uboot FIT signature difference
i try to create a upstream uboot binary for use with rockchip rk3568 (bananapi r2 pro). Currently i'm on preparation phase as i don't have the hardware yet (so i cannot test it).
First thanks to everybody upstreamed support for this SOC in uboot and linux.
i found a compiled uboot.img with this signature:
FIT Image with ATF/OP-TEE/U-Boot
my created itb (make u-boot.itb) has this signature:
FIT image for U-Boot with bl31 (TF-A)
can anybody give me a hint how to create same signature as above? or where i have to look...
i guess the uboot.img is created using this source: https://github.com/rockchip-linux/u-boot
as far as i see the itb gets generated from the dtb
OBJCOPY u-boot-nodtb.bin ./"arch/arm/mach-rockchip/make_fit_atf.py" \ arch/arm/dts/rk3568-evb.dtb > u-boot.its RELOC u-boot-nodtb.bin MKIMAGE u-boot.itb
op-tee seems to be a lib only in rockchip repo, not upstream
https://github.com/rockchip-linux/u-boot/tree/next-dev/lib/optee_clientApi
seems to be some kind of secure boot, idk if this is needed to boot the device
i wonder why uboot differentiate between ATF and BL31...imho BL31 is part of ATF, do i need all parts of ATF (at least BL2) to get same signature? i have some rk3568_ddr_xxxxMHz_v1.08.bin which can be BL2 (did not found any signature and Rockchip ATF source is afaik not yet released, at least not for rk35xx which is new).
"my" source is this:
https://github.com/frank-w/u-boot/tree/2021-10-bpi-r2-pro
regards Frank
Hi Frank,
On Sun, 10 Oct 2021 at 11:51, Frank Wunderlich frank-w@public-files.de wrote:
As far as I know this is just the description, which you can change by updating the 'description' of your .its file, or binman node if you are using that.
I'm not sure about all these flows. It is all quite complicated these days...
Gesendet: Sonntag, 24. Oktober 2021 um 21:53 Uhr Von: "Simon Glass" sjg@chromium.org An: "Frank Wunderlich" frank-w@public-files.de Cc: "Philipp Tomsich" philipp.tomsich@vrull.eu, "Kever Yang" kever.yang@rock-chips.com, "U-Boot Mailing List" u-boot@lists.denx.de Betreff: Re: uboot FIT signature difference
Hi Frank,
i found the signature of my binary here:
https://github.com/frank-w/u-boot/blob/2020-10-bpi/arch/arm/mach-rockchip/ma...
string on the possible source of the other binary differs...maybe it is somehow changed
compile-progress seems to be this:
https://gitlab.com/pgwipeout/quartz64_ci/-/blob/main/.gitlab-ci.yml#L58
so it looks like this python-script is used:
https://gitlab.com/pgwipeout/u-boot-rockchip/-/blob/quartz64/arch/arm/mach-r...
but still different...anyway thanks for looking into it
Regards Frank
no worry, i try my binary on the board if i get it ;)
Frank Wunderlich
