[U-Boot] [RESEND PATCH] board: move all the rockchip board in one folder
The 'evb_rk3036' and 'kylin' is not a vendor name, let's replace them to 'rockchip' which is a real _vendor_ name, and meet the architecure 'board/<vendor>/<board-name>/'.
More boards from rockchip like evb_rk3288, evb_rk3399 will comes later.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/rk3036/Kconfig | 4 ++-- board/{evb_rk3036 => rockchip}/evb_rk3036/Kconfig | 2 +- board/{evb_rk3036 => rockchip}/evb_rk3036/MAINTAINERS | 0 board/{evb_rk3036 => rockchip}/evb_rk3036/Makefile | 0 board/{evb_rk3036 => rockchip}/evb_rk3036/evb_rk3036.c | 0 board/{kylin => rockchip}/kylin_rk3036/Kconfig | 2 +- board/{kylin => rockchip}/kylin_rk3036/MAINTAINERS | 0 board/{kylin => rockchip}/kylin_rk3036/Makefile | 0 board/{kylin => rockchip}/kylin_rk3036/kylin_rk3036.c | 0 9 files changed, 4 insertions(+), 4 deletions(-) rename board/{evb_rk3036 => rockchip}/evb_rk3036/Kconfig (89%) rename board/{evb_rk3036 => rockchip}/evb_rk3036/MAINTAINERS (100%) rename board/{evb_rk3036 => rockchip}/evb_rk3036/Makefile (100%) rename board/{evb_rk3036 => rockchip}/evb_rk3036/evb_rk3036.c (100%) rename board/{kylin => rockchip}/kylin_rk3036/Kconfig (90%) rename board/{kylin => rockchip}/kylin_rk3036/MAINTAINERS (100%) rename board/{kylin => rockchip}/kylin_rk3036/Makefile (100%) rename board/{kylin => rockchip}/kylin_rk3036/kylin_rk3036.c (100%)
diff --git a/arch/arm/mach-rockchip/rk3036/Kconfig b/arch/arm/mach-rockchip/rk3036/Kconfig index cc03808..f7562bd 100644 --- a/arch/arm/mach-rockchip/rk3036/Kconfig +++ b/arch/arm/mach-rockchip/rk3036/Kconfig @@ -15,7 +15,7 @@ config SYS_MALLOC_F_LEN config ROCKCHIP_COMMON bool "Support rk common fuction"
-source "board/evb_rk3036/evb_rk3036/Kconfig" -source "board/kylin/kylin_rk3036/Kconfig" +source "board/rockchip/evb_rk3036/Kconfig" +source "board/rockchip/kylin_rk3036/Kconfig"
endif diff --git a/board/evb_rk3036/evb_rk3036/Kconfig b/board/rockchip/evb_rk3036/Kconfig similarity index 89% rename from board/evb_rk3036/evb_rk3036/Kconfig rename to board/rockchip/evb_rk3036/Kconfig index ae2a9eb..ef45f62 100644 --- a/board/evb_rk3036/evb_rk3036/Kconfig +++ b/board/rockchip/evb_rk3036/Kconfig @@ -4,7 +4,7 @@ config SYS_BOARD default "evb_rk3036"
config SYS_VENDOR - default "evb_rk3036" + default "rockchip"
config SYS_CONFIG_NAME default "evb_rk3036" diff --git a/board/evb_rk3036/evb_rk3036/MAINTAINERS b/board/rockchip/evb_rk3036/MAINTAINERS similarity index 100% rename from board/evb_rk3036/evb_rk3036/MAINTAINERS rename to board/rockchip/evb_rk3036/MAINTAINERS diff --git a/board/evb_rk3036/evb_rk3036/Makefile b/board/rockchip/evb_rk3036/Makefile similarity index 100% rename from board/evb_rk3036/evb_rk3036/Makefile rename to board/rockchip/evb_rk3036/Makefile diff --git a/board/evb_rk3036/evb_rk3036/evb_rk3036.c b/board/rockchip/evb_rk3036/evb_rk3036.c similarity index 100% rename from board/evb_rk3036/evb_rk3036/evb_rk3036.c rename to board/rockchip/evb_rk3036/evb_rk3036.c diff --git a/board/kylin/kylin_rk3036/Kconfig b/board/rockchip/kylin_rk3036/Kconfig similarity index 90% rename from board/kylin/kylin_rk3036/Kconfig rename to board/rockchip/kylin_rk3036/Kconfig index 5d75c1f..8d35b4e 100644 --- a/board/kylin/kylin_rk3036/Kconfig +++ b/board/rockchip/kylin_rk3036/Kconfig @@ -4,7 +4,7 @@ config SYS_BOARD default "kylin_rk3036"
config SYS_VENDOR - default "kylin" + default "rockchip"
config SYS_CONFIG_NAME default "kylin_rk3036" diff --git a/board/kylin/kylin_rk3036/MAINTAINERS b/board/rockchip/kylin_rk3036/MAINTAINERS similarity index 100% rename from board/kylin/kylin_rk3036/MAINTAINERS rename to board/rockchip/kylin_rk3036/MAINTAINERS diff --git a/board/kylin/kylin_rk3036/Makefile b/board/rockchip/kylin_rk3036/Makefile similarity index 100% rename from board/kylin/kylin_rk3036/Makefile rename to board/rockchip/kylin_rk3036/Makefile diff --git a/board/kylin/kylin_rk3036/kylin_rk3036.c b/board/rockchip/kylin_rk3036/kylin_rk3036.c similarity index 100% rename from board/kylin/kylin_rk3036/kylin_rk3036.c rename to board/rockchip/kylin_rk3036/kylin_rk3036.c
Applied to u-boot-rockchip, thanks!
Kever Yang
