[PATCH v2 1/2] timer: sti: convert sti-timer to arm a9 global timer
STI timer is actually ARM Cortex A9 global timer. Convert the driver to use generic global timer name and make it consistent with Linux kernel global timer driver. This also allows any A9 based device to use this driver.
Signed-off-by: William Zhang william.zhang@broadcom.com ---
(no changes since v1)
MAINTAINERS | 2 +- drivers/timer/Kconfig | 8 +++-- drivers/timer/Makefile | 2 +- .../timer/{sti-timer.c => arm_global_timer.c} | 30 ++++++++++--------- 4 files changed, 23 insertions(+), 19 deletions(-) rename drivers/timer/{sti-timer.c => arm_global_timer.c} (66%)
diff --git a/MAINTAINERS b/MAINTAINERS index 1103bb068154..f7d77bb8cfa9 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -503,7 +503,7 @@ F: drivers/mmc/sti_sdhci.c F: drivers/reset/sti-reset.c F: drivers/serial/serial_sti_asc.c F: drivers/sysreset/sysreset_sti.c -F: drivers/timer/sti-timer.c +F: drivers/timer/arm_global_timer.c F: drivers/usb/host/dwc3-sti-glue.c F: include/dwc3-sti-glue.h F: include/dt-bindings/clock/stih407-clks.h diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 20b5af7e260f..3e1d70fbb930 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -215,12 +215,14 @@ config SANDBOX_TIMER Select this to enable an emulated timer for sandbox. It gets time from host os.
-config STI_TIMER - bool "STi timer support" +config ARM_GLOBAL_TIMER + bool "ARM Cortex A9 global timer support" depends on TIMER + depends on ARM default y if ARCH_STI help - Select this to enable a timer for STi devices. + Select this to enable global timer found on ARM Cortex A9 + based devices.
config STM32_TIMER bool "STM32 timer support" diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index d9822a537009..d23569365408 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -22,7 +22,7 @@ obj-$(CONFIG_RISCV_TIMER) += riscv_timer.o obj-$(CONFIG_ROCKCHIP_TIMER) += rockchip_timer.o obj-$(CONFIG_SANDBOX_TIMER) += sandbox_timer.o obj-$(CONFIG_$(SPL_)SIFIVE_CLINT) += sifive_clint_timer.o -obj-$(CONFIG_STI_TIMER) += sti-timer.o +obj-$(CONFIG_ARM_GLOBAL_TIMER) += arm_global_timer.o obj-$(CONFIG_STM32_TIMER) += stm32_timer.o obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_MTK_TIMER) += mtk_timer.o diff --git a/drivers/timer/sti-timer.c b/drivers/timer/arm_global_timer.c similarity index 66% rename from drivers/timer/sti-timer.c rename to drivers/timer/arm_global_timer.c index 87444a0650f6..065f10bb742b 100644 --- a/drivers/timer/sti-timer.c +++ b/drivers/timer/arm_global_timer.c @@ -2,6 +2,8 @@ /* * Copyright (C) 2017, STMicroelectronics - All Rights Reserved * Author(s): Patrice Chotard, patrice.chotard@foss.st.com for STMicroelectronics. + * + * ARM Cortext A9 global timer driver */
#include <common.h> @@ -13,13 +15,13 @@ #include <asm/io.h> #include <asm/arch-armv7/globaltimer.h>
-struct sti_timer_priv { +struct arm_global_timer_priv { struct globaltimer *global_timer; };
-static u64 sti_timer_get_count(struct udevice *dev) +static u64 arm_global_timer_get_count(struct udevice *dev) { - struct sti_timer_priv *priv = dev_get_priv(dev); + struct arm_global_timer_priv *priv = dev_get_priv(dev); struct globaltimer *global_timer = priv->global_timer; u32 low, high; u64 timer; @@ -37,10 +39,10 @@ static u64 sti_timer_get_count(struct udevice *dev) return (u64)((timer << 32) | low); }
-static int sti_timer_probe(struct udevice *dev) +static int arm_global_timer_probe(struct udevice *dev) { struct timer_dev_priv *uc_priv = dev_get_uclass_priv(dev); - struct sti_timer_priv *priv = dev_get_priv(dev); + struct arm_global_timer_priv *priv = dev_get_priv(dev); struct clk clk; int err; ulong ret; @@ -66,20 +68,20 @@ static int sti_timer_probe(struct udevice *dev) return 0; }
-static const struct timer_ops sti_timer_ops = { - .get_count = sti_timer_get_count, +static const struct timer_ops arm_global_timer_ops = { + .get_count = arm_global_timer_get_count, };
-static const struct udevice_id sti_timer_ids[] = { +static const struct udevice_id arm_global_timer_ids[] = { { .compatible = "arm,cortex-a9-global-timer" }, {} };
-U_BOOT_DRIVER(sti_timer) = { - .name = "sti_timer", +U_BOOT_DRIVER(arm_global_timer) = { + .name = "arm_global_timer", .id = UCLASS_TIMER, - .of_match = sti_timer_ids, - .priv_auto = sizeof(struct sti_timer_priv), - .probe = sti_timer_probe, - .ops = &sti_timer_ops, + .of_match = arm_global_timer_ids, + .priv_auto = sizeof(struct arm_global_timer_priv), + .probe = arm_global_timer_probe, + .ops = &arm_global_timer_ops, };
As STI timer is renamed to ARM A9 global timer, change BCM63138 to use the new global timer config symbol name.
This patch applies on top of the my previous patch [1].
[1]: https://lists.denx.de/pipermail/u-boot/2022-August/491060.html
Changes in v2: - Fix typo in the subject line and patch link in the commit message
arch/arm/mach-bcmbca/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-bcmbca/Kconfig b/arch/arm/mach-bcmbca/Kconfig index 27b243cbc3d8..62b371612b6a 100644 --- a/arch/arm/mach-bcmbca/Kconfig +++ b/arch/arm/mach-bcmbca/Kconfig @@ -29,7 +29,7 @@ config BCM4912 config BCM63138 bool "Support for Broadcom 63138 Family" select TIMER - select STI_TIMER + select ARM_GLOBAL_TIMER select CPU_V7A select DM_SERIAL select BCM6345_SERIAL
Hi William
-config STI_TIMER
- bool "ARM Cortex A9 global timer support" depends on TIMER
- depends on ARM default y if ARCH_STI help
based devices.
- Copyright (C) 2017, STMicroelectronics - All Rights Reserved
- Author(s): Patrice Chotard, patrice.chotard@foss.st.com for STMicroelectronics.
- ARM Cortext A9 global timer driver
- struct arm_global_timer_priv *priv = dev_get_priv(dev); struct globaltimer *global_timer = priv->global_timer; u32 low, high; u64 timer;
- struct arm_global_timer_priv *priv = dev_get_priv(dev); struct clk clk; int err; ulong ret;
- .get_count = arm_global_timer_get_count,
- .name = "arm_global_timer", .id = UCLASS_TIMER,
- .of_match = arm_global_timer_ids,
- .priv_auto = sizeof(struct arm_global_timer_priv),
- .probe = arm_global_timer_probe,
- .ops = &arm_global_timer_ops,
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Tested-by: Patrice Chotard patrice.chotard@foss.st.com
Tested on stih410-b2260 boards.
Thanks Patrice
Signed-off-by: William Zhang william.zhang@broadcom.com Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Tested-by: Patrice Chotard patrice.chotard@foss.st.com
For the series, applied to u-boot/master, thanks!
Patrice CHOTARD
William Zhang
