[U-Boot] [PATCH v6 0/7] Add support for Panasonic UniPhier SoCs/boards
UniPhier is the SoC family developed by Panasonic Corporation, based on ARM Cortex-A9.
This patch set adds its SoC/board support code with some drivers.
Masahiro Yamada (7): mtd: denali: add Denali controller configs to Kconfig mtd: denali: add Denali NAND driver for SPL serial: add UniPhier serial driver ARM: UniPhier: add UniPhier SoC support code ARM: UniPhier: add Kconfig and defconfig MAINTAINERS: add me as a maintainer of UniPhier platform git-mailrc: add me as a maintainer of UniPhier platform
MAINTAINERS | 9 + arch/arm/Kconfig | 5 + arch/arm/cpu/armv7/uniphier/Kconfig | 32 + arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 91 ++ arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16 + .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 + arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 162 +++ arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16 + .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 + arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 136 +++ arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16 + .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 142 +++ arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 30 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 108 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 67 ++ arch/arm/include/asm/arch-uniphier/umc-regs.h | 119 +++ configs/ph1_ld4_defconfig | 8 + configs/ph1_pro4_defconfig | 8 + configs/ph1_sld8_defconfig | 8 + doc/README.nand | 6 - doc/git-mailrc | 1 + drivers/mtd/Kconfig | 1 + drivers/mtd/nand/Kconfig | 42 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_spl.c | 231 +++++ drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_uniphier.c | 204 ++++ include/configs/ph1_ld4.h | 59 ++ include/configs/ph1_pro4.h | 61 ++ include/configs/ph1_sld8.h | 61 ++ include/configs/uniphier-common.h | 266 +++++ 78 files changed, 5504 insertions(+), 6 deletions(-) create mode 100644 arch/arm/cpu/armv7/uniphier/Kconfig create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/umc-regs.h create mode 100644 configs/ph1_ld4_defconfig create mode 100644 configs/ph1_pro4_defconfig create mode 100644 configs/ph1_sld8_defconfig create mode 100644 drivers/mtd/nand/Kconfig create mode 100644 drivers/mtd/nand/denali_spl.c create mode 100644 drivers/serial/serial_uniphier.c create mode 100644 include/configs/ph1_ld4.h create mode 100644 include/configs/ph1_pro4.h create mode 100644 include/configs/ph1_sld8.h create mode 100644 include/configs/uniphier-common.h
Commit 3eb3e72a3f66 (nand/denali: Adding Denali NAND driver support) introduced some new options, and some of them were documented by commit f9860cf081ef (nand/denali: Document CONFIG symbols).
This commit allows users to enable/disable them via Kconfig with more detailed help docs.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Chin Liang See clsee@altera.com Cc: Scott Wood scottwood@freescale.com ---
Changes in v6: - Rename oob -> OOB
Changes in v5: - Newly added
Changes in v4: None Changes in v3: None Changes in v2: None
doc/README.nand | 6 ------ drivers/mtd/Kconfig | 1 + drivers/mtd/nand/Kconfig | 32 ++++++++++++++++++++++++++++++++ 3 files changed, 33 insertions(+), 6 deletions(-) create mode 100644 drivers/mtd/nand/Kconfig
diff --git a/doc/README.nand b/doc/README.nand index 320d752..e29188f 100644 --- a/doc/README.nand +++ b/doc/README.nand @@ -215,12 +215,6 @@ Configuration Options:
Platform specific options ========================= - CONFIG_NAND_DENALI - Enables the denali.c driver. - - CONFIG_SYS_NAND_DENALI_64BIT - Indicates that the Denali NAND controller is the 64-bit variant. - CONFIG_NAND_OMAP_GPMC Enables omap_gpmc.c driver for OMAPx and AMxxxx platforms. GPMC controller is used for parallel NAND flash devices, and can diff --git a/drivers/mtd/Kconfig b/drivers/mtd/Kconfig index e69de29..415ab4e 100644 --- a/drivers/mtd/Kconfig +++ b/drivers/mtd/Kconfig @@ -0,0 +1 @@ +source "drivers/mtd/nand/Kconfig" diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig new file mode 100644 index 0000000..1d9bf48 --- /dev/null +++ b/drivers/mtd/nand/Kconfig @@ -0,0 +1,32 @@ +menu "NAND Device Support" + +if !SPL_BUILD + +config NAND_DENALI + bool "Support Denali NAND controller" + help + Enable support for the Denali NAND controller. + +config SYS_NAND_DENALI_64BIT + bool "Use 64-bit variant of Denali NAND controller" + depends on NAND_DENALI + help + The Denali NAND controller IP has some variations in terms of + the bus interface. The DMA setup sequence is completely differenct + between 32bit / 64bit AXI bus variants. + + If your Denali NAND controller is the 64-bit variant, say Y. + Otherwise (32 bit), say N. + +config NAND_DENALI_SPARE_AREA_SKIP_BYTES + int "Number of bytes skipped in OOB area" + depends on NAND_DENALI + range 0 63 + help + This option specifies the number of bytes to skip from the beginning + of OOB area before last ECC sector data starts. This is potentially + used to preserve the bad block marker in the OOB area. + +endif + +endmenu
2014-10-03 19:21 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
Changes in v6:
- Rename oob -> OOB
Changes in v5:
- Newly added
Applied to u-boot-uniphier/master.
The SPL-mode driver for Denali(Cadence) NAND Flash Memory Controller IP.
This driver requires two CONFIG macros: - CONFIG_SPL_NAND_DENALI Define to enable this driver. - CONFIG_SYS_NAND_BAD_BLOCK_POS Specify bad block mark position in the oob space. Typically 0.
Changes in v6: None Changes in v5: - Remove the workaround added by v4 because the denali.h was merget into the mainline - Add Kconfig entry - Add comments where we read out some register values
Changes in v4: - Add a workaround to not depend on the Denali driver posted by Chin Liang See. This driver has been taking too long: http://patchwork.ozlabs.org/patch/381305/
Changes in v3: None Changes in v2: - Avoid unaligned access - Replace a magic number 0x2000 with PIPELINE_ACCESS
drivers/mtd/nand/Kconfig | 10 ++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/denali_spl.c | 231 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 242 insertions(+) create mode 100644 drivers/mtd/nand/denali_spl.c
diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 1d9bf48..75c2c06 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -29,4 +29,14 @@ config NAND_DENALI_SPARE_AREA_SKIP_BYTES
endif
+if SPL_BUILD + +config SPL_NAND_DENALI + bool "Support Denali NAND controller for SPL" + help + This is a small implementation of the Denali NAND controller + for use on SPL. + +endif + endmenu diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index f298f84..47eb34f 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -12,6 +12,7 @@ NORMAL_DRIVERS=y endif
obj-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o +obj-$(CONFIG_SPL_NAND_DENALI) += denali_spl.o obj-$(CONFIG_SPL_NAND_DOCG4) += docg4_spl.o obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o diff --git a/drivers/mtd/nand/denali_spl.c b/drivers/mtd/nand/denali_spl.c new file mode 100644 index 0000000..65fdde8 --- /dev/null +++ b/drivers/mtd/nand/denali_spl.c @@ -0,0 +1,231 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/unaligned.h> +#include <linux/mtd/nand.h> +#include "denali.h" + +#define SPARE_ACCESS 0x41 +#define MAIN_ACCESS 0x42 +#define PIPELINE_ACCESS 0x2000 + +#define BANK(x) ((x) << 24) + +static void __iomem *denali_flash_mem = + (void __iomem *)CONFIG_SYS_NAND_DATA_BASE; +static void __iomem *denali_flash_reg = + (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + +static const int flash_bank; +static uint8_t page_buffer[NAND_MAX_PAGESIZE]; +static int page_size, oob_size, pages_per_block; + +static void index_addr(uint32_t address, uint32_t data) +{ + writel(address, denali_flash_mem + INDEX_CTRL_REG); + writel(data, denali_flash_mem + INDEX_DATA_REG); +} + +static int wait_for_irq(uint32_t irq_mask) +{ + unsigned long timeout = 1000000; + uint32_t intr_status; + + do { + intr_status = readl(denali_flash_reg + INTR_STATUS(flash_bank)); + + if (intr_status & INTR_STATUS__ECC_UNCOR_ERR) { + debug("Uncorrected ECC detected\n"); + return -EIO; + } + + if (intr_status & irq_mask) + break; + + udelay(1); + timeout--; + } while (timeout); + + if (!timeout) { + debug("Timeout with interrupt status %08x\n", intr_status); + return -EIO; + } + + return 0; +} + +static void read_data_from_flash_mem(uint8_t *buf, int len) +{ + int i; + uint32_t *buf32; + + /* transfer the data from the flash */ + buf32 = (uint32_t *)buf; + + /* + * Let's take care of unaligned access although it rarely happens. + * Avoid put_unaligned() for the normal use cases since it leads to + * a bit performance regression. + */ + if ((unsigned long)buf32 % 4) { + for (i = 0; i < len / 4; i++) + put_unaligned(readl(denali_flash_mem + INDEX_DATA_REG), + buf32++); + } else { + for (i = 0; i < len / 4; i++) + *buf32++ = readl(denali_flash_mem + INDEX_DATA_REG); + } + + if (len % 4) { + u32 tmp; + + tmp = cpu_to_le32(readl(denali_flash_mem + INDEX_DATA_REG)); + buf = (uint8_t *)buf32; + for (i = 0; i < len % 4; i++) { + *buf++ = tmp; + tmp >>= 8; + } + } +} + +int denali_send_pipeline_cmd(int page, int ecc_en, int access_type) +{ + uint32_t addr, cmd; + static uint32_t page_count = 1; + + writel(ecc_en, denali_flash_reg + ECC_ENABLE); + + /* clear all bits of intr_status. */ + writel(0xffff, denali_flash_reg + INTR_STATUS(flash_bank)); + + addr = BANK(flash_bank) | page; + + /* setup the acccess type */ + cmd = MODE_10 | addr; + index_addr(cmd, access_type); + + /* setup the pipeline command */ + index_addr(cmd, PIPELINE_ACCESS | page_count); + + cmd = MODE_01 | addr; + writel(cmd, denali_flash_mem + INDEX_CTRL_REG); + + return wait_for_irq(INTR_STATUS__LOAD_COMP); +} + +static int nand_read_oob(void *buf, int page) +{ + int ret; + + ret = denali_send_pipeline_cmd(page, 0, SPARE_ACCESS); + if (ret < 0) + return ret; + + read_data_from_flash_mem(buf, oob_size); + + return 0; +} + +static int nand_read_page(void *buf, int page) +{ + int ret; + + ret = denali_send_pipeline_cmd(page, 1, MAIN_ACCESS); + if (ret < 0) + return ret; + + read_data_from_flash_mem(buf, page_size); + + return 0; +} + +static int nand_block_isbad(int block) +{ + int ret; + + ret = nand_read_oob(page_buffer, block * pages_per_block); + if (ret < 0) + return ret; + + return page_buffer[CONFIG_SYS_NAND_BAD_BLOCK_POS] != 0xff; +} + +/* nand_init() - initialize data to make nand usable by SPL */ +void nand_init(void) +{ + /* access to main area */ + writel(0, denali_flash_reg + TRANSFER_SPARE_REG); + + /* + * These registers are expected to be already set by the hardware + * or earlier boot code. So we read these values out. + */ + page_size = readl(denali_flash_reg + DEVICE_MAIN_AREA_SIZE); + oob_size = readl(denali_flash_reg + DEVICE_SPARE_AREA_SIZE); + pages_per_block = readl(denali_flash_reg + PAGES_PER_BLOCK); +} + +int nand_spl_load_image(uint32_t offs, unsigned int size, void *dst) +{ + int block, page, column, readlen; + int ret; + int force_bad_block_check = 1; + + page = offs / page_size; + column = offs % page_size; + + block = page / pages_per_block; + page = page % pages_per_block; + + while (size) { + if (force_bad_block_check || page == 0) { + ret = nand_block_isbad(block); + if (ret < 0) + return ret; + + if (ret) { + block++; + continue; + } + } + + force_bad_block_check = 0; + + if (unlikely(column || size < page_size)) { + /* Partial page read */ + ret = nand_read_page(page_buffer, + block * pages_per_block + page); + if (ret < 0) + return ret; + + readlen = min(page_size - column, size); + memcpy(dst, page_buffer, readlen); + + column = 0; + } else { + ret = nand_read_page(dst, + block * pages_per_block + page); + if (ret < 0) + return ret; + + readlen = page_size; + } + + size -= readlen; + dst += readlen; + page++; + if (page == pages_per_block) { + block++; + page = 0; + } + } + + return 0; +} + +void nand_deselect(void) {}
- Add Kconfig entry
Changes in v4:
The driver for on-chip UART used on Panasonic UniPhier platform.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Use "const unsigned int mode_x_div = 16" instead of "#define MODE_X_DIV 16" - Use DIV_ROUND_CLOSEST() macro to compute the divisor
drivers/serial/Makefile | 1 + drivers/serial/serial.c | 2 + drivers/serial/serial_uniphier.c | 204 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 207 insertions(+) create mode 100644 drivers/serial/serial_uniphier.c
diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 853a8c6..b4f299b 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -39,6 +39,7 @@ obj-$(CONFIG_FSL_LPUART) += serial_lpuart.o obj-$(CONFIG_MXS_AUART) += mxs_auart.o obj-$(CONFIG_ARC_SERIAL) += serial_arc.o obj-$(CONFIG_TEGRA_SERIAL) += serial_tegra.o +obj-$(CONFIG_UNIPHIER_SERIAL) += serial_uniphier.o
ifndef CONFIG_SPL_BUILD obj-$(CONFIG_USB_TTY) += usbtty.o diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index bbe60af..82fbbd9 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -157,6 +157,7 @@ serial_initfunc(sh_serial_initialize); serial_initfunc(arm_dcc_initialize); serial_initfunc(mxs_auart_initialize); serial_initfunc(arc_serial_initialize); +serial_initfunc(uniphier_serial_initialize);
/** * serial_register() - Register serial driver with serial driver core @@ -250,6 +251,7 @@ void serial_initialize(void) arm_dcc_initialize(); mxs_auart_initialize(); arc_serial_initialize(); + uniphier_serial_initialize();
serial_assign(default_serial_console()->name); } diff --git a/drivers/serial/serial_uniphier.c b/drivers/serial/serial_uniphier.c new file mode 100644 index 0000000..f8c9d92 --- /dev/null +++ b/drivers/serial/serial_uniphier.c @@ -0,0 +1,204 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * Based on serial_ns16550.c + * (C) Copyright 2000 + * Rob Taylor, Flying Pig Systems. robt@flyingpig.com. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <serial.h> + +#define UART_REG(x) \ + u8 x; \ + u8 postpad_##x[3]; + +/* + * Note: Register map is slightly different from that of 16550. + */ +struct uniphier_serial { + UART_REG(rbr); /* 0x00 */ + UART_REG(ier); /* 0x04 */ + UART_REG(iir); /* 0x08 */ + UART_REG(fcr); /* 0x0c */ + u8 mcr; /* 0x10 */ + u8 lcr; + u16 __postpad; + UART_REG(lsr); /* 0x14 */ + UART_REG(msr); /* 0x18 */ + u32 __none1; + u32 __none2; + u16 dlr; + u16 __postpad2; +}; + +#define thr rbr + +/* + * These are the definitions for the Line Control Register + */ +#define UART_LCR_WLS_8 0x03 /* 8 bit character length */ + +/* + * These are the definitions for the Line Status Register + */ +#define UART_LSR_DR 0x01 /* Data ready */ +#define UART_LSR_THRE 0x20 /* Xmit holding register empty */ + +DECLARE_GLOBAL_DATA_PTR; + +static void uniphier_serial_init(struct uniphier_serial *port) +{ + const unsigned int mode_x_div = 16; + unsigned int divisor; + + writeb(UART_LCR_WLS_8, &port->lcr); + + divisor = DIV_ROUND_CLOSEST(CONFIG_SYS_UNIPHIER_UART_CLK, + mode_x_div * gd->baudrate); + + writew(divisor, &port->dlr); +} + +static void uniphier_serial_setbrg(struct uniphier_serial *port) +{ + uniphier_serial_init(port); +} + +static int uniphier_serial_tstc(struct uniphier_serial *port) +{ + return (readb(&port->lsr) & UART_LSR_DR) != 0; +} + +static int uniphier_serial_getc(struct uniphier_serial *port) +{ + while (!uniphier_serial_tstc(port)) + ; + + return readb(&port->rbr); +} + +static void uniphier_serial_putc(struct uniphier_serial *port, const char c) +{ + if (c == '\n') + uniphier_serial_putc(port, '\r'); + + while (!(readb(&port->lsr) & UART_LSR_THRE)) + ; + + writeb(c, &port->thr); +} + +static struct uniphier_serial *serial_ports[4] = { +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE0 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE0, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE1 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE1, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE2 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE2, +#else + NULL, +#endif +#ifdef CONFIG_SYS_UNIPHIER_SERIAL_BASE3 + (struct uniphier_serial *)CONFIG_SYS_UNIPHIER_SERIAL_BASE3, +#else + NULL, +#endif +}; + +/* Multi serial device functions */ +#define DECLARE_ESERIAL_FUNCTIONS(port) \ + static int eserial##port##_init(void) \ + { \ + uniphier_serial_init(serial_ports[port]); \ + return 0 ; \ + } \ + static void eserial##port##_setbrg(void) \ + { \ + uniphier_serial_setbrg(serial_ports[port]); \ + } \ + static int eserial##port##_getc(void) \ + { \ + return uniphier_serial_getc(serial_ports[port]); \ + } \ + static int eserial##port##_tstc(void) \ + { \ + return uniphier_serial_tstc(serial_ports[port]); \ + } \ + static void eserial##port##_putc(const char c) \ + { \ + uniphier_serial_putc(serial_ports[port], c); \ + } + +/* Serial device descriptor */ +#define INIT_ESERIAL_STRUCTURE(port, __name) { \ + .name = __name, \ + .start = eserial##port##_init, \ + .stop = NULL, \ + .setbrg = eserial##port##_setbrg, \ + .getc = eserial##port##_getc, \ + .tstc = eserial##port##_tstc, \ + .putc = eserial##port##_putc, \ + .puts = default_serial_puts, \ +} + +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) +DECLARE_ESERIAL_FUNCTIONS(0); +struct serial_device uniphier_serial0_device = + INIT_ESERIAL_STRUCTURE(0, "ttyS0"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) +DECLARE_ESERIAL_FUNCTIONS(1); +struct serial_device uniphier_serial1_device = + INIT_ESERIAL_STRUCTURE(1, "ttyS1"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) +DECLARE_ESERIAL_FUNCTIONS(2); +struct serial_device uniphier_serial2_device = + INIT_ESERIAL_STRUCTURE(2, "ttyS2"); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) +DECLARE_ESERIAL_FUNCTIONS(3); +struct serial_device uniphier_serial3_device = + INIT_ESERIAL_STRUCTURE(3, "ttyS3"); +#endif + +__weak struct serial_device *default_serial_console(void) +{ +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) + return &uniphier_serial0_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) + return &uniphier_serial1_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) + return &uniphier_serial2_device; +#elif defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) + return &uniphier_serial3_device; +#else +#error "No uniphier serial ports configured." +#endif +} + +void uniphier_serial_initialize(void) +{ +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE0) + serial_register(&uniphier_serial0_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE1) + serial_register(&uniphier_serial1_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE2) + serial_register(&uniphier_serial2_device); +#endif +#if defined(CONFIG_SYS_UNIPHIER_SERIAL_BASE3) + serial_register(&uniphier_serial3_device); +#endif +}
These are used by Panasonic UniPhier SoC family.
Changes in v6: - Increase malloc area from 1MB to 4MB - Improve comments in header files - Add SPDX to umc-regs.h
Changes in v5: - Move Denali configs to defconfigs - Enable CONFIG_SYS_NAND_ONFI_DETECTION - Add UMC settings - Re-enable Denali driver
Changes in v4: - Disable Denali NAND driver. This driver has been taking too long: http://patchwork.ozlabs.org/patch/381305/
Changes in v3: - Add Denali fixup code for PH1-sLD8 and PH1-Pro4
Changes in v2: - Rebase - Remove unnecessary CONFIG_SYS_NAND_PAGE_SIZE definition - Fix a typo in the subject
arch/arm/cpu/armv7/uniphier/Makefile | 23 + arch/arm/cpu/armv7/uniphier/board_common.c | 32 + arch/arm/cpu/armv7/uniphier/board_late_init.c | 91 ++ arch/arm/cpu/armv7/uniphier/cache_uniphier.c | 154 +++ arch/arm/cpu/armv7/uniphier/cmd_pinmon.c | 33 + arch/arm/cpu/armv7/uniphier/cpu_info.c | 59 ++ arch/arm/cpu/armv7/uniphier/dram_init.c | 37 + arch/arm/cpu/armv7/uniphier/init_page_table.c | 1068 ++++++++++++++++++++ arch/arm/cpu/armv7/uniphier/lowlevel_init.S | 159 +++ arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c | 33 + arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c | 16 + .../armv7/uniphier/ph1-ld4/board_postclk_init.c | 42 + arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c | 63 ++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c | 189 ++++ arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c | 44 + arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c | 162 +++ arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c | 16 + .../armv7/uniphier/ph1-pro4/board_postclk_init.c | 39 + arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c | 66 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c | 45 + arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c | 168 +++ .../arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c | 18 + arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c | 75 ++ arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c | 28 + arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c | 136 +++ arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile | 10 + arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c | 16 + .../armv7/uniphier/ph1-sld8/board_postclk_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c | 29 + arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c | 57 ++ arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c | 201 ++++ .../arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c | 51 + arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c | 1 + arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c | 142 +++ arch/arm/cpu/armv7/uniphier/reset.c | 29 + arch/arm/cpu/armv7/uniphier/smp.S | 54 + arch/arm/cpu/armv7/uniphier/spl.c | 17 + arch/arm/cpu/armv7/uniphier/support_card.c | 180 ++++ arch/arm/cpu/armv7/uniphier/timer.c | 39 + arch/arm/include/asm/arch-uniphier/arm-mpcore.h | 46 + arch/arm/include/asm/arch-uniphier/bcu-regs.h | 30 + arch/arm/include/asm/arch-uniphier/board.h | 35 + arch/arm/include/asm/arch-uniphier/boot-device.h | 20 + arch/arm/include/asm/arch-uniphier/led.h | 101 ++ arch/arm/include/asm/arch-uniphier/sbc-regs.h | 108 ++ arch/arm/include/asm/arch-uniphier/sc-regs.h | 62 ++ arch/arm/include/asm/arch-uniphier/sg-regs.h | 182 ++++ arch/arm/include/asm/arch-uniphier/ssc-regs.h | 67 ++ arch/arm/include/asm/arch-uniphier/umc-regs.h | 119 +++ include/configs/ph1_ld4.h | 59 ++ include/configs/ph1_pro4.h | 61 ++ include/configs/ph1_sld8.h | 61 ++ include/configs/uniphier-common.h | 266 +++++ 63 files changed, 4951 insertions(+) create mode 100644 arch/arm/cpu/armv7/uniphier/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/board_common.c create mode 100644 arch/arm/cpu/armv7/uniphier/board_late_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/cache_uniphier.c create mode 100644 arch/arm/cpu/armv7/uniphier/cmd_pinmon.c create mode 100644 arch/arm/cpu/armv7/uniphier/cpu_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/dram_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/init_page_table.c create mode 100644 arch/arm/cpu/armv7/uniphier/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c create mode 100644 arch/arm/cpu/armv7/uniphier/reset.c create mode 100644 arch/arm/cpu/armv7/uniphier/smp.S create mode 100644 arch/arm/cpu/armv7/uniphier/spl.c create mode 100644 arch/arm/cpu/armv7/uniphier/support_card.c create mode 100644 arch/arm/cpu/armv7/uniphier/timer.c create mode 100644 arch/arm/include/asm/arch-uniphier/arm-mpcore.h create mode 100644 arch/arm/include/asm/arch-uniphier/bcu-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/board.h create mode 100644 arch/arm/include/asm/arch-uniphier/boot-device.h create mode 100644 arch/arm/include/asm/arch-uniphier/led.h create mode 100644 arch/arm/include/asm/arch-uniphier/sbc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/sg-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/ssc-regs.h create mode 100644 arch/arm/include/asm/arch-uniphier/umc-regs.h create mode 100644 include/configs/ph1_ld4.h create mode 100644 include/configs/ph1_pro4.h create mode 100644 include/configs/ph1_sld8.h create mode 100644 include/configs/uniphier-common.h
diff --git a/arch/arm/cpu/armv7/uniphier/Makefile b/arch/arm/cpu/armv7/uniphier/Makefile new file mode 100644 index 0000000..7ceddda --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/Makefile @@ -0,0 +1,23 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_SPL_BUILD) += lowlevel_init.o init_page_table.o +obj-$(CONFIG_SPL_BUILD) += spl.o + +obj-y += timer.o +obj-y += reset.o +obj-y += cache_uniphier.o +obj-y += dram_init.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-$(CONFIG_BOARD_LATE_INIT) += board_late_init.o +obj-$(CONFIG_UNIPHIER_SMP) += smp.o +obj-$(if $(CONFIG_SPL_BUILD),,y) += cmd_pinmon.o + +obj-y += board_common.o +obj-$(CONFIG_PFC_MICRO_SUPPORT_CARD) += support_card.o +obj-$(CONFIG_DCC_MICRO_SUPPORT_CARD) += support_card.o + +obj-$(CONFIG_MACH_PH1_LD4) += ph1-ld4/ +obj-$(CONFIG_MACH_PH1_PRO4) += ph1-pro4/ +obj-$(CONFIG_MACH_PH1_SLD8) += ph1-sld8/ diff --git a/arch/arm/cpu/armv7/uniphier/board_common.c b/arch/arm/cpu/armv7/uniphier/board_common.c new file mode 100644 index 0000000..3fb26c6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_common.c @@ -0,0 +1,32 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + led_write(U, B, O, O); + + return 0; +} + +#if CONFIG_NR_DRAM_BANKS >= 2 +void dram_init_banksize(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = CONFIG_SDRAM0_BASE; + gd->bd->bi_dram[0].size = CONFIG_SDRAM0_SIZE; + gd->bd->bi_dram[1].start = CONFIG_SDRAM1_BASE; + gd->bd->bi_dram[1].size = CONFIG_SDRAM1_SIZE; +} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/board_late_init.c b/arch/arm/cpu/armv7/uniphier/board_late_init.c new file mode 100644 index 0000000..3730020 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/board_late_init.c @@ -0,0 +1,91 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <nand.h> +#include <asm/io.h> +#include <../drivers/mtd/nand/denali.h> + +static void nand_denali_wp_disable(void) +{ +#ifdef CONFIG_NAND_DENALI + /* + * Since the boot rom enables the write protection for NAND boot mode, + * it must be disabled somewhere for "nand write", "nand erase", etc. + * The workaround is here to not disturb the Denali NAND controller + * driver just for a really SoC-specific thing. + */ + void __iomem *denali_reg = (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + + writel(WRITE_PROTECT__FLAG, denali_reg + WRITE_PROTECT); +#endif +} + +static void nand_denali_fixup(void) +{ +#if defined(CONFIG_NAND_DENALI) && \ + (defined(CONFIG_MACH_PH1_SLD8) || defined(CONFIG_MACH_PH1_PRO4)) + /* + * The Denali NAND controller on some of UniPhier SoCs does not + * automatically query the device parameters. For those SoCs, + * some registers must be set after the device is probed. + */ + void __iomem *denali_reg = (void __iomem *)CONFIG_SYS_NAND_REGS_BASE; + struct mtd_info *mtd; + struct nand_chip *chip; + + if (nand_curr_device < 0 || + nand_curr_device >= CONFIG_SYS_MAX_NAND_DEVICE) { + /* NAND was not detected. Just return. */ + return; + } + + mtd = &nand_info[nand_curr_device]; + chip = mtd->priv; + + writel(mtd->erasesize / mtd->writesize, denali_reg + PAGES_PER_BLOCK); + writel(0, denali_reg + DEVICE_WIDTH); + writel(mtd->writesize, denali_reg + DEVICE_MAIN_AREA_SIZE); + writel(mtd->oobsize, denali_reg + DEVICE_SPARE_AREA_SIZE); + writel(1, denali_reg + DEVICES_CONNECTED); + + /* + * chip->scan_bbt in nand_scan_tail() has been skipped. + * It should be done in here. + */ + chip->scan_bbt(mtd); +#endif +} + +int board_late_init(void) +{ + puts("MODE: "); + + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: + printf("eMMC Boot\n"); + setenv("bootmode", "emmcboot"); + nand_denali_fixup(); + break; + case BOOT_DEVICE_NAND: + printf("NAND Boot\n"); + setenv("bootmode", "nandboot"); + nand_denali_wp_disable(); + break; + case BOOT_DEVICE_NOR: + printf("NOR Boot\n"); + setenv("bootmode", "norboot"); + nand_denali_fixup(); + break; + default: + printf("Unsupported Boot Mode\n"); + return -1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/cache_uniphier.c b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c new file mode 100644 index 0000000..e47f977 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cache_uniphier.c @@ -0,0 +1,154 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/armv7.h> +#include <asm/arch/ssc-regs.h> + +#ifdef CONFIG_UNIPHIER_L2CACHE_ON +static void uniphier_cache_maint_all(u32 operation) +{ + /* try until the command is successfully set */ + do { + writel(SSCOQM_S_ALL | SSCOQM_CE | operation, SSCOQM); + } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(SSCOLPQS) != SSCOLPQS_EF) + ; + + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); + + writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */ + readl(SSCOPE); /* need a read back to confirm */ +} + +void v7_outer_cache_flush_all(void) +{ + uniphier_cache_maint_all(SSCOQM_CM_WB_INV); +} + +void v7_outer_cache_inval_all(void) +{ + uniphier_cache_maint_all(SSCOQM_CM_INV); +} + +static void __uniphier_cache_maint_range(u32 start, u32 size, u32 operation) +{ + /* try until the command is successfully set */ + do { + writel(SSCOQM_S_ADDRESS | SSCOQM_CE | operation, SSCOQM); + writel(start, SSCOQAD); + writel(size, SSCOQSZ); + + } while (readl(SSCOPPQSEF) & (SSCOPPQSEF_FE | SSCOPPQSEF_OE)); + + /* wait until the operation is completed */ + while (readl(SSCOLPQS) != SSCOLPQS_EF) + ; + + /* clear the complete notification flag */ + writel(SSCOLPQS_EF, SSCOLPQS); +} + +static void uniphier_cache_maint_range(u32 start, u32 end, u32 operation) +{ + u32 size; + + /* + * If start address is not aligned to cache-line, + * do cache operation for the first cache-line + */ + start = start & ~(SSC_LINE_SIZE - 1); + + if (start == 0 && end >= (u32)(-SSC_LINE_SIZE)) { + /* this means cache operation for all range */ + uniphier_cache_maint_all(operation); + return; + } + + /* + * If end address is not aligned to cache-line, + * do cache operation for the last cache-line + */ + size = (end - start + SSC_LINE_SIZE - 1) & ~(SSC_LINE_SIZE - 1); + + while (size) { + u32 chunk_size = size > SSC_RANGE_OP_MAX_SIZE ? + SSC_RANGE_OP_MAX_SIZE : size; + __uniphier_cache_maint_range(start, chunk_size, operation); + + start += chunk_size; + size -= chunk_size; + } + + writel(SSCOPE_CM_SYNC, SSCOPE); /* drain internal buffers */ + readl(SSCOPE); /* need a read back to confirm */ +} + +void v7_outer_cache_flush_range(u32 start, u32 end) +{ + uniphier_cache_maint_range(start, end, SSCOQM_CM_WB_INV); +} + +void v7_outer_cache_inval_range(u32 start, u32 end) +{ + uniphier_cache_maint_range(start, end, SSCOQM_CM_INV); +} + +void v7_outer_cache_enable(void) +{ + u32 tmp; + tmp = readl(SSCC); + tmp |= SSCC_ON; + writel(tmp, SSCC); +} +#endif + +void v7_outer_cache_disable(void) +{ + u32 tmp; + tmp = readl(SSCC); + tmp &= ~SSCC_ON; + writel(tmp, SSCC); +} + +void wakeup_secondary(void); + +void enable_caches(void) +{ + uint32_t reg; + +#ifdef CONFIG_UNIPHIER_SMP + /* + * The secondary CPU must move to DDR, + * before L2 disable. + * On SPL, the Page Table is located on the L2. + */ + wakeup_secondary(); +#endif + /* + * UniPhier SoCs must use L2 cache for init stack pointer. + * We disable L2 and L1 in this order. + * If CONFIG_SYS_DCACHE_OFF is not defined, + * caches are enabled again with a new page table. + */ + + /* L2 disable */ + v7_outer_cache_disable(); + + /* L1 disable */ + reg = get_cr(); + reg &= ~(CR_C | CR_M); + set_cr(reg); + +#ifndef CONFIG_SYS_DCACHE_OFF + dcache_enable(); +#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c new file mode 100644 index 0000000..eef9f39 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cmd_pinmon.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/boot-device.h> + +static int do_pinmon(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + struct boot_device_info *table; + u32 mode_sel, n = 0; + + mode_sel = get_boot_mode_sel(); + + puts("Boot Mode Pin:\n"); + + for (table = boot_device_table; strlen(table->info); table++) { + printf(" %c %02x %s\n", n == mode_sel ? '*' : ' ', n, + table->info); + n++; + } + + return 0; +} + +U_BOOT_CMD( + pinmon, 1, 1, do_pinmon, + "pin monitor", + "" +); diff --git a/arch/arm/cpu/armv7/uniphier/cpu_info.c b/arch/arm/cpu/armv7/uniphier/cpu_info.c new file mode 100644 index 0000000..86d079a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/cpu_info.c @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2013-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +int print_cpuinfo(void) +{ + u32 revision, type, model, rev, required_model = 1, required_rev = 1; + + revision = readl(SG_REVISION); + type = (revision & SG_REVISION_TYPE_MASK) >> SG_REVISION_TYPE_SHIFT; + model = (revision & SG_REVISION_MODEL_MASK) >> SG_REVISION_MODEL_SHIFT; + rev = (revision & SG_REVISION_REV_MASK) >> SG_REVISION_REV_SHIFT; + + puts("CPU: "); + + switch (type) { + case 0x25: + puts("PH1-sLD3 (MN2WS0220)"); + required_model = 2; + break; + case 0x26: + puts("PH1-LD4 (MN2WS0250)"); + required_rev = 2; + break; + case 0x28: + puts("PH1-Pro4 (MN2WS0230)"); + break; + case 0x29: + puts("PH1-sLD8 (MN2WS0270)"); + break; + default: + printf("Unknown Processor ID (0x%x)\n", revision); + return -1; + } + + if (model > 1) + printf(" model %d", model); + + printf(" (rev. %d)\n", rev); + + if (model < required_model) { + printf("Sorry, this model is not supported.\n"); + printf("Required model is %d.", required_model); + return -1; + } else if (rev < required_rev) { + printf("Sorry, this revision is not supported.\n"); + printf("Required revision is %d.", required_rev); + return -1; + } + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/dram_init.c b/arch/arm/cpu/armv7/uniphier/dram_init.c new file mode 100644 index 0000000..5465a0e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/dram_init.c @@ -0,0 +1,37 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> + +int umc_init(void); +void enable_dpll_ssc(void); + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + gd->ram_size = CONFIG_SYS_SDRAM_SIZE; + +#if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) + led_write(B, 4, , ); + + { + int res; + + res = umc_init(); + if (res < 0) + return res; + } + led_write(B, 5, , ); + + enable_dpll_ssc(); +#endif + + led_write(B, 6, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/init_page_table.c b/arch/arm/cpu/armv7/uniphier/init_page_table.c new file mode 100644 index 0000000..d273835 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/init_page_table.c @@ -0,0 +1,1068 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> + +/* encoding without TEX remap */ +#define NO_MAP 0x00000000 /* No Map */ +#define DEVICE 0x00002002 /* Non-shareable Device */ +#define NORMAL 0x0000000e /* Normal Memory Write-Back, No Write-Allocate */ + +#define SSC NORMAL /* System Cache: Normal */ +#define EXT DEVICE /* External Bus: Device */ +#define REG DEVICE /* IO Register: Device */ +#define DDR DEVICE /* DDR SDRAM: Device */ + +#ifdef CONFIG_SPL_BUILD +#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SPL_TEXT_BASE) >> 20)) +#else +#define IS_SPL_TEXT_AREA(x) ((x) == ((CONFIG_SYS_TEXT_BASE) >> 20)) +#endif + +#define IS_INIT_STACK_AREA(x) ((x) == ((CONFIG_SYS_INIT_SP_ADDR) >> 20)) + +#define IS_SSC(x) ((IS_SPL_TEXT_AREA(x)) || \ + (IS_INIT_STACK_AREA(x))) +#define IS_EXT(x) ((x) < 0x100) +#define IS_REG(x) (0x500 <= (x) && (x) < 0x700) +#define IS_DDR(x) (0x800 <= (x) && (x) < 0xf00) + +#define MMU_FLAGS(x) (IS_SSC(x)) ? SSC : \ + (IS_EXT(x)) ? EXT : \ + (IS_REG(x)) ? REG : \ + (IS_DDR(x)) ? DDR : \ + NO_MAP + +#define TBL_ENTRY(x) (((x) << 20) | (MMU_FLAGS(x))) + +const u32 __aligned(PGTABLE_SIZE) init_page_table[PGTABLE_SIZE / sizeof(u32)] + = { + TBL_ENTRY(0x000), TBL_ENTRY(0x001), TBL_ENTRY(0x002), TBL_ENTRY(0x003), + TBL_ENTRY(0x004), TBL_ENTRY(0x005), TBL_ENTRY(0x006), TBL_ENTRY(0x007), + TBL_ENTRY(0x008), TBL_ENTRY(0x009), TBL_ENTRY(0x00a), TBL_ENTRY(0x00b), + TBL_ENTRY(0x00c), TBL_ENTRY(0x00d), TBL_ENTRY(0x00e), TBL_ENTRY(0x00f), + TBL_ENTRY(0x010), TBL_ENTRY(0x011), TBL_ENTRY(0x012), TBL_ENTRY(0x013), + TBL_ENTRY(0x014), TBL_ENTRY(0x015), TBL_ENTRY(0x016), TBL_ENTRY(0x017), + TBL_ENTRY(0x018), TBL_ENTRY(0x019), TBL_ENTRY(0x01a), TBL_ENTRY(0x01b), + TBL_ENTRY(0x01c), TBL_ENTRY(0x01d), TBL_ENTRY(0x01e), TBL_ENTRY(0x01f), + TBL_ENTRY(0x020), TBL_ENTRY(0x021), TBL_ENTRY(0x022), TBL_ENTRY(0x023), + TBL_ENTRY(0x024), TBL_ENTRY(0x025), TBL_ENTRY(0x026), TBL_ENTRY(0x027), + TBL_ENTRY(0x028), TBL_ENTRY(0x029), TBL_ENTRY(0x02a), TBL_ENTRY(0x02b), + TBL_ENTRY(0x02c), TBL_ENTRY(0x02d), TBL_ENTRY(0x02e), TBL_ENTRY(0x02f), + TBL_ENTRY(0x030), TBL_ENTRY(0x031), TBL_ENTRY(0x032), TBL_ENTRY(0x033), + TBL_ENTRY(0x034), TBL_ENTRY(0x035), TBL_ENTRY(0x036), TBL_ENTRY(0x037), + TBL_ENTRY(0x038), TBL_ENTRY(0x039), TBL_ENTRY(0x03a), TBL_ENTRY(0x03b), + TBL_ENTRY(0x03c), TBL_ENTRY(0x03d), TBL_ENTRY(0x03e), TBL_ENTRY(0x03f), + TBL_ENTRY(0x040), TBL_ENTRY(0x041), TBL_ENTRY(0x042), TBL_ENTRY(0x043), + TBL_ENTRY(0x044), TBL_ENTRY(0x045), TBL_ENTRY(0x046), TBL_ENTRY(0x047), + TBL_ENTRY(0x048), TBL_ENTRY(0x049), TBL_ENTRY(0x04a), TBL_ENTRY(0x04b), + TBL_ENTRY(0x04c), TBL_ENTRY(0x04d), TBL_ENTRY(0x04e), TBL_ENTRY(0x04f), + TBL_ENTRY(0x050), TBL_ENTRY(0x051), TBL_ENTRY(0x052), TBL_ENTRY(0x053), + TBL_ENTRY(0x054), TBL_ENTRY(0x055), TBL_ENTRY(0x056), TBL_ENTRY(0x057), + TBL_ENTRY(0x058), TBL_ENTRY(0x059), TBL_ENTRY(0x05a), TBL_ENTRY(0x05b), + TBL_ENTRY(0x05c), TBL_ENTRY(0x05d), TBL_ENTRY(0x05e), TBL_ENTRY(0x05f), + TBL_ENTRY(0x060), TBL_ENTRY(0x061), TBL_ENTRY(0x062), TBL_ENTRY(0x063), + TBL_ENTRY(0x064), TBL_ENTRY(0x065), TBL_ENTRY(0x066), TBL_ENTRY(0x067), + TBL_ENTRY(0x068), TBL_ENTRY(0x069), TBL_ENTRY(0x06a), TBL_ENTRY(0x06b), + TBL_ENTRY(0x06c), TBL_ENTRY(0x06d), TBL_ENTRY(0x06e), TBL_ENTRY(0x06f), + TBL_ENTRY(0x070), TBL_ENTRY(0x071), TBL_ENTRY(0x072), TBL_ENTRY(0x073), + TBL_ENTRY(0x074), TBL_ENTRY(0x075), TBL_ENTRY(0x076), TBL_ENTRY(0x077), + TBL_ENTRY(0x078), TBL_ENTRY(0x079), TBL_ENTRY(0x07a), TBL_ENTRY(0x07b), + TBL_ENTRY(0x07c), TBL_ENTRY(0x07d), TBL_ENTRY(0x07e), TBL_ENTRY(0x07f), + TBL_ENTRY(0x080), TBL_ENTRY(0x081), TBL_ENTRY(0x082), TBL_ENTRY(0x083), + TBL_ENTRY(0x084), TBL_ENTRY(0x085), TBL_ENTRY(0x086), TBL_ENTRY(0x087), + TBL_ENTRY(0x088), TBL_ENTRY(0x089), TBL_ENTRY(0x08a), TBL_ENTRY(0x08b), + TBL_ENTRY(0x08c), TBL_ENTRY(0x08d), TBL_ENTRY(0x08e), TBL_ENTRY(0x08f), + TBL_ENTRY(0x090), TBL_ENTRY(0x091), TBL_ENTRY(0x092), TBL_ENTRY(0x093), + TBL_ENTRY(0x094), TBL_ENTRY(0x095), TBL_ENTRY(0x096), TBL_ENTRY(0x097), + TBL_ENTRY(0x098), TBL_ENTRY(0x099), TBL_ENTRY(0x09a), TBL_ENTRY(0x09b), + TBL_ENTRY(0x09c), TBL_ENTRY(0x09d), TBL_ENTRY(0x09e), TBL_ENTRY(0x09f), + TBL_ENTRY(0x0a0), TBL_ENTRY(0x0a1), TBL_ENTRY(0x0a2), TBL_ENTRY(0x0a3), + TBL_ENTRY(0x0a4), TBL_ENTRY(0x0a5), TBL_ENTRY(0x0a6), TBL_ENTRY(0x0a7), + TBL_ENTRY(0x0a8), TBL_ENTRY(0x0a9), TBL_ENTRY(0x0aa), TBL_ENTRY(0x0ab), + TBL_ENTRY(0x0ac), TBL_ENTRY(0x0ad), TBL_ENTRY(0x0ae), TBL_ENTRY(0x0af), + TBL_ENTRY(0x0b0), TBL_ENTRY(0x0b1), TBL_ENTRY(0x0b2), TBL_ENTRY(0x0b3), + TBL_ENTRY(0x0b4), TBL_ENTRY(0x0b5), TBL_ENTRY(0x0b6), TBL_ENTRY(0x0b7), + TBL_ENTRY(0x0b8), TBL_ENTRY(0x0b9), TBL_ENTRY(0x0ba), TBL_ENTRY(0x0bb), + TBL_ENTRY(0x0bc), TBL_ENTRY(0x0bd), TBL_ENTRY(0x0be), TBL_ENTRY(0x0bf), + TBL_ENTRY(0x0c0), TBL_ENTRY(0x0c1), TBL_ENTRY(0x0c2), TBL_ENTRY(0x0c3), + TBL_ENTRY(0x0c4), TBL_ENTRY(0x0c5), TBL_ENTRY(0x0c6), TBL_ENTRY(0x0c7), + TBL_ENTRY(0x0c8), TBL_ENTRY(0x0c9), TBL_ENTRY(0x0ca), TBL_ENTRY(0x0cb), + TBL_ENTRY(0x0cc), TBL_ENTRY(0x0cd), TBL_ENTRY(0x0ce), TBL_ENTRY(0x0cf), + TBL_ENTRY(0x0d0), TBL_ENTRY(0x0d1), TBL_ENTRY(0x0d2), TBL_ENTRY(0x0d3), + TBL_ENTRY(0x0d4), TBL_ENTRY(0x0d5), TBL_ENTRY(0x0d6), TBL_ENTRY(0x0d7), + TBL_ENTRY(0x0d8), TBL_ENTRY(0x0d9), TBL_ENTRY(0x0da), TBL_ENTRY(0x0db), + TBL_ENTRY(0x0dc), TBL_ENTRY(0x0dd), TBL_ENTRY(0x0de), TBL_ENTRY(0x0df), + TBL_ENTRY(0x0e0), TBL_ENTRY(0x0e1), TBL_ENTRY(0x0e2), TBL_ENTRY(0x0e3), + TBL_ENTRY(0x0e4), TBL_ENTRY(0x0e5), TBL_ENTRY(0x0e6), TBL_ENTRY(0x0e7), + TBL_ENTRY(0x0e8), TBL_ENTRY(0x0e9), TBL_ENTRY(0x0ea), TBL_ENTRY(0x0eb), + TBL_ENTRY(0x0ec), TBL_ENTRY(0x0ed), TBL_ENTRY(0x0ee), TBL_ENTRY(0x0ef), + TBL_ENTRY(0x0f0), TBL_ENTRY(0x0f1), TBL_ENTRY(0x0f2), TBL_ENTRY(0x0f3), + TBL_ENTRY(0x0f4), TBL_ENTRY(0x0f5), TBL_ENTRY(0x0f6), TBL_ENTRY(0x0f7), + TBL_ENTRY(0x0f8), TBL_ENTRY(0x0f9), TBL_ENTRY(0x0fa), TBL_ENTRY(0x0fb), + TBL_ENTRY(0x0fc), TBL_ENTRY(0x0fd), TBL_ENTRY(0x0fe), TBL_ENTRY(0x0ff), + TBL_ENTRY(0x100), TBL_ENTRY(0x101), TBL_ENTRY(0x102), TBL_ENTRY(0x103), + TBL_ENTRY(0x104), TBL_ENTRY(0x105), TBL_ENTRY(0x106), TBL_ENTRY(0x107), + TBL_ENTRY(0x108), TBL_ENTRY(0x109), TBL_ENTRY(0x10a), TBL_ENTRY(0x10b), + TBL_ENTRY(0x10c), TBL_ENTRY(0x10d), TBL_ENTRY(0x10e), TBL_ENTRY(0x10f), + TBL_ENTRY(0x110), TBL_ENTRY(0x111), TBL_ENTRY(0x112), TBL_ENTRY(0x113), + TBL_ENTRY(0x114), TBL_ENTRY(0x115), TBL_ENTRY(0x116), TBL_ENTRY(0x117), + TBL_ENTRY(0x118), TBL_ENTRY(0x119), TBL_ENTRY(0x11a), TBL_ENTRY(0x11b), + TBL_ENTRY(0x11c), TBL_ENTRY(0x11d), TBL_ENTRY(0x11e), TBL_ENTRY(0x11f), + TBL_ENTRY(0x120), TBL_ENTRY(0x121), TBL_ENTRY(0x122), TBL_ENTRY(0x123), + TBL_ENTRY(0x124), TBL_ENTRY(0x125), TBL_ENTRY(0x126), TBL_ENTRY(0x127), + TBL_ENTRY(0x128), TBL_ENTRY(0x129), TBL_ENTRY(0x12a), TBL_ENTRY(0x12b), + TBL_ENTRY(0x12c), TBL_ENTRY(0x12d), TBL_ENTRY(0x12e), TBL_ENTRY(0x12f), + TBL_ENTRY(0x130), TBL_ENTRY(0x131), TBL_ENTRY(0x132), TBL_ENTRY(0x133), + TBL_ENTRY(0x134), TBL_ENTRY(0x135), TBL_ENTRY(0x136), TBL_ENTRY(0x137), + TBL_ENTRY(0x138), TBL_ENTRY(0x139), TBL_ENTRY(0x13a), TBL_ENTRY(0x13b), + TBL_ENTRY(0x13c), TBL_ENTRY(0x13d), TBL_ENTRY(0x13e), TBL_ENTRY(0x13f), + TBL_ENTRY(0x140), TBL_ENTRY(0x141), TBL_ENTRY(0x142), TBL_ENTRY(0x143), + TBL_ENTRY(0x144), TBL_ENTRY(0x145), TBL_ENTRY(0x146), TBL_ENTRY(0x147), + TBL_ENTRY(0x148), TBL_ENTRY(0x149), TBL_ENTRY(0x14a), TBL_ENTRY(0x14b), + TBL_ENTRY(0x14c), TBL_ENTRY(0x14d), TBL_ENTRY(0x14e), TBL_ENTRY(0x14f), + TBL_ENTRY(0x150), TBL_ENTRY(0x151), TBL_ENTRY(0x152), TBL_ENTRY(0x153), + TBL_ENTRY(0x154), TBL_ENTRY(0x155), TBL_ENTRY(0x156), TBL_ENTRY(0x157), + TBL_ENTRY(0x158), TBL_ENTRY(0x159), TBL_ENTRY(0x15a), TBL_ENTRY(0x15b), + TBL_ENTRY(0x15c), TBL_ENTRY(0x15d), TBL_ENTRY(0x15e), TBL_ENTRY(0x15f), + TBL_ENTRY(0x160), TBL_ENTRY(0x161), TBL_ENTRY(0x162), TBL_ENTRY(0x163), + TBL_ENTRY(0x164), TBL_ENTRY(0x165), TBL_ENTRY(0x166), TBL_ENTRY(0x167), + TBL_ENTRY(0x168), TBL_ENTRY(0x169), TBL_ENTRY(0x16a), TBL_ENTRY(0x16b), + TBL_ENTRY(0x16c), TBL_ENTRY(0x16d), TBL_ENTRY(0x16e), TBL_ENTRY(0x16f), + TBL_ENTRY(0x170), TBL_ENTRY(0x171), TBL_ENTRY(0x172), TBL_ENTRY(0x173), + TBL_ENTRY(0x174), TBL_ENTRY(0x175), TBL_ENTRY(0x176), TBL_ENTRY(0x177), + TBL_ENTRY(0x178), TBL_ENTRY(0x179), TBL_ENTRY(0x17a), TBL_ENTRY(0x17b), + TBL_ENTRY(0x17c), TBL_ENTRY(0x17d), TBL_ENTRY(0x17e), TBL_ENTRY(0x17f), + TBL_ENTRY(0x180), TBL_ENTRY(0x181), TBL_ENTRY(0x182), TBL_ENTRY(0x183), + TBL_ENTRY(0x184), TBL_ENTRY(0x185), TBL_ENTRY(0x186), TBL_ENTRY(0x187), + TBL_ENTRY(0x188), TBL_ENTRY(0x189), TBL_ENTRY(0x18a), TBL_ENTRY(0x18b), + TBL_ENTRY(0x18c), TBL_ENTRY(0x18d), TBL_ENTRY(0x18e), TBL_ENTRY(0x18f), + TBL_ENTRY(0x190), TBL_ENTRY(0x191), TBL_ENTRY(0x192), TBL_ENTRY(0x193), + TBL_ENTRY(0x194), TBL_ENTRY(0x195), TBL_ENTRY(0x196), TBL_ENTRY(0x197), + TBL_ENTRY(0x198), TBL_ENTRY(0x199), TBL_ENTRY(0x19a), TBL_ENTRY(0x19b), + TBL_ENTRY(0x19c), TBL_ENTRY(0x19d), TBL_ENTRY(0x19e), TBL_ENTRY(0x19f), + TBL_ENTRY(0x1a0), TBL_ENTRY(0x1a1), TBL_ENTRY(0x1a2), TBL_ENTRY(0x1a3), + TBL_ENTRY(0x1a4), TBL_ENTRY(0x1a5), TBL_ENTRY(0x1a6), TBL_ENTRY(0x1a7), + TBL_ENTRY(0x1a8), TBL_ENTRY(0x1a9), TBL_ENTRY(0x1aa), TBL_ENTRY(0x1ab), + TBL_ENTRY(0x1ac), TBL_ENTRY(0x1ad), TBL_ENTRY(0x1ae), TBL_ENTRY(0x1af), + TBL_ENTRY(0x1b0), TBL_ENTRY(0x1b1), TBL_ENTRY(0x1b2), TBL_ENTRY(0x1b3), + TBL_ENTRY(0x1b4), TBL_ENTRY(0x1b5), TBL_ENTRY(0x1b6), TBL_ENTRY(0x1b7), + TBL_ENTRY(0x1b8), TBL_ENTRY(0x1b9), TBL_ENTRY(0x1ba), TBL_ENTRY(0x1bb), + TBL_ENTRY(0x1bc), TBL_ENTRY(0x1bd), TBL_ENTRY(0x1be), TBL_ENTRY(0x1bf), + TBL_ENTRY(0x1c0), TBL_ENTRY(0x1c1), TBL_ENTRY(0x1c2), TBL_ENTRY(0x1c3), + TBL_ENTRY(0x1c4), TBL_ENTRY(0x1c5), TBL_ENTRY(0x1c6), TBL_ENTRY(0x1c7), + TBL_ENTRY(0x1c8), TBL_ENTRY(0x1c9), TBL_ENTRY(0x1ca), TBL_ENTRY(0x1cb), + TBL_ENTRY(0x1cc), TBL_ENTRY(0x1cd), TBL_ENTRY(0x1ce), TBL_ENTRY(0x1cf), + TBL_ENTRY(0x1d0), TBL_ENTRY(0x1d1), TBL_ENTRY(0x1d2), TBL_ENTRY(0x1d3), + TBL_ENTRY(0x1d4), TBL_ENTRY(0x1d5), TBL_ENTRY(0x1d6), TBL_ENTRY(0x1d7), + TBL_ENTRY(0x1d8), TBL_ENTRY(0x1d9), TBL_ENTRY(0x1da), TBL_ENTRY(0x1db), + TBL_ENTRY(0x1dc), TBL_ENTRY(0x1dd), TBL_ENTRY(0x1de), TBL_ENTRY(0x1df), + TBL_ENTRY(0x1e0), TBL_ENTRY(0x1e1), TBL_ENTRY(0x1e2), TBL_ENTRY(0x1e3), + TBL_ENTRY(0x1e4), TBL_ENTRY(0x1e5), TBL_ENTRY(0x1e6), TBL_ENTRY(0x1e7), + TBL_ENTRY(0x1e8), TBL_ENTRY(0x1e9), TBL_ENTRY(0x1ea), TBL_ENTRY(0x1eb), + TBL_ENTRY(0x1ec), TBL_ENTRY(0x1ed), TBL_ENTRY(0x1ee), TBL_ENTRY(0x1ef), + TBL_ENTRY(0x1f0), TBL_ENTRY(0x1f1), TBL_ENTRY(0x1f2), TBL_ENTRY(0x1f3), + TBL_ENTRY(0x1f4), TBL_ENTRY(0x1f5), TBL_ENTRY(0x1f6), TBL_ENTRY(0x1f7), + TBL_ENTRY(0x1f8), TBL_ENTRY(0x1f9), TBL_ENTRY(0x1fa), TBL_ENTRY(0x1fb), + TBL_ENTRY(0x1fc), TBL_ENTRY(0x1fd), TBL_ENTRY(0x1fe), TBL_ENTRY(0x1ff), + TBL_ENTRY(0x200), TBL_ENTRY(0x201), TBL_ENTRY(0x202), TBL_ENTRY(0x203), + TBL_ENTRY(0x204), TBL_ENTRY(0x205), TBL_ENTRY(0x206), TBL_ENTRY(0x207), + TBL_ENTRY(0x208), TBL_ENTRY(0x209), TBL_ENTRY(0x20a), TBL_ENTRY(0x20b), + TBL_ENTRY(0x20c), TBL_ENTRY(0x20d), TBL_ENTRY(0x20e), TBL_ENTRY(0x20f), + TBL_ENTRY(0x210), TBL_ENTRY(0x211), TBL_ENTRY(0x212), TBL_ENTRY(0x213), + TBL_ENTRY(0x214), TBL_ENTRY(0x215), TBL_ENTRY(0x216), TBL_ENTRY(0x217), + TBL_ENTRY(0x218), TBL_ENTRY(0x219), TBL_ENTRY(0x21a), TBL_ENTRY(0x21b), + TBL_ENTRY(0x21c), TBL_ENTRY(0x21d), TBL_ENTRY(0x21e), TBL_ENTRY(0x21f), + TBL_ENTRY(0x220), TBL_ENTRY(0x221), TBL_ENTRY(0x222), TBL_ENTRY(0x223), + TBL_ENTRY(0x224), TBL_ENTRY(0x225), TBL_ENTRY(0x226), TBL_ENTRY(0x227), + TBL_ENTRY(0x228), TBL_ENTRY(0x229), TBL_ENTRY(0x22a), TBL_ENTRY(0x22b), + TBL_ENTRY(0x22c), TBL_ENTRY(0x22d), TBL_ENTRY(0x22e), TBL_ENTRY(0x22f), + TBL_ENTRY(0x230), TBL_ENTRY(0x231), TBL_ENTRY(0x232), TBL_ENTRY(0x233), + TBL_ENTRY(0x234), TBL_ENTRY(0x235), TBL_ENTRY(0x236), TBL_ENTRY(0x237), + TBL_ENTRY(0x238), TBL_ENTRY(0x239), TBL_ENTRY(0x23a), TBL_ENTRY(0x23b), + TBL_ENTRY(0x23c), TBL_ENTRY(0x23d), TBL_ENTRY(0x23e), TBL_ENTRY(0x23f), + TBL_ENTRY(0x240), TBL_ENTRY(0x241), TBL_ENTRY(0x242), TBL_ENTRY(0x243), + TBL_ENTRY(0x244), TBL_ENTRY(0x245), TBL_ENTRY(0x246), TBL_ENTRY(0x247), + TBL_ENTRY(0x248), TBL_ENTRY(0x249), TBL_ENTRY(0x24a), TBL_ENTRY(0x24b), + TBL_ENTRY(0x24c), TBL_ENTRY(0x24d), TBL_ENTRY(0x24e), TBL_ENTRY(0x24f), + TBL_ENTRY(0x250), TBL_ENTRY(0x251), TBL_ENTRY(0x252), TBL_ENTRY(0x253), + TBL_ENTRY(0x254), TBL_ENTRY(0x255), TBL_ENTRY(0x256), TBL_ENTRY(0x257), + TBL_ENTRY(0x258), TBL_ENTRY(0x259), TBL_ENTRY(0x25a), TBL_ENTRY(0x25b), + TBL_ENTRY(0x25c), TBL_ENTRY(0x25d), TBL_ENTRY(0x25e), TBL_ENTRY(0x25f), + TBL_ENTRY(0x260), TBL_ENTRY(0x261), TBL_ENTRY(0x262), TBL_ENTRY(0x263), + TBL_ENTRY(0x264), TBL_ENTRY(0x265), TBL_ENTRY(0x266), TBL_ENTRY(0x267), + TBL_ENTRY(0x268), TBL_ENTRY(0x269), TBL_ENTRY(0x26a), TBL_ENTRY(0x26b), + TBL_ENTRY(0x26c), TBL_ENTRY(0x26d), TBL_ENTRY(0x26e), TBL_ENTRY(0x26f), + TBL_ENTRY(0x270), TBL_ENTRY(0x271), TBL_ENTRY(0x272), TBL_ENTRY(0x273), + TBL_ENTRY(0x274), TBL_ENTRY(0x275), TBL_ENTRY(0x276), TBL_ENTRY(0x277), + TBL_ENTRY(0x278), TBL_ENTRY(0x279), TBL_ENTRY(0x27a), TBL_ENTRY(0x27b), + TBL_ENTRY(0x27c), TBL_ENTRY(0x27d), TBL_ENTRY(0x27e), TBL_ENTRY(0x27f), + TBL_ENTRY(0x280), TBL_ENTRY(0x281), TBL_ENTRY(0x282), TBL_ENTRY(0x283), + TBL_ENTRY(0x284), TBL_ENTRY(0x285), TBL_ENTRY(0x286), TBL_ENTRY(0x287), + TBL_ENTRY(0x288), TBL_ENTRY(0x289), TBL_ENTRY(0x28a), TBL_ENTRY(0x28b), + TBL_ENTRY(0x28c), TBL_ENTRY(0x28d), TBL_ENTRY(0x28e), TBL_ENTRY(0x28f), + TBL_ENTRY(0x290), TBL_ENTRY(0x291), TBL_ENTRY(0x292), TBL_ENTRY(0x293), + TBL_ENTRY(0x294), TBL_ENTRY(0x295), TBL_ENTRY(0x296), TBL_ENTRY(0x297), + TBL_ENTRY(0x298), TBL_ENTRY(0x299), TBL_ENTRY(0x29a), TBL_ENTRY(0x29b), + TBL_ENTRY(0x29c), TBL_ENTRY(0x29d), TBL_ENTRY(0x29e), TBL_ENTRY(0x29f), + TBL_ENTRY(0x2a0), TBL_ENTRY(0x2a1), TBL_ENTRY(0x2a2), TBL_ENTRY(0x2a3), + TBL_ENTRY(0x2a4), TBL_ENTRY(0x2a5), TBL_ENTRY(0x2a6), TBL_ENTRY(0x2a7), + TBL_ENTRY(0x2a8), TBL_ENTRY(0x2a9), TBL_ENTRY(0x2aa), TBL_ENTRY(0x2ab), + TBL_ENTRY(0x2ac), TBL_ENTRY(0x2ad), TBL_ENTRY(0x2ae), TBL_ENTRY(0x2af), + TBL_ENTRY(0x2b0), TBL_ENTRY(0x2b1), TBL_ENTRY(0x2b2), TBL_ENTRY(0x2b3), + TBL_ENTRY(0x2b4), TBL_ENTRY(0x2b5), TBL_ENTRY(0x2b6), TBL_ENTRY(0x2b7), + TBL_ENTRY(0x2b8), TBL_ENTRY(0x2b9), TBL_ENTRY(0x2ba), TBL_ENTRY(0x2bb), + TBL_ENTRY(0x2bc), TBL_ENTRY(0x2bd), TBL_ENTRY(0x2be), TBL_ENTRY(0x2bf), + TBL_ENTRY(0x2c0), TBL_ENTRY(0x2c1), TBL_ENTRY(0x2c2), TBL_ENTRY(0x2c3), + TBL_ENTRY(0x2c4), TBL_ENTRY(0x2c5), TBL_ENTRY(0x2c6), TBL_ENTRY(0x2c7), + TBL_ENTRY(0x2c8), TBL_ENTRY(0x2c9), TBL_ENTRY(0x2ca), TBL_ENTRY(0x2cb), + TBL_ENTRY(0x2cc), TBL_ENTRY(0x2cd), TBL_ENTRY(0x2ce), TBL_ENTRY(0x2cf), + TBL_ENTRY(0x2d0), TBL_ENTRY(0x2d1), TBL_ENTRY(0x2d2), TBL_ENTRY(0x2d3), + TBL_ENTRY(0x2d4), TBL_ENTRY(0x2d5), TBL_ENTRY(0x2d6), TBL_ENTRY(0x2d7), + TBL_ENTRY(0x2d8), TBL_ENTRY(0x2d9), TBL_ENTRY(0x2da), TBL_ENTRY(0x2db), + TBL_ENTRY(0x2dc), TBL_ENTRY(0x2dd), TBL_ENTRY(0x2de), TBL_ENTRY(0x2df), + TBL_ENTRY(0x2e0), TBL_ENTRY(0x2e1), TBL_ENTRY(0x2e2), TBL_ENTRY(0x2e3), + TBL_ENTRY(0x2e4), TBL_ENTRY(0x2e5), TBL_ENTRY(0x2e6), TBL_ENTRY(0x2e7), + TBL_ENTRY(0x2e8), TBL_ENTRY(0x2e9), TBL_ENTRY(0x2ea), TBL_ENTRY(0x2eb), + TBL_ENTRY(0x2ec), TBL_ENTRY(0x2ed), TBL_ENTRY(0x2ee), TBL_ENTRY(0x2ef), + TBL_ENTRY(0x2f0), TBL_ENTRY(0x2f1), TBL_ENTRY(0x2f2), TBL_ENTRY(0x2f3), + TBL_ENTRY(0x2f4), TBL_ENTRY(0x2f5), TBL_ENTRY(0x2f6), TBL_ENTRY(0x2f7), + TBL_ENTRY(0x2f8), TBL_ENTRY(0x2f9), TBL_ENTRY(0x2fa), TBL_ENTRY(0x2fb), + TBL_ENTRY(0x2fc), TBL_ENTRY(0x2fd), TBL_ENTRY(0x2fe), TBL_ENTRY(0x2ff), + TBL_ENTRY(0x300), TBL_ENTRY(0x301), TBL_ENTRY(0x302), TBL_ENTRY(0x303), + TBL_ENTRY(0x304), TBL_ENTRY(0x305), TBL_ENTRY(0x306), TBL_ENTRY(0x307), + TBL_ENTRY(0x308), TBL_ENTRY(0x309), TBL_ENTRY(0x30a), TBL_ENTRY(0x30b), + TBL_ENTRY(0x30c), TBL_ENTRY(0x30d), TBL_ENTRY(0x30e), TBL_ENTRY(0x30f), + TBL_ENTRY(0x310), TBL_ENTRY(0x311), TBL_ENTRY(0x312), TBL_ENTRY(0x313), + TBL_ENTRY(0x314), TBL_ENTRY(0x315), TBL_ENTRY(0x316), TBL_ENTRY(0x317), + TBL_ENTRY(0x318), TBL_ENTRY(0x319), TBL_ENTRY(0x31a), TBL_ENTRY(0x31b), + TBL_ENTRY(0x31c), TBL_ENTRY(0x31d), TBL_ENTRY(0x31e), TBL_ENTRY(0x31f), + TBL_ENTRY(0x320), TBL_ENTRY(0x321), TBL_ENTRY(0x322), TBL_ENTRY(0x323), + TBL_ENTRY(0x324), TBL_ENTRY(0x325), TBL_ENTRY(0x326), TBL_ENTRY(0x327), + TBL_ENTRY(0x328), TBL_ENTRY(0x329), TBL_ENTRY(0x32a), TBL_ENTRY(0x32b), + TBL_ENTRY(0x32c), TBL_ENTRY(0x32d), TBL_ENTRY(0x32e), TBL_ENTRY(0x32f), + TBL_ENTRY(0x330), TBL_ENTRY(0x331), TBL_ENTRY(0x332), TBL_ENTRY(0x333), + TBL_ENTRY(0x334), TBL_ENTRY(0x335), TBL_ENTRY(0x336), TBL_ENTRY(0x337), + TBL_ENTRY(0x338), TBL_ENTRY(0x339), TBL_ENTRY(0x33a), TBL_ENTRY(0x33b), + TBL_ENTRY(0x33c), TBL_ENTRY(0x33d), TBL_ENTRY(0x33e), TBL_ENTRY(0x33f), + TBL_ENTRY(0x340), TBL_ENTRY(0x341), TBL_ENTRY(0x342), TBL_ENTRY(0x343), + TBL_ENTRY(0x344), TBL_ENTRY(0x345), TBL_ENTRY(0x346), TBL_ENTRY(0x347), + TBL_ENTRY(0x348), TBL_ENTRY(0x349), TBL_ENTRY(0x34a), TBL_ENTRY(0x34b), + TBL_ENTRY(0x34c), TBL_ENTRY(0x34d), TBL_ENTRY(0x34e), TBL_ENTRY(0x34f), + TBL_ENTRY(0x350), TBL_ENTRY(0x351), TBL_ENTRY(0x352), TBL_ENTRY(0x353), + TBL_ENTRY(0x354), TBL_ENTRY(0x355), TBL_ENTRY(0x356), TBL_ENTRY(0x357), + TBL_ENTRY(0x358), TBL_ENTRY(0x359), TBL_ENTRY(0x35a), TBL_ENTRY(0x35b), + TBL_ENTRY(0x35c), TBL_ENTRY(0x35d), TBL_ENTRY(0x35e), TBL_ENTRY(0x35f), + TBL_ENTRY(0x360), TBL_ENTRY(0x361), TBL_ENTRY(0x362), TBL_ENTRY(0x363), + TBL_ENTRY(0x364), TBL_ENTRY(0x365), TBL_ENTRY(0x366), TBL_ENTRY(0x367), + TBL_ENTRY(0x368), TBL_ENTRY(0x369), TBL_ENTRY(0x36a), TBL_ENTRY(0x36b), + TBL_ENTRY(0x36c), TBL_ENTRY(0x36d), TBL_ENTRY(0x36e), TBL_ENTRY(0x36f), + TBL_ENTRY(0x370), TBL_ENTRY(0x371), TBL_ENTRY(0x372), TBL_ENTRY(0x373), + TBL_ENTRY(0x374), TBL_ENTRY(0x375), TBL_ENTRY(0x376), TBL_ENTRY(0x377), + TBL_ENTRY(0x378), TBL_ENTRY(0x379), TBL_ENTRY(0x37a), TBL_ENTRY(0x37b), + TBL_ENTRY(0x37c), TBL_ENTRY(0x37d), TBL_ENTRY(0x37e), TBL_ENTRY(0x37f), + TBL_ENTRY(0x380), TBL_ENTRY(0x381), TBL_ENTRY(0x382), TBL_ENTRY(0x383), + TBL_ENTRY(0x384), TBL_ENTRY(0x385), TBL_ENTRY(0x386), TBL_ENTRY(0x387), + TBL_ENTRY(0x388), TBL_ENTRY(0x389), TBL_ENTRY(0x38a), TBL_ENTRY(0x38b), + TBL_ENTRY(0x38c), TBL_ENTRY(0x38d), TBL_ENTRY(0x38e), TBL_ENTRY(0x38f), + TBL_ENTRY(0x390), TBL_ENTRY(0x391), TBL_ENTRY(0x392), TBL_ENTRY(0x393), + TBL_ENTRY(0x394), TBL_ENTRY(0x395), TBL_ENTRY(0x396), TBL_ENTRY(0x397), + TBL_ENTRY(0x398), TBL_ENTRY(0x399), TBL_ENTRY(0x39a), TBL_ENTRY(0x39b), + TBL_ENTRY(0x39c), TBL_ENTRY(0x39d), TBL_ENTRY(0x39e), TBL_ENTRY(0x39f), + TBL_ENTRY(0x3a0), TBL_ENTRY(0x3a1), TBL_ENTRY(0x3a2), TBL_ENTRY(0x3a3), + TBL_ENTRY(0x3a4), TBL_ENTRY(0x3a5), TBL_ENTRY(0x3a6), TBL_ENTRY(0x3a7), + TBL_ENTRY(0x3a8), TBL_ENTRY(0x3a9), TBL_ENTRY(0x3aa), TBL_ENTRY(0x3ab), + TBL_ENTRY(0x3ac), TBL_ENTRY(0x3ad), TBL_ENTRY(0x3ae), TBL_ENTRY(0x3af), + TBL_ENTRY(0x3b0), TBL_ENTRY(0x3b1), TBL_ENTRY(0x3b2), TBL_ENTRY(0x3b3), + TBL_ENTRY(0x3b4), TBL_ENTRY(0x3b5), TBL_ENTRY(0x3b6), TBL_ENTRY(0x3b7), + TBL_ENTRY(0x3b8), TBL_ENTRY(0x3b9), TBL_ENTRY(0x3ba), TBL_ENTRY(0x3bb), + TBL_ENTRY(0x3bc), TBL_ENTRY(0x3bd), TBL_ENTRY(0x3be), TBL_ENTRY(0x3bf), + TBL_ENTRY(0x3c0), TBL_ENTRY(0x3c1), TBL_ENTRY(0x3c2), TBL_ENTRY(0x3c3), + TBL_ENTRY(0x3c4), TBL_ENTRY(0x3c5), TBL_ENTRY(0x3c6), TBL_ENTRY(0x3c7), + TBL_ENTRY(0x3c8), TBL_ENTRY(0x3c9), TBL_ENTRY(0x3ca), TBL_ENTRY(0x3cb), + TBL_ENTRY(0x3cc), TBL_ENTRY(0x3cd), TBL_ENTRY(0x3ce), TBL_ENTRY(0x3cf), + TBL_ENTRY(0x3d0), TBL_ENTRY(0x3d1), TBL_ENTRY(0x3d2), TBL_ENTRY(0x3d3), + TBL_ENTRY(0x3d4), TBL_ENTRY(0x3d5), TBL_ENTRY(0x3d6), TBL_ENTRY(0x3d7), + TBL_ENTRY(0x3d8), TBL_ENTRY(0x3d9), TBL_ENTRY(0x3da), TBL_ENTRY(0x3db), + TBL_ENTRY(0x3dc), TBL_ENTRY(0x3dd), TBL_ENTRY(0x3de), TBL_ENTRY(0x3df), + TBL_ENTRY(0x3e0), TBL_ENTRY(0x3e1), TBL_ENTRY(0x3e2), TBL_ENTRY(0x3e3), + TBL_ENTRY(0x3e4), TBL_ENTRY(0x3e5), TBL_ENTRY(0x3e6), TBL_ENTRY(0x3e7), + TBL_ENTRY(0x3e8), TBL_ENTRY(0x3e9), TBL_ENTRY(0x3ea), TBL_ENTRY(0x3eb), + TBL_ENTRY(0x3ec), TBL_ENTRY(0x3ed), TBL_ENTRY(0x3ee), TBL_ENTRY(0x3ef), + TBL_ENTRY(0x3f0), TBL_ENTRY(0x3f1), TBL_ENTRY(0x3f2), TBL_ENTRY(0x3f3), + TBL_ENTRY(0x3f4), TBL_ENTRY(0x3f5), TBL_ENTRY(0x3f6), TBL_ENTRY(0x3f7), + TBL_ENTRY(0x3f8), TBL_ENTRY(0x3f9), TBL_ENTRY(0x3fa), TBL_ENTRY(0x3fb), + TBL_ENTRY(0x3fc), TBL_ENTRY(0x3fd), TBL_ENTRY(0x3fe), TBL_ENTRY(0x3ff), + TBL_ENTRY(0x400), TBL_ENTRY(0x401), TBL_ENTRY(0x402), TBL_ENTRY(0x403), + TBL_ENTRY(0x404), TBL_ENTRY(0x405), TBL_ENTRY(0x406), TBL_ENTRY(0x407), + TBL_ENTRY(0x408), TBL_ENTRY(0x409), TBL_ENTRY(0x40a), TBL_ENTRY(0x40b), + TBL_ENTRY(0x40c), TBL_ENTRY(0x40d), TBL_ENTRY(0x40e), TBL_ENTRY(0x40f), + TBL_ENTRY(0x410), TBL_ENTRY(0x411), TBL_ENTRY(0x412), TBL_ENTRY(0x413), + TBL_ENTRY(0x414), TBL_ENTRY(0x415), TBL_ENTRY(0x416), TBL_ENTRY(0x417), + TBL_ENTRY(0x418), TBL_ENTRY(0x419), TBL_ENTRY(0x41a), TBL_ENTRY(0x41b), + TBL_ENTRY(0x41c), TBL_ENTRY(0x41d), TBL_ENTRY(0x41e), TBL_ENTRY(0x41f), + TBL_ENTRY(0x420), TBL_ENTRY(0x421), TBL_ENTRY(0x422), TBL_ENTRY(0x423), + TBL_ENTRY(0x424), TBL_ENTRY(0x425), TBL_ENTRY(0x426), TBL_ENTRY(0x427), + TBL_ENTRY(0x428), TBL_ENTRY(0x429), TBL_ENTRY(0x42a), TBL_ENTRY(0x42b), + TBL_ENTRY(0x42c), TBL_ENTRY(0x42d), TBL_ENTRY(0x42e), TBL_ENTRY(0x42f), + TBL_ENTRY(0x430), TBL_ENTRY(0x431), TBL_ENTRY(0x432), TBL_ENTRY(0x433), + TBL_ENTRY(0x434), TBL_ENTRY(0x435), TBL_ENTRY(0x436), TBL_ENTRY(0x437), + TBL_ENTRY(0x438), TBL_ENTRY(0x439), TBL_ENTRY(0x43a), TBL_ENTRY(0x43b), + TBL_ENTRY(0x43c), TBL_ENTRY(0x43d), TBL_ENTRY(0x43e), TBL_ENTRY(0x43f), + TBL_ENTRY(0x440), TBL_ENTRY(0x441), TBL_ENTRY(0x442), TBL_ENTRY(0x443), + TBL_ENTRY(0x444), TBL_ENTRY(0x445), TBL_ENTRY(0x446), TBL_ENTRY(0x447), + TBL_ENTRY(0x448), TBL_ENTRY(0x449), TBL_ENTRY(0x44a), TBL_ENTRY(0x44b), + TBL_ENTRY(0x44c), TBL_ENTRY(0x44d), TBL_ENTRY(0x44e), TBL_ENTRY(0x44f), + TBL_ENTRY(0x450), TBL_ENTRY(0x451), TBL_ENTRY(0x452), TBL_ENTRY(0x453), + TBL_ENTRY(0x454), TBL_ENTRY(0x455), TBL_ENTRY(0x456), TBL_ENTRY(0x457), + TBL_ENTRY(0x458), TBL_ENTRY(0x459), TBL_ENTRY(0x45a), TBL_ENTRY(0x45b), + TBL_ENTRY(0x45c), TBL_ENTRY(0x45d), TBL_ENTRY(0x45e), TBL_ENTRY(0x45f), + TBL_ENTRY(0x460), TBL_ENTRY(0x461), TBL_ENTRY(0x462), TBL_ENTRY(0x463), + TBL_ENTRY(0x464), TBL_ENTRY(0x465), TBL_ENTRY(0x466), TBL_ENTRY(0x467), + TBL_ENTRY(0x468), TBL_ENTRY(0x469), TBL_ENTRY(0x46a), TBL_ENTRY(0x46b), + TBL_ENTRY(0x46c), TBL_ENTRY(0x46d), TBL_ENTRY(0x46e), TBL_ENTRY(0x46f), + TBL_ENTRY(0x470), TBL_ENTRY(0x471), TBL_ENTRY(0x472), TBL_ENTRY(0x473), + TBL_ENTRY(0x474), TBL_ENTRY(0x475), TBL_ENTRY(0x476), TBL_ENTRY(0x477), + TBL_ENTRY(0x478), TBL_ENTRY(0x479), TBL_ENTRY(0x47a), TBL_ENTRY(0x47b), + TBL_ENTRY(0x47c), TBL_ENTRY(0x47d), TBL_ENTRY(0x47e), TBL_ENTRY(0x47f), + TBL_ENTRY(0x480), TBL_ENTRY(0x481), TBL_ENTRY(0x482), TBL_ENTRY(0x483), + TBL_ENTRY(0x484), TBL_ENTRY(0x485), TBL_ENTRY(0x486), TBL_ENTRY(0x487), + TBL_ENTRY(0x488), TBL_ENTRY(0x489), TBL_ENTRY(0x48a), TBL_ENTRY(0x48b), + TBL_ENTRY(0x48c), TBL_ENTRY(0x48d), TBL_ENTRY(0x48e), TBL_ENTRY(0x48f), + TBL_ENTRY(0x490), TBL_ENTRY(0x491), TBL_ENTRY(0x492), TBL_ENTRY(0x493), + TBL_ENTRY(0x494), TBL_ENTRY(0x495), TBL_ENTRY(0x496), TBL_ENTRY(0x497), + TBL_ENTRY(0x498), TBL_ENTRY(0x499), TBL_ENTRY(0x49a), TBL_ENTRY(0x49b), + TBL_ENTRY(0x49c), TBL_ENTRY(0x49d), TBL_ENTRY(0x49e), TBL_ENTRY(0x49f), + TBL_ENTRY(0x4a0), TBL_ENTRY(0x4a1), TBL_ENTRY(0x4a2), TBL_ENTRY(0x4a3), + TBL_ENTRY(0x4a4), TBL_ENTRY(0x4a5), TBL_ENTRY(0x4a6), TBL_ENTRY(0x4a7), + TBL_ENTRY(0x4a8), TBL_ENTRY(0x4a9), TBL_ENTRY(0x4aa), TBL_ENTRY(0x4ab), + TBL_ENTRY(0x4ac), TBL_ENTRY(0x4ad), TBL_ENTRY(0x4ae), TBL_ENTRY(0x4af), + TBL_ENTRY(0x4b0), TBL_ENTRY(0x4b1), TBL_ENTRY(0x4b2), TBL_ENTRY(0x4b3), + TBL_ENTRY(0x4b4), TBL_ENTRY(0x4b5), TBL_ENTRY(0x4b6), TBL_ENTRY(0x4b7), + TBL_ENTRY(0x4b8), TBL_ENTRY(0x4b9), TBL_ENTRY(0x4ba), TBL_ENTRY(0x4bb), + TBL_ENTRY(0x4bc), TBL_ENTRY(0x4bd), TBL_ENTRY(0x4be), TBL_ENTRY(0x4bf), + TBL_ENTRY(0x4c0), TBL_ENTRY(0x4c1), TBL_ENTRY(0x4c2), TBL_ENTRY(0x4c3), + TBL_ENTRY(0x4c4), TBL_ENTRY(0x4c5), TBL_ENTRY(0x4c6), TBL_ENTRY(0x4c7), + TBL_ENTRY(0x4c8), TBL_ENTRY(0x4c9), TBL_ENTRY(0x4ca), TBL_ENTRY(0x4cb), + TBL_ENTRY(0x4cc), TBL_ENTRY(0x4cd), TBL_ENTRY(0x4ce), TBL_ENTRY(0x4cf), + TBL_ENTRY(0x4d0), TBL_ENTRY(0x4d1), TBL_ENTRY(0x4d2), TBL_ENTRY(0x4d3), + TBL_ENTRY(0x4d4), TBL_ENTRY(0x4d5), TBL_ENTRY(0x4d6), TBL_ENTRY(0x4d7), + TBL_ENTRY(0x4d8), TBL_ENTRY(0x4d9), TBL_ENTRY(0x4da), TBL_ENTRY(0x4db), + TBL_ENTRY(0x4dc), TBL_ENTRY(0x4dd), TBL_ENTRY(0x4de), TBL_ENTRY(0x4df), + TBL_ENTRY(0x4e0), TBL_ENTRY(0x4e1), TBL_ENTRY(0x4e2), TBL_ENTRY(0x4e3), + TBL_ENTRY(0x4e4), TBL_ENTRY(0x4e5), TBL_ENTRY(0x4e6), TBL_ENTRY(0x4e7), + TBL_ENTRY(0x4e8), TBL_ENTRY(0x4e9), TBL_ENTRY(0x4ea), TBL_ENTRY(0x4eb), + TBL_ENTRY(0x4ec), TBL_ENTRY(0x4ed), TBL_ENTRY(0x4ee), TBL_ENTRY(0x4ef), + TBL_ENTRY(0x4f0), TBL_ENTRY(0x4f1), TBL_ENTRY(0x4f2), TBL_ENTRY(0x4f3), + TBL_ENTRY(0x4f4), TBL_ENTRY(0x4f5), TBL_ENTRY(0x4f6), TBL_ENTRY(0x4f7), + TBL_ENTRY(0x4f8), TBL_ENTRY(0x4f9), TBL_ENTRY(0x4fa), TBL_ENTRY(0x4fb), + TBL_ENTRY(0x4fc), TBL_ENTRY(0x4fd), TBL_ENTRY(0x4fe), TBL_ENTRY(0x4ff), + TBL_ENTRY(0x500), TBL_ENTRY(0x501), TBL_ENTRY(0x502), TBL_ENTRY(0x503), + TBL_ENTRY(0x504), TBL_ENTRY(0x505), TBL_ENTRY(0x506), TBL_ENTRY(0x507), + TBL_ENTRY(0x508), TBL_ENTRY(0x509), TBL_ENTRY(0x50a), TBL_ENTRY(0x50b), + TBL_ENTRY(0x50c), TBL_ENTRY(0x50d), TBL_ENTRY(0x50e), TBL_ENTRY(0x50f), + TBL_ENTRY(0x510), TBL_ENTRY(0x511), TBL_ENTRY(0x512), TBL_ENTRY(0x513), + TBL_ENTRY(0x514), TBL_ENTRY(0x515), TBL_ENTRY(0x516), TBL_ENTRY(0x517), + TBL_ENTRY(0x518), TBL_ENTRY(0x519), TBL_ENTRY(0x51a), TBL_ENTRY(0x51b), + TBL_ENTRY(0x51c), TBL_ENTRY(0x51d), TBL_ENTRY(0x51e), TBL_ENTRY(0x51f), + TBL_ENTRY(0x520), TBL_ENTRY(0x521), TBL_ENTRY(0x522), TBL_ENTRY(0x523), + TBL_ENTRY(0x524), TBL_ENTRY(0x525), TBL_ENTRY(0x526), TBL_ENTRY(0x527), + TBL_ENTRY(0x528), TBL_ENTRY(0x529), TBL_ENTRY(0x52a), TBL_ENTRY(0x52b), + TBL_ENTRY(0x52c), TBL_ENTRY(0x52d), TBL_ENTRY(0x52e), TBL_ENTRY(0x52f), + TBL_ENTRY(0x530), TBL_ENTRY(0x531), TBL_ENTRY(0x532), TBL_ENTRY(0x533), + TBL_ENTRY(0x534), TBL_ENTRY(0x535), TBL_ENTRY(0x536), TBL_ENTRY(0x537), + TBL_ENTRY(0x538), TBL_ENTRY(0x539), TBL_ENTRY(0x53a), TBL_ENTRY(0x53b), + TBL_ENTRY(0x53c), TBL_ENTRY(0x53d), TBL_ENTRY(0x53e), TBL_ENTRY(0x53f), + TBL_ENTRY(0x540), TBL_ENTRY(0x541), TBL_ENTRY(0x542), TBL_ENTRY(0x543), + TBL_ENTRY(0x544), TBL_ENTRY(0x545), TBL_ENTRY(0x546), TBL_ENTRY(0x547), + TBL_ENTRY(0x548), TBL_ENTRY(0x549), TBL_ENTRY(0x54a), TBL_ENTRY(0x54b), + TBL_ENTRY(0x54c), TBL_ENTRY(0x54d), TBL_ENTRY(0x54e), TBL_ENTRY(0x54f), + TBL_ENTRY(0x550), TBL_ENTRY(0x551), TBL_ENTRY(0x552), TBL_ENTRY(0x553), + TBL_ENTRY(0x554), TBL_ENTRY(0x555), TBL_ENTRY(0x556), TBL_ENTRY(0x557), + TBL_ENTRY(0x558), TBL_ENTRY(0x559), TBL_ENTRY(0x55a), TBL_ENTRY(0x55b), + TBL_ENTRY(0x55c), TBL_ENTRY(0x55d), TBL_ENTRY(0x55e), TBL_ENTRY(0x55f), + TBL_ENTRY(0x560), TBL_ENTRY(0x561), TBL_ENTRY(0x562), TBL_ENTRY(0x563), + TBL_ENTRY(0x564), TBL_ENTRY(0x565), TBL_ENTRY(0x566), TBL_ENTRY(0x567), + TBL_ENTRY(0x568), TBL_ENTRY(0x569), TBL_ENTRY(0x56a), TBL_ENTRY(0x56b), + TBL_ENTRY(0x56c), TBL_ENTRY(0x56d), TBL_ENTRY(0x56e), TBL_ENTRY(0x56f), + TBL_ENTRY(0x570), TBL_ENTRY(0x571), TBL_ENTRY(0x572), TBL_ENTRY(0x573), + TBL_ENTRY(0x574), TBL_ENTRY(0x575), TBL_ENTRY(0x576), TBL_ENTRY(0x577), + TBL_ENTRY(0x578), TBL_ENTRY(0x579), TBL_ENTRY(0x57a), TBL_ENTRY(0x57b), + TBL_ENTRY(0x57c), TBL_ENTRY(0x57d), TBL_ENTRY(0x57e), TBL_ENTRY(0x57f), + TBL_ENTRY(0x580), TBL_ENTRY(0x581), TBL_ENTRY(0x582), TBL_ENTRY(0x583), + TBL_ENTRY(0x584), TBL_ENTRY(0x585), TBL_ENTRY(0x586), TBL_ENTRY(0x587), + TBL_ENTRY(0x588), TBL_ENTRY(0x589), TBL_ENTRY(0x58a), TBL_ENTRY(0x58b), + TBL_ENTRY(0x58c), TBL_ENTRY(0x58d), TBL_ENTRY(0x58e), TBL_ENTRY(0x58f), + TBL_ENTRY(0x590), TBL_ENTRY(0x591), TBL_ENTRY(0x592), TBL_ENTRY(0x593), + TBL_ENTRY(0x594), TBL_ENTRY(0x595), TBL_ENTRY(0x596), TBL_ENTRY(0x597), + TBL_ENTRY(0x598), TBL_ENTRY(0x599), TBL_ENTRY(0x59a), TBL_ENTRY(0x59b), + TBL_ENTRY(0x59c), TBL_ENTRY(0x59d), TBL_ENTRY(0x59e), TBL_ENTRY(0x59f), + TBL_ENTRY(0x5a0), TBL_ENTRY(0x5a1), TBL_ENTRY(0x5a2), TBL_ENTRY(0x5a3), + TBL_ENTRY(0x5a4), TBL_ENTRY(0x5a5), TBL_ENTRY(0x5a6), TBL_ENTRY(0x5a7), + TBL_ENTRY(0x5a8), TBL_ENTRY(0x5a9), TBL_ENTRY(0x5aa), TBL_ENTRY(0x5ab), + TBL_ENTRY(0x5ac), TBL_ENTRY(0x5ad), TBL_ENTRY(0x5ae), TBL_ENTRY(0x5af), + TBL_ENTRY(0x5b0), TBL_ENTRY(0x5b1), TBL_ENTRY(0x5b2), TBL_ENTRY(0x5b3), + TBL_ENTRY(0x5b4), TBL_ENTRY(0x5b5), TBL_ENTRY(0x5b6), TBL_ENTRY(0x5b7), + TBL_ENTRY(0x5b8), TBL_ENTRY(0x5b9), TBL_ENTRY(0x5ba), TBL_ENTRY(0x5bb), + TBL_ENTRY(0x5bc), TBL_ENTRY(0x5bd), TBL_ENTRY(0x5be), TBL_ENTRY(0x5bf), + TBL_ENTRY(0x5c0), TBL_ENTRY(0x5c1), TBL_ENTRY(0x5c2), TBL_ENTRY(0x5c3), + TBL_ENTRY(0x5c4), TBL_ENTRY(0x5c5), TBL_ENTRY(0x5c6), TBL_ENTRY(0x5c7), + TBL_ENTRY(0x5c8), TBL_ENTRY(0x5c9), TBL_ENTRY(0x5ca), TBL_ENTRY(0x5cb), + TBL_ENTRY(0x5cc), TBL_ENTRY(0x5cd), TBL_ENTRY(0x5ce), TBL_ENTRY(0x5cf), + TBL_ENTRY(0x5d0), TBL_ENTRY(0x5d1), TBL_ENTRY(0x5d2), TBL_ENTRY(0x5d3), + TBL_ENTRY(0x5d4), TBL_ENTRY(0x5d5), TBL_ENTRY(0x5d6), TBL_ENTRY(0x5d7), + TBL_ENTRY(0x5d8), TBL_ENTRY(0x5d9), TBL_ENTRY(0x5da), TBL_ENTRY(0x5db), + TBL_ENTRY(0x5dc), TBL_ENTRY(0x5dd), TBL_ENTRY(0x5de), TBL_ENTRY(0x5df), + TBL_ENTRY(0x5e0), TBL_ENTRY(0x5e1), TBL_ENTRY(0x5e2), TBL_ENTRY(0x5e3), + TBL_ENTRY(0x5e4), TBL_ENTRY(0x5e5), TBL_ENTRY(0x5e6), TBL_ENTRY(0x5e7), + TBL_ENTRY(0x5e8), TBL_ENTRY(0x5e9), TBL_ENTRY(0x5ea), TBL_ENTRY(0x5eb), + TBL_ENTRY(0x5ec), TBL_ENTRY(0x5ed), TBL_ENTRY(0x5ee), TBL_ENTRY(0x5ef), + TBL_ENTRY(0x5f0), TBL_ENTRY(0x5f1), TBL_ENTRY(0x5f2), TBL_ENTRY(0x5f3), + TBL_ENTRY(0x5f4), TBL_ENTRY(0x5f5), TBL_ENTRY(0x5f6), TBL_ENTRY(0x5f7), + TBL_ENTRY(0x5f8), TBL_ENTRY(0x5f9), TBL_ENTRY(0x5fa), TBL_ENTRY(0x5fb), + TBL_ENTRY(0x5fc), TBL_ENTRY(0x5fd), TBL_ENTRY(0x5fe), TBL_ENTRY(0x5ff), + TBL_ENTRY(0x600), TBL_ENTRY(0x601), TBL_ENTRY(0x602), TBL_ENTRY(0x603), + TBL_ENTRY(0x604), TBL_ENTRY(0x605), TBL_ENTRY(0x606), TBL_ENTRY(0x607), + TBL_ENTRY(0x608), TBL_ENTRY(0x609), TBL_ENTRY(0x60a), TBL_ENTRY(0x60b), + TBL_ENTRY(0x60c), TBL_ENTRY(0x60d), TBL_ENTRY(0x60e), TBL_ENTRY(0x60f), + TBL_ENTRY(0x610), TBL_ENTRY(0x611), TBL_ENTRY(0x612), TBL_ENTRY(0x613), + TBL_ENTRY(0x614), TBL_ENTRY(0x615), TBL_ENTRY(0x616), TBL_ENTRY(0x617), + TBL_ENTRY(0x618), TBL_ENTRY(0x619), TBL_ENTRY(0x61a), TBL_ENTRY(0x61b), + TBL_ENTRY(0x61c), TBL_ENTRY(0x61d), TBL_ENTRY(0x61e), TBL_ENTRY(0x61f), + TBL_ENTRY(0x620), TBL_ENTRY(0x621), TBL_ENTRY(0x622), TBL_ENTRY(0x623), + TBL_ENTRY(0x624), TBL_ENTRY(0x625), TBL_ENTRY(0x626), TBL_ENTRY(0x627), + TBL_ENTRY(0x628), TBL_ENTRY(0x629), TBL_ENTRY(0x62a), TBL_ENTRY(0x62b), + TBL_ENTRY(0x62c), TBL_ENTRY(0x62d), TBL_ENTRY(0x62e), TBL_ENTRY(0x62f), + TBL_ENTRY(0x630), TBL_ENTRY(0x631), TBL_ENTRY(0x632), TBL_ENTRY(0x633), + TBL_ENTRY(0x634), TBL_ENTRY(0x635), TBL_ENTRY(0x636), TBL_ENTRY(0x637), + TBL_ENTRY(0x638), TBL_ENTRY(0x639), TBL_ENTRY(0x63a), TBL_ENTRY(0x63b), + TBL_ENTRY(0x63c), TBL_ENTRY(0x63d), TBL_ENTRY(0x63e), TBL_ENTRY(0x63f), + TBL_ENTRY(0x640), TBL_ENTRY(0x641), TBL_ENTRY(0x642), TBL_ENTRY(0x643), + TBL_ENTRY(0x644), TBL_ENTRY(0x645), TBL_ENTRY(0x646), TBL_ENTRY(0x647), + TBL_ENTRY(0x648), TBL_ENTRY(0x649), TBL_ENTRY(0x64a), TBL_ENTRY(0x64b), + TBL_ENTRY(0x64c), TBL_ENTRY(0x64d), TBL_ENTRY(0x64e), TBL_ENTRY(0x64f), + TBL_ENTRY(0x650), TBL_ENTRY(0x651), TBL_ENTRY(0x652), TBL_ENTRY(0x653), + TBL_ENTRY(0x654), TBL_ENTRY(0x655), TBL_ENTRY(0x656), TBL_ENTRY(0x657), + TBL_ENTRY(0x658), TBL_ENTRY(0x659), TBL_ENTRY(0x65a), TBL_ENTRY(0x65b), + TBL_ENTRY(0x65c), TBL_ENTRY(0x65d), TBL_ENTRY(0x65e), TBL_ENTRY(0x65f), + TBL_ENTRY(0x660), TBL_ENTRY(0x661), TBL_ENTRY(0x662), TBL_ENTRY(0x663), + TBL_ENTRY(0x664), TBL_ENTRY(0x665), TBL_ENTRY(0x666), TBL_ENTRY(0x667), + TBL_ENTRY(0x668), TBL_ENTRY(0x669), TBL_ENTRY(0x66a), TBL_ENTRY(0x66b), + TBL_ENTRY(0x66c), TBL_ENTRY(0x66d), TBL_ENTRY(0x66e), TBL_ENTRY(0x66f), + TBL_ENTRY(0x670), TBL_ENTRY(0x671), TBL_ENTRY(0x672), TBL_ENTRY(0x673), + TBL_ENTRY(0x674), TBL_ENTRY(0x675), TBL_ENTRY(0x676), TBL_ENTRY(0x677), + TBL_ENTRY(0x678), TBL_ENTRY(0x679), TBL_ENTRY(0x67a), TBL_ENTRY(0x67b), + TBL_ENTRY(0x67c), TBL_ENTRY(0x67d), TBL_ENTRY(0x67e), TBL_ENTRY(0x67f), + TBL_ENTRY(0x680), TBL_ENTRY(0x681), TBL_ENTRY(0x682), TBL_ENTRY(0x683), + TBL_ENTRY(0x684), TBL_ENTRY(0x685), TBL_ENTRY(0x686), TBL_ENTRY(0x687), + TBL_ENTRY(0x688), TBL_ENTRY(0x689), TBL_ENTRY(0x68a), TBL_ENTRY(0x68b), + TBL_ENTRY(0x68c), TBL_ENTRY(0x68d), TBL_ENTRY(0x68e), TBL_ENTRY(0x68f), + TBL_ENTRY(0x690), TBL_ENTRY(0x691), TBL_ENTRY(0x692), TBL_ENTRY(0x693), + TBL_ENTRY(0x694), TBL_ENTRY(0x695), TBL_ENTRY(0x696), TBL_ENTRY(0x697), + TBL_ENTRY(0x698), TBL_ENTRY(0x699), TBL_ENTRY(0x69a), TBL_ENTRY(0x69b), + TBL_ENTRY(0x69c), TBL_ENTRY(0x69d), TBL_ENTRY(0x69e), TBL_ENTRY(0x69f), + TBL_ENTRY(0x6a0), TBL_ENTRY(0x6a1), TBL_ENTRY(0x6a2), TBL_ENTRY(0x6a3), + TBL_ENTRY(0x6a4), TBL_ENTRY(0x6a5), TBL_ENTRY(0x6a6), TBL_ENTRY(0x6a7), + TBL_ENTRY(0x6a8), TBL_ENTRY(0x6a9), TBL_ENTRY(0x6aa), TBL_ENTRY(0x6ab), + TBL_ENTRY(0x6ac), TBL_ENTRY(0x6ad), TBL_ENTRY(0x6ae), TBL_ENTRY(0x6af), + TBL_ENTRY(0x6b0), TBL_ENTRY(0x6b1), TBL_ENTRY(0x6b2), TBL_ENTRY(0x6b3), + TBL_ENTRY(0x6b4), TBL_ENTRY(0x6b5), TBL_ENTRY(0x6b6), TBL_ENTRY(0x6b7), + TBL_ENTRY(0x6b8), TBL_ENTRY(0x6b9), TBL_ENTRY(0x6ba), TBL_ENTRY(0x6bb), + TBL_ENTRY(0x6bc), TBL_ENTRY(0x6bd), TBL_ENTRY(0x6be), TBL_ENTRY(0x6bf), + TBL_ENTRY(0x6c0), TBL_ENTRY(0x6c1), TBL_ENTRY(0x6c2), TBL_ENTRY(0x6c3), + TBL_ENTRY(0x6c4), TBL_ENTRY(0x6c5), TBL_ENTRY(0x6c6), TBL_ENTRY(0x6c7), + TBL_ENTRY(0x6c8), TBL_ENTRY(0x6c9), TBL_ENTRY(0x6ca), TBL_ENTRY(0x6cb), + TBL_ENTRY(0x6cc), TBL_ENTRY(0x6cd), TBL_ENTRY(0x6ce), TBL_ENTRY(0x6cf), + TBL_ENTRY(0x6d0), TBL_ENTRY(0x6d1), TBL_ENTRY(0x6d2), TBL_ENTRY(0x6d3), + TBL_ENTRY(0x6d4), TBL_ENTRY(0x6d5), TBL_ENTRY(0x6d6), TBL_ENTRY(0x6d7), + TBL_ENTRY(0x6d8), TBL_ENTRY(0x6d9), TBL_ENTRY(0x6da), TBL_ENTRY(0x6db), + TBL_ENTRY(0x6dc), TBL_ENTRY(0x6dd), TBL_ENTRY(0x6de), TBL_ENTRY(0x6df), + TBL_ENTRY(0x6e0), TBL_ENTRY(0x6e1), TBL_ENTRY(0x6e2), TBL_ENTRY(0x6e3), + TBL_ENTRY(0x6e4), TBL_ENTRY(0x6e5), TBL_ENTRY(0x6e6), TBL_ENTRY(0x6e7), + TBL_ENTRY(0x6e8), TBL_ENTRY(0x6e9), TBL_ENTRY(0x6ea), TBL_ENTRY(0x6eb), + TBL_ENTRY(0x6ec), TBL_ENTRY(0x6ed), TBL_ENTRY(0x6ee), TBL_ENTRY(0x6ef), + TBL_ENTRY(0x6f0), TBL_ENTRY(0x6f1), TBL_ENTRY(0x6f2), TBL_ENTRY(0x6f3), + TBL_ENTRY(0x6f4), TBL_ENTRY(0x6f5), TBL_ENTRY(0x6f6), TBL_ENTRY(0x6f7), + TBL_ENTRY(0x6f8), TBL_ENTRY(0x6f9), TBL_ENTRY(0x6fa), TBL_ENTRY(0x6fb), + TBL_ENTRY(0x6fc), TBL_ENTRY(0x6fd), TBL_ENTRY(0x6fe), TBL_ENTRY(0x6ff), + TBL_ENTRY(0x700), TBL_ENTRY(0x701), TBL_ENTRY(0x702), TBL_ENTRY(0x703), + TBL_ENTRY(0x704), TBL_ENTRY(0x705), TBL_ENTRY(0x706), TBL_ENTRY(0x707), + TBL_ENTRY(0x708), TBL_ENTRY(0x709), TBL_ENTRY(0x70a), TBL_ENTRY(0x70b), + TBL_ENTRY(0x70c), TBL_ENTRY(0x70d), TBL_ENTRY(0x70e), TBL_ENTRY(0x70f), + TBL_ENTRY(0x710), TBL_ENTRY(0x711), TBL_ENTRY(0x712), TBL_ENTRY(0x713), + TBL_ENTRY(0x714), TBL_ENTRY(0x715), TBL_ENTRY(0x716), TBL_ENTRY(0x717), + TBL_ENTRY(0x718), TBL_ENTRY(0x719), TBL_ENTRY(0x71a), TBL_ENTRY(0x71b), + TBL_ENTRY(0x71c), TBL_ENTRY(0x71d), TBL_ENTRY(0x71e), TBL_ENTRY(0x71f), + TBL_ENTRY(0x720), TBL_ENTRY(0x721), TBL_ENTRY(0x722), TBL_ENTRY(0x723), + TBL_ENTRY(0x724), TBL_ENTRY(0x725), TBL_ENTRY(0x726), TBL_ENTRY(0x727), + TBL_ENTRY(0x728), TBL_ENTRY(0x729), TBL_ENTRY(0x72a), TBL_ENTRY(0x72b), + TBL_ENTRY(0x72c), TBL_ENTRY(0x72d), TBL_ENTRY(0x72e), TBL_ENTRY(0x72f), + TBL_ENTRY(0x730), TBL_ENTRY(0x731), TBL_ENTRY(0x732), TBL_ENTRY(0x733), + TBL_ENTRY(0x734), TBL_ENTRY(0x735), TBL_ENTRY(0x736), TBL_ENTRY(0x737), + TBL_ENTRY(0x738), TBL_ENTRY(0x739), TBL_ENTRY(0x73a), TBL_ENTRY(0x73b), + TBL_ENTRY(0x73c), TBL_ENTRY(0x73d), TBL_ENTRY(0x73e), TBL_ENTRY(0x73f), + TBL_ENTRY(0x740), TBL_ENTRY(0x741), TBL_ENTRY(0x742), TBL_ENTRY(0x743), + TBL_ENTRY(0x744), TBL_ENTRY(0x745), TBL_ENTRY(0x746), TBL_ENTRY(0x747), + TBL_ENTRY(0x748), TBL_ENTRY(0x749), TBL_ENTRY(0x74a), TBL_ENTRY(0x74b), + TBL_ENTRY(0x74c), TBL_ENTRY(0x74d), TBL_ENTRY(0x74e), TBL_ENTRY(0x74f), + TBL_ENTRY(0x750), TBL_ENTRY(0x751), TBL_ENTRY(0x752), TBL_ENTRY(0x753), + TBL_ENTRY(0x754), TBL_ENTRY(0x755), TBL_ENTRY(0x756), TBL_ENTRY(0x757), + TBL_ENTRY(0x758), TBL_ENTRY(0x759), TBL_ENTRY(0x75a), TBL_ENTRY(0x75b), + TBL_ENTRY(0x75c), TBL_ENTRY(0x75d), TBL_ENTRY(0x75e), TBL_ENTRY(0x75f), + TBL_ENTRY(0x760), TBL_ENTRY(0x761), TBL_ENTRY(0x762), TBL_ENTRY(0x763), + TBL_ENTRY(0x764), TBL_ENTRY(0x765), TBL_ENTRY(0x766), TBL_ENTRY(0x767), + TBL_ENTRY(0x768), TBL_ENTRY(0x769), TBL_ENTRY(0x76a), TBL_ENTRY(0x76b), + TBL_ENTRY(0x76c), TBL_ENTRY(0x76d), TBL_ENTRY(0x76e), TBL_ENTRY(0x76f), + TBL_ENTRY(0x770), TBL_ENTRY(0x771), TBL_ENTRY(0x772), TBL_ENTRY(0x773), + TBL_ENTRY(0x774), TBL_ENTRY(0x775), TBL_ENTRY(0x776), TBL_ENTRY(0x777), + TBL_ENTRY(0x778), TBL_ENTRY(0x779), TBL_ENTRY(0x77a), TBL_ENTRY(0x77b), + TBL_ENTRY(0x77c), TBL_ENTRY(0x77d), TBL_ENTRY(0x77e), TBL_ENTRY(0x77f), + TBL_ENTRY(0x780), TBL_ENTRY(0x781), TBL_ENTRY(0x782), TBL_ENTRY(0x783), + TBL_ENTRY(0x784), TBL_ENTRY(0x785), TBL_ENTRY(0x786), TBL_ENTRY(0x787), + TBL_ENTRY(0x788), TBL_ENTRY(0x789), TBL_ENTRY(0x78a), TBL_ENTRY(0x78b), + TBL_ENTRY(0x78c), TBL_ENTRY(0x78d), TBL_ENTRY(0x78e), TBL_ENTRY(0x78f), + TBL_ENTRY(0x790), TBL_ENTRY(0x791), TBL_ENTRY(0x792), TBL_ENTRY(0x793), + TBL_ENTRY(0x794), TBL_ENTRY(0x795), TBL_ENTRY(0x796), TBL_ENTRY(0x797), + TBL_ENTRY(0x798), TBL_ENTRY(0x799), TBL_ENTRY(0x79a), TBL_ENTRY(0x79b), + TBL_ENTRY(0x79c), TBL_ENTRY(0x79d), TBL_ENTRY(0x79e), TBL_ENTRY(0x79f), + TBL_ENTRY(0x7a0), TBL_ENTRY(0x7a1), TBL_ENTRY(0x7a2), TBL_ENTRY(0x7a3), + TBL_ENTRY(0x7a4), TBL_ENTRY(0x7a5), TBL_ENTRY(0x7a6), TBL_ENTRY(0x7a7), + TBL_ENTRY(0x7a8), TBL_ENTRY(0x7a9), TBL_ENTRY(0x7aa), TBL_ENTRY(0x7ab), + TBL_ENTRY(0x7ac), TBL_ENTRY(0x7ad), TBL_ENTRY(0x7ae), TBL_ENTRY(0x7af), + TBL_ENTRY(0x7b0), TBL_ENTRY(0x7b1), TBL_ENTRY(0x7b2), TBL_ENTRY(0x7b3), + TBL_ENTRY(0x7b4), TBL_ENTRY(0x7b5), TBL_ENTRY(0x7b6), TBL_ENTRY(0x7b7), + TBL_ENTRY(0x7b8), TBL_ENTRY(0x7b9), TBL_ENTRY(0x7ba), TBL_ENTRY(0x7bb), + TBL_ENTRY(0x7bc), TBL_ENTRY(0x7bd), TBL_ENTRY(0x7be), TBL_ENTRY(0x7bf), + TBL_ENTRY(0x7c0), TBL_ENTRY(0x7c1), TBL_ENTRY(0x7c2), TBL_ENTRY(0x7c3), + TBL_ENTRY(0x7c4), TBL_ENTRY(0x7c5), TBL_ENTRY(0x7c6), TBL_ENTRY(0x7c7), + TBL_ENTRY(0x7c8), TBL_ENTRY(0x7c9), TBL_ENTRY(0x7ca), TBL_ENTRY(0x7cb), + TBL_ENTRY(0x7cc), TBL_ENTRY(0x7cd), TBL_ENTRY(0x7ce), TBL_ENTRY(0x7cf), + TBL_ENTRY(0x7d0), TBL_ENTRY(0x7d1), TBL_ENTRY(0x7d2), TBL_ENTRY(0x7d3), + TBL_ENTRY(0x7d4), TBL_ENTRY(0x7d5), TBL_ENTRY(0x7d6), TBL_ENTRY(0x7d7), + TBL_ENTRY(0x7d8), TBL_ENTRY(0x7d9), TBL_ENTRY(0x7da), TBL_ENTRY(0x7db), + TBL_ENTRY(0x7dc), TBL_ENTRY(0x7dd), TBL_ENTRY(0x7de), TBL_ENTRY(0x7df), + TBL_ENTRY(0x7e0), TBL_ENTRY(0x7e1), TBL_ENTRY(0x7e2), TBL_ENTRY(0x7e3), + TBL_ENTRY(0x7e4), TBL_ENTRY(0x7e5), TBL_ENTRY(0x7e6), TBL_ENTRY(0x7e7), + TBL_ENTRY(0x7e8), TBL_ENTRY(0x7e9), TBL_ENTRY(0x7ea), TBL_ENTRY(0x7eb), + TBL_ENTRY(0x7ec), TBL_ENTRY(0x7ed), TBL_ENTRY(0x7ee), TBL_ENTRY(0x7ef), + TBL_ENTRY(0x7f0), TBL_ENTRY(0x7f1), TBL_ENTRY(0x7f2), TBL_ENTRY(0x7f3), + TBL_ENTRY(0x7f4), TBL_ENTRY(0x7f5), TBL_ENTRY(0x7f6), TBL_ENTRY(0x7f7), + TBL_ENTRY(0x7f8), TBL_ENTRY(0x7f9), TBL_ENTRY(0x7fa), TBL_ENTRY(0x7fb), + TBL_ENTRY(0x7fc), TBL_ENTRY(0x7fd), TBL_ENTRY(0x7fe), TBL_ENTRY(0x7ff), + TBL_ENTRY(0x800), TBL_ENTRY(0x801), TBL_ENTRY(0x802), TBL_ENTRY(0x803), + TBL_ENTRY(0x804), TBL_ENTRY(0x805), TBL_ENTRY(0x806), TBL_ENTRY(0x807), + TBL_ENTRY(0x808), TBL_ENTRY(0x809), TBL_ENTRY(0x80a), TBL_ENTRY(0x80b), + TBL_ENTRY(0x80c), TBL_ENTRY(0x80d), TBL_ENTRY(0x80e), TBL_ENTRY(0x80f), + TBL_ENTRY(0x810), TBL_ENTRY(0x811), TBL_ENTRY(0x812), TBL_ENTRY(0x813), + TBL_ENTRY(0x814), TBL_ENTRY(0x815), TBL_ENTRY(0x816), TBL_ENTRY(0x817), + TBL_ENTRY(0x818), TBL_ENTRY(0x819), TBL_ENTRY(0x81a), TBL_ENTRY(0x81b), + TBL_ENTRY(0x81c), TBL_ENTRY(0x81d), TBL_ENTRY(0x81e), TBL_ENTRY(0x81f), + TBL_ENTRY(0x820), TBL_ENTRY(0x821), TBL_ENTRY(0x822), TBL_ENTRY(0x823), + TBL_ENTRY(0x824), TBL_ENTRY(0x825), TBL_ENTRY(0x826), TBL_ENTRY(0x827), + TBL_ENTRY(0x828), TBL_ENTRY(0x829), TBL_ENTRY(0x82a), TBL_ENTRY(0x82b), + TBL_ENTRY(0x82c), TBL_ENTRY(0x82d), TBL_ENTRY(0x82e), TBL_ENTRY(0x82f), + TBL_ENTRY(0x830), TBL_ENTRY(0x831), TBL_ENTRY(0x832), TBL_ENTRY(0x833), + TBL_ENTRY(0x834), TBL_ENTRY(0x835), TBL_ENTRY(0x836), TBL_ENTRY(0x837), + TBL_ENTRY(0x838), TBL_ENTRY(0x839), TBL_ENTRY(0x83a), TBL_ENTRY(0x83b), + TBL_ENTRY(0x83c), TBL_ENTRY(0x83d), TBL_ENTRY(0x83e), TBL_ENTRY(0x83f), + TBL_ENTRY(0x840), TBL_ENTRY(0x841), TBL_ENTRY(0x842), TBL_ENTRY(0x843), + TBL_ENTRY(0x844), TBL_ENTRY(0x845), TBL_ENTRY(0x846), TBL_ENTRY(0x847), + TBL_ENTRY(0x848), TBL_ENTRY(0x849), TBL_ENTRY(0x84a), TBL_ENTRY(0x84b), + TBL_ENTRY(0x84c), TBL_ENTRY(0x84d), TBL_ENTRY(0x84e), TBL_ENTRY(0x84f), + TBL_ENTRY(0x850), TBL_ENTRY(0x851), TBL_ENTRY(0x852), TBL_ENTRY(0x853), + TBL_ENTRY(0x854), TBL_ENTRY(0x855), TBL_ENTRY(0x856), TBL_ENTRY(0x857), + TBL_ENTRY(0x858), TBL_ENTRY(0x859), TBL_ENTRY(0x85a), TBL_ENTRY(0x85b), + TBL_ENTRY(0x85c), TBL_ENTRY(0x85d), TBL_ENTRY(0x85e), TBL_ENTRY(0x85f), + TBL_ENTRY(0x860), TBL_ENTRY(0x861), TBL_ENTRY(0x862), TBL_ENTRY(0x863), + TBL_ENTRY(0x864), TBL_ENTRY(0x865), TBL_ENTRY(0x866), TBL_ENTRY(0x867), + TBL_ENTRY(0x868), TBL_ENTRY(0x869), TBL_ENTRY(0x86a), TBL_ENTRY(0x86b), + TBL_ENTRY(0x86c), TBL_ENTRY(0x86d), TBL_ENTRY(0x86e), TBL_ENTRY(0x86f), + TBL_ENTRY(0x870), TBL_ENTRY(0x871), TBL_ENTRY(0x872), TBL_ENTRY(0x873), + TBL_ENTRY(0x874), TBL_ENTRY(0x875), TBL_ENTRY(0x876), TBL_ENTRY(0x877), + TBL_ENTRY(0x878), TBL_ENTRY(0x879), TBL_ENTRY(0x87a), TBL_ENTRY(0x87b), + TBL_ENTRY(0x87c), TBL_ENTRY(0x87d), TBL_ENTRY(0x87e), TBL_ENTRY(0x87f), + TBL_ENTRY(0x880), TBL_ENTRY(0x881), TBL_ENTRY(0x882), TBL_ENTRY(0x883), + TBL_ENTRY(0x884), TBL_ENTRY(0x885), TBL_ENTRY(0x886), TBL_ENTRY(0x887), + TBL_ENTRY(0x888), TBL_ENTRY(0x889), TBL_ENTRY(0x88a), TBL_ENTRY(0x88b), + TBL_ENTRY(0x88c), TBL_ENTRY(0x88d), TBL_ENTRY(0x88e), TBL_ENTRY(0x88f), + TBL_ENTRY(0x890), TBL_ENTRY(0x891), TBL_ENTRY(0x892), TBL_ENTRY(0x893), + TBL_ENTRY(0x894), TBL_ENTRY(0x895), TBL_ENTRY(0x896), TBL_ENTRY(0x897), + TBL_ENTRY(0x898), TBL_ENTRY(0x899), TBL_ENTRY(0x89a), TBL_ENTRY(0x89b), + TBL_ENTRY(0x89c), TBL_ENTRY(0x89d), TBL_ENTRY(0x89e), TBL_ENTRY(0x89f), + TBL_ENTRY(0x8a0), TBL_ENTRY(0x8a1), TBL_ENTRY(0x8a2), TBL_ENTRY(0x8a3), + TBL_ENTRY(0x8a4), TBL_ENTRY(0x8a5), TBL_ENTRY(0x8a6), TBL_ENTRY(0x8a7), + TBL_ENTRY(0x8a8), TBL_ENTRY(0x8a9), TBL_ENTRY(0x8aa), TBL_ENTRY(0x8ab), + TBL_ENTRY(0x8ac), TBL_ENTRY(0x8ad), TBL_ENTRY(0x8ae), TBL_ENTRY(0x8af), + TBL_ENTRY(0x8b0), TBL_ENTRY(0x8b1), TBL_ENTRY(0x8b2), TBL_ENTRY(0x8b3), + TBL_ENTRY(0x8b4), TBL_ENTRY(0x8b5), TBL_ENTRY(0x8b6), TBL_ENTRY(0x8b7), + TBL_ENTRY(0x8b8), TBL_ENTRY(0x8b9), TBL_ENTRY(0x8ba), TBL_ENTRY(0x8bb), + TBL_ENTRY(0x8bc), TBL_ENTRY(0x8bd), TBL_ENTRY(0x8be), TBL_ENTRY(0x8bf), + TBL_ENTRY(0x8c0), TBL_ENTRY(0x8c1), TBL_ENTRY(0x8c2), TBL_ENTRY(0x8c3), + TBL_ENTRY(0x8c4), TBL_ENTRY(0x8c5), TBL_ENTRY(0x8c6), TBL_ENTRY(0x8c7), + TBL_ENTRY(0x8c8), TBL_ENTRY(0x8c9), TBL_ENTRY(0x8ca), TBL_ENTRY(0x8cb), + TBL_ENTRY(0x8cc), TBL_ENTRY(0x8cd), TBL_ENTRY(0x8ce), TBL_ENTRY(0x8cf), + TBL_ENTRY(0x8d0), TBL_ENTRY(0x8d1), TBL_ENTRY(0x8d2), TBL_ENTRY(0x8d3), + TBL_ENTRY(0x8d4), TBL_ENTRY(0x8d5), TBL_ENTRY(0x8d6), TBL_ENTRY(0x8d7), + TBL_ENTRY(0x8d8), TBL_ENTRY(0x8d9), TBL_ENTRY(0x8da), TBL_ENTRY(0x8db), + TBL_ENTRY(0x8dc), TBL_ENTRY(0x8dd), TBL_ENTRY(0x8de), TBL_ENTRY(0x8df), + TBL_ENTRY(0x8e0), TBL_ENTRY(0x8e1), TBL_ENTRY(0x8e2), TBL_ENTRY(0x8e3), + TBL_ENTRY(0x8e4), TBL_ENTRY(0x8e5), TBL_ENTRY(0x8e6), TBL_ENTRY(0x8e7), + TBL_ENTRY(0x8e8), TBL_ENTRY(0x8e9), TBL_ENTRY(0x8ea), TBL_ENTRY(0x8eb), + TBL_ENTRY(0x8ec), TBL_ENTRY(0x8ed), TBL_ENTRY(0x8ee), TBL_ENTRY(0x8ef), + TBL_ENTRY(0x8f0), TBL_ENTRY(0x8f1), TBL_ENTRY(0x8f2), TBL_ENTRY(0x8f3), + TBL_ENTRY(0x8f4), TBL_ENTRY(0x8f5), TBL_ENTRY(0x8f6), TBL_ENTRY(0x8f7), + TBL_ENTRY(0x8f8), TBL_ENTRY(0x8f9), TBL_ENTRY(0x8fa), TBL_ENTRY(0x8fb), + TBL_ENTRY(0x8fc), TBL_ENTRY(0x8fd), TBL_ENTRY(0x8fe), TBL_ENTRY(0x8ff), + TBL_ENTRY(0x900), TBL_ENTRY(0x901), TBL_ENTRY(0x902), TBL_ENTRY(0x903), + TBL_ENTRY(0x904), TBL_ENTRY(0x905), TBL_ENTRY(0x906), TBL_ENTRY(0x907), + TBL_ENTRY(0x908), TBL_ENTRY(0x909), TBL_ENTRY(0x90a), TBL_ENTRY(0x90b), + TBL_ENTRY(0x90c), TBL_ENTRY(0x90d), TBL_ENTRY(0x90e), TBL_ENTRY(0x90f), + TBL_ENTRY(0x910), TBL_ENTRY(0x911), TBL_ENTRY(0x912), TBL_ENTRY(0x913), + TBL_ENTRY(0x914), TBL_ENTRY(0x915), TBL_ENTRY(0x916), TBL_ENTRY(0x917), + TBL_ENTRY(0x918), TBL_ENTRY(0x919), TBL_ENTRY(0x91a), TBL_ENTRY(0x91b), + TBL_ENTRY(0x91c), TBL_ENTRY(0x91d), TBL_ENTRY(0x91e), TBL_ENTRY(0x91f), + TBL_ENTRY(0x920), TBL_ENTRY(0x921), TBL_ENTRY(0x922), TBL_ENTRY(0x923), + TBL_ENTRY(0x924), TBL_ENTRY(0x925), TBL_ENTRY(0x926), TBL_ENTRY(0x927), + TBL_ENTRY(0x928), TBL_ENTRY(0x929), TBL_ENTRY(0x92a), TBL_ENTRY(0x92b), + TBL_ENTRY(0x92c), TBL_ENTRY(0x92d), TBL_ENTRY(0x92e), TBL_ENTRY(0x92f), + TBL_ENTRY(0x930), TBL_ENTRY(0x931), TBL_ENTRY(0x932), TBL_ENTRY(0x933), + TBL_ENTRY(0x934), TBL_ENTRY(0x935), TBL_ENTRY(0x936), TBL_ENTRY(0x937), + TBL_ENTRY(0x938), TBL_ENTRY(0x939), TBL_ENTRY(0x93a), TBL_ENTRY(0x93b), + TBL_ENTRY(0x93c), TBL_ENTRY(0x93d), TBL_ENTRY(0x93e), TBL_ENTRY(0x93f), + TBL_ENTRY(0x940), TBL_ENTRY(0x941), TBL_ENTRY(0x942), TBL_ENTRY(0x943), + TBL_ENTRY(0x944), TBL_ENTRY(0x945), TBL_ENTRY(0x946), TBL_ENTRY(0x947), + TBL_ENTRY(0x948), TBL_ENTRY(0x949), TBL_ENTRY(0x94a), TBL_ENTRY(0x94b), + TBL_ENTRY(0x94c), TBL_ENTRY(0x94d), TBL_ENTRY(0x94e), TBL_ENTRY(0x94f), + TBL_ENTRY(0x950), TBL_ENTRY(0x951), TBL_ENTRY(0x952), TBL_ENTRY(0x953), + TBL_ENTRY(0x954), TBL_ENTRY(0x955), TBL_ENTRY(0x956), TBL_ENTRY(0x957), + TBL_ENTRY(0x958), TBL_ENTRY(0x959), TBL_ENTRY(0x95a), TBL_ENTRY(0x95b), + TBL_ENTRY(0x95c), TBL_ENTRY(0x95d), TBL_ENTRY(0x95e), TBL_ENTRY(0x95f), + TBL_ENTRY(0x960), TBL_ENTRY(0x961), TBL_ENTRY(0x962), TBL_ENTRY(0x963), + TBL_ENTRY(0x964), TBL_ENTRY(0x965), TBL_ENTRY(0x966), TBL_ENTRY(0x967), + TBL_ENTRY(0x968), TBL_ENTRY(0x969), TBL_ENTRY(0x96a), TBL_ENTRY(0x96b), + TBL_ENTRY(0x96c), TBL_ENTRY(0x96d), TBL_ENTRY(0x96e), TBL_ENTRY(0x96f), + TBL_ENTRY(0x970), TBL_ENTRY(0x971), TBL_ENTRY(0x972), TBL_ENTRY(0x973), + TBL_ENTRY(0x974), TBL_ENTRY(0x975), TBL_ENTRY(0x976), TBL_ENTRY(0x977), + TBL_ENTRY(0x978), TBL_ENTRY(0x979), TBL_ENTRY(0x97a), TBL_ENTRY(0x97b), + TBL_ENTRY(0x97c), TBL_ENTRY(0x97d), TBL_ENTRY(0x97e), TBL_ENTRY(0x97f), + TBL_ENTRY(0x980), TBL_ENTRY(0x981), TBL_ENTRY(0x982), TBL_ENTRY(0x983), + TBL_ENTRY(0x984), TBL_ENTRY(0x985), TBL_ENTRY(0x986), TBL_ENTRY(0x987), + TBL_ENTRY(0x988), TBL_ENTRY(0x989), TBL_ENTRY(0x98a), TBL_ENTRY(0x98b), + TBL_ENTRY(0x98c), TBL_ENTRY(0x98d), TBL_ENTRY(0x98e), TBL_ENTRY(0x98f), + TBL_ENTRY(0x990), TBL_ENTRY(0x991), TBL_ENTRY(0x992), TBL_ENTRY(0x993), + TBL_ENTRY(0x994), TBL_ENTRY(0x995), TBL_ENTRY(0x996), TBL_ENTRY(0x997), + TBL_ENTRY(0x998), TBL_ENTRY(0x999), TBL_ENTRY(0x99a), TBL_ENTRY(0x99b), + TBL_ENTRY(0x99c), TBL_ENTRY(0x99d), TBL_ENTRY(0x99e), TBL_ENTRY(0x99f), + TBL_ENTRY(0x9a0), TBL_ENTRY(0x9a1), TBL_ENTRY(0x9a2), TBL_ENTRY(0x9a3), + TBL_ENTRY(0x9a4), TBL_ENTRY(0x9a5), TBL_ENTRY(0x9a6), TBL_ENTRY(0x9a7), + TBL_ENTRY(0x9a8), TBL_ENTRY(0x9a9), TBL_ENTRY(0x9aa), TBL_ENTRY(0x9ab), + TBL_ENTRY(0x9ac), TBL_ENTRY(0x9ad), TBL_ENTRY(0x9ae), TBL_ENTRY(0x9af), + TBL_ENTRY(0x9b0), TBL_ENTRY(0x9b1), TBL_ENTRY(0x9b2), TBL_ENTRY(0x9b3), + TBL_ENTRY(0x9b4), TBL_ENTRY(0x9b5), TBL_ENTRY(0x9b6), TBL_ENTRY(0x9b7), + TBL_ENTRY(0x9b8), TBL_ENTRY(0x9b9), TBL_ENTRY(0x9ba), TBL_ENTRY(0x9bb), + TBL_ENTRY(0x9bc), TBL_ENTRY(0x9bd), TBL_ENTRY(0x9be), TBL_ENTRY(0x9bf), + TBL_ENTRY(0x9c0), TBL_ENTRY(0x9c1), TBL_ENTRY(0x9c2), TBL_ENTRY(0x9c3), + TBL_ENTRY(0x9c4), TBL_ENTRY(0x9c5), TBL_ENTRY(0x9c6), TBL_ENTRY(0x9c7), + TBL_ENTRY(0x9c8), TBL_ENTRY(0x9c9), TBL_ENTRY(0x9ca), TBL_ENTRY(0x9cb), + TBL_ENTRY(0x9cc), TBL_ENTRY(0x9cd), TBL_ENTRY(0x9ce), TBL_ENTRY(0x9cf), + TBL_ENTRY(0x9d0), TBL_ENTRY(0x9d1), TBL_ENTRY(0x9d2), TBL_ENTRY(0x9d3), + TBL_ENTRY(0x9d4), TBL_ENTRY(0x9d5), TBL_ENTRY(0x9d6), TBL_ENTRY(0x9d7), + TBL_ENTRY(0x9d8), TBL_ENTRY(0x9d9), TBL_ENTRY(0x9da), TBL_ENTRY(0x9db), + TBL_ENTRY(0x9dc), TBL_ENTRY(0x9dd), TBL_ENTRY(0x9de), TBL_ENTRY(0x9df), + TBL_ENTRY(0x9e0), TBL_ENTRY(0x9e1), TBL_ENTRY(0x9e2), TBL_ENTRY(0x9e3), + TBL_ENTRY(0x9e4), TBL_ENTRY(0x9e5), TBL_ENTRY(0x9e6), TBL_ENTRY(0x9e7), + TBL_ENTRY(0x9e8), TBL_ENTRY(0x9e9), TBL_ENTRY(0x9ea), TBL_ENTRY(0x9eb), + TBL_ENTRY(0x9ec), TBL_ENTRY(0x9ed), TBL_ENTRY(0x9ee), TBL_ENTRY(0x9ef), + TBL_ENTRY(0x9f0), TBL_ENTRY(0x9f1), TBL_ENTRY(0x9f2), TBL_ENTRY(0x9f3), + TBL_ENTRY(0x9f4), TBL_ENTRY(0x9f5), TBL_ENTRY(0x9f6), TBL_ENTRY(0x9f7), + TBL_ENTRY(0x9f8), TBL_ENTRY(0x9f9), TBL_ENTRY(0x9fa), TBL_ENTRY(0x9fb), + TBL_ENTRY(0x9fc), TBL_ENTRY(0x9fd), TBL_ENTRY(0x9fe), TBL_ENTRY(0x9ff), + TBL_ENTRY(0xa00), TBL_ENTRY(0xa01), TBL_ENTRY(0xa02), TBL_ENTRY(0xa03), + TBL_ENTRY(0xa04), TBL_ENTRY(0xa05), TBL_ENTRY(0xa06), TBL_ENTRY(0xa07), + TBL_ENTRY(0xa08), TBL_ENTRY(0xa09), TBL_ENTRY(0xa0a), TBL_ENTRY(0xa0b), + TBL_ENTRY(0xa0c), TBL_ENTRY(0xa0d), TBL_ENTRY(0xa0e), TBL_ENTRY(0xa0f), + TBL_ENTRY(0xa10), TBL_ENTRY(0xa11), TBL_ENTRY(0xa12), TBL_ENTRY(0xa13), + TBL_ENTRY(0xa14), TBL_ENTRY(0xa15), TBL_ENTRY(0xa16), TBL_ENTRY(0xa17), + TBL_ENTRY(0xa18), TBL_ENTRY(0xa19), TBL_ENTRY(0xa1a), TBL_ENTRY(0xa1b), + TBL_ENTRY(0xa1c), TBL_ENTRY(0xa1d), TBL_ENTRY(0xa1e), TBL_ENTRY(0xa1f), + TBL_ENTRY(0xa20), TBL_ENTRY(0xa21), TBL_ENTRY(0xa22), TBL_ENTRY(0xa23), + TBL_ENTRY(0xa24), TBL_ENTRY(0xa25), TBL_ENTRY(0xa26), TBL_ENTRY(0xa27), + TBL_ENTRY(0xa28), TBL_ENTRY(0xa29), TBL_ENTRY(0xa2a), TBL_ENTRY(0xa2b), + TBL_ENTRY(0xa2c), TBL_ENTRY(0xa2d), TBL_ENTRY(0xa2e), TBL_ENTRY(0xa2f), + TBL_ENTRY(0xa30), TBL_ENTRY(0xa31), TBL_ENTRY(0xa32), TBL_ENTRY(0xa33), + TBL_ENTRY(0xa34), TBL_ENTRY(0xa35), TBL_ENTRY(0xa36), TBL_ENTRY(0xa37), + TBL_ENTRY(0xa38), TBL_ENTRY(0xa39), TBL_ENTRY(0xa3a), TBL_ENTRY(0xa3b), + TBL_ENTRY(0xa3c), TBL_ENTRY(0xa3d), TBL_ENTRY(0xa3e), TBL_ENTRY(0xa3f), + TBL_ENTRY(0xa40), TBL_ENTRY(0xa41), TBL_ENTRY(0xa42), TBL_ENTRY(0xa43), + TBL_ENTRY(0xa44), TBL_ENTRY(0xa45), TBL_ENTRY(0xa46), TBL_ENTRY(0xa47), + TBL_ENTRY(0xa48), TBL_ENTRY(0xa49), TBL_ENTRY(0xa4a), TBL_ENTRY(0xa4b), + TBL_ENTRY(0xa4c), TBL_ENTRY(0xa4d), TBL_ENTRY(0xa4e), TBL_ENTRY(0xa4f), + TBL_ENTRY(0xa50), TBL_ENTRY(0xa51), TBL_ENTRY(0xa52), TBL_ENTRY(0xa53), + TBL_ENTRY(0xa54), TBL_ENTRY(0xa55), TBL_ENTRY(0xa56), TBL_ENTRY(0xa57), + TBL_ENTRY(0xa58), TBL_ENTRY(0xa59), TBL_ENTRY(0xa5a), TBL_ENTRY(0xa5b), + TBL_ENTRY(0xa5c), TBL_ENTRY(0xa5d), TBL_ENTRY(0xa5e), TBL_ENTRY(0xa5f), + TBL_ENTRY(0xa60), TBL_ENTRY(0xa61), TBL_ENTRY(0xa62), TBL_ENTRY(0xa63), + TBL_ENTRY(0xa64), TBL_ENTRY(0xa65), TBL_ENTRY(0xa66), TBL_ENTRY(0xa67), + TBL_ENTRY(0xa68), TBL_ENTRY(0xa69), TBL_ENTRY(0xa6a), TBL_ENTRY(0xa6b), + TBL_ENTRY(0xa6c), TBL_ENTRY(0xa6d), TBL_ENTRY(0xa6e), TBL_ENTRY(0xa6f), + TBL_ENTRY(0xa70), TBL_ENTRY(0xa71), TBL_ENTRY(0xa72), TBL_ENTRY(0xa73), + TBL_ENTRY(0xa74), TBL_ENTRY(0xa75), TBL_ENTRY(0xa76), TBL_ENTRY(0xa77), + TBL_ENTRY(0xa78), TBL_ENTRY(0xa79), TBL_ENTRY(0xa7a), TBL_ENTRY(0xa7b), + TBL_ENTRY(0xa7c), TBL_ENTRY(0xa7d), TBL_ENTRY(0xa7e), TBL_ENTRY(0xa7f), + TBL_ENTRY(0xa80), TBL_ENTRY(0xa81), TBL_ENTRY(0xa82), TBL_ENTRY(0xa83), + TBL_ENTRY(0xa84), TBL_ENTRY(0xa85), TBL_ENTRY(0xa86), TBL_ENTRY(0xa87), + TBL_ENTRY(0xa88), TBL_ENTRY(0xa89), TBL_ENTRY(0xa8a), TBL_ENTRY(0xa8b), + TBL_ENTRY(0xa8c), TBL_ENTRY(0xa8d), TBL_ENTRY(0xa8e), TBL_ENTRY(0xa8f), + TBL_ENTRY(0xa90), TBL_ENTRY(0xa91), TBL_ENTRY(0xa92), TBL_ENTRY(0xa93), + TBL_ENTRY(0xa94), TBL_ENTRY(0xa95), TBL_ENTRY(0xa96), TBL_ENTRY(0xa97), + TBL_ENTRY(0xa98), TBL_ENTRY(0xa99), TBL_ENTRY(0xa9a), TBL_ENTRY(0xa9b), + TBL_ENTRY(0xa9c), TBL_ENTRY(0xa9d), TBL_ENTRY(0xa9e), TBL_ENTRY(0xa9f), + TBL_ENTRY(0xaa0), TBL_ENTRY(0xaa1), TBL_ENTRY(0xaa2), TBL_ENTRY(0xaa3), + TBL_ENTRY(0xaa4), TBL_ENTRY(0xaa5), TBL_ENTRY(0xaa6), TBL_ENTRY(0xaa7), + TBL_ENTRY(0xaa8), TBL_ENTRY(0xaa9), TBL_ENTRY(0xaaa), TBL_ENTRY(0xaab), + TBL_ENTRY(0xaac), TBL_ENTRY(0xaad), TBL_ENTRY(0xaae), TBL_ENTRY(0xaaf), + TBL_ENTRY(0xab0), TBL_ENTRY(0xab1), TBL_ENTRY(0xab2), TBL_ENTRY(0xab3), + TBL_ENTRY(0xab4), TBL_ENTRY(0xab5), TBL_ENTRY(0xab6), TBL_ENTRY(0xab7), + TBL_ENTRY(0xab8), TBL_ENTRY(0xab9), TBL_ENTRY(0xaba), TBL_ENTRY(0xabb), + TBL_ENTRY(0xabc), TBL_ENTRY(0xabd), TBL_ENTRY(0xabe), TBL_ENTRY(0xabf), + TBL_ENTRY(0xac0), TBL_ENTRY(0xac1), TBL_ENTRY(0xac2), TBL_ENTRY(0xac3), + TBL_ENTRY(0xac4), TBL_ENTRY(0xac5), TBL_ENTRY(0xac6), TBL_ENTRY(0xac7), + TBL_ENTRY(0xac8), TBL_ENTRY(0xac9), TBL_ENTRY(0xaca), TBL_ENTRY(0xacb), + TBL_ENTRY(0xacc), TBL_ENTRY(0xacd), TBL_ENTRY(0xace), TBL_ENTRY(0xacf), + TBL_ENTRY(0xad0), TBL_ENTRY(0xad1), TBL_ENTRY(0xad2), TBL_ENTRY(0xad3), + TBL_ENTRY(0xad4), TBL_ENTRY(0xad5), TBL_ENTRY(0xad6), TBL_ENTRY(0xad7), + TBL_ENTRY(0xad8), TBL_ENTRY(0xad9), TBL_ENTRY(0xada), TBL_ENTRY(0xadb), + TBL_ENTRY(0xadc), TBL_ENTRY(0xadd), TBL_ENTRY(0xade), TBL_ENTRY(0xadf), + TBL_ENTRY(0xae0), TBL_ENTRY(0xae1), TBL_ENTRY(0xae2), TBL_ENTRY(0xae3), + TBL_ENTRY(0xae4), TBL_ENTRY(0xae5), TBL_ENTRY(0xae6), TBL_ENTRY(0xae7), + TBL_ENTRY(0xae8), TBL_ENTRY(0xae9), TBL_ENTRY(0xaea), TBL_ENTRY(0xaeb), + TBL_ENTRY(0xaec), TBL_ENTRY(0xaed), TBL_ENTRY(0xaee), TBL_ENTRY(0xaef), + TBL_ENTRY(0xaf0), TBL_ENTRY(0xaf1), TBL_ENTRY(0xaf2), TBL_ENTRY(0xaf3), + TBL_ENTRY(0xaf4), TBL_ENTRY(0xaf5), TBL_ENTRY(0xaf6), TBL_ENTRY(0xaf7), + TBL_ENTRY(0xaf8), TBL_ENTRY(0xaf9), TBL_ENTRY(0xafa), TBL_ENTRY(0xafb), + TBL_ENTRY(0xafc), TBL_ENTRY(0xafd), TBL_ENTRY(0xafe), TBL_ENTRY(0xaff), + TBL_ENTRY(0xb00), TBL_ENTRY(0xb01), TBL_ENTRY(0xb02), TBL_ENTRY(0xb03), + TBL_ENTRY(0xb04), TBL_ENTRY(0xb05), TBL_ENTRY(0xb06), TBL_ENTRY(0xb07), + TBL_ENTRY(0xb08), TBL_ENTRY(0xb09), TBL_ENTRY(0xb0a), TBL_ENTRY(0xb0b), + TBL_ENTRY(0xb0c), TBL_ENTRY(0xb0d), TBL_ENTRY(0xb0e), TBL_ENTRY(0xb0f), + TBL_ENTRY(0xb10), TBL_ENTRY(0xb11), TBL_ENTRY(0xb12), TBL_ENTRY(0xb13), + TBL_ENTRY(0xb14), TBL_ENTRY(0xb15), TBL_ENTRY(0xb16), TBL_ENTRY(0xb17), + TBL_ENTRY(0xb18), TBL_ENTRY(0xb19), TBL_ENTRY(0xb1a), TBL_ENTRY(0xb1b), + TBL_ENTRY(0xb1c), TBL_ENTRY(0xb1d), TBL_ENTRY(0xb1e), TBL_ENTRY(0xb1f), + TBL_ENTRY(0xb20), TBL_ENTRY(0xb21), TBL_ENTRY(0xb22), TBL_ENTRY(0xb23), + TBL_ENTRY(0xb24), TBL_ENTRY(0xb25), TBL_ENTRY(0xb26), TBL_ENTRY(0xb27), + TBL_ENTRY(0xb28), TBL_ENTRY(0xb29), TBL_ENTRY(0xb2a), TBL_ENTRY(0xb2b), + TBL_ENTRY(0xb2c), TBL_ENTRY(0xb2d), TBL_ENTRY(0xb2e), TBL_ENTRY(0xb2f), + TBL_ENTRY(0xb30), TBL_ENTRY(0xb31), TBL_ENTRY(0xb32), TBL_ENTRY(0xb33), + TBL_ENTRY(0xb34), TBL_ENTRY(0xb35), TBL_ENTRY(0xb36), TBL_ENTRY(0xb37), + TBL_ENTRY(0xb38), TBL_ENTRY(0xb39), TBL_ENTRY(0xb3a), TBL_ENTRY(0xb3b), + TBL_ENTRY(0xb3c), TBL_ENTRY(0xb3d), TBL_ENTRY(0xb3e), TBL_ENTRY(0xb3f), + TBL_ENTRY(0xb40), TBL_ENTRY(0xb41), TBL_ENTRY(0xb42), TBL_ENTRY(0xb43), + TBL_ENTRY(0xb44), TBL_ENTRY(0xb45), TBL_ENTRY(0xb46), TBL_ENTRY(0xb47), + TBL_ENTRY(0xb48), TBL_ENTRY(0xb49), TBL_ENTRY(0xb4a), TBL_ENTRY(0xb4b), + TBL_ENTRY(0xb4c), TBL_ENTRY(0xb4d), TBL_ENTRY(0xb4e), TBL_ENTRY(0xb4f), + TBL_ENTRY(0xb50), TBL_ENTRY(0xb51), TBL_ENTRY(0xb52), TBL_ENTRY(0xb53), + TBL_ENTRY(0xb54), TBL_ENTRY(0xb55), TBL_ENTRY(0xb56), TBL_ENTRY(0xb57), + TBL_ENTRY(0xb58), TBL_ENTRY(0xb59), TBL_ENTRY(0xb5a), TBL_ENTRY(0xb5b), + TBL_ENTRY(0xb5c), TBL_ENTRY(0xb5d), TBL_ENTRY(0xb5e), TBL_ENTRY(0xb5f), + TBL_ENTRY(0xb60), TBL_ENTRY(0xb61), TBL_ENTRY(0xb62), TBL_ENTRY(0xb63), + TBL_ENTRY(0xb64), TBL_ENTRY(0xb65), TBL_ENTRY(0xb66), TBL_ENTRY(0xb67), + TBL_ENTRY(0xb68), TBL_ENTRY(0xb69), TBL_ENTRY(0xb6a), TBL_ENTRY(0xb6b), + TBL_ENTRY(0xb6c), TBL_ENTRY(0xb6d), TBL_ENTRY(0xb6e), TBL_ENTRY(0xb6f), + TBL_ENTRY(0xb70), TBL_ENTRY(0xb71), TBL_ENTRY(0xb72), TBL_ENTRY(0xb73), + TBL_ENTRY(0xb74), TBL_ENTRY(0xb75), TBL_ENTRY(0xb76), TBL_ENTRY(0xb77), + TBL_ENTRY(0xb78), TBL_ENTRY(0xb79), TBL_ENTRY(0xb7a), TBL_ENTRY(0xb7b), + TBL_ENTRY(0xb7c), TBL_ENTRY(0xb7d), TBL_ENTRY(0xb7e), TBL_ENTRY(0xb7f), + TBL_ENTRY(0xb80), TBL_ENTRY(0xb81), TBL_ENTRY(0xb82), TBL_ENTRY(0xb83), + TBL_ENTRY(0xb84), TBL_ENTRY(0xb85), TBL_ENTRY(0xb86), TBL_ENTRY(0xb87), + TBL_ENTRY(0xb88), TBL_ENTRY(0xb89), TBL_ENTRY(0xb8a), TBL_ENTRY(0xb8b), + TBL_ENTRY(0xb8c), TBL_ENTRY(0xb8d), TBL_ENTRY(0xb8e), TBL_ENTRY(0xb8f), + TBL_ENTRY(0xb90), TBL_ENTRY(0xb91), TBL_ENTRY(0xb92), TBL_ENTRY(0xb93), + TBL_ENTRY(0xb94), TBL_ENTRY(0xb95), TBL_ENTRY(0xb96), TBL_ENTRY(0xb97), + TBL_ENTRY(0xb98), TBL_ENTRY(0xb99), TBL_ENTRY(0xb9a), TBL_ENTRY(0xb9b), + TBL_ENTRY(0xb9c), TBL_ENTRY(0xb9d), TBL_ENTRY(0xb9e), TBL_ENTRY(0xb9f), + TBL_ENTRY(0xba0), TBL_ENTRY(0xba1), TBL_ENTRY(0xba2), TBL_ENTRY(0xba3), + TBL_ENTRY(0xba4), TBL_ENTRY(0xba5), TBL_ENTRY(0xba6), TBL_ENTRY(0xba7), + TBL_ENTRY(0xba8), TBL_ENTRY(0xba9), TBL_ENTRY(0xbaa), TBL_ENTRY(0xbab), + TBL_ENTRY(0xbac), TBL_ENTRY(0xbad), TBL_ENTRY(0xbae), TBL_ENTRY(0xbaf), + TBL_ENTRY(0xbb0), TBL_ENTRY(0xbb1), TBL_ENTRY(0xbb2), TBL_ENTRY(0xbb3), + TBL_ENTRY(0xbb4), TBL_ENTRY(0xbb5), TBL_ENTRY(0xbb6), TBL_ENTRY(0xbb7), + TBL_ENTRY(0xbb8), TBL_ENTRY(0xbb9), TBL_ENTRY(0xbba), TBL_ENTRY(0xbbb), + TBL_ENTRY(0xbbc), TBL_ENTRY(0xbbd), TBL_ENTRY(0xbbe), TBL_ENTRY(0xbbf), + TBL_ENTRY(0xbc0), TBL_ENTRY(0xbc1), TBL_ENTRY(0xbc2), TBL_ENTRY(0xbc3), + TBL_ENTRY(0xbc4), TBL_ENTRY(0xbc5), TBL_ENTRY(0xbc6), TBL_ENTRY(0xbc7), + TBL_ENTRY(0xbc8), TBL_ENTRY(0xbc9), TBL_ENTRY(0xbca), TBL_ENTRY(0xbcb), + TBL_ENTRY(0xbcc), TBL_ENTRY(0xbcd), TBL_ENTRY(0xbce), TBL_ENTRY(0xbcf), + TBL_ENTRY(0xbd0), TBL_ENTRY(0xbd1), TBL_ENTRY(0xbd2), TBL_ENTRY(0xbd3), + TBL_ENTRY(0xbd4), TBL_ENTRY(0xbd5), TBL_ENTRY(0xbd6), TBL_ENTRY(0xbd7), + TBL_ENTRY(0xbd8), TBL_ENTRY(0xbd9), TBL_ENTRY(0xbda), TBL_ENTRY(0xbdb), + TBL_ENTRY(0xbdc), TBL_ENTRY(0xbdd), TBL_ENTRY(0xbde), TBL_ENTRY(0xbdf), + TBL_ENTRY(0xbe0), TBL_ENTRY(0xbe1), TBL_ENTRY(0xbe2), TBL_ENTRY(0xbe3), + TBL_ENTRY(0xbe4), TBL_ENTRY(0xbe5), TBL_ENTRY(0xbe6), TBL_ENTRY(0xbe7), + TBL_ENTRY(0xbe8), TBL_ENTRY(0xbe9), TBL_ENTRY(0xbea), TBL_ENTRY(0xbeb), + TBL_ENTRY(0xbec), TBL_ENTRY(0xbed), TBL_ENTRY(0xbee), TBL_ENTRY(0xbef), + TBL_ENTRY(0xbf0), TBL_ENTRY(0xbf1), TBL_ENTRY(0xbf2), TBL_ENTRY(0xbf3), + TBL_ENTRY(0xbf4), TBL_ENTRY(0xbf5), TBL_ENTRY(0xbf6), TBL_ENTRY(0xbf7), + TBL_ENTRY(0xbf8), TBL_ENTRY(0xbf9), TBL_ENTRY(0xbfa), TBL_ENTRY(0xbfb), + TBL_ENTRY(0xbfc), TBL_ENTRY(0xbfd), TBL_ENTRY(0xbfe), TBL_ENTRY(0xbff), + TBL_ENTRY(0xc00), TBL_ENTRY(0xc01), TBL_ENTRY(0xc02), TBL_ENTRY(0xc03), + TBL_ENTRY(0xc04), TBL_ENTRY(0xc05), TBL_ENTRY(0xc06), TBL_ENTRY(0xc07), + TBL_ENTRY(0xc08), TBL_ENTRY(0xc09), TBL_ENTRY(0xc0a), TBL_ENTRY(0xc0b), + TBL_ENTRY(0xc0c), TBL_ENTRY(0xc0d), TBL_ENTRY(0xc0e), TBL_ENTRY(0xc0f), + TBL_ENTRY(0xc10), TBL_ENTRY(0xc11), TBL_ENTRY(0xc12), TBL_ENTRY(0xc13), + TBL_ENTRY(0xc14), TBL_ENTRY(0xc15), TBL_ENTRY(0xc16), TBL_ENTRY(0xc17), + TBL_ENTRY(0xc18), TBL_ENTRY(0xc19), TBL_ENTRY(0xc1a), TBL_ENTRY(0xc1b), + TBL_ENTRY(0xc1c), TBL_ENTRY(0xc1d), TBL_ENTRY(0xc1e), TBL_ENTRY(0xc1f), + TBL_ENTRY(0xc20), TBL_ENTRY(0xc21), TBL_ENTRY(0xc22), TBL_ENTRY(0xc23), + TBL_ENTRY(0xc24), TBL_ENTRY(0xc25), TBL_ENTRY(0xc26), TBL_ENTRY(0xc27), + TBL_ENTRY(0xc28), TBL_ENTRY(0xc29), TBL_ENTRY(0xc2a), TBL_ENTRY(0xc2b), + TBL_ENTRY(0xc2c), TBL_ENTRY(0xc2d), TBL_ENTRY(0xc2e), TBL_ENTRY(0xc2f), + TBL_ENTRY(0xc30), TBL_ENTRY(0xc31), TBL_ENTRY(0xc32), TBL_ENTRY(0xc33), + TBL_ENTRY(0xc34), TBL_ENTRY(0xc35), TBL_ENTRY(0xc36), TBL_ENTRY(0xc37), + TBL_ENTRY(0xc38), TBL_ENTRY(0xc39), TBL_ENTRY(0xc3a), TBL_ENTRY(0xc3b), + TBL_ENTRY(0xc3c), TBL_ENTRY(0xc3d), TBL_ENTRY(0xc3e), TBL_ENTRY(0xc3f), + TBL_ENTRY(0xc40), TBL_ENTRY(0xc41), TBL_ENTRY(0xc42), TBL_ENTRY(0xc43), + TBL_ENTRY(0xc44), TBL_ENTRY(0xc45), TBL_ENTRY(0xc46), TBL_ENTRY(0xc47), + TBL_ENTRY(0xc48), TBL_ENTRY(0xc49), TBL_ENTRY(0xc4a), TBL_ENTRY(0xc4b), + TBL_ENTRY(0xc4c), TBL_ENTRY(0xc4d), TBL_ENTRY(0xc4e), TBL_ENTRY(0xc4f), + TBL_ENTRY(0xc50), TBL_ENTRY(0xc51), TBL_ENTRY(0xc52), TBL_ENTRY(0xc53), + TBL_ENTRY(0xc54), TBL_ENTRY(0xc55), TBL_ENTRY(0xc56), TBL_ENTRY(0xc57), + TBL_ENTRY(0xc58), TBL_ENTRY(0xc59), TBL_ENTRY(0xc5a), TBL_ENTRY(0xc5b), + TBL_ENTRY(0xc5c), TBL_ENTRY(0xc5d), TBL_ENTRY(0xc5e), TBL_ENTRY(0xc5f), + TBL_ENTRY(0xc60), TBL_ENTRY(0xc61), TBL_ENTRY(0xc62), TBL_ENTRY(0xc63), + TBL_ENTRY(0xc64), TBL_ENTRY(0xc65), TBL_ENTRY(0xc66), TBL_ENTRY(0xc67), + TBL_ENTRY(0xc68), TBL_ENTRY(0xc69), TBL_ENTRY(0xc6a), TBL_ENTRY(0xc6b), + TBL_ENTRY(0xc6c), TBL_ENTRY(0xc6d), TBL_ENTRY(0xc6e), TBL_ENTRY(0xc6f), + TBL_ENTRY(0xc70), TBL_ENTRY(0xc71), TBL_ENTRY(0xc72), TBL_ENTRY(0xc73), + TBL_ENTRY(0xc74), TBL_ENTRY(0xc75), TBL_ENTRY(0xc76), TBL_ENTRY(0xc77), + TBL_ENTRY(0xc78), TBL_ENTRY(0xc79), TBL_ENTRY(0xc7a), TBL_ENTRY(0xc7b), + TBL_ENTRY(0xc7c), TBL_ENTRY(0xc7d), TBL_ENTRY(0xc7e), TBL_ENTRY(0xc7f), + TBL_ENTRY(0xc80), TBL_ENTRY(0xc81), TBL_ENTRY(0xc82), TBL_ENTRY(0xc83), + TBL_ENTRY(0xc84), TBL_ENTRY(0xc85), TBL_ENTRY(0xc86), TBL_ENTRY(0xc87), + TBL_ENTRY(0xc88), TBL_ENTRY(0xc89), TBL_ENTRY(0xc8a), TBL_ENTRY(0xc8b), + TBL_ENTRY(0xc8c), TBL_ENTRY(0xc8d), TBL_ENTRY(0xc8e), TBL_ENTRY(0xc8f), + TBL_ENTRY(0xc90), TBL_ENTRY(0xc91), TBL_ENTRY(0xc92), TBL_ENTRY(0xc93), + TBL_ENTRY(0xc94), TBL_ENTRY(0xc95), TBL_ENTRY(0xc96), TBL_ENTRY(0xc97), + TBL_ENTRY(0xc98), TBL_ENTRY(0xc99), TBL_ENTRY(0xc9a), TBL_ENTRY(0xc9b), + TBL_ENTRY(0xc9c), TBL_ENTRY(0xc9d), TBL_ENTRY(0xc9e), TBL_ENTRY(0xc9f), + TBL_ENTRY(0xca0), TBL_ENTRY(0xca1), TBL_ENTRY(0xca2), TBL_ENTRY(0xca3), + TBL_ENTRY(0xca4), TBL_ENTRY(0xca5), TBL_ENTRY(0xca6), TBL_ENTRY(0xca7), + TBL_ENTRY(0xca8), TBL_ENTRY(0xca9), TBL_ENTRY(0xcaa), TBL_ENTRY(0xcab), + TBL_ENTRY(0xcac), TBL_ENTRY(0xcad), TBL_ENTRY(0xcae), TBL_ENTRY(0xcaf), + TBL_ENTRY(0xcb0), TBL_ENTRY(0xcb1), TBL_ENTRY(0xcb2), TBL_ENTRY(0xcb3), + TBL_ENTRY(0xcb4), TBL_ENTRY(0xcb5), TBL_ENTRY(0xcb6), TBL_ENTRY(0xcb7), + TBL_ENTRY(0xcb8), TBL_ENTRY(0xcb9), TBL_ENTRY(0xcba), TBL_ENTRY(0xcbb), + TBL_ENTRY(0xcbc), TBL_ENTRY(0xcbd), TBL_ENTRY(0xcbe), TBL_ENTRY(0xcbf), + TBL_ENTRY(0xcc0), TBL_ENTRY(0xcc1), TBL_ENTRY(0xcc2), TBL_ENTRY(0xcc3), + TBL_ENTRY(0xcc4), TBL_ENTRY(0xcc5), TBL_ENTRY(0xcc6), TBL_ENTRY(0xcc7), + TBL_ENTRY(0xcc8), TBL_ENTRY(0xcc9), TBL_ENTRY(0xcca), TBL_ENTRY(0xccb), + TBL_ENTRY(0xccc), TBL_ENTRY(0xccd), TBL_ENTRY(0xcce), TBL_ENTRY(0xccf), + TBL_ENTRY(0xcd0), TBL_ENTRY(0xcd1), TBL_ENTRY(0xcd2), TBL_ENTRY(0xcd3), + TBL_ENTRY(0xcd4), TBL_ENTRY(0xcd5), TBL_ENTRY(0xcd6), TBL_ENTRY(0xcd7), + TBL_ENTRY(0xcd8), TBL_ENTRY(0xcd9), TBL_ENTRY(0xcda), TBL_ENTRY(0xcdb), + TBL_ENTRY(0xcdc), TBL_ENTRY(0xcdd), TBL_ENTRY(0xcde), TBL_ENTRY(0xcdf), + TBL_ENTRY(0xce0), TBL_ENTRY(0xce1), TBL_ENTRY(0xce2), TBL_ENTRY(0xce3), + TBL_ENTRY(0xce4), TBL_ENTRY(0xce5), TBL_ENTRY(0xce6), TBL_ENTRY(0xce7), + TBL_ENTRY(0xce8), TBL_ENTRY(0xce9), TBL_ENTRY(0xcea), TBL_ENTRY(0xceb), + TBL_ENTRY(0xcec), TBL_ENTRY(0xced), TBL_ENTRY(0xcee), TBL_ENTRY(0xcef), + TBL_ENTRY(0xcf0), TBL_ENTRY(0xcf1), TBL_ENTRY(0xcf2), TBL_ENTRY(0xcf3), + TBL_ENTRY(0xcf4), TBL_ENTRY(0xcf5), TBL_ENTRY(0xcf6), TBL_ENTRY(0xcf7), + TBL_ENTRY(0xcf8), TBL_ENTRY(0xcf9), TBL_ENTRY(0xcfa), TBL_ENTRY(0xcfb), + TBL_ENTRY(0xcfc), TBL_ENTRY(0xcfd), TBL_ENTRY(0xcfe), TBL_ENTRY(0xcff), + TBL_ENTRY(0xd00), TBL_ENTRY(0xd01), TBL_ENTRY(0xd02), TBL_ENTRY(0xd03), + TBL_ENTRY(0xd04), TBL_ENTRY(0xd05), TBL_ENTRY(0xd06), TBL_ENTRY(0xd07), + TBL_ENTRY(0xd08), TBL_ENTRY(0xd09), TBL_ENTRY(0xd0a), TBL_ENTRY(0xd0b), + TBL_ENTRY(0xd0c), TBL_ENTRY(0xd0d), TBL_ENTRY(0xd0e), TBL_ENTRY(0xd0f), + TBL_ENTRY(0xd10), TBL_ENTRY(0xd11), TBL_ENTRY(0xd12), TBL_ENTRY(0xd13), + TBL_ENTRY(0xd14), TBL_ENTRY(0xd15), TBL_ENTRY(0xd16), TBL_ENTRY(0xd17), + TBL_ENTRY(0xd18), TBL_ENTRY(0xd19), TBL_ENTRY(0xd1a), TBL_ENTRY(0xd1b), + TBL_ENTRY(0xd1c), TBL_ENTRY(0xd1d), TBL_ENTRY(0xd1e), TBL_ENTRY(0xd1f), + TBL_ENTRY(0xd20), TBL_ENTRY(0xd21), TBL_ENTRY(0xd22), TBL_ENTRY(0xd23), + TBL_ENTRY(0xd24), TBL_ENTRY(0xd25), TBL_ENTRY(0xd26), TBL_ENTRY(0xd27), + TBL_ENTRY(0xd28), TBL_ENTRY(0xd29), TBL_ENTRY(0xd2a), TBL_ENTRY(0xd2b), + TBL_ENTRY(0xd2c), TBL_ENTRY(0xd2d), TBL_ENTRY(0xd2e), TBL_ENTRY(0xd2f), + TBL_ENTRY(0xd30), TBL_ENTRY(0xd31), TBL_ENTRY(0xd32), TBL_ENTRY(0xd33), + TBL_ENTRY(0xd34), TBL_ENTRY(0xd35), TBL_ENTRY(0xd36), TBL_ENTRY(0xd37), + TBL_ENTRY(0xd38), TBL_ENTRY(0xd39), TBL_ENTRY(0xd3a), TBL_ENTRY(0xd3b), + TBL_ENTRY(0xd3c), TBL_ENTRY(0xd3d), TBL_ENTRY(0xd3e), TBL_ENTRY(0xd3f), + TBL_ENTRY(0xd40), TBL_ENTRY(0xd41), TBL_ENTRY(0xd42), TBL_ENTRY(0xd43), + TBL_ENTRY(0xd44), TBL_ENTRY(0xd45), TBL_ENTRY(0xd46), TBL_ENTRY(0xd47), + TBL_ENTRY(0xd48), TBL_ENTRY(0xd49), TBL_ENTRY(0xd4a), TBL_ENTRY(0xd4b), + TBL_ENTRY(0xd4c), TBL_ENTRY(0xd4d), TBL_ENTRY(0xd4e), TBL_ENTRY(0xd4f), + TBL_ENTRY(0xd50), TBL_ENTRY(0xd51), TBL_ENTRY(0xd52), TBL_ENTRY(0xd53), + TBL_ENTRY(0xd54), TBL_ENTRY(0xd55), TBL_ENTRY(0xd56), TBL_ENTRY(0xd57), + TBL_ENTRY(0xd58), TBL_ENTRY(0xd59), TBL_ENTRY(0xd5a), TBL_ENTRY(0xd5b), + TBL_ENTRY(0xd5c), TBL_ENTRY(0xd5d), TBL_ENTRY(0xd5e), TBL_ENTRY(0xd5f), + TBL_ENTRY(0xd60), TBL_ENTRY(0xd61), TBL_ENTRY(0xd62), TBL_ENTRY(0xd63), + TBL_ENTRY(0xd64), TBL_ENTRY(0xd65), TBL_ENTRY(0xd66), TBL_ENTRY(0xd67), + TBL_ENTRY(0xd68), TBL_ENTRY(0xd69), TBL_ENTRY(0xd6a), TBL_ENTRY(0xd6b), + TBL_ENTRY(0xd6c), TBL_ENTRY(0xd6d), TBL_ENTRY(0xd6e), TBL_ENTRY(0xd6f), + TBL_ENTRY(0xd70), TBL_ENTRY(0xd71), TBL_ENTRY(0xd72), TBL_ENTRY(0xd73), + TBL_ENTRY(0xd74), TBL_ENTRY(0xd75), TBL_ENTRY(0xd76), TBL_ENTRY(0xd77), + TBL_ENTRY(0xd78), TBL_ENTRY(0xd79), TBL_ENTRY(0xd7a), TBL_ENTRY(0xd7b), + TBL_ENTRY(0xd7c), TBL_ENTRY(0xd7d), TBL_ENTRY(0xd7e), TBL_ENTRY(0xd7f), + TBL_ENTRY(0xd80), TBL_ENTRY(0xd81), TBL_ENTRY(0xd82), TBL_ENTRY(0xd83), + TBL_ENTRY(0xd84), TBL_ENTRY(0xd85), TBL_ENTRY(0xd86), TBL_ENTRY(0xd87), + TBL_ENTRY(0xd88), TBL_ENTRY(0xd89), TBL_ENTRY(0xd8a), TBL_ENTRY(0xd8b), + TBL_ENTRY(0xd8c), TBL_ENTRY(0xd8d), TBL_ENTRY(0xd8e), TBL_ENTRY(0xd8f), + TBL_ENTRY(0xd90), TBL_ENTRY(0xd91), TBL_ENTRY(0xd92), TBL_ENTRY(0xd93), + TBL_ENTRY(0xd94), TBL_ENTRY(0xd95), TBL_ENTRY(0xd96), TBL_ENTRY(0xd97), + TBL_ENTRY(0xd98), TBL_ENTRY(0xd99), TBL_ENTRY(0xd9a), TBL_ENTRY(0xd9b), + TBL_ENTRY(0xd9c), TBL_ENTRY(0xd9d), TBL_ENTRY(0xd9e), TBL_ENTRY(0xd9f), + TBL_ENTRY(0xda0), TBL_ENTRY(0xda1), TBL_ENTRY(0xda2), TBL_ENTRY(0xda3), + TBL_ENTRY(0xda4), TBL_ENTRY(0xda5), TBL_ENTRY(0xda6), TBL_ENTRY(0xda7), + TBL_ENTRY(0xda8), TBL_ENTRY(0xda9), TBL_ENTRY(0xdaa), TBL_ENTRY(0xdab), + TBL_ENTRY(0xdac), TBL_ENTRY(0xdad), TBL_ENTRY(0xdae), TBL_ENTRY(0xdaf), + TBL_ENTRY(0xdb0), TBL_ENTRY(0xdb1), TBL_ENTRY(0xdb2), TBL_ENTRY(0xdb3), + TBL_ENTRY(0xdb4), TBL_ENTRY(0xdb5), TBL_ENTRY(0xdb6), TBL_ENTRY(0xdb7), + TBL_ENTRY(0xdb8), TBL_ENTRY(0xdb9), TBL_ENTRY(0xdba), TBL_ENTRY(0xdbb), + TBL_ENTRY(0xdbc), TBL_ENTRY(0xdbd), TBL_ENTRY(0xdbe), TBL_ENTRY(0xdbf), + TBL_ENTRY(0xdc0), TBL_ENTRY(0xdc1), TBL_ENTRY(0xdc2), TBL_ENTRY(0xdc3), + TBL_ENTRY(0xdc4), TBL_ENTRY(0xdc5), TBL_ENTRY(0xdc6), TBL_ENTRY(0xdc7), + TBL_ENTRY(0xdc8), TBL_ENTRY(0xdc9), TBL_ENTRY(0xdca), TBL_ENTRY(0xdcb), + TBL_ENTRY(0xdcc), TBL_ENTRY(0xdcd), TBL_ENTRY(0xdce), TBL_ENTRY(0xdcf), + TBL_ENTRY(0xdd0), TBL_ENTRY(0xdd1), TBL_ENTRY(0xdd2), TBL_ENTRY(0xdd3), + TBL_ENTRY(0xdd4), TBL_ENTRY(0xdd5), TBL_ENTRY(0xdd6), TBL_ENTRY(0xdd7), + TBL_ENTRY(0xdd8), TBL_ENTRY(0xdd9), TBL_ENTRY(0xdda), TBL_ENTRY(0xddb), + TBL_ENTRY(0xddc), TBL_ENTRY(0xddd), TBL_ENTRY(0xdde), TBL_ENTRY(0xddf), + TBL_ENTRY(0xde0), TBL_ENTRY(0xde1), TBL_ENTRY(0xde2), TBL_ENTRY(0xde3), + TBL_ENTRY(0xde4), TBL_ENTRY(0xde5), TBL_ENTRY(0xde6), TBL_ENTRY(0xde7), + TBL_ENTRY(0xde8), TBL_ENTRY(0xde9), TBL_ENTRY(0xdea), TBL_ENTRY(0xdeb), + TBL_ENTRY(0xdec), TBL_ENTRY(0xded), TBL_ENTRY(0xdee), TBL_ENTRY(0xdef), + TBL_ENTRY(0xdf0), TBL_ENTRY(0xdf1), TBL_ENTRY(0xdf2), TBL_ENTRY(0xdf3), + TBL_ENTRY(0xdf4), TBL_ENTRY(0xdf5), TBL_ENTRY(0xdf6), TBL_ENTRY(0xdf7), + TBL_ENTRY(0xdf8), TBL_ENTRY(0xdf9), TBL_ENTRY(0xdfa), TBL_ENTRY(0xdfb), + TBL_ENTRY(0xdfc), TBL_ENTRY(0xdfd), TBL_ENTRY(0xdfe), TBL_ENTRY(0xdff), + TBL_ENTRY(0xe00), TBL_ENTRY(0xe01), TBL_ENTRY(0xe02), TBL_ENTRY(0xe03), + TBL_ENTRY(0xe04), TBL_ENTRY(0xe05), TBL_ENTRY(0xe06), TBL_ENTRY(0xe07), + TBL_ENTRY(0xe08), TBL_ENTRY(0xe09), TBL_ENTRY(0xe0a), TBL_ENTRY(0xe0b), + TBL_ENTRY(0xe0c), TBL_ENTRY(0xe0d), TBL_ENTRY(0xe0e), TBL_ENTRY(0xe0f), + TBL_ENTRY(0xe10), TBL_ENTRY(0xe11), TBL_ENTRY(0xe12), TBL_ENTRY(0xe13), + TBL_ENTRY(0xe14), TBL_ENTRY(0xe15), TBL_ENTRY(0xe16), TBL_ENTRY(0xe17), + TBL_ENTRY(0xe18), TBL_ENTRY(0xe19), TBL_ENTRY(0xe1a), TBL_ENTRY(0xe1b), + TBL_ENTRY(0xe1c), TBL_ENTRY(0xe1d), TBL_ENTRY(0xe1e), TBL_ENTRY(0xe1f), + TBL_ENTRY(0xe20), TBL_ENTRY(0xe21), TBL_ENTRY(0xe22), TBL_ENTRY(0xe23), + TBL_ENTRY(0xe24), TBL_ENTRY(0xe25), TBL_ENTRY(0xe26), TBL_ENTRY(0xe27), + TBL_ENTRY(0xe28), TBL_ENTRY(0xe29), TBL_ENTRY(0xe2a), TBL_ENTRY(0xe2b), + TBL_ENTRY(0xe2c), TBL_ENTRY(0xe2d), TBL_ENTRY(0xe2e), TBL_ENTRY(0xe2f), + TBL_ENTRY(0xe30), TBL_ENTRY(0xe31), TBL_ENTRY(0xe32), TBL_ENTRY(0xe33), + TBL_ENTRY(0xe34), TBL_ENTRY(0xe35), TBL_ENTRY(0xe36), TBL_ENTRY(0xe37), + TBL_ENTRY(0xe38), TBL_ENTRY(0xe39), TBL_ENTRY(0xe3a), TBL_ENTRY(0xe3b), + TBL_ENTRY(0xe3c), TBL_ENTRY(0xe3d), TBL_ENTRY(0xe3e), TBL_ENTRY(0xe3f), + TBL_ENTRY(0xe40), TBL_ENTRY(0xe41), TBL_ENTRY(0xe42), TBL_ENTRY(0xe43), + TBL_ENTRY(0xe44), TBL_ENTRY(0xe45), TBL_ENTRY(0xe46), TBL_ENTRY(0xe47), + TBL_ENTRY(0xe48), TBL_ENTRY(0xe49), TBL_ENTRY(0xe4a), TBL_ENTRY(0xe4b), + TBL_ENTRY(0xe4c), TBL_ENTRY(0xe4d), TBL_ENTRY(0xe4e), TBL_ENTRY(0xe4f), + TBL_ENTRY(0xe50), TBL_ENTRY(0xe51), TBL_ENTRY(0xe52), TBL_ENTRY(0xe53), + TBL_ENTRY(0xe54), TBL_ENTRY(0xe55), TBL_ENTRY(0xe56), TBL_ENTRY(0xe57), + TBL_ENTRY(0xe58), TBL_ENTRY(0xe59), TBL_ENTRY(0xe5a), TBL_ENTRY(0xe5b), + TBL_ENTRY(0xe5c), TBL_ENTRY(0xe5d), TBL_ENTRY(0xe5e), TBL_ENTRY(0xe5f), + TBL_ENTRY(0xe60), TBL_ENTRY(0xe61), TBL_ENTRY(0xe62), TBL_ENTRY(0xe63), + TBL_ENTRY(0xe64), TBL_ENTRY(0xe65), TBL_ENTRY(0xe66), TBL_ENTRY(0xe67), + TBL_ENTRY(0xe68), TBL_ENTRY(0xe69), TBL_ENTRY(0xe6a), TBL_ENTRY(0xe6b), + TBL_ENTRY(0xe6c), TBL_ENTRY(0xe6d), TBL_ENTRY(0xe6e), TBL_ENTRY(0xe6f), + TBL_ENTRY(0xe70), TBL_ENTRY(0xe71), TBL_ENTRY(0xe72), TBL_ENTRY(0xe73), + TBL_ENTRY(0xe74), TBL_ENTRY(0xe75), TBL_ENTRY(0xe76), TBL_ENTRY(0xe77), + TBL_ENTRY(0xe78), TBL_ENTRY(0xe79), TBL_ENTRY(0xe7a), TBL_ENTRY(0xe7b), + TBL_ENTRY(0xe7c), TBL_ENTRY(0xe7d), TBL_ENTRY(0xe7e), TBL_ENTRY(0xe7f), + TBL_ENTRY(0xe80), TBL_ENTRY(0xe81), TBL_ENTRY(0xe82), TBL_ENTRY(0xe83), + TBL_ENTRY(0xe84), TBL_ENTRY(0xe85), TBL_ENTRY(0xe86), TBL_ENTRY(0xe87), + TBL_ENTRY(0xe88), TBL_ENTRY(0xe89), TBL_ENTRY(0xe8a), TBL_ENTRY(0xe8b), + TBL_ENTRY(0xe8c), TBL_ENTRY(0xe8d), TBL_ENTRY(0xe8e), TBL_ENTRY(0xe8f), + TBL_ENTRY(0xe90), TBL_ENTRY(0xe91), TBL_ENTRY(0xe92), TBL_ENTRY(0xe93), + TBL_ENTRY(0xe94), TBL_ENTRY(0xe95), TBL_ENTRY(0xe96), TBL_ENTRY(0xe97), + TBL_ENTRY(0xe98), TBL_ENTRY(0xe99), TBL_ENTRY(0xe9a), TBL_ENTRY(0xe9b), + TBL_ENTRY(0xe9c), TBL_ENTRY(0xe9d), TBL_ENTRY(0xe9e), TBL_ENTRY(0xe9f), + TBL_ENTRY(0xea0), TBL_ENTRY(0xea1), TBL_ENTRY(0xea2), TBL_ENTRY(0xea3), + TBL_ENTRY(0xea4), TBL_ENTRY(0xea5), TBL_ENTRY(0xea6), TBL_ENTRY(0xea7), + TBL_ENTRY(0xea8), TBL_ENTRY(0xea9), TBL_ENTRY(0xeaa), TBL_ENTRY(0xeab), + TBL_ENTRY(0xeac), TBL_ENTRY(0xead), TBL_ENTRY(0xeae), TBL_ENTRY(0xeaf), + TBL_ENTRY(0xeb0), TBL_ENTRY(0xeb1), TBL_ENTRY(0xeb2), TBL_ENTRY(0xeb3), + TBL_ENTRY(0xeb4), TBL_ENTRY(0xeb5), TBL_ENTRY(0xeb6), TBL_ENTRY(0xeb7), + TBL_ENTRY(0xeb8), TBL_ENTRY(0xeb9), TBL_ENTRY(0xeba), TBL_ENTRY(0xebb), + TBL_ENTRY(0xebc), TBL_ENTRY(0xebd), TBL_ENTRY(0xebe), TBL_ENTRY(0xebf), + TBL_ENTRY(0xec0), TBL_ENTRY(0xec1), TBL_ENTRY(0xec2), TBL_ENTRY(0xec3), + TBL_ENTRY(0xec4), TBL_ENTRY(0xec5), TBL_ENTRY(0xec6), TBL_ENTRY(0xec7), + TBL_ENTRY(0xec8), TBL_ENTRY(0xec9), TBL_ENTRY(0xeca), TBL_ENTRY(0xecb), + TBL_ENTRY(0xecc), TBL_ENTRY(0xecd), TBL_ENTRY(0xece), TBL_ENTRY(0xecf), + TBL_ENTRY(0xed0), TBL_ENTRY(0xed1), TBL_ENTRY(0xed2), TBL_ENTRY(0xed3), + TBL_ENTRY(0xed4), TBL_ENTRY(0xed5), TBL_ENTRY(0xed6), TBL_ENTRY(0xed7), + TBL_ENTRY(0xed8), TBL_ENTRY(0xed9), TBL_ENTRY(0xeda), TBL_ENTRY(0xedb), + TBL_ENTRY(0xedc), TBL_ENTRY(0xedd), TBL_ENTRY(0xede), TBL_ENTRY(0xedf), + TBL_ENTRY(0xee0), TBL_ENTRY(0xee1), TBL_ENTRY(0xee2), TBL_ENTRY(0xee3), + TBL_ENTRY(0xee4), TBL_ENTRY(0xee5), TBL_ENTRY(0xee6), TBL_ENTRY(0xee7), + TBL_ENTRY(0xee8), TBL_ENTRY(0xee9), TBL_ENTRY(0xeea), TBL_ENTRY(0xeeb), + TBL_ENTRY(0xeec), TBL_ENTRY(0xeed), TBL_ENTRY(0xeee), TBL_ENTRY(0xeef), + TBL_ENTRY(0xef0), TBL_ENTRY(0xef1), TBL_ENTRY(0xef2), TBL_ENTRY(0xef3), + TBL_ENTRY(0xef4), TBL_ENTRY(0xef5), TBL_ENTRY(0xef6), TBL_ENTRY(0xef7), + TBL_ENTRY(0xef8), TBL_ENTRY(0xef9), TBL_ENTRY(0xefa), TBL_ENTRY(0xefb), + TBL_ENTRY(0xefc), TBL_ENTRY(0xefd), TBL_ENTRY(0xefe), TBL_ENTRY(0xeff), + TBL_ENTRY(0xf00), TBL_ENTRY(0xf01), TBL_ENTRY(0xf02), TBL_ENTRY(0xf03), + TBL_ENTRY(0xf04), TBL_ENTRY(0xf05), TBL_ENTRY(0xf06), TBL_ENTRY(0xf07), + TBL_ENTRY(0xf08), TBL_ENTRY(0xf09), TBL_ENTRY(0xf0a), TBL_ENTRY(0xf0b), + TBL_ENTRY(0xf0c), TBL_ENTRY(0xf0d), TBL_ENTRY(0xf0e), TBL_ENTRY(0xf0f), + TBL_ENTRY(0xf10), TBL_ENTRY(0xf11), TBL_ENTRY(0xf12), TBL_ENTRY(0xf13), + TBL_ENTRY(0xf14), TBL_ENTRY(0xf15), TBL_ENTRY(0xf16), TBL_ENTRY(0xf17), + TBL_ENTRY(0xf18), TBL_ENTRY(0xf19), TBL_ENTRY(0xf1a), TBL_ENTRY(0xf1b), + TBL_ENTRY(0xf1c), TBL_ENTRY(0xf1d), TBL_ENTRY(0xf1e), TBL_ENTRY(0xf1f), + TBL_ENTRY(0xf20), TBL_ENTRY(0xf21), TBL_ENTRY(0xf22), TBL_ENTRY(0xf23), + TBL_ENTRY(0xf24), TBL_ENTRY(0xf25), TBL_ENTRY(0xf26), TBL_ENTRY(0xf27), + TBL_ENTRY(0xf28), TBL_ENTRY(0xf29), TBL_ENTRY(0xf2a), TBL_ENTRY(0xf2b), + TBL_ENTRY(0xf2c), TBL_ENTRY(0xf2d), TBL_ENTRY(0xf2e), TBL_ENTRY(0xf2f), + TBL_ENTRY(0xf30), TBL_ENTRY(0xf31), TBL_ENTRY(0xf32), TBL_ENTRY(0xf33), + TBL_ENTRY(0xf34), TBL_ENTRY(0xf35), TBL_ENTRY(0xf36), TBL_ENTRY(0xf37), + TBL_ENTRY(0xf38), TBL_ENTRY(0xf39), TBL_ENTRY(0xf3a), TBL_ENTRY(0xf3b), + TBL_ENTRY(0xf3c), TBL_ENTRY(0xf3d), TBL_ENTRY(0xf3e), TBL_ENTRY(0xf3f), + TBL_ENTRY(0xf40), TBL_ENTRY(0xf41), TBL_ENTRY(0xf42), TBL_ENTRY(0xf43), + TBL_ENTRY(0xf44), TBL_ENTRY(0xf45), TBL_ENTRY(0xf46), TBL_ENTRY(0xf47), + TBL_ENTRY(0xf48), TBL_ENTRY(0xf49), TBL_ENTRY(0xf4a), TBL_ENTRY(0xf4b), + TBL_ENTRY(0xf4c), TBL_ENTRY(0xf4d), TBL_ENTRY(0xf4e), TBL_ENTRY(0xf4f), + TBL_ENTRY(0xf50), TBL_ENTRY(0xf51), TBL_ENTRY(0xf52), TBL_ENTRY(0xf53), + TBL_ENTRY(0xf54), TBL_ENTRY(0xf55), TBL_ENTRY(0xf56), TBL_ENTRY(0xf57), + TBL_ENTRY(0xf58), TBL_ENTRY(0xf59), TBL_ENTRY(0xf5a), TBL_ENTRY(0xf5b), + TBL_ENTRY(0xf5c), TBL_ENTRY(0xf5d), TBL_ENTRY(0xf5e), TBL_ENTRY(0xf5f), + TBL_ENTRY(0xf60), TBL_ENTRY(0xf61), TBL_ENTRY(0xf62), TBL_ENTRY(0xf63), + TBL_ENTRY(0xf64), TBL_ENTRY(0xf65), TBL_ENTRY(0xf66), TBL_ENTRY(0xf67), + TBL_ENTRY(0xf68), TBL_ENTRY(0xf69), TBL_ENTRY(0xf6a), TBL_ENTRY(0xf6b), + TBL_ENTRY(0xf6c), TBL_ENTRY(0xf6d), TBL_ENTRY(0xf6e), TBL_ENTRY(0xf6f), + TBL_ENTRY(0xf70), TBL_ENTRY(0xf71), TBL_ENTRY(0xf72), TBL_ENTRY(0xf73), + TBL_ENTRY(0xf74), TBL_ENTRY(0xf75), TBL_ENTRY(0xf76), TBL_ENTRY(0xf77), + TBL_ENTRY(0xf78), TBL_ENTRY(0xf79), TBL_ENTRY(0xf7a), TBL_ENTRY(0xf7b), + TBL_ENTRY(0xf7c), TBL_ENTRY(0xf7d), TBL_ENTRY(0xf7e), TBL_ENTRY(0xf7f), + TBL_ENTRY(0xf80), TBL_ENTRY(0xf81), TBL_ENTRY(0xf82), TBL_ENTRY(0xf83), + TBL_ENTRY(0xf84), TBL_ENTRY(0xf85), TBL_ENTRY(0xf86), TBL_ENTRY(0xf87), + TBL_ENTRY(0xf88), TBL_ENTRY(0xf89), TBL_ENTRY(0xf8a), TBL_ENTRY(0xf8b), + TBL_ENTRY(0xf8c), TBL_ENTRY(0xf8d), TBL_ENTRY(0xf8e), TBL_ENTRY(0xf8f), + TBL_ENTRY(0xf90), TBL_ENTRY(0xf91), TBL_ENTRY(0xf92), TBL_ENTRY(0xf93), + TBL_ENTRY(0xf94), TBL_ENTRY(0xf95), TBL_ENTRY(0xf96), TBL_ENTRY(0xf97), + TBL_ENTRY(0xf98), TBL_ENTRY(0xf99), TBL_ENTRY(0xf9a), TBL_ENTRY(0xf9b), + TBL_ENTRY(0xf9c), TBL_ENTRY(0xf9d), TBL_ENTRY(0xf9e), TBL_ENTRY(0xf9f), + TBL_ENTRY(0xfa0), TBL_ENTRY(0xfa1), TBL_ENTRY(0xfa2), TBL_ENTRY(0xfa3), + TBL_ENTRY(0xfa4), TBL_ENTRY(0xfa5), TBL_ENTRY(0xfa6), TBL_ENTRY(0xfa7), + TBL_ENTRY(0xfa8), TBL_ENTRY(0xfa9), TBL_ENTRY(0xfaa), TBL_ENTRY(0xfab), + TBL_ENTRY(0xfac), TBL_ENTRY(0xfad), TBL_ENTRY(0xfae), TBL_ENTRY(0xfaf), + TBL_ENTRY(0xfb0), TBL_ENTRY(0xfb1), TBL_ENTRY(0xfb2), TBL_ENTRY(0xfb3), + TBL_ENTRY(0xfb4), TBL_ENTRY(0xfb5), TBL_ENTRY(0xfb6), TBL_ENTRY(0xfb7), + TBL_ENTRY(0xfb8), TBL_ENTRY(0xfb9), TBL_ENTRY(0xfba), TBL_ENTRY(0xfbb), + TBL_ENTRY(0xfbc), TBL_ENTRY(0xfbd), TBL_ENTRY(0xfbe), TBL_ENTRY(0xfbf), + TBL_ENTRY(0xfc0), TBL_ENTRY(0xfc1), TBL_ENTRY(0xfc2), TBL_ENTRY(0xfc3), + TBL_ENTRY(0xfc4), TBL_ENTRY(0xfc5), TBL_ENTRY(0xfc6), TBL_ENTRY(0xfc7), + TBL_ENTRY(0xfc8), TBL_ENTRY(0xfc9), TBL_ENTRY(0xfca), TBL_ENTRY(0xfcb), + TBL_ENTRY(0xfcc), TBL_ENTRY(0xfcd), TBL_ENTRY(0xfce), TBL_ENTRY(0xfcf), + TBL_ENTRY(0xfd0), TBL_ENTRY(0xfd1), TBL_ENTRY(0xfd2), TBL_ENTRY(0xfd3), + TBL_ENTRY(0xfd4), TBL_ENTRY(0xfd5), TBL_ENTRY(0xfd6), TBL_ENTRY(0xfd7), + TBL_ENTRY(0xfd8), TBL_ENTRY(0xfd9), TBL_ENTRY(0xfda), TBL_ENTRY(0xfdb), + TBL_ENTRY(0xfdc), TBL_ENTRY(0xfdd), TBL_ENTRY(0xfde), TBL_ENTRY(0xfdf), + TBL_ENTRY(0xfe0), TBL_ENTRY(0xfe1), TBL_ENTRY(0xfe2), TBL_ENTRY(0xfe3), + TBL_ENTRY(0xfe4), TBL_ENTRY(0xfe5), TBL_ENTRY(0xfe6), TBL_ENTRY(0xfe7), + TBL_ENTRY(0xfe8), TBL_ENTRY(0xfe9), TBL_ENTRY(0xfea), TBL_ENTRY(0xfeb), + TBL_ENTRY(0xfec), TBL_ENTRY(0xfed), TBL_ENTRY(0xfee), TBL_ENTRY(0xfef), + TBL_ENTRY(0xff0), TBL_ENTRY(0xff1), TBL_ENTRY(0xff2), TBL_ENTRY(0xff3), + TBL_ENTRY(0xff4), TBL_ENTRY(0xff5), TBL_ENTRY(0xff6), TBL_ENTRY(0xff7), + TBL_ENTRY(0xff8), TBL_ENTRY(0xff9), TBL_ENTRY(0xffa), TBL_ENTRY(0xffb), + TBL_ENTRY(0xffc), TBL_ENTRY(0xffd), TBL_ENTRY(0xffe), TBL_ENTRY(0xfff), +}; diff --git a/arch/arm/cpu/armv7/uniphier/lowlevel_init.S b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S new file mode 100644 index 0000000..0ea12d3 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/lowlevel_init.S @@ -0,0 +1,159 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/arm-mpcore.h> +#include <asm/arch/sbc-regs.h> + +ENTRY(lowlevel_init) + mov r8, lr @ persevere link reg across call + + /* + * The UniPhier Boot ROM loads SPL code to the L2 cache. + * But CPUs can only do instruction fetch now because start.S has + * cleared C and M bits. + * First we need to turn on MMU and Dcache again to get back + * data access to L2. + */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + orr r0, r0, #(CR_C | CR_M) @ enable MMU and Dcache + mcr p15, 0, r0, c1, c0, 0 + + /* + * Now we are using the page table embedded in the Boot ROM. + * It is not handy since it is not a straight mapped table for sLD3. + * What we need to do next is to switch over to the page table in SPL. + */ + ldr r3, =init_page_table @ page table must be 16KB aligned + + /* Disable MMU and Dcache before switching Page Table */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + bic r0, r0, #(CR_C | CR_M) @ disable MMU and Dcache + mcr p15, 0, r0, c1, c0, 0 + + bl enable_mmu + +#ifdef CONFIG_UNIPHIER_SMP + /* + * ACTLR (Auxiliary Control Register) for Cortex-A9 + * bit[9] Parity on + * bit[8] Alloc in one way + * bit[7] EXCL (Exclusive cache bit) + * bit[6] SMP + * bit[3] Write full line of zeros mode + * bit[2] L1 Prefetch enable + * bit[1] L2 prefetch enable + * bit[0] FW (Cache and TLB maintenance broadcast) + */ + mrc p15, 0, r0, c1, c0, 1 @ ACTLR (Auxiliary Control Register) + orr r0, r0, #0x41 @ enable SMP, FW bit + mcr p15, 0, r0, c1, c0, 1 + + /* branch by CPU ID */ + mrc p15, 0, r0, c0, c0, 5 @ MPIDR (Multiprocessor Affinity Register) + and r0, r0, #0x3 + cmp r0, #0x0 + beq primary_cpu + ldr r1, =ROM_BOOT_ROMRSV2 + mov r0, #0 + str r0, [r1] +0: wfe + ldr r0, [r1] + cmp r0, #0 + beq 0b + bx r0 @ r0: entry point of U-Boot main for the secondary CPU +primary_cpu: + ldr r1, =ROM_BOOT_ROMRSV2 + ldr r0, =_start @ entry for the secondary CPU + str r0, [r1] + ldr r0, [r1] @ make sure str is complete before sev + sev @ kick the sedoncary CPU + mrc p15, 4, r1, c15, c0, 0 @ Configuration Base Address Register + bfc r1, #0, #13 @ clear bit 12-0 + mov r0, #-1 + str r0, [r1, #SCU_INV_ALL] @ SCU Invalidate All Register + mov r0, #1 @ SCU enable + str r0, [r1, #SCU_CTRL] @ SCU Control Register +#endif + + bl setup_init_ram @ RAM area for temporary stack pointer + + mov lr, r8 @ restore link + mov pc, lr @ back to my caller +ENDPROC(lowlevel_init) + +ENTRY(enable_mmu) + mrc p15, 0, r0, c2, c0, 2 @ TTBCR (Translation Table Base Control Register) + bic r0, r0, #0x37 + orr r0, r0, #0x20 @ disable TTBR1 + mcr p15, 0, r0, c2, c0, 2 + + orr r0, r3, #0x8 @ Outer Cacheability for table walks: WBWA + mcr p15, 0, r0, c2, c0, 0 @ TTBR0 + + mov r0, #0 + mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs + + mov r0, #-1 @ manager for all domains (No permission check) + mcr p15, 0, r0, c3, c0, 0 @ DACR (Domain Access Control Register) + + dsb + isb + /* + * MMU on: + * TLBs was already invalidated in "../start.S" + * So, we don't need to invalidate it here. + */ + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + orr r0, r0, #(CR_C | CR_M) @ MMU and Dcache enable + mcr p15, 0, r0, c1, c0, 0 + + mov pc, lr +ENDPROC(enable_mmu) + +#include <asm/arch/ssc-regs.h> + +#define BOOT_RAM_SIZE (SSC_WAY_SIZE) +#define BOOT_WAY_BITS (0x00000100) /* way 8 */ + +ENTRY(setup_init_ram) + /* + * Touch to zero for the boot way + */ +0: + /* + * set SSCOQM, SSCOQAD, SSCOQSZ, SSCOQWN in this order + */ + ldr r0, = 0x00408006 @ touch to zero with address range + ldr r1, = SSCOQM + str r0, [r1] + ldr r0, = (CONFIG_SYS_INIT_SP_ADDR - BOOT_RAM_SIZE) @ base address + ldr r1, = SSCOQAD + str r0, [r1] + ldr r0, = BOOT_RAM_SIZE + ldr r1, = SSCOQSZ + str r0, [r1] + ldr r0, = BOOT_WAY_BITS + ldr r1, = SSCOQWN + str r0, [r1] + ldr r1, = SSCOPPQSEF + ldr r0, [r1] + cmp r0, #0 @ check if the command is successfully set + bne 0b @ try again if an error occurres + + ldr r1, = SSCOLPQS +1: + ldr r0, [r1] + cmp r0, #0x4 + bne 1b @ wait until the operation is completed + str r0, [r1] @ clear the complete notification flag + + mov pc, lr +ENDPROC(setup_init_ram) diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ + sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c new file mode 100644 index 0000000..85f37f2 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/bcu_init.c @@ -0,0 +1,33 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/bcu-regs.h> + +#define ch(x) ((x) >= 32 ? 0 : (x) < 0 ? 0x11111111 : 0x11111111 << (x)) + +void bcu_init(void) +{ + int shift; + + writel(0x44444444, BCSCR0); /* 0x20000000-0x3fffffff: ASM bus */ + writel(0x11111111, BCSCR2); /* 0x80000000-0x9fffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR3); /* 0xa0000000-0xbfffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR4); /* 0xc0000000-0xdfffffff: IPPC/IPPD-bus */ + writel(0x11111111, BCSCR5); /* 0xe0000000-0Xffffffff: IPPC/IPPD-bus */ + + /* Specify DDR channel */ + shift = (CONFIG_SDRAM1_BASE - CONFIG_SDRAM0_BASE) / 0x04000000 * 4; + writel(ch(shift), BCIPPCCHR2); /* 0x80000000-0x9fffffff */ + + shift -= 32; + writel(ch(shift), BCIPPCCHR3); /* 0xa0000000-0xbfffffff */ + + shift -= 32; + writel(ch(shift), BCIPPCCHR4); /* 0xc0000000-0xdfffffff */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c new file mode 100644 index 0000000..27d772e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-LD4 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c new file mode 100644 index 0000000..4302277 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/board_postclk_init.c @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> +#include <asm/arch/board.h> + +void bcu_init(void); +void sbc_init(void); +void sg_init(void); +void pll_init(void); +void pin_init(void); +void clkrst_init(void); + +int board_postclk_init(void) +{ + bcu_init(); + + sbc_init(); + + sg_init(); + + pll_init(); + + uniphier_board_init(); + + led_write(B, 1, , ); + + clkrst_init(); + + led_write(B, 2, , ); + + pin_init(); + + led_write(B, 3, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c new file mode 100644 index 0000000..a742940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pinctrl.c @@ -0,0 +1,63 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + u32 tmp; + + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(85, 1); /* HSDOUT3 -> RXD0 */ + sg_set_pinsel(88, 1); /* HDDOUT6 -> TXD0 */ + + sg_set_pinsel(69, 23); /* PCIOWR -> TXD1 */ + sg_set_pinsel(70, 23); /* PCIORD -> RXD1 */ + + sg_set_pinsel(128, 13); /* XIRQ6 -> TXD2 */ + sg_set_pinsel(129, 13); /* XIRQ7 -> RXD2 */ + + sg_set_pinsel(110, 1); /* SBO0 -> TXD3 */ + sg_set_pinsel(111, 1); /* SBI0 -> RXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(158, 0); /* XNFRE -> XNFRE_GB */ + sg_set_pinsel(159, 0); /* XNFWE -> XNFWE_GB */ + sg_set_pinsel(160, 0); /* XFALE -> NFALE_GB */ + sg_set_pinsel(161, 0); /* XFCLE -> NFCLE_GB */ + sg_set_pinsel(162, 0); /* XNFWP -> XFNWP_GB */ + sg_set_pinsel(163, 0); /* XNFCE0 -> XNFCE0_GB */ + sg_set_pinsel(164, 0); /* NANDRYBY0 -> NANDRYBY0_GB */ + sg_set_pinsel(22, 0); /* MMCCLK -> XFNCE1_GB */ + sg_set_pinsel(23, 0); /* MMCCMD -> NANDRYBY1_GB */ + sg_set_pinsel(24, 0); /* MMCDAT0 -> NFD0_GB */ + sg_set_pinsel(25, 0); /* MMCDAT1 -> NFD1_GB */ + sg_set_pinsel(26, 0); /* MMCDAT2 -> NFD2_GB */ + sg_set_pinsel(27, 0); /* MMCDAT3 -> NFD3_GB */ + sg_set_pinsel(28, 0); /* MMCDAT4 -> NFD4_GB */ + sg_set_pinsel(29, 0); /* MMCDAT5 -> NFD5_GB */ + sg_set_pinsel(30, 0); /* MMCDAT6 -> NFD6_GB */ + sg_set_pinsel(31, 0); /* MMCDAT7 -> NFD7_GB */ +#endif + +#ifdef CONFIG_USB_EHCI_UNIPHIER + sg_set_pinsel(53, 0); /* USB0VBUS -> USB0VBUS */ + sg_set_pinsel(54, 0); /* USB0OD -> USB0OD */ + sg_set_pinsel(55, 0); /* USB1VBUS -> USB1VBUS */ + sg_set_pinsel(56, 0); /* USB1OD -> USB1OD */ + /* sg_set_pinsel(67, 23); */ /* PCOE -> USB2VBUS */ + /* sg_set_pinsel(68, 23); */ /* PCWAIT -> USB2OD */ +#endif + + tmp = readl(SG_IECTRL); + tmp |= 0x41; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c new file mode 100644 index 0000000..68b9d5f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_init.c @@ -0,0 +1,189 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +#undef DPLL_SSC_RATE_1PER + +void dpll_init(void) +{ + u32 tmp; + + /* + * Set Frequency + * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) + * to FOUT (DPLLCTRL.bit[29:20]) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~0x000f0000; +#if CONFIG_DDR_FREQ == 1600 + tmp |= 0x000c0000; +#elif CONFIG_DDR_FREQ == 1333 + tmp |= 0x000d0000; +#else +# error "Unknown frequency" +#endif + +#if defined(DPLL_SSC_RATE_1PER) + tmp &= ~SC_DPLLCTRL_SSC_RATE; +#else + tmp |= SC_DPLLCTRL_SSC_RATE; +#endif + writel(tmp, SC_DPLLCTRL); + + tmp = readl(SC_DPLLCTRL2); + tmp |= SC_DPLLCTRL2_NRSTDS; + writel(tmp, SC_DPLLCTRL2); +} + +void upll_init(void) +{ + u32 tmp, clk_mode_upll, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK; + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27]) */ + tmp = readl(SC_UPLLCTRL); + tmp &= ~0x18000000; + writel(tmp, SC_UPLLCTRL); + + if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) { + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x0228f5c0; + } else { + /* AXO: default 24.576MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x02328000; + } + } + + writel(tmp, SC_UPLLCTRL); + + /* set 1 to K_LD(UPLLCTRL.bit[27]) */ + tmp |= 0x08000000; + writel(tmp, SC_UPLLCTRL); + + /* wait 10 usec */ + udelay(10); + + /* set 1 to SNRT(UPLLCTRL.bit[28]) */ + tmp |= 0x10000000; + writel(tmp, SC_UPLLCTRL); +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 1 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Set 0 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Set 0x20 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* AXO: default 24.576MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* Set 1 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* wait 10 usec */ + udelay(10); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* set 0 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + upll_init(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 10 usec in upll_init() and vpll_init() + * so 20 usec can be saved here. + */ + udelay(480); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c new file mode 100644 index 0000000..837b2a8 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-pro4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c new file mode 100644 index 0000000..a37ed16 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sbc_init.c @@ -0,0 +1,44 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + +#if !defined(CONFIG_SPL_BUILD) + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); + writel(0x0400bc01, SBBASE1); + writel(0x0800bf01, SBBASE3); + +#if !defined(CONFIG_SPL_BUILD) + /* enable access to sub memory when boot swap is on */ + sg_set_pinsel(155, 1); /* PORT24 -> XECS0 */ +#endif + sg_set_pinsel(156, 1); /* PORT25 -> XECS3 */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c new file mode 100644 index 0000000..b4dd799 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/sg_init.c @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void sg_init(void) +{ + u32 tmp; + + /* Set DDR size */ + tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); + tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE + tmp |= SG_MEMCONF_SPARSEMEM; +#endif + writel(tmp, SG_MEMCONF); + + /* Input ports must be enabled deasserting reset of cores */ + tmp = readl(SG_IECTRL); + tmp |= 0x1; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c new file mode 100644 index 0000000..1344ac1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-ld4/umc_init.c @@ -0,0 +1,162 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/umc-regs.h> + +static inline void umc_start_ssif(void __iomem *ssif_base) +{ + writel(0x00000000, ssif_base + 0x0000b004); + writel(0xffffffff, ssif_base + 0x0000c004); + writel(0x000fffcf, ssif_base + 0x0000c008); + writel(0x00000001, ssif_base + 0x0000b000); + writel(0x00000001, ssif_base + 0x0000c000); + writel(0x03010101, ssif_base + UMC_MDMCHSEL); + writel(0x03010100, ssif_base + UMC_DMDCHSEL); + + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_FETCH); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_WC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_RC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_DST); + + writel(0x00000001, ssif_base + UMC_CPURST); + writel(0x00000001, ssif_base + UMC_IDSRST); + writel(0x00000001, ssif_base + UMC_IXMRST); + writel(0x00000001, ssif_base + UMC_MDMRST); + writel(0x00000001, ssif_base + UMC_MDDRST); + writel(0x00000001, ssif_base + UMC_SIORST); + writel(0x00000001, ssif_base + UMC_VIORST); + writel(0x00000001, ssif_base + UMC_FRCRST); + writel(0x00000001, ssif_base + UMC_RGLRST); + writel(0x00000001, ssif_base + UMC_AIORST); + writel(0x00000001, ssif_base + UMC_DMDRST); +} + +void umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, + int size, int freq) +{ + if (freq == 1333) { + writel(0x45990b11, dramcont + UMC_CMDCTLA); + writel(0x16958924, dramcont + UMC_CMDCTLB); + writel(0x5101046A, dramcont + UMC_INITCTLA); + + if (size == 1) + writel(0x27028B0A, dramcont + UMC_INITCTLB); + else if (size == 2) + writel(0x38028B0A, dramcont + UMC_INITCTLB); + + writel(0x000FF0FF, dramcont + UMC_INITCTLC); + writel(0x00000b51, dramcont + UMC_DRMMR0); + } else if (freq == 1600) { + writel(0x36BB0F17, dramcont + UMC_CMDCTLA); + writel(0x18C6AA24, dramcont + UMC_CMDCTLB); + writel(0x5101387F, dramcont + UMC_INITCTLA); + + if (size == 1) + writel(0x2F030D3F, dramcont + UMC_INITCTLB); + else if (size == 2) + writel(0x43030D3F, dramcont + UMC_INITCTLB); + + writel(0x00FF00FF, dramcont + UMC_INITCTLC); + writel(0x00000d71, dramcont + UMC_DRMMR0); + } + + writel(0x00000006, dramcont + UMC_DRMMR1); + + if (freq == 1333) + writel(0x00000290, dramcont + UMC_DRMMR2); + else if (freq == 1600) + writel(0x00000298, dramcont + UMC_DRMMR2); + + writel(0x00000800, dramcont + UMC_DRMMR3); + + if (freq == 1333) { + if (size == 1) + writel(0x00240512, dramcont + UMC_SPCCTLA); + else if (size == 2) + writel(0x00350512, dramcont + UMC_SPCCTLA); + + writel(0x00ff0006, dramcont + UMC_SPCCTLB); + writel(0x000a00ac, dramcont + UMC_RDATACTL_D0); + } else if (freq == 1600) { + if (size == 1) + writel(0x002B0617, dramcont + UMC_SPCCTLA); + else if (size == 2) + writel(0x003F0617, dramcont + UMC_SPCCTLA); + + writel(0x00ff0008, dramcont + UMC_SPCCTLB); + writel(0x000c00ae, dramcont + UMC_RDATACTL_D0); + } + + writel(0x04060806, dramcont + UMC_WDATACTL_D0); + writel(0x04a02000, dramcont + UMC_DATASET); + writel(0x00000000, ca_base + 0x2300); + writel(0x00400020, dramcont + UMC_DCCGCTL); + writel(0x00000003, dramcont + 0x7000); + writel(0x0000000f, dramcont + 0x8000); + writel(0x000000c3, dramcont + 0x8004); + writel(0x00000071, dramcont + 0x8008); + writel(0x0000003b, dramcont + UMC_DICGCTLA); + writel(0x020a0808, dramcont + UMC_DICGCTLB); + writel(0x00000004, dramcont + UMC_FLOWCTLG); + writel(0x80000201, ca_base + 0xc20); + writel(0x0801e01e, dramcont + UMC_FLOWCTLA); + writel(0x00200000, dramcont + UMC_FLOWCTLB); + writel(0x00004444, dramcont + UMC_FLOWCTLC); + writel(0x200a0a00, dramcont + UMC_SPCSETB); + writel(0x00000000, dramcont + UMC_SPCSETD); + writel(0x00000520, dramcont + UMC_DFICUPDCTLA); +} + +static inline int umc_init_sub(int freq, int size_ch0, int size_ch1) +{ + void __iomem *ssif_base = (void __iomem *)UMC_SSIF_BASE; + void __iomem *ca_base0 = (void __iomem *)UMC_CA_BASE(0); + void __iomem *ca_base1 = (void __iomem *)UMC_CA_BASE(1); + void __iomem *dramcont0 = (void __iomem *)UMC_DRAMCONT_BASE(0); + void __iomem *dramcont1 = (void __iomem *)UMC_DRAMCONT_BASE(1); + + umc_dram_init_start(dramcont0); + umc_dram_init_start(dramcont1); + umc_dram_init_poll(dramcont0); + umc_dram_init_poll(dramcont1); + + writel(0x00000101, dramcont0 + UMC_DIOCTLA); + + writel(0x00000101, dramcont1 + UMC_DIOCTLA); + + umc_dramcont_init(dramcont0, ca_base0, size_ch0, freq); + umc_dramcont_init(dramcont1, ca_base1, size_ch1, freq); + + umc_start_ssif(ssif_base); + + return 0; +} + +int umc_init(void) +{ + return umc_init_sub(CONFIG_DDR_FREQ, CONFIG_SDRAM0_SIZE / 0x08000000, + CONFIG_SDRAM1_SIZE / 0x08000000); +} + +#if CONFIG_DDR_FREQ != 1333 && CONFIG_DDR_FREQ != 1600 +#error Unsupported DDR Frequency. +#endif + +#if (CONFIG_SDRAM0_SIZE == 0x08000000 || CONFIG_SDRAM0_SIZE == 0x10000000) && \ + (CONFIG_SDRAM1_SIZE == 0x08000000 || CONFIG_SDRAM1_SIZE == 0x10000000) && \ + CONFIG_DDR_NUM_CH0 == 1 && CONFIG_DDR_NUM_CH1 == 1 +/* OK */ +#else +#error Unsupported DDR configuration. +#endif diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile new file mode 100644 index 0000000..712afd1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o sbc_init.o \ + sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c new file mode 100644 index 0000000..325a4f6 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-Pro4 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c new file mode 100644 index 0000000..7198829 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/board_postclk_init.c @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/led.h> +#include <asm/arch/board.h> + +void sbc_init(void); +void sg_init(void); +void pll_init(void); +void pin_init(void); +void clkrst_init(void); + +int board_postclk_init(void) +{ + sbc_init(); + + sg_init(); + + pll_init(); + + uniphier_board_init(); + + led_write(B, 1, , ); + + clkrst_init(); + + led_write(B, 2, , ); + + pin_init(); + + led_write(B, 3, , ); + + return 0; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c new file mode 100644 index 0000000..33bccff --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/boot-mode.c @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> +#include <asm/io.h> +#include <asm/arch/boot-device.h> +#include <asm/arch/sg-regs.h> +#include <asm/arch/sbc-regs.h> + +struct boot_device_info boot_device_table[] = { + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB, Addr 4)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, EraseSize 1MB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, EraseSize 1MB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 128KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 256KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, EraseSize 512KB, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, ONFI, Addr 4)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 8, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 16, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 8, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 4, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 8, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 16, ONFI, Addr 5)"}, + {BOOT_DEVICE_NAND, "NAND (Mirror 1, ECC 24, ONFI, Addr 5)"}, + {BOOT_DEVICE_MMC1, "eMMC Boot (3.3V)"}, + {BOOT_DEVICE_MMC1, "eMMC Boot (1.8V)"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, "Reserved"}, + {BOOT_DEVICE_NONE, ""} +}; + +u32 get_boot_mode_sel(void) +{ + return (readl(SG_PINMON0) >> 1) & 0x1f; +} + +u32 spl_boot_device(void) +{ + u32 boot_mode; + + if (boot_is_swapped()) + return BOOT_DEVICE_NOR; + + boot_mode = get_boot_mode_sel(); + + return boot_device_table[boot_mode].type; +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c new file mode 100644 index 0000000..503c247 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pinctrl.c @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(127, 0); /* RXD0 -> RXD0 */ + sg_set_pinsel(128, 0); /* TXD0 -> TXD0 */ + sg_set_pinsel(129, 0); /* RXD1 -> RXD1 */ + sg_set_pinsel(130, 0); /* TXD1 -> TXD1 */ + sg_set_pinsel(131, 0); /* RXD2 -> RXD2 */ + sg_set_pinsel(132, 0); /* TXD2 -> TXD2 */ + sg_set_pinsel(88, 2); /* CH6CLK -> RXD3 */ + sg_set_pinsel(89, 2); /* CH6VAL -> TXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(40, 0); /* NFD0 -> NFD0 */ + sg_set_pinsel(41, 0); /* NFD1 -> NFD1 */ + sg_set_pinsel(42, 0); /* NFD2 -> NFD2 */ + sg_set_pinsel(43, 0); /* NFD3 -> NFD3 */ + sg_set_pinsel(44, 0); /* NFD4 -> NFD4 */ + sg_set_pinsel(45, 0); /* NFD5 -> NFD5 */ + sg_set_pinsel(46, 0); /* NFD6 -> NFD6 */ + sg_set_pinsel(47, 0); /* NFD7 -> NFD7 */ + sg_set_pinsel(48, 0); /* NFALE -> NFALE */ + sg_set_pinsel(49, 0); /* NFCLE -> NFCLE */ + sg_set_pinsel(50, 0); /* XNFRE -> XNFRE */ + sg_set_pinsel(51, 0); /* XNFWE -> XNFWE */ + sg_set_pinsel(52, 0); /* XNFWP -> XNFWP */ + sg_set_pinsel(53, 0); /* XNFCE0 -> XNFCE0 */ + sg_set_pinsel(54, 0); /* NRYBY0 -> NRYBY0 */ +#endif + + writel(1, SG_LOADPINCTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c new file mode 100644 index 0000000..2dcc089 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_init.c @@ -0,0 +1,168 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +#undef DPLL_SSC_RATE_1PER + +void dpll_init(void) +{ + u32 tmp; + + /* + * Set Frequency + * Set 0xc(1600MHz)/0xd(1333MHz)/0xe(1066MHz) + * to FOUT ( DPLLCTRL.bit[29:20] ) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~(0x000f0000); +#if CONFIG_DDR_FREQ == 1600 + tmp |= 0x000c0000; +#elif CONFIG_DDR_FREQ == 1333 + tmp |= 0x000d0000; +#else +# error "Unsupported frequency" +#endif + + /* + * Set Moduration rate + * Set 0x0(1%)/0x1(2%) to SSC_RATE(DPLLCTRL.bit[15]) + */ +#if defined(DPLL_SSC_RATE_1PER) + tmp &= ~0x00008000; +#else + tmp |= 0x00008000; +#endif + writel(tmp, SC_DPLLCTRL); + + tmp = readl(SC_DPLLCTRL2); + tmp |= SC_DPLLCTRL2_NRSTDS; + writel(tmp, SC_DPLLCTRL2); +} + +void stop_mpll(void) +{ + u32 tmp; + + tmp = readl(SC_MPLLOSCCTL); + + if (!(tmp & SC_MPLLOSCCTL_MPLLST)) + return; /* already stopped */ + + tmp &= ~SC_MPLLOSCCTL_MPLLEN; + writel(tmp, SC_MPLLOSCCTL); + + while (readl(SC_MPLLOSCCTL) & SC_MPLLOSCCTL_MPLLST) + ; +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + /* Set VPLL27A & VPLL27B */ + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + +#if defined(CONFIG_MACH_PH1_PRO4) + /* 25MHz or 6.25MHz is default for Pro4R, no need to set VPLLA/B */ + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) + return; +#endif + + /* Disable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Unset VPLA_K_LD and VPLB_K_LD bit */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set VPLA_M and VPLB_M to 0x20 */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ) { + /* Set VPLA_K and VPLB_K for AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066666; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066666; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* Set VPLA_K and VPLB_K for AXO: 24.576 MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* wait 1 usec */ + udelay(1); + + /* Set VPLA_K_LD and VPLB_K_LD to load K parameters */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Unset VPLA_SNRST and VPLB_SNRST bit */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Enable write protect of VPLL27ACTRL[2-7]*, VPLL27BCTRL[2-8] */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + stop_mpll(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 1 usec in vpll_init() so 1 usec can be saved here. + */ + udelay(499); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c new file mode 100644 index 0000000..4538d1a --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/pll_spectrum.c @@ -0,0 +1,18 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void enable_dpll_ssc(void) +{ + u32 tmp; + + tmp = readl(SC_DPLLCTRL); + tmp |= SC_DPLLCTRL_SSC_EN; + writel(tmp, SC_DPLLCTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c new file mode 100644 index 0000000..f113db5 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sbc_init.c @@ -0,0 +1,75 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) + /* + * Only CS1 is connected to support card. + * BKSZ[1:0] should be set to "01". + */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL14); + + if (readl(SBBASE0) & 0x1) { + /* + * Boot Swap Off: boot from mask ROM + * 0x00000000-0x01ffffff: mask ROM + * 0x02000000-0x3effffff: memory bank (31MB) + * 0x03f00000-0x3fffffff: peripherals (1MB) + */ + writel(0x0000be01, SBBASE0); /* dummy */ + writel(0x0200be01, SBBASE1); + } else { + /* + * Boot Swap On: boot from external NOR/SRAM + * 0x02000000-0x03ffffff is a mirror of 0x00000000-0x01ffffff. + * + * 0x00000000-0x01efffff, 0x02000000-0x03efffff: memory bank + * 0x01f00000-0x01ffffff, 0x03f00000-0x03ffffff: peripherals + */ + writel(0x0000bc01, SBBASE0); + } +#elif defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +#if !defined(CONFIG_SPL_BUILD) + /* XECS0: boot/sub memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS1: sub/boot memory (boot swap = off/on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS3: peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL30); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL31); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL32); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL34); + + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0400bc01, SBBASE1); /* sub memory */ + writel(0x0800bf01, SBBASE3); /* peripherals */ + +#if !defined(CONFIG_SPL_BUILD) + sg_set_pinsel(318, 5); /* PORT22 -> XECS0 */ +#endif + sg_set_pinsel(313, 5); /* PORT15 -> XECS3 */ + writel(0x00000001, SG_LOADPINCTRL); + +#endif /* CONFIG_XXX_MICRO_SUPPORT_CARD */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c new file mode 100644 index 0000000..b4dd799 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/sg_init.c @@ -0,0 +1,28 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void sg_init(void) +{ + u32 tmp; + + /* Set DDR size */ + tmp = sg_memconf_val_ch0(CONFIG_SDRAM0_SIZE, CONFIG_DDR_NUM_CH0); + tmp |= sg_memconf_val_ch1(CONFIG_SDRAM1_SIZE, CONFIG_DDR_NUM_CH1); +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE < CONFIG_SDRAM1_BASE + tmp |= SG_MEMCONF_SPARSEMEM; +#endif + writel(tmp, SG_MEMCONF); + + /* Input ports must be enabled deasserting reset of cores */ + tmp = readl(SG_IECTRL); + tmp |= 0x1; + writel(tmp, SG_IECTRL); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c new file mode 100644 index 0000000..dd46287 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-pro4/umc_init.c @@ -0,0 +1,136 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/umc-regs.h> + +static inline void umc_start_ssif(void __iomem *ssif_base) +{ + writel(0x00000001, ssif_base + 0x0000b004); + writel(0xffffffff, ssif_base + 0x0000c004); + writel(0x07ffffff, ssif_base + 0x0000c008); + writel(0x00000001, ssif_base + 0x0000b000); + writel(0x00000001, ssif_base + 0x0000c000); + + writel(0x03010100, ssif_base + UMC_HDMCHSEL); + writel(0x03010101, ssif_base + UMC_MDMCHSEL); + writel(0x03010100, ssif_base + UMC_DVCCHSEL); + writel(0x03010100, ssif_base + UMC_DMDCHSEL); + + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_FETCH); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_WC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_RC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_DST); + writel(0x00000000, ssif_base + 0x0000c044); /* DCGIV_SSIF_REG */ + + writel(0x00000001, ssif_base + UMC_CPURST); + writel(0x00000001, ssif_base + UMC_IDSRST); + writel(0x00000001, ssif_base + UMC_IXMRST); + writel(0x00000001, ssif_base + UMC_HDMRST); + writel(0x00000001, ssif_base + UMC_MDMRST); + writel(0x00000001, ssif_base + UMC_HDDRST); + writel(0x00000001, ssif_base + UMC_MDDRST); + writel(0x00000001, ssif_base + UMC_SIORST); + writel(0x00000001, ssif_base + UMC_GIORST); + writel(0x00000001, ssif_base + UMC_HD2RST); + writel(0x00000001, ssif_base + UMC_VIORST); + writel(0x00000001, ssif_base + UMC_DVCRST); + writel(0x00000001, ssif_base + UMC_RGLRST); + writel(0x00000001, ssif_base + UMC_VPERST); + writel(0x00000001, ssif_base + UMC_AIORST); + writel(0x00000001, ssif_base + UMC_DMDRST); +} + +void umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, + int size, int freq) +{ + writel(0x66bb0f17, dramcont + UMC_CMDCTLA); + writel(0x18c6aa44, dramcont + UMC_CMDCTLB); + writel(0x5101387f, dramcont + UMC_INITCTLA); + writel(0x43030d3f, dramcont + UMC_INITCTLB); + writel(0x00ff00ff, dramcont + UMC_INITCTLC); + writel(0x00000d71, dramcont + UMC_DRMMR0); + writel(0x00000006, dramcont + UMC_DRMMR1); + writel(0x00000298, dramcont + UMC_DRMMR2); + writel(0x00000000, dramcont + UMC_DRMMR3); + writel(0x003f0617, dramcont + UMC_SPCCTLA); + writel(0x00ff0008, dramcont + UMC_SPCCTLB); + writel(0x000c00ae, dramcont + UMC_RDATACTL_D0); + writel(0x000c00ae, dramcont + UMC_RDATACTL_D1); + writel(0x04060802, dramcont + UMC_WDATACTL_D0); + writel(0x04060802, dramcont + UMC_WDATACTL_D1); + writel(0x04a02000, dramcont + UMC_DATASET); + writel(0x00000000, ca_base + 0x2300); + writel(0x00400020, dramcont + UMC_DCCGCTL); + writel(0x0000000f, dramcont + 0x7000); + writel(0x0000000f, dramcont + 0x8000); + writel(0x000000c3, dramcont + 0x8004); + writel(0x00000071, dramcont + 0x8008); + writel(0x00000004, dramcont + UMC_FLOWCTLG); + writel(0x00000000, dramcont + 0x0060); + writel(0x80000201, ca_base + 0xc20); + writel(0x0801e01e, dramcont + UMC_FLOWCTLA); + writel(0x00200000, dramcont + UMC_FLOWCTLB); + writel(0x00004444, dramcont + UMC_FLOWCTLC); + writel(0x200a0a00, dramcont + UMC_SPCSETB); + writel(0x00010000, dramcont + UMC_SPCSETD); + writel(0x80000020, dramcont + UMC_DFICUPDCTLA); +} + +static inline int umc_init_sub(int freq, int size_ch0, int size_ch1) +{ + void __iomem *ssif_base = (void __iomem *)UMC_SSIF_BASE; + void __iomem *ca_base0 = (void __iomem *)UMC_CA_BASE(0); + void __iomem *ca_base1 = (void __iomem *)UMC_CA_BASE(1); + void __iomem *dramcont0 = (void __iomem *)UMC_DRAMCONT_BASE(0); + void __iomem *dramcont1 = (void __iomem *)UMC_DRAMCONT_BASE(1); + + umc_dram_init_start(dramcont0); + umc_dram_init_start(dramcont1); + umc_dram_init_poll(dramcont0); + umc_dram_init_poll(dramcont1); + + writel(0x00000101, dramcont0 + UMC_DIOCTLA); + + writel(0x00000103, dramcont0 + UMC_DIOCTLA); + + writel(0x00000101, dramcont1 + UMC_DIOCTLA); + + writel(0x00000103, dramcont1 + UMC_DIOCTLA); + + umc_dramcont_init(dramcont0, ca_base0, size_ch0, freq); + umc_dramcont_init(dramcont1, ca_base1, size_ch1, freq); + + umc_start_ssif(ssif_base); + + return 0; +} + +int umc_init(void) +{ + return umc_init_sub(CONFIG_DDR_FREQ, CONFIG_SDRAM0_SIZE / 0x08000000, + CONFIG_SDRAM1_SIZE / 0x08000000); +} + +#if CONFIG_DDR_FREQ != 1600 +#error Unsupported DDR frequency. +#endif + +#if ((CONFIG_SDRAM0_SIZE == 0x20000000 && CONFIG_DDR_NUM_CH0 == 2) || \ + (CONFIG_SDRAM0_SIZE == 0x10000000 && CONFIG_DDR_NUM_CH0 == 1)) && \ + ((CONFIG_SDRAM1_SIZE == 0x20000000 && CONFIG_DDR_NUM_CH1 == 2) || \ + (CONFIG_SDRAM1_SIZE == 0x10000000 && CONFIG_DDR_NUM_CH1 == 1)) +/* OK */ +#else + #error Unsupported DDR configuration. +#endif diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile new file mode 100644 index 0000000..b385e19 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/Makefile @@ -0,0 +1,10 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board_info.o +obj-y += boot-mode.o +obj-$(CONFIG_BOARD_POSTCLK_INIT) += board_postclk_init.o bcu_init.o \ + sbc_init.o sg_init.o pll_init.o clkrst_init.o pinctrl.o +obj-$(CONFIG_SPL_BUILD) += pll_spectrum.o \ + umc_init.o diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c new file mode 100644 index 0000000..69b172e --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/bcu_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/bcu_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c new file mode 100644 index 0000000..15dc289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_info.c @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/board.h> + +int checkboard(void) +{ + puts("Board: PH1-sLD8 Board\n"); + + return check_support_card(); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c new file mode 100644 index 0000000..287b33c --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/board_postclk_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/board_postclk_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c new file mode 100644 index 0000000..d359b56 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/boot-mode.c @@ -0,0 +1 @@ +#include "../ph1-pro4/boot-mode.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c new file mode 100644 index 0000000..18965a9 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/clkrst_init.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> + +void clkrst_init(void) +{ + u32 tmp; + + /* deassert reset */ + tmp = readl(SC_RSTCTRL); + tmp |= SC_RSTCTRL_NRST_ETHER | SC_RSTCTRL_NRST_UMC1 + | SC_RSTCTRL_NRST_UMC0 | SC_RSTCTRL_NRST_NAND; + writel(tmp, SC_RSTCTRL); + readl(SC_RSTCTRL); /* dummy read */ + + /* privide clocks */ + tmp = readl(SC_CLKCTRL); + tmp |= SC_CLKCTRL_CLK_ETHER | SC_CLKCTRL_CLK_MIO | SC_CLKCTRL_CLK_UMC + | SC_CLKCTRL_CLK_NAND | SC_CLKCTRL_CLK_SBC | SC_CLKCTRL_CLK_PERI; + writel(tmp, SC_CLKCTRL); + readl(SC_CLKCTRL); /* dummy read */ +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c new file mode 100644 index 0000000..2b6403f --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pinctrl.c @@ -0,0 +1,57 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sg-regs.h> + +void pin_init(void) +{ + /* Comment format: PAD Name -> Function Name */ + +#ifdef CONFIG_UNIPHIER_SERIAL + sg_set_pinsel(70, 3); /* HDDOUT0 -> TXD0 */ + sg_set_pinsel(71, 3); /* HSDOUT1 -> RXD0 */ + + sg_set_pinsel(114, 0); /* TXD1 -> TXD1 */ + sg_set_pinsel(115, 0); /* RXD1 -> RXD1 */ + + sg_set_pinsel(112, 1); /* SBO1 -> TXD2 */ + sg_set_pinsel(113, 1); /* SBI1 -> RXD2 */ + + sg_set_pinsel(110, 1); /* SBO0 -> TXD3 */ + sg_set_pinsel(111, 1); /* SBI0 -> RXD3 */ +#endif + +#ifdef CONFIG_NAND_DENALI + sg_set_pinsel(15, 0); /* XNFRE_GB -> XNFRE_GB */ + sg_set_pinsel(16, 0); /* XNFWE_GB -> XNFWE_GB */ + sg_set_pinsel(17, 0); /* XFALE_GB -> NFALE_GB */ + sg_set_pinsel(18, 0); /* XFCLE_GB -> NFCLE_GB */ + sg_set_pinsel(19, 0); /* XNFWP_GB -> XFNWP_GB */ + sg_set_pinsel(20, 0); /* XNFCE0_GB -> XNFCE0_GB */ + sg_set_pinsel(21, 0); /* NANDRYBY0_GB -> NANDRYBY0_GB */ + sg_set_pinsel(22, 0); /* XFNCE1_GB -> XFNCE1_GB */ + sg_set_pinsel(23, 0); /* NANDRYBY1_GB -> NANDRYBY1_GB */ + sg_set_pinsel(24, 0); /* NFD0_GB -> NFD0_GB */ + sg_set_pinsel(25, 0); /* NFD1_GB -> NFD1_GB */ + sg_set_pinsel(26, 0); /* NFD2_GB -> NFD2_GB */ + sg_set_pinsel(27, 0); /* NFD3_GB -> NFD3_GB */ + sg_set_pinsel(28, 0); /* NFD4_GB -> NFD4_GB */ + sg_set_pinsel(29, 0); /* NFD5_GB -> NFD5_GB */ + sg_set_pinsel(30, 0); /* NFD6_GB -> NFD6_GB */ + sg_set_pinsel(31, 0); /* NFD7_GB -> NFD7_GB */ +#endif + +#ifdef CONFIG_USB_EHCI_UNIPHIER + sg_set_pinsel(41, 0); /* USB0VBUS -> USB0VBUS */ + sg_set_pinsel(42, 0); /* USB0OD -> USB0OD */ + sg_set_pinsel(43, 0); /* USB1VBUS -> USB1VBUS */ + sg_set_pinsel(44, 0); /* USB1OD -> USB1OD */ + /* sg_set_pinsel(114, 4); */ /* TXD1 -> USB2VBUS (shared with UART) */ + /* sg_set_pinsel(115, 4); */ /* RXD1 -> USB2OD */ +#endif +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c new file mode 100644 index 0000000..4d87053 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_init.c @@ -0,0 +1,201 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/sg-regs.h> + +void dpll_init(void) +{ + u32 tmp; + /* + * Set DPLL SSC parameters for DPLLCTRL3 + * [23] DIVN_TEST 0x1 + * [22:16] DIVN 0x50 + * [10] FREFSEL_TEST 0x1 + * [9:8] FREFSEL 0x2 + * [4] ICPD_TEST 0x1 + * [3:0] ICPD 0xb + */ + tmp = readl(SC_DPLLCTRL3); + tmp &= ~0x00ff0717; + tmp |= 0x00d0061b; + writel(tmp, SC_DPLLCTRL3); + + /* + * Set DPLL SSC parameters for DPLLCTRL + * <-1%> <-2%> + * [29:20] SSC_UPCNT 132 (0x084) 132 (0x084) + * [14:0] SSC_dK 6335(0x18bf) 12710(0x31a6) + */ + tmp = readl(SC_DPLLCTRL); + tmp &= ~0x3ff07fff; +#ifdef CONFIG_DPLL_SSC_RATE_1PER + tmp |= 0x084018bf; +#else + tmp |= 0x084031a6; +#endif + writel(tmp, SC_DPLLCTRL); + + /* + * Set DPLL SSC parameters for DPLLCTRL2 + * [31:29] SSC_STEP 0 + * [27] SSC_REG_REF 1 + * [26:20] SSC_M 79 (0x4f) + * [19:0] SSC_K 964689 (0xeb851) + */ + tmp = readl(SC_DPLLCTRL2); + tmp &= ~0xefffffff; + tmp |= 0x0cfeb851; + writel(tmp, SC_DPLLCTRL2); +} + +void upll_init(void) +{ + u32 tmp, clk_mode_upll, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_upll = tmp & SG_PINMON0_CLK_MODE_UPLLSRC_MASK; + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 0 to SNRT(UPLLCTRL.bit28) and K_LD(UPLLCTRL.bit[27]) */ + tmp = readl(SC_UPLLCTRL); + tmp &= ~0x18000000; + writel(tmp, SC_UPLLCTRL); + + if (clk_mode_upll == SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT) { + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x0228f5c0; + } else { + /* AXO: default 24.576MHz */ + tmp &= ~0x07ffffff; + tmp |= 0x02328000; + } + } + + writel(tmp, SC_UPLLCTRL); + + /* set 1 to K_LD(UPLLCTRL.bit[27]) */ + tmp |= 0x08000000; + writel(tmp, SC_UPLLCTRL); + + /* wait 10 usec */ + udelay(10); + + /* set 1 to SNRT(UPLLCTRL.bit[28]) */ + tmp |= 0x10000000; + writel(tmp, SC_UPLLCTRL); +} + +void vpll_init(void) +{ + u32 tmp, clk_mode_axosel; + + tmp = readl(SG_PINMON0); + clk_mode_axosel = tmp & SG_PINMON0_CLK_MODE_AXOSEL_MASK; + + /* set 1 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= 0x00000001; + writel(tmp, SC_VPLL27BCTRL); + + /* Set 0 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* Set 0x20 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp &= ~0x0000007f; + tmp |= 0x00000020; + writel(tmp, SC_VPLL27BCTRL2); + + if (clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U || + clk_mode_axosel == SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A) { + /* AXO: 25MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x00066664; + writel(tmp, SC_VPLL27BCTRL3); + } else { + /* AXO: default 24.576MHz */ + tmp = readl(SC_VPLL27ACTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp &= ~0x000fffff; + tmp |= 0x000f5800; + writel(tmp, SC_VPLL27BCTRL3); + } + + /* Set 1 to VPLA_K_LD and VPLB_K_LD */ + tmp = readl(SC_VPLL27ACTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL3); + tmp = readl(SC_VPLL27BCTRL3); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL3); + + /* wait 10 usec */ + udelay(10); + + /* Set 0 to VPLA_SNRST and VPLB_SNRST */ + tmp = readl(SC_VPLL27ACTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27ACTRL2); + tmp = readl(SC_VPLL27BCTRL2); + tmp |= 0x10000000; + writel(tmp, SC_VPLL27BCTRL2); + + /* set 0 to VPLA27WP and VPLA27WP */ + tmp = readl(SC_VPLL27ACTRL); + tmp &= ~0x00000001; + writel(tmp, SC_VPLL27ACTRL); + tmp = readl(SC_VPLL27BCTRL); + tmp |= ~0x00000001; + writel(tmp, SC_VPLL27BCTRL); +} + +void pll_init(void) +{ + dpll_init(); + upll_init(); + vpll_init(); + + /* + * Wait 500 usec until dpll get stable + * We wait 10 usec in upll_init() and vpll_init() + * so 20 usec can be saved here. + */ + udelay(480); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c new file mode 100644 index 0000000..9b8c485 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/pll_spectrum.c @@ -0,0 +1 @@ +#include "../ph1-ld4/pll_spectrum.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c new file mode 100644 index 0000000..af44dee --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sbc_init.c @@ -0,0 +1,51 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sbc-regs.h> +#include <asm/arch/sg-regs.h> + +void sbc_init(void) +{ +#if !defined(CONFIG_SPL_BUILD) + /* XECS0 : dummy */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL00); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL01); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL02); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL04); +#endif + /* XECS1 : boot memory (always boot swap = on) */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL10); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL11); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL12); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL14); + + /* XECS4 : sub memory */ + writel(SBCTRL0_SAVEPIN_MEM_VALUE, SBCTRL40); + writel(SBCTRL1_SAVEPIN_MEM_VALUE, SBCTRL41); + writel(SBCTRL2_SAVEPIN_MEM_VALUE, SBCTRL42); + writel(SBCTRL4_SAVEPIN_MEM_VALUE, SBCTRL44); + + /* XECS5 : peripherals */ + writel(SBCTRL0_SAVEPIN_PERI_VALUE, SBCTRL50); + writel(SBCTRL1_SAVEPIN_PERI_VALUE, SBCTRL51); + writel(SBCTRL2_SAVEPIN_PERI_VALUE, SBCTRL52); + writel(SBCTRL4_SAVEPIN_PERI_VALUE, SBCTRL54); + + /* base address regsiters */ + writel(0x0000bc01, SBBASE0); /* boot memory */ + writel(0x0900bfff, SBBASE1); /* dummy */ + writel(0x0400bc01, SBBASE4); /* sub memory */ + writel(0x0800bf01, SBBASE5); /* peripherals */ + + sg_set_pinsel(134, 16); /* XIRQ6 -> XECS4 */ + sg_set_pinsel(135, 16); /* XIRQ7 -> XECS5 */ + + /* dummy read to assure write process */ + readl(SG_PINCTRL(33)); +} diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c new file mode 100644 index 0000000..a808289 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/sg_init.c @@ -0,0 +1 @@ +#include "../ph1-ld4/sg_init.c" diff --git a/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c new file mode 100644 index 0000000..ff2dcb1 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/ph1-sld8/umc_init.c @@ -0,0 +1,142 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/umc-regs.h> + +static inline void umc_start_ssif(void __iomem *ssif_base) +{ + writel(0x00000000, ssif_base + 0x0000b004); + writel(0xffffffff, ssif_base + 0x0000c004); + writel(0x000fffcf, ssif_base + 0x0000c008); + writel(0x00000001, ssif_base + 0x0000b000); + writel(0x00000001, ssif_base + 0x0000c000); + writel(0x03010101, ssif_base + UMC_MDMCHSEL); + writel(0x03010100, ssif_base + UMC_DMDCHSEL); + + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_FETCH); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC0); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMQUE1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMWC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_COMRC1); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_WC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_RC); + writel(0x00000000, ssif_base + UMC_CLKEN_SSIF_DST); + + writel(0x00000001, ssif_base + UMC_CPURST); + writel(0x00000001, ssif_base + UMC_IDSRST); + writel(0x00000001, ssif_base + UMC_IXMRST); + writel(0x00000001, ssif_base + UMC_MDMRST); + writel(0x00000001, ssif_base + UMC_MDDRST); + writel(0x00000001, ssif_base + UMC_SIORST); + writel(0x00000001, ssif_base + UMC_VIORST); + writel(0x00000001, ssif_base + UMC_FRCRST); + writel(0x00000001, ssif_base + UMC_RGLRST); + writel(0x00000001, ssif_base + UMC_AIORST); + writel(0x00000001, ssif_base + UMC_DMDRST); +} + +void umc_dramcont_init(void __iomem *dramcont, void __iomem *ca_base, + int size, int freq) +{ +#ifdef CONFIG_DDR_STANDARD + writel(0x55990b11, dramcont + UMC_CMDCTLA); + writel(0x16958944, dramcont + UMC_CMDCTLB); +#else + writel(0x45990b11, dramcont + UMC_CMDCTLA); + writel(0x16958924, dramcont + UMC_CMDCTLB); +#endif + + writel(0x5101046A, dramcont + UMC_INITCTLA); + + if (size == 1) + writel(0x27028B0A, dramcont + UMC_INITCTLB); + else if (size == 2) + writel(0x38028B0A, dramcont + UMC_INITCTLB); + + writel(0x00FF00FF, dramcont + UMC_INITCTLC); + writel(0x00000b51, dramcont + UMC_DRMMR0); + writel(0x00000006, dramcont + UMC_DRMMR1); + writel(0x00000290, dramcont + UMC_DRMMR2); + +#ifdef CONFIG_DDR_STANDARD + writel(0x00000000, dramcont + UMC_DRMMR3); +#else + writel(0x00000800, dramcont + UMC_DRMMR3); +#endif + + if (size == 1) + writel(0x00240512, dramcont + UMC_SPCCTLA); + else if (size == 2) + writel(0x00350512, dramcont + UMC_SPCCTLA); + + writel(0x00ff0006, dramcont + UMC_SPCCTLB); + writel(0x000a00ac, dramcont + UMC_RDATACTL_D0); + writel(0x04060806, dramcont + UMC_WDATACTL_D0); + writel(0x04a02000, dramcont + UMC_DATASET); + writel(0x00000000, ca_base + 0x2300); + writel(0x00400020, dramcont + UMC_DCCGCTL); + writel(0x00000003, dramcont + 0x7000); + writel(0x0000004f, dramcont + 0x8000); + writel(0x000000c3, dramcont + 0x8004); + writel(0x00000077, dramcont + 0x8008); + writel(0x0000003b, dramcont + UMC_DICGCTLA); + writel(0x020a0808, dramcont + UMC_DICGCTLB); + writel(0x00000004, dramcont + UMC_FLOWCTLG); + writel(0x80000201, ca_base + 0xc20); + writel(0x0801e01e, dramcont + UMC_FLOWCTLA); + writel(0x00200000, dramcont + UMC_FLOWCTLB); + writel(0x00004444, dramcont + UMC_FLOWCTLC); + writel(0x200a0a00, dramcont + UMC_SPCSETB); + writel(0x00000000, dramcont + UMC_SPCSETD); + writel(0x00000520, dramcont + UMC_DFICUPDCTLA); +} + +static inline int umc_init_sub(int freq, int size_ch0, int size_ch1) +{ + void __iomem *ssif_base = (void __iomem *)UMC_SSIF_BASE; + void __iomem *ca_base0 = (void __iomem *)UMC_CA_BASE(0); + void __iomem *ca_base1 = (void __iomem *)UMC_CA_BASE(1); + void __iomem *dramcont0 = (void __iomem *)UMC_DRAMCONT_BASE(0); + void __iomem *dramcont1 = (void __iomem *)UMC_DRAMCONT_BASE(1); + + umc_dram_init_start(dramcont0); + umc_dram_init_start(dramcont1); + umc_dram_init_poll(dramcont0); + umc_dram_init_poll(dramcont1); + + writel(0x00000101, dramcont0 + UMC_DIOCTLA); + + writel(0x00000101, dramcont1 + UMC_DIOCTLA); + + umc_dramcont_init(dramcont0, ca_base0, size_ch0, freq); + umc_dramcont_init(dramcont1, ca_base1, size_ch1, freq); + + umc_start_ssif(ssif_base); + + return 0; +} + +int umc_init(void) +{ + return umc_init_sub(CONFIG_DDR_FREQ, CONFIG_SDRAM0_SIZE / 0x08000000, + CONFIG_SDRAM1_SIZE / 0x08000000); +} + +#if CONFIG_DDR_FREQ != 1333 +#error Unsupported DDR frequency. +#endif + +#if (CONFIG_SDRAM0_SIZE == 0x08000000 || CONFIG_SDRAM0_SIZE == 0x10000000) && \ + (CONFIG_SDRAM1_SIZE == 0x08000000 || CONFIG_SDRAM1_SIZE == 0x10000000) && \ + CONFIG_DDR_NUM_CH0 == 1 && CONFIG_DDR_NUM_CH1 == 1 +/* OK */ +#else +#error Unsupported DDR configuration. +#endif diff --git a/arch/arm/cpu/armv7/uniphier/reset.c b/arch/arm/cpu/armv7/uniphier/reset.c new file mode 100644 index 0000000..b0dc967 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/reset.c @@ -0,0 +1,29 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/sc-regs.h> +#include <asm/arch/board.h> + +void reset_cpu(unsigned long ignored) +{ + u32 tmp; + + uniphier_board_reset(); + + writel(5, SC_IRQTIMSET); /* default value */ + + tmp = readl(SC_SLFRSTSEL); + tmp &= ~0x3; /* mask [1:0] */ + tmp |= 0x0; /* XRST reboot */ + writel(tmp, SC_SLFRSTSEL); + + tmp = readl(SC_SLFRSTCTL); + tmp |= 0x1; + writel(tmp, SC_SLFRSTCTL); +} diff --git a/arch/arm/cpu/armv7/uniphier/smp.S b/arch/arm/cpu/armv7/uniphier/smp.S new file mode 100644 index 0000000..25ba981 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/smp.S @@ -0,0 +1,54 @@ +/* + * Copyright (C) 2013 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <config.h> +#include <linux/linkage.h> +#include <asm/system.h> +#include <asm/arch/led.h> +#include <asm/arch/sbc-regs.h> + +/* Entry point of U-Boot main program for the secondary CPU */ +LENTRY(secondary_entry) + mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Contrl Register) + bic r0, r0, #(CR_C | CR_M) @ MMU and Dcache disable + mcr p15, 0, r0, c1, c0, 0 + mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs + mcr p15, 0, r0, c7, c5, 0 @ invalidate icache + dsb + led_write(C,0,,) + ldr r1, =ROM_BOOT_ROMRSV2 + mov r0, #0 + str r0, [r1] +0: wfe + ldr r4, [r1] @ r4: entry point for secondary CPUs + cmp r4, #0 + beq 0b + led_write(C, P, U, 1) + bx r4 @ secondary CPUs jump to linux +ENDPROC(secondary_entry) + +ENTRY(wakeup_secondary) + ldr r1, =ROM_BOOT_ROMRSV2 +0: ldr r0, [r1] + cmp r0, #0 + bne 0b + + /* set entry address and send event to the secondary CPU */ + ldr r0, =secondary_entry + str r0, [r1] + ldr r0, [r1] @ make sure store is complete + mov r0, #0x100 +0: subs r0, r0, #1 @ I don't know the reason, but without this wait + bne 0b @ fails to wake up the secondary CPU + sev + + /* wait until the secondary CPU reach to secondary_entry */ +0: ldr r0, [r1] + cmp r0, #0 + bne 0b + bx lr +ENDPROC(wakeup_secondary) diff --git a/arch/arm/cpu/armv7/uniphier/spl.c b/arch/arm/cpu/armv7/uniphier/spl.c new file mode 100644 index 0000000..40d28ad --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/spl.c @@ -0,0 +1,17 @@ +/* + * Copyright (C) 2013-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <spl.h> + +void spl_board_init(void) +{ +#if defined(CONFIG_BOARD_POSTCLK_INIT) + board_postclk_init(); +#endif + dram_init(); +} diff --git a/arch/arm/cpu/armv7/uniphier/support_card.c b/arch/arm/cpu/armv7/uniphier/support_card.c new file mode 100644 index 0000000..40d4940 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/support_card.c @@ -0,0 +1,180 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/board.h> + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) + +#define PFC_MICRO_SUPPORT_CARD_RESET \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x000D0034) +#define PFC_MICRO_SUPPORT_CARD_REVISION \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x000D00E0) +/* + * 0: reset deassert, 1: reset + * + * bit[0]: LAN, I2C, LED + * bit[1]: UART + */ +void support_card_reset_deassert(void) +{ + writel(0, PFC_MICRO_SUPPORT_CARD_RESET); +} + +void support_card_reset(void) +{ + writel(3, PFC_MICRO_SUPPORT_CARD_RESET); +} + +static int support_card_show_revision(void) +{ + u32 revision; + + revision = readl(PFC_MICRO_SUPPORT_CARD_REVISION); + printf("(PFC CPLD version %d.%d)\n", revision >> 4, revision & 0xf); + return 0; +} +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) + +#define DCC_MICRO_SUPPORT_CARD_RESET_LAN \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401300) +#define DCC_MICRO_SUPPORT_CARD_RESET_UART \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401304) +#define DCC_MICRO_SUPPORT_CARD_RESET_I2C \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x00401308) +#define DCC_MICRO_SUPPORT_CARD_REVISION \ + ((CONFIG_SUPPORT_CARD_BASE) + 0x005000E0) + +void support_card_reset_deassert(void) +{ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED */ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */ + writel(1, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */ +} + +void support_card_reset(void) +{ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_LAN); /* LAN and LED */ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_UART); /* UART */ + writel(0, DCC_MICRO_SUPPORT_CARD_RESET_I2C); /* I2C */ +} + +static int support_card_show_revision(void) +{ + u32 revision; + + revision = readl(DCC_MICRO_SUPPORT_CARD_REVISION); + + if (revision >= 0x67) { + printf("(DCC CPLD version 3.%d.%d)\n", + revision >> 4, revision & 0xf); + return 0; + } else { + printf("(DCC CPLD unknown version)\n"); + return -1; + } +} +#endif + +void support_card_init(void) +{ + /* + * After power on, we need to keep the LAN controller in reset state + * for a while. (200 usec) + * Fortunatelly, enough wait time is already inserted in pll_init() + * function. So we do not have to wait here. + */ + support_card_reset_deassert(); +} + +int check_support_card(void) +{ + printf("SC: Micro Support Card "); + return support_card_show_revision(); +} + +#if defined(CONFIG_SMC911X) +#include <netdev.h> + +int board_eth_init(bd_t *bis) +{ + return smc911x_initialize(0, CONFIG_SMC911X_BASE); +} +#endif + +#if !defined(CONFIG_SYS_NO_FLASH) + +#include <mtd/cfi_flash.h> + +#if CONFIG_SYS_MAX_FLASH_BANKS > 1 +static phys_addr_t flash_banks_list[CONFIG_SYS_MAX_FLASH_BANKS] = + CONFIG_SYS_FLASH_BANKS_LIST; + +phys_addr_t cfi_flash_bank_addr(int i) +{ + return flash_banks_list[i]; +} +#endif + +int mem_is_flash(phys_addr_t base) +{ + const int loop = 128; + u32 *scratch_addr; + u32 saved_value; + int ret = 1; + int i; + + scratch_addr = map_physmem(base + 0x01e00000, + sizeof(u32) * loop, MAP_NOCACHE); + + for (i = 0; i < loop; i++, scratch_addr++) { + saved_value = readl(scratch_addr); + writel(~saved_value, scratch_addr); + if (readl(scratch_addr) != saved_value) { + /* We assume no memory or SRAM here. */ + writel(saved_value, scratch_addr); + ret = 0; + break; + } + } + + unmap_physmem(scratch_addr, MAP_NOCACHE); + + return ret; +} + +int board_flash_wp_on(void) +{ + int i; + int ret = 1; + + for (i = 0; i < CONFIG_SYS_MAX_FLASH_BANKS; i++) { + if (mem_is_flash(cfi_flash_bank_addr(i))) { + /* + * We found at least one flash. + * We need to return 0 and call flash_init(). + */ + ret = 0; + } +#if CONFIG_SYS_MAX_FLASH_BANKS > 1 + else { + /* + * We might have a SRAM here. + * To prevent SRAM data from being destroyed, + * we set dummy address (SDRAM). + */ + flash_banks_list[i] = 0x80000000 + 0x10000 * i; + } +#endif + } + + return ret; +} +#endif diff --git a/arch/arm/cpu/armv7/uniphier/timer.c b/arch/arm/cpu/armv7/uniphier/timer.c new file mode 100644 index 0000000..6edc084 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/timer.c @@ -0,0 +1,39 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/arm-mpcore.h> + +#define PERIPHCLK (50 * 1000 * 1000) /* 50 MHz */ +#define PRESCALER ((PERIPHCLK) / (CONFIG_SYS_TIMER_RATE) - 1) + +static void *get_global_timer_base(void) +{ + void *val; + + asm("mrc p15, 4, %0, c15, c0, 0" : "=r" (val) : : "memory"); + + return val + GLOBAL_TIMER_OFFSET; +} + +unsigned long timer_read_counter(void) +{ + /* + * ARM 64bit Global Timer is too much for our purpose. + * We use only lower 32 bit of the timer counter. + */ + return readl(get_global_timer_base() + GTIMER_CNT_L); +} + +int timer_init(void) +{ + /* enable timer */ + writel(PRESCALER << 8 | 1, get_global_timer_base() + GTIMER_CTRL); + + return 0; +} diff --git a/arch/arm/include/asm/arch-uniphier/arm-mpcore.h b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h new file mode 100644 index 0000000..cf7cd46 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/arm-mpcore.h @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_ARM_MPCORE_H +#define ARCH_ARM_MPCORE_H + +/* Snoop Control Unit */ +#define SCU_OFFSET 0x00 + +/* SCU Control Register */ +#define SCU_CTRL 0x00 +/* SCU Configuration Register */ +#define SCU_CONF 0x04 +/* SCU CPU Power Status Register */ +#define SCU_PWR_STATUS 0x08 +/* SCU Invalidate All Registers in Secure State */ +#define SCU_INV_ALL 0x0C +/* SCU Filtering Start Address Register */ +#define SCU_FILTER_START 0x40 +/* SCU Filtering End Address Register */ +#define SCU_FILTER_END 0x44 +/* SCU Access Control Register */ +#define SCU_SAC 0x50 +/* SCU Non-secure Access Control Register */ +#define SCU_SNSAC 0x54 + +/* Global Timer */ +#define GLOBAL_TIMER_OFFSET 0x200 + +/* Global Timer Counter Registers */ +#define GTIMER_CNT_L 0x00 +#define GTIMER_CNT_H 0x04 +/* Global Timer Control Register */ +#define GTIMER_CTRL 0x08 +/* Global Timer Interrupt Status Register */ +#define GTIMER_STAT 0x0C +/* Comparator Value Registers */ +#define GTIMER_CMP_L 0x10 +#define GTIMER_CMP_H 0x14 +/* Auto-increment Register */ +#define GTIMER_INC 0x18 + +#endif /* ARCH_ARM_MPCORE_H */ diff --git a/arch/arm/include/asm/arch-uniphier/bcu-regs.h b/arch/arm/include/asm/arch-uniphier/bcu-regs.h new file mode 100644 index 0000000..0dfd94e --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/bcu-regs.h @@ -0,0 +1,30 @@ +/* + * UniPhier BCU (Bus Control Unit) registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_BCU_REGS_H +#define ARCH_BCU_REGS_H + +#define BCU_BASE 0x50080000 + +#define BCSCR(x) (BCU_BASE + 0x180 + (x) * 4) +#define BCSCR0 (BCSCR(0)) +#define BCSCR1 (BCSCR(1)) +#define BCSCR2 (BCSCR(2)) +#define BCSCR3 (BCSCR(3)) +#define BCSCR4 (BCSCR(4)) +#define BCSCR5 (BCSCR(5)) + +#define BCIPPCCHR(x) (BCU_BASE + 0x0280 + (x) * 4) +#define BCIPPCCHR0 (BCIPPCCHR(0)) +#define BCIPPCCHR1 (BCIPPCCHR(1)) +#define BCIPPCCHR2 (BCIPPCCHR(2)) +#define BCIPPCCHR3 (BCIPPCCHR(3)) +#define BCIPPCCHR4 (BCIPPCCHR(4)) +#define BCIPPCCHR5 (BCIPPCCHR(5)) + +#endif /* ARCH_BCU_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/board.h b/arch/arm/include/asm/arch-uniphier/board.h new file mode 100644 index 0000000..e6ba4e4 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/board.h @@ -0,0 +1,35 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_BOARD_H +#define ARCH_BOARD_H + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) || \ + defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +void support_card_reset(void); +void support_card_init(void); +int check_support_card(void); +#else +#define support_card_reset() do {} while (0) +#define support_card_init() do {} while (0) +static inline int check_support_card(void) +{ + return 0; +} +#endif + +static inline void uniphier_board_reset(void) +{ + support_card_reset(); +} + +static inline void uniphier_board_init(void) +{ + support_card_init(); +} + +#endif /* ARCH_BOARD_H */ diff --git a/arch/arm/include/asm/arch-uniphier/boot-device.h b/arch/arm/include/asm/arch-uniphier/boot-device.h new file mode 100644 index 0000000..6987f57 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/boot-device.h @@ -0,0 +1,20 @@ +/* + * Copyright (C) 2011-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_BOOT_DEVICE_H_ +#define _ASM_BOOT_DEVICE_H_ + +u32 get_boot_mode_sel(void); + +struct boot_device_info { + u32 type; + char *info; +}; + +extern struct boot_device_info boot_device_table[]; + +#endif /* _ASM_BOOT_DEVICE_H_ */ diff --git a/arch/arm/include/asm/arch-uniphier/led.h b/arch/arm/include/asm/arch-uniphier/led.h new file mode 100644 index 0000000..21277da --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/led.h @@ -0,0 +1,101 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_LED_H +#define ARCH_LED_H + +#include <config.h> + +#define LED_CHAR_0 0x7e +#define LED_CHAR_1 0x0c +#define LED_CHAR_2 0xb6 +#define LED_CHAR_3 0x9e +#define LED_CHAR_4 0xcc +#define LED_CHAR_5 0xda +#define LED_CHAR_6 0xfa +#define LED_CHAR_7 0x4e +#define LED_CHAR_8 0xfe +#define LED_CHAR_9 0xde + +#define LED_CHAR_A 0xee +#define LED_CHAR_B 0xf8 +#define LED_CHAR_C 0x72 +#define LED_CHAR_D 0xbc +#define LED_CHAR_E 0xf2 +#define LED_CHAR_F 0xe2 +#define LED_CHAR_G 0x7a +#define LED_CHAR_H 0xe8 +#define LED_CHAR_I 0x08 +#define LED_CHAR_J 0x3c +#define LED_CHAR_K 0xea +#define LED_CHAR_L 0x70 +#define LED_CHAR_M 0x6e +#define LED_CHAR_N 0xa8 +#define LED_CHAR_O 0xb8 +#define LED_CHAR_P 0xe6 +#define LED_CHAR_Q 0xce +#define LED_CHAR_R 0xa0 +#define LED_CHAR_S 0xc8 +#define LED_CHAR_T 0x8c +#define LED_CHAR_U 0x7c +#define LED_CHAR_V 0x54 +#define LED_CHAR_W 0xfc +#define LED_CHAR_X 0xec +#define LED_CHAR_Y 0xdc +#define LED_CHAR_Z 0xa4 + +#define LED_CHAR_SPACE 0x00 +#define LED_CHAR_DOT 0x01 + +#define LED_CHAR_ (LED_CHAR_SPACE) + +/** Macro to translate 4 characters into integer to display led */ +#define LED_C2I(C0, C1, C2, C3) \ + (~( \ + (LED_CHAR_##C0 << 24) | \ + (LED_CHAR_##C1 << 16) | \ + (LED_CHAR_##C2 << 8) | \ + (LED_CHAR_##C3) \ + )) + +#if defined(CONFIG_SUPPORT_CARD_LED_BASE) + +#define LED_ADDR CONFIG_SUPPORT_CARD_LED_BASE + +#ifdef __ASSEMBLY__ + +#define led_write(C0, C1, C2, C3) raw_led_write LED_C2I(C0, C1, C2, C3) +.macro raw_led_write data + ldr r0, =\data + ldr r1, =LED_ADDR + str r0, [r1] +.endm + +#else /* __ASSEMBLY__ */ + +#include <asm/io.h> + +#define led_write(C0, C1, C2, C3) \ +do { \ + raw_led_write(LED_C2I(C0, C1, C2, C3)); \ +} while (0) + +static inline void raw_led_write(u32 data) +{ + writel(data, LED_ADDR); +} + +#endif /* __ASSEMBLY__ */ + +#else /* CONFIG_SUPPORT_CARD_LED_BASE */ + +#define led_write(C0, C1, C2, C3) +#define raw_led_write(x) + +#endif /* CONFIG_SUPPORT_CARD_LED_BASE */ + +#endif /* ARCH_LED_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sbc-regs.h b/arch/arm/include/asm/arch-uniphier/sbc-regs.h new file mode 100644 index 0000000..8e41078 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sbc-regs.h @@ -0,0 +1,108 @@ +/* + * UniPhier SBC (System Bus Controller) registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SBC_REGS_H +#define ARCH_SBC_REGS_H + +#define SBBASE_BASE 0x58c00100 +#define SBBASE(x) (SBBASE_BASE + (x) * 0x10) + +#define SBBASE0 (SBBASE(0)) +#define SBBASE1 (SBBASE(1)) +#define SBBASE2 (SBBASE(2)) +#define SBBASE3 (SBBASE(3)) +#define SBBASE4 (SBBASE(4)) +#define SBBASE5 (SBBASE(5)) +#define SBBASE6 (SBBASE(6)) +#define SBBASE7 (SBBASE(7)) + +#define SBBASE_BANK_ENABLE (0x00000001) + +#define SBCTRL_BASE 0x58c00200 +#define SBCTRL(x, y) (SBCTRL_BASE + (x) * 0x10 + (y) * 4) + +#define SBCTRL00 SBCTRL(0, 0) +#define SBCTRL01 SBCTRL(0, 1) +#define SBCTRL02 SBCTRL(0, 2) +#define SBCTRL03 SBCTRL(0, 3) +#define SBCTRL04 (SBCTRL_BASE + 0x100) + +#define SBCTRL10 SBCTRL(1, 0) +#define SBCTRL11 SBCTRL(1, 1) +#define SBCTRL12 SBCTRL(1, 2) +#define SBCTRL13 SBCTRL(1, 3) +#define SBCTRL14 (SBCTRL_BASE + 0x110) + +#define SBCTRL20 SBCTRL(2, 0) +#define SBCTRL21 SBCTRL(2, 1) +#define SBCTRL22 SBCTRL(2, 2) +#define SBCTRL23 SBCTRL(2, 3) +#define SBCTRL24 (SBCTRL_BASE + 0x120) + +#define SBCTRL30 SBCTRL(3, 0) +#define SBCTRL31 SBCTRL(3, 1) +#define SBCTRL32 SBCTRL(3, 2) +#define SBCTRL33 SBCTRL(3, 3) +#define SBCTRL34 (SBCTRL_BASE + 0x130) + +#define SBCTRL40 SBCTRL(4, 0) +#define SBCTRL41 SBCTRL(4, 1) +#define SBCTRL42 SBCTRL(4, 2) +#define SBCTRL43 SBCTRL(4, 3) +#define SBCTRL44 (SBCTRL_BASE + 0x140) + +#define SBCTRL50 SBCTRL(5, 0) +#define SBCTRL51 SBCTRL(5, 1) +#define SBCTRL52 SBCTRL(5, 2) +#define SBCTRL53 SBCTRL(5, 3) +#define SBCTRL54 (SBCTRL_BASE + 0x150) + +#define SBCTRL60 SBCTRL(6, 0) +#define SBCTRL61 SBCTRL(6, 1) +#define SBCTRL62 SBCTRL(6, 2) +#define SBCTRL63 SBCTRL(6, 3) +#define SBCTRL64 (SBCTRL_BASE + 0x160) + +#define SBCTRL70 SBCTRL(7, 0) +#define SBCTRL71 SBCTRL(7, 1) +#define SBCTRL72 SBCTRL(7, 2) +#define SBCTRL73 SBCTRL(7, 3) +#define SBCTRL74 (SBCTRL_BASE + 0x170) + +/* slower but LED works */ +#define SBCTRL0_SAVEPIN_PERI_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_PERI_VALUE 0x07168d00 +#define SBCTRL2_SAVEPIN_PERI_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_PERI_VALUE 0x02110110 + +/* faster but LED does not work */ +#define SBCTRL0_SAVEPIN_MEM_VALUE 0x55450000 +#define SBCTRL1_SAVEPIN_MEM_VALUE 0x06057700 +/* NOR flash needs more wait counts than SRAM */ +#define SBCTRL2_SAVEPIN_MEM_VALUE 0x34000009 +#define SBCTRL4_SAVEPIN_MEM_VALUE 0x02110210 + +#define SBCTRL0_ADMULTIPLX_PERI_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_PERI_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_PERI_VALUE 0x14000020 + +#define SBCTRL0_ADMULTIPLX_MEM_VALUE 0x33120000 +#define SBCTRL1_ADMULTIPLX_MEM_VALUE 0x03005500 +#define SBCTRL2_ADMULTIPLX_MEM_VALUE 0x14000010 + +#define ROM_BOOT_ROMRSV2 0x59801208 + +#ifndef __ASSEMBLY__ +#include <asm/io.h> +static inline int boot_is_swapped(void) +{ + return !(readl(SBBASE0) & SBBASE_BANK_ENABLE); +} +#endif + +#endif /* ARCH_SBC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sc-regs.h b/arch/arm/include/asm/arch-uniphier/sc-regs.h new file mode 100644 index 0000000..1197bb5 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sc-regs.h @@ -0,0 +1,62 @@ +/* + * UniPhier SC (System Control) block registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SC_REGS_H +#define ARCH_SC_REGS_H + +#define SC_BASE_ADDR 0x61840000 + +#define SC_MPLLOSCCTL (SC_BASE_ADDR | 0x1184) +#define SC_MPLLOSCCTL_MPLLEN (0x1 << 0) +#define SC_MPLLOSCCTL_MPLLST (0x1 << 1) + +#define SC_DPLLCTRL (SC_BASE_ADDR | 0x1200) +#define SC_DPLLCTRL_SSC_EN (0x1 << 31) +#define SC_DPLLCTRL_FOUTMODE_MASK (0xf << 16) +#define SC_DPLLCTRL_SSC_RATE (0x1 << 15) + +#define SC_DPLLCTRL2 (SC_BASE_ADDR | 0x1204) +#define SC_DPLLCTRL2_NRSTDS (0x1 << 28) + +#define SC_DPLLCTRL3 (SC_BASE_ADDR | 0x1208) +#define SC_DPLLCTRL3_LPFSEL_COEF2 (0x0 << 31) +#define SC_DPLLCTRL3_LPFSEL_COEF3 (0x1 << 31) + +#define SC_UPLLCTRL (SC_BASE_ADDR | 0x1210) + +#define SC_VPLL27ACTRL (SC_BASE_ADDR | 0x1270) +#define SC_VPLL27ACTRL2 (SC_BASE_ADDR | 0x1274) +#define SC_VPLL27ACTRL3 (SC_BASE_ADDR | 0x1278) + +#define SC_VPLL27BCTRL (SC_BASE_ADDR | 0x1290) +#define SC_VPLL27BCTRL2 (SC_BASE_ADDR | 0x1294) +#define SC_VPLL27BCTRL3 (SC_BASE_ADDR | 0x1298) + +#define SC_RSTCTRL (SC_BASE_ADDR | 0x2000) +#define SC_RSTCTRL_NRST_ETHER (0x1 << 12) +#define SC_RSTCTRL_NRST_UMC1 (0x1 << 5) +#define SC_RSTCTRL_NRST_UMC0 (0x1 << 4) +#define SC_RSTCTRL_NRST_NAND (0x1 << 2) + +#define SC_RSTCTRL2 (SC_BASE_ADDR | 0x2004) +#define SC_RSTCTRL3 (SC_BASE_ADDR | 0x2008) + +#define SC_CLKCTRL (SC_BASE_ADDR | 0x2104) +#define SC_CLKCTRL_CLK_ETHER (0x1 << 12) +#define SC_CLKCTRL_CLK_MIO (0x1 << 11) +#define SC_CLKCTRL_CLK_UMC (0x1 << 4) +#define SC_CLKCTRL_CLK_NAND (0x1 << 2) +#define SC_CLKCTRL_CLK_SBC (0x1 << 1) +#define SC_CLKCTRL_CLK_PERI (0x1 << 0) + +/* System reset control register */ +#define SC_IRQTIMSET (SC_BASE_ADDR | 0x3000) +#define SC_SLFRSTSEL (SC_BASE_ADDR | 0x3010) +#define SC_SLFRSTCTL (SC_BASE_ADDR | 0x3014) + +#endif /* ARCH_SC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/sg-regs.h b/arch/arm/include/asm/arch-uniphier/sg-regs.h new file mode 100644 index 0000000..79d7ec7 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/sg-regs.h @@ -0,0 +1,182 @@ +/* + * UniPhier SG (SoC Glue) block registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SG_REGS_H +#define ARCH_SG_REGS_H + +/* Base Address */ +#define SG_CTRL_BASE 0x5f800000 +#define SG_DBG_BASE 0x5f900000 + +/* Revision */ +#define SG_REVISION (SG_CTRL_BASE | 0x0000) +#define SG_REVISION_TYPE_SHIFT 16 +#define SG_REVISION_TYPE_MASK (0xff << SG_REVISION_TYPE_SHIFT) +#define SG_REVISION_MODEL_SHIFT 8 +#define SG_REVISION_MODEL_MASK (0x3 << SG_REVISION_MODEL_SHIFT) +#define SG_REVISION_REV_SHIFT 0 +#define SG_REVISION_REV_MASK (0x1f << SG_REVISION_REV_SHIFT) + +/* Memory Configuration */ +#define SG_MEMCONF (SG_CTRL_BASE | 0x0400) + +#define SG_MEMCONF_CH0_SIZE_64MB ((0x0 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_SIZE_128MB ((0x0 << 10) | (0x02 << 0)) +#define SG_MEMCONF_CH0_SIZE_256MB ((0x0 << 10) | (0x03 << 0)) +#define SG_MEMCONF_CH0_SIZE_512MB ((0x1 << 10) | (0x00 << 0)) +#define SG_MEMCONF_CH0_SIZE_1024MB ((0x1 << 10) | (0x01 << 0)) +#define SG_MEMCONF_CH0_NUM_1 (0x1 << 8) +#define SG_MEMCONF_CH0_NUM_2 (0x0 << 8) + +#define SG_MEMCONF_CH1_SIZE_64MB ((0x0 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_SIZE_128MB ((0x0 << 11) | (0x02 << 2)) +#define SG_MEMCONF_CH1_SIZE_256MB ((0x0 << 11) | (0x03 << 2)) +#define SG_MEMCONF_CH1_SIZE_512MB ((0x1 << 11) | (0x00 << 2)) +#define SG_MEMCONF_CH1_SIZE_1024MB ((0x1 << 11) | (0x01 << 2)) +#define SG_MEMCONF_CH1_NUM_1 (0x1 << 9) +#define SG_MEMCONF_CH1_NUM_2 (0x0 << 9) + +#define SG_MEMCONF_SPARSEMEM (0x1 << 4) + +/* Pin Control */ +#define SG_PINCTRL_BASE (SG_CTRL_BASE | 0x1000) + +#if defined(CONFIG_MACH_PH1_PRO4) +# define SG_PINCTRL(n) (SG_PINCTRL_BASE + (n) * 8) +#elif defined(CONFIG_MACH_PH1_LD4) || defined(CONFIG_MACH_PH1_SLD8) +# define SG_PINCTRL(n) (SG_PINCTRL_BASE + (n) * 4) +#endif + +#if defined(CONFIG_MACH_PH1_PRO4) +#define SG_PINSELBITS 4 +#elif defined(CONFIG_MACH_PH1_LD4) || defined(CONFIG_MACH_PH1_SLD8) +#define SG_PINSELBITS 8 +#endif + +#define SG_PINSEL_ADDR(n) (SG_PINCTRL((n) * (SG_PINSELBITS) / 32)) +#define SG_PINSEL_MASK(n) (~(((1 << (SG_PINSELBITS)) - 1) << \ + ((n) * (SG_PINSELBITS) % 32))) +#define SG_PINSEL_MODE(n, mode) ((mode) << ((n) * (SG_PINSELBITS) % 32)) + +/* Only for PH1-Pro4 */ +#define SG_LOADPINCTRL (SG_CTRL_BASE | 0x1700) + +/* Input Enable */ +#define SG_IECTRL (SG_CTRL_BASE | 0x1d00) + +/* Pin Monitor */ +#define SG_PINMON0 (SG_DBG_BASE | 0x0100) + +#define SG_PINMON0_CLK_MODE_UPLLSRC_MASK (0x3 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_DEFAULT (0x0 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27A (0x2 << 19) +#define SG_PINMON0_CLK_MODE_UPLLSRC_VPLL27B (0x3 << 19) + +#define SG_PINMON0_CLK_MODE_AXOSEL_MASK (0x3 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_24576KHZ (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6144KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_6250KHZ (0x3 << 16) + +#define SG_PINMON0_CLK_MODE_AXOSEL_DEFAULT (0x0 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_U (0x1 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_20480KHZ (0x2 << 16) +#define SG_PINMON0_CLK_MODE_AXOSEL_25000KHZ_A (0x3 << 16) + +#ifndef __ASSEMBLY__ +#include <linux/types.h> +#include <asm/io.h> + +static inline void sg_set_pinsel(int n, int value) +{ + writel((readl(SG_PINSEL_ADDR(n)) & SG_PINSEL_MASK(n)) + | SG_PINSEL_MODE(n, value), SG_PINSEL_ADDR(n)); +} + +static inline u32 sg_memconf_val_ch0(unsigned long size, int num) +{ + int size_mb = (size >> 20) / num; + u32 ret; + + switch (size_mb) { + case 64: + ret = SG_MEMCONF_CH0_SIZE_64MB; + break; + case 128: + ret = SG_MEMCONF_CH0_SIZE_128MB; + break; + case 256: + ret = SG_MEMCONF_CH0_SIZE_256MB; + break; + case 512: + ret = SG_MEMCONF_CH0_SIZE_512MB; + break; + case 1024: + ret = SG_MEMCONF_CH0_SIZE_1024MB; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH0_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH0_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} + +static inline u32 sg_memconf_val_ch1(unsigned long size, int num) +{ + int size_mb = (size >> 20) / num; + u32 ret; + + switch (size_mb) { + case 64: + ret = SG_MEMCONF_CH1_SIZE_64MB; + break; + case 128: + ret = SG_MEMCONF_CH1_SIZE_128MB; + break; + case 256: + ret = SG_MEMCONF_CH1_SIZE_256MB; + break; + case 512: + ret = SG_MEMCONF_CH1_SIZE_512MB; + break; + case 1024: + ret = SG_MEMCONF_CH1_SIZE_1024MB; + break; + default: + BUG(); + break; + } + + switch (num) { + case 1: + ret |= SG_MEMCONF_CH1_NUM_1; + break; + case 2: + ret |= SG_MEMCONF_CH1_NUM_2; + break; + default: + BUG(); + break; + } + return ret; +} +#endif /* __ASSEMBLY__ */ + +#endif /* ARCH_SG_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/ssc-regs.h b/arch/arm/include/asm/arch-uniphier/ssc-regs.h new file mode 100644 index 0000000..77b3470 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/ssc-regs.h @@ -0,0 +1,67 @@ +/* + * UniPhier System Cache (L2 Cache) registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_SSC_REGS_H +#define ARCH_SSC_REGS_H + +#define SSCC 0x500c0000 +#define SSCC_BST (0x1 << 20) +#define SSCC_ACT (0x1 << 19) +#define SSCC_WTG (0x1 << 18) +#define SSCC_PRD (0x1 << 17) +#define SSCC_WBWA (0x1 << 16) +#define SSCC_EX (0x1 << 13) +#define SSCC_ON (0x1 << 0) + +#define SSCLPDAWCR 0x500c0030 + +#define SSCOPE 0x506c0244 +#define SSCOPE_CM_SYNC 0x00000008 + +#define SSCOQM 0x506c0248 +#define SSCOQM_TID_MASK (0x3 << 21) +#define SSCOQM_TID_BY_WAY (0x2 << 21) +#define SSCOQM_TID_BY_INST_WAY (0x1 << 21) +#define SSCOQM_TID_BY_DATA_WAY (0x0 << 21) +#define SSCOQM_S_MASK (0x3 << 17) +#define SSCOQM_S_WAY (0x2 << 17) +#define SSCOQM_S_ALL (0x1 << 17) +#define SSCOQM_S_ADDRESS (0x0 << 17) +#define SSCOQM_CE (0x1 << 15) +#define SSCOQM_CW (0x1 << 14) +#define SSCOQM_CM_MASK (0x7) +#define SSCOQM_CM_DIRT_TOUCH (0x7) +#define SSCOQM_CM_ZERO_TOUCH (0x6) +#define SSCOQM_CM_NORM_TOUCH (0x5) +#define SSCOQM_CM_PREF_FETCH (0x4) +#define SSCOQM_CM_SSC_FETCH (0x3) +#define SSCOQM_CM_WB_INV (0x2) +#define SSCOQM_CM_WB (0x1) +#define SSCOQM_CM_INV (0x0) + +#define SSCOQAD 0x506c024c +#define SSCOQSZ 0x506c0250 +#define SSCOQWN 0x506c0258 + +#define SSCOPPQSEF 0x506c025c +#define SSCOPPQSEF_FE (0x1 << 1) +#define SSCOPPQSEF_OE (0x1 << 0) + +#define SSCOLPQS 0x506c0260 +#define SSCOLPQS_EF (0x1 << 2) +#define SSCOLPQS_EST (0x1 << 1) +#define SSCOLPQS_QST (0x1 << 0) + +#define SSCOQCE0 0x506c0270 + +#define SSC_LINE_SIZE 128 +#define SSC_NUM_ENTRIES 256 +#define SSC_WAY_SIZE ((SSC_LINE_SIZE) * (SSC_NUM_ENTRIES)) +#define SSC_RANGE_OP_MAX_SIZE (0x00400000 - (SSC_LINE_SIZE)) + +#endif /* ARCH_SSC_REGS_H */ diff --git a/arch/arm/include/asm/arch-uniphier/umc-regs.h b/arch/arm/include/asm/arch-uniphier/umc-regs.h new file mode 100644 index 0000000..6159281 --- /dev/null +++ b/arch/arm/include/asm/arch-uniphier/umc-regs.h @@ -0,0 +1,119 @@ +/* + * UniPhier UMC (Universal Memory Controller) registers + * + * Copyright (C) 2011-2014 Panasonic Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef ARCH_UMC_REGS_H +#define ARCH_UMC_REGS_H + +#define UMC_BASE 0x5b800000 + +/* SSIF registers */ +#define UMC_SSIF_BASE UMC_BASE + +#define UMC_CPURST 0x00000700 +#define UMC_IDSRST 0x0000070C +#define UMC_IXMRST 0x00000714 +#define UMC_HDMRST 0x00000718 +#define UMC_MDMRST 0x0000071C +#define UMC_HDDRST 0x00000720 +#define UMC_MDDRST 0x00000724 +#define UMC_SIORST 0x00000728 +#define UMC_GIORST 0x0000072C +#define UMC_HD2RST 0x00000734 +#define UMC_VIORST 0x0000073C +#define UMC_FRCRST 0x00000748 /* LD4/sLD8 */ +#define UMC_DVCRST 0x00000748 /* Pro4 */ +#define UMC_RGLRST 0x00000750 +#define UMC_VPERST 0x00000758 +#define UMC_AIORST 0x00000764 +#define UMC_DMDRST 0x00000770 + +#define UMC_HDMCHSEL 0x00000898 +#define UMC_MDMCHSEL 0x0000089C +#define UMC_DVCCHSEL 0x000008C8 +#define UMC_DMDCHSEL 0x000008F0 + +#define UMC_CLKEN_SSIF_FETCH 0x0000C060 +#define UMC_CLKEN_SSIF_COMQUE0 0x0000C064 +#define UMC_CLKEN_SSIF_COMWC0 0x0000C068 +#define UMC_CLKEN_SSIF_COMRC0 0x0000C06C +#define UMC_CLKEN_SSIF_COMQUE1 0x0000C070 +#define UMC_CLKEN_SSIF_COMWC1 0x0000C074 +#define UMC_CLKEN_SSIF_COMRC1 0x0000C078 +#define UMC_CLKEN_SSIF_WC 0x0000C07C +#define UMC_CLKEN_SSIF_RC 0x0000C080 +#define UMC_CLKEN_SSIF_DST 0x0000C084 + +/* CA registers */ +#define UMC_CA_BASE(ch) (UMC_BASE + 0x00001000 + 0x00001000 * (ch)) + +/* DRAM controller registers */ +#define UMC_DRAMCONT_BASE(ch) (UMC_BASE + 0x00400000 + 0x00200000 * (ch)) + +#define UMC_CMDCTLA 0x00000000 +#define UMC_CMDCTLB 0x00000004 +#define UMC_INITCTLA 0x00000008 +#define UMC_INITCTLB 0x0000000C +#define UMC_INITCTLC 0x00000010 +#define UMC_INITSET 0x00000014 +#define UMC_INITSTAT 0x00000018 +#define UMC_DRMMR0 0x0000001C +#define UMC_DRMMR1 0x00000020 +#define UMC_DRMMR2 0x00000024 +#define UMC_DRMMR3 0x00000028 +#define UMC_SPCCTLA 0x00000030 +#define UMC_SPCCTLB 0x00000034 +#define UMC_SPCSETA 0x00000038 +#define UMC_SPCSETB 0x0000003C +#define UMC_SPCSETC 0x00000040 +#define UMC_SPCSETD 0x00000044 +#define UMC_SPCSTATA 0x00000050 +#define UMC_SPCSTATB 0x00000054 +#define UMC_SPCSTATC 0x00000058 +#define UMC_ACSSETA 0x00000060 +#define UMC_FLOWCTLA 0x00000400 +#define UMC_FLOWCTLB 0x00000404 +#define UMC_FLOWCTLC 0x00000408 +#define UMC_FLOWCTLG 0x00000508 +#define UMC_RDATACTL_D0 0x00000600 +#define UMC_WDATACTL_D0 0x00000604 +#define UMC_RDATACTL_D1 0x00000608 +#define UMC_WDATACTL_D1 0x0000060C +#define UMC_DATASET 0x00000610 +#define UMC_DCCGCTL 0x00000720 +#define UMC_DICGCTLA 0x00000724 +#define UMC_DICGCTLB 0x00000728 +#define UMC_DIOCTLA 0x00000C00 +#define UMC_DFICUPDCTLA 0x00000C20 + +#ifndef __ASSEMBLY__ + +#include <linux/types.h> + +static inline void umc_polling(u32 address, u32 expval, u32 mask) +{ + u32 nmask = ~mask; + u32 data; + do { + data = readl(address) & nmask; + } while (data != expval); +} + +static inline void umc_dram_init_start(void __iomem *dramcont) +{ + writel(0x00000002, dramcont + UMC_INITSET); +} + +static inline void umc_dram_init_poll(void __iomem *dramcont) +{ + while ((readl(dramcont + UMC_INITSTAT) & 0x00000002)) + ; +} + +#endif + +#endif diff --git a/include/configs/ph1_ld4.h b/include/configs/ph1_ld4.h new file mode 100644 index 0000000..a28d7b5 --- /dev/null +++ b/include/configs/ph1_ld4.h @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 1 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 36864000 + +#define CONFIG_SMC911X + +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +#define CONFIG_DDR_FREQ 1600 + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 + +#define CONFIG_SPL_TEXT_BASE 0x40000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_pro4.h b/include/configs/ph1_pro4.h new file mode 100644 index 0000000..b79967f --- /dev/null +++ b/include/configs/ph1_pro4.h @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 1 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 73728000 + +#define CONFIG_SMC911X + +#define CONFIG_DDR_NUM_CH0 2 +#define CONFIG_DDR_NUM_CH1 2 + +#define CONFIG_DDR_FREQ 1600 + +#define CONFIG_UNIPHIER_SMP + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x20000000 +#define CONFIG_SDRAM1_BASE 0xa0000000 +#define CONFIG_SDRAM1_SIZE 0x20000000 + +#define CONFIG_SPL_TEXT_BASE 0x100000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/ph1_sld8.h b/include/configs/ph1_sld8.h new file mode 100644 index 0000000..9d391f1 --- /dev/null +++ b/include/configs/ph1_sld8.h @@ -0,0 +1,61 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __PH1_XXX_H +#define __PH1_XXX_H + +/* + * Support Card Select + * + * CONFIG_PFC_MICRO_SUPPORT_CARD - Original Micro Support Card made by PFC. + * CONFIG_DCC_MICRO_SUPPORT_CARD - DCC version Micro Support Card. + * CPLD is re-programmed for ARIMA board compatibility. + * No define - No support card. + */ + +#if 0 +#define CONFIG_PFC_MICRO_SUPPORT_CARD +#else +#define CONFIG_DCC_MICRO_SUPPORT_CARD +#endif + +/* + * Serial Configuration + * SoC UART : enable CONFIG_UNIPHIER_SERIAL + * On-board UART: enable CONFIG_SYS_NS16550_SERIAL + */ +#if 1 +#define CONFIG_UNIPHIER_SERIAL +#else +#define CONFIG_SYS_NS16550_SERIAL +#endif + +#define CONFIG_SYS_UNIPHIER_UART_CLK 80000000 + +#define CONFIG_SMC911X + +#define CONFIG_DDR_NUM_CH0 1 +#define CONFIG_DDR_NUM_CH1 1 + +#define CONFIG_DDR_FREQ 1333 + +/* #define CONFIG_DDR_STANDARD */ + +/* + * Memory Size & Mapping + */ +/* Physical start address of SDRAM */ +#define CONFIG_SDRAM0_BASE 0x80000000 +#define CONFIG_SDRAM0_SIZE 0x10000000 +#define CONFIG_SDRAM1_BASE 0x90000000 +#define CONFIG_SDRAM1_SIZE 0x10000000 + +#define CONFIG_SPL_TEXT_BASE 0x40000 + +#include "uniphier-common.h" + +#endif /* __PH1_XXX_H */ diff --git a/include/configs/uniphier-common.h b/include/configs/uniphier-common.h new file mode 100644 index 0000000..18fe277 --- /dev/null +++ b/include/configs/uniphier-common.h @@ -0,0 +1,266 @@ +/* + * Copyright (C) 2012-2014 Panasonic Corporation + * Author: Masahiro Yamada yamada.m@jp.panasonic.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* U-boot - Common settings for UniPhier Family */ + +#ifndef __CONFIG_UNIPHIER_COMMON_H__ +#define __CONFIG_UNIPHIER_COMMON_H__ + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) && \ + defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# error "Both CONFIG_PFC_MICRO_SUPPORT_CARD and CONFIG_DCC_MICRO_SUPPORT_CARD \ +are defined. Select only one of them." +#endif + +/* + * Support card address map + */ +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) +# define CONFIG_SUPPORT_CARD_BASE 0x03f00000 +# define CONFIG_SUPPORT_CARD_ETHER_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00000000) +# define CONFIG_SUPPORT_CARD_LED_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00090000) +# define CONFIG_SUPPORT_CARD_UART_BASE (CONFIG_SUPPORT_CARD_BASE + 0x000b0000) +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# define CONFIG_SUPPORT_CARD_BASE 0x08000000 +# define CONFIG_SUPPORT_CARD_ETHER_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00000000) +# define CONFIG_SUPPORT_CARD_LED_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00401630) +# define CONFIG_SUPPORT_CARD_UART_BASE (CONFIG_SUPPORT_CARD_BASE + 0x00200000) +#endif + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_COM1 CONFIG_SUPPORT_CARD_UART_BASE +#define CONFIG_SYS_NS16550_CLK 12288000 +#define CONFIG_SYS_NS16550_REG_SIZE -2 + +#define CONFIG_SMC911X_BASE CONFIG_SUPPORT_CARD_ETHER_BASE +#define CONFIG_SMC911X_32_BIT + +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE0 0x54006800 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE1 0x54006900 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE2 0x54006a00 +#define CONFIG_SYS_UNIPHIER_SERIAL_BASE3 0x54006b00 + +/*----------------------------------------------------------------------- + * MMU and Cache Setting + *----------------------------------------------------------------------*/ + +/* Comment out the following to enable L1 cache */ +/* #define CONFIG_SYS_ICACHE_OFF */ +/* #define CONFIG_SYS_DCACHE_OFF */ + +/* Comment out the following to enable L2 cache */ +#define CONFIG_UNIPHIER_L2CACHE_ON + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_LATE_INIT + +#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) + +#define CONFIG_TIMESTAMP + +/* FLASH related */ +#define CONFIG_MTD_DEVICE + +/* + * uncomment the following to disable FLASH related code. + */ +/* #define CONFIG_SYS_NO_FLASH */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI + +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MONITOR_BASE 0 +#define CONFIG_SYS_FLASH_BASE 0 + +/* + * flash_toggle does not work for out supoort card. + * We need to use flash_status_poll. + */ +#define CONFIG_SYS_CFI_FLASH_STATUS_POLL + +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#if defined(CONFIG_PFC_MICRO_SUPPORT_CARD) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_FLASH_BANKS_LIST {0x00000000} +# define CONFIG_SYS_FLASH_BANKS_SIZES {0x02000000} +#endif + +#if defined(CONFIG_DCC_MICRO_SUPPORT_CARD) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_FLASH_BANKS_LIST {0x04000000} +# define CONFIG_SYS_FLASH_BANKS_SIZES {0x04000000} +#endif + +/* serial console configuration */ +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_GENERIC_BOARD + +#if !defined(CONFIG_SPL_BUILD) +#define CONFIG_USE_ARCH_MEMSET +#define CONFIG_USE_ARCH_MEMCPY +#endif + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ + +#define CONFIG_CMDLINE_EDITING /* add command line history */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_CONS_INDEX 1 + +/* + * For NAND booting the environment is embedded in the U-Boot image. Please take + * look at the file board/amcc/canyonlands/u-boot-nand.lds for details. + */ +/* #define CONFIG_ENV_IS_IN_NAND */ +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET 0x0 +/* #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE) */ + +/* Time clock 1MHz */ +#define CONFIG_SYS_TIMER_RATE 1000000 + +/* + * By default, ARP timeout is 5 sec. + * The first ARP request does not seem to work. + * So we need to retry ARP request anyway. + * We want to shrink the interval until the second ARP request. + */ +#define CONFIG_ARP_TIMEOUT 500UL /* 0.5 msec */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_TIME +#define CONFIG_CMD_NAND /* NAND flash suppport */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 +#define CONFIG_SYS_NAND_MAX_CHIPS 2 +#define CONFIG_SYS_NAND_ONFI_DETECTION + +#define CONFIG_NAND_DENALI_ECC_SIZE 1024 + +#define CONFIG_SYS_NAND_REGS_BASE 0x68100000 +#define CONFIG_SYS_NAND_DATA_BASE 0x68000000 + +#define CONFIG_SYS_NAND_BASE (CONFIG_SYS_NAND_DATA_BASE + 0x10) + +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_BAD_BLOCK_POS 0 + +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01000000) + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ +#define CONFIG_AUTOBOOT_KEYED 1 +#define CONFIG_AUTOBOOT_PROMPT \ + "Press SPACE to abort autoboot in %d seconds\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "d" +#define CONFIG_AUTOBOOT_STOP_STR " " + +/* + * Network Configuration + */ +#define CONFIG_ETHADDR 00:21:83:24:00:00 +#define CONFIG_SERVERIP 192.168.11.1 +#define CONFIG_IPADDR 192.168.11.10 +#define CONFIG_GATEWAYIP 192.168.11.1 +#define CONFIG_NETMASK 255.255.255.0 + +#define CONFIG_LOADADDR 0x84000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR +#define CONFIG_BOOTFILE "fit.itb" + +#define CONFIG_CMDLINE_EDITING /* add command line history */ + +#define CONFIG_BOOTCOMMAND "run $bootmode" + +#define CONFIG_ROOTPATH "/nfs/root/path" +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs $bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off;" \ + "tftpboot; bootm;" + +#define CONFIG_BOOTARGS " user_debug=0x1f init=/sbin/init" + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "image_offset=0x00080000\0" \ + "image_size=0x00f00000\0" \ + "verify=n\0" \ + "autostart=yes\0" \ + "norboot=run add_default_bootargs;" \ + "bootm $image_offset\0" \ + "nandboot=run add_default_bootargs;" \ + "nand read $loadaddr $image_offset $image_size;" \ + "bootm\0" \ + "add_default_bootargs=setenv bootargs $bootargs" \ + " console=ttyS0,$baudrate\0" \ + +/* FIT support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +/* Open Firmware flat tree */ +#define CONFIG_OF_LIBFDT + +#define CONFIG_HAVE_ARM_SECURE + +/* Memory Size & Mapping */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SDRAM0_BASE + +#if CONFIG_SDRAM0_BASE + CONFIG_SDRAM0_SIZE >= CONFIG_SDRAM1_BASE +/* Thre is no memory hole */ +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_SYS_SDRAM_SIZE (CONFIG_SDRAM0_SIZE + CONFIG_SDRAM1_SIZE) +#else +#define CONFIG_NR_DRAM_BANKS 2 +#define CONFIG_SYS_SDRAM_SIZE (CONFIG_SDRAM0_SIZE) +#endif + +#define CONFIG_SYS_TEXT_BASE 0x84000000 + +#if defined(CONFIG_SPL_BUILD) +#define CONFIG_BOARD_POSTCLK_INIT +#else +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_SPL_MALLOC_START (0x0ff00000) +#define CONFIG_SYS_SPL_MALLOC_SIZE (0x00004000) + +#define CONFIG_SYS_INIT_SP_ADDR (0x0ff08000) + +#define CONFIG_SPL_FRAMEWORK +#define CONFIG_SPL_NAND_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT /* for mem_malloc_init */ +#define CONFIG_SPL_LIBGENERIC_SUPPORT + +#define CONFIG_SPL_BOARD_INIT + +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x10000 + +#endif /* __CONFIG_UNIPHIER_COMMON_H__ */
2014-10-03 19:21 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
These are used by Panasonic UniPhier SoC family.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com
Changes in v6:
- Increase malloc area from 1MB to 4MB
- Improve comments in header files
- Add SPDX to umc-regs.h
Changes in v5:
- Move Denali configs to defconfigs
- Enable CONFIG_SYS_NAND_ONFI_DETECTION
- Add UMC settings
- Re-enable Denali driver
Changes in v4:
- Disable Denali NAND driver. This driver has been taking too long: http://patchwork.ozlabs.org/patch/381305/
Changes in v3:
- Add Denali fixup code for PH1-sLD8 and PH1-Pro4
Changes in v2:
- Rebase
- Remove unnecessary CONFIG_SYS_NAND_PAGE_SIZE definition
- Fix a typo in the subject
Applied to u-boot-uniphier/master.
This commit allows to build Panasonic UniPhier family: PH1-LD4, PH1-Pro4, PH1-sLD8
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v6: None Changes in v5: - Add Denali config options to defconfigs
Changes in v4: None Changes in v3: - Rebase on the current u-boot/master
Changes in v2: - Rebase on the current u-boot/master
arch/arm/Kconfig | 5 +++++ arch/arm/cpu/armv7/uniphier/Kconfig | 32 ++++++++++++++++++++++++++++++++ configs/ph1_ld4_defconfig | 8 ++++++++ configs/ph1_pro4_defconfig | 8 ++++++++ configs/ph1_sld8_defconfig | 8 ++++++++ 5 files changed, 61 insertions(+) create mode 100644 arch/arm/cpu/armv7/uniphier/Kconfig create mode 100644 configs/ph1_ld4_defconfig create mode 100644 configs/ph1_pro4_defconfig create mode 100644 configs/ph1_sld8_defconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 3efede2..43ba33a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -521,6 +521,9 @@ config TARGET_COLIBRI_PXA270 config TARGET_JORNADA bool "Support jornada"
+config ARCH_UNIPHIER + bool "Panasonic UniPhier platform" + endchoice
source "arch/arm/cpu/armv8/Kconfig" @@ -549,6 +552,8 @@ source "arch/arm/cpu/armv7/rmobile/Kconfig"
source "arch/arm/cpu/armv7/tegra-common/Kconfig"
+source "arch/arm/cpu/armv7/uniphier/Kconfig" + source "arch/arm/cpu/arm926ejs/versatile/Kconfig"
source "arch/arm/cpu/armv7/zynq/Kconfig" diff --git a/arch/arm/cpu/armv7/uniphier/Kconfig b/arch/arm/cpu/armv7/uniphier/Kconfig new file mode 100644 index 0000000..34f5496 --- /dev/null +++ b/arch/arm/cpu/armv7/uniphier/Kconfig @@ -0,0 +1,32 @@ +menu "Panasonic UniPhier platform" + depends on ARCH_UNIPHIER + +config SYS_CPU + string + default "armv7" + +config SYS_SOC + string + default "uniphier" + +config SYS_CONFIG_NAME + string + default "ph1_pro4" if MACH_PH1_PRO4 + default "ph1_ld4" if MACH_PH1_LD4 + default "ph1_sld8" if MACH_PH1_SLD8 + +choice + prompt "UniPhier SoC select" + +config MACH_PH1_PRO4 + bool "PH1-Pro4" + +config MACH_PH1_LD4 + bool "PH1-LD4" + +config MACH_PH1_SLD8 + bool "PH1-sLD8" + +endchoice + +endmenu diff --git a/configs/ph1_ld4_defconfig b/configs/ph1_ld4_defconfig new file mode 100644 index 0000000..53f3126 --- /dev/null +++ b/configs/ph1_ld4_defconfig @@ -0,0 +1,8 @@ +CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_UNIPHIER=y ++S:CONFIG_MACH_PH1_LD4=y +CONFIG_NAND_DENALI=y +CONFIG_SYS_NAND_DENALI_64BIT=y +CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 +S:CONFIG_SPL_NAND_DENALI=y diff --git a/configs/ph1_pro4_defconfig b/configs/ph1_pro4_defconfig new file mode 100644 index 0000000..209466e --- /dev/null +++ b/configs/ph1_pro4_defconfig @@ -0,0 +1,8 @@ +CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_UNIPHIER=y ++S:CONFIG_MACH_PH1_PRO4=y +CONFIG_NAND_DENALI=y +CONFIG_SYS_NAND_DENALI_64BIT=y +CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 +S:CONFIG_SPL_NAND_DENALI=y diff --git a/configs/ph1_sld8_defconfig b/configs/ph1_sld8_defconfig new file mode 100644 index 0000000..658977b --- /dev/null +++ b/configs/ph1_sld8_defconfig @@ -0,0 +1,8 @@ +CONFIG_SPL=y ++S:CONFIG_ARM=y ++S:CONFIG_ARCH_UNIPHIER=y ++S:CONFIG_MACH_PH1_SLD8=y +CONFIG_NAND_DENALI=y +CONFIG_SYS_NAND_DENALI_64BIT=y +CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 +S:CONFIG_SPL_NAND_DENALI=y
Changes in v2:
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Acked-by: Albert ARIBAUD albert.u.boot@aribaud.net Acked-by: Michal Simek monstr@monstr.eu ---
Changes in v6: None Changes in v5: - Add u-boot-uniphier repo info
Changes in v4: None Changes in v3: None Changes in v2: - Newly added
MAINTAINERS | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/MAINTAINERS b/MAINTAINERS index af194ca..aafa061 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -149,6 +149,15 @@ F: arch/arm/include/asm/arch-davinci/ F: arch/arm/include/asm/arch-omap*/ F: arch/arm/include/asm/ti-common/
+ARM UNIPHIER +M: Masahiro Yamada yamada.m@jp.panasonic.com +S: Maintained +T: git git://git.denx.de/u-boot-uniphier.git +F: arch/arm/cpu/armv7/uniphier/ +F: arch/arm/include/asm/arch-uniphier/ +F: configs/ph1_*_defconfig +F: drivers/serial/serial_uniphier.c + ARM ZYNQ M: Michal Simek monstr@monstr.eu S: Maintained
- Newly added
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - Rebase
doc/git-mailrc | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/git-mailrc b/doc/git-mailrc index 0fba100..35f2eb2 100644 --- a/doc/git-mailrc +++ b/doc/git-mailrc @@ -63,6 +63,7 @@ alias sunxi uboot, ijc, jwrdegoede alias tegra uboot, sjg, Tom Warren twarren@nvidia.com, Stephen Warren swarren@nvidia.com alias tegra2 tegra alias ti uboot, trini +alias uniphier uboot, masahiro alias zynq uboot, monstr
alias avr32 uboot, abiessmann
- Rebase
Masahiro YAMADA
Masahiro Yamada
