[U-Boot] [PATCH v3 4/8] x86: slimbootloader: Add serial driver
Slim Bootloader provides serial port info thru its HOB list pointer. All these HOBs are eligible for Slim Bootloader based board only. - Get serial port information from the serial port info hob - Leverage ns16550 driver with slimbootloader specific platform data
Signed-off-by: Aiden Park aiden.park@intel.com ---
Changes in v3: * Use HOB function from the common HOB library
arch/x86/cpu/slimbootloader/Makefile | 2 +- arch/x86/cpu/slimbootloader/serial.c | 69 +++++++++++++++++++ .../asm/arch-slimbootloader/slimbootloader.h | 36 ++++++++++ 3 files changed, 106 insertions(+), 1 deletion(-) create mode 100644 arch/x86/cpu/slimbootloader/serial.c
diff --git a/arch/x86/cpu/slimbootloader/Makefile b/arch/x86/cpu/slimbootloader/Makefile index 05d0ca4a19..68c4a91955 100644 --- a/arch/x86/cpu/slimbootloader/Makefile +++ b/arch/x86/cpu/slimbootloader/Makefile @@ -2,4 +2,4 @@ # # Copyright (C) 2019 Intel Corporation <www.intel.com>
-obj-y += car.o slimbootloader.o dram.o +obj-y += car.o slimbootloader.o dram.o serial.o diff --git a/arch/x86/cpu/slimbootloader/serial.c b/arch/x86/cpu/slimbootloader/serial.c new file mode 100644 index 0000000000..84469a2ddf --- /dev/null +++ b/arch/x86/cpu/slimbootloader/serial.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <ns16550.h> +#include <serial.h> +#include <asm/arch/slimbootloader.h> + +/** + * The serial port info hob is generated by Slim Bootloader, so eligible for + * Slim Bootloader based boards only. + */ +int slimbootloader_serial_ofdata_to_platdata(struct udevice *dev) +{ + const struct efi_guid guid = LOADER_SERIAL_PORT_INFO_GUID; + struct serial_port_info *serial_info = NULL; + struct ns16550_platdata *plat = dev->platdata; + + if (!gd->arch.hob_list) + panic("hob list not found!"); + + serial_info = (struct serial_port_info *) + hob_get_guid_hob_data(gd->arch.hob_list, NULL, &guid); + + if (!serial_info) { + debug("failed to get serial port information\n"); + return -ENOENT; + } + debug("type:%d base=0x%08x baudrate=%d stride=%d clk=%d\n", + serial_info->type, + serial_info->base, + serial_info->baud, + serial_info->stride, + serial_info->clk); + + /* + * The serial_info->type provides port io or mmio access type info, + * but the access type will be controlled by + * CONFIG_SYS_NS16550_PORT_MAPPED or CONFIG_SYS_NS16550_MEM32. + * + * TBD: ns16550 access type configuration in runtime. + * ex) plat->access_type = serial_info->type + */ + plat->base = serial_info->base; + /* ns16550 uses reg_shift, then covert stride to shift */ + plat->reg_shift = (serial_info->stride >> 1); + plat->clock = serial_info->clk; + + return 0; +} + +static const struct udevice_id slimbootloader_serial_ids[] = { + { .compatible = "intel,slimbootloader-uart" }, + {} +}; + +U_BOOT_DRIVER(serial_slimbootloader) = { + .name = "serial_slimbootloader", + .id = UCLASS_SERIAL, + .of_match = slimbootloader_serial_ids, + .ofdata_to_platdata = slimbootloader_serial_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct ns16550_platdata), + .priv_auto_alloc_size = sizeof(struct NS16550), + .probe = ns16550_serial_probe, + .ops = &ns16550_serial_ops, +}; diff --git a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h index d9265ac534..5a0994544a 100644 --- a/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h +++ b/arch/x86/include/asm/arch-slimbootloader/slimbootloader.h @@ -18,6 +18,15 @@ { 0xa9, 0xe4, 0x92, 0xf3, 0x57, 0xd1, 0x28, 0x32 } \ }
+/** + * A GUID to get SerialPort info hob which is provided by Slim Bootloader + */ +#define LOADER_SERIAL_PORT_INFO_GUID \ + { \ + 0x6c6872fe, 0x56a9, 0x4403, \ + { 0xbb, 0x98, 0x95, 0x8d, 0x62, 0xde, 0x87, 0xf1 } \ + } + /** * A single entry of memory map information * @@ -35,6 +44,33 @@ struct memory_map_entry { u8 rsvd[6]; } __packed;
+/** + * This includes serial port info which has already been initialized in previous + * Slim Bootloader stage. + * The Slim Bootloader initializes serial port regardless of debug/release build + * modes, and it passes the information to a payload thru hob. So, a payload can + * re-use the serial information without re-initializing serial port. + * + * @rev : revision of serial_port_info structure. currently 1. + * @rsvd : padding for alignment + * @type : port io: 1, mmio: 2 + * @base : io base address. ex) 0x3f8, 0x80001000 + * @baud : uart baud rate + * @stride: register stride in Bytes + * @clk : uart frequency in Hz + * @rsvd1 : reserved + */ +struct serial_port_info { + u8 rev; + u8 rsvd[3]; + u32 type; + u32 base; + u32 baud; + u32 stride; + u32 clk; + u32 rsvd1; +} __packed; + /** * This includes all memory map entries which is sorted based on physical start * address, from low to high, and carved out reserved, acpi nvs, acpi reclaim -- 2.20.1
Changes in v3:
- Use HOB function from the common HOB library
- Copyright (C) 2019 Intel Corporation <www.intel.com>
- The serial port info hob is generated by Slim Bootloader, so eligible for
- Slim Bootloader based boards only.
This should be static.
[snip]
Other than that, Reviewed-by: Bin Meng bmeng.cn@gmail.com
Hi Bin,
-----Original Message----- From: Bin Meng [mailto:bmeng.cn@gmail.com] Sent: Sunday, July 14, 2019 1:49 AM To: Park, Aiden aiden.park@intel.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Simon Glass sjg@chromium.org Subject: Re: [PATCH v3 4/8] x86: slimbootloader: Add serial driver
Changes in v3:
- Copyright (C) 2019 Intel Corporation <www.intel.com> */
+eligible for
Thanks. Let me add 'static'.
[snip]
Best Regards, Aiden
Bin Meng
Park, Aiden
