[U-Boot-Users] [PATCH] mpc83xx: Consolidate the ECC support of 83xx
Remove the duplicated source code of ecc command on the <board>.c, for reused, move these code to cpu/mpc83xx directory.
Signed-off-by: Dave Liu daveliu@freescale.com --- board/mpc8349emds/mpc8349emds.c | 327 -------------------------------- board/mpc8360emds/mpc8360emds.c | 378 ------------------------------------- cpu/mpc83xx/Makefile | 2 +- cpu/mpc83xx/ecc.c | 390 +++++++++++++++++++++++++++++++++++++++ 4 files changed, 391 insertions(+), 706 deletions(-) create mode 100644 cpu/mpc83xx/ecc.c
diff --git a/board/mpc8349emds/mpc8349emds.c b/board/mpc8349emds/mpc8349emds.c index 071591e..521d1bb 100644 --- a/board/mpc8349emds/mpc8349emds.c +++ b/board/mpc8349emds/mpc8349emds.c @@ -29,7 +29,6 @@ #include <i2c.h> #include <spd.h> #include <miiphy.h> -#include <command.h> #if defined(CONFIG_SPD_EEPROM) #include <spd_sdram.h> #endif @@ -258,332 +257,6 @@ void sdram_init(void) } #endif
-#if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) -/* - * ECC user commands - */ -void ecc_print_status(void) -{ - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - - printf("\nECC mode: %s\n\n", (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) ? "ON" : "OFF"); - - /* Interrupts */ - printf("Memory Error Interrupt Enable:\n"); - printf(" Multiple-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MBEE) ? 1 : 0); - printf(" Single-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_SBEE) ? 1 : 0); - printf(" Memory Select Error Interrupt Enable: %d\n\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MSEE) ? 1 : 0); - - /* Error disable */ - printf("Memory Error Disable:\n"); - printf(" Multiple-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MBED) ? 1 : 0); - printf(" Sinle-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_SBED) ? 1 : 0); - printf(" Memory Select Error Disable: %d\n\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MSED) ? 1 : 0); - - /* Error injection */ - printf("Memory Data Path Error Injection Mask High/Low: %08lx %08lx\n", - ddr->data_err_inject_hi, ddr->data_err_inject_lo); - - printf("Memory Data Path Error Injection Mask ECC:\n"); - printf(" ECC Mirror Byte: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EMB) ? 1 : 0); - printf(" ECC Injection Enable: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EIEN) ? 1 : 0); - printf(" ECC Error Injection Mask: 0x%02x\n\n", - ddr->ecc_err_inject & ECC_ERR_INJECT_EEIM); - - /* SBE counter/threshold */ - printf("Memory Single-Bit Error Management (0..255):\n"); - printf(" Single-Bit Error Threshold: %d\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBET) >> ECC_ERROR_MAN_SBET_SHIFT); - printf(" Single-Bit Error Counter: %d\n\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBEC) >> ECC_ERROR_MAN_SBEC_SHIFT); - - /* Error detect */ - printf("Memory Error Detect:\n"); - printf(" Multiple Memory Errors: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MME) ? 1 : 0); - printf(" Multiple-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MBE) ? 1 : 0); - printf(" Single-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_SBE) ? 1 : 0); - printf(" Memory Select Error: %d\n\n", - (ddr->err_detect & ECC_ERROR_DETECT_MSE) ? 1 : 0); - - /* Capture data */ - printf("Memory Error Address Capture: 0x%08lx\n", ddr->capture_address); - printf("Memory Data Path Read Capture High/Low: %08lx %08lx\n", - ddr->capture_data_hi, ddr->capture_data_lo); - printf("Memory Data Path Read Capture ECC: 0x%02x\n\n", - ddr->capture_ecc & CAPTURE_ECC_ECE); - - printf("Memory Error Attributes Capture:\n"); - printf(" Data Beat Number: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_BNUM) >> ECC_CAPT_ATTR_BNUM_SHIFT); - printf(" Transaction Size: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSIZ) >> ECC_CAPT_ATTR_TSIZ_SHIFT); - printf(" Transaction Source: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSRC) >> ECC_CAPT_ATTR_TSRC_SHIFT); - printf(" Transaction Type: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TTYP) >> ECC_CAPT_ATTR_TTYP_SHIFT); - printf(" Error Information Valid: %d\n\n", - ddr->capture_attributes & ECC_CAPT_ATTR_VLD); -} - -int do_ecc ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - volatile immap_t *immap = (immap_t *)CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - volatile u32 val; - u64 *addr, count, val64; - register u64 *i; - - if (argc > 4) { - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; - } - - if (argc == 2) { - if (strcmp(argv[1], "status") == 0) { - ecc_print_status(); - return 0; - } else if (strcmp(argv[1], "captureclear") == 0) { - ddr->capture_address = 0; - ddr->capture_data_hi = 0; - ddr->capture_data_lo = 0; - ddr->capture_ecc = 0; - ddr->capture_attributes = 0; - return 0; - } - } - - if (argc == 3) { - if (strcmp(argv[1], "sbecnt") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBEC_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBET); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "sbethr") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBET_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBEC); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "errdisable") == 0) { - val = ddr->err_disable; - - if (strcmp(argv[2], "+sbe") == 0) { - val |= ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "+mbe") == 0) { - val |= ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "+mse") == 0) { - val |= ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "+all") == 0) { - val |= (ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else if (strcmp(argv[2], "-sbe") == 0) { - val &= ~ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "-mbe") == 0) { - val &= ~ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "-mse") == 0) { - val &= ~ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "-all") == 0) { - val &= ~(ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else { - printf("Incorrect err_disable field\n"); - return 1; - } - - ddr->err_disable = val; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - return 0; - } else if (strcmp(argv[1], "errdetectclr") == 0) { - val = ddr->err_detect; - - if (strcmp(argv[2], "mme") == 0) { - val |= ECC_ERROR_DETECT_MME; - } else if (strcmp(argv[2], "sbe") == 0) { - val |= ECC_ERROR_DETECT_SBE; - } else if (strcmp(argv[2], "mbe") == 0) { - val |= ECC_ERROR_DETECT_MBE; - } else if (strcmp(argv[2], "mse") == 0) { - val |= ECC_ERROR_DETECT_MSE; - } else if (strcmp(argv[2], "all") == 0) { - val |= (ECC_ERROR_DETECT_MME | - ECC_ERROR_DETECT_MBE | - ECC_ERROR_DETECT_SBE | - ECC_ERROR_DETECT_MSE); - } else { - printf("Incorrect err_detect field\n"); - return 1; - } - - ddr->err_detect = val; - return 0; - } else if (strcmp(argv[1], "injectdatahi") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_hi = val; - return 0; - } else if (strcmp(argv[1], "injectdatalo") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_lo = val; - return 0; - } else if (strcmp(argv[1], "injectecc") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - if (val > 0xff) { - printf("Incorrect ECC inject mask, should be 0x00..0xff\n"); - return 1; - } - val |= (ddr->ecc_err_inject & ~ECC_ERR_INJECT_EEIM); - - ddr->ecc_err_inject = val; - return 0; - } else if (strcmp(argv[1], "inject") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EIEN; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EIEN; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - return 0; - } else if (strcmp(argv[1], "mirror") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EMB; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EMB; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - return 0; - } - } - - if (argc == 4) { - if (strcmp(argv[1], "test") == 0) { - addr = (u64 *)simple_strtoul(argv[2], NULL, 16); - count = simple_strtoul(argv[3], NULL, 16); - - if ((u32)addr % 8) { - printf("Address not alligned on double word boundary\n"); - return 1; - } - - disable_interrupts(); - icache_disable(); - - for (i = addr; i < addr + count; i++) { - /* enable injects */ - ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* write memory location injecting errors */ - *i = 0x1122334455667788ULL; - __asm__ __volatile__ ("sync"); - - /* disable injects */ - ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* read data, this generates ECC error */ - val64 = *i; - __asm__ __volatile__ ("sync"); - - /* disable errors for ECC */ - ddr->err_disable |= ~ECC_ERROR_ENABLE; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - - /* re-initialize memory, write the location again - * NOT injecting errors this time */ - *i = 0xcafecafecafecafeULL; - __asm__ __volatile__ ("sync"); - - /* enable errors for ECC */ - ddr->err_disable &= ECC_ERROR_ENABLE; - __asm__ __volatile__ ("sync"); - __asm__ __volatile__ ("isync"); - } - - icache_enable(); - enable_interrupts(); - - return 0; - } - } - - printf ("Usage:\n%s\n", cmdtp->usage); - return 1; -} - -U_BOOT_CMD( - ecc, 4, 0, do_ecc, - "ecc - support for DDR ECC features\n", - "status - print out status info\n" - "ecc captureclear - clear capture regs data\n" - "ecc sbecnt <val> - set Single-Bit Error counter\n" - "ecc sbethr <val> - set Single-Bit Threshold\n" - "ecc errdisable <flag> - clear/set disable Memory Error Disable, flag:\n" - " [-|+]sbe - Single-Bit Error\n" - " [-|+]mbe - Multiple-Bit Error\n" - " [-|+]mse - Memory Select Error\n" - " [-|+]all - all errors\n" - "ecc errdetectclr <flag> - clear Memory Error Detect, flag:\n" - " mme - Multiple Memory Errors\n" - " sbe - Single-Bit Error\n" - " mbe - Multiple-Bit Error\n" - " mse - Memory Select Error\n" - " all - all errors\n" - "ecc injectdatahi <hi> - set Memory Data Path Error Injection Mask High\n" - "ecc injectdatalo <lo> - set Memory Data Path Error Injection Mask Low\n" - "ecc injectecc <ecc> - set ECC Error Injection Mask\n" - "ecc inject <en|dis> - enable/disable error injection\n" - "ecc mirror <en|dis> - enable/disable mirror byte\n" - "ecc test <addr> <cnt> - test mem region:\n" - " - enables injects\n" - " - writes pattern injecting errors\n" - " - disables injects\n" - " - reads pattern back, generates error\n" - " - re-inits memory" -); -#endif /* if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) */ - #if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) diff --git a/board/mpc8360emds/mpc8360emds.c b/board/mpc8360emds/mpc8360emds.c index b109317..3fa093d 100644 --- a/board/mpc8360emds/mpc8360emds.c +++ b/board/mpc8360emds/mpc8360emds.c @@ -1,8 +1,6 @@ /* * Copyright (C) 2006 Freescale Semiconductor, Inc. - * * Dave Liu daveliu@freescale.com - * based on board/mpc8349emds/mpc8349emds.c * * See file CREDITS for list of people who contributed to this * project. @@ -19,7 +17,6 @@ #include <i2c.h> #include <spd.h> #include <miiphy.h> -#include <command.h> #if defined(CONFIG_PCI) #include <pci.h> #endif @@ -288,381 +285,6 @@ void sdram_init(void) } #endif
-#if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) -/* - * ECC user commands - */ -void ecc_print_status(void) -{ - volatile immap_t *immap = (immap_t *) CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - - printf("\nECC mode: %s\n\n", - (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) ? "ON" : "OFF"); - - /* Interrupts */ - printf("Memory Error Interrupt Enable:\n"); - printf(" Multiple-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MBEE) ? 1 : 0); - printf(" Single-Bit Error Interrupt Enable: %d\n", - (ddr->err_int_en & ECC_ERR_INT_EN_SBEE) ? 1 : 0); - printf(" Memory Select Error Interrupt Enable: %d\n\n", - (ddr->err_int_en & ECC_ERR_INT_EN_MSEE) ? 1 : 0); - - /* Error disable */ - printf("Memory Error Disable:\n"); - printf(" Multiple-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MBED) ? 1 : 0); - printf(" Sinle-Bit Error Disable: %d\n", - (ddr->err_disable & ECC_ERROR_DISABLE_SBED) ? 1 : 0); - printf(" Memory Select Error Disable: %d\n\n", - (ddr->err_disable & ECC_ERROR_DISABLE_MSED) ? 1 : 0); - - /* Error injection */ - printf("Memory Data Path Error Injection Mask High/Low: %08lx %08lx\n", - ddr->data_err_inject_hi, ddr->data_err_inject_lo); - - printf("Memory Data Path Error Injection Mask ECC:\n"); - printf(" ECC Mirror Byte: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EMB) ? 1 : 0); - printf(" ECC Injection Enable: %d\n", - (ddr->ecc_err_inject & ECC_ERR_INJECT_EIEN) ? 1 : 0); - printf(" ECC Error Injection Mask: 0x%02x\n\n", - ddr->ecc_err_inject & ECC_ERR_INJECT_EEIM); - - /* SBE counter/threshold */ - printf("Memory Single-Bit Error Management (0..255):\n"); - printf(" Single-Bit Error Threshold: %d\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBET) >> ECC_ERROR_MAN_SBET_SHIFT); - printf(" Single-Bit Error Counter: %d\n\n", - (ddr->err_sbe & ECC_ERROR_MAN_SBEC) >> ECC_ERROR_MAN_SBEC_SHIFT); - - /* Error detect */ - printf("Memory Error Detect:\n"); - printf(" Multiple Memory Errors: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MME) ? 1 : 0); - printf(" Multiple-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_MBE) ? 1 : 0); - printf(" Single-Bit Error: %d\n", - (ddr->err_detect & ECC_ERROR_DETECT_SBE) ? 1 : 0); - printf(" Memory Select Error: %d\n\n", - (ddr->err_detect & ECC_ERROR_DETECT_MSE) ? 1 : 0); - - /* Capture data */ - printf("Memory Error Address Capture: 0x%08lx\n", ddr->capture_address); - printf("Memory Data Path Read Capture High/Low: %08lx %08lx\n", - ddr->capture_data_hi, ddr->capture_data_lo); - printf("Memory Data Path Read Capture ECC: 0x%02x\n\n", - ddr->capture_ecc & CAPTURE_ECC_ECE); - - printf("Memory Error Attributes Capture:\n"); - printf(" Data Beat Number: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_BNUM) >> - ECC_CAPT_ATTR_BNUM_SHIFT); - printf(" Transaction Size: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSIZ) >> - ECC_CAPT_ATTR_TSIZ_SHIFT); - printf(" Transaction Source: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TSRC) >> - ECC_CAPT_ATTR_TSRC_SHIFT); - printf(" Transaction Type: %d\n", - (ddr->capture_attributes & ECC_CAPT_ATTR_TTYP) >> - ECC_CAPT_ATTR_TTYP_SHIFT); - printf(" Error Information Valid: %d\n\n", - ddr->capture_attributes & ECC_CAPT_ATTR_VLD); -} - -int do_ecc(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) -{ - volatile immap_t *immap = (immap_t *) CFG_IMMR; - volatile ddr83xx_t *ddr = &immap->ddr; - volatile u32 val; - u64 *addr; - u32 count; - register u64 *i; - u32 ret[2]; - u32 pattern[2]; - u32 writeback[2]; - - /* The pattern is written into memory to generate error */ - pattern[0] = 0xfedcba98UL; - pattern[1] = 0x76543210UL; - - /* After injecting error, re-initialize the memory with the value */ - writeback[0] = 0x01234567UL; - writeback[1] = 0x89abcdefUL; - - if (argc > 4) { - printf("Usage:\n%s\n", cmdtp->usage); - return 1; - } - - if (argc == 2) { - if (strcmp(argv[1], "status") == 0) { - ecc_print_status(); - return 0; - } else if (strcmp(argv[1], "captureclear") == 0) { - ddr->capture_address = 0; - ddr->capture_data_hi = 0; - ddr->capture_data_lo = 0; - ddr->capture_ecc = 0; - ddr->capture_attributes = 0; - return 0; - } - } - if (argc == 3) { - if (strcmp(argv[1], "sbecnt") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, " - "should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBEC_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBET); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "sbethr") == 0) { - val = simple_strtoul(argv[2], NULL, 10); - if (val > 255) { - printf("Incorrect Counter value, " - "should be 0..255\n"); - return 1; - } - - val = (val << ECC_ERROR_MAN_SBET_SHIFT); - val |= (ddr->err_sbe & ECC_ERROR_MAN_SBEC); - - ddr->err_sbe = val; - return 0; - } else if (strcmp(argv[1], "errdisable") == 0) { - val = ddr->err_disable; - - if (strcmp(argv[2], "+sbe") == 0) { - val |= ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "+mbe") == 0) { - val |= ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "+mse") == 0) { - val |= ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "+all") == 0) { - val |= (ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else if (strcmp(argv[2], "-sbe") == 0) { - val &= ~ECC_ERROR_DISABLE_SBED; - } else if (strcmp(argv[2], "-mbe") == 0) { - val &= ~ECC_ERROR_DISABLE_MBED; - } else if (strcmp(argv[2], "-mse") == 0) { - val &= ~ECC_ERROR_DISABLE_MSED; - } else if (strcmp(argv[2], "-all") == 0) { - val &= ~(ECC_ERROR_DISABLE_SBED | - ECC_ERROR_DISABLE_MBED | - ECC_ERROR_DISABLE_MSED); - } else { - printf("Incorrect err_disable field\n"); - return 1; - } - - ddr->err_disable = val; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - return 0; - } else if (strcmp(argv[1], "errdetectclr") == 0) { - val = ddr->err_detect; - - if (strcmp(argv[2], "mme") == 0) { - val |= ECC_ERROR_DETECT_MME; - } else if (strcmp(argv[2], "sbe") == 0) { - val |= ECC_ERROR_DETECT_SBE; - } else if (strcmp(argv[2], "mbe") == 0) { - val |= ECC_ERROR_DETECT_MBE; - } else if (strcmp(argv[2], "mse") == 0) { - val |= ECC_ERROR_DETECT_MSE; - } else if (strcmp(argv[2], "all") == 0) { - val |= (ECC_ERROR_DETECT_MME | - ECC_ERROR_DETECT_MBE | - ECC_ERROR_DETECT_SBE | - ECC_ERROR_DETECT_MSE); - } else { - printf("Incorrect err_detect field\n"); - return 1; - } - - ddr->err_detect = val; - return 0; - } else if (strcmp(argv[1], "injectdatahi") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_hi = val; - return 0; - } else if (strcmp(argv[1], "injectdatalo") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - - ddr->data_err_inject_lo = val; - return 0; - } else if (strcmp(argv[1], "injectecc") == 0) { - val = simple_strtoul(argv[2], NULL, 16); - if (val > 0xff) { - printf("Incorrect ECC inject mask, " - "should be 0x00..0xff\n"); - return 1; - } - val |= (ddr->ecc_err_inject & ~ECC_ERR_INJECT_EEIM); - - ddr->ecc_err_inject = val; - return 0; - } else if (strcmp(argv[1], "inject") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EIEN; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EIEN; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - return 0; - } else if (strcmp(argv[1], "mirror") == 0) { - val = ddr->ecc_err_inject; - - if (strcmp(argv[2], "en") == 0) - val |= ECC_ERR_INJECT_EMB; - else if (strcmp(argv[2], "dis") == 0) - val &= ~ECC_ERR_INJECT_EMB; - else - printf("Incorrect command\n"); - - ddr->ecc_err_inject = val; - return 0; - } - } - if (argc == 4) { - if (strcmp(argv[1], "testdw") == 0) { - addr = (u64 *) simple_strtoul(argv[2], NULL, 16); - count = simple_strtoul(argv[3], NULL, 16); - - if ((u32) addr % 8) { - printf("Address not alligned on " - "double word boundary\n"); - return 1; - } - disable_interrupts(); - - for (i = addr; i < addr + count; i++) { - - /* enable injects */ - ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - - /* write memory location injecting errors */ - ppcDWstore((u32 *) i, pattern); - __asm__ __volatile__("sync"); - - /* disable injects */ - ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - - /* read data, this generates ECC error */ - ppcDWload((u32 *) i, ret); - __asm__ __volatile__("sync"); - - /* re-initialize memory, double word write the location again, - * generates new ECC code this time */ - ppcDWstore((u32 *) i, writeback); - __asm__ __volatile__("sync"); - } - enable_interrupts(); - return 0; - } - if (strcmp(argv[1], "testword") == 0) { - addr = (u64 *) simple_strtoul(argv[2], NULL, 16); - count = simple_strtoul(argv[3], NULL, 16); - - if ((u32) addr % 8) { - printf("Address not alligned on " - "double word boundary\n"); - return 1; - } - disable_interrupts(); - - for (i = addr; i < addr + count; i++) { - - /* enable injects */ - ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - - /* write memory location injecting errors */ - *(u32 *) i = 0xfedcba98UL; - __asm__ __volatile__("sync"); - - /* sub double word write, - * bus will read-modify-write, - * generates ECC error */ - *((u32 *) i + 1) = 0x76543210UL; - __asm__ __volatile__("sync"); - - /* disable injects */ - ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; - __asm__ __volatile__("sync"); - __asm__ __volatile__("isync"); - - /* re-initialize memory, - * double word write the location again, - * generates new ECC code this time */ - ppcDWstore((u32 *) i, writeback); - __asm__ __volatile__("sync"); - } - enable_interrupts(); - return 0; - } - } - printf("Usage:\n%s\n", cmdtp->usage); - return 1; -} - -U_BOOT_CMD(ecc, 4, 0, do_ecc, - "ecc - support for DDR ECC features\n", - "status - print out status info\n" - "ecc captureclear - clear capture regs data\n" - "ecc sbecnt <val> - set Single-Bit Error counter\n" - "ecc sbethr <val> - set Single-Bit Threshold\n" - "ecc errdisable <flag> - clear/set disable Memory Error Disable, flag:\n" - " [-|+]sbe - Single-Bit Error\n" - " [-|+]mbe - Multiple-Bit Error\n" - " [-|+]mse - Memory Select Error\n" - " [-|+]all - all errors\n" - "ecc errdetectclr <flag> - clear Memory Error Detect, flag:\n" - " mme - Multiple Memory Errors\n" - " sbe - Single-Bit Error\n" - " mbe - Multiple-Bit Error\n" - " mse - Memory Select Error\n" - " all - all errors\n" - "ecc injectdatahi <hi> - set Memory Data Path Error Injection Mask High\n" - "ecc injectdatalo <lo> - set Memory Data Path Error Injection Mask Low\n" - "ecc injectecc <ecc> - set ECC Error Injection Mask\n" - "ecc inject <en|dis> - enable/disable error injection\n" - "ecc mirror <en|dis> - enable/disable mirror byte\n" - "ecc testdw <addr> <cnt> - test mem region with double word access:\n" - " - enables injects\n" - " - writes pattern injecting errors with double word access\n" - " - disables injects\n" - " - reads pattern back with double word access, generates error\n" - " - re-inits memory\n" - "ecc testword <addr> <cnt> - test mem region with word access:\n" - " - enables injects\n" - " - writes pattern injecting errors with word access\n" - " - writes pattern with word access, generates error\n" - " - disables injects\n" " - re-inits memory"); -#endif /* if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) */ - #if (defined(CONFIG_OF_FLAT_TREE) || defined(CONFIG_OF_LIBFDT)) \ && defined(CONFIG_OF_BOARD_SETUP)
diff --git a/cpu/mpc83xx/Makefile b/cpu/mpc83xx/Makefile index bb96f77..2329970 100644 --- a/cpu/mpc83xx/Makefile +++ b/cpu/mpc83xx/Makefile @@ -29,7 +29,7 @@ LIB = $(obj)lib$(CPU).a
START = start.o COBJS = traps.o cpu.o cpu_init.o speed.o interrupts.o \ - spd_sdram.o qe_io.o pci.o + spd_sdram.o ecc.o qe_io.o pci.o
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) diff --git a/cpu/mpc83xx/ecc.c b/cpu/mpc83xx/ecc.c new file mode 100644 index 0000000..6f13094 --- /dev/null +++ b/cpu/mpc83xx/ecc.c @@ -0,0 +1,390 @@ +/* + * Copyright (C) 2007 Freescale Semiconductor, Inc. + * + * Dave Liu daveliu@freescale.com + * based on the contribution of Marian Balakowicz m8@semihalf.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + */ + +#include <common.h> +#include <mpc83xx.h> +#include <command.h> + +#if defined(CONFIG_DDR_ECC) && defined(CONFIG_DDR_ECC_CMD) +void ecc_print_status(void) +{ + volatile immap_t *immap = (immap_t *) CFG_IMMR; + volatile ddr83xx_t *ddr = &immap->ddr; + + printf("\nECC mode: %s\n\n", + (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) ? "ON" : "OFF"); + + /* Interrupts */ + printf("Memory Error Interrupt Enable:\n"); + printf(" Multiple-Bit Error Interrupt Enable: %d\n", + (ddr->err_int_en & ECC_ERR_INT_EN_MBEE) ? 1 : 0); + printf(" Single-Bit Error Interrupt Enable: %d\n", + (ddr->err_int_en & ECC_ERR_INT_EN_SBEE) ? 1 : 0); + printf(" Memory Select Error Interrupt Enable: %d\n\n", + (ddr->err_int_en & ECC_ERR_INT_EN_MSEE) ? 1 : 0); + + /* Error disable */ + printf("Memory Error Disable:\n"); + printf(" Multiple-Bit Error Disable: %d\n", + (ddr->err_disable & ECC_ERROR_DISABLE_MBED) ? 1 : 0); + printf(" Sinle-Bit Error Disable: %d\n", + (ddr->err_disable & ECC_ERROR_DISABLE_SBED) ? 1 : 0); + printf(" Memory Select Error Disable: %d\n\n", + (ddr->err_disable & ECC_ERROR_DISABLE_MSED) ? 1 : 0); + + /* Error injection */ + printf("Memory Data Path Error Injection Mask High/Low: %08lx %08lx\n", + ddr->data_err_inject_hi, ddr->data_err_inject_lo); + + printf("Memory Data Path Error Injection Mask ECC:\n"); + printf(" ECC Mirror Byte: %d\n", + (ddr->ecc_err_inject & ECC_ERR_INJECT_EMB) ? 1 : 0); + printf(" ECC Injection Enable: %d\n", + (ddr->ecc_err_inject & ECC_ERR_INJECT_EIEN) ? 1 : 0); + printf(" ECC Error Injection Mask: 0x%02x\n\n", + ddr->ecc_err_inject & ECC_ERR_INJECT_EEIM); + + /* SBE counter/threshold */ + printf("Memory Single-Bit Error Management (0..255):\n"); + printf(" Single-Bit Error Threshold: %d\n", + (ddr->err_sbe & ECC_ERROR_MAN_SBET) >> ECC_ERROR_MAN_SBET_SHIFT); + printf(" Single-Bit Error Counter: %d\n\n", + (ddr->err_sbe & ECC_ERROR_MAN_SBEC) >> ECC_ERROR_MAN_SBEC_SHIFT); + + /* Error detect */ + printf("Memory Error Detect:\n"); + printf(" Multiple Memory Errors: %d\n", + (ddr->err_detect & ECC_ERROR_DETECT_MME) ? 1 : 0); + printf(" Multiple-Bit Error: %d\n", + (ddr->err_detect & ECC_ERROR_DETECT_MBE) ? 1 : 0); + printf(" Single-Bit Error: %d\n", + (ddr->err_detect & ECC_ERROR_DETECT_SBE) ? 1 : 0); + printf(" Memory Select Error: %d\n\n", + (ddr->err_detect & ECC_ERROR_DETECT_MSE) ? 1 : 0); + + /* Capture data */ + printf("Memory Error Address Capture: 0x%08lx\n", ddr->capture_address); + printf("Memory Data Path Read Capture High/Low: %08lx %08lx\n", + ddr->capture_data_hi, ddr->capture_data_lo); + printf("Memory Data Path Read Capture ECC: 0x%02x\n\n", + ddr->capture_ecc & CAPTURE_ECC_ECE); + + printf("Memory Error Attributes Capture:\n"); + printf(" Data Beat Number: %d\n", + (ddr->capture_attributes & ECC_CAPT_ATTR_BNUM) >> + ECC_CAPT_ATTR_BNUM_SHIFT); + printf(" Transaction Size: %d\n", + (ddr->capture_attributes & ECC_CAPT_ATTR_TSIZ) >> + ECC_CAPT_ATTR_TSIZ_SHIFT); + printf(" Transaction Source: %d\n", + (ddr->capture_attributes & ECC_CAPT_ATTR_TSRC) >> + ECC_CAPT_ATTR_TSRC_SHIFT); + printf(" Transaction Type: %d\n", + (ddr->capture_attributes & ECC_CAPT_ATTR_TTYP) >> + ECC_CAPT_ATTR_TTYP_SHIFT); + printf(" Error Information Valid: %d\n\n", + ddr->capture_attributes & ECC_CAPT_ATTR_VLD); +} + +int do_ecc(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) +{ + volatile immap_t *immap = (immap_t *) CFG_IMMR; + volatile ddr83xx_t *ddr = &immap->ddr; + volatile u32 val; + u64 *addr; + u32 count; + register u64 *i; + u32 ret[2]; + u32 pattern[2]; + u32 writeback[2]; + + /* The pattern is written into memory to generate error */ + pattern[0] = 0xfedcba98UL; + pattern[1] = 0x76543210UL; + + /* After injecting error, re-initialize the memory with the value */ + writeback[0] = 0x01234567UL; + writeback[1] = 0x89abcdefUL; + + if (argc > 4) { + printf("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + if (argc == 2) { + if (strcmp(argv[1], "status") == 0) { + ecc_print_status(); + return 0; + } else if (strcmp(argv[1], "captureclear") == 0) { + ddr->capture_address = 0; + ddr->capture_data_hi = 0; + ddr->capture_data_lo = 0; + ddr->capture_ecc = 0; + ddr->capture_attributes = 0; + return 0; + } + } + if (argc == 3) { + if (strcmp(argv[1], "sbecnt") == 0) { + val = simple_strtoul(argv[2], NULL, 10); + if (val > 255) { + printf("Incorrect Counter value, " + "should be 0..255\n"); + return 1; + } + + val = (val << ECC_ERROR_MAN_SBEC_SHIFT); + val |= (ddr->err_sbe & ECC_ERROR_MAN_SBET); + + ddr->err_sbe = val; + return 0; + } else if (strcmp(argv[1], "sbethr") == 0) { + val = simple_strtoul(argv[2], NULL, 10); + if (val > 255) { + printf("Incorrect Counter value, " + "should be 0..255\n"); + return 1; + } + + val = (val << ECC_ERROR_MAN_SBET_SHIFT); + val |= (ddr->err_sbe & ECC_ERROR_MAN_SBEC); + + ddr->err_sbe = val; + return 0; + } else if (strcmp(argv[1], "errdisable") == 0) { + val = ddr->err_disable; + + if (strcmp(argv[2], "+sbe") == 0) { + val |= ECC_ERROR_DISABLE_SBED; + } else if (strcmp(argv[2], "+mbe") == 0) { + val |= ECC_ERROR_DISABLE_MBED; + } else if (strcmp(argv[2], "+mse") == 0) { + val |= ECC_ERROR_DISABLE_MSED; + } else if (strcmp(argv[2], "+all") == 0) { + val |= (ECC_ERROR_DISABLE_SBED | + ECC_ERROR_DISABLE_MBED | + ECC_ERROR_DISABLE_MSED); + } else if (strcmp(argv[2], "-sbe") == 0) { + val &= ~ECC_ERROR_DISABLE_SBED; + } else if (strcmp(argv[2], "-mbe") == 0) { + val &= ~ECC_ERROR_DISABLE_MBED; + } else if (strcmp(argv[2], "-mse") == 0) { + val &= ~ECC_ERROR_DISABLE_MSED; + } else if (strcmp(argv[2], "-all") == 0) { + val &= ~(ECC_ERROR_DISABLE_SBED | + ECC_ERROR_DISABLE_MBED | + ECC_ERROR_DISABLE_MSED); + } else { + printf("Incorrect err_disable field\n"); + return 1; + } + + ddr->err_disable = val; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + return 0; + } else if (strcmp(argv[1], "errdetectclr") == 0) { + val = ddr->err_detect; + + if (strcmp(argv[2], "mme") == 0) { + val |= ECC_ERROR_DETECT_MME; + } else if (strcmp(argv[2], "sbe") == 0) { + val |= ECC_ERROR_DETECT_SBE; + } else if (strcmp(argv[2], "mbe") == 0) { + val |= ECC_ERROR_DETECT_MBE; + } else if (strcmp(argv[2], "mse") == 0) { + val |= ECC_ERROR_DETECT_MSE; + } else if (strcmp(argv[2], "all") == 0) { + val |= (ECC_ERROR_DETECT_MME | + ECC_ERROR_DETECT_MBE | + ECC_ERROR_DETECT_SBE | + ECC_ERROR_DETECT_MSE); + } else { + printf("Incorrect err_detect field\n"); + return 1; + } + + ddr->err_detect = val; + return 0; + } else if (strcmp(argv[1], "injectdatahi") == 0) { + val = simple_strtoul(argv[2], NULL, 16); + + ddr->data_err_inject_hi = val; + return 0; + } else if (strcmp(argv[1], "injectdatalo") == 0) { + val = simple_strtoul(argv[2], NULL, 16); + + ddr->data_err_inject_lo = val; + return 0; + } else if (strcmp(argv[1], "injectecc") == 0) { + val = simple_strtoul(argv[2], NULL, 16); + if (val > 0xff) { + printf("Incorrect ECC inject mask, " + "should be 0x00..0xff\n"); + return 1; + } + val |= (ddr->ecc_err_inject & ~ECC_ERR_INJECT_EEIM); + + ddr->ecc_err_inject = val; + return 0; + } else if (strcmp(argv[1], "inject") == 0) { + val = ddr->ecc_err_inject; + + if (strcmp(argv[2], "en") == 0) + val |= ECC_ERR_INJECT_EIEN; + else if (strcmp(argv[2], "dis") == 0) + val &= ~ECC_ERR_INJECT_EIEN; + else + printf("Incorrect command\n"); + + ddr->ecc_err_inject = val; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + return 0; + } else if (strcmp(argv[1], "mirror") == 0) { + val = ddr->ecc_err_inject; + + if (strcmp(argv[2], "en") == 0) + val |= ECC_ERR_INJECT_EMB; + else if (strcmp(argv[2], "dis") == 0) + val &= ~ECC_ERR_INJECT_EMB; + else + printf("Incorrect command\n"); + + ddr->ecc_err_inject = val; + return 0; + } + } + if (argc == 4) { + if (strcmp(argv[1], "testdw") == 0) { + addr = (u64 *) simple_strtoul(argv[2], NULL, 16); + count = simple_strtoul(argv[3], NULL, 16); + + if ((u32) addr % 8) { + printf("Address not alligned on " + "double word boundary\n"); + return 1; + } + disable_interrupts(); + + for (i = addr; i < addr + count; i++) { + + /* enable injects */ + ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + + /* write memory location injecting errors */ + ppcDWstore((u32 *) i, pattern); + __asm__ __volatile__("sync"); + + /* disable injects */ + ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + + /* read data, this generates ECC error */ + ppcDWload((u32 *) i, ret); + __asm__ __volatile__("sync"); + + /* re-initialize memory, double word write the location again, + * generates new ECC code this time */ + ppcDWstore((u32 *) i, writeback); + __asm__ __volatile__("sync"); + } + enable_interrupts(); + return 0; + } + if (strcmp(argv[1], "testword") == 0) { + addr = (u64 *) simple_strtoul(argv[2], NULL, 16); + count = simple_strtoul(argv[3], NULL, 16); + + if ((u32) addr % 8) { + printf("Address not alligned on " + "double word boundary\n"); + return 1; + } + disable_interrupts(); + + for (i = addr; i < addr + count; i++) { + + /* enable injects */ + ddr->ecc_err_inject |= ECC_ERR_INJECT_EIEN; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + + /* write memory location injecting errors */ + *(u32 *) i = 0xfedcba98UL; + __asm__ __volatile__("sync"); + + /* sub double word write, + * bus will read-modify-write, + * generates ECC error */ + *((u32 *) i + 1) = 0x76543210UL; + __asm__ __volatile__("sync"); + + /* disable injects */ + ddr->ecc_err_inject &= ~ECC_ERR_INJECT_EIEN; + __asm__ __volatile__("sync"); + __asm__ __volatile__("isync"); + + /* re-initialize memory, + * double word write the location again, + * generates new ECC code this time */ + ppcDWstore((u32 *) i, writeback); + __asm__ __volatile__("sync"); + } + enable_interrupts(); + return 0; + } + } + printf("Usage:\n%s\n", cmdtp->usage); + return 1; +} + +U_BOOT_CMD(ecc, 4, 0, do_ecc, + "ecc - support for DDR ECC features\n", + "status - print out status info\n" + "ecc captureclear - clear capture regs data\n" + "ecc sbecnt <val> - set Single-Bit Error counter\n" + "ecc sbethr <val> - set Single-Bit Threshold\n" + "ecc errdisable <flag> - clear/set disable Memory Error Disable, flag:\n" + " [-|+]sbe - Single-Bit Error\n" + " [-|+]mbe - Multiple-Bit Error\n" + " [-|+]mse - Memory Select Error\n" + " [-|+]all - all errors\n" + "ecc errdetectclr <flag> - clear Memory Error Detect, flag:\n" + " mme - Multiple Memory Errors\n" + " sbe - Single-Bit Error\n" + " mbe - Multiple-Bit Error\n" + " mse - Memory Select Error\n" + " all - all errors\n" + "ecc injectdatahi <hi> - set Memory Data Path Error Injection Mask High\n" + "ecc injectdatalo <lo> - set Memory Data Path Error Injection Mask Low\n" + "ecc injectecc <ecc> - set ECC Error Injection Mask\n" + "ecc inject <en|dis> - enable/disable error injection\n" + "ecc mirror <en|dis> - enable/disable mirror byte\n" + "ecc testdw <addr> <cnt> - test mem region with double word access:\n" + " - enables injects\n" + " - writes pattern injecting errors with double word access\n" + " - disables injects\n" + " - reads pattern back with double word access, generates error\n" + " - re-inits memory\n" + "ecc testword <addr> <cnt> - test mem region with word access:\n" + " - enables injects\n" + " - writes pattern injecting errors with word access\n" + " - writes pattern with word access, generates error\n" + " - disables injects\n" " - re-inits memory"); +#endif
Dave Liu
