[PATCH 1/1] tis: fix tpm_tis_remove()
tpm_tis_remove() leads to calling tpm_tis_ready() with the IO region unmapped and chip->locality == -1 (locality released). This leads to a crash in mmio_write_bytes().
The patch implements these changes:
tpm_tis_remove(): Unmap the IO region after calling tpm_tis_cleanup().
tpm_tis_cleanup(): Request locality before IO output and releasing locality.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/tpm/tpm2_tis_core.c | 6 ++++++ drivers/tpm/tpm2_tis_mmio.c | 5 ++++- 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/tpm/tpm2_tis_core.c b/drivers/tpm/tpm2_tis_core.c index ec8c730fe9..51392c4584 100644 --- a/drivers/tpm/tpm2_tis_core.c +++ b/drivers/tpm/tpm2_tis_core.c @@ -378,8 +378,14 @@ out: int tpm_tis_cleanup(struct udevice *dev) { struct tpm_chip *chip = dev_get_priv(dev); + int ret; + + ret = tpm_tis_request_locality(dev, 0); + if (ret) + return ret;
tpm_tis_ready(dev); + tpm_tis_release_locality(dev, chip->locality);
return 0; diff --git a/drivers/tpm/tpm2_tis_mmio.c b/drivers/tpm/tpm2_tis_mmio.c index 9cedff2225..a646ce41ff 100644 --- a/drivers/tpm/tpm2_tis_mmio.c +++ b/drivers/tpm/tpm2_tis_mmio.c @@ -118,10 +118,13 @@ iounmap: static int tpm_tis_remove(struct udevice *dev) { struct tpm_tis_chip_data *drv_data = (void *)dev_get_driver_data(dev); + int ret; + + ret = tpm_tis_cleanup(dev);
iounmap(drv_data->iobase);
- return tpm_tis_cleanup(dev); + return ret; }
static const struct tpm_ops tpm_tis_ops = {
Hi Heinrich,
int ret;
if (ret)
return ret;
tpm_tis_ready(dev);
int ret;
- return ret;
2.32.0
Thanks for looking into this
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Ilias Apalodimas
