[PATCH v3 0/7] vpl: Introduce a verifying program loader
U-Boot provides a verified-boot feature based around FIT, but there is no standard way of implementing it for a board. At present the various required pieces must be built up separately, to produce a working implementation. In particular, there is no built-in support for selecting A/B boot or recovery mode.
This series introduces VPL, a verified program loader. Its purpose is to run the verified-boot process and decide which SPL binary should be run. Adding VPL into the boot flow provides a standard way of implementing verified boot. So far, only the phase itself is added along with some Kconfig options. The next step is to create a build for sandbox.
Changes in v3: - Move VPL Kconfig options to a separate patch - Add full build support for VPL
Changes in v2: - Add some more VPL Kconfig options
Simon Glass (7): doc: Convert SPL documentation to ReST doc: Expand SPL docs to explain the phase and config test: Tidy up test building with SPL spl: Move TPL_HASH_SUPPORT down next to other TPL options binman: Add VPL support Introduce Verifying Program Loader (VPL) vpl: Add Kconfig options for VPL
Kconfig | 10 + Makefile | 15 +- arch/sandbox/Kconfig | 8 + common/Kconfig | 67 ++++++ common/spl/Kconfig | 226 +++++++++++++++++++-- common/spl/spl.c | 25 ++- doc/develop/index.rst | 1 + doc/{README.SPL => develop/spl.rst} | 99 +++++---- drivers/clk/Kconfig | 10 + drivers/core/Makefile | 2 +- drivers/gpio/Kconfig | 11 + drivers/i2c/Kconfig | 11 + drivers/misc/Kconfig | 19 ++ drivers/pinctrl/Kconfig | 18 +- drivers/rtc/Kconfig | 9 + drivers/serial/Kconfig | 20 ++ drivers/sysreset/Kconfig | 10 + drivers/timer/Kconfig | 10 + include/bootstage.h | 2 + include/linux/kconfig.h | 3 + include/spl.h | 20 +- lib/Kconfig | 62 ++++++ scripts/Kbuild.include | 4 + scripts/Makefile.autoconf | 12 ++ scripts/Makefile.build | 4 + scripts/Makefile.lib | 5 + scripts/Makefile.spl | 37 +++- test/test-main.c | 2 +- tools/binman/etype/u_boot_vpl.py | 42 ++++ tools/binman/etype/u_boot_vpl_bss_pad.py | 44 ++++ tools/binman/etype/u_boot_vpl_dtb.py | 28 +++ tools/binman/etype/u_boot_vpl_expanded.py | 45 ++++ tools/binman/etype/u_boot_vpl_nodtb.py | 42 ++++ tools/binman/ftest.py | 110 ++++++++-- tools/binman/state.py | 3 +- tools/binman/test/082_fdt_update_all.dts | 2 + tools/binman/test/201_u_boot_vpl.dts | 11 + tools/binman/test/202_u_boot_vpl_nodtb.dts | 13 ++ tools/binman/test/203_fdt_incl_vpl.dts | 13 ++ tools/binman/test/204_vpl_bss_pad.dts | 17 ++ 40 files changed, 997 insertions(+), 95 deletions(-) rename doc/{README.SPL => develop/spl.rst} (61%) create mode 100644 tools/binman/etype/u_boot_vpl.py create mode 100644 tools/binman/etype/u_boot_vpl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_vpl_dtb.py create mode 100644 tools/binman/etype/u_boot_vpl_expanded.py create mode 100644 tools/binman/etype/u_boot_vpl_nodtb.py create mode 100644 tools/binman/test/201_u_boot_vpl.dts create mode 100644 tools/binman/test/202_u_boot_vpl_nodtb.dts create mode 100644 tools/binman/test/203_fdt_incl_vpl.dts create mode 100644 tools/binman/test/204_vpl_bss_pad.dts
Move this documentation over to .rst format.
(no changes since v1)
doc/develop/index.rst | 1 + doc/{README.SPL => develop/spl.rst} | 36 +++++++++++++++-------------- 2 files changed, 20 insertions(+), 17 deletions(-) rename doc/{README.SPL => develop/spl.rst} (87%)
diff --git a/doc/develop/index.rst b/doc/develop/index.rst index 3edffbc6373..79f345c9331 100644 --- a/doc/develop/index.rst +++ b/doc/develop/index.rst @@ -14,6 +14,7 @@ Implementation global_data logging menus + spl uefi/index version
diff --git a/doc/README.SPL b/doc/develop/spl.rst similarity index 87% rename from doc/README.SPL rename to doc/develop/spl.rst index 2beb6d8f11b..1165f95335f 100644 --- a/doc/README.SPL +++ b/doc/develop/spl.rst @@ -20,19 +20,19 @@ u-boot-spl.map. A config option named CONFIG_SPL_BUILD is enabled by Kconfig for SPL. Source files can therefore be compiled for SPL with different settings.
-For example: +For example::
-ifeq ($(CONFIG_SPL_BUILD),y) -obj-y += board_spl.o -else -obj-y += board.o -endif + ifeq ($(CONFIG_SPL_BUILD),y) + obj-y += board_spl.o + else + obj-y += board.o + endif
-obj-$(CONFIG_SPL_BUILD) += foo.o + obj-$(CONFIG_SPL_BUILD) += foo.o
-#ifdef CONFIG_SPL_BUILD - foo(); -#endif + #ifdef CONFIG_SPL_BUILD + foo(); + #endif
The building of SPL images can be enabled by CONFIG_SPL option in Kconfig. @@ -71,11 +71,13 @@ Device tree The U-Boot device tree is filtered by the fdtgrep tools during the build process to generate a much smaller device tree used in SPL (spl/u-boot-spl.dtb) with: + - the mandatory nodes (/alias, /chosen, /config) - the nodes with one pre-relocation property: 'u-boot,dm-pre-reloc' or 'u-boot,dm-spl'
fdtgrep is also used to remove: + - the properties defined in CONFIG_OF_SPL_REMOVE_PROPS - all the pre-relocation properties ('u-boot,dm-pre-reloc', 'u-boot,dm-spl' and 'u-boot,dm-tpl') @@ -98,14 +100,14 @@ stack usage at various points in run sequence of SPL. The -fstack-usage option to gcc will produce '.su' files (such as arch/arm/cpu/armv7/syslib.su) that will give stack usage information and cflow can construct program flow.
-Must have gcc 4.6 or later, which supports -fstack-usage +Must have gcc 4.6 or later, which supports -fstack-usage:
-1) Build normally -2) Perform the following shell command to generate a list of C files used in -SPL: -$ find spl -name '*.su' | sed -e 's:^spl/::' -e 's:[.]su$:.c:' > used-spl.list -3) Execute cflow: -$ cflow --main=board_init_r `cat used-spl.list` 2>&1 | $PAGER +#. Build normally +#. Perform the following shell command to generate a list of C files used in + SPL: +#. `find spl -name '*.su' | sed -e 's:^spl/::' -e 's:[.]su$:.c:' > used-spl.list` +#. Execute cflow: + `$ cflow --main=board_init_r $(cat used-spl.list) 2>&1 | $PAGER`
cflow will spit out a number of warnings as it does not parse the config files and picks functions based on #ifdef. Parsing the '.i'
Add a bit more information about how to use SPL.
doc/develop/spl.rst | 59 +++++++++++++++++++++++++++------------------ 1 file changed, 36 insertions(+), 23 deletions(-)
diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index 1165f95335f..c2a29a8c0a4 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -42,29 +42,42 @@ configured by defining CONFIG_SPL_TEXT_BASE. The linker script has to be defined with CONFIG_SPL_LDSCRIPT.
To support generic U-Boot libraries and drivers in the SPL binary one can -optionally define CONFIG_SPL_XXX_SUPPORT. Currently following options -are supported: - -CONFIG_SPL_LIBCOMMON_SUPPORT (common/libcommon.o) -CONFIG_SPL_LIBDISK_SUPPORT (disk/libdisk.o) -CONFIG_SPL_I2C_SUPPORT (drivers/i2c/libi2c.o) -CONFIG_SPL_GPIO_SUPPORT (drivers/gpio/libgpio.o) -CONFIG_SPL_MMC_SUPPORT (drivers/mmc/libmmc.o) -CONFIG_SPL_SERIAL_SUPPORT (drivers/serial/libserial.o) -CONFIG_SPL_SPI_FLASH_SUPPORT (drivers/mtd/spi/libspi_flash.o) -CONFIG_SPL_SPI_SUPPORT (drivers/spi/libspi.o) -CONFIG_SPL_FS_FAT (fs/fat/libfat.o) -CONFIG_SPL_FS_EXT4 -CONFIG_SPL_LIBGENERIC_SUPPORT (lib/libgeneric.o) -CONFIG_SPL_POWER_SUPPORT (drivers/power/libpower.o) -CONFIG_SPL_NAND_SUPPORT (drivers/mtd/nand/raw/libnand.o) -CONFIG_SPL_DRIVERS_MISC_SUPPORT (drivers/misc) -CONFIG_SPL_DMA (drivers/dma/libdma.o) -CONFIG_SPL_POST_MEM_SUPPORT (post/drivers/memory.o) -CONFIG_SPL_NAND_LOAD (drivers/mtd/nand/raw/nand_spl_load.o) -CONFIG_SPL_SPI_LOAD (drivers/mtd/spi/spi_spl_load.o) -CONFIG_SPL_RAM_DEVICE (common/spl/spl.c) -CONFIG_SPL_WATCHDOG_SUPPORT (drivers/watchdog/libwatchdog.o) +optionally define CONFIG_SPL_XXX_SUPPORT (or CONFIG_SPL_XXX_SUPPORT for older +options). + +Adding SPL-specific code +------------------------ + +To check whether a feature is enabled, use CONFIG_IS_ENABLED():: + + if (CONFIG_IS_ENABLED(CLK)) + ... + +This checks CONFIG_CLK for the main build, CONFIG_SPL_CLK for the SPL build, +CONFIG_TPL_CLK for the TPL build, etc. + +U-Boot Phases +------------- + +U-Boot boots through the following phases: + +TPL + Very early init, as tiny as possible. This loads SPL. + +SPL + Secondary program loader. Sets up SDRAM and loads U-Boot proper. It may also + load other firmware components. + +U-Boot + U-Boot proper, containing the command line and boot logic. + + +Checking the boot phase +----------------------- + +Use `spl_phase()` to find the current U-Boot phase, e.g. `PHASE_SPL`. You can +also find the previous and next phase and get the phase name. +
Device tree -----------
We can in principle add tests to any SPL build, e.g. TPL or VPL. Update the build rules to handle this.
Makefile | 2 +- scripts/Makefile.spl | 2 +- test/test-main.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/Makefile b/Makefile index 0d3192cebad..f7f62979ae2 100644 --- a/Makefile +++ b/Makefile @@ -841,7 +841,7 @@ libs-$(CONFIG_API) += api/ ifdef CONFIG_POST libs-y += post/ endif -libs-$(CONFIG_UNIT_TEST) += test/ +libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/ libs-$(CONFIG_UT_ENV) += test/env/ libs-$(CONFIG_UT_OPTEE) += test/optee/ libs-$(CONFIG_UT_OVERLAY) += test/overlay/ diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index 5be1a9ba1b1..ffe919dafab 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -109,7 +109,7 @@ libs-y += dts/ libs-y += fs/ libs-$(CONFIG_SPL_POST_MEM_SUPPORT) += post/drivers/ libs-$(CONFIG_SPL_NET_SUPPORT) += net/ -libs-$(CONFIG_SPL_UNIT_TEST) += test/ +libs-$(CONFIG_$(SPL_TPL_)UNIT_TEST) += test/
head-y := $(addprefix $(obj)/,$(head-y)) libs-y := $(addprefix $(obj)/,$(libs-y)) diff --git a/test/test-main.c b/test/test-main.c index 7afe8741cf9..3cdf6849c57 100644 --- a/test/test-main.c +++ b/test/test-main.c @@ -45,7 +45,7 @@ static int dm_test_pre_run(struct unit_test_state *uts) uts->force_fail_alloc = false; uts->skip_post_probe = false; gd->dm_root = NULL; - if (IS_ENABLED(CONFIG_UT_DM) && !CONFIG_IS_ENABLED(OF_PLATDATA)) + if (CONFIG_IS_ENABLED(UT_DM) && !CONFIG_IS_ENABLED(OF_PLATDATA)) memset(dm_testdrv_op_count, '\0', sizeof(dm_testdrv_op_count)); arch_reset_for_test();
This option should be next to other TPL options, not next to the SPL hash option, so it matches the placement conventions in this file.
Move it.
common/spl/Kconfig | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index fa80524cfb2..10384b835b2 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -519,17 +519,6 @@ config SPL_HASH_SUPPORT this option to build system-specific drivers for hash acceleration as part of an SPL build.
-config TPL_HASH_SUPPORT - bool "Support hashing drivers in TPL" - depends on TPL - select SHA1 - select SHA256 - help - Enable hashing drivers in SPL. These drivers can be used to - accelerate secure boot processing in secure applications. Enable - this option to build system-specific drivers for hash acceleration - as part of an SPL build. - config SPL_DMA bool "Support DMA drivers" help @@ -1491,6 +1480,17 @@ config TPL_GPIO_SUPPORT for example. Enable this option to build the drivers in drivers/gpio as part of an TPL build.
+config TPL_HASH_SUPPORT + bool "Support hashing drivers in TPL" + depends on TPL + select SHA1 + select SHA256 + help + Enable hashing drivers in SPL. These drivers can be used to + accelerate secure boot processing in secure applications. Enable + this option to build system-specific drivers for hash acceleration + as part of an SPL build. + config TPL_I2C_SUPPORT bool "Support I2C" help
Add support for U-Boot's Verifying Program Loader phase.
tools/binman/etype/u_boot_vpl.py | 42 ++++++++ tools/binman/etype/u_boot_vpl_bss_pad.py | 44 +++++++++ tools/binman/etype/u_boot_vpl_dtb.py | 28 ++++++ tools/binman/etype/u_boot_vpl_expanded.py | 45 +++++++++ tools/binman/etype/u_boot_vpl_nodtb.py | 42 ++++++++ tools/binman/ftest.py | 110 +++++++++++++++++---- tools/binman/state.py | 3 +- tools/binman/test/082_fdt_update_all.dts | 2 + tools/binman/test/201_u_boot_vpl.dts | 11 +++ tools/binman/test/202_u_boot_vpl_nodtb.dts | 13 +++ tools/binman/test/203_fdt_incl_vpl.dts | 13 +++ tools/binman/test/204_vpl_bss_pad.dts | 17 ++++ 12 files changed, 348 insertions(+), 22 deletions(-) create mode 100644 tools/binman/etype/u_boot_vpl.py create mode 100644 tools/binman/etype/u_boot_vpl_bss_pad.py create mode 100644 tools/binman/etype/u_boot_vpl_dtb.py create mode 100644 tools/binman/etype/u_boot_vpl_expanded.py create mode 100644 tools/binman/etype/u_boot_vpl_nodtb.py create mode 100644 tools/binman/test/201_u_boot_vpl.dts create mode 100644 tools/binman/test/202_u_boot_vpl_nodtb.dts create mode 100644 tools/binman/test/203_fdt_incl_vpl.dts create mode 100644 tools/binman/test/204_vpl_bss_pad.dts
diff --git a/tools/binman/etype/u_boot_vpl.py b/tools/binman/etype/u_boot_vpl.py new file mode 100644 index 00000000000..9daaca4f6fd --- /dev/null +++ b/tools/binman/etype/u_boot_vpl.py @@ -0,0 +1,42 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for vpl/u-boot-vpl.bin +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_vpl(Entry_blob): + """U-Boot VPL binary + + Properties / Entry arguments: + - filename: Filename of u-boot-vpl.bin (default 'vpl/u-boot-vpl.bin') + + This is the U-Boot VPL (Verifying Program Loader) binary. This is a small + binary which loads before SPL, typically into on-chip SRAM. It is + responsible for locating, loading and jumping to SPL, the next-stage + loader. Note that VPL is not relocatable so must be loaded to the correct + address in SRAM, or written to run from the correct address if direct + flash execution is possible (e.g. on x86 devices). + + SPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + + in the binman README for more information. + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up symbols to write into the VPL binary. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.elf_fname = 'vpl/u-boot-vpl' + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl.bin' + + def WriteSymbols(self, section): + elf.LookupAndWriteSymbols(self.elf_fname, self, section.GetImage()) diff --git a/tools/binman/etype/u_boot_vpl_bss_pad.py b/tools/binman/etype/u_boot_vpl_bss_pad.py new file mode 100644 index 00000000000..073833b3d0d --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_bss_pad.py @@ -0,0 +1,44 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2021 Google LLC +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for BSS padding for vpl/u-boot-vpl.bin. This padding +# can be added after the VPL binary to ensure that anything concatenated +# to it will appear to VPL to be at the end of BSS rather than the start. +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob +from patman import tools + +class Entry_u_boot_vpl_bss_pad(Entry_blob): + """U-Boot VPL binary padded with a BSS region + + Properties / Entry arguments: + None + + This holds the padding added after the VPL binary to cover the BSS (Block + Started by Symbol) region. This region holds the various variables used by + VPL. It is set to 0 by VPL when it starts up. If you want to append data to + the VPL image (such as a device tree file), you must pad out the BSS region + to avoid the data overlapping with U-Boot variables. This entry is useful in + that case. It automatically pads out the entry size to cover both the code, + data and BSS. + + The contents of this entry will a certain number of zero bytes, determined + by __bss_size + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up the BSS address. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def ObtainContents(self): + fname = tools.GetInputFilename('vpl/u-boot-vpl') + bss_size = elf.GetSymbolAddress(fname, '__bss_size') + if not bss_size: + self.Raise('Expected __bss_size symbol in vpl/u-boot-vpl') + self.SetContents(tools.GetBytes(0, bss_size)) + return True diff --git a/tools/binman/etype/u_boot_vpl_dtb.py b/tools/binman/etype/u_boot_vpl_dtb.py new file mode 100644 index 00000000000..f6253bf2431 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_dtb.py @@ -0,0 +1,28 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for U-Boot device tree in VPL (Verifying Program Loader) +# + +from binman.entry import Entry +from binman.etype.blob_dtb import Entry_blob_dtb + +class Entry_u_boot_vpl_dtb(Entry_blob_dtb): + """U-Boot VPL device tree + + Properties / Entry arguments: + - filename: Filename of u-boot.dtb (default 'vpl/u-boot-vpl.dtb') + + This is the VPL device tree, containing configuration information for + VPL. VPL needs this to know what devices are present and which drivers + to activate. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl.dtb' + + def GetFdtEtype(self): + return 'u-boot-vpl-dtb' diff --git a/tools/binman/etype/u_boot_vpl_expanded.py b/tools/binman/etype/u_boot_vpl_expanded.py new file mode 100644 index 00000000000..945a90f856e --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_expanded.py @@ -0,0 +1,45 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright 2021 Google LLC +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for expanded U-Boot VPL binary +# + +from patman import tout + +from binman import state +from binman.etype.blob_phase import Entry_blob_phase + +class Entry_u_boot_vpl_expanded(Entry_blob_phase): + """U-Boot VPL flat binary broken out into its component parts + + Properties / Entry arguments: + - vpl-dtb: Controls whether this entry is selected (set to 'y' or '1' to + select) + + This is a section containing the U-Boot binary, BSS padding if needed and a + devicetree. Using this entry type automatically creates this section, with + the following entries in it: + + u-boot-vpl-nodtb + u-boot-vpl-bss-pad + u-boot-dtb + + Having the devicetree separate allows binman to update it in the final + image, so that the entries positions are provided to the running U-Boot. + + This entry is selected based on the value of the 'vpl-dtb' entryarg. If + this is non-empty (and not 'n' or '0') then this expanded entry is selected. + """ + def __init__(self, section, etype, node): + bss_pad = state.GetEntryArgBool('vpl-bss-pad') + super().__init__(section, etype, node, 'u-boot-vpl', 'u-boot-vpl-dtb', + bss_pad) + + @classmethod + def UseExpanded(cls, node, etype, new_etype): + val = state.GetEntryArgBool('vpl-dtb') + tout.DoOutput(tout.INFO if val else tout.DETAIL, + "Node '%s': etype '%s': %s %sselected" % + (node.path, etype, new_etype, '' if val else 'not ')) + return val diff --git a/tools/binman/etype/u_boot_vpl_nodtb.py b/tools/binman/etype/u_boot_vpl_nodtb.py new file mode 100644 index 00000000000..25c966cf342 --- /dev/null +++ b/tools/binman/etype/u_boot_vpl_nodtb.py @@ -0,0 +1,42 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (c) 2016 Google, Inc +# Written by Simon Glass sjg@chromium.org +# +# Entry-type module for 'u-boot-vpl-nodtb.bin' +# + +from binman import elf +from binman.entry import Entry +from binman.etype.blob import Entry_blob + +class Entry_u_boot_vpl_nodtb(Entry_blob): + """VPL binary without device tree appended + + Properties / Entry arguments: + - filename: Filename to include (default 'vpl/u-boot-vpl-nodtb.bin') + + This is the U-Boot VPL binary, It does not include a device tree blob at + the end of it so may not be able to work without it, assuming VPL needs + a device tree to operate on your platform. You can add a u_boot_vpl_dtb + entry after this one, or use a u_boot_vpl entry instead, which normally + expands to a section containing u-boot-vpl-dtb, u-boot-vpl-bss-pad and + u-boot-vpl-dtb + + VPL can access binman symbols at runtime. See: + + 'Access to binman entry offsets at run time (symbols)' + + in the binman README for more information. + + The ELF file 'vpl/u-boot-vpl' must also be available for this to work, since + binman uses that to look up symbols to write into the VPL binary. + """ + def __init__(self, section, etype, node): + super().__init__(section, etype, node) + self.elf_fname = 'vpl/u-boot-vpl' + + def GetDefaultFilename(self): + return 'vpl/u-boot-vpl-nodtb.bin' + + def WriteSymbols(self, section): + elf.LookupAndWriteSymbols(self.elf_fname, self, section.GetImage()) diff --git a/tools/binman/ftest.py b/tools/binman/ftest.py index 5383eec489a..14daa69a69b 100644 --- a/tools/binman/ftest.py +++ b/tools/binman/ftest.py @@ -40,12 +40,14 @@ U_BOOT_DATA = b'1234' U_BOOT_IMG_DATA = b'img' U_BOOT_SPL_DATA = b'56780123456789abcdefghi' U_BOOT_TPL_DATA = b'tpl9876543210fedcbazyw' +U_BOOT_VPL_DATA = b'vpl76543210fedcbazywxyz_' BLOB_DATA = b'89' ME_DATA = b'0abcd' VGA_DATA = b'vga' U_BOOT_DTB_DATA = b'udtb' U_BOOT_SPL_DTB_DATA = b'spldtb' U_BOOT_TPL_DTB_DATA = b'tpldtb' +U_BOOT_VPL_DTB_DATA = b'vpldtb' X86_START16_DATA = b'start16' X86_START16_SPL_DATA = b'start16spl' X86_START16_TPL_DATA = b'start16tpl' @@ -56,6 +58,7 @@ PPC_MPC85XX_BR_DATA = b'ppcmpc85xxbr' U_BOOT_NODTB_DATA = b'nodtb with microcode pointer somewhere in here' U_BOOT_SPL_NODTB_DATA = b'splnodtb with microcode pointer somewhere in here' U_BOOT_TPL_NODTB_DATA = b'tplnodtb with microcode pointer somewhere in here' +U_BOOT_VPL_NODTB_DATA = b'vplnodtb' FSP_DATA = b'fsp' CMC_DATA = b'cmc' VBT_DATA = b'vbt' @@ -126,6 +129,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.img', U_BOOT_IMG_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.bin', U_BOOT_SPL_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl.bin', U_BOOT_TPL_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl.bin', U_BOOT_VPL_DATA) TestFunctional._MakeInputFile('blobfile', BLOB_DATA) TestFunctional._MakeInputFile('me.bin', ME_DATA) TestFunctional._MakeInputFile('vga.bin', VGA_DATA) @@ -151,6 +155,8 @@ class TestFunctional(unittest.TestCase): U_BOOT_SPL_NODTB_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl-nodtb.bin', U_BOOT_TPL_NODTB_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl-nodtb.bin', + U_BOOT_VPL_NODTB_DATA) TestFunctional._MakeInputFile('fsp.bin', FSP_DATA) TestFunctional._MakeInputFile('cmc.bin', CMC_DATA) TestFunctional._MakeInputFile('vbt.bin', VBT_DATA) @@ -273,6 +279,7 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('u-boot.dtb', U_BOOT_DTB_DATA) TestFunctional._MakeInputFile('spl/u-boot-spl.dtb', U_BOOT_SPL_DTB_DATA) TestFunctional._MakeInputFile('tpl/u-boot-tpl.dtb', U_BOOT_TPL_DTB_DATA) + TestFunctional._MakeInputFile('vpl/u-boot-vpl.dtb', U_BOOT_VPL_DTB_DATA)
def _RunBinman(self, *args, **kwargs): """Run binman using the command line @@ -385,8 +392,8 @@ class TestFunctional(unittest.TestCase): shutil.rmtree(tmpdir) return data
- def _GetDtbContentsForSplTpl(self, dtb_data, name): - """Create a version of the main DTB for SPL or SPL + def _GetDtbContentsForSpls(self, dtb_data, name): + """Create a version of the main DTB for SPL / TPL / VPL
For testing we don't actually have different versions of the DTB. With U-Boot we normally run fdtgrep to remove unwanted nodes, but for tests @@ -454,11 +461,11 @@ class TestFunctional(unittest.TestCase):
# For testing purposes, make a copy of the DT for SPL and TPL. Add # a node indicating which it is, so aid verification. - for name in ['spl', 'tpl']: + for name in ['spl', 'tpl', 'vpl']: dtb_fname = '%s/u-boot-%s.dtb' % (name, name) outfile = os.path.join(self._indir, dtb_fname) TestFunctional._MakeInputFile(dtb_fname, - self._GetDtbContentsForSplTpl(dtb_data, name)) + self._GetDtbContentsForSpls(dtb_data, name))
try: retcode = self._DoTestFile(fname, map=map, update_dtb=update_dtb, @@ -563,6 +570,16 @@ class TestFunctional(unittest.TestCase): TestFunctional._MakeInputFile('tpl/u-boot-tpl', tools.ReadFile(cls.ElfTestFile(src_fname)))
+ @classmethod + def _SetupVplElf(cls, src_fname='bss_data'): + """Set up an ELF file with a '_dt_ucode_base_size' symbol + + Args: + Filename of ELF file to use as VPL + """ + TestFunctional._MakeInputFile('vpl/u-boot-vpl', + tools.ReadFile(cls.ElfTestFile(src_fname))) + @classmethod def _SetupDescriptor(cls): with open(cls.TestFile('descriptor.bin'), 'rb') as fd: @@ -1832,21 +1849,24 @@ class TestFunctional(unittest.TestCase): data = self._DoReadFileRealDtb('082_fdt_update_all.dts')
base_expected = { - 'section:image-pos': 0, - 'u-boot-tpl-dtb:size': 513, - 'u-boot-spl-dtb:size': 513, - 'u-boot-spl-dtb:offset': 493, - 'image-pos': 0, - 'section/u-boot-dtb:image-pos': 0, - 'u-boot-spl-dtb:image-pos': 493, - 'section/u-boot-dtb:size': 493, - 'u-boot-tpl-dtb:image-pos': 1006, - 'section/u-boot-dtb:offset': 0, - 'section:size': 493, 'offset': 0, + 'image-pos': 0, + 'size': 2320, 'section:offset': 0, - 'u-boot-tpl-dtb:offset': 1006, - 'size': 1519 + 'section:image-pos': 0, + 'section:size': 565, + 'section/u-boot-dtb:offset': 0, + 'section/u-boot-dtb:image-pos': 0, + 'section/u-boot-dtb:size': 565, + 'u-boot-spl-dtb:offset': 565, + 'u-boot-spl-dtb:image-pos': 565, + 'u-boot-spl-dtb:size': 585, + 'u-boot-tpl-dtb:offset': 1150, + 'u-boot-tpl-dtb:image-pos': 1150, + 'u-boot-tpl-dtb:size': 585, + 'u-boot-vpl-dtb:image-pos': 1735, + 'u-boot-vpl-dtb:offset': 1735, + 'u-boot-vpl-dtb:size': 585, }
# We expect three device-tree files in the output, one after the other. @@ -1854,11 +1874,12 @@ class TestFunctional(unittest.TestCase): # and 'tpl' in the TPL tree, to make sure they are distinct from the # main U-Boot tree. All three should have the same postions and offset. start = 0 - for item in ['', 'spl', 'tpl']: + self.maxDiff = None + for item in ['', 'spl', 'tpl', 'vpl']: dtb = fdt.Fdt.FromData(data[start:]) dtb.Scan() props = self._GetPropTree(dtb, BASE_DTB_PROPS + REPACK_DTB_PROPS + - ['spl', 'tpl']) + ['spl', 'tpl', 'vpl']) expected = dict(base_expected) if item: expected[item] = 0 @@ -1878,7 +1899,7 @@ class TestFunctional(unittest.TestCase): # over to the expected place. start = 0 for fname in ['u-boot.dtb.out', 'spl/u-boot-spl.dtb.out', - 'tpl/u-boot-tpl.dtb.out']: + 'tpl/u-boot-tpl.dtb.out', 'vpl/u-boot-vpl.dtb.out']: dtb = fdt.Fdt.FromData(data[start:]) size = dtb._fdt_obj.totalsize() pathname = tools.GetOutputFilename(os.path.split(fname)[1]) @@ -1886,7 +1907,7 @@ class TestFunctional(unittest.TestCase): name = os.path.split(fname)[0]
if name: - orig_indata = self._GetDtbContentsForSplTpl(dtb_data, name) + orig_indata = self._GetDtbContentsForSpls(dtb_data, name) else: orig_indata = dtb_data self.assertNotEqual(outdata, orig_indata, @@ -4542,5 +4563,52 @@ class TestFunctional(unittest.TestCase): data = self._DoReadFile('201_opensbi.dts') self.assertEqual(OPENSBI_DATA, data[:len(OPENSBI_DATA)])
+ def testVpl(self): + """Test that an image with VPL and its device tree can be created""" + # ELF file with a '__bss_size' symbol + self._SetupVplElf() + data = self._DoReadFile('201_u_boot_vpl.dts') + self.assertEqual(U_BOOT_VPL_DATA + U_BOOT_VPL_DTB_DATA, data) + + def testVplNoDtb(self): + """Test that an image with vpl/u-boot-vpl-nodtb.bin can be created""" + self._SetupVplElf() + data = self._DoReadFile('202_u_boot_vpl_nodtb.dts') + self.assertEqual(U_BOOT_VPL_NODTB_DATA, + data[:len(U_BOOT_VPL_NODTB_DATA)]) + + def testExpandedVpl(self): + """Test that an expanded entry type is selected for TPL when needed""" + self._SetupVplElf() + + entry_args = { + 'vpl-bss-pad': 'y', + 'vpl-dtb': 'y', + } + self._DoReadFileDtb('203_fdt_incl_vpl.dts', use_expanded=True, + entry_args=entry_args) + image = control.images['image'] + entries = image.GetEntries() + self.assertEqual(1, len(entries)) + + # We only have u-boot-vpl, which be expanded + self.assertIn('u-boot-vpl', entries) + entry = entries['u-boot-vpl'] + self.assertEqual('u-boot-vpl-expanded', entry.etype) + subent = entry.GetEntries() + self.assertEqual(3, len(subent)) + self.assertIn('u-boot-vpl-nodtb', subent) + self.assertIn('u-boot-vpl-bss-pad', subent) + self.assertIn('u-boot-vpl-dtb', subent) + + def testVplBssPadMissing(self): + """Test that a missing symbol is detected""" + self._SetupVplElf('u_boot_ucode_ptr') + with self.assertRaises(ValueError) as e: + self._DoReadFile('204_vpl_bss_pad.dts') + self.assertIn('Expected __bss_size symbol in vpl/u-boot-vpl', + str(e.exception)) + + if __name__ == "__main__": unittest.main() diff --git a/tools/binman/state.py b/tools/binman/state.py index dfb17604554..e4a3abd2805 100644 --- a/tools/binman/state.py +++ b/tools/binman/state.py @@ -17,6 +17,7 @@ from patman import tout DTB_TYPE_FNAME = { 'u-boot-spl-dtb': 'spl/u-boot-spl.dtb', 'u-boot-tpl-dtb': 'tpl/u-boot-tpl.dtb', + 'u-boot-vpl-dtb': 'vpl/u-boot-vpl.dtb', }
# Records the device-tree files known to binman, keyed by entry type (e.g. @@ -263,7 +264,7 @@ def GetAllFdts(): """Yield all device tree files being used by binman
Yields: - Device trees being used (U-Boot proper, SPL, TPL) + Device trees being used (U-Boot proper, SPL, TPL, VPL) """ if main_dtb: yield main_dtb diff --git a/tools/binman/test/082_fdt_update_all.dts b/tools/binman/test/082_fdt_update_all.dts index 284975cc289..1aea56989f0 100644 --- a/tools/binman/test/082_fdt_update_all.dts +++ b/tools/binman/test/082_fdt_update_all.dts @@ -14,5 +14,7 @@ }; u-boot-tpl-dtb { }; + u-boot-vpl-dtb { + }; }; }; diff --git a/tools/binman/test/201_u_boot_vpl.dts b/tools/binman/test/201_u_boot_vpl.dts new file mode 100644 index 00000000000..a3a281a91e0 --- /dev/null +++ b/tools/binman/test/201_u_boot_vpl.dts @@ -0,0 +1,11 @@ +// SPDX-License-Identifier: GPL-2.0+ +/dts-v1/; + +/ { + binman { + u-boot-vpl { + }; + u-boot-vpl-dtb { + }; + }; +}; diff --git a/tools/binman/test/202_u_boot_vpl_nodtb.dts b/tools/binman/test/202_u_boot_vpl_nodtb.dts new file mode 100644 index 00000000000..055016badd5 --- /dev/null +++ b/tools/binman/test/202_u_boot_vpl_nodtb.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl-nodtb { + }; + }; +}; diff --git a/tools/binman/test/203_fdt_incl_vpl.dts b/tools/binman/test/203_fdt_incl_vpl.dts new file mode 100644 index 00000000000..435256fe317 --- /dev/null +++ b/tools/binman/test/203_fdt_incl_vpl.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl { + }; + }; +}; diff --git a/tools/binman/test/204_vpl_bss_pad.dts b/tools/binman/test/204_vpl_bss_pad.dts new file mode 100644 index 00000000000..d1e55fff4f2 --- /dev/null +++ b/tools/binman/test/204_vpl_bss_pad.dts @@ -0,0 +1,17 @@ +/dts-v1/; + +/ { + #address-cells = <1>; + #size-cells = <1>; + + binman { + u-boot-vpl { + }; + + u-boot-vpl-bss-pad { + }; + + u-boot { + }; + }; +};
Add support for VPL, a new phase of U-Boot. This runs after TPL. It is responsible for selecting which SPL binary to run, based on a verified-boot process.
Makefile | 13 +++++++++++++ common/spl/Kconfig | 15 ++++++++++++++- common/spl/spl.c | 25 ++++++++++++++++++++++--- doc/develop/spl.rst | 6 +++++- include/bootstage.h | 2 ++ include/linux/kconfig.h | 3 +++ include/spl.h | 20 +++++++++++++++++--- scripts/Kbuild.include | 4 ++++ scripts/Makefile.autoconf | 12 ++++++++++++ scripts/Makefile.build | 4 ++++ scripts/Makefile.lib | 5 +++++ scripts/Makefile.spl | 35 ++++++++++++++++++++++++++--------- 12 files changed, 127 insertions(+), 17 deletions(-)
diff --git a/Makefile b/Makefile index f7f62979ae2..b2ba80ca5de 100644 --- a/Makefile +++ b/Makefile @@ -946,6 +946,7 @@ INPUTS-$(CONFIG_SPL_FRAMEWORK) += u-boot.img endif endif INPUTS-$(CONFIG_TPL) += tpl/u-boot-tpl.bin +INPUTS-$(CONFIG_VPL) += vpl/u-boot-vpl.bin INPUTS-$(CONFIG_OF_SEPARATE) += u-boot.dtb INPUTS-$(CONFIG_BINMAN_STANDALONE_FDT) += u-boot.dtb ifeq ($(CONFIG_SPL_FRAMEWORK),y) @@ -1986,6 +1987,18 @@ tpl/u-boot-tpl.bin: tools prepare \ $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all $(TPL_SIZE_CHECK)
+tpl/u-boot-tpl: tools prepare \ + $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_OF_HOSTFILE)$(CONFIG_TPL_OF_PLATDATA),dts/dt.dtb) + $(Q)$(MAKE) obj=tpl -f $(srctree)/scripts/Makefile.spl all + +vpl/u-boot-vpl.bin: vpl/u-boot-vpl + @: + $(VPL_SIZE_CHECK) + +vpl/u-boot-vpl: tools prepare \ + $(if $(CONFIG_OF_SEPARATE)$(CONFIG_OF_EMBED)$(CONFIG_OF_HOSTFILE)$(CONFIG_VPL_OF_PLATDATA),dts/dt.dtb) + $(Q)$(MAKE) obj=vpl -f $(srctree)/scripts/Makefile.spl all + TAG_SUBDIRS := $(patsubst %,$(srctree)/%,$(u-boot-dirs) include)
FIND := find diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 10384b835b2..0443197cd55 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -1,4 +1,4 @@ -menu "SPL / TPL" +menu "SPL / TPL / VPL"
config SUPPORT_SPL bool @@ -6,6 +6,9 @@ config SUPPORT_SPL config SUPPORT_TPL bool
+config SUPPORT_VPL + bool + config SPL_DFU_NO_RESET bool
@@ -280,6 +283,16 @@ config SPL_READ_ONLY writeable memory) of anything it wants to modify, such as device-private data.
+config TPL_SEPARATE_BSS + bool "BSS section is in a different memory region from text" + default y if SPL_SEPARATE_BSS + help + Some platforms need a large BSS region in TPL and can provide this + because RAM is already set up. In this case BSS can be moved to RAM. + This option should then be enabled so that the correct device tree + location is used. Normally we put the device tree at the end of BSS + but with this option enabled, it goes at _image_binary_end. + config SPL_BANNER_PRINT bool "Enable output of the SPL banner 'U-Boot SPL ...'" default y diff --git a/common/spl/spl.c b/common/spl/spl.c index eba77cace6d..27ed855c018 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -55,6 +55,11 @@ binman_sym_declare(ulong, spl, image_pos); binman_sym_declare(ulong, spl, size); #endif
+#ifdef CONFIG_VPL +binman_sym_declare(ulong, vpl, image_pos); +binman_sym_declare(ulong, vpl, size); +#endif + /* Define board data structure */ static struct bd_info bdata __attribute__ ((section(".data")));
@@ -139,21 +144,33 @@ void spl_fixup_fdt(void *fdt_blob)
ulong spl_get_image_pos(void) { - return spl_phase() == PHASE_TPL ? +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return binman_sym(ulong, vpl, image_pos); +#endif + return spl_next_phase() == PHASE_SPL ? binman_sym(ulong, spl, image_pos) : binman_sym(ulong, u_boot_any, image_pos); }
ulong spl_get_image_size(void) { - return spl_phase() == PHASE_TPL ? +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return binman_sym(ulong, vpl, size); +#endif + return spl_next_phase() == PHASE_SPL ? binman_sym(ulong, spl, size) : binman_sym(ulong, u_boot_any, size); }
ulong spl_get_image_text_base(void) { - return spl_phase() == PHASE_TPL ? CONFIG_SPL_TEXT_BASE : +#ifdef CONFIG_VPL + if (spl_next_phase() == PHASE_VPL) + return CONFIG_VPL_TEXT_BASE; +#endif + return spl_next_phase() == PHASE_SPL ? CONFIG_SPL_TEXT_BASE : CONFIG_SYS_TEXT_BASE; }
@@ -430,6 +447,8 @@ static enum bootstage_id get_bootstage_id(bool start)
if (IS_ENABLED(CONFIG_TPL_BUILD) && phase == PHASE_TPL) return start ? BOOTSTAGE_ID_START_TPL : BOOTSTAGE_ID_END_TPL; + else if (IS_ENABLED(CONFIG_VPL_BUILD) && phase == PHASE_VPL) + return start ? BOOTSTAGE_ID_START_VPL : BOOTSTAGE_ID_END_VPL; else return start ? BOOTSTAGE_ID_START_SPL : BOOTSTAGE_ID_END_SPL; } diff --git a/doc/develop/spl.rst b/doc/develop/spl.rst index c2a29a8c0a4..ede79431118 100644 --- a/doc/develop/spl.rst +++ b/doc/develop/spl.rst @@ -62,7 +62,11 @@ U-Boot Phases U-Boot boots through the following phases:
TPL - Very early init, as tiny as possible. This loads SPL. + Very early init, as tiny as possible. This loads SPL (or VPL if enabled). + +VPL + Optional verification step, which can select one of several SPL binaries, + if A/B verified boot
SPL Secondary program loader. Sets up SDRAM and loads U-Boot proper. It may also diff --git a/include/bootstage.h b/include/bootstage.h index f837a387c8c..1a384e5b60a 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -176,6 +176,8 @@ enum bootstage_id { BOOTSTAGE_ID_END_TPL, BOOTSTAGE_ID_START_SPL, BOOTSTAGE_ID_END_SPL, + BOOTSTAGE_ID_START_VPL, + BOOTSTAGE_ID_END_VPL, BOOTSTAGE_ID_START_UBOOT_F, BOOTSTAGE_ID_START_UBOOT_R, BOOTSTAGE_ID_USB_START, diff --git a/include/linux/kconfig.h b/include/linux/kconfig.h index d109ed3119e..26f1216f7da 100644 --- a/include/linux/kconfig.h +++ b/include/linux/kconfig.h @@ -37,6 +37,8 @@
#if defined(CONFIG_TPL_BUILD) #define _CONFIG_PREFIX TPL_ +#elif defined(CONFIG_VPL_BUILD) +#define _CONFIG_PREFIX VPL_ #elif defined(CONFIG_SPL_BUILD) #define _CONFIG_PREFIX SPL_ #else @@ -52,6 +54,7 @@ * CONFIG_FOO if CONFIG_SPL_BUILD is undefined, * CONFIG_SPL_FOO if CONFIG_SPL_BUILD is defined. * CONFIG_TPL_FOO if CONFIG_TPL_BUILD is defined. + * CONFIG_VPL_FOO if CONFIG_VPL_BUILD is defined. */ #define CONFIG_VAL(option) config_val(option)
diff --git a/include/spl.h b/include/spl.h index cee9a42ddb5..d9fe4e1bfd4 100644 --- a/include/spl.h +++ b/include/spl.h @@ -60,6 +60,7 @@ static inline bool u_boot_first_phase(void) enum u_boot_phase { PHASE_NONE, /* Invalid phase, signifying before U-Boot */ PHASE_TPL, /* Running in TPL */ + PHASE_VPL, /* Running in VPL */ PHASE_SPL, /* Running in SPL */ PHASE_BOARD_F, /* Running in U-Boot before relocation */ PHASE_BOARD_R, /* Running in U-Boot after relocation */ @@ -112,7 +113,9 @@ static inline enum u_boot_phase spl_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_TPL; -#elif CONFIG_SPL_BUILD +#elif defined(CONFIG_VPL_BUILD) + return PHASE_VPL; +#elif defined(CONFIG_SPL_BUILD) return PHASE_SPL; #else DECLARE_GLOBAL_DATA_PTR; @@ -134,10 +137,15 @@ static inline enum u_boot_phase spl_prev_phase(void) { #ifdef CONFIG_TPL_BUILD return PHASE_NONE; +#elif defined(CONFIG_VPL_BUILD) + return PHASE_TPL; /* VPL requires TPL */ #elif defined(CONFIG_SPL_BUILD) - return IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : PHASE_NONE; + return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : + IS_ENABLED(CONFIG_TPL) ? PHASE_TPL : + PHASE_NONE; #else - return IS_ENABLED(CONFIG_SPL) ? PHASE_SPL : PHASE_NONE; + return IS_ENABLED(CONFIG_SPL) ? PHASE_SPL : + PHASE_NONE; #endif }
@@ -150,6 +158,8 @@ static inline enum u_boot_phase spl_prev_phase(void) static inline enum u_boot_phase spl_next_phase(void) { #ifdef CONFIG_TPL_BUILD + return IS_ENABLED(CONFIG_VPL) ? PHASE_VPL : PHASE_SPL; +#elif defined(CONFIG_VPL_BUILD) return PHASE_SPL; #else return PHASE_BOARD_F; @@ -166,6 +176,8 @@ static inline const char *spl_phase_name(enum u_boot_phase phase) switch (phase) { case PHASE_TPL: return "TPL"; + case PHASE_VPL: + return "VPL"; case PHASE_SPL: return "SPL"; case PHASE_BOARD_F: @@ -180,6 +192,8 @@ static inline const char *spl_phase_name(enum u_boot_phase phase) #ifdef CONFIG_SPL_BUILD # ifdef CONFIG_TPL_BUILD # define SPL_TPL_NAME "TPL" +# elif defined(CONFIG_VPL_BUILD) +# define SPL_TPL_NAME "VPL" # else # define SPL_TPL_NAME "SPL" # endif diff --git a/scripts/Kbuild.include b/scripts/Kbuild.include index dfb67226b08..c87d9c9f5f2 100644 --- a/scripts/Kbuild.include +++ b/scripts/Kbuild.include @@ -325,11 +325,15 @@ endif
ifdef CONFIG_SPL_BUILD SPL_ := SPL_ +ifeq ($(CONFIG_VPL_BUILD),y) +SPL_TPL_ := VPL_ +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_TPL_ := TPL_ else SPL_TPL_ := SPL_ endif +endif else SPL_ := SPL_TPL_ := diff --git a/scripts/Makefile.autoconf b/scripts/Makefile.autoconf index 0bfc1b2a629..ad556f80f71 100644 --- a/scripts/Makefile.autoconf +++ b/scripts/Makefile.autoconf @@ -18,6 +18,10 @@ ifeq ($(shell grep -q '^CONFIG_TPL=y' include/config/auto.conf 2>/dev/null && ec __all: tpl/include/autoconf.mk endif
+ifeq ($(shell grep -q '^CONFIG_VPL=y' include/config/auto.conf 2>/dev/null && echo y),y) +__all: vpl/include/autoconf.mk +endif + include include/config/auto.conf
include scripts/Kbuild.include @@ -84,6 +88,10 @@ tpl/u-boot.cfg: include/config.h FORCE $(Q)mkdir -p $(dir $@) $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_TPL_BUILD)
+vpl/u-boot.cfg: include/config.h FORCE + $(Q)mkdir -p $(dir $@) + $(call cmd,u_boot_cfg,-DCONFIG_SPL_BUILD -DCONFIG_VPL_BUILD) + include/autoconf.mk: u-boot.cfg $(call cmd,autoconf)
@@ -95,6 +103,10 @@ tpl/include/autoconf.mk: tpl/u-boot.cfg $(Q)mkdir -p $(dir $@) $(call cmd,autoconf)
+vpl/include/autoconf.mk: vpl/u-boot.cfg + $(Q)mkdir -p $(dir $@) + $(call cmd,autoconf) + # include/config.h # Prior to Kconfig, it was generated by mkconfig. Now it is created here. define filechk_config_h diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 7e59ca54cd0..1d72ba18ebd 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -4,6 +4,9 @@ # ==========================================================================
# Modified for U-Boot +prefix := vpl +src := $(patsubst $(prefix)/%,%,$(obj)) +ifeq ($(obj),$(src)) prefix := tpl src := $(patsubst $(prefix)/%,%,$(obj)) ifeq ($(obj),$(src)) @@ -13,6 +16,7 @@ ifeq ($(obj),$(src)) prefix := . endif endif +endif
PHONY := __build __build: diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 78bbebe7e93..c08ad44db5f 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -556,16 +556,21 @@ cmd_mkimage = $(objtree)/tools/mkimage $(MKIMAGEFLAGS_$(@F)) -d $< $@ \ # 'u-boot,dm-pre-reloc' property and thus are not needed by SPL. The second # pass removes various unused properties from the remaining nodes. # The output is typically a much smaller device tree file. +ifeq ($(CONFIG_VPL_BUILD),y) +fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-vpl +else ifeq ($(CONFIG_TPL_BUILD),y) fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-tpl else fdtgrep_props := -b u-boot,dm-pre-reloc -b u-boot,dm-spl endif +endif quiet_cmd_fdtgrep = FDTGREP $@ cmd_fdtgrep = $(objtree)/tools/fdtgrep $(fdtgrep_props) -RT $< \ -n /chosen -n /config -O dtb | \ $(objtree)/tools/fdtgrep -r -O dtb - -o $@ \ -P u-boot,dm-pre-reloc -P u-boot,dm-spl -P u-boot,dm-tpl \ + -P u-boot,dm-vpl \ $(addprefix -P ,$(subst $",,$(CONFIG_OF_SPL_REMOVE_PROPS)))
# fdt_rm_props diff --git a/scripts/Makefile.spl b/scripts/Makefile.spl index ffe919dafab..082ddb9c5f2 100644 --- a/scripts/Makefile.spl +++ b/scripts/Makefile.spl @@ -27,8 +27,16 @@ UBOOTINCLUDE := -I$(obj)/include $(UBOOTINCLUDE) KBUILD_CPPFLAGS += -DCONFIG_SPL_BUILD ifeq ($(CONFIG_TPL_BUILD),y) KBUILD_CPPFLAGS += -DCONFIG_TPL_BUILD +else +ifeq ($(CONFIG_VPL_BUILD),y) +KBUILD_CPPFLAGS += -DCONFIG_VPL_BUILD +endif endif
+ifeq ($(CONFIG_VPL_BUILD),y) +SPL_BIN := u-boot-vpl +SPL_NAME := vpl +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_BIN := u-boot-tpl SPL_NAME := tpl @@ -36,16 +44,21 @@ else SPL_BIN := u-boot-spl SPL_NAME := spl endif +endif
export SPL_NAME
ifdef CONFIG_SPL_BUILD SPL_ := SPL_ +ifeq ($(CONFIG_VPL_BUILD),y) +SPL_TPL_ := VPL_ +else ifeq ($(CONFIG_TPL_BUILD),y) SPL_TPL_ := TPL_ else SPL_TPL_ := SPL_ endif +endif else SPL_ := SPL_TPL_ := @@ -57,6 +70,9 @@ endif ifeq ($(obj)$(CONFIG_SUPPORT_TPL),tpl) $(error You cannot build TPL without enabling CONFIG_SUPPORT_TPL) endif +ifeq ($(obj)$(CONFIG_SUPPORT_VPL),vpl) +$(error You cannot build VPL without enabling CONFIG_SUPPORT_VPL) +endif
include $(srctree)/config.mk include $(srctree)/arch/$(ARCH)/Makefile @@ -90,13 +106,12 @@ libs-$(CONFIG_SPL_FRAMEWORK) += common/spl/ endif libs-y += common/init/
+# Special handling for a few options which support SPL/TPL/VPL +libs-$(CONFIG_$(SPL_TPL_)LIBCOMMON_SUPPORT) += common/ cmd/ env/ +libs-$(CONFIG_$(SPL_TPL_)LIBGENERIC_SUPPORT) += lib/ + # Special handling for a few options which support SPL/TPL -ifeq ($(CONFIG_TPL_BUILD),y) -libs-$(CONFIG_TPL_LIBCOMMON_SUPPORT) += common/ cmd/ env/ -libs-$(CONFIG_TPL_LIBGENERIC_SUPPORT) += lib/ -else -libs-$(CONFIG_SPL_LIBCOMMON_SUPPORT) += common/ cmd/ env/ -libs-$(CONFIG_SPL_LIBGENERIC_SUPPORT) += lib/ +ifeq ($(CONFIG_TPL_BUILD)$(CONFIG_VPL_BUILD),) ifdef CONFIG_SPL_FRAMEWORK libs-$(CONFIG_PARTITIONS) += disk/ endif @@ -182,7 +197,7 @@ LDPPFLAGS += \ sed -ne 's/GNU ld version ([0-9][0-9]*).([0-9][0-9]*).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
# Turn various CONFIG symbols into IMAGE symbols for easy reuse of -# the scripts between SPL and TPL. +# the scripts between SPL, TPL and VPL. ifneq ($(CONFIG_$(SPL_TPL_)MAX_SIZE),) LDPPFLAGS += -DIMAGE_MAX_SIZE=$(CONFIG_$(SPL_TPL_)MAX_SIZE) endif @@ -264,6 +279,7 @@ ifeq ($(CONFIG_SYS_SOC),"at91") INPUTS-y += $(obj)/boot.bin endif
+ifndef CONFIG_VPL_BUILD ifdef CONFIG_TPL_BUILD INPUTS-$(CONFIG_TPL_X86_16BIT_INIT) += $(obj)/u-boot-x86-start16-tpl.bin \ $(obj)/u-boot-x86-reset16-tpl.bin @@ -271,6 +287,7 @@ else INPUTS-$(CONFIG_SPL_X86_16BIT_INIT) += $(obj)/u-boot-x86-start16-spl.bin \ $(obj)/u-boot-x86-reset16-spl.bin endif +endif
INPUTS-$(CONFIG_ARCH_ZYNQ) += $(obj)/boot.bin INPUTS-$(CONFIG_ARCH_ZYNQMP) += $(obj)/boot.bin @@ -310,7 +327,7 @@ endif
ifneq ($(build_dtb),) $(obj)/$(SPL_BIN)-dtb.bin: $(obj)/$(SPL_BIN)-nodtb.bin \ - $(if $(CONFIG_SPL_SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ + $(if $(CONFIG_$(SPL_TPL_)SEPARATE_BSS),,$(obj)/$(SPL_BIN)-pad.bin) \ $(FINAL_DTB_CONTAINER) FORCE $(call if_changed,cat)
@@ -401,7 +418,7 @@ LDFLAGS_$(SPL_BIN) += $(call ld-option, --no-dynamic-linker)
LDFLAGS_$(SPL_BIN) += --build-id=none
-# Pick the best-match (i.e. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) +# Pick the best match (e.g. SPL_TEXT_BASE for SPL, TPL_TEXT_BASE for TPL) ifneq ($(CONFIG_$(SPL_TPL_)TEXT_BASE),) LDFLAGS_$(SPL_BIN) += -Ttext $(CONFIG_$(SPL_TPL_)TEXT_BASE) endif
Add VPL versions of commonly used Kconfig options.
Kconfig | 10 +++ arch/sandbox/Kconfig | 8 ++ common/Kconfig | 67 ++++++++++++++ common/spl/Kconfig | 189 +++++++++++++++++++++++++++++++++++++++ drivers/clk/Kconfig | 10 +++ drivers/core/Makefile | 2 +- drivers/gpio/Kconfig | 11 +++ drivers/i2c/Kconfig | 11 +++ drivers/misc/Kconfig | 19 ++++ drivers/pinctrl/Kconfig | 18 +++- drivers/rtc/Kconfig | 9 ++ drivers/serial/Kconfig | 20 +++++ drivers/sysreset/Kconfig | 10 +++ drivers/timer/Kconfig | 10 +++ lib/Kconfig | 62 +++++++++++++ 15 files changed, 453 insertions(+), 3 deletions(-)
diff --git a/Kconfig b/Kconfig index f8c1a77bedb..8cd8c59d045 100644 --- a/Kconfig +++ b/Kconfig @@ -264,6 +264,16 @@ config TPL_SYS_MALLOC_F_LEN particular needs this to operate, so that it can allocate the initial serial device and any others that are needed.
+config VPL_SYS_MALLOC_F_LEN + hex "Size of malloc() pool in VPL before relocation" + depends on SYS_MALLOC_F && VPL + default SYS_MALLOC_F_LEN + help + Before relocation, memory is very limited on many platforms. Still, + we can provide a small malloc() pool if needed. Driver model in + particular needs this to operate, so that it can allocate the + initial serial device and any others that are needed. + menuconfig EXPERT bool "Configure standard U-Boot features (expert users)" default y diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index f83282d9d56..e504b08b951 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -29,6 +29,14 @@ config SANDBOX_SPL bool "Enable SPL for sandbox" select SUPPORT_SPL
+config SANDBOX_TPL + bool "Enable TPL for sandbox" + select SUPPORT_TPL + +config SANDBOX_VPL + bool "Enable VPL for sandbox" + select SUPPORT_VPL + config SYS_CONFIG_NAME default "sandbox_spl" if SANDBOX_SPL default "sandbox" if !SANDBOX_SPL diff --git a/common/Kconfig b/common/Kconfig index 26496f9a2e7..2a7f08af1dc 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -81,6 +81,15 @@ config TPL_LOGLEVEL int default LOGLEVEL
+config VPL_LOGLEVEL + int "loglevel for VPL" + default LOGLEVEL + help + All Messages with a loglevel smaller than the console loglevel will + be compiled in to VPL. See LOGLEVEL for a list of available log + levels. Setting this to a value above 4 may increase the code size + significantly. + config SILENT_CONSOLE bool "Support a silent console" help @@ -254,6 +263,15 @@ config LOG
if LOG
+config VPL_LOG + bool "Enable logging support in VPL" + depends on LOG + help + This enables support for logging of status and debug messages. These + can be displayed on the console, recorded in a memory buffer, or + discarded if not needed. Logging supports various categories and + levels of severity. + config LOG_MAX_LEVEL int "Maximum log level to record" default 6 @@ -415,6 +433,47 @@ config TPL_LOG_CONSOLE
endif
+config VPL_LOG + bool "Enable logging support in VPL" + depends on LOG + help + This enables support for logging of status and debug messages. These + can be displayed on the console, recorded in a memory buffer, or + discarded if not needed. Logging supports various categories and + levels of severity. + +if VPL_LOG + +config VPL_LOG_MAX_LEVEL + int "Maximum log level to record in VPL" + default 3 + help + This selects the maximum log level that will be recorded. Any value + higher than this will be ignored. If possible log statements below + this level will be discarded at build time. Levels: + + 0 - emergency + 1 - alert + 2 - critical + 3 - error + 4 - warning + 5 - note + 6 - info + 7 - debug + 8 - debug content + 9 - debug hardware I/O + +config VPL_LOG_CONSOLE + bool "Allow log output to the console in VPL" + default y + help + Enables a log driver which writes log records to the console. + Generally the console is the serial port or LCD display. Only the + log message is shown - other details like level, category, file and + line number are omitted. + +endif + config LOG_ERROR_RETURN bool "Log all functions which return an error" help @@ -711,6 +770,14 @@ config TPL_BLOBLIST This enables a bloblist in TPL. The bloblist is set up in TPL and passed to SPL and U-Boot proper.
+config VPL_BLOBLIST + bool "Support for a bloblist in VPL" + depends on BLOBLIST + default y if TPL_BLOBLIST + help + This enables a bloblist in VPL. The bloblist is set up in VPL and + passed to SPL and U-Boot proper. + config BLOBLIST_SIZE hex "Size of bloblist" depends on BLOBLIST diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0443197cd55..106296d81d6 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -167,6 +167,13 @@ config SPL_BOARD_INIT spl_board_init() from board_init_r(). This function should be provided by the board.
+config VPL_BOARD_INIT + bool "Call board-specific initialization in VPL" + help + If this option is enabled, U-Boot will call the function + spl_board_init() from board_init_r(). This function should be + provided by the board. + config SPL_BOOTROM_SUPPORT bool "Support returning to the BOOTROM" help @@ -310,6 +317,15 @@ config TPL_BANNER_PRINT info. Disabling this option could be useful to reduce TPL boot time (e.g. approx. 6 ms faster, when output on i.MX6 with 115200 baud).
+config VPL_BANNER_PRINT + bool "Enable output of the VPL banner 'U-Boot VPL ...'" + depends on VPL + default y + help + If this option is enabled, VPL will print the banner with version + info. Disabling this option could be useful to reduce VPL boot time + (e.g. approx. 6 ms faster, when output on i.MX6 with 115200 baud). + config SPL_EARLY_BSS depends on ARM && !ARM64 bool "Allows initializing BSS early before entering board_init_f" @@ -819,6 +835,27 @@ config SPL_DM_SPI_FLASH Enable support for SPI DM flash drivers in SPL.
endif + +if TPL + +config VPL_CACHE + depends on CACHE + bool "Support cache drivers in SPL" + help + Enable support for cache drivers in SPL. + +config VPL_DM_SPI + bool "Support SPI DM drivers in SPL" + help + Enable support for SPI DM drivers in SPL. + +config VPL_DM_SPI_FLASH + bool "Support SPI DM FLASH drivers in SPL" + help + Enable support for SPI DM flash drivers in SPL. + +endif + if SPL_UBI config SPL_UBI_LOAD_BY_VOLNAME bool "Support loading volumes by name" @@ -1636,6 +1673,158 @@ config TPL_YMODEM_SUPPORT
endif # TPL
+config VPL + bool + depends on SUPPORT_SPL + prompt "Enable VPL" + help + If you want to build VPL as well as the normal image, TPL and SPL, + say Y. + +if VPL + +config VPL_FRAMEWORK + bool "Support VPL based upon the common SPL framework" + default y + help + Enable the SPL framework under common/spl/ for VPL builds. + This framework supports MMC, NAND and YMODEM and other methods + loading of U-Boot's next stage. If unsure, say Y. + +config VPL_HANDOFF + bool "Pass hand-off information from VPL to SPL" + depends on HANDOFF && VPL_BLOBLIST + default y + help + This option enables VPL to write handoff information. This can be + used to pass information like the size of SDRAM from VPL to SPL. Also + VPL can receive information from TPL in the same place if that is + enabled. + +config VPL_LIBCOMMON_SUPPORT + bool "Support common libraries" + default y if SPL_LIBCOMMON_SUPPORT + help + Enable support for common U-Boot libraries within VPL. See + SPL_LIBCOMMON_SUPPORT for details. + +config VPL_LIBGENERIC_SUPPORT + bool "Support generic libraries" + default y if SPL_LIBGENERIC_SUPPORT + help + Enable support for generic U-Boot libraries within VPL. These + libraries include generic code to deal with device tree, hashing, + printf(), compression and the like. This option is enabled on many + boards. Enable this option to build the code in lib/ as part of an + SPL build. + +config VPL_DRIVERS_MISC_SUPPORT + bool "Support misc drivers" + default y if TPL_DRIVERS_MISC_SUPPORT + help + Enable miscellaneous drivers in VPL. These drivers perform various + tasks that don't fall nicely into other categories, Enable this + option to build the drivers in drivers/misc as part of an VPL + build, for those that support building in VPL (not all drivers do). + +config VPL_ENV_SUPPORT + bool "Support an environment" + help + Enable environment support in VPL. The U-Boot environment provides + a number of settings (essentially name/value pairs) which can + control many aspects of U-Boot's operation. Enabling this option will + make env_get() and env_set() available in VSPL. + +config VPL_GPIO_SUPPORT + bool "Support GPIO in VPL" + default y if SPL_GPIO_SUPPORT + help + Enable support for GPIOs (General-purpose Input/Output) in VPL. + GPIOs allow U-Boot to read the state of an input line (high or + low) and set the state of an output line. This can be used to + drive LEDs, control power to various system parts and read user + input. GPIOs can be useful in TPL to enable a 'sign-of-life' LED, + for example. Enable this option to build the drivers in + drivers/gpio as part of an TPL build. + +config VPL_HASH_SUPPORT + bool "Support hashing drivers in VPL" + depends on VPL + select SHA1 + select SHA256 + help + Enable hashing drivers in SPL. These drivers can be used to + accelerate secure boot processing in secure applications. Enable + this option to build system-specific drivers for hash acceleration + as part of an SPL build. + +config VPL_I2C_SUPPORT + bool "Support I2C in VPL" + default y if SPL_I2C_SUPPORT + help + Enable support for the I2C bus in TPL. Vee SPL_I2C_SUPPORT for + details. + +config VPL_PCH_SUPPORT + bool "Support PCH drivers" + default y if TPL_PCH_SUPPORT + help + Enable support for PCH (Platform Controller Hub) devices in VPL. + These are used to set up GPIOs and the SPI peripheral early in + boot. This enables the drivers in drivers/pch as part of a VPL + build. + +config VPL_PCI + bool "Support PCI drivers" + default y if SPL_PCI + help + Enable support for PCI in VPL. For platforms that need PCI to boot, + or must perform some init using PCI in VPL, this provides the + necessary driver support. This enables the drivers in drivers/pci + as part of a VPL build. + +config VPL_RTC_SUPPORT + bool "Support RTC drivers" + help + Enable RTC (Real-time Clock) support in VPL. This includes support + for reading and setting the time. Some RTC devices also have some + non-volatile (battery-backed) memory which is accessible if + needed. This enables the drivers in drivers/rtc as part of an VPL + build. + +config VPL_SERIAL_SUPPORT + bool "Support serial" + default y if SPL_SERIAL_SUPPORT + select VPL_PRINTF + select VPL_STRTO + help + Enable support for serial in VPL. See SPL_SERIAL_SUPPORT for + details. + +config VPL_SPI_SUPPORT + bool "Support SPI drivers" + help + Enable support for using SPI in VPL. See SPL_SPI_SUPPORT for + details. + +config VPL_SPI_FLASH_SUPPORT + bool "Support SPI flash drivers" + help + Enable support for using SPI flash in VPL, and loading U-Boot from + SPI flash. SPI flash (Serial Peripheral Bus flash) is named after + the SPI bus that is used to connect it to a system. It is a simple + but fast bidirectional 4-wire bus (clock, chip select and two data + lines). This enables the drivers in drivers/mtd/spi as part of an + VPL build. This normally requires VPL_SPI_SUPPORT. + +config VPL_TEXT_BASE + hex "VPL Text Base" + default 0x0 + help + The address in memory that VPL will be running from. + +endif + config SPL_AT91_MCK_BYPASS bool "Use external clock signal as a source of main clock for AT91 platforms" depends on ARCH_AT91 diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index e07c6dd78a6..4b0bed66bfb 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -30,6 +30,16 @@ config TPL_CLK setting up clocks within TPL, and allows the same drivers to be used as U-Boot proper.
+config VPL_CLK + bool "Enable clock support in VPL" + depends on CLK && VPL_DM + help + The clock subsystem adds a small amount of overhead to the image. + If this is acceptable and you have a need to use clock drivers in + SPL, enable this option. It might provide a cleaner interface to + setting up clocks within TPL, and allows the same drivers to be + used as U-Boot proper. + config CLK_BCM6345 bool "Clock controller driver for BCM6345" depends on CLK && ARCH_BMIPS diff --git a/drivers/core/Makefile b/drivers/core/Makefile index 5edd4e41357..07a0886383f 100644 --- a/drivers/core/Makefile +++ b/drivers/core/Makefile @@ -5,7 +5,7 @@ obj-y += device.o fdtaddr.o lists.o root.o uclass.o util.o obj-$(CONFIG_$(SPL_TPL_)ACPIGEN) += acpi.o obj-$(CONFIG_DEVRES) += devres.o -obj-$(CONFIG_$(SPL_)DM_DEVICE_REMOVE) += device-remove.o +obj-$(CONFIG_$(SPL_TPL_)DM_DEVICE_REMOVE) += device-remove.o obj-$(CONFIG_$(SPL_)SIMPLE_BUS) += simple-bus.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_DM) += dump.o diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index de4dc51d4b4..36a0074f5b9 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -36,6 +36,17 @@ config TPL_DM_GPIO particular GPIOs that they provide. The uclass interface is defined in include/asm-generic/gpio.h.
+config VPL_DM_GPIO + bool "Enable Driver Model for GPIO drivers in VPL" + depends on DM_GPIO && VPL_DM && VPL_GPIO + default y + help + Enable driver model for GPIO access in VPL. The standard GPIO + interface (gpio_get_value(), etc.) is then implemented by + the GPIO uclass. Drivers provide methods to query the + particular GPIOs that they provide. The uclass interface + is defined in include/asm-generic/gpio.h. + config GPIO_HOG bool "Enable GPIO hog support" depends on DM_GPIO diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 35d6e2c8ec5..31f9cb44769 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -25,6 +25,17 @@ config SPL_DM_I2C device (bus child) info is kept as parent platdata. The interface is defined in include/i2c.h.
+config VPL_DM_I2C + bool "Enable Driver Model for I2C drivers in VPL" + depends on VPL_DM && DM_I2C + default y + help + Enable driver model for I2C. The I2C uclass interface: probe, read, + write and speed, is implemented with the bus drivers operations, + which provide methods for bus setting and data transfer. Each chip + device (bus child) info is kept as parent platdata. The interface + is defined in include/i2c.h. + config I2C_CROS_EC_TUNNEL tristate "Chrome OS EC tunnel I2C bus" depends on CROS_EC diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index 997b7132211..12f419771a2 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -122,6 +122,16 @@ config TPL_CROS_EC control access to the battery and main PMIC depending on the device. You can use the 'crosec' command to access it.
+config VPL_CROS_EC + bool "Enable Chrome OS EC in VPL" + depends on VPL + help + Enable access to the Chrome OS EC in VPL. This is a separate + microcontroller typically available on a SPI bus on Chromebooks. It + provides access to the keyboard, some internal storage and may + control access to the battery and main PMIC depending on the + device. You can use the 'crosec' command to access it. + config CROS_EC_I2C bool "Enable Chrome OS EC I2C driver" depends on CROS_EC @@ -185,6 +195,15 @@ config TPL_CROS_EC_SANDBOX EC flash read/write/erase support and a few other things. It is enough to perform a Chrome OS verified boot on sandbox.
+config VPL_CROS_EC_SANDBOX + bool "Enable Chrome OS EC sandbox driver in VPL" + depends on VPL_CROS_EC && SANDBOX + help + Enable a sandbox emulation of the Chrome OS EC in VPL. This supports + keyboard (use the -l flag to enable the LCD), verified boot context, + EC flash read/write/erase support and a few other things. It is + enough to perform a Chrome OS verified boot on sandbox. + config CROS_EC_SPI bool "Enable Chrome OS EC SPI driver" depends on CROS_EC diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 77fb8511144..d967a82f726 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -89,20 +89,34 @@ config TPL_PINCTRL This option is an TPL variant of the PINCTRL option. See the help of PINCTRL for details.
+config VPL_PINCTRL + bool "Support pin controllers in VPL" + depends on VPL && VPL_DM + help + This option is an VPL variant of the PINCTRL option. + See the help of PINCTRL for details. + config SPL_PINCTRL_FULL bool "Support full pin controllers in SPL" depends on SPL_PINCTRL && SPL_OF_CONTROL default n if TARGET_STM32F746_DISCO default y help - This option is an SPL-variant of the PINCTRL_FULL option. + This option is an SPL variant of the PINCTRL_FULL option. See the help of PINCTRL_FULL for details.
config TPL_PINCTRL_FULL bool "Support full pin controllers in TPL" depends on TPL_PINCTRL && TPL_OF_CONTROL help - This option is an TPL-variant of the PINCTRL_FULL option. + This option is a TPL variant of the PINCTRL_FULL option. + See the help of PINCTRL_FULL for details. + +config VPL_PINCTRL_FULL + bool "Support full pin controllers in VPL" + depends on VPL_PINCTRL && VPL_OF_CONTROL + help + This option is a VPL variant of the PINCTRL_FULL option. See the help of PINCTRL_FULL for details.
config SPL_PINCTRL_GENERIC diff --git a/drivers/rtc/Kconfig b/drivers/rtc/Kconfig index cbdfddb80f6..3de6d3fb4d8 100644 --- a/drivers/rtc/Kconfig +++ b/drivers/rtc/Kconfig @@ -32,6 +32,15 @@ config TPL_DM_RTC drivers to perform the actual functions. See rtc.h for a description of the API.
+config VPL_DM_RTC + bool "Enable Driver Model for RTC drivers in VPL" + depends on VPL_DM + help + Enable drver model for real-time-clock drivers. The RTC uclass + then provides the rtc_get()/rtc_set() interface, delegating to + drivers to perform the actual functions. See rtc.h for a + description of the API. + config RTC_ENABLE_32KHZ_OUTPUT bool "Enable RTC 32Khz output" help diff --git a/drivers/serial/Kconfig b/drivers/serial/Kconfig index 961e3fb0314..a8fdffe2ccf 100644 --- a/drivers/serial/Kconfig +++ b/drivers/serial/Kconfig @@ -63,6 +63,16 @@ config TPL_SERIAL_PRESENT This option enables the full UART in TPL, so if is it disabled, the full UART driver will be omitted, thus saving space.
+config VPL_SERIAL_PRESENT + bool "Provide a serial driver in VPL" + depends on DM_SERIAL && VPL + default y + help + In very space-constrained devices even the full UART driver is too + large. In this case the debug UART can still be used in some cases. + This option enables the full UART in TPL, so if is it disabled, + the full UART driver will be omitted, thus saving space. + # Logic to allow us to use the imply keyword to set what the default port # should be. The default is otherwise 1. config CONS_INDEX_0 @@ -172,6 +182,16 @@ config TPL_DM_SERIAL implements serial_putc() etc. The uclass interface is defined in include/serial.h.
+config VPL_DM_SERIAL + bool "Enable Driver Model for serial drivers in VPL" + depends on DM_SERIAL + default y if VPL && DM_SERIAL + help + Enable driver model for serial in VPL. This replaces + drivers/serial/serial.c with the serial uclass, which + implements serial_putc() etc. The uclass interface is + defined in include/serial.h. + config DEBUG_UART bool "Enable an early debug UART for debugging" help diff --git a/drivers/sysreset/Kconfig b/drivers/sysreset/Kconfig index ac77ffbc8be..fec6fed6c31 100644 --- a/drivers/sysreset/Kconfig +++ b/drivers/sysreset/Kconfig @@ -31,6 +31,16 @@ config TPL_SYSRESET to effect a reset. The uclass will try all available drivers when reset_walk() is called.
+config VPL_SYSRESET + bool "Enable support for system reset drivers in VPL mode" + depends on SYSRESET && VPL_DM + default y if TPL_SYSRESET + help + Enable system reset drivers which can be used to reset the CPU or + board. Each driver can provide a reset method which will be called + to effect a reset. The uclass will try all available drivers when + reset_walk() is called. + if SYSRESET
config SYSRESET_CMD_RESET diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index ee81dfa7768..ac601f00ecf 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -27,6 +27,16 @@ config TPL_TIMER function. This enables the drivers in drivers/timer as part of an TPL build.
+config VPL_TIMER + bool "Enable driver model for timer drivers in VPL" + depends on TIMER && VPL + default y if TPL_TIMER + help + Enable support for timer drivers in VPL. These can be used to get + a timer value when in VPL, or perhaps for implementing a delay + function. This enables the drivers in drivers/timer as part of an + TPL build. + config TIMER_EARLY bool "Allow timer to be used early in U-Boot" depends on TIMER diff --git a/lib/Kconfig b/lib/Kconfig index ad0cd52edd8..1706eef91c5 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -72,6 +72,11 @@ config TPL_PRINTF select TPL_SPRINTF select TPL_STRTO if !TPL_USE_TINY_PRINTF
+config VPL_PRINTF + bool + select VPL_SPRINTF + select VPL_STRTO if !VPL_USE_TINY_PRINTF + config SPRINTF bool default y @@ -82,6 +87,9 @@ config SPL_SPRINTF config TPL_SPRINTF bool
+config VPL_SPRINTF + bool + config SSCANF bool default n @@ -96,6 +104,9 @@ config SPL_STRTO config TPL_STRTO bool
+config VPL_STRTO + bool + config IMAGE_SPARSE bool
@@ -148,6 +159,17 @@ config TPL_USE_TINY_PRINTF
The supported format specifiers are %c, %s, %u/%d and %x.
+config VPL_USE_TINY_PRINTF + bool "Enable tiny printf() version for VPL" + depends on VPL + help + This option enables a tiny, stripped down printf version. + This should only be used in space limited environments, + like SPL versions with hard memory limits. This version + reduces the code size by about 2.5KiB on armv7. + + The supported format specifiers are %c, %s, %u/%d and %x. + config PANIC_HANG bool "Do not reset the system on fatal error" help @@ -331,6 +353,17 @@ config TPL_TPM for the low-level TPM interface, but only one TPM is supported at a time by the TPM library.
+config VPL_TPM + bool "Trusted Platform Module (TPM) Support in VPL" + depends on VPL_DM + help + This enables support for TPMs which can be used to provide security + features for your board. The TPM can be connected via LPC or I2C + and a sandbox TPM is provided for testing purposes. Use the 'tpm' + command to interactive the TPM. Driver model support is provided + for the low-level TPM interface, but only one TPM is supported at + a time by the TPM library. + endmenu
menu "Android Verified Boot" @@ -518,6 +551,12 @@ config SPL_LZMA help This enables support for LZMA compression algorithm for SPL boot.
+config VPL_LZMA + bool "Enable LZMA decompression support for VPL build" + default y if LZMA + help + This enables support for LZMA compression algorithm for VPL boot. + config SPL_LZO bool "Enable LZO decompression support in SPL" help @@ -598,6 +637,7 @@ config OF_LIBFDT_OVERLAY
config SPL_OF_LIBFDT bool "Enable the FDT library for SPL" + depends on SPL_LIBGENERIC_SUPPORT default y if SPL_OF_CONTROL help This enables the FDT library (libfdt). It provides functions for @@ -619,6 +659,7 @@ config SPL_OF_LIBFDT_ASSUME_MASK
config TPL_OF_LIBFDT bool "Enable the FDT library for TPL" + depends on TPL_LIBGENERIC_SUPPORT default y if TPL_OF_CONTROL help This enables the FDT library (libfdt). It provides functions for @@ -638,6 +679,27 @@ config TPL_OF_LIBFDT_ASSUME_MASK 0xff means all assumptions are made and any invalid data may cause unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h
+config VPL_OF_LIBFDT + bool "Enable the FDT library for VPL" + default y if VPL_OF_CONTROL && !VPL_OF_PLATDATA + help + This enables the FDT library (libfdt). It provides functions for + accessing binary device tree images in memory, such as adding and + removing nodes and properties, scanning through the tree and finding + particular compatible nodes. The library operates on a flattened + version of the device tree. + +config VPL_OF_LIBFDT_ASSUME_MASK + hex "Mask of conditions to assume for libfdt" + depends on VPL_OF_LIBFDT || FIT + default 0xff + help + Use this to change the assumptions made by libfdt in SPL about the + device tree it is working with. A value of 0 means that no assumptions + are made, and libfdt is able to deal with malicious data. A value of + 0xff means all assumptions are made and any invalid data may cause + unsafe execution. See FDT_ASSUME_PERFECT, etc. in libfdt_internal.h + config FDT_FIXUP_PARTITIONS bool "overwrite MTD partitions in DTS through defined in 'mtdparts'" depends on OF_LIBFDT
Hi Tom,
On Sun, 11 Jul 2021 at 20:19, Simon Glass sjg@chromium.org wrote:
U-Boot provides a verified-boot feature based around FIT, but there is no standard way of implementing it for a board. At present the various required pieces must be built up separately, to produce a working implementation. In particular, there is no built-in support for selecting A/B boot or recovery mode.
This series introduces VPL, a verified program loader. Its purpose is to run the verified-boot process and decide which SPL binary should be run. Adding VPL into the boot flow provides a standard way of implementing verified boot. So far, only the phase itself is added along with some Kconfig options. The next step is to create a build for sandbox.
Changes in v3:
- Move VPL Kconfig options to a separate patch
- Add full build support for VPL
Changes in v2:
- Add some more VPL Kconfig options
Simon Glass (7): doc: Convert SPL documentation to ReST doc: Expand SPL docs to explain the phase and config test: Tidy up test building with SPL spl: Move TPL_HASH_SUPPORT down next to other TPL options binman: Add VPL support Introduce Verifying Program Loader (VPL) vpl: Add Kconfig options for VPL
Any thoughts on this one? I have a few updates so can send a rebase v4 if that helps.
On Tue, Jul 27, 2021 at 10:20:49AM -0600, Simon Glass wrote:
Hi Tom,
Changes in v3:
Changes in v2:
Perhaps some of these general questions would be answered with seeing an implementation for not just sandbox, but real hardware too. But I'm missing what this provides exactly that we can't do already, or that would justify a whole new stage rather than just some updates within existing logic. What is this doing over SPL_FIT_SIGNATURE for example? Checking in with a TPM to confirm good measurements? Having written that out, now I really do want to see this implemented on real hardware much more so than sandbox.
Hi Tom,
Hi Tom,
Changes in v3:
Changes in v2:
Yes it was actually implemented on coral, an x86 Chromebook which is in-tree. I have various patches to come but the docs are at [1]
The core reason for it is that SPL sets up SDRAM (and perhaps other things) so needs to be updateable, so we cannot boot the vboot logic in SPL. TPL often has very small size limits so it is difficult to put it in there. I am thinking that VPL can be an optional phase used only if verified boot is enabled. That makes it easy since it has a defined purpose which can be enabled/disabled.
BTW in doing this I wonder whether we should look again at the SPL_TPL_ Makefile variables. Do you think PHASE might be better?
[1] https://github.com/sjg20/u-boot/blob/cros-2021.04/cros/doc/cros_coral.rst
Hi
On Wed, Jul 28, 2021 at 5:34 PM Simon Glass sjg@chromium.org wrote:
Hi Tom,
Hi Tom,
Let's try to understand. So we can have:
TPL (redundant most of cpus support it) -> VPL -\
-> SPL1 -\ = > UBOOT_B e/o fitImage
| -> ATF1 | -> TEE1
-> SPL2 -\ => UBOOT_A e/o fitImage | => ATF2 | => TEE2
If you have this kind of system TPL and VPL can be combined. Is this the scenario we will use with this patchset?
The funny thing here is that a lot of people ask to update the TPL. After adding the VPL the communication will happen using hob memory area?
One of the most interesting parts will be to tag the TPL(x) to know what of them the bootrom load.
Michael
Changes in v3:
Changes in v2:
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Hi Michael,
On Wed, 28 Jul 2021 at 09:54, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Hi Tom,
Hi Tom,
-> SPL1 -\ = > UBOOT_B e/o fitImage | -> ATF1 | -> TEE1 -> SPL2 -\ => UBOOT_A e/o fitImage | => ATF2 | => TEE2
I'm not quite sure how to read that diagram. I think we should have SPLA_ and SPL_B (and perhaps SPL_RECOVERY) so it matches with U-Boot proper.
Only if there is space to store both the early-init code and the verified boot. So for coral this is not possible.
But if I understand things correctly, then yes this is the idea.
Michael
Changes in v3:
Changes in v2:
On Wed, Jul 28, 2021 at 09:33:56AM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Changes in v3:
Changes in v2:
There's always a "no updates before HERE" line to draw, as you need a fall-back option. Since you mention SDRAM, does that mean both TPL and VPL are running in SRAM/similar space? If so, why isn't this just part of TPL, for when you have "a lot" of pre-SDRAM memory to use?
Hi Tom,
Hi Tom,
Hi Tom,
Changes in v3:
Changes in v2:
It depends on the architecture. For coral (and other modern x86 devices) there is 32KB which is enough to run TPL but not enough to run VPL. So TPL sets up 'Cache-as-RAM' which provides additional SRAM. Other architectures may have their own constraints.
But another key difference is that we use OF_PLATDATA in TPL and that is fine for the basic init needed there. But VPL needs lots of drivers as well as info about the firmware image layout so it adds to the work needed to get them running in that environment. So ideally, VPL can be built without OF_PLATDATA.
Or put it another way, TPL needs to be as small as possible so it can run on the widest array of devices. VPL is an optional phase (only used with verified boot) so we should not pollute TPL with that. I have a lot of other thoughts about all of this, some of which are in the VBE doc...
Regards, SImon
On Wed, Jul 28, 2021 at 12:37:55PM -0600, Simon Glass wrote:
Hi Tom,
Hi Tom,
Hi Tom,
Changes in v3:
Changes in v2:
And in this case then VPL sets up DRAM?
Right, the intention behind allowing "TPL" in-tree was that we have enough cases where we're size constrained and just need to allow for something "functional enough". This was what the old PowerPC "SPL" was about, and SoCs keep coming out with relatively tiny initial memory spaces.
I guess my concerns at the high level fall in to a few spots: - I don't really like the idea of having to introduce yet another stage. At that point, what infrastructure from U-Boot is it really even using? - In order to use this we're now needing platforms to support TPL to add in VPL. - That kind of ties in to another part of the issue I see. Why is this not just a feature to enable in earlier stage? - Why do we have both verified and "A/B or recovery" in the same spot?
Some of this I guess comes down to my thinking about how yes, x86 is constrained, but we have a lot of other platforms with 128/256/way more pre-SDRAM memory available and verified is the key feature to enable rather than A/B update. And again, what does the verified part of this provide over FIT_SIGNATURE? Outside of that A/B case, at least.
Hi Tom,
(just to reply to this old email)
Hi Tom,
Hi Tom,
Hi Tom,
On Sun, 11 Jul 2021 at 20:19, Simon Glass sjg@chromium.org wrote: > > U-Boot provides a verified-boot feature based around FIT, but there is > no standard way of implementing it for a board. At present the various > required pieces must be built up separately, to produce a working > implementation. In particular, there is no built-in support for selecting > A/B boot or recovery mode. > > This series introduces VPL, a verified program loader. Its purpose is to > run the verified-boot process and decide which SPL binary should be run. > Adding VPL into the boot flow provides a standard way of implementing > verified boot. So far, only the phase itself is added along with some > Kconfig options. The next step is to create a build for sandbox. > > Changes in v3: > - Move VPL Kconfig options to a separate patch > - Add full build support for VPL > > Changes in v2: > - Add some more VPL Kconfig options > > Simon Glass (7): > doc: Convert SPL documentation to ReST > doc: Expand SPL docs to explain the phase and config > test: Tidy up test building with SPL > spl: Move TPL_HASH_SUPPORT down next to other TPL options > binman: Add VPL support > Introduce Verifying Program Loader (VPL) > vpl: Add Kconfig options for VPL
No, SPL. Nothing changes there.
Well I've been avoiding it for years...
Well the verification will be in VPL in U-Boot.
Not necessarily. If the platform has enough memory to enable verification in TPL then that is still an option.
Yes that's possible, but it cannot be implemented in TPL in quite a few platforms, as I see it.
I'm not sure what this means, sorry.
It uses FIT_SIGNATURE, but with U-Boot being the target binary. So there are two updateable parts: firmware and kernel.
