Re: [U-Boot] B4860/B4420 patches and some updates for qixis and T4240QDS
Hello Andy
Any update on this patch set?
Regards Poonam
From: Aggrwal Poonam-B10812 Sent: Friday, December 21, 2012 6:16 PM To: U-Boot-Denx Subject: B4860/B4420 patches and some updates for qixis and T4240QDS
The patchset contains the following patches:
Mainly related to B4860/B4420QDS. Some are qixis updates and related additions for B4860/B4420QDS and T4240QDS.
[PATCH 01/09] powerpc/mpc85xx: Few updates for B4860 cpu changes [PATCH 02/09] powerpc/mpc85xx:Add support of B4420 SoC [PATCH 03/09] board/freescale/common:Add support of QTAG register [PATCH 04/09] powerpc/mpc85xx:Fix Core cluster configuration loop [PATCH 05/09] powerpc/b4860qds: Added Support for B4860QDS [PATCH 06/09] powerpc/qixis: enable qixis dump command and add switch dumping command [PATCH 07/09] powerpc/b4860qds: Add support to dump switch settings on b4860qds board [PATCH 08/09] powerpc/t4240qds: Add support to dump switch settings on t4240qds board [PATCH 09/09] powerpc/t4240qds: Print FPGA detail version
Regards Poonam
I'm seeing these errors, when these patches are enabled:
/local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:575:2: error: #error Processor type not defined for this platform /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:579:2: error: #error "CONFIG_SYS_CCSRBAR_DEFAULT is not defined for this platform." /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:575:2: error: #error Processor type not defined for this platform /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:579:2: error: #error "CONFIG_SYS_CCSRBAR_DEFAULT is not defined for this platform." In file included from /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config.h:25:0, from /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include/config.h:13, from /local/afleming/u-boot/include/common.h:37, from /local/afleming/u-boot/lib/asm-offsets.c:18: /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:575:2: error: #error Processor type not defined for this platform /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/config_mpc85xx.h:579:2: error: #error "CONFIG_SYS_CCSRBAR_DEFAULT is not defined for this platform." In file included from /local/afleming/u-boot/include/mpc85xx.h:14:0, from /local/afleming/u-boot/include/common.h:93, from /local/afleming/u-boot/lib/asm-offsets.c:18: /local/afleming/u-boot/include/e500.h:19:26: error: 'CONFIG_SYS_NUM_FMAN' undeclared here (not in a function) In file included from /local/afleming/u-boot/include/common.h:94:0, from /local/afleming/u-boot/lib/asm-offsets.c:18: /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/immap_85xx.h:1400:33: error: 'CONFIG_SYS_FSL_SRIO_MAX_PORTS' undeclared here (not in a function) /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/immap_85xx.h:1498:28: error: 'CONFIG_SYS_FSL_SRIO_OB_WIN_NUM' undeclared here (not in a function) /local/afleming/u-boot/build/B4420QDS_SPIFLASH/include2/asm/immap_85xx.h:1500:27: error: 'CONFIG_SYS_FSL_SRIO_IB_WIN_NUM' undeclared here (not in a function) make: *** [/local/afleming/u-boot/build/B4420QDS_SPIFLASH/lib/asm-offsets.s] Error 1 make: *** Waiting for unfinished jobs....
This was also seen on B4860QDS_SPIFLASH
On Thu, Jan 17, 2013 at 11:18 PM, Aggrwal Poonam-B10812 < B10812@freescale.com> wrote:
Hello Andy
Regards Poonam
Regards Poonam
I have found the problem:
-B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +B4860QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000
-B4420QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 +B4420QDS_SPIFLASH powerpc mpc85xx b4860qds freescale - B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000
For some reason, the SPIFLASH versions of these boards didn't have the processor specified. I will add that change to the patches, and push them upstream.
Hello Andy
Regards Poonam
Regards Poonam
Andy Fleming
