[PATCH] arm64: zynqmp: enable the PMUFW watchdog
From 528b3117a36b7b4eea1839afbea7191d60638b0c Mon Sep 17 00:00:00 2001
From: Jorge Ramirez-Ortiz jorge@foundries.io Date: Wed, 23 Mar 2022 14:41:15 +0100 Subject: [PATCH] arm64: zynqmp: enable the PMUFW watchdog
If the PMUFW was built with support for the CSU watchdog we must let the firmware know that it can be started.
We do this by faking the FSBL done state.
Reference code in PMUFW: https://github.com/Xilinx/embeddedsw/blob/master/lib/sw_apps/zynqmp_pmufw/sr...
It needs this fix on the PMUFW https://github.com/Xilinx/embeddedsw/pull/190
Signed-off-by: Jorge Ramirez-Ortiz jorge@foundries.io --- arch/arm/mach-zynqmp/include/mach/hardware.h | 5 ++++- board/xilinx/zynqmp/zynqmp.c | 4 ++++ 2 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index a70d6d611b..24c3ef3d7d 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -174,8 +174,11 @@ struct csu_regs {
#define ZYNQMP_PMU_BASEADDR 0xFFD80000
+#define FSBL_COMPLETION 0x1 + struct pmu_regs { - u32 reserved[18]; + u32 reserved[17]; + u32 gen_storage5; /* 0x44 */ u32 gen_storage6; /* 0x48 */ };
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 70b3c81f12..c88c5fb8ea 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -419,6 +419,10 @@ int board_init(void) zynqmp_pm_cfg_obj_size); printf("Silicon version:\t%d\n", zynqmp_get_silicon_version());
+ /* fake FSBL completion to start the PMUFW watchdog when enabled */ + writel(readl(&pmu_base->gen_storage5) | FSBL_COMPLETION, + &pmu_base->gen_storage5); + /* the CSU disables the JTAG interface when secure boot is enabled */ if (CONFIG_IS_ENABLED(ZYNQMP_RESTORE_JTAG)) restore_jtag();
On 23/03/22, Jorge Ramirez-Ortiz wrote:
From 528b3117a36b7b4eea1839afbea7191d60638b0c Mon Sep 17 00:00:00 2001 From: Jorge Ramirez-Ortiz jorge@foundries.io Date: Wed, 23 Mar 2022 14:41:15 +0100 Subject: [PATCH] arm64: zynqmp: enable the PMUFW watchdog
um, seems my sendpatch script is a bit off. please let me know if I should send a v2.
struct pmu_regs {
- u32 reserved[18];
- u32 reserved[17];
- u32 gen_storage5; /* 0x44 */ u32 gen_storage6; /* 0x48 */
- /* fake FSBL completion to start the PMUFW watchdog when enabled */
- writel(readl(&pmu_base->gen_storage5) | FSBL_COMPLETION,
- /* the CSU disables the JTAG interface when secure boot is enabled */ if (CONFIG_IS_ENABLED(ZYNQMP_RESTORE_JTAG)) restore_jtag();
-- 2.34.1
/* FSBL might not be running anywhere - i.e: SPL boots PMUFW */
SPL doesn't boot PMUFW. It is the first firmware in BOOT.BIN which is loaded by bootrom to PMU. It means comment is not correct. FSBL or SPL just sending PMU configuration object to PMUFW.
- struct pmu_regs {
- u32 reserved[18];
- u32 reserved[17];
- u32 gen_storage5; /* 0x44 */ u32 gen_storage6; /* 0x48 */ };
I look at the code in FSBL and it set it up XFsbl_HandoffExit which is at the end of FSBL. It means this should be setup in SPL not in U-Boot proper.
There is also any XFSBL_FSBL_ENCRYPTED_MASK which maybe you should take a look in connection your other patches.
M
yeah I guess it depends what you mean by boot - unless SPL configures it, it wont really boot to a functional state.
but anyway ok, will change.
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index a70d6d611b..24c3ef3d7d 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -174,8 +174,11 @@ struct csu_regs { #define ZYNQMP_PMU_BASEADDR 0xFFD80000 +#define FSBL_COMPLETION 0x1
- struct pmu_regs {
- u32 reserved[18];
- u32 reserved[17];
not sure what you mean. This piece of code I am posting only executes in SPL, doesn it?
um, ok thanks for the info!
M
- struct pmu_regs {
- u32 reserved[18];
- u32 reserved[17];
ah. ok. Then fine.
M
Jorge Ramirez-Ortiz
Michal Simek
