[U-Boot] [PATCH 1/2] cfi_flash: Add manufact_match helper function
Consolidate manufacturer matching into the function manufact_match() and use it.
Signed-off-by: Stefan Roese sr@denx.de --- drivers/mtd/cfi_flash.c | 16 +++++++++------- 1 file changed, 9 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index b2dfc53..d865c40 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -1425,13 +1425,18 @@ int write_buff (flash_info_t * info, uchar * src, ulong addr, ulong cnt) return flash_write_cfiword (info, wp, cword); }
+static inline int manufact_match(flash_info_t *info, u32 manu) +{ + return info->manufacturer_id == ((manu & FLASH_VENDMASK) >> 16); +} + /*----------------------------------------------------------------------- */ #ifdef CONFIG_SYS_FLASH_PROTECTION
static int cfi_protect_bugfix(flash_info_t *info, long sector, int prot) { - if (info->manufacturer_id == ((INTEL_MANUFACT & FLASH_VENDMASK) >> 16) + if (manufact_match(info, INTEL_MANUFACT) && info->device_id == NUMONYX_256MBIT) { /* * see errata called @@ -1488,8 +1493,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) case CFI_CMDSET_AMD_EXTENDED: case CFI_CMDSET_AMD_STANDARD: /* U-Boot only checks the first byte */ - if (info->manufacturer_id == - ((ATM_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (manufact_match(info, ATM_MANUFACT)) { if (prot) { flash_unlock_seq (info, 0); flash_write_cmd (info, 0, @@ -1507,8 +1511,7 @@ int flash_real_protect (flash_info_t * info, long sector, int prot) 0, ATM_CMD_UNLOCK_SECT); } } - if (info->manufacturer_id == - ((AMD_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (manufact_match(info, AMD_MANUFACT)) { int flag = disable_interrupts(); int lock_flag;
@@ -1738,8 +1741,7 @@ static int cmdset_amd_init(flash_info_t *info, struct cfi_qry *qry) flash_write_cmd(info, 0, info->cfi_offset, FLASH_CMD_CFI);
#ifdef CONFIG_SYS_FLASH_PROTECTION - if (info->ext_addr && info->manufacturer_id == - ((AMD_MANUFACT & FLASH_VENDMASK) >> 16)) { + if (info->ext_addr && manufact_match(info, AMD_MANUFACT)) { ushort spus;
/* read sector protect/unprotect scheme */
Patch 66863b05 [cfi_flash: add support for Spansion flash PPB sector protection] introduced the PPB (Persistent Protection Bit) locking for Spansion chips. But right now the sector protection status (locked vs unlocked) is set to unlocked for all sectors upon bootup. The real sector protection status is ignored.
This patch now reads the current sector protection status and uses it for these AMD/Spansion flash chips.
Signed-off-by: Stefan Roese sr@denx.de Cc: Anatolij Gustschin agust@denx.de Cc: Holger Brunck holger.brunck@keymile.com --- drivers/mtd/cfi_flash.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index d865c40..b026815 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -2160,6 +2160,23 @@ ulong flash_get_size (phys_addr_t base, int banknum) FLASH_OFFSET_PROTECT, FLASH_STATUS_PROTECT); break; + case CFI_CMDSET_AMD_EXTENDED: + case CFI_CMDSET_AMD_STANDARD: + if (!manufact_match(info, AMD_MANUFACT)) { + /* default: not protected */ + info->protect[sect_cnt] = 0; + break; + } + + /* Read protection (PPB) from sector */ + flash_unlock_seq(info, 0); + flash_write_cmd(info, 0, info->addr_unlock1, + FLASH_CMD_READ_ID); + info->protect[sect_cnt] = + flash_isset(info, sect_cnt, + FLASH_OFFSET_PROTECT, + FLASH_STATUS_PROTECT); + break; default: /* default: not protected */ info->protect[sect_cnt] = 0;
Stefan Roese
