[U-Boot] [PATCH] Allow OMAP2 boards to setup GPMC chipselects.
Expose the enable_gpmc_cs_config() function so OMAP2 boards can register GPMC chipselects.
Signed-off-by: Mark Jackson mpfj@newflow.co.uk --- arch/arm/include/asm/arch-am33xx/sys_proto.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 588d8de..97ab60d 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -35,5 +35,7 @@ void ddr_pll_config(unsigned int ddrpll_M); void sdelay(unsigned long); void gpmc_init(void); +void enable_gpmc_cs_config(const u32 *gpmc_config, struct gpmc_cs *cs, u32 base, + u32 size); void omap_nand_switch_ecc(int); #endif
u32 size);
Can you please correct the description? You're exposing the function for am33xx not omap2. Otherwise fine with me, and I assume you need this on a custom board (aside: the function already exists/is used in arch/arm/cpu/armv7/am33xx/mem.c). Are you planning to submit that support as well? Thanks!
void omap_nand_switch_ecc(int); #endifu32 size);
Sure ... I'll repost with the comment changed.
Yes ... I've not written my own version, I'm using the existing code.
And, yes, I've a new CPU board I'm working on, which I'll submit later (once we've done a hardware re-spin).
Cheers Mark J.
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
Thanks.
Looking forward to it!
- -- Tom
Mark Jackson
