[U-Boot] [PATCH 1/2] lib: uuid: add function to generate UUID version 4
lib/uuid.c: Add get_uuid_str() - this function returns 36 character hexadecimal ASCII string representation of a 128-bit (16 octets) UUID (Universally Unique Identifier) version 4 based on RFC4122, which is randomly generated.
Source: https://www.ietf.org/rfc/rfc4122.txt
Changes: Move functions: - disk/part_efi.c uuid_string() to lib/uuid.c -> uuid_bin_to_str() - disk/part_efi.c string_uuid() to lib/uuid.c -> uuid_str_to_bin()
Update files: - include/common.h - disk/part_efi.c - lib/Makefile
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com cc: Jason Hobbs jason.hobbs@calxeda.com cc: Stephen Warren swarren@nvidia.com cc: Lukasz Majewski l.majewski@samsung.com cc: trini@ti.com --- disk/part_efi.c | 90 ++++++------------------------------------ include/common.h | 7 +++- lib/Makefile | 4 ++ lib/uuid.c | 114 ++++++++++++++++++++++++++++++++++++++++++++++++++++-- 4 files changed, 131 insertions(+), 84 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 733d5bd..a280ab5 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -63,26 +63,6 @@ static char *print_efiname(gpt_entry *pte) return name; }
-static void uuid_string(unsigned char *uuid, char *str) -{ - static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, - 12, 13, 14, 15}; - int i; - - for (i = 0; i < 16; i++) { - sprintf(str, "%02x", uuid[le[i]]); - str += 2; - switch (i) { - case 3: - case 5: - case 7: - case 9: - *str++ = '-'; - break; - } - } -} - static efi_guid_t system_guid = PARTITION_SYSTEM_GUID;
static inline int is_bootable(gpt_entry *p) @@ -103,6 +83,7 @@ void print_part_efi(block_dev_desc_t * dev_desc) gpt_entry *gpt_pte = NULL; int i = 0; char uuid[37]; + unsigned char *uuid_bin;
if (!dev_desc) { printf("%s: Invalid Argument(s)\n", __func__); @@ -132,9 +113,11 @@ void print_part_efi(block_dev_desc_t * dev_desc) le64_to_cpu(gpt_pte[i].ending_lba), print_efiname(&gpt_pte[i])); printf("\tattrs:\t0x%016llx\n", gpt_pte[i].attributes.raw); - uuid_string(gpt_pte[i].partition_type_guid.b, uuid); + uuid_bin = (unsigned char *)gpt_pte[i].partition_type_guid.b; + uuid_bin_to_str(uuid_bin, uuid); printf("\ttype:\t%s\n", uuid); - uuid_string(gpt_pte[i].unique_partition_guid.b, uuid); + uuid_bin = (unsigned char *)gpt_pte[i].unique_partition_guid.b; + uuid_bin_to_str(uuid_bin, uuid); printf("\tuuid:\t%s\n", uuid); }
@@ -182,7 +165,7 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part, sprintf((char *)info->type, "U-Boot"); info->bootable = is_bootable(&gpt_pte[part - 1]); #ifdef CONFIG_PARTITION_UUIDS - uuid_string(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); + uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); #endif
debug("%s: start 0x" LBAF ", size 0x" LBAF ", name %s", __func__, @@ -237,60 +220,6 @@ static int set_protective_mbr(block_dev_desc_t *dev_desc) return 0; }
-/** - * string_uuid(); Convert UUID stored as string to bytes - * - * @param uuid - UUID represented as string - * @param dst - GUID buffer - * - * @return return 0 on successful conversion - */ -static int string_uuid(char *uuid, u8 *dst) -{ - efi_guid_t guid; - u16 b, c, d; - u64 e; - u32 a; - u8 *p; - u8 i; - - const u8 uuid_str_len = 36; - - /* The UUID is written in text: */ - /* 1 9 14 19 24 */ - /* xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx */ - - debug("%s: uuid: %s\n", __func__, uuid); - - if (strlen(uuid) != uuid_str_len) - return -1; - - for (i = 0; i < uuid_str_len; i++) { - if ((i == 8) || (i == 13) || (i == 18) || (i == 23)) { - if (uuid[i] != '-') - return -1; - } else { - if (!isxdigit(uuid[i])) - return -1; - } - } - - a = (u32)simple_strtoul(uuid, NULL, 16); - b = (u16)simple_strtoul(uuid + 9, NULL, 16); - c = (u16)simple_strtoul(uuid + 14, NULL, 16); - d = (u16)simple_strtoul(uuid + 19, NULL, 16); - e = (u64)simple_strtoull(uuid + 24, NULL, 16); - - p = (u8 *) &e; - guid = EFI_GUID(a, b, c, d >> 8, d & 0xFF, - *(p + 5), *(p + 4), *(p + 3), - *(p + 2), *(p + 1) , *p); - - memcpy(dst, guid.b, sizeof(efi_guid_t)); - - return 0; -} - int write_gpt_table(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_entry *gpt_e) { @@ -358,6 +287,7 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e, size_t efiname_len, dosname_len; #ifdef CONFIG_PARTITION_UUIDS char *str_uuid; + unsigned char *bin_uuid; #endif
for (i = 0; i < parts; i++) { @@ -391,7 +321,9 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e,
#ifdef CONFIG_PARTITION_UUIDS str_uuid = partitions[i].uuid; - if (string_uuid(str_uuid, gpt_e[i].unique_partition_guid.b)) { + bin_uuid = gpt_e[i].unique_partition_guid.b; + + if (uuid_str_to_bin(str_uuid, bin_uuid)) { printf("Partition no. %d: invalid guid: %s\n", i, str_uuid); return -1; @@ -438,7 +370,7 @@ int gpt_fill_header(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_h->header_crc32 = 0; gpt_h->partition_entry_array_crc32 = 0;
- if (string_uuid(str_guid, gpt_h->disk_guid.b)) + if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b)) return -1;
return 0; diff --git a/include/common.h b/include/common.h index 96a45a6..18f0224 100644 --- a/include/common.h +++ b/include/common.h @@ -815,7 +815,9 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/uuid.c */ -void uuid_str_to_bin(const char *uuid, unsigned char *out); +char *get_uuid_str(void); +int uuid_bin_to_str(unsigned char *uuid, char *str); +int uuid_str_to_bin(char *uuid, unsigned char *out); int uuid_str_valid(const char *uuid);
/* lib/vsprintf.c */ @@ -830,7 +832,8 @@ char * strmhz(char *buf, unsigned long hz); /* lib/rand.c */ #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ - defined(CONFIG_CMD_LINK_LOCAL) + defined(CONFIG_CMD_LINK_LOCAL) || \ + defined(CONFIG_PARTITION_UUIDS) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index dedb97b..ca7f878 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -65,3 +65,7 @@ obj-y += vsprintf.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o +ifdef CONFIG_PARTITION_UUIDS +obj-y += rand.o +obj-y += uuid.o +endif diff --git a/lib/uuid.c b/lib/uuid.c index c48bf38..d75ae16 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -5,7 +5,29 @@ */
#include <linux/ctype.h> -#include "common.h" +#include <errno.h> +#include <common.h> +#include <part_efi.h> +#include <malloc.h> + +#define UUID_STR_BYTE_LEN 37 + +#define UUID_VERSION_CLEAR_BITS 0x0fff +#define UUID_VERSION_SHIFT 12 +#define UUID_VERSION 0x4 + +#define UUID_VARIANT_CLEAR_BITS 0x3f +#define UUID_VARIANT_SHIFT 7 +#define UUID_VARIANT 0x1 + +struct uuid { + unsigned int time_low; + unsigned short time_mid; + unsigned short time_hi_and_version; + unsigned char clock_seq_hi_and_reserved; + unsigned char clock_seq_low; + unsigned char node[6]; +};
/* * This is what a UUID string looks like. @@ -43,14 +65,17 @@ int uuid_str_valid(const char *uuid) return 1; }
-void uuid_str_to_bin(const char *uuid, unsigned char *out) +int uuid_str_to_bin(char *uuid, unsigned char *out) { uint16_t tmp16; uint32_t tmp32; uint64_t tmp64;
if (!uuid || !out) - return; + return -EINVAL; + + if (!uuid_str_valid(uuid)) + return -EINVAL;
tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); memcpy(out, &tmp32, 4); @@ -66,4 +91,87 @@ void uuid_str_to_bin(const char *uuid, unsigned char *out)
tmp64 = cpu_to_be64(simple_strtoull(uuid + 24, NULL, 16)); memcpy(out + 10, (char *)&tmp64 + 2, 6); + + return 0; +} + +int uuid_bin_to_str(unsigned char *uuid, char *str) +{ + static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, + 12, 13, 14, 15}; + char *str_ptr = str; + int i; + + for (i = 0; i < 16; i++) { + sprintf(str, "%02x", uuid[le[i]]); + str += 2; + switch (i) { + case 3: + case 5: + case 7: + case 9: + *str++ = '-'; + break; + } + } + + if (!uuid_str_valid(str_ptr)) + return -EINVAL; + + return 0; +} + +/* + * get_uuid_str() - this function returns pointer to 36 character hexadecimal + * ASCII string representation of a 128-bit (16 octets) UUID (Universally + * Unique Identifier) version 4 based on RFC4122. + * source: https://www.ietf.org/rfc/rfc4122.txt + * + * Layout of UUID Version 4: + * timestamp - 60-bit: time_low, time_mid, time_hi_and_version + * version - 4 bit (bit 4 through 7 of the time_hi_and_version) + * clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low + * variant: - bit 6 and 7 of clock_seq_hi_and_reserved + * node - 48 bit + * In this version all fields beside 4 bit version are randomly generated. + * + * @ret: pointer to 36 bytes len characters array + */ +char *get_uuid_str(void) +{ + struct uuid uuid; + char *uuid_str = NULL; + int *ptr = (int *)&uuid; + int i; + + uuid_str = malloc(UUID_STR_BYTE_LEN); + if (!uuid_str) { + error("uuid_str pointer is null"); + return NULL; + } + + memset(&uuid, 0x0, sizeof(uuid)); + + /* Set all fields randomly */ + for (i = 0; i < sizeof(uuid) / 4; i++) + *(ptr + i) = rand(); + + /* Set V4 format */ + uuid.time_hi_and_version &= UUID_VERSION_CLEAR_BITS; + uuid.time_hi_and_version |= UUID_VERSION << UUID_VERSION_SHIFT; + + uuid.clock_seq_hi_and_reserved &= UUID_VARIANT_CLEAR_BITS; + uuid.clock_seq_hi_and_reserved |= UUID_VARIANT << UUID_VARIANT_SHIFT; + + uuid_bin_to_str((unsigned char *)&uuid, uuid_str); + + if (!uuid_str_valid(uuid_str)) { + error("Invalid UUID string"); + return NULL; + } + + /* Put end of string */ + uuid_str[UUID_STR_BYTE_LEN - 1] = '\0'; + + return uuid_str; }
Changes: - randomly generate each partition uuid if undefined - print info about generated uuid - save environment on gpt write success - update doc/README.gpt
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com cc: Piotr Wilczek p.wilczek@samsung.com cc: Tom Rini trini@ti.com --- common/cmd_gpt.c | 29 +++++++++++++++++++++++------ doc/README.gpt | 1 + 2 files changed, 24 insertions(+), 6 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 1f12e6d..7be5fcf 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -31,6 +31,7 @@ */ static char extract_env(const char *str, char **env) { + int ret = -1; char *e, *s;
if (!str || strlen(str) < 4) @@ -43,16 +44,23 @@ static char extract_env(const char *str, char **env) memset(s + strlen(s) - 1, '\0', 1); memmove(s, s + 2, strlen(s) - 1); e = getenv(s); - free(s); if (e == NULL) { - printf("Environmental '%s' not set\n", str); - return -1; /* env not set */ + printf("%s unset. ", str); + e = get_uuid_str(); + if (e) { + printf("Setting to: %s\n", e); + setenv(s, e); + ret = 0; + } + } else { + ret = 0; } + *env = e; - return 0; + free(s); }
- return -1; + return ret; }
/** @@ -299,8 +307,17 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE; }
- if (gpt_default(blk_dev_desc, argv[4])) + puts("Writing GPT: "); + + ret = gpt_default(blk_dev_desc, argv[4]); + if (!ret) { + puts("success!\n"); + saveenv(); + return CMD_RET_SUCCESS; + } else { + puts("error!\n"); return CMD_RET_FAILURE; + } } else { return CMD_RET_USAGE; } diff --git a/doc/README.gpt b/doc/README.gpt index 5c133f3..afe2538 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -176,3 +176,4 @@ Please, pay attention at -l switch for parted. "uuid" program is recommended to generate UUID string. Moreover it can decode (-d switch) passed in UUID string. It can be used to generate partitions UUID passed to u-boot environment variables. +If each partition "uuid" no exists then it will be randomly generated.
On 02/28/2014 08:18 AM, Przemyslaw Marczak wrote:
Changes:
- int ret = -1;
Why does the function return char not int? At least the type of ret should match the return type of the function.
There's no need to introduce a ret variable anyway; just don't delete the return statements that are already in the function.
if (e == NULL) {free(s);
e = get_uuid_str();
if (e) {
setenv(s, e);
Why should the environment variable be set? I rather dislike commands that randomly set environment variables as an implicit side-effect.
It'd be far better if this function simply wasn't modified, but rather the user was provided with a function to explicitly set an environment variable to a randomly generated GPT. That way the user/script would be in control. Something like:
$ gen_random_uuid env_var_name
if (!ret) {
puts("success!\n");
saveenv();
Uggh. Definitely don't save the environment behind the user's back. There is no reason to believe that's safe. What if the user had added some temporary changes to their environment that they didn't want saved? This kind of logic belongs in scripts, not code.
Hello again,
Changes:
- int ret = -1;
Right notice, this should be fixed.
But I need to move "free(s)" so I can't leave current return statements. Other way I need to put "free(s)" in few places.
e = get_uuid_str();
if (e) {
setenv(s, e);
And here I forget about free(e)...
Actually automatically generated uuids was the main purpose of this patches. Setting each env variable in this place was the most easy way to make this without a lot of duplicated code.
Why do you treat it like a side-effect? If user wants have own generated uuids - then he can manually set env variables like "uuid_gpt_disk". This actually is not changed - when uuid env is set then it will be used like in current version of code. When user can't generate uuids or just wants to have it automatically generated then my code do this job.
I understand that this is very important code, but setting each val manually with random uuid actually will not change anything - user still needs to do something.
The other way is to provide a function for parse e.g $partitions but then it will be a code duplication. The main job is done by set_gpt_info() so this is why I modified this code.
if (!ret) {
puts("success!\n");
saveenv();
The one and only reason for put saveenv() here was that if uuids are randomly generated or even just are in environment then I can be sure that next gpt write (e.g. in case of overwrite sector 0 by mistake) is using the same uuids values.
Maybe saveenv() in this place is not the best idea but in other side user actually uses this command just once.
Thank you
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 03/03/2014 08:45 AM, Przemyslaw Marczak wrote:
[snip]
Having been using this code again myself recently, at the high level, this is useful. Having to copy/paste in N UUIDs gets silly. But I also wonder..
[snip]
Is this really an important use case to cover?
The way I see things, would it be possible (and not a pain) to make the UUID part of the partition string passed to 'gpt write' optional. If not passed, generate the UUIDs needed. What was used would be seen in 'part list' and so forth.
- -- Tom
Hello Tom,
[snip]
[snip]
It can be important if somebody uses UUIDS to boot kernel. In kernel documentation you can find a notice about kernel function name_to_dev_t() - so by command line you can pass uuid for root partition. And the same is for arg "suspend" in kernel cmd line.
Tom
Ok, so I remove saveenv() from my changes and then we will have two cases:
# gpt write mmc 0 $partitions case 1: envorinment uuids are not set; then: proper uuids variables are set automatically (and printed) case 2: environment uuids are set in env (e.g. some user has put his own env); then users uuids will be used and new uuids are not generated automatically
So this will not change current "gpt" usability - just add new feature, moreover user will be informed about each uuid generation. In case when someone use gpt write by mistake and overwrite uuids by randomly generated then he can easily back to his own uuids by setting each in environment and run gpt write again.
-----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJTFI32AAoJENk4IS6UOR1WAyQP/2bfClvRaWtLzUDggRUnNr99 RKSgB1m/nl09ZwclB2Gn1FZL2IR/M0u+ia89FE9leSN4eoOEswN2rrUiExVv7QpJ d+oCH/H3oNDAyb9L4HXXYHeRGCVHK7KE/KP5Ngb7KfTGZhj5kHdkx9iQM7dO9OtX DmvW5+JoRXgXPkpmvy5s20IzRUbBEqGC6Z2h8Y/VKHTDnrUmYvFb6XPgjwwrYVB6 +Hx/7K2R1uXQTuoHM7FqVAqKx7GGiUmcpLG90iHeYcX4fib/+RwC7hcre0rRj71v NyAnO4t0nXKefLXYe5iGold7cNx9xUKO3s4u2EkC9lNGRkN6RcVuaxzEKGD4/QTX fHA2q6FwSVLv4lXBT6UWxXiky2C9TMY/DUNM0EWe2KSx2V2glXPKiBX7gRk0Rq0d EWq1G5oQS0qiZgb+vUQ4Acf4/HDjhAl1l18Hx6w+26LNvz8Fi+o7Om4kkBdI5sos GX2auS1RxQc3qQkrAjxFx1xpDr9iMikV6nNqYDcVU894PeCgzmUWaWG/IrBFixO6 2XjF1sMth8LrVqUHirh3Y7lDU+FFPP+mMb6eaY3oajtVkg3u6cpQ0eJ0A612CsXG oaTPxWKKTsWlBxaVIgzu2OXeYg5BJF4OTKxjNiV2wptheEVc4RVLDiQ1yf74YEHy Hve7lpxa9i4Oo9Vf2Pd7 =5FKf -----END PGP SIGNATURE-----
Thank you,
On Mon, Mar 03, 2014 at 04:31:35PM +0100, Przemyslaw Marczak wrote:
Hello Tom,
[snip]
[snip]
Right. But that seems to be putting things in the wrong order. If you need to restore UUIDs to your partition table, you pass in the optional and already known UUID. If you're starting from scratch, by the time the installer is run U-Boot is long gone. And tying things back to the commodity distro stuff, we would be fetching 'root=UUID=...' from some file generated and controlled on the Linux side of things anyhow. To be clear, on the OS side of the equation there's much better ways to find out that partition1 has a UUID of ... than poking the U-Boot environment.
I'd go so far as to say we don't need to print the uuids, they're available via 'part list ...'. A notice that we're generating UUIDs is probably not too spammy.
Right. We're making the use case of "fresh device, create new table" easier and we're still allowing "existing device, re-establish old UUIDs".
Hello Tom,
[snip]
[snip]
Ok, I understand this.
Ok, I will remove this notice.
That's the point.
Thanks,
Hello Tom,
[snip]
[snip]
That's the point.
Yay for agreement then, even if it took a few rounds to see we're on the same side :) I look forward to v2.
- -- Tom
Hello Tom,
[snip]
[snip]
That's the point.
Tom -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.11 (GNU/Linux) Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQIcBAEBAgAGBQJTFL1DAAoJENk4IS6UOR1WT0EP/12dTZmJGcgZYPgIaRohWAjS Dk3n0PdkPszGic/n5j6un6b8gSck27cTI3aM5YvqRioRBTzw6tvGVoIBOfrtEKdZ EV78iqMq1cozL3o3VdltQlLAzdLzSMwkkEqdD9K4vWpihdr19PPPuaPlV0ynw4/D 6+a1azEqTtznx96bGIH0XLK37ZtVre0/n1+9nd+mQ/swibHQM84GNPdR1L5m3hnJ W80XCnX4wRh238KxXRKr/fqG5w9cVXFcsPWESXzfA+pzi9Jy37dkhMX3CyAGuwS0 QDLz1gg4h6CYGCRulN6rfNYHbLg8YYbJ/5xa4/dSntUW84uZJRMq93T9yKYX+qKM Iezp+EKzoL3Lagz3K2GmwopazEd+0goEHauoQ8QUGDdgMGapXui5NBUNyke78JK8 U/WszX6JOWjagenWHDYiBvPhwIWdGw3FUJVijutKhK8KpKKihC9eDOsdoxz+Lyfu agcZ8rtJ8s6QBEf+xo/PRS+twJeHuTe/CptORm52cXxPMrwOKK17UxrjLJIuDSDl fqVsUaUHmxFmUNU/k5SGI60d/nZGmi7j8EzMMRIK8DJ18Sk0FaBOj/PKo2xBf3RO afbnEQXi831j42V2HSOEEY6rKRzES9d0roSUFIe5EvP/s/1/O1OanimtrXRISjF9 rKXW1zAJZKQlBbYoDOSa =eGvG -----END PGP SIGNATURE-----
I hope to send V2 tomorrow :) Regards
I don't know why you need the uuid_bin temporary variable; you could just as well do the cast as part of the function parameter. Not a big deal though.
- uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid);
#endif
But you don't use a temporary here, for example.
See below; I think this prototype should be added in a separate patch.
Can this ever fail? If you're explicitly changing it to have a return cdoe, why do none of the callers check the return code?
- defined(CONFIG_CMD_LINK_LOCAL) || \
- defined(CONFIG_PARTITION_UUIDS)
This patch does two things:
a) Refactor the UUID bin<->str code so that it's in a shared place b) Add new code get_uuid_str().
I think this patch should only do (a), and (b) should be part of a separate patch. As such, the hunk above should be separated out. Perhaps (b) should be part of patch 2/2, or a new patch inserted between the two.
Also, not everyone who defines CONFIG_PARTITION_UUIDs needs the new get_uuid_str() function, and hence not everyone needs rand() etc.
That'd be better as:
obj-$(CONFIG_PARTITION_UUIDS) rand.o obj-$(CONFIG_PARTITION_UUIDS) uuid.o
... although the rand.o change should be in a separate patch.
+struct uuid {
- unsigned int time_low;
- unsigned short time_mid;
- unsigned short time_hi_and_version;
- unsigned char clock_seq_hi_and_reserved;
- unsigned char clock_seq_low;
- unsigned char node[6];
Most/all of that is support for get_uuid_str(), so should probably be added in a separate patch.
if (!uuid || !out)
return;
return -EINVAL;
- if (!uuid_str_valid(uuid))
return -EINVAL;
I'm not convinced it's useful to add this error-check; the code already works or doesn't. Adding a unit-test to test/command_ut.c might be more useful.
- get_uuid_str() - this function returns pointer to 36 character hexadecimal
- ASCII string representation of a 128-bit (16 octets) UUID (Universally
- Unique Identifier) version 4 based on RFC4122.
- Layout of UUID Version 4:
- timestamp - 60-bit: time_low, time_mid, time_hi_and_version
- version - 4 bit (bit 4 through 7 of the time_hi_and_version)
- clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low
- variant: - bit 6 and 7 of clock_seq_hi_and_reserved
- node - 48 bit
- In this version all fields beside 4 bit version are randomly generated.
- @ret: pointer to 36 bytes len characters array
This function name isn't particularly good; it gives no hint that it's generating a random UUID. Perhaps generate_random_uuid_str() would be better.
Why does the function malloc the string, rather than writing to a user-allocated buffer like uuid_bin_to_str()? That would be more consistent with the other API, and simpler to code, and then couldn't ever fail.
- struct uuid uuid;
- char *uuid_str = NULL;
- int *ptr = (int *)&uuid;
- int i;
- uuid_str = malloc(UUID_STR_BYTE_LEN);
- if (!uuid_str) {
More like allocation failed; the existing message implies that a NULL pointer was passed into the function. Does error() tell you which file/line/function the problem occurred in?
- /* Set all fields randomly */
- for (i = 0; i < sizeof(uuid) / 4; i++)
Replace "4" with sizeof(int) or even better, sizeof(*ptr).
- uuid_bin_to_str((unsigned char *)&uuid, uuid_str);
Why not generate a random binary UUID; it's quite possible the caller wants a binary version and would just have to undo this call. You could create separate generate_random_uuid_bin() and provide a simple wrapper generate_random_uuid_str() that called it.
- if (!uuid_str_valid(uuid_str)) {
return NULL;
Isn't that code already part of uuid_bin_to_str()?
- /* Put end of string */
- uuid_str[UUID_STR_BYTE_LEN - 1] = '\0';
If it isn't already, uuid_bin_to_str() should be doing that.
Hello Stephen, Thank you for review.
Just because the line was too long.
- uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); #endif
Because this line doesn't exceeds 80 characters...
Ok, will be changed.
Actually it shouldn't, so I will change this return type to void.
Ok, I will separate each change.
I understand but now this will be a part of UUID library so do you prefer to add proper #ifdef in code?
#ifdef CONFIG_GENERATE_UUID char *get_uuid_str(void) { ... ... } #endif
Ok, it will be included in get_uuid_str() patch.
+struct uuid {
OK.
if (!uuid || !out)
return;
return -EINVAL;
return -EINVAL;
Right, this code is simple. Error check will be removed from here.
- node - 48 bit
What about this?
/* To generate bin uuid */ void gen_rand_uuid(unsigned char *uuid) { if (!uuid) return; ... }
So as in declaration above - user should pass allocated pointer.
- struct uuid uuid;
- int i;
- if (!uuid_str) {
I agree with you - this was not good.
Ok.
Ok, will be added.
return NULL;
Right, this is duplication...
I will improve those changes in the next version. Thank you for comments.
You can wrap the parameter list.
What about this?
I don't think there's a need to shorten the words so much, but at least that's accurate.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com cc: Stephen Warren swarren@nvidia.com cc: trini@ti.com
--- Changes v2: - This commit is new after separate: [PATCH 1/2] lib: uuid: add function to generate UUID version 4 - it introduces small refactor of common lib uuid functions --- disk/part_efi.c | 90 +++++++----------------------------------------------- include/common.h | 3 +- lib/Makefile | 1 + lib/uuid.c | 33 ++++++++++++++++++-- 4 files changed, 44 insertions(+), 83 deletions(-)
return 0; diff --git a/include/common.h b/include/common.h index 96a45a6..32377ad 100644 --- a/include/common.h +++ b/include/common.h @@ -815,7 +815,8 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/uuid.c */ -void uuid_str_to_bin(const char *uuid, unsigned char *out); +void uuid_bin_to_str(unsigned char *uuid, char *str); +int uuid_str_to_bin(char *uuid, unsigned char *out); int uuid_str_valid(const char *uuid);
/* lib/vsprintf.c */ diff --git a/lib/Makefile b/lib/Makefile index dedb97b..70962b2 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -61,6 +61,7 @@ obj-y += string.o obj-y += time.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index c48bf38..803bdcd 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -5,7 +5,8 @@ */
/* * This is what a UUID string looks like. @@ -43,14 +44,17 @@ int uuid_str_valid(const char *uuid) return 1; }
if (!uuid || !out) - return; + return -EINVAL; + + if (strlen(uuid) != UUID_STR_LEN) + return -EINVAL;
tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); memcpy(out, &tmp32, 4); @@ -66,4 +70,27 @@ void uuid_str_to_bin(const char *uuid, unsigned char *out)
tmp64 = cpu_to_be64(simple_strtoull(uuid + 24, NULL, 16)); memcpy(out + 10, (char *)&tmp64 + 2, 6); + + return 0; +} + +void uuid_bin_to_str(unsigned char *uuid, char *str) +{ + static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, + 12, 13, 14, 15}; + char *str_ptr = str; + int i; + + for (i = 0; i < 16; i++) { + sprintf(str, "%02x", uuid[le[i]]); + str += 2; + switch (i) { + case 3: + case 5: + case 7: + case 9: + *str++ = '-'; + break; + } + } }
This patch adds support to generate UUID (Universally Unique Identifier) in version 4 based on RFC4122, which is randomly.
Changes: - add new config: CONFIG_RANDOM_UUID: compile uuid.c and rand.c
Update files: - include/common.h - lib/Makefile - lib/uuid.c
lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation UUID v4 to address given by user.
- add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of 16 bytes binary UUID to address given by user.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com cc: Stephen Warren swarren@nvidia.com cc: trini@ti.com
--- Changes v2: - put uuid generation changes in a separate commit - get_uuid_str() - change name to gen_rand_uuid_str() - add new function: gen_rand_uuid() - remove unnecessary '\0' at the end of uuid string - drop unnecessary error checking - functions now takes pointers to allocated memory instead of alloc it itself - add new config option: CONFIG_RANDOM_UUID --- include/common.h | 5 +++- lib/Makefile | 4 ++- lib/uuid.c | 81 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 88 insertions(+), 2 deletions(-)
diff --git a/include/common.h b/include/common.h index 32377ad..20e9ae6 100644 --- a/include/common.h +++ b/include/common.h @@ -815,6 +815,8 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/uuid.c */ +void gen_rand_uuid(unsigned char *uuid_bin); +void gen_rand_uuid_str(char *uuid_str); void uuid_bin_to_str(unsigned char *uuid, char *str); int uuid_str_to_bin(char *uuid, unsigned char *out); int uuid_str_valid(const char *uuid); @@ -831,7 +833,8 @@ char * strmhz(char *buf, unsigned long hz); /* lib/rand.c */ #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ - defined(CONFIG_CMD_LINK_LOCAL) + defined(CONFIG_CMD_LINK_LOCAL) || \ + defined(CONFIG_RANDOM_UUID) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index 70962b2..64a430f 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -59,10 +59,12 @@ obj-y += linux_string.o obj-$(CONFIG_REGEX) += slre.o obj-y += string.o obj-y += time.o +obj-y += vsprintf.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o obj-$(CONFIG_PARTITION_UUIDS) += uuid.o -obj-y += vsprintf.o +obj-$(CONFIG_RANDOM_UUID) += uuid.o +obj-$(CONFIG_RANDOM_UUID) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index 803bdcd..c0218ba 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -7,6 +7,29 @@ #include <linux/ctype.h> #include <errno.h> #include <common.h> +#include <part_efi.h> +#include <malloc.h> + +#define UUID_STR_LEN 36 +#define UUID_STR_BYTE_LEN 37 +#define UUID_BIN_BYTE_LEN 16 + +#define UUID_VERSION_CLEAR_BITS 0x0fff +#define UUID_VERSION_SHIFT 12 +#define UUID_VERSION 0x4 + +#define UUID_VARIANT_CLEAR_BITS 0x3f +#define UUID_VARIANT_SHIFT 7 +#define UUID_VARIANT 0x1 + +struct uuid { + unsigned int time_low; + unsigned short time_mid; + unsigned short time_hi_and_version; + unsigned char clock_seq_hi_and_reserved; + unsigned char clock_seq_low; + unsigned char node[6]; +};
/* * This is what a UUID string looks like. @@ -94,3 +117,61 @@ void uuid_bin_to_str(unsigned char *uuid, char *str) } } } + +/* + * gen_rand_uuid() - this function generates 16 bytes len UUID V4 (randomly) + * and stores it at a given pointer. + * + * Layout of UUID Version 4: + * timestamp - 60-bit: time_low, time_mid, time_hi_and_version + * version - 4 bit (bit 4 through 7 of the time_hi_and_version) + * clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low + * variant: - bit 6 and 7 of clock_seq_hi_and_reserved + * node - 48 bit + * In this version all fields beside 4 bit version are randomly generated. + * source: https://www.ietf.org/rfc/rfc4122.txt + * + * @param uuid_bin pointer to 16 bytes len array +*/ +void gen_rand_uuid(unsigned char *uuid_bin) +{ + struct uuid *uuid = (struct uuid *)uuid_bin; + unsigned int *ptr = (unsigned int *)uuid_bin; + int i; + + if (!uuid_bin) + return; + + memset(uuid_bin, 0x0, sizeof(struct uuid)); + + /* Set all fields randomly */ + for (i = 0; i < sizeof(struct uuid) / sizeof(*ptr); i++) + *(ptr + i) = rand(); + + /* Set V4 format */ + uuid->time_hi_and_version &= UUID_VERSION_CLEAR_BITS; + uuid->time_hi_and_version |= UUID_VERSION << UUID_VERSION_SHIFT; + + uuid->clock_seq_hi_and_reserved &= UUID_VARIANT_CLEAR_BITS; + uuid->clock_seq_hi_and_reserved |= UUID_VARIANT << UUID_VARIANT_SHIFT; +} + +/* + * gen_rand_uuid_str() - this function generates UUID v4 (randomly) + * into 36 character hexadecimal ASCII string representation of a 128-bit + * (16 octets) UUID (Universally Unique Identifier) version 4 based on RFC4122 + * and stores it at a given pointer. + * + * @param uuid_str pointer to 37 bytes len array + */ +void gen_rand_uuid_str(char *uuid_str) +{ + unsigned char uuid_bin[UUID_BIN_BYTE_LEN]; + + if (!uuid_str) + return; + + gen_rand_uuid(uuid_bin); + + uuid_bin_to_str(uuid_bin, uuid_str); +}
Changes:
Update files:
- include/common.h
- lib/Makefile
- lib/uuid.c
The patch already contains the list of changed files; there's little point duplicating this in the patch description.
s/cc/Cc/
Moving vsprintf.o seems entirely unrelated to this patch. If you want to clean that up, it should be a separate patch.
I really hope listing the same object multiple times in obj-y is OK.
Why not sort the lines you added so based on the config variable, so
obj-$(CONFIG_RANDOM_MACADDR) += rand.o +obj-$(CONFIG_RANDOM_UUID) += rand.o
rather than:
If UUID_STR_BYTE_LEN is the length in bytes, what units is UUID_STR_LEN in? I suppose the difference is the NULL terminator, but the names don't make that clear at all. I would suggest not defining UUID_STR_BYTE_LEN at all, but rather just writing "+ 1" at the appropriate place in the source code.
Also, s/_BYTE// there.
s/CLEAR_BITS/MASK/
+struct uuid {
Is that structure definition endianness-safe?
- gen_rand_uuid() - this function generates 16 bytes len UUID V4 (randomly)
I think "this function generates a random binary UUID v4, and stores it into the memory pointed at by the supplied pointer, which must be 16 bytes in size" would be better.
- struct uuid *uuid = (struct uuid *)uuid_bin;
- unsigned int *ptr = (unsigned int *)uuid_bin;
- int i;
- if (!uuid_bin)
return;
I think you should either (a) assume NULL will never be passed to this function, or (b) return an error code if it happens. Silently failing to do anything doesn't make sense.
- memset(uuid_bin, 0x0, sizeof(struct uuid));
- for (i = 0; i < sizeof(struct uuid) / sizeof(*ptr); i++)
If the entire thing is filled randomly, why memset() the struct?
- gen_rand_uuid_str() - this function generates UUID v4 (randomly)
- into 36 character hexadecimal ASCII string representation of a 128-bit
- (16 octets) UUID (Universally Unique Identifier) version 4 based on RFC4122
- and stores it at a given pointer.
There's a lot of duplication in that description. I think "this function generates a random string-formatted UUID v4, and stores it into the memory pointed at by the supplied pointer, which must be 37 bytes in size" would be better.
- unsigned char uuid_bin[UUID_BIN_BYTE_LEN];
- if (!uuid_str)
return;
Again, I would drop that error-checking.
Hello again,
Changes:
Update files:
- include/common.h
- lib/Makefile
- lib/uuid.c
s/cc/Cc/
rather than:
s/CLEAR_BITS/MASK/
+struct uuid {
UUID format is big-endian. Actually for version 4 it doesn't matter because of it is random, and RFC says that version and variant are the most significant bits of proper structure field. In this code version and variant mask are stored at most significant bits - so this is big endian. Actually we uses it as a string and as you can check in generated uuids its proper. As wiki says: "Version 4 UUIDs have the form xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx where x is any hexadecimal digit and y is one of 8, 9, A, or B (e.g., f47ac10b-58cc-4372-a567-0e02b2c3d479)."
Even if this code runs on big-endian machine, version and variant are still set properly (most significant bits).
- int i;
- if (!uuid_bin)
return;
- if (!uuid_str)
return;
I also apply other comments to V3. Thanks
Dear Przemyslaw Marczak,
OK. Then you must make sure to store the data such that they result in a big endian data format.
I don't see how come to this conclusion. As far as I can see, you initialize a binary data structure (where data storage _does_ depend on the endianess), and then simply use this memory area - there is no endianess handling anywhere.
Please also note that your code needs fixing due to alignment issues. You cannot just cast a struct pointer which requires 32 bit alignment to an arbitrary (i. e. unaligned) char pointer (comment to patch sent).
In message cc0f558724a4d3ea3497b84601038f5f18f37a7b.1394037321.git.p.marczak@samsung.com you wrote:
+struct uuid {
This struct starts with an uint, so it requires alignment on a 32 bit boundary (i. e. an address that is a multiple of 4).
Here you cast a pointer to the (unaligned) character buffer to a struct buffer, which requires alignment.
This code is dangerous - if the size of the struct should not be a multiple of sizeof(uint), there would remain uninitialized data.
And note that it is likely that all these accesses are unaligned and might cause exceptions.
- /* Set V4 format */
- uuid->time_hi_and_version &= UUID_VERSION_CLEAR_BITS;
- uuid->time_hi_and_version |= UUID_VERSION << UUID_VERSION_SHIFT;
Potentially unaligned accesses.
+struct uuid {
And this needs to be marked as packed since we're using this as a direct representation of things on-disk.
Potentially unaligned buffer. There's only one caller thus far, and it will be aligned there. We do need to comment that the pointer needs to be aligned.
With the struct not packed, it'll be padded out so this works. But looking at how we later use this as I say above, we do need to pack it, and then this will not be safe. Some looping of strncpy into the char buffer, as a char so we whack the rand data in?
As-is no (hidden padding), with packed yes-but-handled (compiler can see this too, will behave correctly).
Dear Tom,
In message 20140313191814.GB16360@bill-the-cat you wrote:
+struct uuid {
Not really. The arrangement of the elemnts makes sure that there are no inter-element gaps, and even if we had arrays of such structs (which we don;t have) it would work as the struct adds up to a multiple of 32 bits.
No. We should rather fix the code such that it works with any alignment. It is trivial here to use a struct uuid on the stack and then use memcpy() to cpy the data from the struct to the buffer - no casting needed anywhere, and no alignment concerns either.
I can't see why we would not simply initialize the elements step by step. It's just such a small struct.
On 03/13/2014 01:48 PM, Wolfgang Denk wrote:
Dear Tom,
+struct uuid {
Why not just change the prototype of the function so that it takes a pointer to a struct uuid. That way, the compiler will ensure that everything is aligned correctly (assuming there are no broken casts at the call site), and we won't have to either document any assumptions about alignment, nor perform a memcpy() to work around any misalignment.
Hello,
+struct uuid {
ok, I will add packed attribute.
I can change this pointer above to unsigned int.
We know that uuid is 16bytes, so change the divider to "4" is better solution?
Ok, I change this to clrsetbits.
Thanks
--- Changes v2: - cmd_gpt: extract_env: change return type from char to int - add tmp array to generate uuid string - store generated uuid in env and next get it from it - don't need to alloc and maintain allcoated memory outside extract_env()
--- common/cmd_gpt.c | 33 ++++++++++++++++++++++++++------- doc/README.gpt | 1 + include/common.h | 3 ++- lib/Makefile | 1 + 4 files changed, 30 insertions(+), 8 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 1f12e6d..cad402f 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -29,9 +29,11 @@ * * @return - zero on successful expand and env is set */ -static char extract_env(const char *str, char **env) +static int extract_env(const char *str, char **env) { + int ret = -1; char *e, *s; + char uuid_str[37];
if (!str || strlen(str) < 4) return -1; @@ -43,16 +45,25 @@ static char extract_env(const char *str, char **env) memset(s + strlen(s) - 1, '\0', 1); memmove(s, s + 2, strlen(s) - 1); e = getenv(s); - free(s); if (e == NULL) { - printf("Environmental '%s' not set\n", str); - return -1; /* env not set */ + printf("%s unset. ", str); + gen_rand_uuid_str(uuid_str); + setenv(s, uuid_str); + + e = getenv(s); + if (e) { + puts("Setting to random.\n"); + ret = 0; + } + } else { + ret = 0; } + *env = e; - return 0; + free(s); }
/** @@ -299,8 +310,16 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE; }
- if (gpt_default(blk_dev_desc, argv[4])) + puts("Writing GPT: "); + + ret = gpt_default(blk_dev_desc, argv[4]); + if (!ret) { + puts("success!\n"); + return CMD_RET_SUCCESS; + } else { + puts("error!\n"); return CMD_RET_FAILURE; + } } else { return CMD_RET_USAGE; } diff --git a/doc/README.gpt b/doc/README.gpt index 5c133f3..afe2538 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -176,3 +176,4 @@ Please, pay attention at -l switch for parted. "uuid" program is recommended to generate UUID string. Moreover it can decode (-d switch) passed in UUID string. It can be used to generate partitions UUID passed to u-boot environment variables. +If each partition "uuid" no exists then it will be randomly generated. diff --git a/include/common.h b/include/common.h index 20e9ae6..665c98f 100644 --- a/include/common.h +++ b/include/common.h @@ -834,7 +834,8 @@ char * strmhz(char *buf, unsigned long hz); #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ defined(CONFIG_CMD_LINK_LOCAL) || \ - defined(CONFIG_RANDOM_UUID) + defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_PARTITION_UUIDS) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index 64a430f..e989b18 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -65,6 +65,7 @@ obj-$(CONFIG_BOOTP_PXE) += uuid.o obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-$(CONFIG_RANDOM_UUID) += uuid.o obj-$(CONFIG_RANDOM_UUID) += rand.o +obj-$(CONFIG_PARTITION_UUIDS) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o
Changes:
char uuid_str[37];
e = getenv(s);
if (e) {
Shouldn't this be printed right after the "if (e == NULL)" check above? That's where the decision is made to generate a random UUID.
Here, "if (!e)", the code should return an error.
But, I still don't like changing the environment. Why can't the above few lines be:
+ gen_rand_uuid_str(uuid_str); + e = uuid_str;
"If each" means "if all of them", implying that it's an all-or-nothing solution, and the random generation only happens of none of the UUIDs were supplied, not on a UUID-by-UUID basis. So, s/each/a/ or s/each/any/.
Hello, Sorry for silent, but I've had some other work. I agree with yours previous comments and those will apply to v3 but I don't agree with few comments to this patch.
Changes:
char uuid_str[37];
In this place ret is "-1".
e = getenv(s);
if (e) {
If (!e) then ret is still "-1". If (e) then ret = 0 and proper info is printed.
e = uuid_str;
Such solution needs more code rewriting and breaking some existing cmd_gpt design. "e" is used outside this function but uuid_str is local here. I don't like to make it static. Using getenv and return its pointer will work the same as previous.
Please note that variables set by user are not overwritten here so this code will only set null uuid env variables. Moreover user can see after gpt command that environment is the same with mmc part shows, I think it is useful instead of situation when uuid is set but not present in environment.
Ok :)
Thanks
Changes:
e = getenv(s);
if (e) {
But ret has nothing to do with it; there's no code in this function which prints messges based on ret.
The code should be:
e = getenv(s); if (e == NULL) { printf("Env var '%s' not set; using random UUID\n", str); // generate random UUID here if (UUID generation failed) { printf("ERROR generating random UUID\n"); return -1; } }
With the code in your patch, the following happens:
* Env var is set: Nothing printed.
* Env var not set, but problem during UUID generation: "%s unset. " is printed without a \n at the end. The error does get propagated back tot he caller, which might print a message with \n at the end, but you shouldn't place that kind of requirement on the caller. Rather, this function should be fully self-contained.
* Env var set, and UUID generated OK: "%s unset. Setting to random.\n" is printed.
e = uuid_str;
I don't think convenience of coding or the size of the patch is justification for writing values to the user's environment when they didn't ask for it. What if they run saveenv after executing this function, yet they specifically want the environment variables unset, so that a random UUID is generated each time this function/command is run?
Changes:
e = getenv(s);
if (e) {
The code should be:
Take a note that gen_rand_uuid_str() doesn't return any error. So this error is not true.
- Env var is set: Nothing printed.
And env var is not changed - and this is as before.
- Env var not set, but problem during UUID generation: "%s unset. " is
- Env var set, and UUID generated OK: "%s unset. Setting to random.\n"
is printed.
e = uuid_str;
Actually I don't understand what is the problem. What is the difference when user set manually $uuid_gpt_* or use generated by gpt command if next he write "save", in both situations variables are saved. I don't think it is a problem.
Thanks
Update files:
- include/common.h
- disk/part_efi.c
- lib/Makefile
That's not a particularly useful patch description. How about:
Move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. Rename uuid_string() to uuid_bin_to_str(), so that's the naming is consistent with the existing uuid_str_to_bin(). Add an error return code to uuid_str_to_bin(). Convert existing users to the new library functions.
This one patch, Acked-by: Stephen Warren swarren@nvidia.com
Oh, I hope listing uuid.o twice in obj-y won't cause any issue...
Update files:
- include/common.h
- disk/part_efi.c
- lib/Makefile
As I'm applying and testing this locally right now, I'll take that better wording (and ack), thanks!
Nope, we're good, it gets filtered now. We should handle this better once we have Kconfig in, but, one step at a time.
- -- Tom
Update files:
- include/common.h
- disk/part_efi.c
- lib/Makefile
On second thought, and reading the rest of Stephen's review, please make a v3 of the series incorporating his feedback, making sure that the series is bisectable, we drop the unused str_ptr from 1/3 and also we catch the other direct use of '36' rather than UUID_STR_LEN in lib/uuid.c. Note that to maintain bisectablity I'm OK with adding '36' directly in one patch and removing in the next.
if (!uuid || !out)
return;
return -EINVAL;
- if (strlen(uuid) != UUID_STR_LEN)
return -EINVAL;
Oh. This patch won't compile, since UUID_STR_LEN doesn't exist yet.
if (!uuid || !out)
return;
return -EINVAL;
return -EINVAL;
Yup, made this '36' and fixed in 2/3.
- -- Tom
Changes: - move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. - rename uuid_string() to uuid_bin_to_str() for consistency with existing uuid_str_to_bin() - add an error return code to uuid_str_to_bin()
Update existing code to the new library functions.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Jason Hobbs jason.hobbs@calxeda.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: trini@ti.com
Changes v3: - reword commit message - add UUID_STR_LEN definition in lib/uuid.c - remove unused string pointer from uuid_bin_to_str() --- disk/part_efi.c | 90 +++++++------------------------------------------------- include/common.h | 3 +- lib/Makefile | 1 + lib/uuid.c | 34 +++++++++++++++++++-- 4 files changed, 45 insertions(+), 83 deletions(-)
/* lib/vsprintf.c */ diff --git a/lib/Makefile b/lib/Makefile index dedb97b..70962b2 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -61,6 +61,7 @@ obj-y += string.o obj-y += time.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index c48bf38..925e501 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -5,7 +5,10 @@ */
#include <linux/ctype.h> -#include "common.h" +#include <errno.h> +#include <common.h> + +#define UUID_STR_LEN 36
/* * This is what a UUID string looks like. @@ -43,14 +46,17 @@ int uuid_str_valid(const char *uuid) return 1; }
tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); memcpy(out, &tmp32, 4); @@ -66,4 +72,26 @@ void uuid_str_to_bin(const char *uuid, unsigned char *out)
tmp64 = cpu_to_be64(simple_strtoull(uuid + 24, NULL, 16)); memcpy(out + 10, (char *)&tmp64 + 2, 6); + + return 0; +} + +void uuid_bin_to_str(unsigned char *uuid, char *str) +{ + static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, + 12, 13, 14, 15}; + int i; + + for (i = 0; i < 16; i++) { + sprintf(str, "%02x", uuid[le[i]]); + str += 2; + switch (i) { + case 3: + case 5: + case 7: + case 9: + *str++ = '-'; + break; + } + } }
lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation UUID v4 to the memory at given address.
- add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of UUID v4 to the memory at given address.
Changes v3: - remove unused UUID_STR_BYTE_LEN - reword comments - remove null pointer checking from gen_rand_uuid() and gen_rand_uuid_str() - remove unneeded memset from gen_rand_uuid() - undo moving vsprintf.o object in lib/Makefile - add attribute "packed" to the uuid structure - gen_rand_uuid(): add endian functions for modify uuid data - gen_rand_uuid(): use memcpy() to store uuid data into given buffer for avoid unaligned access issues - change uuid version and variant masks to proper for use with clrsetbits_* - add #ifdef CONFIG_RANDOM_UUID to random uuid code for avoid warnings --- include/common.h | 5 +++- lib/Makefile | 3 +++ lib/uuid.c | 78 +++++++++++++++++++++++++++++++++++++++++++++++++++++++- 3 files changed, 84 insertions(+), 2 deletions(-)
/* lib/uuid.c */ +void gen_rand_uuid(unsigned char *uuid_bin); +void gen_rand_uuid_str(char *uuid_str); void uuid_bin_to_str(unsigned char *uuid, char *str); int uuid_str_to_bin(char *uuid, unsigned char *out); int uuid_str_valid(const char *uuid); @@ -831,7 +833,8 @@ char * strmhz(char *buf, unsigned long hz); /* lib/rand.c */ #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ - defined(CONFIG_CMD_LINK_LOCAL) + defined(CONFIG_CMD_LINK_LOCAL) || \ + defined(CONFIG_RANDOM_UUID) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index 70962b2..fc7a24a 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -62,7 +62,10 @@ obj-y += time.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o obj-$(CONFIG_PARTITION_UUIDS) += uuid.o +obj-$(CONFIG_PARTITION_UUIDS) += rand.o obj-y += vsprintf.o +obj-$(CONFIG_RANDOM_UUID) += uuid.o +obj-$(CONFIG_RANDOM_UUID) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index 925e501..0f22e14 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -7,8 +7,30 @@ #include <linux/ctype.h> #include <errno.h> #include <common.h> +#include <asm/io.h> +#include <part_efi.h> +#include <malloc.h>
#define UUID_STR_LEN 36 +#define UUID_BIN_LEN 16 + +#define UUID_VERSION_MASK 0xf000 +#define UUID_VERSION_SHIFT 12 +#define UUID_VERSION 0x4 + +#define UUID_VARIANT_MASK 0xc0 +#define UUID_VARIANT_SHIFT 7 +#define UUID_VARIANT 0x1 + +/* This is structure is in big-endian */ +struct uuid { + unsigned int time_low; + unsigned short time_mid; + unsigned short time_hi_and_version; + unsigned char clock_seq_hi_and_reserved; + unsigned char clock_seq_low; + unsigned char node[6]; +} __packed;
/* * This is what a UUID string looks like. @@ -21,7 +43,6 @@ * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx * le le le be be */ - int uuid_str_valid(const char *uuid) { int i, valid; @@ -95,3 +116,58 @@ void uuid_bin_to_str(unsigned char *uuid, char *str) } } } + +/* + * gen_rand_uuid() - this function generates a random binary UUID v4 and stores + * it into the memory pointed at by the supplied pointer, + * which must be 16 bytes in size + * + * Layout of UUID Version 4: + * timestamp - 60-bit: time_low, time_mid, time_hi_and_version + * version - 4 bit (bit 4 through 7 of the time_hi_and_version) + * clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low + * variant: - bit 6 and 7 of clock_seq_hi_and_reserved + * node - 48 bit + * In this version all fields beside 4 bit version are randomly generated. + * source: https://www.ietf.org/rfc/rfc4122.txt + * + * @param uuid_bin pointer to 16 bytes len array +*/ +#ifdef CONFIG_RANDOM_UUID +void gen_rand_uuid(unsigned char *uuid_bin) +{ + struct uuid uuid; + unsigned int *ptr = (unsigned int *)&uuid; + int i; + + /* Set all fields randomly */ + for (i = 0; i < sizeof(struct uuid) / sizeof(*ptr); i++) + *(ptr + i) = cpu_to_be32(rand()); + + clrsetbits_be16(&uuid.time_hi_and_version, + UUID_VERSION_MASK, + UUID_VERSION << UUID_VERSION_SHIFT); + + clrsetbits_8(&uuid.clock_seq_hi_and_reserved, + UUID_VARIANT_MASK, + UUID_VARIANT << UUID_VARIANT_SHIFT); + + memcpy(uuid_bin, &uuid, sizeof(struct uuid)); +} + +/* + * gen_rand_uuid_str() - this function generates a random string formatted + * UUID v4 and stores it into the memory pointed at by + * the supplied pointer, which must be 37 bytes in size + * + * @param uuid_str pointer to 37 bytes len array + */ +void gen_rand_uuid_str(char *uuid_str) +{ + unsigned char uuid_bin[UUID_BIN_LEN]; + + gen_rand_uuid(uuid_bin); + + uuid_bin_to_str(uuid_bin, uuid_str); +} +#endif
In message bf85640549b0798b838145e9bad6dcc59454e7ae.1394807506.git.p.marczak@samsung.com you wrote:
+struct uuid {
+} __packed;
Maybe we should define UUID_BIN_LEN as sizeof(struct uuid) ?
+struct uuid {
+} __packed;
Ok, I add this.
Thanks
Changes: - randomly generate partition uuid if any is undefined - print info about set/unset/generated uuid - update doc/README.gpt
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Tom Rini trini@ti.com Cc: Jason Hobbs jason.hobbs@calxeda.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com
Changes v3: - print info if uuid_gpt_* env is get from env/set random - change some word in README.gpt to meaningful --- common/cmd_gpt.c | 36 +++++++++++++++++++++++++++++------- doc/README.gpt | 1 + include/common.h | 3 ++- lib/Makefile | 1 + 4 files changed, 33 insertions(+), 8 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 1f12e6d..31a3fe1 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -29,9 +29,11 @@ * * @return - zero on successful expand and env is set */ -static char extract_env(const char *str, char **env) +static int extract_env(const char *str, char **env) { + int ret = -1; char *e, *s; + char uuid_str[37];
if (!str || strlen(str) < 4) return -1; @@ -43,16 +45,28 @@ static char extract_env(const char *str, char **env) memset(s + strlen(s) - 1, '\0', 1); memmove(s, s + 2, strlen(s) - 1); e = getenv(s); - free(s); if (e == NULL) { - printf("Environmental '%s' not set\n", str); - return -1; /* env not set */ + printf("%s ", str); + gen_rand_uuid_str(uuid_str); + setenv(s, uuid_str); + + e = getenv(s); + if (e) { + puts("set to random.\n"); + ret = 0; + } else { + puts("unset - can't get random UUID.\n"); + } + } else { + printf("%s get from environment.\n", str); + ret = 0; } + *env = e; - return 0; + free(s); }
/** @@ -299,8 +313,16 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE; }
- if (gpt_default(blk_dev_desc, argv[4])) + puts("Writing GPT:\n"); + + ret = gpt_default(blk_dev_desc, argv[4]); + if (!ret) { + puts("success!\n"); + return CMD_RET_SUCCESS; + } else { + puts("error!\n"); return CMD_RET_FAILURE; + } } else { return CMD_RET_USAGE; } diff --git a/doc/README.gpt b/doc/README.gpt index 5c133f3..9d0a8df 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -176,3 +176,4 @@ Please, pay attention at -l switch for parted. "uuid" program is recommended to generate UUID string. Moreover it can decode (-d switch) passed in UUID string. It can be used to generate partitions UUID passed to u-boot environment variables. +If any partition "uuid" no exists then it will be randomly generated. diff --git a/include/common.h b/include/common.h index 20e9ae6..665c98f 100644 --- a/include/common.h +++ b/include/common.h @@ -834,7 +834,8 @@ char * strmhz(char *buf, unsigned long hz); #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ defined(CONFIG_CMD_LINK_LOCAL) || \ - defined(CONFIG_RANDOM_UUID) + defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_PARTITION_UUIDS) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index fc7a24a..f4c06c6 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -66,6 +66,7 @@ obj-$(CONFIG_PARTITION_UUIDS) += rand.o obj-y += vsprintf.o obj-$(CONFIG_RANDOM_UUID) += uuid.o obj-$(CONFIG_RANDOM_UUID) += rand.o +obj-$(CONFIG_PARTITION_UUIDS) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o
In message e7d9246677ecb9a8c774e9e5f8d31ae3fd53d487.1394807506.git.p.marczak@samsung.com you wrote:
Changes:
- int ret = -1; char *e, *s;
- char uuid_str[37];
Should we not rather use a #defined macro here instead of the magic number 37 ?
printf("%s ", str);
e = getenv(s);
if (e) {
Can we keep the "var not set" part, so the user understands why U-Boot assigns a random ID here?
} else {
Make this debug() ?
if (!ret) {
puts("success!\n");
} else {
This code is too verbose - I suggest to turn all these puts() into debug().
Please invert the logic so you can bail out early and reduce the indentation level.
Changes:
Ok, then I create proper header for uuid: "include/uuid.h"
printf("%s ", str);
e = getenv(s);
if (e) {
Ok, I will add this info.
} else {
Make this debug() ?
if (!ret) {
puts("success!\n");
} else {
Ok.
Ok.
This can be changed to debug(), but I leave print error/success info when command finish.
Thanks
In message 5ef7cdb8df4fb05c3c371e29d7a61e28e1563a68.1394807506.git.p.marczak@samsung.com you wrote:
Changes:
12, 13, 14, 15};
- int i;
You mentioned before that the UUID format was big endian. Hoever, here you always use trhe same byte order 3-2-1-0 when formatting the initi "int" field - you do not take into account whether this code is running on a BE or a LE system. Is this code not only correct for LE systems, but broken when running on a BE machine?
Hello,
Changes:
12, 13, 14, 15};
- int i;
Right notice, this function should include all inverted operations from uuid_str_to_bin(), I will correct this.
Thank you
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: trini@ti.com
Changes v4: - add uuid/guid description --- disk/part_efi.c | 90 +++++++------------------------------------------------- include/common.h | 3 +- lib/Makefile | 1 + lib/uuid.c | 61 +++++++++++++++++++++++++++++++++----- 4 files changed, 68 insertions(+), 87 deletions(-)
return 0; diff --git a/include/common.h b/include/common.h index 090fcde..b1d1068 100644 --- a/include/common.h +++ b/include/common.h @@ -816,7 +816,8 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/vsprintf.c */ diff --git a/lib/Makefile b/lib/Makefile index 8814ff9..2e8bd20 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -61,6 +61,7 @@ obj-y += string.o obj-y += time.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index c48bf38..03c5b97 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -5,18 +5,40 @@ */
/* - * This is what a UUID string looks like. + * UUID - Universally Unique IDentifier - 128 bits unique number. + * There are 5 versions and one variant of UUID defined by RFC4122 + * specification. Depends on version uuid number base on a time, + * host name, MAC address or random data. + * + * UUID binary format (16 bytes): + * + * 4B-2B-2B-2B-6B (big endian - network byte order) + * + * UUID string is 36 length of characters (36 bytes): + * + * 0 9 14 19 24 + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, le means the field should be converted + * to little endian and be means it should be converted to big endian. * - * x is a hexadecimal character. fields are separated by '-'s. When converting - * to a binary UUID, le means the field should be converted to little endian, - * and be means it should be converted to big endian. + * UUID is also used as GUID (Globally Unique Identifier) with the same binary + * format but it differs in string format like below. * + * GUID: * 0 9 14 19 24 * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx * le le le be be + * + * GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique numbers. */
int uuid_str_valid(const char *uuid) @@ -43,14 +65,17 @@ int uuid_str_valid(const char *uuid) return 1; }
tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); memcpy(out, &tmp32, 4); @@ -66,4 +91,26 @@ void uuid_str_to_bin(const char *uuid, unsigned char *out)
Changes in lib/uuid.c to: - uuid_str_to_bin() - uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions This change allows easy recognize which UUID type is or should be stored in given string array. Binary data of UUID and GUID is always stored in big endian, only string representations are different as follows.
String byte: 0 36 String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx string UUID: be be be be be string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
--- Changes v4: (new commit) - change simple error checking to uuid_str_valid() in uuid_str_to_bin() - add new parameter to define UUID string format for UUID or GUID which diffe in endianness of first three string blocks. - update functions calls and declarations - add uuid.h header - remove functions declarations from common.h --- disk/part_efi.c | 17 ++++++------ include/common.h | 4 +-- include/uuid.h | 21 ++++++++++++++ lib/uuid.c | 85 ++++++++++++++++++++++++++++++++++++++++---------------- 4 files changed, 92 insertions(+), 35 deletions(-) create mode 100644 include/uuid.h
diff --git a/disk/part_efi.c b/disk/part_efi.c index a280ab5..216a292 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -100,8 +100,8 @@ void print_part_efi(block_dev_desc_t * dev_desc)
printf("Part\tStart LBA\tEnd LBA\t\tName\n"); printf("\tAttributes\n"); - printf("\tType UUID\n"); - printf("\tPartition UUID\n"); + printf("\tType GUID\n"); + printf("\tPartition GUID\n");
for (i = 0; i < le32_to_cpu(gpt_head->num_partition_entries); i++) { /* Stop at the first non valid PTE */ @@ -114,11 +114,11 @@ void print_part_efi(block_dev_desc_t * dev_desc) print_efiname(&gpt_pte[i])); printf("\tattrs:\t0x%016llx\n", gpt_pte[i].attributes.raw); uuid_bin = (unsigned char *)gpt_pte[i].partition_type_guid.b; - uuid_bin_to_str(uuid_bin, uuid); + uuid_bin_to_str(uuid_bin, uuid, UUID_STR_FORMAT_GUID); printf("\ttype:\t%s\n", uuid); uuid_bin = (unsigned char *)gpt_pte[i].unique_partition_guid.b; - uuid_bin_to_str(uuid_bin, uuid); - printf("\tuuid:\t%s\n", uuid); + uuid_bin_to_str(uuid_bin, uuid, UUID_STR_FORMAT_GUID); + printf("\tguid:\t%s\n", uuid); }
/* Remember to free pte */ @@ -165,7 +165,8 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part, sprintf((char *)info->type, "U-Boot"); info->bootable = is_bootable(&gpt_pte[part - 1]); #ifdef CONFIG_PARTITION_UUIDS - uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); + uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid, + UUID_STR_FORMAT_GUID); #endif
debug("%s: start 0x" LBAF ", size 0x" LBAF ", name %s", __func__, @@ -323,7 +324,7 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e, str_uuid = partitions[i].uuid; bin_uuid = gpt_e[i].unique_partition_guid.b;
- if (uuid_str_to_bin(str_uuid, bin_uuid)) { + if (uuid_str_to_bin(str_uuid, bin_uuid, UUID_STR_FORMAT_STD)) { printf("Partition no. %d: invalid guid: %s\n", i, str_uuid); return -1; @@ -370,7 +371,7 @@ int gpt_fill_header(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_h->header_crc32 = 0; gpt_h->partition_entry_array_crc32 = 0;
- if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b)) + if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b, UUID_STR_FORMAT_GUID)) return -1;
return 0; diff --git a/include/common.h b/include/common.h index b1d1068..658c326 100644 --- a/include/common.h +++ b/include/common.h @@ -816,9 +816,7 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/uuid.c */ -void uuid_bin_to_str(unsigned char *uuid, char *str); -int uuid_str_to_bin(char *uuid, unsigned char *out); -int uuid_str_valid(const char *uuid); +#include <uuid.h>
/* lib/vsprintf.c */ #include <vsprintf.h> diff --git a/include/uuid.h b/include/uuid.h new file mode 100644 index 0000000..0d16038 --- /dev/null +++ b/include/uuid.h @@ -0,0 +1,21 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * Przemyslaw Marczak p.marczak@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __UUID_H__ +#define __UUID_H__ + +typedef enum { + UUID_STR_FORMAT_STD, + UUID_STR_FORMAT_GUID +} uuid_str_t; + +#define UUID_STR_LEN 36 +#define UUID_BIN_LEN 16 + +int uuid_str_valid(const char *uuid); +int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, uuid_str_t format); +void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, uuid_str_t format); +#endif diff --git a/lib/uuid.c b/lib/uuid.c index 03c5b97..75a5608 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -7,8 +7,9 @@ #include <linux/ctype.h> #include <errno.h> #include <common.h> - -#define UUID_STR_LEN 36 +#include <asm/io.h> +#include <part_efi.h> +#include <malloc.h>
/* * UUID - Universally Unique IDentifier - 128 bits unique number. @@ -40,7 +41,6 @@ * * GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique numbers. */ - int uuid_str_valid(const char *uuid) { int i, valid; @@ -59,57 +59,94 @@ int uuid_str_valid(const char *uuid) } }
- if (i != 36 || !valid) + if (i != UUID_STR_LEN || !valid) return 0;
return 1; }
-int uuid_str_to_bin(char *uuid, unsigned char *out) +/* + * uuid_str_to_bin() - convert string UUID or GUID to big endian binary data. + * + * @param uuid_str - pointer to UUID or GUID string [37B] + * @param uuid_bin - pointer to allocated array for big endian output [16B] + * @str_format - UUID string format: 0 - UUID; 1 - GUID + */ +int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, + uuid_str_t str_format) { uint16_t tmp16; uint32_t tmp32; uint64_t tmp64;
- if (!uuid || !out) + if (!uuid_str_valid(uuid_str)) return -EINVAL;
- if (strlen(uuid) != UUID_STR_LEN) - return -EINVAL; + if (str_format == UUID_STR_FORMAT_STD) { + tmp32 = cpu_to_be32(simple_strtoul(uuid_str, NULL, 16)); + memcpy(uuid_bin, &tmp32, 4);
- tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); - memcpy(out, &tmp32, 4); + tmp16 = cpu_to_be16(simple_strtoul(uuid_str + 9, NULL, 16)); + memcpy(uuid_bin + 4, &tmp16, 2);
- tmp16 = cpu_to_le16(simple_strtoul(uuid + 9, NULL, 16)); - memcpy(out + 4, &tmp16, 2); + tmp16 = cpu_to_be16(simple_strtoul(uuid_str + 14, NULL, 16)); + memcpy(uuid_bin + 6, &tmp16, 2); + } else { + tmp32 = cpu_to_le32(simple_strtoul(uuid_str, NULL, 16)); + memcpy(uuid_bin, &tmp32, 4);
- tmp16 = cpu_to_le16(simple_strtoul(uuid + 14, NULL, 16)); - memcpy(out + 6, &tmp16, 2); + tmp16 = cpu_to_le16(simple_strtoul(uuid_str + 9, NULL, 16)); + memcpy(uuid_bin + 4, &tmp16, 2);
- tmp16 = cpu_to_be16(simple_strtoul(uuid + 19, NULL, 16)); - memcpy(out + 8, &tmp16, 2); + tmp16 = cpu_to_le16(simple_strtoul(uuid_str + 14, NULL, 16)); + memcpy(uuid_bin + 6, &tmp16, 2); + } + + tmp16 = cpu_to_be16(simple_strtoul(uuid_str + 19, NULL, 16)); + memcpy(uuid_bin + 8, &tmp16, 2);
- tmp64 = cpu_to_be64(simple_strtoull(uuid + 24, NULL, 16)); - memcpy(out + 10, (char *)&tmp64 + 2, 6); + tmp64 = cpu_to_be64(simple_strtoull(uuid_str + 24, NULL, 16)); + memcpy(uuid_bin + 10, (char *)&tmp64 + 2, 6);
return 0; }
-void uuid_bin_to_str(unsigned char *uuid, char *str) +/* + * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. + * + * @param uuid_bin - pointer to binary data of UUID (big endian) [16B] + * @param uuid_str - pointer to allocated array for output string [37B] + * @str_format - UUID string format: 0 - UUID; 1 - GUID + */ +void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, + uuid_str_t str_format) { - static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, - 12, 13, 14, 15}; + const u8 uuid_char_order[UUID_BIN_LEN] = {0, 1, 2, 3, 4, 5, 6, 7, 8, + 9, 10, 11, 12, 13, 14, 15}; + const u8 guid_char_order[UUID_BIN_LEN] = {3, 2, 1, 0, 5, 4, 7, 6, 8, + 9, 10, 11, 12, 13, 14, 15}; + const u8 *char_order; int i;
+ /* + * UUID and GUID bin data - always in big endian: + * 4B-2B-2B-2B-6B + * be be be be be + */ + if (str_format == UUID_STR_FORMAT_STD) + char_order = uuid_char_order; + else + char_order = guid_char_order; + for (i = 0; i < 16; i++) { - sprintf(str, "%02x", uuid[le[i]]); - str += 2; + sprintf(uuid_str, "%02x", uuid_bin[char_order[i]]); + uuid_str += 2; switch (i) { case 3: case 5: case 7: case 9: - *str++ = '-'; + *uuid_str++ = '-'; break; } }
In message 1395251911-26540-2-git-send-email-p.marczak@samsung.com you wrote:
- uuid_str_to_bin()
- uuid_bin_to_str()
Checkpatch says:
WARNING: do not add new typedefs #199: FILE: include/uuid.h:10: +typedef enum {
WARNING: line over 80 characters #209: FILE: include/uuid.h:20: +void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, uuid_str_t format);
Please fix.
- uuid_str_to_bin()
- uuid_bin_to_str()
Ah, this patch pretty much solves all the comments I had on patch 1/6, so feel free to ignore those.
Just a couple minor points below, but otherwise, patches 1 and 2, Acked-by: Stephen Warren swarren@nvidia.com
+typedef enum {
- UUID_STR_FORMAT_STD,
- UUID_STR_FORMAT_GUID
+} uuid_str_t;
I would rename "STD" to "UUID"; after all, someone wanting to use GUIDs might think /that/ is the standard format:-)
But this is a bit bike-sheddy/nit-picky, so if you don't want to I won't object.
12, 13, 14, 15};
- const u8 uuid_char_order[UUID_BIN_LEN] = {0, 1, 2, 3, 4, 5, 6, 7, 8,
- const u8 guid_char_order[UUID_BIN_LEN] = {3, 2, 1, 0, 5, 4, 7, 6, 8,
These are really more binary data order than char order, since each one of the bytes pointed at by entries in these arrays ends up being 2 characters. s/char/bin/ in the variable names perhaps?
* 4B-2B-2B-2B-6B
* be be be be be
Strings don't really have an endianness, since they're already byte data. Rather than endianness, you really mean "normal numerical digit ordering". This comment also applies to the description of UUID string formats in patch 1/6.
Hello Stephen, Thanks for review again:)
- uuid_str_to_bin()
- uuid_bin_to_str()
Ok, thank you.
+typedef enum {
+} uuid_str_t;
Actually I think that UUID_STR_FORMAT_UUID gives no information that this the main format of UUID, so I prefer to leave STD.
{uuid_str_t str_format)
12, 13, 14, 15};
Yes, you are right. But according to the specification UUID and UUID bin format are always in big-endian - only bytes in some STRING blocks have different order. This works in two ways but to be consistent with specification I called this as "uuid_char_order". And this is directly used by sprintf: "sprintf(uuid_str, "%02x", uuid_bin[char_order[i]]);".
* 4B-2B-2B-2B-6B
* be be be be be
Right but the comment above says about "bin" data (16B len).
Thanks
- uuid_str_to_bin()
- uuid_bin_to_str()
12, 13, 14, 15};
7, 8,
6, 8,
That doesn't make much sense.
If I have 2 bytes stored in memory as:
0xaa 0x55
... and sometimes the string representation of them is aa55 and sometimes 55aa, then *by definition*, that's interpreting the binary data as BE vs LE. The binary data is not always BE.
The only exception would be if for bytes in memory 0xaa 0x55 the 16-bit integer/numerical (in-register) value was always 0xaa55 (BE), yet the string representation of that integer was sometimes aa55 and sometimes 55aa. However, that's not how integer->string conversion works. Different string representations of the binary data would only be possible if the binary data isn't an integer but rather a string of bytes, yet endianness has no meaning for data that is natively a string of bytes, only for larger values that have been serialized into a string of bytes.
Source: https://www.ietf.org/rfc/rfc4122.txt
lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representati UUID v4 to the memory at given address.
Changes v3: - remove unused UUID_STR_BYTE_LEN - reword comments - remove null pointer checking from gen_rand_uuid() and gen_rand_uuid_str() - remove unneeded memset from gen_rand_uuid() - undo moving vsprintf.o object in lib/Makefile - add attribute "packed" to the uuid structure - gen_rand_uuid(): add endian functions for modify uuid data - gen_rand_uuid(): use memcpy() to store uuid data into given buffer for avoi unaligned access issues - change uuid version and variant masks to proper for use with clrsetbits_* - add #ifdef CONFIG_RANDOM_UUID to random uuid code for avoid warnings
Changes v4: - add new parameter to define UUID string format for UUID or GUID which differs in endianness of first three string blocks. - add uuid structure and version 4 data to uuid header file - lib/Makefile: add CONFIG_RAND_UUID dependency to rand.o and uuid.o --- include/common.h | 3 ++- include/uuid.h | 22 ++++++++++++++++++- lib/Makefile | 2 ++ lib/uuid.c | 65 ++++++++++++++++++++++++++++++++++++++++++++++++++++++-- 4 files changed, 88 insertions(+), 4 deletions(-)
diff --git a/include/common.h b/include/common.h index 658c326..deb08f2 100644 --- a/include/common.h +++ b/include/common.h @@ -830,7 +830,8 @@ char * strmhz(char *buf, unsigned long hz); /* lib/rand.c */ #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ - defined(CONFIG_CMD_LINK_LOCAL) + defined(CONFIG_CMD_LINK_LOCAL) || \ + defined(CONFIG_RANDOM_UUID) #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/include/uuid.h b/include/uuid.h index 0d16038..32e592c 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -7,15 +7,35 @@ #ifndef __UUID_H__ #define __UUID_H__
+/* This is structure is in big-endian */ +struct uuid { + unsigned int time_low; + unsigned short time_mid; + unsigned short time_hi_and_version; + unsigned char clock_seq_hi_and_reserved; + unsigned char clock_seq_low; + unsigned char node[6]; +} __packed; + typedef enum { UUID_STR_FORMAT_STD, UUID_STR_FORMAT_GUID } uuid_str_t;
#define UUID_STR_LEN 36 -#define UUID_BIN_LEN 16 +#define UUID_BIN_LEN sizeof(struct uuid) + +#define UUID_VERSION_MASK 0xf000 +#define UUID_VERSION_SHIFT 12 +#define UUID_VERSION 0x4 + +#define UUID_VARIANT_MASK 0xc0 +#define UUID_VARIANT_SHIFT 7 +#define UUID_VARIANT 0x1
int uuid_str_valid(const char *uuid); int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, uuid_str_t format); void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, uuid_str_t format); +void gen_rand_uuid(unsigned char *uuid_bin); +void gen_rand_uuid_str(char *uuid_str, uuid_str_t format); #endif diff --git a/lib/Makefile b/lib/Makefile index 2e8bd20..fd75e80 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -63,6 +63,8 @@ obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o +obj-$(CONFIG_RANDOM_UUID) += uuid.o +obj-$(CONFIG_RANDOM_UUID) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index 75a5608..d3ba60e 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -14,8 +14,23 @@ /* * UUID - Universally Unique IDentifier - 128 bits unique number. * There are 5 versions and one variant of UUID defined by RFC4122 - * specification. Depends on version uuid number base on a time, - * host name, MAC address or random data. + * specification. Depends on version uuid number base on: + * - time, MAC address(v1), + * - user ID(v2), + * - MD5 of name or URL(v3), + * - random data(v4), + * - SHA-1 of name or URL(v5), + * + * This library implements UUID v4. + * + * Layout of UUID Version 4: + * timestamp - 60-bit: time_low, time_mid, time_hi_and_version + * version - 4 bit (bit 4 through 7 of the time_hi_and_version) + * clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low + * variant: - bit 6 and 7 of clock_seq_hi_and_reserved + * node - 48 bit + * In this version all fields beside 4 bit version are randomly generated. + * source: https://www.ietf.org/rfc/rfc4122.txt * * UUID binary format (16 bytes): * @@ -151,3 +166,49 @@ void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, } } } + +/* + * gen_rand_uuid() - this function generates a random binary UUID v4. + * + * @param uuid_bin - pointer to allocated array [16B]. Output is in big endian. +*/ +#ifdef CONFIG_RANDOM_UUID +void gen_rand_uuid(unsigned char *uuid_bin) +{ + struct uuid uuid; + unsigned int *ptr = (unsigned int *)&uuid; + int i; + + /* Set all fields randomly */ + for (i = 0; i < sizeof(struct uuid) / sizeof(*ptr); i++) + *(ptr + i) = cpu_to_be32(rand()); + + clrsetbits_be16(&uuid.time_hi_and_version, + UUID_VERSION_MASK, + UUID_VERSION << UUID_VERSION_SHIFT); + + clrsetbits_8(&uuid.clock_seq_hi_and_reserved, + UUID_VARIANT_MASK, + UUID_VARIANT << UUID_VARIANT_SHIFT); + + memcpy(uuid_bin, &uuid, sizeof(struct uuid)); +} + +/* + * gen_rand_uuid_str() - this function generates UUID v4 (random) in two string + * formats UUID or GUID. + * + * @param uuid_str - pointer to allocated array [37B]. + * @param - uuid output type: UUID - 0, GUID - 1 + */ +void gen_rand_uuid_str(char *uuid_str, uuid_str_t str_format) +{ + unsigned char uuid_bin[UUID_BIN_LEN]; + + /* Generate UUID (big endian) */ + gen_rand_uuid(uuid_bin); + + /* Convert UUID bin to UUID or GUID formated STRING */ + uuid_bin_to_str(uuid_bin, uuid_str, str_format); +} +#endif
Some nits in the comments below, but otherwise: Acked-by: Stephen Warren swarren@nvidia.com
Not any more; with the introduction of enum uuid_str_t, some of the fields could be either LE or BE. I would say "See the comment near the top of lib/uuid.c for details of the endianness of fields in this struct".
- UUID - Universally Unique IDentifier - 128 bits unique number.
I still have no idea what "Depends on version uuid number base on" means.
- user ID(v2),
- random data(v4),
- This library implements UUID v4.
I think that should say "gen_rand_uuid()" not "This library", since the source of the data in the UUID fields only matters when creating the UUID, not when performing str<->bin conversion.
- node - 48 bit
gen_rand_uuid() doesn't actually honor that format; it creates pure random data rather than filling in any timestamps, clock sequence data, etc.
Hello Stephen,
No, those fields are always in big-endian. So no matter what is architecture endianess - this data should be stored as big endian. Only string representation has different character order for GUID.
It means that each UUID version "result" depends on different source data, as listed here...
- user ID(v2),
- random data(v4),
Yes, right notice.
I should remove "Version 4" in the comment subject, because layout refers to all uuid versions.
- node - 48 bit
Actually, yes but two fields are NOT set randomly, and this is what comment includes: "In this version all fields beside 4 bit version are randomly generated." Moreover the gen_rand_uuid() respects endianess for setting bits, and this could be checked on linux host by "uuid -d uboot_uuid_string" in shell.
Thanks
How bout replacing that sentence with:
A UUID contains a set of fields. The set varies depending on the version of the UUID, as shown below:
- user ID(v2),
- random data(v4),
- node - 48 bit
While it's true that some fields are set non-randomly, most aren't; you really can't claim that e.g. placing random data in the timestamp field is a valid timestamp.
Ok, no problem.
- user ID(v2),
- random data(v4),
- timestamp - 60-bit: time_low, time_mid, time_hi_and_version
- version - 4 bit (bit 4 through 7 of the time_hi_and_version)
- clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low
- variant: - bit 6 and 7 of clock_seq_hi_and_reserved
- node - 48 bit
- In this version all fields beside 4 bit version are randomly generated.
As I said before, I will remove the "version 4" from the comment head because the layout is valid for all uuid versions. So we can take into account the meaning of each field only after checking the version of uuid first.
Thanks
Those commands basis on implementation of random UUID generator version 4 which is described in RFC4122. The same algorithm is used for generation both ids but string representation is different as below.
char: 0 9 14 19 24 36 xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx UUID: be be be be be GUID: le le le be be
Commands usage: - uuid <varname(optional)> - guid <varname(optional)>
The result is saved in environment as a "varname" variable if argument is given, if not then its printed.
New config: - CONFIG_CMD_UUID
--- Changes v4: - new commit --- README | 2 +- include/common.h | 4 +++- lib/Makefile | 2 ++ lib/uuid.c | 44 +++++++++++++++++++++++++++++++++++++++++++- 4 files changed, 49 insertions(+), 3 deletions(-)
diff --git a/README b/README index 216f0c7..f69b94e 100644 --- a/README +++ b/README @@ -1012,7 +1012,7 @@ The following options need to be configured: CONFIG_CMD_CDP * Cisco Discover Protocol support CONFIG_CMD_MFSL * Microblaze FSL support CONFIG_CMD_XIMG Load part of Multi Image - + CONFIG_CMD_UUID * Generate random UUID or GUID string
EXAMPLE: If you want all functions except of network support you can write: diff --git a/include/common.h b/include/common.h index deb08f2..de748f1 100644 --- a/include/common.h +++ b/include/common.h @@ -831,7 +831,9 @@ char * strmhz(char *buf, unsigned long hz); #if defined(CONFIG_RANDOM_MACADDR) || \ defined(CONFIG_BOOTP_RANDOM_DELAY) || \ defined(CONFIG_CMD_LINK_LOCAL) || \ - defined(CONFIG_RANDOM_UUID) + defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_CMD_UUID) + #define RAND_MAX -1U void srand(unsigned int seed); unsigned int rand(void); diff --git a/lib/Makefile b/lib/Makefile index fd75e80..b85c825 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -65,6 +65,8 @@ obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_RANDOM_UUID) += uuid.o obj-$(CONFIG_RANDOM_UUID) += rand.o +obj-$(CONFIG_CMD_UUID) += uuid.o +obj-$(CONFIG_CMD_UUID) += rand.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o diff --git a/lib/uuid.c b/lib/uuid.c index d3ba60e..0112b03 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> #include <linux/ctype.h> #include <errno.h> #include <common.h> @@ -172,7 +173,7 @@ void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, * * @param uuid_bin - pointer to allocated array [16B]. Output is in big endian. */ -#ifdef CONFIG_RANDOM_UUID +#if defined(CONFIG_RANDOM_UUID) || defined(CONFIG_CMD_UUID) void gen_rand_uuid(unsigned char *uuid_bin) { struct uuid uuid; @@ -211,4 +212,45 @@ void gen_rand_uuid_str(char *uuid_str, uuid_str_t str_format) /* Convert UUID bin to UUID or GUID formated STRING */ uuid_bin_to_str(uuid_bin, uuid_str, str_format); } + +#ifdef CONFIG_CMD_UUID +int do_uuid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char uuid[UUID_STR_LEN + 1]; + uuid_str_t str_format; + + if (!strcmp(argv[0], "uuid")) + str_format = UUID_STR_FORMAT_STD; + else + str_format = UUID_STR_FORMAT_GUID; + + if (argc == 1) { + gen_rand_uuid_str(uuid, str_format); + printf("%s\n", uuid); + } else if (argc == 2) { + gen_rand_uuid_str(uuid, str_format); + setenv(argv[1], uuid); + } else { + return CMD_RET_USAGE; + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(uuid, CONFIG_SYS_MAXARGS, 1, do_uuid, + "UUID - generate Universally Unique Identifier version 4", + "<varname(optional)>\n" + "Argument:\n" + "varname: for set result in a environment variable\n" + "e.g. uuid uuid_env" +); + +U_BOOT_CMD(guid, CONFIG_SYS_MAXARGS, 1, do_uuid, + "GUID - generate Globally Unique Identifier based on UUID version 4", + "<varname(optional)>\n" + "Argument:\n" + "varname: for set result in a environment variable\n" + "e.g. guid guid_env" +); +#endif #endif
Commands usage:
Square brackets are usually used to indicate optional parameters:
- uuid [<varname>] - guid [<varname>]
- defined(CONFIG_RANDOM_UUID) || \
- defined(CONFIG_CMD_UUID)
Why not require that if you want to use CONFIG_CMD_UUID, you must define CONFIG_RANDOM_UUID too? You can even make that automatic in include/config_fallbacks.h which already does similar things:
#if defined(CONFIG_CMD_FAT) && !defined(CONFIG_FS_FAT) #define CONFIG_FS_FAT #endif
That way, you won't need to touch lib/Makefile in this patch either, or modify the ifdef that wraps gen_rand_uuid().
- char uuid[UUID_STR_LEN + 1];
- uuid_str_t str_format;
- if (!strcmp(argv[0], "uuid"))
- else
- if (argc == 1) {
- } else if (argc == 2) {
- } else {
This duplicates some code; the call to gen_rand_uuid(). I think it would be better as:
if (argc < 2) return CMD_RET_USAGE; gen_rand_uuid_str(uuid, str_format); if (argc == 1) printf("%s\n", uuid); else setenv(argv[1], uuid);
- "UUID - generate Universally Unique Identifier version 4",
Would it be batter to say "a random ..." rather than "... version 4"? I'm not sure if the details of the version matter so long as its a valid UUID, and certainly the fact the generated UUID is random is likely more interesting.
- "<varname(optional)>\n"
"[<varname>]\n"
Hello Stephen,
Commands usage:
- uuid [<varname>]
- guid [<varname>]
Ok, I change this.
I change this part of code in one of my other patch set which can be found here: http://patchwork.ozlabs.org/patch/332499/ After apply those changes then I add some automation here.
- else
- if (argc == 1) {
- } else {
Yes, this is better, but the first condition should be as: if ((argc != 1) || (argc != 2))
"[<varname>]\n"
Ok, I also apply those two commands above.
Thanks
On 03/26/2014 06:01 AM, Przemyslaw Marczak wrote:
Hello Stephen,
OK. It seems better to get the code right when first introduced, but as long as it gets simplified, I guess that's fine.
s/||/&&/
Hello Stephen,
s/||/&&/
Ah, my mistake. This should be as: if (argc > 2) return CMD_RET_USAGE;
since argc value could be only "1" or only "2".
Thanks
Changes: - randomly generate partition uuid if any is undefined and CONFIG_RAND_UUID is defined - print debug info about set/unset/generated uuid - update doc/README.gpt
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Tom Rini trini@ti.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com
Changes v4: - change printf/puts to debug - reduce indentation level in extract_env() - generate rand uuid if CONFIG_RAND_UUID is defined --- common/cmd_gpt.c | 62 +++++++++++++++++++++++++++++++++++++++++--------------- doc/README.gpt | 24 ++++++++++++++++------ lib/uuid.c | 4 ++-- 3 files changed, 66 insertions(+), 24 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 1f12e6d..4048b77 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -29,30 +29,52 @@ * * @return - zero on successful expand and env is set */ -static char extract_env(const char *str, char **env) +static int extract_env(const char *str, char **env) { + int ret = -1; char *e, *s; - +#ifdef CONFIG_RANDOM_UUID + char uuid_str[UUID_STR_LEN + 1]; +#endif if (!str || strlen(str) < 4) return -1;
- if ((strncmp(str, "${", 2) == 0) && (str[strlen(str) - 1] == '}')) { - s = strdup(str); - if (s == NULL) - return -1; - memset(s + strlen(s) - 1, '\0', 1); - memmove(s, s + 2, strlen(s) - 1); + if (!((strncmp(str, "${", 2) == 0) && (str[strlen(str) - 1] == '}'))) + return -1; + + s = strdup(str); + if (s == NULL) + return -1; + + memset(s + strlen(s) - 1, '\0', 1); + memmove(s, s + 2, strlen(s) - 1); + + e = getenv(s); + if (e == NULL) { +#ifdef CONFIG_RANDOM_UUID + debug("%s unset. ", str); + gen_rand_uuid_str(uuid_str, UUID_STR_FORMAT_STD); + setenv(s, uuid_str); + e = getenv(s); - free(s); - if (e == NULL) { - printf("Environmental '%s' not set\n", str); - return -1; /* env not set */ + if (e) { + debug("Set to random.\n"); + ret = 0; + } else { + debug("Can't get random UUID.\n"); } - *env = e; - return 0; +#else + debug("%s unset.\n", str); +#endif + } else { + debug("%s get from environment.\n", str); + ret = 0; }
- return -1; + *env = e; + free(s); + + return ret; }
/** @@ -299,8 +321,16 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE; }
- if (gpt_default(blk_dev_desc, argv[4])) + puts("Writing GPT: "); + + ret = gpt_default(blk_dev_desc, argv[4]); + if (!ret) { + puts("success!\n"); + return CMD_RET_SUCCESS; + } else { + puts("error!\n"); return CMD_RET_FAILURE; + } } else { return CMD_RET_USAGE; } diff --git a/doc/README.gpt b/doc/README.gpt index 5c133f3..51515c8 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -101,7 +101,7 @@ Offset Size Description 40 8 B First usable LBA for partitions (primary partition table last LBA + 1) 48 8 B Last usable LBA (secondary partition table first LBA - 1) -56 16 B Disk GUID (also referred as UUID on UNIXes) +56 16 B Disk GUID (also referred as UUID on UNIXes) in big endian 72 8 B Partition entries starting LBA (always 2 in primary copy) 80 4 B Number of partition entries 84 4 B Size of a partition entry (usually 128) @@ -132,8 +132,8 @@ of the Primary. ---------------------- Offset Size Description
- 0 16 B Partition type GUID - 16 16 B Unique partition GUID + 0 16 B Partition type GUID (Big Endian) + 16 16 B Unique partition GUID in (Big Endian) 32 8 B First LBA (Little Endian) 40 8 B Last LBA (inclusive) 48 8 B Attribute flags [+] @@ -160,6 +160,9 @@ To restore GUID partition table one needs to: Fields 'name', 'size' and 'uuid' are mandatory for every partition. The field 'start' is optional.
+ option: CONFIG_RANDOM_UUID + If any partition "uuid" no exists then it is randomly generated. + 2. Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT'
2. From u-boot prompt type: @@ -168,11 +171,20 @@ To restore GUID partition table one needs to: Useful info: ============
-Two programs, namely: 'fdisk' and 'parted' are recommended to work with GPT -recovery. Parted is able to handle GUID partitions. Unfortunately the 'fdisk' -hasn't got such ability. +Two programs, namely: 'gdisk' and 'parted' are recommended to work with GPT +recovery. Both are able to handle GUID partitions. Please, pay attention at -l switch for parted.
"uuid" program is recommended to generate UUID string. Moreover it can decode (-d switch) passed in UUID string. It can be used to generate partitions UUID passed to u-boot environment variables. +If optional CONFIG_RANDOM_UUID is defined then for any partition which environment +uuid is unset, uuid is randomly generated and stored in correspond environment +variable. + +note: +Each string block of UUID generated by program "uuid" is in big endian and it is +also stored in big endian in disk GPT. +Partitions layout can be printed by typing "mmc part". Note that each partition +GUID has different byte order than UUID generated before, this is because first +three blocks of GUID string are in Little Endian. diff --git a/lib/uuid.c b/lib/uuid.c index 0112b03..a15fd0d 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -252,5 +252,5 @@ U_BOOT_CMD(guid, CONFIG_SYS_MAXARGS, 1, do_uuid, "varname: for set result in a environment variable\n" "e.g. guid guid_env" ); -#endif -#endif +#endif /* CONFIG_CMD_UUID */ +#endif /* CONFIG_RANDOM_UUID || CONFIG_CMD_UUID */
Changes:
The changelog should be below the --- line, and a patch description should exist.
Assuming the comments below are fixed, Acked-by: Stephen Warren swarren@nvidia.com
- char uuid_str[UUID_STR_LEN + 1];
The blank line needs to be after the #endif not before the #ifdef, so the variable declarations are separate from the code.
return -1;
s = strdup(str);
if (s == NULL)
return -1;
- if (!((strncmp(str, "${", 2) == 0) && (str[strlen(str) - 1] == '}')))
return -1;
Since you're inverting that test, you need to change && to || too.
According to your earlier comment, GUIDs have a mix of LE and BE fields, so I would simply drop this change and the similar change below. Let wikipedia or the comment you added near to top of lib/uuid.c specify the details.
- option: CONFIG_RANDOM_UUID
- If any partition "uuid" no exists then it is randomly generated.
s/"uuid"/UUID/
Hello Stephen,
Changes:
This is the patch description:) and there is also change log below "---", but okay I can make some edits.
Ok.
return -1;
s = strdup(str);
if (s == NULL)
return -1;
return -1;
No, because the invertion refers to the result of "if" - not one of conditions. !(cond1 && cond2) is the same as: (!cond1 || !cond2) so this change is ok.
Actually I think that this is an important info here. The information about endianness is also placed in few places in lib/uuid.c
s/"uuid"/UUID/
Ok.
Thanks
Changes:
s = strdup(str);
if (s == NULL)
return -1;
return -1;
Ah yes, right.
Why isn't the endianness of all the fields in this structure defined in this comment then?
Changes:
s = strdup(str);
if (s == NULL)
return -1;
return -1;
Ah yes, right.
Right notice, I will add there more info.
Thanks
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: trini@ti.com --- include/configs/trats.h | 1 + include/configs/trats2.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/include/configs/trats.h b/include/configs/trats.h index 7cea259..30a978c 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -276,6 +276,7 @@ /* GPT */ #define CONFIG_EFI_PARTITION #define CONFIG_PARTITION_UUIDS +#define CONFIG_RANDOM_UUID
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_CACHELINE_SIZE 32 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 6d389df..df98b70 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -283,6 +283,7 @@ #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ #define CONFIG_EFI_PARTITION #define CONFIG_PARTITION_UUIDS +#define CONFIG_RANDOM_UUID
#define CONFIG_BOARD_EARLY_INIT_F
Patch description? Why are these function useful on these platforms?
For completeness (I have no real ack power of Samsung platforms), Acked-by: Stephen Warren swarren@nvidia.com
Hello Stephen,
Ok, I add some more description. And thank you for review.
Regards
Dear Przemyslaw Marczak,
In message 1395251911-26540-1-git-send-email-p.marczak@samsung.com you wrote:
Changes:
Please make sure to run your patches through checkpatch. Here I get this:
WARNING: line over 80 characters #331: FILE: lib/uuid.c:41: + * GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique numbers.
Please fix.
Hello,
Changes:
- GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique numbers.
Please fix.
Sorry for this. I will fix it in next patchset. Are other changes acceptable?
Thank you,
Changes:
- UUID string is 36 length of characters (36 bytes):
- 0 9 14 19 24
- xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
- be be be be be
- GUID:
- 0 9 14 19 24
- le le le be be
Given that ...
12, 13, 14, 15};
Should this actually be named uuid_bin_to_guid_str or guid_bin_to_str?
And "le" doesn't seem like the correct variable name, since it's actually a mix of 3 LE and 2 BE conversions, isn't it?
This commit introduces cleanup for uuid library. Changes: - move uuid<->string conversion functions into lib/uuid.c so they can be used by code outside part_efi.c. - rename uuid_string() to uuid_bin_to_str() for consistency with existing uuid_str_to_bin() - add an error return code to uuid_str_to_bin() - update existing code to the new library functions.
--- Changes v2: - This commit is new after separate: [PATCH 1/2] lib: uuid: add function to generate UUID version 4 - it introduces small refactor of common lib uuid functions
Changes v5: - none --- disk/part_efi.c | 90 +++++++------------------------------------------------- include/common.h | 3 +- lib/Makefile | 1 + lib/uuid.c | 61 +++++++++++++++++++++++++++++++++----- 4 files changed, 68 insertions(+), 87 deletions(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 733d5bd..a280ab5 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -63,26 +63,6 @@ static char *print_efiname(gpt_entry *pte) return name; }
-static void uuid_string(unsigned char *uuid, char *str) -{ - static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, - 12, 13, 14, 15}; - int i; - - for (i = 0; i < 16; i++) { - sprintf(str, "%02x", uuid[le[i]]); - str += 2; - switch (i) { - case 3: - case 5: - case 7: - case 9: - *str++ = '-'; - break; - } - } -} - static efi_guid_t system_guid = PARTITION_SYSTEM_GUID;
static inline int is_bootable(gpt_entry *p) @@ -103,6 +83,7 @@ void print_part_efi(block_dev_desc_t * dev_desc) gpt_entry *gpt_pte = NULL; int i = 0; char uuid[37]; + unsigned char *uuid_bin;
if (!dev_desc) { printf("%s: Invalid Argument(s)\n", __func__); @@ -132,9 +113,11 @@ void print_part_efi(block_dev_desc_t * dev_desc) le64_to_cpu(gpt_pte[i].ending_lba), print_efiname(&gpt_pte[i])); printf("\tattrs:\t0x%016llx\n", gpt_pte[i].attributes.raw); - uuid_string(gpt_pte[i].partition_type_guid.b, uuid); + uuid_bin = (unsigned char *)gpt_pte[i].partition_type_guid.b; + uuid_bin_to_str(uuid_bin, uuid); printf("\ttype:\t%s\n", uuid); - uuid_string(gpt_pte[i].unique_partition_guid.b, uuid); + uuid_bin = (unsigned char *)gpt_pte[i].unique_partition_guid.b; + uuid_bin_to_str(uuid_bin, uuid); printf("\tuuid:\t%s\n", uuid); }
@@ -182,7 +165,7 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part, sprintf((char *)info->type, "U-Boot"); info->bootable = is_bootable(&gpt_pte[part - 1]); #ifdef CONFIG_PARTITION_UUIDS - uuid_string(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); + uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); #endif
debug("%s: start 0x" LBAF ", size 0x" LBAF ", name %s", __func__, @@ -237,60 +220,6 @@ static int set_protective_mbr(block_dev_desc_t *dev_desc) return 0; }
-/** - * string_uuid(); Convert UUID stored as string to bytes - * - * @param uuid - UUID represented as string - * @param dst - GUID buffer - * - * @return return 0 on successful conversion - */ -static int string_uuid(char *uuid, u8 *dst) -{ - efi_guid_t guid; - u16 b, c, d; - u64 e; - u32 a; - u8 *p; - u8 i; - - const u8 uuid_str_len = 36; - - /* The UUID is written in text: */ - /* 1 9 14 19 24 */ - /* xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx */ - - debug("%s: uuid: %s\n", __func__, uuid); - - if (strlen(uuid) != uuid_str_len) - return -1; - - for (i = 0; i < uuid_str_len; i++) { - if ((i == 8) || (i == 13) || (i == 18) || (i == 23)) { - if (uuid[i] != '-') - return -1; - } else { - if (!isxdigit(uuid[i])) - return -1; - } - } - - a = (u32)simple_strtoul(uuid, NULL, 16); - b = (u16)simple_strtoul(uuid + 9, NULL, 16); - c = (u16)simple_strtoul(uuid + 14, NULL, 16); - d = (u16)simple_strtoul(uuid + 19, NULL, 16); - e = (u64)simple_strtoull(uuid + 24, NULL, 16); - - p = (u8 *) &e; - guid = EFI_GUID(a, b, c, d >> 8, d & 0xFF, - *(p + 5), *(p + 4), *(p + 3), - *(p + 2), *(p + 1) , *p); - - memcpy(dst, guid.b, sizeof(efi_guid_t)); - - return 0; -} - int write_gpt_table(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_entry *gpt_e) { @@ -358,6 +287,7 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e, size_t efiname_len, dosname_len; #ifdef CONFIG_PARTITION_UUIDS char *str_uuid; + unsigned char *bin_uuid; #endif
for (i = 0; i < parts; i++) { @@ -391,7 +321,9 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e,
#ifdef CONFIG_PARTITION_UUIDS str_uuid = partitions[i].uuid; - if (string_uuid(str_uuid, gpt_e[i].unique_partition_guid.b)) { + bin_uuid = gpt_e[i].unique_partition_guid.b; + + if (uuid_str_to_bin(str_uuid, bin_uuid)) { printf("Partition no. %d: invalid guid: %s\n", i, str_uuid); return -1; @@ -438,7 +370,7 @@ int gpt_fill_header(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_h->header_crc32 = 0; gpt_h->partition_entry_array_crc32 = 0;
- if (string_uuid(str_guid, gpt_h->disk_guid.b)) + if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b)) return -1;
return 0; diff --git a/include/common.h b/include/common.h index 072a1e1..c48c696 100644 --- a/include/common.h +++ b/include/common.h @@ -822,7 +822,8 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/uuid.c */ -void uuid_str_to_bin(const char *uuid, unsigned char *out); +void uuid_bin_to_str(unsigned char *uuid, char *str); +int uuid_str_to_bin(char *uuid, unsigned char *out); int uuid_str_valid(const char *uuid);
/* lib/vsprintf.c */ diff --git a/lib/Makefile b/lib/Makefile index ae80865..d7ff7ca 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -61,6 +61,7 @@ obj-y += string.o obj-y += time.o obj-$(CONFIG_TRACE) += trace.o obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-$(CONFIG_PARTITION_UUIDS) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_LIB_RAND) += rand.o
diff --git a/lib/uuid.c b/lib/uuid.c index c48bf38..3af3a7d 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -5,18 +5,40 @@ */
/* - * This is what a UUID string looks like. + * UUID - Universally Unique IDentifier - 128 bits unique number. + * There are 5 versions and one variant of UUID defined by RFC4122 + * specification. Depends on version uuid number base on a time, + * host name, MAC address or random data. + * + * UUID binary format (16 bytes): + * + * 4B-2B-2B-2B-6B (big endian - network byte order) + * + * UUID string is 36 length of characters (36 bytes): + * + * 0 9 14 19 24 + * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx + * be be be be be + * + * where x is a hexadecimal character. Fields are separated by '-'s. + * When converting to a binary UUID, le means the field should be converted + * to little endian and be means it should be converted to big endian. * - * x is a hexadecimal character. fields are separated by '-'s. When converting - * to a binary UUID, le means the field should be converted to little endian, - * and be means it should be converted to big endian. + * UUID is also used as GUID (Globally Unique Identifier) with the same binary + * format but it differs in string format like below. * + * GUID: * 0 9 14 19 24 * xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx * le le le be be + * + * GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique id. */
-void uuid_str_to_bin(const char *uuid, unsigned char *out) +int uuid_str_to_bin(char *uuid, unsigned char *out) { uint16_t tmp16; uint32_t tmp32; uint64_t tmp64;
if (!uuid || !out) - return; + return -EINVAL; + + if (strlen(uuid) != UUID_STR_LEN) + return -EINVAL;
Changes v5: - update file: net/bootp.c - remove previous added uuid_str_t typedef --- disk/part_efi.c | 17 ++++++------ include/common.h | 4 +-- include/uuid.h | 21 ++++++++++++++ lib/uuid.c | 83 ++++++++++++++++++++++++++++++++++++++++---------------- net/bootp.c | 2 +- 5 files changed, 91 insertions(+), 36 deletions(-) create mode 100644 include/uuid.h
return 0; diff --git a/include/common.h b/include/common.h index c48c696..cbd3c9e 100644 --- a/include/common.h +++ b/include/common.h @@ -822,9 +822,7 @@ void udelay (unsigned long); void mdelay(unsigned long);
/* lib/vsprintf.c */ #include <vsprintf.h> diff --git a/include/uuid.h b/include/uuid.h new file mode 100644 index 0000000..e8feeed --- /dev/null +++ b/include/uuid.h @@ -0,0 +1,21 @@ +/* + * Copyright (C) 2014 Samsung Electronics + * Przemyslaw Marczak p.marczak@samsung.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __UUID_H__ +#define __UUID_H__ + +enum { + UUID_STR_FORMAT_STD, + UUID_STR_FORMAT_GUID +}; + +#define UUID_STR_LEN 36 +#define UUID_BIN_LEN 16 + +int uuid_str_valid(const char *uuid); +int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, int str_format); +void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, int str_format); +#endif diff --git a/lib/uuid.c b/lib/uuid.c index 3af3a7d..8db865f 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -7,8 +7,9 @@ #include <linux/ctype.h> #include <errno.h> #include <common.h> - -#define UUID_STR_LEN 36 +#include <asm/io.h> +#include <part_efi.h> +#include <malloc.h>
/* * UUID - Universally Unique IDentifier - 128 bits unique number. @@ -40,7 +41,6 @@ * * GUID is used e.g. in GPT (GUID Partition Table) as a partiions unique id. */ - int uuid_str_valid(const char *uuid) { int i, valid; @@ -59,57 +59,92 @@ int uuid_str_valid(const char *uuid) } }
return 1; }
-int uuid_str_to_bin(char *uuid, unsigned char *out) +/* + * uuid_str_to_bin() - convert string UUID or GUID to big endian binary data. + * + * @param uuid_str - pointer to UUID or GUID string [37B] + * @param uuid_bin - pointer to allocated array for big endian output [16B] + * @str_format - UUID string format: 0 - UUID; 1 - GUID + */ +int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, int str_format) { uint16_t tmp16; uint32_t tmp32; uint64_t tmp64;
return 0; }
-void uuid_bin_to_str(unsigned char *uuid, char *str) +/* + * uuid_bin_to_str() - convert big endian binary data to string UUID or GUID. + * + * @param uuid_bin - pointer to binary data of UUID (big endian) [16B] + * @param uuid_str - pointer to allocated array for output string [37B] + * @str_format - UUID string format: 0 - UUID; 1 - GUID + */ +void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, int str_format) { - static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, - 12, 13, 14, 15}; + const u8 uuid_char_order[UUID_BIN_LEN] = {0, 1, 2, 3, 4, 5, 6, 7, 8, + 9, 10, 11, 12, 13, 14, 15}; + const u8 guid_char_order[UUID_BIN_LEN] = {3, 2, 1, 0, 5, 4, 7, 6, 8, + 9, 10, 11, 12, 13, 14, 15}; + const u8 *char_order; int i;
+ /* + * UUID and GUID bin data - always in big endian: + * 4B-2B-2B-2B-6B + * be be be be be + */ + if (str_format == UUID_STR_FORMAT_STD) + char_order = uuid_char_order; + else + char_order = guid_char_order; + for (i = 0; i < 16; i++) { - sprintf(str, "%02x", uuid[le[i]]); - str += 2; + sprintf(uuid_str, "%02x", uuid_bin[char_order[i]]); + uuid_str += 2; switch (i) { case 3: case 5: case 7: case 9: - *str++ = '-'; + *uuid_str++ = '-'; break; } } diff --git a/net/bootp.c b/net/bootp.c index 4300f1c..189a003 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -439,7 +439,7 @@ static int DhcpExtended(u8 *e, int message_type, IPaddr_t ServerID, *e++ = 17; *e++ = 0; /* type 0 - UUID */
- uuid_str_to_bin(uuid, e); + uuid_str_to_bin(uuid, e, UUID_STR_FORMAT_STD); e += 16; } else { printf("Invalid pxeuuid: %s\n", uuid);
This patch adds support to generate UUID (Universally Unique Identifier) in version 4 based on RFC4122, which is randomly.
Changes: - new configs: - CONFIG_LIB_UUID for compile lib/uuid.c - CONFIG_RANDOM_UUID for functions gen_rand_uuid() and gen_rand_uuid_str() - add configs dependency to include/config_fallbacks.h for lib uuid.
lib/uuid.c: - add gen_rand_uuid() - this function writes 16 bytes len binary representation of UUID v4 to the memory at given address.
--- Changes v2: - put uuid generation changes in a separate commit - get_uuid_str() - change name to gen_rand_uuid_str() - add new function: gen_rand_uuid() - remove unnecessary '\0' at the end of uuid string - drop unnecessary error checking - functions now takes pointers to allocated memory instead of alloc it itself - add new config option: CONFIG_RANDOM_UUID
Changes v5: - reword some comments - introduce config CMD_LIB_UUID, cleanup config dependency - remove use of typedef uuid_str_t --- include/config_fallbacks.h | 13 +++++++++ include/uuid.h | 22 +++++++++++++++- lib/Makefile | 3 +-- lib/uuid.c | 66 ++++++++++++++++++++++++++++++++++++++++++++-- 4 files changed, 99 insertions(+), 5 deletions(-)
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index d8339b2..f31a2f5 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -55,6 +55,19 @@ #define HAVE_BLOCK_DEVICE #endif
+#if (defined(CONFIG_PARTITION_UUIDS) || \ + defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_BOOTP_PXE)) && \ + !defined(CONFIG_LIB_UUID) +#define CONFIG_LIB_UUID +#endif + +#if defined(CONFIG_RANDOM_UUID) && \ + !defined(CONFIG_LIB_RAND) && \ + !defined(CONFIG_LIB_HW_RAND) +#define CONFIG_LIB_RAND +#endif + #ifndef CONFIG_SYS_PROMPT #define CONFIG_SYS_PROMPT "=> " #endif diff --git a/include/uuid.h b/include/uuid.h index e8feeed..93027c1 100644 --- a/include/uuid.h +++ b/include/uuid.h @@ -7,15 +7,35 @@ #ifndef __UUID_H__ #define __UUID_H__
+/* This is structure is in big-endian */ +struct uuid { + unsigned int time_low; + unsigned short time_mid; + unsigned short time_hi_and_version; + unsigned char clock_seq_hi_and_reserved; + unsigned char clock_seq_low; + unsigned char node[6]; +} __packed; + enum { UUID_STR_FORMAT_STD, UUID_STR_FORMAT_GUID };
int uuid_str_valid(const char *uuid); int uuid_str_to_bin(char *uuid_str, unsigned char *uuid_bin, int str_format); void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, int str_format); +void gen_rand_uuid(unsigned char *uuid_bin); +void gen_rand_uuid_str(char *uuid_str, int str_format); #endif diff --git a/lib/Makefile b/lib/Makefile index d7ff7ca..27e4f78 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -60,8 +60,7 @@ obj-$(CONFIG_REGEX) += slre.o obj-y += string.o obj-y += time.o obj-$(CONFIG_TRACE) += trace.o -obj-$(CONFIG_BOOTP_PXE) += uuid.o -obj-$(CONFIG_PARTITION_UUIDS) += uuid.o +obj-$(CONFIG_LIB_UUID) += uuid.o obj-y += vsprintf.o obj-$(CONFIG_LIB_RAND) += rand.o
diff --git a/lib/uuid.c b/lib/uuid.c index 8db865f..44d0c93 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -14,8 +14,22 @@ /* * UUID - Universally Unique IDentifier - 128 bits unique number. * There are 5 versions and one variant of UUID defined by RFC4122 - * specification. Depends on version uuid number base on a time, - * host name, MAC address or random data. + * specification. A UUID contains a set of fields. The set varies + * depending on the version of the UUID, as shown below: + * - time, MAC address(v1), + * - user ID(v2), + * - MD5 of name or URL(v3), + * - random data(v4), + * - SHA-1 of name or URL(v5), + * + * Layout of UUID: + * timestamp - 60-bit: time_low, time_mid, time_hi_and_version + * version - 4 bit (bit 4 through 7 of the time_hi_and_version) + * clock seq - 14 bit: clock_seq_hi_and_reserved, clock_seq_low + * variant: - bit 6 and 7 of clock_seq_hi_and_reserved + * node - 48 bit + * + * source: https://www.ietf.org/rfc/rfc4122.txt * * UUID binary format (16 bytes): * @@ -149,3 +163,51 @@ void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, int str_format) } } } + +/* + * gen_rand_uuid() - this function generates a random binary UUID version 4. + * In this version all fields beside 4 bits of version and + * 2 bits of variant are randomly generated. + * + * @param uuid_bin - pointer to allocated array [16B]. Output is in big endian. +*/ +#ifdef CONFIG_RANDOM_UUID +void gen_rand_uuid(unsigned char *uuid_bin) +{ + struct uuid uuid; + unsigned int *ptr = (unsigned int *)&uuid; + int i; + + /* Set all fields randomly */ + for (i = 0; i < sizeof(struct uuid) / sizeof(*ptr); i++) + *(ptr + i) = cpu_to_be32(rand()); + + clrsetbits_be16(&uuid.time_hi_and_version, + UUID_VERSION_MASK, + UUID_VERSION << UUID_VERSION_SHIFT); + + clrsetbits_8(&uuid.clock_seq_hi_and_reserved, + UUID_VARIANT_MASK, + UUID_VARIANT << UUID_VARIANT_SHIFT); + + memcpy(uuid_bin, &uuid, sizeof(struct uuid)); +} + +/* + * gen_rand_uuid_str() - this function generates UUID v4 (random) in two string + * formats UUID or GUID. + * + * @param uuid_str - pointer to allocated array [37B]. + * @param - uuid output type: UUID - 0, GUID - 1 + */ +void gen_rand_uuid_str(char *uuid_str, int str_format) +{ + unsigned char uuid_bin[UUID_BIN_LEN]; + + /* Generate UUID (big endian) */ + gen_rand_uuid(uuid_bin); + + /* Convert UUID bin to UUID or GUID formated STRING */ + uuid_bin_to_str(uuid_bin, uuid_str, str_format); +} +#endif
Commands usage: - uuid [<varname>] - guid [<varname>]
The result is saved in environment as a "varname" variable if argument is given, if not then it is printed.
Changes v5: - reword commands description - uuid command code refactor - remove use of typedef uuid_str_t --- README | 2 +- include/config_fallbacks.h | 14 ++++++++------ lib/uuid.c | 44 +++++++++++++++++++++++++++++++++++++++++++- 3 files changed, 52 insertions(+), 8 deletions(-)
diff --git a/README b/README index 7cb7c4f..025386f 100644 --- a/README +++ b/README @@ -1012,7 +1012,7 @@ The following options need to be configured: CONFIG_CMD_CDP * Cisco Discover Protocol support CONFIG_CMD_MFSL * Microblaze FSL support CONFIG_CMD_XIMG Load part of Multi Image - + CONFIG_CMD_UUID * Generate random UUID or GUID string
EXAMPLE: If you want all functions except of network support you can write: diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index f31a2f5..5eacfb6 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -56,15 +56,17 @@ #endif
#if (defined(CONFIG_PARTITION_UUIDS) || \ - defined(CONFIG_RANDOM_UUID) || \ - defined(CONFIG_BOOTP_PXE)) && \ - !defined(CONFIG_LIB_UUID) + defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_CMD_UUID) || \ + defined(CONFIG_BOOTP_PXE)) && \ + !defined(CONFIG_LIB_UUID) #define CONFIG_LIB_UUID #endif
-#if defined(CONFIG_RANDOM_UUID) && \ - !defined(CONFIG_LIB_RAND) && \ - !defined(CONFIG_LIB_HW_RAND) +#if (defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_CMD_UUID)) && \ + (!defined(CONFIG_LIB_RAND) && \ + !defined(CONFIG_LIB_HW_RAND)) #define CONFIG_LIB_RAND #endif
diff --git a/lib/uuid.c b/lib/uuid.c index 44d0c93..f32b602 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -4,6 +4,7 @@ * SPDX-License-Identifier: GPL-2.0+ */
+#include <common.h> #include <linux/ctype.h> #include <errno.h> #include <common.h> @@ -171,7 +172,7 @@ void uuid_bin_to_str(unsigned char *uuid_bin, char *uuid_str, int str_format) * * @param uuid_bin - pointer to allocated array [16B]. Output is in big endian. */ -#ifdef CONFIG_RANDOM_UUID +#if defined(CONFIG_RANDOM_UUID) || defined(CONFIG_CMD_UUID) void gen_rand_uuid(unsigned char *uuid_bin) { struct uuid uuid; @@ -210,4 +211,45 @@ void gen_rand_uuid_str(char *uuid_str, int str_format) /* Convert UUID bin to UUID or GUID formated STRING */ uuid_bin_to_str(uuid_bin, uuid_str, str_format); } + +#ifdef CONFIG_CMD_UUID +int do_uuid(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + char uuid[UUID_STR_LEN + 1]; + int str_format; + + if (!strcmp(argv[0], "uuid")) + str_format = UUID_STR_FORMAT_STD; + else + str_format = UUID_STR_FORMAT_GUID; + + if (argc > 2) + return CMD_RET_USAGE; + + gen_rand_uuid_str(uuid, str_format); + + if (argc == 1) + printf("%s\n", uuid); + else + setenv(argv[1], uuid); + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(uuid, CONFIG_SYS_MAXARGS, 1, do_uuid, + "UUID - generate random Universally Unique Identifier", + "[<varname>]\n" + "Argument:\n" + "varname: for set result in a environment variable\n" + "e.g. uuid uuid_env" +); + +U_BOOT_CMD(guid, CONFIG_SYS_MAXARGS, 1, do_uuid, + "GUID - generate Globally Unique Identifier based on random UUID", + "[<varname>]\n" + "Argument:\n" + "varname: for set result in a environment variable\n" + "e.g. guid guid_env" +); +#endif #endif
--- Changes v2: - cmd_gpt: extract_env: change return type from char to int - add tmp array to generate uuid string - store generated uuid in env and next get it from it - don't need to alloc and maintain allcoated memory outside extract_env()
Changes v3: - print info if uuid_gpt_* env is get from env/set random - change some word in README.gpt to meaningful
Changes v5: - cosmetic changes only --- common/cmd_gpt.c | 61 ++++++++++++++++++++++++++++++++++++++++++-------------- doc/README.gpt | 22 +++++++++++++++----- lib/uuid.c | 4 ++-- 3 files changed, 65 insertions(+), 22 deletions(-)
diff --git a/common/cmd_gpt.c b/common/cmd_gpt.c index 1f12e6d..e38422d 100644 --- a/common/cmd_gpt.c +++ b/common/cmd_gpt.c @@ -29,30 +29,53 @@ * * @return - zero on successful expand and env is set */ -static char extract_env(const char *str, char **env) +static int extract_env(const char *str, char **env) { + int ret = -1; char *e, *s; +#ifdef CONFIG_RANDOM_UUID + char uuid_str[UUID_STR_LEN + 1]; +#endif
/** @@ -299,8 +322,16 @@ static int do_gpt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return CMD_RET_FAILURE; }
- if (gpt_default(blk_dev_desc, argv[4])) + puts("Writing GPT: "); + + ret = gpt_default(blk_dev_desc, argv[4]); + if (!ret) { + puts("success!\n"); + return CMD_RET_SUCCESS; + } else { + puts("error!\n"); return CMD_RET_FAILURE; + } } else { return CMD_RET_USAGE; } diff --git a/doc/README.gpt b/doc/README.gpt index 5c133f3..f822894 100644 --- a/doc/README.gpt +++ b/doc/README.gpt @@ -132,8 +132,8 @@ of the Primary. ---------------------- Offset Size Description
+ option: CONFIG_RANDOM_UUID + If any partition "UUID" no exists then it is randomly generated. + 2. Define 'CONFIG_EFI_PARTITION' and 'CONFIG_CMD_GPT'
"uuid" program is recommended to generate UUID string. Moreover it can decode (-d switch) passed in UUID string. It can be used to generate partitions UUID passed to u-boot environment variables. +If optional CONFIG_RANDOM_UUID is defined then for any partition which environment +uuid is unset, uuid is randomly generated and stored in correspond environment +variable. + +note: +Each string block of UUID generated by program "uuid" is in big endian and it is +also stored in big endian in disk GPT. +Partitions layout can be printed by typing "mmc part". Note that each partition +GUID has different byte order than UUID generated before, this is because first +three blocks of GUID string are in Little Endian. diff --git a/lib/uuid.c b/lib/uuid.c index f32b602..f6b4423 100644 --- a/lib/uuid.c +++ b/lib/uuid.c @@ -251,5 +251,5 @@ U_BOOT_CMD(guid, CONFIG_SYS_MAXARGS, 1, do_uuid, "varname: for set result in a environment variable\n" "e.g. guid guid_env" ); -#endif -#endif +#endif /* CONFIG_CMD_UUID */ +#endif /* CONFIG_RANDOM_UUID || CONFIG_CMD_UUID */
This change enables automatically uuid generation by command gpt. In case of updating partitions layout user don't need to care about generate uuid manually.
Changes v5: - add commit message --- include/configs/trats.h | 1 + include/configs/trats2.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/include/configs/trats.h b/include/configs/trats.h index c00d60a..1ed4b9f 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -276,6 +276,7 @@ /* GPT */ #define CONFIG_EFI_PARTITION #define CONFIG_PARTITION_UUIDS +#define CONFIG_RANDOM_UUID
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_CACHELINE_SIZE 32 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 59896b1..6d89ca9 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -283,6 +283,7 @@ #define CONFIG_ENV_OFFSET ((32 - 4) << 10) /* 32KiB - 4KiB */ #define CONFIG_EFI_PARTITION #define CONFIG_PARTITION_UUIDS +#define CONFIG_RANDOM_UUID
Changes v5:
Acked-by: Minkyu Kang mk7.kang@samsung.com
Thanks, Minkyu Kang.
Signed-off-by: Przemyslaw Marczak p.marczak@samsung.com Cc: Stephen Warren swarren@nvidia.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: trini@ti.com
Changes v3: - reword commit message - add UUID_STR_LEN definition in lib/uuid.c - remove unused string pointer from uuid_bin_to_str()
Changes v4: - add uuid/guid description
Changes v5: - none
Changes v6: - none --- disk/part_efi.c | 90 +++++++------------------------------------------------- include/common.h | 3 +- lib/Makefile | 1 + lib/uuid.c | 61 +++++++++++++++++++++++++++++++++----- 4 files changed, 68 insertions(+), 87 deletions(-)
#include <linux/ctype.h> -#include "common.h" +#include <errno.h> +#include <common.h> + +#define UUID_STR_LEN 36
int uuid_str_valid(const char *uuid) @@ -43,14 +65,17 @@ int uuid_str_valid(const char *uuid) return 1; }
tmp32 = cpu_to_le32(simple_strtoul(uuid, NULL, 16)); memcpy(out, &tmp32, 4); @@ -66,4 +91,26 @@ void uuid_str_to_bin(const char *uuid, unsigned char *out)
tmp64 = cpu_to_be64(simple_strtoull(uuid + 24, NULL, 16)); memcpy(out + 10, (char *)&tmp64 + 2, 6); + + return 0; +} + +void uuid_bin_to_str(unsigned char *uuid, char *str) +{ + static const u8 le[16] = {3, 2, 1, 0, 5, 4, 7, 6, 8, 9, 10, 11, + 12, 13, 14, 15}; + int i; + + for (i = 0; i < 16; i++) { + sprintf(str, "%02x", uuid[le[i]]); + str += 2; + switch (i) { + case 3: + case 5: + case 7: + case 9: + *str++ = '-'; + break; + } + } }
Changes in lib/uuid.c to: - uuid_str_to_bin() - uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions This change allows easy recognize which UUID type is or should be stored in given string array. Binary data of UUID and GUID is always stored in big endian, only string representations are different as follows.
String byte: 0 36 String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx string UUID: be be be be be string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
--- Changes v4: (new commit) - change simple error checking to uuid_str_valid() in uuid_str_to_bin() - add new parameter to define UUID string format for UUID or GUID which diffe in endianness of first three string blocks. - update functions calls and declarations - add uuid.h header - remove functions declarations from common.h
Changes v6: - none --- disk/part_efi.c | 17 ++++++------ include/common.h | 4 +-- include/uuid.h | 21 ++++++++++++++ lib/uuid.c | 83 ++++++++++++++++++++++++++++++++++++++++---------------- net/bootp.c | 2 +- 5 files changed, 91 insertions(+), 36 deletions(-) create mode 100644 include/uuid.h
diff --git a/disk/part_efi.c b/disk/part_efi.c index a280ab5..216a292 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -100,8 +100,8 @@ void print_part_efi(block_dev_desc_t * dev_desc)
printf("Part\tStart LBA\tEnd LBA\t\tName\n"); printf("\tAttributes\n"); - printf("\tType UUID\n"); - printf("\tPartition UUID\n"); + printf("\tType GUID\n"); + printf("\tPartition GUID\n");
for (i = 0; i < le32_to_cpu(gpt_head->num_partition_entries); i++) { /* Stop at the first non valid PTE */ @@ -114,11 +114,11 @@ void print_part_efi(block_dev_desc_t * dev_desc) print_efiname(&gpt_pte[i])); printf("\tattrs:\t0x%016llx\n", gpt_pte[i].attributes.raw); uuid_bin = (unsigned char *)gpt_pte[i].partition_type_guid.b; - uuid_bin_to_str(uuid_bin, uuid); + uuid_bin_to_str(uuid_bin, uuid, UUID_STR_FORMAT_GUID); printf("\ttype:\t%s\n", uuid); uuid_bin = (unsigned char *)gpt_pte[i].unique_partition_guid.b; - uuid_bin_to_str(uuid_bin, uuid); - printf("\tuuid:\t%s\n", uuid); + uuid_bin_to_str(uuid_bin, uuid, UUID_STR_FORMAT_GUID); + printf("\tguid:\t%s\n", uuid); }
/* Remember to free pte */ @@ -165,7 +165,8 @@ int get_partition_info_efi(block_dev_desc_t * dev_desc, int part, sprintf((char *)info->type, "U-Boot"); info->bootable = is_bootable(&gpt_pte[part - 1]); #ifdef CONFIG_PARTITION_UUIDS - uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid); + uuid_bin_to_str(gpt_pte[part - 1].unique_partition_guid.b, info->uuid, + UUID_STR_FORMAT_GUID); #endif
debug("%s: start 0x" LBAF ", size 0x" LBAF ", name %s", __func__, @@ -323,7 +324,7 @@ int gpt_fill_pte(gpt_header *gpt_h, gpt_entry *gpt_e, str_uuid = partitions[i].uuid; bin_uuid = gpt_e[i].unique_partition_guid.b;
- if (uuid_str_to_bin(str_uuid, bin_uuid)) { + if (uuid_str_to_bin(str_uuid, bin_uuid, UUID_STR_FORMAT_STD)) { printf("Partition no. %d: invalid guid: %s\n", i, str_uuid); return -1; @@ -370,7 +371,7 @@ int gpt_fill_header(block_dev_desc_t *dev_desc, gpt_header *gpt_h, gpt_h->header_crc32 = 0; gpt_h->partition_entry_array_crc32 = 0;
- if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b)) + if (uuid_str_to_bin(str_guid, gpt_h->disk_guid.b, UUID_STR_FORMAT_GUID)) return -1;
/* lib/uuid.c */ -void uuid_bin_to_str(unsigned char *uuid, char *str); -int uuid_str_to_bin(char *uuid, unsigned char *out); -int uuid_str_valid(const char *uuid); +#include <uuid.h>
return 1; }
return 0; }
- uuid_str_to_bin()
- uuid_bin_to_str()
- add gen_rand_uuid_str() - this function writes 37 bytes len hexadecimal ASCII string representation of UUID v4 to the memory at given address.
Changes v6: - fix indentation in include/config_fallbacks.h --- include/config_fallbacks.h | 13 +++++++++ include/uuid.h | 22 +++++++++++++++- lib/Makefile | 3 +-- lib/uuid.c | 66 ++++++++++++++++++++++++++++++++++++++++++++-- 4 files changed, 99 insertions(+), 5 deletions(-)
diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index d8339b2..a8630ab 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -55,6 +55,19 @@ #define HAVE_BLOCK_DEVICE #endif
Hello,
Changes:
- new configs:
lib/uuid.c:
Changes v2:
Changes v3:
- reword comments
Changes v4:
Changes v5:
Changes v6:
I am sending next version because there was an indentation issue in version 5 of this patch which is fixed now.
Thanks
Changes:
- new configs:
lib/uuid.c:
Changes v6: - none --- README | 2 +- include/config_fallbacks.h | 8 +++++--- lib/uuid.c | 44 +++++++++++++++++++++++++++++++++++++++++++- 3 files changed, 49 insertions(+), 5 deletions(-)
EXAMPLE: If you want all functions except of network support you can write: diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index a8630ab..5eacfb6 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -57,14 +57,16 @@
#if (defined(CONFIG_PARTITION_UUIDS) || \ defined(CONFIG_RANDOM_UUID) || \ + defined(CONFIG_CMD_UUID) || \ defined(CONFIG_BOOTP_PXE)) && \ !defined(CONFIG_LIB_UUID) #define CONFIG_LIB_UUID #endif
Commands usage:
- uuid [<varname>]
- guid [<varname>]
New config:
- CONFIG_CMD_UUID
Changes v6: - none --- common/cmd_gpt.c | 61 ++++++++++++++++++++++++++++++++++++++++++-------------- doc/README.gpt | 22 +++++++++++++++----- lib/uuid.c | 4 ++-- 3 files changed, 65 insertions(+), 22 deletions(-)
On Wed, Apr 02, 2014 at 10:20:06AM +0200, Przemyslaw Marczak wrote:
Changes:
--- Changes v5: - add commit message
Changes v6: - none --- include/configs/trats.h | 1 + include/configs/trats2.h | 1 + 2 files changed, 2 insertions(+)
hello,
Thank you:)
participants (5)
Minkyu Kang
Przemyslaw Marczak
Stephen Warren
