[U-Boot] [PATCH 0/4] ARM: chiliboard: move towards driver model and device-tree boot
Currently on master branch we are no longer able to boot Linux on chiliboard. This is due to issue described at [1]. This series makes the boot to Linux working once again.
This patch moves board support code to use driver model where possible and device-tree bot. As part of that we import DTS files from Linux v4.19.
[1] https://lists.denx.de/pipermail/u-boot/2018-November/348558.html
Marcin Niestroj (4): ARM: dts: am335x-chili*: add chiliSOM and chiliboard DTS files ARM: dts: am335x-chiliboard: add /chosen/stdout-path ARM: chiliboard: move towards driver model and device-tree boot ARM: chiliboard: remove dead !CONFIG_DM_SERIAL code
arch/arm/dts/Makefile | 3 +- arch/arm/dts/am335x-chiliboard-u-boot.dtsi | 11 ++ arch/arm/dts/am335x-chiliboard.dts | 200 +++++++++++++++++++++ arch/arm/dts/am335x-chilisom.dtsi | 178 ++++++++++++++++++ board/grinn/chiliboard/board.c | 61 ------- configs/chiliboard_defconfig | 12 +- 6 files changed, 401 insertions(+), 64 deletions(-) create mode 100644 arch/arm/dts/am335x-chiliboard-u-boot.dtsi create mode 100644 arch/arm/dts/am335x-chiliboard.dts create mode 100644 arch/arm/dts/am335x-chilisom.dtsi
Import chiliSOM and chiliboard dts files from Linux v4.19. They will be used after transition to driver model and device-tree based boot.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/am335x-chiliboard.dts | 200 +++++++++++++++++++++++++++++ arch/arm/dts/am335x-chilisom.dtsi | 178 +++++++++++++++++++++++++ 3 files changed, 380 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/am335x-chiliboard.dts create mode 100644 arch/arm/dts/am335x-chilisom.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 84b7e5335c..55f3fd1b25 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -187,7 +187,8 @@ dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb \ am335x-icev2.dtb \ am335x-pxm50.dtb \ am335x-rut.dtb \ - am335x-pdu001.dtb + am335x-pdu001.dtb \ + am335x-chiliboard.dtb dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb \ diff --git a/arch/arm/dts/am335x-chiliboard.dts b/arch/arm/dts/am335x-chiliboard.dts new file mode 100644 index 0000000000..59431b2359 --- /dev/null +++ b/arch/arm/dts/am335x-chiliboard.dts @@ -0,0 +1,200 @@ +/* + * Copyright (C) 2015 Jablotron s.r.o. -- http://www.jablotron.com/ + * Author: Rostislav Lisovy lisovy@jablotron.cz + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; +#include "am335x-chilisom.dtsi" + +/ { + model = "AM335x Chiliboard"; + compatible = "grinn,am335x-chiliboard", "grinn,am335x-chilisom", + "ti,am33xx"; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_gpio_pins>; + + led0 { + label = "led0"; + gpios = <&gpio3 7 GPIO_ACTIVE_LOW>; + default-state = "keep"; + linux,default-trigger = "heartbeat"; + }; + + led1 { + label = "led1"; + gpios = <&gpio3 8 GPIO_ACTIVE_LOW>; + default-state = "keep"; + }; + }; +}; + +&am33xx_pinmux { + uart0_pins: pinmux_uart0_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x970, PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */ + AM33XX_IOPAD(0x974, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */ + >; + }; + + cpsw_default: cpsw_default { + pinctrl-single,pins = < + /* Slave 1 */ + AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE1) /* mii1_crs.rmii1_crs */ + AM33XX_IOPAD(0x910, PIN_INPUT_PULLUP | MUX_MODE1) /* mii1_rxerr.rmii1_rxerr */ + AM33XX_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* mii1_txen.rmii1_txen */ + AM33XX_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* mii1_txd1.rmii1_txd1 */ + AM33XX_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* mii1_txd0.rmii1_txd0 */ + AM33XX_IOPAD(0x93c, PIN_INPUT_PULLUP | MUX_MODE1) /* mii1_rxd1.rmii1_rxd1 */ + AM33XX_IOPAD(0x940, PIN_INPUT_PULLUP | MUX_MODE1) /* mii1_rxd0.rmii1_rxd0 */ + AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii1_ref_clk.rmii_ref_clk */ + >; + }; + + cpsw_sleep: cpsw_sleep { + pinctrl-single,pins = < + /* Slave 1 reset value */ + AM33XX_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE7) + >; + }; + + davinci_mdio_default: davinci_mdio_default { + pinctrl-single,pins = < + /* mdio_data.mdio_data */ + AM33XX_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) + /* mdio_clk.mdio_clk */ + AM33XX_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0) + >; + }; + + davinci_mdio_sleep: davinci_mdio_sleep { + pinctrl-single,pins = < + /* MDIO reset value */ + AM33XX_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7) + AM33XX_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7) + >; + }; + + usb1_drvvbus: usb1_drvvbus { + pinctrl-single,pins = < + AM33XX_IOPAD(0xa34, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* usb1_drvvbus.usb1_drvvbus */ + >; + }; + + sd_pins: pinmux_sd_card { + pinctrl-single,pins = < + AM33XX_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */ + AM33XX_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */ + AM33XX_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */ + AM33XX_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */ + AM33XX_IOPAD(0x900, PIN_INPUT | MUX_MODE0) /* mmc0_clk.mmc0_clk */ + AM33XX_IOPAD(0x904, PIN_INPUT | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */ + AM33XX_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */ + >; + }; + + led_gpio_pins: led_gpio_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x9e4, PIN_OUTPUT | MUX_MODE7) /* emu0.gpio3_7 */ + AM33XX_IOPAD(0x9e8, PIN_OUTPUT | MUX_MODE7) /* emu1.gpio3_8 */ + >; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + + status = "okay"; +}; + +&ldo4_reg { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; +}; + +/* Ethernet */ +&mac { + slaves = <1>; + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&cpsw_default>; + pinctrl-1 = <&cpsw_sleep>; + status = "okay"; +}; + +&davinci_mdio { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&davinci_mdio_default>; + pinctrl-1 = <&davinci_mdio_sleep>; + status = "okay"; +}; + +&cpsw_emac0 { + phy_id = <&davinci_mdio>, <0>; + phy-mode = "rmii"; +}; + +&phy_sel { + rmii-clock-ext; +}; + +/* USB */ +&usb { + status = "okay"; +}; + +&usb_ctrl_mod { + status = "okay"; +}; + +&usb1_phy { + status = "okay"; +}; + +&usb1 { + pinctrl-names = "default"; + pinctrl-0 = <&usb1_drvvbus>; + + status = "okay"; + dr_mode = "host"; +}; + +&cppi41dma { + status = "okay"; +}; + +/* microSD */ +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&sd_pins>; + vmmc-supply = <&ldo4_reg>; + bus-width = <0x4>; + cd-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&tps { + interrupt-parent = <&intc>; + interrupts = <7>; /* NNMI */ + + charger { + status = "okay"; + }; + + pwrbutton { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/am335x-chilisom.dtsi b/arch/arm/dts/am335x-chilisom.dtsi new file mode 100644 index 0000000000..1b43ebd08b --- /dev/null +++ b/arch/arm/dts/am335x-chilisom.dtsi @@ -0,0 +1,178 @@ +/* + * Copyright (C) 2015 Jablotron s.r.o. -- http://www.jablotron.com/ + * Author: Rostislav Lisovy lisovy@jablotron.cz + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +#include "am33xx.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "Grinn AM335x ChiliSOM"; + compatible = "grinn,am335x-chilisom", "ti,am33xx"; + + cpus { + cpu@0 { + cpu0-supply = <&dcdc2_reg>; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x20000000>; /* 512 MB */ + }; +}; + +&am33xx_pinmux { + pinctrl-names = "default"; + + i2c0_pins: pinmux_i2c0_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda */ + AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl */ + >; + }; + + nandflash_pins: nandflash_pins { + pinctrl-single,pins = < + AM33XX_IOPAD(0x800, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */ + AM33XX_IOPAD(0x804, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */ + AM33XX_IOPAD(0x808, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */ + AM33XX_IOPAD(0x80c, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */ + AM33XX_IOPAD(0x810, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */ + AM33XX_IOPAD(0x814, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */ + AM33XX_IOPAD(0x818, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */ + AM33XX_IOPAD(0x81c, PIN_INPUT_PULLDOWN | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */ + + AM33XX_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */ + AM33XX_IOPAD(0x87c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */ + AM33XX_IOPAD(0x890, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */ + AM33XX_IOPAD(0x894, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */ + AM33XX_IOPAD(0x898, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_wen.gpmc_wen */ + AM33XX_IOPAD(0x89c, PIN_OUTPUT_PULLUP | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */ + >; + }; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + + status = "okay"; + clock-frequency = <400000>; + + tps: tps@24 { + reg = <0x24>; + }; + +}; + +/include/ "tps65217.dtsi" + +&tps { + regulators { + dcdc1_reg: regulator@0 { + regulator-name = "vdds_dpr"; + regulator-always-on; + }; + + dcdc2_reg: regulator@1 { + /* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */ + regulator-name = "vdd_mpu"; + regulator-min-microvolt = <925000>; + regulator-max-microvolt = <1325000>; + regulator-boot-on; + regulator-always-on; + }; + + dcdc3_reg: regulator@2 { + /* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */ + regulator-name = "vdd_core"; + regulator-min-microvolt = <925000>; + regulator-max-microvolt = <1150000>; + regulator-boot-on; + regulator-always-on; + }; + + ldo1_reg: regulator@3 { + regulator-name = "vio,vrtc,vdds"; + regulator-boot-on; + regulator-always-on; + }; + + ldo2_reg: regulator@4 { + regulator-name = "vdd_3v3aux"; + regulator-boot-on; + regulator-always-on; + }; + + ldo3_reg: regulator@5 { + regulator-name = "vdd_1v8"; + regulator-boot-on; + regulator-always-on; + }; + + ldo4_reg: regulator@6 { + regulator-name = "vdd_3v3d"; + regulator-boot-on; + regulator-always-on; + }; + }; +}; + +&rtc { + system-power-controller; + + pinctrl-0 = <&ext_wakeup>; + pinctrl-names = "default"; + + ext_wakeup: ext-wakeup { + pins = "ext_wakeup0"; + input-enable; + }; +}; + +/* NAND Flash */ +&elm { + status = "okay"; +}; + +&gpmc { + status = "okay"; + pinctrl-names = "default"; + pinctrl-0 = <&nandflash_pins>; + ranges = <0 0 0x08000000 0x01000000>; /* CS0 0 @addr 0x08000000, size 0x01000000 */ + nand@0,0 { + compatible = "ti,omap2-nand"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + interrupt-parent = <&gpmc>; + interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ + <1 IRQ_TYPE_NONE>; /* termcount */ + rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */ + ti,nand-ecc-opt = "bch8"; + ti,elm-id = <&elm>; + nand-bus-width = <8>; + gpmc,device-width = <1>; + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <44>; + gpmc,cs-wr-off-ns = <44>; + gpmc,adv-on-ns = <6>; + gpmc,adv-rd-off-ns = <34>; + gpmc,adv-wr-off-ns = <44>; + gpmc,we-on-ns = <0>; + gpmc,we-off-ns = <40>; + gpmc,oe-on-ns = <0>; + gpmc,oe-off-ns = <54>; + gpmc,access-ns = <64>; + gpmc,rd-cycle-ns = <82>; + gpmc,wr-cycle-ns = <82>; + gpmc,bus-turnaround-ns = <0>; + gpmc,cycle2cycle-delay-ns = <0>; + gpmc,clk-activation-ns = <0>; + gpmc,wr-access-ns = <40>; + gpmc,wr-data-mux-bus-ns = <0>; + }; +};
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com Reviewed-by: Tom Rini trini@konsulko.com
Add that node path in u-boot overlay dtsi file for now to keep am335x-chiliboard.dts in sync with Linux.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- arch/arm/dts/am335x-chiliboard-u-boot.dtsi | 11 +++++++++++ 1 file changed, 11 insertions(+) create mode 100644 arch/arm/dts/am335x-chiliboard-u-boot.dtsi
diff --git a/arch/arm/dts/am335x-chiliboard-u-boot.dtsi b/arch/arm/dts/am335x-chiliboard-u-boot.dtsi new file mode 100644 index 0000000000..4f9d308039 --- /dev/null +++ b/arch/arm/dts/am335x-chiliboard-u-boot.dtsi @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ or X11 +/* + * Copyright (C) 2018 Grinn Sp. z o.o. -- http://www.grinn-global.com/ + * Author: Marcin Niestroj m.niestroj@grinn-global.com + */ + +/ { + chosen { + stdout-path = &uart0; + }; +};
This patch mostly enables DM drivers in board defconfig and all their dependencies. Additionally we remove ethernet platform data, as all details are in device-tree now.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- board/grinn/chiliboard/board.c | 53 ---------------------------------- configs/chiliboard_defconfig | 12 ++++++-- 2 files changed, 10 insertions(+), 55 deletions(-)
diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 73a7d8281c..2bb91e31b7 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -150,56 +150,3 @@ int board_late_init(void) return 0; } #endif - -#if !defined(CONFIG_DM_ETH) && defined(CONFIG_DRIVER_TI_CPSW) && \ - !defined(CONFIG_SPL_BUILD) -static void cpsw_control(int enabled) -{ - /* VTP can be added here */ - - return; -} - -static struct cpsw_slave_data cpsw_slaves[] = { - { - .slave_reg_ofs = 0x208, - .sliver_reg_ofs = 0xd80, - .phy_addr = 0, - } -}; - -static struct cpsw_platform_data cpsw_data = { - .mdio_base = CPSW_MDIO_BASE, - .cpsw_base = CPSW_BASE, - .mdio_div = 0xff, - .channels = 8, - .cpdma_reg_ofs = 0x800, - .slaves = 1, - .slave_data = cpsw_slaves, - .ale_reg_ofs = 0xd00, - .ale_entries = 1024, - .host_port_reg_ofs = 0x108, - .hw_stats_reg_ofs = 0x900, - .bd_ram_ofs = 0x2000, - .mac_control = (1 << 5), - .control = cpsw_control, - .host_port_num = 0, - .version = CPSW_CTRL_VERSION_2, -}; - -int board_eth_init(bd_t *bis) -{ - int rv, n = 0; - - writel(RMII_MODE_ENABLE | RMII_CHIPCKL_ENABLE, &cdev->miisel); - cpsw_slaves[0].phy_if = PHY_INTERFACE_MODE_RMII; - - rv = cpsw_register(&cpsw_data); - if (rv < 0) - printf("Error %d registering CPSW switch\n", rv); - else - n += rv; - - return n; -} -#endif diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index b6cde09d6f..3de0223469 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -29,19 +29,27 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nand0=8000000.nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nand:128k(NAND.SPL),128k(NAND.SPL.backup1),128k(NAND.SPL.backup2),128k(NAND.SPL.backup3),256k(NAND.u-boot-spl-os),1m(NAND.u-boot),128k(NAND.u-boot-env),128k(NAND.u-boot-env.backup1),8m(NAND.kernel),-(NAND.file-system)" +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="am335x-chiliboard" CONFIG_ENV_IS_IN_MMC=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_GPIO=y +CONFIG_MISC=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y -CONFIG_DRIVER_TI_CPSW=y +CONFIG_DM_ETH=y CONFIG_MII=y +CONFIG_DRIVER_TI_CPSW=y CONFIG_SPI=y CONFIG_OMAP3_SPI=y +CONFIG_TIMER=y +CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_DSPS=y +CONFIG_USB_MUSB_TI=y CONFIG_USB_STORAGE=y CONFIG_FAT_WRITE=y CONFIG_LZO=y -CONFIG_OF_LIBFDT=y
DM_SERIAL is selected by TARGET_CHILIBOARD, so there is no reason to keep code that will not be built. Remove it.
Signed-off-by: Marcin Niestroj m.niestroj@grinn-global.com --- board/grinn/chiliboard/board.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/board/grinn/chiliboard/board.c b/board/grinn/chiliboard/board.c index 2bb91e31b7..dc0de620fc 100644 --- a/board/grinn/chiliboard/board.c +++ b/board/grinn/chiliboard/board.c @@ -19,7 +19,6 @@ #include <environment.h> #include <errno.h> #include <miiphy.h> -#include <serial.h> #include <spl.h> #include <watchdog.h>
@@ -69,13 +68,6 @@ static void enable_board_pin_mux(void) } #endif /* CONFIG_SKIP_LOWLEVEL_INIT */
-#ifndef CONFIG_DM_SERIAL -struct serial_device *default_serial_console(void) -{ - return &eserial1_device; -} -#endif - #ifndef CONFIG_SKIP_LOWLEVEL_INIT void set_uart_mux_conf(void) {
Marcin Niestroj
