[U-Boot] [PATCH 0/3] Support for SM502 on PCI bus
This patch series adds support for SM502 on ICON board.
Anatolij Gustschin (3): video: sm501: add support for SM501 chips on PCI bus video: sm501.c: add weak default functions ppc4xx: icon: add support for SM502 chip
board/mosaixtech/icon/icon.c | 69 +++++++++++++++++++++++++ drivers/video/sm501.c | 117 ++++++++++++++++++++++++++++++++++++++++-- include/configs/icon.h | 23 ++++++++ include/pci_ids.h | 1 + 4 files changed, 205 insertions(+), 5 deletions(-)
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/video/sm501.c | 89 ++++++++++++++++++++++++++++++++++++++++++++++--- include/pci_ids.h | 1 + 2 files changed, 85 insertions(+), 5 deletions(-)
diff --git a/drivers/video/sm501.c b/drivers/video/sm501.c index 283d2d9..544e0a0 100644 --- a/drivers/video/sm501.c +++ b/drivers/video/sm501.c @@ -31,6 +31,7 @@
#include <common.h>
+#include <asm/io.h> #include <video_fb.h> #include <sm501.h>
@@ -54,6 +55,18 @@
GraphicDevice sm501;
+void write_be32(int off, unsigned int val) +{ + out_be32((unsigned __iomem *)(sm501.isaBase + off), val); +} + +void write_le32(int off, unsigned int val) +{ + out_le32((unsigned __iomem *)(sm501.isaBase + off), val); +} + +void (*write_reg32)(int off, unsigned int val) = write_be32; + /*----------------------------------------------------------------------------- * SmiSetRegs -- *----------------------------------------------------------------------------- @@ -66,7 +79,7 @@ static void SmiSetRegs (void) */ const SMI_REGS *preg = board_get_regs (); while (preg->Index) { - write32 (preg->Index, preg->Value); + write_reg32 (preg->Index, preg->Value); /* * Insert a delay between */ @@ -75,26 +88,92 @@ static void SmiSetRegs (void) } }
+#ifdef CONFIG_VIDEO_SM501_PCI +static struct pci_device_id sm501_pci_tbl[] = { + { PCI_VENDOR_ID_SMI, PCI_DEVICE_ID_SMI_501 }, + {} +}; +#endif + /*----------------------------------------------------------------------------- * video_hw_init -- *----------------------------------------------------------------------------- */ void *video_hw_init (void) { +#ifdef CONFIG_VIDEO_SM501_PCI + unsigned int pci_mem_base, pci_mmio_base; + unsigned int id; + unsigned short device_id; + pci_dev_t devbusfn; + int mem; +#endif unsigned int *vm, i;
memset (&sm501, 0, sizeof (GraphicDevice));
+#ifdef CONFIG_VIDEO_SM501_PCI + printf("Video: "); + + /* Look for SM501/SM502 chips */ + devbusfn = pci_find_devices(sm501_pci_tbl, 0); + if (devbusfn < 0) { + printf ("PCI Controller not found.\n"); + goto not_pci; + } + + /* Setup */ + pci_write_config_dword (devbusfn, PCI_COMMAND, + (PCI_COMMAND_MEMORY | PCI_COMMAND_IO)); + pci_read_config_word (devbusfn, PCI_DEVICE_ID, &device_id); + pci_read_config_dword (devbusfn, PCI_REVISION_ID, &id); + pci_read_config_dword (devbusfn, PCI_BASE_ADDRESS_0, &pci_mem_base); + pci_read_config_dword (devbusfn, PCI_BASE_ADDRESS_1, &pci_mmio_base); + sm501.frameAdrs = pci_mem_to_phys (devbusfn, pci_mem_base); + sm501.isaBase = pci_mem_to_phys (devbusfn, pci_mmio_base); + + if (sm501.isaBase) + write_reg32 = write_le32; + + mem = in_le32 ((unsigned __iomem *)(sm501.isaBase + 0x10)); + mem = (mem & 0x0000e000) >> 13; + switch (mem) { + case 1: + mem = 8; + break; + case 2: + mem = 16; + break; + case 3: + mem = 32; + break; + case 4: + mem = 64; + break; + case 5: + mem = 2; + break; + case 0: + default: + mem = 4; + } + printf ("PCI SM50%d %d MB\n", ((id & 0xff) == 0xC0) ? 2 : 1, mem); +not_pci: +#endif /* * Initialization of the access to the graphic chipset Retreive base * address of the chipset (see board/RPXClassic/eccx.c) */ - if ((sm501.isaBase = board_video_init ()) == 0) { - return (NULL); + if (!sm501.isaBase) { + sm501.isaBase = board_video_init (); + if (!sm501.isaBase) + return NULL; }
- if ((sm501.frameAdrs = board_video_get_fb ()) == 0) { - return (NULL); + if (!sm501.frameAdrs) { + sm501.frameAdrs = board_video_get_fb (); + if (!sm501.frameAdrs) + return NULL; }
sm501.winSizeX = board_get_width (); diff --git a/include/pci_ids.h b/include/pci_ids.h index edfdc1e..dcc381d 100644 --- a/include/pci_ids.h +++ b/include/pci_ids.h @@ -1454,6 +1454,7 @@ #define PCI_DEVICE_ID_SMI_710 0x0710 #define PCI_DEVICE_ID_SMI_712 0x0712 #define PCI_DEVICE_ID_SMI_810 0x0810 +#define PCI_DEVICE_ID_SMI_501 0x0501
#define PCI_VENDOR_ID_HUGHES 0x1273 #define PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002
Applied to u-boot-video/next.
Anatolij
For boards using sm501/sm502 on PCI bus some driver functions normaly defined in the board code are not needed and empty. Provide weak default functions for them and do not enforce board code to define empty functions.
Signed-off-by: Anatolij Gustschin agust@denx.de --- drivers/video/sm501.c | 28 ++++++++++++++++++++++++++++ 1 files changed, 28 insertions(+), 0 deletions(-)
diff --git a/drivers/video/sm501.c b/drivers/video/sm501.c index 544e0a0..40606db 100644 --- a/drivers/video/sm501.c +++ b/drivers/video/sm501.c @@ -95,6 +95,34 @@ static struct pci_device_id sm501_pci_tbl[] = { }; #endif
+/* + * We do not enforce board code to provide empty/unused + * functions for this driver and define weak default + * functions here. + */ +unsigned int __board_video_init (void) +{ + return 0; +} + +unsigned int board_video_init (void) + __attribute__((weak, alias("__board_video_init"))); + +unsigned int __board_video_get_fb (void) +{ + return 0; +} + +unsigned int board_video_get_fb (void) + __attribute__((weak, alias("__board_video_get_fb"))); + +void __board_validate_screen (unsigned int base) +{ +} + +void board_validate_screen (unsigned int base) + __attribute__((weak, alias("__board_validate_screen"))); + /*----------------------------------------------------------------------------- * video_hw_init -- *-----------------------------------------------------------------------------
Anatolij
Adds initialization code for SM502 graphics controller and NL6448BC20-21D LCD panel.
Signed-off-by: Anatolij Gustschin agust@denx.de Cc: Stefan Roese sr@denx.de --- board/mosaixtech/icon/icon.c | 69 ++++++++++++++++++++++++++++++++++++++++++ include/configs/icon.h | 23 ++++++++++++++ 2 files changed, 92 insertions(+), 0 deletions(-)
diff --git a/board/mosaixtech/icon/icon.c b/board/mosaixtech/icon/icon.c index fbace9e..ecea1ee 100644 --- a/board/mosaixtech/icon/icon.c +++ b/board/mosaixtech/icon/icon.c @@ -317,3 +317,72 @@ int board_pcie_last(void) /* Only 2 PCIe ports used on ICON, so the last one is 1 */ return 1; } + +/* + * Video + */ +#ifdef CONFIG_VIDEO_SM501 +#include <sm501.h> + +#define DISPLAY_WIDTH 640 +#define DISPLAY_HEIGHT 480 + +static const SMI_REGS sm502_init_regs[] = { + {0x00004, 0x0}, + {0x00040, 0x00021847}, + {0x00044, 0x091a0a01}, /* 24 MHz pixclk */ + {0x00054, 0x0}, + {0x00048, 0x00021847}, + {0x0004C, 0x091a0a01}, + {0x00054, 0x1}, + {0x80004, 0xc428bb17}, + {0x8000C, 0x00000000}, + {0x80010, 0x0a000a00}, + {0x80014, 0x02800000}, + {0x80018, 0x01e00000}, + {0x8001C, 0x00000000}, + {0x80020, 0x01e00280}, + {0x80024, 0x02fa027f}, + {0x80028, 0x004a0280}, + {0x8002C, 0x020c01df}, + {0x80030, 0x000201e7}, + {0x80200, 0x00010000}, + {0x00008, 0x20000000}, /* gpio29 is pwm0, LED_PWM */ + {0x0000C, 0x3f000000}, /* gpio56 - gpio61 as flat panel data pins */ + {0x10020, 0x25725728}, /* 20 kHz pwm0, 50 % duty cycle, disabled */ + {0x80000, 0x0f010106}, /* vsync & hsync pos, disp on */ + {0, 0} +}; + +/* + * Return a pointer to the register initialization table. + */ +const SMI_REGS *board_get_regs(void) +{ + return sm502_init_regs; +} + +int board_get_width(void) +{ + return DISPLAY_WIDTH; +} + +int board_get_height(void) +{ + return DISPLAY_HEIGHT; +} + +#ifdef CONFIG_CONSOLE_EXTRA_INFO +/* + * Return text to be printed besides the logo. + */ +void video_get_info_str(int line_number, char *info) +{ + if (line_number == 1) + strcpy(info, " Board: ICON"); + else + info[0] = '\0'; +} +#endif + +#endif /* CONFIG_VIDEO_SM501 */ diff --git a/include/configs/icon.h b/include/configs/icon.h index 3a57d69..7a4e60c 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -143,6 +143,26 @@ #define CONFIG_SYS_M41T11_BASE_YEAR 1900 /* play along with linux */
/* + * Video options + */ +#define CONFIG_VIDEO + +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO_SM501 +#define CONFIG_VIDEO_SM501_32BPP +#define CONFIG_VIDEO_SM501_PCI +#define VIDEO_FB_LITTLE_ENDIAN +#define CONFIG_CFB_CONSOLE +#define CONFIG_VIDEO_LOGO +#define CONFIG_CONSOLE_EXTRA_INFO +#define CONFIG_VGA_AS_SINGLE_DEVICE +#define CONFIG_VIDEO_SW_CURSOR +#define CONFIG_VIDEO_BMP_RLE8 +#define CONFIG_SPLASH_SCREEN +#define CFG_CONSOLE_IS_IN_ENV +#endif + +/* * Environment */ #define CONFIG_ENV_IS_IN_FLASH 1 /* Environment uses flash */ @@ -171,6 +191,9 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SNTP +#ifdef CONFIG_VIDEO +#define CONFIG_CMD_BMP +#endif
#define CONFIG_IBM_EMAC4_V4 /* 440SPe has this EMAC version */ #define CONFIG_PHY_ADDR 1 /* PHY address, See schematics */
Dear Anatolij Gustschin,
As Stefan is on vacation, I jump in and apply this to "next".
Thanks.
Anatolij Gustschin
