[U-Boot] UCLASS_MISC bug
I would like to point that this was not a very good idea:
=== Cut === --- uboot-imx-next/drivers/misc/misc-uclass.c 2018-12-20 20:35:22.505180339 -0800 +++ u-boot-imx/drivers/misc/misc-uclass.c 2019-03-13 11:50:19.408982814 -0700 @@ -68,4 +68,7 @@ int misc_set_enabled(struct udevice *dev UCLASS_DRIVER(misc) = { .id = UCLASS_MISC, .name = "misc", +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .post_bind = dm_scan_fdt_dev, +#endif }; === Cut ===
The problem comes up with all those "glue" layers like e.g. in usb/dwc3 and everywhere else.
Those "glues" primarily bind drivers to e.g. USB interfaces like e.g. dwc3-generic does. That is where it should stop because glue knows better what to bind. However, after glue has bound appropriate drivers to their interfaces that post_bind scans FDT again and finds yet another bunch of drivers that it binds on top of what glue already bound. This happens e.g. with DWC3 drivers that glues bind to interfaces depending on their declared roles. However both peripheral and XHCI drivers are compatible with "snps,dwc3" so they are bound on top creating a huge mess. Here is a dm tree fragment of its action:
=== Cut === phy 0 [ + ] imx8mq_usb_phy |-- phy@381f0040 misc 0 [ + ] imx8m_dwc3_glue |-- usb@38100000 usb 0 [ ] imx8m_dwc3_periphera | |-- dwc3 usb 0 [ ] xhci-dwc3 | `-- dwc3 phy 1 [ ] imx8mq_usb_phy |-- phy@382f0040 misc 1 [ ] imx8m_dwc3_glue |-- usb@38200000 usb 1 [ ] xhci-dwc3 | |-- dwc3 usb 2 [ ] xhci-dwc3 | `-- dwc3 === Cut ===
The glue bound imx8m_dwc3_peripheral to USB0 then post_bind found yet another "compatible" driver, xhci-dwc3 and bound it to the same interface.
Then glue bound xhci-dwc3 to USB1 but post_bind found yet another "compatible" driver, xhci-dwc3 and bound it again so there are TWO xhci drivers bound to the same interface.
This is simplified picture -- I removed "compatible" from my peripheral driver so it only comes up once, under USB0. If I leave that "compatible" with "snps,dwc3" there everything gets even weirder :(
That diff above is the latest 2019.04-rc3 u-boot-imx-next vs 2019.01-rc something release.
We either need some additional special flag to disable that post_bind where it is not needed or create a special new class for those binding "glues" or this change should be reverted.
P.S. I'm going to post imx8m USB glue, USB PHY, USB peripheral initial drivers probably Monday late night as they still need some cleanup. It all works with full Linux Kernel DTS files, picks power domains from there.
Don't know what to do with my board-specific DTS as there is (and probably will not be) our board submitted -- it is not secret but used in our devices only and not available to the public -- so it doesn't make sense to post a full DTS. Will probably send a fragment.
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
+ Simon Glass
Hi Serguey,
We can also see the problem on TI platforms.
Tested with a am57xx evm
JJ
On Tue, 19 Mar 2019 at 23:29, Jean-Jacques Hiblot jjhiblot@ti.com wrote:
- Simon Glass
Hi Serguey,
- .post_bind = dm_scan_fdt_dev,
Can you check for an existing device and not create a new one in that case?
Maybe use device_find_first_child_by_uclass() ?
JJ
- KSI@home KOI8 Net < > The impossible we do immediately. *
- Las Vegas NV, USA < > Miracles require 24-hour notice. *
Simon,
- Simon Glass
Hi Serguey,
If I'm not mistaken, that would not solve the issue because the device are bound in the bind() callback of the misc driver.
One solution would be to use another UCLASS that really does not do anything (UCLASS_NOP for example). It would be ok because we don't use any of the features offered by the MISC UCLASS
Another solution would be to use a flag stored in the uclass priv data to tell not bind devices in the post_bind callback.
I prefer the first approach.
JJ
JJ
Simon, Sergey,
On 22/03/2019 17:33, Jean-Jacques Hiblot wrote:
Simon,
- Simon Glass
Hi Serguey,
A patch being worth a thousand words, I posted a patch for such a UCLASS : https://patchwork.ozlabs.org/patch/1061383/
JJ
JJ
JJ
Jean-Jacques Hiblot
Sergey Kubushyn
