[U-Boot] uboot information
Hello,
Sorry for the inconvenience, i have problem for read mmc on my board with braswell cpu, i would like test on other board, i have nuc intel with braswell,is there possible when there is already bios to load uboot ?
else has any chance, I use coreboot + uboot, i would like run kernel on sdmmc, but i have an problem for communicate with sdcard. I read cid & reference of card but when try read SCR(version & bus width) of card, doesn't work . For read scr, it's first Transfer mode in SDMA .i had no error for read data but buffer is empty, why ?I use coreboot + uboot, i would like run kernel on sdmmc, but i have an problem for communicate with sdcard. I read cid & reference of card but when try read SCR(version & bus width) of card, doesn't work . For read scr, it's first Transfer mode in SDMA .i had no error for read data but buffer is empty, why ?
Sébastien Basset
+Bin
Hi Sebastian,
On 17 March 2017 at 11:23, Sébastien Basset sbasset@aviwest.com wrote:
Hello,
Just to be clear, are you running U-Boot on top of Coreboot?
Coreboot load uboot as payload.
Le 17 mars 2017 19:14, "Simon Glass" sjg@chromium.org a écrit :
+Bin
Hi Sebastian,
Hello,
Does the MMC work OK in coreboot?
It is possible to load U-Boot from UEFI if that helps?
- Simon
+Bin
Hi Sebastian,
Hello,
hi,
i see controller:
src/soc/intel/braswell/chip.c/enable_dev ( Intel Braswell SoC ), type: 2 vendor: 0x8086. device: 0x2296 class: 0x08 Generic system peripheral subclass: 0x05 SD Host controller prog: 0x01 revision: 0x35 src/soc/intel/braswell/southcluster.c/southcluster_enable_dev ( Intel Braswell SoC ) PCI: 00:12.0 [8086/2296] ops PCI: 00:12.0 [8086/2296] enabled
but i can't test sdcard in coreboot ...
i had intel back on this issue, on braswell 3160 version, it's not possible of boot on sdcard : It can be found on page 31 of the Braswell** Design In for The Internet of Things (IoT) document 555139.
it's very strange !!??
else i try to boot on usb:
I added node in dts file :
usb@14,0 { reg = <0x000a0000 0 0 0 0>; compatible = "xhci-pci"; };
is there another step for see controller with usb start command ?
Thank you for your information.
2017-03-22 14:05 GMT+01:00 Simon Glass sjg@chromium.org:
- Simon
+Bin
Hi Sebastian,
wrote:
Hello,
with
on
no
i
with
& bus
in
On 22 March 2017 at 08:20, Sébastien Basset sbasset@aviwest.com wrote:
hi,
i see controller:
I thought you said it was MMC...do you mean it is a USB controller with an USB->MMC device?
- Simon
+Bin
Hi Sebastian,
Hello,
1/ No, As i am stuck on the mmc (pci controller internal soc), 2/ Now i try to boot on usb key, but i don't see controller usb Sorry, these are two different problems.
2017-03-22 17:22 GMT+01:00 Simon Glass sjg@chromium.org:
hi,
i see controller:
Intel
possible
of
- Simon
+Bin
Hi Sebastian,
Hello,
board
intel
uboot ?
kernel
cid
card,
had
uboot,
communicate
SCR(version
mode
It is better to post at the bottom that the top, for mailing lists.
I think PCI XHCI has some problems. I'm not sure of its status.
MMC seems to work well on Minnowboard Max (baytrail) but I am not sure about braswell. Is it perhaps a slightly different chip?
hi,
i see controller:
- Simon
+Bin
Hi Sebastian,
On 17 March 2017 at 11:23, Sébastien Basset sbasset@aviwest.com wrote: > > Hello, > > Sorry for the inconvenience, i have problem for read mmc on my > board > with braswell cpu, i would like test on other board, i have nuc > intel > with > braswell,is there possible when there is already bios to load > uboot ? > > else has any chance, I use coreboot + uboot, i would like run > kernel > on > sdmmc, but i have an problem for communicate with sdcard. I read > cid > & > reference of card but when try read SCR(version & bus width) of > card, > doesn't work . For read scr, it's first Transfer mode in SDMA .i > had > no > error for read data but buffer is empty, why ?I use coreboot + > uboot, > i > would like run kernel on sdmmc, but i have an problem for > communicate > with > sdcard. I read cid & reference of card but when try read > SCR(version > & bus > width) of card, doesn't work . For read scr, it's first Transfer > mode > in > SDMA .i had no error for read data but buffer is empty, why ?
2017-03-23 3:19 GMT+01:00 Simon Glass sjg@chromium.org:
For PCI XHCI, i see controller usb and root hub, but cannot reset port:
portstatus 711, change 0, 5 Gb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0 portstatus 711, change 10, 5 Gb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0 portstatus 711, change 10, 5 Gb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0 portstatus 711, change 10, 5 Gb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0 portstatus 711, change 10, 5 Gb/s STAT_C_CONNECTION = 0 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0 Cannot enable port 10 after 5 retries, disabling port. Maybe the USB cable is bad? cannot reset port 10!?
do you have an idea,why reset port is break down ?
For MMC, braswell n3160 is dedicated for embedded iot, maybe for security.
No I am not sure. It could possibly be a driver problem, or perhaps the port is not enabled in the FSP config?
Do you mean that you cannot use MMC on this chip?
Sébastien Basset
