int interface, port; - /*Set the frame max size and jabber size to 65535. */ - const unsigned int max_frame = 65535; - - // FIXME: should support node argument for remote node init - if (octeon_has_feature(OCTEON_FEATURE_BGX)) { - int ipd_port; - int node = cvmx_get_node_num(); - - for (interface = 0; - interface < cvmx_helper_get_number_of_interfaces(); - interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - cvmx_helper_interface_mode_t imode = cvmx_helper_interface_get_mode(xiface); - int num_ports = cvmx_helper_ports_on_interface(xiface); - - // FIXME: should be an easier way to determine - // that an interface is Ethernet/BGX - switch (imode) { - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_XAUI: - case CVMX_HELPER_INTERFACE_MODE_RXAUI: - case CVMX_HELPER_INTERFACE_MODE_XLAUI: - case CVMX_HELPER_INTERFACE_MODE_XFI: - case CVMX_HELPER_INTERFACE_MODE_10G_KR: - case CVMX_HELPER_INTERFACE_MODE_40G_KR4: - for (port = 0; port < num_ports; port++) { - ipd_port = cvmx_helper_get_ipd_port(xiface, port); - cvmx_pki_set_max_frm_len(ipd_port, max_frame); - cvmx_helper_bgx_set_jabber(xiface, port, max_frame); - } - break; - default: - break; - } - } - } else { - /*Set the frame max size and jabber size to 65535. */ - for (interface = 0; interface < cvmx_helper_get_number_of_interfaces(); - interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(cvmx_get_node_num(), - interface); - /* - * Set the frame max size and jabber size to 65535, as the defaults - * are too small. - */ - cvmx_helper_interface_mode_t imode = cvmx_helper_interface_get_mode(xiface); - int num_ports = cvmx_helper_ports_on_interface(xiface); - - switch (imode) { - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_QSGMII: - case CVMX_HELPER_INTERFACE_MODE_XAUI: - case CVMX_HELPER_INTERFACE_MODE_RXAUI: - for (port = 0; port < num_ports; port++) - csr_wr(CVMX_GMXX_RXX_JABBER(port, interface), 65535); - /* Set max and min value for frame check */ - cvmx_pip_set_frame_check(interface, -1); - break; - - case CVMX_HELPER_INTERFACE_MODE_RGMII: - case CVMX_HELPER_INTERFACE_MODE_GMII: - /* Set max and min value for frame check */ - cvmx_pip_set_frame_check(interface, -1); - for (port = 0; port < num_ports; port++) { - csr_wr(CVMX_GMXX_RXX_FRM_MAX(port, interface), 65535); - csr_wr(CVMX_GMXX_RXX_JABBER(port, interface), 65535); - } - break; - case CVMX_HELPER_INTERFACE_MODE_ILK: - /* Set max and min value for frame check */ - cvmx_pip_set_frame_check(interface, -1); - for (port = 0; port < num_ports; port++) { - int ipd_port = cvmx_helper_get_ipd_port(interface, port); - - cvmx_ilk_enable_la_header(ipd_port, 0); - } - break; - case CVMX_HELPER_INTERFACE_MODE_SRIO: - /* Set max and min value for frame check */ - cvmx_pip_set_frame_check(interface, -1); - break; - case CVMX_HELPER_INTERFACE_MODE_AGL: - /* Set max and min value for frame check */ - cvmx_pip_set_frame_check(interface, -1); - csr_wr(CVMX_AGL_GMX_RXX_FRM_MAX(0), 65535); - csr_wr(CVMX_AGL_GMX_RXX_JABBER(0), 65535); - break; - default: - break; - } - } - } -} - -/** - * Enable storing short packets only in the WQE - * unless NO_WPTR is set, which already has the same effect - */ -void cvmx_helper_cfg_store_short_packets_in_wqe(void) -{ - int interface, port; - cvmx_ipd_ctl_status_t ipd_ctl_status; - unsigned int dyn_rs = 1; - - if (octeon_has_feature(OCTEON_FEATURE_PKI)) - return; - - /* NO_WPTR combines WQE with 1st MBUF, RS is redundant */ - ipd_ctl_status.u64 = csr_rd(CVMX_IPD_CTL_STATUS); - if (ipd_ctl_status.s.no_wptr) { - dyn_rs = 0; - /* Note: consider also setting 'ignrs' wtn NO_WPTR is set */ - } - - for (interface = 0; interface < cvmx_helper_get_number_of_interfaces(); interface++) { - int num_ports = cvmx_helper_ports_on_interface(interface); - - for (port = 0; port < num_ports; port++) { - cvmx_pip_port_cfg_t port_cfg; - int pknd = port; - - if (octeon_has_feature(OCTEON_FEATURE_PKND)) - pknd = cvmx_helper_get_pknd(interface, port); - else - pknd = cvmx_helper_get_ipd_port(interface, port); - port_cfg.u64 = csr_rd(CVMX_PIP_PRT_CFGX(pknd)); - port_cfg.s.dyn_rs = dyn_rs; - csr_wr(CVMX_PIP_PRT_CFGX(pknd), port_cfg.u64); - } - } -} - int __cvmx_helper_cfg_pko_port_interface(int pko_port) { return cvmx_cfg_pko_port_map[pko_port].ccppl_interface; @@ -716,16 +473,6 @@ int cvmx_helper_cfg_ipd2pko_port_base(int ipd_port) return ipd2pko_port_cache[ipd_y][ipd_x].ccppp_base_port; }
-int cvmx_helper_cfg_ipd2pko_port_num(int ipd_port) -{ - int ipd_y, ipd_x; - - ipd_y = IPD2PKO_CACHE_Y(ipd_port); - ipd_x = __cvmx_helper_cfg_ipd2pko_cachex(ipd_port); - - return ipd2pko_port_cache[ipd_y][ipd_x].ccppp_nports; -} - /** * Return the number of queues to be assigned to this pko_port * @@ -980,8 +727,6 @@ int __cvmx_helper_init_port_valid(void) rc = __cvmx_helper_parse_bgx_dt(fdt_addr); if (!rc) rc = __cvmx_fdt_parse_vsc7224(fdt_addr); - if (!rc) - rc = __cvmx_fdt_parse_avsp5410(fdt_addr); if (!rc && octeon_has_feature(OCTEON_FEATURE_BGX_XCV)) rc = __cvmx_helper_parse_bgx_rgmii_dt(fdt_addr);
@@ -1030,44 +775,6 @@ int __cvmx_helper_init_port_valid(void) return 0; }
-typedef int (*cvmx_import_config_t)(void); -cvmx_import_config_t cvmx_import_app_config; - -int __cvmx_helper_init_port_config_data_local(void) -{ - int rv = 0; - int dbg = 0; - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - - if (octeon_has_feature(OCTEON_FEATURE_PKND)) { - if (cvmx_import_app_config) { - rv = (*cvmx_import_app_config)(); - if (rv != 0) { - debug("failed to import config\n"); - return -1; - } - } - - cvmx_helper_cfg_init_pko_port_map(); - __cvmx_helper_cfg_init_ipd2pko_cache(); - } else { - if (cvmx_import_app_config) { - rv = (*cvmx_import_app_config)(); - if (rv != 0) { - debug("failed to import config\n"); - return -1; - } - } - } - if (dbg) { - cvmx_helper_cfg_show_cfg(); - cvmx_pko_queue_show(); - } - return rv; -} - /* * This call is made from Linux octeon_ethernet driver * to setup the PKO with a specific queue count and @@ -1077,9 +784,8 @@ int cvmx_pko_alloc_iport_and_queues(int interface, int port, int port_cnt, int q { int rv, p, port_start, cnt;
- if (dbg) - debug("%s: intf %d/%d pcnt %d qcnt %d\n", __func__, interface, port, port_cnt, - queue_cnt); + debug("%s: intf %d/%d pcnt %d qcnt %d\n", __func__, interface, port, port_cnt, + queue_cnt);
if (!port_cfg_data_initialized) cvmx_init_port_cfg(); @@ -1122,6 +828,7 @@ static void cvmx_init_port_cfg(void) struct cvmx_srio_port_param *sr;
pcfg = &cvmx_cfg_port[node][i][j]; + memset(pcfg, 0, sizeof(*pcfg));
pcfg->port_fdt_node = CVMX_HELPER_CFG_INVALID_VALUE; @@ -1188,8 +895,7 @@ int __cvmx_helper_init_port_config_data(int node) int pknd = 0, bpid = 0; const int use_static_config = 1;
- if (dbg) - printf("%s:\n", __func__); + debug("%s:\n", __func__);
if (!port_cfg_data_initialized) cvmx_init_port_cfg(); @@ -1295,10 +1001,11 @@ int __cvmx_helper_init_port_config_data(int node) __cvmx_helper_cfg_init_ipd2pko_cache(); }
- if (dbg) { - cvmx_helper_cfg_show_cfg(); - cvmx_pko_queue_show(); - } +#ifdef DEBUG + cvmx_helper_cfg_show_cfg(); + cvmx_pko_queue_show(); +#endif + return rv; }
@@ -1336,39 +1043,6 @@ int cvmx_helper_get_port_fdt_node_offset(int xiface, int index) return cvmx_cfg_port[xi.node][xi.interface][index].port_fdt_node; }
-/** - * Search for a port based on its FDT node offset - * - * @param of_offset Node offset of port to search for - * @param[out] xiface xinterface of match - * @param[out] index port index of match - * - * Return: 0 if found, -1 if not found - */ -int cvmx_helper_cfg_get_xiface_index_by_fdt_node_offset(int of_offset, int *xiface, int *index) -{ - int iface; - int i; - int node; - struct cvmx_cfg_port_param *pcfg = NULL; - *xiface = -1; - *index = -1; - - for (node = 0; node < CVMX_MAX_NODES; node++) { - for (iface = 0; iface < CVMX_HELPER_MAX_IFACE; iface++) { - for (i = 0; i < CVMX_HELPER_CFG_MAX_PORT_PER_IFACE; i++) { - pcfg = &cvmx_cfg_port[node][iface][i]; - if (pcfg->valid && pcfg->port_fdt_node == of_offset) { - *xiface = cvmx_helper_node_interface_to_xiface(node, iface); - *index = i; - return 0; - } - } - } - } - return -1; -} - /** * @INTERNAL * Store the FDT node offset in the device tree of a phy @@ -1439,23 +1113,6 @@ bool cvmx_helper_get_port_autonegotiation(int xiface, int index) return !cvmx_cfg_port[xi.node][xi.interface][index].disable_an; }
-/** - * @INTERNAL - * Override default forward error correction for a port - * - * @param xiface node and interface - * @param index port index - * @param enable true to enable fec, false to disable it - */ -void cvmx_helper_set_port_fec(int xiface, int index, bool enable) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - cvmx_cfg_port[xi.node][xi.interface][index].enable_fec = enable; -} - /** * @INTERNAL * Returns if forward error correction is enabled or not. @@ -1474,161 +1131,6 @@ bool cvmx_helper_get_port_fec(int xiface, int index) return cvmx_cfg_port[xi.node][xi.interface][index].enable_fec; }
-/** - * @INTERNAL - * Configure the SRIO RX interface AGC settings for host mode - * - * @param xiface node and interface - * @param index lane - * @param long_run true for long run, false for short run - * @param agc_override true to put AGC in manual mode - * @param ctle_zero RX equalizer peaking control (default 0x6) - * @param agc_pre_ctle AGC pre-CTLE gain (default 0x5) - * @param agc_post_ctle AGC post-CTLE gain (default 0x4) - * - * NOTE: This must be called before SRIO is initialized to take effect - */ -void cvmx_helper_set_srio_rx(int xiface, int index, bool long_run, bool ctle_zero_override, - u8 ctle_zero, bool agc_override, uint8_t agc_pre_ctle, - uint8_t agc_post_ctle) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - struct cvmx_cfg_port_param *pcfg = &cvmx_cfg_port[xi.node][xi.interface][index]; - struct cvmx_srio_port_param *sr = long_run ? &pcfg->srio_long : &pcfg->srio_short; - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - sr->srio_rx_ctle_zero_override = ctle_zero_override; - sr->srio_rx_ctle_zero = ctle_zero; - sr->srio_rx_ctle_agc_override = agc_override; - sr->srio_rx_agc_pre_ctle = agc_pre_ctle; - sr->srio_rx_agc_post_ctle = agc_post_ctle; -} - -/** - * @INTERNAL - * Get the SRIO RX interface AGC settings for host mode - * - * @param xiface node and interface - * @param index lane - * @param long_run true for long run, false for short run - * @param[out] agc_override true to put AGC in manual mode - * @param[out] ctle_zero RX equalizer peaking control (default 0x6) - * @param[out] agc_pre_ctle AGC pre-CTLE gain (default 0x5) - * @param[out] agc_post_ctle AGC post-CTLE gain (default 0x4) - */ -void cvmx_helper_get_srio_rx(int xiface, int index, bool long_run, bool *ctle_zero_override, - u8 *ctle_zero, bool *agc_override, uint8_t *agc_pre_ctle, - uint8_t *agc_post_ctle) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - struct cvmx_cfg_port_param *pcfg = &cvmx_cfg_port[xi.node][xi.interface][index]; - struct cvmx_srio_port_param *sr = long_run ? &pcfg->srio_long : &pcfg->srio_short; - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - if (ctle_zero_override) - *ctle_zero_override = sr->srio_rx_ctle_zero_override; - if (ctle_zero) - *ctle_zero = sr->srio_rx_ctle_zero; - if (agc_override) - *agc_override = sr->srio_rx_ctle_agc_override; - if (agc_pre_ctle) - *agc_pre_ctle = sr->srio_rx_agc_pre_ctle; - if (agc_post_ctle) - *agc_post_ctle = sr->srio_rx_agc_post_ctle; -} - -/** - * @INTERNAL - * Configure the SRIO TX interface for host mode - * - * @param xiface node and interface - * @param index lane - * @param long_run true for long run, false for short run - * @param tx_swing tx swing value to use (default 0x7), -1 to not - * override. - * @param tx_gain PCS SDS TX gain (default 0x3), -1 to not - * override - * @param tx_premptap_override true to override preemphasis control - * @param tx_premptap_pre preemphasis pre tap value (default 0x0) - * @param tx_premptap_post preemphasis post tap value (default 0xF) - * @param tx_vboost vboost enable (1 = enable, -1 = don't override) - * hardware default is 1. - * - * NOTE: This must be called before SRIO is initialized to take effect - */ -void cvmx_helper_set_srio_tx(int xiface, int index, bool long_run, int tx_swing, int tx_gain, - bool tx_premptap_override, uint8_t tx_premptap_pre, - u8 tx_premptap_post, int tx_vboost) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - struct cvmx_cfg_port_param *pcfg = &cvmx_cfg_port[xi.node][xi.interface][index]; - struct cvmx_srio_port_param *sr = long_run ? &pcfg->srio_long : &pcfg->srio_short; - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - - sr->srio_tx_swing_override = (tx_swing != -1); - sr->srio_tx_swing = tx_swing != -1 ? tx_swing : 0x7; - sr->srio_tx_gain_override = (tx_gain != -1); - sr->srio_tx_gain = tx_gain != -1 ? tx_gain : 0x3; - sr->srio_tx_premptap_override = tx_premptap_override; - sr->srio_tx_premptap_pre = tx_premptap_override ? tx_premptap_pre : 0; - sr->srio_tx_premptap_post = tx_premptap_override ? tx_premptap_post : 0xF; - sr->srio_tx_vboost_override = tx_vboost != -1; - sr->srio_tx_vboost = (tx_vboost != -1) ? tx_vboost : 1; -} - -/** - * @INTERNAL - * Get the SRIO TX interface settings for host mode - * - * @param xiface node and interface - * @param index lane - * @param long_run true for long run, false for short run - * @param[out] tx_swing_override true to override pcs_sds_txX_swing - * @param[out] tx_swing tx swing value to use (default 0x7) - * @param[out] tx_gain_override true to override default gain - * @param[out] tx_gain PCS SDS TX gain (default 0x3) - * @param[out] tx_premptap_override true to override preemphasis control - * @param[out] tx_premptap_pre preemphasis pre tap value (default 0x0) - * @param[out] tx_premptap_post preemphasis post tap value (default 0xF) - * @param[out] tx_vboost_override override vboost setting - * @param[out] tx_vboost vboost enable (default true) - */ -void cvmx_helper_get_srio_tx(int xiface, int index, bool long_run, bool *tx_swing_override, - u8 *tx_swing, bool *tx_gain_override, uint8_t *tx_gain, - bool *tx_premptap_override, uint8_t *tx_premptap_pre, - u8 *tx_premptap_post, bool *tx_vboost_override, bool *tx_vboost) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - struct cvmx_cfg_port_param *pcfg = &cvmx_cfg_port[xi.node][xi.interface][index]; - struct cvmx_srio_port_param *sr = long_run ? &pcfg->srio_long : &pcfg->srio_short; - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - - if (tx_swing_override) - *tx_swing_override = sr->srio_tx_swing_override; - if (tx_swing) - *tx_swing = sr->srio_tx_swing; - if (tx_gain_override) - *tx_gain_override = sr->srio_tx_gain_override; - if (tx_gain) - *tx_gain = sr->srio_tx_gain; - if (tx_premptap_override) - *tx_premptap_override = sr->srio_tx_premptap_override; - if (tx_premptap_pre) - *tx_premptap_pre = sr->srio_tx_premptap_pre; - if (tx_premptap_post) - *tx_premptap_post = sr->srio_tx_premptap_post; - if (tx_vboost_override) - *tx_vboost_override = sr->srio_tx_vboost_override; - if (tx_vboost) - *tx_vboost = sr->srio_tx_vboost; -} - /** * @INTERNAL * Sets the PHY info data structure @@ -1683,23 +1185,6 @@ struct cvmx_phy_gpio_leds *cvmx_helper_get_port_phy_leds(int xiface, int index) return cvmx_cfg_port[xi.node][xi.interface][index].gpio_leds; }
-/** - * @INTERNAL - * Sets a pointer to the PHY LED configuration (if local GPIOs drive them) - * - * @param xiface node and interface - * @param index portindex - * @param leds pointer to led data structure - */ -void cvmx_helper_set_port_phy_leds(int xiface, int index, struct cvmx_phy_gpio_leds *leds) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - cvmx_cfg_port[xi.node][xi.interface][index].gpio_leds = leds; -} - /** * @INTERNAL * Disables RGMII TX clock bypass and sets delay value @@ -1743,59 +1228,6 @@ void cvmx_helper_cfg_get_rgmii_tx_clk_delay(int xiface, int index, bool *bypass, *clk_delay = cvmx_cfg_port[xi.node][xi.interface][index].rgmii_tx_clk_delay; }
-/** - * @INTERNAL - * Retrieve the SFP node offset in the device tree - * - * @param xiface node and interface - * @param index port index - * - * Return: offset in device tree or -1 if error or not defined. - */ -int cvmx_helper_cfg_get_sfp_fdt_offset(int xiface, int index) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - return cvmx_cfg_port[xi.node][xi.interface][index].sfp_of_offset; -} - -/** - * @INTERNAL - * Sets the SFP node offset - * - * @param xiface node and interface - * @param index port index - * @param sfp_of_offset Offset of SFP node in device tree - */ -void cvmx_helper_cfg_set_sfp_fdt_offset(int xiface, int index, int sfp_of_offset) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - cvmx_cfg_port[xi.node][xi.interface][index].sfp_of_offset = sfp_of_offset; -} - -/** - * Get data structure defining the Microsemi VSC7224 channel info - * or NULL if not present - * - * @param xiface node and interface - * @param index port index - * - * Return: pointer to vsc7224 data structure or NULL if not present - */ -struct cvmx_vsc7224_chan *cvmx_helper_cfg_get_vsc7224_chan_info(int xiface, int index) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - return cvmx_cfg_port[xi.node][xi.interface][index].vsc7224_chan; -} - /** * Sets the Microsemi VSC7224 channel info data structure * @@ -1813,40 +1245,6 @@ void cvmx_helper_cfg_set_vsc7224_chan_info(int xiface, int index, cvmx_cfg_port[xi.node][xi.interface][index].vsc7224_chan = vsc7224_chan_info; }
-/** - * Get data structure defining the Avago AVSP5410 phy info - * or NULL if not present - * - * @param xiface node and interface - * @param index port index - * - * Return: pointer to avsp5410 data structure or NULL if not present - */ -struct cvmx_avsp5410 *cvmx_helper_cfg_get_avsp5410_info(int xiface, int index) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - return cvmx_cfg_port[xi.node][xi.interface][index].avsp5410; -} - -/** - * Sets the Avago AVSP5410 phy info data structure - * - * @param xiface node and interface - * @param index port index - * @param[in] avsp5410_info Avago AVSP5410 data structure - */ -void cvmx_helper_cfg_set_avsp5410_info(int xiface, int index, struct cvmx_avsp5410 *avsp5410_info) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - cvmx_cfg_port[xi.node][xi.interface][index].avsp5410 = avsp5410_info; -} - /** * Gets the SFP data associated with a port * @@ -1879,36 +1277,3 @@ void cvmx_helper_cfg_set_sfp_info(int xiface, int index, struct cvmx_fdt_sfp_inf cvmx_init_port_cfg(); cvmx_cfg_port[xi.node][xi.interface][index].sfp_info = sfp_info; } - -/** - * Returns a pointer to the phy device associated with a port - * - * @param xiface node and interface - * @param index port index - * - * return pointer to phy device or NULL if none - */ -struct phy_device *cvmx_helper_cfg_get_phy_device(int xiface, int index) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - return cvmx_cfg_port[xi.node][xi.interface][index].phydev; -} - -/** - * Sets the phy device associated with a port - * - * @param xiface node and interface - * @param index port index - * @param[in] phydev phy device to assiciate - */ -void cvmx_helper_cfg_set_phy_device(int xiface, int index, struct phy_device *phydev) -{ - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - - if (!port_cfg_data_initialized) - cvmx_init_port_cfg(); - cvmx_cfg_port[xi.node][xi.interface][index].phydev = phydev; -} diff --git a/arch/mips/mach-octeon/cvmx-helper-fdt.c b/arch/mips/mach-octeon/cvmx-helper-fdt.c index 3177dfb6e5ae..400c73ad51e4 100644 --- a/arch/mips/mach-octeon/cvmx-helper-fdt.c +++ b/arch/mips/mach-octeon/cvmx-helper-fdt.c @@ -1,14 +1,17 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Marvell International Ltd. + * Copyright (C) 2020-2022 Marvell International Ltd. * * FDT Helper functions similar to those provided to U-Boot. */
+#include <dm.h> +#include <i2c.h> #include <log.h> #include <malloc.h> #include <net.h> #include <linux/delay.h> +#include <asm-generic/gpio.h>
#include <mach/cvmx-regs.h> #include <mach/cvmx-csr.h> @@ -19,35 +22,6 @@ #include <mach/cvmx-helper-board.h> #include <mach/cvmx-helper-cfg.h> #include <mach/cvmx-helper-fdt.h> -#include <mach/cvmx-helper-gpio.h> - -/** Structure used to get type of GPIO from device tree */ -struct gpio_compat { - char *compatible; /** Compatible string */ - enum cvmx_gpio_type type; /** Type */ - int8_t size; /** (max) Number of pins */ -}; - -#define GPIO_REG_PCA953X_IN 0 -#define GPIO_REG_PCA953X_OUT 1 -#define GPIO_REG_PCA953X_INVERT 2 -#define GPIO_REG_PCA953X_DIR 3 - -#define GPIO_REG_PCA957X_IN 0 -#define GPIO_REG_PCA957X_INVERT 1 -#define GPIO_REG_PCA957X_CFG 4 -#define GPIO_REG_PCA957X_OUT 5 - -enum cvmx_i2c_mux_type { I2C_MUX, I2C_SWITCH }; - -/** Structure used to get type of GPIO from device tree */ -struct mux_compat { - char *compatible; /** Compatible string */ - enum cvmx_i2c_bus_type type; /** Mux chip type */ - enum cvmx_i2c_mux_type mux_type; /** Type of mux */ - u8 enable; /** Enable bit for mux */ - u8 size; /** (max) Number of channels */ -};
/** * Local allocator to handle both SE and U-Boot that also zeroes out memory @@ -57,45 +31,19 @@ struct mux_compat { * Return: pointer to allocated memory or NULL if out of memory. * Alignment is set to 8-bytes. */ -void *__cvmx_fdt_alloc(size_t size) +static void *cvmx_fdt_alloc(size_t size) { return calloc(size, 1); }
-/** - * Free allocated memory. - * - * @param ptr pointer to memory to free - * - * NOTE: This only works in U-Boot since SE does not really have a freeing - * mechanism. In SE the memory is zeroed out. - */ -void __cvmx_fdt_free(void *ptr, size_t size) -{ - free(ptr); -} - -/** - * Look up a phandle and follow it to its node then return the offset of that - * node. - * - * @param[in] fdt_addr pointer to FDT blob - * @param node node to read phandle from - * @param[in] prop_name name of property to find - * @param[in,out] lenp Number of phandles, input max number - * @param[out] nodes Array of phandle nodes - * - * Return: -ve error code on error or 0 for success - */ -int cvmx_fdt_lookup_phandles(const void *fdt_addr, int node, - const char *prop_name, int *lenp, - int *nodes) +int cvmx_ofnode_lookup_phandles(ofnode node, const char *prop_name, int *lenp, + ofnode *nodes) { const u32 *phandles; int count; int i;
- phandles = fdt_getprop(fdt_addr, node, prop_name, &count); + phandles = ofnode_get_property(node, prop_name, &count); if (!phandles || count < 0) return -FDT_ERR_NOTFOUND;
@@ -104,8 +52,8 @@ int cvmx_fdt_lookup_phandles(const void *fdt_addr, int node, count = *lenp;
for (i = 0; i < count; i++) - nodes[i] = fdt_node_offset_by_phandle(fdt_addr, - fdt32_to_cpu(phandles[i])); + nodes[i] = ofnode_get_by_phandle(fdt32_to_cpu(phandles[i])); + *lenp = count; return 0; } @@ -142,126 +90,6 @@ int cvmx_fdt_get_cpu_node(const void *fdt_addr, int node) return fdt32_to_cpu(ranges[2]) / 0x10; }
-/** - * Get the total size of the flat device tree - * - * @param[in] fdt_addr Address of FDT - * - * Return: Size of flat device tree in bytes or error if negative. - */ -int cvmx_fdt_get_fdt_size(const void *fdt_addr) -{ - int rc; - - rc = fdt_check_header(fdt_addr); - if (rc) - return rc; - return fdt_totalsize(fdt_addr); -} - -/** - * Returns if a node is compatible with one of the items in the string list - * - * @param[in] fdt_addr Pointer to flat device tree - * @param node Node offset to check - * @param[in] strlist Array of FDT device compatibility strings, - * must end with NULL or empty string. - * - * Return: 0 if at least one item matches, 1 if no matches - */ -int cvmx_fdt_node_check_compatible_list(const void *fdt_addr, int node, const char *const *strlist) -{ - while (*strlist && **strlist) { - if (!fdt_node_check_compatible(fdt_addr, node, *strlist)) - return 0; - strlist++; - } - return 1; -} - -/** - * Given a FDT node, return the next compatible node. - * - * @param[in] fdt_addr Pointer to flat device tree - * @param start_offset Starting node offset or -1 to find the first - * @param strlist Array of FDT device compatibility strings, must - * end with NULL or empty string. - * - * Return: next matching node or -1 if no more matches. - */ -int cvmx_fdt_node_offset_by_compatible_list(const void *fdt_addr, int startoffset, - const char *const *strlist) -{ - int offset; - - for (offset = fdt_next_node(fdt_addr, startoffset, NULL); offset >= 0; - offset = fdt_next_node(fdt_addr, offset, NULL)) { - if (!cvmx_fdt_node_check_compatible_list(fdt_addr, offset, strlist)) - return offset; - } - return -1; -} - -/** - * Attaches a PHY to a SFP or QSFP. - * - * @param sfp sfp to attach PHY to - * @param phy_info phy descriptor to attach or NULL to detach - */ -void cvmx_sfp_attach_phy(struct cvmx_fdt_sfp_info *sfp, struct cvmx_phy_info *phy_info) -{ - sfp->phy_info = phy_info; - if (phy_info) - phy_info->sfp_info = sfp; -} - -/** - * Assigns an IPD port to a SFP slot - * - * @param sfp Handle to SFP data structure - * @param ipd_port Port to assign it to - * - * Return: 0 for success, -1 on error - */ -int cvmx_sfp_set_ipd_port(struct cvmx_fdt_sfp_info *sfp, int ipd_port) -{ - int i; - - if (sfp->is_qsfp) { - int xiface; - cvmx_helper_interface_mode_t mode; - - xiface = cvmx_helper_get_interface_num(ipd_port); - mode = cvmx_helper_interface_get_mode(xiface); - sfp->ipd_port[0] = ipd_port; - - switch (mode) { - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_XFI: - case CVMX_HELPER_INTERFACE_MODE_10G_KR: - for (i = 1; i < 4; i++) - sfp->ipd_port[i] = cvmx_helper_get_ipd_port(xiface, i); - break; - case CVMX_HELPER_INTERFACE_MODE_XLAUI: - case CVMX_HELPER_INTERFACE_MODE_40G_KR4: - sfp->ipd_port[0] = ipd_port; - for (i = 1; i < 4; i++) - sfp->ipd_port[i] = -1; - break; - default: - debug("%s: Interface mode %s for interface 0x%x, ipd_port %d not supported for QSFP\n", - __func__, cvmx_helper_interface_mode_to_string(mode), xiface, - ipd_port); - return -1; - } - } else { - sfp->ipd_port[0] = ipd_port; - for (i = 1; i < 4; i++) - sfp->ipd_port[i] = -1; - } - return 0; -} - /** * Parses all of the channels assigned to a VSC7224 device * @@ -271,10 +99,10 @@ int cvmx_sfp_set_ipd_port(struct cvmx_fdt_sfp_info *sfp, int ipd_port) * * Return: 0 for success, -1 on error */ -static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, +static int cvmx_fdt_parse_vsc7224_channels(ofnode node, struct cvmx_vsc7224 *vsc7224) { - int parent_offset = of_offset; + struct ofnode_phandle_args phandle; int err = 0; int reg; int num_chan = 0; @@ -289,35 +117,33 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, bool is_tx; bool is_qsfp; const char *mac_str; + ofnode node_chan;
- debug("%s(%p, %d, %s)\n", __func__, fdt_addr, of_offset, vsc7224->name); - do { - /* Walk through all channels */ - of_offset = fdt_node_offset_by_compatible(fdt_addr, of_offset, - "vitesse,vsc7224-channel"); - if (of_offset == -FDT_ERR_NOTFOUND) { - break; - } else if (of_offset < 0) { - debug("%s: Failed finding compatible channel\n", - __func__); - err = -1; + debug("%s(%x, %s)\n", __func__, ofnode_to_offset(node), vsc7224->name); + ofnode_for_each_compatible_node(node_chan, "vitesse,vsc7224-channel") { + if (!ofnode_valid(node_chan)) { + debug("%s: Error parsing FDT node %s\n", + __func__, ofnode_get_name(node)); break; } - if (fdt_parent_offset(fdt_addr, of_offset) != parent_offset) + + if (ofnode_to_offset(ofnode_get_parent(node_chan)) != + ofnode_to_offset(node)) break; - reg = cvmx_fdt_get_int(fdt_addr, of_offset, "reg", -1); + + reg = ofnode_get_addr(node_chan); if (reg < 0 || reg > 3) { debug("%s: channel reg is either not present or out of range\n", __func__); err = -1; break; } - is_tx = cvmx_fdt_get_bool(fdt_addr, of_offset, "direction-tx"); + is_tx = ofnode_read_bool(node_chan, "direction-tx");
debug("%s(%s): Adding %cx channel %d\n", __func__, vsc7224->name, is_tx ? 't' : 'r', reg); - tap_values = (const uint32_t *)fdt_getprop(fdt_addr, of_offset, "taps", &len); + tap_values = ofnode_get_property(node_chan, "taps", &len); if (!tap_values) { debug("%s: Error: no taps defined for vsc7224 channel %d\n", __func__, reg); @@ -341,8 +167,8 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, num_taps = len / 16; debug("%s: Adding %d taps\n", __func__, num_taps);
- channel = __cvmx_fdt_alloc(sizeof(*channel) + - num_taps * sizeof(struct cvmx_vsc7224_tap)); + channel = cvmx_fdt_alloc(sizeof(*channel) + + num_taps * sizeof(struct cvmx_vsc7224_tap)); if (!channel) { debug("%s: Out of memory\n", __func__); err = -1; @@ -351,11 +177,12 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, vsc7224->channel[reg] = channel; channel->num_taps = num_taps; channel->lane = reg; - channel->of_offset = of_offset; + channel->of_offset = ofnode_to_offset(node_chan); channel->is_tx = is_tx; - channel->pretap_disable = cvmx_fdt_get_bool(fdt_addr, of_offset, "pretap-disable"); - channel->posttap_disable = - cvmx_fdt_get_bool(fdt_addr, of_offset, "posttap-disable"); + channel->pretap_disable = ofnode_read_bool(node_chan, + "pretap-disable"); + channel->posttap_disable = ofnode_read_bool(node_chan, + "posttap-disable"); channel->vsc7224 = vsc7224; /* Read all the tap values */ for (i = 0; i < num_taps; i++) { @@ -371,9 +198,9 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, channel->ipd_port = -1;
mac_str = "sfp-mac"; - if (fdt_getprop(fdt_addr, of_offset, mac_str, NULL)) { + if (ofnode_get_property(node_chan, mac_str, NULL)) { is_qsfp = false; - } else if (fdt_getprop(fdt_addr, of_offset, "qsfp-mac", NULL)) { + } else if (ofnode_get_property(node_chan, "qsfp-mac", NULL)) { is_qsfp = true; mac_str = "qsfp-mac"; } else { @@ -381,52 +208,59 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, vsc7224->name, reg); return -1; } - of_mac = cvmx_fdt_lookup_phandle(fdt_addr, of_offset, mac_str); - if (of_mac < 0) { + + err = ofnode_parse_phandle_with_args(node_chan, mac_str, NULL, + 0, 0, &phandle); + if (err) { debug("%s: Error %d with MAC %s phandle for %s\n", __func__, of_mac, mac_str, vsc7224->name); return -1; }
- debug("%s: Found mac at offset %d\n", __func__, of_mac); - err = cvmx_helper_cfg_get_xiface_index_by_fdt_node_offset(of_mac, &xiface, &index); - if (!err) { - channel->xiface = xiface; - channel->index = index; - channel->ipd_port = cvmx_helper_get_ipd_port(xiface, index); - - debug("%s: Found MAC, xiface: 0x%x, index: %d, ipd port: %d\n", __func__, - xiface, index, channel->ipd_port); - if (channel->ipd_port >= 0) { - cvmx_helper_cfg_set_vsc7224_chan_info(xiface, index, channel); - debug("%s: Storing config channel for xiface 0x%x, index %d\n", - __func__, xiface, index); - } - sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, index); - if (!sfp_info) { - debug("%s: Warning: no (Q)SFP+ slot found for xinterface 0x%x, index %d for channel %d\n", - __func__, xiface, index, channel->lane); - continue; - } + debug("%s: Found mac at %s\n", __func__, + ofnode_get_name(phandle.node)); + + xiface = (ofnode_get_addr(ofnode_get_parent(phandle.node)) + >> 24) & 0x0f; + index = ofnode_get_addr(phandle.node); + channel->xiface = xiface; + channel->index = index; + channel->ipd_port = cvmx_helper_get_ipd_port(xiface, index); + + debug("%s: Found MAC, xiface: 0x%x, index: %d, ipd port: %d\n", __func__, + xiface, index, channel->ipd_port); + if (channel->ipd_port >= 0) { + cvmx_helper_cfg_set_vsc7224_chan_info(xiface, index, channel); + debug("%s: Storing config channel for xiface 0x%x, index %d\n", + __func__, xiface, index); + } + sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, index); + if (!sfp_info) { + debug("%s: Warning: no (Q)SFP+ slot found for xinterface 0x%x, index %d for channel %d\n", + __func__, xiface, index, channel->lane); + continue; + }
- /* Link it */ - channel->next = sfp_info->vsc7224_chan; - if (sfp_info->vsc7224_chan) - sfp_info->vsc7224_chan->prev = channel; - sfp_info->vsc7224_chan = channel; - sfp_info->is_vsc7224 = true; - debug("%s: Registering VSC7224 %s channel %d with SFP %s\n", __func__, - vsc7224->name, channel->lane, sfp_info->name); - if (!sfp_info->mod_abs_changed) { - debug("%s: Registering cvmx_sfp_vsc7224_mod_abs_changed at %p for xinterface 0x%x, index %d\n", - __func__, &cvmx_sfp_vsc7224_mod_abs_changed, xiface, index); - cvmx_sfp_register_mod_abs_changed( - sfp_info, - &cvmx_sfp_vsc7224_mod_abs_changed, - NULL); - } + /* Link it */ + channel->next = sfp_info->vsc7224_chan; + if (sfp_info->vsc7224_chan) + sfp_info->vsc7224_chan->prev = channel; + sfp_info->vsc7224_chan = channel; + sfp_info->is_vsc7224 = true; + debug("%s: Registering VSC7224 %s channel %d with SFP %s\n", __func__, + vsc7224->name, channel->lane, sfp_info->name); + if (!sfp_info->mod_abs_changed) { + debug("%s: Registering cvmx_sfp_vsc7224_mod_abs_changed at %p for xinterface 0x%x, index %d\n", + __func__, &cvmx_sfp_vsc7224_mod_abs_changed, xiface, index); + cvmx_sfp_register_mod_abs_changed( + sfp_info, + &cvmx_sfp_vsc7224_mod_abs_changed, + NULL); } - } while (!err && num_chan < 4); + + if (num_chan >= 4) + break; + }
return err; } @@ -441,12 +275,17 @@ static int cvmx_fdt_parse_vsc7224_channels(const void *fdt_addr, int of_offset, */ int __cvmx_fdt_parse_vsc7224(const void *fdt_addr) { - int of_offset = -1; struct cvmx_vsc7224 *vsc7224 = NULL; - struct cvmx_fdt_gpio_info *gpio_info = NULL; + ofnode node; int err = 0; - int of_parent; static bool parsed; + const int *init_array; + struct udevice *dev; + u16 value; + int reg; + int len; + int ret; + int i;
debug("%s(%p)\n", __func__, fdt_addr);
@@ -454,30 +293,23 @@ int __cvmx_fdt_parse_vsc7224(const void *fdt_addr) debug("%s: Already parsed\n", __func__); return 0; } - do { - of_offset = fdt_node_offset_by_compatible(fdt_addr, of_offset, - "vitesse,vsc7224"); - debug("%s: of_offset: %d\n", __func__, of_offset); - if (of_offset == -FDT_ERR_NOTFOUND) { - break; - } else if (of_offset < 0) { - err = -1; - debug("%s: Error %d parsing FDT\n", - __func__, of_offset); + + ofnode_for_each_compatible_node(node, "vitesse,vsc7224") { + if (!ofnode_valid(node)) { + debug("%s: Error parsing FDT node %s\n", + __func__, ofnode_get_name(node)); break; }
- vsc7224 = __cvmx_fdt_alloc(sizeof(*vsc7224)); - + vsc7224 = cvmx_fdt_alloc(sizeof(*vsc7224)); if (!vsc7224) { debug("%s: Out of memory!\n", __func__); return -1; } - vsc7224->of_offset = of_offset; - vsc7224->i2c_addr = cvmx_fdt_get_int(fdt_addr, of_offset, - "reg", -1); - of_parent = fdt_parent_offset(fdt_addr, of_offset); - vsc7224->i2c_bus = cvmx_fdt_get_i2c_bus(fdt_addr, of_parent); + + vsc7224->of_offset = ofnode_to_offset(node); + vsc7224->i2c_addr = ofnode_get_addr(node); + vsc7224->i2c_bus = cvmx_ofnode_get_i2c_bus(ofnode_get_parent(node)); if (vsc7224->i2c_addr < 0) { debug("%s: Error: reg field missing\n", __func__); err = -1; @@ -488,168 +320,90 @@ int __cvmx_fdt_parse_vsc7224(const void *fdt_addr) err = -1; break; } - vsc7224->name = fdt_get_name(fdt_addr, of_offset, NULL); + vsc7224->name = ofnode_get_name(node); debug("%s: Adding %s\n", __func__, vsc7224->name); - if (fdt_getprop(fdt_addr, of_offset, "reset", NULL)) { - gpio_info = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "reset"); - vsc7224->reset_gpio = gpio_info; - } - if (fdt_getprop(fdt_addr, of_offset, "los", NULL)) { - gpio_info = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "los"); - vsc7224->los_gpio = gpio_info; - } - debug("%s: Parsing channels\n", __func__); - err = cvmx_fdt_parse_vsc7224_channels(fdt_addr, of_offset, vsc7224); + + err = gpio_request_by_name_nodev(node, "reset", 0, + &vsc7224->reset_gpio, + GPIOD_IS_OUT); if (err) { - debug("%s: Error parsing VSC7224 channels\n", __func__); - break; + printf("%s: reset GPIO not found in DT!\n", __func__); + return -ENODEV; } - } while (of_offset > 0);
- if (err) { - debug("%s(): Error\n", __func__); - if (vsc7224) { - if (vsc7224->reset_gpio) - __cvmx_fdt_free(vsc7224->reset_gpio, sizeof(*vsc7224->reset_gpio)); - if (vsc7224->los_gpio) - __cvmx_fdt_free(vsc7224->los_gpio, sizeof(*vsc7224->los_gpio)); - if (vsc7224->i2c_bus) - cvmx_fdt_free_i2c_bus(vsc7224->i2c_bus); - __cvmx_fdt_free(vsc7224, sizeof(*vsc7224)); + err = gpio_request_by_name_nodev(node, "los", 0, + &vsc7224->los_gpio, + GPIOD_IS_IN); + if (err) { + printf("%s: los GPIO not found in DT!\n", __func__); + return -ENODEV; } - } - if (!err) - parsed = true; - - return err; -} - -/** - * @INTERNAL - * Parses all instances of the Avago AVSP5410 gearbox phy - * - * @param[in] fdt_addr Address of flat device tree - * - * Return: 0 for success, error otherwise - */ -int __cvmx_fdt_parse_avsp5410(const void *fdt_addr) -{ - int of_offset = -1; - struct cvmx_avsp5410 *avsp5410 = NULL; - struct cvmx_fdt_sfp_info *sfp_info; - int err = 0; - int of_parent; - static bool parsed; - int of_mac; - int xiface, index; - bool is_qsfp; - const char *mac_str; - - debug("%s(%p)\n", __func__, fdt_addr);
- if (parsed) { - debug("%s: Already parsed\n", __func__); - return 0; - } - - do { - of_offset = fdt_node_offset_by_compatible(fdt_addr, of_offset, - "avago,avsp-5410"); - debug("%s: of_offset: %d\n", __func__, of_offset); - if (of_offset == -FDT_ERR_NOTFOUND) { - break; - } else if (of_offset < 0) { - err = -1; - debug("%s: Error %d parsing FDT\n", __func__, of_offset); - break; + /* + * This code was taken from the NIC23 board specific code + * but should be better placed here in the common code + */ + debug("%s: Putting device in reset\n", __func__); + dm_gpio_set_value(&vsc7224->reset_gpio, 1); + mdelay(10); + debug("%s: Taking device out of reset\n", __func__); + dm_gpio_set_value(&vsc7224->reset_gpio, 0); + mdelay(50); + + init_array = ofnode_get_property(node, "vitesse,reg-init", + &len); + if (!init_array) { + debug("%s: No initialization array\n", __func__); + continue; } - - avsp5410 = __cvmx_fdt_alloc(sizeof(*avsp5410)); - - if (!avsp5410) { - debug("%s: Out of memory!\n", __func__); + if ((len % 8) != 0) { + printf("%s: Error: register init string should be an array of reg number followed by value\n", + __func__); return -1; } - avsp5410->of_offset = of_offset; - avsp5410->i2c_addr = cvmx_fdt_get_int(fdt_addr, of_offset, - "reg", -1); - of_parent = fdt_parent_offset(fdt_addr, of_offset); - avsp5410->i2c_bus = cvmx_fdt_get_i2c_bus(fdt_addr, of_parent); - if (avsp5410->i2c_addr < 0) { - debug("%s: Error: reg field missing\n", __func__); - err = -1; - break; - } - if (!avsp5410->i2c_bus) { - debug("%s: Error getting i2c bus\n", __func__); - err = -1; - break; - } - avsp5410->name = fdt_get_name(fdt_addr, of_offset, NULL); - debug("%s: Adding %s\n", __func__, avsp5410->name); - - /* Now find out which interface it's mapped to */ - avsp5410->ipd_port = -1;
- mac_str = "sfp-mac"; - if (fdt_getprop(fdt_addr, of_offset, mac_str, NULL)) { - is_qsfp = false; - } else if (fdt_getprop(fdt_addr, of_offset, "qsfp-mac", NULL)) { - is_qsfp = true; - mac_str = "qsfp-mac"; - } else { - debug("%s: Error: MAC not found for %s\n", __func__, avsp5410->name); - return -1; - } - of_mac = cvmx_fdt_lookup_phandle(fdt_addr, of_offset, mac_str); - if (of_mac < 0) { - debug("%s: Error %d with MAC %s phandle for %s\n", __func__, of_mac, - mac_str, avsp5410->name); + ret = i2c_get_chip(vsc7224->i2c_bus->i2c_bus, + vsc7224->i2c_addr, 1, &dev); + if (ret) { + debug("Cannot find I2C device: %d\n", ret); return -1; }
- debug("%s: Found mac at offset %d\n", __func__, of_mac); - err = cvmx_helper_cfg_get_xiface_index_by_fdt_node_offset(of_mac, &xiface, &index); - if (!err) { - avsp5410->xiface = xiface; - avsp5410->index = index; - avsp5410->ipd_port = cvmx_helper_get_ipd_port(xiface, index); - - debug("%s: Found MAC, xiface: 0x%x, index: %d, ipd port: %d\n", __func__, - xiface, index, avsp5410->ipd_port); - if (avsp5410->ipd_port >= 0) { - cvmx_helper_cfg_set_avsp5410_info(xiface, index, avsp5410); - debug("%s: Storing config phy for xiface 0x%x, index %d\n", - __func__, xiface, index); - } - sfp_info = cvmx_helper_cfg_get_sfp_info(xiface, index); - if (!sfp_info) { - debug("%s: Warning: no (Q)SFP+ slot found for xinterface 0x%x, index %d\n", - __func__, xiface, index); - continue; + for (i = 0; i < len / sizeof(int); i += 2) { + u8 buffer[2]; + + reg = fdt32_to_cpu(init_array[i]); + value = fdt32_to_cpu(init_array[i + 1]); + buffer[0] = value >> 8; + buffer[1] = value & 0xff; + ret = dm_i2c_write(dev, reg, buffer, 2); + if (ret) { + debug("Cannot write I2C device: %d\n", ret); + return -1; }
- sfp_info->is_avsp5410 = true; - sfp_info->avsp5410 = avsp5410; - debug("%s: Registering AVSP5410 %s with SFP %s\n", __func__, avsp5410->name, - sfp_info->name); - if (!sfp_info->mod_abs_changed) { - debug("%s: Registering cvmx_sfp_avsp5410_mod_abs_changed at %p for xinterface 0x%x, index %d\n", - __func__, &cvmx_sfp_avsp5410_mod_abs_changed, xiface, index); - cvmx_sfp_register_mod_abs_changed( - sfp_info, - &cvmx_sfp_avsp5410_mod_abs_changed, - NULL); - } + debug(" Wrote 0x%02x <= 0x%02x%02x\n", reg, + buffer[0], buffer[1]); + } + + debug("%s: Parsing channels\n", __func__); + err = cvmx_fdt_parse_vsc7224_channels(node, vsc7224); + if (err) { + debug("%s: Error parsing VSC7224 channels\n", __func__); + break; } - } while (of_offset > 0); + }
if (err) { debug("%s(): Error\n", __func__); - if (avsp5410) { - if (avsp5410->i2c_bus) - cvmx_fdt_free_i2c_bus(avsp5410->i2c_bus); - __cvmx_fdt_free(avsp5410, sizeof(*avsp5410)); + if (vsc7224) { + dm_gpio_free(vsc7224->reset_gpio.dev, + &vsc7224->reset_gpio); + dm_gpio_free(vsc7224->los_gpio.dev, + &vsc7224->los_gpio); + if (vsc7224->i2c_bus) + cvmx_fdt_free_i2c_bus(vsc7224->i2c_bus); + free(vsc7224); } } if (!err) @@ -659,312 +413,76 @@ int __cvmx_fdt_parse_avsp5410(const void *fdt_addr) }
/** - * Parse QSFP GPIOs for SFP - * - * @param[in] fdt_addr Pointer to flat device tree - * @param of_offset Offset of QSFP node - * @param[out] sfp_info Pointer to sfp info to fill in + * Given the parent offset of an i2c device build up a list describing the bus + * which can contain i2c muxes and switches. * - * Return: 0 for success - */ -static int cvmx_parse_qsfp(const void *fdt_addr, int of_offset, struct cvmx_fdt_sfp_info *sfp_info) -{ - sfp_info->select = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "select"); - sfp_info->mod_abs = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "mod_prs"); - sfp_info->reset = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "reset"); - sfp_info->interrupt = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "interrupt"); - sfp_info->lp_mode = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "lp_mode"); - return 0; -} - -/** - * Parse SFP GPIOs for SFP + * @param[in] node ofnode of the parent node of a GPIO device in + * the device tree. * - * @param[in] fdt_addr Pointer to flat device tree - * @param of_offset Offset of SFP node - * @param[out] sfp_info Pointer to sfp info to fill in + * @return pointer to list of i2c devices starting from the root which + * can include i2c muxes and switches or NULL if error. Note that + * all entries are allocated on the heap. * - * Return: 0 for success + * @see cvmx_fdt_free_i2c_bus() */ -static int cvmx_parse_sfp(const void *fdt_addr, int of_offset, struct cvmx_fdt_sfp_info *sfp_info) +struct cvmx_fdt_i2c_bus_info *cvmx_ofnode_get_i2c_bus(ofnode node) { - sfp_info->mod_abs = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "mod_abs"); - sfp_info->rx_los = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "rx_los"); - sfp_info->tx_disable = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "tx_disable"); - sfp_info->tx_error = cvmx_fdt_gpio_get_info_phandle(fdt_addr, of_offset, "tx_error"); - return 0; -} - -/** - * Parse SFP/QSFP EEPROM and diag - * - * @param[in] fdt_addr Pointer to flat device tree - * @param of_offset Offset of SFP node - * @param[out] sfp_info Pointer to sfp info to fill in - * - * Return: 0 for success, -1 on error - */ -static int cvmx_parse_sfp_eeprom(const void *fdt_addr, int of_offset, - struct cvmx_fdt_sfp_info *sfp_info) -{ - int of_eeprom; - int of_diag; - - debug("%s(%p, %d, %s)\n", __func__, fdt_addr, of_offset, sfp_info->name); - of_eeprom = cvmx_fdt_lookup_phandle(fdt_addr, of_offset, "eeprom"); - if (of_eeprom < 0) { - debug("%s: Missing "eeprom" from device tree for %s\n", __func__, sfp_info->name); - return -1; - } - - sfp_info->i2c_bus = cvmx_fdt_get_i2c_bus(fdt_addr, fdt_parent_offset(fdt_addr, of_eeprom)); - sfp_info->i2c_eeprom_addr = cvmx_fdt_get_int(fdt_addr, of_eeprom, "reg", 0x50); - - debug("%s(%p, %d, %s, %d)\n", __func__, fdt_addr, of_offset, sfp_info->name, - sfp_info->i2c_eeprom_addr); - - if (!sfp_info->i2c_bus) { - debug("%s: Error: could not determine i2c bus for eeprom for %s\n", __func__, - sfp_info->name); - return -1; + struct cvmx_fdt_i2c_bus_info *businfo = NULL; + struct udevice *bus; + int ret; + + businfo = cvmx_fdt_alloc(sizeof(*businfo)); + if (!businfo) { + debug("Out of memory\n"); + return NULL; } - of_diag = cvmx_fdt_lookup_phandle(fdt_addr, of_offset, "diag"); - if (of_diag >= 0) - sfp_info->i2c_diag_addr = cvmx_fdt_get_int(fdt_addr, of_diag, "reg", 0x51); - else - sfp_info->i2c_diag_addr = 0x51; - return 0; -} - -/** - * Parse SFP information from device tree - * - * @param[in] fdt_addr Address of flat device tree - * - * Return: pointer to sfp info or NULL if error - */ -struct cvmx_fdt_sfp_info *cvmx_helper_fdt_parse_sfp_info(const void *fdt_addr, int of_offset) -{ - struct cvmx_fdt_sfp_info *sfp_info = NULL; - int err = -1; - bool is_qsfp;
- if (!fdt_node_check_compatible(fdt_addr, of_offset, "ethernet,sfp-slot")) { - is_qsfp = false; - } else if (!fdt_node_check_compatible(fdt_addr, of_offset, "ethernet,qsfp-slot")) { - is_qsfp = true; - } else { - debug("%s: Error: incompatible sfp/qsfp slot, compatible=%s\n", __func__, - (char *)fdt_getprop(fdt_addr, of_offset, "compatible", NULL)); - goto error_exit; - } + debug("%s: Found node %s\n", __func__, ofnode_get_name(node)); + businfo->of_offset = ofnode_to_offset(node);
- debug("%s: %ssfp module found at offset %d\n", __func__, is_qsfp ? "q" : "", of_offset); - sfp_info = __cvmx_fdt_alloc(sizeof(*sfp_info)); - if (!sfp_info) { - debug("%s: Error: out of memory\n", __func__); - goto error_exit; - } - sfp_info->name = fdt_get_name(fdt_addr, of_offset, NULL); - sfp_info->of_offset = of_offset; - sfp_info->is_qsfp = is_qsfp; - sfp_info->last_mod_abs = -1; - sfp_info->last_rx_los = -1; - - if (is_qsfp) - err = cvmx_parse_qsfp(fdt_addr, of_offset, sfp_info); - else - err = cvmx_parse_sfp(fdt_addr, of_offset, sfp_info); - if (err) { - debug("%s: Error in %s parsing %ssfp GPIO info\n", __func__, sfp_info->name, - is_qsfp ? "q" : ""); - goto error_exit; - } - debug("%s: Parsing %ssfp module eeprom\n", __func__, is_qsfp ? "q" : ""); - err = cvmx_parse_sfp_eeprom(fdt_addr, of_offset, sfp_info); - if (err) { - debug("%s: Error parsing eeprom info for %s\n", __func__, sfp_info->name); - goto error_exit; + /* + * Get I2C bus and probe it automatically - needed for later use + */ + ret = device_get_global_by_ofnode(node, &bus); + if (!bus || ret) { + printf("Cannot find a I2C bus\n"); + return NULL; }
- /* Register default check for mod_abs changed */ - if (!err) - cvmx_sfp_register_check_mod_abs(sfp_info, cvmx_sfp_check_mod_abs, NULL); + businfo->i2c_bus = bus;
-error_exit: - /* Note: we don't free any data structures on error since it gets - * rather complicated with i2c buses and whatnot. - */ - return err ? NULL : sfp_info; + return businfo; }
/** - * @INTERNAL - * Parse a slice of the Inphi/Cortina CS4343 in the device tree + * Return the Octeon bus number for a bus descriptor * - * @param[in] fdt_addr Address of flat device tree - * @param of_offset fdt offset of slice - * @param phy_info phy_info data structure + * @param[in] bus bus descriptor * - * Return: slice number if non-negative, otherwise error + * @return Octeon twsi bus number or -1 on error */ -static int cvmx_fdt_parse_cs4343_slice(const void *fdt_addr, int of_offset, - struct cvmx_phy_info *phy_info) +int cvmx_fdt_i2c_get_root_bus(const struct cvmx_fdt_i2c_bus_info *bus) { - struct cvmx_cs4343_slice_info *slice; - int reg; - int reg_offset; - - reg = cvmx_fdt_get_int(fdt_addr, of_offset, "reg", -1); - reg_offset = cvmx_fdt_get_int(fdt_addr, of_offset, "slice_offset", -1); - - if (reg < 0 || reg >= 4) { - debug("%s(%p, %d, %p): Error: reg %d undefined or out of range\n", __func__, - fdt_addr, of_offset, phy_info, reg); - return -1; - } - if (reg_offset % 0x1000 || reg_offset > 0x3000 || reg_offset < 0) { - debug("%s(%p, %d, %p): Error: reg_offset 0x%x undefined or out of range\n", - __func__, fdt_addr, of_offset, phy_info, reg_offset); - return -1; - } - if (!phy_info->cs4343_info) { - debug("%s: Error: phy info cs4343 datastructure is NULL\n", __func__); + if (bus->type != CVMX_I2C_BUS_OCTEON) return -1; - } - debug("%s(%p, %d, %p): %s, reg: %d, slice offset: 0x%x\n", __func__, fdt_addr, of_offset, - phy_info, fdt_get_name(fdt_addr, of_offset, NULL), reg, reg_offset); - slice = &phy_info->cs4343_info->slice[reg]; - slice->name = fdt_get_name(fdt_addr, of_offset, NULL); - slice->mphy = phy_info->cs4343_info; - slice->phy_info = phy_info; - slice->of_offset = of_offset; - slice->slice_no = reg; - slice->reg_offset = reg_offset; - /* SR settings */ - slice->sr_stx_cmode_res = cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-cmode-res", 3); - slice->sr_stx_drv_lower_cm = - cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-drv-lower-cm", 8); - slice->sr_stx_level = cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-level", 0x1c); - slice->sr_stx_pre_peak = cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-pre-peak", 1); - slice->sr_stx_muxsubrate_sel = - cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-muxsubrate-sel", 0); - slice->sr_stx_post_peak = cvmx_fdt_get_int(fdt_addr, of_offset, "sr-stx-post-peak", 8); - /* CX settings */ - slice->cx_stx_cmode_res = cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-cmode-res", 3); - slice->cx_stx_drv_lower_cm = - cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-drv-lower-cm", 8); - slice->cx_stx_level = cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-level", 0x1c); - slice->cx_stx_pre_peak = cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-pre-peak", 1); - slice->cx_stx_muxsubrate_sel = - cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-muxsubrate-sel", 0); - slice->cx_stx_post_peak = cvmx_fdt_get_int(fdt_addr, of_offset, "cx-stx-post-peak", 0xC); - /* 1000Base-X settings */ - /* CX settings */ - slice->basex_stx_cmode_res = - cvmx_fdt_get_int(fdt_addr, of_offset, "basex-stx-cmode-res", 3); - slice->basex_stx_drv_lower_cm = - cvmx_fdt_get_int(fdt_addr, of_offset, "basex-stx-drv-lower-cm", 8); - slice->basex_stx_level = cvmx_fdt_get_int(fdt_addr, of_offset, - "basex-stx-level", 0x1c); - slice->basex_stx_pre_peak = cvmx_fdt_get_int(fdt_addr, of_offset, - "basex-stx-pre-peak", 1); - slice->basex_stx_muxsubrate_sel = - cvmx_fdt_get_int(fdt_addr, of_offset, - "basex-stx-muxsubrate-sel", 0); - slice->basex_stx_post_peak = - cvmx_fdt_get_int(fdt_addr, of_offset, "basex-stx-post-peak", 8); - /* Get the link LED gpio pin */ - slice->link_gpio = cvmx_fdt_get_int(fdt_addr, of_offset, - "link-led-gpio", -1); - slice->error_gpio = cvmx_fdt_get_int(fdt_addr, of_offset, - "error-led-gpio", -1); - slice->los_gpio = cvmx_fdt_get_int(fdt_addr, of_offset, - "los-input-gpio", -1); - slice->link_inverted = cvmx_fdt_get_bool(fdt_addr, of_offset, - "link-led-gpio-inverted"); - slice->error_inverted = cvmx_fdt_get_bool(fdt_addr, of_offset, - "error-led-gpio-inverted"); - slice->los_inverted = cvmx_fdt_get_bool(fdt_addr, of_offset, - "los-input-gpio-inverted"); - /* Convert GPIOs to be die based if they're not already */ - if (slice->link_gpio > 4 && slice->link_gpio <= 8) - slice->link_gpio -= 4; - if (slice->error_gpio > 4 && slice->error_gpio <= 8) - slice->error_gpio -= 4; - if (slice->los_gpio > 4 && slice->los_gpio <= 8) - slice->los_gpio -= 4; - - return reg; + return bus->channel; }
/** - * @INTERNAL - * Parses either a CS4343 phy or a slice of the phy from the device tree - * @param[in] fdt_addr Address of FDT - * @param of_offset offset of slice or phy in device tree - * @param phy_info phy_info data structure to fill in + * Frees all entries for an i2c bus descriptor * - * Return: 0 for success, -1 on error + * @param bus bus to free + * + * @return 0 */ -int cvmx_fdt_parse_cs4343(const void *fdt_addr, int of_offset, struct cvmx_phy_info *phy_info) +int cvmx_fdt_free_i2c_bus(struct cvmx_fdt_i2c_bus_info *bus) { - int of_slice = -1; - struct cvmx_cs4343_info *cs4343; - int err = -1; - int reg; - - debug("%s(%p, %d, %p): %s (%s)\n", __func__, - fdt_addr, of_offset, phy_info, - fdt_get_name(fdt_addr, of_offset, NULL), - (const char *)fdt_getprop(fdt_addr, of_offset, "compatible", NULL)); + struct cvmx_fdt_i2c_bus_info *last;
- if (!phy_info->cs4343_info) - phy_info->cs4343_info = __cvmx_fdt_alloc(sizeof(struct cvmx_cs4343_info)); - if (!phy_info->cs4343_info) { - debug("%s: Error: out of memory!\n", __func__); - return -1; - } - cs4343 = phy_info->cs4343_info; - /* If we're passed to a slice then process only that slice */ - if (!fdt_node_check_compatible(fdt_addr, of_offset, "cortina,cs4343-slice")) { - err = 0; - of_slice = of_offset; - of_offset = fdt_parent_offset(fdt_addr, of_offset); - reg = cvmx_fdt_parse_cs4343_slice(fdt_addr, of_slice, phy_info); - if (reg >= 0) - phy_info->cs4343_slice_info = &cs4343->slice[reg]; - else - err = reg; - } else if (!fdt_node_check_compatible(fdt_addr, of_offset, - "cortina,cs4343")) { - /* Walk through and process all of the slices */ - of_slice = - fdt_node_offset_by_compatible(fdt_addr, of_offset, "cortina,cs4343-slice"); - while (of_slice > 0 && fdt_parent_offset(fdt_addr, of_slice) == - of_offset) { - debug("%s: Parsing slice %s\n", __func__, - fdt_get_name(fdt_addr, of_slice, NULL)); - err = cvmx_fdt_parse_cs4343_slice(fdt_addr, of_slice, - phy_info); - if (err < 0) - break; - of_slice = fdt_node_offset_by_compatible(fdt_addr, - of_slice, - "cortina,cs4343-slice"); - } - } else { - debug("%s: Error: unknown compatible string %s for %s\n", __func__, - (const char *)fdt_getprop(fdt_addr, of_offset, - "compatible", NULL), - fdt_get_name(fdt_addr, of_offset, NULL)); + while (bus) { + last = bus; + bus = bus->child; + free(last); } - - if (err >= 0) { - cs4343->name = fdt_get_name(fdt_addr, of_offset, NULL); - cs4343->phy_info = phy_info; - cs4343->of_offset = of_offset; - } - - return err < 0 ? -1 : 0; + return 0; } diff --git a/arch/mips/mach-octeon/cvmx-helper-util.c b/arch/mips/mach-octeon/cvmx-helper-util.c index 92298fd8d1e3..6d775eee9245 100644 --- a/arch/mips/mach-octeon/cvmx-helper-util.c +++ b/arch/mips/mach-octeon/cvmx-helper-util.c @@ -181,127 +181,6 @@ const char *cvmx_helper_interface_mode_to_string(cvmx_helper_interface_mode_t mo return "UNKNOWN"; }
-/** - * Debug routine to dump the packet structure to the console - * - * @param work Work queue entry containing the packet to dump - * @return - */ -int cvmx_helper_dump_packet(cvmx_wqe_t *work) -{ - u64 count; - u64 remaining_bytes; - union cvmx_buf_ptr buffer_ptr; - cvmx_buf_ptr_pki_t bptr; - cvmx_wqe_78xx_t *wqe = (void *)work; - u64 start_of_buffer; - u8 *data_address; - u8 *end_of_data; - - if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { - cvmx_pki_dump_wqe(wqe); - cvmx_wqe_pki_errata_20776(work); - } else { - debug("WORD0 = %lx\n", (unsigned long)work->word0.u64); - debug("WORD1 = %lx\n", (unsigned long)work->word1.u64); - debug("WORD2 = %lx\n", (unsigned long)work->word2.u64); - debug("Packet Length: %u\n", cvmx_wqe_get_len(work)); - debug(" Input Port: %u\n", cvmx_wqe_get_port(work)); - debug(" QoS: %u\n", cvmx_wqe_get_qos(work)); - debug(" Buffers: %u\n", cvmx_wqe_get_bufs(work)); - } - - if (cvmx_wqe_get_bufs(work) == 0) { - int wqe_pool; - - if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { - debug("%s: ERROR: Unexpected bufs==0 in WQE\n", __func__); - return -1; - } - wqe_pool = (int)cvmx_fpa_get_wqe_pool(); - buffer_ptr.u64 = 0; - buffer_ptr.s.pool = wqe_pool; - - buffer_ptr.s.size = 128; - buffer_ptr.s.addr = cvmx_ptr_to_phys(work->packet_data); - if (cvmx_likely(!work->word2.s.not_IP)) { - union cvmx_pip_ip_offset pip_ip_offset; - - pip_ip_offset.u64 = csr_rd(CVMX_PIP_IP_OFFSET); - buffer_ptr.s.addr += - (pip_ip_offset.s.offset << 3) - work->word2.s.ip_offset; - buffer_ptr.s.addr += (work->word2.s.is_v6 ^ 1) << 2; - } else { - /* - * WARNING: This code assume that the packet - * is not RAW. If it was, we would use - * PIP_GBL_CFG[RAW_SHF] instead of - * PIP_GBL_CFG[NIP_SHF]. - */ - union cvmx_pip_gbl_cfg pip_gbl_cfg; - - pip_gbl_cfg.u64 = csr_rd(CVMX_PIP_GBL_CFG); - buffer_ptr.s.addr += pip_gbl_cfg.s.nip_shf; - } - } else { - buffer_ptr = work->packet_ptr; - } - - remaining_bytes = cvmx_wqe_get_len(work); - - while (remaining_bytes) { - /* native cn78xx buffer format, unless legacy-translated */ - if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE) && !wqe->pki_wqe_translated) { - bptr.u64 = buffer_ptr.u64; - /* XXX- assumes cache-line aligned buffer */ - start_of_buffer = (bptr.addr >> 7) << 7; - debug(" Buffer Start:%llx\n", (unsigned long long)start_of_buffer); - debug(" Buffer Data: %llx\n", (unsigned long long)bptr.addr); - debug(" Buffer Size: %u\n", bptr.size); - data_address = (uint8_t *)cvmx_phys_to_ptr(bptr.addr); - end_of_data = data_address + bptr.size; - } else { - start_of_buffer = ((buffer_ptr.s.addr >> 7) - buffer_ptr.s.back) << 7; - debug(" Buffer Start:%llx\n", (unsigned long long)start_of_buffer); - debug(" Buffer I : %u\n", buffer_ptr.s.i); - debug(" Buffer Back: %u\n", buffer_ptr.s.back); - debug(" Buffer Pool: %u\n", buffer_ptr.s.pool); - debug(" Buffer Data: %llx\n", (unsigned long long)buffer_ptr.s.addr); - debug(" Buffer Size: %u\n", buffer_ptr.s.size); - data_address = (uint8_t *)cvmx_phys_to_ptr(buffer_ptr.s.addr); - end_of_data = data_address + buffer_ptr.s.size; - } - - debug("\t\t"); - count = 0; - while (data_address < end_of_data) { - if (remaining_bytes == 0) - break; - - remaining_bytes--; - debug("%02x", (unsigned int)*data_address); - data_address++; - if (remaining_bytes && count == 7) { - debug("\n\t\t"); - count = 0; - } else { - count++; - } - } - debug("\n"); - - if (remaining_bytes) { - if (octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE) && - !wqe->pki_wqe_translated) - buffer_ptr.u64 = *(uint64_t *)cvmx_phys_to_ptr(bptr.addr - 8); - else - buffer_ptr.u64 = - *(uint64_t *)cvmx_phys_to_ptr(buffer_ptr.s.addr - 8); - } - } - return 0; -} - /** * @INTERNAL * @@ -678,68 +557,6 @@ void cvmx_helper_free_packet_data(cvmx_wqe_t *work) } }
-void cvmx_helper_setup_legacy_red(int pass_thresh, int drop_thresh) -{ - unsigned int node = cvmx_get_node_num(); - int aura, bpid; - int buf_cnt; - bool ena_red = 0, ena_drop = 0, ena_bp = 0; - -#define FPA_RED_AVG_DLY 1 -#define FPA_RED_LVL_DLY 3 -#define FPA_QOS_AVRG 0 - /* Trying to make it backward compatible with older chips */ - - /* Setting up avg_dly and prb_dly, enable bits */ - if (octeon_has_feature(OCTEON_FEATURE_FPA3)) { - cvmx_fpa3_config_red_params(node, FPA_QOS_AVRG, - FPA_RED_LVL_DLY, FPA_RED_AVG_DLY); - } - - /* Disable backpressure on queued buffers which is aura in 78xx*/ - /* - * Assumption is that all packets from all interface and ports goes - * in same poolx/aurax for backward compatibility - */ - aura = cvmx_fpa_get_packet_pool(); - buf_cnt = cvmx_fpa_get_packet_pool_buffer_count(); - pass_thresh = buf_cnt - pass_thresh; - drop_thresh = buf_cnt - drop_thresh; - /* Map aura to bpid 0*/ - bpid = 0; - cvmx_pki_write_aura_bpid(node, aura, bpid); - /* Don't enable back pressure */ - ena_bp = 0; - /* enable RED */ - ena_red = 1; - /* - * This will enable RED on all interfaces since - * they all have packet buffer coming from same aura - */ - cvmx_helper_setup_aura_qos(node, aura, ena_red, ena_drop, pass_thresh, - drop_thresh, ena_bp, 0); -} - -/** - * Setup Random Early Drop to automatically begin dropping packets. - * - * @param pass_thresh - * Packets will begin slowly dropping when there are less than - * this many packet buffers free in FPA 0. - * @param drop_thresh - * All incoming packets will be dropped when there are less - * than this many free packet buffers in FPA 0. - * Return: Zero on success. Negative on failure - */ -int cvmx_helper_setup_red(int pass_thresh, int drop_thresh) -{ - if (octeon_has_feature(OCTEON_FEATURE_PKI)) - cvmx_helper_setup_legacy_red(pass_thresh, drop_thresh); - else - cvmx_ipd_setup_red(pass_thresh, drop_thresh); - return 0; -} - /** * @INTERNAL * Setup the common GMX settings that determine the number of @@ -979,35 +796,6 @@ int cvmx_helper_get_bpid(int interface, int port) return CVMX_INVALID_BPID; }
-/** - * Display interface statistics. - * - * @param port IPD/PKO port number - * - * Return: none - */ -void cvmx_helper_show_stats(int port) -{ - cvmx_pip_port_status_t status; - cvmx_pko_port_status_t pko_status; - - /* ILK stats */ - if (octeon_has_feature(OCTEON_FEATURE_ILK)) - __cvmx_helper_ilk_show_stats(); - - /* PIP stats */ - cvmx_pip_get_port_stats(port, 0, &status); - debug("port %d: the number of packets - ipd: %d\n", port, - (int)status.packets); - - /* PKO stats */ - cvmx_pko_get_port_status(port, 0, &pko_status); - debug("port %d: the number of packets - pko: %d\n", port, - (int)pko_status.packets); - - /* TODO: other stats */ -} - /** * Returns the interface number for an IPD/PKO port number. * @@ -1187,39 +975,3 @@ int cvmx_helper_get_interface_index_num(int ipd_port)
return -1; } - -/** - * Prints out a buffer with the address, hex bytes, and ASCII - * - * @param addr Start address to print on the left - * @param[in] buffer array of bytes to print - * @param count Number of bytes to print - */ -void cvmx_print_buffer_u8(unsigned int addr, const uint8_t *buffer, - size_t count) -{ - uint i; - - while (count) { - unsigned int linelen = count < 16 ? count : 16; - - debug("%08x:", addr); - - for (i = 0; i < linelen; i++) - debug(" %0*x", 2, buffer[i]); - - while (i++ < 17) - debug(" "); - - for (i = 0; i < linelen; i++) { - if (buffer[i] >= 0x20 && buffer[i] < 0x7f) - debug("%c", buffer[i]); - else - debug("."); - } - debug("\n"); - addr += linelen; - buffer += linelen; - count -= linelen; - } -} diff --git a/arch/mips/mach-octeon/cvmx-helper.c b/arch/mips/mach-octeon/cvmx-helper.c index d0620d6cda0f..ccec57edf844 100644 --- a/arch/mips/mach-octeon/cvmx-helper.c +++ b/arch/mips/mach-octeon/cvmx-helper.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020 Marvell International Ltd. + * Copyright (C) 2020-2022 Marvell International Ltd. * * Helper functions for common, but complicated tasks. */ @@ -302,20 +302,6 @@ static const struct iface_ops iface_ops_npi = { .enable = __cvmx_helper_npi_enable, };
-/** - * @INTERNAL - * This structure specifies the interface methods used by interfaces - * configured as srio. - */ -static const struct iface_ops iface_ops_srio = { - .mode = CVMX_HELPER_INTERFACE_MODE_SRIO, - .enumerate = __cvmx_helper_srio_probe, - .probe = __cvmx_helper_srio_probe, - .enable = __cvmx_helper_srio_enable, - .link_get = __cvmx_helper_srio_link_get, - .link_set = __cvmx_helper_srio_link_set, -}; - /** * @INTERNAL * This structure specifies the interface methods used by interfaces @@ -442,35 +428,6 @@ int __cvmx_helper_init_interface(int xiface, int num_ipd_ports, int has_fcs, return 0; }
-/* - * Shut down the interfaces; free the resources. - * @INTERNAL - */ -void __cvmx_helper_shutdown_interfaces_node(unsigned int node) -{ - int i; - int nifaces; /* number of interfaces */ - struct cvmx_iface *piface; - - nifaces = cvmx_helper_get_number_of_interfaces(); - for (i = 0; i < nifaces; i++) { - piface = &cvmx_interfaces[node][i]; - - /* - * For SE apps, bootmem was meant to be allocated and never - * freed. - */ - piface->cvif_ipd_port_link_info = 0; - } -} - -void __cvmx_helper_shutdown_interfaces(void) -{ - unsigned int node = cvmx_get_node_num(); - - __cvmx_helper_shutdown_interfaces_node(node); -} - int __cvmx_helper_set_link_info(int xiface, int index, cvmx_helper_link_info_t link_info) { struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); @@ -525,27 +482,12 @@ u64 cvmx_rgmii_backpressure_dis = 1; typedef int (*cvmx_export_config_t)(void); cvmx_export_config_t cvmx_export_app_config;
-void cvmx_rgmii_set_back_pressure(uint64_t backpressure_dis) -{ - cvmx_rgmii_backpressure_dis = backpressure_dis; -} - /* * internal functions that are not exported in the .h file but must be * declared to make gcc happy. */ extern cvmx_helper_link_info_t __cvmx_helper_get_link_info(int interface, int port);
-/** - * cvmx_override_iface_phy_mode(int interface, int index) is a function pointer. - * It is meant to allow customization of interfaces which do not have a PHY. - * - * @returns 0 if MAC decides TX_CONFIG_REG or 1 if PHY decides TX_CONFIG_REG. - * - * If this function pointer is NULL then it defaults to the MAC. - */ -int (*cvmx_override_iface_phy_mode)(int interface, int index); - /** * cvmx_override_ipd_port_setup(int ipd_port) is a function * pointer. It is meant to allow customization of the IPD @@ -607,7 +549,7 @@ int __cvmx_helper_early_ports_on_interface(int interface) * chip and configuration, this can be 1-16. A value of 0 * specifies that the interface doesn't exist or isn't usable. * - * @param xiface xiface to get the port count for + * @param xiface to get the port count for * * Return: Number of ports on interface. Can be Zero. */ @@ -919,15 +861,9 @@ static cvmx_helper_interface_mode_t __cvmx_get_mode_cnf75xx(int xiface) break; } } else if ((interface < 3) && OCTEON_IS_MODEL(OCTEON_CNF75XX)) { - cvmx_sriox_status_reg_t sriox_status_reg; - int srio_port = interface - 1; - - sriox_status_reg.u64 = csr_rd(CVMX_SRIOX_STATUS_REG(srio_port)); - - if (sriox_status_reg.s.srio) - iface_ops[interface] = &iface_ops_srio; - else - iface_ops[interface] = &iface_ops_dis; + /* SRIO is disabled for now */ + printf("SRIO disabled for now!\n"); + iface_ops[interface] = &iface_ops_dis; } else if (interface == 3) { /* DPI */ iface_ops[interface] = &iface_ops_npi; } else if (interface == 4) { /* LOOP */ @@ -1046,7 +982,6 @@ static cvmx_helper_interface_mode_t __cvmx_get_mode_octeon2(int interface) (OCTEON_IS_MODEL(OCTEON_CN66XX) && interface >= 4 && interface <= 7)) { /* Only present in CN63XX & CN66XX Octeon model */ - union cvmx_sriox_status_reg sriox_status_reg;
/* cn66xx pass1.0 has only 2 SRIO interfaces. */ if ((interface == 5 || interface == 7) && @@ -1059,12 +994,9 @@ static cvmx_helper_interface_mode_t __cvmx_get_mode_octeon2(int interface) */ iface_ops[interface] = &iface_ops_dis; } else { - sriox_status_reg.u64 = - csr_rd(CVMX_SRIOX_STATUS_REG(interface - 4)); - if (sriox_status_reg.s.srio) - iface_ops[interface] = &iface_ops_srio; - else - iface_ops[interface] = &iface_ops_dis; + /* SRIO is disabled for now */ + printf("SRIO disabled for now!\n"); + iface_ops[interface] = &iface_ops_dis; } } else if (OCTEON_IS_MODEL(OCTEON_CN66XX)) { union cvmx_mio_qlmx_cfg mio_qlm_cfg; @@ -1438,16 +1370,6 @@ static int __cvmx_helper_global_setup_backpressure(int node) return 0; }
-/** - * @INTERNAL - * Verify the per port IPD backpressure is aligned properly. - * Return: Zero if working, non zero if misaligned - */ -int __cvmx_helper_backpressure_is_misaligned(void) -{ - return 0; -} - /** * @INTERNAL * Enable packet input/output from the hardware. This function is @@ -1467,7 +1389,7 @@ int __cvmx_helper_packet_hardware_enable(int xiface)
if (iface_node_ops[xi.node][xi.interface]->enable) result = iface_node_ops[xi.node][xi.interface]->enable(xiface); - result |= __cvmx_helper_board_hardware_enable(xiface); + return result; }
@@ -1609,7 +1531,8 @@ int cvmx_helper_initialize_packet_io_node(unsigned int node) /* Skip invalid/disabled interfaces */ if (cvmx_helper_ports_on_interface(xiface) <= 0) continue; - printf("Node %d Interface %d has %d ports (%s)\n", node, interface, + debug("Node %d Interface %d has %d ports (%s)\n", + node, interface, cvmx_helper_ports_on_interface(xiface), cvmx_helper_interface_mode_to_string( cvmx_helper_interface_get_mode(xiface))); @@ -1730,445 +1653,6 @@ int cvmx_agl_set_backpressure_override(u32 interface, uint32_t port_mask) return 0; }
-/** - * Helper function for global packet IO shutdown - */ -int cvmx_helper_shutdown_packet_io_global_cn78xx(int node) -{ - int num_interfaces = cvmx_helper_get_number_of_interfaces(); - cvmx_wqe_t *work; - int interface; - int result = 0; - - /* Shut down all interfaces and disable TX and RX on all ports */ - for (interface = 0; interface < num_interfaces; interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - int index; - int num_ports = cvmx_helper_ports_on_interface(xiface); - - if (num_ports > 4) - num_ports = 4; - - cvmx_bgx_set_backpressure_override(xiface, 0); - for (index = 0; index < num_ports; index++) { - cvmx_helper_link_info_t link_info; - - if (!cvmx_helper_is_port_valid(xiface, index)) - continue; - - cvmx_helper_bgx_shutdown_port(xiface, index); - - /* Turn off link LEDs */ - link_info.u64 = 0; - cvmx_helper_update_link_led(xiface, index, link_info); - } - } - - /* Stop input first */ - cvmx_helper_pki_shutdown(node); - - /* Retrieve all packets from the SSO and free them */ - result = 0; - while ((work = cvmx_pow_work_request_sync(CVMX_POW_WAIT))) { - cvmx_helper_free_pki_pkt_data(work); - cvmx_wqe_pki_free(work); - result++; - } - - if (result > 0) - debug("%s: Purged %d packets from SSO\n", __func__, result); - - /* - * No need to wait for PKO queues to drain, - * dq_close() drains the queues to NULL. - */ - - /* Shutdown PKO interfaces */ - for (interface = 0; interface < num_interfaces; interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - - cvmx_helper_pko3_shut_interface(xiface); - } - - /* Disable MAC address filtering */ - for (interface = 0; interface < num_interfaces; interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - - switch (cvmx_helper_interface_get_mode(xiface)) { - case CVMX_HELPER_INTERFACE_MODE_XAUI: - case CVMX_HELPER_INTERFACE_MODE_RXAUI: - case CVMX_HELPER_INTERFACE_MODE_XLAUI: - case CVMX_HELPER_INTERFACE_MODE_XFI: - case CVMX_HELPER_INTERFACE_MODE_10G_KR: - case CVMX_HELPER_INTERFACE_MODE_40G_KR4: - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_MIXED: { - int index; - int num_ports = cvmx_helper_ports_on_interface(xiface); - - for (index = 0; index < num_ports; index++) { - if (!cvmx_helper_is_port_valid(xiface, index)) - continue; - - /* Reset MAC filtering */ - cvmx_helper_bgx_rx_adr_ctl(node, interface, index, 0, 0, 0); - } - break; - } - default: - break; - } - } - - for (interface = 0; interface < num_interfaces; interface++) { - int index; - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - int num_ports = cvmx_helper_ports_on_interface(xiface); - - for (index = 0; index < num_ports; index++) { - /* Doing this twice should clear it since no packets - * can be received. - */ - cvmx_update_rx_activity_led(xiface, index, false); - cvmx_update_rx_activity_led(xiface, index, false); - } - } - - /* Shutdown the PKO unit */ - result = cvmx_helper_pko3_shutdown(node); - - /* Release interface structures */ - __cvmx_helper_shutdown_interfaces(); - - return result; -} - -/** - * Undo the initialization performed in - * cvmx_helper_initialize_packet_io_global(). After calling this routine and the - * local version on each core, packet IO for Octeon will be disabled and placed - * in the initial reset state. It will then be safe to call the initialize - * later on. Note that this routine does not empty the FPA pools. It frees all - * buffers used by the packet IO hardware to the FPA so a function emptying the - * FPA after shutdown should find all packet buffers in the FPA. - * - * Return: Zero on success, negative on failure. - */ -int cvmx_helper_shutdown_packet_io_global(void) -{ - const int timeout = 5; /* Wait up to 5 seconds for timeouts */ - int result = 0; - int num_interfaces = cvmx_helper_get_number_of_interfaces(); - int interface; - int num_ports; - int index; - struct cvmx_buffer_list *pool0_buffers; - struct cvmx_buffer_list *pool0_buffers_tail; - cvmx_wqe_t *work; - union cvmx_ipd_ctl_status ipd_ctl_status; - int wqe_pool = (int)cvmx_fpa_get_wqe_pool(); - int node = cvmx_get_node_num(); - cvmx_pcsx_mrx_control_reg_t control_reg; - - if (octeon_has_feature(OCTEON_FEATURE_BGX)) - return cvmx_helper_shutdown_packet_io_global_cn78xx(node); - - /* Step 1: Disable all backpressure */ - for (interface = 0; interface < num_interfaces; interface++) { - cvmx_helper_interface_mode_t mode = - cvmx_helper_interface_get_mode(interface); - - if (mode == CVMX_HELPER_INTERFACE_MODE_AGL) - cvmx_agl_set_backpressure_override(interface, 0x1); - else if (mode != CVMX_HELPER_INTERFACE_MODE_DISABLED) - cvmx_gmx_set_backpressure_override(interface, 0xf); - } - - /* Step 2: Wait for the PKO queues to drain */ - result = __cvmx_helper_pko_drain(); - if (result < 0) { - debug("WARNING: %s: Failed to drain some PKO queues\n", - __func__); - } - - /* Step 3: Disable TX and RX on all ports */ - for (interface = 0; interface < num_interfaces; interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, - interface); - - switch (cvmx_helper_interface_get_mode(interface)) { - case CVMX_HELPER_INTERFACE_MODE_DISABLED: - case CVMX_HELPER_INTERFACE_MODE_PCIE: - /* Not a packet interface */ - break; - case CVMX_HELPER_INTERFACE_MODE_NPI: - case CVMX_HELPER_INTERFACE_MODE_SRIO: - case CVMX_HELPER_INTERFACE_MODE_ILK: - /* - * We don't handle the NPI/NPEI/SRIO packet - * engines. The caller must know these are - * idle. - */ - break; - case CVMX_HELPER_INTERFACE_MODE_LOOP: - /* - * Nothing needed. Once PKO is idle, the - * loopback devices must be idle. - */ - break; - case CVMX_HELPER_INTERFACE_MODE_SPI: - /* - * SPI cannot be disabled from Octeon. It is - * the responsibility of the caller to make - * sure SPI is idle before doing shutdown. - * - * Fall through and do the same processing as - * RGMII/GMII. - */ - fallthrough; - case CVMX_HELPER_INTERFACE_MODE_GMII: - case CVMX_HELPER_INTERFACE_MODE_RGMII: - /* Disable outermost RX at the ASX block */ - csr_wr(CVMX_ASXX_RX_PRT_EN(interface), 0); - num_ports = cvmx_helper_ports_on_interface(xiface); - if (num_ports > 4) - num_ports = 4; - for (index = 0; index < num_ports; index++) { - union cvmx_gmxx_prtx_cfg gmx_cfg; - - if (!cvmx_helper_is_port_valid(interface, index)) - continue; - gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); - gmx_cfg.s.en = 0; - csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmx_cfg.u64); - /* Poll the GMX state machine waiting for it to become idle */ - csr_wr(CVMX_NPI_DBG_SELECT, - interface * 0x800 + index * 0x100 + 0x880); - if (CVMX_WAIT_FOR_FIELD64(CVMX_DBG_DATA, union cvmx_dbg_data, - data & 7, ==, 0, timeout * 1000000)) { - debug("GMX RX path timeout waiting for idle\n"); - result = -1; - } - if (CVMX_WAIT_FOR_FIELD64(CVMX_DBG_DATA, union cvmx_dbg_data, - data & 0xf, ==, 0, timeout * 1000000)) { - debug("GMX TX path timeout waiting for idle\n"); - result = -1; - } - } - /* Disable outermost TX at the ASX block */ - csr_wr(CVMX_ASXX_TX_PRT_EN(interface), 0); - /* Disable interrupts for interface */ - csr_wr(CVMX_ASXX_INT_EN(interface), 0); - csr_wr(CVMX_GMXX_TX_INT_EN(interface), 0); - break; - case CVMX_HELPER_INTERFACE_MODE_XAUI: - case CVMX_HELPER_INTERFACE_MODE_RXAUI: - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_QSGMII: - case CVMX_HELPER_INTERFACE_MODE_PICMG: - num_ports = cvmx_helper_ports_on_interface(xiface); - if (num_ports > 4) - num_ports = 4; - for (index = 0; index < num_ports; index++) { - union cvmx_gmxx_prtx_cfg gmx_cfg; - - if (!cvmx_helper_is_port_valid(interface, index)) - continue; - gmx_cfg.u64 = csr_rd(CVMX_GMXX_PRTX_CFG(index, interface)); - gmx_cfg.s.en = 0; - csr_wr(CVMX_GMXX_PRTX_CFG(index, interface), gmx_cfg.u64); - if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(index, interface), - union cvmx_gmxx_prtx_cfg, rx_idle, ==, 1, - timeout * 1000000)) { - debug("GMX RX path timeout waiting for idle\n"); - result = -1; - } - if (CVMX_WAIT_FOR_FIELD64(CVMX_GMXX_PRTX_CFG(index, interface), - union cvmx_gmxx_prtx_cfg, tx_idle, ==, 1, - timeout * 1000000)) { - debug("GMX TX path timeout waiting for idle\n"); - result = -1; - } - /* For SGMII some PHYs require that the PCS - * interface be powered down and reset (i.e. - * Atheros/Qualcomm PHYs). - */ - if (cvmx_helper_interface_get_mode(interface) == - CVMX_HELPER_INTERFACE_MODE_SGMII) { - u64 reg; - - reg = CVMX_PCSX_MRX_CONTROL_REG(index, interface); - /* Power down the interface */ - control_reg.u64 = csr_rd(reg); - control_reg.s.pwr_dn = 1; - csr_wr(reg, control_reg.u64); - csr_rd(reg); - } - } - break; - case CVMX_HELPER_INTERFACE_MODE_AGL: { - int port = cvmx_helper_agl_get_port(interface); - union cvmx_agl_gmx_prtx_cfg agl_gmx_cfg; - - agl_gmx_cfg.u64 = csr_rd(CVMX_AGL_GMX_PRTX_CFG(port)); - agl_gmx_cfg.s.en = 0; - csr_wr(CVMX_AGL_GMX_PRTX_CFG(port), agl_gmx_cfg.u64); - if (CVMX_WAIT_FOR_FIELD64(CVMX_AGL_GMX_PRTX_CFG(port), - union cvmx_agl_gmx_prtx_cfg, rx_idle, ==, 1, - timeout * 1000000)) { - debug("AGL RX path timeout waiting for idle\n"); - result = -1; - } - if (CVMX_WAIT_FOR_FIELD64(CVMX_AGL_GMX_PRTX_CFG(port), - union cvmx_agl_gmx_prtx_cfg, tx_idle, ==, 1, - timeout * 1000000)) { - debug("AGL TX path timeout waiting for idle\n"); - result = -1; - } - } break; - default: - break; - } - } - - /* Step 4: Retrieve all packets from the POW and free them */ - while ((work = cvmx_pow_work_request_sync(CVMX_POW_WAIT))) { - cvmx_helper_free_packet_data(work); - cvmx_fpa1_free(work, wqe_pool, 0); - } - - /* Step 5 */ - cvmx_ipd_disable(); - - /* - * Step 6: Drain all prefetched buffers from IPD/PIP. Note that IPD/PIP - * have not been reset yet - */ - __cvmx_ipd_free_ptr(); - - /* Step 7: Free the PKO command buffers and put PKO in reset */ - cvmx_pko_shutdown(); - - /* Step 8: Disable MAC address filtering */ - for (interface = 0; interface < num_interfaces; interface++) { - int xiface = cvmx_helper_node_interface_to_xiface(node, interface); - - switch (cvmx_helper_interface_get_mode(interface)) { - case CVMX_HELPER_INTERFACE_MODE_DISABLED: - case CVMX_HELPER_INTERFACE_MODE_PCIE: - case CVMX_HELPER_INTERFACE_MODE_SRIO: - case CVMX_HELPER_INTERFACE_MODE_ILK: - case CVMX_HELPER_INTERFACE_MODE_NPI: - case CVMX_HELPER_INTERFACE_MODE_LOOP: - break; - case CVMX_HELPER_INTERFACE_MODE_XAUI: - case CVMX_HELPER_INTERFACE_MODE_RXAUI: - case CVMX_HELPER_INTERFACE_MODE_GMII: - case CVMX_HELPER_INTERFACE_MODE_RGMII: - case CVMX_HELPER_INTERFACE_MODE_SPI: - case CVMX_HELPER_INTERFACE_MODE_SGMII: - case CVMX_HELPER_INTERFACE_MODE_QSGMII: - case CVMX_HELPER_INTERFACE_MODE_PICMG: - num_ports = cvmx_helper_ports_on_interface(xiface); - if (num_ports > 4) - num_ports = 4; - for (index = 0; index < num_ports; index++) { - if (!cvmx_helper_is_port_valid(interface, index)) - continue; - csr_wr(CVMX_GMXX_RXX_ADR_CTL(index, interface), 1); - csr_wr(CVMX_GMXX_RXX_ADR_CAM_EN(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM0(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM1(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM2(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM3(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM4(index, interface), 0); - csr_wr(CVMX_GMXX_RXX_ADR_CAM5(index, interface), 0); - } - break; - case CVMX_HELPER_INTERFACE_MODE_AGL: { - int port = cvmx_helper_agl_get_port(interface); - - csr_wr(CVMX_AGL_GMX_RXX_ADR_CTL(port), 1); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM_EN(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM0(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM1(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM2(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM3(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM4(port), 0); - csr_wr(CVMX_AGL_GMX_RXX_ADR_CAM5(port), 0); - } break; - default: - break; - } - } - - /* - * Step 9: Drain all FPA buffers out of pool 0 before we reset - * IPD/PIP. This is needed to keep IPD_QUE0_FREE_PAGE_CNT in - * sync. We temporarily keep the buffers in the pool0_buffers - * list. - */ - pool0_buffers = NULL; - pool0_buffers_tail = NULL; - while (1) { - struct cvmx_buffer_list *buffer = cvmx_fpa1_alloc(0); - - if (buffer) { - buffer->next = NULL; - - if (!pool0_buffers) - pool0_buffers = buffer; - else - pool0_buffers_tail->next = buffer; - - pool0_buffers_tail = buffer; - } else { - break; - } - } - - /* Step 10: Reset IPD and PIP */ - ipd_ctl_status.u64 = csr_rd(CVMX_IPD_CTL_STATUS); - ipd_ctl_status.s.reset = 1; - csr_wr(CVMX_IPD_CTL_STATUS, ipd_ctl_status.u64); - - /* Make sure IPD has finished reset. */ - if (OCTEON_IS_OCTEON2() || OCTEON_IS_MODEL(OCTEON_CN70XX)) { - if (CVMX_WAIT_FOR_FIELD64(CVMX_IPD_CTL_STATUS, union cvmx_ipd_ctl_status, rst_done, - ==, 0, 1000)) { - debug("IPD reset timeout waiting for idle\n"); - result = -1; - } - } - - /* Step 11: Restore the FPA buffers into pool 0 */ - while (pool0_buffers) { - struct cvmx_buffer_list *n = pool0_buffers->next; - - cvmx_fpa1_free(pool0_buffers, 0, 0); - pool0_buffers = n; - } - - /* Step 12: Release interface structures */ - __cvmx_helper_shutdown_interfaces(); - - return result; -} - -/** - * Does core local shutdown of packet io - * - * Return: Zero on success, non-zero on failure - */ -int cvmx_helper_shutdown_packet_io_local(void) -{ - /* - * Currently there is nothing to do per core. This may change - * in the future. - */ - return 0; -} - /** * Auto configure an IPD/PKO port link state and speed. This * function basically does the equivalent of: @@ -2290,50 +1774,6 @@ int cvmx_helper_link_set(int xipd_port, cvmx_helper_link_info_t link_info) return result; }
-/** - * Configure a port for internal and/or external loopback. Internal loopback - * causes packets sent by the port to be received by Octeon. External loopback - * causes packets received from the wire to sent out again. - * - * @param xipd_port IPD/PKO port to loopback. - * @param enable_internal - * Non zero if you want internal loopback - * @param enable_external - * Non zero if you want external loopback - * - * Return: Zero on success, negative on failure. - */ -int cvmx_helper_configure_loopback(int xipd_port, int enable_internal, int enable_external) -{ - int result = -1; - int xiface = cvmx_helper_get_interface_num(xipd_port); - struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); - int index = cvmx_helper_get_interface_index_num(xipd_port); - - if (index >= cvmx_helper_ports_on_interface(xiface)) - return -1; - - cvmx_helper_interface_get_mode(xiface); - if (iface_node_ops[xi.node][xi.interface]->loopback) - result = iface_node_ops[xi.node][xi.interface]->loopback(xipd_port, enable_internal, - enable_external); - - return result; -} - -void cvmx_helper_setup_simulator_io_buffer_counts(int node, int num_packet_buffers, int pko_buffers) -{ - if (octeon_has_feature(OCTEON_FEATURE_PKI)) { - cvmx_helper_pki_set_dflt_pool_buffer(node, num_packet_buffers); - cvmx_helper_pki_set_dflt_aura_buffer(node, num_packet_buffers); - - } else { - cvmx_ipd_set_packet_pool_buffer_count(num_packet_buffers); - cvmx_ipd_set_wqe_pool_buffer_count(num_packet_buffers); - cvmx_pko_set_cmd_queue_pool_buffer_count(pko_buffers); - } -} - void *cvmx_helper_mem_alloc(int node, uint64_t alloc_size, uint64_t align) { s64 paddr; @@ -2346,266 +1786,3 @@ void *cvmx_helper_mem_alloc(int node, uint64_t alloc_size, uint64_t align) } return cvmx_phys_to_ptr(paddr); } - -void cvmx_helper_mem_free(void *buffer, uint64_t size) -{ - __cvmx_bootmem_phy_free(cvmx_ptr_to_phys(buffer), size, 0); -} - -int cvmx_helper_qos_config_init(cvmx_qos_proto_t qos_proto, cvmx_qos_config_t *qos_cfg) -{ - int i; - - memset(qos_cfg, 0, sizeof(cvmx_qos_config_t)); - qos_cfg->pkt_mode = CVMX_QOS_PKT_MODE_HWONLY; /* Process PAUSEs in hardware only.*/ - qos_cfg->pool_mode = CVMX_QOS_POOL_PER_PORT; /* One Pool per BGX:LMAC.*/ - qos_cfg->pktbuf_size = 2048; /* Fit WQE + MTU in one buffer.*/ - qos_cfg->aura_size = 1024; /* 1K buffers typically enough for any application.*/ - qos_cfg->pko_pfc_en = 1; /* Enable PKO layout for PFC feature. */ - qos_cfg->vlan_num = 1; /* For Stacked VLAN, use 2nd VLAN in the QPG algorithm.*/ - qos_cfg->qos_proto = qos_proto; /* Use PFC flow-control protocol.*/ - qos_cfg->qpg_base = -1; /* QPG Table index is undefined.*/ - qos_cfg->p_time = 0x60; /* PAUSE packets time window.*/ - qos_cfg->p_interval = 0x10; /* PAUSE packets interval.*/ - for (i = 0; i < CVMX_QOS_NUM; i++) { - qos_cfg->groups[i] = i; /* SSO Groups = 0...7 */ - qos_cfg->group_prio[i] = i; /* SSO Group priority = QOS. */ - qos_cfg->drop_thresh[i] = 99; /* 99% of the Aura size.*/ - qos_cfg->red_thresh[i] = 90; /* 90% of the Aura size.*/ - qos_cfg->bp_thresh[i] = 70; /* 70% of the Aura size.*/ - } - return 0; -} - -int cvmx_helper_qos_port_config_update(int xipdport, cvmx_qos_config_t *qos_cfg) -{ - cvmx_user_static_pko_queue_config_t pkocfg; - cvmx_xport_t xp = cvmx_helper_ipd_port_to_xport(xipdport); - int xiface = cvmx_helper_get_interface_num(xipdport); - cvmx_xiface_t xi = cvmx_helper_xiface_to_node_interface(xiface); - - /* Configure PKO port for PFC SQ layout: */ - cvmx_helper_pko_queue_config_get(xp.node, &pkocfg); - pkocfg.pknd.pko_cfg_iface[xi.interface].pfc_enable = 1; - cvmx_helper_pko_queue_config_set(xp.node, &pkocfg); - return 0; -} - -int cvmx_helper_qos_port_setup(int xipdport, cvmx_qos_config_t *qos_cfg) -{ - const int channles = CVMX_QOS_NUM; - int bufsize = qos_cfg->pktbuf_size; - int aura_size = qos_cfg->aura_size; - cvmx_xport_t xp = cvmx_helper_ipd_port_to_xport(xipdport); - int node = xp.node; - int ipdport = xp.port; - int port = cvmx_helper_get_interface_index_num(xp.port); - int xiface = cvmx_helper_get_interface_num(xipdport); - cvmx_xiface_t xi = cvmx_helper_xiface_to_node_interface(xiface); - cvmx_fpa3_pool_t gpool; - cvmx_fpa3_gaura_t gaura; - cvmx_bgxx_cmr_rx_ovr_bp_t ovrbp; - struct cvmx_pki_qpg_config qpgcfg; - struct cvmx_pki_style_config stcfg, stcfg_dflt; - struct cvmx_pki_pkind_config pkcfg; - int chan, bpid, group, qpg; - int bpen, reden, dropen, passthr, dropthr, bpthr; - int nbufs, pkind, style; - char name[32]; - - if (qos_cfg->pool_mode == CVMX_QOS_POOL_PER_PORT) { - /* Allocate and setup packet Pool: */ - nbufs = aura_size * channles; - sprintf(name, "QOS.P%d", ipdport); - gpool = cvmx_fpa3_setup_fill_pool(node, -1 /*auto*/, name, bufsize, nbufs, NULL); - if (!__cvmx_fpa3_pool_valid(gpool)) { - printf("%s: Failed to setup FPA Pool\n", __func__); - return -1; - } - for (chan = 0; chan < channles; chan++) - qos_cfg->gpools[chan] = gpool; - } else { - printf("%s: Invalid pool_mode %d\n", __func__, qos_cfg->pool_mode); - return -1; - } - /* Allocate QPG entries: */ - qos_cfg->qpg_base = cvmx_pki_qpg_entry_alloc(node, -1 /*auto*/, channles); - if (qos_cfg->qpg_base < 0) { - printf("%s: Failed to allocate QPG entry\n", __func__); - return -1; - } - for (chan = 0; chan < channles; chan++) { - /* Allocate and setup Aura, setup BP threshold: */ - gpool = qos_cfg->gpools[chan]; - sprintf(name, "QOS.A%d", ipdport + chan); - gaura = cvmx_fpa3_set_aura_for_pool(gpool, -1 /*auto*/, name, bufsize, aura_size); - if (!__cvmx_fpa3_aura_valid(gaura)) { - printf("%s: Failed to setup FPA Aura for Channel %d\n", __func__, chan); - return -1; - } - qos_cfg->gauras[chan] = gaura; - bpen = 1; - reden = 1; - dropen = 1; - dropthr = (qos_cfg->drop_thresh[chan] * 10 * aura_size) / 1000; - passthr = (qos_cfg->red_thresh[chan] * 10 * aura_size) / 1000; - bpthr = (qos_cfg->bp_thresh[chan] * 10 * aura_size) / 1000; - cvmx_fpa3_setup_aura_qos(gaura, reden, passthr, dropthr, bpen, bpthr); - cvmx_pki_enable_aura_qos(node, gaura.laura, reden, dropen, bpen); - - /* Allocate BPID, link Aura and Channel using BPID: */ - bpid = cvmx_pki_bpid_alloc(node, -1 /*auto*/); - if (bpid < 0) { - printf("%s: Failed to allocate BPID for channel %d\n", - __func__, chan); - return -1; - } - qos_cfg->bpids[chan] = bpid; - cvmx_pki_write_aura_bpid(node, gaura.laura, bpid); - cvmx_pki_write_channel_bpid(node, ipdport + chan, bpid); - - /* Setup QPG entries: */ - group = qos_cfg->groups[chan]; - qpg = qos_cfg->qpg_base + chan; - cvmx_pki_read_qpg_entry(node, qpg, &qpgcfg); - qpgcfg.port_add = chan; - qpgcfg.aura_num = gaura.laura; - qpgcfg.grp_ok = (node << CVMX_WQE_GRP_NODE_SHIFT) | group; - qpgcfg.grp_bad = (node << CVMX_WQE_GRP_NODE_SHIFT) | group; - qpgcfg.grptag_ok = (node << CVMX_WQE_GRP_NODE_SHIFT) | 0; - qpgcfg.grptag_bad = (node << CVMX_WQE_GRP_NODE_SHIFT) | 0; - cvmx_pki_write_qpg_entry(node, qpg, &qpgcfg); - } - /* Allocate and setup STYLE: */ - cvmx_helper_pki_get_dflt_style(node, &stcfg_dflt); - style = cvmx_pki_style_alloc(node, -1 /*auto*/); - cvmx_pki_read_style_config(node, style, CVMX_PKI_CLUSTER_ALL, &stcfg); - stcfg.tag_cfg = stcfg_dflt.tag_cfg; - stcfg.parm_cfg.tag_type = CVMX_POW_TAG_TYPE_ORDERED; - stcfg.parm_cfg.qpg_qos = CVMX_PKI_QPG_QOS_VLAN; - stcfg.parm_cfg.qpg_base = qos_cfg->qpg_base; - stcfg.parm_cfg.qpg_port_msb = 0; - stcfg.parm_cfg.qpg_port_sh = 0; - stcfg.parm_cfg.qpg_dis_grptag = 1; - stcfg.parm_cfg.fcs_strip = 1; - stcfg.parm_cfg.mbuff_size = bufsize - 64; /* Do not use 100% of the buffer. */ - stcfg.parm_cfg.force_drop = 0; - stcfg.parm_cfg.nodrop = 0; - stcfg.parm_cfg.rawdrp = 0; - stcfg.parm_cfg.cache_mode = 2; /* 1st buffer in L2 */ - stcfg.parm_cfg.wqe_vs = qos_cfg->vlan_num; - cvmx_pki_write_style_config(node, style, CVMX_PKI_CLUSTER_ALL, &stcfg); - - /* Setup PKIND: */ - pkind = cvmx_helper_get_pknd(xiface, port); - cvmx_pki_read_pkind_config(node, pkind, &pkcfg); - pkcfg.cluster_grp = 0; /* OCTEON3 has only one cluster group = 0 */ - pkcfg.initial_style = style; - pkcfg.initial_parse_mode = CVMX_PKI_PARSE_LA_TO_LG; - cvmx_pki_write_pkind_config(node, pkind, &pkcfg); - - /* Setup parameters of the QOS packet and enable QOS flow-control: */ - cvmx_bgx_set_pause_pkt_param(xipdport, 0, 0x0180c2000001, 0x8808, qos_cfg->p_time, - qos_cfg->p_interval); - cvmx_bgx_set_flowctl_mode(xipdport, qos_cfg->qos_proto, qos_cfg->pkt_mode); - - /* Enable PKI channel backpressure in the BGX: */ - ovrbp.u64 = csr_rd_node(node, CVMX_BGXX_CMR_RX_OVR_BP(xi.interface)); - ovrbp.s.en &= ~(1 << port); - ovrbp.s.ign_fifo_bp &= ~(1 << port); - csr_wr_node(node, CVMX_BGXX_CMR_RX_OVR_BP(xi.interface), ovrbp.u64); - return 0; -} - -int cvmx_helper_qos_sso_setup(int xipdport, cvmx_qos_config_t *qos_cfg) -{ - const int channels = CVMX_QOS_NUM; - cvmx_sso_grpx_pri_t grppri; - int chan, qos, group; - cvmx_xport_t xp = cvmx_helper_ipd_port_to_xport(xipdport); - int node = xp.node; - - for (chan = 0; chan < channels; chan++) { - qos = cvmx_helper_qos2prio(chan); - group = qos_cfg->groups[qos]; - grppri.u64 = csr_rd_node(node, CVMX_SSO_GRPX_PRI(group)); - grppri.s.pri = qos_cfg->group_prio[chan]; - csr_wr_node(node, CVMX_SSO_GRPX_PRI(group), grppri.u64); - } - return 0; -} - -int cvmx_helper_get_chan_e_name(int chan, char *namebuf, int buflen) -{ - int n, dpichans; - - if ((unsigned int)chan >= CVMX_PKO3_IPD_NUM_MAX) { - printf("%s: Channel %d is out of range (0..4095)\n", __func__, chan); - return -1; - } - if (OCTEON_IS_MODEL(OCTEON_CN78XX)) - dpichans = 64; - else - dpichans = 128; - - if (chan >= 0 && chan < 64) - n = snprintf(namebuf, buflen, "LBK%d", chan); - else if (chan >= 0x100 && chan < (0x100 + dpichans)) - n = snprintf(namebuf, buflen, "DPI%d", chan - 0x100); - else if (chan == 0x200) - n = snprintf(namebuf, buflen, "NQM"); - else if (chan >= 0x240 && chan < (0x240 + (1 << 1) + 2)) - n = snprintf(namebuf, buflen, "SRIO%d:%d", (chan - 0x240) >> 1, - (chan - 0x240) & 0x1); - else if (chan >= 0x400 && chan < (0x400 + (1 << 8) + 256)) - n = snprintf(namebuf, buflen, "ILK%d:%d", (chan - 0x400) >> 8, - (chan - 0x400) & 0xFF); - else if (chan >= 0x800 && chan < (0x800 + (5 << 8) + (3 << 4) + 16)) - n = snprintf(namebuf, buflen, "BGX%d:%d:%d", (chan - 0x800) >> 8, - ((chan - 0x800) >> 4) & 0x3, (chan - 0x800) & 0xF); - else - n = snprintf(namebuf, buflen, "--"); - return n; -} - -#ifdef CVMX_DUMP_DIAGNOSTICS -void cvmx_helper_dump_for_diagnostics(int node) -{ - if (!(OCTEON_IS_OCTEON3() && !OCTEON_IS_MODEL(OCTEON_CN70XX))) { - printf("Diagnostics are not implemented for this model\n"); - return; - } -#ifdef CVMX_DUMP_GSER - { - int qlm, num_qlms; - - num_qlms = cvmx_qlm_get_num(); - for (qlm = 0; qlm < num_qlms; qlm++) { - cvmx_dump_gser_config_node(node, qlm); - cvmx_dump_gser_status_node(node, qlm); - } - } -#endif -#ifdef CVMX_DUMP_BGX - { - int bgx; - - for (bgx = 0; bgx < CVMX_HELPER_MAX_GMX; bgx++) { - cvmx_dump_bgx_config_node(node, bgx); - cvmx_dump_bgx_status_node(node, bgx); - } - } -#endif -#ifdef CVMX_DUMP_PKI - cvmx_pki_config_dump(node); - cvmx_pki_stats_dump(node); -#endif -#ifdef CVMX_DUMP_PKO - cvmx_helper_pko3_config_dump(node); - cvmx_helper_pko3_stats_dump(node); -#endif -#ifdef CVMX_DUMO_SSO - cvmx_sso_config_dump(node); -#endif -} -#endif
This patch adds the newly added C files to the Makefile to enable compilation. This is done in a separate step, to not introduce build breakage while adding the single files with potentially missing externals.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/Makefile | 35 +++++++++++++++++++++++++++++++++- 1 file changed, 34 insertions(+), 1 deletion(-)
diff --git a/arch/mips/mach-octeon/Makefile b/arch/mips/mach-octeon/Makefile index 40ddab27eacd..6aa7b367416f 100644 --- a/arch/mips/mach-octeon/Makefile +++ b/arch/mips/mach-octeon/Makefile @@ -12,13 +12,46 @@ obj-y += cvmx-coremask.o obj-y += cvmx-bootmem.o obj-y += bootoctlinux.o
-# QLM related code +# Misc Octeon C files, mostly for QLM & ethernet support +obj-y += cvmx-agl.o +obj-y += cvmx-fpa.o +obj-y += cvmx-fpa-resource.o +obj-y += cvmx-fau-compat.o +obj-y += cvmx-global-resources.o +obj-y += cvmx-cmd-queue.o +obj-y += cvmx-helper-agl.o +obj-y += cvmx-helper-bgx.o +obj-y += cvmx-helper-board.o obj-y += cvmx-helper-cfg.o obj-y += cvmx-helper-fdt.o +obj-y += cvmx-helper-fpa.o +obj-y += cvmx-helper-ilk.o +obj-y += cvmx-helper-ipd.o obj-y += cvmx-helper-jtag.o +obj-y += cvmx-helper-loop.o +obj-y += cvmx-helper-npi.o +obj-y += cvmx-helper-pki.o +obj-y += cvmx-helper-pko.o +obj-y += cvmx-helper-pko3.o +obj-y += cvmx-helper-rgmii.o +obj-y += cvmx-helper-sfp.o +obj-y += cvmx-helper-sgmii.o obj-y += cvmx-helper-util.o +obj-y += cvmx-helper-xaui.o obj-y += cvmx-helper.o +obj-y += cvmx-ilk.o +obj-y += cvmx-ipd.o obj-y += cvmx-pcie.o +obj-y += cvmx-pki.o +obj-y += cvmx-pki-resources.o +obj-y += cvmx-pko.o +obj-y += cvmx-pko-internal-ports-range.o +obj-y += cvmx-pko3.o +obj-y += cvmx-pko3-compat.o +obj-y += cvmx-pko3-resources.o +obj-y += cvmx-pko3-queue.o +obj-y += cvmx-range.o obj-y += cvmx-qlm.o +obj-y += cvmx-qlm-tables.o obj-y += octeon_fdt.o obj-y += octeon_qlm.o
Call octeon_bootmem_init() earlier in the boot process, so that this bootmemory infrastructure is already initialized when e.g. the networking support gets probed.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/Kconfig | 1 + arch/mips/mach-octeon/cpu.c | 13 ++++++++++++- 2 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 06cae68ee576..9b62764f4fe6 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -101,6 +101,7 @@ config ARCH_JZ47XX
config ARCH_OCTEON bool "Support Marvell Octeon CN7xxx platforms" + select ARCH_EARLY_INIT_R select CPU_CAVIUM_OCTEON select DISPLAY_CPUINFO select DMA_ADDR_T_64BIT diff --git a/arch/mips/mach-octeon/cpu.c b/arch/mips/mach-octeon/cpu.c index 6cfcc3eae04e..fffd9dfb8580 100644 --- a/arch/mips/mach-octeon/cpu.c +++ b/arch/mips/mach-octeon/cpu.c @@ -393,14 +393,25 @@ static int init_bootcmd_console(void) return ret; }
-int arch_misc_init(void) +int arch_early_init_r(void) { int ret;
+ /* + * Needs to be called pretty early, so that e.g. networking etc + * can access the bootmem infrastructure + */ ret = octeon_bootmem_init(); if (ret) return ret;
+ return 0; +} + +int arch_misc_init(void) +{ + int ret; + ret = octeon_configure_load_memory(); if (ret) return ret;
Import configure_lmtdma_window from Marvell 2013 U-Boot as it's needed for network functionality.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/mach-octeon/cpu.c | 34 +++++++++++++++++++++++++++++++++- 1 file changed, 33 insertions(+), 1 deletion(-)
diff --git a/arch/mips/mach-octeon/cpu.c b/arch/mips/mach-octeon/cpu.c index fffd9dfb8580..1bdc6cd72903 100644 --- a/arch/mips/mach-octeon/cpu.c +++ b/arch/mips/mach-octeon/cpu.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2020 Marvell International Ltd. + * Copyright (C) 2020-2022 Marvell International Ltd. */
#include <dm.h> @@ -17,6 +17,8 @@ #include <mach/cvmx-bootmem.h> #include <mach/cvmx-regs.h> #include <mach/cvmx-sata-defs.h> +#include <mach/octeon-model.h> +#include <mach/octeon-feature.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -393,6 +395,33 @@ static int init_bootcmd_console(void) return ret; }
+static void configure_lmtdma_window(void) +{ + u64 tmp; + u64 addr; + u64 end_addr; + + CVMX_MF_CVM_MEM_CTL(tmp); + tmp &= ~0x1ffull; + tmp |= 0x104ull; + + /* enable LMTDMA */ + tmp |= (1ull << 51); + /* configure scratch line 2 for LMT */ + /* TODO: reserve this scratch line, so that others will not use it */ + /* TODO: store LMTLINE in global var */ + tmp |= (CVMX_PKO_LMTLINE << 45); + /* clear LMTLINE in scratch */ + addr = CVMX_PKO_LMTLINE * CVMX_CACHE_LINE_SIZE; + end_addr = addr + CVMX_CACHE_LINE_SIZE; + + while (addr < end_addr) { + *CASTPTR(volatile u64, addr + CVMX_SCRATCH_BASE) = (u64)0; + addr += 8; + } + CVMX_MT_CVM_MEM_CTL(tmp); +} + int arch_early_init_r(void) { int ret; @@ -405,6 +434,9 @@ int arch_early_init_r(void) if (ret) return ret;
+ if (octeon_has_feature(OCTEON_FEATURE_PKO3)) + configure_lmtdma_window(); + return 0; }
This patch moves CONFIG_SYS_INIT_SP_OFFSET to a higher address so that it does not interfere with larger U-Boot images. This was noticed, while adding network support to the EBB7304 board.
Signed-off-by: Stefan Roese sr@denx.de --- include/configs/octeon_common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/octeon_common.h b/include/configs/octeon_common.h index 2e4bfd035162..7e71c83887f3 100644 --- a/include/configs/octeon_common.h +++ b/include/configs/octeon_common.h @@ -8,7 +8,7 @@ #define __OCTEON_COMMON_H__
#if defined(CONFIG_RAM_OCTEON) -#define CONFIG_SYS_INIT_SP_OFFSET 0x20100000 +#define CONFIG_SYS_INIT_SP_OFFSET 0x20180000 #else /* No DDR init -> run in L2 cache with limited resources */ #define CONFIG_SYS_INIT_SP_OFFSET 0x00180000
Add the Octeon ethernet (BGX) and SMI DT node to the dtsi file.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/dts/mrvl,cn73xx.dtsi | 35 ++++++++++++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index 2a17f7a6a63e..77f3548a326a 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -267,5 +267,40 @@ interrupts = <0x6c010 4>; }; }; + + /* SMI1 */ + smi1: mdio@1180000003880 { + compatible = "cavium,octeon-3860-mdio"; + reg = <0x11800 0x00003880 0x0 0x40>; + #address-cells = <1>; + #size-cells = <0>; + }; + + /* BGX 0 */ + bgx0: ethernet-mac-nexus@11800e0000000 { + compatible = "cavium,octeon-7890-bgx"; + reg = <0x11800 0xe0000000 0x0 0x1000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + /* BGX 1 */ + bgx1: ethernet-mac-nexus@11800e1000000 { + compatible = "cavium,octeon-7890-bgx"; + reg = <0x11800 0xe1000000 0x0 0x1000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + /* BGX 2*/ + bgx2: ethernet-mac-nexus@11800e2000000 { + compatible = "cavium,octeon-7890-bgx"; + reg = <0x11800 0xe2000000 0x0 0x1000000>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; }; };
Add the Octeon ethernet (BGX), SMI and PHY DT nodes to the EBB7304 dts file to enable ethernet support on this board.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/dts/mrvl,octeon-ebb7304.dts | 45 +++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/arch/mips/dts/mrvl,octeon-ebb7304.dts b/arch/mips/dts/mrvl,octeon-ebb7304.dts index fda559d8629d..08247eb4e0ee 100644 --- a/arch/mips/dts/mrvl,octeon-ebb7304.dts +++ b/arch/mips/dts/mrvl,octeon-ebb7304.dts @@ -201,3 +201,48 @@ cd-gpios = <&gpio 25 1>; /* active low */ }; }; + +/* SMI_1 -- Available on rev 2 and later boards */ +&smi1 { + /** + * The phy names are broken down as follows: + * (m)phyxxyzzs + * where: + * xx = 01 for SGMII, 10 for DXAUI, 20 for RXAUI + * and 40 for XFI/LXAUI + * y = QLM/DLM number + * zz = PHY address (decimal) + * s = sub-phy number in the case of the Cortina + * PHY + * a mphy is a nexus phy that contains one or more + * sub-phys, for example the Cortina CS4223. + */ + + /* QLM 2 */ + phy01208: ethernet-phy@01208 { + reg = <8>; + compatible = "marvell,88e1240", "ethernet-phy-ieee802.3-c22"; + + marvell,reg-init = <3 0x10 0 0x8665>, + <3 0x11 0 0x00aa>, + <3 0x12 0 0x4105>, + <3 0x13 0 0x8a08>; + + interrupt-parent = <&gpio>; + interrupts = <12 8>; /* Pin 12, active low */ + }; +}; + +/* BGX 0 */ +&bgx0 { + status = "okay"; + phy-handle = <&phy01208>; /* put phy-handle in BGX node and MAC node */ + + /* SerDes 0, may differ from PCS Lane/LMAC */ + eth0: ethernet-mac@D { + compatible = "cavium,octeon-7890-bgx-port"; + reg = <0>; + local-mac-address = [ 00 00 00 00 00 00 ]; + phy-handle = <&phy01208>; + }; +};
Add the Octeon ethernet (BGX) and SFP DT nodes to the NIC23 dts file to enable ethernet support on this board.
Signed-off-by: Stefan Roese sr@denx.de --- arch/mips/dts/mrvl,octeon-nic23.dts | 238 ++++++++++++++++++++++++++++ 1 file changed, 238 insertions(+)
diff --git a/arch/mips/dts/mrvl,octeon-nic23.dts b/arch/mips/dts/mrvl,octeon-nic23.dts index 72ef56d834e4..dfbd51c92468 100644 --- a/arch/mips/dts/mrvl,octeon-nic23.dts +++ b/arch/mips/dts/mrvl,octeon-nic23.dts @@ -118,11 +118,208 @@ &i2c0 { u-boot,dm-pre-reloc; /* Needed early for DDR SPD EEPROM */ clock-frequency = <100000>; + + sfp0eeprom: eeprom@50 { + compatible = "atmel,24c01"; + reg = <0x50>; + }; + + sfp0alerts: eeprom@51 { + compatible = "atmel,24c01"; + reg = <0x51>; + }; };
&i2c1 { u-boot,dm-pre-reloc; /* Needed early for DDR SPD EEPROM */ clock-frequency = <100000>; + + vitesse@10 { + compatible = "vitesse,vsc7224"; + reg = <0x10>; + #address-cells = <1>; + #size-cells = <0>; + + /* Note that reset is active high with this device */ + reset = <&gpio 7 0>; + + /* LoS pin can be pulled low when there is a loss of signal */ + los = <&gpio 6 0>; + + vitesse,reg-init = + /* Clear all masks */ + /* Page select FSYNC0 (0x30) */ + <0x7f 0x0030>, + /* Set FSYNC0 for 10.3125Gbps */ + <0x80 0x2841>, /* See Table 3. */ + <0x81 0x0008>, + <0x82 0xc000>, + <0x83 0x0010>, + <0x84 0x1d00>, + + /* All channels Rx settings set equally */ + <0x7f 0x0050>, + /* Shrink EQ_BUFF */ + <0x82 0x0014>, + /* Set EQVGA_ADAP = 1 (enable EQVGA circuitry), + * USE_UNIT_GAIN = 1 (EQVGA is in unity gain), + * USE_LPF = 0 (VGA adapt not using LPF), + * USE_EQVGA = 1 + <0x89 0x7f13>, + /* Select min DFE Delay (DFE_DELAY) */ + <0x90 0x5785>, + /* Set DFE 1-3 limit (DXMAX) = 32dec, + * AP Max limit = 127 decimal + */ + <0x92 0x207f>, + /* Set AP Min limit = 32 decimal */ + <0x93 0x2000>, + /* Set DFE Averaging to the slowest (DFE_AVG) */ + <0x94 0x0031>, + /* Set Inductor Bypass OD_IND_BYP = 0 & fastest Rise/Fall */ + <0x9c 0x0000>, + /* Setting DFE Boost = none. Must set for + * rev C (if DFE in adapt mode) + */ + <0xaa 0x0888>, + /* Setting EQ Min = 8 & Max limit = 72 dec. + * Must set for rev C, otherwise EQ is 0 + * (if EQ is in adaptive mode) + */ + <0xa8 0x2408>, + /* Setting EQVGA = 96, when in EQVGA manual mode */ + <0xa9 0x0060>, + /* Setting SW_BFOCM, bits 15:14 to 01 */ + <0x87 0x4021>, + /* Turn off adaptive input equalization + * and VGA adaptive algorithm control. + */ + <0x89 0x7313>, + /* Turn on adaptive input equalization + * and VGA adaptive algorithm control. + */ + <0x89 0x7f13>; + + vitesse-channel@0 { + compatible = "vitesse,vsc7224-channel"; + reg = <0>; + direction-tx; + sfp-mac = <ð0>; + + /* TAP settings. The format of this is as + * follows: + * - cable length in meters, 0 = active or + * optical module + * - maintap value + * - pretap value + * - posttap value + * + * For the cable length, the value will apply + * for that cable length and greater until the + * next largest cable length specified. These + * values must be ordered first by channel mask + * then by cable length. These are typically + * set for the transmit channels, not the + * receive channels. + */ + taps = <0 0x0013 0x000f 0x0000>, + <1 0x001f 0x000f 0x0004>, + <3 0x0014 0x000b 0x0004>, + <5 0x0014 0x0009 0x0006>, + <7 0x0014 0x000f 0x0000>, + <10 0x0012 0x000b 0x0013>; + }; + + vitesse-channel@1 { + compatible = "vitesse,vsc7224-channel"; + reg = <1>; + /* Ignore mod_abs and module */ + direction-rx; + sfp-mac = <ð0>; + + /* Disable pre-tap */ + pretap-disable; + + /* Disable post-tap */ + posttap-disable; + + /* Taps has the following fields: + * - cable length (ignored for rx) + * - main tap value + * - pre tap value + * - post tap value + * + * NOTE: if taps are disabled then they + * are not programmed. + */ + taps = <0 0x0a 0x0b 0x10>; + }; + + vitesse-channel@2 { + compatible = "vitesse,vsc7224-channel"; + reg = <2>; + direction-tx; + sfp-mac = <ð1>; + + /* TAP settings. The format of this is as + * follows: + * - cable length in meters, 0 = active or + * optical module + * - maintap value + * - pretap value + * - posttap value + * + * For the cable length, the value will apply + * for that cable length and greater until the + * next largest cable length specified. These + * values must be ordered first by channel mask + * then by cable length. These are typically + * set for the transmit channels, not the + * receive channels. + */ + taps = <0 0x0013 0x000f 0x0000>, + <1 0x001f 0x000f 0x0004>, + <3 0x0014 0x000b 0x0004>, + <5 0x0014 0x0009 0x0006>, + <7 0x0014 0x000f 0x0000>, + <10 0x0012 0x000b 0x0013>; + }; + + vitesse-channel@3 { + compatible = "vitesse,vsc7224-channel"; + reg = <3>; + /* Ignore mod_abs and module */ + direction-rx; + sfp-mac = <ð1>; + + /* Disable pre-tap */ + pretap-disable; + + /* Disable post-tap */ + posttap-disable; + + /* Taps has the following fields: + * - cable length (ignored for rx) + * - main tap value + * - pre tap value + * - post tap value + * + * NOTE: if taps are disabled then they + * are not programmed. + */ + taps = <0 0x0a 0x0b 0x10>; + }; + }; + + sfp1eeprom: eeprom@50 { + compatible = "atmel,24c01"; + reg = <0x50>; + }; + + sfp1alerts: eeprom@51 { + compatible = "atmel,24c01"; + reg = <0x51>; + }; };
&mmc { @@ -151,6 +348,26 @@ compatible = "marvell,pci-bootcmd"; status = "okay"; }; + + sfp0: sfp-slot@0 { + compatible = "ethernet,sfp-slot"; + tx_disable = <&gpio 16 0>; + mod_abs = <&gpio 17 0>; + tx_error = <&gpio 19 0>; + rx_los = <&gpio 18 0>; + eeprom = <&sfp0eeprom>; + diag = <&sfp0alerts>; + }; + + sfp1: sfp-slot@1 { + compatible = "ethernet,sfp-slot"; + tx_disable = <&gpio 21 0>; + mod_abs = <&gpio 22 0>; + tx_error = <&gpio 24 0>; + rx_los = <&gpio 23 0>; + eeprom = <&sfp1eeprom>; + diag = <&sfp1alerts>; + }; };
&spi { @@ -160,3 +377,24 @@ reg = <0>; }; }; + +/* BGX 2 */ +&bgx2 { + status = "okay"; + + /* SerDes 0, may differ from PCS Lane/LMAC */ + eth0: ethernet-mac@0 { + compatible = "cavium,octeon-7890-bgx-port"; + reg = <0>; + local-mac-address = [ 00 00 00 00 00 00 ]; + sfp-slot = <&sfp0>; + }; + + /* SerDes 1, may differ from PCS Lane/LMAC */ + eth1: ethernet-mac@1 { + compatible = "cavium,octeon-7890-bgx-port"; + reg = <1>; + local-mac-address = [ 00 00 00 00 00 00 ]; + sfp-slot = <&sfp1>; + }; +};
This patchs adds the ethernet & MDIO driver for the MIPS Octeon II / III SoC platform. Please note that these drivers are based on the 2013 U-Boot version from Marvell and make use of the platform supported helper functions for the ethernet functionality, including stuff like SFP handling.
Signed-off-by: Stefan Roese sr@denx.de Cc: Ramon Fried rfried.dev@gmail.com Cc: Joe Hershberger joe.hershberger@ni.com --- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/octeon/Makefile | 6 + drivers/net/octeon/octeon_eth.c | 1060 ++++++++++++++++++++++++++++++ drivers/net/octeon/octeon_mdio.c | 226 +++++++ 5 files changed, 1300 insertions(+) create mode 100644 drivers/net/octeon/Makefile create mode 100644 drivers/net/octeon/octeon_eth.c create mode 100644 drivers/net/octeon/octeon_mdio.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index a6171a7c7ffd..e17892898453 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -490,6 +490,13 @@ config MT7628_ETH The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards.
+config NET_OCTEON + bool "MIPS Octeon ethernet support" + depends on ARCH_OCTEON + help + You must select Y to enable network device support for + MIPS Octeon SoCs. If unsure, say n + config NET_OCTEONTX bool "OcteonTX Ethernet support" depends on ARCH_OCTEONTX diff --git a/drivers/net/Makefile b/drivers/net/Makefile index a6d0c23f02d3..63144b27bf02 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -72,6 +72,7 @@ obj-$(CONFIG_MVNETA) += mvneta.o obj-$(CONFIG_MVPP2) += mvpp2.o obj-$(CONFIG_NATSEMI) += natsemi.o obj-$(CONFIG_NETCONSOLE) += netconsole.o +obj-$(CONFIG_NET_OCTEON) += octeon/ obj-$(CONFIG_NET_OCTEONTX) += octeontx/ obj-$(CONFIG_NET_OCTEONTX2) += octeontx2/ obj-$(CONFIG_NS8382X) += ns8382x.o diff --git a/drivers/net/octeon/Makefile b/drivers/net/octeon/Makefile new file mode 100644 index 000000000000..c573411a6293 --- /dev/null +++ b/drivers/net/octeon/Makefile @@ -0,0 +1,6 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2018-2022 Marvell International Ltd. +# + +obj-$(CONFIG_NET_OCTEON) += octeon_eth.o octeon_mdio.o diff --git a/drivers/net/octeon/octeon_eth.c b/drivers/net/octeon/octeon_eth.c new file mode 100644 index 000000000000..fbb1afc08abc --- /dev/null +++ b/drivers/net/octeon/octeon_eth.c @@ -0,0 +1,1060 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <dm.h> +#include <dm/device_compat.h> +#include <env.h> +#include <net.h> +#include <netdev.h> +#include <malloc.h> +#include <miiphy.h> +#include <misc.h> +#include <asm/io.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/cvmx-bootmem.h> +#include <mach/octeon-model.h> +#include <mach/cvmx-fuse.h> +#include <mach/octeon-feature.h> +#include <mach/octeon_fdt.h> +#include <mach/cvmx-qlm.h> +#include <mach/octeon_eth.h> +#include <mach/octeon_qlm.h> +#include <mach/cvmx-pcie.h> +#include <mach/cvmx-coremask.h> + +#include <mach/cvmx-agl-defs.h> +#include <mach/cvmx-asxx-defs.h> +#include <mach/cvmx-bgxx-defs.h> +#include <mach/cvmx-dbg-defs.h> +#include <mach/cvmx-gmxx-defs.h> +#include <mach/cvmx-gserx-defs.h> +#include <mach/cvmx-ipd-defs.h> +#include <mach/cvmx-l2c-defs.h> +#include <mach/cvmx-npi-defs.h> +#include <mach/cvmx-pcsx-defs.h> +#include <mach/cvmx-pexp-defs.h> +#include <mach/cvmx-pki-defs.h> +#include <mach/cvmx-pko-defs.h> +#include <mach/cvmx-smix-defs.h> +#include <mach/cvmx-sriox-defs.h> +#include <mach/cvmx-xcv-defs.h> +#include <mach/cvmx-pcsxx-defs.h> + +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-helper-fdt.h> +#include <mach/cvmx-helper-bgx.h> +#include <mach/cvmx-helper-cfg.h> + +#include <mach/cvmx-hwpko.h> +#include <mach/cvmx-pko.h> +#include <mach/cvmx-pki.h> +#include <mach/cvmx-config.h> +#include <mach/cvmx-mdio.h> + +/** Maximum receive packet size (hardware default is 1536) */ +#define CONFIG_OCTEON_NETWORK_MRU 1536 + +#define OCTEON_BOOTLOADER_NAMED_BLOCK_TMP_PREFIX "__tmp" + +/** + * Enables RX packet debugging if octeon_debug_rx_packets is set in the + * environment. + */ +#define DEBUG_RX_PACKET + +/** + * Enables TX packet debugging if octeon_debug_tx_packets is set in the + * environment. + */ +#define DEBUG_TX_PACKET + +/* Global flag indicating common hw has been set up */ +static int octeon_global_hw_inited; + +#if defined(DEBUG_RX_PACKET) || defined(DEBUG_TX_PACKET) +static int packet_rx_debug; +static int packet_tx_debug; +#endif + +/* Make sure that we have enough buffers to keep prefetching blocks happy. + * Absolute minimum is probably about 200. + */ +#define NUM_PACKET_BUFFERS 1000 + +#define PKO_SHUTDOWN_TIMEOUT_VAL 100 + +/* Define the offsets from the base CSR */ +#define GMX_PRT_CFG 0x10 + +#define GMX_RX_FRM_MAX 0x30 +#define GMX_RX_JABBER 0x38 + +#define GMX_RX_ADR_CTL 0x100 +#define GMX_RX_ADR_CAM_EN 0x108 +#define GMX_RX_ADR_CAM0 0x180 +#define GMX_RX_ADR_CAM1 0x188 +#define GMX_RX_ADR_CAM2 0x190 +#define GMX_RX_ADR_CAM3 0x198 +#define GMX_RX_ADR_CAM4 0x1a0 +#define GMX_RX_ADR_CAM5 0x1a8 +#define GMX_TX_OVR_BP 0x4c8 + +/** + * Set the hardware MAC address for a device + * + * @param interface interface of port to set + * @param index index of port to set MAC address for + * @param addr Address structure to change it too. + * @return Zero on success + */ +static int cvm_oct_set_mac_address(struct udevice *dev) +{ + struct octeon_eth_info *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + cvmx_gmxx_prtx_cfg_t gmx_cfg; + cvmx_helper_interface_mode_t mode; + cvmx_gmxx_rxx_adr_ctl_t control; + u8 *ptr = (uint8_t *)pdata->enetaddr; + int interface = priv->interface; + int index = priv->index; + u64 mac = 0; + u64 gmx_reg; + int xipd_port; + int i; + + for (i = 0; i < 6; i++) + mac = (mac << 8) | (u64)(ptr[i]); + + debug("%s(%s (%pM))\n", __func__, dev->name, ptr); + mode = cvmx_helper_interface_get_mode(interface); + + /* It's rather expensive to change the MAC address for BGX so we only + * do this if it has changed or not been set previously. + */ + if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + xipd_port = cvmx_helper_get_ipd_port(interface, index); + if (priv->last_bgx_mac != mac || !priv->bgx_mac_set) { + cvmx_helper_bgx_set_mac(xipd_port, 1, 2, mac); + priv->last_bgx_mac = mac; + priv->bgx_mac_set = 1; + } + return 0; + } + + if (mode == CVMX_HELPER_INTERFACE_MODE_AGL) { + gmx_reg = CVMX_AGL_GMX_RXX_INT_REG(0); + } else { + gmx_reg = CVMX_GMXX_RXX_INT_REG(index, interface); + csr_wr(CVMX_GMXX_SMACX(index, interface), mac); + } + + /* Disable interface */ + gmx_cfg.u64 = csr_rd(gmx_reg + GMX_PRT_CFG); + csr_wr(gmx_reg + GMX_PRT_CFG, gmx_cfg.u64 & ~1ull); + debug("%s: gmx reg: 0x%llx\n", __func__, gmx_reg); + + csr_wr(gmx_reg + GMX_RX_ADR_CAM0, ptr[0]); + csr_wr(gmx_reg + GMX_RX_ADR_CAM1, ptr[1]); + csr_wr(gmx_reg + GMX_RX_ADR_CAM2, ptr[2]); + csr_wr(gmx_reg + GMX_RX_ADR_CAM3, ptr[3]); + csr_wr(gmx_reg + GMX_RX_ADR_CAM4, ptr[4]); + csr_wr(gmx_reg + GMX_RX_ADR_CAM5, ptr[5]); + + control.u64 = 0; + control.s.bcst = 1; /* Allow broadcast MAC addresses */ + control.s.mcst = 1; /* Force reject multicast packets */ + control.s.cam_mode = 1; /* Filter packets based on the CAM */ + + csr_wr(gmx_reg + GMX_RX_ADR_CTL, control.u64); + + csr_wr(gmx_reg + GMX_RX_ADR_CAM_EN, 1); + + /* Return interface to previous enable state */ + csr_wr(gmx_reg + GMX_PRT_CFG, gmx_cfg.u64); + + return 0; +} + +static void cvm_oct_fill_hw_memory(u64 pool, u64 size, u64 elements) +{ + static int alloc_count; + char tmp_name[64]; + int ret; + + debug("%s: pool: 0x%llx, size: 0xx%llx, count: 0x%llx\n", + __func__, pool, size, elements); + sprintf(tmp_name, "%s_fpa_alloc_%d", + OCTEON_BOOTLOADER_NAMED_BLOCK_TMP_PREFIX, alloc_count++); + ret = cvmx_fpa_setup_pool(pool, tmp_name, NULL, size, elements); +} + +/** + * Configure common hardware for all interfaces + */ +static void cvm_oct_configure_common_hw(void) +{ + int mru = env_get_ulong("octeon_mru", 0, CONFIG_OCTEON_NETWORK_MRU); + int packet_pool_size = CVMX_FPA_PACKET_POOL_SIZE; + + if (mru > packet_pool_size) + packet_pool_size = (mru + CVMX_CACHE_LINE_SIZE - 1) & + ~(CVMX_CACHE_LINE_SIZE - 1); + + /* Setup the FPA */ + cvmx_fpa_enable(); + + cvm_oct_fill_hw_memory(CVMX_FPA_WQE_POOL, CVMX_FPA_WQE_POOL_SIZE, + NUM_PACKET_BUFFERS); +#if CVMX_FPA_OUTPUT_BUFFER_POOL != CVMX_FPA_PACKET_POOL + if (!octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) { + cvm_oct_fill_hw_memory(CVMX_FPA_OUTPUT_BUFFER_POOL, + CVMX_FPA_OUTPUT_BUFFER_POOL_SIZE, 128); + } +#endif + cvm_oct_fill_hw_memory(CVMX_FPA_PACKET_POOL, packet_pool_size, + NUM_PACKET_BUFFERS); + + cvmx_helper_initialize_packet_io_global(); + cvmx_helper_initialize_packet_io_local(); + + /* The MRU defaults to 1536 bytes by the hardware. Setting + * CONFIG_OCTEON_NETWORK_MRU allows this to be overridden. + */ + if (octeon_has_feature(OCTEON_FEATURE_PKI)) { + struct cvmx_pki_global_config gbl_cfg; + int i; + + cvmx_pki_read_global_config(0, &gbl_cfg); + for (i = 0; i < CVMX_PKI_NUM_FRAME_CHECK; i++) + gbl_cfg.frm_len[i].maxlen = mru; + cvmx_pki_write_global_config(0, &gbl_cfg); + } + + /* Set POW get work timeout to maximum value */ + if (octeon_has_feature(OCTEON_FEATURE_CN68XX_WQE) || + octeon_has_feature(OCTEON_FEATURE_CN78XX_WQE)) + csr_wr(CVMX_SSO_NW_TIM, 0x3ff); + else + csr_wr(CVMX_POW_NW_TIM, 0x3ff); +} + +/** + * Enables Ethernet devices to allow packets to be transmitted and received. + * For example, this is activated when the DHCP command is issued. + * + * @param dev Ethernet device to initialize + * @param bis board data structure, not used. + * + * @return 1 for success + */ +int octeon_eth_init(struct udevice *dev) +{ + struct octeon_eth_info *priv = dev_get_priv(dev); + + debug("%s(), dev_ptr: %p, dev: %s, port: %d\n", __func__, dev, + dev->name, priv->port); + + if (priv->initted_flag) { + debug("%s already initialized\n", dev->name); + return 1; + } + + if (!octeon_global_hw_inited) { + debug("Initializing common hardware\n"); + cvm_oct_configure_common_hw(); + } + + /* Ignore backpressure on RGMII ports */ + if (!octeon_has_feature(OCTEON_FEATURE_BGX)) + csr_wr(priv->gmx_base + GMX_TX_OVR_BP, 0xf << 8 | 0xf); + + debug("%s: Setting MAC address\n", __func__); + cvm_oct_set_mac_address(dev); + + if (!octeon_global_hw_inited) { + debug("Enabling packet input\n"); + cvmx_helper_ipd_and_packet_input_enable(); + octeon_global_hw_inited = 1; + + /* Connect, configure and start the PHY, if the device is + * connected to one. If not, then it's most likely an SPF + * enabled port, which does not have such PHY setup here. + */ + if (priv->mdio_dev) { + priv->phy_dev = dm_eth_phy_connect(dev); + phy_config(priv->phy_dev); + phy_startup(priv->phy_dev); + } + } + priv->enabled = 0; + priv->initted_flag = 1; + + debug("%s exiting successfully\n", __func__); + return 1; +} + +/** + * Initializes the specified interface and port + * + * @param interface interface to initialize + * @param index port index on interface + * @param port ipd port number + * @param if_mode interface mode + * + * @return 0 for success, -1 if out of memory, 1 if port is invalid + */ +static int octeon_eth_initialize(struct udevice *dev, int interface, + int index, int port, + cvmx_helper_interface_mode_t if_mode) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + int eth; + + eth = cvmx_helper_get_port_fdt_node_offset(interface, index); + if (eth <= 0) { + debug("ERROR: No fdt node for interface %d, index %d\n", + interface, index); + return 1; + } + + oct_eth_info->is_c45 = (if_mode == CVMX_HELPER_INTERFACE_MODE_XAUI) || + (if_mode == CVMX_HELPER_INTERFACE_MODE_RXAUI) || + (if_mode == CVMX_HELPER_INTERFACE_MODE_XFI) || + (if_mode == CVMX_HELPER_INTERFACE_MODE_XLAUI) || + (if_mode == CVMX_HELPER_INTERFACE_MODE_10G_KR) || + (if_mode == CVMX_HELPER_INTERFACE_MODE_10G_KR); + oct_eth_info->port = port; + oct_eth_info->index = index; + oct_eth_info->interface = interface; + oct_eth_info->initted_flag = 0; + /* This is guaranteed to force the link state to be printed out */ + oct_eth_info->link_state = 0xffffffffffffffffULL; + debug("Setting up port: %d, int: %d, index: %d, device: octeth%d\n", + oct_eth_info->port, oct_eth_info->interface, oct_eth_info->index, + dev_seq(dev)); + if (if_mode == CVMX_HELPER_INTERFACE_MODE_AGL) { + oct_eth_info->gmx_base = CVMX_AGL_GMX_RXX_INT_REG(0); + } else { + if (!octeon_has_feature(OCTEON_FEATURE_BGX)) + oct_eth_info->gmx_base = + CVMX_GMXX_RXX_INT_REG(index, interface); + } + + return 0; +} + +/** + * @INTERNAL + * Converts a BGX address to the node, interface and port number + * + * @param bgx_addr Address of CSR register + * + * @return node, interface and port number, will be -1 for invalid address. + */ +static struct cvmx_xiface __cvmx_bgx_reg_addr_to_xiface(u64 bgx_addr) +{ + struct cvmx_xiface xi = { -1, -1 }; + + xi.node = cvmx_csr_addr_to_node(bgx_addr); + bgx_addr = cvmx_csr_addr_strip_node(bgx_addr); + if ((bgx_addr & 0xFFFFFFFFF0000000) != 0x00011800E0000000) { + debug("%s: Invalid BGX address 0x%llx\n", __func__, + (unsigned long long)bgx_addr); + xi.node = -1; + return xi; + } + xi.interface = (bgx_addr >> 24) & 0x0F; + + return xi; +} + +static int octeon_nic_probe(struct udevice *dev) +{ + struct octeon_eth_info *info = dev_get_priv(dev); + struct ofnode_phandle_args phandle; + struct cvmx_xiface xi; + ofnode node, mdio_node; + int ipd_port; + int intf; + int ret; + + /* The empty stub is to keep cvmx_user_app_init() happy. */ + cvmx_npi_max_pknds = 1; + __cvmx_helper_init_port_valid(); + + xi = __cvmx_bgx_reg_addr_to_xiface(dev_read_addr(dev)); + intf = xi.interface; + debug("%s: Found BGX node %d, interface %d\n", __func__, xi.node, intf); + + ipd_port = cvmx_helper_get_ipd_port(intf, xi.node); + ret = octeon_eth_initialize(dev, intf, xi.node, ipd_port, + cvmx_helper_interface_get_mode(intf)); + + /* Move to subnode, as this includes the "phy-handle" */ + node = dev_read_first_subnode(dev); + + /* Check if an SPF module is conneted, then no MDIO is probed */ + ret = ofnode_parse_phandle_with_args(node, "sfp-slot", NULL, 0, 0, + &phandle); + if (!ret) { + dev_dbg(dev, "sfp-slot found, not probing for MDIO\n"); + return 0; + } + + /* Continue with MDIO probing */ + ret = ofnode_parse_phandle_with_args(node, "phy-handle", NULL, 0, 0, + &phandle); + if (ret) { + dev_err(dev, "phy-handle not found in subnode\n"); + return -ENODEV; + } + + /* Get MDIO node */ + mdio_node = ofnode_get_parent(phandle.node); + ret = uclass_get_device_by_ofnode(UCLASS_MDIO, mdio_node, + &info->mdio_dev); + if (ret) { + dev_err(dev, "mdio_dev not found\n"); + return -ENODEV; + } + + return 0; +} + +/** + * Sets the hardware MAC address of the Ethernet device + * + * @param dev - Ethernet device + * + * @return 0 for success + */ +int octeon_eth_write_hwaddr(struct udevice *dev) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_plat(dev); + + /* Skip if the interface isn't yet enabled */ + if (!oct_eth_info->enabled) { + debug("%s: Interface not enabled, not setting MAC address\n", + __func__); + return 0; + } + debug("%s: Setting %s address to %02x:%02x:%02x:%02x:%02x:%02x\n", + __func__, dev->name, pdata->enetaddr[0], pdata->enetaddr[1], + pdata->enetaddr[2], pdata->enetaddr[3], pdata->enetaddr[4], + pdata->enetaddr[5]); + return cvm_oct_set_mac_address(dev); +} + +/** + * Enables and disables the XCV RGMII interface + * + * @param interface Interface number + * @param index Port index (should be 0 for RGMII) + * @param enable True to enable it, false to disable it + */ +static void octeon_bgx_xcv_rgmii_enable(int interface, int index, bool enable) +{ + union cvmx_xcv_reset xcv_reset; + + debug("%s(%d, %d, %sable)\n", __func__, interface, index, + enable ? "en" : "dis"); + xcv_reset.u64 = csr_rd(CVMX_XCV_RESET); + xcv_reset.s.rx_pkt_rst_n = enable ? 1 : 0; + csr_wr(CVMX_XCV_RESET, xcv_reset.u64); +} + +/** + * Enables a SGMII interface + * + * @param dev - Ethernet device to initialize + */ +void octeon_eth_sgmii_enable(struct udevice *dev) +{ + struct octeon_eth_info *oct_eth_info; + cvmx_gmxx_prtx_cfg_t gmx_cfg; + int index, interface; + cvmx_helper_interface_mode_t if_mode; + + oct_eth_info = dev_get_priv(dev); + interface = oct_eth_info->interface; + index = oct_eth_info->index; + + debug("%s(%s) (%d.%d)\n", __func__, dev->name, interface, index); + if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + cvmx_bgxx_cmrx_config_t cmr_config; + + cmr_config.u64 = + csr_rd(CVMX_BGXX_CMRX_CONFIG(index, interface)); + cmr_config.s.enable = 1; + cmr_config.s.data_pkt_tx_en = 1; + cmr_config.s.data_pkt_rx_en = 1; + csr_wr(CVMX_BGXX_CMRX_CONFIG(index, interface), cmr_config.u64); + mdelay(100); + if (cvmx_helper_bgx_is_rgmii(interface, index)) + octeon_bgx_xcv_rgmii_enable(interface, index, true); + } else { + if_mode = cvmx_helper_interface_get_mode(interface); + /* Normal operating mode. */ + + if (if_mode == CVMX_HELPER_INTERFACE_MODE_SGMII || + if_mode == CVMX_HELPER_INTERFACE_MODE_QSGMII) { + cvmx_pcsx_miscx_ctl_reg_t pcsx_miscx_ctl_reg; + + debug(" if mode: (Q)SGMII\n"); + pcsx_miscx_ctl_reg.u64 = csr_rd(CVMX_PCSX_MISCX_CTL_REG(index, interface)); + pcsx_miscx_ctl_reg.s.gmxeno = 0; + csr_wr(CVMX_PCSX_MISCX_CTL_REG(index, interface), + pcsx_miscx_ctl_reg.u64); + } else if (if_mode != CVMX_HELPER_INTERFACE_MODE_AGL) { + cvmx_pcsxx_misc_ctl_reg_t pcsxx_misc_ctl_reg; + + debug(" if mode: AGM\n"); + pcsxx_misc_ctl_reg.u64 = + csr_rd(CVMX_PCSXX_MISC_CTL_REG(interface)); + pcsxx_misc_ctl_reg.s.gmxeno = 0; + csr_wr(CVMX_PCSXX_MISC_CTL_REG(interface), + pcsxx_misc_ctl_reg.u64); + } + + gmx_cfg.u64 = csr_rd(oct_eth_info->gmx_base + GMX_PRT_CFG); + gmx_cfg.s.en = 1; + csr_wr(oct_eth_info->gmx_base + GMX_PRT_CFG, gmx_cfg.u64); + gmx_cfg.u64 = csr_rd(oct_eth_info->gmx_base + GMX_PRT_CFG); + } +} + +/** + * Enables an Ethernet interface + * + * @param dev - Ethernet device to enable + */ +void octeon_eth_enable(struct udevice *dev) +{ + struct octeon_eth_info *oct_eth_info; + u64 tmp; + int interface; + cvmx_helper_interface_mode_t if_mode; + + oct_eth_info = dev_get_priv(dev); + interface = oct_eth_info->interface; + if_mode = cvmx_helper_interface_get_mode(interface); + + switch (if_mode) { + case CVMX_HELPER_INTERFACE_MODE_RGMII: + case CVMX_HELPER_INTERFACE_MODE_GMII: + debug(" rgmii/gmii mode\n"); + tmp = csr_rd(CVMX_ASXX_RX_PRT_EN(interface)); + tmp |= (1ull << (oct_eth_info->port & 0x3)); + csr_wr(CVMX_ASXX_RX_PRT_EN(interface), tmp); + tmp = csr_rd(CVMX_ASXX_TX_PRT_EN(interface)); + tmp |= (1ull << (oct_eth_info->port & 0x3)); + csr_wr(CVMX_ASXX_TX_PRT_EN(interface), tmp); + octeon_eth_write_hwaddr(dev); + break; + + case CVMX_HELPER_INTERFACE_MODE_SGMII: + case CVMX_HELPER_INTERFACE_MODE_XAUI: + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_XFI: + case CVMX_HELPER_INTERFACE_MODE_10G_KR: + case CVMX_HELPER_INTERFACE_MODE_40G_KR4: + case CVMX_HELPER_INTERFACE_MODE_MIXED: + case CVMX_HELPER_INTERFACE_MODE_AGL: + debug(" SGMII/XAUI/etc.\n"); + octeon_eth_sgmii_enable(dev); + octeon_eth_write_hwaddr(dev); + break; + + default: + break; + } +} + +void octeon_phy_port_check(struct udevice *dev) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + struct phy_device *phydev = oct_eth_info->phydev; + + if (oct_eth_info->phy_port_check) + oct_eth_info->phy_port_check(phydev); +} + +/** + * Configure the RGMII port for the negotiated speed + * + * @param dev Linux device for the RGMII port + */ +static void cvm_oct_configure_rgmii_speed(struct udevice *dev) +{ + struct octeon_eth_info *priv = dev_get_priv(dev); + int port = priv->port; + cvmx_helper_link_info_t link_state = cvmx_helper_link_get(port); + + /* If the port is down some PHYs we need to check modules, etc. */ + if (!link_state.s.link_up) + octeon_phy_port_check(dev); + + if (link_state.u64 != priv->link_state) { + cvmx_helper_interface_mode_t mode; + + octeon_phy_port_check(dev); + + debug("%s(%s): Link state changed\n", __func__, dev->name); + printf("%s: ", dev->name); + if (!link_state.s.link_up) { + puts("Down "); + } else { + printf("Up %d Mbps ", link_state.s.speed); + if (link_state.s.full_duplex) + puts("Full duplex "); + else + puts("Half duplex "); + } + mode = cvmx_helper_interface_get_mode(priv->interface); + printf("(port %2d) (%s)\n", port, + cvmx_helper_interface_mode_to_string(mode)); + debug("%s: Setting link state\n", __func__); + cvmx_helper_link_set(priv->port, link_state); + priv->link_state = link_state.u64; + } +} + +#if defined(DEBUG_TX_PACKET) || defined(DEBUG_RX_PACKET) +static void print_mac(const char *label, const uint8_t *mac_addr) +{ + printf("%s: %02x:%02x:%02x:%02x:%02x:%02x", label, mac_addr[0], + mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]); +} + +static void print_ip(const void *packet) +{ + u8 *p = (uint8_t *)packet; + u16 length; + u8 hdr_len; + + puts("IP Header:\n"); + if ((p[0] & 0xF0) != 0x40) { + printf("Invalid IP version %d\n", *p >> 4); + return; + } + hdr_len = *p & 0x0F; + if (hdr_len < 5) + printf("Invalid IP header length %d\n", hdr_len); + printf(" Version: 4, Header length: %d\n", hdr_len); + length = (p[2] << 8) | p[3]; + printf(" TOS: 0x%02x, length: %d\n", p[1], length); + printf(" ID: %d, %s%s%s fragment offset: %d\n", (p[4] << 8) | p[5], + p[6] & 0x80 ? "congested, " : "", p[6] & 0x40 ? "DF, " : "", + p[6] & 0x20 ? "MF, " : "", ((p[6] & 0x1F) << 8) | p[7]); + printf(" TTL: %d, Protocol: %d, Header Checksum: 0x%x\n", p[8], p[9], + (p[10] << 8) | p[11]); + printf(" Source IP: %d.%d.%d.%d\n Destination IP: %d.%d.%d.%d\n", + p[12], p[13], p[14], p[15], p[16], p[17], p[18], p[19]); + if (p[9] == 17 || p[9] == 6) + printf(" Source port: %u, Destination port: %u\n", + (p[20] << 8) | p[21], (p[22] << 8) | p[23]); + puts("\n"); +} + +/** + * Prints out a packet for debugging purposes + * + * @param[in] packet - pointer to packet data + * @param length - length of packet in bytes + */ +static void print_packet(const void *packet, int length) +{ + int i, j; + const unsigned char *up = packet; + u16 type = (up[12] << 8 | up[13]); + int start = 14; + + print_mac("DMAC", &up[0]); + puts(" "); + print_mac("SMAC", &up[6]); + printf(" TYPE: %04x\n", type); + + if (type == 0x0800) + print_ip(&up[start]); + + for (i = start; (i + 16) < length; i += 16) { + printf("%04x ", i); + for (j = 0; j < 16; ++j) + printf("%02x ", up[i + j]); + + printf(" "); + for (j = 0; j < 16; ++j) + printf("%c", + ((up[i + j] >= ' ') && (up[i + j] <= '~')) ? + up[i + j] : + '.'); + printf("\n"); + } + printf("%04x ", i); + for (j = 0; i + j < length; ++j) + printf("%02x ", up[i + j]); + + for (; j < 16; ++j) + printf(" "); + + printf(" "); + for (j = 0; i + j < length; ++j) + printf("%c", ((up[i + j] >= ' ') && (up[i + j] <= '~')) ? + up[i + j] : + '.'); + + printf("\n"); +} +#endif + +/** + * String representation of error codes. + */ +static const char * const rx_error_codes[] = { + "OK", + "partial", + "jabber", + "overrun", + "oversize", + "alignment", + "fragment", + "fcs", + "undersize", + "extend", + "length mismatch", + "rgmii rx", + "skip error", + "nibble error (studder)", + "(undefined)", + "(undefined)", + "SPI 4.2 FCS", + "skip", + "L2 malformed", +}; + +/** + * Called to receive a packet + * + * @param dev - device to receive on + * + * @return - length of packet + * + * This function is used to poll packets. In turn it calls NetReceive + * to process the packets. + */ +static int nic_recv(struct udevice *dev, int flags, uchar **packetp) +{ + cvmx_wqe_t *work = cvmx_pow_work_request_sync(CVMX_POW_WAIT); + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + cvmx_buf_ptr_t buf_ptr; + void *packet_data; + int length; + int error_code; + + if (!oct_eth_info->enabled) { + oct_eth_info->enabled = 1; + debug("%s: Enabling interface %s\n", __func__, dev->name); + octeon_eth_enable(dev); + } + + if (!work) { + /* + * Somtimes the link is not up yet. Return here in this + * case, this function will be called again later. + */ + return 0; + } + + error_code = cvmx_wqe_get_rcv_err(work); + if (error_code) { + /* Work has error, so drop */ + cvmx_helper_free_packet_data(work); + cvmx_wqe_free(work); + if (error_code < ARRAY_SIZE(rx_error_codes) && + !octeon_has_feature(OCTEON_FEATURE_BGX)) + printf("Receive error (code %d: %s), dropping\n", + error_code, rx_error_codes[error_code]); + else + printf("Receive error (code %d (unknown), dropping\n", + error_code); + return 0; + } + if (cvmx_wqe_get_bufs(work) != 1) { + /* can only support single-buffer packets */ + printf("Abnormal packet received in %u bufs, dropping\n", + cvmx_wqe_get_bufs(work)); + length = cvmx_wqe_get_len(work); + buf_ptr = cvmx_wqe_get_packet_ptr(work); + packet_data = cvmx_phys_to_ptr(buf_ptr.s.addr); + print_packet(packet_data, length); + cvmx_helper_free_packet_data(work); + cvmx_wqe_free(work); + return 0; + } + + buf_ptr = cvmx_wqe_get_packet_ptr(work); + packet_data = cvmx_phys_to_ptr(buf_ptr.s.addr); + length = cvmx_wqe_get_len(work); + + oct_eth_info->packets_received++; + debug("############# got work: %p, len: %d, packet_ptr: %p\n", work, + length, packet_data); +#if defined(DEBUG_RX_PACKET) + if (packet_rx_debug) { + printf("\nRX packet: interface: %d, index: %d\n", + oct_eth_info->interface, oct_eth_info->index); + print_packet(packet_data, length); + } +#endif + *packetp = (uchar *)packet_data; + + /* Save work for free_pkt() */ + oct_eth_info->work = work; + + /* Free WQE and packet data */ + return length; +} + +static int nic_free_pkt(struct udevice *dev, uchar *pkt, int pkt_len) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + cvmx_wqe_t *work = oct_eth_info->work; + + if (!work) + return 0; + + cvmx_helper_free_packet_data(work); + cvmx_wqe_free(work); + oct_eth_info->work = NULL; + + return 0; +} + +/** + * Packet transmit + * + * @param skb Packet to send + * @param dev Device info structure + * @return Always returns zero + */ +static int cvm_oct_xmit(struct udevice *dev, void *packet, int len) +{ + struct octeon_eth_info *priv = dev_get_priv(dev); + int queue = cvmx_pko_get_base_queue(priv->port); + cvmx_pko_command_word0_t pko_command; + cvmx_buf_ptr_t hw_buffer; + int rv; + + debug("%s: addr: %p, len: %d\n", __func__, packet, len); + + hw_buffer.u64 = 0; + hw_buffer.s.addr = cvmx_ptr_to_phys(packet); + hw_buffer.s.pool = CVMX_FPA_PACKET_POOL; + hw_buffer.s.size = len; + hw_buffer.s.back = 0; + + /* Build the PKO command */ + pko_command.u64 = 0; + pko_command.s.subone0 = 1; + pko_command.s.dontfree = 0; + pko_command.s.segs = 1; + pko_command.s.total_bytes = len; + /* Send the packet to the output queue */ + + debug("%s: port: %d, queue: %d\n", __func__, priv->port, queue); + cvmx_pko_send_packet_prepare(priv->port, queue, 0); + rv = cvmx_pko_send_packet_finish(priv->port, queue, pko_command, + hw_buffer, 0); + if (rv) + printf("Failed to send the packet rv=%d\n", rv); + + return 0; +} + +static int nic_xmit(struct udevice *dev, void *pkt, int pkt_len) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + void *fpa_buf = cvmx_fpa_alloc(CVMX_FPA_PACKET_POOL); + + if (!oct_eth_info->enabled) { + oct_eth_info->enabled = 1; + octeon_eth_enable(dev); + } + + /* We need to copy this to a FPA buffer, then give that to TX */ + + if (oct_eth_info->packets_sent == 0 && + !octeon_has_feature(OCTEON_FEATURE_BGX)) + cvm_oct_configure_rgmii_speed(dev); + + if (!fpa_buf) { + printf("ERROR allocating buffer for packet!\n"); + return -1; + } + + memcpy(fpa_buf, pkt, pkt_len); +#ifdef DEBUG_TX_PACKET + if (packet_tx_debug) { + printf("\nTX packet: interface: %d, index: %d\n", + oct_eth_info->interface, oct_eth_info->index); + print_packet(pkt, pkt_len); + } +#endif + cvm_oct_xmit(dev, fpa_buf, pkt_len); + oct_eth_info->packets_sent++; + + return 0; +} + +int nic_open(struct udevice *dev) +{ + octeon_eth_init(dev); + + return 0; +} + +static void octeon_eth_halt_bgx(struct udevice *dev, + cvmx_helper_interface_mode_t mode) +{ + union cvmx_bgxx_cmrx_config cmr_config; + union cvmx_bgxx_cmr_rx_adrx_cam cmr_cam; + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + int index = oct_eth_info->index; + int xiface = oct_eth_info->interface; + struct cvmx_xiface xi = cvmx_helper_xiface_to_node_interface(xiface); + + debug("%s(%s(%d.%d), %d)\n", __func__, dev->name, xiface, index, mode); + + /* For RGMII we need to properly shut down the XCV interface */ + if (cvmx_helper_bgx_is_rgmii(xiface, index)) { + debug(" Shut down XCV RGMII\n"); + octeon_bgx_xcv_rgmii_enable(xi.interface, index, false); + } else { + cmr_config.u64 = csr_rd_node(xi.node, + CVMX_BGXX_CMRX_CONFIG(index, xi.interface)); + cmr_config.s.data_pkt_tx_en = 0; + cmr_config.s.data_pkt_rx_en = 0; + csr_wr_node(xi.node, CVMX_BGXX_CMRX_CONFIG(index, xi.interface), + cmr_config.u64); + + cmr_cam.u64 = csr_rd_node(xi.node, + CVMX_BGXX_CMR_RX_ADRX_CAM(index * 8, xi.interface)); + cmr_cam.s.en = 0; + csr_wr_node(xi.node, + CVMX_BGXX_CMR_RX_ADRX_CAM(index * 8, xi.interface), + cmr_cam.u64); + oct_eth_info->last_bgx_mac = 0; + oct_eth_info->bgx_mac_set = 0; + } +} + +/** + * Halts the specified Ethernet interface preventing it from receiving any more + * packets. + * + * @param dev - Ethernet device to shut down. + */ +void octeon_eth_halt(struct udevice *dev) +{ + struct octeon_eth_info *oct_eth_info = dev_get_priv(dev); + int index = oct_eth_info->index; + int interface = oct_eth_info->interface; + cvmx_helper_interface_mode_t mode; + union cvmx_gmxx_rxx_adr_ctl adr_ctl; + cvmx_gmxx_prtx_cfg_t gmx_cfg; + u64 tmp; + + debug("%s(%s): Halting\n", __func__, dev->name); + + oct_eth_info->enabled = 0; + + mode = cvmx_helper_interface_get_mode(oct_eth_info->interface); + if (octeon_has_feature(OCTEON_FEATURE_BGX)) { + octeon_eth_halt_bgx(dev, mode); + return; + } + + /* Stop SCC */ + /* Disable reception on this port at the GMX block */ + switch (mode) { + case CVMX_HELPER_INTERFACE_MODE_RGMII: + case CVMX_HELPER_INTERFACE_MODE_GMII: + debug(" RGMII/GMII\n"); + tmp = csr_rd(CVMX_ASXX_RX_PRT_EN(oct_eth_info->interface)); + tmp &= ~(1ull << index); + /* Disable the RGMII RX ports */ + csr_wr(CVMX_ASXX_RX_PRT_EN(oct_eth_info->interface), tmp); + tmp = csr_rd(CVMX_ASXX_TX_PRT_EN(oct_eth_info->interface)); + tmp &= ~(1ull << index); + /* Disable the RGMII TX ports */ + csr_wr(CVMX_ASXX_TX_PRT_EN(oct_eth_info->interface), tmp); + /* No break! */ + case CVMX_HELPER_INTERFACE_MODE_SGMII: + case CVMX_HELPER_INTERFACE_MODE_QSGMII: + case CVMX_HELPER_INTERFACE_MODE_XAUI: + case CVMX_HELPER_INTERFACE_MODE_RXAUI: + case CVMX_HELPER_INTERFACE_MODE_XLAUI: + case CVMX_HELPER_INTERFACE_MODE_XFI: + case CVMX_HELPER_INTERFACE_MODE_10G_KR: + case CVMX_HELPER_INTERFACE_MODE_40G_KR4: + case CVMX_HELPER_INTERFACE_MODE_MIXED: + case CVMX_HELPER_INTERFACE_MODE_AGL: + /* Disable MAC filtering */ + gmx_cfg.u64 = csr_rd(oct_eth_info->gmx_base + GMX_PRT_CFG); + csr_wr(oct_eth_info->gmx_base + GMX_PRT_CFG, + gmx_cfg.u64 & ~1ull); + adr_ctl.u64 = 0; + adr_ctl.s.bcst = 1; /* Reject broadcast */ + csr_wr(oct_eth_info->gmx_base + GMX_RX_ADR_CTL, adr_ctl.u64); + csr_wr(oct_eth_info->gmx_base + GMX_RX_ADR_CAM_EN, 0); + csr_wr(oct_eth_info->gmx_base + GMX_PRT_CFG, gmx_cfg.u64); + break; + default: + printf("%s: Unknown mode %d for interface 0x%x:%d\n", __func__, + mode, interface, index); + break; + } +} + +void nic_stop(struct udevice *dev) +{ + octeon_eth_halt(dev); +} + +int nic_write_hwaddr(struct udevice *dev) +{ + cvm_oct_set_mac_address(dev); + + return 0; +} + +static const struct eth_ops octeon_nic_ops = { + .start = nic_open, + .stop = nic_stop, + .send = nic_xmit, + .recv = nic_recv, + .free_pkt = nic_free_pkt, + .write_hwaddr = nic_write_hwaddr, +}; + +static const struct udevice_id octeon_nic_ids[] = { + { .compatible = "cavium,octeon-7890-bgx" }, + {} +}; + +U_BOOT_DRIVER(octeon_nic) = { + .name = "octeon_nic", + .id = UCLASS_ETH, + .probe = octeon_nic_probe, + .of_match = octeon_nic_ids, + .ops = &octeon_nic_ops, + .priv_auto = sizeof(struct octeon_eth_info), +}; diff --git a/drivers/net/octeon/octeon_mdio.c b/drivers/net/octeon/octeon_mdio.c new file mode 100644 index 000000000000..34ee80901fb6 --- /dev/null +++ b/drivers/net/octeon/octeon_mdio.c @@ -0,0 +1,226 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018-2022 Marvell International Ltd. + */ + +#include <dm.h> +#include <fdt_support.h> +#include <log.h> +#include <miiphy.h> +#include <net.h> +#include <linux/delay.h> + +#include <mach/cvmx-regs.h> +#include <mach/cvmx-csr.h> +#include <mach/octeon-model.h> +#include <mach/octeon-feature.h> +#include <mach/cvmx-smix-defs.h> +#include <mach/cvmx-config.h> +#include <mach/cvmx-helper.h> +#include <mach/cvmx-helper-board.h> +#include <mach/cvmx-mdio.h> + +#define CVMX_SMI_DRV_CTL 0x0001180000001828ull +#define DEFAULT_MDIO_SPEED 2500000 /** 2.5 MHz default speed */ + +/** + * cvmx_smi_drv_ctl + * + * Enables the SMI interface. + * + */ +union cvmx_smi_drv_ctl { + u64 u64; + struct cvmx_smi_drv_ctl_s { + u64 reserved_14_63 : 50; + u64 pctl : 6; + u64 reserved_6_7 : 2; + u64 nctl : 6; + } s; +}; + +struct octeon_mdiobus { + struct mii_dev *mii_dev; + /** + * The local bus is in the lower 8 bits, followed by the remote bus in + * the top 8 bits. Bit 16 will be set if the bus is non-local. + */ + u32 bus_id; + + int node; /** Node number */ + int speed; /** Bus speed, normally 2.5 MHz */ + int fdt_node; /** Node in FDT */ + bool local; /** true if local MDIO bus */ +}; + +static int octeon_mdio_read(struct udevice *mdio_dev, int phy_addr, + int dev_addr, int reg_addr) +{ + struct octeon_mdiobus *p = dev_get_priv(mdio_dev); + struct mii_dev *dev = p->mii_dev; + int value; + + debug("%s(0x%p(%s): bus_id=%d phy_addr=%d, 0x%x, 0x%x) - ", __func__, + dev, dev->name, p->bus_id, phy_addr, dev_addr, reg_addr); + if (IS_ENABLED(CONFIG_PHYLIB_10G) && dev_addr != MDIO_DEVAD_NONE) { + debug("clause 45 mode\n"); + value = cvmx_mdio_45_read(p->bus_id & 0xff, phy_addr, dev_addr, + reg_addr); + } else { + value = cvmx_mdio_read(p->bus_id & 0xff, phy_addr, reg_addr); + } + + debug("Return value: 0x%x\n", value); + return value; +} + +static int octeon_mdio_write(struct udevice *mdio_dev, int phy_addr, + int dev_addr, int reg_addr, u16 value) +{ + struct octeon_mdiobus *p = dev_get_priv(mdio_dev); + struct mii_dev *dev = p->mii_dev; + + debug("%s(0x%p(%s): bus_id=%d phy_addr=%d, 0x%x, 0x%x, 0x%x)\n", + __func__, dev, dev->name, p->bus_id, phy_addr, dev_addr, reg_addr, + value); + + if (IS_ENABLED(CONFIG_PHYLIB_10G) && dev_addr != MDIO_DEVAD_NONE) { + debug("clause 45 mode\n"); + return cvmx_mdio_45_write(p->bus_id & 0xff, phy_addr, dev_addr, + reg_addr, value); + } + + return cvmx_mdio_write(p->bus_id & 0xff, phy_addr, reg_addr, value); +} + +/** + * Converts a MDIO register address to a bus number + * + * @param reg_addr MDIO base register address + * + * @return MDIO bus number or -1 if invalid address + */ +int octeon_mdio_reg_addr_to_bus(u64 reg_addr) +{ + int bus_base; + int bus; + + /* Adjust the bus number based on the node number */ + bus_base = cvmx_csr_addr_to_node(reg_addr) * 4; + reg_addr = cvmx_csr_addr_strip_node(reg_addr); + + switch (reg_addr) { + case 0x1180000001800: + case 0x1180000003800: /* 68XX/78XX address */ + bus = 0; + break; + case 0x1180000001900: + case 0x1180000003880: + bus = 1; + break; + case 0x1180000003900: + bus = 2; + break; + case 0x1180000003980: + bus = 3; + break; + default: + printf("%s: Unknown register address 0x%llx\n", __func__, + reg_addr); + return -1; + } + bus += bus_base; + debug("%s: address 0x%llx is bus %d\n", __func__, reg_addr, bus); + return bus; +} + +static int octeon_mdio_probe(struct udevice *dev) +{ + struct octeon_mdiobus *p = dev_get_priv(dev); + union cvmx_smi_drv_ctl drv_ctl; + cvmx_smix_clk_t smi_clk; + u64 mdio_addr; + int bus; + u64 sclock; + u32 sample_dly; + u64 denom; + + mdio_addr = dev_read_addr(dev); + debug("%s: Translated address: 0x%llx\n", __func__, mdio_addr); + bus = octeon_mdio_reg_addr_to_bus(mdio_addr); + p->bus_id = bus; + debug("%s: bus: %d\n", __func__, bus); + + drv_ctl.u64 = csr_rd(CVMX_SMI_DRV_CTL); + drv_ctl.s.pctl = dev_read_u32_default(dev, "cavium,pctl-drive-strength", + drv_ctl.s.pctl); + drv_ctl.s.nctl = dev_read_u32_default(dev, "cavium,nctl-drive-strength", + drv_ctl.s.nctl); + debug("%s: Set MDIO PCTL drive strength to 0x%x and NCTL drive strength to 0x%x\n", + __func__, drv_ctl.s.pctl, drv_ctl.s.nctl); + csr_wr(CVMX_SMI_DRV_CTL, drv_ctl.u64); + + /* Set the bus speed, default is 2.5MHz */ + p->speed = dev_read_u32_default(dev, "cavium,max-speed", + DEFAULT_MDIO_SPEED); + sclock = gd->bus_clk; + smi_clk.u64 = csr_rd(CVMX_SMIX_CLK(bus & 3)); + smi_clk.s.phase = sclock / (p->speed * 2); + + /* Allow sample delay to be specified */ + sample_dly = dev_read_u32_default(dev, "cavium,sample-delay", 0); + /* Only change the sample delay if it is set, otherwise use + * the default value of 2. + */ + if (sample_dly) { + u32 sample; + + denom = (sclock * 1000ULL) / sample_dly; + debug("%s: sclock: %llu, sample_dly: %u ps, denom: %llu\n", + __func__, sclock, sample_dly, denom); + sample = (sclock + denom - 1) / denom; + debug("%s: sample: %u\n", __func__, smi_clk.s.sample); + if (sample < 2) { + printf("%s: warning: cavium,sample-delay %u ps is too small in device tree for %s\n", + __func__, sample_dly, dev->name); + sample = 2; + } + if (sample > (2 * smi_clk.s.phase - 3)) { + printf("%s: warning: cavium,sample-delay %u ps is too large in device tree for %s\n", + __func__, sample_dly, dev->name); + sample = 2 * smi_clk.s.phase - 3; + } + smi_clk.s.sample = sample & 0xf; + smi_clk.s.sample_hi = (sample >> 4) & 0xf; + debug("%s(%s): sample delay: %u ps (%d clocks)\n", __func__, + dev->name, sample_dly, smi_clk.s.sample); + } + csr_wr(CVMX_SMIX_CLK(bus & 3), smi_clk.u64); + + debug("mdio clock phase: %d clocks\n", smi_clk.s.phase); + csr_wr(CVMX_SMIX_CLK(bus & 3), smi_clk.u64); + debug("Enabling SMI interface %s\n", dev->name); + csr_wr(CVMX_SMIX_EN(bus & 3), 1); + + /* Muxed MDIO bus support removed for now! */ + return 0; +} + +static const struct mdio_ops octeon_mdio_ops = { + .read = octeon_mdio_read, + .write = octeon_mdio_write, +}; + +static const struct udevice_id octeon_mdio_ids[] = { + { .compatible = "cavium,octeon-3860-mdio" }, + {} +}; + +U_BOOT_DRIVER(octeon_mdio) = { + .name = "octeon_mdio", + .id = UCLASS_MDIO, + .of_match = octeon_mdio_ids, + .probe = octeon_mdio_probe, + .ops = &octeon_mdio_ops, + .priv_auto = sizeof(struct octeon_mdiobus), +};
This patch enables the Kconfig symbols needed for full ethernet support on the EBB7304. Also the PHY autonegotiation timeout is increased, as the default 5 seconds are sometime a bit short. With this, ethernet can be used on this board. Here an example of a tftp load:
=> tftp ffffffff81000000 big ethernet-mac-nexus@11800e0000000 Waiting for PHY auto negotiation to complete....... done Using ethernet-mac-nexus@11800e0000000 device TFTP from server 192.168.1.5; our IP address is 192.168.1.243 Filename 'big'. Load address: 0xffffffff81000000 Loading: ################################################## 10 MiB 13.2 MiB/s done Bytes transferred = 10485760 (a00000 hex)
Signed-off-by: Stefan Roese sr@denx.de --- configs/octeon_ebb7304_defconfig | 7 +++++++ include/configs/octeon_ebb7304.h | 2 ++ 2 files changed, 9 insertions(+)
diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index 9824f8b97ae5..3d9bbaaab4df 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -25,6 +25,7 @@ CONFIG_CMD_PART=y CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_RTC=y CONFIG_CMD_TIME=y @@ -36,6 +37,7 @@ CONFIG_EFI_PARTITION=y CONFIG_PARTITION_TYPE_GUID=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x800000001FBFE000 +CONFIG_TFTP_TSIZE=y CONFIG_CLK=y # CONFIG_INPUT is not set CONFIG_MISC=y @@ -53,7 +55,12 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y +CONFIG_PHYLIB=y +CONFIG_PHY_MARVELL=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y CONFIG_E1000=y +CONFIG_NET_OCTEON=y CONFIG_PCI=y CONFIG_PCIE_OCTEON=y CONFIG_DM_REGULATOR=y diff --git a/include/configs/octeon_ebb7304.h b/include/configs/octeon_ebb7304.h index 358db69a05b3..8c6c57bd546a 100644 --- a/include/configs/octeon_ebb7304.h +++ b/include/configs/octeon_ebb7304.h @@ -16,4 +16,6 @@ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_8BIT #define CONFIG_SYS_FLASH_EMPTY_INFO /* flinfo indicates empty blocks */
+#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ + #endif /* __CONFIG_H__ */
This patch enables the Kconfig symbols needed for full ethernet support on the NIC23. Additionally board specific setup is done, mostly GPIOs related to SFP / GPIO configuration. With this, ethernet can be used on this board. Here an example of a tftp load:
=> tftp ffffffff81000000 big Using ethernet-mac-nexus@11800e2000000 device TFTP from server 192.168.1.5; our IP address is 192.168.1.247 Filename 'big'. Load address: 0xffffffff81000000 Loading: ################################################## 10 MiB 9.7 MiB/s done Bytes transferred = 10485760 (a00000 hex)
Signed-off-by: Stefan Roese sr@denx.de --- board/Marvell/octeon_nic23/board.c | 87 +++++++++++++++++++++++++++++- configs/octeon_nic23_defconfig | 10 +++- 2 files changed, 95 insertions(+), 2 deletions(-)
diff --git a/board/Marvell/octeon_nic23/board.c b/board/Marvell/octeon_nic23/board.c index 9f5eb2e2a182..3e2c54444397 100644 --- a/board/Marvell/octeon_nic23/board.c +++ b/board/Marvell/octeon_nic23/board.c @@ -1,10 +1,11 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2021 Stefan Roese sr@denx.de + * Copyright (C) 2021-2022 Stefan Roese sr@denx.de */
#include <dm.h> #include <ram.h> +#include <asm/gpio.h>
#include <mach/octeon_ddr.h> #include <mach/cvmx-qlm.h> @@ -84,6 +85,52 @@ int board_fix_fdt(void *fdt) return rc; }
+int board_early_init_f(void) +{ + struct gpio_desc gpio = {}; + ofnode node; + + /* Initial GPIO configuration */ + + /* GPIO 7: Vitesse reset */ + node = ofnode_by_compatible(ofnode_null(), "vitesse,vsc7224"); + if (ofnode_valid(node)) { + gpio_request_by_name_nodev(node, "los", 0, &gpio, GPIOD_IS_IN); + dm_gpio_free(gpio.dev, &gpio); + gpio_request_by_name_nodev(node, "reset", 0, &gpio, + GPIOD_IS_OUT); + if (dm_gpio_is_valid(&gpio)) { + /* Vitesse reset */ + debug("%s: Setting GPIO 7 to 1\n", __func__); + dm_gpio_set_value(&gpio, 1); + } + dm_gpio_free(gpio.dev, &gpio); + } + + /* SFP+ transmitters */ + ofnode_for_each_compatible_node(node, "ethernet,sfp-slot") { + gpio_request_by_name_nodev(node, "tx_disable", 0, + &gpio, GPIOD_IS_OUT); + if (dm_gpio_is_valid(&gpio)) { + debug("%s: Setting GPIO %d to 1\n", __func__, + gpio.offset); + dm_gpio_set_value(&gpio, 1); + } + dm_gpio_free(gpio.dev, &gpio); + gpio_request_by_name_nodev(node, "mod_abs", 0, &gpio, + GPIOD_IS_IN); + dm_gpio_free(gpio.dev, &gpio); + gpio_request_by_name_nodev(node, "tx_error", 0, &gpio, + GPIOD_IS_IN); + dm_gpio_free(gpio.dev, &gpio); + gpio_request_by_name_nodev(node, "rx_los", 0, &gpio, + GPIOD_IS_IN); + dm_gpio_free(gpio.dev, &gpio); + } + + return 0; +} + void board_configure_qlms(void) { octeon_configure_qlm(4, 3000, CVMX_QLM_MODE_SATA_2X1, 0, 0, 0, 0); @@ -100,7 +147,45 @@ void board_configure_qlms(void)
int board_late_init(void) { + struct gpio_desc gpio = {}; + ofnode node; + + /* Turn on SFP+ transmitters */ + ofnode_for_each_compatible_node(node, "ethernet,sfp-slot") { + gpio_request_by_name_nodev(node, "tx_disable", 0, + &gpio, GPIOD_IS_OUT); + if (dm_gpio_is_valid(&gpio)) { + debug("%s: Setting GPIO %d to 0\n", __func__, + gpio.offset); + dm_gpio_set_value(&gpio, 0); + } + dm_gpio_free(gpio.dev, &gpio); + } + board_configure_qlms();
return 0; } + +int last_stage_init(void) +{ + struct gpio_desc gpio = {}; + ofnode node; + + node = ofnode_by_compatible(ofnode_null(), "vitesse,vsc7224"); + if (!ofnode_valid(node)) { + printf("Vitesse SPF DT node not found!"); + return 0; + } + + gpio_request_by_name_nodev(node, "reset", 0, &gpio, GPIOD_IS_OUT); + if (dm_gpio_is_valid(&gpio)) { + /* Take Vitesse retimer out of reset */ + debug("%s: Setting GPIO 7 to 0\n", __func__); + dm_gpio_set_value(&gpio, 0); + mdelay(50); + } + dm_gpio_free(gpio.dev, &gpio); + + return 0; +} diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index 5427a9970a71..d44c650cef3c 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -12,6 +12,7 @@ CONFIG_ARCH_OCTEON=y CONFIG_TARGET_OCTEON_NIC23=y # CONFIG_MIPS_CACHE_SETUP is not set # CONFIG_MIPS_CACHE_DISABLE is not set +CONFIG_MIPS_RELOCATION_TABLE_SIZE=0xc000 CONFIG_DEBUG_UART=y CONFIG_AHCI=y CONFIG_OF_BOARD_FIXUP=y @@ -19,7 +20,9 @@ CONFIG_SYS_LOAD_ADDR=0xffffffff80100000 CONFIG_SYS_CONSOLE_ENV_OVERWRITE=y # CONFIG_SYS_DEVICE_NULLDEV is not set CONFIG_ARCH_MISC_INIT=y +CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y +CONFIG_LAST_STAGE_INIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -37,6 +40,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_ENV_ADDR=0xe000 +CONFIG_TFTP_TSIZE=y CONFIG_SATA=y CONFIG_AHCI_MVEBU=y CONFIG_CLK=y @@ -50,7 +54,11 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y -# CONFIG_NETDEVICES is not set +CONFIG_PHYLIB=y +CONFIG_PHYLIB_10G=y +CONFIG_DM_MDIO=y +CONFIG_DM_ETH_PHY=y +CONFIG_NET_OCTEON=y CONFIG_PCI=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y
Hi Daniel,
On 07.04.22 09:11, Stefan Roese wrote:
This patchset adds the networking files and drivers including device helper headers and C files. Please excuse the massive amount of files in this patch series. Also the sometimes huge files (mostly headers with register definitions) that I needed to include.
The infrastructure code with all the headers is ported mistly without any intended functional changes from the 2013 Cavium / Marvell U-Boot version. It has undergone many hours of extensive code cleanup and reformatting. Some of it done by using tools (checkpatch, Lindent, clang format etc) and also some of it done manually, as I couldn't find some tools that could do the needed work in a reliable and functional way. The result is that checkpatch now only throws a "few" warnings that are left. Some of those can't be removed without an even more extensive cleanup / rewrite of the code, like the addition of typedefs.
The added header, helper and infrastructure files in the first part of the patch-series (patches 1-43) are the foundation, that is used by the main Octeon U-Boot ethernet driver (patch 50/52). Patches 47-49 add the DT nodes and properties to the corresponding dtsi / dts files. Patches 51 & 52 finally enable the ethernet support both MIPS Octeon boards, EBB7304 & NIC23.
All this is tested on the 2 Cavium / Marvell MIPS Octeon boards: EBB7304 & NIC23
This patchset including the small Marvell PHY patches is available in this gitlab branch:
https://source.denx.de/u-boot/custodians/u-boot-marvell/-/tree/mips-octeon-e...
Changes in v2:
- As suggested by Daniel, remove all unreferenced functions from the source code by manually inspecting u-boot.map [1]
- Rebased on latest TOT
[1] Here the diffstat comarison between v1 and v2: v1: 77 files changed, 42315 insertions(+), 586 deletions(-) v2: 78 files changed, 33672 insertions(+), 2524 deletions(-)
Thanks, Stefan
Daniel, do you have any comments on this patchset? Tom has assigned it to me in patchwork and I would really like to get it merged into mainline, if possible. So if you don't have any obejctions, then I would pull it via the Marvell tree soon.
Thanks, Stefan
Hi Stefan,
Am 02.05.22 um 18:00 schrieb Stefan Roese:
Hi Daniel,
Changes in v2:
Thanks, Stefan
for the parts that I can reasonably review, I don't have any objections. I'd be happy if you pull it yourself as I'm currently really busy ;)
Changes in v2:
Thanks, Stefan
Aaron Williams (40): mips: octeon: Add misc cvmx-* header files mips: octeon: Add cvmx-ilk-defs.h header file mips: octeon: Add cvmx-iob-defs.h header file mips: octeon: Add cvmx-lbk-defs.h header file mips: octeon: Add cvmx-npei-defs.h header file mips: octeon: Add cvmx-pcsxx-defs.h header file mips: octeon: Add cvmx-xcv-defs.h header file mips: octeon: Add cvmx-helper-agl.c mips: octeon: Add cvmx-helper-bgx.c mips: octeon: Add cvmx-helper-board.c mips: octeon: Add cvmx-helper-fpa.c mips: octeon: Add cvmx-helper-ilk.c mips: octeon: Add cvmx-helper-ipd.c mips: octeon: Add cvmx-helper-loop.c mips: octeon: Add cvmx-helper-npi.c mips: octeon: Add cvmx-helper-pki.c mips: octeon: Add cvmx-helper-pko.c mips: octeon: Add cvmx-helper-pko3.c mips: octeon: Add cvmx-helper-rgmii.c mips: octeon: Add cvmx-helper-sgmii.c mips: octeon: Add cvmx-helper-sfp.c mips: octeon: Add cvmx-helper-xaui.c mips: octeon: Add cvmx-agl.c mips: octeon: Add cvmx-cmd-queue.c mips: octeon: Add cvmx-fau-compat.c mips: octeon: Add cvmx-fpa.c mips: octeon: Add cvmx-fpa-resource.c mips: octeon: Add cvmx-global-resource.c mips: octeon: Add cvmx-ilk.c mips: octeon: Add cvmx-ipd.c mips: octeon: Add cvmx-pki.c mips: octeon: Add cvmx-pki-resources.c mips: octeon: Add cvmx-pko.c mips: octeon: Add cvmx-pko3.c mips: octeon: Add cvmx-pko3-queue.c mips: octeon: Add cvmx-pko3-compat.c mips: octeon: Add cvmx-pko3-resources.c mips: octeon: Add cvmx-pko-internal-ports-range.c mips: octeon: Add cvmx-qlm-tables.c mips: octeon: Add cvmx-range.c
Stefan Roese (12): mips: octeon: Misc changes to existing headers for upcoming eth support mips: octeon: Misc changes to existing C files for upcoming eth support mips: octeon: Makefile: Enable building of the newly added C files mips: octeon: cpu.c: Move bootmem init to arch_early_init_r() mips: octeon: cpu.c: Implement configure_lmtdma_window() mips: octeon: octeon_common.h: Move init SP because of increased image size mips: octeon: mrvl,cn73xx.dtsi: Add ethernet (BGX) and SMI DT nodes mips: octeon: mrvl,octeon-ebb7304.dts: Add ethernet DT support mips: octeon: mrvl,octeon-nic23.dts: Add ethernet DT support net: Add ethernet support for MIPS Octeon mips: octeon: ebb7304: Enable ethernet support mips: octeon: nic23: Enable ethernet support
arch/mips/Kconfig | 1 + arch/mips/dts/mrvl,cn73xx.dtsi | 35 + arch/mips/dts/mrvl,octeon-ebb7304.dts | 45 + arch/mips/dts/mrvl,octeon-nic23.dts | 238 ++ arch/mips/mach-octeon/Makefile | 35 +- arch/mips/mach-octeon/cpu.c | 47 +- arch/mips/mach-octeon/cvmx-agl.c | 216 + arch/mips/mach-octeon/cvmx-bootmem.c | 3 +- arch/mips/mach-octeon/cvmx-cmd-queue.c | 355 ++ arch/mips/mach-octeon/cvmx-fau-compat.c | 53 + arch/mips/mach-octeon/cvmx-fpa-resource.c | 219 + arch/mips/mach-octeon/cvmx-fpa.c | 1127 ++++++ arch/mips/mach-octeon/cvmx-global-resources.c | 517 +++ arch/mips/mach-octeon/cvmx-helper-agl.c | 231 ++ arch/mips/mach-octeon/cvmx-helper-bgx.c | 2737 +++++++++++++ arch/mips/mach-octeon/cvmx-helper-board.c | 1824 +++++++++ arch/mips/mach-octeon/cvmx-helper-cfg.c | 655 +-- arch/mips/mach-octeon/cvmx-helper-fdt.c | 898 +---- arch/mips/mach-octeon/cvmx-helper-fpa.c | 76 + arch/mips/mach-octeon/cvmx-helper-ilk.c | 902 +++++ arch/mips/mach-octeon/cvmx-helper-ipd.c | 286 ++ arch/mips/mach-octeon/cvmx-helper-loop.c | 178 + arch/mips/mach-octeon/cvmx-helper-npi.c | 137 + arch/mips/mach-octeon/cvmx-helper-pki.c | 549 +++ arch/mips/mach-octeon/cvmx-helper-pko.c | 203 + arch/mips/mach-octeon/cvmx-helper-pko3.c | 1088 +++++ arch/mips/mach-octeon/cvmx-helper-rgmii.c | 398 ++ arch/mips/mach-octeon/cvmx-helper-sfp.c | 1309 ++++++ arch/mips/mach-octeon/cvmx-helper-sgmii.c | 781 ++++ arch/mips/mach-octeon/cvmx-helper-util.c | 248 -- arch/mips/mach-octeon/cvmx-helper-xaui.c | 518 +++ arch/mips/mach-octeon/cvmx-helper.c | 845 +--- arch/mips/mach-octeon/cvmx-ilk.c | 1199 ++++++ arch/mips/mach-octeon/cvmx-ipd.c | 149 + arch/mips/mach-octeon/cvmx-pki-resources.c | 285 ++ arch/mips/mach-octeon/cvmx-pki.c | 910 +++++ .../cvmx-pko-internal-ports-range.c | 99 + arch/mips/mach-octeon/cvmx-pko.c | 788 ++++ arch/mips/mach-octeon/cvmx-pko3-compat.c | 656 +++ arch/mips/mach-octeon/cvmx-pko3-queue.c | 879 ++++ arch/mips/mach-octeon/cvmx-pko3-resources.c | 213 + arch/mips/mach-octeon/cvmx-pko3.c | 786 ++++ arch/mips/mach-octeon/cvmx-qlm-tables.c | 292 ++ arch/mips/mach-octeon/cvmx-range.c | 259 ++ arch/mips/mach-octeon/include/mach/cvmx-agl.h | 45 + .../mach-octeon/include/mach/cvmx-bootmem.h | 3 +- .../mach-octeon/include/mach/cvmx-config.h | 128 + arch/mips/mach-octeon/include/mach/cvmx-fau.h | 581 +++ arch/mips/mach-octeon/include/mach/cvmx-fpa.h | 3 +- .../mips/mach-octeon/include/mach/cvmx-fpa3.h | 37 - .../include/mach/cvmx-helper-board.h | 6 +- .../include/mach/cvmx-helper-fdt.h | 40 +- .../include/mach/cvmx-helper-pko.h | 2 +- .../mach-octeon/include/mach/cvmx-helper.h | 20 + .../mach-octeon/include/mach/cvmx-ilk-defs.h | 2269 +++++++++++ .../mach-octeon/include/mach/cvmx-iob-defs.h | 1328 ++++++ .../mach-octeon/include/mach/cvmx-lbk-defs.h | 157 + .../mips/mach-octeon/include/mach/cvmx-mdio.h | 516 +++ .../mach-octeon/include/mach/cvmx-npei-defs.h | 3550 +++++++++++++++++ .../include/mach/cvmx-pcsxx-defs.h | 787 ++++ .../include/mach/cvmx-pki-cluster.h | 343 ++ arch/mips/mach-octeon/include/mach/cvmx-pko.h | 213 + .../include/mach/cvmx-pko3-resources.h | 36 + .../mips/mach-octeon/include/mach/cvmx-pko3.h | 1052 +++++ .../mach-octeon/include/mach/cvmx-range.h | 23 + .../mips/mach-octeon/include/mach/cvmx-regs.h | 100 +- .../mach-octeon/include/mach/cvmx-xcv-defs.h | 226 ++ .../mach-octeon/include/mach/octeon_eth.h | 54 +- board/Marvell/octeon_nic23/board.c | 87 +- configs/octeon_ebb7304_defconfig | 7 + configs/octeon_nic23_defconfig | 10 +- drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/octeon/Makefile | 6 + drivers/net/octeon/octeon_eth.c | 1060 +++++ drivers/net/octeon/octeon_mdio.c | 226 ++ include/configs/octeon_common.h | 2 +- include/configs/octeon_ebb7304.h | 2 + 78 files changed, 33672 insertions(+), 2524 deletions(-) create mode 100644 arch/mips/mach-octeon/cvmx-agl.c create mode 100644 arch/mips/mach-octeon/cvmx-cmd-queue.c create mode 100644 arch/mips/mach-octeon/cvmx-fau-compat.c create mode 100644 arch/mips/mach-octeon/cvmx-fpa-resource.c create mode 100644 arch/mips/mach-octeon/cvmx-fpa.c create mode 100644 arch/mips/mach-octeon/cvmx-global-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-agl.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-bgx.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-board.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-fpa.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-ilk.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-ipd.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-loop.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-npi.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pki.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-pko3.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-rgmii.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-sfp.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-sgmii.c create mode 100644 arch/mips/mach-octeon/cvmx-helper-xaui.c create mode 100644 arch/mips/mach-octeon/cvmx-ilk.c create mode 100644 arch/mips/mach-octeon/cvmx-ipd.c create mode 100644 arch/mips/mach-octeon/cvmx-pki-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-pki.c create mode 100644 arch/mips/mach-octeon/cvmx-pko-internal-ports-range.c create mode 100644 arch/mips/mach-octeon/cvmx-pko.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-compat.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-queue.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3-resources.c create mode 100644 arch/mips/mach-octeon/cvmx-pko3.c create mode 100644 arch/mips/mach-octeon/cvmx-qlm-tables.c create mode 100644 arch/mips/mach-octeon/cvmx-range.c create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-agl.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-config.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-fau.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-ilk-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-iob-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-lbk-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-mdio.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-npei-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pcsxx-defs.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pki-cluster.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3-resources.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-pko3.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-range.h create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-xcv-defs.h create mode 100644 drivers/net/octeon/Makefile create mode 100644 drivers/net/octeon/octeon_eth.c create mode 100644 drivers/net/octeon/octeon_mdio.c
Applied to u-boot-marvell/master
Thanks, Stefan
Daniel Schwierzeck
Stefan Roese
