[U-Boot] [PATCH V2] Convert CONFIG_FSL_USDHC to Kconfig
This converts the following to Kconfig: CONFIG_FSL_USDHC
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Based on re-sync'd defconfigs Remove references to non-FSL boards
diff --git a/configs/apalis-imx8qm_defconfig b/configs/apalis-imx8qm_defconfig index 46a0a2a975..6a259381c2 100644 --- a/configs/apalis-imx8qm_defconfig +++ b/configs/apalis-imx8qm_defconfig @@ -35,7 +35,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_MISC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index b76c4c1b85..7b73265abd 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -59,7 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 33e40cd7d3..18ef5d2dce 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 34a6cde1ee..1054c05d8c 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index cb361daafb..4080a7b310 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index ec042d7912..f8342ccb16 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -55,7 +55,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index cad8f4bc5b..04d1042060 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -51,7 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 6f4fe45760..4c74c49309 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -57,7 +57,7 @@ CONFIG_DWC_AHSATA=y # CONFIG_DWC_AHSATA_AHCI is not set CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index e184223773..4d6aa11b40 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -52,7 +52,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/colibri-imx8qxp_defconfig b/configs/colibri-imx8qxp_defconfig index b35ec5841d..a223a16ddd 100644 --- a/configs/colibri-imx8qxp_defconfig +++ b/configs/colibri-imx8qxp_defconfig @@ -34,7 +34,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_IMX_LPI2C=y CONFIG_MISC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_MICREL=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index f792a9ef5c..6f8b63949c 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -58,7 +58,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 8e769cd70e..c1bee450f6 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -52,7 +52,7 @@ CONFIG_DFU_NAND=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS_DT=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index 5a5104c2ee..1a012d851e 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -52,7 +52,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 3022a187cc..8e749d9a03 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -52,7 +52,7 @@ CONFIG_SYS_I2C_MXC=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 2275ee7d1b..3e8f1e9d7f 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -67,7 +67,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 40df91a59b..eb51d2e523 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -65,7 +65,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 91b6a7424f..fe23657107 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index fbf1f89ece..a4c93a5805 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 54197f7541..735165916a 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -43,7 +43,7 @@ CONFIG_SYS_BOOTCOUNT_EXT_DEVPART="1:5" CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 64516bbb8b..5d869c08e1 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -63,7 +63,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD_DEVICE=y CONFIG_PHYLIB=y CONFIG_E1000=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index cf47190938..df3d35acc4 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -63,7 +63,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD_DEVICE=y CONFIG_PHYLIB=y CONFIG_MV88E61XX_SWITCH=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index e511fd3cb3..a0d38ae97b 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -66,7 +66,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index b86b9e8773..6eb7c7ab3a 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -39,7 +39,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index dbf230c7d6..44486cbfa3 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -32,7 +32,7 @@ CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_SYS_I2C_MXC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 4ea0803ab5..fc990a8add 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 290e1a7558..e9f920f118 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -67,7 +67,7 @@ CONFIG_SPL_OF_TRANSLATE=y CONFIG_PCF8575_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 268c909882..5442ce7db4 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -44,7 +44,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-mipi" CONFIG_OF_LIST="imx6q-icore-mipi imx6dl-icore-mipi" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index b15c547e37..c7544c68c8 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -54,7 +54,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 4ea0803ab5..fc990a8add 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 712c79f54e..9f0cc0ffed 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -41,7 +41,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" CONFIG_OF_LIST="imx6q-icore-rqs imx6dl-icore-rqs" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 8a7b1ad6d5..620d979342 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -38,7 +38,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index d24027cd69..94d43fdd04 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 584d766262..f0f53bada7 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -38,7 +38,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 80f7cb3e03..05e0498a5e 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index aa23b9caa3..3294931ef8 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -51,7 +51,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ATHEROS=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 3740f17de2..d7974e8fad 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -56,7 +56,7 @@ CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ATHEROS=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index 87b25e6e1d..578e7010e5 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -34,7 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 456f1e3fa9..03a0e88635 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -39,7 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index f6e351f50a..27f1e09922 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -21,7 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index cd78c5cb33..66f49c0e54 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -28,7 +28,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index 17947860ee..501eaf6942 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -29,7 +29,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 9fc443c386..3d73734609 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -35,7 +35,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_DM_THERMAL=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 866e0b5baa..4675c9d33c 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 98ae70e026..cdca47e06d 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig index ebb48c3aa3..d20e3dbbe1 100644 --- a/configs/mx6memcal_defconfig +++ b/configs/mx6memcal_defconfig @@ -36,6 +36,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_CACHE=y # CONFIG_NET is not set # CONFIG_MMC is not set +CONFIG_FSL_USDHC=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 8056e53da1..5f2b40f4a1 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 27c215f6f7..3ca42d7344 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 65e9c4f117..379407ab43 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -35,7 +35,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index 02f972af0d..516aac1f14 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -62,7 +62,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 9400805831..2c88fe67c2 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -74,7 +74,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 643cad4a65..e614ef29ea 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -34,7 +34,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 3dada9961a..6ade0ef142 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -34,7 +34,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 63a7a74b0a..9b3f2252de 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -43,7 +43,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 81f5fa5e76..7efe321b88 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 565dc890a7..4e6f1ed554 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -31,7 +31,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 11c2a82779..fa9853def6 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -34,7 +34,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 135961a0c4..c5fabf9950 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -38,7 +38,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 21c936648c..82093af750 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -47,7 +47,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 1d777b5fb2..c848c530a8 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -44,7 +44,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 1014bd8a02..274fec0e58 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -44,7 +44,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index f4681a630c..2528ba8061 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -30,7 +30,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_74X164=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index 6fb30ce4f1..f71a495183 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -31,7 +31,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_74X164=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index 45901f041f..1107507b51 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -48,7 +48,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_PHYLIB=y diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig index 2f566984d5..b8ced1994a 100644 --- a/configs/mx7dsabresd_qspi_defconfig +++ b/configs/mx7dsabresd_qspi_defconfig @@ -48,7 +48,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index d4eba65ac0..df854436a0 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -22,7 +22,7 @@ CONFIG_IMX_RGPIO2P=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7ULP=y CONFIG_DM_REGULATOR=y diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index ae8d4b4d39..b2451adce7 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -21,7 +21,7 @@ CONFIG_IMX_RGPIO2P=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7ULP=y CONFIG_DM_REGULATOR=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index c50e79aba8..11bee9b550 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 85a8a8d708..141289f174 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 5a2df361fd..841418350b 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -39,7 +39,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index fdc0f2b03f..e0af34c8a7 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -39,7 +39,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 230b12f7e6..53eb96a986 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 72e590a4fe..e60c237857 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 93374282a6..c928b258b1 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -49,7 +49,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index 14e15b03b2..a14a139298 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -70,7 +70,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_PWRSEQ=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index b33b0c4028..0fbfc61754 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -32,7 +32,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 82ee6d0fc6..2999b57096 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -42,7 +42,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index f7e5faa27e..44aa70d656 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -43,7 +43,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index f710d0dece..6787439e43 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -42,7 +42,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:-(nand);spi2.0:1024k(bootloader),64k CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index cf43b43924..91fdd5c53b 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -35,7 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index ff0cd6c3aa..4b9bb36984 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -30,7 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ull-phycore-segin" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_FEC_MXC=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index 55f25d5c24..7395598599 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 71350fb87e..3869eb70cc 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 03452635e9..ad29af1b71 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -48,7 +48,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 86f4280de7..a2cddfcf4f 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -43,7 +43,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 43c5d9e002..3d45872a84 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index 2e23c7b491..1a8a4541c6 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 956bb35c9b..b864b537c3 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 4cc4954e84..886ddacba2 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -48,7 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),495M(ubi0),14M(res0),2M(res1),512k(res2),512k(res3),-(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 1410bf8c8d..2367a17dd1 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -48,7 +48,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 0b6304eb4d..8938b39c7f 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 427bd9dae3..cf3647a8f1 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 40ca954487..0b690f1ae7 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index 748b13ea84..7bc687f64d 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 88fbbf4bc0..f5859038be 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -50,7 +50,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 2816f66c8e..86d1da3324 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -34,7 +34,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index 887f938c70..4f2d4141c8 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index 6abefa3bdd..9ad9ea3c2d 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 67aae058ae..36b4b3cae8 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 6ecba56ea2..21bc3fab75 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index d291d0fd98..0a8cc6d171 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index b5acd0e856..e02b8a5c10 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index f2a8376111..03e893044b 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -59,7 +59,7 @@ CONFIG_LED_STATUS_BIT5=5 CONFIG_LED_STATUS_STATE5=2 CONFIG_LED_STATUS_CMD=y CONFIG_PCA9551_LED=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 259ffee043..ea6da7aa65 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -29,7 +29,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 4f00e48110..597f557f7b 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index 55f4ff59d2..cb1b17c424 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -30,7 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ull-dart-6ul" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_FEC_MXC=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index c731d96e9c..19e0a911e7 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -42,7 +42,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index c4a9624f4b..f07ec5f651 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -54,7 +54,7 @@ CONFIG_SYS_I2C_MXC_I2C1=y CONFIG_SYS_I2C_MXC_I2C2=y CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index a0289421ff..80accfb509 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -33,7 +33,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 11f16cf47d..a022454976 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -39,7 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 0f911a9669..7a6ea6f8c6 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y # CONFIG_NET is not set CONFIG_DFU_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index 64fed1dc72..70cdd792b7 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index c203353f58..913d577bcd 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index 1aee743590..2b539f21be 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index f361ad93a8..fd208e7752 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -34,7 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC_IMX=y +CONFIG_FSL_USDHC=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0 diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c6812f6517..b758b250f5 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -694,6 +694,13 @@ config FSL_ESDHC_IMX This selects support for the i.MX eSDHC (Enhanced Secure Digital Host Controller) found on numerous Freescale/NXP SoCs.
+config FSL_USDHC + bool "Freescale/NXP i.MX uSDHC controller support" + depends on MX6 || MX7 ||ARCH_MX7ULP || IMX8 + select FSL_ESDHC_IMX + help + This enables the Ultra Secured Digital Host Controller enhancements + endmenu
config SYS_FSL_ERRATUM_ESDHC111 diff --git a/include/configs/advantech_dms-ba16.h b/include/configs/advantech_dms-ba16.h index a037349162..1298859812 100644 --- a/include/configs/advantech_dms-ba16.h +++ b/include/configs/advantech_dms-ba16.h @@ -39,7 +39,6 @@ #define CONFIG_LBA48
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* USB Configs */ diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index 32623c263a..6eb8395162 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -15,7 +15,6 @@
#undef CONFIG_BOOTM_NETBSD
-#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 974571df43..4eceb10e8f 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_MXC_I2C3_SPEED 400000
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 3
diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index 4c93fc6cbe..8ae9eb5a7b 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -147,7 +147,6 @@ #define CONFIG_ENV_SECT_SIZE (64 * 1024)
/* MMC Config*/ -#define CONFIG_FSL_USDHC #ifdef CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index 2469066849..6f3c34d1ad 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -15,7 +15,6 @@
-#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5b010000 #define USDHC2_BASE_ADDR 0x5b020000 diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 147f801353..aee9f2f1d0 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -40,7 +40,6 @@ #define CONFIG_SYS_MXC_I2C3_SPEED 400000
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 2
diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index fb1b899d71..4f99805ee2 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -55,7 +55,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 7d2e573846..c3a17b010c 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -49,7 +49,6 @@ #define CONFIG_ARP_TIMEOUT 200UL
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 3 #define CONFIG_SYS_MMC_ENV_DEV 2 /* 1 = SDHC3, 2 = SDHC4 (eMMC) */ diff --git a/include/configs/display5.h b/include/configs/display5.h index 1d3334ff12..e3f90a6279 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -77,7 +77,6 @@ #endif
diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 16e4136fa9..c2113439c3 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -216,7 +216,6 @@ #define CONFIG_IMX_BOOTAUX
#define CONFIG_CMD_MMC -#define CONFIG_FSL_USDHC
#define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0 diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 8fdf677573..5a9fd57060 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -47,7 +47,6 @@ #undef CONFIG_CMD_CRC32 #undef CONFIG_BOOTM_NETBSD
-#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5B010000 #define USDHC2_BASE_ADDR 0x5B020000 diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index c1f193487e..02c4e9f8f6 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -46,7 +46,6 @@ #undef CONFIG_CMD_CRC32 #undef CONFIG_BOOTM_NETBSD
-#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5B010000 #define USDHC2_BASE_ADDR 0x5B020000 diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index dbae276121..2435ebbc7f 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* MMC Configs */ -#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_MMC_ENV_DEV 1 /* 0 = SDHC2, 1 = SDHC4 (eMMC) */ diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 2b8ce9d71d..f6c0e21d07 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -55,7 +55,6 @@ #define CONFIG_SYS_MAXARGS 32
/* MMC */ -#define CONFIG_FSL_USDHC
/* Secure boot (HAB) support */ #ifdef CONFIG_SECURE_BOOT diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 4f822ef9a0..70dda35eb0 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -40,7 +40,6 @@ #define CONFIG_MXC_UART
#define CONFIG_ARMV7_SECURE_BASE 0x00900000
diff --git a/include/configs/mx7ulp_evk.h b/include/configs/mx7ulp_evk.h index 2af5a4fe3e..763a46b47f 100644 --- a/include/configs/mx7ulp_evk.h +++ b/include/configs/mx7ulp_evk.h @@ -27,8 +27,6 @@ #define IRAM_BASE_ADDR OCRAM_0_BASE #define IOMUXC_BASE_ADDR IOMUXC1_RBASE
-#define CONFIG_FSL_USDHC - #define CONFIG_SYS_FSL_USDHC_NUM 1
#define CONFIG_SYS_FSL_ESDHC_ADDR 0 diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index 8fef250ac4..943fca9377 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -31,7 +31,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index 0f1a010b4e..650caaa573 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -37,7 +37,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
#define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR #define CONFIG_SUPPORT_EMMC_BOOT diff --git a/include/configs/s32v234evb.h b/include/configs/s32v234evb.h index 216932046b..cc6d920637 100644 --- a/include/configs/s32v234evb.h +++ b/include/configs/s32v234evb.h @@ -65,7 +65,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_SYS_UART_PORT (1)
-#define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC_BASE_ADDR #define CONFIG_SYS_FSL_ESDHC_NUM 1
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 5de8b81334..82ef4c3ca1 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -622,7 +622,6 @@ CONFIG_FSL_SGMII_RISER CONFIG_FSL_SPI_INTERFACE CONFIG_FSL_TBCLK_EXTRA_DIV CONFIG_FSL_TRUST_ARCH_v1 -CONFIG_FSL_USDHC CONFIG_FSL_VIA CONFIG_FSMC_NAND_BASE CONFIG_FSMTDBLK
Adam Ford
