[U-Boot] booting from sd card problem
Hi, I am using uboot-toradex in my iris carrier with colibri t30 module.In that when i am booting from sd card it is showing following error,
U-Boot 2011.06-00004-gccd521c (Mar 17 2014 - 09:48:16) TEGRA3 DRAM: 1 GiB MMC: Tegra2 SD/MMC: 0, Tegra2 SD/MMC: 1mmc_reset: power control = 0F, host control = 00Board: Toradex Colibri T30Net: Net Initialization SkippedNo ethernet found.Hit any key to stop autoboot: 0 Colibri T30 # run sdbootLoading kernel and rootfs from MMC/SD Card...mmc_reset: power control = 0F, host control = 00mmc1 is current deviceGUID Partition Table Header signature is wrong:0xE1A0000DEA000002 != 0x5452415020494645get_partition_info_efi: *** ERROR: Invalid Primary GPT ***Loading file "/boot/uImage" from mmc device 1:1 (gpt1)GUID Partition Table Header signature is wrong:0xE1A0000DEA000002 != 0x5452415020494645get_partition_info_efi: *** ERROR: Invalid Primary GPT ***4324368 bytes read## Booting kernel from Legacy Image at 80408000 ... Image Name: Linux-3.1.10 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4324304 Bytes = 4.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OKOK what was the problem? please help me. In my board environment variables are following, Colibri T30 # prbaudrate=115200bootcmd=run emmcboot; run usbboot; run nfsbootbootdelay=3defargs=core_edp_mv=1300 usb_high_speed=1emmcboot=run setup; setenv bootargs ${defargs} ${mmcargs} ${setupargs} ${vidargs}; echo Booting from internal eMMC chip...; mmc read ${loadaddr} ${lnxmethaddr=00:14:2d:26:0b:9bfdtaddr=8014d538gptoffset=0xa001ipaddr=192.168.10.2lnxoffset=0x5000loadaddr=0x80408000memargs=vmalloc=128M mem=1012M@2048M fbmem=12M@3060Mmmc_kernel_size=0x4000mmcargs=ip=off root=/dev/mmcblk0p1 rw,noatime rootfstype=ext3 rootwaitnetmask=255.255.255.0nfsargs=ip=:::::eth0:on root=/dev/nfs rw netdevwaitnfsboot=run setup; setenv bootargs ${defargs} ${nfsargs} ${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS...; usb start && dhcp && bootmsdargs=ip=off root=/dev/mmcblk1p1 rw,noatime rootfstype=ext3 rootwaitsdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} ${vidargs}; echo Loading kernel and rootfs from MMC/SD Card...; mmc dev 1 && ext2l}serverip=192.168.10.1setup=setenv setupargs gpt gpt_sector=${gptoffset} asix_mac=${ethaddr} no_console_suspend=1 console=tty1 console=ttyS0,${baudrate}n8 debug_uartport=ls}stderr=serial,lcdstdin=serial,usbkbdstdout=serial,lcdusbargs=root=/dev/sda2 rw,noatime rootwaitusbboot=run setup; setenv bootargs ${defargs} ${setupargs} ${usbargs} ${vidargs}; echo Booting from USB stick...; usb start && fatload usb 0:1 ${loadamverify=novidargs=video=tegrafb0:640x480-16@60 Environment size: 1625/4092 bytesColibri T30 #
please give me a solution. regards,shobin.b
module.In
Hi, i cannot read your message at all ... where the linebreaks are gone?
best regards, Hannes
host
SkippedNo
control =
Table
was
setup;
Booting
9bfdtaddr=8014d538gptoffset=0xa001ipaddr=192.168.10. 2lnxoffset=0x5000loadaddr=0x80408000memargs=vmalloc=128M mem=1012M@2048M
fbmem=12M@3060Mmmc_kernel_size=0x4000mmcargs=ip=off root=/dev/mmcblk0p1 rw,noatime rootfstype=ext3 rootwaitnetmask=255.255.255. 0nfsargs=ip=:::::eth0:on root=/dev/nfs rw netdevwaitnfsboot=run setup;
setenv
DHCP/
rw,noatime rootfstype=ext3 rootwaitsdboot=run setup; setenv bootargs $ {defargs} ${sdargs} ${setupargs} ${vidargs}; echo Loading kernel and
rootfs
${setupargs}
fatload
please give me a solution. regards,shobin.b _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On 08/11/2014 01:55 AM, shobin b wrote:
Hi, I am using uboot-toradex in my iris carrier with colibri t30 module. In that when i am booting from sd card it is showing following error,
get_parti tion_info_efi: *** ERROR: Invalid Primary GPT ***4324368 bytes read## Booting kernel from Legacy Image at 80408000 ... Image Name: Linux-3.1.10 Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4324304 Bytes = 4.1 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OKOK what was the problem? please help me.
You should contact Toradex, since that appears to be an old downstream fork of U-Boot, not mainline U-boot (which doesn't yet support this board, although support is coming very soon IIUC).
If you could format your email so that the log messages display on separate lines like they do on your screen, that would help people trying to read it greatly...
GUID Partition Table Header signature is wrong:0xE1A0000DEA000002 != 0x5452415020494645 get_partition_info_efi: *** ERROR: Invalid Primary GPT ***Loading file "/boot/uImage" from mmc device 1:1 (gpt1) GUID Partition Table Header signature is wrong:0xE1A0000DEA000002 != 0x5452415020494645 get_partition_info_efi: *** ERROR: Invalid Primary GPT ***4324368 bytes read
It looks like your partition table is corrupted. I would suggest re-installing.
Hannes Petermaier
shobin b
Stephen Warren
