[PATCH v2 0/6] ufs: core: initial cleanup and defines sync with Linux v6.12
This serie fixes the build and checkpatch warnings, and does a split of the ufs.h into a separate ufshci.h which helps syndhronizing the defines from Linux v6.12.
No functional changes intended, tests on hardware are welcome.
Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- Changes in v2: - Colect tested & review tags - drop EXPORT SYMBOL of ufshcd_map_desc_id_to_length in patch 2 - Link to v1: https://lore.kernel.org/r/20241120-topic-ufs-cleanup-v1-0-a5cef54b1cdc@linar...
--- Neil Armstrong (6): ufs: core: include missing include/ufs.h ufs: core: mark unexported functions as static ufs: core: cosmetic fixups ufs: core: move ufshci defines in a separate header ufs: core: sync unipro.h with Linux v6.12 ufs: core: sync ufshci.h with Linux v6.12
drivers/ufs/ufs.c | 44 +++-- drivers/ufs/ufs.h | 335 +----------------------------------- drivers/ufs/ufshci.h | 469 +++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/ufs/unipro.h | 128 ++++++++------ 4 files changed, 571 insertions(+), 405 deletions(-) --- base-commit: d580a013cca67a8115fb88d260498bde181709a1 change-id: 20241120-topic-ufs-cleanup-23671e3fc9e9
Add missing ufs.h causing build warning on some symbols.
Tested-by: Love Kumar love.kumar@amd.com Reviewed-by: Neha Malcom Francis n-francis@ti.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufs.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index f7d8c40c448c6865b7c04e03bab6f3f93a44a591..31c2959aeb12931b2bbdf26b3c676ae1a7b0fd1a 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -19,6 +19,7 @@ #include <malloc.h> #include <hexdump.h> #include <scsi.h> +#include <ufs.h> #include <asm/io.h> #include <asm/dma-mapping.h> #include <linux/bitops.h>
Mark the remaining local functions as static to avoid build warnings.
Also drop the EXPORT_SYMBOL of ufshcd_map_desc_id_to_length.
Tested-by: Love Kumar love.kumar@amd.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufs.c | 27 +++++++++++++-------------- 1 file changed, 13 insertions(+), 14 deletions(-)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 31c2959aeb12931b2bbdf26b3c676ae1a7b0fd1a..654f8b6799ec6735f2db4f6e1c81ee94ec14a74e 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -1035,8 +1035,8 @@ static inline void ufshcd_init_query(struct ufs_hba *hba, /** * ufshcd_query_flag() - API function for sending flag query requests */ -int ufshcd_query_flag(struct ufs_hba *hba, enum query_opcode opcode, - enum flag_idn idn, bool *flag_res) +static int ufshcd_query_flag(struct ufs_hba *hba, enum query_opcode opcode, + enum flag_idn idn, bool *flag_res) { struct ufs_query_req *request = NULL; struct ufs_query_res *response = NULL; @@ -1171,9 +1171,9 @@ out: /** * ufshcd_query_descriptor_retry - API function for sending descriptor requests */ -int ufshcd_query_descriptor_retry(struct ufs_hba *hba, enum query_opcode opcode, - enum desc_idn idn, u8 index, u8 selector, - u8 *desc_buf, int *buf_len) +static int ufshcd_query_descriptor_retry(struct ufs_hba *hba, enum query_opcode opcode, + enum desc_idn idn, u8 index, u8 selector, + u8 *desc_buf, int *buf_len) { int err; int retries; @@ -1265,8 +1265,8 @@ static void ufshcd_init_desc_sizes(struct ufs_hba *hba) * ufshcd_map_desc_id_to_length - map descriptor IDN to its length * */ -int ufshcd_map_desc_id_to_length(struct ufs_hba *hba, enum desc_idn desc_id, - int *desc_len) +static int ufshcd_map_desc_id_to_length(struct ufs_hba *hba, enum desc_idn desc_id, + int *desc_len) { switch (desc_id) { case QUERY_DESC_IDN_DEVICE: @@ -1303,15 +1303,14 @@ int ufshcd_map_desc_id_to_length(struct ufs_hba *hba, enum desc_idn desc_id, } return 0; } -EXPORT_SYMBOL(ufshcd_map_desc_id_to_length);
/** * ufshcd_read_desc_param - read the specified descriptor parameter * */ -int ufshcd_read_desc_param(struct ufs_hba *hba, enum desc_idn desc_id, - int desc_index, u8 param_offset, u8 *param_read_buf, - u8 param_size) +static int ufshcd_read_desc_param(struct ufs_hba *hba, enum desc_idn desc_id, + int desc_index, u8 param_offset, + u8 *param_read_buf, u8 param_size) { int ret; u8 *desc_buf; @@ -1570,8 +1569,8 @@ static int ufshcd_read_device_desc(struct ufs_hba *hba, u8 *buf, u32 size) * ufshcd_read_string_desc - read string descriptor * */ -int ufshcd_read_string_desc(struct ufs_hba *hba, int desc_index, - u8 *buf, u32 size, bool ascii) +static int ufshcd_read_string_desc(struct ufs_hba *hba, int desc_index, + u8 *buf, u32 size, bool ascii) { int err = 0;
@@ -1882,7 +1881,7 @@ static void ufshcd_def_desc_sizes(struct ufs_hba *hba) hba->desc_size.hlth_desc = QUERY_DESC_HEALTH_DEF_SIZE; }
-int ufs_start(struct ufs_hba *hba) +static int ufs_start(struct ufs_hba *hba) { struct ufs_dev_desc card = {0}; int ret;
Fixes some alignment warnings, missing comments on write barrier, missing parenthesis around macro parameters and a comment typo.
No functional changes intended.
Reviewed-by: Neha Malcom Francis n-francis@ti.com Tested-by: Love Kumar love.kumar@amd.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufs.c | 16 ++++++---------- drivers/ufs/ufs.h | 6 +++--- drivers/ufs/unipro.h | 4 ++-- 3 files changed, 11 insertions(+), 15 deletions(-)
diff --git a/drivers/ufs/ufs.c b/drivers/ufs/ufs.c index 654f8b6799ec6735f2db4f6e1c81ee94ec14a74e..91f6ad3bfef9846aab39331efd9493b1a98432d3 100644 --- a/drivers/ufs/ufs.c +++ b/drivers/ufs/ufs.c @@ -314,16 +314,12 @@ static int ufshcd_disable_tx_lcc(struct ufs_hba *hba, bool peer) ufshcd_dme_peer_get(hba, UIC_ARG_MIB(PA_CONNECTEDTXDATALANES), &tx_lanes); for (i = 0; i < tx_lanes; i++) { + unsigned int val = UIC_ARG_MIB_SEL(TX_LCC_ENABLE, + UIC_ARG_MPHY_TX_GEN_SEL_INDEX(i)); if (!peer) - err = ufshcd_dme_set(hba, - UIC_ARG_MIB_SEL(TX_LCC_ENABLE, - UIC_ARG_MPHY_TX_GEN_SEL_INDEX(i)), - 0); + err = ufshcd_dme_set(hba, val, 0); else - err = ufshcd_dme_peer_set(hba, - UIC_ARG_MIB_SEL(TX_LCC_ENABLE, - UIC_ARG_MPHY_TX_GEN_SEL_INDEX(i)), - 0); + err = ufshcd_dme_peer_set(hba, val, 0); if (err) { dev_err(hba->dev, "%s: TX LCC Disable failed, peer = %d, lane = %d, err = %d\n", __func__, peer, i, err); @@ -1962,7 +1958,7 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops)
ufshcd_ops_init(hba);
- /* Read capabilties registers */ + /* Read capabilities registers */ hba->capabilities = ufshcd_readl(hba, REG_CONTROLLER_CAPABILITIES); if (hba->quirks & UFSHCD_QUIRK_BROKEN_64BIT_ADDRESS) hba->capabilities &= ~MASK_64_ADDRESSING_SUPPORT; @@ -2001,7 +1997,7 @@ int ufshcd_probe(struct udevice *ufs_dev, struct ufs_hba_ops *hba_ops) REG_INTERRUPT_STATUS); ufshcd_writel(hba, 0, REG_INTERRUPT_ENABLE);
- mb(); + mb(); /* flush previous writes */
/* Reset the attached device */ ufshcd_device_reset(hba); diff --git a/drivers/ufs/ufs.h b/drivers/ufs/ufs.h index 00ecca350c350cc930d9056aba8ada0475a280dd..f4f042005e7fc2638ea6b33f26839c668d22bc9e 100644 --- a/drivers/ufs/ufs.h +++ b/drivers/ufs/ufs.h @@ -130,8 +130,8 @@ enum { (sizeof(struct utp_upiu_header))) #define RESPONSE_UPIU_SENSE_DATA_LENGTH 18 #define UPIU_HEADER_DWORD(byte3, byte2, byte1, byte0)\ - cpu_to_be32((byte3 << 24) | (byte2 << 16) |\ - (byte1 << 8) | (byte0)) + cpu_to_be32(((byte3) << 24) | ((byte2) << 16) |\ + ((byte1) << 8) | (byte0)) /* * UFS Protocol Information Unit related definitions */ @@ -915,7 +915,7 @@ static inline int ufshcd_ops_get_max_pwr_mode(struct ufs_hba *hba, }
static inline int ufshcd_ops_hce_enable_notify(struct ufs_hba *hba, - bool status) + bool status) { if (hba->ops && hba->ops->hce_enable_notify) return hba->ops->hce_enable_notify(hba, status); diff --git a/drivers/ufs/unipro.h b/drivers/ufs/unipro.h index 6df953e6e6073748ac640faea00aa6ac2a8c8663..0aa35ef31dfd263739c0b5c75c26f9191f38e8ec 100644 --- a/drivers/ufs/unipro.h +++ b/drivers/ufs/unipro.h @@ -59,7 +59,7 @@ #define RXSQCTRL 0x00B5 #define CFGRXOVR6 0x00BF
-#define is_mphy_tx_attr(attr) (attr < RX_MODE) +#define is_mphy_tx_attr(attr) ((attr) < RX_MODE) #define RX_MIN_ACTIVATETIME_UNIT_US 100 #define HIBERN8TIME_UNIT_US 100
@@ -77,7 +77,7 @@ #define CBPRGPLL2 UNIPRO_CB_OFFSET(0x00F8) #define CBPRGTUNING UNIPRO_CB_OFFSET(0x00FB)
-#define UNIPRO_CB_OFFSET(x) (0x8000 | x) +#define UNIPRO_CB_OFFSET(x) (0x8000 | (x))
/* * PHY Adpater attributes
Splitting the header will help synchronizing the defines again with Linux.
Acked-by: Neha Malcom Francis n-francis@ti.com Tested-by: Love Kumar love.kumar@amd.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufs.h | 329 +------------------------------------------------- drivers/ufs/ufshci.h | 334 +++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 335 insertions(+), 328 deletions(-)
diff --git a/drivers/ufs/ufs.h b/drivers/ufs/ufs.h index f4f042005e7fc2638ea6b33f26839c668d22bc9e..53137fae3a81ce87d744dd56c49db2a8ffba1d3d 100644 --- a/drivers/ufs/ufs.h +++ b/drivers/ufs/ufs.h @@ -4,6 +4,7 @@
#include <linux/types.h> #include <asm/io.h> +#include "ufshci.h" #include "unipro.h"
struct udevice; @@ -14,11 +15,6 @@ struct udevice; #define RESPONSE_UPIU_SENSE_DATA_LENGTH 18 #define UFS_MAX_LUNS 0x7F
-enum { - TASK_REQ_UPIU_SIZE_DWORDS = 8, - TASK_RSP_UPIU_SIZE_DWORDS = 8, - ALIGNED_UPIU_SIZE = 512, -};
/* UFS device power modes */ enum ufs_dev_pwr_mode { @@ -84,44 +80,6 @@ enum { /* Offset of the response code in the UPIU header */ #define UPIU_RSP_CODE_OFFSET 8
-/* To accommodate UFS2.0 required Command type */ -enum { - UTP_CMD_TYPE_UFS_STORAGE = 0x1, -}; - -enum { - UTP_SCSI_COMMAND = 0x00000000, - UTP_NATIVE_UFS_COMMAND = 0x10000000, - UTP_DEVICE_MANAGEMENT_FUNCTION = 0x20000000, - UTP_REQ_DESC_INT_CMD = 0x01000000, -}; - -/* UTP Transfer Request Data Direction (DD) */ -enum { - UTP_NO_DATA_TRANSFER = 0x00000000, - UTP_HOST_TO_DEVICE = 0x02000000, - UTP_DEVICE_TO_HOST = 0x04000000, -}; - -/* Overall command status values */ -enum { - OCS_SUCCESS = 0x0, - OCS_INVALID_CMD_TABLE_ATTR = 0x1, - OCS_INVALID_PRDT_ATTR = 0x2, - OCS_MISMATCH_DATA_BUF_SIZE = 0x3, - OCS_MISMATCH_RESP_UPIU_SIZE = 0x4, - OCS_PEER_COMM_FAILURE = 0x5, - OCS_ABORTED = 0x6, - OCS_FATAL_ERROR = 0x7, - OCS_INVALID_COMMAND_STATUS = 0x0F, - MASK_OCS = 0x0F, -}; - -/* The maximum length of the data byte count field in the PRDT is 256KB */ -#define PRDT_DATA_BYTE_COUNT_MAX (256 * 1024) -/* The granularity of the data byte count field in the PRDT is 32-bit */ -#define PRDT_DATA_BYTE_COUNT_PAD 4 - #define GENERAL_UPIU_REQUEST_SIZE (sizeof(struct utp_upiu_req)) #define QUERY_DESC_MAX_SIZE 255 #define QUERY_DESC_MIN_SIZE 2 @@ -297,79 +255,6 @@ enum desc_header_offset { QUERY_DESC_DESC_TYPE_OFFSET = 0x01, };
-struct ufshcd_sg_entry { - __le32 base_addr; - __le32 upper_addr; - __le32 reserved; - __le32 size; -}; - -#define MAX_BUFF 128 -/** - * struct utp_transfer_cmd_desc - UFS Command Descriptor structure - * @command_upiu: Command UPIU Frame address - * @response_upiu: Response UPIU Frame address - * @prd_table: Physical Region Descriptor - */ -struct utp_transfer_cmd_desc { - u8 command_upiu[ALIGNED_UPIU_SIZE]; - u8 response_upiu[ALIGNED_UPIU_SIZE]; - struct ufshcd_sg_entry prd_table[MAX_BUFF]; -}; - -/** - * struct request_desc_header - Descriptor Header common to both UTRD and UTMRD - * @dword0: Descriptor Header DW0 - * @dword1: Descriptor Header DW1 - * @dword2: Descriptor Header DW2 - * @dword3: Descriptor Header DW3 - */ -struct request_desc_header { - __le32 dword_0; - __le32 dword_1; - __le32 dword_2; - __le32 dword_3; -}; - -/** - * struct utp_transfer_req_desc - UTRD structure - * @header: UTRD header DW-0 to DW-3 - * @command_desc_base_addr_lo: UCD base address low DW-4 - * @command_desc_base_addr_hi: UCD base address high DW-5 - * @response_upiu_length: response UPIU length DW-6 - * @response_upiu_offset: response UPIU offset DW-6 - * @prd_table_length: Physical region descriptor length DW-7 - * @prd_table_offset: Physical region descriptor offset DW-7 - */ -struct utp_transfer_req_desc { - /* DW 0-3 */ - struct request_desc_header header; - - /* DW 4-5*/ - __le32 command_desc_base_addr_lo; - __le32 command_desc_base_addr_hi; - - /* DW 6 */ - __le16 response_upiu_length; - __le16 response_upiu_offset; - - /* DW 7 */ - __le16 prd_table_length; - __le16 prd_table_offset; -}; - -/** - * struct utp_upiu_header - UPIU header structure - * @dword_0: UPIU header DW-0 - * @dword_1: UPIU header DW-1 - * @dword_2: UPIU header DW-2 - */ -struct utp_upiu_header { - __be32 dword_0; - __be32 dword_1; - __be32 dword_2; -}; - /** * struct utp_upiu_query - upiu request buffer structure for * query request. @@ -403,27 +288,6 @@ struct utp_upiu_cmd { u8 cdb[UFS_CDB_SIZE]; };
-/* - * UTMRD structure. - */ -struct utp_task_req_desc { - /* DW 0-3 */ - struct request_desc_header header; - - /* DW 4-11 - Task request UPIU structure */ - struct utp_upiu_header req_header; - __be32 input_param1; - __be32 input_param2; - __be32 input_param3; - __be32 __reserved1[2]; - - /* DW 12-19 - Task Management Response UPIU structure */ - struct utp_upiu_header rsp_header; - __be32 output_param1; - __be32 output_param2; - __be32 __reserved2[3]; -}; - /** * struct utp_upiu_req - general upiu request structure * @header:UPIU header structure DW-0 to DW-2 @@ -551,63 +415,6 @@ struct uic_command { int result; };
-/* GenSelectorIndex calculation macros for M-PHY attributes */ -#define UIC_ARG_MPHY_TX_GEN_SEL_INDEX(lane) (lane) -#define UIC_ARG_MPHY_RX_GEN_SEL_INDEX(lane) (PA_MAXDATALANES + (lane)) - -#define UIC_ARG_MIB_SEL(attr, sel) ((((attr) & 0xFFFF) << 16) |\ - ((sel) & 0xFFFF)) -#define UIC_ARG_MIB(attr) UIC_ARG_MIB_SEL(attr, 0) -#define UIC_ARG_ATTR_TYPE(t) (((t) & 0xFF) << 16) -#define UIC_GET_ATTR_ID(v) (((v) >> 16) & 0xFFFF) - -/* Link Status*/ -enum link_status { - UFSHCD_LINK_IS_DOWN = 1, - UFSHCD_LINK_IS_UP = 2, -}; - -#define UIC_ARG_MIB_SEL(attr, sel) ((((attr) & 0xFFFF) << 16) |\ - ((sel) & 0xFFFF)) -#define UIC_ARG_MIB(attr) UIC_ARG_MIB_SEL(attr, 0) -#define UIC_ARG_ATTR_TYPE(t) (((t) & 0xFF) << 16) -#define UIC_GET_ATTR_ID(v) (((v) >> 16) & 0xFFFF) - -/* UIC Commands */ -enum uic_cmd_dme { - UIC_CMD_DME_GET = 0x01, - UIC_CMD_DME_SET = 0x02, - UIC_CMD_DME_PEER_GET = 0x03, - UIC_CMD_DME_PEER_SET = 0x04, - UIC_CMD_DME_POWERON = 0x10, - UIC_CMD_DME_POWEROFF = 0x11, - UIC_CMD_DME_ENABLE = 0x12, - UIC_CMD_DME_RESET = 0x14, - UIC_CMD_DME_END_PT_RST = 0x15, - UIC_CMD_DME_LINK_STARTUP = 0x16, - UIC_CMD_DME_HIBER_ENTER = 0x17, - UIC_CMD_DME_HIBER_EXIT = 0x18, - UIC_CMD_DME_TEST_MODE = 0x1A, -}; - -/* UIC Config result code / Generic error code */ -enum { - UIC_CMD_RESULT_SUCCESS = 0x00, - UIC_CMD_RESULT_INVALID_ATTR = 0x01, - UIC_CMD_RESULT_FAILURE = 0x01, - UIC_CMD_RESULT_INVALID_ATTR_VALUE = 0x02, - UIC_CMD_RESULT_READ_ONLY_ATTR = 0x03, - UIC_CMD_RESULT_WRITE_ONLY_ATTR = 0x04, - UIC_CMD_RESULT_BAD_INDEX = 0x05, - UIC_CMD_RESULT_LOCKED_ATTR = 0x06, - UIC_CMD_RESULT_BAD_TEST_FEATURE_INDEX = 0x07, - UIC_CMD_RESULT_PEER_COMM_FAILURE = 0x08, - UIC_CMD_RESULT_BUSY = 0x09, - UIC_CMD_RESULT_DME_FAILURE = 0x0A, -}; - -#define MASK_UIC_COMMAND_RESULT 0xFF - /* Host <-> Device UniPro Link state */ enum uic_link_state { UIC_LINK_OFF_STATE = 0, /* Link powered down or disabled */ @@ -940,17 +747,6 @@ static inline int ufshcd_vops_device_reset(struct ufs_hba *hba) return 0; }
-/* Controller UFSHCI version */ -enum { - UFSHCI_VERSION_10 = 0x00010000, /* 1.0 */ - UFSHCI_VERSION_11 = 0x00010100, /* 1.1 */ - UFSHCI_VERSION_20 = 0x00000200, /* 2.0 */ - UFSHCI_VERSION_21 = 0x00000210, /* 2.1 */ - UFSHCI_VERSION_30 = 0x00000300, /* 3.0 */ - UFSHCI_VERSION_31 = 0x00000310, /* 3.1 */ - UFSHCI_VERSION_40 = 0x00000400, /* 4.0 */ -}; - /* Interrupt disable masks */ enum { /* Interrupt disable mask for UFSHCI v1.0 */ @@ -964,123 +760,6 @@ enum { INTERRUPT_MASK_ALL_VER_21 = 0x71FFF, };
-/* UFSHCI Registers */ -enum { - REG_CONTROLLER_CAPABILITIES = 0x00, - REG_UFS_VERSION = 0x08, - REG_CONTROLLER_DEV_ID = 0x10, - REG_CONTROLLER_PROD_ID = 0x14, - REG_AUTO_HIBERNATE_IDLE_TIMER = 0x18, - REG_INTERRUPT_STATUS = 0x20, - REG_INTERRUPT_ENABLE = 0x24, - REG_CONTROLLER_STATUS = 0x30, - REG_CONTROLLER_ENABLE = 0x34, - REG_UIC_ERROR_CODE_PHY_ADAPTER_LAYER = 0x38, - REG_UIC_ERROR_CODE_DATA_LINK_LAYER = 0x3C, - REG_UIC_ERROR_CODE_NETWORK_LAYER = 0x40, - REG_UIC_ERROR_CODE_TRANSPORT_LAYER = 0x44, - REG_UIC_ERROR_CODE_DME = 0x48, - REG_UTP_TRANSFER_REQ_INT_AGG_CONTROL = 0x4C, - REG_UTP_TRANSFER_REQ_LIST_BASE_L = 0x50, - REG_UTP_TRANSFER_REQ_LIST_BASE_H = 0x54, - REG_UTP_TRANSFER_REQ_DOOR_BELL = 0x58, - REG_UTP_TRANSFER_REQ_LIST_CLEAR = 0x5C, - REG_UTP_TRANSFER_REQ_LIST_RUN_STOP = 0x60, - REG_UTP_TASK_REQ_LIST_BASE_L = 0x70, - REG_UTP_TASK_REQ_LIST_BASE_H = 0x74, - REG_UTP_TASK_REQ_DOOR_BELL = 0x78, - REG_UTP_TASK_REQ_LIST_CLEAR = 0x7C, - REG_UTP_TASK_REQ_LIST_RUN_STOP = 0x80, - REG_UIC_COMMAND = 0x90, - REG_UIC_COMMAND_ARG_1 = 0x94, - REG_UIC_COMMAND_ARG_2 = 0x98, - REG_UIC_COMMAND_ARG_3 = 0x9C, - - UFSHCI_REG_SPACE_SIZE = 0xA0, - - REG_UFS_CCAP = 0x100, - REG_UFS_CRYPTOCAP = 0x104, - - UFSHCI_CRYPTO_REG_SPACE_SIZE = 0x400, -}; - -/* Controller capability masks */ -enum { - MASK_TRANSFER_REQUESTS_SLOTS = 0x0000001F, - MASK_TASK_MANAGEMENT_REQUEST_SLOTS = 0x00070000, - MASK_AUTO_HIBERN8_SUPPORT = 0x00800000, - MASK_64_ADDRESSING_SUPPORT = 0x01000000, - MASK_OUT_OF_ORDER_DATA_DELIVERY_SUPPORT = 0x02000000, - MASK_UIC_DME_TEST_MODE_SUPPORT = 0x04000000, -}; - -/* Interrupt Status 20h */ -#define UTP_TRANSFER_REQ_COMPL 0x1 -#define UIC_DME_END_PT_RESET 0x2 -#define UIC_ERROR 0x4 -#define UIC_TEST_MODE 0x8 -#define UIC_POWER_MODE 0x10 -#define UIC_HIBERNATE_EXIT 0x20 -#define UIC_HIBERNATE_ENTER 0x40 -#define UIC_LINK_LOST 0x80 -#define UIC_LINK_STARTUP 0x100 -#define UTP_TASK_REQ_COMPL 0x200 -#define UIC_COMMAND_COMPL 0x400 -#define DEVICE_FATAL_ERROR 0x800 -#define CONTROLLER_FATAL_ERROR 0x10000 -#define SYSTEM_BUS_FATAL_ERROR 0x20000 - -#define UFSHCD_UIC_PWR_MASK (UIC_HIBERNATE_ENTER |\ - UIC_HIBERNATE_EXIT |\ - UIC_POWER_MODE) - -#define UFSHCD_UIC_MASK (UIC_COMMAND_COMPL | UIC_POWER_MODE) - -#define UFSHCD_ERROR_MASK (UIC_ERROR |\ - DEVICE_FATAL_ERROR |\ - CONTROLLER_FATAL_ERROR |\ - SYSTEM_BUS_FATAL_ERROR) - -#define INT_FATAL_ERRORS (DEVICE_FATAL_ERROR |\ - CONTROLLER_FATAL_ERROR |\ - SYSTEM_BUS_FATAL_ERROR) - -/* Host Controller Enable 0x34h */ -#define CONTROLLER_ENABLE 0x1 -#define CONTROLLER_DISABLE 0x0 -/* HCS - Host Controller Status 30h */ -#define DEVICE_PRESENT 0x1 -#define UTP_TRANSFER_REQ_LIST_READY 0x2 -#define UTP_TASK_REQ_LIST_READY 0x4 -#define UIC_COMMAND_READY 0x8 -#define HOST_ERROR_INDICATOR 0x10 -#define DEVICE_ERROR_INDICATOR 0x20 -#define UIC_POWER_MODE_CHANGE_REQ_STATUS_MASK UFS_MASK(0x7, 8) - -#define UFSHCD_STATUS_READY (UTP_TRANSFER_REQ_LIST_READY |\ - UTP_TASK_REQ_LIST_READY |\ - UIC_COMMAND_READY) - -enum { - PWR_OK = 0x0, - PWR_LOCAL = 0x01, - PWR_REMOTE = 0x02, - PWR_BUSY = 0x03, - PWR_ERROR_CAP = 0x04, - PWR_FATAL_ERROR = 0x05, -}; - -/* UICCMD - UIC Command */ -#define COMMAND_OPCODE_MASK 0xFF -#define GEN_SELECTOR_INDEX_MASK 0xFFFF - -#define MIB_ATTRIBUTE_MASK UFS_MASK(0xFFFF, 16) -#define RESET_LEVEL 0xFF - -#define ATTR_SET_TYPE_MASK UFS_MASK(0xFF, 16) -#define CFG_RESULT_CODE_MASK 0xFF -#define GENERIC_ERROR_CODE_MASK 0xFF - #define ufshcd_writel(hba, val, reg) \ writel((val), (hba)->mmio_base + (reg)) #define ufshcd_readl(hba, reg) \ @@ -1103,12 +782,6 @@ static inline void ufshcd_rmwl(struct ufs_hba *hba, u32 mask, u32 val, u32 reg) ufshcd_writel(hba, tmp, reg); }
-/* UTRLRSR - UTP Transfer Request Run-Stop Register 60h */ -#define UTP_TRANSFER_REQ_LIST_RUN_STOP_BIT 0x1 - -/* UTMRLRSR - UTP Task Management Request Run-Stop Register 80h */ -#define UTP_TASK_REQ_LIST_RUN_STOP_BIT 0x1 - int ufshcd_probe(struct udevice *dev, struct ufs_hba_ops *hba_ops);
#endif diff --git a/drivers/ufs/ufshci.h b/drivers/ufs/ufshci.h new file mode 100644 index 0000000000000000000000000000000000000000..db30812b176f9e36529452e260b847241f97fdab --- /dev/null +++ b/drivers/ufs/ufshci.h @@ -0,0 +1,334 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +#ifndef __UFSHCI_H +#define __UFSHCI_H + +enum { + TASK_REQ_UPIU_SIZE_DWORDS = 8, + TASK_RSP_UPIU_SIZE_DWORDS = 8, + ALIGNED_UPIU_SIZE = 512, +}; + +/* To accommodate UFS2.0 required Command type */ +enum { + UTP_CMD_TYPE_UFS_STORAGE = 0x1, +}; + +enum { + UTP_SCSI_COMMAND = 0x00000000, + UTP_NATIVE_UFS_COMMAND = 0x10000000, + UTP_DEVICE_MANAGEMENT_FUNCTION = 0x20000000, + UTP_REQ_DESC_INT_CMD = 0x01000000, +}; + +/* UTP Transfer Request Data Direction (DD) */ +enum { + UTP_NO_DATA_TRANSFER = 0x00000000, + UTP_HOST_TO_DEVICE = 0x02000000, + UTP_DEVICE_TO_HOST = 0x04000000, +}; + +/* Overall command status values */ +enum { + OCS_SUCCESS = 0x0, + OCS_INVALID_CMD_TABLE_ATTR = 0x1, + OCS_INVALID_PRDT_ATTR = 0x2, + OCS_MISMATCH_DATA_BUF_SIZE = 0x3, + OCS_MISMATCH_RESP_UPIU_SIZE = 0x4, + OCS_PEER_COMM_FAILURE = 0x5, + OCS_ABORTED = 0x6, + OCS_FATAL_ERROR = 0x7, + OCS_INVALID_COMMAND_STATUS = 0x0F, + MASK_OCS = 0x0F, +}; + +/* The maximum length of the data byte count field in the PRDT is 256KB */ +#define PRDT_DATA_BYTE_COUNT_MAX (256 * 1024) +/* The granularity of the data byte count field in the PRDT is 32-bit */ +#define PRDT_DATA_BYTE_COUNT_PAD 4 + +/* Controller UFSHCI version */ +enum { + UFSHCI_VERSION_10 = 0x00010000, /* 1.0 */ + UFSHCI_VERSION_11 = 0x00010100, /* 1.1 */ + UFSHCI_VERSION_20 = 0x00000200, /* 2.0 */ + UFSHCI_VERSION_21 = 0x00000210, /* 2.1 */ + UFSHCI_VERSION_30 = 0x00000300, /* 3.0 */ + UFSHCI_VERSION_31 = 0x00000310, /* 3.1 */ + UFSHCI_VERSION_40 = 0x00000400, /* 4.0 */ +}; + +/* UFSHCI Registers */ +enum { + REG_CONTROLLER_CAPABILITIES = 0x00, + REG_UFS_VERSION = 0x08, + REG_CONTROLLER_DEV_ID = 0x10, + REG_CONTROLLER_PROD_ID = 0x14, + REG_AUTO_HIBERNATE_IDLE_TIMER = 0x18, + REG_INTERRUPT_STATUS = 0x20, + REG_INTERRUPT_ENABLE = 0x24, + REG_CONTROLLER_STATUS = 0x30, + REG_CONTROLLER_ENABLE = 0x34, + REG_UIC_ERROR_CODE_PHY_ADAPTER_LAYER = 0x38, + REG_UIC_ERROR_CODE_DATA_LINK_LAYER = 0x3C, + REG_UIC_ERROR_CODE_NETWORK_LAYER = 0x40, + REG_UIC_ERROR_CODE_TRANSPORT_LAYER = 0x44, + REG_UIC_ERROR_CODE_DME = 0x48, + REG_UTP_TRANSFER_REQ_INT_AGG_CONTROL = 0x4C, + REG_UTP_TRANSFER_REQ_LIST_BASE_L = 0x50, + REG_UTP_TRANSFER_REQ_LIST_BASE_H = 0x54, + REG_UTP_TRANSFER_REQ_DOOR_BELL = 0x58, + REG_UTP_TRANSFER_REQ_LIST_CLEAR = 0x5C, + REG_UTP_TRANSFER_REQ_LIST_RUN_STOP = 0x60, + REG_UTP_TASK_REQ_LIST_BASE_L = 0x70, + REG_UTP_TASK_REQ_LIST_BASE_H = 0x74, + REG_UTP_TASK_REQ_DOOR_BELL = 0x78, + REG_UTP_TASK_REQ_LIST_CLEAR = 0x7C, + REG_UTP_TASK_REQ_LIST_RUN_STOP = 0x80, + REG_UIC_COMMAND = 0x90, + REG_UIC_COMMAND_ARG_1 = 0x94, + REG_UIC_COMMAND_ARG_2 = 0x98, + REG_UIC_COMMAND_ARG_3 = 0x9C, + + UFSHCI_REG_SPACE_SIZE = 0xA0, + + REG_UFS_CCAP = 0x100, + REG_UFS_CRYPTOCAP = 0x104, + + UFSHCI_CRYPTO_REG_SPACE_SIZE = 0x400, +}; + +/* Controller capability masks */ +enum { + MASK_TRANSFER_REQUESTS_SLOTS = 0x0000001F, + MASK_TASK_MANAGEMENT_REQUEST_SLOTS = 0x00070000, + MASK_AUTO_HIBERN8_SUPPORT = 0x00800000, + MASK_64_ADDRESSING_SUPPORT = 0x01000000, + MASK_OUT_OF_ORDER_DATA_DELIVERY_SUPPORT = 0x02000000, + MASK_UIC_DME_TEST_MODE_SUPPORT = 0x04000000, +}; + +/* Interrupt Status 20h */ +#define UTP_TRANSFER_REQ_COMPL 0x1 +#define UIC_DME_END_PT_RESET 0x2 +#define UIC_ERROR 0x4 +#define UIC_TEST_MODE 0x8 +#define UIC_POWER_MODE 0x10 +#define UIC_HIBERNATE_EXIT 0x20 +#define UIC_HIBERNATE_ENTER 0x40 +#define UIC_LINK_LOST 0x80 +#define UIC_LINK_STARTUP 0x100 +#define UTP_TASK_REQ_COMPL 0x200 +#define UIC_COMMAND_COMPL 0x400 +#define DEVICE_FATAL_ERROR 0x800 +#define CONTROLLER_FATAL_ERROR 0x10000 +#define SYSTEM_BUS_FATAL_ERROR 0x20000 + +#define UFSHCD_UIC_PWR_MASK (UIC_HIBERNATE_ENTER |\ + UIC_HIBERNATE_EXIT |\ + UIC_POWER_MODE) + +#define UFSHCD_UIC_MASK (UIC_COMMAND_COMPL | UIC_POWER_MODE) + +#define UFSHCD_ERROR_MASK (UIC_ERROR |\ + DEVICE_FATAL_ERROR |\ + CONTROLLER_FATAL_ERROR |\ + SYSTEM_BUS_FATAL_ERROR) + +#define INT_FATAL_ERRORS (DEVICE_FATAL_ERROR |\ + CONTROLLER_FATAL_ERROR |\ + SYSTEM_BUS_FATAL_ERROR) + +/* Host Controller Enable 0x34h */ +#define CONTROLLER_ENABLE 0x1 +#define CONTROLLER_DISABLE 0x0 +/* HCS - Host Controller Status 30h */ +#define DEVICE_PRESENT 0x1 +#define UTP_TRANSFER_REQ_LIST_READY 0x2 +#define UTP_TASK_REQ_LIST_READY 0x4 +#define UIC_COMMAND_READY 0x8 +#define HOST_ERROR_INDICATOR 0x10 +#define DEVICE_ERROR_INDICATOR 0x20 +#define UIC_POWER_MODE_CHANGE_REQ_STATUS_MASK UFS_MASK(0x7, 8) + +#define UFSHCD_STATUS_READY (UTP_TRANSFER_REQ_LIST_READY |\ + UTP_TASK_REQ_LIST_READY |\ + UIC_COMMAND_READY) + +enum { + PWR_OK = 0x0, + PWR_LOCAL = 0x01, + PWR_REMOTE = 0x02, + PWR_BUSY = 0x03, + PWR_ERROR_CAP = 0x04, + PWR_FATAL_ERROR = 0x05, +}; + +/* UICCMD - UIC Command */ +#define COMMAND_OPCODE_MASK 0xFF +#define GEN_SELECTOR_INDEX_MASK 0xFFFF + +#define MIB_ATTRIBUTE_MASK UFS_MASK(0xFFFF, 16) +#define RESET_LEVEL 0xFF + +#define ATTR_SET_TYPE_MASK UFS_MASK(0xFF, 16) +#define CFG_RESULT_CODE_MASK 0xFF +#define GENERIC_ERROR_CODE_MASK 0xFF + +/* GenSelectorIndex calculation macros for M-PHY attributes */ +#define UIC_ARG_MPHY_TX_GEN_SEL_INDEX(lane) (lane) +#define UIC_ARG_MPHY_RX_GEN_SEL_INDEX(lane) (PA_MAXDATALANES + (lane)) + +#define UIC_ARG_MIB_SEL(attr, sel) ((((attr) & 0xFFFF) << 16) |\ + ((sel) & 0xFFFF)) +#define UIC_ARG_MIB(attr) UIC_ARG_MIB_SEL(attr, 0) +#define UIC_ARG_ATTR_TYPE(t) (((t) & 0xFF) << 16) +#define UIC_GET_ATTR_ID(v) (((v) >> 16) & 0xFFFF) + +/* Link Status*/ +enum link_status { + UFSHCD_LINK_IS_DOWN = 1, + UFSHCD_LINK_IS_UP = 2, +}; + +#define UIC_ARG_MIB_SEL(attr, sel) ((((attr) & 0xFFFF) << 16) |\ + ((sel) & 0xFFFF)) +#define UIC_ARG_MIB(attr) UIC_ARG_MIB_SEL(attr, 0) +#define UIC_ARG_ATTR_TYPE(t) (((t) & 0xFF) << 16) +#define UIC_GET_ATTR_ID(v) (((v) >> 16) & 0xFFFF) + +/* UIC Commands */ +enum uic_cmd_dme { + UIC_CMD_DME_GET = 0x01, + UIC_CMD_DME_SET = 0x02, + UIC_CMD_DME_PEER_GET = 0x03, + UIC_CMD_DME_PEER_SET = 0x04, + UIC_CMD_DME_POWERON = 0x10, + UIC_CMD_DME_POWEROFF = 0x11, + UIC_CMD_DME_ENABLE = 0x12, + UIC_CMD_DME_RESET = 0x14, + UIC_CMD_DME_END_PT_RST = 0x15, + UIC_CMD_DME_LINK_STARTUP = 0x16, + UIC_CMD_DME_HIBER_ENTER = 0x17, + UIC_CMD_DME_HIBER_EXIT = 0x18, + UIC_CMD_DME_TEST_MODE = 0x1A, +}; + +/* UIC Config result code / Generic error code */ +enum { + UIC_CMD_RESULT_SUCCESS = 0x00, + UIC_CMD_RESULT_INVALID_ATTR = 0x01, + UIC_CMD_RESULT_FAILURE = 0x01, + UIC_CMD_RESULT_INVALID_ATTR_VALUE = 0x02, + UIC_CMD_RESULT_READ_ONLY_ATTR = 0x03, + UIC_CMD_RESULT_WRITE_ONLY_ATTR = 0x04, + UIC_CMD_RESULT_BAD_INDEX = 0x05, + UIC_CMD_RESULT_LOCKED_ATTR = 0x06, + UIC_CMD_RESULT_BAD_TEST_FEATURE_INDEX = 0x07, + UIC_CMD_RESULT_PEER_COMM_FAILURE = 0x08, + UIC_CMD_RESULT_BUSY = 0x09, + UIC_CMD_RESULT_DME_FAILURE = 0x0A, +}; + +#define MASK_UIC_COMMAND_RESULT 0xFF + +/* UTRLRSR - UTP Transfer Request Run-Stop Register 60h */ +#define UTP_TRANSFER_REQ_LIST_RUN_STOP_BIT 0x1 + +/* UTMRLRSR - UTP Task Management Request Run-Stop Register 80h */ +#define UTP_TASK_REQ_LIST_RUN_STOP_BIT 0x1 + +struct ufshcd_sg_entry { + __le32 base_addr; + __le32 upper_addr; + __le32 reserved; + __le32 size; +}; + +#define MAX_BUFF 128 +/** + * struct utp_transfer_cmd_desc - UFS Command Descriptor structure + * @command_upiu: Command UPIU Frame address + * @response_upiu: Response UPIU Frame address + * @prd_table: Physical Region Descriptor + */ +struct utp_transfer_cmd_desc { + u8 command_upiu[ALIGNED_UPIU_SIZE]; + u8 response_upiu[ALIGNED_UPIU_SIZE]; + struct ufshcd_sg_entry prd_table[MAX_BUFF]; +}; + +/** + * struct request_desc_header - Descriptor Header common to both UTRD and UTMRD + * @dword0: Descriptor Header DW0 + * @dword1: Descriptor Header DW1 + * @dword2: Descriptor Header DW2 + * @dword3: Descriptor Header DW3 + */ +struct request_desc_header { + __le32 dword_0; + __le32 dword_1; + __le32 dword_2; + __le32 dword_3; +}; + +/** + * struct utp_transfer_req_desc - UTRD structure + * @header: UTRD header DW-0 to DW-3 + * @command_desc_base_addr_lo: UCD base address low DW-4 + * @command_desc_base_addr_hi: UCD base address high DW-5 + * @response_upiu_length: response UPIU length DW-6 + * @response_upiu_offset: response UPIU offset DW-6 + * @prd_table_length: Physical region descriptor length DW-7 + * @prd_table_offset: Physical region descriptor offset DW-7 + */ +struct utp_transfer_req_desc { + /* DW 0-3 */ + struct request_desc_header header; + + /* DW 4-5*/ + __le32 command_desc_base_addr_lo; + __le32 command_desc_base_addr_hi; + + /* DW 6 */ + __le16 response_upiu_length; + __le16 response_upiu_offset; + + /* DW 7 */ + __le16 prd_table_length; + __le16 prd_table_offset; +}; + +/** + * struct utp_upiu_header - UPIU header structure + * @dword_0: UPIU header DW-0 + * @dword_1: UPIU header DW-1 + * @dword_2: UPIU header DW-2 + */ +struct utp_upiu_header { + __be32 dword_0; + __be32 dword_1; + __be32 dword_2; +}; + +/* + * UTMRD structure. + */ +struct utp_task_req_desc { + /* DW 0-3 */ + struct request_desc_header header; + + /* DW 4-11 - Task request UPIU structure */ + struct utp_upiu_header req_header; + __be32 input_param1; + __be32 input_param2; + __be32 input_param3; + __be32 __reserved1[2]; + + /* DW 12-19 - Task Management Response UPIU structure */ + struct utp_upiu_header rsp_header; + __be32 output_param1; + __be32 output_param2; + __be32 __reserved2[3]; +}; + +#endif
Sync unipro.h with the version found in the Linux v6.12 version commit adc218676eef ("Linux 6.12").
It adds new defines, and moves defines to the same place as the Linux header.
Acked-by: Neha Malcom Francis n-francis@ti.com Tested-by: Love Kumar love.kumar@amd.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/unipro.h | 124 +++++++++++++++++++++++++++++++-------------------- 1 file changed, 76 insertions(+), 48 deletions(-)
diff --git a/drivers/ufs/unipro.h b/drivers/ufs/unipro.h index 0aa35ef31dfd263739c0b5c75c26f9191f38e8ec..56833602b77abbfa4abff5f2b57461986fe815dc 100644 --- a/drivers/ufs/unipro.h +++ b/drivers/ufs/unipro.h @@ -34,6 +34,18 @@ /* * M-RX Configuration Attributes */ +#define RX_HS_G1_SYNC_LENGTH_CAP 0x008B +#define RX_HS_G1_PREP_LENGTH_CAP 0x008C +#define RX_MIN_ACTIVATETIME_CAPABILITY 0x008F +#define RX_HIBERN8TIME_CAPABILITY 0x0092 +#define RX_HS_G2_SYNC_LENGTH_CAP 0x0094 +#define RX_HS_G3_SYNC_LENGTH_CAP 0x0095 +#define RX_HS_G2_PREP_LENGTH_CAP 0x0096 +#define RX_HS_G3_PREP_LENGTH_CAP 0x0097 +#define RX_ADV_GRANULARITY_CAP 0x0098 +#define RX_HIBERN8TIME_CAP 0x0092 +#define RX_ADV_HIBERN8TIME_CAP 0x0099 +#define RX_ADV_MIN_ACTIVATETIME_CAP 0x009A #define RX_MODE 0x00A1 #define RX_HSRATE_SERIES 0x00A2 #define RX_HSGEAR 0x00A3 @@ -42,24 +54,27 @@ #define RX_HS_UNTERMINATED_ENABLE 0x00A6 #define RX_ENTER_HIBERN8 0x00A7 #define RX_BYPASS_8B10B_ENABLE 0x00A8 -#define RX_TERMINATION_FORCE_ENABLE 0x0089 -#define RX_MIN_ACTIVATETIME_CAPABILITY 0x008F -#define RX_HIBERN8TIME_CAPABILITY 0x0092 +#define RX_TERMINATION_FORCE_ENABLE 0x00A9 +#define RXCALCTRL 0x00B4 +#define RXSQCTRL 0x00B5 +#define CFGRXCDR8 0x00BA +#define CFGRXOVR8 0x00BD +#define CFGRXOVR6 0x00BF +#define RXDIRECTCTRL2 0x00C7 +#define CFGRXOVR4 0x00E9 #define RX_REFCLKFREQ 0x00EB #define RX_CFGCLKFREQVAL 0x00EC #define CFGWIDEINLN 0x00F0 -#define CFGRXCDR8 0x00BA #define ENARXDIRECTCFG4 0x00F2 -#define CFGRXOVR8 0x00BD -#define RXDIRECTCTRL2 0x00C7 #define ENARXDIRECTCFG3 0x00F3 -#define RXCALCTRL 0x00B4 #define ENARXDIRECTCFG2 0x00F4 -#define CFGRXOVR4 0x00E9 -#define RXSQCTRL 0x00B5 -#define CFGRXOVR6 0x00BF
#define is_mphy_tx_attr(attr) ((attr) < RX_MODE) +#define RX_ADV_FINE_GRAN_STEP(x) ((((x) & 0x3) << 1) | 0x1) +#define SYNC_LEN_FINE(x) ((x) & 0x3F) +#define SYNC_LEN_COARSE(x) ((1 << 6) | ((x) & 0x3F)) +#define PREP_LEN(x) ((x) & 0xF) + #define RX_MIN_ACTIVATETIME_UNIT_US 100 #define HIBERN8TIME_UNIT_US 100
@@ -80,48 +95,51 @@ #define UNIPRO_CB_OFFSET(x) (0x8000 | (x))
/* - * PHY Adpater attributes + * PHY Adapter attributes */ -#define PA_ACTIVETXDATALANES 0x1560 -#define PA_ACTIVERXDATALANES 0x1580 -#define PA_TXTRAILINGCLOCKS 0x1564 #define PA_PHY_TYPE 0x1500 #define PA_AVAILTXDATALANES 0x1520 -#define PA_AVAILRXDATALANES 0x1540 -#define PA_MINRXTRAILINGCLOCKS 0x1543 -#define PA_TXPWRSTATUS 0x1567 -#define PA_RXPWRSTATUS 0x1582 -#define PA_TXFORCECLOCK 0x1562 -#define PA_TXPWRMODE 0x1563 -#define PA_LEGACYDPHYESCDL 0x1570 #define PA_MAXTXSPEEDFAST 0x1521 #define PA_MAXTXSPEEDSLOW 0x1522 #define PA_MAXRXSPEEDFAST 0x1541 #define PA_MAXRXSPEEDSLOW 0x1542 #define PA_TXLINKSTARTUPHS 0x1544 +#define PA_AVAILRXDATALANES 0x1540 +#define PA_MINRXTRAILINGCLOCKS 0x1543 #define PA_LOCAL_TX_LCC_ENABLE 0x155E +#define PA_ACTIVETXDATALANES 0x1560 +#define PA_CONNECTEDTXDATALANES 0x1561 +#define PA_TXFORCECLOCK 0x1562 +#define PA_TXPWRMODE 0x1563 +#define PA_TXTRAILINGCLOCKS 0x1564 #define PA_TXSPEEDFAST 0x1565 #define PA_TXSPEEDSLOW 0x1566 -#define PA_REMOTEVERINFO 0x15A0 +#define PA_TXPWRSTATUS 0x1567 #define PA_TXGEAR 0x1568 #define PA_TXTERMINATION 0x1569 #define PA_HSSERIES 0x156A +#define PA_LEGACYDPHYESCDL 0x1570 #define PA_PWRMODE 0x1571 +#define PA_ACTIVERXDATALANES 0x1580 +#define PA_CONNECTEDRXDATALANES 0x1581 +#define PA_RXPWRSTATUS 0x1582 #define PA_RXGEAR 0x1583 #define PA_RXTERMINATION 0x1584 #define PA_MAXRXPWMGEAR 0x1586 #define PA_MAXRXHSGEAR 0x1587 -#define PA_RXHSUNTERMCAP 0x15A5 -#define PA_RXLSTERMCAP 0x15A6 -#define PA_GRANULARITY 0x15AA #define PA_PACPREQTIMEOUT 0x1590 #define PA_PACPREQEOBTIMEOUT 0x1591 +#define PA_REMOTEVERINFO 0x15A0 +#define PA_LOGICALLANEMAP 0x15A1 +#define PA_SLEEPNOCONFIGTIME 0x15A2 +#define PA_STALLNOCONFIGTIME 0x15A3 +#define PA_SAVECONFIGTIME 0x15A4 +#define PA_RXHSUNTERMCAP 0x15A5 +#define PA_RXLSTERMCAP 0x15A6 #define PA_HIBERN8TIME 0x15A7 #define PA_LOCALVERINFO 0x15A9 +#define PA_GRANULARITY 0x15AA #define PA_TACTIVATE 0x15A8 -#define PA_PACPFRAMECOUNT 0x15C0 -#define PA_PACPERRORCOUNT 0x15C1 -#define PA_PHYTESTCONTROL 0x15C2 #define PA_PWRMODEUSERDATA0 0x15B0 #define PA_PWRMODEUSERDATA1 0x15B1 #define PA_PWRMODEUSERDATA2 0x15B2 @@ -134,12 +152,9 @@ #define PA_PWRMODEUSERDATA9 0x15B9 #define PA_PWRMODEUSERDATA10 0x15BA #define PA_PWRMODEUSERDATA11 0x15BB -#define PA_CONNECTEDTXDATALANES 0x1561 -#define PA_CONNECTEDRXDATALANES 0x1581 -#define PA_LOGICALLANEMAP 0x15A1 -#define PA_SLEEPNOCONFIGTIME 0x15A2 -#define PA_STALLNOCONFIGTIME 0x15A3 -#define PA_SAVECONFIGTIME 0x15A4 +#define PA_PACPFRAMECOUNT 0x15C0 +#define PA_PACPERRORCOUNT 0x15C1 +#define PA_PHYTESTCONTROL 0x15C2 #define PA_TXHSADAPTTYPE 0x15D4
/* Adapt type for PA_TXHSADAPTTYPE attribute */ @@ -151,9 +166,9 @@ #define PA_HIBERN8_TIME_UNIT_US 100
/*Other attributes*/ +#define VS_POWERSTATE 0xD083 #define VS_MPHYCFGUPDT 0xD085 #define VS_DEBUGOMC 0xD09E -#define VS_POWERSTATE 0xD083 #define VS_MPHYDISABLE 0xD0C1
#define PA_GRANULARITY_MIN_VAL 1 @@ -163,7 +178,7 @@ #define PA_MAXDATALANES 4
/* PA power modes */ -enum { +enum ufs_pa_pwr_mode { FAST_MODE = 1, SLOW_MODE = 2, FASTAUTO_MODE = 4, @@ -171,8 +186,11 @@ enum { UNCHANGED = 7, };
+#define PWRMODE_MASK 0xF +#define PWRMODE_RX_OFFSET 4 + /* PA TX/RX Frequency Series */ -enum { +enum ufs_hs_gear_rate { PA_HS_MODE_A = 1, PA_HS_MODE_B = 2, }; @@ -193,14 +211,24 @@ enum ufs_hs_gear_tag { UFS_HS_G1, /* HS Gear 1 (default for reset) */ UFS_HS_G2, /* HS Gear 2 */ UFS_HS_G3, /* HS Gear 3 */ + UFS_HS_G4, /* HS Gear 4 */ + UFS_HS_G5 /* HS Gear 5 */ +}; + +enum ufs_lanes { + UFS_LANE_DONT_CHANGE, /* Don't change Lane */ + UFS_LANE_1, /* Lane 1 (default for reset) */ + UFS_LANE_2, /* Lane 2 */ };
enum ufs_unipro_ver { UFS_UNIPRO_VER_RESERVED = 0, UFS_UNIPRO_VER_1_40 = 1, /* UniPro version 1.40 */ UFS_UNIPRO_VER_1_41 = 2, /* UniPro version 1.41 */ - UFS_UNIPRO_VER_1_6 = 3, /* UniPro version 1.6 */ - UFS_UNIPRO_VER_MAX = 4, /* UniPro unsupported version */ + UFS_UNIPRO_VER_1_6 = 3, /* UniPro version 1.6 */ + UFS_UNIPRO_VER_1_61 = 4, /* UniPro version 1.61 */ + UFS_UNIPRO_VER_1_8 = 5, /* UniPro version 1.8 */ + UFS_UNIPRO_VER_MAX = 6, /* UniPro unsupported version */ /* UniPro version field mask in PA_LOCALVERINFO */ UFS_UNIPRO_VER_MASK = 0xF, }; @@ -208,27 +236,27 @@ enum ufs_unipro_ver { /* * Data Link Layer Attributes */ +#define DL_TXPREEMPTIONCAP 0x2000 +#define DL_TC0TXMAXSDUSIZE 0x2001 +#define DL_TC0RXINITCREDITVAL 0x2002 +#define DL_TC1TXMAXSDUSIZE 0x2003 +#define DL_TC1RXINITCREDITVAL 0x2004 +#define DL_TC0TXBUFFERSIZE 0x2005 +#define DL_TC1TXBUFFERSIZE 0x2006 #define DL_TC0TXFCTHRESHOLD 0x2040 #define DL_FC0PROTTIMEOUTVAL 0x2041 #define DL_TC0REPLAYTIMEOUTVAL 0x2042 #define DL_AFC0REQTIMEOUTVAL 0x2043 #define DL_AFC0CREDITTHRESHOLD 0x2044 #define DL_TC0OUTACKTHRESHOLD 0x2045 +#define DL_PEERTC0PRESENT 0x2046 +#define DL_PEERTC0RXINITCREVAL 0x2047 #define DL_TC1TXFCTHRESHOLD 0x2060 #define DL_FC1PROTTIMEOUTVAL 0x2061 #define DL_TC1REPLAYTIMEOUTVAL 0x2062 #define DL_AFC1REQTIMEOUTVAL 0x2063 #define DL_AFC1CREDITTHRESHOLD 0x2064 #define DL_TC1OUTACKTHRESHOLD 0x2065 -#define DL_TXPREEMPTIONCAP 0x2000 -#define DL_TC0TXMAXSDUSIZE 0x2001 -#define DL_TC0RXINITCREDITVAL 0x2002 -#define DL_TC0TXBUFFERSIZE 0x2005 -#define DL_PEERTC0PRESENT 0x2046 -#define DL_PEERTC0RXINITCREVAL 0x2047 -#define DL_TC1TXMAXSDUSIZE 0x2003 -#define DL_TC1RXINITCREDITVAL 0x2004 -#define DL_TC1TXBUFFERSIZE 0x2006 #define DL_PEERTC1PRESENT 0x2066 #define DL_PEERTC1RXINITCREVAL 0x2067
Sync ufshci.h with the version found in the Linux v6.12 version commit adc218676eef ("Linux 6.12").
Acked-by: Neha Malcom Francis n-francis@ti.com Tested-by: Love Kumar love.kumar@amd.com Signed-off-by: Neil Armstrong neil.armstrong@linaro.org --- drivers/ufs/ufshci.h | 285 +++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 210 insertions(+), 75 deletions(-)
diff --git a/drivers/ufs/ufshci.h b/drivers/ufs/ufshci.h index db30812b176f9e36529452e260b847241f97fdab..08af517b1028804e64602767f7a51bbfb083c59b 100644 --- a/drivers/ufs/ufshci.h +++ b/drivers/ufs/ufshci.h @@ -8,61 +8,14 @@ enum { ALIGNED_UPIU_SIZE = 512, };
-/* To accommodate UFS2.0 required Command type */ -enum { - UTP_CMD_TYPE_UFS_STORAGE = 0x1, -}; - -enum { - UTP_SCSI_COMMAND = 0x00000000, - UTP_NATIVE_UFS_COMMAND = 0x10000000, - UTP_DEVICE_MANAGEMENT_FUNCTION = 0x20000000, - UTP_REQ_DESC_INT_CMD = 0x01000000, -}; - -/* UTP Transfer Request Data Direction (DD) */ -enum { - UTP_NO_DATA_TRANSFER = 0x00000000, - UTP_HOST_TO_DEVICE = 0x02000000, - UTP_DEVICE_TO_HOST = 0x04000000, -}; - -/* Overall command status values */ -enum { - OCS_SUCCESS = 0x0, - OCS_INVALID_CMD_TABLE_ATTR = 0x1, - OCS_INVALID_PRDT_ATTR = 0x2, - OCS_MISMATCH_DATA_BUF_SIZE = 0x3, - OCS_MISMATCH_RESP_UPIU_SIZE = 0x4, - OCS_PEER_COMM_FAILURE = 0x5, - OCS_ABORTED = 0x6, - OCS_FATAL_ERROR = 0x7, - OCS_INVALID_COMMAND_STATUS = 0x0F, - MASK_OCS = 0x0F, -}; - -/* The maximum length of the data byte count field in the PRDT is 256KB */ -#define PRDT_DATA_BYTE_COUNT_MAX (256 * 1024) -/* The granularity of the data byte count field in the PRDT is 32-bit */ -#define PRDT_DATA_BYTE_COUNT_PAD 4 - -/* Controller UFSHCI version */ -enum { - UFSHCI_VERSION_10 = 0x00010000, /* 1.0 */ - UFSHCI_VERSION_11 = 0x00010100, /* 1.1 */ - UFSHCI_VERSION_20 = 0x00000200, /* 2.0 */ - UFSHCI_VERSION_21 = 0x00000210, /* 2.1 */ - UFSHCI_VERSION_30 = 0x00000300, /* 3.0 */ - UFSHCI_VERSION_31 = 0x00000310, /* 3.1 */ - UFSHCI_VERSION_40 = 0x00000400, /* 4.0 */ -}; - /* UFSHCI Registers */ enum { REG_CONTROLLER_CAPABILITIES = 0x00, + REG_MCQCAP = 0x04, REG_UFS_VERSION = 0x08, - REG_CONTROLLER_DEV_ID = 0x10, - REG_CONTROLLER_PROD_ID = 0x14, + REG_EXT_CONTROLLER_CAPABILITIES = 0x0C, + REG_CONTROLLER_PID = 0x10, + REG_CONTROLLER_MID = 0x14, REG_AUTO_HIBERNATE_IDLE_TIMER = 0x18, REG_INTERRUPT_STATUS = 0x20, REG_INTERRUPT_ENABLE = 0x24, @@ -94,20 +47,98 @@ enum { REG_UFS_CCAP = 0x100, REG_UFS_CRYPTOCAP = 0x104,
+ REG_UFS_MEM_CFG = 0x300, + REG_UFS_MCQ_CFG = 0x380, + REG_UFS_ESILBA = 0x384, + REG_UFS_ESIUBA = 0x388, UFSHCI_CRYPTO_REG_SPACE_SIZE = 0x400, };
/* Controller capability masks */ enum { - MASK_TRANSFER_REQUESTS_SLOTS = 0x0000001F, + MASK_TRANSFER_REQUESTS_SLOTS_SDB = 0x0000001F, + MASK_TRANSFER_REQUESTS_SLOTS_MCQ = 0x000000FF, + MASK_NUMBER_OUTSTANDING_RTT = 0x0000FF00, MASK_TASK_MANAGEMENT_REQUEST_SLOTS = 0x00070000, + MASK_EHSLUTRD_SUPPORTED = 0x00400000, MASK_AUTO_HIBERN8_SUPPORT = 0x00800000, MASK_64_ADDRESSING_SUPPORT = 0x01000000, MASK_OUT_OF_ORDER_DATA_DELIVERY_SUPPORT = 0x02000000, MASK_UIC_DME_TEST_MODE_SUPPORT = 0x04000000, + MASK_CRYPTO_SUPPORT = 0x10000000, + MASK_LSDB_SUPPORT = 0x20000000, + MASK_MCQ_SUPPORT = 0x40000000, +}; + +/* MCQ capability mask */ +enum { + MASK_EXT_IID_SUPPORT = 0x00000400, +}; + +enum { + REG_SQATTR = 0x0, + REG_SQLBA = 0x4, + REG_SQUBA = 0x8, + REG_SQDAO = 0xC, + REG_SQISAO = 0x10, + + REG_CQATTR = 0x20, + REG_CQLBA = 0x24, + REG_CQUBA = 0x28, + REG_CQDAO = 0x2C, + REG_CQISAO = 0x30, +}; + +enum { + REG_SQHP = 0x0, + REG_SQTP = 0x4, + REG_SQRTC = 0x8, + REG_SQCTI = 0xC, + REG_SQRTS = 0x10, +}; + +enum { + REG_CQHP = 0x0, + REG_CQTP = 0x4, +}; + +enum { + REG_CQIS = 0x0, + REG_CQIE = 0x4, +}; + +enum { + SQ_START = 0x0, + SQ_STOP = 0x1, + SQ_ICU = 0x2, +}; + +enum { + SQ_STS = 0x1, + SQ_CUS = 0x2, +}; + +#define SQ_ICU_ERR_CODE_MASK GENMASK(7, 4) +#define UFS_MASK(mask, offset) ((mask) << (offset)) + +/* UFS Version 08h */ +#define MINOR_VERSION_NUM_MASK UFS_MASK(0xFFFF, 0) +#define MAJOR_VERSION_NUM_MASK UFS_MASK(0xFFFF, 16) + +/* Controller UFSHCI version */ +enum { + UFSHCI_VERSION_10 = 0x00010000, /* 1.0 */ + UFSHCI_VERSION_11 = 0x00010100, /* 1.1 */ + UFSHCI_VERSION_20 = 0x00000200, /* 2.0 */ + UFSHCI_VERSION_21 = 0x00000210, /* 2.1 */ + UFSHCI_VERSION_30 = 0x00000300, /* 3.0 */ + UFSHCI_VERSION_31 = 0x00000310, /* 3.1 */ + UFSHCI_VERSION_40 = 0x00000400, /* 4.0 */ };
-/* Interrupt Status 20h */ +/* + * IS - Interrupt Status - 20h + */ #define UTP_TRANSFER_REQ_COMPL 0x1 #define UIC_DME_END_PT_RESET 0x2 #define UIC_ERROR 0x4 @@ -122,25 +153,25 @@ enum { #define DEVICE_FATAL_ERROR 0x800 #define CONTROLLER_FATAL_ERROR 0x10000 #define SYSTEM_BUS_FATAL_ERROR 0x20000 +#define CRYPTO_ENGINE_FATAL_ERROR 0x40000 +#define MCQ_CQ_EVENT_STATUS 0x100000
-#define UFSHCD_UIC_PWR_MASK (UIC_HIBERNATE_ENTER |\ - UIC_HIBERNATE_EXIT |\ +#define UFSHCD_UIC_HIBERN8_MASK (UIC_HIBERNATE_ENTER |\ + UIC_HIBERNATE_EXIT) + +#define UFSHCD_UIC_PWR_MASK (UFSHCD_UIC_HIBERN8_MASK |\ UIC_POWER_MODE)
-#define UFSHCD_UIC_MASK (UIC_COMMAND_COMPL | UIC_POWER_MODE) +#define UFSHCD_UIC_MASK (UIC_COMMAND_COMPL | UFSHCD_UIC_PWR_MASK)
-#define UFSHCD_ERROR_MASK (UIC_ERROR |\ - DEVICE_FATAL_ERROR |\ - CONTROLLER_FATAL_ERROR |\ - SYSTEM_BUS_FATAL_ERROR) +#define UFSHCD_ERROR_MASK (UIC_ERROR | INT_FATAL_ERRORS)
#define INT_FATAL_ERRORS (DEVICE_FATAL_ERROR |\ CONTROLLER_FATAL_ERROR |\ - SYSTEM_BUS_FATAL_ERROR) + SYSTEM_BUS_FATAL_ERROR |\ + CRYPTO_ENGINE_FATAL_ERROR |\ + UIC_LINK_LOST)
-/* Host Controller Enable 0x34h */ -#define CONTROLLER_ENABLE 0x1 -#define CONTROLLER_DISABLE 0x0 /* HCS - Host Controller Status 30h */ #define DEVICE_PRESENT 0x1 #define UTP_TRANSFER_REQ_LIST_READY 0x2 @@ -163,6 +194,70 @@ enum { PWR_FATAL_ERROR = 0x05, };
+/* HCE - Host Controller Enable 34h */ +#define CONTROLLER_ENABLE 0x1 +#define CONTROLLER_DISABLE 0x0 +#define CRYPTO_GENERAL_ENABLE 0x2 + +/* UECPA - Host UIC Error Code PHY Adapter Layer 38h */ +#define UIC_PHY_ADAPTER_LAYER_ERROR 0x80000000 +#define UIC_PHY_ADAPTER_LAYER_ERROR_CODE_MASK 0x1F +#define UIC_PHY_ADAPTER_LAYER_LANE_ERR_MASK 0xF +#define UIC_PHY_ADAPTER_LAYER_GENERIC_ERROR 0x10 + +/* UECDL - Host UIC Error Code Data Link Layer 3Ch */ +#define UIC_DATA_LINK_LAYER_ERROR 0x80000000 +#define UIC_DATA_LINK_LAYER_ERROR_CODE_MASK 0xFFFF +#define UIC_DATA_LINK_LAYER_ERROR_TCX_REP_TIMER_EXP 0x2 +#define UIC_DATA_LINK_LAYER_ERROR_AFCX_REQ_TIMER_EXP 0x4 +#define UIC_DATA_LINK_LAYER_ERROR_FCX_PRO_TIMER_EXP 0x8 +#define UIC_DATA_LINK_LAYER_ERROR_RX_BUF_OF 0x20 +#define UIC_DATA_LINK_LAYER_ERROR_PA_INIT 0x2000 +#define UIC_DATA_LINK_LAYER_ERROR_NAC_RECEIVED 0x0001 +#define UIC_DATA_LINK_LAYER_ERROR_TCx_REPLAY_TIMEOUT 0x0002 + +/* UECN - Host UIC Error Code Network Layer 40h */ +#define UIC_NETWORK_LAYER_ERROR 0x80000000 +#define UIC_NETWORK_LAYER_ERROR_CODE_MASK 0x7 +#define UIC_NETWORK_UNSUPPORTED_HEADER_TYPE 0x1 +#define UIC_NETWORK_BAD_DEVICEID_ENC 0x2 +#define UIC_NETWORK_LHDR_TRAP_PACKET_DROPPING 0x4 + +/* UECT - Host UIC Error Code Transport Layer 44h */ +#define UIC_TRANSPORT_LAYER_ERROR 0x80000000 +#define UIC_TRANSPORT_LAYER_ERROR_CODE_MASK 0x7F +#define UIC_TRANSPORT_UNSUPPORTED_HEADER_TYPE 0x1 +#define UIC_TRANSPORT_UNKNOWN_CPORTID 0x2 +#define UIC_TRANSPORT_NO_CONNECTION_RX 0x4 +#define UIC_TRANSPORT_CONTROLLED_SEGMENT_DROPPING 0x8 +#define UIC_TRANSPORT_BAD_TC 0x10 +#define UIC_TRANSPORT_E2E_CREDIT_OVERFOW 0x20 +#define UIC_TRANSPORT_SAFETY_VALUE_DROPPING 0x40 + +/* UECDME - Host UIC Error Code DME 48h */ +#define UIC_DME_ERROR 0x80000000 +#define UIC_DME_ERROR_CODE_MASK 0x1 + +/* UTRIACR - Interrupt Aggregation control register - 0x4Ch */ +#define INT_AGGR_TIMEOUT_VAL_MASK 0xFF +#define INT_AGGR_COUNTER_THRESHOLD_MASK UFS_MASK(0x1F, 8) +#define INT_AGGR_COUNTER_AND_TIMER_RESET 0x10000 +#define INT_AGGR_STATUS_BIT 0x100000 +#define INT_AGGR_PARAM_WRITE 0x1000000 +#define INT_AGGR_ENABLE 0x80000000 + +/* UTRLRSR - UTP Transfer Request Run-Stop Register 60h */ +#define UTP_TRANSFER_REQ_LIST_RUN_STOP_BIT 0x1 + +/* UTMRLRSR - UTP Task Management Request Run-Stop Register 80h */ +#define UTP_TASK_REQ_LIST_RUN_STOP_BIT 0x1 + +/* REG_UFS_MEM_CFG - Global Config Registers 300h */ +#define MCQ_MODE_SELECT BIT(0) + +/* CQISy - CQ y Interrupt Status Register */ +#define UFSHCD_MCQ_CQIS_TAIL_ENT_PUSH_STS 0x1 + /* UICCMD - UIC Command */ #define COMMAND_OPCODE_MASK 0xFF #define GEN_SELECTOR_INDEX_MASK 0xFFFF @@ -171,7 +266,7 @@ enum { #define RESET_LEVEL 0xFF
#define ATTR_SET_TYPE_MASK UFS_MASK(0xFF, 16) -#define CFG_RESULT_CODE_MASK 0xFF +#define CONFIG_RESULT_CODE_MASK 0xFF #define GENERIC_ERROR_CODE_MASK 0xFF
/* GenSelectorIndex calculation macros for M-PHY attributes */ @@ -190,12 +285,6 @@ enum link_status { UFSHCD_LINK_IS_UP = 2, };
-#define UIC_ARG_MIB_SEL(attr, sel) ((((attr) & 0xFFFF) << 16) |\ - ((sel) & 0xFFFF)) -#define UIC_ARG_MIB(attr) UIC_ARG_MIB_SEL(attr, 0) -#define UIC_ARG_ATTR_TYPE(t) (((t) & 0xFF) << 16) -#define UIC_GET_ATTR_ID(v) (((v) >> 16) & 0xFFFF) - /* UIC Commands */ enum uic_cmd_dme { UIC_CMD_DME_GET = 0x01, @@ -231,11 +320,57 @@ enum {
-/* UTRLRSR - UTP Transfer Request Run-Stop Register 60h */ -#define UTP_TRANSFER_REQ_LIST_RUN_STOP_BIT 0x1 +#define INT_AGGR_COUNTER_THLD_VAL(c) (((c) & 0x1F) << 8) +#define INT_AGGR_TIMEOUT_VAL(t) (((t) & 0xFF) << 0) + +/* + * Request Descriptor Definitions + */ + +/* To accommodate UFS2.0 required Command type */ +enum { + UTP_CMD_TYPE_UFS_STORAGE = 0x1, +}; + +enum { + UTP_SCSI_COMMAND = 0x00000000, + UTP_REQ_DESC_INT_CMD = 0x01000000, + UTP_NATIVE_UFS_COMMAND = 0x10000000, + UTP_DEVICE_MANAGEMENT_FUNCTION = 0x20000000, +}; + +/* UTP Transfer Request Data Direction (DD) */ +enum utp_data_direction { + UTP_NO_DATA_TRANSFER = 0, + UTP_HOST_TO_DEVICE = 1, + UTP_DEVICE_TO_HOST = 2, +}; + +/* Overall command status values */ +enum utp_ocs { + OCS_SUCCESS = 0x0, + OCS_INVALID_CMD_TABLE_ATTR = 0x1, + OCS_INVALID_PRDT_ATTR = 0x2, + OCS_MISMATCH_DATA_BUF_SIZE = 0x3, + OCS_MISMATCH_RESP_UPIU_SIZE = 0x4, + OCS_PEER_COMM_FAILURE = 0x5, + OCS_ABORTED = 0x6, + OCS_FATAL_ERROR = 0x7, + OCS_DEVICE_FATAL_ERROR = 0x8, + OCS_INVALID_CRYPTO_CONFIG = 0x9, + OCS_GENERAL_CRYPTO_ERROR = 0xA, + OCS_INVALID_COMMAND_STATUS = 0x0F, +}; + +enum { + MASK_OCS = 0x0F, +}; + +/* The maximum length of the data byte count field in the PRDT is 256KB */ +#define PRDT_DATA_BYTE_COUNT_MAX SZ_256K +/* The granularity of the data byte count field in the PRDT is 32-bit */ +#define PRDT_DATA_BYTE_COUNT_PAD 4
struct ufshcd_sg_entry { __le32 base_addr;
Neil Armstrong
