[U-Boot] [PATCH v2 1/3] configs: ti_omap4_common: Include TWL6030 power and I2C support in SPL
This includes the TWL6030 power driver in SPL, to allow powering up MMC devices. This is especially relevant when the bootrom didn't power any MMC device yet but U-Boot is to be loaded from MMC (e.g. after setting boot mode from the SYS_BOOT pins in peripheral boot).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- include/configs/ti_omap4_common.h | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 5fad3c1..7e08887 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -65,9 +65,7 @@ #define CONFIG_CONS_INDEX 3
/* TWL6030 */ -#ifndef CONFIG_SPL_BUILD #define CONFIG_TWL6030_POWER 1 -#endif
/* USB */ #define CONFIG_USB_MUSB_UDC 1 @@ -162,11 +160,4 @@ #define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ #endif
-#ifdef CONFIG_SPL_BUILD -/* No need for i2c in SPL mode as we will use SRI2C for PMIC access on OMAP4 */ -#undef CONFIG_SYS_I2C -#undef CONFIG_SYS_I2C_OMAP24XX -#undef CONFIG_SPL_I2C_SUPPORT -#endif - #endif /* __CONFIG_TI_OMAP4_COMMON_H */
This adds support for initializing MMC power from TWL6030 in SPL, which is required when the bootrom didn't power the MMC device yet and U-Boot is to be loaded from MMC (e.g. after setting boot mode from the SYS_BOOT pins in peripheral boot).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- board/ti/panda/panda.c | 2 +- include/configs/omap4_panda.h | 2 ++ 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 13b5daf..ebab4e7 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -292,12 +292,12 @@ int board_mmc_init(bd_t *bis) { return omap_mmc_init(0, 0, 0, -1, -1); } +#endif
void board_mmc_power_init(void) { twl6030_power_mmc_init(0); } -#endif
#ifdef CONFIG_USB_EHCI
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index ffa22c3..41991e0 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -33,6 +33,8 @@
#include <configs/ti_omap4_common.h>
+#define CONFIG_SPL_ABORT_ON_RAW_IMAGE + /* GPIO */
/* ENV related config options */
This reworks spl_set_header_raw_uboot to allow having both os boot (which comes with a valid header) and aborting when no valid header is found (thus excluding raw u-boot.bin images).
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/spl/spl.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index b7ec333..e14ec80 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -129,10 +129,8 @@ int spl_parse_image_header(const struct image_header *header) * is bad, and thus should be skipped silently. */ panic("** no mkimage signature but raw image not supported"); -#elif defined(CONFIG_SPL_ABORT_ON_RAW_IMAGE) - /* Signature not found, proceed to other boot methods. */ - return -EINVAL; -#else +#endif + #ifdef CONFIG_SPL_OS_BOOT ulong start, end;
@@ -147,6 +145,11 @@ int spl_parse_image_header(const struct image_header *header) return 0; } #endif + +#ifdef CONFIG_SPL_ABORT_ON_RAW_IMAGE + /* Signature not found, proceed to other boot methods. */ + return -EINVAL; +#else /* Signature not found - assume u-boot.bin */ debug("mkimage signature not found - ih_magic = %x\n", header->ih_magic);
Paul Kocialkowski
