[PATCH v3 0/2] x86: p2sb: P2SB fixes
Currently it is possible to select the P2SB driver without selecting the P2SB uclass, which can't work. Fix this by adding a "depends on" in Kconfig.
While at it, correct the meaning of P2SB (according to Intel's documentation P2SB stands for "Primary to Sideband Bridge").
Remark: I have resent this series as V2 as I had messed up the cover letter in V1.
Changes in v3: - Replaced the term in two more places
Changes in v2: - Fixed cover letter
Wolfgang Wallner (2): drivers: p2sb: replace Primary-to-Sideband Bus with Primary to Sideband Bridge x86: p2sb: make P2SB driver depend on P2SB uclass
arch/x86/Kconfig | 1 + drivers/misc/Kconfig | 12 ++++++------ 2 files changed, 7 insertions(+), 6 deletions(-)
In Intel's documentation the term P2SB stands for "Primary to Sideband Bridge".
Signed-off-by: Wolfgang Wallner wolfgang.wallner@br-automation.com ---
drivers/misc/Kconfig | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 6bb5bc77e9..b67e906a76 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -243,10 +243,10 @@ config NUVOTON_NCT6102D in the Nuvoton Super IO chips on X86 platforms.
config P2SB - bool "Intel Primary-to-Sideband Bus" + bool "Intel Primary to Sideband Bridge" depends on X86 || SANDBOX help - This enables support for the Intel Primary-to-Sideband bus, + This enables support for the Intel Primary to Sideband Bridge, abbreviated to P2SB. The P2SB is used to access various peripherals such as eSPI, GPIO, through memory-mapped I/O in a large chunk of PCI space. The space is segmented into different channels and peripherals @@ -256,20 +256,20 @@ config P2SB devices - see pcr_readl(), etc.
config SPL_P2SB - bool "Intel Primary-to-Sideband Bus in SPL" + bool "Intel Primary to Sideband Bridge in SPL" depends on SPL && (X86 || SANDBOX) help - The Primary-to-Sideband bus is used to access various peripherals + The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is segmented into different channels and peripherals are accessed by device-specific means within those channels. Devices should be added in the device tree as subnodes of the p2sb.
config TPL_P2SB - bool "Intel Primary-to-Sideband Bus in TPL" + bool "Intel Primary to Sideband Bridge in TPL" depends on TPL && (X86 || SANDBOX) help - The Primary-to-Sideband bus is used to access various peripherals + The Primary to Sideband Bridge is used to access various peripherals through memory-mapped I/O in a large chunk of PCI space. The space is segmented into different channels and peripherals are accessed by device-specific means within those channels. Devices should be added
On Wed, 1 Jul 2020 at 05:37, Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Changes in v3:
On Wed, Jul 1, 2020 at 7:37 PM Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Changes in v3:
applied to u-boot-x86, thanks!
(no changes since v2)
arch/x86/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index c8eae24c07..27295ef384 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -717,6 +717,7 @@ config HAVE_ITSS
config HAVE_P2SB bool "Enable P2SB" + depends on P2SB help Select this to include the driver for the Primary to Sideband Bridge (P2SB) which is found on several Intel
Changes in v2:
Changes in v2:
Bin Meng
Wolfgang Wallner
